    4. {gelöst} Maxcul Adapter veraltet, bitte aktualisieren.
    • ESP8266
      ESP8266 last edited by ESP8266
      @thomas-braun , so sieht es seit 12:44 aus
      logparser.0
      	1689	2024-07-28 12:44:58.899	info	starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.logparser, node: v20.16.0, js-controller: 6.0.9
      host.iobroker
      		2024-07-28 12:44:56.014	warn	Do not restart adapter system.adapter.maxcul.0 because restart loop detected
      host.iobroker
      		2024-07-28 12:44:56.013	error	instance system.adapter.maxcul.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.iobroker
      		2024-07-28 12:44:56.012	error	Caught by controller[0]: Cannot load serialport module
      maxcul.0
      	1636	2024-07-28 12:44:55.262	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      maxcul.0
      	1636	2024-07-28 12:44:55.247	error	Exception-Code: ERR_DLOPEN_FAILED: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'.
      maxcul.0
      	1636	2024-07-28 12:44:55.244	error	Error: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'. at Module._extensions..node (node:internal/modules/cjs/loader:1454:18) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
      maxcul.0
      	1636	2024-07-28 12:44:55.238	error	uncaught exception: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node
      und es hat sich nichts weiter getan.
      Das war schon der 2. Versuch.
      Der erste sah so aus:
      host.iobroker
      		2024-07-28 12:23:55.288	warn	Do not restart adapter system.adapter.maxcul.0 because restart loop detected
      host.iobroker
      		2024-07-28 12:23:55.288	error	instance system.adapter.maxcul.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.iobroker
      		2024-07-28 12:23:55.287	error	Caught by controller[0]: Cannot load serialport module
      maxcul.0
      	289114	2024-07-28 12:23:54.644	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      maxcul.0
      	289114	2024-07-28 12:23:54.635	error	Exception-Code: ERR_DLOPEN_FAILED: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'.
      maxcul.0
      	289114	2024-07-28 12:23:54.633	error	Error: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'. at Module._extensions..node (node:internal/modules/cjs/loader:1454:18) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
      maxcul.0
      	289114	2024-07-28 12:23:54.629	error	uncaught exception: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'.
      host.iobroker
      		2024-07-28 12:23:20.908	error	instance system.adapter.maxcul.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.iobroker
      		2024-07-28 12:23:20.903	error	Caught by controller[0]: Cannot load serialport module
      maxcul.0
      	289047	2024-07-28 12:23:20.236	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      maxcul.0
      	289047	2024-07-28 12:23:20.224	error	Exception-Code: ERR_DLOPEN_FAILED: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'.
      maxcul.0
      	289047	2024-07-28 12:23:20.222	error	Error: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'. at Module._extensions..node (node:internal/modules/cjs/loader:1454:18) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
      maxcul.0
      	289047	2024-07-28 12:23:20.217	error	uncaught exception: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'.
      host.iobroker
      		2024-07-28 12:22:43.996	error	instance system.adapter.maxcul.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.iobroker
      		2024-07-28 12:22:43.989	error	Caught by controller[0]: Cannot load serialport module
      maxcul.0
      	288903	2024-07-28 12:22:43.133	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      maxcul.0
      	288903	2024-07-28 12:22:43.105	error	Exception-Code: ERR_DLOPEN_FAILED: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'.
      maxcul.0
      	288903	2024-07-28 12:22:43.098	error	Error: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'. at Module._extensions..node (node:internal/modules/cjs/loader:1454:18) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10) at Module.load (node:internal/modules/cjs/loader:1208:32) at Module._load (node:internal/modules/cjs/loader:1024:12) at Module.require (node:internal/modules/cjs/loader:1233:19) at require (node:internal/modules/helpers:179:18) at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/index.js:14:22) at Module._compile (node:internal/modules/cjs/loader:1358:14) at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
      maxcul.0
      	288903	2024-07-28 12:22:43.087	error	uncaught exception: Module did not self-register: '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node
        Thomas Braun Most Active @ESP8266 last edited by Thomas Braun
        @esp8266 sagte in Maxcul Adapter veraltet, bitte aktualisieren.:
        Dann knall den nochmal rein:
        iob upgrade maxcul@1.3.1 --debug
        Der Rebuild schaut dann auf meiner Kiste so aus:
        echad@chet:~ $ iob upgrade iobroker.maxcul@1.3.1 --debug
        Would you like to reinstall version 1.3.1 of maxcul now? [(y)es, (n)o]: y
        Update maxcul from @1.3.1 to @1.3.1
        Uninstall npm packet "iobroker.maxcul" for a clean re-installation
        removed 41 packages in 8s
        191 packages are looking for funding
          run `npm fund` for details
        NPM version: 10.8.2
        Installing iobroker.maxcul@1.3.1... (System call)
        > @serialport/bindings@9.2.8 install
        > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
        prebuild-install warn install No prebuilt binaries found (target=22.5.1 runtime=node arch=arm64 libc= platform=linux)
        gyp info it worked if it ends with ok
        gyp info using node-gyp@10.1.0
        gyp info using node@22.5.1 | linux | arm64
        gyp info find Python using Python version 3.12.4 found at "/usr/bin/python3"
        gyp info spawn /usr/bin/python3
        gyp info spawn args [
        gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
        gyp info spawn args 'binding.gyp',
        gyp info spawn args '-f',
        gyp info spawn args 'make',
        gyp info spawn args '-I',
        gyp info spawn args '/opt/iobroker/node_modules/@serialport/bindings/build/config.gypi',
        gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',
        gyp info spawn args '/home/iobroker/.cache/node-gyp/22.5.1/include/node/common.gypi',
        gyp info spawn args '-Dlibrary=shared_library',
        gyp info spawn args '-Dvisibility=default',
        gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.5.1',
        gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
        gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.5.1/<(target_arch)/node.lib',
        gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/@serialport/bindings',
        gyp info spawn args '-Dnode_engine=v8',
        gyp info spawn args '--depth=.',
        gyp info spawn args '--no-parallel',
        gyp info spawn args '--generator-output',
        gyp info spawn args 'build',
        gyp info spawn args '-Goutput_dir=.'
        gyp info spawn args ]
        gyp info spawn make
        gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
        make: Entering directory '/opt/iobroker/node_modules/@serialport/bindings/build'
          CXX(target) Release/obj.target/bindings/src/serialport.o
        In file included from /home/iobroker/.cache/node-gyp/22.5.1/include/node/v8-array-buffer.h:12,
                         from /home/iobroker/.cache/node-gyp/22.5.1/include/node/v8.h:24,
                         from /home/iobroker/.cache/node-gyp/22.5.1/include/node/node.h:73,
                         from ../../../nan/nan.h:62,
                         from ../src/./serialport.h:13,
                         from ../src/serialport.cpp:1:
        /home/iobroker/.cache/node-gyp/22.5.1/include/node/v8-local-handle.h:401:30: warning: template-id not allowed for constructor in C++20 [-Wtemplate-id-cdtor]
          401 |   V8_INLINE explicit Local<T>(const LocalBase<T>& other)
        /home/iobroker/.cache/node-gyp/22.5.1/include/node/v8-local-handle.h:401:30: note: remove the ‘< >’
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           78 |   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
          135 |   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
          175 |   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
          215 |   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:271:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
          271 |   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:316:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
          316 |   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:366:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
          366 |   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
        ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../src/serialport.cpp:412:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
          412 |   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
        ../src/serialport.cpp: At global scope:
        ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
          433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
        ../src/serialport.cpp:433:28: note: remove parentheses
        ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
          452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
        ../src/serialport.cpp:452:30: note: remove parentheses
        /home/iobroker/.cache/node-gyp/22.5.1/include/node/node.h:1232:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
         1232 |       (node::addon_register_func) (regfunc),                          \
        /home/iobroker/.cache/node-gyp/22.5.1/include/node/node.h:1266:3: note: in expansion of macro ‘NODE_MODULE_X’
         1266 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
        ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
          486 | NODE_MODULE(serialport, init);
          CXX(target) Release/obj.target/bindings/src/serialport_unix.o
                         from ../src/serialport.h:13,
                         from ../src/serialport_unix.cpp:2:
        ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
        ../src/serialport_unix.cpp:179:82: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
          179 |     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
        ../src/serialport_unix.cpp:179:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
        ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
        ../src/serialport_unix.cpp:89:84: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
           89 |     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
        ../src/serialport_unix.cpp:89:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
          CXX(target) Release/obj.target/bindings/src/poller.o
                         from ../src/poller.cpp:1:
          CXX(target) Release/obj.target/bindings/src/serialport_linux.o
          SOLINK_MODULE(target) Release/obj.target/bindings.node
          COPY Release/bindings.node
        make: Leaving directory '/opt/iobroker/node_modules/@serialport/bindings/build'
        gyp info ok
        added 41 packages in 40s
        204 packages are looking for funding
        upload [3] maxcul.admin /opt/iobroker/node_modules/iobroker.maxcul/admin/index.html index.html text/html
        upload [2] maxcul.admin /opt/iobroker/node_modules/iobroker.maxcul/admin/index_m.html index_m.html text/html
        upload [1] maxcul.admin /opt/iobroker/node_modules/iobroker.maxcul/admin/maxcul.png maxcul.png image/png
        upload [0] maxcul.admin /opt/iobroker/node_modules/iobroker.maxcul/admin/words.js words.js application/javascript
        echad@chet:~ $
        ESP8266 mcm1957 2 Replies Last reply Reply Quote 1
        • ESP8266
          ESP8266 @Thomas Braun last edited by
          @thomas-braun , super das hat gepasst.👍
          Wenn ich euch nicht hätte 😊
          • mcm1957
            mcm1957 @Thomas Braun last edited by
            Achtung:
            Der REinstall funktioniert erst richtig mit js-controller 6++. Erst ab 6.x.x wird zuerst ein implizites npm deinstall ausgeführt und dann ein npm i.
            Der 5er macht nur ein npm i - und npm optimiert alles weg wenn die Version schon installiert ist. Beim 5er sollte es helfen zuerst eine version downzugraden und dann wieder upzugraden. Da tut npm dann was.
              Thomas Braun Most Active @mcm1957 last edited by
              @mcm1957
              Hatte mich schon gewundert.
              war mir nämlich neu. Aber ich rebuilde auch nicht sooooo oft meine Adapter.
              ESP8266 mcm1957 2 Replies Last reply Reply Quote 0
              • ESP8266
                Nun ist die "beta" Repository bei mir komplett Aktuell....
                • mcm1957
                  @thomas-braun said in Maxcul Adapter veraltet, bitte aktualisieren.:
                  @mcm1957
                  Bei Tests hat sich gezeigt, dass npm zu viel optimiert. Ein REinstall hat daher nicht wirklich das gebracht was man erwartet - nämlich dass der Stand installiert wird der im Package drinnen ist. Hat man (- ja soll man nicht-) eine Datei des Adapters verändert dann hat ein Reinstall nicht wie erwartet den Stand wiederhergestellt der im Package drinnen ist sondern (im allgeminen) nichts gemacht... js-controller 6 macht daher bei reinstall nun zuerst ein (npm only) deinstall gefolgt von einem npm install. Npm only deinstall soll heißen, dass nur das npm package deinstalliert wird nicht aber der normale Deinstall Ablauf durchgeführt wird. Kurz - Einstellungen, States, ... bleiben alle erhalten.
                    guergen @ESP8266 last edited by guergen
                    @esp8266 Hast Du jetzt mit Node 20 den Maxcul 1.3.1 laufen, sehe ich das richtig?
                    Also erst den Node auf 20 und dann den Befehl von thomas?
                      guergen @haus-automatisierung last edited by
                      @haus-automatisierung Zum Testen hätt ich dir was geben können, den Cul hast Du ja noch, nen Fensterkontakt ist schnell abgebaut 😉
                      Leider zu spät gesehen, aber es scheint ja zu funktionieren...
                      haus-automatisierung ESP8266 2 Replies Last reply Reply Quote 0
                      • haus-automatisierung
                        haus-automatisierung Developer Most Active @guergen last edited by
                        @guergen Klar, irgendwie bekommt man das hin. Ich mache nur aktuell schon super viel an Adaptern, welche ich selbst nicht nutze (nur um die am leben zu halten). Mir fehlt die Zeit an allen Ecken und Enden weiter zu machen.
                        Und wir sprechen ja von einem recht selten genutzten Adapter. Die Dankbarkeit wird sich in Grenzen halten und die Produkte und Protokolle sind ja eh schon abgekündigt.
                        ESP8266 1 Reply Last reply Reply Quote 2
                        • ESP8266
                          ESP8266 @guergen last edited by ESP8266
                          @guergen , ich betreibe Maxcul im Cube modus und brauche den Adapter trotzdem. Der cul liegt in der Schublade.
                          Aber schau mal dort, wie ich das gelöst habe... https://forum.iobroker.net/topic/61650/usb-port-to-ip-oder-maxcube-mit-maxcul-adapter-via-lan?_=1723539547532
                          Das läuft schon über ein Jahr bei mir.
                          • ESP8266
                            ESP8266 @haus-automatisierung last edited by
                            @haus-automatisierung sagte in {gelöst} Maxcul Adapter veraltet, bitte aktualisieren.:
                            Der beste Beweis, das wir in einer Wegwerfgesellschaft leben.
                              haus-automatisierung Developer Most Active @ESP8266 last edited by
                              @esp8266 sagte in {gelöst} Maxcul Adapter veraltet, bitte aktualisieren.:
                              Was man dann unterstützt, wenn man auf proprietäre Produkte und Protokolle einzelner Hersteller setzt.
                                @esp8266 Hast mich nicht verstanden....
                                Du hast es jetzt so gelöst?:
                                Node 20 auf den Rechner und dann den Befehl von Thomas.
                                Sind die Fehler:
                                jetzt weg?
                                  Thomas Braun Most Active @guergen last edited by
                                  @guergen
                                  Probier es doch einfach auf deiner Kiste aus.
                                  2018
