    4. iob diag - Skript
    iob diag - Skript
      Homoran Global Moderator Administrators @Dolomiti last edited by Homoran
      @dolomiti sagte in iob diag - Skript:
      Davon abgesehehn kommt bei mir nix im Langtext
      das soll ja getestet werden.
      Müsste im oberen Drittel stehen, und bei dir ebenfalls grün sein
      EDIT:
      siehe Post von @Meister-Mopper
      *** LIFE CYCLE STATUS ***
      Your Operating System is the current Debian stable version 'bookworm'!
      • Meister Mopper
        Meister Mopper last edited by
        Hier das Ergebnis meines Master-LXC (trixie habe ich aber auf keinem lxc laufen).
        bash
        Skript v.2024-08-18
        *** BASE SYSTEM ***
        Static hostname: iobroker
              Icon name: computer-container
                Chassis: container ☐
         Virtualization: lxc
                 Kernel: Linux 6.8.12-1-pve
           Architecture: x86-64
        OS is similar to:
        model name      : Intel(R) Core(TM) i3-10110U CPU @ 2.10GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
        18:04:19 up 10 days,  2:16,  1 user,  load average: 2.02, 1.83, 1.58
        CPU threads: 2
        *** Time and Time Zones ***
                      Local time: Sun 2024-08-18 18:04:19 CEST
                  Universal time: Sun 2024-08-18 16:04:19 UTC
                        RTC time: n/a
                     NTP service: inactive
                 RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        thomas
        HOME=/home/thomas
        GROUPS=thomas adm dialout sudo systemd-journal redis iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video redis
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            6.4G        3.2G        3.1G        126K        161M        3.3G
        Swap:             0B          0B          0B
        Total:          6.4G        3.2G        3.1G
        Active iob-Instances:   54
                6144 M total memory
                3022 M used memory
                2280 M active memory
                 781 M inactive memory
                2967 M free memory
                   0 M buffer memory
                 154 M swap cache
                   0 M total swap
                   0 M used swap
                   0 M free swap
        top - 18:04:20 up 10 days,  2:16,  1 user,  load average: 2.02, 1.83, 1.58
        Tasks:  63 total,   2 running,  61 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   6144.0 total,   2966.1 free,   3023.8 used,    154.2 buff/cache
        MiB Swap:      0.0 total,      0.0 free,      0.0 used.   3120.2 avail Mem
        *** FAILED SERVICES ***
         UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
        * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
        * sys-kernel-debug.mount  loaded failed failed Kernel Debug File System
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        3 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                   Type      Size  Used Avail Use% Mounted on
        rpool/data/subvol-100-disk-1 zfs        32G  8.5G   24G  27% /
        none                         tmpfs     492K  4.0K  488K   1% /dev
        udev                         devtmpfs   16G     0   16G   0% /dev/tty
        tmpfs                        tmpfs      16G     0   16G   0% /dev/shm
        tmpfs                        tmpfs     6.3G  120K  6.3G   1% /run
        tmpfs                        tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs                        tmpfs     3.2G     0  3.2G   0% /run/user/1000
        dmesg: read kernel buffer failed: Operation not permitted
        Show mounted filesystems:
        TARGET SOURCE                       FSTYPE OPTIONS
        /      rpool/data/subvol-100-disk-1 zfs    rw,noatime,xattr,posixacl,casesensitive
        /var:
        872M    /var/
        544M    /var/cache
        541M    /var/cache/apt
        494M    /var/cache/apt/archives
        212M    /var/log
        Archived and active journals take up 200.2M in the file system.
        /opt/iobroker/backups:
        138M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        832M    /opt/iobroker/iobroker-data/
        518M    /opt/iobroker/iobroker-data/files
        276M    /opt/iobroker/iobroker-data/backup-objects
        185M    /opt/iobroker/iobroker-data/files/javascript.admin
        169M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        16M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        15M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        11M     /opt/iobroker/iobroker-data/objects.jsonl
        11M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
        8.4M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.1e6546bb.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
        /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if00
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.16.0
        /usr/bin/node           v20.16.0
        /usr/bin/npm            10.8.1
        /usr/bin/npx            10.8.1
        /usr/bin/corepack       0.28.2
        nodejs:
         Installed: 20.16.0-1nodesource1
         Candidate: 20.16.0-1nodesource1
         Version table:
        *** 20.16.0-1nodesource1 1001
               500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
               100 /var/lib/dpkg/status
            20.15.1-1nodesource1 1001
            20.15.0-1nodesource1 1001
            20.14.0-1nodesource1 1001
            20.13.1-1nodesource1 1001
            20.13.0-1nodesource1 1001
            20.12.2-1nodesource1 1001
            20.12.1-1nodesource1 1001
            20.12.0-1nodesource1 1001
            20.11.1-1nodesource1 1001
            20.11.0-1nodesource1 1001
            20.10.0-1nodesource1 1001
            20.9.0-1nodesource1 1001
            20.8.1-1nodesource1 1001
            20.8.0-1nodesource1 1001
            20.7.0-1nodesource1 1001
            20.6.1-1nodesource1 1001
            20.6.0-1nodesource1 1001
            20.5.1-1nodesource1 1001
            20.5.0-1nodesource1 1001
            20.4.0-1nodesource1 1001
            20.3.1-1nodesource1 1001
            20.3.0-1nodesource1 1001
            20.2.0-1nodesource1 1001
            20.1.0-1nodesource1 1001
            20.0.0-1nodesource1 1001
            18.19.0+dfsg-6~deb12u2 500
               500 http://deb.debian.org/debian bookworm/main amd64 Packages
            18.19.0+dfsg-6~deb12u1 500
               500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: redis
        Core adapters versions
        js-controller:  6.0.9
        admin:          7.0.22
        javascript:     8.7.6
        nodejs modules from github:     4
        +-- iobroker.bluelink@2.3.6 (git+ssh://git@github.com/Newan/ioBroker.bluelink.git#cfdb728c50b2373f05766dba34797a220302d309)
        | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
        | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
        +-- iobroker.vaillant@0.4.0 (git+ssh://git@github.com/TA2k/ioBroker.vaillant.git#fcdfef2d5daac95190d5ab2ba2ab5e213f937a41)
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
         system.adapter.alias-manager.0          : alias-manager         : rpizigbee                                -  enabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.backitup.1               : backitup              : rpizigbee                                -  enabled
        + system.adapter.bluelink.0               : bluelink              : iobroker                                 -  enabled
        + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
         system.adapter.daswetter.0              : daswetter             : rpizigbee                                -  enabled
        + system.adapter.denon.0                  : denon                 : rpizigbee                                -  enabled
        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
         system.adapter.dwd.0                    : dwd                   : rpizigbee                                -  enabled
        + system.adapter.enigma2.0                : enigma2               : rpizigbee                                -  enabled
        + system.adapter.enigma2.1                : enigma2               : rpizigbee                                -  enabled
         system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
        + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
        + system.adapter.heos.0                   : heos                  : rpizigbee                                -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
        + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
        + system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
         system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
         system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
         system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
         system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
         system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
         system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
         system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.linux-control.0          : linux-control         : rpizigbee                                -  enabled
        + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
        + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
        + system.adapter.nut.1                    : nut                   : iobroker                                 -  enabled
        + system.adapter.ocpp.0                   : ocpp                  : rpizigbee                                -  enabled, port: 9220
        + system.adapter.openligadb.0             : openligadb            : iobroker                                 -  enabled
        + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
        + system.adapter.pi-hole.1                : pi-hole               : rpizigbee                                -  enabled
        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
        + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
        + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
        + system.adapter.rpi2.0                   : rpi2                  : rpizigbee                                -  enabled
        + system.adapter.samsung_tizen.0          : samsung_tizen         : rpizigbee                                -  enabled, port: 8002
        + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
        + system.adapter.sayit.1                  : sayit                 : iobroker                                 -  enabled
        + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
        + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled
        + system.adapter.sayit.4                  : sayit                 : iobroker                                 -  enabled
        + system.adapter.sayit.5                  : sayit                 : iobroker                                 -  enabled
        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.smartmeter.0             : smartmeter            : rpizigbee                                -  enabled
        + system.adapter.solax.0                  : solax                 : iobroker                                 -  enabled
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 8883, bind: 0.0.0.0
        + system.adapter.tankerkoenig.0           : tankerkoenig          : rpizigbee                                -  enabled
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        + system.adapter.tuya.0                   : tuya                  : rpizigbee                                -  enabled
        + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
        + system.adapter.vaillant.0               : vaillant              : rpizigbee                                -  enabled
         system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
         system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
         system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
         system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
         system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
         system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
         system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
         system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
         system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
         system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
         system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.yeelight-2.0             : yeelight-2            : rpizigbee                                -  enabled
        + system.adapter.zigbee.0                 : zigbee                : rpizigbee                                -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100MSJ-if00
        + instance is alive
        ioBroker-Repositories
        │ (index) │ name            │ url                                                     │ auto upgrade │
        │ 0       │ 'stable'        │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
        │ 1       │ '(beta) latest' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
        │ 2       │ 'stable-live'   │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
        │ 3       │ 'latest-live'   │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.0.22   , installed 7.0.22
        Adapter    "backitup"     : 3.0.16   , installed 3.0.16
        Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
        Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
        Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
        Adapter    "denon"        : 1.15.12  , installed 1.15.12
        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
        Adapter    "enigma2"      : 2.1.1    , installed 2.1.1
        Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
        Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
        Adapter    "harmony"      : 1.4.0    , installed 1.4.0
        Adapter    "heos"         : 2.2.1    , installed 2.2.1
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
        Adapter    "hue"          : 3.11.0   , installed 3.11.0
        Adapter    "ical"         : 1.15.0   , installed 1.15.0
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "javascript"   : 8.7.6    , installed 8.7.6
        Controller "js-controller": 6.0.9    , installed 6.0.9
        Adapter    "modbus"       : 6.2.3    , installed 6.2.3
        Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
        Adapter    "nut"          : 1.6.0    , installed 1.6.0
        Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
        Adapter    "openligadb"   : 1.4.9    , installed 1.4.9
        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
        Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
        Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
        Adapter    "samsung"      : 0.6.0    , installed 0.6.0
        Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
        Adapter    "sayit"        : 3.0.5    , installed 3.0.5
        Adapter    "scenes"       : 3.2.1    , installed 3.2.1
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "solax"        : 0.9.9    , installed 0.9.9
        Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
        Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
        Adapter    "synology"     : 3.1.0    , installed 3.1.0
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "telegram"     : 3.9.0    , installed 3.9.0
        Adapter    "text2command" : 3.0.3    , installed 3.0.3
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "traccar"      : 1.1.4    , installed 1.1.4
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
        Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
        Adapter    "vis-map"      : 1.0.5    , installed 1.0.5
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "yeelight-2"   : 1.4.0    , installed 1.4.0
        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
        Objects and States
        Objects:        23058
        States:         24327
        Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists... Done
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          35104      131/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          32330      1/init
        tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      110        32536      124/redis-server 0.
        tcp        0      0 192.168.178.10:12010    0.0.0.0:*               LISTEN      1001       39136      393/io.hm-rpc.1
        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       34416      137/iobroker.js-con
        tcp        0      0 0.0.0.0:8883            0.0.0.0:*               LISTEN      1001       67265983   3623001/io.sonoff.0
        tcp        0      0 192.168.178.10:2001     0.0.0.0:*               LISTEN      1001       39803      568/io.hm-rpc.0
        tcp6       0      0 :::3000                 :::*                    LISTEN      1001       44592      880/io.fullybrowser
        tcp6       0      0 :::22                   :::*                    LISTEN      0          35115      131/sshd: /usr/sbin
        tcp6       0      0 :::111                  :::*                    LISTEN      0          32332      1/init
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       47625      1034/io.simple-api.
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9871275    531497/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       34578      156/io.admin.0
        tcp6       0      0 :::6556                 :::*                    LISTEN      0          32456      1/init
        tcp6       0      0 ::1:6379                :::*                    LISTEN      110        32537      124/redis-server 0.
        tcp6       0      0 :::61991                :::*                    LISTEN      1001       39003      268/io.harmony.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       92149192   770498/io.chromecas
        udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       39004      268/io.harmony.0
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          32331      1/init
        udp6       0      0 :::111                  :::*                                0          32333      1/init
        2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 10: Fenster Konferenzraum:0.LOW_BAT: false
        2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 11: Fenster Gästezimmer oben:0.LOW_BAT: false
        2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 12: Fenster Bad oben:0.LOW_BAT: false
        2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 13: Fenster Fitness:0.LOW_BAT: false
        2024-08-18 18:00:00.686  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 14: Fenster Gäste unten:0.LOW_BAT: false
        2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 15: Postkasten:0.LOW_BAT: false
        2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 16: Heizung Küche:0.LOW_BAT: false
        2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 17: Heizung Bad unten:0.LOW_BAT: false
        2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 18: Heizung Schlafzimmer:0.LOW_BAT: false
        2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 19: Heizung Wohnzimmer:0.LOW_BAT: false
        2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 20: Heizung Gästezimmer oben:0.LOW_BAT: false
        2024-08-18 18:00:00.687  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 21: Heizung Konferenzraum:0.LOW_BAT: false
        2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 22: Heizung Bad oben:0.LOW_BAT: false
        2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 23: Heizung Büro:0.LOW_BAT: false
        2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 24: Heizung Fitnessraum:0.LOW_BAT: false
        2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 25: Heizung Gästezimmer unten:0.LOW_BAT: false
        2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 26: Presence Kueche:0.LOW_BAT: false
        2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 27: Lichtsensor:0.LOW_BAT: false
        2024-08-18 18:00:00.694  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 28: Sensor Bad unten:0.LOW_BAT: false
        2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 29: Sensor Wohnzimmer:0.LOW_BAT: false
        2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 30: Außenthermometer:0.LOW_BAT: false
        2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 31: Wetterstation:0.LOW_BAT: true
        2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Geräte Nr. 32: Heizung Bad oben 2:0.LOW_BAT: false
        2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Text: Wetterstation:0.LOW_BAT
        2024-08-18 18:00:00.695  - info: javascript.0 (843813) script.js.javascript.Homematic_Akkustaende: Anzahl Geräte: 34 # davon LOWBAT erkannt: 1
        • Dolomiti
          @Thomas-Braun
          OK. In der Langfassung kommt der Text weiter oben.
          Bei mir also ok
            Thomas Braun Most Active @Meister Mopper last edited by
            @meister-mopper sagte in iob diag - Skript:
            Trixie ist ja auch eine Ausgabe von meinem System....
            • Meister Mopper
              Meister Mopper @Thomas Braun last edited by
              @thomas-braun sagte in iob diag - Skript:
              I know, es war nur eine Ergänzung für Mitleser.
              • Feuersturm
                Feuersturm @Thomas Braun last edited by
                @thomas-braun Hi,
                bei mir wird das ausgegeben:
                ```bash
                Skript v.2024-08-18
                *** BASE SYSTEM ***
                 Static hostname: ioB-Prod-Testsystem
                         Chassis: container
                  Virtualization: lxc
                Operating System: Ubuntu 22.04.4 LTS
                          Kernel: Linux 6.5.13-1-pve
                OS is similar to: debian
                model name      : Intel(R) Celeron(R) CPU  N3150  @ 1.60GHz
                Docker          : false
                Kernel          : x86_64
                Userland        : 64 bit
                 19:30:53 up 15 days,  5:33,  1 user,  load average: 3.39, 2.72, 2.50
                CPU threads: 4
                Your Operating System 'jammy focal' is an aging Ubuntu LTS release! Please upgrade to the latest LTS release 'noble' in due time!
                Das ist das OS auf dem Testsystem
                Welcome to Ubuntu 22.04.4 LTS (GNU/Linux 6.5.13-1-pve x86_64)
                 * Documentation:  https://help.ubuntu.com
                 * Management:     https://landscape.canonical.com
                 * Support:        https://ubuntu.com/pro
                Last login: Sun Aug 18 19:27:48 2024 from 192.168.178.128
                proxmox@ioB-Prod-Testsystem:~$ ^C
                proxmox@ioB-Prod-Testsystem:~$ lsb_release -a
                No LSB modules are available.
                Distributor ID: Ubuntu
                Description:    Ubuntu 22.04.4 LTS
                Release:        22.04
                Codename:       jammy
                • Ist die Ausgabe jammy focal von iob diag richtig oder müsste es nur jammy sein?
                • Laut dieser Liste https://wiki.ubuntu.com/Releases wird jammy noch bis 2027 gepflegt. Prüft iob diag ob es nur eine aktuellere Version gibt oder auf welcher Basis wird die Aussage "is an aging Ubuntu LTS release" generiert?
                  Thomas Braun Most Active @Feuersturm last edited by Thomas Braun
                  @feuersturm sagte in iob diag - Skript:
                  Das ist die Ausgabe von
                  lsb_release -sc
                  Ja, deswegen ja auch die Aussage, dass deine Distribution nicht das aktuelle LTS-Release ist, aber noch unterhalten wird.
                  • Feuersturm
                    @thomas-braun Der Befehl
                    proxmox@ioB-Prod-Testsystem:~$ lsb_release -sc
                    jammy
                    gibt aber nur jammy aus und nicht jammy focal
                      @feuersturm
                      Muss ich mal schauen wo das herkommt. Bist bislang der erste bei dem das passiert.
                        Hab es im Code gefixt. Variablen vertauscht... 😉
                        • Feuersturm
                          @thomas-braun Das sieht besser aus 🙂
                          Your Operating System 'jammy' is an aging Ubuntu LTS release! Please upgrade to
                            @feuersturm
                            In der Summary gleichlautend?
                            Ich hab da noch einen Knoten drin, scheint mir.
                            • Feuersturm
                              @thomas-braun Sieht gut aus bei mir:
                              Skript v.2024-08-18
                              *** BASE SYSTEM ***
                                       Chassis: container
                                Virtualization: lxc
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : 64 bit
                               21:22:28 up 15 days,  7:24,  1 user,  load average: 1.95, 2.04, 2.25
                              CPU threads: 4
                              Your Operating System 'jammy' is an aging Ubuntu LTS release! Please upgrade to the latest LTS release 'noble' in due time!
                              und Summary
                                                      v.2024-08-18
                                       Chassis: container
                                Virtualization: lxc
                              Installation:           lxc
                              Kernel:                 x86_64
                              Userland:               64 bit
                              Timezone:               Europe/Berlin (CEST, +0200)
                              User-ID:                1001
                              Boot Target:            graphical.target
                              Pending OS-Updates:     0
                              Pending iob updates:    2
                              Nodejs-Installation:
                              /usr/bin/npm            10.8.1
                              /usr/bin/npx            10.8.1
                              Recommended versions are nodejs 20.16.0 and npm 10.8.1
                              MEMORY:
                              Mem:            8.0G        2.2G        4.8G        0.0K        1.0G        5.8G
                              Swap:           2.0G        1.1G        976M
                              Total:           10G        3.3G        5.8G
                              Active iob-Instances:   31
                              ioBroker Core:          js-controller           6.0.10
                                                      admin                   7.0.23
                              Objects type: jsonl
                              States  type: jsonl
                              + system.adapter.admin.0                  : admin                 : ioB-Prod-Testsystem                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.web.0                    : web                   : ioB-Prod-Testsystem                      -  enabled, port: 8082, bind: 192.168.178.105, run as: admin
                              + system.adapter.web.1                    : web                   : ioB-Prod-Testsystem                      -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
                              Objects:                14532
                              States:                 12032
                              Size of iob-Database:
                              27M     /opt/iobroker/iobroker-data/objects.jsonl
                              17M     /opt/iobroker/iobroker-data/objects.json.migrated
                              17M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                              2.3M    /opt/iobroker/iobroker-data/objects_BACKUP_153020.json
                              1.2M    /opt/iobroker/iobroker-data/objects_REMOTE_153020.json
                              19M     /opt/iobroker/iobroker-data/states.jsonl
                              6.3M    /opt/iobroker/iobroker-data/states.json.migrated
                              6.3M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                              0       /opt/iobroker/iobroker-data/states.json.broken
                                Homoran Global Moderator Administrators @Feuersturm last edited by
                                @feuersturm rein aus Neugier
                                welche Farbe hat die Zeile?
                                  @feuersturm
                                  Danke. Bei 'testing releases' wird da warum auch immer was unterschiedliches angezeigt. Und ich verstehe gerade nicht warum...
                                  • Feuersturm
                                    Feuersturm @Homoran last edited by
                                    @homoran sagte in iob diag - Skript:
                                    Bei der Langfassung und Summary ist die Information Gelb,
                                      So soll es sein. Stabile Releases wären Grün, abgekündigte wären Rot.
                                      Nashra Negalein 2 Replies Last reply Reply Quote 0
                                      • Nashra
                                        Nashra Most Active Forum Testing @Thomas Braun last edited by
                                        Moin, hier mit LXC
        v.2024-08-18_5
                                         Static hostname: ioBroker
                                          Virtualization: lxc
                                        Installation:           lxc
                                        Kernel:                 x86_64
                                        Userland:               64 bit
                                        User-ID:                1000
                                        /usr/bin/npm            10.8.1
                                        /usr/bin/npx            10.8.1
                                        MEMORY:
                                        Mem:             12G        4.1G        7.9G        122K        873M        8.7G
                                        Swap:             0B          0B          0B
                                        Total:           12G        4.1G        7.9G
                                        Active iob-Instances:   45
                                        ioBroker Core:          js-controller           6.0.9
        admin                   7.0.22
                                        Objects type: jsonl
                                        States  type: jsonl
                                        + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.1.14, run as: admin
                                        Objects:                54190
                                        States:                 50980
                                        86M     /opt/iobroker/iobroker-data/objects.jsonl
                                        88M     /opt/iobroker/iobroker-data/states.jsonl
                                        • Negalein
                                          Negalein Global Moderator @Thomas Braun last edited by
                                          hier ein LXC
        v.2024-08-18_5
                                                   Chassis: container
                                            Virtualization: lxc
                                                    Kernel: Linux 5.15.30-2-pve
                                          Installation:           lxc
                                          Kernel:                 x86_64
                                          Userland:               64 bit
                                          Timezone:               Europe/Vienna (CEST, +0200)
                                          User-ID:                1001
                                          Pending OS-Updates:     31
                                          Pending iob updates:    4
                                          /usr/bin/nodejs         v20.15.0
                                          /usr/bin/node           v20.15.0
                                          /usr/bin/npm            10.7.0
                                          /usr/bin/npx            10.7.0
                                          /usr/bin/corepack       0.28.1
                                          MEMORY:
                                          Mem:             10G        4.8G        4.4G        0.0K        865M        5.3G
                                          Swap:           3.1G        1.1G        2.0G
                                          Total:           13G        5.8G        6.4G
                                          Active iob-Instances:   60
                                          Active repo(s): Beta (latest)
                                          ioBroker Core:          js-controller           5.0.19
        admin                   7.0.24
                                          Objects type: jsonl
                                          States  type: jsonl
                                          + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                          + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          Objects:                32233
                                          States:                 31404
                                          53M     /opt/iobroker/iobroker-data/objects.jsonl
                                          29M     /opt/iobroker/iobroker-data/objects.json.migrated
                                          29M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                          0       /opt/iobroker/iobroker-data/objects.json.broken
                                          54M     /opt/iobroker/iobroker-data/states.jsonl
                                          9.4M    /opt/iobroker/iobroker-data/states.json.migrated
                                          9.4M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                          Your Operating System jammy is an aging Ubuntu LTS release! Please upgrade to the latest LTS release 'noble' in due time!
                                            Shadowhunter23 last edited by
                                            Vielleicht noch ein Hinweis, ich habe 4 zigbee Adapter und keinen USB Stick. Angezeigt wird nur bis Adapter .2
                                            Die Koordinatoren sind alle per Netzwerk eingebunden. Ob du das abfragen kann das kein USB Stick angeschlossen ist weiß ich nicht.
                                            USB-Devices by-id:
                                            HINT:
                                            tcp
                                            HINT:
                                            Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                                            tcp
                                            HINT:
                                            Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
                                            tcp
                                            738
                                            151250
