    4. Node-Red
    5. Wasserregulierung Aquarium
    • Aphofis
      Aphofis @mickym last edited by Aphofis
      @mickym
      Jetzt wird erst auf false die Rechnung ausgegeben. und in den Datenpunkt Test Wasser Kallibriert eingetragen.
              "id": "e96d40e5c03c8e73",
              "type": "tab",
              "label": "Flow 2",
              "disabled": false,
              "info": "",
              "env": []
              "id": "8eeeee9dee4f69dd",
              "type": "junction",
              "z": "e96d40e5c03c8e73",
              "x": 180,
              "y": 80,
              "wires": [
                      "ed6a34a53f4a5f8a"
              "id": "4135d8f01c675d48",
              "type": "debug",
              "name": "ml aktuell",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "payload",
              "targetType": "msg",
              "statusVal": "",
              "statusType": "auto",
              "x": 880,
              "y": 180,
              "wires": []
              "id": "d603f22a313281eb",
              "type": "calculator",
              "name": "multi ml",
              "inputMsgField": "payload",
              "outputMsgField": "payload",
              "operation": "mult",
              "constant": "5.21",
              "round": true,
              "truncate": false,
              "decimals": "2",
              "decimals2": 0,
              "x": 660,
              "y": 180,
              "wires": [
                      "4135d8f01c675d48",
                      "be1fec4a5a0c39ea"
              "outputLabels": [
                  "ml"
              "icon": "font-awesome/fa-subscript"
              "id": "17fc122a8cc82dc5",
              "type": "ioBroker in",
              "name": "Schwimmer",
              "attrname": "payload",
              "topic": "0_userdata.0.Test_Wasser.Test_Schwimmer",
              "payloadType": "value",
              "onlyack": "",
              "func": "all",
              "gap": "",
              "fireOnStart": "false",
              "outFormat": "MQTT",
              "x": 70,
              "y": 120,
              "wires": [
                      "8eeeee9dee4f69dd"
              "id": "9f9432b0c01ceb15",
              "type": "ioBroker get",
              "name": "Wasserdurchfluß",
              "topic": "0_userdata.0.Test_Wasser.Test_Durchfluss",
              "errOnInvalidState": "nothing",
              "x": 490,
              "y": 180,
              "wires": [
                      "d603f22a313281eb"
              "id": "df1de44c69ce020f",
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "true",
              "payloadType": "str",
              "x": 90,
              "y": 80,
              "wires": [
                      "8eeeee9dee4f69dd"
              "id": "ed6a34a53f4a5f8a",
              "type": "ioBroker out",
              "name": "Magnetventil",
              "topic": "0_userdata.0.Test_Wasser.Test_Magnetventil",
              "ack": "false",
              "autoCreate": "false",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 890,
              "y": 80,
              "wires": []
              "id": "be1fec4a5a0c39ea",
              "name": "Wasser errechnet ml",
              "topic": "0_userdata.0.Test_Wasser.Test_Wasser_kallibriert",
              "ack": "true",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 920,
              "y": 220,
              "wires": []
              "id": "2eb8ac5cc0f35dca",
              "onlyack": "",
              "func": "all",
              "gap": "",
              "x": 70,
              "y": 180,
              "wires": [
                      "74d17f220e91338e"
              "id": "fb8e38c311376891",
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "false",
              "x": 90,
              "y": 40,
              "wires": [
                      "8eeeee9dee4f69dd"
              "id": "74d17f220e91338e",
              "type": "switch",
              "name": "",
              "property": "payload",
              "propertyType": "msg",
              "rules": [
                      "t": "eq",
                      "v": "false",
                      "vt": "str"
              "checkall": "true",
              "repair": false,
              "outputs": 1,
              "x": 270,
              "y": 180,
              "wires": [
                      "9f9432b0c01ceb15"
      • mickym
        mickym Most Active @Aphofis last edited by
        @aphofis Ja Du machst zwar immer mehr, als wir zusammen entwickeln aber immerhin bist Du jetzt auf dem richtigen Weg, aber schmei0 diese Kalkulator Node weg - sondern lerne mit den Standardnodes umzugehen. Es gibt NOdes die man sich zusätzlich installieren kann, aber das braucht man nicht.
        Für Berechnungen nutzt man JSONATA. Also schmeiß das weg und nutze die Node, die man nutzt um ein payload zu Ändern.
        Aphofis 1 Reply Last reply Reply Quote 0
        • Aphofis
          @mickym sagte in Wasserregulierung Aquarium:
          JSONATA
          Welche ist denn JSONATA
          oder meinst du json
          • mickym
            @aphofis
            Sowas braucht kein Mensch und ICH werde diese NODES nicht installieren
            Um eine payload zu ÄNDERN gibt es eine Standardnode. Wie heißt die wohl ÄNDERN = ...... - NOde
            Aphofis 1 Reply Last reply Reply Quote 1
            • Aphofis
              @mickym
              ok also change node
              hab die calculator Node rausgeschmissen.
              • mickym
                mickym Most Active @Aphofis last edited by mickym
                @aphofis Sehr gut 🙂
                So also mit der Change Node kannst Du eine payload innerhalb des Nachrichtenobjektes verschieben, sie neu schreiben, ändern oder löschen.
                Sind dir diese 4 Fälle geläufig?
                Importiere Dir mal diesen Flow - und schau Dir an, was wir mit dem Nachrichtenobjekt machen können:
                       "id": "cd051990e045ac73",
                       "type": "inject",
                       "z": "95d5d241e51360cd",
                       "name": "",
                       "props": [
                               "p": "payload"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "payload": "20",
                       "payloadType": "num",
                       "x": 370,
                       "y": 460,
                       "wires": [
                               "070a2b4cb0049c8b",
                               "79acf22a95932020"
                       "id": "070a2b4cb0049c8b",
                       "type": "debug",
                       "name": "Komplettes Nachrichtenobjekt",
                       "active": true,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "complete": "true",
                       "targetType": "full",
                       "statusVal": "",
                       "x": 630,
                       "y": 420,
                       "wires": []
                       "id": "79acf22a95932020",
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 570,
                       "y": 480,
                       "wires": [
                               "3429626fc84b980b"
                       "id": "3429626fc84b980b",
                       "type": "debug",
                       "name": "Verändertes Nachrichtenobjekt",
                       "active": true,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "complete": "true",
                       "statusVal": "",
                       "x": 830,
                       "y": 480,
                       "wires": []
                Damit siehst Du auch wie ein minimales Nachrichtenobjekt in der Regel aussieht. Schau Dir auch an, was der UNTERSCHIED ist, wenn Du Dir das komplette Nachrichtenobjekt ausgibst oder nur die payload Eigenschaft des Nachrichtenobjektes.
                Aphofis 2 Replies Last reply Reply Quote 1
                • Aphofis
                  @mickym bekannt ja aber was genau verschieben und setzen heißt nicht so genau
                  • Aphofis
                    Ja hab ich gesehen.
                    1. Debug hat den Wert 20
                    2. Debug hat den Wert 0
                    • mickym
                      @aphofis sagte in Wasserregulierung Aquarium:
                      Na deswegen machen wir erst mal diese Grundlagen.
                      Also importiere den unteren Flow - und Du musst wissen, welche Datentypen es gibt.
                      Also: Zeichenkette, Boolean, Zahl, Objekt, Array.
                      • mickym
                        @aphofis Na siehst Du dass wir das GESAMTE Nachrichtenobjekt ausgegeben haben?
                        • mickym
                          Ja hab ich gesehen.
                          Nein - die 2. Debug Node enthält nicht den Wert 0 sondern eine leere Zeichenkette.
                          mickym Aphofis 2 Replies Last reply Reply Quote 1
                          • Aphofis
                            @mickym
                            Ja die Datentypen sind mir bekannt. Wir wollen ja nur mit value (Zahlen) arbeiten.
                            • mickym
                              mickym Most Active @mickym last edited by
                              Ja hab ich gesehen.
                              • Aphofis
                                @mickym
                                Ja hab ich gesehen.
                                Ja hab ich gesehen.
                                Jupp oder halt eine leere Zeichenkette durch die Change Node
                                • mickym
                                  @mickym
                                  Ja aber willst Du ein paar Grundlagen lernen?
                                  • Aphofis
                                    @mickym auf jeden Fall ich bin dabei und versuche dem zu folgen was du schreibst
                                    • mickym
                                      @aphofis Wie ist ein Objekt definiert, wie ist ein Array definiert?
                                      und siehst du den Unterschied, ob man sich ein Nachrichtenobjekt ausgibt oder nur die Eigenschaft eines Objektes?
                                      Ändere mal in der 1. Debug Node - die Ausgabe nur auf die payload und kannst Du mir den Unterschied erklären?
                                      • Aphofis
                                        Aphofis last edited by Aphofis
                                        @mickym Dann wird aus msg:Object msg:payload Number also kann man damit schon festlegen ob man ein Objekt oder ob ein Value erwartet wird bzw ausgegeben wird.
                                        hatte vergessen das man im Debug den Pfeil anklicken kann wo man dann sieht das eine object ID und das payload ausgegeben wird dh die Change Node filtert das man dann nur den payload wert hat.
                                        • mickym
                                          Nein, eine Debug Node legt gar nichts fest, sondern sie gibt entweder das gesamte Nachrichtenobjekt oder eine Eigenschaft des Datenpunktes aus.
                                          Mach mal wie bei mir eine 2 Debug Node an die Inject Node und gib nur den Inhalt der Inject Node aus.
                                          Dann steht noch aus, wie ein Array und ein Objekt definiert ist.
                                          Wir werden das soweit klären - hier nochmal, das gesamte Nachrichtenobjekt und nur die payload.
                                                 "type": "inject",
                                                 "name": "",
                                                 "props": [
                                                         "p": "payload"
                                                 "repeat": "",
                                                 "crontab": "",
                                                 "once": false,
                                                 "onceDelay": 0.1,
                                                 "topic": "",
                                                 "payload": "20",
                                                 "x": 370,
                                                 "y": 400,
                                                 "wires": [
                                                         "070a2b4cb0049c8b",
                                                         "0e3767a4155ad26b"
                                                 "type": "debug",
                                                 "active": true,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "complete": "true",
                                                 "statusVal": "",
                                                 "x": 630,
                                                 "y": 420,
                                                 "wires": []
                                                 "id": "0e3767a4155ad26b",
                                                 "type": "debug",
                                                 "name": "payload",
                                                 "active": true,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "statusVal": "",
                                                 "x": 560,
                                                 "y": 380,
                                                 "wires": []
                                          • Aphofis
                                            @mickym
                                            Inject Debug ausgabe ist auch nur
                                            msg.payload : number
                                            20
                                            81.1k
                                            14407
