    4. Adapterfehler WEB-Server und IP-Kameras
      Loco @Loco last edited by
      admin.0
      2024-08-14 14:10:08.274	info	<== Disconnect system.user.admin from ::ffff:192.168.220.191 web
      admin.0
      host.E5440
      2024-08-14 14:10:07.616	info	instance system.adapter.web.0 is handled by compact group controller pid 42532
      host.E5440.compactgroup1
      2024-08-14 14:10:06.452	info	Do not restart adapter system.adapter.web.0 because desired by instance
      2024-08-14 14:10:06.452	info	instance system.adapter.web.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      2024-08-14 14:10:06.452	warn	instance system.adapter.web.0 terminated due to 11
      web.0
      2024-08-14 14:10:05.919	info	(COMPACT) http server listening on port 8096
      web.0
      2024-08-14 14:10:05.918	info	(COMPACT) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      web.0
      2024-08-14 14:10:05.918	error	(COMPACT) port 8088 already in use
      web.0
      2024-08-14 14:10:05.111	debug	(COMPACT) Activating web files from objectDB
      web.0
      2024-08-14 14:10:05.111	debug	(COMPACT) Activating extensions
      web.0
      2024-08-14 14:10:05.110	debug	(COMPACT) Secure connection not enabled - using http createServer
      web.0
      2024-08-14 14:10:05.109	debug	(COMPACT) Activating states & socket info
      web.0
      2024-08-14 14:10:05.053	info	(COMPACT) starting. Version 6.3.0 in C:/ioBroker/node_modules/iobroker.web, node: v20.16.0, js-controller: 6.0.10
      2024-08-14 14:10:04.856	info	instance system.adapter.web.0 started in COMPACT mode
      host.E5440
      2024-08-14 14:10:03.981	info	stopInstance system.adapter.web.0 (force=false, process=true)
      admin.0
      2024-08-14 14:09:58.991	info	==> Connected system.user.admin from ::ffff:192.168.220.191
      host.E5440
      2024-08-14 14:09:12.019	info	instance system.adapter.cameras.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      cameras.0
      2024-08-14 14:09:11.901	info	terminating
      cameras.0
      2024-08-14 14:09:11.402	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      cameras.0
      2024-08-14 14:09:11.402	info	terminating
      cameras.0
      2024-08-14 14:09:11.399	info	Got terminate signal TERMINATE_YOURSELF
      host.E5440
      2024-08-14 14:09:11.398	info	stopInstance system.adapter.cameras.0 send kill signal
      host.E5440
      2024-08-14 14:09:11.393	info	stopInstance system.adapter.cameras.0 (force=false, process=true)
      host.E5440
      2024-08-14 14:09:11.392	info	"system.adapter.cameras.0" disabled
      host.E5440
      2024-08-14 14:04:20.423	info	instance system.adapter.web.0 is handled by compact group controller pid 42532
      2024-08-14 14:04:19.562	info	Do not restart adapter system.adapter.web.0 because desired by instance
      2024-08-14 14:04:19.562	info	instance system.adapter.web.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
      2024-08-14 14:04:19.562	warn	instance system.adapter.web.0 terminated due to 11
      web.0
      2024-08-14 14:04:18.997	info	(COMPACT) http server listening on port 8095
      web.0
      2024-08-14 14:04:18.996	info	(COMPACT) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      web.0
      2024-08-14 14:04:18.996	error	(COMPACT) port 8088 already in use
        Homoran Global Moderator Administrators @Loco last edited by
        @loco ich kenne den compact mode nicht, aber das
        @loco sagte in Adapterfehler WEB-Server und IP-Kameras:
        host.E5440.compactgroup1 2024-08-14 14:10:06.452 warn instance system.adapter.web.0 terminated due to 11
        klingt für mich danach, dass die gesamte Gruppe die Ressourcen gemeinsam nutzt
          Loco @Homoran last edited by
          @homoran wie kann ich den compact Mode den umschalten?
          Homoran S crunchip 3 Replies Last reply Reply Quote 0
            keine Ahnung!
            ich hab den noch nie genutzt.
              Ich hab auch keine Ahnung wieso "Compact Mode". Hatte alles neu aufgesetzt auf einem Win11-64bit und dann meine alte VIS importiert...
                Shadowhunter23 @Loco last edited by
                @loco
                Laut suche im Forum:
                https://forum.iobroker.net/topic/32789/anleitung-für-adapter-entwickler-compact-mode-testen
                  Homoran Global Moderator Administrators @Shadowhunter23 last edited by
                  @shadowhunter23
                  naja, das ist jetzt 4 Jahre alt und richtete sich an Entwickler.
                  Ich denke schon, dass sich da bis heute noch was geändert haben kann.
                  L S 2 Replies Last reply Reply Quote 0
                    crunchip Forum Testing Most Active @Loco last edited by
                    @loco hatte ich doch oben schon gezeigt
                      Zumindest hat das geklappt. Habe den compact mode deaktiviert. Mal sehen was jetzt so passiert....
                        Shadowhunter23 @Homoran last edited by Shadowhunter23
                        @homoran sagte in Adapterfehler WEB-Server und IP-Kameras:
                        Möglich aber der Befehl ist aktiv und man könnte den verwenden...
                          Loco @Shadowhunter23 last edited by
                          @shadowhunter23
                          habe den compact mode deaktiviert, jetzt startet meine VIS aber nicht mehr
                          mehr passiert nicht...
                            für alle Instanzen?
                            danach iobroker neu gestartet?
                            Was sagt die Browserkonsole?
                              Loco @Homoran last edited by Homoran
                              C:\ioBroker>iob list instances
                              + system.adapter.admin.0                  : admin                 : E5440                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.alexa2.0                 : alexa2                : E5440                                    -  enabled
                              + system.adapter.backitup.0               : backitup              : E5440                                    -  enabled
                              + system.adapter.broadlink2.0             : broadlink2            : E5440                                    -  enabled
                                system.adapter.cameras.0                : cameras               : E5440                                    - disabled, port: 8200, bind: 127.0.0.1
                              + system.adapter.chromecast.0             : chromecast            : E5440                                    -  enabled
                                system.adapter.daswetter.0              : daswetter             : E5440                                    -  enabled
                              + system.adapter.deyeidc.0                : deyeidc               : E5440                                    -  enabled, port: 8899
                              + system.adapter.discovery.0              : discovery             : E5440                                    -  enabled
                              + system.adapter.echarts.0                : echarts               : E5440                                    -  enabled
                                system.adapter.flot.0                   : flot                  : E5440                                    -  enabled
                              + system.adapter.fritzdect.0              : fritzdect             : E5440                                    -  enabled
                              + system.adapter.history.0                : history               : E5440                                    -  enabled
                                system.adapter.hue.0                    : hue                   : E5440                                    - disabled, port: 443
                                system.adapter.hue.1                    : hue                   : E5440                                    - disabled, port: 443
                                system.adapter.hue.2                    : hue                   : E5440                                    - disabled, port: 443
                                system.adapter.ical.0                   : ical                  : E5440                                    -  enabled
                                system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: E5440                                    -  enabled
                                system.adapter.icons-icons8.0           : icons-icons8          : E5440                                    -  enabled
                                system.adapter.icons-mfd-png.0          : icons-mfd-png         : E5440                                    -  enabled
                                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : E5440                                    -  enabled
                                system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: E5440                                    -  enabled
                                system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : E5440                                    -  enabled
                              + system.adapter.javascript.0             : javascript            : E5440                                    -  enabled
                              + system.adapter.net-tools.0              : net-tools             : E5440                                    -  enabled
                                system.adapter.onvif.0                  : onvif                 : E5440                                    - disabled
                              + system.adapter.ping.0                   : ping                  : E5440                                    -  enabled
                              + system.adapter.pollenflug.0             : pollenflug            : E5440                                    -  enabled
                              + system.adapter.signal-cmb.0             : signal-cmb            : E5440                                    -  enabled
                              + system.adapter.sonoff.0                 : sonoff                : E5440                                    -  enabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.sourceanalytix.0         : sourceanalytix        : E5440                                    -  enabled
                              + system.adapter.tankerkoenig.0           : tankerkoenig          : E5440                                    -  enabled
                              + system.adapter.tr-064.0                 : tr-064                : E5440                                    -  enabled
                              + system.adapter.trashschedule.0          : trashschedule         : E5440                                    -  enabled
                                system.adapter.vesync.0                 : vesync                : E5440                                    - disabled
                                system.adapter.vis-bars.0               : vis-bars              : E5440                                    -  enabled
                                system.adapter.vis-history.0            : vis-history           : E5440                                    -  enabled
                                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : E5440                                    -  enabled
                                system.adapter.vis-icontwo.0            : vis-icontwo           : E5440                                    -  enabled
                              + system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : E5440                                    -  enabled
                              + system.adapter.vis-justgage.0           : vis-justgage          : E5440                                    -  enabled
                                system.adapter.vis-material-advanced.0  : vis-material-advanced : E5440                                    -  enabled
                                system.adapter.vis-metro.0              : vis-metro             : E5440                                    -  enabled
                                system.adapter.vis-players.0            : vis-players           : E5440                                    -  enabled
                                system.adapter.vis-timeandweather.0     : vis-timeandweather    : E5440                                    -  enabled
                                system.adapter.vis-weather.0            : vis-weather           : E5440                                    -  enabled
                                system.adapter.vis.0                    : vis                   : E5440                                    -  enabled
                              + system.adapter.web.0                    : web                   : E5440                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + system.adapter.wifilight.0              : wifilight             : E5440                                    -  enabled
                              + instance is alive
                                @loco
                                Also, auch nach aktivieren des Compact Mode läuft meine vis nicht mehr! iobroker läuft vis kein Zugriff mehr! Was kann ich machen?
                                  crunchip Forum Testing Most Active @Loco last edited by crunchip
                                  @loco dann zeig mal jetzt die Einstellung im Web Adapter
                                  Und was zeigt die Browser console(f12) ?
                                    Loco @crunchip last edited by
                                    @crunchip sieht aus wie vorher:
                                    + system.adapter.web.0                    : web                   : E5440                                    -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                                    + instance is alive
                                    Keine Verbindung mehr in der VIS
                                    crunchip S 3 Replies Last reply Reply Quote 0
                                      Deshalb
                                      @crunchip sagte in Adapterfehler WEB-Server und IP-Kameras:
                                      Ist aber nicht normal
                                        Shadowhunter23 @Loco last edited by Shadowhunter23
                                        Nicht ganz der Port ist jetzt 8083 anstatt 8082. Wird aber wohl nicht das erwartete ändern.
                                          Vergleich doch mal meinen screen
                                          https://forum.iobroker.net/post/1190976
                                          Wie schon geschrieben, fehlt dir da bisserl was in den Einstellungen und nun ist dein websocket nicht eingestellt
                                          Ausserdem warten wir immer noch aufs Browserlog
                                            Wie kann ich denn dieses Browser-Log erstellen? Und soll das erstellt werden im Fehlerfall?
                                            Ich glaube das ist eher der Nachteil wenn iobroker unter Win läuft und nicht auf einer Pi. Vermute auf einer Pi würde das laufen....
                                            3877
