    4. iob Befehle werden nicht ausgeführt
      Homoran Global Moderator Administrators @Merowinger last edited by
      @merowinger sagte in iob Befehle werden nicht ausgeführt:
      der hat keinen ssh Zugang
      warum nicht?
        Merowinger @Homoran last edited by
        @homoran weil ich über den host per pct enter hinein komme.
        Iobroker läuft als Container auf Proxmox.
        Thomas Braun Homoran R 3 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @Merowinger last edited by
          @merowinger
          Zeig mal die Langfassung von
          iob diag
          nun.
          M 2 Replies Last reply Reply Quote 1
            Merowinger @Thomas Braun last edited by
            Skript v.2024-05-22
            *** BASE SYSTEM ***
             Static hostname: iobroker
                   Icon name: computer-container
                     Chassis: container
              Virtualization: lxc
            Operating System: Ubuntu 22.04.4 LTS
                      Kernel: Linux 6.8.8-4-pve
                Architecture: x86-64
            model name      : Intel(R) Xeon(R) W-2135 CPU @ 3.70GHz
            Docker          : false
            Virtualization  : lxc
            Kernel          : x86_64
            Userland        : 64 bit
            Systemuptime and Load:
             15:12:21 up 41 min,  1 user,  load average: 1.67, 1.88, 1.87
            CPU threads: 2
            *** Time and Time Zones ***
                           Local time: Sun 2024-08-18 15:12:21 CEST
                       Universal time: Sun 2024-08-18 13:12:21 UTC
                             RTC time: n/a
                          NTP service: inactive
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            Benny
            HOME=/home/Benny
            GROUPS=Benny sudo iobroker
            js-controller is not running
            *** Display-Server-Setup ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            8.2G        488M        6.0G        0.0K        1.7G        7.7G
            Swap:           1.0G          0B        1.0G
            Total:          9.2G        488M        7.0G
            Active iob-Instances:   1
                     8192 M total memory
                      488 M used memory
                      500 M active memory
                     1338 M inactive memory
                     6020 M free memory
                        0 M buffer memory
                     1682 M swap cache
                     1024 M total swap
                        0 M used swap
                     1024 M free swap
            top - 15:12:21 up 41 min,  1 user,  load average: 1.70, 1.88, 1.87
            Tasks:  34 total,   1 running,  33 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   8192.0 total,   6020.7 free,    488.6 used,   1682.7 buff/cache
            MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   7703.2 avail Mem
            *** FAILED SERVICES ***
              UNIT                        LOAD   ACTIVE SUB    DESCRIPTION
            * apparmor.service            loaded failed failed Load AppArmor profiles
            * iobroker.service            loaded failed failed ioBroker Server
            * networkd-dispatcher.service loaded failed failed Dispatcher daemon for systemd-networkd
            * systemd-sysusers.service    loaded failed failed Create System Users
            * unattended-upgrades.service loaded failed failed Unattended Upgrades Shutdown
            LOAD   = Reflects whether the unit definition was properly loaded.
            ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
            SUB    = The low-level unit activation state, values depend on unit type.
            5 loaded units listed.
            *** FILESYSTEM ***
            Filesystem                       Type   Size  Used Avail Use% Mounted on
            /dev/mapper/pve-vm--107--disk--0 ext4    98G   23G   71G  24% /
            none                             tmpfs  492K  4.0K  488K   1% /dev
            tmpfs                            tmpfs   32G     0   32G   0% /dev/shm
            tmpfs                            tmpfs   13G  148K   13G   1% /run
            tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
            tmpfs                            tmpfs  6.3G     0  6.3G   0% /run/user/1002
            [Fri Aug 16 23:00:14 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
            [Fri Aug 16 23:00:14 2024] EXT4-fs (dm-29): mounted filesystem 6cb11462-725e-4ef5-a82e-1dd5619f4256 ro without journal. Quota mode: none.
            [Fri Aug 16 23:00:32 2024] EXT4-fs (dm-29): unmounting filesystem 6cb11462-725e-4ef5-a82e-1dd5619f4256.
            [Fri Aug 16 23:00:32 2024] EXT4-fs (dm-17): mounted filesystem 92d97cc4-4866-46a1-9c25-8700a3ec0e70 r/w with ordered data mode. Quota mode: none.
            [Fri Aug 16 23:00:41 2024] EXT4-fs (dm-17): unmounting filesystem 92d97cc4-4866-46a1-9c25-8700a3ec0e70.
            [Fri Aug 16 23:00:42 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
            [Fri Aug 16 23:00:42 2024] EXT4-fs (dm-29): mounted filesystem 7e019a09-a2a5-43e9-bbbb-3292548ad267 ro without journal. Quota mode: none.
            [Fri Aug 16 23:02:05 2024] EXT4-fs (dm-29): unmounting filesystem 7e019a09-a2a5-43e9-bbbb-3292548ad267.
            [Fri Aug 16 23:02:07 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
            [Fri Aug 16 23:02:07 2024] EXT4-fs (dm-29): mounted filesystem 09c4fcf9-be1a-4e4b-9212-4fe9120b6112 ro without journal. Quota mode: none.
            [Fri Aug 16 23:02:20 2024] EXT4-fs (dm-29): unmounting filesystem 09c4fcf9-be1a-4e4b-9212-4fe9120b6112.
            [Fri Aug 16 23:02:21 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
            [Fri Aug 16 23:02:21 2024] EXT4-fs (dm-29): mounted filesystem f55e38cf-c8af-4660-80fb-2b3874cf34b7 ro without journal. Quota mode: none.
            [Fri Aug 16 23:02:46 2024] EXT4-fs (dm-29): unmounting filesystem f55e38cf-c8af-4660-80fb-2b3874cf34b7.
            [Fri Aug 16 23:02:46 2024] EXT4-fs (dm-29): mounted filesystem e588106e-e4ec-4e88-82a7-a8283f7db9d5 ro without journal. Quota mode: none.
            [Fri Aug 16 23:02:56 2024] EXT4-fs (dm-29): unmounting filesystem e588106e-e4ec-4e88-82a7-a8283f7db9d5.
            [Fri Aug 16 23:02:56 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
            [Fri Aug 16 23:02:56 2024] EXT4-fs (dm-29): mounted filesystem 2061cbc0-6630-423c-b25c-c45b8704b39c ro without journal. Quota mode: none.
            [Fri Aug 16 23:03:15 2024] EXT4-fs (dm-29): unmounting filesystem 2061cbc0-6630-423c-b25c-c45b8704b39c.
            [Fri Aug 16 23:03:16 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
            [Fri Aug 16 23:03:16 2024] EXT4-fs (dm-29): mounted filesystem eb16eae9-15cb-426e-95d7-4dff52aa89d8 ro without journal. Quota mode: none.
            [Fri Aug 16 23:06:46 2024] EXT4-fs (dm-29): unmounting filesystem eb16eae9-15cb-426e-95d7-4dff52aa89d8.
            [Fri Aug 16 23:06:47 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
            [Fri Aug 16 23:06:47 2024] EXT4-fs (dm-29): mounted filesystem 5292950e-3110-4b44-9627-ccb93466bdb6 ro without journal. Quota mode: none.
            [Fri Aug 16 23:06:56 2024] EXT4-fs (dm-29): unmounting filesystem 5292950e-3110-4b44-9627-ccb93466bdb6.
            [Fri Aug 16 23:06:57 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
            [Fri Aug 16 23:06:57 2024] EXT4-fs (dm-29): mounted filesystem 6766b937-5cf1-4e3a-9ac0-8e52e0aa7706 ro without journal. Quota mode: none.
            [Fri Aug 16 23:07:13 2024] EXT4-fs (dm-29): unmounting filesystem 6766b937-5cf1-4e3a-9ac0-8e52e0aa7706.
            [Fri Aug 16 23:07:14 2024] EXT4-fs (dm-29): mounted filesystem bd4590c2-e9a3-4fd9-b4ce-b70b34d8743a ro without journal. Quota mode: none.
            [Fri Aug 16 23:07:43 2024] EXT4-fs (dm-29): unmounting filesystem bd4590c2-e9a3-4fd9-b4ce-b70b34d8743a.
            [Fri Aug 16 23:08:39 2024] EXT4-fs (dm-19): mounted filesystem fe8a5df3-16f8-4fa9-843c-800ebaac2ec8 r/w with ordered data mode. Quota mode: none.
            [Fri Aug 16 23:09:21 2024] EXT4-fs (dm-19): unmounting filesystem fe8a5df3-16f8-4fa9-843c-800ebaac2ec8.
            [Fri Aug 16 23:09:21 2024] EXT4-fs (dm-28): mounted filesystem 6e9a2031-1c35-477c-9fec-0026551869bd ro without journal. Quota mode: none.
            [Fri Aug 16 23:10:02 2024] EXT4-fs (dm-28): unmounting filesystem 6e9a2031-1c35-477c-9fec-0026551869bd.
            [Fri Aug 16 23:10:03 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
            [Fri Aug 16 23:10:03 2024] EXT4-fs (dm-29): mounted filesystem 7946a8f2-4b31-47db-ab3b-45c146de8f9f ro without journal. Quota mode: none.
            [Fri Aug 16 23:12:10 2024] EXT4-fs (dm-29): unmounting filesystem 7946a8f2-4b31-47db-ab3b-45c146de8f9f.
            [Fri Aug 16 23:12:11 2024] EXT4-fs (dm-29): mounted filesystem 6064ea71-3cd7-4c09-add6-d57d0062cfaf ro without journal. Quota mode: none.
            [Fri Aug 16 23:12:33 2024] EXT4-fs (dm-29): unmounting filesystem 6064ea71-3cd7-4c09-add6-d57d0062cfaf.
            [Fri Aug 16 23:12:34 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
            [Fri Aug 16 23:12:34 2024] EXT4-fs (dm-29): mounted filesystem 2d0f14a9-f7f8-4e27-99f8-fe6600e75602 ro without journal. Quota mode: none.
            [Fri Aug 16 23:13:59 2024] EXT4-fs (dm-29): unmounting filesystem 2d0f14a9-f7f8-4e27-99f8-fe6600e75602.
            [Fri Aug 16 23:39:22 2024] EXT4-fs (dm-23): unmounting filesystem 3531f713-7070-49bd-baf7-cea479bbbe46.
            [Sat Aug 17 23:00:13 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
            [Sat Aug 17 23:00:13 2024] EXT4-fs (dm-29): mounted filesystem 6cb11462-725e-4ef5-a82e-1dd5619f4256 ro without journal. Quota mode: none.
            [Sat Aug 17 23:00:41 2024] EXT4-fs (dm-29): unmounting filesystem 6cb11462-725e-4ef5-a82e-1dd5619f4256.
            [Sat Aug 17 23:00:41 2024] EXT4-fs (dm-17): mounted filesystem 92d97cc4-4866-46a1-9c25-8700a3ec0e70 r/w with ordered data mode. Quota mode: none.
            [Sat Aug 17 23:00:52 2024] EXT4-fs (dm-17): unmounting filesystem 92d97cc4-4866-46a1-9c25-8700a3ec0e70.
            [Sat Aug 17 23:00:53 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
            [Sat Aug 17 23:00:53 2024] EXT4-fs (dm-29): mounted filesystem 7e019a09-a2a5-43e9-bbbb-3292548ad267 ro without journal. Quota mode: none.
            [Sat Aug 17 23:02:26 2024] EXT4-fs (dm-29): unmounting filesystem 7e019a09-a2a5-43e9-bbbb-3292548ad267.
            [Sat Aug 17 23:02:27 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
            [Sat Aug 17 23:02:27 2024] EXT4-fs (dm-29): mounted filesystem 09c4fcf9-be1a-4e4b-9212-4fe9120b6112 ro without journal. Quota mode: none.
            [Sat Aug 17 23:02:41 2024] EXT4-fs (dm-29): unmounting filesystem 09c4fcf9-be1a-4e4b-9212-4fe9120b6112.
            [Sat Aug 17 23:02:42 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
            [Sat Aug 17 23:02:42 2024] EXT4-fs (dm-29): mounted filesystem f55e38cf-c8af-4660-80fb-2b3874cf34b7 ro without journal. Quota mode: none.
            [Sat Aug 17 23:03:12 2024] EXT4-fs (dm-29): unmounting filesystem f55e38cf-c8af-4660-80fb-2b3874cf34b7.
            [Sat Aug 17 23:03:13 2024] EXT4-fs (dm-29): mounted filesystem e588106e-e4ec-4e88-82a7-a8283f7db9d5 ro without journal. Quota mode: none.
            [Sat Aug 17 23:03:22 2024] EXT4-fs (dm-29): unmounting filesystem e588106e-e4ec-4e88-82a7-a8283f7db9d5.
            [Sat Aug 17 23:03:23 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
            [Sat Aug 17 23:03:23 2024] EXT4-fs (dm-29): mounted filesystem 2061cbc0-6630-423c-b25c-c45b8704b39c ro without journal. Quota mode: none.
            [Sat Aug 17 23:03:41 2024] EXT4-fs (dm-29): unmounting filesystem 2061cbc0-6630-423c-b25c-c45b8704b39c.
            [Sat Aug 17 23:03:42 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
            [Sat Aug 17 23:03:42 2024] EXT4-fs (dm-29): mounted filesystem eb16eae9-15cb-426e-95d7-4dff52aa89d8 ro without journal. Quota mode: none.
            [Sat Aug 17 23:07:19 2024] EXT4-fs (dm-29): unmounting filesystem eb16eae9-15cb-426e-95d7-4dff52aa89d8.
            [Sat Aug 17 23:07:20 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
            [Sat Aug 17 23:07:20 2024] EXT4-fs (dm-29): mounted filesystem 5292950e-3110-4b44-9627-ccb93466bdb6 ro without journal. Quota mode: none.
            [Sat Aug 17 23:07:30 2024] EXT4-fs (dm-29): unmounting filesystem 5292950e-3110-4b44-9627-ccb93466bdb6.
            [Sat Aug 17 23:07:31 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
            [Sat Aug 17 23:07:31 2024] EXT4-fs (dm-29): mounted filesystem 6766b937-5cf1-4e3a-9ac0-8e52e0aa7706 ro without journal. Quota mode: none.
            [Sat Aug 17 23:07:46 2024] EXT4-fs (dm-29): unmounting filesystem 6766b937-5cf1-4e3a-9ac0-8e52e0aa7706.
            [Sat Aug 17 23:07:47 2024] EXT4-fs (dm-29): mounted filesystem bd4590c2-e9a3-4fd9-b4ce-b70b34d8743a ro without journal. Quota mode: none.
            [Sat Aug 17 23:08:14 2024] EXT4-fs (dm-29): unmounting filesystem bd4590c2-e9a3-4fd9-b4ce-b70b34d8743a.
            [Sat Aug 17 23:09:52 2024] EXT4-fs (dm-19): mounted filesystem fe8a5df3-16f8-4fa9-843c-800ebaac2ec8 r/w with ordered data mode. Quota mode: none.
            [Sat Aug 17 23:10:16 2024] EXT4-fs (dm-19): unmounting filesystem fe8a5df3-16f8-4fa9-843c-800ebaac2ec8.
            [Sat Aug 17 23:10:16 2024] EXT4-fs (dm-28): mounted filesystem 6e9a2031-1c35-477c-9fec-0026551869bd ro without journal. Quota mode: none.
            [Sat Aug 17 23:11:02 2024] EXT4-fs (dm-28): unmounting filesystem 6e9a2031-1c35-477c-9fec-0026551869bd.
            [Sat Aug 17 23:11:03 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
            [Sat Aug 17 23:11:03 2024] EXT4-fs (dm-29): mounted filesystem 7946a8f2-4b31-47db-ab3b-45c146de8f9f ro without journal. Quota mode: none.
            [Sat Aug 17 23:13:01 2024] EXT4-fs (dm-29): unmounting filesystem 7946a8f2-4b31-47db-ab3b-45c146de8f9f.
            [Sat Aug 17 23:13:02 2024] EXT4-fs (dm-29): mounted filesystem 6064ea71-3cd7-4c09-add6-d57d0062cfaf ro without journal. Quota mode: none.
            [Sat Aug 17 23:13:24 2024] EXT4-fs (dm-29): unmounting filesystem 6064ea71-3cd7-4c09-add6-d57d0062cfaf.
            [Sat Aug 17 23:13:24 2024] EXT4-fs (dm-29): write access unavailable, skipping orphan cleanup
            [Sat Aug 17 23:13:24 2024] EXT4-fs (dm-29): mounted filesystem 2d0f14a9-f7f8-4e27-99f8-fe6600e75602 ro without journal. Quota mode: none.
            [Sat Aug 17 23:14:50 2024] EXT4-fs (dm-29): unmounting filesystem 2d0f14a9-f7f8-4e27-99f8-fe6600e75602.
            [Sun Aug 18 11:12:58 2024] EXT4-fs (dm-16): unmounting filesystem 7e019a09-a2a5-43e9-bbbb-3292548ad267.
            [Sun Aug 18 11:12:59 2024] EXT4-fs (dm-16): mounted filesystem 7e019a09-a2a5-43e9-bbbb-3292548ad267 r/w with ordered data mode. Quota mode: none.
            [Sun Aug 18 11:26:08 2024] EXT4-fs (dm-16): unmounting filesystem 7e019a09-a2a5-43e9-bbbb-3292548ad267.
            [Sun Aug 18 11:26:09 2024] EXT4-fs (dm-16): mounted filesystem 7e019a09-a2a5-43e9-bbbb-3292548ad267 r/w with ordered data mode. Quota mode: none.
            [Sun Aug 18 14:31:18 2024] EXT4-fs (dm-15): unmounting filesystem eb16eae9-15cb-426e-95d7-4dff52aa89d8.
            [Sun Aug 18 14:31:19 2024] EXT4-fs (dm-15): mounted filesystem eb16eae9-15cb-426e-95d7-4dff52aa89d8 r/w with ordered data mode. Quota mode: none.
            Show mounted filesystems:
            TARGET                                SOURCE                           FSTYPE     OPTIONS
            /                                     /dev/mapper/pve-vm--107--disk--0 ext4       rw,relatime,stripe=16
            |-/run                                tmpfs                            tmpfs      rw,nosuid,nodev,size=13084708k,nr_inodes=819200,mode=755,inode64
            | |-/run/lock                         tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
            | |-/run/rpc_pipefs                   sunrpc                           rpc_pipefs ro,relatime
            | `-/run/user/1002                    tmpfs                            tmpfs      rw,nosuid,nodev,relatime,size=6542352k,nr_inodes=1635588,mode=700,uid=1002,gid=1002,inode64
            |-/dev                                none                             tmpfs      rw,relatime,size=492k,mode=755,inode64
            | |-/dev/shm                          tmpfs                            tmpfs      rw,nosuid,nodev,inode64
            | |-/dev/hugepages                    hugetlbfs                        hugetlbfs  rw,relatime,pagesize=2M
            | |-/dev/mqueue                       mqueue                           mqueue     rw,relatime
            | |-/dev/bus/usb/001/003              udev[/bus/usb/001/003]           devtmpfs   rw,nosuid,relatime,size=32677884k,nr_inodes=8169471,mode=755,inode64
            | |-/dev/ttyUSB0                      udev[/ttyUSB0]                   devtmpfs   rw,nosuid,relatime,size=32677884k,nr_inodes=8169471,mode=755,inode64
            | |-/dev/bus/usb/001/002              udev[/bus/usb/001/002]           devtmpfs   rw,nosuid,relatime,size=32677884k,nr_inodes=8169471,mode=755,inode64
            | |-/dev/ttyUSB1                      udev[/ttyUSB1]                   devtmpfs   rw,nosuid,relatime,size=32677884k,nr_inodes=8169471,mode=755,inode64
            | |-/dev/pts                          devpts                           devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
            | |-/dev/ptmx                         devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
            | |-/dev/lxc/console                  devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
            | |-/dev/console                      devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
            | |-/dev/lxc/tty1                     devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
            | `-/dev/lxc/tty2                     devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666,max=1026
            |-/proc                               proc                             proc       rw,nosuid,nodev,noexec,relatime
            | |-/proc/sys                         proc[/sys]                       proc       ro,relatime
            | | |-/proc/sys/kernel/random/boot_id none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,inode64
            | | `-/proc/sys/net                   proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
            | |-/proc/sysrq-trigger               proc[/sysrq-trigger]             proc       ro,relatime
            | |-/proc/cpuinfo                     lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/diskstats                   lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/loadavg                     lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/meminfo                     lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/slabinfo                    lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/stat                        lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | |-/proc/swaps                       lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            | `-/proc/uptime                      lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            `-/sys                                sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
              |-/sys/fs/fuse/connections          fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
              |-/sys/devices/virtual/net          sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
              |-/sys/kernel/debug                 debugfs                          debugfs    rw,nosuid,nodev,noexec,relatime
              |-/sys/kernel/security              securityfs                       securityfs rw,nosuid,nodev,noexec,relatime
              |-/sys/fs/pstore                    pstore                           pstore     rw,nosuid,nodev,noexec,relatime
              |-/sys/fs/cgroup                    none                             cgroup2    rw,nosuid,nodev,noexec,relatime
              `-/sys/devices/system/cpu           lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
            /var:
            5.2G    /var/
            4.3G    /var/log
            4.0G    /var/log/journal/2a2fff2f04dc408d995be9b80a65a02e
            756M    /var/lib
            Archived and active journals take up 8.0M in the file system.
            /opt/iobroker/backups:
            1.1G    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            sort: write failed: 'standard output': Broken pipe
            sort: write error
            1.6G    /opt/iobroker/iobroker-data/
            1.3G    /opt/iobroker/iobroker-data/files
            442M    /opt/iobroker/iobroker-data/files/javascript.admin
            409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            sort: write error
            35M     /opt/iobroker/iobroker-data/objects.jsonl
            35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
            27M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
            24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.1e6546bb.js.map
            USB-Devices by-id:
            No Devices found 'by-id'
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v20.16.0
            /usr/bin/node           v20.16.0
            /usr/bin/npm            10.8.1
            /usr/bin/npx            10.8.1
            /usr/bin/corepack       0.28.2
            nodejs:
              Installed: 20.16.0-1nodesource1
              Candidate: 20.16.0-1nodesource1
              Version table:
             *** 20.16.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                    100 /var/lib/dpkg/status
                 20.15.1-1nodesource1 1001
                 20.15.0-1nodesource1 1001
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
                 12.22.9~dfsg-1ubuntu3.6 500
                    500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                    500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
                 12.22.9~dfsg-1ubuntu3 500
                    500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            iobroker is not running on this host.
            Objects type: jsonl
            States  type: redis
            Core adapters versions
            js-controller:  6.0.9
            admin:          7.0.22
            javascript:     8.7.6
            nodejs modules from github:     2
            | | | | | `-- reconnect-core@0.0.1 invalid: "https://github.com/dodo/reconnect-core/tarball/merged" from node_modules/node-xmpp-core
            +-- iobroker.icons-open-icon-library-png@0.1.3 invalid: "https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master" from the root project
            Adapter State
              system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
              system.adapter.backitup.1               : backitup              : raspberrypi                              -  enabled
              system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
              system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
              system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
              system.adapter.devices.0                : devices               : iobroker                                 -  enabled
              system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
              system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
              system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker                                 - disabled
              system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 - disabled
              system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
              system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
              system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
              system.adapter.gruenbeck.0              : gruenbeck             : iobroker                                 - disabled
              system.adapter.homekit-controller.0     : homekit-controller    : iobroker                                 - disabled
              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
              system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 -  enabled
              system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
              system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
              system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
              system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
              system.adapter.info.0                   : info                  : iobroker                                 -  enabled
              system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
              system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
              system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
              system.adapter.kecontact.0              : kecontact             : iobroker                                 -  enabled
              system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
              system.adapter.mpd.0                    : mpd                   : raspberrypi                              -  enabled, port: 6600
              system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
              system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
              system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
              system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 - disabled
              system.adapter.octoprint.0              : octoprint             : iobroker                                 - disabled
              system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
              system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
              system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
              system.adapter.reolink.0                : reolink               : iobroker                                 - disabled
              system.adapter.robonect.0               : robonect              : iobroker                                 - disabled
              system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
              system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
              system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
              system.adapter.signal-cmb.0             : signal-cmb            : iobroker                                 -  enabled
              system.adapter.signal-cmb.1             : signal-cmb            : iobroker                                 -  enabled
              system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              system.adapter.smartgarden.0            : smartgarden           : iobroker                                 -  enabled
              system.adapter.smartmeter.0             : smartmeter            : iobroker                                 -  enabled
              system.adapter.smartmeter.1             : smartmeter            : iobroker                                 -  enabled
              system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
              system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
              system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
              system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
              system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
              system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
              system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
              system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
              system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
              system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
              system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
              system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
              system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 - disabled
              system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Upgrade policy: none
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "admin"        : 7.0.22   , installed 7.0.22
            Adapter    "backitup"     : 3.0.16   , installed 3.0.16
            Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
            Adapter    "device-reminder": 3.1.2  , installed 3.1.2
            Adapter    "discovery"    : 4.5.0    , installed 4.5.0
            Adapter    "echarts"      : 1.7.2    , installed 1.7.2
            Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
            Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
            Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
            Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
            Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
            Adapter    "gruenbeck"    : 0.0.43   , installed 0.0.43
            Adapter    "homekit-controller": 0.5.10, installed 0.5.10
            Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
            Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
            Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
            Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
            Adapter    "javascript"   : 8.7.6    , installed 8.7.6
            Controller "js-controller": 6.0.9    , installed 6.0.9
            Adapter    "kecontact"    : 2.2.0    , installed 2.2.0
            Adapter    "modbus"       : 6.2.3    , installed 6.2.3
            Adapter    "mpd"          : 2.1.0    , installed 2.1.0
            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
            Adapter    "node-red"     : 5.2.1    , installed 5.2.1
            Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
            Adapter    "nut"          : 1.6.0    , installed 1.6.0
            Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
            Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
            Adapter    "pushover"     : 3.0.6    , installed 3.0.6
            Adapter    "pvforecast"   : 3.0.0    , installed 3.0.0
            Adapter    "reolink"      : 1.1.0    , installed 1.1.0
            Adapter    "robonect"     : 1.3.6    , installed 1.3.6
            Adapter    "scenes"       : 3.2.1    , installed 3.2.1
            Adapter    "shelly"       : 7.0.0    , installed 7.0.0
            Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
            Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
            Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "text2command" : 3.0.3    , installed 3.0.3
            Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
            Adapter    "upnp"         : 1.0.21   , installed 1.0.21
            Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
            Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
            Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
            Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
            Adapter    "weatherunderground": 3.7.0, installed 3.7.0
            Adapter    "wled"         : 0.7.2    , installed 0.7.2
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            Objects and States
            Objects:        16130
            States:         10635
            Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
            Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
            Hit:3 http://archive.ubuntu.com/ubuntu jammy-security InRelease
            Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        161129393  104/systemd-resolve
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          161145003  383/master
            tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      108        161144945  161/influxd
            tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      112        161144011  165/redis-server 0.
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          161129157  1/init
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          161144026  244/sshd: /usr/sbin
            tcp6       0      0 ::1:6379                :::*                    LISTEN      112        161144012  165/redis-server 0.
            tcp6       0      0 :::8086                 :::*                    LISTEN      108        161145391  161/influxd
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          161145004  383/master
            tcp6       0      0 :::111                  :::*                    LISTEN      0          161129159  1/init
            tcp6       0      0 :::22                   :::*                    LISTEN      0          161144037  244/sshd: /usr/sbin
            udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        161129392  104/systemd-resolve
            udp        0      0 192.168.178.138:68      0.0.0.0:*                           101        161137405  94/systemd-networkd
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          161129158  1/init
            udp6       0      0 :::111                  :::*                                0          161129160  1/init
            2024-08-18 15:08:17.587  - error: host.iobroker Caught by controller[1]:     at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3032:37)
            2024-08-18 15:08:17.587  - error: host.iobroker Caught by controller[1]:     at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3093:33)
            2024-08-18 15:08:17.587  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:478:21)
            2024-08-18 15:08:17.587  - error: host.iobroker Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-08-18 15:08:17.587  - error: host.iobroker Caught by controller[1]: Error: DB closed
            2024-08-18 15:08:17.587  - error: host.iobroker Caught by controller[1]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
            2024-08-18 15:08:17.588  - error: host.iobroker Caught by controller[1]:     at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
            2024-08-18 15:08:17.588  - error: host.iobroker Caught by controller[1]:     at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3032:37)
            2024-08-18 15:08:17.588  - error: host.iobroker Caught by controller[1]:     at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3093:33)
            2024-08-18 15:08:17.588  - error: host.iobroker Caught by controller[1]:     at processImmediate (node:internal/timers:478:21)
            2024-08-18 15:08:17.588  - info: host.iobroker instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
            2024-08-18 15:08:17.626  - info: host.iobroker instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
            2024-08-18 15:08:17.641  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
            2024-08-18 15:08:17.641  - error: host.iobroker Caught by controller[0]: Error: Connection is closed.
            2024-08-18 15:08:17.641  - error: host.iobroker Caught by controller[0]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
            2024-08-18 15:08:17.641  - error: host.iobroker Caught by controller[0]:     at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25)
            2024-08-18 15:08:17.641  - error: host.iobroker Caught by controller[0]:     at ObjectsInRedisClient._setObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3455:45)
            2024-08-18 15:08:17.641  - error: host.iobroker Caught by controller[0]:     at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3687:44)
            2024-08-18 15:08:17.641  - error: host.iobroker Caught by controller[0]:     at processImmediate (node:internal/timers:478:21)
            2024-08-18 15:08:17.641  - info: host.iobroker instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
            2024-08-18 15:08:17.641  - info: host.iobroker All instances are stopped.
            2024-08-18 15:08:17.682  - warn: host.iobroker instance system.adapter.pushover.0 terminated due to SIGKILL
            2024-08-18 15:08:17.682  - info: host.iobroker instance system.adapter.pushover.0 terminated with code null ()
            2024-08-18 15:08:17.683  - info: host.iobroker All instances are stopped.
            2024-08-18 15:08:17.842  - info: host.iobroker terminated
              @thomas-braun Copy text starting here:
                                      v.2024-05-22
                       Chassis: container
                Virtualization: lxc
              Installation:           lxc
              Kernel:                 x86_64
              Userland:               64 bit
              Timezone:               Europe/Berlin (CEST, +0200)
              User-ID:                1002
              Boot Target:            graphical.target
              Pending OS-Updates:     0
              Pending iob updates:    0
              Nodejs-Installation:
              /usr/bin/npm            10.8.1
              /usr/bin/npx            10.8.1
              Recommended versions are nodejs 20.16.0 and npm 10.8.1
              MEMORY:
              Mem:            8.2G        493M        6.0G        0.0K        1.7G        7.7G
              Swap:           1.0G          0B        1.0G
              Total:          9.2G        493M        7.0G
              ioBroker Core:          js-controller           6.0.9
                                      admin                   7.0.22
              ioBroker Status:        iobroker is not running on this host.
              Objects type: jsonl
              States  type: redis
              Objects:                16130
              States:                 10635
              Size of iob-Database:
              11M     /opt/iobroker/iobroker-data/objects.json.migrated
              11M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
              9.3M    /opt/iobroker/iobroker-data/states.jsonl
              1.7M    /opt/iobroker/iobroker-data/states.json.migrated
              1.7M    /opt/iobroker/iobroker-data/states.json.bak.migrated
              === Mark text until here for copying ===
                ja und?
                das wird genauso ringerichtet wie jede native Linux Installation.
                anscheinend ja nicht richtig, was immer das ist.
                  Schalt das auf multi-user um.
                  sudo systemctl set-default multi-user.target
                  Warum failen da gleich 5 Services?
                  Setz den Benny da rein:
                  sudo usermod -aG adm Benny
                  Spendier ja in Kürze einen aktuellen Container. Schnubbibunti 20.04 'jammy' läuft läus.
                    reutli @Merowinger last edited by
                    Das geht durchaus in Proxmox im Contaiber statt
                    pct enter
                    einen
                    ssh
                    zu nutzen:
                    einfach im Container die '/etc/ssh/sshd_config" editieren und dort aus
                    PermitRootLogin without-password
                    ein
                    PermitRootLogin yes
                    machen, dann klappt es auch mit SSH.
                    siehe z.B.: https://forum.proxmox.com/threads/cannot-ssh-to-new-container.38114/
                    M Homoran 2 Replies Last reply Reply Quote 0
                      Merowinger @reutli last edited by
                      @reutli Vielen Dank. Ich weiß, versuche aber auch intern so wenig Ports offen zu haben wie möglich.
                        Homoran Global Moderator Administrators @reutli last edited by Homoran
                        @reutli Wieso root-login?
                        Was soll der Quatsch!
                        und dann noch root login per SSH freischalten???
                        Da wird ein stinknormaler User angelegt und der SSH Zugang über diesen genutzt!
                        Der verlinkte Thread ist übrigens steinalt!
                        M R 2 Replies Last reply Reply Quote 1
                          @homoran Ganz genau, dafür habe ich auch schon vor langer Zeit einen nutzer im iobroker angelegt. Nur hat noch was bei den Rechten gefehlt.
                          Vielen Dank!
                            nee, im Linux musst du den anlegen!
                              @homoran hihi für mich ists der iobroker-Container 🙂
                                reutli @Homoran last edited by reutli
                                @homoran sagte in iob Befehle werden nicht ausgeführt:
                                ...das hat mit "root" nichts zu tun, sondern damit, dass man sich per ssh und passwort auf den container verbinden kann. ich melde mich auf meinen proxmox containern nie mit root an....
                                aber immer noch gültig.
                                  @reutli Also vielen lieben Dank für die Hilfe.
                                  Für mich sind alle Fragen geklärt.
                                  Von mir aus kann der Thread gerne geschlossen werden.
                                    @reutli sagte in iob Befehle werden nicht ausgeführt:
                                    Natürlich hat es das!
                                    dazu musst du aber nicht den root-login freischalten!
                                    Der SSH Server muss bei der Installation des OS aktiviert, und ein User angelegt werden.
                                    Der Root darf kein Passwort bekommen!
                                      Gut, nehme ich so hin.
                                      Vielleicht gibt es hier noch Proxmox Spezialisten, die das Verhalten des SSH Deamon in Proxmox erklären können. Wenn man nach SSH Zugriff (ganz ohne root) sucht, findet man überall die gleichen Anleitungen.
                                      Wenn das also alles Quatsch ist, was ich nciht bewerten aknn, dann lösch bitte alle meine Einträge in diesem Post.
                                      Nichts für ungut... 🤷‍♂️
                                        @reutli du musst unterscheiden ob es sich um Zugriff auf das PVE oder um den Zugriff in einen lcx/VM handelt!
                                        EDIT:
                                        Vorgehen bei der Installation siehe hier
                                        https://www.iobroker.net/#de/documentation/install/proxmox.md
                                        lxc etwas weiter unten
                                        • Meister Mopper
                                          Meister Mopper @Homoran last edited by Meister Mopper
                                          EDIT:
                                          Der root login ist auf VM/LXC bei mir tatsächlich nicht möglich. Beim node aber sehr wohl.
                                          Weiß jetzt nicht wie und warum ich das ändern sollte.
                                          ╭╴at  ~ took 30m56s
                                          ╰─ ssh root@192.168.178.10
                                          root@192.168.178.10's password:
                                          Permission denied, please try again.
                                          root@192.168.178.10: Permission denied (publickey,password).
                                          ╭╴at  ~ took 49s
                                          ╰─ ssh root@192.168.1.7
                                          root@192.168.1.7's password:
                                          Linux HA-PVE-01 6.8.12-1-pve #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-1 (2024-08-05T16:17Z) x86_64
                                          The programs included with the Debian GNU/Linux system are free software;
                                          the exact distribution terms for each program are described in the
                                          individual files in /usr/share/doc/*/copyright.
                                          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                          permitted by applicable law.
                                          Last login: Sun Aug 18 18:39:30 2024
                                          root@HA-PVE-01:~#
                                            Homoran Global Moderator Administrators @Meister Mopper last edited by
                                            @meister-mopper sagte in iob Befehle werden nicht ausgeführt:
                                            ich arbeite mich jetztvzwar seit einigen Jahren immer ein wenig tiefer in Linux ein (Thomas sei Dank!) aber so richtig kenne ich mich auch noch nicht aus.
                                            Ganz prinzipiell ist der root-Zugriff per Remote natürlich ein Sicherheitsrisiko, insbesondere, wenn man dann noch die Passwortabfrage deaktivieren würde.
                                            Da man auch über die GUI da als root einsteigt, wäre das aber erstmal alles.
                                            ich glaube allerdings inzwischen kann man auch in der pve einen normalen User mit Sudo-Rechten anlegen.
                                            Ob das bei Proxmox einen Unterschied ausmacht was die Rechteverbiegung angeht, weiss ich nicht.
                                            1467
