    3. Off Topic
    4. Magic Mirror zusammen mit IOBroker
    • Kusselin
      Kusselin @Thomas Braun last edited by
      @thomas-braun schau thomas
      pi@MagicMirror-live:~/MagicMirror$ node -v
      v16.20.2
      pi@MagicMirror-live:~/MagicMirror$ npm -v
      8.19.4
      pi@MagicMirror-live:~/MagicMirror$ sudo apt update
      [sudo] password for pi:
      Sorry, try again.
      OK:1 https://deb.nodesource.com/node_16.x jammy InRelease
      OK:2 http://archive.ubuntu.com/ubuntu jammy InRelease
      Holen:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [128 kB]
      Holen:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease [129 kB]
      Holen:5 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages [1.941 kB]
      Holen:6 http://archive.ubuntu.com/ubuntu jammy-updates/main Translation-en [343 kB]
      Holen:7 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 c-n-f Metadata [17,7 kB]
      Holen:8 http://archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 Packages [2.314 kB]
      Holen:9 http://archive.ubuntu.com/ubuntu jammy-updates/restricted Translation-en [397 kB]
      Holen:10 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages [1.110 kB]
      Holen:11 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 c-n-f Metadata [25,9 kB]
      Holen:12 http://archive.ubuntu.com/ubuntu jammy-updates/multiverse amd64 Packages [43,3 kB]
      Holen:13 http://archive.ubuntu.com/ubuntu jammy-updates/multiverse amd64 c-n-f Metadata [444 B]
      Holen:14 http://archive.ubuntu.com/ubuntu jammy-security/main amd64 Packages [1.712 kB]
      Holen:15 http://archive.ubuntu.com/ubuntu jammy-security/main Translation-en [283 kB]
      Holen:16 http://archive.ubuntu.com/ubuntu jammy-security/main amd64 c-n-f Metadata [13,1 kB]
      Holen:17 http://archive.ubuntu.com/ubuntu jammy-security/restricted amd64 Packages [2.226 kB]
      Holen:18 http://archive.ubuntu.com/ubuntu jammy-security/restricted Translation-en [383 kB]
      Holen:19 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages [888 kB]
      Holen:20 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 c-n-f Metadata [19,0 kB]
      Es wurden 12,0 MB in 4 s geholt (3.270 kB/s).
      Paketlisten werden gelesen… Fertig
      Abhängigkeitsbaum wird aufgebaut… Fertig
      Statusinformationen werden eingelesen… Fertig
      Aktualisierung für 7 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
      pi@MagicMirror-live:~/MagicMirror$ apt policy nodejs
      nodejs:
        Installiert:           16.20.2-deb-1nodesource1
        Installationskandidat: 16.20.2-deb-1nodesource1
        Versionstabelle:
       *** 16.20.2-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x jammy/main amd64 Packages
              100 /var/lib/dpkg/status
           12.22.9~dfsg-1ubuntu3.6 500
              500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
              500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
           12.22.9~dfsg-1ubuntu3 500
              500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
        Thomas Braun Most Active @Kusselin last edited by
        @kusselin
        Ich vermute, da läuft kein ioBroker auf der Kiste, oder?
        Dann musst du das nodesource-Repo 'von Hand' auf den aktuellen Stand bringen.
        sudo rm /etc/apt/sources.list.d/node*
        curl -fsSL https://deb.nodesource.com/setup_20.x -o nodesource_setup.sh
        bash nodesource_setup.sh
        sudo apt update
        sudo apt install nodejs
        Kusselin 2 Replies Last reply Reply Quote 0
        • Kusselin
          @thomas-braun nee da läuft kein iobroker..ist reiner lxc für magicmirror..dann so wie du vorgegeben hast updaten ok?
          • Kusselin
            @thomas-braun ergebnis deiner codes jetzt
            pi@MagicMirror-live:~/MagicMirror$ npm run server
            > magicmirror@2.27.0 server
            > node ./serveronly
            [2024-08-09 11:18:05.959] [LOG]   Starting MagicMirror: v2.27.0
            [2024-08-09 11:18:05.970] [LOG]   Loading config ...
            [2024-08-09 11:18:05.972] [LOG]   config template file not exists, no envsubst
            [2024-08-09 11:18:06.407] [LOG]   Loading module helpers ...
            [2024-08-09 11:18:06.408] [LOG]   No helper found for module: alert.
            [2024-08-09 11:18:06.568] [LOG]   Initializing new module helper ...
            [2024-08-09 11:18:06.569] [LOG]   Module helper loaded: updatenotification
            [2024-08-09 11:18:06.569] [LOG]   No helper found for module: clock.
            [2024-08-09 11:18:06.643] [LOG]   Initializing new module helper ...
            [2024-08-09 11:18:06.644] [LOG]   Module helper loaded: calendar
            [2024-08-09 11:18:06.644] [LOG]   No helper found for module: weather.
            [2024-08-09 11:18:06.706] [LOG]   Initializing new module helper ...
            [2024-08-09 11:18:06.706] [LOG]   Module helper loaded: MMM-Remote-Control
            [2024-08-09 11:18:06.707] [LOG]   No helper found for module: compliments.
            [2024-08-09 11:18:06.765] [LOG]   Initializing new module helper ...
            [2024-08-09 11:18:06.765] [LOG]   Module helper loaded: newsfeed
            [2024-08-09 11:18:06.775] [LOG]   Initializing new module helper ...
            [2024-08-09 11:18:06.775] [LOG]   Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.27.0
            [2024-08-09 11:18:06.776] [LOG]   Version is ok!
            [2024-08-09 11:18:06.776] [LOG]   Module helper loaded: MMM-Fuel
            [2024-08-09 11:18:06.786] [LOG]   Initializing new module helper ...
            [2024-08-09 11:18:06.787] [LOG]   Module helper loaded: MMM-PublicTransportHafas
            [2024-08-09 11:18:07.089] [LOG]   Initializing new module helper ...
            [2024-08-09 11:18:07.089] [LOG]   Module helper loaded: MMM-RNV
            [2024-08-09 11:18:07.090] [LOG]   Initializing new module helper ...
            [2024-08-09 11:18:07.090] [LOG]   Module helper loaded: MMM-ioBroker
            [2024-08-09 11:18:07.123] [LOG]   Initializing new module helper ...
            [2024-08-09 11:18:07.123] [LOG]   Module helper loaded: MMM-COVID19-AMPEL
            [2024-08-09 11:18:07.125] [LOG]   Initializing new module helper ...
            [2024-08-09 11:18:07.126] [LOG]   Module helper loaded: MMM-SoccerLiveScore
            [2024-08-09 11:18:07.129] [ERROR] Whoops! There was an uncaught exception...
            [2024-08-09 11:18:07.133] [ERROR] Error: Cannot find module 'node-fetch'
            Require stack:
            - /home/pi/MagicMirror/modules/MMM-Tankerkoenig/node_helper.js
            - /home/pi/MagicMirror/js/app.js
            - /home/pi/MagicMirror/serveronly/index.js
                at Module._resolveFilename (node:internal/modules/cjs/loader:1145:15)
                at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                at Module._load (node:internal/modules/cjs/loader:986:27)
                at Module.require (node:internal/modules/cjs/loader:1233:19)
                at require (node:internal/modules/helpers:179:18)
                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Tankerkoenig/node_helper.js:8:15)
                at Module._compile (node:internal/modules/cjs/loader:1358:14)
                at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                at Module.load (node:internal/modules/cjs/loader:1208:32)
                at Module._load (node:internal/modules/cjs/loader:1024:12)
                at loadModule (/home/pi/MagicMirror/js/app.js:183:19)
                at loadModules (/home/pi/MagicMirror/js/app.js:213:10)
                at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                at async App.start (/home/pi/MagicMirror/js/app.js:261:3) {
              code: 'MODULE_NOT_FOUND',
              requireStack: [
                '/home/pi/MagicMirror/modules/MMM-Tankerkoenig/node_helper.js',
                '/home/pi/MagicMirror/js/app.js',
                '/home/pi/MagicMirror/serveronly/index.js'
            [2024-08-09 11:18:07.133] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [2024-08-09 11:18:07.133] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
            [2024-08-09 11:18:07.219] [INFO]  System information:
            ### SYSTEM:   manufacturer: ; model: ; raspberry: undefined; virtual: false
            ### OS:       platform: linux; distro: Ubuntu; release: 22.04.4 LTS; arch: x64; kernel: 6.5.13-3-pve
            ### VERSIONS: electron: undefined; used node: 20.16.0; installed node: 20.16.0; npm: 10.8.1; pm2:
            ### OTHER:    timeZone: UTC; ELECTRON_ENABLE_GPU: undefined
              @kusselin
              Also läuft das nun in der aktuellen nodejs-Umgebung.
              Fein.
              Zur Konfiguration des ganzen kann ich dir nix raten, da musst du mal auf der Seite von magicmirror schauen.
              Kusselin 1 Reply Last reply Reply Quote 0
              • Kusselin
                @thomas-braun o.k. laufen tut er in der aktuellen umgebung aber ich kann ihn nicht aufrufen...
                am besten wirds sein das ich die config sichere udn den container neu aufsetze mit aktuellem Ubuntu system...
                ist das O.K.?
                  @kusselin
                  Und was soll das bringen?
                  Den MagicMirror musst du auch in einem anderen System richtig konfigurieren.
                  • Kusselin
                    @thomas-braun war jetzt nur ne Frage.....
                    lt. der consolenausgabe läuft der MM aber die Module laufen nicht...kannst du das auch herauslesen?
                    • Kusselin
                      Kusselin @mrjeschke last edited by Kusselin
                      @mrjeschke Hi, ich habe jetzt mal ein bisschen probiert und neu installiert.. ich habe ja den MM in einem Container udn auch gesichert...wenn ich diesen wieder aufspiele dann geht er ist aber nicht aktuell...aber man kann ja auch probieren....also was habe ich gemacht..
                      1. Neuen ConLXC Container angelegt
                      2. Ubuntu 24 LTS installiert
                      3. apt-get update && apt-get upgrade -y ausgeführt
                      4. neuen User "MM" angelegt mit useradd -s /bin/bash -m MM
                      5. passwort für MM vergeben
                      6. den Neuen User der Gruppe "sudo" zugeführt mit sudo usermod -a -G sudo MM
                      7. reboot
                      8. angemeldet mit MM uns pass
                      9. dann folegenden Befehl ausgeführt:
                      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                      1. nach Installation folegenden weiteren Befehl ausgeführt:
                      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                      1. dann cd eingegeben und ich stehe auf
                      mm@MagicMirror-live:~$
                      1. dann nano mm.sh eingegeben und fiolgendes dort eingefügt:
                      cd ~/MagicMirror
                      npm run server
                      • Dann die Datei ausfürbargemacht mit
                      chmod +r ~/mm.sh
                      1. dann crontab -e eingebgeben und 1 gewählt dann dort das ganz unten als letztes eingegeben:
                      @reboot /home/pi/mm.sh
                      1. dann raus und reboot gemacht....
                        15.sicherheitshalber ins verzeichnis /MagicMirror gegangen udn npm run server ausgeführt..
                      2. dann kommt das raus:
                      mm@MagicMirror-live:~/MagicMirror$ npm run server
                      > magicmirror@2.28.0 server
                      > node ./serveronly
                      [2024-08-10 16:51:17.974] [LOG]   Starting MagicMirror: v2.28.0
                      [2024-08-10 16:51:17.986] [LOG]   Loading config ...
                      [2024-08-10 16:51:17.989] [LOG]   config template file not exists, no envsubst
                      [2024-08-10 16:51:18.334] [LOG]   Loading module helpers ...
                      [2024-08-10 16:51:18.335] [LOG]   No helper found for module: alert.
                      [2024-08-10 16:51:18.343] [LOG]   Initializing new module helper ...
                      [2024-08-10 16:51:18.344] [LOG]   Module helper loaded: updatenotification
                      [2024-08-10 16:51:18.344] [LOG]   No helper found for module: clock.
                      [2024-08-10 16:51:18.561] [LOG]   Initializing new module helper ...
                      [2024-08-10 16:51:18.563] [LOG]   Module helper loaded: calendar
                      [2024-08-10 16:51:18.565] [LOG]   No helper found for module: compliments.
                      [2024-08-10 16:51:18.567] [LOG]   No helper found for module: weather.
                      [2024-08-10 16:51:18.568] [LOG]   No helper found for module: weather.
                      [2024-08-10 16:51:18.717] [LOG]   Initializing new module helper ...
                      [2024-08-10 16:51:18.717] [LOG]   Module helper loaded: newsfeed
                      [2024-08-10 16:51:18.718] [LOG]   All module helpers loaded.
                      [2024-08-10 16:51:18.724] [LOG]   Starting server on port 8080 ...
                      [2024-08-10 16:51:18.746] [LOG]   Server started ...
                      [2024-08-10 16:51:18.747] [LOG]   Connecting socket for: updatenotification
                      [2024-08-10 16:51:18.747] [LOG]   Starting module helper: updatenotification
                      [2024-08-10 16:51:18.748] [LOG]   Connecting socket for: calendar
                      [2024-08-10 16:51:18.748] [LOG]   Starting node helper for: calendar
                      [2024-08-10 16:51:18.748] [LOG]   Connecting socket for: newsfeed
                      [2024-08-10 16:51:18.748] [LOG]   Starting node helper for: newsfeed
                      [2024-08-10 16:51:18.749] [LOG]   Sockets connected & modules started ...
                      [2024-08-10 16:51:18.749] [INFO]
                      >>>   Ready to go! Please point your browser to: http://localhost:8080   <<<
                      [2024-08-10 16:51:18.871] [INFO]  System information:
                      ### OS:       platform: linux; distro: Ubuntu; release: 24.04 LTS; arch: x64; kernel: 6.5.13-3-pve
                      ### VERSIONS: electron: undefined; used node: 20.9.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.2
                      ^C[2024-08-10 16:51:29.977] [LOG]   [SIGINT] Received. Shutting down server...
                      [2024-08-10 16:51:29.977] [LOG]   Stopping module helper: updatenotification
                      [2024-08-10 16:51:29.977] [LOG]   Stopping module helper: calendar
                      [2024-08-10 16:51:29.977] [LOG]   Stopping module helper: newsfeed
                      [2024-08-10 16:51:29.978] [LOG]   Node_helpers stopped ...
                      whats that 😞
                      Er fährt den Server wieder runter.. 😞 wieso ?
                      Bin ich wieder falsch vorgegangen?????
                      Danke und Gruss
                      Thomas Braun M 2 Replies Last reply Reply Quote 0
                        @kusselin sagte in Magic Mirror zusammen mit IOBroker:
                        Wozu? Der User soll natürlich keine root-Rechte erhalten können.
                          mrjeschke @Kusselin last edited by
                          @kusselin
                          Ich musste das ganze WE arbeiten. Darum konnte ich es mir erst jetzt ansehen.
                          Der Server ist runtergefahren weil du Strg-C gedrückt hast (vermute ich)
                          Das ist ja nur zum Test ob es überhaupt läuft.
                          Den Autostart muss du anpassen da du den usernamen geändert hast.
                          Im crontab musst du den username (pi) durch den neuen usernamen (MM) ersetzen.
                          Den Autostart auf systemd zu ändern wäre sicher besser.
                          Mit der Konfiguration wirst du aber keine Verbindung bekommen.
                          Dazu muss noch die config.js angepasst werden da der Server sonst nur aus localhost reagiert.
                          address: "0.0.0.0",
                          ipWhitelist: [],
                          • Kusselin
                            @thomas-braun sagte in Magic Mirror zusammen mit IOBroker:
                            Doch, ich muss den neuen user der Gruppo sudo (in der /etc/sodoer) zuordnen, sonst kann ich unter dem neuen User MM nicht installieren (Beschreibung).
                            • Kusselin
                              @mrjeschke sagte in Magic Mirror zusammen mit IOBroker:
                              @kusselin
                              Oh mann....stimmt das kann sein..weil ich dann wieder auf dem "Prompt" stand...also mm@....
                              Heisst für mich...nach dem starten vom "npm run server" nichts mehr machen....richtig?
                              Wenn ich dann aber mal zb. den Container neu starten muss, dann greift der Cron richtig?
                              Ne Frage zum Cron habe ich auch noch....wenn ich mit dem User "MM" angemeldet bin und mache dann ein "CD" dann, dann steht da ja in putty zb. mm@magicmirror-live..
                              Heisst das jetzt das ich von hier ab dann im home-verzeichnis von user mm bin, also das ich dann hier das "nano mm.sh" machen kann? oder muss ich da dann erst noch nach cd home navigieren..? das hab ich noch nicht so verstanden udn es wäre nett wenn ihr mir das noch erklären könnt. Danke
                              @kusselin
                              O.K. ist auch verständlich habe ich auch nicht gemacht....danke
                              Du meinst mit systemd, richtig? nicht Cron.
                              @kusselin
                              Sorry, das ist natürlich bei so einem Wetter auch nicht gerade angenehm. Danke für Deine Unterstützung.
                              Aber hätte der MM nicht bei
                              wenn ich die IP:8080 eingebe im Browser erscheinen müssen? bevor ich CTRL+c gedrückt habe?
                              Das ist er nämlich auch nicht.....also aufgegangen im Browser.
                              Ich probiers nochmal.....
                              Ach und nochwas...ich kann ja jetzt die alte config.js speichern....kann ich diese dann 1:1 in die neue Installation übernehmen? (Ich muss natürlich unter modules die Module installiert haben. Geht das ?
                              Aber soweit bin ich schon korrekt vorgegangen vom Ablauf oder?
                                @kusselin
                                Ja richtig. Gehe mit cd in das home-Verzeichnis
                                Mit
                                nano mm.sh
                                die Datei öffnen und Inhalt reinkopieren
                                cd ~/MagicMirror
                                npm run Server
                                speichern + beenden und ausführbar machen
                                chmod +x mm.sh
                                Dann
                                crontab -e
                                den username korrigieren
                                dann kannst du dein alte config.js in das config-Verzeichnis kopieren und den Container neu starten
                                Dann sollte alles wieder laufen. Den Befehl npm run server brauchst du dann nicht mehr.
                                Der war nur zum Test ob die Sofware läuft.
                                • Kusselin
                                  @mrjeschke ich probiers und melde mich.
                                  ne Frage noch zu /home....ich komme da aber auch rein indem ich cd /home schreibe...du sagst aber ich solle dann erstmal cd machen....bin ich dann wirklich auch im home verzeichnis von user mm?
                                    @kusselin
                                    Wenn du cd eingibst kommst du in das home-Vereichnis des angemeldeten users.
                                    Wenn du cd /home eingibst landest du ein Verzeichnis höher.
                                    Also das Verzeichnis in dem sich die Verzeichisse aller user sind.
                                    Probier es aus. Mit pwd zeigt er dir dein aktuelles Vezeichnis an.
                                    cd
                                    pwd
                                    cd /home
                                    pwd
                                    Kusselin 1 Reply Last reply Reply Quote 2
                                    • Kusselin
                                      @kusselin
                                      cd
                                      pwd
                                      cd /home
                                      pwd
                                      ahh ok...mit cd und user mm bzw. pi komme ich in das jeweilige "Home-verzeichnis" des entsprechenden Users.
                                      Mit cd /home komme ich generell in das "Home-Verzeichnis" unabhängig vom User richtig verstanden?
                                        Mit cd /pfad/irgendwohin (steht für Change Directory) wechselst du in das angegebene Verzeichnis.
                                        Mit cd ohne weitere Angaben springst du immer sofort in das /home des Users, mit dem du eingeloggt bist.
                                        MIt cd - springst du in das vorherige Verzeichnis zurück.
                                        Kusselin 1 Reply Last reply Reply Quote 1
                                        • Kusselin
                                          o.k. danke Thomas...so ist es natürlich ausfürlich erklärt...aber so wie ichs oben geschrieben habe, passt es doch auch einfach ja oder nein?
                                          • Kusselin
                                            @kusselin
                                            Mit
                                            nano mm.sh
                                            cd ~/MagicMirror
                                            npm run Server
                                            chmod +x mm.sh
                                            Dann
                                            crontab -e
                                            Habs eben nochmal probiert mit dem Befehl:
                                            es kam dann noch die Meldung bei der Installation ob ich den Screensaver disablen will...habe da ja gesagt...
                                            und dann kommt noch die Meldung ob ich pm2 autostarting will? was mach ich da? yes oder?
                                            magic mirror
                                            24
                                            224
                                            41946
