    4. Test Adapter Energiefluss-erweitert v0.8.x GitHub/Latest
    • U66
      U66 @SKB last edited by U66
      @skb
      energiefluss-erweitert.1
      	2024-08-11 15:09:55.954	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      	2024-08-11 15:09:55.953	info	terminating
      	2024-08-11 15:09:55.953	info	Cleared interval for relative values!
      	2024-08-11 15:09:55.951	error	Parameter "id" needs to be of type "string" but type "undefined" has been passed
      	2024-08-11 15:09:55.951	error	Error: Parameter "id" needs to be of type "string" but type "undefined" has been passed at Validator.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/validator.js:129:13) at EnergieflussErweitert.getForeignState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:4538:32) at /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/cjs/lib/common/tools.js:1586:18 at new Promise (<anonymous>) at EnergieflussErweitert.getForeignStateAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/cjs/lib/common/tools.js:1584:12) at EnergieflussErweitert.calculateValue (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:311:29) at sourceRunner (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:828:20) at async EnergieflussErweitert.refreshData (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:845:7) at async EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1522:4)
      	2024-08-11 15:09:55.949	error	unhandled promise rejection: Parameter "id" needs to be of type "string" but type "undefined" has been passed
      	2024-08-11 15:09:55.949	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      SKB 2 Replies Last reply Reply Quote 0
      • SKB
        SKB Developer Most Active @U66 last edited by
        @u66 Schaue ich mir an. Danke!
          ralle @SKB last edited by
          @skb
          Wollte einmal Rückmeldung geben nach meinen Problemen mit dem einspielen der Config bzw. das der Adapter nicht gestartet ist.
          ich hab alles gelöscht und neu eingegeben. kurz vor Ende hatte ich mal einen Neustart des Adapter gemacht und er hatte sich so verhalten wie vorher, er startete nicht mehr. Dann habe ich die Hälfte des neu angelegten mal gelöscht und neu gestartet , das hat funktioniert.
          Danach habe ich den Rest dazugefügt und bis jetzt läuft alles auch nach einem Neustart des Adapters!
          vielen Dank für deine Hilfe SKB, dies ist nicht selbstverständlich, klasse Programmierarbeit!
          U66 SKB 2 Replies Last reply Reply Quote 0
          • U66
            U66 @ralle last edited by
            @ralle said in Test Adapter Energiefluss-erweitert v0.5.x-alpha.x GitHub:
            Das kann aber nicht die Lösung sein ???
            • SKB
              SKB Developer Most Active @ralle last edited by
              @ralle Danke für die Rückmeldung - dies kann aber, wie @U66 schon sagte, nicht die Lösung sein.
              Leider müsst ihr Euch noch 2 Tage gedulden, da ich aktuell in Urlaub bin und mein Laptop seit eben nicht mehr startet 😞
              Homoran U66 2 Replies Last reply Reply Quote 1
                Homoran Global Moderator Administrators @SKB last edited by Homoran
                @skb sagte in Test Adapter Energiefluss-erweitert v0.5.x-alpha.x GitHub:
                dann könnt ihr euch endlich erholen
                SKB 1 Reply Last reply Reply Quote 1
                • SKB
                  SKB Developer Most Active @Homoran last edited by
                  @homoran Machen wir sowieso immer - auch wenn der Laptop starten würde 😉
                  • U66
                    @skb said in Test Adapter Energiefluss-erweitert v0.5.x-alpha.x GitHub:
                    Das ist doch kein Problem,jeder hier ist froh das der Adapter von Dir so gepflegt und weiterentwickelt wird.
                    schönen Resturlaub noch 😊
                    • SKB
                      @u66 Könntest Du die Version von Gihub nochmals drüber installieren. Ich habe zum Testen einmal ein paar Ausgaben zugefügt. Nicht wundern - der Fehler sollte noch bestehen, aber die Ausgabe wären wichtig. Könntest Du diese dann hier einstellen?
                      Danke!
                      U66 1 Reply Last reply Reply Quote 0
                      • U66
                        @skb
                        Bin auch gerade unterwegs, wird erst am Abend
                        U66 1 Reply Last reply Reply Quote 1
                        • U66
                          U66 @U66 last edited by U66
                          @u66 ```
                          energiefluss-erweitert.0
                          	2024-08-15 07:52:50.168	info	terminating
                          web.0
                          	2024-08-15 07:52:50.157	info	socket.io server listening on port 8082
                          web.0
                          	2024-08-15 07:52:50.037	info	starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v18.20.4, js-controller: 6.0.9
                          	2024-08-15 07:52:49.667	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                          	2024-08-15 07:52:49.666	info	terminating
                          	2024-08-15 07:52:49.666	info	Cleared interval for relative values!
                          	2024-08-15 07:52:49.664	error	Error: Parameter "id" needs to be of type "string" but type "undefined" has been passed at Validator.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/validator.js:129:13) at EnergieflussErweitert.getForeignState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:4538:32) at /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/cjs/lib/common/tools.js:1586:18 at new Promise (<anonymous>) at EnergieflussErweitert.getForeignStateAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/cjs/lib/common/tools.js:1584:12) at EnergieflussErweitert.calculateValue (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:311:29) at sourceRunner (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:828:20) at async EnergieflussErweitert.refreshData (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:845:7) at async EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1522:4)
                          	2024-08-15 07:52:49.664	error	Parameter "id" needs to be of type "string" but type "undefined" has been passed
                          	2024-08-15 07:52:49.663	error	unhandled promise rejection: Parameter "id" needs to be of type "string" but type "undefined" has been passed
                          	2024-08-15 07:52:49.663	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          	2024-08-15 07:52:49.662	debug	Value-Settings for Element 466 found! Applying Settings!
                          	2024-08-15 07:52:49.662	debug	Values for: 466 - Using source: 36 rawValue: false Settings: {"threshold":0,"type":"image","source":36,"source_type":"boolean"}
                          	2024-08-15 07:52:49.661	debug	Values for: 205 - Using source: 36 rawValue: false Settings: {"threshold":0,"calculate_kw":"none","decimal_places":0,"convert":false,"type":"text","source":36,"source_option":-1,"source_display":"own_text","subtract":[-1],"add":[-1],"source_type":"boolean","text":""}
                          	2024-08-15 07:52:49.661	debug	Updated through elmSources: {"1":44,"14":0,"15":17910,"16":201,"17":184,"18":385,"19":80,"20":731,"21":0.11,"22":0,"23":3.31,"24":0.5,"25":266,"27":0,"28":0,"29":1,"30":"--:--h","32":0,"33":false,"34":false,"36":false}
                          	2024-08-15 07:52:49.661	debug	Current Value of tuya.0.74500708e09806147e72.1: false - saved Value: undefined
                          	2024-08-15 07:52:49.661	info	Loading initial for tuya.0.74500708e09806147e72.1 with {"val":false,"ack":true,"ts":1723701123604,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1723650417095}
                          	2024-08-15 07:52:49.661	debug	Value of tuya.0.74500708e09806147e72.1 changed! Processing!
                          	2024-08-15 07:52:49.661	debug	Value-Settings for Element 205 found! Applying Settings!
                          • SKB
                            @u66 Das sieht mir nicht nach der neueren Version aus, da eine Menge Info Logs fehlen.
                            Bitte über Benutzerdefiniert via Github Katze installieren, upload machen und dann die Ausgabe posten. Adapter muss nicht auf Debug stehen.
                            • U66
                              @skb
                              	2024-08-15 09:37:53.013	debug	State changed! New value for Source: alpha-ess.0.Realtime.PV_power_string_1 with Value: 770 belongs to Elements: 93,124
                              	2024-08-15 09:37:53.013	debug	Value: 770 is greater than Threshold: 0. Applying Animation!
                              	2024-08-15 09:37:53.013	debug	Animation has a positive factor!
                              	2024-08-15 09:37:53.012	debug	Animation - Settings for Element anim_path_303_387 found! Applying Settings!
                              	2024-08-15 09:37:53.012	debug	Found corresponding animations for ID: alpha-ess.0.Realtime.PV_power_string_1 !Applying!
                              	2024-08-15 09:37:53.012	debug	Values for: 124 - Using source: 16 rawValue: 770 Settings: {"threshold":0,"type":"circle","source":16,"fill_type":-1,"border_type":-1,"source_type":"number"}
                              	2024-08-15 09:37:53.012	debug	Value-Settings for Element 124 found! Applying Settings!
                              	2024-08-15 09:37:52.990	debug	Threshold for: 93 is: 0
                              	2024-08-15 09:37:52.990	debug	Values for: 93 - Using source: 16 rawValue: 770 Settings: {"threshold":0,"calculate_kw":"auto","decimal_places":1,"convert":false,"type":"text","source":16,"source_option":-1,"source_display":"value","subtract":[-1],"add":[-1],"override":{">=0":{"display":"fill","fill":"rgb(26,255,49","unit":" W","value":"val => val.toFixed(0)"},">=1000":{"unit":" kW","value":"val => parseFloat(val/1000).toFixed(2)","display":"fill","fill":"rgb(26,255,49"},">=9995":{"unit":" kW","value":"val => parseFloat(val/1000).toFixed(1)","display":"fill","fill":"rgb(26,255,49"},"<= -9995":{"unit":" kW","value":"val => parseFloat(val*-1/1000).toFixed(1)","display":"fill","fill":"rgb(34,139,34)"},"<= -1000":{"unit":" kW","value":"val => parseFloat(val*-1/1000).toFixed(2)","display":"fill","fill":"rgb(34,139,34)"},"default":{"unit":" W","value":"val => (val*-1).toFixed(0)","display":"fill","fill":"rgb(34,139,34)"}},"source_type":"number","text":"ID 93"}
                              	2024-08-15 09:37:52.990	debug	Gathering override for ID: 93, Value: 770 and Override: {">=0":{"display":"fill","fill":"rgb(26,255,49","unit":" W","value":"val => val.toFixed(0)"},">=1000":{"unit":" kW","value":"val => parseFloat(val/1000).toFixed(2)","display":"fill","fill":"rgb(26,255,49"},">=9995":{"unit":" kW","value":"val => parseFloat(val/1000).toFixed(1)","display":"fill","fill":"rgb(26,255,49"},"<= -9995":{"unit":" kW","value":"val => parseFloat(val*-1/1000).toFixed(1)","display":"fill","fill":"rgb(34,139,34)"},"<= -1000":{"unit":" kW","value":"val => parseFloat(val*-1/1000).toFixed(2)","display":"fill","fill":"rgb(34,139,34)"},"default":{"unit":" W","value":"val => (val*-1).toFixed(0)","display":"fill","fill":"rgb(34,139,34)"}}
                              	2024-08-15 09:37:52.989	debug	Updated through elmSources: {"1":62.4,"14":0,"15":17910,"16":770}
                              	2024-08-15 09:37:52.989	debug	Current Value of alpha-ess.0.Realtime.PV_power_string_1: 770 - saved Value: undefined
                              	2024-08-15 09:37:52.989	info	Loading initial for alpha-ess.0.Realtime.PV_power_string_1 with {"val":770,"ack":true,"ts":1723707460725,"q":0,"from":"system.adapter.alpha-ess.0","user":"system.user.admin","lc":1723707460725}
                              	2024-08-15 09:37:52.989	debug	Value of alpha-ess.0.Realtime.PV_power_string_1 changed! Processing!
                              	2024-08-15 09:37:52.989	debug	Value-Settings for Element 93 found! Applying Settings!
                              • SKB
                                SKB Developer Most Active @U66 last edited by SKB
                                @u66 Bitte den Adapter nicht auf Debug stellen, sondern einfach nur starten! Dann den Inhalt des Startes hier einstellen.
                                Diese Log-Fetzen sind ja völlig aus dem Zusammenhang.
                                • U66
                                  @skb
                                  	2024-08-15 10:03:37.227	info	terminating
                                  	2024-08-15 10:03:36.726	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                  	2024-08-15 10:03:36.725	info	terminating
                                  	2024-08-15 10:03:36.725	info	Cleared interval for relative values!
                                  	2024-08-15 10:03:36.722	error	Parameter "id" needs to be of type "string" but type "undefined" has been passed
                                  	2024-08-15 10:03:36.722	error	Error: Parameter "id" needs to be of type "string" but type "undefined" has been passed at Validator.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/validator.js:129:13) at EnergieflussErweitert.getForeignState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:4538:32) at /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/cjs/lib/common/tools.js:1586:18 at new Promise (<anonymous>) at EnergieflussErweitert.getForeignStateAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/cjs/lib/common/tools.js:1584:12) at EnergieflussErweitert.calculateValue (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:311:29) at sourceRunner (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:828:20) at async EnergieflussErweitert.refreshData (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:845:7) at async EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1522:4)
                                  • SKB
                                    @u66 Da fehlen Info Ausgaben. Sowas wie:
                                    2024-08-15 09:47:55.415 - info: host.ioBroker-master instance system.adapter.energiefluss-erweitert.0 in version "0.5.1-alpha.4" started with pid 1671
                                    2024-08-15 09:47:55.910 - info: energiefluss-erweitert.0 (1671) starting. Version 0.5.1-alpha.4 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v18.17.1, js-controller: 6.0.9
                                    2024-08-15 09:47:55.925 - info: energiefluss-erweitert.0 (1671) Adapter started. Loading config!
                                    2024-08-15 09:47:55.939 - info: energiefluss-erweitert.0 (1671) Sources: {"sonnen.0.status.userSoc":{"id":1,"factor":1,"elmSources":[13,18],"elmAnimations":[],"addSources":[],"subtractSources":[]},"sonnen.0.status.consumption":{"id":2,"factor":1,"elmSources":[7],"elmAnimations":[],"addSources":[],"subtractSources":[]},"sonnen.0.status.gridFeedIn":{"id":3,"factor":1,"elmSources":[19,20],"elmAnimations":["anim_path_5_14","anim_path_14_7"],"addSources":[],"subtractSources":[]},"sonnen.0.status.pacTotal":{"id":4,"factor":1,"elmSources":[16,28],"elmAnimations":["anim_path_5_13","anim_path_13_7"],"addSources":[],"subtractSources":[]},"evcc.0.loadpoint.1.status.chargePower":{"id":5,"factor":1,"elmSources":[23,26],"elmAnimations":["anim_path_7_22"],"addSources":[],"subtractSources":[9]},"evcc.0.loadpoint.1.status.vehicleSoc":{"id":6,"factor":1,"elmSources":[22,27],"elmAnimations":[],"addSources":[],"subtractSources":[]},"sonnen.0.status.production":{"id":7,"factor":1,"elmSources":[2,5,6],"elmAnimations":["anim_path_5_7"],"addSources":[],"subtractSources":[]},"pvforecast.0.summary.energy.today":{"id":8,"factor":1,"elmSources":[31,38,55],"elmAnimations":[],"addSources":[],"subtractSources":[]},"javascript.0.Solar.Produktion.heute":{"id":9,"factor":1,"elmSources":[34,39,54],"elmAnimations":[],"addSources":[],"subtractSources":[]},"energiefluss-erweitert.0.calculation.battery.remaining":{"id":10,"factor":1,"elmSources":[37],"elmAnimations":[],"addSources":[],"subtractSources":[]},"shelly.0.SHPLG-S#DE6919#1.Relay0.Power":{"id":11,"factor":1,"elmSources":[43],"elmAnimations":["anim_path_7_40"],"addSources":[],"subtractSources":[9]},"shelly.0.SHSW-PM#E89F6D847D4C#1.Relay0.Power":{"id":12,"factor":1,"elmSources":[46,48],"elmAnimations":["anim_path_7_45"],"addSources":[],"subtractSources":[9]},"0_userdata.0.Energiefluss_Test.verbrauch":{"id":13,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"0_userdata.0.Energiefluss_Test.Test-String":{"id":14,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"energiefluss-erweitert.0.calculation.battery.remaining_target_DT":{"id":15,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"shelly.0.SHSW-PM#84CCA8AC76BE#1.Relay0.Switch":{"id":16,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"energiefluss-erweitert.0.calculation.consumption.consumption":{"id":17,"factor":1,"elmSources":[9],"elmAnimations":[],"addSources":[],"subtractSources":[]},"sonnen.0.configurations.EM_USOC":{"id":19,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"sonnen.0.configurations.CM_MarketingModuleCapacity":{"id":20,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"shelly.0.SHPLG-S#DE6919#1.Relay0.Switch":{"id":21,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"weatherunderground.0.forecast.0d.iconURL":{"id":"weatherunderground.0.forecast.0d.iconURL","elmSources":["56"]}}
                                    2024-08-15 09:47:55.939 - info: energiefluss-erweitert.0 (1671) Loading initial for sonnen.0.status.userSoc with {"val":0,"ack":true,"ts":1723708073999,"q":0,"from":"system.adapter.sonnen.0","user":"system.user.admin","lc":1723510323475}
                                    Das sind die wichtigen Ausgaben.
                                    • SKB
                                      @u66 Wenn Du nochmal die Version von Github installierst, sollte der Fehler weg sein.
                                      @ralle Dein Fehler sollte damit auch "Geschichte" sein 😉
                                      U66 R 2 Replies Last reply Reply Quote 0
                                      • U66
                                        @skb
                                        Ja haut alles wieder hin.....Danke
                                          tja nun hab ich alles neu gemacht, egal. Lag also nicht mir , hatte ich keinen Fehler gemacht...?
                                          • SKB
                                            @ralle ... Geduld ist eine Tugend 😉
                                            Wenn ein Programm durch den Benutzer abstürzt, hat nicht der Benutzer den Fehler begangen, sondern der Programmierer schlampig gearbeitet oder schlichtweg etwas übersehen 🙂
                                            diagramm energiefluss energiefluss-erweitert vis visualisierung visualization
                                            65
                                            1421
                                            777795
