    4. pivCCU nach Update node.js nicht erreichbar
    • Ro75
      Ro75 @Homoran last edited by
      @homoran sagte in pivCCU nach Update node.js nicht erreichbar:
      aber erst nach dem runterfahren den Stecker ziehen
      sollte nach 1 Mio. Ausführungen eigentlich klar sein. 😬
      Ro75.
        wibear @Homoran last edited by
        @homoran; @Ro75
        Immer noch dasselbe:
        systemctl status pivccu-dkms.service
        ● pivccu-dkms.service - piVCCU DKMS Modules
             Loaded: loaded (/lib/systemd/system/pivccu-dkms.service; enabled; vendor p>
             Active: failed (Result: exit-code) since Tue 2024-08-13 18:55:50 CEST; 5mi>
            Process: 814 ExecStart=/var/lib/piVCCU/dkms/ensure_modules.sh (code=exited,>
           Main PID: 814 (code=exited, status=1/FAILURE)
                CPU: 713ms
        Aug 13 18:55:48 iobroker-pi systemd[1]: Starting piVCCU DKMS Modules...
        Aug 13 18:55:50 iobroker-pi ensure_modules.sh[814]: Remove DKMS package ... FAI>
        Aug 13 18:55:50 iobroker-pi ensure_modules.sh[814]: Error! There is no instance>
        Aug 13 18:55:50 iobroker-pi ensure_modules.sh[814]: for kernel 6.6.45-v7l+ (arm>
        Aug 13 18:55:50 iobroker-pi systemd[1]: pivccu-dkms.service: Main process exite>
        Aug 13 18:55:50 iobroker-pi systemd[1]: pivccu-dkms.service: Failed with result>
        Aug 13 18:55:50 iobroker-pi systemd[1]: Failed to start piVCCU DKMS Modules.
        lines 1-14/14 (END)
             Loaded: loaded (/lib/systemd/system/pivccu-dkms.service; enabled; vendor preset: enabled)
             Active: failed (Result: exit-code) since Tue 2024-08-13 18:55:50 CEST; 5min ago
            Process: 814 ExecStart=/var/lib/piVCCU/dkms/ensure_modules.sh (code=exited, status=1/FAILURE)
                CPU: 713ms
        Aug 13 18:55:50 iobroker-pi ensure_modules.sh[814]: Remove DKMS package ... FAILED
        Aug 13 18:55:50 iobroker-pi ensure_modules.sh[814]: Error! There is no instance of pivccu 1.0.84
        Aug 13 18:55:50 iobroker-pi ensure_modules.sh[814]: for kernel 6.6.45-v7l+ (armv7l) located in the DKMS tree.
        Aug 13 18:55:50 iobroker-pi systemd[1]: pivccu-dkms.service: Main process exited, code=exited, status=1/FAILURE
        Aug 13 18:55:50 iobroker-pi systemd[1]: pivccu-dkms.service: Failed with result 'exit-code'.
          Homoran Global Moderator Administrators @wibear last edited by
          @wibear sagte in pivCCU nach Update node.js nicht erreichbar:
          hattest du ein Betriebssystem Update gefahren, das ggf. gestört wurde?
            Ich habe raspi-update ausgeführt, es lief aber ohne Probleme.
              Thomas Braun Most Active @wibear last edited by
              Jaja... Damit knallst du dir aber den offiziellen Kernel weg. Und die pivCCU-Kernelmodule laufen so erst mal nur mit dem offiziellen.
              Finger weg von raspi-update! Das ist NICHT der Weg sein System aktuell zu halten!
                oooh!
                da bin ich jetzt überfragt, ob du dir damit nicht ins Knie geschossen hast.
                Wahrscheinlich musst du jetzt eine Installation für Bookworm machen.
                Möglicherweise sind die komplexen Änderungen jetzt bei dir schon in PiOS 11 drin.
                Thomas Braun W 2 Replies Last reply Reply Quote 0
                  Zu genau dem Fall gibt es drüben bei pivCCU aber in der Installationsanleitung was.
                  Hab ich eben gelesen.
                    Aber was kann ich jetzt tun?
                    Ich hab noch ein Image iob und Raspi vor 6 Monaten nach der Installation sowie Backups der letzten Woche.
                      @wibear
                      sieh mal da nach was dazu dort steht
                      @thomas-braun sagte in pivCCU nach Update node.js nicht erreichbar:
                      Kann ich da ein downgrade machen?
                      Du solltest eher ein Upgrade der pivCCU-Pakete machen, wenn es denn welche gibt.
                      Hier gibt es aber ein paar Hinweise, was man da machen kann:
                      https://alexreinert.github.io/piVCCU/docs/setup/raspberrypi.html
                        Nach diesen Hinweisen habe ich ausgeführt, aber alles war bei mir aktuell.
                        Was ist, wenn ich ein funktionierendes Image nach der Installation und dann die aktuellen Backups einspiele?
                          @wibear
                          Das unter
                          Migrating from custom kernel to original Raspbian kernel with custom modules and device tree overlay
                          hast du gemacht?
                          Das installiert nämlich den zu deinen pivccu-Kernelmodulen passenden Kernel wieder.
                          Reboot danach unbedingt erforderlich!
                            wibear @Thomas Braun last edited by
                            Migrating from custom kernel habe ich ausgeführt, es wurde aber laut log nichts zu updaten gegeben.
                              @wibear
                              Da wird auch nix upgedatet, da wird eher downgegraded (und der Paketmanager wieder in den Sattel gehoben).
                                @thomas-braun @Homoran @Ro75
                                Guten Morgen zusammen, vielen Dank für Eure Unterstützung. Es lag an raspi-update und AlexReinert hat mir geholfen, es i.O. zu bringen. Viele Grüße
                                2374
