    5. Aquarium Wasserstand (Wasser Niveau Regulierung)
      paul53 @Aphofis last edited by paul53
      @aphofis sagte: Hab denXMl Export angehängt.
      Habe beide Skripte in ein Skript zusammengeführt und angepasst.
       <variables>
         <variable id="GnuRk+7KsY$0X2R3aUO1">Wassermenge</variable>
         <variable id="8TTn.0gElhjE;FlI3{:~">Wasser_Tag</variable>
         <variable id="1Q4.:OQ6u!U%3ez6^aej">Wasser_Jahr</variable>
       </variables>
       <block type="variables_set" id="HUSPsI8yrvs1R9buB5UE" x="-1212" y="-763">
         <field name="VAR" id="GnuRk+7KsY$0X2R3aUO1">Wassermenge</field>
           <block type="math_arithmetic" id="e1#%MoOBW(WQNQtz+];;">
               <shadow type="math_number" id="f)g1|Fqv,`2l-1dYfZ34">
                 <field name="NUM">1</field>
               <block type="get_value" id="|=$q%x;t`MAEW/vG=BLQ">
                 <field name="OID">sonoff.0.Aqua_Float.SENSOR.COUNTER.C2</field>
               <shadow type="math_number" id="j[l*MeT/~[+quhxnrS7C">
                 <field name="NUM">5.1</field>
           <block type="variables_set" id="HchfBD.f$i=}z$B3%%ro">
             <field name="VAR" id="8TTn.0gElhjE;FlI3{:~">Wasser_Tag</field>
               <block type="get_value" id="M_~UzJP71@mQ8;LaEqA;">
                 <field name="OID">0_userdata.0.Aqua_Control.0.Wasser.Wasserzähler_Tag</field>
               <block type="variables_set" id="eg3d1X/Cm`7YA1`r@6/5">
                 <field name="VAR" id="1Q4.:OQ6u!U%3ez6^aej">Wasser_Jahr</field>
                   <block type="get_value" id="HFTLl.5s}DD!S3VkI2}w">
                     <field name="OID">0_userdata.0.Aqua_Control.0.Wasser.Wasserzähler_Jahr</field>
                   <block type="on_ext" id="0:-d[({.Z}?pVdpxL($`">
                     <value name="OID0">
                       <shadow type="field_oid" id="0W#F=X0/oRtnrPk9h3{x">
                         <field name="oid">sonoff.0.Aqua_Float.POWER</field>
                       <block type="text" id="*P`{6.y$Qz:6)XRyP/e.">
                         <field name="TEXT">sonoff.0.Aqua_Float.SENSOR.COUNTER.C2</field>
                       <block type="variables_set" id=".o$v5mYbaxJ%Dy^rAJ~@">
                           <block type="math_arithmetic" id="Q,q,)Fqfx8Dcu]de0[XS">
                               <block type="on_source" id="3{.pWaaavxoM|Ix^BlA}">
                               <shadow type="math_number" id=")SsRvEav^gC^x{KjjCyf">
                           <block type="update" id="?h=3;[vg7tLw)/h@7:$A">
                             <field name="OID">0_userdata.0.Aqua_Control.0.Wasser.Wasser_Counter</field>
                               <block type="variables_get" id=",s^*MoNszpa:oog%EMAW">
                               <block type="debug" id="^-PLnz!%La/%esP+p|q%">
                                 <field name="Severity">info</field>
                                 <value name="TEXT">
                                   <shadow type="text" id="W!}jJFO{vTG9fL(st@|Z">
                                   <block type="text_join" id="oliPeI~VRSKRwW7]r|%]" inline="true">
                                     <value name="ADD0">
                                       <block type="variables_get" id="-A9r0_TWSe~DfBweAXDt">
                                     <value name="ADD1">
                                       <block type="text" id="8Ojo1T/MND*{-XQvij#:">
                                         <field name="TEXT"> ml</field>
                       <block type="on" id=".Kws=H5v3:9sC$2y}XY.">
                         <field name="OID">sonoff.0.Aqua_Float.POWER</field>
                           <block type="control" id="`#?D6cI2R48DM4)iEV2)">
                             <field name="OID">sonoff.0.Aqua_Control.POWER1</field>
                               <block type="on_source" id="Z:Ey]JGh2[+Z2p6CktfV">
                               <block type="controls_if" id="fwTIogd8xTfe{#gzL9Cn">
                                   <block type="logic_negate" id="U/Ou4#ODbm6%waUiXwK3">
                                     <value name="BOOL">
                                       <block type="on_source" id="LKR8T,H^%|Gh2gr{;F,#">
                                   <block type="timeouts_settimeout" id="RtR6.MNo`wh`ud[PbJ]:">
                                     <field name="DELAY">500</field>
                                     <field name="UNIT">ms</field>
                                       <block type="math_change" id="IX/.|6z/Aro1]dY5SAYb">
                                         <value name="DELTA">
                                           <shadow type="math_number" id="=M*S)jZ,M4p(dx.CTNCh">
                                           <block type="variables_get" id="su_iSda]mMUcg|Ylu@=o">
                                           <block type="update" id="fwHm}o7U6~1d|Z|{o_na">
                                               <block type="math_rndfixed" id=";]qdo[hKwhyu5U)H]|AP">
                                                 <field name="n">1</field>
                                                 <value name="x">
                                                   <shadow type="math_number" id="%/fU!@WL!D1NR8vZIXrJ">
                                                     <field name="NUM">3.1234</field>
                                                   <block type="variables_get" id=".$Y/`yQi2Ep48g$zUH!(">
                                               <block type="math_change" id="|lE6{O$UQZ68v5$V-mhf">
                                                   <shadow type="math_number" id="r(O489L+4qKOus0|bJZ]">
                                                   <block type="math_arithmetic" id="aUjod9%H]Jr`c:7;L`1L">
                                                     <field name="OP">DIVIDE</field>
                                                       <shadow type="math_number" id="G]!BBiks_53Irs;)eRZ/">
                                                       <block type="variables_get" id="==0y1MmV=A38?y{8!7Qp">
                                                       <shadow type="math_number" id="W)Ad2(Y4FzH8rN6?DDSG">
                                                         <field name="NUM">1000</field>
                                                   <block type="update" id="v@JXdPp^SX$e}[;*TN;5">
                                                       <block type="math_rndfixed" id="H]3.WGAtE,UJ;+O:yMqK">
                                                         <field name="n">3</field>
                                                         <value name="x">
                                                           <shadow type="math_number" id="%?~4gjL?h%jK9FuG!MeL">
                                                           <block type="variables_get" id="/n6Y=9C~2W@KV$RXN-DW">
                                                       <block type="update" id="`NW9_QcSlKGP;b[9@.QH">
                                                           <block type="math_number" id="|m|G@]xx7.d^nS-E2Q,B">
                                                             <field name="NUM">0</field>
                                                           <block type="debug" id="ESkP;ss;~ZDB;gISHFI]">
                                                             <value name="TEXT">
                                                               <block type="text_join" id="R[aL32f3![219OSKE$k!" inline="true">
        <value name="ADD0">
        <block type="variables_get" id="Y%f8;@,D;lNrR?pmQ|(Z">
        <value name="ADD1">
        <block type="text" id="q=ZJuFoniJND[_z;_j~M">
        <field name="TEXT"> Liter</field>
                                                               <block type="telegram_call" id="HP%v-*cCsG%`jLmz$NzT" inline="true">
        <field name="INSTANCE">.0</field>
        <field name="LANGUAGE"></field>
        <field name="REPEATS">1</field>
        <field name="LOG"></field>
        <value name="MESSAGE">
        <shadow type="text" id=":(YMTpY/k)a7+-W7~g|M">
        <block type="text_join" id=";;6oqX}l/W(ws@3[8iFR" inline="true">
        <value name="ADD0">
        <block type="variables_get" id="wimbm((,ufreXmGowP_b">
        <value name="ADD1">
        <block type="text" id="e)3mz5qz)A1i;o:E{!47">
        <value name="ADD2">
        <block type="text" id="We*0)kla7,,mg^N5.sPb">
        <field name="TEXT"> Wasser wurden dosiert</field>
        <value name="USERNAME">
        <shadow type="text" id="X{lxgUXzI0kZ[MSI2uZV">
        <field name="TEXT"></field>
        <block type="http_get" id="e9^C0,Xruq+R^Q=|k3dc">
        <field name="TIMEOUT">2000</field>
        <field name="TYPE">text</field>
        <value name="URL">
        <shadow type="text" id=",_J4F8mdkf!o;QG{KC2z">
        <field name="TEXT">http://192.168.0.71/cm?cmnd=counter2 0</field>
       <block type="schedule" id="eY2k):|9:7y;jFJ|-e{." x="-637" y="-488">
         <field name="SCHEDULE">0 0 1 1 *</field>
           <block type="variables_set" id="cEkH53kNZuyOARmP+Q|,">
               <block type="math_number" id="9;ptE-Ve[-8t]`aa|Tgl">
               <block type="update" id="|*@i5i^pfX8@UCo}nN4j">
                   <block type="math_number" id="27z6jlXz=#}B7;,?{V7M">
           <block type="schedule" id="!0s4!(IKf352-$Cjs+=H">
             <field name="SCHEDULE">0 0 * * *</field>
               <block type="variables_set" id="u2/ozk5F`Si~3`_cLs4`">
                   <block type="math_number" id="kQwxXS=Yw7,Q5s]YKP}*">
                   <block type="update" id=",B.vece!}v4W4j`J0O1r">
                       <block type="math_number" id="(P{ST5UTzs=*|2/~;Z+d">
      EDIT: Habe noch eine Verzögerung eingebaut, damit das Magnetventil geschlossen ist, wenn die Wassermenge ausgewertet wird.
      Aphofis 1 Reply Last reply Reply Quote 1
      • Aphofis
        Aphofis @paul53 last edited by Aphofis
        Das ja bombastisch!!!
        Ich frage mich bei jeder Steuerung wie man sowas kann.
        Ich hatte die bestehenden Werte aus den Datenpunkten gelöscht und dann das neue Blockly gestartet. Es wird zwar gezählt aber es steht nur in Wasser Jahr der alte Wert.
        Der war 7,004 Liter den hatte ich auch auf Null gesetzt. Doch nach dem Wasser dosiert wurde steht Wasser Tag auf "0" und Wasser Jahr wurde der alte wert 7,004 angenommen. Woher kommt das !? Ach ja und im Telegram Bot kommt nix an.
        Eingetragenen Bot Token hab ich kontrolliert der stimmt. Die Aquarium Steuerung, meldet per Telegram auch wenn Futter dosiert wird und Pumpe ein und ausgeschaltet wird also verbindung zu Telegram ist vorhanden.
          @aphofis sagte: Der war 7,004 Liter den hatte ich auch auf Null gesetzt.
          Vor dem Skriptstart?
          @aphofis sagte in Aquarium Wasserstand (Wasser Niveau Regulierung):
          Kam die Logausgabe "7.004 Liter"?
          Mit Telegram kenne ich mich nicht aus.
          Aphofis 1 Reply Last reply Reply Quote 0
          • Aphofis
            Ja Logausgabe kam mit 7,004 Liter aber woher hat die Steuerung den Wert. Hatte den ja vor Script Start gelöscht.
            Ich Pumpe mal etwas Wasser aus dem Becken ab. Mal sehen vielleicht geht es ja wenn das von selsbt auslöst und nicht wenn ich den Schwimmer von hand betätige.
            • Aphofis
              Aphofis @Aphofis last edited by Aphofis
              Also Wasser Tag & Wasser Jahr bleibt auf null.
              Log Ausgabe sagt 0 liter sprich nur Jahr macht eine Ausgabe die tages angabe in ml fehlt.
              Telegram sagt auch nichts
              Counter wird sauber auf 0" gesetzt
                @aphofis sagte: Counter wird sauber auf 0" gesetzt
                Bevor er auf 0 gesetzt wird: Zeigt er die dosierte Wassermenge an?
                Er sollte nicht per Skript auf 0 gesetzt werden, denn das muss auch passieren, wenn der Sensorwert auf 0 gesetzt wird (httpGet).
                Der Sensorwert ändert sich und das Log mit Wassermenge in ml kommt?
                • Aphofis
                  Hatte mal den javascript adapter neu gestartet nun werden ml Tag und Liter Jahr angezeigt und Telegram bekomme ich schon hin
                  • Aphofis
                    Hab ja die Steuerung jetzt schon ein paar Tage am laufen. Irgenwie reagiert die Steuerung nicht darauf wenn der Schwimmer true ist. wenn ich den Schwimmer von Hand einmal hoch ziehe also false setze und dann auf true los lasse dann erst reagiert die Steuerung.
                    Ist da irgendwas falsch !?
                    Momentan sieht es so aus.
                      <variables>
                      </variables>
                                    <value name="OID0">
                                          <block type="math_rndfixed" id="~C}Q;4pD[j1fqWGOQbxr">
                                            <field name="n">2</field>
                                            <value name="x">
                                              <shadow type="math_number" id="sYM=iIrazCVz3G9{m*Wp">
                                                <value name="TEXT">
                                                    <value name="ADD0">
                                                    <value name="ADD1">
                                                    <value name="BOOL">
                                                    <field name="DELAY">15</field>
        <value name="x">
        <block type="telegram" id="%Ac!=W);Rce9~t/iuvmU" collapsed="true">
        <field name="ESCAPING">FALSE</field>
        <field name="DISABLE_WEB_PAGE_PREVIEW">FALSE</field>
        <shadow type="text" id="/qlY{U].1kjbanyv~*S8">
        <block type="text_join" id=";;6oqX}l/W(ws@3[8iFR" inline="false">
        <mutation items="6"></mutation>
        <value name="ADD0">
        <block type="math_rndfixed" id="I;(*n|Y1J;sj}Vs~,1w`">
        <value name="x">
        <shadow type="math_number" id="IZ`3Rk8S?(K[:=/b[Fvi">
        <value name="ADD1">
        <value name="ADD2">
        <value name="ADD3">
        <block type="text_newline" id="~nUOik7/[6b_mj-#r6(;">
        <field name="Type">\n</field>
        <value name="ADD4">
        <block type="math_rndfixed" id="4-Nd9(iT2OOMTVJH6gx6">
        <value name="x">
        <block type="variables_get" id="n+Wsz3PbGc-kKOFZzy/6">
        <value name="ADD5">
        <block type="text" id="f_S0X,P8Fohvyjt[~}Wt">
        <field name="TEXT"> Liter wurden dieses Jahr dosiert</field>
        <value name="x">
        <value name="TEXT">
        <value name="ADD0">
        <value name="ADD1">
        <field name="TIMEOUT">10</field>
        <value name="URL">
                      <block type="schedule" id="eY2k):|9:7y;jFJ|-e{." x="-437" y="-687">
                      @aphofis sagte: Momentan sieht es so aus.
                      Das Magnetventil muss direkt auf den Schwimmer reagieren. Der Teil im Programm darunter wird 15 s nach Schließen des Magnetventils ausgeführt.
                      • Aphofis
                        verstehe ich nicht, die Einstellung ist doch so
                        wo wird eigentlich der timeout beendet !?
                          @aphofis sagte: wo wird eigentlich der timeout beendet !?
                          Der beendet sich nach 15 s selbst und führt dann das verzögerte Programm aus.
                          Weshalb hast du die Verzögerung auf 15 s gesetzt? Ein Magnetventil schließt normalerweise schneller.
                          • Aphofis
                            @paul53 keine Ahnug was das falsch gelaufen ist. hab ich zurück auf 500ms gestellt
                            • Aphofis
                              Das Wasser wird immer noch nicht richtig gezählt und der Wert wird nihct resettet
                              Der wert aktuell wird durchgehend gezählt aber auch nicht zurück gesetzt.
                              Ich finde den Fehler nicht.
                              Wenn wasser dosiert wird kommen ja um die vier zählungen in einer sekunde zu stande. die Steuerung muss also vielleicht 2 sek warten und die werte speichern ausrechnen tasmota counter resetten und dann erst weiter zählen.
                              javascript.0	12:10:58.058	info	script.js.AquaPi.Technik_Steuerung.Wasserstand_Regulierung: 211247 ml Aktuell
                              javascript.0	12:11:13.123	info	script.js.AquaPi.Technik_Steuerung.Wasserstand_Regulierung: 211255 ml Aktuell
                              javascript.0	12:11:28.045	info	script.js.AquaPi.Technik_Steuerung.Wasserstand_Regulierung: 211263 ml Aktuell
                              javascript.0	12:11:43.093	info	script.js.AquaPi.Technik_Steuerung.Wasserstand_Regulierung: 211272 ml Aktuell
                              javascript.0	12:11:58.070	info	script.js.AquaPi.Technik_Steuerung.Wasserstand_Regulierung: 211281 ml Aktuell
                              javascript.0	12:12:13.093	info	script.js.AquaPi.Technik_Steuerung.Wasserstand_Regulierung: 211293 ml Aktuell
                              javascript.0	12:12:28.180	info	script.js.AquaPi.Technik_Steuerung.Wasserstand_Regulierung: 211303 ml Aktuell
                              javascript.0	12:12:43.061	info	script.js.AquaPi.Technik_Steuerung.Wasserstand_Regulierung: 211309 ml Aktuell
                              javascript.0	12:12:58.030	info	script.js.AquaPi.Technik_Steuerung.Wasserstand_Regulierung: 211322 ml Aktuell
                              javascript.0	12:13:13.084	info	script.js.AquaPi.Technik_Steuerung.Wasserstand_Regulierung: 211327 ml Aktuell
                              javascript.0	12:13:28.146	info	script.js.AquaPi.Technik_Steuerung.Wasserstand_Regulierung: 211337 ml Aktuell
                              javascript.0	12:13:43.139	info	script.js.AquaPi.Technik_Steuerung.Wasserstand_Regulierung: 211353 ml Aktuell
                              javascript.0	12:13:57.998	info	script.js.AquaPi.Technik_Steuerung.Wasserstand_Regulierung: 211360 ml Aktuell
                              javascript.0	12:14:13.082	info	script.js.AquaPi.Technik_Steuerung.Wasserstand_Regulierung: 211368 ml Aktuell
                              Ausgewählte Blöcke exportieren
                                <variables>
                                  <variable id="Ovk0Oa33E*$]Mz^7{~.3">Wasser_Gesamt</variable>
                                </variables>
                                          <field name="OID">sonoff.0.Aqua_Float.SENSOR.COUNTER.C1</field>
                                          <field name="NUM">5.182</field>
                                            <block type="variables_set" id="CA,Qr(B*Ax}^Rcx{WiM0">
                                              <field name="VAR" id="Ovk0Oa33E*$]Mz^7{~.3">Wasser_Gesamt</field>
                                                <block type="get_value" id="j]bLYMumfN_Ej:OBArxI">
                                                  <field name="OID">0_userdata.0.Aqua_Control.0.Wasser.Wasser_Gesamt</field>
                                                  <value name="OID0">
                                                      <field name="TEXT">sonoff.0.Aqua_Float.SENSOR.COUNTER.C1</field>
                                                              <value name="TEXT">
        <value name="ADD0">
        <value name="ADD1">
        <field name="TEXT"> ml Aktuell</field>
        <value name="BOOL">
        <field name="DELAY">200</field>
        <block type="math_change" id="|Oi./blga6U/DN#4L}cB">
        <block type="math_arithmetic" id="]M+aVNab-ngeovV)j^g@">
        <block type="variables_get" id="P(Ibc,eZ|YYJM/Sz+:;Z">
        <shadow type="math_number" id="}@$j#%R5)f]P3nf@i||6">
        <value name="x">
        <value name="x">
        <block type="update" id="3)$zk|xkb)ME;O,`Pb4h">
        <block type="math_rndfixed" id="8|$7qbgnf2HyoIJku[)2">
        <value name="x">
        <block type="variables_get" id="AN!(vppC8|3s`)1tLCm^">
        <value name="TEXT">
        <value name="ADD0">
        <value name="ADD1">
        <block type="debug" id="?XjRd=PU1#Fj(f#xl+mC">
        <value name="TEXT">
        <block type="text_join" id="qZJM||k00I36j8XRC(_D" inline="true">
        <value name="ADD0">
        <block type="variables_get" id="!AST/{)(*stRx}e6R#i=">
        <value name="ADD1">
        <block type="text" id="[G8=298XTdIwTD?Vf-]v">
        <field name="TEXT"> ml Heute</field>
        <block type="debug" id=")R2t?-dNSqu)sk@uUf7P">
        <value name="TEXT">
        <block type="text_join" id="tFjhop@BpJ{DM2V9fgF~" inline="true">
        <value name="ADD0">
        <block type="variables_get" id="-/WYH+yRlL2^$93UY@NC">
        <value name="ADD1">
        <block type="text" id="e3jEG}s0@g6ww)3e(Z*G">
        <field name="TEXT"> Liter Gesamt</field>
        <block type="debug" id="#z1|ehxGsPSwxWtTu9|B">
        <value name="TEXT">
        <block type="text_join" id="p.8rZ(UWm@M4h]MJKwz*" inline="true">
        <value name="ADD0">
        <block type="get_value" id="X9/9B+*-H{rJgrce]hjh">
        <value name="ADD1">
        <block type="text" id="[!*5OpdK%*CIY=7U;a`I">
        <field name="TEXT"> Pulse Count</field>
        <block type="request" id="pWM7@T;V-m3CCu`$#~o!">
        <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation>
        <field name="WITH_STATEMENT">FALSE</field>
        <field name="LOG">debug</field>
        <value name="URL">
        <shadow type="text" id="2+7Jn:,Rp_p6,1h1#*g=">
        <field name="TEXT">http://192.168.0.71/cm?user=admin&amp;password=Kasjopayac3po&amp;cmnd=counter2%200</field>
        <block type="text" id="rpv,(m{smGL,#8,7_QUP">
                                                        <block type="schedule" id="eY2k):|9:7y;jFJ|-e{.">
                                <variables>
                                </variables>
                                                  <value name="OID0">
                                                              <value name="TEXT">
        <value name="ADD0">
        <value name="ADD1">
        <value name="BOOL">
        <value name="x">
        <value name="x">
        <value name="x">
        <value name="TEXT">
        <value name="ADD0">
        <value name="ADD1">
        <value name="TEXT">
        <value name="ADD0">
        <value name="ADD1">
        <value name="TEXT">
        <value name="ADD0">
        <value name="ADD1">
        <value name="TEXT">
        <value name="ADD0">
        <value name="ADD1">
        <value name="URL">
        <field name="TEXT">http://192.168.0.71/cm?user=admin&amp;password=Password&amp;cmnd=counter2%200</field>
                              815
