    3. Off Topic
    4. Microcontroller
    5. Erfahrung SuperMini ESP32 C3 Bluetooth, Tasmota etc. ?
      Dieter_P @Ralla66 last edited by
      @ralla66
      Bisher leider nein. Es kommt mir so vor als ob der iBeacon Treiber/paket nicht aktiv wäre.
      Die Ausgaben in der Konsole sollten von tele/ibeacon/sensor kommen.
      Ich sehe bisher nur tele/tasmota.../BLE
      08:56:26.964 MQT: tele/tasmota_CD3740/BLE = {"Time":"2024-08-12T08:56:26","BLEDevices":{"total":1,"3ACA849830BA":{"i":0,"r":-97}}}
      08:56:26.968 MQT: tele/tasmota_CD3740/BLE = {"Time":"2024-08-12T08:56:26","BLE":{"scans":60,"adverts":13828,"devices":1,"resets":0}}
        Dieter_P @Dieter_P last edited by Dieter_P
        @dieter_p
        oja, wie ich diese Tasmota Doku liebe ... dass man das Feature aktivieren muß steht nirgends... aber nun läufts 🙂
        09:08:01.843 CMD: IBEACON 1
        09:08:01.850 MQT: stat/tasmota_CD3740/RESULT = {"IBEACON":1}
        09:08:03.648 MQT: tele/tasmota_CD3740/SENSOR = {"Time":"2024-08-12T09:08:03","IBEACON":{"MAC":"3ACA849830BA","RSSI":-99,"STATE":"ON","PERSEC":0}}
        09:08:18.041 MQT: tele/tasmota_CD3740/SENSOR = {"Time":"2024-08-12T09:08:18","IBEACON":{"MAC":"3ACA849830BA","RSSI":-100,"STATE":"ON","PERSEC":0}}
        09:08:28.768 MQT: tele/tasmota_CD3740/SENSOR = {"Time":"2024-08-12T09:08:28","IBEACON":{"MAC":"3ACA849830BA","RSSI":-96,"STATE":"ON","PERSEC":0}}
        09:08:38.499 MQT: tele/tasmota_CD3740/SENSOR = {"Time":"2024-08-12T09:08:38","IBEACON":{"MAC":"3ACA849830BA","RSSI":-98,"STATE":"ON","PERSEC":1}}
        09:08:45.883 MQT: tele/tasmota_CD3740/SENSOR = {"Time":"2024-08-12T09:08:45","IBEACON":{"MAC":"3ACA849830BA","RSSI":-97,"STATE":"ON","PERSEC":1}}
        09:08:55.194 MQT: tele/tasmota_CD3740/SENSOR = {"Time":"2024-08-12T09:08:55","IBEACON":{"MAC":"3ACA849830BA","RSSI":-97,"STATE":"ON","PERSEC":1}}
        Und auch die Scanintervalle erscheinen jetzt schnell genug
        Jetzt nur nochmal testen, ob ich den Xiaomi BLE "Kram" deaktiviert bekomme.
        Ralla66 1 Reply Last reply Reply Quote 0
        • Ralla66
          Ralla66 Most Active @Dieter_P last edited by Ralla66
          @dieter_p sagte in Erfahrung SuperMini ESP32 C3 Bluetooth, Tasmota etc. ?:
          wie denn, per Konsole ?
          edit:
          erledtigt mit lesen 🙂
            @ralla66
            Danke für den Hinweis. Kann ja nicht "meckern" und selbst eher kryptisch bleiben.
            Die Funktion lässt sich per Konsole mit
            IBEACON 1
            aktivieren. Bisherige versuche Bluettoth bzw. die MI Funktion zu deaktivieren mit
            MI32 0
            oder
            MI 0
            wirkten sich dann auch auf die IBEACON Funktion aus. Bleibt es eben an 🙂
            • Ralla66
              @dieter_p
              eventuell mit Alias und BLE Adress Fllter
                @ralla66
                Mmmh, die IBEACON Funktion ist nachdem Neustart wieder deaktiviert und darum wollte ich die Beispielregel mal testen:
                Rule1 ON System#Boot DO backlog iBeacon 1; BLEAlias A4C1386A1E24=iBfred A4C1387FC1E1=iBjames; iBeaconOnlyAliased 2 endon
                Rule1 1
                https://tasmota.github.io/docs/Bluetooth_ESP32/#ibeacon-mqtt-fields
                Regeln und Skript zusammen zu kompilieren geht nicht, also ohne Skript 😞
                Ralla66 1 Reply Last reply Reply Quote 1
                • Ralla66
                  @dieter_p
                  wenn es per Rule geht reicht das ja, mit scripting kannst du halt mehr Unsinn machen.
                  Wenn Anwesenheit ist on oder off dann mache BlaBla.........
                  Rules ist Glaube ich max 4 mal.
                    @ralla66
                    Mööp und schon hab ich mir mit meinem HW-Aufbau ein Ei gelegt. Der C3 ist mitlerweile in ein kleines Gehäuse gewandert und die USB-Buchse dient nur der Stromversorgung. An die USB Buchse des Chip komme ich so einfach nicht ran.
                    Kennst Du einen Weg die Selbstkompilierte bin per OTA auf den Chip zu laden? Da ging doch was. Erst die Minimal-Version flashen und dann die eigene Factory hinterher, oder?
                    • Ralla66
                      so läufts bei mir, mach aber vorher ne Sicherung in Tasmota
                        @ralla66
                        Danke Dir. Nun funktioniert auch die Regel (inkl. Alias) und die Infos zum Beacon kommen per MqTT.
                        Feine Sache 🙂
                        bluetooth esp32c3 esphome tasmota
                        2376
