    4. js-controller 6.0.x jetzt für alle User im STABLE!
    • JoJo58
      JoJo58 @crunchip last edited by
      @crunchip @Thomas-Braun
      Hier das Ergebnis:
      Summary:
                             v.2024-05-22
      Static hostname: vm-iobroker
            Icon name: computer-vm
              Chassis: vm 🖴
       Virtualization: kvm
               Kernel: Linux 6.1.0-23-amd64
         Architecture: x86-64
      Hardware Vendor: QEMU
       Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               64 bit
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      Display-Server:         false
      Boot Target:            graphical.target
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/nodejs         v20.16.0
      /usr/bin/node           v20.16.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.28.2
      Recommended versions are nodejs 20.16.0 and npm 10.8.1
      MEMORY:
      Mem:             16G        5.7G         10G        1.1M        1.4G         11G
      Swap:           1.0G          0B        1.0G
      Total:           17G        5.7G         11G
      Active iob-Instances:   62
      Upgrade policy: none
      ioBroker Core:          js-controller           6.0.9
                             admin                   7.0.22
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : vm-iobroker                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : vm-iobroker                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.web.1                    : web                   : vm-iobroker                              -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
      Objects:                72049
      States:                 65059
      Size of iob-Database:
      129M    /opt/iobroker/iobroker-data/objects.jsonl
      236M    /opt/iobroker/iobroker-data/states.jsonl
      Langfassung:
      Skript v.2024-05-22
      *** BASE SYSTEM ***
              Chassis: vm 🖴
       Virtualization: kvm
      model name      : QEMU Virtual CPU version 2.5+
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
      12:40:31 up 37 min,  2 users,  load average: 0.98, 1.28, 1.06
      CPU threads: 8
      *** Time and Time Zones ***
                    Local time: Fri 2024-08-16 12:40:31 CEST
                Universal time: Fri 2024-08-16 10:40:31 UTC
                      RTC time: Fri 2024-08-16 10:40:31
                   NTP service: active
               RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      smarthome
      HOME=/home/smarthome
      GROUPS=smarthome cdrom floppy audio dip video plugdev users netdev bluetooth lpadmin scanner iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth redis
      *** Display-Server-Setup ***
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:             16G        5.7G         10G        1.1M        1.3G         11G
      Swap:           1.0G          0B        1.0G
      Total:           17G        5.7G         11G
             15991 M total memory
              5451 M used memory
               440 M active memory
              5533 M inactive memory
              9620 M free memory
                89 M buffer memory
              1121 M swap cache
               974 M total swap
                 0 M used swap
               974 M free swap
      top - 12:40:31 up 37 min,  2 users,  load average: 0.98, 1.28, 1.06
      Tasks: 235 total,   3 running, 232 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 40.0 us,  0.0 sy,  0.0 ni, 60.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  15991.7 total,   9624.3 free,   5447.1 used,   1210.9 buff/cache
      MiB Swap:    975.0 total,    975.0 free,      0.0 used.  10544.6 avail Mem
      *** FAILED SERVICES ***
       UNIT               LOAD   ACTIVE SUB    DESCRIPTION
      * networking.service loaded failed failed Raise network interfaces
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** FILESYSTEM ***
      Filesystem            Type      Size  Used Avail Use% Mounted on
      udev                  devtmpfs  7.8G     0  7.8G   0% /dev
      tmpfs                 tmpfs     1.6G 1008K  1.6G   1% /run
      /dev/sda1             ext4       62G   44G   16G  74% /
      tmpfs                 tmpfs     7.9G     0  7.9G   0% /dev/shm
      tmpfs                 tmpfs     5.0M     0  5.0M   0% /run/lock
      192.168.1.6:/RasPi-BU nfs        11T  9.6T  1.2T  89% /mnt/backup
      tmpfs                 tmpfs     1.6G   28K  1.6G   1% /run/user/1000
      [Fri Aug 16 12:03:05 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Aug 16 12:03:05 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET                                                  SOURCE                FSTYPE          OPTIONS
      /                                                       /dev/sda1             ext4            rw,relatime,errors=remount-ro
      |-/sys                                                  sysfs                 sysfs           rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security                                securityfs            securityfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                                      cgroup2               cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore                                      pstore                pstore          rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf                                         bpf                   bpf             rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/tracing                                 tracefs               tracefs         rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/debug                                   debugfs               debugfs         rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections                            fusectl               fusectl         rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config                                  configfs              configfs        rw,nosuid,nodev,noexec,relatime
      |-/proc                                                 proc                  proc            rw,nosuid,nodev,noexec,relatime
      | `-/proc/sys/fs/binfmt_misc                            systemd-1             autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=13983
      |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc           binfmt_misc     rw,nosuid,nodev,noexec,relatime
      |-/dev                                                  udev                  devtmpfs        rw,nosuid,relatime,size=8155500k,nr_inodes=2038875,mode=755,inode64
      | |-/dev/pts                                            devpts                devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                                            tmpfs                 tmpfs           rw,nosuid,nodev,inode64
      | |-/dev/mqueue                                         mqueue                mqueue          rw,nosuid,nodev,noexec,relatime
      | `-/dev/hugepages                                      hugetlbfs             hugetlbfs       rw,relatime,pagesize=2M
      |-/run                                                  tmpfs                 tmpfs           rw,nosuid,nodev,noexec,relatime,size=1637556k,mode=755,inode64
      | |-/run/lock                                           tmpfs                 tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
      | |-/run/credentials/systemd-sysusers.service           ramfs                 ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-sysctl.service             ramfs                 ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                 ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                 ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/rpc_pipefs                                     sunrpc                rpc_pipefs      rw,relatime
      | `-/run/user/1000                                      tmpfs                 tmpfs           rw,nosuid,nodev,relatime,size=1637552k,nr_inodes=409388,mode=700,uid=1000,gid=1000,inode64
      |   `-/run/user/1000/gvfs                               gvfsd-fuse            fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      `-/mnt/backup                                           192.168.1.6:/RasPi-BU nfs             rw,relatime,vers=3,rsize=32768,wsize=32768,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.1.6,mountvers=3,mountport=30000,mountproto=udp,local_lock=none,addr=192.168.1.6
      /var:
      4.9G    /var/
      2.9G    /var/log/journal/16b2cb0d6af74575856d4757cf8a865a
      2.9G    /var/log
      1.7G    /var/cache/apt
      Archived and active journals take up 2.0G in the file system.
      /opt/iobroker/backups:
      25G     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.8G    /opt/iobroker/iobroker-data/
      1.2G    /opt/iobroker/iobroker-data/files
      441M    /opt/iobroker/iobroker-data/files/javascript.admin
      409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      208M    /opt/iobroker/iobroker-data/states.jsonl
      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyUSB0
      *** NodeJS-Installation ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
       Installed: 20.16.0-1nodesource1
       Candidate: 20.16.0-1nodesource1
       Version table:
      *** 20.16.0-1nodesource1 1001
             500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
             100 /var/lib/dpkg/status
          20.15.1-1nodesource1 1001
          20.15.0-1nodesource1 1001
          20.14.0-1nodesource1 1001
          20.13.1-1nodesource1 1001
          20.13.0-1nodesource1 1001
          20.12.2-1nodesource1 1001
          20.12.1-1nodesource1 1001
          20.12.0-1nodesource1 1001
          20.11.1-1nodesource1 1001
          20.11.0-1nodesource1 1001
          20.10.0-1nodesource1 1001
          20.9.0-1nodesource1 1001
          20.8.1-1nodesource1 1001
          20.8.0-1nodesource1 1001
          20.7.0-1nodesource1 1001
          20.6.1-1nodesource1 1001
          20.6.0-1nodesource1 1001
          20.5.1-1nodesource1 1001
          20.5.0-1nodesource1 1001
          20.4.0-1nodesource1 1001
          20.3.1-1nodesource1 1001
          20.3.0-1nodesource1 1001
          20.2.0-1nodesource1 1001
          20.1.0-1nodesource1 1001
          20.0.0-1nodesource1 1001
          18.19.0+dfsg-6~deb12u2 500
             500 http://deb.debian.org/debian bookworm/main amd64 Packages
          18.19.0+dfsg-6~deb12u1 500
             500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.9
      admin:          7.0.22
      javascript:     8.7.6
      nodejs modules from github:     6
      +-- iobroker.alexa2@3.26.5 (git+ssh://git@github.com/Apollon77/ioBroker.alexa2.git#37160cf729a9c70ca70679d4b1d3c16ba51c6456)
      +-- iobroker.drops-weather@0.3.1 (git+ssh://git@github.com/inbux/ioBroker.drops-weather.git#608ed1fcbbde3f59b6a09f2f188b92823481ae90)
      +-- iobroker.life360@0.2.22 (git+ssh://git@github.com/MiGoller/ioBroker.life360.git#23166aab1b2e36d917a9b7b480d9faa7f73ca2d1)
      +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#b9a3db457ac1a6e1ef4b7ab6edcfddc0388e4b19)
      +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
      +-- iobroker.vis-owl@0.2.13 (git+ssh://git@github.com/gerbuchner/ioBroker.vis-owl.git#26f227f5d70d75b265c03bb40c3e400d90013b84)
      Adapter State
      + system.adapter.alexa2.0                 : alexa2                : vm-iobroker                              -  enabled
       system.adapter.alias-manager.0          : alias-manager         : vm-iobroker                              - disabled
      + system.adapter.backitup.0               : backitup              : vm-iobroker                              -  enabled
      + system.adapter.backitup.1               : backitup              : vm-iobroker                              -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : vm-iobroker                              -  enabled
      + system.adapter.cloud.0                  : cloud                 : vm-iobroker                              -  enabled
      + system.adapter.cloud.1                  : cloud                 : vm-iobroker                              -  enabled
       system.adapter.daswetter.0              : daswetter             : vm-iobroker                              -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : vm-iobroker                              -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : vm-iobroker                              -  enabled
       system.adapter.devices.0                : devices               : vm-iobroker                              - disabled
      + system.adapter.discovery.0              : discovery             : vm-iobroker                              -  enabled
      + system.adapter.drops-weather.0          : drops-weather         : vm-iobroker                              -  enabled
       system.adapter.dwd.0                    : dwd                   : vm-iobroker                              -  enabled
      + system.adapter.echarts.0                : echarts               : vm-iobroker                              -  enabled
      + system.adapter.email.0                  : email                 : vm-iobroker                              -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : vm-iobroker                              -  enabled
       system.adapter.feiertage.0              : feiertage             : vm-iobroker                              -  enabled
       system.adapter.flot.0                   : flot                  : vm-iobroker                              - disabled
      + system.adapter.fullybrowser.0           : fullybrowser          : vm-iobroker                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : vm-iobroker                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : vm-iobroker                              -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : vm-iobroker                              -  enabled, port: 0
      + system.adapter.hm-rpc.3                 : hm-rpc                : vm-iobroker                              -  enabled, port: 0
      + system.adapter.hue.0                    : hue                   : vm-iobroker                              -  enabled, port: 443
       system.adapter.ical.0                   : ical                  : vm-iobroker                              -  enabled
       system.adapter.ical.1                   : ical                  : vm-iobroker                              -  enabled
       system.adapter.iceroad.0                : iceroad               : vm-iobroker                              -  enabled
       system.adapter.icons-icons8.0           : icons-icons8          : vm-iobroker                              - disabled
       system.adapter.icons-mfd-png.0          : icons-mfd-png         : vm-iobroker                              - disabled
       system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : vm-iobroker                              - disabled
      + system.adapter.influxdb.0               : influxdb              : vm-iobroker                              -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : vm-iobroker                              -  enabled
      + system.adapter.iot.0                    : iot                   : vm-iobroker                              -  enabled
      + system.adapter.javascript.0             : javascript            : vm-iobroker                              -  enabled
       system.adapter.life360.0                : life360               : vm-iobroker                              - disabled
      + system.adapter.linux-control.0          : linux-control         : vm-iobroker                              -  enabled
      + system.adapter.logparser.0              : logparser             : vm-iobroker                              -  enabled
       system.adapter.material.0               : material              : vm-iobroker                              - disabled
       system.adapter.meteoalarm.0             : meteoalarm            : vm-iobroker                              -  enabled
       system.adapter.meteoalarm.1             : meteoalarm            : vm-iobroker                              -  enabled
       system.adapter.meteoalarm.2             : meteoalarm            : vm-iobroker                              -  enabled
       system.adapter.meteoalarm.3             : meteoalarm            : vm-iobroker                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : vm-iobroker                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.net-tools.0              : net-tools             : vm-iobroker                              -  enabled
      + system.adapter.notification-manager.0   : notification-manager  : vm-iobroker                              -  enabled
      + system.adapter.nuki-extended.0          : nuki-extended         : vm-iobroker                              -  enabled
      + system.adapter.nut.0                    : nut                   : vm-iobroker                              -  enabled
      + system.adapter.operating-hours.0        : operating-hours       : vm-iobroker                              -  enabled
      + system.adapter.parcel.0                 : parcel                : vm-iobroker                              -  enabled
      + system.adapter.parcel.1                 : parcel                : vm-iobroker                              -  enabled
      + system.adapter.ping.0                   : ping                  : vm-iobroker                              -  enabled
      + system.adapter.pollenflug.0             : pollenflug            : vm-iobroker                              -  enabled
      + system.adapter.proxmox.0                : proxmox               : vm-iobroker                              -  enabled, port: 8006
      + system.adapter.pushover.0               : pushover              : vm-iobroker                              -  enabled
      + system.adapter.pushover.1               : pushover              : vm-iobroker                              -  enabled
      + system.adapter.pushover.2               : pushover              : vm-iobroker                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : vm-iobroker                              -  enabled
      + system.adapter.samsung_tizen.0          : samsung_tizen         : vm-iobroker                              -  enabled, port: 8002
      + system.adapter.scenes.0                 : scenes                : vm-iobroker                              -  enabled
       system.adapter.schoolfree.0             : schoolfree            : vm-iobroker                              -  enabled
      + system.adapter.shelly.0                 : shelly                : vm-iobroker                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : vm-iobroker                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.snmp.0                   : snmp                  : vm-iobroker                              -  enabled
      + system.adapter.socketio.0               : socketio              : vm-iobroker                              -  enabled, port: 8094, bind: 0.0.0.0, run as: admin
      + system.adapter.sourceanalytix.0         : sourceanalytix        : vm-iobroker                              -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : vm-iobroker                              -  enabled
      + system.adapter.telegram.0               : telegram              : vm-iobroker                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : vm-iobroker                              -  enabled
      + system.adapter.tr-064.0                 : tr-064                : vm-iobroker                              -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : vm-iobroker                              -  enabled
      + system.adapter.upnp.0                   : upnp                  : vm-iobroker                              -  enabled
       system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : vm-iobroker                              - disabled
       system.adapter.vis-colorpicker.0        : vis-colorpicker       : vm-iobroker                              - disabled
       system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : vm-iobroker                              - disabled
       system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : vm-iobroker                              - disabled
       system.adapter.vis-icontwo.0            : vis-icontwo           : vm-iobroker                              - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : vm-iobroker                              -  enabled
       system.adapter.vis-justgage.0           : vis-justgage          : vm-iobroker                              - disabled
       system.adapter.vis-map.0                : vis-map               : vm-iobroker                              - disabled
       system.adapter.vis-material-advanced.0  : vis-material-advanced : vm-iobroker                              - disabled
       system.adapter.vis-material-webfont.0   : vis-material-webfont  : vm-iobroker                              - disabled
       system.adapter.vis-materialdesign.0     : vis-materialdesign    : vm-iobroker                              - disabled
       system.adapter.vis-metro.0              : vis-metro             : vm-iobroker                              - disabled
       system.adapter.vis-owl.0                : vis-owl               : vm-iobroker                              - disabled
       system.adapter.vis-timeandweather.0     : vis-timeandweather    : vm-iobroker                              - disabled
       system.adapter.vis-weather.0            : vis-weather           : vm-iobroker                              - disabled
       system.adapter.vis.0                    : vis                   : vm-iobroker                              -  enabled
       system.adapter.weatherunderground.0     : weatherunderground    : vm-iobroker                              -  enabled
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : vm-iobroker                              -  enabled
      + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : vm-iobroker                              -  enabled
      + system.adapter.ws.0                     : ws                    : vm-iobroker                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
       system.adapter.yr.0                     : yr                    : vm-iobroker                              -  enabled
      + system.adapter.zigbee.0                 : zigbee                : vm-iobroker                              -  enabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.0.22   , installed 7.0.22
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.16   , installed 3.0.16
      Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
      Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "email"        : 1.3.1    , installed 1.3.1
      Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
      Adapter    "hue"          : 3.11.0   , installed 3.11.0
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.9    , installed 6.0.9
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "logparser"    : 2.2.2    , installed 2.2.2
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "meteoalarm"   : 3.0.2    , installed 3.0.2
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
      Adapter    "notification-manager": 1.1.2, installed 1.1.2
      Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "operating-hours": 1.0.6  , installed 1.0.6
      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
      Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
      Adapter    "scenes"       : 3.2.1    , installed 3.2.1
      Adapter    "schoolfree"   : 1.1.4    , installed 1.1.4
      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "snmp"         : 3.2.0    , installed 3.2.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-map"      : 1.0.5    , installed 1.0.5
      Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      Objects and States
      Objects:        72049
      States:         65059
      Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://repos.influxdata.com/debian stable InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      995        20499      636/influxd
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          846        610/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12417      1/init
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1002       20893      1570/io.shelly.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      112        14210      604/mosquitto
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       19406      747/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       12784      747/iobroker.js-con
      tcp        0      0 192.168.1.14:42010      0.0.0.0:*               LISTEN      1002       24007      1242/io.hm-rpc.1
      tcp        0      0 192.168.1.14:42001      0.0.0.0:*               LISTEN      1002       25651      1216/io.hm-rpc.0
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          828        594/cupsd
      tcp        0      0 192.168.1.14:49292      0.0.0.0:*               LISTEN      1002       20052      1257/io.hm-rpc.3
      tcp        0      0 0.0.0.0:44467           0.0.0.0:*               LISTEN      115        12755      717/rpc.statd
      tcp        0      0 0.0.0.0:44155           0.0.0.0:*               LISTEN      0          22684      -
      tcp6       0      0 :::56179                :::*                    LISTEN      115        12759      717/rpc.statd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1002       16147      790/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1002       34256      3291/io.web.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1002       38562      3334/io.ws.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      995        22644      636/influxd
      tcp6       0      0 :::8087                 :::*                    LISTEN      1002       29326      3125/io.simple-api.
      tcp6       0      0 :::8089                 :::*                    LISTEN      1002       40253      3312/io.web.1
      tcp6       0      0 :::8094                 :::*                    LISTEN      1002       36115      3347/io.socketio.0
      tcp6       0      0 :::8188                 :::*                    LISTEN      999        22048      625/node
      tcp6       0      0 :::8000                 :::*                    LISTEN      1002       30131      3209/io.upnp.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          848        610/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          14371      1/init
      tcp6       0      0 :::1883                 :::*                    LISTEN      112        14211      604/mosquitto
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          827        594/cupsd
      tcp6       0      0 :::35813                :::*                    LISTEN      0          22686      -
      udp        0      0 0.0.0.0:42838           0.0.0.0:*                           115        12752      717/rpc.statd
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1002       40232      3209/io.upnp.0
      udp        0      0 0.0.0.0:43018           0.0.0.0:*                           1002       29379      3209/io.upnp.0
      udp        0      0 0.0.0.0:51474           0.0.0.0:*                           0          22683      -
      udp        0      0 0.0.0.0:51675           0.0.0.0:*                           1002       19900      984/io.broadlink2.0
      udp        0      0 0.0.0.0:51787           0.0.0.0:*                           1002       22418      984/io.broadlink2.0
      udp        0      0 0.0.0.0:45727           0.0.0.0:*                           105        19332      549/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           105        19330      549/avahi-daemon: r
      udp        0      0 0.0.0.0:46609           0.0.0.0:*                           1002       22419      984/io.broadlink2.0
      udp        0      0 0.0.0.0:47439           0.0.0.0:*                           1002       26825      1585/io.snmp.0
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1002       22415      984/io.broadlink2.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13990      1/init
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          12722      627/cups-browsed
      udp        0      0 127.0.0.1:893           0.0.0.0:*                           0          12747      717/rpc.statd
      udp6       0      0 :::34696                :::*                                115        12757      717/rpc.statd
      udp6       0      0 :::35676                :::*                                105        19333      549/avahi-daemon: r
      udp6       0      0 :::36223                :::*                                0          22685      -
      udp6       0      0 :::5353                 :::*                                105        19331      549/avahi-daemon: r
      udp6       0      0 :::111                  :::*                                0          15864      1/init
      udp6       0      0 fe80::9064:1cff:fe5:546 :::*                                0          22731      564/NetworkManager
      2024-08-16 12:35:07.951  - info: ical.1 (7088) Terminated (NO_ERROR): Without reason
      2024-08-16 12:35:08.464  - info: host.vm-iobroker instance system.adapter.ical.1 having pid 7088 terminated with code 0 (NO_ERROR)
      2024-08-16 12:35:09.475  - info: host.vm-iobroker instance system.adapter.dwd.0 having pid 8016 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-08-16 12:36:11.436  - info: javascript.0 (867) script.js.VIS_Scripte.Material-Design_DasWetter: Material Design Widgets: Wetter Skript triggered by 'hm-rpc.1.000EDF29AF0CB5.1.ACTUAL_TEMPERATURE'
      2024-08-16 12:36:11.559  - info: host.vm-iobroker instance system.adapter.meteoalarm.0 in version "3.0.2" started with pid 8118
      2024-08-16 12:36:15.033  - info: host.vm-iobroker instance system.adapter.meteoalarm.0 having pid 8118 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-08-16 12:36:20.016  - info: host.vm-iobroker instance system.adapter.meteoalarm.2 in version "3.0.2" started with pid 8145
      2024-08-16 12:36:25.124  - info: host.vm-iobroker instance system.adapter.meteoalarm.2 having pid 8145 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-08-16 12:37:43.521  - info: admin.0 (790) failed connection to socket.io from ::ffff:192.168.1.57: Passport was not initialized
      2024-08-16 12:37:44.693  - info: admin.0 (790) failed connection to socket.io from ::ffff:192.168.1.57: Passport was not initialized
      2024-08-16 12:37:45.357  - info: admin.0 (790) failed connection to socket.io from ::ffff:192.168.1.57: Passport was not initialized
      2024-08-16 12:37:45.451  - info: admin.0 (790) failed connection to socket.io from ::ffff:192.168.1.57: Passport was not initialized
      2024-08-16 12:37:45.518  - info: admin.0 (790) failed connection to socket.io from ::ffff:192.168.1.57: Passport was not initialized
      2024-08-16 12:37:45.625  - info: admin.0 (790) failed connection to socket.io from ::ffff:192.168.1.57: Passport was not initialized
      2024-08-16 12:37:45.703  - info: admin.0 (790) failed connection to socket.io from ::ffff:192.168.1.57: Passport was not initialized
      2024-08-16 12:37:45.841  - info: admin.0 (790) failed connection to socket.io from ::ffff:192.168.1.57: Passport was not initialized
      2024-08-16 12:37:45.944  - info: admin.0 (790) failed connection to socket.io from ::ffff:192.168.1.57: Passport was not initialized
      2024-08-16 12:38:22.312  - info: javascript.0 (867) script.js.VIS_Scripte.Material-Design_DasWetter: Material Design Widgets: Wetter Skript triggered by 'hm-rpc.1.000EDF29AF0CB5.1.ACTUAL_TEMPERATURE'
      2024-08-16 12:39:25.497  - info: admin.0 (790) <== Disconnect system.user.admin from ::ffff:192.168.1.55 admin
      2024-08-16 12:39:25.636  - info: admin.0 (790) ==> Connected system.user.admin from ::ffff:192.168.1.55
      2024-08-16 12:39:26.528  - info: admin.0 (790) ==> Connected system.user.admin from ::ffff:192.168.1.55
      2024-08-16 12:40:07.009  - info: host.vm-iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 9001
      2024-08-16 12:40:09.379  - info: host.vm-iobroker instance system.adapter.dwd.0 having pid 9001 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-08-16 12:40:21.610  - info: host.vm-iobroker instance system.adapter.meteoalarm.3 in version "3.0.2" started with pid 9030
      2024-08-16 12:40:25.063  - info: host.vm-iobroker instance system.adapter.meteoalarm.3 having pid 9030 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      Danke für eure Hilfe.
      Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @JoJo58 last edited by
        @jojo58
        Dicke Dinger seh ich da nicht. Der nicht laufende networking.service kommt mir komisch vor.
        Stell vielleicht mal von jsonl auf redis um.
        JoJo58 2 Replies Last reply Reply Quote 0
        • JoJo58
          JoJo58 @Thomas Braun last edited by
          Das mit dem network.sevice habe ich auch gesehen, aber keine Ahnung woher das kommt. Es scheint aber auf die Funktionalität des IOB keinen Einfluss zu haben.
          Auf redis umstellen traue ich mich noch nicht, da werde ich wohl erst noch etwas dazu recherchieren müssen.
            crunchip Forum Testing Most Active @JoJo58 last edited by
            @jojo58 sagte in js-controller 6.0.x jetzt für alle User im STABLE!:
            /opt/iobroker/backups: 25G /opt/iobroker/backups/
            Zwar nicht Thema, macht aber wenig Sinn
            JoJo58 1 Reply Last reply Reply Quote 0
            • JoJo58
              @crunchip sagte in js-controller 6.0.x jetzt für alle User im STABLE!:
              Ich weiß, aber das liegt daran, das ich auch auf OneDrive sichere und die letzten 20 behalte. Die liegen alle immer auf OneDrive und leider auch unter /opt/iobroker/backups.
              Ich weiß nicht warum die doppelt gespeichert werden. Ich bin immer davon ausgegangen, das das sozusagen temporäre Daten für OneDrive sind. Das ich es also so hinnehmen muss.
              • JoJo58
                Ich habe eben ein "apt full-upgrade" gemacht und danach den Server neu gestartet, Jetzt schwankt die Auslastung unter Hosts zwischen 70% und 105% und wenn ich über ssh mal top eingebe, kommt das raus:
                top - 09:27:26 up 17 min,  1 user,  load average: 1,35, 2,16, 1,78
                Tasks: 229 total,   1 running, 228 sleeping,   0 stopped,   0 zombie
                %CPU(s): 13,0 us,  1,3 sy,  0,0 ni, 84,7 id,  0,0 wa,  0,0 hi,  0,9 si,  0,0 st
                MiB Spch:  15991,7 total,   9823,0 free,   5236,7 used,   1185,4 buff/cache
                MiB Swap:    975,0 total,    975,0 free,      0,0 used.  10755,0 avail Spch
                   PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     ZEIT+ BEFEHL
                   757 iobroker  20   0   22,1g 998,6m  50788 S  76,5   6,2  17:14.68 iobroker.js-con
                   959 iobroker  20   0   31,8g 723940  50984 S  16,9   4,4   5:41.55 io.javascript.0
                   944 iobroker  20   0   11,1g 153936  44624 S   8,3   0,9   1:26.85 io.influxdb.0
                  3454 iobroker  20   0   11,0g 118436  48972 S   7,9   0,7   1:19.55 io.operating-ho
                  2019 iobroker  20   0   11,3g 152108  51228 S   7,0   0,9   0:13.57 io.zigbee.0
                  1679 iobroker  20   0   11,1g  81968  44776 S   3,6   0,5   0:07.06 io.proxmox.0
                  2415 iobroker  20   0   11,0g  88808  49136 S   3,0   0,5   0:09.82 io.logparser.0
                  1767 iobroker  20   0   11,0g 103460  48984 S   2,6   0,6   0:13.38 io.shelly.0
                top - 09:28:33 up 18 min,  1 user,  load average: 1,52, 2,05, 1,77
                Tasks: 229 total,   2 running, 227 sleeping,   0 stopped,   0 zombie
                %CPU(s): 17,8 us,  1,4 sy,  0,0 ni, 80,0 id,  0,0 wa,  0,0 hi,  0,8 si,  0,0 st
                MiB Spch:  15991,7 total,   9774,7 free,   5271,5 used,   1199,1 buff/cache
                MiB Swap:    975,0 total,    975,0 free,      0,0 used.  10720,2 avail Spch
                   757 iobroker  20   0   22,1g 996,5m  50788 R 118,2   6,2  18:11.70 iobroker.js-con
                   959 iobroker  20   0   31,8g 749536  50984 S  20,4   4,6   5:56.12 io.javascript.0
                   944 iobroker  20   0   11,1g 163976  44624 S   7,9   1,0   1:32.19 io.influxdb.0
                   637 influxdb  20   0 1666088 157516  28532 S   2,3   1,0   0:05.66 influxd
                  3454 iobroker  20   0   11,0g 118960  48972 S   2,3   0,7   1:25.66 io.operating-ho
                  3604 iobroker  20   0   11,0g  89996  44700 S   1,3   0,5   0:17.64 io.upnp.0
                  1580 iobroker  20   0   21,0g  87492  45772 S   0,7   0,5   0:06.33 io.hue.0
                  2250 iobroker  20   0   21,1g  95864  46244 S   0,7   0,6   0:21.31 io.fb-checkpres
                    17 root      20   0       0      0      0 I   0,3   0,0   0:00.37 kworker/0:1-mm_percpu_wq
                    60 root      20   0       0      0      0 I   0,3   0,0   0:00.18 kworker/u16:6-writeback
                top - 09:49:21 up 39 min,  1 user,  load average: 2,01, 1,87, 1,94
                %CPU(s): 13,7 us,  1,0 sy,  0,0 ni, 84,4 id,  0,1 wa,  0,0 hi,  0,7 si,  0,0 st
                MiB Spch:  15991,7 total,   9398,7 free,   5419,7 used,   1430,1 buff/cache
                MiB Swap:    975,0 total,    975,0 free,      0,0 used.  10572,0 avail Spch
                   757 iobroker  20   0   22,2g   1,0g  50788 R  91,7   6,3  37:53.33 iobroker.js-con
                   959 iobroker  20   0   31,8g 746432  50984 S  16,9   4,6  11:23.84 io.javascript.0
                  9414 iobroker  20   0   21,3g  86692  45172 S  11,0   0,5   0:05.93 io.daswetter.0
                  3454 iobroker  20   0   11,0g 124744  48972 S   6,6   0,8   3:39.92 io.operating-ho
                   944 iobroker  20   0   11,1g 153964  44624 S   6,3   0,9   3:24.35 io.influxdb.0
                  2415 iobroker  20   0   11,0g  92096  49136 S   2,3   0,6   0:19.33 io.logparser.0
                  3604 iobroker  20   0   11,0g  91448  44700 S   1,7   0,6   0:37.79 io.upnp.0
                  1580 iobroker  20   0   21,0g  90992  45772 S   1,0   0,6   0:11.31 io.hue.0
                  1442 iobroker  20   0   11,3g  94588  45380 S   0,7   0,6   0:23.14 io.alexa2.0
                  3510 iobroker  20   0   11,0g 107328  44132 S   0,7   0,7   0:35.51 io.sourceanalyt
                Der JS-Controller ist immer ganz oben. Meinst du das eine Umstellung auf redis da wirklich helfen könnte?
                Ro75 foxriver76 2 Replies Last reply Reply Quote 0
                • Ro75
                  Ro75 @JoJo58 last edited by
                  Aus eigener Erfahrung, JA - 16GB RAM ist auch nicht zu wenig. Bei mir lag dananch die Auslastung bei unter 5%.
                      685 redis     20   0 1185512 810768   7096 S   5,0   5,0 154:49.97 redis-server
                  2320615 iobroker  20   0   21,6g 430364  43192 S   4,3   2,7  26:37.21 io.javascript.0
                  2803140 root      20   0       0      0      0 D   4,0   0,0   2:00.92 kworker/0:3+pm
                  2027671 plex      20   0   94912  51152  10288 S   3,6   0,3  38:18.95 Plex DLNA Serve
                  2321527 iobroker  20   0   21,2g  88272  36248 S   3,3   0,5   2:55.22 io.tapo.0
                  2321146 iobroker  20   0   11,3g 130728  39344 S   3,0   0,8  22:11.21 io.zigbee.0
                  2321816 iobroker  20   0   21,0g  83488  35936 S   3,0   0,5  12:56.69 io.linux-contro
                  2320724 iobroker  20   0   11,0g  96380  34604 S   2,6   0,6  15:53.22 io.influxdb.0
                  2320849 iobroker  20   0   21,0g 105820  35580 S   2,0   0,7  14:12.71 io.hue.0
                  2320975 iobroker  20   0   11,0g  71812  34228 S   2,0   0,4   9:25.16 io.ping.0
                  2029873 grafana   20   0 1680360 186972 110368 S   1,7   1,2  27:34.04 grafana
                  2047265 influxdb  20   0 1896428 262700  46784 S   1,7   1,6  28:18.78 influxd
                  2322489 iobroker  20   0   11,0g  87756  38328 S   1,7   0,5  11:04.29 io.upnp.0
                  2321182 iobroker  20   0   11,0g  87492  37952 S   1,3   0,5   4:55.54 io.tr-064.0
                     2623 pihole    20   0  138224  11136   8068 S   1,0   0,1  33:32.34 redis-server
                  2046919 root       0 -20       0      0      0 I   0,7   0,0  10:06.59 kworker/u9:2-uvcvideo
                        1 root      20   0  168268  13176   7932 S   0,3   0,1   5:05.31 systemd
                      339 root      20   0       0      0      0 S   0,3   0,0   1:35.85 jbd2/sda2-8
                      404 root      19  -1  151244  77024  75188 S   0,3   0,5   3:35.55 systemd-journal
                      621 message+  20   0    9308   5160   3796 S   0,3   0,0   3:51.75 dbus-daemon
                      687 Debian-+  20   0   24680  11504   7596 S   0,3   0,1  14:24.72 snmpd
                      753 pihole    10 -10  713576  41240  11348 S   0,3   0,3  19:13.74 pihole-FTL
                     2516 35002     20   0 7425832 103848  20736 S   0,3   0,6   6:58.94 java
                     3209 ubuntu    20   0 3277172 264848  13824 S   0,3   1,6   9:54.92 java
                     3593 35002     20   0 7827192 156024  20956 S   0,3   1,0   9:33.72 java
                     3822 911       20   0  398604 182960  25652 S   0,3   1,1  10:08.59 uvicorn
                  2027673 plex      20   0   43940  12368  10356 S   0,3   0,1   1:47.77 Plex Tuner Serv
                  2320476 iobroker  20   0   21,3g 157528  41440 S   0,3   1,0   1:39.71 iobroker.js-con
                  2320554 ubuntu    20   0 7832008 240004  20192 S   0,3   1,5   1:34.19 java
                  2321619 iobroker  20   0   11,2g 108920  35844 S   0,3   0,7   0:54.00 io.imap.0
                  2787903 root      20   0       0      0      0 I   0,3   0,0   1:13.14 kworker/0:1-kacpi_notify
                  2843965 ubuntu    20   0   11212   4724   3844 R   0,3   0,0   0:00.63 top
                        2 root      20   0       0      0      0 S   0,0   0,0   0:00.28 kthreadd
                        3 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_gp
                  Ro75.
                  • foxriver76
                    foxriver76 Developer @JoJo58 last edited by
                    @jojo58 würde empfehlen mal einzelne Adapter zu stoppen um evtl. zu schauen welcher dazu führt, da die DB im Controller läuft kann es durchaus an einem Adapter liegen. In unserem Benchmark Tests war nichts auffällig zwischen Controller 6 zu 5.
                    JoJo58 1 Reply Last reply Reply Quote 1
                      ist unnötig und bereitete in der Vergangenheit schon mal Probleme
                      ggf github versionen reduzieren
                      da solltest du mal dein /etc/network/interfaces kontrollieren, ggf ist da etwas falsch eingetragen
                      in der Regel werden die nicht doppelt gesichert, manuell angestoßene Backups bleiben in dem Ordner oder wenn das Verzeichnis nicht leer ist, bleiben auch die automatischen drin und zu zuger letzt, wenn ein backup fehl schlug, bleiben sie auch dort liegen, müsstest du allerdings im log sehen bzw auf der Gegenstelle kein backup vorhanden sein
                      • JoJo58
                        JoJo58 @foxriver76 last edited by
                        @foxriver76
                        Dauerte etwas bis ich die meisten Adapter mal deaktiviert und dann einzeln wieder aktiviert hatte. Es gibt 2 Adapter die Probleme bereiten. Das ist "operating-hours.0" und "upnp.0". Ohne diese Beiden liegt die Auslastung bei Hosts um die 20%, ab und zu mal Spitzen um die 50%-60%. Aktiviere ich dann "UPnP" liegt die Auslastung um die 55% mit Spitzen um die 80%.
                        Aktiviere ich dann noch "Betriebsstunden", ist es vorbei mit der Ruhe, dann liege ich im Schnitt bei 80%. Wenn ich dann die "Aktualisierungsrate" in der Instanz runter setze, wird's schon mal besser. Auf diesen Adapter könnte ich notfalls auch verzichten, nutze den nur, weil ich Sammler und Jäger bin. Ich lasse den "operating-hours.0" erstmal deaktiviert.
                        Auf den "UPnP" will ich nicht verzichten, da nutze ich dann doch einige Datenpunkte.
                        @Ro75
                        Ich werde mir die Videos von Matthias zu "Redis" mal erneut ansehen und dann wohl umstellen.
                        @crunchip
                        Deinen Hinweisen werde ich auch noch nachgehen.
                        Danke euch für die Hilfe und Tipps.
                        Johannes
                        • JoJo58
                          JoJo58 @Ro75 last edited by
                          @ro75
                          Ich kann es kaum glauben. Ich habe umgestellt auf Redis und jetzt langweilt sich die Maschine. Ganz selten geht es mal auf über 1%. Auch über ssh und top ist alles entspannt. Und das obwohl alle Instanzen aktiviert sind.
                          Danke... 👍 😆
                          Ro75 1 Reply Last reply Reply Quote 0
                          • Ro75
                            @jojo58 meine Rede.Top.
                            Ro75.
                            • mcm1957
                              mcm1957 @JoJo58 last edited by
                              @jojo58 said in js-controller 6.0.x jetzt für alle User im STABLE!:
                              Welche Refreshrate hast du bei operating-hours eingestellt?
                              An sich sollte der bei einem ersten Blick nicht so viel tun - außer du hast 2000 States konfiguriert :-).
                              • JoJo58
                                JoJo58 @mcm1957 last edited by
                                @mcm1957 sagte in js-controller 6.0.x jetzt für alle User im STABLE!:
                                Das steht jetzt gerade auf 1 Sekunde. Angelegt sind um die 30 States. Ich weiß, ist übertrieben und ich setze es auch wieder auf 10 Sekunden. 😉
                                  Joe550 @Thomas Braun last edited by
                                  Hallo Thomas,
                                  Danke für deine schnelle und kompetente Unterstützung.
                                  Ich habe alles neu installiert und das Backup eingespielt.
                                  Nach einigen Stolpersteinen läuft das System wieder.
                                  Super Forum hier mit engagierten Usern.
                                  Nochmals Danke
                                  VG Joe550
                                  • Merlin123
                                    Merlin123 last edited by
                                    js-controler 6.0.9
                                    node 20.16.0
                                    Admin 7.0.24
                                    Mir gelingt es nicht, den js-controler aus dem Admin zu aktualisieren.
                                    Es kommt immer nur
                                    SyntaxError: Unexpected token '<', "<!doctype "... is not valid JSON
                                    Das hat auch noch mit keiner vorherigen Version geklappt.
                                    Hatte schonmal danach gefragt, da hieß es, dass es eigentlich nach nem manuellen Update dann gehen sollte, ist aber nicht so.
                                    Hat jemand ne Idee?
                                    Vor allen, da mittlerweile die manuelle Anweisung nicht mehr angezeigt werden, ist das ziemlich nervig
                                      Thomas Braun Most Active @Merlin123 last edited by
                                      @merlin123
                                      Was willste denn da updaten? 6.0.9 ist die aktuelle stabile Version.
                                      • Merlin123
                                        Merlin123 @Thomas Braun last edited by
                                        @thomas-braun Er bietet mir die 6.0.10 an. Ist bei mir ja aber ein grundsätzliches Problem.
                                        • foxriver76
                                          foxriver76 Developer last edited by foxriver76
                                          Es kommt im Beta heute noch eine 6.0.11 welche das Verhalten der System-Update Meldungen anpasst, da gerade auf Facebook viele Leute verwirrt zu sein scheinen von den Meldungen, was sicher auch daran liegt dass Admin bis zu 7.0.22 das Popup mit dem Titel „Adapterwarnungen“ angezeigt hat auch wenn es keine Warnungen sind.
                                          Jedenfalls - es wird die Notification nun nur noch einmalig erstellt wenn neue Updates hinzu gekommen sind und nicht mehr bei jedem Repo Update was potentiell dazu geführt hatte dass die Meldung mehrmals täglich kam. Somit folgt sie nun der gleichen Logik wie die Benachrichtigung über neue Adapter Updates welche vom Admin generiert wird. Ich denke, das ist eine gute Vorgehensweise und hoffe sie sorgt für weniger Verwirrung.
                                          Gerne Feedback geben ob das so passt, damit wir das auch zeitnah ins stable bekommen.
                                          mcm1957 Gaspode Feuersturm crunchip 4 Replies Last reply Reply Quote 4
                                          • mcm1957
                                            mcm1957 @foxriver76 last edited by
                                            @foxriver76
                                            Wenn*s um STABLE geht bitte selbst durchschalten. Bin heute nur eingeschränkt verfügbar.
                                            1.0k
                                            controller js-controller kiera stable
                                            47
                                            257
                                            63865
