pivCCU nach Update node.js nicht erreichbar
Passt es so?
======================= SUMMARY ======================= v.2024-05-22 Static hostname: iobroker-pi Icon name: computer Operating System: Raspbian GNU/Linux 11 (bullseye) Kernel: Linux 6.6.44-v7l+ Architecture: arm Installation: native Kernel: armv7l Userland: 32 bit Timezone: Europe/Berlin (CEST, +0200) User-ID: 1000 Display-Server: false Boot Target: multi-user.target Pending OS-Updates: 0 Pending iob updates: 1 Nodejs-Installation: /usr/bin/nodejs v20.16.0 /usr/bin/node v20.16.0 /usr/bin/npm 10.8.1 /usr/bin/npx 10.8.1 /usr/bin/corepack 0.28.2 Recommended versions are nodejs and npm Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 3.9G 1.0G 2.2G 1.0M 704M 2.8G Swap: 99M 0B 99M Total: 4.0G 1.0G 2.3G Active iob-Instances: 6 Active repo(s): stable ioBroker Core: js-controller 5.0.19 admin 7.0.22 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : iobroker-pi - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.web.0 : web : iobroker-pi - enabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 7430 States: 6249 Size of iob-Database: 17M /opt/iobroker/iobroker-data/objects.jsonl 11M /opt/iobroker/iobroker-data/states.jsonl =================== END OF SUMMARY ====================
=== Mark text until here for copying ===
wibear@iobroker-pi:~ $ b nodejs-update 20
-bash: b: command not found
wibear@iobroker-pi:~ $ -
Starte die Kiste mal komplett durch und dann gibst du uns die Langfassung.
Nach reboot:
Skript v.2024-05-22 *** BASE SYSTEM *** Static hostname: iobroker-pi Icon name: computer Operating System: Raspbian GNU/Linux 11 (bullseye) Kernel: Linux 6.6.44-v7l+ Architecture: arm Model : Raspberry Pi 4 Model B Rev 1.5 Docker : false Virtualization : none Kernel : armv7l Userland : 32 bit Systemuptime and Load: 16:10:24 up 1 min, 1 user, load average: 2.37, 1.01, 0.38 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Tue 2024-08-13 16:10:25 CEST Universal time: Tue 2024-08-13 14:10:25 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': wibear HOME=/home/wibear GROUPS=wibear adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** Display-Server-Setup *** Display-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 3.9G 1.0G 2.3G 1.0M 519M 2.7G Swap: 99M 0B 99M Total: 4.0G 1.0G 2.4G Active iob-Instances: 10 3885 M total memory 1016 M used memory 156 M active memory 1281 M inactive memory 2349 M free memory 48 M buffer memory 471 M swap cache 99 M total swap 0 M used swap 99 M free swap *** top - Table Of Processes *** top - 16:10:25 up 1 min, 1 user, load average: 2.37, 1.01, 0.38 Tasks: 202 total, 1 running, 201 sleeping, 0 stopped, 0 zombie %Cpu(s): 16.7 us, 3.0 sy, 0.0 ni, 80.3 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 3885.9 total, 2349.2 free, 1016.4 used, 520.2 buff/cache MiB Swap: 100.0 total, 100.0 free, 0.0 used. 2742.4 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * pivccu-dkms.service loaded failed failed piVCCU DKMS Modules * pivccu-rpi-modules.service loaded failed failed piVCCU RPi Kernel loader LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 2 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 29G 11G 18G 39% / devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 778M 1.1M 777M 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 255M 63M 193M 25% /boot tmpfs tmpfs 389M 0 389M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Tue Aug 13 16:08:37 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=D8:3A:DD:16:18:C4 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000 console=tty1 root=PARTUUID=e605bf32-02 rootfstype=ext4 fsck.repair=yes rootwait [Tue Aug 13 16:08:38 2024] EXT4-fs (mmcblk0p2): mounted filesystem d3104e7d-5f59-47e0-8621-290882475163 ro with ordered data mode. Quota mode: none. [Tue Aug 13 16:08:38 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Tue Aug 13 16:08:39 2024] EXT4-fs (mmcblk0p2): re-mounted d3104e7d-5f59-47e0-8621-290882475163 r/w. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime |-/dev devtmpfs devtmpfs rw,relatime,size=1726396k,nr_inodes=34271,mode=755 | |-/dev/shm tmpfs tmpfs rw,nosuid,nodev | |-/dev/pts devpts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 | `-/dev/mqueue mqueue mqueue rw,nosuid,nodev,noexec,relatime |-/proc proc proc rw,relatime | `-/proc/sys/fs/binfmt_misc systemd-1 autofs rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct |-/sys sysfs sysfs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/security securityfs securityfs rw,nosuid,nodev,noexec,relatime | |-/sys/fs/cgroup cgroup2 cgroup2 rw,nosuid,nodev,noexec,relatime | |-/sys/fs/pstore pstore pstore rw,nosuid,nodev,noexec,relatime | |-/sys/fs/bpf bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700 | |-/sys/kernel/tracing tracefs tracefs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/debug debugfs debugfs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/config configfs configfs rw,nosuid,nodev,noexec,relatime | `-/sys/fs/fuse/connections fusectl fusectl rw,nosuid,nodev,noexec,relatime |-/run tmpfs tmpfs rw,nosuid,nodev,size=795828k,nr_inodes=819200,mode=755 | |-/run/lock tmpfs tmpfs rw,nosuid,nodev,noexec,relatime,size=5120k | |-/run/rpc_pipefs sunrpc rpc_pipefs rw,relatime | `-/run/user/1000 tmpfs tmpfs rw,nosuid,nodev,relatime,size=397912k,nr_inodes=99478,mode=700,uid=1000,gid=1000 |-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro `-/var/lib/lxcfs lxcfs fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other Files in neuralgic directories: /var: du: cannot access '/var/lib/lxcfs/cgroup': Input/output error 4.7G /var/ 3.3G /var/log 2.9G /var/log/journal/6462312882a642219bbda7aff5f4f5b9 2.9G /var/log/journal 734M /var/lib Archived and active journals take up 2.8G in the file system. /opt/iobroker/backups: 82M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 752M /opt/iobroker/iobroker-data/ 594M /opt/iobroker/iobroker-data/files 441M /opt/iobroker/iobroker-data/files/javascript.admin 409M /opt/iobroker/iobroker-data/files/javascript.admin/static 408M /opt/iobroker/iobroker-data/files/javascript.admin/static/js The five largest files in iobroker-data are: 27M /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map 24M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map 18M /opt/iobroker/iobroker-data/objects.jsonl 12M /opt/iobroker/iobroker-data/states.jsonl 8.7M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' *** NodeJS-Installation *** /usr/bin/nodejs v20.16.0 /usr/bin/node v20.16.0 /usr/bin/npm 10.8.1 /usr/bin/npx 10.8.1 /usr/bin/corepack 0.28.2 nodejs: Installed: 20.16.0-1nodesource1 Candidate: 20.16.0-1nodesource1 Version table: *** 20.16.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 100 /var/lib/dpkg/status 20.15.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.15.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.14.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.13.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.13.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.12.2-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.12.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.12.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.11.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.11.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.10.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.9.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.8.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.8.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.7.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.6.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.6.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.5.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.5.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.4.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.3.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.3.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.2.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.1.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.0.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 12.22.12~dfsg-1~deb11u4 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.19 admin: 7.0.22 javascript: 8.7.6 nodejs modules from github: 1 +-- iobroker.vw-connect@0.5.3 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#b5fbfb41f65b8a1efb646e9efb68f1cbd1627d27) Adapter State + system.adapter.admin.0 : admin : iobroker-pi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : iobroker-pi - enabled + system.adapter.backitup.0 : backitup : iobroker-pi - enabled system.adapter.device-reminder.0 : device-reminder : iobroker-pi - enabled system.adapter.discovery.0 : discovery : iobroker-pi - enabled system.adapter.ems-esp.0 : ems-esp : iobroker-pi - enabled system.adapter.fb-checkpresence.0 : fb-checkpresence : iobroker-pi - enabled system.adapter.habpanel.0 : habpanel : iobroker-pi - enabled + system.adapter.history.0 : history : iobroker-pi - enabled + system.adapter.hm-rega.0 : hm-rega : iobroker-pi - enabled + system.adapter.hm-rpc.0 : hm-rpc : iobroker-pi - enabled, port: 18701 system.adapter.hm-rpc.1 : hm-rpc : iobroker-pi - enabled, port: 12001 system.adapter.hm-rpc.2 : hm-rpc : iobroker-pi - enabled, port: 12010 + system.adapter.influxdb.0 : influxdb : iobroker-pi - enabled, port: 8086 system.adapter.info.0 : info : iobroker-pi - enabled + system.adapter.javascript.0 : javascript : iobroker-pi - enabled system.adapter.mqtt.0 : mqtt : iobroker-pi - enabled, port: 1883, bind: 192.168.178.10 system.adapter.netatmo-crawler.0 : netatmo-crawler : iobroker-pi - enabled system.adapter.rpi2.0 : rpi2 : iobroker-pi - enabled system.adapter.shelly.0 : shelly : iobroker-pi - enabled, port: 1882, bind: 0.0.0.0 system.adapter.simple-api.0 : simple-api : iobroker-pi - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.tr-064.0 : tr-064 : iobroker-pi - enabled system.adapter.tuya.0 : tuya : iobroker-pi - disabled system.adapter.vw-connect.0 : vw-connect : iobroker-pi - enabled system.adapter.weatherunderground.0 : weatherunderground : iobroker-pi - disabled system.adapter.web.0 : web : iobroker-pi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobroker-pi - enabled + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker-pi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hm-rpc.0 : hm-rpc : iobroker-pi - enabled, port: 18701 system.adapter.hm-rpc.1 : hm-rpc : iobroker-pi - enabled, port: 12001 system.adapter.hm-rpc.2 : hm-rpc : iobroker-pi - enabled, port: 12010 + system.adapter.influxdb.0 : influxdb : iobroker-pi - enabled, port: 8086 system.adapter.mqtt.0 : mqtt : iobroker-pi - enabled, port: 1883, bind: 192.168.178.10 system.adapter.shelly.0 : shelly : iobroker-pi - enabled, port: 1882, bind: 0.0.0.0 system.adapter.simple-api.0 : simple-api : iobroker-pi - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.web.0 : web : iobroker-pi - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 7.0.22 , installed 7.0.22 Adapter "alexa2" : 3.26.5 , installed 3.26.5 Adapter "backitup" : 3.0.16 , installed 3.0.16 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "discovery" : 4.5.0 , installed 4.5.0 Adapter "ems-esp" : 3.5.0 , installed 3.5.0 Adapter "fb-checkpresence": 1.2.4 , installed 1.2.4 Adapter "habpanel" : 0.5.0 , installed 0.5.0 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "hm-rega" : 4.0.0 , installed 4.0.0 Adapter "hm-rpc" : 1.17.0 , installed 1.17.0 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "javascript" : 8.7.6 , installed 8.7.6 Controller "js-controller": 6.0.9 , installed 5.0.19 [Updatable] Adapter "mqtt" : 5.2.0 , installed 5.2.0 Adapter "netatmo-crawler": 0.8.1 , installed 0.8.1 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "shelly" : 7.0.0 , installed 7.0.0 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "socketio" : 6.7.1 , installed 6.7.1 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "tuya" : 3.15.0 , installed 3.15.0 Adapter "weatherunderground": 3.7.0, installed 3.7.0 Adapter "web" : 6.2.5 , installed 6.2.5 Adapter "whatsapp-cmb" : 0.3.0 , installed 0.3.0 Adapter "ws" : 2.6.2 , installed 2.6.2 Objects and States Please stand by - This may take a while Objects: 7430 States: 6295 *** OS-Repositories and Updates *** Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease Hit:2 https://repos.influxdata.com/debian bullseye InRelease Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:4 https://packages.grafana.com/oss/deb stable InRelease Hit:5 https://apt.pivccu.de/piVCCU stable InRelease Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 10.0.3.1:53 0.0.0.0:* LISTEN 0 6228 814/dnsmasq tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 6194 785/sshd: /usr/sbin tcp 0 0 192.168.178.10:12001 0.0.0.0:* LISTEN 1001 12319 1854/io.hm-rpc.1 tcp 0 0 192.168.178.10:12010 0.0.0.0:* LISTEN 1001 12330 1869/io.hm-rpc.2 tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 9377 1407/io.shelly.0 tcp 0 0 192.168.178.10:1883 0.0.0.0:* LISTEN 1001 8528 1324/io.mqtt.0 tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 7195 905/iobroker.js-con tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 5644 905/iobroker.js-con tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 999 6272 730/influxd tcp6 0 0 :::22 :::* LISTEN 0 6196 785/sshd: /usr/sbin tcp6 0 0 :::3000 :::* LISTEN 111 5642 904/grafana tcp6 0 0 :::8086 :::* LISTEN 999 6362 730/influxd tcp6 0 0 :::8087 :::* LISTEN 1001 6952 1464/io.simple-api. tcp6 0 0 :::8082 :::* LISTEN 1001 7769 1483/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1001 7239 990/io.admin.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 787 337/avahi-daemon: r udp 0 0 0.0.0.0:47656 0.0.0.0:* 108 789 337/avahi-daemon: r udp 0 0 10.0.3.1:53 0.0.0.0:* 0 6227 814/dnsmasq udp 0 0 0.0.0.0:67 0.0.0.0:* 0 6224 814/dnsmasq udp 0 0 0.0.0.0:68 0.0.0.0:* 0 897 598/dhclient udp6 0 0 :::5353 :::* 108 788 337/avahi-daemon: r udp6 0 0 :::34059 :::* 108 790 337/avahi-daemon: r *** Log File - Last 25 Lines *** 2024-08-13 16:10:57.691 - info: hm-rpc.1 (1854) starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.16.0, js-controller: 5.0.19 2024-08-13 16:10:58.329 - info: hm-rpc.1 (1854) xmlrpc server is trying to listen on 192.168.178.10:12001 2024-08-13 16:10:58.342 - info: hm-rpc.1 (1854) xmlrpc client is trying to connect to 192.168.178.12:2001/ with ["http://192.168.178.10:12001","iobroker-pi:hm-rpc.1:d56a41b7e622f59142e1fdc67550700c"] 2024-08-13 16:10:59.322 - info: shelly.0 (1407) [MQTT] Client Close: (shelly1pmminig3 / shelly1pmminig3-5432044f4ff4 / shelly1pmminig3#5432044f4ff4#1) (false) 2024-08-13 16:10:59.922 - error: shelly.0 (1407) [MQTT] Unable to get mqttprefix of client with id "shelly1pmminig3-5432044f4ff4" 2024-08-13 16:11:00.713 - info: hm-rpc.2 (1869) starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.16.0, js-controller: 5.0.19 2024-08-13 16:11:00.868 - info: shelly.0 (1407) [MQTT] Client Close: 192.168.178.78 (shellyplusplugs / shellyplusplugs-d4d4dae85f70 / shellyplusplugs#d4d4dae85f70#1) (false) 2024-08-13 16:11:00.928 - error: shelly.0 (1407) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for (undefined / undefined / undefined): TypeError: Cannot read properties of undefined (reading 'replace') 2024-08-13 16:11:00.929 - error: shelly.0 (1407) [MQTT] Unable to get mqttprefix of client with id "shellyplusplugs-d4d4dae85f70" 2024-08-13 16:11:01.071 - info: hm-rpc.2 (1869) xmlrpc server is trying to listen on 192.168.178.10:12010 2024-08-13 16:11:01.077 - info: hm-rpc.2 (1869) xmlrpc client is trying to connect to 192.168.178.12:2010/ with ["http://192.168.178.10:12010","iobroker-pi:hm-rpc.2:03c58894ec83886e7c67f29e17b46f89"] 2024-08-13 16:11:01.519 - error: hm-rpc.2 (1869) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.12:2010 2024-08-13 16:11:01.525 - error: hm-rpc.1 (1854) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.12:2001 2024-08-13 16:11:02.712 - info: ems-esp.0 (1426) ems : energy polling every 10 minutes 2024-08-13 16:11:02.713 - info: ems-esp.0 (1426) ems : polling every 15 secs 2024-08-13 16:11:10.056 - info: fb-checkpresence.0 (1726) createFbDeviceObjects finished successfully 2024-08-13 16:11:10.058 - info: fb-checkpresence.0 (1726) states successfully subscribed 2024-08-13 16:11:10.059 - info: fb-checkpresence.0 (1726) loop successfully started 2024-08-13 16:11:20.232 - info: hm-rpc.0 (1791) binrpc -> 192.168.178.12:8701/ init ["xmlrpc_bin://192.168.178.10:18701",""] 2024-08-13 16:11:20.238 - error: hm-rpc.0 (1791) Cannot call init: [xmlrpc_bin://192.168.178.10:18701, ""] Socket closed before the connection was established 2024-08-13 16:11:20.246 - info: hm-rpc.0 (1791) terminating 2024-08-13 16:11:20.248 - info: hm-rpc.0 (1791) Terminated (NO_ERROR): Without reason 2024-08-13 16:11:20.853 - info: host.iobroker-pi instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR) 2024-08-13 16:11:20.854 - info: host.iobroker-pi Restart adapter system.adapter.hm-rpc.0 because enabled 2024-08-13 16:11:23.334 - error: hm-rega.0 (1231) CCU 192.168.178.12 unreachable
Es ist dir doch oben schon einmal gelungen, klopp bitte die lange Fassung in </> (codetags) hier rein.
Das ist sonst grottenschlecht zu lesen.
@wibear sagte in pivCCU nach Update node.js nicht erreichbar:
pivccu-rpi-modules.service loaded failed failed piVCCU RPi Kernel loaderDa klemmt es. Hat aber nix mit nodejs oder dem ioBroker zu tun, da werden die pivCCU Module nicht geladen.
Und wo du einmal dran bist:
iob stop iob update iob upgrade self iob start
@meister-mopper sagte in pivCCU nach Update node.js nicht erreichbar:
======================= SUMMARY ======================= v.2024-05-22 Static hostname: iobroker-pi Icon name: computer Operating System: Raspbian GNU/Linux 11 (bullseye) Kernel: Linux 6.6.44-v7l+ Architecture: arm Installation: native Kernel: armv7l Userland: 32 bit Timezone: Europe/Berlin (CEST, +0200) User-ID: 1000 Display-Server: false Boot Target: multi-user.target Pending OS-Updates: 0 Pending iob updates: 1 Nodejs-Installation: /usr/bin/nodejs v20.16.0 /usr/bin/node v20.16.0 /usr/bin/npm 10.8.1 /usr/bin/npx 10.8.1 /usr/bin/corepack 0.28.2 Recommended versions are nodejs 20.16.0 and npm 10.8.1 Your nodejs installation is correct MEMORY: total used free shared buff/cache available Mem: 3.9G 945M 2.3G 1.0M 604M 2.8G Swap: 99M 0B 99M Total: 4.0G 945M 2.4G Active iob-Instances: 21 Active repo(s): stable ioBroker Core: js-controller 5.0.19 admin 7.0.22 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : iobroker-pi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : iobroker-pi - enabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 7430 States: 6297 Size of iob-Database: 9.6M /opt/iobroker/iobroker-data/objects.jsonl 13M /opt/iobroker/iobroker-data/states.jsonl =================== END OF SUMMARY ====================
Die Ausgabe von iob diag hat die schon dabei. Muss nur kopiert und eingefügt werden.
Jetzt sind zwei CodeTags drumherum, das ist auch falsch. -
Ist es besser?
Skript v.2024-05-22 *** BASE SYSTEM *** Static hostname: iobroker-pi Icon name: computer Operating System: Raspbian GNU/Linux 11 (bullseye) Kernel: Linux 6.6.44-v7l+ Architecture: arm Model : Raspberry Pi 4 Model B Rev 1.5 Docker : false Virtualization : none Kernel : armv7l Userland : 32 bit Systemuptime and Load: 16:21:41 up 13 min, 1 user, load average: 1.00, 1.08, 0.80 CPU threads: 4 *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** Time and Time Zones *** Local time: Tue 2024-08-13 16:21:42 CEST Universal time: Tue 2024-08-13 14:21:42 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': wibear HOME=/home/wibear GROUPS=wibear adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** Display-Server-Setup *** Display-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 3.9G 941M 2.3G 1.0M 626M 2.8G Swap: 99M 0B 99M Total: 4.0G 941M 2.4G Active iob-Instances: 21 3885 M total memory 942 M used memory 230 M active memory 1233 M inactive memory 2317 M free memory 76 M buffer memory 550 M swap cache 99 M total swap 0 M used swap 99 M free swap *** top - Table Of Processes *** top - 16:21:42 up 13 min, 1 user, load average: 1.00, 1.08, 0.80 Tasks: 194 total, 1 running, 193 sleeping, 0 stopped, 0 zombie %Cpu(s): 30.0 us, 11.4 sy, 0.0 ni, 52.9 id, 4.3 wa, 0.0 hi, 1.4 si, 0.0 st MiB Mem : 3885.9 total, 2316.9 free, 942.0 used, 627.0 buff/cache MiB Swap: 100.0 total, 100.0 free, 0.0 used. 2817.4 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * pivccu-dkms.service loaded failed failed piVCCU DKMS Modules * pivccu-rpi-modules.service loaded failed failed piVCCU RPi Kernel loader LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 2 loaded units listed. *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 29G 11G 18G 39% / devtmpfs devtmpfs 1.7G 0 1.7G 0% /dev tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 778M 1.1M 777M 1% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 255M 63M 193M 25% /boot tmpfs tmpfs 389M 0 389M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Tue Aug 13 16:08:37 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=D8:3A:DD:16:18:C4 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000 console=tty1 root=PARTUUID=e605bf32-02 rootfstype=ext4 fsck.repair=yes rootwait [Tue Aug 13 16:08:38 2024] EXT4-fs (mmcblk0p2): mounted filesystem d3104e7d-5f59-47e0-8621-290882475163 ro with ordered data mode. Quota mode: none. [Tue Aug 13 16:08:38 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Tue Aug 13 16:08:39 2024] EXT4-fs (mmcblk0p2): re-mounted d3104e7d-5f59-47e0-8621-290882475163 r/w. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime |-/dev devtmpfs devtmpfs rw,relatime,size=1726396k,nr_inodes=34271,mode=755 | |-/dev/shm tmpfs tmpfs rw,nosuid,nodev | |-/dev/pts devpts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 | `-/dev/mqueue mqueue mqueue rw,nosuid,nodev,noexec,relatime |-/proc proc proc rw,relatime | `-/proc/sys/fs/binfmt_misc systemd-1 autofs rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct |-/sys sysfs sysfs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/security securityfs securityfs rw,nosuid,nodev,noexec,relatime | |-/sys/fs/cgroup cgroup2 cgroup2 rw,nosuid,nodev,noexec,relatime | |-/sys/fs/pstore pstore pstore rw,nosuid,nodev,noexec,relatime | |-/sys/fs/bpf bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700 | |-/sys/kernel/tracing tracefs tracefs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/debug debugfs debugfs rw,nosuid,nodev,noexec,relatime | |-/sys/kernel/config configfs configfs rw,nosuid,nodev,noexec,relatime | `-/sys/fs/fuse/connections fusectl fusectl rw,nosuid,nodev,noexec,relatime |-/run tmpfs tmpfs rw,nosuid,nodev,size=795828k,nr_inodes=819200,mode=755 | |-/run/lock tmpfs tmpfs rw,nosuid,nodev,noexec,relatime,size=5120k | |-/run/rpc_pipefs sunrpc rpc_pipefs rw,relatime | `-/run/user/1000 tmpfs tmpfs rw,nosuid,nodev,relatime,size=397912k,nr_inodes=99478,mode=700,uid=1000,gid=1000 |-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro `-/var/lib/lxcfs lxcfs fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other Files in neuralgic directories: /var: du: cannot access '/var/lib/lxcfs/cgroup': Input/output error 4.7G /var/ 3.3G /var/log 2.9G /var/log/journal/6462312882a642219bbda7aff5f4f5b9 2.9G /var/log/journal 738M /var/lib Archived and active journals take up 2.8G in the file system. /opt/iobroker/backups: 82M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 746M /opt/iobroker/iobroker-data/ 594M /opt/iobroker/iobroker-data/files 441M /opt/iobroker/iobroker-data/files/javascript.admin 409M /opt/iobroker/iobroker-data/files/javascript.admin/static 408M /opt/iobroker/iobroker-data/files/javascript.admin/static/js The five largest files in iobroker-data are: 27M /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map 24M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map 13M /opt/iobroker/iobroker-data/states.jsonl 9.6M /opt/iobroker/iobroker-data/objects.jsonl 8.7M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' *** NodeJS-Installation *** /usr/bin/nodejs v20.16.0 /usr/bin/node v20.16.0 /usr/bin/npm 10.8.1 /usr/bin/npx 10.8.1 /usr/bin/corepack 0.28.2 nodejs: Installed: 20.16.0-1nodesource1 Candidate: 20.16.0-1nodesource1 Version table: *** 20.16.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 100 /var/lib/dpkg/status 20.15.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.15.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.14.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.13.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.13.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.12.2-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.12.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.12.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.11.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.11.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.10.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.9.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.8.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.8.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.7.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.6.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.6.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.5.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.5.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.4.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.3.1-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.3.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.2.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.1.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 20.0.0-1nodesource1 600 500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages 12.22.12~dfsg-1~deb11u4 500 500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages Temp directories causing npm8 problem: 0 No problems detected Errors in npm tree: *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 5.0.19 admin: 7.0.22 javascript: 8.7.6 nodejs modules from github: 1 +-- iobroker.vw-connect@0.5.3 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#b5fbfb41f65b8a1efb646e9efb68f1cbd1627d27) Adapter State + system.adapter.admin.0 : admin : iobroker-pi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : iobroker-pi - enabled + system.adapter.backitup.0 : backitup : iobroker-pi - enabled + system.adapter.device-reminder.0 : device-reminder : iobroker-pi - enabled + system.adapter.discovery.0 : discovery : iobroker-pi - enabled + system.adapter.ems-esp.0 : ems-esp : iobroker-pi - enabled + system.adapter.fb-checkpresence.0 : fb-checkpresence : iobroker-pi - enabled system.adapter.habpanel.0 : habpanel : iobroker-pi - enabled + system.adapter.history.0 : history : iobroker-pi - enabled + system.adapter.hm-rega.0 : hm-rega : iobroker-pi - enabled + system.adapter.hm-rpc.0 : hm-rpc : iobroker-pi - enabled, port: 18701 system.adapter.hm-rpc.1 : hm-rpc : iobroker-pi - enabled, port: 12001 system.adapter.hm-rpc.2 : hm-rpc : iobroker-pi - enabled, port: 12010 + system.adapter.influxdb.0 : influxdb : iobroker-pi - enabled, port: 8086 system.adapter.info.0 : info : iobroker-pi - enabled + system.adapter.javascript.0 : javascript : iobroker-pi - enabled + system.adapter.mqtt.0 : mqtt : iobroker-pi - enabled, port: 1883, bind: 192.168.178.10 system.adapter.netatmo-crawler.0 : netatmo-crawler : iobroker-pi - enabled + system.adapter.rpi2.0 : rpi2 : iobroker-pi - enabled + system.adapter.shelly.0 : shelly : iobroker-pi - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : iobroker-pi - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.tr-064.0 : tr-064 : iobroker-pi - enabled system.adapter.tuya.0 : tuya : iobroker-pi - disabled + system.adapter.vw-connect.0 : vw-connect : iobroker-pi - enabled system.adapter.weatherunderground.0 : weatherunderground : iobroker-pi - disabled + system.adapter.web.0 : web : iobroker-pi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.whatsapp-cmb.0 : whatsapp-cmb : iobroker-pi - enabled + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker-pi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hm-rpc.0 : hm-rpc : iobroker-pi - enabled, port: 18701 system.adapter.hm-rpc.1 : hm-rpc : iobroker-pi - enabled, port: 12001 system.adapter.hm-rpc.2 : hm-rpc : iobroker-pi - enabled, port: 12010 + system.adapter.influxdb.0 : influxdb : iobroker-pi - enabled, port: 8086 + system.adapter.mqtt.0 : mqtt : iobroker-pi - enabled, port: 1883, bind: 192.168.178.10 + system.adapter.shelly.0 : shelly : iobroker-pi - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.simple-api.0 : simple-api : iobroker-pi - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : iobroker-pi - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 7.0.22 , installed 7.0.22 Adapter "alexa2" : 3.26.5 , installed 3.26.5 Adapter "backitup" : 3.0.16 , installed 3.0.16 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "discovery" : 4.5.0 , installed 4.5.0 Adapter "ems-esp" : 3.5.0 , installed 3.5.0 Adapter "fb-checkpresence": 1.2.4 , installed 1.2.4 Adapter "habpanel" : 0.5.0 , installed 0.5.0 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "hm-rega" : 4.0.0 , installed 4.0.0 Adapter "hm-rpc" : 1.17.0 , installed 1.17.0 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "javascript" : 8.7.6 , installed 8.7.6 Controller "js-controller": 6.0.9 , installed 5.0.19 [Updatable] Adapter "mqtt" : 5.2.0 , installed 5.2.0 Adapter "netatmo-crawler": 0.8.1 , installed 0.8.1 Adapter "rpi2" : 1.3.2 , installed 1.3.2 Adapter "shelly" : 7.0.0 , installed 7.0.0 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "socketio" : 6.7.1 , installed 6.7.1 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "tuya" : 3.15.0 , installed 3.15.0 Adapter "weatherunderground": 3.7.0, installed 3.7.0 Adapter "web" : 6.2.5 , installed 6.2.5 Adapter "whatsapp-cmb" : 0.3.0 , installed 0.3.0 Adapter "ws" : 2.6.2 , installed 2.6.2 Objects and States Please stand by - This may take a while Objects: 7430 States: 6279 *** OS-Repositories and Updates *** Hit:1 https://repos.influxdata.com/debian bullseye InRelease Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease Hit:5 https://apt.pivccu.de/piVCCU stable InRelease Hit:6 https://packages.grafana.com/oss/deb stable InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 10.0.3.1:53 0.0.0.0:* LISTEN 0 6228 814/dnsmasq tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 6194 785/sshd: /usr/sbin tcp 0 0 192.168.178.10:12001 0.0.0.0:* LISTEN 1001 39110 5590/io.hm-rpc.1 tcp 0 0 192.168.178.10:12010 0.0.0.0:* LISTEN 1001 36706 5591/io.hm-rpc.2 tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 9377 1407/io.shelly.0 tcp 0 0 192.168.178.10:1883 0.0.0.0:* LISTEN 1001 8528 1324/io.mqtt.0 tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 7195 905/iobroker.js-con tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 5644 905/iobroker.js-con tcp 0 0 127.0.0.1:8088 0.0.0.0:* LISTEN 999 6272 730/influxd tcp6 0 0 :::22 :::* LISTEN 0 6196 785/sshd: /usr/sbin tcp6 0 0 :::3000 :::* LISTEN 111 5642 904/grafana tcp6 0 0 :::8086 :::* LISTEN 999 6362 730/influxd tcp6 0 0 :::8087 :::* LISTEN 1001 6952 1464/io.simple-api. tcp6 0 0 :::8082 :::* LISTEN 1001 7769 1483/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1001 7239 990/io.admin.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 787 337/avahi-daemon: r udp 0 0 0.0.0.0:47656 0.0.0.0:* 108 789 337/avahi-daemon: r udp 0 0 10.0.3.1:53 0.0.0.0:* 0 6227 814/dnsmasq udp 0 0 0.0.0.0:67 0.0.0.0:* 0 6224 814/dnsmasq udp 0 0 0.0.0.0:68 0.0.0.0:* 0 897 598/dhclient udp6 0 0 :::5353 :::* 108 788 337/avahi-daemon: r udp6 0 0 :::34059 :::* 108 790 337/avahi-daemon: r *** Log File - Last 25 Lines *** 2024-08-13 16:21:48.384 - info: hm-rpc.2 (4770) Terminated (NO_ERROR): Without reason 2024-08-13 16:21:49.099 - info: host.iobroker-pi instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR) 2024-08-13 16:21:49.099 - info: host.iobroker-pi Restart adapter system.adapter.hm-rpc.1 because enabled 2024-08-13 16:21:49.099 - info: host.iobroker-pi instance system.adapter.hm-rpc.2 terminated with code 0 (NO_ERROR) 2024-08-13 16:21:49.100 - info: host.iobroker-pi Restart adapter system.adapter.hm-rpc.2 because enabled 2024-08-13 16:21:49.884 - info: hm-rpc.0 (5004) starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.16.0, js-controller: 5.0.19 2024-08-13 16:21:50.185 - info: hm-rpc.0 (5004) binrpc server is trying to listen on 192.168.178.10:18701 2024-08-13 16:21:50.187 - info: hm-rpc.0 (5004) binrpc client is trying to connect to 192.168.178.12:8701/ with ["xmlrpc_bin://192.168.178.10:18701","iobroker-pi:hm-rpc.0:586ced57dee52ef270bfb61be9f07a73"] 2024-08-13 16:21:50.457 - error: hm-rpc.0 (5004) Init not possible, going to stop: connect EHOSTUNREACH 192.168.178.12:8701 2024-08-13 16:21:50.461 - error: hm-rega.0 (1231) CCU 192.168.178.12 unreachable 2024-08-13 16:22:19.230 - info: host.iobroker-pi instance system.adapter.hm-rpc.1 started with pid 5590 2024-08-13 16:22:19.243 - info: host.iobroker-pi instance system.adapter.hm-rpc.2 started with pid 5591 2024-08-13 16:22:20.462 - info: hm-rpc.0 (5004) binrpc -> 192.168.178.12:8701/ init ["xmlrpc_bin://192.168.178.10:18701",""] 2024-08-13 16:22:20.481 - error: hm-rpc.0 (5004) Cannot call init: [xmlrpc_bin://192.168.178.10:18701, ""] Socket closed before the connection was established 2024-08-13 16:22:20.542 - info: hm-rpc.0 (5004) terminating 2024-08-13 16:22:20.544 - info: hm-rpc.0 (5004) Terminated (NO_ERROR): Without reason 2024-08-13 16:22:21.115 - info: host.iobroker-pi instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR) 2024-08-13 16:22:23.573 - error: hm-rega.0 (1231) CCU 192.168.178.12 unreachable 2024-08-13 16:22:21.116 - info: host.iobroker-pi Restart adapter system.adapter.hm-rpc.0 because enabled 2024-08-13 16:22:25.483 - info: hm-rpc.1 (5590) starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.16.0, js-controller: 5.0.19 2024-08-13 16:22:25.516 - info: hm-rpc.2 (5591) starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.16.0, js-controller: 5.0.19 2024-08-13 16:22:25.834 - info: hm-rpc.1 (5590) xmlrpc server is trying to listen on 192.168.178.10:12001 2024-08-13 16:22:25.835 - info: hm-rpc.1 (5590) xmlrpc client is trying to connect to 192.168.178.12:2001/ with ["http://192.168.178.10:12001","iobroker-pi:hm-rpc.1:b7e0bbb00b214da627cd2ac33e1e6a94"] 2024-08-13 16:22:25.863 - info: hm-rpc.2 (5591) xmlrpc server is trying to listen on 192.168.178.10:12010 2024-08-13 16:22:25.865 - info: hm-rpc.2 (5591) xmlrpc client is trying to connect to 192.168.178.12:2010/ with ["http://192.168.178.10:12010","iobroker-pi:hm-rpc.2:53dc961ed27d3c18a140cba29ed780cc"]
Ist es besser?
Wie Du vielleicht selbst siehst - nein
@djmarc75 sagte in pivCCU nach Update node.js nicht erreichbar:
Ist es besser?
jetzt, ja!
im ersten hab ich nicht alle versteckten code-tags finden und fixen können
EDIT: Jetzt aber!
@thomas-braun sagte in pivCCU nach Update node.js nicht erreichbar:
ausgeführt
Dann ist ioBroker-seitig jetzt alles i.O.
@wibear sagte:
FAILED SERVICES UNIT LOAD ACTIVE SUB DESCRIPTION pivccu-dkms.service loaded failed failed piVCCU DKMS Modules pivccu-rpi-modules.service loaded failed failed piVCCU RPi Kernel loader
Das hat nichts mit Node.js oder ioBroker zu tun.
@paul53 Was könnte der Grund für FailedServices sein?
systemctl status pivccu-dkms.service systemctl status pivccu-rpi-modules.service
könnte dir das vielleicht verraten. Ansonsten wäre das ein Fall für die Kollegen eine Tür weiter bei pivCCU.
oder mal mit
sudo pivccu-info
nachsehen -
pivCCU zeigt State: STOPPED
Kann ich das starten? -
Das zeigt aber mit Sicherheit noch mehr...
sudo systemctl start pivccu-dkms.service sudo systemctl start pivccu-rpi-modules.service
systemctl status pivccu-rpi-modules.service ● pivccu-rpi-modules.service - piVCCU RPi Kernel loader Loaded: loaded (/lib/systemd/system/pivccu-rpi-modules.service; enabled; v> Active: failed (Result: exit-code) since Tue 2024-08-13 16:08:45 CEST; 36m> Process: 727 ExecStart=/var/lib/piVCCU/rpi-modules/ensure_headers.sh (code=> Main PID: 727 (code=exited, status=1/FAILURE) CPU: 15ms Aug 13 16:08:45 iobroker-pi systemd[1]: Starting piVCCU RPi Kernel loader... Aug 13 16:08:45 iobroker-pi ensure_headers.sh[727]: Could not determine kernel > Aug 13 16:08:45 iobroker-pi systemd[1]: pivccu-rpi-modules.service: Main proces> Aug 13 16:08:45 iobroker-pi systemd[1]: pivccu-rpi-modules.service: Failed with> Aug 13 16:08:45 iobroker-pi systemd[1]: Failed to start piVCCU RPi Kernel loade>
An wen kann ich mich mit pivCCU wenden?
Hilft es, ein pivCCU Backup einzuspielen? -
sudo systemctl start pivccu-dkms.service Job for pivccu-dkms.service failed because the control process exited with error code. See "systemctl status pivccu-dkms.service" and "journalctl -xe" for details.
