    4. Backup files not deleted from /opt/...s because some errors.
    • simatec
      simatec Developer Most Active @Alero last edited by
      @alero Genau ... bitte hier den vollständigen Log posten
        Homoran Global Moderator Administrators @Alero last edited by
        @alero
        @simatec sagte in Backup files not deleted from /opt/...s because some errors.:
        in deinem Screenshot ist das iobroker Backup schon durch!
        Etwaige Fehler dabei sind nicht zu sehen.
        • Codierknecht
          Codierknecht Developer Most Active @Alero last edited by Codierknecht
          @alero
          Kopiere den kompletten Text des Log und poste ihn hier ... in Code-Tags </>
            Alero @Codierknecht last edited by
            @codierknecht
            Hi, genau das habe ich doch im ersten post gemacht.
            Gut dann noch einmal.
            [DEBUG] [mount] cifs-mount command: "sudo mount -t cifs -o username=backup,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.42.100/backup/Iobroker/Standard /opt/iobroker/backups"
            [DEBUG] [mount] mount successfully completed
            [DEBUG] [mount] done
            [DEBUG] [iobroker] host.iobroker-prod-12 27132 states saved
            [DEBUG] [iobroker] host.iobroker-prod-12 28136 objects saved
            [DEBUG] [iobroker] Backup created: /opt/iobroker/backups/iobroker_2024_08_16-03_00_20_backupiobroker.tar.gz
            [DEBUG] [iobroker] This backup can only be restored with js-controller version up from 4.1
            [DEBUG] [iobroker] done
            [DEBUG] [influxDB] InfluxDB-Backup started ...
            [DEBUG] [influxDB] Start InfluxDB Backup ...
            [DEBUG] [influxDB] InfluxDB Backup tmp directory created
            [DEBUG] [influxDB] Packed 99MB so far...
            [DEBUG] [influxDB] Packed 201MB so far...
            [DEBUG] [influxDB] Packed 302MB so far...
            [DEBUG] [influxDB] Packed 362MB so far...
            [DEBUG] [influxDB] Packed 402MB so far...
            [DEBUG] [influxDB] Packed 412MB so far...
            [DEBUG] [influxDB] Packed 453MB so far...
            [DEBUG] [influxDB] Packed 493MB so far...
            [DEBUG] [influxDB] Packed 536MB so far...
            [DEBUG] [influxDB] Packed 640MB so far...
            [DEBUG] [influxDB] Packed 749MB so far...
            [DEBUG] [influxDB] Packed 854MB so far...
            [DEBUG] [influxDB] Packed 897MB so far...
            [DEBUG] [influxDB] Packed 939MB so far...
            [DEBUG] [influxDB] Packed 985MB so far...
            [DEBUG] [influxDB] Packed 1028MB so far...
            [DEBUG] [influxDB] Packed 1064MB so far...
            [DEBUG] [influxDB] Packed 1102MB so far...
            [DEBUG] [influxDB] Packed 1159MB so far...
            [DEBUG] [influxDB] Packed 1266MB so far...
            [DEBUG] [influxDB] Packed 1370MB so far...
            [DEBUG] [influxDB] Packed 1463MB so far...
            [DEBUG] [influxDB] Packed 1508MB so far...
            [DEBUG] [influxDB] Packed 1559MB so far...
            [DEBUG] [influxDB] Packed 1591MB so far...
            [DEBUG] [influxDB] Packed 1631MB so far...
            [DEBUG] [influxDB] Packed 1677MB so far...
            [DEBUG] [influxDB] Packed 1728MB so far...
            [DEBUG] [influxDB] Packed 1777MB so far...
            [DEBUG] [influxDB] Packed 1885MB so far...
            [DEBUG] [influxDB] Packed 1990MB so far...
            [DEBUG] [influxDB] Packed 2096MB so far...
            [DEBUG] [influxDB] Packed 2133MB so far...
            [DEBUG] [influxDB] Packed 2156MB so far...
            [DEBUG] [influxDB] Packed 2180MB so far...
            [DEBUG] [influxDB] Packed 2196MB so far...
            [DEBUG] [influxDB] Backup created: /opt/iobroker/backups/influxDB_2024_08_16-03_00_35_backupiobroker.tar.gz
            [DEBUG] [influxDB] Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_08_16-03_00_35_backupiobroker"
            [DEBUG] [influxDB] InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_08_16-03_00_35_backupiobroker" successfully deleted
            [DEBUG] [influxDB] InfluxDB-Backup for is finish
            [DEBUG] [influxDB] done
            [DEBUG] [grafana] Start Grafana Backup ...
            [DEBUG] [grafana] Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
            [DEBUG] [grafana] Created dashboard directory
            [DEBUG] [grafana] Created dashboards_manually_restore directory
            [DEBUG] [grafana] Created datasource directory
            [DEBUG] [grafana] start Grafana request ...
            [DEBUG] [grafana] Grafana is available ... Status: 200
            [DEBUG] [grafana] found Dashboard: fritz-box-router-status
            [DEBUG] [grafana] found Dashboard: test
            [DEBUG] [grafana] found Dashboard: photovoltaik
            [DEBUG] [grafana] found Dashboard: wetterstation
            [DEBUG] [grafana] found Dashboard: solar-pv-system
            [DEBUG] [grafana] found Dashboard: home-energy
            [DEBUG] [grafana] found Dashboard: open-weather-map
            [DEBUG] [grafana] found Dashboard: synology-dashboard
            [DEBUG] [grafana] found Dashboard: proxmox
            [DEBUG] [grafana] start Grafana backup compress ...
            [DEBUG] [grafana] Backup created: /opt/iobroker/backups/grafana_2024_08_16-03_15_51_backupiobroker.tar.gz
            [DEBUG] [grafana] Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
            [DEBUG] [grafana] Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
            [DEBUG] [grafana] done
            [DEBUG] [cifs] used copy path: /backup/Iobroker/Standard
            [DEBUG] [cifs] done
            [ERROR] [clean] Backup files not deleted from /opt/iobroker/backups because some errors.
            [DEBUG] [clean] done
            [DEBUG] [historyHTML] new history html values created
            [DEBUG] [historyHTML] done
            [DEBUG] [historyJSON] new history json values created
            [DEBUG] [historyJSON] done
            [DEBUG] [umount] mount active, umount is started ...
            [DEBUG] [umount] umount successfully completed
            [DEBUG] [umount] done
            [DEBUG] [email] [iobroker] used E-Mail-Instance: email.0
            [DEBUG] [email] done
            [DEBUG] [notification] Admin notification will be sent
            [DEBUG] [notification] done
            Homoran Codierknecht simatec 3 Replies Last reply Reply Quote 0
              @alero sagte in Backup files not deleted from /opt/...s because some errors.:
              dann könnte höchstens das die Ursache sein. verstehe ich aber nicht
              • Codierknecht
                Hmm, dachte da gibt's mittlerweile noch mehr zu sehen. Sorry.
                Da bin ich jetzt auch überfragt.
                Es ist ja kein wirklicher Fehler ersichtlich, der das Löschen verhindern würde.
                  Alero @Homoran last edited by
                  Hier bin ich seit gestern auf dem neusten Stand.js Controller und Co. Fehler immer noch da.
                    was willst du mir damit sagen?
                    damit sollte fas nichts zu tun haben.
                    Wenn, dann hat es was mit deinem Speicherort zu tun
                    sind die Backups da angekommen?
                    Was ist das?
                      Alero @Homoran last edited by Alero
                      ja sie kommen an. Das ist mein Sysnology Server.
                      • simatec
                        @alero
                        Was steht denn in deiner Mail zum Backup drin? Auch in den Notifications von iobroker sollte der Fehler angezeigt werden
                          Alero @simatec last edited by Alero
                          @simatec
                          Da stand nur das drin was er als Fehlermeldung angezeigt hat und das ich unter history nachschauen soll. Was ich dann gemacht habe.
                          Heute sind alle files gelöscht worden. Es waren bestimmt 30 files die er gelöscht hat. Fehler ist weg.
                          Warum keine Ahnung. Ich habe nichts geändert.
                          Jetzt kommt ab und zu diese FM
                          cannot call visUtils: Cannot convert undefined or null to object
                          Ich bin nicht im beta repository.
                          Danke für eure Hilfe.
                            mading @Alero last edited by
                            @simatec
                            Das sind zwei paar Schuhe meiner Meinung nach mit der Fehlermeldung (cannot call visUtils) und dass er die temp. Datei lokal im iob nicht löscht.
                            Ich hatte das gleiche Problem, dass er die lokale, temporär abgelegte Datei nicht gelöscht hat. Die Logik sieht vermutlich vor, dass wenn es bei der externen Ablage zu einem Fehler kommt, die lokale Datei nicht gelöscht wird. In meinem Fall hat die Ablage auf meiner Synology geklapt, nur die zusätzliche Ablage auf Dropbox nicht. Macht evtl. Sinn einzubauen, dass er lokal löscht sobald zumindest eine Kopie existiert. Ich erstelle mal einen Jira dazu…
                            Die Fehlermeldung cannot call visUtils habe ich seit dem Amin 7 update bzw. ggf seit dem jscontoller Update.
                              Alero @mading last edited by
                              @mading
                              hi,
                              "es sind zwei paar schuhe". ich weiss. Wollte es nur erwähnt haben.
                              vielen Dank für deine Hilfe und Infos.
                              597
