    4. Test Adapter Energiefluss-erweitert v0.8.x GitHub/Latest
    • U66
      U66 @U66 last edited by U66
      @u66 ```
      energiefluss-erweitert.0
      	2024-08-15 07:52:50.168	info	terminating
      web.0
      	2024-08-15 07:52:50.157	info	socket.io server listening on port 8082
      web.0
      	2024-08-15 07:52:50.037	info	starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v18.20.4, js-controller: 6.0.9
      	2024-08-15 07:52:49.667	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      	2024-08-15 07:52:49.666	info	terminating
      	2024-08-15 07:52:49.666	info	Cleared interval for relative values!
      	2024-08-15 07:52:49.664	error	Error: Parameter "id" needs to be of type "string" but type "undefined" has been passed at Validator.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/validator.js:129:13) at EnergieflussErweitert.getForeignState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:4538:32) at /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/cjs/lib/common/tools.js:1586:18 at new Promise (<anonymous>) at EnergieflussErweitert.getForeignStateAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/cjs/lib/common/tools.js:1584:12) at EnergieflussErweitert.calculateValue (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:311:29) at sourceRunner (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:828:20) at async EnergieflussErweitert.refreshData (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:845:7) at async EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1522:4)
      	2024-08-15 07:52:49.664	error	Parameter "id" needs to be of type "string" but type "undefined" has been passed
      	2024-08-15 07:52:49.663	error	unhandled promise rejection: Parameter "id" needs to be of type "string" but type "undefined" has been passed
      	2024-08-15 07:52:49.663	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      	2024-08-15 07:52:49.662	debug	Value-Settings for Element 466 found! Applying Settings!
      	2024-08-15 07:52:49.662	debug	Values for: 466 - Using source: 36 rawValue: false Settings: {"threshold":0,"type":"image","source":36,"source_type":"boolean"}
      	2024-08-15 07:52:49.661	debug	Values for: 205 - Using source: 36 rawValue: false Settings: {"threshold":0,"calculate_kw":"none","decimal_places":0,"convert":false,"type":"text","source":36,"source_option":-1,"source_display":"own_text","subtract":[-1],"add":[-1],"source_type":"boolean","text":""}
      	2024-08-15 07:52:49.661	debug	Updated through elmSources: {"1":44,"14":0,"15":17910,"16":201,"17":184,"18":385,"19":80,"20":731,"21":0.11,"22":0,"23":3.31,"24":0.5,"25":266,"27":0,"28":0,"29":1,"30":"--:--h","32":0,"33":false,"34":false,"36":false}
      	2024-08-15 07:52:49.661	debug	Current Value of tuya.0.74500708e09806147e72.1: false - saved Value: undefined
      	2024-08-15 07:52:49.661	info	Loading initial for tuya.0.74500708e09806147e72.1 with {"val":false,"ack":true,"ts":1723701123604,"q":0,"from":"system.adapter.tuya.0","user":"system.user.admin","lc":1723650417095}
      	2024-08-15 07:52:49.661	debug	Value of tuya.0.74500708e09806147e72.1 changed! Processing!
      	2024-08-15 07:52:49.661	debug	Value-Settings for Element 205 found! Applying Settings!
      • SKB
        SKB Developer Most Active @U66 last edited by
        @u66 Das sieht mir nicht nach der neueren Version aus, da eine Menge Info Logs fehlen.
        Bitte über Benutzerdefiniert via Github Katze installieren, upload machen und dann die Ausgabe posten. Adapter muss nicht auf Debug stehen.
        U66 1 Reply Last reply Reply Quote 1
        • U66
          U66 @SKB last edited by U66
          @skb
          	2024-08-15 09:37:53.013	debug	State changed! New value for Source: alpha-ess.0.Realtime.PV_power_string_1 with Value: 770 belongs to Elements: 93,124
          	2024-08-15 09:37:53.013	debug	Value: 770 is greater than Threshold: 0. Applying Animation!
          	2024-08-15 09:37:53.013	debug	Animation has a positive factor!
          	2024-08-15 09:37:53.012	debug	Animation - Settings for Element anim_path_303_387 found! Applying Settings!
          	2024-08-15 09:37:53.012	debug	Found corresponding animations for ID: alpha-ess.0.Realtime.PV_power_string_1 !Applying!
          	2024-08-15 09:37:53.012	debug	Values for: 124 - Using source: 16 rawValue: 770 Settings: {"threshold":0,"type":"circle","source":16,"fill_type":-1,"border_type":-1,"source_type":"number"}
          	2024-08-15 09:37:53.012	debug	Value-Settings for Element 124 found! Applying Settings!
          	2024-08-15 09:37:52.990	debug	Threshold for: 93 is: 0
          	2024-08-15 09:37:52.990	debug	Values for: 93 - Using source: 16 rawValue: 770 Settings: {"threshold":0,"calculate_kw":"auto","decimal_places":1,"convert":false,"type":"text","source":16,"source_option":-1,"source_display":"value","subtract":[-1],"add":[-1],"override":{">=0":{"display":"fill","fill":"rgb(26,255,49","unit":" W","value":"val => val.toFixed(0)"},">=1000":{"unit":" kW","value":"val => parseFloat(val/1000).toFixed(2)","display":"fill","fill":"rgb(26,255,49"},">=9995":{"unit":" kW","value":"val => parseFloat(val/1000).toFixed(1)","display":"fill","fill":"rgb(26,255,49"},"<= -9995":{"unit":" kW","value":"val => parseFloat(val*-1/1000).toFixed(1)","display":"fill","fill":"rgb(34,139,34)"},"<= -1000":{"unit":" kW","value":"val => parseFloat(val*-1/1000).toFixed(2)","display":"fill","fill":"rgb(34,139,34)"},"default":{"unit":" W","value":"val => (val*-1).toFixed(0)","display":"fill","fill":"rgb(34,139,34)"}},"source_type":"number","text":"ID 93"}
          	2024-08-15 09:37:52.990	debug	Gathering override for ID: 93, Value: 770 and Override: {">=0":{"display":"fill","fill":"rgb(26,255,49","unit":" W","value":"val => val.toFixed(0)"},">=1000":{"unit":" kW","value":"val => parseFloat(val/1000).toFixed(2)","display":"fill","fill":"rgb(26,255,49"},">=9995":{"unit":" kW","value":"val => parseFloat(val/1000).toFixed(1)","display":"fill","fill":"rgb(26,255,49"},"<= -9995":{"unit":" kW","value":"val => parseFloat(val*-1/1000).toFixed(1)","display":"fill","fill":"rgb(34,139,34)"},"<= -1000":{"unit":" kW","value":"val => parseFloat(val*-1/1000).toFixed(2)","display":"fill","fill":"rgb(34,139,34)"},"default":{"unit":" W","value":"val => (val*-1).toFixed(0)","display":"fill","fill":"rgb(34,139,34)"}}
          	2024-08-15 09:37:52.989	debug	Updated through elmSources: {"1":62.4,"14":0,"15":17910,"16":770}
          	2024-08-15 09:37:52.989	debug	Current Value of alpha-ess.0.Realtime.PV_power_string_1: 770 - saved Value: undefined
          	2024-08-15 09:37:52.989	info	Loading initial for alpha-ess.0.Realtime.PV_power_string_1 with {"val":770,"ack":true,"ts":1723707460725,"q":0,"from":"system.adapter.alpha-ess.0","user":"system.user.admin","lc":1723707460725}
          	2024-08-15 09:37:52.989	debug	Value of alpha-ess.0.Realtime.PV_power_string_1 changed! Processing!
          	2024-08-15 09:37:52.989	debug	Value-Settings for Element 93 found! Applying Settings!
          • SKB
            SKB Developer Most Active @U66 last edited by SKB
            @u66 Bitte den Adapter nicht auf Debug stellen, sondern einfach nur starten! Dann den Inhalt des Startes hier einstellen.
            Diese Log-Fetzen sind ja völlig aus dem Zusammenhang.
            U66 1 Reply Last reply Reply Quote 0
            • U66
              @skb
              	2024-08-15 10:03:37.227	info	terminating
              	2024-08-15 10:03:36.726	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
              	2024-08-15 10:03:36.725	info	terminating
              	2024-08-15 10:03:36.725	info	Cleared interval for relative values!
              	2024-08-15 10:03:36.722	error	Parameter "id" needs to be of type "string" but type "undefined" has been passed
              	2024-08-15 10:03:36.722	error	Error: Parameter "id" needs to be of type "string" but type "undefined" has been passed at Validator.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/validator.js:129:13) at EnergieflussErweitert.getForeignState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:4538:32) at /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/cjs/lib/common/tools.js:1586:18 at new Promise (<anonymous>) at EnergieflussErweitert.getForeignStateAsync (/opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/cjs/lib/common/tools.js:1584:12) at EnergieflussErweitert.calculateValue (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:311:29) at sourceRunner (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:828:20) at async EnergieflussErweitert.refreshData (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:845:7) at async EnergieflussErweitert.getConfig (/opt/iobroker/node_modules/iobroker.energiefluss-erweitert/main.js:1522:4)
              SKB 2 Replies Last reply Reply Quote 0
              • SKB
                @u66 Da fehlen Info Ausgaben. Sowas wie:
                2024-08-15 09:47:55.415 - info: host.ioBroker-master instance system.adapter.energiefluss-erweitert.0 in version "0.5.1-alpha.4" started with pid 1671
                2024-08-15 09:47:55.910 - info: energiefluss-erweitert.0 (1671) starting. Version 0.5.1-alpha.4 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v18.17.1, js-controller: 6.0.9
                2024-08-15 09:47:55.925 - info: energiefluss-erweitert.0 (1671) Adapter started. Loading config!
                2024-08-15 09:47:55.939 - info: energiefluss-erweitert.0 (1671) Sources: {"sonnen.0.status.userSoc":{"id":1,"factor":1,"elmSources":[13,18],"elmAnimations":[],"addSources":[],"subtractSources":[]},"sonnen.0.status.consumption":{"id":2,"factor":1,"elmSources":[7],"elmAnimations":[],"addSources":[],"subtractSources":[]},"sonnen.0.status.gridFeedIn":{"id":3,"factor":1,"elmSources":[19,20],"elmAnimations":["anim_path_5_14","anim_path_14_7"],"addSources":[],"subtractSources":[]},"sonnen.0.status.pacTotal":{"id":4,"factor":1,"elmSources":[16,28],"elmAnimations":["anim_path_5_13","anim_path_13_7"],"addSources":[],"subtractSources":[]},"evcc.0.loadpoint.1.status.chargePower":{"id":5,"factor":1,"elmSources":[23,26],"elmAnimations":["anim_path_7_22"],"addSources":[],"subtractSources":[9]},"evcc.0.loadpoint.1.status.vehicleSoc":{"id":6,"factor":1,"elmSources":[22,27],"elmAnimations":[],"addSources":[],"subtractSources":[]},"sonnen.0.status.production":{"id":7,"factor":1,"elmSources":[2,5,6],"elmAnimations":["anim_path_5_7"],"addSources":[],"subtractSources":[]},"pvforecast.0.summary.energy.today":{"id":8,"factor":1,"elmSources":[31,38,55],"elmAnimations":[],"addSources":[],"subtractSources":[]},"javascript.0.Solar.Produktion.heute":{"id":9,"factor":1,"elmSources":[34,39,54],"elmAnimations":[],"addSources":[],"subtractSources":[]},"energiefluss-erweitert.0.calculation.battery.remaining":{"id":10,"factor":1,"elmSources":[37],"elmAnimations":[],"addSources":[],"subtractSources":[]},"shelly.0.SHPLG-S#DE6919#1.Relay0.Power":{"id":11,"factor":1,"elmSources":[43],"elmAnimations":["anim_path_7_40"],"addSources":[],"subtractSources":[9]},"shelly.0.SHSW-PM#E89F6D847D4C#1.Relay0.Power":{"id":12,"factor":1,"elmSources":[46,48],"elmAnimations":["anim_path_7_45"],"addSources":[],"subtractSources":[9]},"0_userdata.0.Energiefluss_Test.verbrauch":{"id":13,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"0_userdata.0.Energiefluss_Test.Test-String":{"id":14,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"energiefluss-erweitert.0.calculation.battery.remaining_target_DT":{"id":15,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"shelly.0.SHSW-PM#84CCA8AC76BE#1.Relay0.Switch":{"id":16,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"energiefluss-erweitert.0.calculation.consumption.consumption":{"id":17,"factor":1,"elmSources":[9],"elmAnimations":[],"addSources":[],"subtractSources":[]},"sonnen.0.configurations.EM_USOC":{"id":19,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"sonnen.0.configurations.CM_MarketingModuleCapacity":{"id":20,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"shelly.0.SHPLG-S#DE6919#1.Relay0.Switch":{"id":21,"factor":1,"elmSources":[],"elmAnimations":[],"addSources":[],"subtractSources":[]},"weatherunderground.0.forecast.0d.iconURL":{"id":"weatherunderground.0.forecast.0d.iconURL","elmSources":["56"]}}
                2024-08-15 09:47:55.939 - info: energiefluss-erweitert.0 (1671) Loading initial for sonnen.0.status.userSoc with {"val":0,"ack":true,"ts":1723708073999,"q":0,"from":"system.adapter.sonnen.0","user":"system.user.admin","lc":1723510323475}
                Das sind die wichtigen Ausgaben.
                • SKB
                  @u66 Wenn Du nochmal die Version von Github installierst, sollte der Fehler weg sein.
                  @ralle Dein Fehler sollte damit auch "Geschichte" sein 😉
                  U66 R 2 Replies Last reply Reply Quote 0
                  • U66
                    @skb
                    Ja haut alles wieder hin.....Danke
                      ralle @SKB last edited by
                      @skb said in Test Adapter Energiefluss-erweitert v0.5.x-alpha.x GitHub:
                      tja nun hab ich alles neu gemacht, egal. Lag also nicht mir , hatte ich keinen Fehler gemacht...?
                      • SKB
                        SKB Developer Most Active @ralle last edited by
                        @ralle ... Geduld ist eine Tugend 😉
                        Wenn ein Programm durch den Benutzer abstürzt, hat nicht der Benutzer den Fehler begangen, sondern der Programmierer schlampig gearbeitet oder schlichtweg etwas übersehen 🙂
                          Das kann man so nicht stehen lassen...... vielen Dank das du diesen Adapter Programmiert hast und so viel Zeit investierst. So etwas zu Programmieren muss man auch erst mal können.
                          .......und, nur wer Arbeitet kann Fehler machen, wer behauptet er würde keine Fehler machen der Arbeitet auch nicht!
                          SKB 1 Reply Last reply Reply Quote 1
                          • SKB
                            @ralle Danke Dir! Freut mich, wenn der Adapter dir gefällt, einen Nutzen und Freude bringt 👍😉
                            Ja, da hast Du allerdings Recht!
                            • SKB
                              SKB Developer Most Active last edited by
                              Hallo Zusammen,
                              ich hatte die Idee, noch ein Kontextmenü beim Rechtsklick anzubieten. Welche hilfreichen Eigenschaften könnte man hier Eurer Meinung nach unterbringen?
                              2024-08-16 17_53_56-Energiefluss - erweitert Configuration – Mozilla Firefox.png
                              Danke 🙂
                              • U66
                                @skb
                                Zuweisung eines Datenpunktes ?
                                falls ich das richtig verstanden habe.............
                                • SKB
                                  @u66 Auch eine Idee.
                                  Aber da denke ich, das dies über die Configbar besser ist?!
                                  • U66
                                    @skb
                                    Hallo
                                    hab mal noch was
                                    mein Sonnenaufgang zeigt mir jetzt wohl die sekunden an...
                                    Wie bekomme ich die denn wieder weg.
                                    • SKB
                                      @u66 Umformatieren und dann in eigenen Datenpunkt.
                                      Gibt keine Formatierung. Vielleicht mal drüber überlegen.
                                      • U66
                                        @skb
                                        Ja ist ja kein Thema
                                        wunderte mich nur, weil es erst bei dem neuesten Adapterupdate zusehen war.
                                        habs auch heute erst vernommen.
                                        Ich leg einfach ein kleines Rechteck mit Hintergrundfarbe drüber, geht ja auch
                                        • SKB
                                          @u66 Wo bekommst Du denn die Werte her? Kann man dort nicht die Bedingungen einstellen, das keine Sekunden kommen?
                                          • U66
                                            U66 last edited by
                                            @skb
                                            Astrozeiten sind fest im Javascript Adapter drinn
                                            Die sek. sind wohl durch ein Update dazugekommen.
                                            Ist ja nicht weiter schlimm, hatte mich nur gewundert
                                            früher
                                            diagramm energiefluss energiefluss-erweitert vis visualisierung visualization
                                            65
                                            1421
                                            780330
