    4. Anzahl der Objekte Unterscheidet sich im Admin vs. IOB Diag
      Adnim @arteck last edited by
      @arteck sagte in Anzahl der Objekte Unterscheidet sich im Admin vs. IOB Diag:
      ist dann immer noch ein schiefstand ?
      ja ist unverändert.
      Objects: 10515
      States: 46359
      vs
      Objekte: 10522, Zustände: 8846
      Skript v.2024-05-22
      *** BASE SYSTEM ***
       Static hostname: iobroker1
             Icon name: computer-container
               Chassis: container
        Virtualization: lxc
      Operating System: Ubuntu 22.04.4 LTS
                Kernel: Linux 6.8.12-1-pve
          Architecture: x86-64
      model name      : Intel(R) Core(TM) i7-7567U CPU @ 3.50GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       09:24:39 up 3 days,  1:58,  2 users,  load average: 0.49, 0.58, 0.35
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Wed 2024-08-14 09:24:39 CEST
                 Universal time: Wed 2024-08-14 07:24:39 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      christoph
      HOME=/home/christoph
      GROUPS=christoph adm sudo iobroker
      js-controller is not running
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:             15G        261M         14G        0.0K        1.1G         15G
      Swap:           8.2G          0B        8.2G
      Total:           23G        261M         22G
      Active iob-Instances:   2
              15500 M total memory
                261 M used memory
                250 M active memory
                889 M inactive memory
              14133 M free memory
                  0 M buffer memory
               1104 M swap cache
               8191 M total swap
                  0 M used swap
               8191 M free swap
      top - 09:24:39 up 3 days,  1:58,  2 users,  load average: 0.49, 0.58, 0.35
      Tasks:  28 total,   1 running,  27 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  15500.0 total,  14133.6 free,    262.1 used,   1104.3 buff/cache
      MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.  15237.8 avail Mem
      *** FAILED SERVICES ***
        UNIT                     LOAD   ACTIVE SUB    DESCRIPTION
      * apparmor.service         loaded failed failed Load AppArmor profiles
      * iobroker.service         loaded failed failed ioBroker Server
      * systemd-sysusers.service loaded failed failed Create System Users
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      3 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                       Type   Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--104--disk--0 ext4    63G   14G   46G  24% /
      none                             tmpfs  492K  4.0K  488K   1% /dev
      tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
      tmpfs                            tmpfs  3.2G  116K  3.2G   1% /run
      tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
      tmpfs                            tmpfs  1.6G     0  1.6G   0% /run/user/1000
      [Sun Aug 11 07:25:04 2024] EXT4-fs (dm-1): mounted filesystem 665bdbd3-7a9d-46d2-9afa-de180c0ccfc9 ro with ordered data mode. Quota mode: none.
      [Sun Aug 11 07:25:09 2024] EXT4-fs (dm-1): re-mounted 665bdbd3-7a9d-46d2-9afa-de180c0ccfc9 r/w. Quota mode: none.
      [Sun Aug 11 07:25:44 2024] EXT4-fs (dm-11): mounted filesystem 32f046e3-22f9-4048-8ceb-3fff80bfc146 r/w with ordered data mode. Quota mode: none.
      [Sun Aug 11 07:25:50 2024] EXT4-fs (dm-13): mounted filesystem a272216f-1dc4-4d89-8106-e180ffbd5bb5 r/w with ordered data mode. Quota mode: none.
      [Sun Aug 11 07:26:02 2024] EXT4-fs (dm-12): mounted filesystem 4adb5760-eb08-44c1-b51b-6d3cc66727aa r/w with ordered data mode. Quota mode: none.
      Show mounted filesystems:
      TARGET                                SOURCE                           FSTYPE     OPTIONS
      /                                     /dev/mapper/pve-vm--104--disk--0 ext4       rw,relatime,stripe=16
      |-/dev                                none                             tmpfs      rw,relatime,size=492k,mode=755,inode64
      | |-/dev/mqueue                       mqueue                           mqueue     rw,relatime
      | |-/dev/pts                          devpts                           devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
      | |-/dev/ptmx                         devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
      | |-/dev/lxc/console                  devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
      | |-/dev/console                      devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
      | |-/dev/lxc/tty1                     devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
      | |-/dev/lxc/tty2                     devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
      | |-/dev/shm                          tmpfs                            tmpfs      rw,nosuid,nodev,inode64
      | `-/dev/hugepages                    hugetlbfs                        hugetlbfs  rw,relatime,pagesize=2M
      |-/proc                               proc                             proc       rw,nosuid,nodev,noexec,relatime
      | |-/proc/sys                         proc[/sys]                       proc       ro,relatime
      | | |-/proc/sys/kernel/random/boot_id none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,inode64
      | | `-/proc/sys/net                   proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
      | |-/proc/sysrq-trigger               proc[/sysrq-trigger]             proc       ro,relatime
      | |-/proc/cpuinfo                     lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/diskstats                   lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/loadavg                     lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/meminfo                     lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/slabinfo                    lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/stat                        lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/swaps                       lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | `-/proc/uptime                      lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      |-/sys                                sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections          fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
      | |-/sys/devices/virtual/net          sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/debug                 debugfs                          debugfs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security              securityfs                       securityfs rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/pstore                    pstore                           pstore     rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                    none                             cgroup2    rw,nosuid,nodev,noexec,relatime
      | `-/sys/devices/system/cpu           lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      `-/run                                tmpfs                            tmpfs      rw,nosuid,nodev,size=3253548k,nr_inodes=819200,mode=755,inode64
        |-/run/lock                         tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
        `-/run/user/1000                    tmpfs                            tmpfs      rw,nosuid,nodev,relatime,size=1626772k,nr_inodes=406693,mode=700,uid=1000,gid=1000,inode64
      /var:
      2.2G    /var/
      1.6G    /var/log
      1.5G    /var/log/journal/b354c482f7cc342776f020ee5ea440c3
      350M    /var/cache
      Archived and active journals take up 1.4G in the file system.
      /opt/iobroker/backups:
      27M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      929M    /opt/iobroker/iobroker-data/
      745M    /opt/iobroker/iobroker-data/files
      493M    /opt/iobroker/iobroker-data/files/javascript.admin
      461M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      460M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      19M     /opt/iobroker/iobroker-data/objects.json
      19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.1d90720e.js.map
      16M     /opt/iobroker/iobroker-data/objects.jsonl
      15M     /opt/iobroker/iobroker-data/states.json
      13M     /opt/iobroker/iobroker-data/states.jsonl
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.16.0
      /usr/bin/node           v20.16.0
      /usr/bin/npm            10.8.1
      /usr/bin/npx            10.8.1
      /usr/bin/corepack       0.28.2
      nodejs:
        Installed: 20.16.0-1nodesource1
        Candidate: 20.16.0-1nodesource1
        Version table:
       *** 20.16.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           12.22.9~dfsg-1ubuntu3.6 500
              500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
              500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
           12.22.9~dfsg-1ubuntu3 500
              500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.10
      admin:          7.0.23
      javascript:     8.8.2
      nodejs modules from github:     0
      Adapter State
        system.adapter.admin.0                  : admin                 : iobroker1                                -  enabled, port: 8081, bind: 192.165.175.15, run as: admin
        system.adapter.alexa2.0                 : alexa2                : iobroker1                                -  enabled
        system.adapter.cloud.0                  : cloud                 : iobroker1                                - disabled
        system.adapter.device-reminder.0        : device-reminder       : iobroker1                                -  enabled
        system.adapter.device-watcher.0         : device-watcher        : iobroker1                                -  enabled
        system.adapter.discovery.0              : discovery             : iobroker1                                - disabled
        system.adapter.dwd.0                    : dwd                   : iobroker1                                -  enabled
        system.adapter.eusec.0                  : eusec                 : iobroker1                                - disabled
        system.adapter.feiertage.0              : feiertage             : iobroker1                                -  enabled
        system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker1                                -  enabled
        system.adapter.hm-rega.0                : hm-rega               : iobroker1                                -  enabled
        system.adapter.hm-rpc.0                 : hm-rpc                : iobroker1                                -  enabled, port: 0
        system.adapter.hm-rpc.1                 : hm-rpc                : iobroker1                                -  enabled, port: 0
        system.adapter.hm-rpc.3                 : hm-rpc                : iobroker1                                -  enabled, port: 0
        system.adapter.homeconnect.0            : homeconnect           : iobroker1                                -  enabled
        system.adapter.hue.0                    : hue                   : iobroker1                                -  enabled, port: 443
        system.adapter.hue.1                    : hue                   : iobroker1                                -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : iobroker1                                -  enabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker1                                - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker1                                - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : iobroker1                                - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker1                                - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker1                                - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker1                                - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker1                                - disabled
        system.adapter.jarvis.0                 : jarvis                : iobroker1                                -  enabled
        system.adapter.javascript.0             : javascript            : iobroker1                                -  enabled
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker1                                -  enabled, port: 54321
        system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: iobroker1                                -  enabled
      + system.adapter.radar2.0                 : radar2                : iobrokerraspi                            -  enabled
        system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker1                                -  enabled
        system.adapter.simple-api.0             : simple-api            : iobroker1                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.socketio.0               : socketio              : iobroker1                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker1                                -  enabled
        system.adapter.telegram.0               : telegram              : iobroker1                                -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.trashschedule.0          : trashschedule         : iobroker1                                -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker1                                - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker1                                - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker1                                - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker1                                - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker1                                -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker1                                - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker1                                - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker1                                - disabled
        system.adapter.vis-material.0           : vis-material          : iobroker1                                - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker1                                - disabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker1                                - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker1                                - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker1                                - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker1                                - disabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker1                                - disabled
        system.adapter.vis.0                    : vis                   : iobroker1                                -  enabled
        system.adapter.weather-warnings.0       : weather-warnings      : iobroker1                                -  enabled
        system.adapter.web.0                    : web                   : iobroker1                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 7.0.23   , installed 7.0.23
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "eusec"        : 1.2.1    , installed 1.2.1
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "heatingcontrol": 2.12.8  , installed 2.12.8
      Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
      Adapter    "hm-rpc"       : 2.0.0    , installed 2.0.0
      Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
      Adapter    "hue"          : 3.12.0   , installed 3.12.0
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 8.8.2    , installed 8.8.2
      Controller "js-controller": 6.0.10   , installed 6.0.10
      Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
      Adapter    "panasonic-comfort-cloud": 3.0.2, installed 3.0.2
      Adapter    "radar2"       : 2.2.0    , installed 2.2.0
      Adapter    "shuttercontrol": 1.7.3   , installed 1.7.3
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "weather-warnings": 0.6.7 , installed 0.6.7
      Adapter    "web"          : 6.3.0    , installed 6.3.0
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Objects and States
      Objects:        10515
      States:         46359
      Hit:1 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
      Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18109      204/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          18990      322/master
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        17212      139/systemd-resolve
      tcp6       0      0 :::22                   :::*                    LISTEN      0          18111      204/sshd: /usr/sbin
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          18991      322/master
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        17211      139/systemd-resolve
      2024-08-14 09:20:02.982  - info: host.iobroker1 instance system.adapter.hm-rpc.3 terminated with code 0 (NO_ERROR)
      2024-08-14 09:20:02.997  - info: host.iobroker1 instance system.adapter.device-watcher.0 terminated with code 0 (NO_ERROR)
      2024-08-14 09:20:03.025  - info: host.iobroker1 instance system.adapter.trashschedule.0 terminated with code 0 (NO_ERROR)
      2024-08-14 09:20:03.026  - info: host.iobroker1 instance system.adapter.jarvis.0 terminated with code 0 (NO_ERROR)
      2024-08-14 09:20:03.038  - info: host.iobroker1 instance system.adapter.socketio.0 terminated with code 0 (NO_ERROR)
      2024-08-14 09:20:03.038  - info: host.iobroker1 All instances are stopped.
      2024-08-14 09:20:03.065  - info: host.iobroker1 instance system.adapter.weather-warnings.0 terminated with code 0 (NO_ERROR)
      2024-08-14 09:20:03.065  - info: host.iobroker1 All instances are stopped.
      2024-08-14 09:20:03.065  - info: host.iobroker1 instance system.adapter.device-reminder.0 terminated with code 0 (NO_ERROR)
      2024-08-14 09:20:03.087  - info: host.iobroker1 instance system.adapter.alexa2.0 terminated with code 0 (NO_ERROR)
      2024-08-14 09:20:03.087  - info: host.iobroker1 All instances are stopped.
      2024-08-14 09:20:03.133  - warn: host.iobroker1 instance system.adapter.hue.0 terminated due to SIGKILL
      2024-08-14 09:20:03.133  - info: host.iobroker1 instance system.adapter.hue.0 terminated with code null ()
      2024-08-14 09:20:03.139  - info: host.iobroker1 All instances are stopped.
      2024-08-14 09:20:03.139  - warn: host.iobroker1 instance system.adapter.hue.1 terminated due to SIGKILL
      2024-08-14 09:20:03.139  - info: host.iobroker1 instance system.adapter.hue.1 terminated with code null ()
      2024-08-14 09:20:03.158  - warn: host.iobroker1 instance system.adapter.web.0 terminated due to SIGKILL
      2024-08-14 09:20:03.158  - info: host.iobroker1 instance system.adapter.web.0 terminated with code null ()
      2024-08-14 09:20:03.158  - info: host.iobroker1 All instances are stopped.
      2024-08-14 09:20:03.170  - warn: host.iobroker1 instance system.adapter.telegram.0 terminated due to SIGKILL
      2024-08-14 09:20:03.170  - info: host.iobroker1 instance system.adapter.telegram.0 terminated with code null ()
      2024-08-14 09:20:03.170  - info: host.iobroker1 All instances are stopped.
      2024-08-14 09:20:03.329  - info: host.iobroker1 terminated
      • MartinP
        MartinP @Thomas Braun last edited by
        @thomas-braun Ich dachte, die Objekte und Zustände wären das statische Abbild der Iobroker - Welt, die man sich aufgebaut hat. States und Objekte dürfen sich ändern, aber die "Landkarte" muss gleich bleiben.
        Wenn für mich als Anwender Objekte und Zustände auftauchen und wieder verschwinden, hinterlässt das ein ungutes Gefühl.
        Es könnte z.b. ein alias Erzeugt werden, das das abendliche Einschalten der Außenbeleuchtung mit der Ansteuerung des Haustürschlosses verknüpft.
          Thomas Braun Most Active @MartinP last edited by
          @martinp sagte in Anzahl der Objekte Unterscheidet sich im Admin vs. IOB Diag:
          Das ist aber das grundlegende Prinzip des ioBrokers. Insbesondere die States ändern sich 'am laufenden Band', die Objekte natürlich nicht so schnell.
          • haus-automatisierung
            haus-automatisierung Developer Most Active @Adnim last edited by
            @adnim sagte in Anzahl der Objekte Unterscheidet sich im Admin vs. IOB Diag:
            ja ist unverändert.
            Objects: 10515
            States: 46359
            Rein technisch ist es ja gar nicht möglich, dass man mehr States als Objekte hat. Jeder State braucht ja ein zugehöriges State-Objekt.
            Bei jsonl werden ja immer mehr States hinten angehängt und irgendwann komprimiert. Eventuell zählt also das CLI falsch bzw. auch die doppelten Einträge.
              Homoran Global Moderator Administrators @haus-automatisierung last edited by
              @haus-automatisierung sagte in Anzahl der Objekte Unterscheidet sich im Admin vs. IOB Diag:
              Deswegen ja
              @homoran sagte in Anzahl der Objekte Unterscheidet sich im Admin vs. IOB Diag:
              ....oder states ohne Objekte......
              wer weiß wie viele Installationen noch unterwegs sind in denen die states ohne Objekte angelegt wurden
                haus-automatisierung Developer Most Active @Homoran last edited by
                Wie soll das gehen?
                  Wie soll das gehen?
                  frag mich nicht!
                  War anscheinend früher möglich.
                  Irgendwann gab's dann eine Meldung, dass kein Objekt existiert.
                    Thomas Braun Most Active @Homoran last edited by Thomas Braun
                    Auf meiner Kiste macht es auch keinen Unterschied, ob Doubletten herausgefiltert werden (geht mit uniq) :
                    echad@chet:~ $ iob list states 2>/dev/null | uniq | wc -l
                    9020
                    echad@chet:~ $ iob list states 2>/dev/null | wc -l
                    9020
                    echad@chet:~ $
                    L A 2 Replies Last reply Reply Quote 0
                      Lucky_ESA Developer Most Active @Thomas Braun last edited by
                      Fehlerhafte Objecte und States werden von Vis1 oder Blockly Imports angelegt. Hatte vor 1 Jahr auch das Thema und musste 3 Tage den Fehler suchen. Das sollte aber iob fix jetzt beheben. Vielleicht daher die Differenz.
                        Adnim @Thomas Braun last edited by
                        hier auch nicht
                        christoph@iobroker1:~$ iob list states 2>/dev/null | uniq | wc -l
                        46585
                        christoph@iobroker1:~$ iob list states 2>/dev/null | wc -l
                        46585
                          Thomas Braun Most Active @Adnim last edited by
                          46585
                          Also hat die Liste der States bei dir 46585 Zeilen.
                          Warum die so lang ist und wie der admin die 8846 ermittelt kann ich dir nicht sagen.
                          Auf meinen Testinstallationen kamen immer für mich plausible Werte dabei heraus.
                          • MartinP
                            @thomas-braun dass sich States ÄNDERN sehr ich ein, dass beim Hinzufügen neuer Geräte welche erzeugt werden auch, aber dass das Ganze nicht nachvollziehbar ist nicht...
                            Da ist es doch ziemlich diskriminierend, dass man den User vom im Objektbaum manuell herumfuhrwerken abhalten will 😎😎😎😎
                            2500
