    4. Betriebssystem-Paket Update
    • Codierknecht
      Codierknecht Developer Most Active last edited by
      @sebaboehm
      Operating System: Raspbian GNU/Linux 10 (buster)
      Ist bereits beerdigt.
      Das kannst Du nur durch eine komplette Neuinstallation fixen.
      Dann am besten gleich ein 64Bit-OS.
      https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
      Also:
      • Backup ziehen
      • neu aufsetzen
      • Backup rein
      • glücklich sein
      S 1 Reply Last reply Reply Quote 2
        sebaboehm @sebaboehm last edited by
        @sebaboehm
        Skript v.2024-05-22
        *** BASE SYSTEM ***
           Static hostname: ioBroker-RasPi4-8GB
                 Icon name: computer
                    Kernel: Linux 5.10.103-v7l+
              Architecture: arm
        Model		: Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : 32 bit
        Systemuptime and Load:
         13:40:43 up 38 min,  1 user,  load average: 0.01, 0.46, 0.87
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Wed 2024-08-14 13:40:43 CEST
                   Universal time: Wed 2024-08-14 11:40:43 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        js-controller is not running
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal: 	tty
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:           7.9G        208M        6.9G        8.0M        807M        7.4G
        Swap:           99M          0B         99M
        Total:         8.0G        208M        7.0G
        Active iob-Instances: 	1
                 7898 M total memory
                  208 M used memory
                  425 M active memory
                  401 M inactive memory
                 6882 M free memory
                  212 M buffer memory
                  595 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        top - 13:40:44 up 38 min,  1 user,  load average: 0.01, 0.46, 0.87
        Tasks: 123 total,   1 running, 122 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  3.0 sy,  0.0 ni, 97.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   7898.7 total,   6882.9 free,    207.9 used,    807.9 buff/cache
        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   7398.9 avail Mem
        *** FAILED SERVICES ***
          UNIT             LOAD   ACTIVE SUB    DESCRIPTION
        * iobroker.service loaded failed failed ioBroker Server
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed. Pass --all to see loaded but inactive units, too.
        To show all installed unit files use 'systemctl list-unit-files'.
        *** FILESYSTEM ***
        /dev/root      ext4       29G   18G   11G  62% /
        devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     3.9G  8.5M  3.9G   1% /run
        tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
        [Wed Aug 14 13:02:21 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:B6:16:58 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Wed Aug 14 13:02:22 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Wed Aug 14 13:02:22 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Wed Aug 14 13:02:25 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        Show mounted filesystems:
        TARGET                                SOURCE         FSTYPE     OPTIONS
        /                                     /dev/mmcblk0p2 ext4       rw,noatime
        |-/dev                                devtmpfs       devtmpfs   rw,relatime,size=3879288k,nr_inodes=74941,mode=755
        | |-/dev/shm                          tmpfs          tmpfs      rw,nosuid,nodev
        | |-/dev/pts                          devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | `-/dev/mqueue                       mqueue         mqueue     rw,relatime
        |-/sys                                sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security              securityfs     securityfs rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup                    tmpfs          tmpfs      ro,nosuid,nodev,noexec,mode=755
        | | |-/sys/fs/cgroup/unified          cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
        | | |-/sys/fs/cgroup/systemd          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
        | | |-/sys/fs/cgroup/net_cls,net_prio cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
        | | |-/sys/fs/cgroup/blkio            cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,blkio
        | | |-/sys/fs/cgroup/freezer          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,freezer
        | | |-/sys/fs/cgroup/cpuset           cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
        | | |-/sys/fs/cgroup/perf_event       cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
        | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
        | | |-/sys/fs/cgroup/devices          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,devices
        | | `-/sys/fs/cgroup/pids             cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,pids
        | |-/sys/fs/bpf                       none           bpf        rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/debug                 debugfs        debugfs    rw,relatime
        | `-/sys/kernel/config                configfs       configfs   rw,relatime
        |-/proc                               proc           proc       rw,relatime
        | `-/proc/sys/fs/binfmt_misc          systemd-1      autofs     rw,relatime,fd=35,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
        |-/run                                tmpfs          tmpfs      rw,nosuid,nodev,mode=755
        | |-/run/lock                         tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/rpc_pipefs                   sunrpc         rpc_pipefs rw,relatime
        | `-/run/user/1000                    tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=808828k,mode=700,uid=1000,gid=1000
        `-/boot                               /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        2.7G	/var/
        2.4G	/var/cache/apt
        2.4G	/var/cache
        2.3G	/var/cache/apt/archives
        164M	/var/lib
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        5.9G	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.2G	/opt/iobroker/iobroker-data/
        779M	/opt/iobroker/iobroker-data/files
        441M	/opt/iobroker/iobroker-data/files/javascript.admin
        409M	/opt/iobroker/iobroker-data/files/javascript.admin/static
        408M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
        38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        27M	/opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
        24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        24M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.1e6546bb.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2428212-if00
        HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
        /dev/ttyACM0
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v18.20.4
        /usr/bin/node 		v18.20.4
        /usr/bin/npm 		10.7.0
        /usr/bin/npx 		10.7.0
        /usr/bin/corepack 	0.28.0
        nodejs:
          Installed: 18.20.4-1nodesource1
          Candidate: 18.20.4-1nodesource1
          Version table:
         *** 18.20.4-1nodesource1 600
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             18.20.3-1nodesource1 600
             18.20.2-1nodesource1 600
             18.20.1-1nodesource1 600
             18.20.0-1nodesource1 600
             18.19.1-1nodesource1 600
             18.19.0-1nodesource1 600
             18.18.2-1nodesource1 600
             18.18.1-1nodesource1 600
             18.18.0-1nodesource1 600
             18.17.1-1nodesource1 600
             18.17.0-1nodesource1 600
             18.16.1-1nodesource1 600
             18.16.0-1nodesource1 600
             18.15.0-1nodesource1 600
             18.14.2-1nodesource1 600
             18.14.1-1nodesource1 600
             18.14.0-1nodesource1 600
             18.13.0-1nodesource1 600
             18.12.0-1nodesource1 600
             18.11.0-1nodesource1 600
             18.10.0-1nodesource1 600
             18.9.1-1nodesource1 600
             18.9.0-1nodesource1 600
             18.8.0-1nodesource1 600
             18.7.0-1nodesource1 600
             18.6.0-1nodesource1 600
             18.5.0-1nodesource1 600
             18.4.0-1nodesource1 600
             18.3.0-1nodesource1 600
             18.2.0-1nodesource1 600
             18.1.0-1nodesource1 600
             18.0.0-1nodesource1 600
             10.24.0~dfsg-1~deb10u3 500
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        iobroker is not running on this host.
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	6.0.9
          sebaboehm @Codierknecht last edited by
          @codierknecht kann man das nicht updaten?
          Wie konnte das passieren?
          L Codierknecht 2 Replies Last reply Reply Quote 0
            legro @sebaboehm last edited by
            @sebaboehm
            Wie gesagt, dein System ist uralt, da hilft dann in der Tat bloß eine Neuinstallation.😖
            Ich habe einen Umzug von einem Pi4 auf einen Pi5 hinter mir. Da half auch bloß eine Neuinstallation. Was es dabei ggf. alles zu bedenken gilt, kannst hier nachlesen.
            Viel Erfolg!
            • Codierknecht
              Codierknecht Developer Most Active @sebaboehm last edited by
              @sebaboehm sagte in Betriebssystem-Paket Update:
              Nein.
              Und das ist ein 32-Bit-OS. Für den Pi4 solltest Du eh auf 64-Bit wechseln.
              Regelmäßig hier mitlesen. Oder bei SocialMedia.
              Dann hättest Du vermutlich mitbekommen, dass buster abgekündigt ist und man reagieren sollte.
                Thomas Braun Most Active @sebaboehm last edited by Thomas Braun
                @sebaboehm
                Wie schon gesagt muss die Kiste komplett neuinstalliert werden.
                Diesmal direkt in der 64Bit-Version.
                Und mit einem User, der weder pi noch iobroker (oder VaRian7en davon) heißt.
                Schau dir per
                systemctl status iobroker
                an wo es da klemmen könnte.
                Zu zigbee: Stell da den Link 'by-id' ein.
                Bring das System auf nodejs@20.~
                Edit: nodejs 20 läuft auf deinem System schon nicht mehr, kannste also vergessen.
                Nein, nicht auf das Bookworm-Release (Debian 12) und nicht mit dem Architektur-Wechsel auf 64Bit.
                Releases folgen einem Release Plan. Den hat @Codierknecht oben zitiert. Ist also kein Ereignis aus heiterem Himmel sondern schon Jahre im Voraus bekannt.
                Ich würde versuchen das Ding auf einen möglichst aktuellen Stand zu bringen und dann davon ein Backup ziehen und damit umziehen.
                  sebaboehm @Thomas Braun last edited by
                  Wenn ich das jetzt neu installiere und dann das Backup einspiele, ist dann alles wieder da?
                  auch die Zigbee Geräte?
                  Codierknecht Homoran Thomas Braun L 4 Replies Last reply Reply Quote 0
                  • Codierknecht
                    In der Regel: Ja!
                    Dauert je nach Größe der Installation max. 1-2 Stunden.
                      Homoran Global Moderator Administrators @sebaboehm last edited by
                      @codierknecht sagte in Betriebssystem-Paket Update:
                      In der Regel: Ja!
                      ...vorausgesetzt du hast die entsprechenden Optionen konfiguriert
                        Das ist der Sinn und Zweck von Backups.
                        In der Regel schon. Ob es mit einem ConBee_II funktioniert weiß ich aber nicht. Musste vielleicht mal nachlesen.
                          sebaboehm @Homoran last edited by
                          @homoran welche Optionen?
                          Ich meine ich musste damals da noch etwas mehr installieren auf dem Pi oder?
                          Sorry, bin da seit längerer Zeit nicht mehr im Thema und weiss nicht mehr was ich damals alles gemacht hatte
                          • Codierknecht
                            Mal so ganz allgemein gesprochen:
                            So ein Server ist kein "fire & forget" System. Mit sowas muss man sich von Zeit zu Zeit auch beschäftigen.
                            Wer einen ioBroker aufsetzt, macht sich automatisch zum Server-Admin ... mit den entsprechenden Pflichten.
                            "never change a running system" war noch nie 'ne gute Idee.
                              Je nach Ausgestaltung deines Systems ist einiges an zusätzlicher Handarbeit notwendig. Bei mir war‘s ziemlich aufwendig, aber dank BackItUp & Co. konnte ich alles wiederherstellen. Aber das kannst du alles in dem oben referenzierte Thread ja mal nachlesen.
                                Wenn das Einspielen des Backups erfolgreich war, dauert es dann trotzdem noch etwas bis alles wieder da ist?
                                Ich konnte das Backup nur mit "--force" einspielen
                                Thomas Braun Codierknecht 2 Replies Last reply Reply Quote 0
                                  Ja.
                                  Das wäre mir suspekt.
                                  • Codierknecht
                                    Das dauert in der Regel sogar 'ne ganze Weile, da hier erst nacheinander alle nötigen Adapter installiert werden.
                                    Da ist Geduld angesagt. Warte, bis sich im Log eine Weile nix mehr ändert ...
                                      @thomas-braun ging nicht anders wegen:
                                      The current version of js-controller differs from the version in the backup.
                                      The js-controller version of the backup can not be restored automatically.
                                      To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@5.0.19 --omit=dev" inside your ioBroker directory
                                      If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
                                        Das wäre der Weg gewesen, nicht per --force da einfach alles reinprügeln.
                                          @thomas-braun das hat nicht funktioniert
                                            Das glaube ich ehrlich gesagt nicht, das ist nämlich eine ganz grundlegende Funktion und funktioniert 'immer'.
                                            1669
