    4. Zeigt her eure Vis2
    Zeigt her eure Vis2
    • U
      UlliJ @hugo1217 last edited by
      @hugo1217
      so vielleicht, halt die Datenpunkte anpassen
       <variables>
         <variable id="T8/jDjgD!L{Z_}9#i|x:">Autarkie</variable>
       </variables>
       <block type="comment" id="!~h$$x-UZY0nKbx`a=dE" x="-934" y="77">
         <field name="COMMENT">Autarkie</field>
           <block type="on_ext" id="C3YxxzeO[J.Um`.P{Wp@">
             <value name="OID0">
               <shadow type="field_oid" id="JY!jc9Y?{At~^+W4ZJiC">
                 <field name="oid">ID auswählen</field>
             <value name="OID1">
               <shadow type="field_oid" id="xrsxPzV`:.}f(hMzHz{)">
               <block type="comment" id="8(-[*396xWm8M#.Gjb$]">
                 <field name="COMMENT">(1-Netzbezug/Hausverbrauch)*100</field>
                   <block type="variables_set" id="m;lYgNaf{69Sa(C!{?3y">
                     <field name="VAR" id="T8/jDjgD!L{Z_}9#i|x:">Autarkie</field>
                       <block type="math_rndfixed" id="o_L4L!rORa:;M?O$yGgE" inline="false">
                         <field name="n">1</field>
                         <value name="x">
                           <shadow type="math_number" id="_d-Aj,Yp=/epfAmgTzB:">
                             <field name="NUM">3.1234</field>
                           <block type="math_arithmetic" id="8A#0X^xck?x6^o*!YS+T" inline="false">
                               <shadow type="math_number" id="vjY?VgtpDFLIS3lGP!xk">
                                 <field name="NUM">1</field>
                               <block type="math_arithmetic" id="$)W{y1!R$DCR9^gGUW/^" inline="false">
                                   <shadow type="math_number" id="YkFi#^`fYeQdADL:rCI3">
                                   <shadow type="math_number" id="J=%qRGS[Hip%|ZQ/_fa9">
                                   <block type="math_arithmetic" id="U%]Ij5WW!j[xvb{_yN!;" inline="false">
                                     <field name="OP">DIVIDE</field>
                                       <shadow type="math_number" id="rOSrMrOWU[*+A~LkXf5(">
                                       <block type="get_value" id="AO5L0XOXe/S9]l-eRgQL">
                                         <field name="OID">ID auswählen</field>
                                       <shadow type="math_number" id="mC,1Rco$^H*h*=E.~!:?">
                                       <block type="get_value" id="]i`|//J77YMYrFlTl:LL">
                               <shadow type="math_number" id="BG8N_)[@$GX/uUnVYV%y">
                                 <field name="NUM">100</field>
                       <block type="update" id="d}v5QTv10-dq!6lQ8_*}">
                         <field name="OID">0_userdata.0.4000_EnergieErzeugung.Zaehler.Autarkie</field>
                           <block type="variables_get" id="Vn4}XRs/xr9!)ElL,`n:">
                           <block type="debug" id="nWz7zV{(vP4V]dA1pg[0">
                             <field name="Severity">info</field>
                             <value name="TEXT">
                               <shadow type="text" id=".u5z?6px~$#Ay;i,2Tvn">
                               <block type="variables_get" id="0*A253_zO81(P;^xb3=m">
       <block type="comment" id="urV=FF?a(NB8V9`vyzy7" x="-562" y="63">
         <field name="COMMENT">dein DP mit Netzbezug</field>
       <block type="comment" id="v00O75mIa6aTF[LMEAfm" x="-563" y="163">
         <field name="COMMENT">dein DP mit Hausverbrauch</field>
       <block type="comment" id="mt{i|1)wJ$!p@7`eC386" x="-263" y="237">
       <block type="comment" id="_mnpV1TTL,HQyxEaQLzv" x="-198" y="357">
        hugo1217 @UlliJ last edited by
        @ullij
        Super hat geklappt. Bei mir war eine leichte verwirrung da. Dachte es wäre der Live wert aber das ist der Tages wert.
        Versuche mal ein Live wert zu bekommen anhand deiner Funktion.
        Danke nochmal
        • icebear
          icebear last edited by
          @UlliJ
          @hugo1217
          Ich bin ja hier kein MOD oder ähnliches , aber vielleicht solltet ihr euer Thema in den Script/Logiken Bereich verschieben, sonst läuft der ursprüngliche Titel hier irgendwann ins leere.
          Das ganze läuft ein bischen am eigentlichen Thema vorbei.
          • Nashra
            Nashra Most Active Forum Testing @UlliJ last edited by
            @ullij sagte in Zeigt her eure Vis2:
            es ist etwas Arbeit aber die Seite mit der Energieübersicht ist soweit fertig...bis einem etwas neues einfällt.
            Edit: Damit es nicht so langweilig ist mit Animation für die Batterie (beim Entladen andersrum) und die Energieflüsse zwischen den einzelnen Teilen
            Hallo @UlliJ
            würdest du die Energie-View teilen, danke.
            • U
              UlliJ @Nashra last edited by
              @nashra
              bitte sehr
              energieMain.txt
              card_Leistung.txt
              cardBatterie.txt
              cardEnergieAktuell.txt
              cardEnergiefluss.txt
              cardEnergieInfo.txt
              cardPrognose.txt
              cardPV.txt
              DialogPVInfo.txt
              DialogCharts.txt
              Die PV Seite braucht noch den Slider von Inventwo.
              CSS für die Lade/Entladeanimation ins Projekt kopieren.
              .charge
                 background: linear-gradient(0deg, #4CAF50, #FFEB3B, #4CAF50, #FFEB3B);
                 background-size: 100% 300%;
                 animation: gradient-bgcharge 2s ease-in-out infinite;
                 animation-direction: normal;
                 height: 100vh;
              .discharge
                 background: linear-gradient(180deg, #4CAF50, #FFEB3B, #4CAF50, #FFEB3B);
                 animation-direction: reverse;
                 height: 100vh;
              Da fehlen jetzt noch scripte und wahrscheinlich noch mehr CSS für die Animationen der Svg's. Ausserdem nutze ich auch noch MDCss von Uhula, da werden Formatierungen fehlen. Probier einfach mal.
              P I 2 Replies Last reply Reply Quote 1
              • agreen
                agreen @Einstein2002 last edited by
                @einstein2002
                das ist das Standard Navi von VIS2.
                  ALEX_SH last edited by
                  @ullij
                  Wie bekommst du bei der Sonnenbatterie die Arbeit raus? sprich Wh bzw kWh des aktuellen Tages? ich bekomme nur die Momentanleistung.
                  Vielen Dank
                  Viele Grüße
                  • U
                    @alex_sh
                    sind selbst gebaute Zähler. Bedient werden die aus einem Blockly für die Integration der Leistung über der Zeit. Die Tageszähler werden nachts auf 0 gesetzt.
                    ein Ausschnitt
                    Viele Grüße
                      ALEX_SH @UlliJ last edited by
                      @ullij hey danke für die Info, das werd ich auch mal versuchen umzusetzen.
                      • N
                        NoVinoPhobie @ALEX_SH last edited by
                        @alex_sh Du kannst auch den SourceAnalytix nehmen. Der summiert dir die Istwerte auf, dass du den bisherigen Verbrauch/Ertrag hast. Das dann auch für heute, gestern, die einzelnen Wochentage, Monat, Jahr, Quartal.
                          Einstein2002 @agreen last edited by Einstein2002
                          @agreen
                          Moin,
                          meinst Du es wäre sehr unverschämt wenn ich Dich Bitten würde die VIS2 oder Teile davon zu Teilen?
                          Es gab doch mit der VIS1 mal eine Seite da hat fast jeder seine VIS zum Download angeboten. Oder irre ich mich?
                          Vielen Dank für dies Großartige Forum und die vielen Helfer bei den Fragen.
                          agreen 1 Reply Last reply Reply Quote 0
                          • miwi
                            miwi last edited by
                            Anzeige über Tablet eingebaut in der Seitenwange des Flurschranks.
                            I Crazy32 2 Replies Last reply Reply Quote 2
                            • agreen
                              agreen @Einstein2002 last edited by agreen
                              @einstein2002
                              habs hier hochgeladen ...
                              guckst du
                              E R 2 Replies Last reply Reply Quote 1
                                @agreen
                                Danke, habe es eben erst gesehen, dann werde ich mal schauen ob ich es irgendwie umsetzten kann.
                                Ganz lieben Dank!
                                Michael
                                  ple @UlliJ last edited by
                                  @ullij Kurze Frage, könntest du vielleicht dein ganzen Projekt teilen? Ich hätte da sehr großes Interesse daran.
                                  Gruß und Besten Dank.
                                  • U
                                    UlliJ last edited by UlliJ
                                    @ple
                                    würde ich gerne, ist aber wohl zu gross für das Forum und der Reimport funktioniert auch gerade nicht...möchte sehen was da exportiert wird.
                                    Edit: alle Bilder und Schriftarten raus genommen, dann geht es
                                    2024-10-20anonym.zip
                                    Aber: vieles ist nicht fertig, geht noch nicht wie gewollt und ich habe Zweifel das Du damit froh wirst.
                                    ich hatte schon mal etwas exportiert (https://forum.iobroker.net/topic/73231/zeigt-her-eure-vis2/29?_=1729318063625), hilft Dir das schon weiter?
                                    • I
                                      iobroker2001 @miwi last edited by
                                      @miwi So muss eine Visualisierung aussehen, gefällt mir sehr gut!
                                      • Negalein
                                        @miwi sagte in Zeigt her eure Vis2:
                                        könntest du für mich einen Export machen?
                                        miwi 1 Reply Last reply Reply Quote 0
                                        • miwi
                                          miwi @Negalein last edited by
                                          @negalein Gerne. Hier ist die Zip Datei mit dem View und den Grafiken. Aus Datenschutzgründen habe ich die benutzten Aktoren mit XXXX versehen.
                                          miwi
                                          Viewmiwi.zip
                                            rallef @miwi last edited by
                                            @miwi Hallo,
                                            wie kann ich die zip Datei in vis-2 importieren. Bekomme immer eine Fehler?
                                            69
                                            12736
