    4. iob diag - Skript
    iob diag - Skript
      Hc-Yami @Thomas Braun last edited by
      @thomas-braun läuft wie ein Länderspiel, dankeschön. 🙂
      Wo findet man die obligatorische Kaffeedose?
        Thomas Braun Most Active @Thomas Braun last edited by
        Könnte mal einer der Raspberry 5 User einen vollständigen Lauf zeigen?
        Ich glaube das hakelt da noch an ein paar Stellen. Die würde ich gerne noch ausbügeln.
          Lucky_ESA Developer Most Active @Thomas Braun last edited by
          Skript v.2023-10-10
          *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
                    Kernel: Linux 6.6.20+rpt-rpi-2712
              Architecture: arm64
          Model           : Raspberry Pi 5 Model B Rev 1.0
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           23:01:51 up 4 days,  8:55,  1 user,  load average: 0.22, 0.38, 0.34
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Mon 2024-04-01 23:01:51 CEST
                     Universal time: Mon 2024-04-01 21:01:51 UTC
                           RTC time: Mon 2024-04-01 21:01:51
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            8.4G        5.5G        1.5G        5.5M        1.5G        2.9G
          Swap:           104M          0B        104M
          Total:          8.5G        5.5G        1.6G
                   8052 M total memory
                   5246 M used memory
                   4928 M active memory
                   1077 M inactive memory
                   1431 M free memory
                    161 M buffer memory
                   1314 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          vc_gencmd_read_response returned -1
          error=1 error_msg="Command not registered"
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          Filesystem                     Type      Size  Used Avail Use% Mounted on
          udev                           devtmpfs  3.8G     0  3.8G   0% /dev
          tmpfs                          tmpfs     806M  5.2M  801M   1% /run
          /dev/mmcblk0p2                 ext4      117G  9.3G  102G   9% /
          tmpfs                          tmpfs     4.0G     0  4.0G   0% /dev/shm
          tmpfs                          tmpfs     5.0M   48K  5.0M   1% /run/lock
          /dev/mmcblk0p1                 vfat      510M   63M  448M  13% /boot/firmware
          192.168.2.56:/volume1/iobroker nfs       3.5T  2.8T  776G  79% /opt/iobroker/backups
          tmpfs                          tmpfs     806M     0  806M   0% /run/user/1000
          [Thu Mar 28 13:06:18 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:99:6E:9A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=675ae9ae-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Thu Mar 28 13:06:21 2024] EXT4-fs (mmcblk0p2): mounted filesystem 3b614a3f-4a65-4480-876a-8a998e01ac9b ro with ordered data mode. Quota mode: none.
          [Thu Mar 28 13:06:22 2024] EXT4-fs (mmcblk0p2): re-mounted 3b614a3f-4a65-4480-876a-8a998e01ac9b r/w. Quota mode: none.
          TARGET                  SOURCE                         FSTYPE OPTIONS
          /                       /dev/mmcblk0p2                 ext4   rw,noatime
          |-/boot/firmware        /dev/mmcblk0p1                 vfat   rw,relatime,fmask=
          `-/opt/iobroker/backups 192.168.2.56:/volume1/iobroker nfs    rw,relatime,vers=3
          /var:
          2.0G    /var/
          1.4G    /var/log/journal/87fcd42a64fb499e969e09ffa538a8fe
          1.4G    /var/log
          343M    /var/cache
          Archived and active journals take up 1.3G in the file system.
          /opt/iobroker/backups:
          9.9G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          951M    /opt/iobroker/iobroker-data/
          595M    /opt/iobroker/iobroker-data/files
          266M    /opt/iobroker/iobroker-data/backup-objects
          166M    /opt/iobroker/iobroker-data/files/vis-2
          82M     /opt/iobroker/iobroker-data/files/vis-2/static
          78M     /opt/iobroker/iobroker-data/objects.jsonl
          33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.3c875f4c.js.map
          19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.b4e310b6.js.map
          19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.6aba9d5c.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_d6df2ac6ddc9eb118cf3914f1d69213e-if00-port0
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.20.0
          /usr/bin/node           v18.20.0
          /usr/bin/npm            10.5.0
          /usr/bin/npx            10.5.0
          /usr/bin/corepack       0.25.2
          nodejs:
            Installed: 18.20.0-1nodesource1
            Candidate: 18.20.0-1nodesource1
            Version table:
           *** 18.20.0-1nodesource1 1001
                  100 /var/lib/dpkg/status
               18.19.1-1nodesource1 1001
               18.19.0+dfsg-6~deb12u1 500
               18.19.0-1nodesource1 1001
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0+dfsg1-1 500
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.19
          admin:          6.15.2
          javascript:     7.11.1
          Adapters from github:   9
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          + system.adapter.e2-openwebif.0           : e2-openwebif          : iobroker                                 -  enabled
          + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
            system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
          + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
          + system.adapter.fritzboxdect.0           : fritzboxdect          : iobroker                                 -  enabled
          + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
          + system.adapter.hekr.0                   : hekr                  : iobroker                                 -  enabled
          + system.adapter.hiob.0                   : hiob                  : iobroker                                 -  enabled, port: 8097
          + system.adapter.hiobs.0                  : hiobs                 : iobroker                                 -  enabled, port: 8095
          + system.adapter.history.0                : history               : iobroker                                 -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
          + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
          + system.adapter.imap.0                   : imap                  : iobroker                                 -  enabled
          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled
          + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
          + system.adapter.lgtv.1                   : lgtv                  : iobroker                                 -  enabled
            system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
          + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled, port: 80, 90, 8088, 8999, 554
          + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
          + system.adapter.philips-android-tv.0     : philips-android-tv    : iobroker                                 -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
          + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
          + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
          + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
            system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
            system.adapter.vis-owl.0                : vis-owl               : iobroker                                 -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
            system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.wallpanel.0              : wallpanel             : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
          + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
          + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): beta
          Installed ioBroker-Instances
          Used repository: beta
          Adapter    "admin"        : 6.15.2   , installed 6.15.2
          Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
          Adapter    "backitup"     : 2.11.0   , installed 2.11.0
          Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
          Adapter    "discovery"    : 4.4.0    , installed 4.4.0
          Adapter    "email"        : 1.2.2    , installed 1.2.2
          Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
          Adapter    "followthesun" : 0.5.0    , installed 0.5.0
          Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
          Adapter    "hekr"         : 0.0.6    , installed 0.0.6
          Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
          Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
          Adapter    "ical"         : 1.14.3   , installed 1.14.3
          Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
          Adapter    "imap"         : 0.1.3    , installed 0.1.3
          Adapter    "iot"          : 2.0.11   , installed 2.0.11
          Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
          Adapter    "javascript"   : 7.11.1   , installed 7.11.1
          Adapter    "lg-thinq"     : 0.3.3    , installed 0.3.3
          Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
          Adapter    "linux-control": 1.1.5    , installed 1.1.5
          Adapter    "logparser"    : 2.2.2    , installed 2.2.2
          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
          Adapter    "onvif"        : 1.1.3    , installed 1.1.3
          Adapter    "parcel"       : 0.2.7    , installed 0.2.7
          Adapter    "socketio"     : 6.6.1    , installed 6.6.1
          Adapter    "telegram"     : 3.1.0    , installed 3.1.0
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
          Adapter    "trashschedule": 3.2.0    , installed 3.2.0
          Adapter    "tuya"         : 3.15.0   , installed 3.15.0
          Adapter    "vis-2"        : 2.9.48   , installed 2.9.47 [Updatable]
          Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
          Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
          Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
          Adapter    "web"          : 6.2.5    , installed 6.2.4  [Updatable]
          Adapter    "worx"         : 2.3.4    , installed 2.3.4
          Adapter    "ws"           : 2.5.11   , installed 2.5.11
          Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
          Adapter    "zigbee"       : 1.10.2   , installed 1.10.2
          Objects and States
          Objects:        29996
          States:         25284
          Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists... Done
          Pending Updates: 16
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:38893           0.0.0.0:*               LISTEN      103        6574       1059/rpc.statd
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       7524       1181/io.mqtt.0
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       3950       815/iobroker.js-con
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6370       815/iobroker.js-con
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          8253       1/init
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6304       828/sshd: /usr/sbin
          tcp        0      0 192.168.2.66:8701       0.0.0.0:*               LISTEN      1001       4583563    939275/io.hm-rpc.1
          tcp        0      0 192.168.2.66:9292       0.0.0.0:*               LISTEN      1001       4583690    939361/io.hm-rpc.2
          tcp        0      0 192.168.2.66:2010       0.0.0.0:*               LISTEN      1001       4578722    938471/io.hm-rpc.0
          tcp        0      0 0.0.0.0:35019           0.0.0.0:*               LISTEN      0          7907678    -
          tcp6       0      0 :::45649                :::*                    LISTEN      0          7907680    -
          tcp6       0      0 :::111                  :::*                    LISTEN      0          7274       1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          6306       828/sshd: /usr/sbin
          tcp6       0      0 :::8095                 :::*                    LISTEN      1001       10781      2307/io.hiobs.0
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       9186       1977/io.simple-api.
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9713       1325/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6447       912/io.admin.0
          tcp6       0      0 :::8097                 :::*                    LISTEN      1001       562465     120279/io.hiob.0
          tcp6       0      0 :::35675                :::*                    LISTEN      103        6578       1059/rpc.statd
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          9289       1/init
          udp        0      0 127.0.0.1:811           0.0.0.0:*                           0          8263       1059/rpc.statd
          udp        0      0 0.0.0.0:42082           0.0.0.0:*                           104        6217       687/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6215       687/avahi-daemon: r
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       8520       1212/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       8521       1212/io.tuya.0
          udp        0      0 0.0.0.0:35386           0.0.0.0:*                           0          7907677    -
          udp        0      0 0.0.0.0:44296           0.0.0.0:*                           103        6572       1059/rpc.statd
          udp6       0      0 :::40946                :::*                                103        6576       1059/rpc.statd
          udp6       0      0 :::111                  :::*                                0          7276       1/init
          udp6       0      0 fe80::eb3e:7926:d35:546 :::*                                0          9281930    788/NetworkManager
          udp6       0      0 :::5353                 :::*                                104        6216       687/avahi-daemon: r
          udp6       0      0 :::47552                :::*                                0          7907679    -
          udp6       0      0 :::43790                :::*                                104        6218       687/avahi-daemon: r
          2024-04-01 22:57:59.799  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Start Aktualisierung Worx!1
          2024-04-01 22:57:59.836  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Wifi Qualität wurde geändert: -80
          2024-04-01 23:00:00.006  - info: javascript.0 (960) script.js.Scripts.Alexa_Antworttext.Gartenbeleuchtung: Gartenbeleuchtung
          2024-04-01 23:00:00.009  - info: javascript.0 (960) script.js.Scripts.Allgemein.Prüfung_Regen: Start Regen Check
          2024-04-01 23:00:00.024  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 2030238
          2024-04-01 23:00:00.049  - info: javascript.0 (960) script.js.Scripts.Allgemein.Astro: Astro: Gültige Zeiten: [aktueller Tag: 0] | [nächster Tag: 14] | [Aktualisiert: 0] | Aktuelle Tageszeit: Nacht | Kommende Tageszeit: Mitternacht
          2024-04-01 23:00:00.891  - info: javascript.0 (960) script.js.Scripts.Allgemein.Dachfenster_automatisch: Der Server Karte ist Online!!!
          2024-04-01 23:00:01.531  - info: daswetter.0 (2030238) starting. Version 3.1.13 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.20.0, js-controller: 5.0.19
          2024-04-01 23:00:04.032  - info: host.iobroker instance system.adapter.ical.0 started with pid 2030479
          2024-04-01 23:00:05.135  - info: trashschedule.0 (2262) Setting "actionNeeded" flag for type.restmüll.actionNeeded to true (???)
          2024-04-01 23:00:05.560  - info: ical.0 (2030479) starting. Version 1.14.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.20.0, js-controller: 5.0.19
          2024-04-01 23:00:06.323  - info: ical.0 (2030479) processing URL: Muell https://calendar.google.com/calendar/ical/c241cf4fcd482c213a45430df0868c1653d1e8d1b854ece0b0863fdc99bb146b%40group.calendar.google.com/public/basic.ics
          2024-04-01 23:00:06.428  - info: trashschedule.0 (2262) Setting "actionNeeded" flag for type.restmüll.actionNeeded to true (???)
          2024-04-01 23:00:11.538  - info: ical.0 (2030479) Terminated (NO_ERROR): Without reason
          2024-04-01 23:00:12.062  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
          2024-04-01 23:00:12.071  - info: daswetter.0 (2030238) still wrong data structure from server received! repaired...
          2024-04-01 23:00:14.767  - info: daswetter.0 (2030238) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
          2024-04-01 23:00:15.272  - info: daswetter.0 (2030238) cleaned everything up...
          2024-04-01 23:00:15.278  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-04-01 23:00:21.417  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Klingenarbeitszeit wurde aktualisiert:  531.9
          2024-04-01 23:00:21.440  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Temperatur Akku hat sich geändert: 11.6
          2024-04-01 23:00:21.462  - info: javascript.0 (960) script.js.Scripts.Alexa_Antworttext.Worx: HTML Aktualisierung: worx.0.202130266301009363E0.mower.status - 1
          2024-04-01 23:00:21.462  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Trigger Aktualisierung Worx!1
          2024-04-01 23:00:21.463  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Start Aktualisierung Worx!1
          2024-04-01 23:00:21.498  - info: javascript.0 (960) script.js.Scripts.Allgemein.Worx_neu: Wifi Qualität wurde geändert: -80
          iob diag has finished.
          Press any key for a summary
                                  v.2023-10-10
                 Icon name: computer
              Architecture: arm64
          Installation:           native
          Kernel:                 aarch64
          Userland:               arm64
          Timezone:               Europe/Berlin (CEST, +0200)
          User-ID:                1000
          X-Server:               false
          Pending OS-Updates:     16
          Pending iob updates:    2
          Nodejs-Installation:    /usr/bin/nodejs         v18.20.0
                                  /usr/bin/npm            10.5.0
                                  /usr/bin/npx            10.5.0
          Recommended versions are nodejs 18.20.0 and npm 10.5.0
          MEMORY:
          Mem:            8.4G        5.4G        1.4G        5.5M        1.8G        3.1G
          Swap:           104M          0B        104M
          Total:          8.5G        5.4G        1.5G
          Active iob-Instances:   47
          ioBroker Core:          js-controller           5.0.19
                                  admin                   6.15.2
          Objects type: jsonl
          States  type: jsonl
          Objects:                29996
          States:                 25284
          Size of iob-Database:
          87M     /opt/iobroker/iobroker-data/objects.jsonl
          15M     /opt/iobroker/iobroker-data/states.jsonl
          === Mark text until here for copying ===
          pi@iobroker:~ $
            Thomas Braun Most Active @Lucky_ESA last edited by
            @lucky_esa
            Das kommt vermutlich bei dir mit Fehler um die Ecke, oder?
            vcgencmd mem_oom
              @thomas-braun Natürlich.
              pi@iobroker:~ $ vcgencmd mem_oom
              pi@iobroker:~ $ ^C
              pi@iobroker:~ $ vcgencmd commands
              commands="commands, set_logging, bootloader_config, bootloader_version, cache_flush, codec_enabled, get_mem, get_rsts, measure_clock, measure_temp, measure_volts, get_hvs_asserts, get_config, get_throttled, pmicrd, pmicwr, read_ring_osc, version, readmr, otp_dump, pmic_read_adc, power_monitor"
              pi@iobroker:~ $
              Verwende doch get_throttled.
              Gruß//Lucky
                @lucky_esa
                Dann ist 'mem_oom' wohl aus der Firmware für den RPi5 geflogen. Ich hab den Code jetzt aus dem Skript herausgenommen, die Info war eh nicht so wirklich aussagekräftig.
                'get_throttled' wird an anderer Stelle natürlich abgefragt.
                  Thomas Braun Most Active @Thomas Braun last edited by Thomas Braun
                  Neuer Diagnosepunkt
                  'Life Cycle Status'
                  ist drin. Können bitte User von Dockern und LXCs da mal schauen ob und mit welchen Meldungen da im Langtext und in der Zusammenfassung da sowas erscheint?
                  (Bitte wie im ersten Eröffungsposting in diesem Thread gezeigt direkt vom github laden).
                  *** LIFE CYCLE STATUS ***
                  Your Operating System codenamed 'trixie' is a testing release! Please use it only for testing purposes!
                  Gleiche Meldung dann in der Summary.
                  Danke schön!
                  S Feuersturm 2 Replies Last reply Reply Quote 3
                    Shadowhunter23 @Thomas Braun last edited by Shadowhunter23
                    LXCs
                    Gerne:
                    Your Operating System is the current Debian stable version 'bookworm'!
                    Und Summery am Ende:
                    Dolomiti 1 Reply Last reply Reply Quote 0
                    • Dolomiti
                      Dolomiti @Shadowhunter23 last edited by
                      LXCs
                      Weder im Langtext noch in der Zusammenfassung wir etwas angezeigt. Egal ob über iob diag oder dem direktem Skritpaufruf aus deiner Signatur.
                      js-controller: 6.0.10
                      admin:7.0.24
                      npm: 20.16.0
                        Homoran Global Moderator Administrators @Dolomiti last edited by
                        @dolomiti sagte in iob diag - Skript:
                        du sollst ja auch den Testaufruf aus dem ersten Post ausführen, damit das neue Skript nach Testung freigeschaltet werden kann.
                        • Dolomiti
                          Dolomiti @Homoran last edited by Dolomiti
                          @homoran sagte in iob diag - Skript:
                          Dann hätte Thomas evtl. ein Hinweis schreiben sollen, dass man das Skript aus dem ersten Post nehmen soll. Das geht aus der Meldung von vor 5 Stunden nicht hervor.
                          @Thomas-Braun
                          Davon abgesehehn kommt bei mir nix im Langtext und folgendes in der Zusammenfassung
                            Homoran Global Moderator Administrators @Dolomiti last edited by Homoran
                            das soll ja getestet werden.
                            Müsste im oberen Drittel stehen, und bei dir ebenfalls grün sein
                            EDIT:
                            siehe Post von @Meister-Mopper
                            • Meister Mopper
                              Meister Mopper last edited by
                              Hier das Ergebnis meines Master-LXC (trixie habe ich aber auf keinem lxc laufen).
                              bash
                              Skript v.2024-08-18
                              *** BASE SYSTEM ***
                                    Icon name: computer-container
                                      Chassis: container ☐
                               Virtualization: lxc
                                       Kernel: Linux 6.8.12-1-pve
                                 Architecture: x86-64
                              OS is similar to:
                              model name      : Intel(R) Core(TM) i3-10110U CPU @ 2.10GHz
                              Docker          : false
                              Virtualization  : lxc
                              Kernel          : x86_64
                              Userland        : 64 bit
                              18:04:19 up 10 days,  2:16,  1 user,  load average: 2.02, 1.83, 1.58
                              CPU threads: 2
                                            Local time: Sun 2024-08-18 18:04:19 CEST
                                        Universal time: Sun 2024-08-18 16:04:19 UTC
                                              RTC time: n/a
                                           NTP service: inactive
                                       RTC in local TZ: no
                              *** Users and Groups ***
                              User that called 'iob diag':
                              thomas
                              HOME=/home/thomas
                              GROUPS=thomas adm dialout sudo systemd-journal redis iobroker
                              iobroker
                              HOME=/home/iobroker
                              GROUPS=iobroker tty dialout audio video redis
                              *** Display-Server-Setup ***
                              Display-Server: false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            6.4G        3.2G        3.1G        126K        161M        3.3G
                              Swap:             0B          0B          0B
                              Total:          6.4G        3.2G        3.1G
                              Active iob-Instances:   54
                                      6144 M total memory
                                      3022 M used memory
                                      2280 M active memory
                                       781 M inactive memory
                                      2967 M free memory
                                         0 M buffer memory
                                       154 M swap cache
                                         0 M total swap
                                         0 M used swap
                                         0 M free swap
                              top - 18:04:20 up 10 days,  2:16,  1 user,  load average: 2.02, 1.83, 1.58
                              Tasks:  63 total,   2 running,  61 sleeping,   0 stopped,   0 zombie
                              %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :   6144.0 total,   2966.1 free,   3023.8 used,    154.2 buff/cache
                              MiB Swap:      0.0 total,      0.0 free,      0.0 used.   3120.2 avail Mem
                               UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
                              * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
                              * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                              * sys-kernel-debug.mount  loaded failed failed Kernel Debug File System
                              LOAD   = Reflects whether the unit definition was properly loaded.
                              ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                              SUB    = The low-level unit activation state, values depend on unit type.
                              3 loaded units listed.
                              *** FILESYSTEM ***
                              rpool/data/subvol-100-disk-1 zfs        32G  8.5G   24G  27% /
                              none                         tmpfs     492K  4.0K  488K   1% /dev
                              udev                         devtmpfs   16G     0   16G   0% /dev/tty
                              tmpfs                        tmpfs      16G     0   16G   0% /dev/shm
                              tmpfs                        tmpfs     6.3G  120K  6.3G   1% /run
                              tmpfs                        tmpfs     5.0M     0  5.0M   0% /run/lock
                              tmpfs                        tmpfs     3.2G     0  3.2G   0% /run/user/1000
                              dmesg: read kernel buffer failed: Operation not permitted
                              Show mounted filesystems:
                              /      rpool/data/subvol-100-disk-1 zfs    rw,noatime,xattr,posixacl,casesensitive
                              /var:
                              872M    /var/
                              544M    /var/cache
                              541M    /var/cache/apt
                              494M    /var/cache/apt/archives
                              212M    /var/log
                              Archived and active journals take up 200.2M in the file system.
                              138M    /opt/iobroker/backups/
                              832M    /opt/iobroker/iobroker-data/
                              518M    /opt/iobroker/iobroker-data/files
                              276M    /opt/iobroker/iobroker-data/backup-objects
                              185M    /opt/iobroker/iobroker-data/files/javascript.admin
                              169M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                              16M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                              15M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                              11M     /opt/iobroker/iobroker-data/objects.jsonl
                              11M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
                              8.4M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.1e6546bb.js.map
                              USB-Devices by-id:
                              No Devices found 'by-id'
                              HINT:
                              Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                              /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if00
                              /usr/bin/nodejs         v20.16.0
                              /usr/bin/node           v20.16.0
                              /usr/bin/npm            10.8.1
                              /usr/bin/npx            10.8.1
                              /usr/bin/corepack       0.28.2
                              nodejs:
                               Installed: 20.16.0-1nodesource1
                               Candidate: 20.16.0-1nodesource1
                               Version table:
                              *** 20.16.0-1nodesource1 1001
                                     500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                  20.15.1-1nodesource1 1001
                                  20.15.0-1nodesource1 1001
                                  20.14.0-1nodesource1 1001
                                  20.13.1-1nodesource1 1001
                                  20.13.0-1nodesource1 1001
                                  20.12.2-1nodesource1 1001
                                  20.12.1-1nodesource1 1001
                                  20.12.0-1nodesource1 1001
                                  20.11.1-1nodesource1 1001
                                  20.11.0-1nodesource1 1001
                                  20.10.0-1nodesource1 1001
                                  20.9.0-1nodesource1 1001
                                  20.8.1-1nodesource1 1001
                                  20.8.0-1nodesource1 1001
                                  20.7.0-1nodesource1 1001
                                  20.6.1-1nodesource1 1001
                                  20.6.0-1nodesource1 1001
                                  20.5.1-1nodesource1 1001
                                  20.5.0-1nodesource1 1001
                                  20.4.0-1nodesource1 1001
                                  20.3.1-1nodesource1 1001
                                  20.3.0-1nodesource1 1001
                                  20.2.0-1nodesource1 1001
                                  20.1.0-1nodesource1 1001
                                  20.0.0-1nodesource1 1001
                                  18.19.0+dfsg-6~deb12u2 500
                                     500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                     500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                              Errors in npm tree:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: redis
                              js-controller:  6.0.9
                              admin:          7.0.22
                              javascript:     8.7.6
                              nodejs modules from github:     4
                              +-- iobroker.bluelink@2.3.6 (git+ssh://git@github.com/Newan/ioBroker.bluelink.git#cfdb728c50b2373f05766dba34797a220302d309)
                              | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                              | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                              +-- iobroker.vaillant@0.4.0 (git+ssh://git@github.com/TA2k/ioBroker.vaillant.git#fcdfef2d5daac95190d5ab2ba2ab5e213f937a41)
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                               system.adapter.alias-manager.0          : alias-manager         : rpizigbee                                -  enabled
                              + system.adapter.backitup.1               : backitup              : rpizigbee                                -  enabled
                              + system.adapter.bluelink.0               : bluelink              : iobroker                                 -  enabled
                              + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                               system.adapter.daswetter.0              : daswetter             : rpizigbee                                -  enabled
                              + system.adapter.denon.0                  : denon                 : rpizigbee                                -  enabled
                               system.adapter.dwd.0                    : dwd                   : rpizigbee                                -  enabled
                              + system.adapter.enigma2.0                : enigma2               : rpizigbee                                -  enabled
                              + system.adapter.enigma2.1                : enigma2               : rpizigbee                                -  enabled
                              + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
                              + system.adapter.heos.0                   : heos                  : rpizigbee                                -  enabled
                              + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
                              + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
                              + system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                               system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                               system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
                               system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
                               system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
                               system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                               system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
                              + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                              + system.adapter.linux-control.0          : linux-control         : rpizigbee                                -  enabled
                              + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                              + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
                              + system.adapter.nut.1                    : nut                   : iobroker                                 -  enabled
                              + system.adapter.ocpp.0                   : ocpp                  : rpizigbee                                -  enabled, port: 9220
                              + system.adapter.openligadb.0             : openligadb            : iobroker                                 -  enabled
                              + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
                              + system.adapter.pi-hole.1                : pi-hole               : rpizigbee                                -  enabled
                              + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                              + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
                              + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                              + system.adapter.rpi2.0                   : rpi2                  : rpizigbee                                -  enabled
                              + system.adapter.samsung_tizen.0          : samsung_tizen         : rpizigbee                                -  enabled, port: 8002
                              + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                              + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
                              + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
                              + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
                              + system.adapter.sayit.4                  : sayit                 : iobroker                                 -  enabled
                              + system.adapter.sayit.5                  : sayit                 : iobroker                                 -  enabled
                              + system.adapter.smartmeter.0             : smartmeter            : rpizigbee                                -  enabled
                              + system.adapter.solax.0                  : solax                 : iobroker                                 -  enabled
                              + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 8883, bind: 0.0.0.0
                              + system.adapter.tankerkoenig.0           : tankerkoenig          : rpizigbee                                -  enabled
                              + system.adapter.tuya.0                   : tuya                  : rpizigbee                                -  enabled
                              + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                              + system.adapter.vaillant.0               : vaillant              : rpizigbee                                -  enabled
                               system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                               system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
                               system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
                               system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
                               system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                               system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                               system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                               system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
                               system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
                               system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                              + system.adapter.yeelight-2.0             : yeelight-2            : rpizigbee                                -  enabled
                              + system.adapter.zigbee.0                 : zigbee                : rpizigbee                                -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if00
                              + instance is alive
                              │ (index) │ name            │ url                                                     │ auto upgrade │
                              │ 0       │ 'stable'        │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                              │ 1       │ '(beta) latest' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                              │ 2       │ 'stable-live'   │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
                              │ 3       │ 'latest-live'   │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
                              Active repo(s): stable
                              Upgrade policy: none
                              Used repository: stable
                              Adapter    "admin"        : 7.0.22   , installed 7.0.22
                              Adapter    "backitup"     : 3.0.16   , installed 3.0.16
                              Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
                              Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
                              Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
                              Adapter    "denon"        : 1.15.12  , installed 1.15.12
                              Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                              Adapter    "enigma2"      : 2.1.1    , installed 2.1.1
                              Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                              Adapter    "harmony"      : 1.4.0    , installed 1.4.0
                              Adapter    "heos"         : 2.2.1    , installed 2.2.1
                              Adapter    "hue"          : 3.11.0   , installed 3.11.0
                              Adapter    "ical"         : 1.15.0   , installed 1.15.0
                              Adapter    "iot"          : 3.3.0    , installed 3.3.0
                              Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                              Controller "js-controller": 6.0.9    , installed 6.0.9
                              Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                              Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                              Adapter    "nut"          : 1.6.0    , installed 1.6.0
                              Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
                              Adapter    "openligadb"   : 1.4.9    , installed 1.4.9
                              Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                              Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
                              Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
                              Adapter    "samsung"      : 0.6.0    , installed 0.6.0
                              Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
                              Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                              Adapter    "scenes"       : 3.2.1    , installed 3.2.1
                              Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                              Adapter    "solax"        : 0.9.9    , installed 0.9.9
                              Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                              Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
                              Adapter    "synology"     : 3.1.0    , installed 3.1.0
                              Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                              Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                              Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                              Adapter    "traccar"      : 1.1.4    , installed 1.1.4
                              Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                              Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                              Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                              Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                              Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                              Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                              Adapter    "vis-map"      : 1.0.5    , installed 1.0.5
                              Adapter    "ws"           : 2.6.2    , installed 2.6.2
                              Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
                              Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                              Objects and States
                              Objects:        23058
                              States:         24327
                              Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                              Hit:2 http://deb.debian.org/debian bookworm InRelease
                              Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                              Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                              Pending Updates: 0
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          35104      131/sshd: /usr/sbin
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          32330      1/init
                              tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      110        32536      124/redis-server 0.
                              tcp        0      0 192.168.178.10:12010    0.0.0.0:*               LISTEN      1001       39136      393/io.hm-rpc.1
                              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       34416      137/iobroker.js-con
                              tcp        0      0 0.0.0.0:8883            0.0.0.0:*               LISTEN      1001       67265983   3623001/io.sonoff.0
                              tcp        0      0 192.168.178.10:2001     0.0.0.0:*               LISTEN      1001       39803      568/io.hm-rpc.0
                              tcp6       0      0 :::3000                 :::*                    LISTEN      1001       44592      880/io.fullybrowser
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          35115      131/sshd: /usr/sbin
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          32332      1/init
                              tcp6       0      0 :::8087                 :::*                    LISTEN      1001       47625      1034/io.simple-api.
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9871275    531497/io.web.0
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       34578      156/io.admin.0
                              tcp6       0      0 :::6556                 :::*                    LISTEN      0          32456      1/init
                              tcp6       0      0 ::1:6379                :::*                    LISTEN      110        32537      124/redis-server 0.
                              tcp6       0      0 :::61991                :::*                    LISTEN      1001       39003      268/io.harmony.0
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       92149192   770498/io.chromecas
                              udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       39004      268/io.harmony.0
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          32331      1/init
                              udp6       0      0 :::111                  :::*                                0          32333      1/init
                              2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 10: Fenster Konferenzraum:0.LOW_BAT: false
                              2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 11: Fenster Gästezimmer oben:0.LOW_BAT: false
                              2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 12: Fenster Bad oben:0.LOW_BAT: false
                              2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 13: Fenster Fitness:0.LOW_BAT: false
                              2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 14: Fenster Gäste unten:0.LOW_BAT: false
                              2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 15: Postkasten:0.LOW_BAT: false
                              2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 16: Heizung Küche:0.LOW_BAT: false
                              2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 17: Heizung Bad unten:0.LOW_BAT: false
                              2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 18: Heizung Schlafzimmer:0.LOW_BAT: false
                              2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 19: Heizung Wohnzimmer:0.LOW_BAT: false
                              2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 20: Heizung Gästezimmer oben:0.LOW_BAT: false
                              2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 21: Heizung Konferenzraum:0.LOW_BAT: false
                              2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 22: Heizung Bad oben:0.LOW_BAT: false
                              2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 23: Heizung Büro:0.LOW_BAT: false
                              2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 24: Heizung Fitnessraum:0.LOW_BAT: false
                              2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 25: Heizung Gästezimmer unten:0.LOW_BAT: false
                              2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 26: Presence Kueche:0.LOW_BAT: false
                              2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 27: Lichtsensor:0.LOW_BAT: false
                              2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 28: Sensor Bad unten:0.LOW_BAT: false
                              2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 29: Sensor Wohnzimmer:0.LOW_BAT: false
                              2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 30: Außenthermometer:0.LOW_BAT: false
                              2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 31: Wetterstation:0.LOW_BAT: true
                              2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 32: Heizung Bad oben 2:0.LOW_BAT: false
                              2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Text: Wetterstation:0.LOW_BAT
                              2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Anzahl Geräte: 34 # davon LOWBAT erkannt: 1
                              • Dolomiti
                                @Thomas-Braun
                                OK. In der Langfassung kommt der Text weiter oben.
                                Bei mir also ok
                                  Thomas Braun Most Active @Meister Mopper last edited by
                                  @meister-mopper sagte in iob diag - Skript:
                                  Trixie ist ja auch eine Ausgabe von meinem System....
                                  • Meister Mopper
                                    Meister Mopper @Thomas Braun last edited by
                                    @thomas-braun sagte in iob diag - Skript:
                                    I know, es war nur eine Ergänzung für Mitleser.
                                    • Feuersturm
                                      Feuersturm @Thomas Braun last edited by
                                      @thomas-braun Hi,
                                      bei mir wird das ausgegeben:
                                      ```bash
                                      Skript v.2024-08-18
                                      *** BASE SYSTEM ***
                                       Static hostname: ioB-Prod-Testsystem
                                               Chassis: container
                                        Virtualization: lxc
                                      Operating System: Ubuntu 22.04.4 LTS
                                                Kernel: Linux 6.5.13-1-pve
                                      OS is similar to: debian
                                      model name      : Intel(R) Celeron(R) CPU  N3150  @ 1.60GHz
                                      Docker          : false
                                      Kernel          : x86_64
                                      Userland        : 64 bit
                                       19:30:53 up 15 days,  5:33,  1 user,  load average: 3.39, 2.72, 2.50
                                      CPU threads: 4
                                      Your Operating System 'jammy focal' is an aging Ubuntu LTS release! Please upgrade to the latest LTS release 'noble' in due time!
                                      Das ist das OS auf dem Testsystem
                                      Welcome to Ubuntu 22.04.4 LTS (GNU/Linux 6.5.13-1-pve x86_64)
                                       * Documentation:  https://help.ubuntu.com
                                       * Management:     https://landscape.canonical.com
                                       * Support:        https://ubuntu.com/pro
                                      Last login: Sun Aug 18 19:27:48 2024 from 192.168.178.128
                                      proxmox@ioB-Prod-Testsystem:~$ ^C
                                      proxmox@ioB-Prod-Testsystem:~$ lsb_release -a
                                      No LSB modules are available.
                                      Distributor ID: Ubuntu
                                      Description:    Ubuntu 22.04.4 LTS
                                      Release:        22.04
                                      Codename:       jammy
                                      • Ist die Ausgabe jammy focal von iob diag richtig oder müsste es nur jammy sein?
                                      • Laut dieser Liste https://wiki.ubuntu.com/Releases wird jammy noch bis 2027 gepflegt. Prüft iob diag ob es nur eine aktuellere Version gibt oder auf welcher Basis wird die Aussage "is an aging Ubuntu LTS release" generiert?
                                        Thomas Braun Most Active @Feuersturm last edited by Thomas Braun
                                        @feuersturm sagte in iob diag - Skript:
                                        Das ist die Ausgabe von
                                        lsb_release -sc
                                        Ja, deswegen ja auch die Aussage, dass deine Distribution nicht das aktuelle LTS-Release ist, aber noch unterhalten wird.
                                        • Feuersturm
                                          @thomas-braun Der Befehl
                                          proxmox@ioB-Prod-Testsystem:~$ lsb_release -sc
                                          jammy
                                          gibt aber nur jammy aus und nicht jammy focal
                                            @feuersturm
                                            Muss ich mal schauen wo das herkommt. Bist bislang der erste bei dem das passiert.
                                            738
                                            151382
