    4. Node.js v16.20.2 update v18.20.4 sinvoll ?
      klaris @Thomas Braun last edited by Homoran
      Skript v.2024-05-22
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v7+
            Architecture: arm
      Model           : Raspberry Pi 3 Model B Plus Rev 1.3
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : 32 bit
      Systemuptime and Load:
       10:02:18 up 6 min,  1 user,  load average: 6.16, 3.09, 1.37
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      ~ Under-voltage detected
      Previously detected issues:
      ~ Under-voltage has occurred
      *** Time and Time Zones ***
                     Local time: Fri 2024-08-16 10:02:19 CEST
                 Universal time: Fri 2024-08-16 08:02:19 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** Display-Server-Setup ***
      Display-Server: true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            921M        714M         66M        0.0K        140M        154M
      Swap:            99M         99M        0.0K
      Total:          1.0G        813M         67M
      Active iob-Instances:   4
                921 M total memory
                713 M used memory
                164 M active memory
                620 M inactive memory
                 66 M free memory
                 13 M buffer memory
                127 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      top - 10:02:19 up 6 min,  1 user,  load average: 6.16, 3.09, 1.37
      Tasks: 150 total,   4 running, 146 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 60.9 us,  8.7 sy,  0.0 ni, 29.0 id,  0.0 wa,  0.0 hi,  1.4 si,  0.0 st
      MiB Mem :    922.0 total,     65.2 free,    715.1 used,    141.6 buff/cache
      MiB Swap:    100.0 total,      0.9 free,     99.1 used.    153.3 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       29G  6.4G   22G  23% /
      devtmpfs       devtmpfs  333M     0  333M   0% /dev
      tmpfs          tmpfs     461M     0  461M   0% /dev/shm
      tmpfs          tmpfs     185M  716K  184M   1% /run
      /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
      [Fri Aug 16 09:55:33 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f4bc8267-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Fri Aug 16 09:55:36 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [Fri Aug 16 09:55:36 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [Fri Aug 16 09:55:38 2024] EXT4-fs (mmcblk0p2): recovery complete
      [Fri Aug 16 09:55:38 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Aug 16 09:55:38 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Fri Aug 16 09:55:41 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET                       SOURCE         FSTYPE     OPTIONS
      /                            /dev/mmcblk0p2 ext4       rw,noatime
      |-/dev                       devtmpfs       devtmpfs   rw,relatime,size=340460k,nr_inodes=85115,mode=755
      | |-/dev/shm                 tmpfs          tmpfs      rw,nosuid,nodev
      | |-/dev/pts                 devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | `-/dev/mqueue              mqueue         mqueue     rw,nosuid,nodev,noexec,relatime
      |-/proc                      proc           proc       rw,relatime
      | `-/proc/sys/fs/binfmt_misc systemd-1      autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
      |-/sys                       sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security     securityfs     securityfs rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup           cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore           pstore         pstore     rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf              bpf            bpf        rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug        debugfs        debugfs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing      tracefs        tracefs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections fusectl        fusectl    rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config       configfs       configfs   rw,nosuid,nodev,noexec,relatime
      |-/run                       tmpfs          tmpfs      rw,nosuid,nodev,size=188820k,nr_inodes=819200,mode=755
      | |-/run/lock                tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/rpc_pipefs          sunrpc         rpc_pipefs rw,relatime
      | `-/run/user/1000           tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=94408k,nr_inodes=23602,mode=700,uid=1000,gid=1000
      `-/boot                      /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      1.7G    /var/
      1.3G    /var/log/journal/12c8c2c8ac934bc8ad22f3445d207b46
      1.3G    /var/log
      193M    /var/cache
      Archived and active journals take up 1.2G in the file system.
      /opt/iobroker/backups:
      13M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      751M    /opt/iobroker/iobroker-data/
      608M    /opt/iobroker/iobroker-data/files
      441M    /opt/iobroker/iobroker-data/files/javascript.admin
      409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      14M     /opt/iobroker/iobroker-data/objects.jsonl
      8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
      8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
      8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2486562-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.16.0
      /usr/bin/node           v20.16.0
      /usr/bin/npm            10.8.1
      /usr/bin/npx            10.8.1
      /usr/bin/corepack       0.28.2
      nodejs:
        Installed: 20.16.0-1nodesource1
        Candidate: 20.16.0-1nodesource1
        Version table:
       *** 20.16.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.9
      admin:          7.0.22
      javascript:     8.7.6
      nodejs modules from github:     2
      +-- iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
      +-- iobroker.govee@0.0.6 (git+ssh://git@github.com/nbuenger/ioBroker.govee.git#73ec80b6350890015d95428dd3bbd3f72417a073)
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
        system.adapter.countdown.0              : countdown             : raspberrypi                              - disabled
        system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
        system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
        system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
        system.adapter.govee-app.1              : govee-app             : raspberrypi                              - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
        system.adapter.iot.2                    : iot                   : raspberrypi                              - disabled
        system.adapter.iot.3                    : iot                   : raspberrypi                              -  enabled
        system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        system.adapter.meross.1                 : meross                : raspberrypi                              -  enabled
        system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
        system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.sonoff.1                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.systeminfo.0             : systeminfo            : raspberrypi                              -  enabled
        system.adapter.telegram.1               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      + system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
        system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.whatsapp-cmb.2           : whatsapp-cmb          : raspberrypi                              - disabled
      + system.adapter.whatsapp-cmb.3           : whatsapp-cmb          : raspberrypi                              -  enabled
        system.adapter.wifilight.0              : wifilight             : raspberrypi                              - disabled
        system.adapter.wled.0                   : wled                  : raspberrypi                              - disabled
        system.adapter.yahka.0                  : yahka                 : raspberrypi                              - disabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name     │ url                                              │ auto upgrade │
      │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false        │
      │ 1       │ 'beta'   │ 'https://github.com/nbuenger/ioBroker.govee'     │ false        │
      │ 2       │ '__test' │ 'https://github.com/nbuenger/ioBroker.govee'     │ false        │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.0.22   , installed 7.0.22
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.16   , installed 3.0.16
      Adapter    "countdown"    : 2.2.0    , installed 2.2.0
      Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
      Adapter    "deconz"       : 1.4.1    , installed 1.4.1
      Adapter    "discovery"    : 4.5.0    , installed 3.1.0  [Updatable]
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.1.0  [Updatable]
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.9    , installed 6.0.9
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "shelly"       : 7.0.0    , installed 6.4.1  [Updatable]
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.0    , installed 2.5.3  [Updatable]
      Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
      Adapter    "telegram"     : 3.9.0    , installed 1.16.0 [Updatable]
      Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.2.3  [Updatable]
      Adapter    "wifilight"    : 1.2.2    , installed 1.1.4  [Updatable]
      Adapter    "wled"         : 0.7.2    , installed 0.7.1  [Updatable]
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      ^X
      Objects and States
      Please stand by - This may take a while        Objects:  9851
      States:         8648
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:3 https://phoscon.de/apt/deconz bullseye InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       14164      366/deCONZ
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12992      508/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       14225      366/deCONZ
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       25642      2374/io.sonoff.1
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23746      2236/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       23741      2236/iobroker.js-co
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12994      508/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       23878      2254/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25453      2639/io.web.0
      udp        0      0 0.0.0.0:36041           0.0.0.0:*                           108        12950      360/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12948      360/avahi-daemon: r
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24391      2462/io.deconz.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       13070      366/deCONZ
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       25998      2367/io.shelly.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          10182      650/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        12949      360/avahi-daemon: r
      udp6       0      0 :::1900                 :::*                                1001       24393      2462/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       24392      2462/io.deconz.0
      udp6       0      0 :::37277                :::*                                108        12951      360/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          13007      650/dhcpcd
      2024-08-16 10:02:15.183  - info: iot.3 (2660) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2024-08-16 10:02:16.607  - info: shelly.0 (2367) [CoAP] Device 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1) connected! Polltime set to 15 sec.
      2024-08-16 10:02:16.674  - info: shelly.0 (2367) [CoAP] Device 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1) connected! Polltime set to 15 sec.
      2024-08-16 10:02:19.220  - info: iot.3 (2660) Connection changed: connect "paramithi_arcor_de"
      2024-08-16 10:02:23.821  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:02:24.022  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:02:26.300  - warn: shelly.0 (2367) [authEnabled] 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:02:40.487  - info: alexa2.0 (2356) Using cached smart home devices list from Fri Aug 16 2024 09:35:48 GMT+0200 (Central European Summer Time)
      2024-08-16 10:02:40.747  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:02:41.972  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:02:43.555  - info: alexa2.0 (2356) No smart home devices to query
      2024-08-16 10:02:43.994  - warn: shelly.0 (2367) [authEnabled] 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:02:44.474  - info: alexa2.0 (2356) Subscribing to states...
      2024-08-16 10:02:44.487  - info: alexa2.0 (2356) Deleting the following states: ["Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78","Smart-Home-Devices.13dbd4f6-cda6-4f09-aa47-157bd5f0a52e","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae","Smart-Home-Devices.97a94f07-49e6-4729-8677-73d943f2d53e","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f","Smart-Home-Devices.9bfa2b30-51b2-493d-bac5-f72930756f6a","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.#delete","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.#enabled","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.#query","Smart-Home-Devices.02fa9112-98b0-447c-84e3-53a6bfb66d00.powerState","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.#delete","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.#enabled","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.#query","Smart-Home-Devices.044d08ce-9f5e-42ea-9808-92ceabff9aae.powerState","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.#delete","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.#enabled","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.#query","Smart-Home-Devices.0671bf8a-2235-4c30-a60c-62c780b08884.connectivity","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.#delete","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.#enabled","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.#query","Smart-Home-Devices.06d953fd-41c1-465b-9902-5def8ccc35ff.powerState","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.#delete","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.#enabled","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.#query","Smart-Home-Devices.088e96b3-8ae8-49c9-948d-685ed0a278e4.powerState","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.#delete","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.#enabled","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.#query","Smart-Home-Devices.09b5a573-9944-4c05-b93d-b65156e28066.powerState","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.#delete","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.#enabled","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.#query","Smart-Home-Devices.0bf38fd1-5b00-4481-b145-f31a4f57bafc.powerState","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.#delete","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.#enabled","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.#query","Smart-Home-Devices.0c1f9249-4bb8-4905-b241-425a38f3d682.powerState","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.#delete","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.#enabled","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.#query","Smart-Home-Devices.0c99b435-806f-467c-b70f-54443d078f56.powerState","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.#delete","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.#enabled","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.#query","Smart-Home-Devices.0d5c9353-64af-4a62-b080-0cc57abdedf0.powerState","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.#delete","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.#enabled","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.#query","Smart-Home-Devices.0ec8b832-1c7c-4190-9f6e-b8d2e03ccfb7.powerState","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.#delete","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.#enabled","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.#query","Smart-Home-Devices.0f70ac3f-9aa3-4399-9b1c-867112615806.powerState","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.#delete","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.#enabled","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.#query","Smart-Home-Devices.1138c9eb-98f2-4d75-9dc4-294a18026cc1.powerState","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.#delete","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.#enabled","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.#query","Smart-Home-Devices.127172bf-714d-4b98-8468-8bbc21fa8e58.connectivity","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.#delete","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.#enabled","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.#query","Smart-Home-Devices.12ae504c-0924-49a5-957b-0a7c5055bf78.powerState","Smart-Home-Devices.13dbd4f6-cda6-4f09-aa47-157bd5f0a52e.#delete","Smart-Home-Devices.13dbd4f6-cda6-4f09-aa47-157bd5f0a52e.#enabled","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.#delete","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.#enabled","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.#query","Smart-Home-Devices.142d4319-3632-499b-aa86-01d997ad31a1.powerState","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.#delete","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.#enabled","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.#query","Smart-Home-Devices.148638b0-c363-481f-ae58-16deb35bb7c0.powerState","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.#delete","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.#enabled","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.#query","Smart-Home-Devices.17bb91f2-0a1d-4fbf-8162-6ccc874d9a4b.powerState","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.#delete","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.#enabled","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.#query","Smart-Home-Devices.183bf39e-04d8-4668-a1c3-867c262696e9.powerState","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.#delete","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.#enabled","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.#query","Smart-Home-Devices.1a68e10a-4fab-4449-9045-9987130538f1.powerState","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.#delete","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.#enabled","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.#query","Smart-Home-Devices.1b909ec1-6ddb-4744-9e1c-e799d6641423.powerState","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.#delete","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.#enabled","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.#query","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.brightness","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.color-brightness","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.color-hue","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.color-saturation","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.colorName","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.colorRgb","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.connectivity","Smart-Home-Devices.1bccb2cd-c7c7-4453-aee4-2aa01c64e8a1.powerState","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.#delete","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.#enabled","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.#query","Smart-Home-Devices.1bf5b77a-1a0e-44a6-9612-c776e5fa2bb7.powerState","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.#delete","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.#enabled","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.#query","Smart-Home-Devices.1d38a71b-f89a-410c-a19c-8110d1f5ebef.powerState","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.#delete","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.#enabled","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.#query","Smart-Home-Devices.205a256c-d336-449e-b6e7-c8eb794fe054.powerState","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.#delete","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.#enabled","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.#query","Smart-Home-Devices.20b36f84-666f-4664-9eab-1d6af8c60347.powerState","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.#delete","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.#enabled","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.#query","Smart-Home-Devices.20d2c117-3588-4383-baa5-cbc65813026d.powerState","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.#delete","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.#enabled","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.#query","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.brightness","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.color-brightness","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.color-hue","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.color-saturation","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorName","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorRgb","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorTemperatureInKelvin","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.colorTemperatureName","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.connectivity","Smart-Home-Devices.215c46bd-2571-413d-8180-69dcda492cd6.powerState","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.#delete","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.#enabled","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.#query","Smart-Home-Devices.21698e32-3a59-4ddb-bff6-8df39422c739.powerState","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.#delete","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.#enabled","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.#query","Smart-Home-Devices.252856e5-1510-46af-af6e-a8987b335c2a.powerState","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.#delete","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.#enabled","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.#query","Smart-Home-Devices.2cecdca6-703f-416e-b29e-b585405d61fe.powerState","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.#delete","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.#enabled","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.#query","Smart-Home-Devices.2d98ccf1-c1ff-47bd-891f-31a26ccb16aa.powerState","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.#delete","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.#enabled","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.#query","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.connectivity","Smart-Home-Devices.2da00b24-68a7-45d8-913c-c32642467735.powerState","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.#delete","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.#enabled","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.#query","Smart-Home-Devices.2e226e1b-f9cf-4915-9f00-ad3899db6282.connectivity","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.#delete","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.#enabled","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.#query","Smart-Home-Devices.304b1c08-99b4-4452-9a63-c71f47cc5355.powerState","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.#delete","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.#enabled","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.#query","Smart-Home-Devices.34f33511-598c-4167-ba4c-433c1ce15912.powerState","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.#delete","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.#enabled","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.#query","Smart-Home-Devices.39940899-015f-41f3-8a29-98e113ffc8bc.powerState","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.#delete","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.#enabled","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.#query","Smart-Home-Devices.39e11818-09f7-45ef-8615-19ab9563b761.powerState","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.#delete","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.#enabled","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.#query","Smart-Home-Devices.3a3c3175-992b-4d32-a34c-48dd33f3c89f.powerState","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.#delete","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.#enabled","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.#query","Smart-Home-Devices.3caecd3d-e144-49c8-90f6-6ae5e153f465.powerState","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.#delete","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.#enabled","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.#query","Smart-Home-Devices.3d41106c-ac7e-4042-a537-8405654dbb34.powerState","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.#delete","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.#enabled","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.#query","Smart-Home-Devices.3dd5b4bd-643a-452a-9da2-de14b76a54aa.powerState","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.#delete","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.#enabled","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.#query","Smart-Home-Devices.3ea4f006-3104-4482-bb96-1242e7ded3fd.powerState","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.#delete","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.#enabled","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.#query","Smart-Home-Devices.3f3f3d97-d348-4532-876d-ec44d072678d.powerState","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.#delete","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.#enabled","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.#query","Smart-Home-Devices.426371a5-924c-4145-a57a-d00b87fc79e3.powerState","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.#delete","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.#enabled","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.#query","Smart-Home-Devices.429b8e30-1a78-4755-8390-fc8538dd0097.powerState","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.#delete","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.#enabled","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.#query","Smart-Home-Devices.45f6ef7b-ae66-4524-94a6-d1e86080a607.powerState","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.#delete","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.#enabled","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.#query","Smart-Home-Devices.468150c0-5aa9-40f7-81b0-6f8fef64a89d.powerState","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.#delete","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.#enabled","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.#query","Smart-Home-Devices.48ed8423-d425-40ba-97e7-15c45c6be6b7.powerState","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.#delete","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.#enabled","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.#query","Smart-Home-Devices.50fc3919-8bfb-4d61-bffa-0fee9bc547c5.connectivity","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.#delete","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.#enabled","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.#query","Smart-Home-Devices.53bbfb73-a151-4009-a0fd-808006436072.powerState","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.#delete","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.#enabled","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.#query","Smart-Home-Devices.55ca8057-69ef-4fc1-87fb-b6a9a3883795.powerState","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.#delete","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.#enabled","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.#query","Smart-Home-Devices.55f4b610-bdf0-43d6-9eb2-be58d6ebad6e.powerState","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.#delete","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.#enabled","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.#query","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.connectivity","Smart-Home-Devices.57b3b4db-acde-4d79-aee2-d2c916b8eb00.powerState","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.#delete","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.#enabled","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.#query","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.connectivity","Smart-Home-Devices.5a759996-cf07-405c-9337-2a64d6fe9b29.powerState","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.#delete","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.#enabled","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.#query","Smart-Home-Devices.5c190d68-f0c1-47a2-b63d-219d2a4c0bfb.powerState","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.#delete","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.#enabled","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.#query","Smart-Home-Devices.5c4ccbf2-42ec-43a3-a093-a564bc99045c.powerState","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.#delete","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.#enabled","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.#query","Smart-Home-Devices.5ee285b4-cbdd-40d4-9d81-41a98f8d01bb.connectivity","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.#delete","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.#enabled","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.#query","Smart-Home-Devices.5fa6c5c8-d4db-4deb-b699-dc039a8de44e.powerState","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.#delete","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.#enabled","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.#query","Smart-Home-Devices.63ba84c4-3f0c-44a9-bb86-653bbc7276d9.powerState","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.#delete","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.#enabled","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.#query","Smart-Home-Devices.65223388-0094-4898-b635-d453ca1e2b59.powerState","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.#delete","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.#enabled","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.#query","Smart-Home-Devices.67fd6f9f-193b-4838-b121-121339bf29c6.powerState","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.#delete","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.#enabled","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.#query","Smart-Home-Devices.689926f7-1cb9-4215-ad92-e2c0e2d6ad34.powerState","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.#delete","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.#enabled","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.#query","Smart-Home-Devices.6aefb79b-1c8f-4a2b-b617-f32526d9ada4.powerState","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.#delete","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.#enabled","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.#query","Smart-Home-Devices.6b47b8d5-8561-447e-b686-ee687e4df56b.powerState","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.#delete","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.#enabled","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.#query","Smart-Home-Devices.6c2912fc-f0e8-41a5-ae6b-fb08ee9755eb.connectivity","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.#delete","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.#enabled","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.#query","Smart-Home-Devices.6f15fa6a-12e1-4948-af3f-15bc46430718.powerState","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.#delete","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.#enabled","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.#query","Smart-Home-Devices.700f2e73-2d7d-4967-ba02-f53e80189f25.powerState","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.#delete","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.#enabled","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.#query","Smart-Home-Devices.749fd5bf-9947-4c91-8a8e-42669078c6be.powerState","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.#delete","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.#enabled","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.#query","Smart-Home-Devices.755b246e-070f-4387-b271-f81ea5348853.powerState","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.#delete","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.#enabled","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.#query","Smart-Home-Devices.77230170-d8b5-411c-a907-ab58c3954aea.powerState","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.#delete","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.#enabled","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.#query","Smart-Home-Devices.797aa6f8-224a-4cdb-bd50-6a4a0424370c.powerState","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.#delete","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.#enabled","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.#query","Smart-Home-Devices.7b147708-5250-47f9-a2bf-509f0da4f9a2.powerState","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.#delete","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.#enabled","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.#query","Smart-Home-Devices.7b293e6c-fa89-415c-a993-7117bd803bed.powerState","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.#delete","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.#enabled","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.#query","Smart-Home-Devices.7b70fb0d-3c3e-476e-a914-df7e9ea3689f.powerState","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.#delete","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.#enabled","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.#query","Smart-Home-Devices.7bbbee95-cc82-4da4-8fd9-4cb6ad2c372a.powerState","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.#delete","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.#enabled","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.#query","Smart-Home-Devices.7c7d5f2e-0d52-4634-9e13-4c2c15b6743c.powerState","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.#delete","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.#enabled","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.#query","Smart-Home-Devices.7f316149-e041-4198-b0a9-def647d198f0.powerState","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.#delete","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.#enabled","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.#query","Smart-Home-Devices.7fc059d7-c60a-471e-b27c-b2fcb39b5176.powerState","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.#delete","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.#enabled","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.#query","Smart-Home-Devices.8300a541-4007-4389-9287-c4702c9e426a.powerState","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.#delete","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.#enabled","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.#query","Smart-Home-Devices.840e7e03-3cf0-4540-be06-ed39936c267e.powerState","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.#delete","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.#enabled","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.#query","Smart-Home-Devices.84db4d86-c332-49d4-ab9f-957fcd84dc45.powerState","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.#delete","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.#enabled","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.#query","Smart-Home-Devices.8b09e0e1-5e0c-479e-9dc3-c9741f79cbf3.powerState","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.#delete","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.#enabled","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.#query","Smart-Home-Devices.8b82f1d2-5a4d-4597-9d82-419b3f76636d.powerState","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.#delete","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.#enabled","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.#query","Smart-Home-Devices.8b8e05af-ff3d-4116-bceb-9583e6aa98be.powerState","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.#delete","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.#enabled","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.#query","Smart-Home-Devices.8d32c4ac-0df5-428a-a30e-44b39472b79f.powerState","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.#delete","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.#enabled","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.#query","Smart-Home-Devices.8d4228ee-2d32-472c-b7a4-db8382375255.powerState","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.#delete","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.#enabled","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.#query","Smart-Home-Devices.8e2a2a47-9720-4c65-8ecf-8d58eb31049f.powerState","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.#delete","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.#enabled","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.#query","Smart-Home-Devices.927cd434-07b0-4c6f-9761-676c988a5c73.powerState","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.#delete","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.#enabled","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.#query","Smart-Home-Devices.9282571c-6bf6-4a83-9997-682dd70ac8a4.powerState","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.#delete","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.#enabled","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.#query","Smart-Home-Devices.929c1547-4c1c-4d3a-958d-60a77fd8e9f8.powerState","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.#delete","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.#enabled","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.#query","Smart-Home-Devices.933ad596-8f8d-42a5-8558-efdb6bfbaad9.powerState","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.#delete","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.#enabled","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.#query","Smart-Home-Devices.93ecf90e-fb6f-4514-b67d-3cb569b25356.connectivity","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.#delete","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.#enabled","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.#query","Smart-Home-Devices.95cfe913-d231-4492-b40a-2a65160723ae.powerState","Smart-Home-Devices.97a94f07-49e6-4729-8677-73d943f2d53e.#delete","Smart-Home-Devices.97a94f07-49e6-4729-8677-73d943f2d53e.#enabled","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.#delete","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.#enabled","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.#query","Smart-Home-Devices.9935a0da-38f7-4433-a409-b48d5abfcd5f.powerState","Smart-Home-Devices.9bfa2b30-51b2-493d-bac5-f72930756f6a.#delete","Smart-Home-Devices.9bfa2b30-51b2-493d-bac5-f72930756f6a.#enabled","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.#delete","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.#enabled","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.#query","Smart-Home-Devices.9dc5d2df-25c1-4ad4-bf07-3e986b3ad907.powerState","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.#delete","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.#enabled","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.#query","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.connectivity","Smart-Home-Devices.9f1f46c0-31e6-4821-a57f-b622ece5f58f.lockState","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.#delete","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.#enabled","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.#query","Smart-Home-Devices.a466e4c2-9e3e-48e0-a371-7ffedfbf055e.powerState","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.#delete","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.#enabled","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.#query","Smart-Home-Devices.a6abf997-7bee-414b-8dee-bb382017bf08.powerState","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.#delete","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.#enabled","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.#query","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.connectivity","Smart-Home-Devices.a6d0d999-34fa-4754-b41c-5788eda1fb0a.powerState","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.#delete","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.#enabled","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.#query","Smart-Home-Devices.a7b015c0-0613-46dd-95b7-523545662af2.powerState","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.#delete","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.#enabled","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.#query","Smart-Home-Devices.a8bac81b-376c-44a6-ba85-b5efa779f459.powerState","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.#delete","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.#enabled","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.#query","Smart-Home-Devices.aac30a47-5bf4-4efd-9539-3fe9ae6c4cde.powerState","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.#delete","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.#enabled","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.#query","Smart-Home-Devices.b06ef7b2-578a-40a0-957d-c07008a20f5b.powerState","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.#delete","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.#enabled","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.#query","Smart-Home-Devices.b1d9f44e-fd03-45d2-9e5d-acc1ee60ea06.powerState","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.#delete","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.#enabled","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.#query","Smart-Home-Devices.b4be7bf9-c90d-4607-92e5-239960cdec0b.powerState","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.#delete","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.#enabled","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.#query","Smart-Home-Devices.b5364c9e-e8fd-41f7-b4fa-a0edafbaa164.powerState","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.#delete","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.#enabled","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.#query","Smart-Home-Devices.b5c0ddc3-9e7a-4457-a1e7-5687f1fa1634.powerState","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.#delete","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.#enabled","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.#query","Smart-Home-Devices.b97b342d-4d2c-448e-a384-24c77b15843c.powerState","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.#delete","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.#enabled","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.#query","Smart-Home-Devices.bc2a4aa3-67fe-44f5-b575-870778a703ad.powerState","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.#delete","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.#enabled","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.#query","Smart-Home-Devices.bf6ce590-c811-477a-817d-458990eaf06d.powerState","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.#delete","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.#enabled","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.#query","Smart-Home-Devices.c2c94f4a-9b46-4252-89b6-b5b2bad9431c.powerState","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.#delete","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.#enabled","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.#query","Smart-Home-Devices.c5906261-960d-4c66-a162-14b01f6e9cd1.powerState","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.#delete","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.#enabled","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.#query","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.connectivity","Smart-Home-Devices.ceefd4fb-d317-4a38-a9a0-4a1da35136c4.powerState","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.#delete","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.#enabled","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.#query","Smart-Home-Devices.d13f6a67-d31a-42a6-90fb-903014a1e8a2.powerState","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.#delete","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.#enabled","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.#query","Smart-Home-Devices.d18aa706-d09e-4744-90f9-4cbb4c8af358.powerState","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.#delete","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.#enabled","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.#query","Smart-Home-Devices.d64a39fe-8ec4-48b0-9bd7-910ce6875650.powerState","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.#delete","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.#enabled","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.#query","Smart-Home-Devices.d8387e67-a631-4b83-a18a-fd4a3ea43670.powerState","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.#delete","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.#enabled","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.#query","Smart-Home-Devices.dad21e68-4b54-4a72-9cf4-de14aae58586.powerState","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.#delete","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.#enabled","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.#query","Smart-Home-Devices.dc172d58-49c1-444e-9a86-370fcb061a64.powerState","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.#delete","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.#enabled","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.#query","Smart-Home-Devices.dc8ebd65-9eb5-4913-9b89-024f1a49902a.powerState","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.#delete","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.#enabled","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.#query","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.connectivity","Smart-Home-Devices.de124003-490f-4dee-a2d8-e99c8c99d753.powerState","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.#delete","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.#enabled","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.#query","Smart-Home-Devices.de41e599-8221-4637-9215-881ed9c4ccc6.powerState","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.#delete","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.#enabled","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.#query","Smart-Home-Devices.dfccb154-b515-4b26-aea0-86899c5b29f9.powerState","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.#delete","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.#enabled","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.#query","Smart-Home-Devices.dffa2181-0cf4-4fd9-a7bd-78eacee9c7a6.powerState","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.#delete","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.#enabled","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.#query","Smart-Home-Devices.e63f2044-6640-4929-906e-2138a59ad0cb.powerState","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.#delete","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.#enabled","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.#query","Smart-Home-Devices.e647492b-b2c6-4eaa-b5e8-140991878aee.powerState","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.#delete","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.#enabled","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.#query","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.connectivity","Smart-Home-Devices.e6bf6ebd-7b50-4387-91f7-028383455a1a.powerState","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.#delete","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.#enabled","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.#query","Smart-Home-Devices.e74a34bf-7530-4f11-af5e-9a9c25055fd2.powerState","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.#delete","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.#enabled","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.#query","Smart-Home-Devices.e7885989-f118-4fba-b645-3081e7d9ff6a.powerState","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90.#delete","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90.#enabled","Smart-Home-Devices.ea93f7c8-dbd8-4e0f-89b9-9e7e413ccc90.powerState","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.#delete","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.#enabled","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.#query","Smart-Home-Devices.eb07e160-581f-49ba-9301-c0e9677b51cb.powerState","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.#delete","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.#enabled","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.#query","Smart-Home-Devices.ebd87f46-84c0-4b0a-b1d4-3088a64b3711.powerState","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.#delete","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.#enabled","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.#query","Smart-Home-Devices.ecd1fdc9-0348-4efa-baed-0d33af04ac48.powerState","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.#delete","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.#enabled","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.#query","Smart-Home-Devices.ed0d687d-c4d1-498b-a76e-1db283231982.powerState","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.#delete","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.#enabled","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.#query","Smart-Home-Devices.edb91df3-2918-4e6c-b8a7-c536f145306b.powerState","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.#delete","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.#enabled","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.#query","Smart-Home-Devices.ee829313-cec0-4845-8aa7-4476d5dc8921.powerState","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.#delete","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.#enabled","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.#query","Smart-Home-Devices.ef1f46ed-8217-4dd3-b618-e2c32027c58c.powerState","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.#delete","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.#enabled","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.#query","Smart-Home-Devices.f1dd3290-cef5-4981-aee6-09db69e73197.powerState","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61.#delete","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61.#enabled","Smart-Home-Devices.f3235c1a-7f6b-4e94-b14c-fdbfa8102c61.powerState","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.#delete","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.#enabled","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.#query","Smart-Home-Devices.f3737e74-3e7a-4505-b14c-ad4c11fe94c9.connectivity","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.#delete","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.#enabled","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.#query","Smart-Home-Devices.f4ac8cf5-8543-476a-be3d-60b296965822.powerState","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.#delete","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.#enabled","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.#query","Smart-Home-Devices.f5e0a2fe-a0e0-41a4-bf55-69f89935cc2c.powerState","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.#delete","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.#enabled","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.#query","Smart-Home-Devices.fd854de4-4c6d-4aef-bf40-c2fc2c089f51.powerState","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.#delete","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.#enabled","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.#query","Smart-Home-Devices.fe4955b1-cd38-4cc6-aa90-648d2b6346a9.powerState","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee.#enabled","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee.#delete","Smart-Home-Devices.6831de30-643b-40b7-aed6-47eaf343b1ee.powerState","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72.#enabled","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72.#delete","Smart-Home-Devices.3ea38a1d-4652-47c9-a5f9-dfd4e7859c72.powerState","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73.#enabled","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73.#delete","Smart-Home-Devices.00c21e90-4f85-4da3-87b7-d23fb6dd4f73.powerState","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#enabled","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#delete","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.powerState","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.connectivity","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.connectivity-reason","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#query","Smart-Home-Devices.4ac06f2d-3841-4a7b-9ea2-7d9603531af6.#includeInAllQuery","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae.#enabled","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae.#delete","Smart-Home-Devices.953a6575-bfe0-452b-9c7c-ec62b4343cae.powerState","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08.#enabled","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08.#delete","Smart-Home-Devices.64fc6b88-6e12-4354-aeed-8439683bac08.powerState","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692.#enabled","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692.#delete","Smart-Home-Devices.ea854d35-11ed-4e90-a55d-ab76ac221692.powerState","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0.#enabled","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0.#delete","Smart-Home-Devices.906ffd49-65f6-47b0-8bf7-b6ba997b3ee0.powerState","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42.#enabled","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42.#delete","Smart-Home-Devices.51b1fb71-f252-4665-94ef-79a9716c6f42.powerState","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681.#enabled","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681.#delete","Smart-Home-Devices.28589764-e273-4410-b9ee-1bf2c4bfc681.powerState","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44.#enabled","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44.#delete","Smart-Home-Devices.66d3ca09-37d4-4746-a687-80344be1df44.powerState","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94.#enabled","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94.#delete","Smart-Home-Devices.87ad0d6a-4c43-4ca0-9cb9-8ccbf7430d94.powerState","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f.#enabled","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f.#delete","Smart-Home-Devices.822481d2-47e0-4a07-8ac6-6743e7b2068f.powerState","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1.#enabled","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1.#delete","Smart-Home-Devices.a7f3274d-14f4-430b-8f48-8512add2a2b1.powerState","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb.#enabled","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb.#delete","Smart-Home-Devices.37dfbbf1-801b-4ad1-b67f-8126096d0dcb.powerState","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766.#enabled","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766.#delete","Smart-Home-Devices.f2129675-e660-48c8-9f98-7ccffd3df766.powerState","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c.#enabled","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c.#delete","Smart-Home-Devices.924d49f7-52df-43ec-bdb5-fa55f9f1eb1c.powerState","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb.#enabled","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb.#delete","Smart-Home-Devices.1b12edfe-0a2b-4a23-b5d3-b91a06d971bb.powerState","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf.#enabled","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf.#delete","Smart-Home-Devices.80a16a1c-d06e-4b23-9dd6-580e29790faf.powerState","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778.#enabled","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778.#delete","Smart-Home-Devices.99750e93-7351-41fe-878c-029545bd4778.powerState","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230.#enabled","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230.#delete","Smart-Home-Devices.af3bd733-6bb1-4f67-adfd-3a9dd9aff230.powerState","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c.#enabled","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c.#delete","Smart-Home-Devices.6f720b71-80af-4408-a0e4-231fdf43f27c.powerState","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c.#enabled","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c.#delete","Smart-Home-Devices.3a383b9a-1b21-4091-bba3-eb64573faf7c.powerState","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3.#enabled","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3.#delete","Smart-Home-Devices.230befba-f6b1-417f-8773-7516bfca33c3.powerState","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462.#enabled","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462.#delete","Smart-Home-Devices.6130d11e-b141-4ce4-96b6-fa1a3ea59462.powerState","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106.#enabled","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106.#delete","Smart-Home-Devices.c3b07261-e0e5-422f-98c5-f6527e988106.powerState","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569.#enabled","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569.#delete","Smart-Home-Devices.f0d748f5-73cb-48eb-8ed5-94866f44a569.powerState","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83.#enabled","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83.#delete","Smart-Home-Devices.4d91c8e8-ac53-4e9c-9da7-505a00a5bc83.powerState","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e.#enabled","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e.#delete","Smart-Home-Devices.4f1243da-eb04-4d7f-8451-5fbd50b5a37e.powerState","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df.#enabled","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df.#delete","Smart-Home-Devices.41d468ed-5c43-4c38-b2e0-506d629f09df.powerState","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36.#enabled","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36.#delete","Smart-Home-Devices.0cd24420-da38-46e1-9c32-f44247498b36.powerState","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3.#enabled","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3.#delete","Smart-Home-Devices.121a07d3-acef-4c1b-94d5-e091029a8db3.powerState","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541.#enabled","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541.#delete","Smart-Home-Devices.b2b9a980-2976-447e-853c-a95d43554541.powerState","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae.#enabled","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae.#delete","Smart-Home-Devices.40cff091-7beb-4013-aafa-f10f9733b4ae.powerState","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454.#enabled","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454.#delete","Smart-Home-Devices.1b3ea845-127d-4d40-8f25-fd64acf17454.powerState","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a.#enabled","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a.#delete","Smart-Home-Devices.eed9fcbf-8451-4673-920a-5a7dee82108a.powerState","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528.#enabled","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528.#delete","Smart-Home-Devices.9d18bcda-fc1e-4016-ab9b-67b8c5fda528.powerState","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb.#enabled","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb.#delete","Smart-Home-Devices.7da8181e-67c3-4cec-a446-b2f69e4684cb.powerState"]
      2024-08-16 10:02:46.462  - info: alexa2.0 (2356) Alexa-Push-Connection (macDms = true) established. Disable Polling
      2024-08-16 10:02:50.879  - info: alexa2.0 (2356) Initialization Done ...
      2024-08-16 10:02:58.087  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:02:58.468  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:03:04.559  - warn: shelly.0 (2367) [authEnabled] 192.168.178.58 (shelly1 / shelly1-E89F6D85A972 / SHSW-1#E89F6D85A972#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:03:14.693  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:03:15.762  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:03:32.089  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:03:34.866  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:03:48.956  - warn: shelly.0 (2367) [authEnabled] 192.168.178.182 (shelly1 / shelly1-E89F6D85E83C / SHSW-1#E89F6D85E83C#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-08-16 10:03:51.851  - warn: shelly.0 (2367) [authEnabled] 192.168.178.88 (shelly1 / shelly1-98CDAC2D9964 / SHSW-1#98CDAC2D9964#1): This device is not protected via restricted login (see adapter documentation for details)
      iob diag has finished.
      Press any key for a summary
      BananaJoe Homoran Thomas Braun 4 Replies Last reply Reply Quote 0
        klaris @Thomas Braun last edited by
        @thomas-braun sobald ich den backitup adapter instalieren möchte hängt das system sich auf ...
        • BananaJoe
          BananaJoe Most Active @klaris last edited by
          @klaris sagte in Node.js v16.20.2 update v18.20.4 sinvoll ?:
          *** RASPBERRY THROTTLING ***
          Current issues:
          ~ Under-voltage detected
          Previously detected issues:
          ~ Under-voltage has occurred
          Der Grund warum die Buchse so lahm ist ... Netzteil ist zu schwach, da fährt das System auf Sparbetrieb in dem es drosselt
            Homoran Global Moderator Administrators @klaris last edited by Homoran
            load average: 6.16, 3.09, 1.37
            da hast du wohl deinen
            Raspberry Pi 3 Model B Plus Rev 1.3
            etwas überfordert.
            dein 1GB RAM geht auch zu Ende
            • BananaJoe
              Und ja, ein neuerer Pi mit mehr Power könnte nicht schaden ... so ein 3er ist echt in die Jahre gekommen, ein 4er 5er wäre um ein vielfaches schneller.
                Thomas Braun Most Active @klaris last edited by
                Operating System: Raspbian GNU/Linux 11 (bullseye)
                Setz das in nächster Zeit komplett neu auf. Als Bookworm / Debian 12 in der 64Bit-Version.
                Mit einem User, der weder pi noch iobroker oder ähnlich heißt.
                Current issues:
                Deine Stromversorgung ist zu wackelig. Verwende ein gutes Netzteil, kein Handyladegerät oder sowas.
                *** Display-Server-Setup ***
                Display-Server: true
                Server immer ohne Desktop.
                [Fri Aug 16 09:55:36 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                [Fri Aug 16 09:55:36 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                [Fri Aug 16 09:55:38 2024] EXT4-fs (mmcblk0p2): recovery complete
                Kiste immer sauber herunterfahren. Schont das Dateisystem.
                ioBroker-Repositories
                Sind falsch angelegt.
                Die hängt sich nicht auf, die Kiste ist nur mehr als überlastet.
                  Homoran Global Moderator Administrators @BananaJoe last edited by
                  @bananajoe sagte in Node.js v16.20.2 update v18.20.4 sinvoll ?:
                  vor allem bei 25 geplanten Adaptern!
                  @klaris
                  1GB reicht maximal für <10, eher weniger.
                  Aber nur wenn sonst nichts drauf läuft.
                    klaris @Homoran last edited by klaris
                    @homoran danke Leute für die schnelle antwort und die guten tipps!! also lag es nicht daran das ich was falsch gemacht habe ....ich muss mir ein aktuelles model kaufen ...habe mein gute anker ladegerät erst mal angeschlossen 😊
                      Naja, das Setup ist auch strubbelig.
                        @thomas-braun sagte in Node.js v16.20.2 update v18.20.4 sinvoll ?:
                          @thomas-braun das kannst du laut sagen ... wie gesagt BackItUp lässt sich auch mit laaange warten nicht instalieren "system hängt sich auf ..der Adaptere kann den Genauen Gerätestatus nicht anfordern,der status wird anhand der zuletzt gesendeten Befehls vermutet"
                            @homoran wie das anker netzteil 30W ist auch nicht gut ?
                              wie der ist auch nicht gut ?
                              Ein LADEgerät ist halt kein NETZTEIL.
                                @thomas-braun ok wieder was gelernt !!!!
                                  nein, es braucht nur unheimlich lange wenn die Load >4 wird.
                                  Wenn dann noch der RAM ausgeht und alles über den
                                  MiB Swap: 100.0 total, 0.9 free, 99.1 used.
                                  SWAP ausgelagert wird ist nicht nur zähflüsdiger Verkehr, sondern massiver Stau
                                    @homoran wenn ich unötige adapter deinstaliere bringt das was ?
                                      im Moment sind ja nur wenige aktiv, wenn ich das diag sehe. Also nein!
                                      Wenn jetzt eine stabilere Stromversorgung dazu führt, dass die CPU nicht mehr gedrosselt wird, könntest du Glück mit dem Anker haben.
                                      was sagt denn aktuell incl. Header top?
                                        @homoran said in Node.js v16.20.2 update v18.20.4 sinvoll ?:
                                        so wie das system jetz läuft ist es ok....mehr brauche ich nicht ..wurde gerne noch einen backup adapter instalieren aber leider kein speicher..oder ich setze das system neu mit einer kleineren js und node version ?
                                        top - 11:25:33 up 14 min,  1 user,  load average: 0.17, 0.49, 0.62
                                        Tasks: 140 total,   1 running, 139 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s):  2.3 us,  0.6 sy,  0.0 ni, 96.9 id,  0.0 wa,  0.0 hi,  0.2 si,  0.0 st
                                        MiB Mem :    922.0 total,    104.5 free,    660.4 used,    157.0 buff/cache
                                        MiB Swap:    100.0 total,      1.7 free,     98.3 used.    209.5 avail Mem
                                          @klaris
                                          und der rest?
                                          die load ist runter, aber Speicher ist da nicht wirklich frei.
                                          der Swap ist auch schon wieder verbraucht
                                          EDIT:
                                          Keine nachträglichen Änderungen ohne Kennzeichnung!!
                                          da steht ja mittlerweile ganz was anderes
                                            @homoran ja der gute alte raspberry kommt an seine grenze
                                            was meinst du damit"Keine nachträglichen Änderungen ohne Kennzeichnung!!
                                            2058
