    3. Einsteigerfragen
    4. Automatisierung
    5. goto in node red
    goto in node red
      bynight @bynight last edited by bynight
      @bynight Hallo Micky, ich hab schon wieder ne Frage:
      ich bekomme von dem Shelly die 3 Phasen korrekt angezeigt.
      Aber sobald ich den SummenNode für die Gesamtleistung anhänge bekomme ich TypeError: Cannot read properties of undefined (reading 'toString'). Hinter den Victron Nodes funktioniert der SummenNode aber.
      Lese ich den Shelly falsch aus oder fehlt weiter hinten noch was oder passt der Summen Node nicht?
      Danke und Gruß,
      Ronald
      [{"id":"89fd986bbb999da8","type":"ui_artlessgauge","z":"82e5452c01cee4bf","group":"e428548ce9e7be58","order":14,"width":8,"height":1,"name":"Summe Shelly 3EM #02","icon":"fa-bar-chart","label":"Summe Shelly 3EM #02","unit":"W","layout":"linear","decimals":"0","differential":true,"minmax":false,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload","secondary":"secondary","inline":false,"animate":true,"sectors":[{"val":-10000,"col":"#00ff00","t":"min","dot":1},{"val":-2000,"col":"#28c828","t":"sec","dot":0},{"val":0,"col":"#cccc00","t":"sec","dot":0},{"val":4400,"col":"#fb6565","t":"sec","dot":0},{"val":7000,"col":"#ff00ff","t":"sec","dot":0},{"val":10000,"col":"#ff00ff","t":"max","dot":1}],"lineWidth":"5","bgcolorFromTheme":true,"diffCenter":"0","x":1270,"y":2560,"wires":[]},{"id":"47f64f65b6d5e911","type":"shelly-gen1","z":"82e5452c01cee4bf","hostname":"192.168.178.84","description":"Shelly 3EM #02","mode":"polling","verbose":false,"server":"","outputmode":"event","uploadretryinterval":5000,"pollinginterval":"5000","pollstatus":true,"getstatusoncommand":true,"devicetype":"SHEM-3","devicetypemustmatchexactly":true,"outputs":1,"x":638,"y":2581,"wires":[["38c5a45ce8d0c7b5","d7ba4e620986b182","197d5eb7ccfdfac4"]]},{"id":"06b36d06d4c01cc4","type":"ui_artlessgauge","z":"82e5452c01cee4bf","group":"e428548ce9e7be58","order":15,"width":8,"height":1,"name":"Shelly 3EM #03","icon":"fa-bar-chart","label":"Shelly 3EM #03","unit":"W","layout":"linear","decimals":"0","differential":true,"minmax":false,"colorTrack":"#555555","style":"","colorFromTheme":true,"property":"payload","secondary":"secondary","inline":false,"animate":true,"sectors":[{"val":-4000,"col":"#00ff00","t":"min","dot":1},{"val":-2000,"col":"#28c828","t":"sec","dot":0},{"val":0,"col":"#cccc00","t":"sec","dot":0},{"val":4400,"col":"#fb6565","t":"sec","dot":0},{"val":7000,"col":"#ff00ff","t":"sec","dot":0},{"val":10000,"col":"#ff00ff","t":"max","dot":1}],"lineWidth":"5","bgcolorFromTheme":true,"diffCenter":"0","x":540,"y":2680,"wires":[]},{"id":"70c8facf6744462c","type":"debug","z":"82e5452c01cee4bf","name":"debug 62","active":false,"tosidebar":true,"console":true,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"auto","x":1009,"y":2561,"wires":[]},{"id":"38c5a45ce8d0c7b5","type":"function","z":"82e5452c01cee4bf","name":"function 7","func":"var newmsg = {payload: msg.payload.emeters[0].power};\nreturn newmsg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":838,"y":2581,"wires":[["70c8facf6744462c","686c871ac2585c7e"]]},{"id":"af6c890c54e4ec5a","type":"debug","z":"82e5452c01cee4bf","name":"debug 64","active":false,"tosidebar":true,"console":true,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1008,"y":2621,"wires":[]},{"id":"d7ba4e620986b182","type":"function","z":"82e5452c01cee4bf","name":"function 8","func":"var newmsg = {payload: msg.payload.emeters[1].power};\nreturn newmsg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":838,"y":2621,"wires":[["af6c890c54e4ec5a"]]},{"id":"e3f2e33ffab7bb36","type":"debug","z":"82e5452c01cee4bf","name":"debug 65","active":false,"tosidebar":true,"console":true,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1009,"y":2681,"wires":[]},{"id":"197d5eb7ccfdfac4","type":"function","z":"82e5452c01cee4bf","name":"function 9","func":"var newmsg = {payload: msg.payload.emeters[2].power};\nreturn newmsg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":838,"y":2661,"wires":[["e3f2e33ffab7bb36"]]},{"id":"686c871ac2585c7e","type":"sum","z":"82e5452c01cee4bf","name":"","topic":"","x":1190,"y":2620,"wires":[["89fd986bbb999da8","55c58fb1d96329a5"]]},{"id":"55c58fb1d96329a5","type":"debug","z":"82e5452c01cee4bf","name":"Summe Shelly","active":false,"tosidebar":true,"console":true,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1250,"y":2680,"wires":[]},{"id":"e428548ce9e7be58","type":"ui_group","name":"links","tab":"2dbf5f84d75bd5b7","order":1,"disp":false,"width":8,"collapse":false,"className":""},{"id":"2dbf5f84d75bd5b7","type":"ui_tab","name":"ATB18 Dashboard","icon":"fa-flash","order":1,"disabled":false,"hidden":false}]
      • mickym
        mickym Most Active @bynight last edited by
        @bynight Mit Summennodes oder so einem Schmarn arbeite ich nicht. Ich benutze für einfache Berechnungen immer nur die Standardnodes. Ausserdem vermeide ich function Nodes wo immer es geht. Wenn Du aber Summen periodisch zusammenzählen willst, dann benötigst du wohl den Kontext der function Nodes - insofern kann Deine Summennode eine Vereinfachung darstellen.
        Wenn die Summennode hinter der Shelly Node funktioniert, hinter der function Node nicht, dann hast du mit der function Node das Nachrichtenobjekt so verändert, dass diese nicht mehr funktioniert.
        Dazu müsstest Du über eine Debug ausgabe - die Nachrichtenobjekte, sowie den Fehler aus der Summennode sowie deren Definition zeigen.
        Ich kann mir leider nicht jede Node installieren, die sich irgendjemand mal installiert hat.
          bynight @mickym last edited by bynight
          @mickym wie komme ich an den Kontext einzelner Nodes, speziell der Funktion Node?
          Der Summennode funktioniert hinter den Victrons, nicht hinter dem Shelly!
          Im Debug hinter den Function Nodes wird jeweils ordentlich der Leistungswert ausgegeben.
          Nur die Summe aller drei bekomme ich nicht hin. Sobald ich den Summen Node an einen der Function Nodes hänge, bekomme ich rote Fernster.
          Bei Victron funzt es, bei Shelly nicht:
          vllt passt ja der Text in den function Nodes nicht:
          return newmsg;
          • mickym
            @bynight klick halt mal auf die node-id umzu sehen, welche node den fehler ausspukt.
              @mickym es ist die node-red-contrib-sum:
              • mickym
                @bynight Gut dann kann ja der Fehler nur aus der function Node 8 kommen. Also diese auf Fehler überprüfen bzw. im Protokoll schauen, ob da manchmal keine Zahlenwerte rauskommen.
                  @mickym ist nicht nur bei der 8, auch bei 7 und 9... auch wenn ich einen Switch verwende :
                  selbes Ergebnis... 😕
                  • mickym
                    @bynight Ja dann scheint halt nicht immer dieser Wert aus dem Shelly zu kommen und Du musst ggf. abfangen, wenn dieser Wert Null ist.
                      @mickym nach langer Suche im Netz bin ich nun fündig geworden:
                      Shelly scheint die Summe zu liefern, obwohl ich den Wert im Array nicht finden kann:
                      Somit ist es ganz einfach, entweder per Function oder per Switch:
                      • mickym
                        @bynight Na dann ist ja alles gut! 🙂
                          @mickym ja endlich :-))) und nun hab ich auch noch das Summieren rausgekriegt...
                          im Switch:
                          oder in Function:
                          überall dasselbe Ergebnis :-)))
                          Du hast das Thema übrigens 2023 schon mal behandelt. Der Fragesteller hat fast dieselben Ansätze gehabt wie ich... 😉
                          Die Lösung habe ich dann aber erst hier ganz unten gefunden...
                          link text
                          Danke für die Hilfe!
                          Und Grüße,
                          Ronald
                          • mickym
                            @bynight Das geht aber mit JSONATa viel einfacher.
                            Zeig mal das komplette Array hier in CodeTags. Kopiere einfach den Wert über die Schaltfläche aus dem Debugfenster und stell ihn hier in CodeTags ein.
                              @mickym meinst Du das hier?
                              17.8.2024, 01:43:01node: debug 66
                              msg : Object
                              object
                              status: object
                              wifi_sta: object
                              cloud: object
                              mqtt: object
                              time: "01:43"
                              unixtime: 1723851795
                              serial: 391
                              has_update: false
                              mac: "485519DB63BC"
                              cfg_changed_cnt: 0
                              actions_stats: object
                              relays: array[1]
                              emeters: array[3]
                              0: object
                              1: object
                              2: object
                              total_power: 272.12
                              emeter_n: object
                              fs_mounted: true
                              v_data: 1
                              ct_calst: 0
                              update: object
                              ram_total: 49920
                              ram_free: 30904
                              fs_size: 233681
                              fs_free: 153612
                              uptime: 7981
                              payload: object
                              relays: array[1]
                              0: object
                              emeters: array[3]
                              0: object
                              1: object
                              2: object
                              _msgid: "5ae6ba6a42a5c12a"
                              Jetzt sehe ich auch die Total Power im Status. Bisher habe ich immer nur relays und emeters gesehen. Den Status Reiter habe ich bisher nie gesehen... 😕
                              Was soll denn einfacher gehen als ein Switch mit status.total_power drin oder eben die 3 Power Werte addiert?
                              Das ist alles für 3 Shellys und 9 Phasen...
                              • mickym
                                mickym Most Active @bynight last edited by mickym
                                @bynight sagte in goto in node red:
                                msg : Object
                                object
                                status: object
                                wifi_sta: object
                                cloud: object
                                mqtt: object
                                time: "01:43"
                                serial: 391
                                has_update: false
                                mac: "485519DB63BC"
                                cfg_changed_cnt: 0
                                relays: array[1]
                                emeters: array[3]
                                0: object
                                1: object
                                2: object
                                total_power: 272.12
                                emeter_n: object
                                fs_mounted: true
                                v_data: 1
                                ct_calst: 0
                                update: object
                                ram_total: 49920
                                ram_free: 30904
                                fs_size: 233681
                                fs_free: 153612
                                uptime: 7981
                                payload: object
                                relays: array[1]
                                0: object
                                emeters: array[3]
                                0: object
                                1: object
                                2: object
                                Nein so genau nicht. Nichts mit der Maus markieren, sondern das Objekt schön über die Schaltfläche Wert kopieren und dann in die Zwischen ablage kopieren und dann hier in Codetags reinstellen.
                                Also wenn Deine payload bzw. Teile Deines Nachrichtenobjektes warscheinich so aussieht
                                  "payload": {
                                    "emeters": [
                                        "power": 20
                                        "power": 120
                                        "power": 220
                                        "power": 30
                                Dann kannst Du das mit JSONATA einfach so aufsummieren:
                                $sum(payload.emeters.power)
                                Testen kannst Du auch solche Sachen direkt im JSONATA exerciser: https://try.jsonata.org/Pel8ES7G0
                                • mickym
                                  im Switch:
                                  Ausserdem läst man in JSONATA das msg weg, sondern greift direkt auf die Namen des Objektes zu.
                                  6306
