    4. Beim Update von Adaptern stürzt der ioBroker ab
    • [erledigt] 15. 05. Wartungsarbeiten am ioBroker Forum
      Homoran Global Moderator Administrators @flommaster last edited by
      @flommaster dann bitte die Langfassung von iob diag
        flommaster @Homoran last edited by flommaster
        Hier ist das komplette Ergebnis.
        Ich habe nach dem letzten Versuch das Problem, dass ich den Controller gar nicht mehr zum laufen bekomme...
        Skript v.2024-05-22
        *** BASE SYSTEM ***
           Static hostname: ioBrokerdebian
                 Icon name: computer-desktop
                   Chassis: desktop
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 5.10.0-32-amd64
              Architecture: x86-64
        model name      : Intel(R) Celeron(R) CPU J3355 @ 2.00GHz
        Docker          : false
        Virtualization  : none
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         14:18:18 up 54 min,  1 user,  load average: 2.75, 4.55, 3.06
        CPU threads: 2
        *** Time and Time Zones ***
                       Local time: Sun 2024-08-18 14:18:19 CEST
                   Universal time: Sun 2024-08-18 12:18:19 UTC
                         RTC time: Sun 2024-08-18 12:18:19
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        flo
        HOME=/home/flo
        GROUPS=flo cdrom floppy sudo audio dip video plugdev netdev iobroker
        js-controller is not running
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            3.7G        158M        3.0G        2.0M        606M        3.3G
        Swap:           3.9G         27M        3.9G
        Total:          7.7G        185M        6.9G
        Active iob-Instances:   0
                 3749 M total memory
                  158 M used memory
                  401 M active memory
                  198 M inactive memory
                 2983 M free memory
                  299 M buffer memory
                  307 M swap cache
                 3923 M total swap
                   27 M used swap
                 3896 M free swap
        top - 14:18:19 up 54 min,  1 user,  load average: 2.75, 4.55, 3.06
        Tasks: 106 total,   2 running, 104 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  3.1 us,  0.0 sy,  0.0 ni, 96.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3749.5 total,   2983.8 free,    158.6 used,    607.1 buff/cache
        MiB Swap:   3924.0 total,   3897.0 free,     27.0 used.   3348.1 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs  1.9G     0  1.9G   0% /dev
        tmpfs          tmpfs     375M  2.2M  373M   1% /run
        /dev/mmcblk0p2 ext4       53G   21G   30G  42% /
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        /dev/mmcblk0p1 vfat      511M  5.8M  506M   2% /boot/efi
        tmpfs          tmpfs     375M     0  375M   0% /run/user/1000
        [Sun Aug 18 13:23:25 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Sun Aug 18 13:23:26 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro
        Show mounted filesystems:
        TARGET                        SOURCE         FSTYPE     OPTIONS
        /                             /dev/mmcblk0p2 ext4       rw,relatime,errors=remount-ro
        |-/sys                        sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security      securityfs     securityfs rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup            cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
        | |-/sys/fs/pstore            pstore         pstore     rw,nosuid,nodev,noexec,relatime
        | |-/sys/firmware/efi/efivars efivarfs       efivarfs   rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/bpf               none           bpf        rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/tracing       tracefs        tracefs    rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/debug         debugfs        debugfs    rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/config        configfs       configfs   rw,nosuid,nodev,noexec,relatime
        | `-/sys/fs/fuse/connections  fusectl        fusectl    rw,nosuid,nodev,noexec,relatime
        |-/proc                       proc           proc       rw,nosuid,nodev,noexec,relatime
        | `-/proc/sys/fs/binfmt_misc  systemd-1      autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=11397
        |-/dev                        udev           devtmpfs   rw,nosuid,relatime,size=1901928k,nr_inodes=475482,mode=755
        | |-/dev/pts                  devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | |-/dev/shm                  tmpfs          tmpfs      rw,nosuid,nodev
        | |-/dev/mqueue               mqueue         mqueue     rw,nosuid,nodev,noexec,relatime
        | `-/dev/hugepages            hugetlbfs      hugetlbfs  rw,relatime,pagesize=2M
        |-/run                        tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=383948k,mode=755
        | |-/run/lock                 tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/rpc_pipefs           sunrpc         rpc_pipefs rw,relatime
        | `-/run/user/1000            tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=383944k,nr_inodes=95986,mode=700,uid=1000,gid=1000
        `-/boot/efi                   /dev/mmcblk0p1 vfat       rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
        /var:
        4.7G    /var/
        4.0G    /var/log/journal/37ccd33008fc48b08294fcfc7d596e40
        4.0G    /var/log
        521M    /var/cache
        Archived and active journals take up 72.0M in the file system.
        /opt/iobroker/backups:
        2.1G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        2.5G    /opt/iobroker/iobroker-data/
        1.7G    /opt/iobroker/iobroker-data/history
        512M    /opt/iobroker/iobroker-data/files
        139M    /opt/iobroker/iobroker-data/backup-objects
        88M     /opt/iobroker/iobroker-data/files/echarts.admin
        41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
        23M     /opt/iobroker/iobroker-data/objects.json.migrated
        23M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
        23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D307ZMZV-if00-port0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.20.4
        /usr/bin/node           v18.20.4
        /usr/bin/npm            10.7.0
        /usr/bin/npx            10.7.0
        /usr/bin/corepack       0.28.0
        nodejs:
          Installed: 18.20.4-1nodesource1
          Candidate: 18.20.4-1nodesource1
          Version table:
         *** 18.20.4-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             18.20.3-1nodesource1 500
             18.20.2-1nodesource1 500
             18.20.1-1nodesource1 500
             18.20.0-1nodesource1 500
             18.19.1-1nodesource1 500
             18.19.0-1nodesource1 500
             18.18.2-1nodesource1 500
             18.18.1-1nodesource1 500
             18.18.0-1nodesource1 500
             18.17.1-1nodesource1 500
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main amd64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        node:internal/modules/cjs/loader:1143
          throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
            at Module._load (node:internal/modules/cjs/loader:981:27)
            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
            at node:internal/main/run_main_module:28:49 {
          code: 'MODULE_NOT_FOUND',
          requireStack: []
        Node.js v18.20.4
        Core adapters versions
          throw err;
          requireStack: []
        Node.js v18.20.4
        js-controller:
          throw err;
          requireStack: []
        Node.js v18.20.4
        admin:
          throw err;
          requireStack: []
        Node.js v18.20.4
        javascript:
        nodejs modules from github:     1
        |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
        Adapter State
        ioBroker-Repositories
          throw err;
          requireStack: []
        Node.js v18.20.4
        Installed ioBroker-Instances
          throw err;
          requireStack: []
        Node.js v18.20.4
        Objects and States
        Objects:        0
        States:         0
        Hit:1 http://ftp.debian.org/debian bullseye-backports InRelease
        Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:3 http://deb.debian.org/debian bullseye InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          16130      703/exim4
        tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          16363      786/smbd
        tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          16364      786/smbd
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        16070      425/redis-server 12
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          10125      1/init
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14876      461/sshd: /usr/sbin
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          16131      703/exim4
        tcp6       0      0 :::445                  :::*                    LISTEN      0          16361      786/smbd
        tcp6       0      0 ::1:6379                :::*                    LISTEN      109        16071      425/redis-server 12
        tcp6       0      0 :::139                  :::*                    LISTEN      0          16362      786/smbd
        tcp6       0      0 :::111                  :::*                    LISTEN      0          10129      1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14887      461/sshd: /usr/sbin
        udp        0      0 0.0.0.0:39663           0.0.0.0:*                           108        16019      418/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16017      418/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16032      407/dhclient
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          10126      1/init
        udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          16280      424/nmbd
        udp        0      0 192.168.178.66:137      0.0.0.0:*                           0          16279      424/nmbd
        udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          16117      424/nmbd
        udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          16282      424/nmbd
        udp        0      0 192.168.178.66:138      0.0.0.0:*                           0          16281      424/nmbd
        udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          16118      424/nmbd
        udp6       0      0 :::5353                 :::*                                108        16018      418/avahi-daemon: r
        udp6       0      0 :::36880                :::*                                108        16020      418/avahi-daemon: r
        udp6       0      0 :::111                  :::*                                0          10132      1/init
        2024-08-18 13:35:45.339  - info: sql.0 (879) Terminated (NO_ERROR): Without reason
        2024-08-18 13:35:45.802  - error: sql.0 (879) Objects database error: read ECONNRESET
        2024-08-18 13:35:46.445  - info: modbus.1 (1048) terminating with timeout
        2024-08-18 13:35:45.384  - info: admin.0 (755) terminating http server on port 8081
        2024-08-18 13:35:46.272  - info: admin.0 (755) terminating
        2024-08-18 13:35:46.366  - info: admin.0 (755) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-08-18 13:35:43.410  - info: eusec.0 (1746) Disconnect from station T8410P202112109E
        2024-08-18 13:35:43.423  - info: eusec.0 (1746) Disconnect from station T84A1P102312214F
        2024-08-18 13:35:43.424  - info: eusec.0 (1746) Disconnect from station T84A1P1023122467
        2024-08-18 13:35:43.464  - info: eusec.0 (1746) terminating
        2024-08-18 13:35:43.466  - info: eusec.0 (1746) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-08-18 13:35:43.492  - info: eusec.0 (1746) Disconnected from station T8410P202112109E
        2024-08-18 13:35:44.969  - info: eusec.0 (1746) Disconnected from station T84A1P102312214F
        2024-08-18 13:35:46.206  - info: eusec.0 (1746) Disconnected from station T84A1P1023122467
        2024-08-18 13:35:46.776  - info: eusec.0 (1746) terminating
        2024-08-18 13:35:46.997  - info: admin.0 (755) terminating
        2024-08-18 13:35:47.926  - info: meross.0 (978) terminating
        2024-08-18 13:35:47.980  - info: meross.0 (978) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2024-08-18 13:35:48.000  - info: admin.0 (755) terminating with timeout
        2024-08-18 13:35:50.865  - info: meross.0 (978) terminating
        2024-08-18 13:35:50.896  - error: eusec.0 (1746) go2rtc error: exit with signal: terminated
        2024-08-18 13:35:50.905  - info: eusec.0 (1746) go2rtc terminated with exitcode 0
        2024-08-18 13:35:50.907  - info: eusec.0 (1746) terminating with timeout
        2024-08-18 13:35:51.525  - error: history.0 (795) Cannot find view "system" for search "instance" : Connection is closed.
          @flommaster sagte in Beim Update von Adaptern stürzt der ioBroker ab:
          oh ja, der rödelt gewaltig!
          ok, läuft ja im Moment nicht.
          sollte beizeiten mal auf v20 hochgezogen werden.
          mal sehn was @Thomas-Braun meint.
          ich würde versuchen den Controller drüberzuinstallieren
            Thomas Braun Most Active @flommaster last edited by
            @flommaster
            Läuft das System von einer SD-Karte? Hat der NUC keine SSD/Festplatte?
            sudo usermod -aG adm flo
            exit
            iob nodejs-update
            cd /opt/iobroker
            npm install iobroker.js-controller@6.0.9
            Dann mal einen kompletten Neustart von der Kiste.
            Und wenn das läuft installierst du da Debian 12 'Bookworm', dein Debian 11 hat das Lebensende erreicht.
              flommaster @Thomas Braun last edited by
              @thomas-braun @Homoran
              Hallo Thomas, hallo Homoran,
              vielen Dank für die schnelle Unterstützung!
              Doch der NUC hat ne SSD. Eine SD-Karte nutze ich bei dem Gerät nicht.
              Ok, ich habe die Kiste neu gestartet und die Befehle ausgeführt.
              Am Schluss erhalte ich folgende Fehlermeldung:
              npm warn cleanup Failed to remove some directories [
              npm warn cleanup   [
              npm warn cleanup     '/opt/iobroker/node_modules/iobroker.javascript/node_modules',
              npm warn cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin'] {
              npm warn cleanup       errno: -39,
              npm warn cleanup       code: 'ENOTEMPTY',
              npm warn cleanup       syscall: 'rmdir',
              npm warn cleanup       path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin'
              npm warn cleanup     }
              npm warn cleanup   ],
              npm warn cleanup   [
              npm warn cleanup     '/opt/iobroker/node_modules/iobroker.javascript',
              npm warn cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readable-stream'] {
              npm warn cleanup       path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readable-stream'
              npm warn cleanup     }
              npm warn cleanup   ],
              npm warn cleanup   [
              npm warn cleanup     }
              npm warn cleanup   ]
              npm warn cleanup ]
              npm error code 127
              npm error path /opt/iobroker/node_modules/zlib
              npm error command failed
              npm error command sh -c node-waf clean || true; node-waf configure build
              npm error sh: 1: node-waf: not found
              npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T12_33_37_590Z-debug-0.log
              Habt Ihr eine Idee, wie ich das System noch retten kann?
              Vielen Dank und viele Grüße
              Florian
                iob stop
                iob fix
                iob start
                  @flommaster
                  Ich wunder mich nur, weil typischerweise das Gerät
                  /dev/mmcblk0p2
                  eine SD-Karte beschreibt.
                  node-waf liefert:
                  https://forum.iobroker.net/topic/74670/adapter-lassen-sich-nicht-mehr-aktualisieren
                  Ro75 1 Reply Last reply Reply Quote 0
                  • Ro75
                    Ro75 @Thomas Braun last edited by
                    @thomas-braun laut den Daten ist keine SSD gemountet. Das Teil läuft von einer SD-Karte. Meine Vermutung. Das Teil hat einen SD-Karten-Slot. Karte rein und dann vielleicht Klonen wollen auf SSD und vergessen rauszunehmen. Oder Geklont und ohne SD-KArte läuft das Teil nicht. Oder Oder Oder...
                    Ro75.
                      Thomas Braun Most Active @Ro75 last edited by
                      @ro75 sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                      Ja, würde ich auch so sehen.
                        Ich weiß beim besten Willen nicht, wie das Teil auf einer SD-Karten laufen soll.
                        Ich habe gerade noch mal alle Anschlüsse geprüft. In meinem NUC steckt keine SD-Karte...
                        Es könnte ggf. dran liegen, dass ich den NUC vor ein paar Jahren von einem Raspberry PI mit SD-Karte umgezogen habe...
                        Mit den Updates bin ich jetzt durch.
                        Das System läuft jetzt auf Debian Bookworm
                        /usr/bin/nodejs
                        v20.16.0
                        /usr/bin/node
                        v20.16.0
                        /usr/bin/npm
                        10.8.1
                        /usr/bin/npx
                        10.8.1
                        nodejs:
                          Installiert:           20.16.0-1nodesource1
                          Installationskandidat: 20.16.0-1nodesource1
                          Versionstabelle:
                         *** 20.16.0-1nodesource1 1001
                                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                             20.15.1-1nodesource1 1001
                             20.15.0-1nodesource1 1001
                             20.14.0-1nodesource1 1001
                             20.13.1-1nodesource1 1001
                             20.13.0-1nodesource1 1001
                             20.12.2-1nodesource1 1001
                             20.12.1-1nodesource1 1001
                             20.12.0-1nodesource1 1001
                             20.11.1-1nodesource1 1001
                             20.11.0-1nodesource1 1001
                             20.10.0-1nodesource1 1001
                             20.9.0-1nodesource1 1001
                             20.8.1-1nodesource1 1001
                             20.8.0-1nodesource1 1001
                             20.7.0-1nodesource1 1001
                             20.6.1-1nodesource1 1001
                             20.6.0-1nodesource1 1001
                             20.5.1-1nodesource1 1001
                             20.5.0-1nodesource1 1001
                             20.4.0-1nodesource1 1001
                             20.3.1-1nodesource1 1001
                             20.3.0-1nodesource1 1001
                             20.2.0-1nodesource1 1001
                             20.1.0-1nodesource1 1001
                             20.0.0-1nodesource1 1001
                             18.19.0+dfsg-6~deb12u2 500
                                500 http://deb.debian.org/debian bookworm/main amd64 Packages
                             18.19.0+dfsg-6~deb12u1 500
                                500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
                        Den ioBroker bekomme ich aber leider nicht zum laufen.
                        Ich habe mehrfach den Fixer (iob fix) als auch die Installation ausgeführt.
                        Mir ist gerade aufgefallen, dass im Verzeichnis die Datei "/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js" fehlt.
                        /opt/iobroker/node_modules/iobroker.js-controller$ dir
                        build  LICENSE  node_modules
                          Vermutlich geclont. Da clonst du aber auch die falschen Devices mit.
                            @flommaster
                            iob stop
                            cd /opt/iobroker
                            iob start
                              Hallo Thomas,
                              nach zahlreichen Warnmeldungen, kommt dann eine Error Meldung (npm error code 127) die den Vorgang abbricht.
                              npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.web-speedy.git
                              npm warn skipping integrity check for git dependency ssh://git@github.com/peterbaumert/ioBroker.vofo-speedtest.git
                              npm warn skipping integrity check for git dependency ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git
                              npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2-widgets-material.git
                              npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2.git
                              npm warn skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git
                              npm warn skipping integrity check for git dependency ssh://git@github.com/aendue/ioBroker.reolink.git
                              npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.ical.git
                              npm warn skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git
                              npm warn skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git
                              npm warn skipping integrity check for git dependency ssh://git@github.com/WLAN-Kabel/ioBroker.calendar.git
                              npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                              npm warn deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                              npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                              npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
                              npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
                              npm warn deprecated uid-number@0.0.6: This package is no longer supported.
                              npm warn deprecated npmlog@5.0.1: This package is no longer supported.
                              npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                              npm warn deprecated npmlog@6.0.2: This package is no longer supported.
                              npm warn deprecated har-validator@5.1.5: this library is no longer supported
                              npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                              npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
                              npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
                              npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
                              npm warn deprecated q@1.1.2: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
                              npm warn deprecated
                              npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
                              npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                              npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                              npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
                              npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
                              npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                              npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
                              npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                              npm warn deprecated google-p12-pem@3.1.4: Package is no longer maintained
                              npm warn deprecated gauge@3.0.2: This package is no longer supported.
                              npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                              npm warn deprecated gauge@4.0.4: This package is no longer supported.
                              npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                              npm warn deprecated later@1.2.0: Please upgrade to the maintained and new drop-in replacement @breejs/later at https://github.com/breejs/later 🚀 Thanks and happy hacking! 🚀  @niftylettuce
                              npm error code 127
                              npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T19_24_28_844Z-debug-0.log
                              Kann ich da noch was retten?
                              mikeal created this issue in request/request
                              open Request’s Past, Present and Future #3142
                              Qix- created this issue in visionmedia/debug
                              closed ReDos Vulnerability Regression Visibility Notice #797
                                Das ist genau das Ding aus dem anderen Thread. Welcher Adapter war das da? mihome-vaccuum?
                                Versuch den mal zu aktualisieren.
                                iob update
                                iob upgrade BÖSER_ADAPTER
                                  Das geht gar nicht mehr.
                                  iob upgrade mihome-vaccuum
                                  node:internal/modules/cjs/loader:1148
                                    throw err;
                                      at Module._resolveFilename (node:internal/modules/cjs/loader:1145:15)
                                      at Module._load (node:internal/modules/cjs/loader:986:27)
                                      at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
                                    requireStack: []
                                  Node.js v20.16.0
                                  Kann ich den Adapter auch komplett löschen. Den Staubsauger nutze ich nur noch manuell...
                                    @flommaster
                                    cd /opt/iobroker && npm ls
                                    spuckt aus?
                                    mcm1957 F 2 Replies Last reply Reply Quote 0
                                    • mcm1957
                                      mcm1957 @Thomas Braun last edited by
                                      Wo stammen eigentlich die ganzen GITHUB dependencies her, z.B.
                                      Den Adapter gibts (dort) gar nicht ...
                                        @thomas-braun sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                                        zu viele Fehler...
                                        Teil 1
                                        iobroker.inst@2.0.3 /opt/iobroker
                                        ├── @alcalzone/esbuild-register@2.5.1-1 extraneous
                                        ├── @alcalzone/jsonl-db@3.1.1 extraneous
                                        ├── @alcalzone/pak@0.8.1 extraneous
                                        ├── @alcalzone/proper-lockfile@4.1.3-0 extraneous
                                        ├── @aws-sdk/util-utf8-browser@3.259.0 extraneous
                                        ├── @azure/abort-controller@1.1.0 extraneous
                                        ├── @azure/core-auth@1.7.2 extraneous
                                        ├── @azure/core-client@ extraneous
                                        ├── @azure/core-http-compat@ extraneous
                                        ├── @azure/core-lro@ extraneous
                                        ├── @azure/core-paging@1.6.2 extraneous
                                        ├── @azure/core-rest-pipeline@ extraneous
                                        ├── @azure/core-tracing@1.1.2 extraneous
                                        ├── @azure/core-util@ extraneous
                                        ├── @azure/identity@ extraneous
                                        ├── @azure/keyvault-keys@ extraneous
                                        ├── @azure/logger@1.1.4 extraneous
                                        ├── @azure/msal-browser@ extraneous
                                        ├── @azure/msal-common@ extraneous
                                        ├── @azure/msal-node@1.18.4 extraneous
                                        ├── @babel/code-frame@7.24.7 extraneous
                                        ├── @babel/helper-validator-identifier@7.24.7 extraneous
                                        ├── @babel/highlight@7.24.7 extraneous
                                        ├── @babel/runtime@ extraneous
                                        ├── @colors/colors@1.5.0 extraneous
                                        ├── @dabh/diagnostics@2.0.3 extraneous
                                        ├── @datalust/winston-seq@1.0.2 extraneous
                                        ├── @gar/promisify@1.1.3 extraneous
                                        ├── @googleapis/calendar@9.7.7 extraneous
                                        ├── @googleapis/drive@5.1.0 extraneous
                                        ├── @googleapis/oauth2@1.0.7 extraneous
                                        ├── @httptoolkit/websocket-stream@6.0.1 extraneous
                                        ├── @iobroker/db-base@ extraneous
                                        ├── @iobroker/db-objects-file@ extraneous
                                        ├── @iobroker/db-objects-jsonl@ extraneous
                                        ├── @iobroker/db-objects-redis@ extraneous
                                        ├── @iobroker/db-states-file@ extraneous
                                        ├── @iobroker/db-states-jsonl@ extraneous
                                        ├── @iobroker/db-states-redis@ extraneous
                                        ├── @iobroker/js-controller-adapter@ extraneous
                                        ├── @iobroker/js-controller-cli@ extraneous
                                        ├── @iobroker/js-controller-common-db@ extraneous
                                        ├── @iobroker/js-controller-common@ extraneous
                                        ├── @iobroker/plugin-base@1.2.1 extraneous
                                        ├── @iobroker/plugin-sentry@1.2.1 extraneous
                                        ├── @iobroker/socket-classes@1.5.6 extraneous
                                        ├── @iobroker/webserver@1.0.3 extraneous
                                        ├── @isaacs/cliui@8.0.2 extraneous
                                        ├── @js-joda/core@ extraneous
                                        ├── @mapbox/node-pre-gyp@1.0.11 extraneous
                                        ├── @microsoft/microsoft-graph-types@2.40.0 extraneous
                                        ├── @nodelib/fs.scandir@2.1.5 extraneous
                                        ├── @nodelib/fs.stat@2.0.5 extraneous
                                        ├── @nodelib/fs.walk@1.2.8 extraneous
                                        ├── @npmcli/fs@2.1.2 extraneous
                                        ├── @npmcli/move-file@2.0.1 extraneous
                                        ├── @pkgjs/parseargs@0.11.0 extraneous
                                        ├── @protobufjs/aspromise@1.1.2 extraneous
                                        ├── @protobufjs/base64@1.1.2 extraneous
                                        ├── @protobufjs/codegen@2.0.4 extraneous
                                        ├── @protobufjs/eventemitter@1.1.0 extraneous
                                        ├── @protobufjs/fetch@1.1.0 extraneous
                                        ├── @protobufjs/float@1.0.2 extraneous
                                        ├── @protobufjs/inquire@1.1.0 extraneous
                                        ├── @protobufjs/path@1.1.2 extraneous
                                        ├── @protobufjs/pool@1.1.0 extraneous
                                        ├── @protobufjs/utf8@1.1.0 extraneous
                                        ├── @quasar/extras@ extraneous
                                        ├── @samverschueren/stream-to-observable@0.3.1 extraneous
                                        ├── @sentry-internal/tracing@ extraneous
                                        ├── @sentry/core@5.30.0 extraneous
                                        ├── @sentry/hub@5.30.0 extraneous
                                        ├── @sentry/minimal@5.30.0 extraneous
                                        ├── @sentry/node@ extraneous
                                        ├── @sentry/tracing@ extraneous
                                        ├── @sentry/types@ extraneous
                                        ├── @sentry/utils@ extraneous
                                        ├── @sindresorhus/is@4.6.0 extraneous
                                        ├── @socket.io/component-emitter@3.1.2 extraneous
                                        ├── @szmarczak/http-timer@4.0.6 extraneous
                                        ├── @tediousjs/connection-string@0.5.0 extraneous
                                        ├── @tootallnate/once@2.0.0 extraneous
                                        ├── @types/bl@5.1.0 extraneous
                                        ├── @types/cacheable-request@6.0.3 extraneous
                                        ├── @types/caseless@0.12.5 extraneous
                                        ├── @types/cookie@0.4.1 extraneous
                                        ├── @types/cors@2.8.17 extraneous
                                        ├── @types/geojson@7946.0.14 extraneous
                                        ├── @types/http-cache-semantics@4.0.4 extraneous
                                        ├── @types/keyv@3.1.4 extraneous
                                        ├── @types/leaflet@1.9.12 extraneous
                                        ├── @types/minimist@1.2.5 extraneous
                                        ├── @types/node-cron@2.0.8 extraneous
                                        ├── @types/node@ extraneous
                                        ├── @types/normalize-package-data@2.4.4 extraneous
                                        ├── @types/parse-json@4.0.2 extraneous
                                        ├── @types/readable-stream@4.0.15 extraneous
                                        ├── @types/request@2.48.12 extraneous
                                        ├── @types/responselike@1.0.3 extraneous
                                        ├── @types/tough-cookie@4.0.5 extraneous
                                        ├── @types/triple-beam@1.3.5 extraneous
                                        ├── @types/tz-offset@0.0.3 extraneous
                                        ├── @types/ws@8.5.12 extraneous
                                        ├── abab@2.0.6 extraneous
                                        ├── abbrev@1.1.1 extraneous
                                        ├── abort-controller@3.0.0 extraneous
                                        ├── agentkeepalive@4.5.0 extraneous
                                        ├── aggregate-error@3.1.0 extraneous
                                        ├── ajv@ extraneous
                                        ├── ansi-align@3.0.1 extraneous
                                        ├── ansi-colors@4.1.3 extraneous
                                        ├── ansi-escapes@4.3.2 extraneous
                                        ├── ansi-regex@5.0.1 extraneous
                                        ├── ansi-styles@4.3.0 extraneous
                                        ├── any-observable@0.5.1 extraneous
                                        ├── anymatch@3.1.3 extraneous
                                        ├── aproba@2.0.0 extraneous
                                        ├── archiver-utils@5.0.2 extraneous
                                        ├── archiver@7.0.1 extraneous
                                        ├── are-we-there-yet@2.0.0 extraneous
                                        ├── arg@4.1.0 extraneous
                                        ├── argparse@1.0.10 extraneous
                                        ├── array-buffer-byte-length@1.0.1 extraneous
                                        ├── array-flatten@1.1.1 extraneous
                                        ├── array-union@2.1.0 extraneous
                                        ├── arraybuffer.prototype.slice@1.0.3 extraneous
                                        ├── arrify@2.0.1 extraneous
                                        ├── asn1@0.2.6 extraneous
                                        ├── async-exit-hook@2.0.1 extraneous
                                        ├── authenticate-pam@1.0.5 extraneous
                                        ├── available-typed-arrays@1.0.7 extraneous
                                        ├── aws-crt@ extraneous
                                        ├── b4a@1.6.6 extraneous
                                        ├── balanced-match@1.0.2 extraneous
                                        ├── bare-events@2.4.2 extraneous
                                        ├── base-64@1.0.0 extraneous
                                        ├── base64-js@1.5.1 extraneous
                                        ├── bcrypt-pbkdf@1.0.2 extraneous
                                        ├── binary-extensions@2.3.0 extraneous
                                        ├── bindings@1.5.0 extraneous
                                        ├── bl@6.0.14 extraneous
                                        ├── bluebird@3.7.2 extraneous
                                        ├── body-parser@1.20.2 extraneous
                                        ├── bottleneck@2.19.5 extraneous
                                        ├── boxen@5.1.2 extraneous
                                        ├── brace-expansion@2.0.1 extraneous
                                        ├── braces@3.0.3 extraneous
                                        ├── buffer-crc32@1.0.0 extraneous
                                        ├── buffer-equal-constant-time@1.0.1 extraneous
                                        ├── buffer-shims@1.0.0 extraneous
                                        ├── buffer@6.0.3 extraneous
                                        ├── buildcheck@0.0.6 extraneous
                                        ├── builtins@1.0.3 extraneous
                                        ├── busboy@1.6.0 extraneous
                                        ├── byte-length@1.0.2 extraneous
                                        ├── bytes@3.1.2 extraneous
                                        ├── cacache@16.1.3 extraneous
                                        ├── cacheable-lookup@5.0.4 extraneous
                                        ├── cacheable-request@7.0.4 extraneous
                                        ├── callsites@3.1.0 extraneous
                                        ├── camelcase-keys@6.2.2 extraneous
                                        ├── camelcase@5.3.1 extraneous
                                        ├── capitalize@2.0.4 extraneous
                                        ├── chalk@4.1.2 extraneous
                                        ├── chardet@0.7.0 extraneous
                                        ├── charenc@0.0.2 extraneous
                                        ├── chokidar@3.6.0 extraneous
                                        ├── chownr@2.0.0 extraneous
                                        ├── ci-info@3.9.0 extraneous
                                        ├── clean-stack@2.2.0 extraneous
                                        ├── cli-boxes@2.2.1 extraneous
                                        ├── cli-cursor@3.1.0 extraneous
                                        ├── cli-truncate@0.2.1 extraneous
                                        ├── cli-width@3.0.0 extraneous
                                        ├── clone-response@1.0.3 extraneous
                                        ├── cloneextend@0.0.3 extraneous
                                        ├── cluster-key-slot@1.1.2 extraneous
                                        ├── coap-packet@1.1.1 extraneous
                                        ├── coffeescript@1.12.7 extraneous
                                        ├── color-convert@2.0.1 extraneous
                                        ├── color-name@1.1.4 extraneous
                                        ├── color-string@1.9.1 extraneous
                                        ├── color-support@1.1.3 extraneous
                                        ├── color@3.2.1 extraneous
                                        ├── colors@1.4.0
                                        ├── colorspace@1.1.4 extraneous
                                        ├── commander@9.5.0 extraneous
                                        ├── commist@3.2.0 extraneous
                                        ├── compress-commons@6.0.2 extraneous
                                        ├── compress-json@2.1.2 extraneous
                                        ├── compressible@2.0.18 extraneous
                                        ├── compression@1.7.4 extraneous
                                        ├── concat-map@0.0.1 extraneous
                                        ├── configstore@5.0.1 extraneous
                                        ├── connect-flash@0.1.1 extraneous
                                        ├── connect@3.7.0 extraneous
                                        ├── console-control-strings@1.1.0 extraneous
                                        ├── content-disposition@0.5.4 extraneous
                                        ├── content-type@1.0.5 extraneous
                                        ├── core-js@ extraneous
                                        ├── cors@2.8.5 extraneous
                                        ├── cosmiconfig@7.1.0 extraneous
                                        ├── cpu-features@ extraneous
                                        ├── crc-32@1.2.2 extraneous
                                        ├── crc@ extraneous
                                        ├── crc32-stream@6.0.0 extraneous
                                        ├── cross-fetch@4.0.0 extraneous
                                        ├── crypt@0.0.2 extraneous
                                        ├── crypto-js@ extraneous
                                        ├── crypto-random-string@2.0.0 extraneous
                                        ├── cssstyle@ extraneous
                                        ├── cycle@1.0.3 extraneous
                                        ├── dashdash@1.14.1 extraneous
                                        ├── data-urls@4.0.0 extraneous
                                        ├── data-view-buffer@1.0.1 extraneous
                                        ├── data-view-byte-length@1.0.1 extraneous
                                        ├── data-view-byte-offset@1.0.0 extraneous
                                        ├── date-and-time@ extraneous
                                        ├── date-fns@1.30.1 extraneous
                                        ├── dateformat@4.6.3 extraneous
                                        ├── dayjs@ extraneous
                                        ├── decache@4.6.2 extraneous
                                        ├── decamelize-keys@1.1.1 extraneous
                                        ├── decimal.js@10.4.3 extraneous
                                        ├── decompress-response@6.0.0 extraneous
                                        ├── deep-clone@3.0.3 extraneous
                                        ├── deep-extend@0.6.0 extraneous
                                        ├── deep-is@0.1.4 extraneous
                                        ├── defer-to-connect@2.0.1 extraneous
                                        ├── define-lazy-prop@2.0.0 extraneous
                                        ├── del@6.1.1 extraneous
                                        ├── delegates@1.0.0 extraneous
                                        ├── denque@1.5.1 extraneous
                                        ├── destroy@1.2.0 extraneous
                                        ├── detect-libc@2.0.3 extraneous
                                        ├── diacritics@1.3.0 extraneous
                                        ├── digest-header@1.1.0 extraneous
                                        ├── dir-glob@3.0.1 extraneous
                                        ├── diskusage@1.2.0 extraneous
                                        ├── domexception@4.0.0 extraneous
                                        ├── dot-prop@6.0.1 extraneous
                                        ├── draftlog@1.0.13 extraneous
                                        ├── dropbox-v2-api@ extraneous
                                        ├── duplexer@0.1.2 extraneous
                                        ├── duplexer3@0.1.5 extraneous
                                        ├── duplexify@3.7.1 extraneous
                                        ├── eastasianwidth@0.2.0 extraneous
                                        ├── ecc-jsbn@0.1.2 extraneous
                                        ├── ecdsa-sig-formatter@1.0.11 extraneous
                                        ├── echarts@ extraneous
                                        ├── ee-first@1.1.1 extraneous
                                        ├── elegant-spinner@1.0.1 extraneous
                                        ├── emoji-regex@9.2.2 extraneous
                                        ├── enabled@2.0.0 extraneous
                                        ├── encodeurl@1.0.2 extraneous
                                        ├── encoding@0.1.13 extraneous
                                        ├── end-of-stream@1.4.4 extraneous
                                        ├── entities@4.5.0 extraneous
                                        ├── err-code@2.0.3 extraneous
                                        ├── es-abstract@ extraneous
                                        ├── es-aggregate-error@1.0.13 extraneous
                                        ├── es-object-atoms@1.0.0 extraneous
                                        ├── es-set-tostringtag@2.0.3 extraneous
                                        ├── es-to-primitive@1.2.1 extraneous
                                        ├── es6-promise@4.2.8 extraneous
                                        ├── es6-promisify@5.0.0 extraneous
                                        ├── esbuild@0.11.23 extraneous
                                        ├── escalade@3.1.2 extraneous
                                        ├── escape-goat@3.0.0 extraneous
                                        ├── escape-html@1.0.3 extraneous
                                        ├── escape-string-regexp@4.0.0 extraneous
                                        ├── escodegen@1.14.3 extraneous
                                        ├── esprima@1.2.2 extraneous
                                        ├── estraverse@4.3.0 extraneous
                                        ├── esutils@2.0.3 extraneous
                                        ├── etag@1.8.1 extraneous
                                        ├── event-stream@4.0.1 extraneous
                                        ├── event-target-shim@5.0.1 extraneous
                                        ├── eventemitter2@6.4.9 extraneous
                                        ├── events@3.3.0 extraneous
                                        ├── execa@5.1.1 extraneous
                                        ├── expand-template@2.0.3 extraneous
                                        ├── express-fileupload@1.5.1 extraneous
                                        ├── express@4.19.2 extraneous
                                        ├── external-editor@3.1.0 extraneous
                                        ├── fast-deep-equal@3.1.3 extraneous
                                        ├── fast-fifo@1.3.2 extraneous
                                        ├── fast-glob@ extraneous
                                        ├── fast-json-stable-stringify@2.1.0 extraneous
                                        ├── fast-levenshtein@2.0.6 extraneous
                                        ├── fast-text-encoding@1.0.6 extraneous
                                        ├── fast-unique-numbers@ extraneous
                                        ├── fast-uri@3.0.1 extraneous
                                        ├── fast-xml-parser@ extraneous
                                        ├── fastq@1.17.1 extraneous
                                        ├── fastseries@2.0.0 extraneous
                                        ├── fecha@4.2.3 extraneous
                                        ├── figures@3.2.0 extraneous
                                        ├── file-stream-rotator@0.6.1 extraneous
                                        ├── file-type@10.11.0 extraneous
                                        ├── file-uri-to-path@1.0.0 extraneous
                                        ├── fill-range@7.1.1 extraneous
                                        ├── finalhandler@1.2.0 extraneous
                                        ├── find-up@5.0.0 extraneous
                                        ├── fn.name@1.1.0 extraneous
                                        ├── for-each@0.3.3 extraneous
                                        ├── foreground-child@3.3.0 extraneous
                                        ├── form-data-encoder@2.1.4 extraneous
                                        ├── form-data@4.0.0 extraneous
                                        ├── forwarded@0.2.0 extraneous
                                        ├── fresh@0.5.2 extraneous
                                        ├── from@0.1.7 extraneous
                                        ├── fs-constants@1.0.0 extraneous
                                        ├── fs-extra@7.0.1
                                        ├── fs-minipass@2.1.0 extraneous
                                        ├── fs.realpath@1.0.0 extraneous
                                        ├── fsevents@ extraneous
                                        ├── ftp@0.3.10 extraneous
                                        ├── function.prototype.name@1.1.6 extraneous
                                        ├── functions-have-names@1.2.3 extraneous
                                        ├── futoin-hkdf@1.4.3 extraneous
                                        ├── gauge@3.0.2 extraneous
                                        ├── gaxios@5.1.3 extraneous
                                        ├── gcp-metadata@5.3.0 extraneous
                                        ├── generate-function@2.3.1 extraneous
                                        ├── get-ssl-certificate@2.3.3 extraneous
                                        ├── get-stream@5.2.0 extraneous
                                        ├── get-symbol-description@1.0.2 extraneous
                                        ├── getpass@0.1.7 extraneous
                                        ├── github-from-package@0.0.0 extraneous
                                        ├── github-url-from-git@1.5.0 extraneous
                                        ├── glob-parent@5.1.2 extraneous
                                        ├── glob@10.4.5 extraneous
                                        ├── global-dirs@2.1.0 extraneous
                                        ├── globalthis@1.0.4 extraneous
                                        ├── globby@11.1.0 extraneous
                                        ├── glossy@0.1.7 extraneous
                                        ├── google-auth-library@ extraneous
                                        ├── google-p12-pem@4.0.1 extraneous
                                        ├── googleapis-common@6.0.4 extraneous
                                        ├── googleapis@ extraneous
                                        ├── gtoken@6.1.2 extraneous
                                        ├── hard-rejection@2.1.0 extraneous
                                        ├── has-ansi@2.0.0 extraneous
                                        ├── has-bigints@1.0.2 extraneous
                                        ├── has-flag@4.0.0 extraneous
                                        ├── has-tostringtag@1.0.2 extraneous
                                        ├── has-unicode@2.0.1 extraneous
                                        ├── has-yarn@2.1.0 extraneous
                                        ├── he@1.2.0 extraneous
                                        ├── help-me@5.0.0 extraneous
                                        ├── homebridge-plugin-wrapper@ extraneous
                                        ├── hosted-git-info@3.0.8 extraneous
                                        ├── hot-patcher@1.0.0 extraneous
                                        ├── html-encoding-sniffer@3.0.0 extraneous
                                        ├── http-cache-semantics@4.1.1 extraneous
                                        ├── http-errors@2.0.0 extraneous
                                        ├── http-proxy-agent@5.0.0 extraneous
                                        ├── http2-wrapper@1.0.3 extraneous
                                        ├── https@1.0.0 extraneous
                                        ├── humanize-ms@1.2.1 extraneous
                                        ├── ical.js@ extraneous
                                        ├── iconv-lite@0.4.24 extraneous
                                        ├── ieee754@1.2.1 extraneous
                                        ├── ignore-walk@3.0.4 extraneous
                                        ├── ignore@5.3.2 extraneous
                                        ├── image-type@4.1.0 extraneous
                                        ├── immediate@3.0.6 extraneous
                                        ├── import-fresh@3.3.0 extraneous
                                        ├── import-lazy@2.1.0 extraneous
                                        ├── import-local@3.2.0 extraneous
                                        ├── imurmurhash@0.1.4 extraneous
                                        ├── indent-string@3.2.0 extraneous
                                        ├── infer-owner@1.0.4 extraneous
                                        ├── inflight@1.0.6 extraneous
                                        ├── ini@1.3.7 extraneous
                                        ├── inquirer-autosubmit-prompt@0.2.0 extraneous
                                        ├── inquirer@7.3.3 extraneous
                                        ├── int64-buffer@1.0.1 extraneous
                                        ├── internal-slot@1.0.7 extraneous
                                        ├── iobroker-adapter-helpers@0.0.8 extraneous
                                        ├── iobroker.admin@ invalid: "^6.10.1" from the root project
                                        ├── iobroker.backitup@ invalid: "2.6.23" from the root project
                                        ├── iobroker.bmw@2.5.7
                                        ├── iobroker.calendar@ invalid: "github:WLAN-Kabel/ioBroker.calendar#c36410258c21a4a92eba80fb0ec084fc254c9259" from the root project
                                        ├── iobroker.cloud@4.4.1
                                        ├── iobroker.coronavirus-statistics@0.8.7
                                        ├── iobroker.daswetter@3.1.10
                                        ├── iobroker.discovery@ invalid: "3.1.0" from the root project
                                        ├── iobroker.dwd@2.8.5
                                        ├── iobroker.echarts@ invalid: "1.5.1" from the root project
                                        ├── iobroker.energiefluss@ invalid: "github:SKB-CGN/ioBroker.energiefluss#fc7a5b48f0f485b130619796daf0a9533f5b8426" from the root project
                                        ├── iobroker.eusec@1.1.2
                                        ├── iobroker.flot@ invalid: "1.12.0" from the root project
                                        ├── iobroker.fritzbox@0.2.1
                                        ├── iobroker.fullcalendar@ invalid: "1.2.0" from the root project
                                        ├── iobroker.fullybrowser@2.1.2
                                        ├── iobroker.gartenbewaesserung@ invalid: "github:TA2k/ioBroker.gartenbewaesserung#1931dcd562edf9dfa818dbf5cec61e28d3f72d72" from the root project
                                        ├── iobroker.ham@ invalid: "github:ioBroker/ioBroker.ham" from the root project
                                        ├── iobroker.harmony@1.2.2
                                        ├── iobroker.heatingcontrol@ invalid: "2.11.1" from the root project
                                        ├── iobroker.history@2.2.6
                                        ├── iobroker.hm-rega@3.0.47
                                        ├── iobroker.hm-rpc@1.15.19
                                        ├── iobroker.hue@3.9.5
                                        ├── iobroker.ical@ invalid: "github:iobroker-community-adapters/ioBroker.ical#ad28140ed1fa7ab23683d7e12b6204da06b7ce6f" from the root project
                                        ├── iobroker.icons-icons8@0.0.1
                                        ├── iobroker.icons-material-png@0.1.0
                                        ├── iobroker.icons-mfd-png@1.1.0
                                        ├── iobroker.icons-ultimate-png@1.0.1
                                        ├── iobroker.info@ invalid: "1.9.26" from the root project
                                        ├── iobroker.javascript@ invalid: "7.1.4" from the root project
                                        ├── iobroker.js-controller@ invalid: "^6.0.9" from the root project
                                        ├── iobroker.logparser@2.2.0
                                        ├── iobroker.material@ invalid: "1.3.1" from the root project
                                        ├── iobroker.meross@1.15.1
                                        ├── iobroker.mihome-vacuum@3.11.0
                                        ├── iobroker.milight-smart-light@ invalid: "1.2.2" from the root project
                                        ├── iobroker.milight@0.3.6
                                        ├── iobroker.mobile@ invalid: "1.0.1" from the root project
                                        ├── iobroker.modbus@ invalid: "5.0.11" from the root project
                                        ├── iobroker.mqtt@ invalid: "4.1.1" from the root project
                                        ├── iobroker.nina@ invalid: "0.0.25" from the root project
                                        ├── iobroker.pollenflug@1.0.6
                                        ├── iobroker.pushover@3.0.3
                                        ├── iobroker.pushsafer@1.0.3
                                        ├── iobroker.pvforecast@2.7.1
                                        ├── iobroker.renault@ invalid: "github:TA2k/ioBroker.renault" from the root project
                                        ├── iobroker.reolink@ invalid: "github:aendue/ioBroker.reolink#b78aab6744cdb81b360fd947a9c6e2fd6808bab1" from the root project
                                        ├── iobroker.schoolfree@ invalid: "1.1.2" from the root project
                                        ├── iobroker.simple-api@2.7.2
                                        ├── iobroker.smartmeter@3.3.4
                                        ├── iobroker.socketio@6.5.2
                                        ├── iobroker.sourceanalytix@ invalid: "github:DrozmotiX/ioBroker.sourceanalytix#362346b297c0a21c717ec20bd8d16331bca3b22d" from the root project
                                        ├── iobroker.sql@2.2.0
                                        ├── iobroker.statistics@2.3.0
                                        ├── iobroker.sunnyportal@0.1.5
                                        ├── iobroker.synology@ invalid: "2.1.13" from the root project
                                        ├── iobroker.tankerkoenig@ invalid: "3.3.7" from the root project
                                        ├── iobroker.terminal@ invalid: "1.0.0" from the root project
                                        ├── iobroker.tr-064@4.2.18
                                        ├── iobroker.trashschedule@2.2.0
                                        ├── iobroker.unifi@ invalid: "0.6.6" from the root project
                                        ├── iobroker.upnp@1.0.21
                                        ├── iobroker.valloxmv@1.2.0
                                        ├── iobroker.viessmannapi@ invalid: "github:TA2k/ioBroker.viessmannapi" from the root project
                                        ├── iobroker.virtualpowermeter@ invalid: "1.4.6" from the root project
                                        ├── iobroker.vis-2-widgets-material@ invalid: "github:ioBroker/ioBroker.vis-2-widgets-material#355a97e7d532721eaa97326fd873d13f12894ebd" from the root project
                                        ├── iobroker.vis-2@ invalid: "github:ioBroker/ioBroker.vis-2#17c7dcf5f26768f1f3a4badb087eddf9344591ea" from the root project
                                        ├── iobroker.vis-colorpicker@ invalid: "2.0.3" from the root project
                                        ├── iobroker.vis-fancyswitch@1.1.0
                                        ├── iobroker.vis-google-fonts@1.0.4
                                        ├── iobroker.vis-history@1.0.0
                                        ├── iobroker.vis-hqwidgets@ invalid: "1.4.0" from the root project
                                        ├── iobroker.vis-inventwo@ invalid: "3.3.3" from the root project
                                        ├── iobroker.vis-jqui-mfd@1.0.12
                                        ├── iobroker.vis-justgage@1.0.2
                                        ├── iobroker.vis-map@1.0.4
                                        ├── iobroker.vis-materialdesign@ invalid: "github:Scrounger/ioBroker.vis-materialdesign#8b7529d493f223dfc4f1d1f632553fcb35bbcc92" from the root project
                                        ├── iobroker.vis-metro@ invalid: "1.2.0" from the root project
                                        ├── iobroker.vis-rgraph@0.0.2
                                        ├── iobroker.vis-timeandweather@ invalid: "1.2.2" from the root project
                                        ├── iobroker.vis-weather@ invalid: "2.5.6" from the root project
                                        ├── iobroker.vis@ invalid: "1.4.16" from the root project
                                        ├── iobroker.vofo-speedtest@ invalid: "github:peterbaumert/ioBroker.vofo-speedtest#921201b4bbd53a88a64fc843c7242f9e7e8c0325" from the root project
                                        ├── iobroker.weatherunderground@3.4.2
                                        ├── iobroker.web-speedy@ invalid: "github:iobroker-community-adapters/ioBroker.web-speedy#8a5ad6a42a15688b6bb539f22e30ba2a1978c118" from the root project
                                        ├── iobroker.web@ invalid: "6.1.0" from the root project
                                        ├── iobroker.webcal@ invalid: "github:dirkhe/ioBroker.webcal#feature/DigestAuth" from the root project
                                        ├── iobroker.wiffi-wz@2.2.1
                                        ├── iobroker.windows-control@0.1.5
                                        ├── iobroker.worx@2.3.2
                                        ├── iobroker.ws@2.5.3
                                        ├── iobroker@2.0.3
                                        ├── ioredis@ extraneous
                                        ├── ip-address@9.0.5 extraneous
                                        ├── ip-regex@4.3.0 extraneous
                                        ├── ipaddr.js@2.2.0 extraneous
                                        ├── is-array-buffer@3.0.4 extraneous
                                        ├── is-bigint@1.0.4 extraneous
                                        ├── is-binary-path@2.1.0 extraneous
                                        ├── is-boolean-object@1.1.2 extraneous
                                        ├── is-buffer@1.1.6 extraneous
                                        ├── is-callable@1.2.7 extraneous
                                        ├── is-ci@2.0.0 extraneous
                                        ├── is-core-module@2.15.0 extraneous
                                        ├── is-data-view@1.0.1 extraneous
                                        ├── is-date-object@1.0.5 extraneous
                                        ├── is-docker@2.2.1 extraneous
                                        ├── is-empty-object@1.1.1 extraneous
                                        ├── is-extglob@2.1.1 extraneous
                                        ├── is-fullwidth-code-point@3.0.0 extraneous
                                        ├── is-glob@4.0.3 extraneous
                                        ├── is-installed-globally@0.3.2 extraneous
                                        ├── is-interactive@1.0.0 extraneous
                                        ├── is-lambda@1.0.1 extraneous
                                        ├── is-negative-zero@2.0.3 extraneous
                                        ├── is-npm@5.0.0 extraneous
                                        ├── is-number-object@1.0.7 extraneous
                                        ├── is-number@7.0.0 extraneous
                                        ├── is-obj@2.0.0 extraneous
                                        ├── is-observable@1.1.0 extraneous
                                        ├── is-path-cwd@2.2.0 extraneous
                                        ├── is-path-inside@3.0.3 extraneous
                                        ├── is-plain-obj@1.1.0 extraneous
                                        ├── is-potential-custom-element-name@1.0.1 extraneous
                                        ├── is-promise@2.2.2 extraneous
                                        ├── is-property@1.0.2 extraneous
                                        ├── is-regex@1.1.4 extraneous
                                        ├── is-scoped@2.1.0 extraneous
                                        ├── is-shared-array-buffer@1.0.3 extraneous
                                        ├── is-string@1.0.7 extraneous
                                        ├── is-symbol@1.0.4 extraneous
                                        ├── is-typed-array@1.1.13 extraneous
                                        ├── is-unicode-supported@0.1.0 extraneous
                                        ├── is-url-superb@4.0.0 extraneous
                                        ├── is-url@1.2.4 extraneous
                                        ├── is-weakref@1.0.2 extraneous
                                        ├── is-wsl@2.2.0 extraneous
                                        ├── is-yarn-global@0.3.0 extraneous
                                        ├── is@3.3.0 extraneous
                                        ├── is2@2.0.9 extraneous
                                        ├── isomorphic-ws@4.0.1 extraneous
                                        ├── issue-regex@3.1.0 extraneous
                                        ├── jackspeak@3.4.3 extraneous
                                        ├── js-md4@0.3.2 extraneous
                                        ├── js-sdsl@4.3.0 extraneous
                                        ├── js-tokens@4.0.0 extraneous
                                        ├── js-yaml@ extraneous
                                        ├── jsbi@4.3.0 extraneous
                                        ├── jsbn@1.1.0 extraneous
                                        ├── jsdom@ extraneous
                                        ├── jshashes@1.0.8 extraneous
                                        ├── json-buffer@3.0.1 extraneous
                                        ├── json-logic-js@2.0.5 extraneous
                                        ├── json-parse-even-better-errors@2.3.1 extraneous
                                        ├── json-schema-traverse@1.0.0 extraneous
                                        ├── json5@2.2.3 extraneous
                                        ├── jsonata@ extraneous
                                        ├── jsonc-parser@3.3.1 extraneous
                                        ├── jsonwebtoken@9.0.2 extraneous
                                        ├── jszip@ extraneous
                                        ├── jwa@2.0.0 extraneous
                                        ├── jws@4.0.0 extraneous
                                        ├── keyv@4.5.4 extraneous
                                        ├── kind-of@6.0.3 extraneous
                                        ├── kuler@2.0.0 extraneous
                                        ├── later@1.2.0 extraneous
                                        ├── latest-version@5.1.0 extraneous
                                        ├── layerr@0.1.2 extraneous
                                        ├── lazystream@1.0.1 extraneous
                                        ├── leven@2.1.0 extraneous
                                        ├── levn@0.3.0 extraneous
                                        ├── lie@3.3.0 extraneous
                                        ├── lines-and-columns@1.2.4 extraneous
                                        ├── listr-input@0.2.1 extraneous
                                        ├── listr-silent-renderer@1.1.1 extraneous
                                        ├── listr-update-renderer@0.5.0 extraneous
                                        ├── listr-verbose-renderer@0.5.0 extraneous
                                        ├── listr@0.14.3 extraneous
                                        ├── loadavg-windows@1.1.1 extraneous
                                        ├── locate-path@6.0.0 extraneous
                                        ├── lodash.defaults@4.2.0 extraneous
                                        ├── lodash.flatten@4.4.0 extraneous
                                        ├── lodash.includes@4.3.0 extraneous
                                        ├── lodash.isarguments@3.1.0 extraneous
                                        ├── lodash.isboolean@3.0.3 extraneous
                                        ├── lodash.isequal@4.5.0 extraneous
                                        ├── lodash.isinteger@4.0.4 extraneous
                                        ├── lodash.isnumber@3.0.3 extraneous
                                        ├── lodash.isplainobject@4.0.6 extraneous
                                        ├── lodash.isstring@4.0.1 extraneous
                                        ├── lodash.once@4.1.1 extraneous
                                        ├── lodash.zip@4.2.0 extraneous
                                        ├── log-symbols@4.1.0 extraneous
                                        ├── log-update@2.3.0 extraneous
                                        ├── logform@ extraneous
                                        ├── long@5.2.3 extraneous
                                        ├── lowercase-keys@2.0.0 extraneous
                                        ├── lru_map@0.3.3 extraneous
                                        ├── lru-cache@6.0.0 extraneous
                                        ├── make-dir@3.1.0 extraneous
                                        ├── make-fetch-happen@10.2.1 extraneous
                                        ├── map-age-cleaner@0.1.3 extraneous
                                        ├── map-obj@4.3.0 extraneous
                                        ├── map-stream@0.0.7 extraneous
                                        ├── md5@2.3.0 extraneous
                                        ├── media-typer@0.3.0 extraneous
                                        ├── meow@8.1.2 extraneous
                                        ├── merge-descriptors@1.0.1 extraneous
                                        ├── merge2@1.4.1 extraneous
                                        ├── methods@1.1.2 extraneous
                                        ├── micro@9.4.1 extraneous
                                        ├── micromatch@4.0.7 extraneous
                                        ├── mime-db@1.53.0 extraneous
                                        ├── mimic-response@1.0.1 extraneous
                                        ├── min-indent@1.0.1 extraneous
                                        ├── minimatch@9.0.5 extraneous
                                        ├── minimist-options@4.1.0 extraneous
                                        ├── minipass-collect@1.0.2 extraneous
                                        ├── minipass-fetch@2.1.2 extraneous
                                        ├── minipass-flush@1.0.5 extraneous
                                        ├── minipass-pipeline@1.2.4 extraneous
                                        ├── minipass-sized@1.0.3 extraneous
                                        ├── minipass@7.1.2 extraneous
                                        ├── minizlib@2.1.2 extraneous
                                        ├── mkdirp-classic@0.5.3 extraneous
                                        ├── mkdirp@1.0.4 extraneous
                                        ├── mock-require@3.0.3 extraneous
                                        ├── moment-duration-format@2.3.2 extraneous
                                        ├── mqtt-connection@4.1.0 extraneous
                                        ├── mqtt-packet@9.0.0 extraneous
                                        ├── mqtt@ extraneous
                                        ├── mute-stream@0.0.8 extraneous
                                        ├── named-placeholders@1.1.3 extraneous
                                        ├── nan@ extraneous
                                        ├── nanoid@3.3.7 extraneous
                                        ├── napi-build-utils@1.0.2 extraneous
                                        ├── native-duplexpair@1.0.0 extraneous
                                        ├── nconf@0.10.0 extraneous
                                        ├── nested-property@4.0.0 extraneous
                                        ├── netmask@2.0.2 extraneous
                                        ├── new-github-release-url@1.0.0 extraneous
                                        ├── node-abi@3.65.0 extraneous
                                        ├── node-abort-controller@3.1.1 extraneous
                                        ├── node-cron@2.0.3 extraneous
                                        ├── node-fetch@2.7.0 extraneous
                                        ├── node-forge@ extraneous
                                        ├── node-gyp@ extraneous
                                        ├── node-ical@0.16.1 extraneous
                                        ├── node-inspect@2.0.0 extraneous
                                        ├── node-libcurl@3.0.0 extraneous
                                        ├── node-mndp@0.0.3 extraneous
                                        ├── node-persist@0.0.11 extraneous
                                        ├── node-rsa@1.1.1 extraneous
                                        ├── node-unifi@2.5.1 extraneous
                                        ├── node-wol@0.1.1 extraneous
                                        ├── node.extend@2.0.3 extraneous
                                        ├── nopt@5.0.0 extraneous
                                        ├── normalize-package-data@3.0.3 extraneous
                                        ├── normalize-path@3.0.0 extraneous
                                        ├── normalize-url@6.1.0 extraneous
                                        ├── np@7.7.0 extraneous
                                        ├── npm-name@6.0.1 extraneous
                                        ├── npmlog@5.0.1 extraneous
                                        ├── number-allocator@1.0.14 extraneous
                                        ├── nwsapi@2.2.12 extraneous
                                        ├── object-assign@4.1.1 extraneous
                                        ├── object-hash@3.0.0 extraneous
                                        ├── on-finished@2.4.1 extraneous
                                        ├── once@1.4.0 extraneous
                                        ├── one-time@1.0.0 extraneous
                                        ├── onedrive-api@1.1.1 extraneous
                                        ├── open@7.4.2 extraneous
                                        ├── opencollective-postinstall@2.0.3 extraneous
                                        ├── optionator@0.8.3 extraneous
                                        ├── org-regex@1.0.0 extraneous
                                        ├── os-tmpdir@1.0.2 extraneous
                                        ├── ospath@1.2.2 extraneous
                                        ├── osx-temperature-sensor@ extraneous
                                        ├── otplib@11.0.1 extraneous
                                        ├── ow@0.21.0 extraneous
                                        ├── p-cancelable@2.1.1 extraneous
                                        ├── p-defer@1.0.0 extraneous
                                        ├── p-event@4.2.0 extraneous
                                        ├── p-finally@1.0.0 extraneous
                                        ├── p-limit@2.3.0 extraneous
                                        ├── p-locate@5.0.0 extraneous
                                        ├── p-map@2.1.0 extraneous
                                        ├── p-memoize@4.0.4 extraneous
                                        ├── p-reflect@2.1.0 extraneous
                                        ├── p-settle@4.1.1 extraneous
                                        ├── p-throttle@4.1.1 extraneous
                                        ├── p-timeout@4.1.0 extraneous
                                        ├── p-try@2.2.0 extraneous
                                        ├── package-json-from-dist@1.0.0 extraneous
                                        ├── package-json@6.5.0 extraneous
                                        ├── pako@ extraneous
                                        ├── parent-module@1.0.1 extraneous
                                        ├── parse-json@5.2.0 extraneous
                                        ├── parse5@ extraneous
                                        ├── passport-local@1.0.0 extraneous
                                        ├── passport@0.7.0 extraneous
                                        ├── path-exists@4.0.0 extraneous
                                        ├── path-is-absolute@1.0.1 extraneous
                                        ├── path-parse@1.0.7 extraneous
                                        ├── path-posix@1.0.0 extraneous
                                        ├── path-scurry@1.11.1 extraneous
                                        ├── path-to-regexp@0.1.7 extraneous
                                        ├── path-type@4.0.0 extraneous
                                        ├── pause-stream@0.0.11 extraneous
                                        ├── picomatch@2.3.1 extraneous
                                        ├── pidtree@0.6.0 extraneous
                                        ├── pidusage@3.0.2 extraneous
                                        ├── ping@0.4.4 extraneous
                                        ├── pkg-dir@5.0.0 extraneous
                                        ├── pluralize@8.0.0 extraneous
                                        ├── possible-typed-array-names@1.0.0 extraneous
                                        ├── prebuild-install@7.1.2 extraneous
                                        ├── prelude-ls@1.1.2 extraneous
                                        ├── prepend-http@2.0.0 extraneous
                                        ├── process-nextick-args@2.0.1 extraneous
                                        ├── process@0.11.10 extraneous
                                        ├── promise-inflight@1.0.1 extraneous
                                        ├── promise-object@0.1.7 extraneous
                                        ├── promise-retry@2.0.1 extraneous
                                        ├── promise-retryer@0.0.1 extraneous
                                        ├── promisify-child-process@4.1.2 extraneous
                                        ├── prompt@1.3.0 extraneous
                                        ├── protobufjs@ extraneous
                                        ├── proxy-addr@2.0.7 extraneous
                                        ├── proxy-from-env@1.1.0 extraneous
                                        ├── pump@3.0.0 extraneous
                                        ├── pupa@2.1.1 extraneous
                                        ├── q@1.1.2 extraneous
                                        ├── quasar@ extraneous
                                        ├── queue-microtask@1.2.3 extraneous
                                        ├── queue-tick@1.0.1 extraneous
                                        ├── quick-lru@5.1.1 extraneous
                                        ├── range-parser@1.2.1 extraneous
                                        ├── raw-body@2.5.2 extraneous
                                        ├── rc@1.2.8 extraneous
                                        ├── read-pkg-up@7.0.1 extraneous
                                        ├── read-pkg@5.2.0 extraneous
                                        ├── read@1.0.7 extraneous
                                        ├── readable-stream@ extraneous
                                        ├── readdir-glob@1.1.3 extraneous
                                        ├── readdirp@3.6.0 extraneous
                                        ├── readline-sync@1.4.10 extraneous
                                        ├── readline@1.3.0 extraneous
                                        ├── redent@3.0.0 extraneous
                                        ├── redis-commands@1.7.0 extraneous
                                        ├── redis-errors@1.2.0 extraneous
                                        ├── redis-parser@3.0.0 extraneous
                                        ├── regenerator-runtime@0.14.1 extraneous
                                        ├── regex-escape@3.4.10 extraneous
                                        ├── regexp.prototype.flags@1.5.2 extraneous
                                        ├── registry-auth-token@4.2.2 extraneous
                                        ├── registry-url@5.1.0 extraneous
                                        ├── reinterval@1.1.0 extraneous
                                        ├── remove-trailing-separator@1.1.0 extraneous
                                        ├── require-from-string@2.0.2 extraneous
                                        ├── resolve-alpn@1.2.1 extraneous
                                        ├── resolve-cwd@3.0.0 extraneous
                                        ├── resolve-from@4.0.0 extraneous
                                        ├── respjs@4.2.0 extraneous
                                        ├── responselike@2.0.1 extraneous
                                        ├── restore-cursor@3.1.0 extraneous
                                        ├── retry-axios@2.6.0 extraneous
                                        ├── retry@0.12.0 extraneous
                                        ├── reusify@1.0.4 extraneous
                                        ├── revalidator@0.1.8 extraneous
                                        ├── rfdc@1.4.1 extraneous
                                        ├── rimraf@3.0.2 extraneous
                                        ├── rrule@2.8.1 extraneous
                                        ├── rrweb-cssom@0.6.0 extraneous
                                        ├── run-async@2.4.1 extraneous
                                        ├── run-parallel@1.2.0 extraneous
                                        ├── rxjs@ extraneous
                                        ├── safe-array-concat@1.1.2 extraneous
                                        ├── safe-regex-test@1.0.3 extraneous
                                        ├── safe-stable-stringify@2.4.3 extraneous
                                        ├── safer-buffer@2.1.2 extraneous
                                        ├── saxes@6.0.0 extraneous
                                        ├── scoped-regex@2.1.0 extraneous
                                        ├── secure-keys@1.0.0 extraneous
                                        ├── semver-diff@3.1.1 extraneous
                                        ├── semver@5.7.2
                                        ├── send@0.18.0 extraneous
                                        ├── seq-logging@1.1.2 extraneous
                                        ├── seq-queue@0.0.5 extraneous
                                        ├── serve-static@1.15.0 extraneous
                                        ├── set-function-name@2.0.2 extraneous
                                        ├── setimmediate@1.0.5 extraneous
                                        ├── setprototypeof@1.2.0 extraneous
                                        ├── signal-exit@4.1.0 extraneous
                                        ├── simple-concat@1.0.1 extraneous
                                        ├── simple-get@3.1.1 extraneous
                                        ├── simple-ssh@1.1.1 extraneous
                                        ├── simple-swizzle@0.2.2 extraneous
                                        ├── slash@3.0.0 extraneous
                                        ├── slice-ansi@0.0.4 extraneous
                                        ├── smart-buffer@4.2.0 extraneous
                                        ├── socks-proxy-agent@7.0.0 extraneous
                                        ├── socks@2.8.3 extraneous
                                        ├── speedtest-net@1.6.2 extraneous
                                        ├── split@1.0.1 extraneous
                                        ├── sprintf-js@1.1.3 extraneous
                                        ├── sqlstring@2.3.3 extraneous
                                        ├── ssh2@ extraneous
                                        ├── ssri@9.0.1 extraneous
                                        ├── stack-trace@0.0.10 extraneous
                                        ├── stampit-event-bus@0.1.1 extraneous
                                        ├── stampit-state-machine@0.2.1 extraneous
                                        ├── stampit@2.1.2 extraneous
                                        ├── standard-as-callback@2.1.0 extraneous
                                        ├── static-eval@2.0.2 extraneous
                                        ├── statuses@2.0.1 extraneous
                                        ├── stoppable@1.1.0 extraneous
                                        ├── stream-combiner@0.2.2 extraneous
                                        ├── stream-shift@1.0.3 extraneous
                                        ├── streamsearch@1.1.0 extraneous
                                        ├── streamx@2.18.0 extraneous
                                        ├── string-argv@0.3.2 extraneous
                                        ├── string-width-cjs@npm:string-width@4.2.3 extraneous
                                        ├── string-width@5.1.2 extraneous
                                        ├── string.prototype.trim@1.2.9 extraneous
                                        ├── string.prototype.trimend@1.0.8 extraneous
                                        ├── string.prototype.trimstart@1.0.8 extraneous
                                        ├── strip-ansi-cjs@npm:strip-ansi@6.0.1 extraneous
                                        ├── strip-ansi@6.0.1 extraneous
                                        ├── strip-indent@3.0.0 extraneous
                                        ├── strip-json-comments@2.0.1 extraneous
                                        ├── strnum@1.0.5 extraneous
                                        ├── suncalc@1.9.0 extraneous
                                        ├── suncalc2@1.8.1 extraneous
                                        ├── supermixer@1.0.5 extraneous
                                        ├── supports-color@7.2.0 extraneous
                                        ├── supports-hyperlinks@2.3.0 extraneous
                                        ├── supports-preserve-symlinks-flag@1.0.0 extraneous
                                        ├── sweet-collections@1.1.0 extraneous
                                        ├── symbol-observable@3.0.0 extraneous
                                        ├── symbol-tree@3.2.4 extraneous
                                        ├── syno@ extraneous
                                        ├── systeminformation@ extraneous
                                        ├── tar-fs@2.1.1 extraneous
                                        ├── tar-stream@3.1.7 extraneous
                                        ├── tar@6.2.1 extraneous
                                        ├── tarn@3.0.2 extraneous
                                        ├── tcp-port-used@1.0.2 extraneous
                                        ├── tedious@ extraneous
                                        ├── terminal-link@2.1.1 extraneous
                                        ├── text-decoder@1.1.1 extraneous
                                        ├── text-hex@1.0.0 extraneous
                                        ├── thirty-two@1.0.2 extraneous
                                        ├── through@2.3.8 extraneous
                                        ├── through2@2.0.5 extraneous
                                        ├── tiny-typed-emitter@2.1.0 extraneous
                                        ├── tinycolor2@1.6.0 extraneous
                                        ├── tmp@0.0.33 extraneous
                                        ├── to-readable-stream@2.1.0 extraneous
                                        ├── to-regex-range@5.0.1 extraneous
                                        ├── toidentifier@1.0.1 extraneous
                                        ├── tr46@4.1.1 extraneous
                                        ├── trim-newlines@3.0.1 extraneous
                                        ├── triple-beam@1.4.1 extraneous
                                        ├── tsdav@ extraneous
                                        ├── tslib@2.3.0 extraneous
                                        ├── tweetnacl@0.14.5 extraneous
                                        ├── type-check@0.3.2 extraneous
                                        ├── type-fest@0.21.3 extraneous
                                        ├── type-is@1.6.18 extraneous
                                        ├── typed-array-buffer@1.0.2 extraneous
                                        ├── typed-array-byte-length@1.0.1 extraneous
                                        ├── typed-array-byte-offset@1.0.2 extraneous
                                        ├── typed-array-length@1.0.6 extraneous
                                        ├── typedarray-to-buffer@3.1.5 extraneous
                                        ├── typedarray.prototype.slice@1.0.3 extraneous
                                        ├── typescript@ extraneous
                                        ├── tz-offset@0.0.1 extraneous
                                        ├── uid-number@0.0.6 extraneous
                                        ├── unbox-primitive@1.0.2 extraneous
                                        ├── undici-types@6.19.6 extraneous
                                        ├── unique-filename@2.0.1 extraneous
                                        ├── unique-slug@3.0.0 extraneous
                                        ├── unique-string@2.0.0 extraneous
                                        ├── unix-dgram@2.0.6 extraneous
                                        ├── unpipe@1.0.0 extraneous
                                        ├── update-notifier@5.1.0 extraneous
                                        ├── uri-js@4.4.1 extraneous
                                        ├── url-join@4.0.1 extraneous
                                        ├── url-parse-lax@3.0.0 extraneous
                                        ├── url-template@2.0.8 extraneous
                                        ├── url@0.11.4 extraneous
                                        ├── vali-date@1.0.0 extraneous
                                        ├── validate-npm-package-name@3.0.0 extraneous
                                        ├── vary@1.1.2 extraneous
                                        ├── virtual-tsc@0.6.2 extraneous
                                        ├── vue-i18n@ extraneous
                                        ├── vuelidate-messages@0.1.2 extraneous
                                        ├── vuelidate@ extraneous
                                        ├── vuex-map-fields@1.4.1 extraneous
                                        ├── w3c-xmlserializer@4.0.0 extraneous
                                        ├── wake_on_lan@1.0.0 extraneous
                                        ├── weak-daemon@1.0.3 extraneous
                                        ├── webdav@ extraneous
                                        ├── webidl-conversions@7.0.0 extraneous
                                        ├── websocket-stream@5.5.2 extraneous
                                        ├── whatwg-encoding@2.0.0 extraneous
                                        ├── whatwg-mimetype@3.0.0 extraneous
                                        ├── whatwg-url@12.0.1 extraneous
                                        ├── which-boxed-primitive@1.0.2 extraneous
                                        ├── which-typed-array@1.1.15 extraneous
                                        ├── wide-align@1.1.5 extraneous
                                        ├── widest-line@3.1.0 extraneous
                                        ├── window-size@0.1.4 extraneous
                                        ├── winston-daily-rotate-file@5.0.0 extraneous
                                        ├── winston-seq-updated@1.0.4 extraneous
                                        ├── winston-syslog@2.7.1 extraneous
                                        ├── winston-transport@4.7.1 extraneous
                                        ├── winston@ extraneous
                                        ├── word-wrap@1.2.5 extraneous
                                        ├── worker-timers-broker@6.1.8 extraneous
                                        ├── worker-timers-worker@7.0.71 extraneous
                                        ├── worker-timers@7.1.8 extraneous
                                        ├── wrap-ansi-cjs@npm:wrap-ansi@7.0.0 extraneous
                                        ├── wrap-ansi@8.1.0 extraneous
                                        ├── wrappy@1.0.2 extraneous
                                        ├── write-file-atomic@3.0.3 extraneous
                                        ├── xdg-basedir@4.0.0 extraneous
                                        ├── xml-js@1.6.11 extraneous
                                        ├── xml-name-validator@4.0.0 extraneous
                                        ├── xmlchars@2.2.0 extraneous
                                        ├── xregexp@2.0.0 extraneous
                                        ├── yallist@4.0.0 extraneous
                                        ├── yaml@ extraneous
                                        ├── yargs-parser@20.2.9 extraneous
                                        ├── yargs@7.1.2
                                        ├── yocto-queue@0.1.0 extraneous
                                        ├── zip-stream@6.0.1 extraneous
                                        └── zrender@ extraneous
                                          flommaster @flommaster last edited by
                                          Teil 2
                                          npm error code ELSPROBLEMS
                                          npm error extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
                                          npm error extraneous: @alcalzone/jsonl-db@3.1.1 /opt/iobroker/node_modules/@alcalzone/jsonl-db
                                          npm error extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/@alcalzone/pak
                                          npm error extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
                                          npm error extraneous: @aws-sdk/util-utf8-browser@3.259.0 /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser
                                          npm error extraneous: @azure/abort-controller@1.1.0 /opt/iobroker/node_modules/@azure/abort-controller
                                          npm error extraneous: @azure/core-auth@1.7.2 /opt/iobroker/node_modules/@azure/core-auth
                                          npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
                                          npm error extraneous: @azure/core-http-compat@ /opt/iobroker/node_modules/@azure/core-http-compat
                                          npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
                                          npm error extraneous: @azure/core-paging@1.6.2 /opt/iobroker/node_modules/@azure/core-paging
                                          npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
                                          npm error extraneous: @azure/core-tracing@1.1.2 /opt/iobroker/node_modules/@azure/core-tracing
                                          npm error extraneous: @azure/core-util@ /opt/iobroker/node_modules/@azure/core-util
                                          npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
                                          npm error extraneous: @azure/keyvault-keys@ /opt/iobroker/node_modules/@azure/keyvault-keys
                                          npm error extraneous: @azure/logger@1.1.4 /opt/iobroker/node_modules/@azure/logger
                                          npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
                                          npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
                                          npm error extraneous: @azure/msal-node@1.18.4 /opt/iobroker/node_modules/@azure/msal-node
                                          npm error extraneous: @babel/code-frame@7.24.7 /opt/iobroker/node_modules/@babel/code-frame
                                          npm error extraneous: @babel/helper-validator-identifier@7.24.7 /opt/iobroker/node_modules/@babel/helper-validator-identifier
                                          npm error extraneous: @babel/highlight@7.24.7 /opt/iobroker/node_modules/@babel/highlight
                                          npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
                                          npm error extraneous: @colors/colors@1.5.0 /opt/iobroker/node_modules/@colors/colors
                                          npm error extraneous: @dabh/diagnostics@2.0.3 /opt/iobroker/node_modules/@dabh/diagnostics
                                          npm error extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
                                          npm error extraneous: @gar/promisify@1.1.3 /opt/iobroker/node_modules/@gar/promisify
                                          npm error extraneous: @googleapis/calendar@9.7.7 /opt/iobroker/node_modules/@googleapis/calendar
                                          npm error extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
                                          npm error extraneous: @googleapis/oauth2@1.0.7 /opt/iobroker/node_modules/@googleapis/oauth2
                                          npm error extraneous: @httptoolkit/websocket-stream@6.0.1 /opt/iobroker/node_modules/@httptoolkit/websocket-stream
                                          npm error extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
                                          npm error extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
                                          npm error extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
                                          npm error extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
                                          npm error extraneous: @iobroker/db-states-file@ /opt/iobroker/node_modules/@iobroker/db-states-file
                                          npm error extraneous: @iobroker/db-states-jsonl@ /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                                          npm error extraneous: @iobroker/db-states-redis@ /opt/iobroker/node_modules/@iobroker/db-states-redis
                                          npm error extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
                                          npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
                                          npm error extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modules/@iobroker/js-controller-common-db
                                          npm error extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
                                          npm error extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
                                          npm error extraneous: @iobroker/plugin-sentry@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-sentry
                                          npm error extraneous: @iobroker/socket-classes@1.5.6 /opt/iobroker/node_modules/@iobroker/socket-classes
                                          npm error extraneous: @iobroker/webserver@1.0.3 /opt/iobroker/node_modules/@iobroker/webserver
                                          npm error extraneous: @isaacs/cliui@8.0.2 /opt/iobroker/node_modules/@isaacs/cliui
                                          npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
                                          npm error extraneous: @mapbox/node-pre-gyp@1.0.11 /opt/iobroker/node_modules/@mapbox/node-pre-gyp
                                          npm error extraneous: @microsoft/microsoft-graph-types@2.40.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
                                          npm error extraneous: @nodelib/fs.scandir@2.1.5 /opt/iobroker/node_modules/@nodelib/fs.scandir
                                          npm error extraneous: @nodelib/fs.stat@2.0.5 /opt/iobroker/node_modules/@nodelib/fs.stat
                                          npm error extraneous: @nodelib/fs.walk@1.2.8 /opt/iobroker/node_modules/@nodelib/fs.walk
                                          npm error extraneous: @npmcli/fs@2.1.2 /opt/iobroker/node_modules/@npmcli/fs
                                          npm error extraneous: @npmcli/move-file@2.0.1 /opt/iobroker/node_modules/@npmcli/move-file
                                          npm error extraneous: @pkgjs/parseargs@0.11.0 /opt/iobroker/node_modules/@pkgjs/parseargs
                                          npm error extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
                                          npm error extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
                                          npm error extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
                                          npm error extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
                                          npm error extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
                                          npm error extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
                                          npm error extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
                                          npm error extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
                                          npm error extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
                                          npm error extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
                                          npm error extraneous: @quasar/extras@ /opt/iobroker/node_modules/@quasar/extras
                                          npm error extraneous: @samverschueren/stream-to-observable@0.3.1 /opt/iobroker/node_modules/@samverschueren/stream-to-observable
                                          npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
                                          npm error extraneous: @sentry/core@5.30.0 /opt/iobroker/node_modules/@sentry/core
                                          npm error extraneous: @sentry/hub@5.30.0 /opt/iobroker/node_modules/@sentry/hub
                                          npm error extraneous: @sentry/minimal@5.30.0 /opt/iobroker/node_modules/@sentry/minimal
                                          npm error extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
                                          npm error extraneous: @sentry/tracing@ /opt/iobroker/node_modules/@sentry/tracing
                                          npm error extraneous: @sentry/types@ /opt/iobroker/node_modules/@sentry/types
                                          npm error extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
                                          npm error extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/@sindresorhus/is
                                          npm error extraneous: @socket.io/component-emitter@3.1.2 /opt/iobroker/node_modules/@socket.io/component-emitter
                                          npm error extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/@szmarczak/http-timer
                                          npm error extraneous: @tediousjs/connection-string@0.5.0 /opt/iobroker/node_modules/@tediousjs/connection-string
                                          npm error extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
                                          npm error extraneous: @types/bl@5.1.0 /opt/iobroker/node_modules/@types/bl
                                          npm error extraneous: @types/cacheable-request@6.0.3 /opt/iobroker/node_modules/@types/cacheable-request
                                          npm error extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                                          npm error extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/@types/cookie
                                          npm error extraneous: @types/cors@2.8.17 /opt/iobroker/node_modules/@types/cors
                                          npm error extraneous: @types/geojson@7946.0.14 /opt/iobroker/node_modules/@types/geojson
                                          npm error extraneous: @types/http-cache-semantics@4.0.4 /opt/iobroker/node_modules/@types/http-cache-semantics
                                          npm error extraneous: @types/keyv@3.1.4 /opt/iobroker/node_modules/@types/keyv
                                          npm error extraneous: @types/leaflet@1.9.12 /opt/iobroker/node_modules/@types/leaflet
                                          npm error extraneous: @types/minimist@1.2.5 /opt/iobroker/node_modules/@types/minimist
                                          npm error extraneous: @types/node-cron@2.0.8 /opt/iobroker/node_modules/@types/node-cron
                                          npm error extraneous: @types/node@ /opt/iobroker/node_modules/@types/node
                                          npm error extraneous: @types/normalize-package-data@2.4.4 /opt/iobroker/node_modules/@types/normalize-package-data
                                          npm error extraneous: @types/parse-json@4.0.2 /opt/iobroker/node_modules/@types/parse-json
                                          npm error extraneous: @types/readable-stream@4.0.15 /opt/iobroker/node_modules/@types/readable-stream
                                          npm error extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                                          npm error extraneous: @types/responselike@1.0.3 /opt/iobroker/node_modules/@types/responselike
                                          npm error extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                                          npm error extraneous: @types/triple-beam@1.3.5 /opt/iobroker/node_modules/@types/triple-beam
                                          npm error extraneous: @types/tz-offset@0.0.3 /opt/iobroker/node_modules/@types/tz-offset
                                          npm error extraneous: @types/ws@8.5.12 /opt/iobroker/node_modules/@types/ws
                                          npm error extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
                                          npm error extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
                                          npm error extraneous: abort-controller@3.0.0 /opt/iobroker/node_modules/abort-controller
                                          npm error extraneous: agentkeepalive@4.5.0 /opt/iobroker/node_modules/agentkeepalive
                                          npm error extraneous: aggregate-error@3.1.0 /opt/iobroker/node_modules/aggregate-error
                                          npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
                                          npm error extraneous: ansi-align@3.0.1 /opt/iobroker/node_modules/ansi-align
                                          npm error extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/ansi-colors
                                          npm error extraneous: ansi-escapes@4.3.2 /opt/iobroker/node_modules/ansi-escapes
                                          npm error extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/ansi-regex
                                          npm error extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/ansi-styles
                                          npm error extraneous: any-observable@0.5.1 /opt/iobroker/node_modules/any-observable
                                          npm error extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
                                          npm error extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
                                          npm error extraneous: archiver-utils@5.0.2 /opt/iobroker/node_modules/archiver-utils
                                          npm error extraneous: archiver@7.0.1 /opt/iobroker/node_modules/archiver
                                          npm error extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
                                          npm error extraneous: arg@4.1.0 /opt/iobroker/node_modules/arg
                                          npm error extraneous: argparse@1.0.10 /opt/iobroker/node_modules/argparse
                                          npm error extraneous: array-buffer-byte-length@1.0.1 /opt/iobroker/node_modules/array-buffer-byte-length
                                          npm error extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/array-flatten
                                          npm error extraneous: array-union@2.1.0 /opt/iobroker/node_modules/array-union
                                          npm error extraneous: arraybuffer.prototype.slice@1.0.3 /opt/iobroker/node_modules/arraybuffer.prototype.slice
                                          npm error extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
                                          npm error extraneous: asn1@0.2.6 /opt/iobroker/node_modules/asn1
                                          npm error extraneous: async-exit-hook@2.0.1 /opt/iobroker/node_modules/async-exit-hook
                                          npm error extraneous: authenticate-pam@1.0.5 /opt/iobroker/node_modules/authenticate-pam
                                          npm error extraneous: available-typed-arrays@1.0.7 /opt/iobroker/node_modules/available-typed-arrays
                                          npm error extraneous: aws-crt@ /opt/iobroker/node_modules/aws-crt
                                          npm error extraneous: b4a@1.6.6 /opt/iobroker/node_modules/b4a
                                          npm error extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/balanced-match
                                          npm error extraneous: bare-events@2.4.2 /opt/iobroker/node_modules/bare-events
                                          npm error extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
                                          npm error extraneous: base64-js@1.5.1 /opt/iobroker/node_modules/base64-js
                                          npm error extraneous: bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/bcrypt-pbkdf
                                          npm error extraneous: binary-extensions@2.3.0 /opt/iobroker/node_modules/binary-extensions
                                          npm error extraneous: bindings@1.5.0 /opt/iobroker/node_modules/bindings
                                          npm error extraneous: bl@6.0.14 /opt/iobroker/node_modules/bl
                                          npm error extraneous: bluebird@3.7.2 /opt/iobroker/node_modules/bluebird
                                          npm error extraneous: body-parser@1.20.2 /opt/iobroker/node_modules/body-parser
                                          npm error extraneous: bottleneck@2.19.5 /opt/iobroker/node_modules/bottleneck
                                          npm error extraneous: boxen@5.1.2 /opt/iobroker/node_modules/boxen
                                          npm error extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/brace-expansion
                                          npm error extraneous: braces@3.0.3 /opt/iobroker/node_modules/braces
                                          npm error extraneous: buffer-crc32@1.0.0 /opt/iobroker/node_modules/buffer-crc32
                                          npm error extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
                                          npm error extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
                                          npm error extraneous: buffer@6.0.3 /opt/iobroker/node_modules/buffer
                                          npm error extraneous: buildcheck@0.0.6 /opt/iobroker/node_modules/buildcheck
                                          npm error extraneous: builtins@1.0.3 /opt/iobroker/node_modules/builtins
                                          npm error extraneous: busboy@1.6.0 /opt/iobroker/node_modules/busboy
                                          npm error extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
                                          npm error extraneous: bytes@3.1.2 /opt/iobroker/node_modules/bytes
                                          npm error extraneous: cacache@16.1.3 /opt/iobroker/node_modules/cacache
                                          npm error extraneous: cacheable-lookup@5.0.4 /opt/iobroker/node_modules/cacheable-lookup
                                          npm error extraneous: cacheable-request@7.0.4 /opt/iobroker/node_modules/cacheable-request
                                          npm error extraneous: callsites@3.1.0 /opt/iobroker/node_modules/callsites
                                          npm error extraneous: camelcase-keys@6.2.2 /opt/iobroker/node_modules/camelcase-keys
                                          npm error extraneous: camelcase@5.3.1 /opt/iobroker/node_modules/camelcase
                                          npm error extraneous: capitalize@2.0.4 /opt/iobroker/node_modules/capitalize
                                          npm error extraneous: chalk@4.1.2 /opt/iobroker/node_modules/chalk
                                          npm error extraneous: chardet@0.7.0 /opt/iobroker/node_modules/chardet
                                          npm error extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
                                          npm error extraneous: chokidar@3.6.0 /opt/iobroker/node_modules/chokidar
                                          npm error extraneous: chownr@2.0.0 /opt/iobroker/node_modules/chownr
                                          npm error extraneous: ci-info@3.9.0 /opt/iobroker/node_modules/ci-info
                                          npm error extraneous: clean-stack@2.2.0 /opt/iobroker/node_modules/clean-stack
                                          npm error extraneous: cli-boxes@2.2.1 /opt/iobroker/node_modules/cli-boxes
                                          npm error extraneous: cli-cursor@3.1.0 /opt/iobroker/node_modules/cli-cursor
                                          npm error extraneous: cli-truncate@0.2.1 /opt/iobroker/node_modules/cli-truncate
                                          npm error extraneous: cli-width@3.0.0 /opt/iobroker/node_modules/cli-width
                                          npm error extraneous: clone-response@1.0.3 /opt/iobroker/node_modules/clone-response
                                          npm error extraneous: cloneextend@0.0.3 /opt/iobroker/node_modules/cloneextend
                                          npm error extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
                                          npm error extraneous: coap-packet@1.1.1 /opt/iobroker/node_modules/coap-packet
                                          npm error extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                                          npm error extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/color-convert
                                          npm error extraneous: color-name@1.1.4 /opt/iobroker/node_modules/color-name
                                          npm error extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
                                          npm error extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
                                          npm error extraneous: color@3.2.1 /opt/iobroker/node_modules/color
                                          npm error extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
                                          npm error extraneous: commander@9.5.0 /opt/iobroker/node_modules/commander
                                          npm error extraneous: commist@3.2.0 /opt/iobroker/node_modules/commist
                                          npm error extraneous: compress-commons@6.0.2 /opt/iobroker/node_modules/compress-commons
                                          npm error extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
                                          npm error extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
                                          npm error extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
                                          npm error extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
                                          npm error extraneous: configstore@5.0.1 /opt/iobroker/node_modules/configstore
                                          npm error extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
                                          npm error extraneous: connect@3.7.0 /opt/iobroker/node_modules/connect
                                          npm error extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
                                          npm error extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/content-disposition
                                          npm error extraneous: content-type@1.0.5 /opt/iobroker/node_modules/content-type
                                          npm error extraneous: core-js@ /opt/iobroker/node_modules/core-js
                                          npm error extraneous: cors@2.8.5 /opt/iobroker/node_modules/cors
                                          npm error extraneous: cosmiconfig@7.1.0 /opt/iobroker/node_modules/cosmiconfig
                                          npm error extraneous: cpu-features@ /opt/iobroker/node_modules/cpu-features
                                          npm error extraneous: crc-32@1.2.2 /opt/iobroker/node_modules/crc-32
                                          npm error extraneous: crc@ /opt/iobroker/node_modules/crc
                                          npm error extraneous: crc32-stream@6.0.0 /opt/iobroker/node_modules/crc32-stream
                                          npm error extraneous: cross-fetch@4.0.0 /opt/iobroker/node_modules/cross-fetch
                                          npm error extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
                                          npm error extraneous: crypto-js@ /opt/iobroker/node_modules/crypto-js
                                          npm error extraneous: crypto-random-string@2.0.0 /opt/iobroker/node_modules/crypto-random-string
                                          npm error extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
                                          npm error extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
                                          npm error extraneous: dashdash@1.14.1 /opt/iobroker/node_modules/dashdash
                                          npm error extraneous: data-urls@4.0.0 /opt/iobroker/node_modules/data-urls
                                          npm error extraneous: data-view-buffer@1.0.1 /opt/iobroker/node_modules/data-view-buffer
                                          npm error extraneous: data-view-byte-length@1.0.1 /opt/iobroker/node_modules/data-view-byte-length
                                          npm error extraneous: data-view-byte-offset@1.0.0 /opt/iobroker/node_modules/data-view-byte-offset
                                          npm error extraneous: date-and-time@ /opt/iobroker/node_modules/date-and-time
                                          npm error extraneous: date-fns@1.30.1 /opt/iobroker/node_modules/date-fns
                                          npm error extraneous: dateformat@4.6.3 /opt/iobroker/node_modules/dateformat
                                          npm error extraneous: dayjs@ /opt/iobroker/node_modules/dayjs
                                          npm error extraneous: decache@4.6.2 /opt/iobroker/node_modules/decache
                                          npm error extraneous: decamelize-keys@1.1.1 /opt/iobroker/node_modules/decamelize-keys
                                          npm error extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
                                          npm error extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
                                          npm error extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
                                          npm error extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
                                          npm error extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is
                                          npm error extraneous: defer-to-connect@2.0.1 /opt/iobroker/node_modules/defer-to-connect
                                          npm error extraneous: define-lazy-prop@2.0.0 /opt/iobroker/node_modules/define-lazy-prop
                                          npm error extraneous: del@6.1.1 /opt/iobroker/node_modules/del
                                          npm error extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
                                          npm error extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
                                          npm error extraneous: destroy@1.2.0 /opt/iobroker/node_modules/destroy
                                          npm error extraneous: detect-libc@2.0.3 /opt/iobroker/node_modules/detect-libc
                                          npm error extraneous: diacritics@1.3.0 /opt/iobroker/node_modules/diacritics
                                          npm error extraneous: digest-header@1.1.0 /opt/iobroker/node_modules/digest-header
                                          npm error extraneous: dir-glob@3.0.1 /opt/iobroker/node_modules/dir-glob
                                          npm error extraneous: diskusage@1.2.0 /opt/iobroker/node_modules/diskusage
                                          npm error extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception
                                          npm error extraneous: dot-prop@6.0.1 /opt/iobroker/node_modules/dot-prop
                                          npm error extraneous: draftlog@1.0.13 /opt/iobroker/node_modules/draftlog
                                          npm error extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
                                          npm error extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
                                          npm error extraneous: duplexer3@0.1.5 /opt/iobroker/node_modules/duplexer3
                                          npm error extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/duplexify
                                          npm error extraneous: eastasianwidth@0.2.0 /opt/iobroker/node_modules/eastasianwidth
                                          npm error extraneous: ecc-jsbn@0.1.2 /opt/iobroker/node_modules/ecc-jsbn
                                          npm error extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
                                          npm error extraneous: echarts@ /opt/iobroker/node_modules/echarts
                                          npm error extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/ee-first
                                          npm error extraneous: elegant-spinner@1.0.1 /opt/iobroker/node_modules/elegant-spinner
                                          npm error extraneous: emoji-regex@9.2.2 /opt/iobroker/node_modules/emoji-regex
                                          npm error extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
                                          npm error extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/encodeurl
                                          npm error extraneous: encoding@0.1.13 /opt/iobroker/node_modules/encoding
                                          npm error extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/end-of-stream
                                          npm error extraneous: entities@4.5.0 /opt/iobroker/node_modules/entities
                                          npm error extraneous: err-code@2.0.3 /opt/iobroker/node_modules/err-code
                                          npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
                                          npm error extraneous: es-aggregate-error@1.0.13 /opt/iobroker/node_modules/es-aggregate-error
                                          npm error extraneous: es-object-atoms@1.0.0 /opt/iobroker/node_modules/es-object-atoms
                                          npm error extraneous: es-set-tostringtag@2.0.3 /opt/iobroker/node_modules/es-set-tostringtag
                                          npm error extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
                                          npm error extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
                                          npm error extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
                                          npm error extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
                                          npm error extraneous: escalade@3.1.2 /opt/iobroker/node_modules/escalade
                                          npm error extraneous: escape-goat@3.0.0 /opt/iobroker/node_modules/escape-goat
                                          npm error extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/escape-html
                                          npm error extraneous: escape-string-regexp@4.0.0 /opt/iobroker/node_modules/escape-string-regexp
                                          npm error extraneous: escodegen@1.14.3 /opt/iobroker/node_modules/escodegen
                                          npm error extraneous: esprima@1.2.2 /opt/iobroker/node_modules/esprima
                                          npm error extraneous: estraverse@4.3.0 /opt/iobroker/node_modules/estraverse
                                          npm error extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils
                                          npm error extraneous: etag@1.8.1 /opt/iobroker/node_modules/etag
                                          npm error extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
                                          npm error extraneous: event-target-shim@5.0.1 /opt/iobroker/node_modules/event-target-shim
                                          npm error extraneous: eventemitter2@6.4.9 /opt/iobroker/node_modules/eventemitter2
                                          npm error extraneous: events@3.3.0 /opt/iobroker/node_modules/events
                                          npm error extraneous: execa@5.1.1 /opt/iobroker/node_modules/execa
                                          npm error extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
                                          npm error extraneous: express-fileupload@1.5.1 /opt/iobroker/node_modules/express-fileupload
                                          npm error extraneous: express@4.19.2 /opt/iobroker/node_modules/express
                                          npm error extraneous: external-editor@3.1.0 /opt/iobroker/node_modules/external-editor
                                          npm error extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
                                          npm error extraneous: fast-fifo@1.3.2 /opt/iobroker/node_modules/fast-fifo
                                          npm error extraneous: fast-glob@ /opt/iobroker/node_modules/fast-glob
                                          npm error extraneous: fast-json-stable-stringify@2.1.0 /opt/iobroker/node_modules/fast-json-stable-stringify
                                          npm error extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein
                                          npm error extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
                                          npm error extraneous: fast-unique-numbers@ /opt/iobroker/node_modules/fast-unique-numbers
                                          npm error extraneous: fast-uri@3.0.1 /opt/iobroker/node_modules/fast-uri
                                          npm error extraneous: fast-xml-parser@ /opt/iobroker/node_modules/fast-xml-parser
                                          npm error extraneous: fastq@1.17.1 /opt/iobroker/node_modules/fastq
                                          npm error extraneous: fastseries@2.0.0 /opt/iobroker/node_modules/fastseries
                                          npm error extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
                                          npm error extraneous: figures@3.2.0 /opt/iobroker/node_modules/figures
                                          npm error extraneous: file-stream-rotator@0.6.1 /opt/iobroker/node_modules/file-stream-rotator
                                          npm error extraneous: file-type@10.11.0 /opt/iobroker/node_modules/file-type
                                          npm error extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
                                          npm error extraneous: fill-range@7.1.1 /opt/iobroker/node_modules/fill-range
                                          npm error extraneous: finalhandler@1.2.0 /opt/iobroker/node_modules/finalhandler
                                          npm error extraneous: find-up@5.0.0 /opt/iobroker/node_modules/find-up
                                          npm error extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
                                          npm error extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
                                          npm error extraneous: foreground-child@3.3.0 /opt/iobroker/node_modules/foreground-child
                                          npm error extraneous: form-data-encoder@2.1.4 /opt/iobroker/node_modules/form-data-encoder
                                          npm error extraneous: form-data@4.0.0 /opt/iobroker/node_modules/form-data
                                          npm error extraneous: forwarded@0.2.0 /opt/iobroker/node_modules/forwarded
                                          npm error extraneous: fresh@0.5.2 /opt/iobroker/node_modules/fresh
                                          npm error extraneous: from@0.1.7 /opt/iobroker/node_modules/from
                                          npm error extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
                                          npm error extraneous: fs-minipass@2.1.0 /opt/iobroker/node_modules/fs-minipass
                                          npm error extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
                                          npm error extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
                                          npm error extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
                                          npm error extraneous: function.prototype.name@1.1.6 /opt/iobroker/node_modules/function.prototype.name
                                          npm error extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
                                          npm error extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
                                          npm error extraneous: gauge@3.0.2 /opt/iobroker/node_modules/gauge
                                          npm error extraneous: gaxios@5.1.3 /opt/iobroker/node_modules/gaxios
                                          npm error extraneous: gcp-metadata@5.3.0 /opt/iobroker/node_modules/gcp-metadata
                                          npm error extraneous: generate-function@2.3.1 /opt/iobroker/node_modules/generate-function
                                          npm error extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ssl-certificate
                                          npm error extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/get-stream
                                          npm error extraneous: get-symbol-description@1.0.2 /opt/iobroker/node_modules/get-symbol-description
                                          npm error extraneous: getpass@0.1.7 /opt/iobroker/node_modules/getpass
                                          npm error extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
                                          npm error extraneous: github-url-from-git@1.5.0 /opt/iobroker/node_modules/github-url-from-git
                                          npm error extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/glob-parent
                                          npm error extraneous: glob@10.4.5 /opt/iobroker/node_modules/glob
                                          npm error extraneous: global-dirs@2.1.0 /opt/iobroker/node_modules/global-dirs
                                          npm error extraneous: globalthis@1.0.4 /opt/iobroker/node_modules/globalthis
                                          npm error extraneous: globby@11.1.0 /opt/iobroker/node_modules/globby
                                          npm error extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
                                          npm error extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
                                          npm error extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
                                          npm error extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
                                          npm error extraneous: googleapis@ /opt/iobroker/node_modules/googleapis
                                          npm error extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
                                          npm error extraneous: hard-rejection@2.1.0 /opt/iobroker/node_modules/hard-rejection
                                          npm error extraneous: has-ansi@2.0.0 /opt/iobroker/node_modules/has-ansi
                                          npm error extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
                                          npm error extraneous: has-flag@4.0.0 /opt/iobroker/node_modules/has-flag
                                          npm error extraneous: has-tostringtag@1.0.2 /opt/iobroker/node_modules/has-tostringtag
                                          npm error extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
                                          npm error extraneous: has-yarn@2.1.0 /opt/iobroker/node_modules/has-yarn
                                          npm error extraneous: he@1.2.0 /opt/iobroker/node_modules/he
                                          npm error extraneous: help-me@5.0.0 /opt/iobroker/node_modules/help-me
                                          npm error extraneous: homebridge-plugin-wrapper@ /opt/iobroker/node_modules/homebridge-plugin-wrapper
                                          npm error extraneous: hosted-git-info@3.0.8 /opt/iobroker/node_modules/hosted-git-info
                                          npm error extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
                                          npm error extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
                                          npm error extraneous: http-cache-semantics@4.1.1 /opt/iobroker/node_modules/http-cache-semantics
                                          npm error extraneous: http-errors@2.0.0 /opt/iobroker/node_modules/http-errors
                                          npm error extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
                                          npm error extraneous: http2-wrapper@1.0.3 /opt/iobroker/node_modules/http2-wrapper
                                          npm error extraneous: https@1.0.0 /opt/iobroker/node_modules/https
                                          npm error extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
                                          npm error extraneous: ical.js@ /opt/iobroker/node_modules/ical.js
                                          npm error extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/iconv-lite
                                          npm error extraneous: ieee754@1.2.1 /opt/iobroker/node_modules/ieee754
                                          npm error extraneous: ignore-walk@3.0.4 /opt/iobroker/node_modules/ignore-walk
                                          npm error extraneous: ignore@5.3.2 /opt/iobroker/node_modules/ignore
                                          npm error extraneous: image-type@4.1.0 /opt/iobroker/node_modules/image-type
                                          npm error extraneous: immediate@3.0.6 /opt/iobroker/node_modules/immediate
                                          npm error extraneous: import-fresh@3.3.0 /opt/iobroker/node_modules/import-fresh
                                          npm error extraneous: import-lazy@2.1.0 /opt/iobroker/node_modules/import-lazy
                                          npm error extraneous: import-local@3.2.0 /opt/iobroker/node_modules/import-local
                                          npm error extraneous: imurmurhash@0.1.4 /opt/iobroker/node_modules/imurmurhash
                                          npm error extraneous: indent-string@3.2.0 /opt/iobroker/node_modules/indent-string
                                          npm error extraneous: infer-owner@1.0.4 /opt/iobroker/node_modules/infer-owner
                                          npm error extraneous: inflight@1.0.6 /opt/iobroker/node_modules/inflight
                                          npm error extraneous: ini@1.3.7 /opt/iobroker/node_modules/ini
                                          npm error extraneous: inquirer-autosubmit-prompt@0.2.0 /opt/iobroker/node_modules/inquirer-autosubmit-prompt
                                          npm error extraneous: inquirer@7.3.3 /opt/iobroker/node_modules/inquirer
                                          npm error extraneous: int64-buffer@1.0.1 /opt/iobroker/node_modules/int64-buffer
                                          npm error extraneous: internal-slot@1.0.7 /opt/iobroker/node_modules/internal-slot
                                          npm error extraneous: iobroker-adapter-helpers@0.0.8 /opt/iobroker/node_modules/iobroker-adapter-helpers
                                          npm error invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
                                          npm error invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
                                          npm error invalid: iobroker.calendar@ /opt/iobroker/node_modules/iobroker.calendar
                                          npm error invalid: iobroker.discovery@ /opt/iobroker/node_modules/iobroker.discovery
                                          npm error invalid: iobroker.echarts@ /opt/iobroker/node_modules/iobroker.echarts
                                          npm error invalid: iobroker.energiefluss@ /opt/iobroker/node_modules/iobroker.energiefluss
                                          npm error invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
                                          npm error invalid: iobroker.fullcalendar@ /opt/iobroker/node_modules/iobroker.fullcalendar
                                          npm error invalid: iobroker.gartenbewaesserung@ /opt/iobroker/node_modules/iobroker.gartenbewaesserung
                                          npm error invalid: iobroker.ham@ /opt/iobroker/node_modules/iobroker.ham
                                          npm error invalid: iobroker.heatingcontrol@ /opt/iobroker/node_modules/iobroker.heatingcontrol
                                          npm error invalid: iobroker.ical@ /opt/iobroker/node_modules/iobroker.ical
                                          npm error invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
                                          npm error invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
                                          npm error invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
                                          npm error invalid: iobroker.material@ /opt/iobroker/node_modules/iobroker.material
                                          npm error invalid: iobroker.milight-smart-light@ /opt/iobroker/node_modules/iobroker.milight-smart-light
                                          npm error invalid: iobroker.mobile@ /opt/iobroker/node_modules/iobroker.mobile
                                          npm error invalid: iobroker.modbus@ /opt/iobroker/node_modules/iobroker.modbus
                                          npm error invalid: iobroker.mqtt@ /opt/iobroker/node_modules/iobroker.mqtt
                                          npm error invalid: iobroker.nina@ /opt/iobroker/node_modules/iobroker.nina
                                          npm error invalid: iobroker.renault@ /opt/iobroker/node_modules/iobroker.renault
                                          npm error invalid: iobroker.reolink@ /opt/iobroker/node_modules/iobroker.reolink
                                          npm error invalid: iobroker.schoolfree@ /opt/iobroker/node_modules/iobroker.schoolfree
                                          npm error invalid: iobroker.sourceanalytix@ /opt/iobroker/node_modules/iobroker.sourceanalytix
                                          npm error invalid: iobroker.synology@ /opt/iobroker/node_modules/iobroker.synology
                                          npm error invalid: iobroker.tankerkoenig@ /opt/iobroker/node_modules/iobroker.tankerkoenig
                                          npm error invalid: iobroker.terminal@ /opt/iobroker/node_modules/iobroker.terminal
                                          npm error invalid: iobroker.unifi@ /opt/iobroker/node_modules/iobroker.unifi
                                          npm error invalid: iobroker.viessmannapi@ /opt/iobroker/node_modules/iobroker.viessmannapi
                                          npm error invalid: iobroker.virtualpowermeter@ /opt/iobroker/node_modules/iobroker.virtualpowermeter
                                          npm error invalid: iobroker.vis-2-widgets-material@ /opt/iobroker/node_modules/iobroker.vis-2-widgets-material
                                          npm error invalid: iobroker.vis-2@ /opt/iobroker/node_modules/iobroker.vis-2
                                          npm error invalid: iobroker.vis-colorpicker@ /opt/iobroker/node_modules/iobroker.vis-colorpicker
                                          npm error invalid: iobroker.vis-hqwidgets@ /opt/iobroker/node_modules/iobroker.vis-hqwidgets
                                          npm error invalid: iobroker.vis-inventwo@ /opt/iobroker/node_modules/iobroker.vis-inventwo
                                          npm error invalid: iobroker.vis-materialdesign@ /opt/iobroker/node_modules/iobroker.vis-materialdesign
                                          npm error invalid: iobroker.vis-metro@ /opt/iobroker/node_modules/iobroker.vis-metro
                                          npm error invalid: iobroker.vis-timeandweather@ /opt/iobroker/node_modules/iobroker.vis-timeandweather
                                          npm error invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
                                          npm error invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
                                          npm error invalid: iobroker.vofo-speedtest@ /opt/iobroker/node_modules/iobroker.vofo-speedtest
                                          npm error invalid: iobroker.web-speedy@ /opt/iobroker/node_modules/iobroker.web-speedy
                                          npm error invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
                                          npm error invalid: iobroker.webcal@ /opt/iobroker/node_modules/iobroker.webcal
                                          npm error extraneous: ioredis@ /opt/iobroker/node_modules/ioredis
                                          npm error extraneous: ip-address@9.0.5 /opt/iobroker/node_modules/ip-address
                                          npm error extraneous: ip-regex@4.3.0 /opt/iobroker/node_modules/ip-regex
                                          npm error extraneous: ipaddr.js@2.2.0 /opt/iobroker/node_modules/ipaddr.js
                                          npm error extraneous: is-array-buffer@3.0.4 /opt/iobroker/node_modules/is-array-buffer
                                          npm error extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
                                          npm error extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
                                          npm error extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
                                          npm error extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
                                          npm error extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
                                          npm error extraneous: is-ci@2.0.0 /opt/iobroker/node_modules/is-ci
                                          npm error extraneous: is-core-module@2.15.0 /opt/iobroker/node_modules/is-core-module
                                          npm error extraneous: is-data-view@1.0.1 /opt/iobroker/node_modules/is-data-view
                                          npm error extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
                                          npm error extraneous: is-docker@2.2.1 /opt/iobroker/node_modules/is-docker
                                          npm error extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
                                          npm error extraneous: is-extglob@2.1.1 /opt/iobroker/node_modules/is-extglob
                                          npm error extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/is-fullwidth-code-point
                                          npm error extraneous: is-glob@4.0.3 /opt/iobroker/node_modules/is-glob
                                          npm error extraneous: is-installed-globally@0.3.2 /opt/iobroker/node_modules/is-installed-globally
                                          npm error extraneous: is-interactive@1.0.0 /opt/iobroker/node_modules/is-interactive
                                          npm error extraneous: is-lambda@1.0.1 /opt/iobroker/node_modules/is-lambda
                                          npm error extraneous: is-negative-zero@2.0.3 /opt/iobroker/node_modules/is-negative-zero
                                          npm error extraneous: is-npm@5.0.0 /opt/iobroker/node_modules/is-npm
                                          npm error extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
                                          npm error extraneous: is-number@7.0.0 /opt/iobroker/node_modules/is-number
                                          npm error extraneous: is-obj@2.0.0 /opt/iobroker/node_modules/is-obj
                                          npm error extraneous: is-observable@1.1.0 /opt/iobroker/node_modules/is-observable
                                          npm error extraneous: is-path-cwd@2.2.0 /opt/iobroker/node_modules/is-path-cwd
                                          npm error extraneous: is-path-inside@3.0.3 /opt/iobroker/node_modules/is-path-inside
                                          npm error extraneous: is-plain-obj@1.1.0 /opt/iobroker/node_modules/is-plain-obj
                                          npm error extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
                                          npm error extraneous: is-promise@2.2.2 /opt/iobroker/node_modules/is-promise
                                          npm error extraneous: is-property@1.0.2 /opt/iobroker/node_modules/is-property
                                          npm error extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
                                          npm error extraneous: is-scoped@2.1.0 /opt/iobroker/node_modules/is-scoped
                                          npm error extraneous: is-shared-array-buffer@1.0.3 /opt/iobroker/node_modules/is-shared-array-buffer
                                          npm error extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
                                          npm error extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
                                          npm error extraneous: is-typed-array@1.1.13 /opt/iobroker/node_modules/is-typed-array
                                          npm error extraneous: is-unicode-supported@0.1.0 /opt/iobroker/node_modules/is-unicode-supported
                                          npm error extraneous: is-url-superb@4.0.0 /opt/iobroker/node_modules/is-url-superb
                                          npm error extraneous: is-url@1.2.4 /opt/iobroker/node_modules/is-url
                                          npm error extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
                                          npm error extraneous: is-wsl@2.2.0 /opt/iobroker/node_modules/is-wsl
                                          npm error extraneous: is-yarn-global@0.3.0 /opt/iobroker/node_modules/is-yarn-global
                                          npm error extraneous: is@3.3.0 /opt/iobroker/node_modules/is
                                          npm error extraneous: is2@2.0.9 /opt/iobroker/node_modules/is2
                                          npm error extraneous: isomorphic-ws@4.0.1 /opt/iobroker/node_modules/isomorphic-ws
                                          npm error extraneous: issue-regex@3.1.0 /opt/iobroker/node_modules/issue-regex
                                          npm error extraneous: jackspeak@3.4.3 /opt/iobroker/node_modules/jackspeak
                                          npm error extraneous: js-md4@0.3.2 /opt/iobroker/node_modules/js-md4
                                          npm error extraneous: js-sdsl@4.3.0 /opt/iobroker/node_modules/js-sdsl
                                          npm error extraneous: js-tokens@4.0.0 /opt/iobroker/node_modules/js-tokens
                                          npm error extraneous: js-yaml@ /opt/iobroker/node_modules/js-yaml
                                          npm error extraneous: jsbi@4.3.0 /opt/iobroker/node_modules/jsbi
                                          npm error extraneous: jsbn@1.1.0 /opt/iobroker/node_modules/jsbn
                                          npm error extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
                                          npm error extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
                                          npm error extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/json-buffer
                                          npm error extraneous: json-logic-js@2.0.5 /opt/iobroker/node_modules/json-logic-js
                                          npm error extraneous: json-parse-even-better-errors@2.3.1 /opt/iobroker/node_modules/json-parse-even-better-errors
                                          npm error extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse
                                          npm error extraneous: json5@2.2.3 /opt/iobroker/node_modules/json5
                                          npm error extraneous: jsonata@ /opt/iobroker/node_modules/jsonata
                                          npm error extraneous: jsonc-parser@3.3.1 /opt/iobroker/node_modules/jsonc-parser
                                          npm error extraneous: jsonwebtoken@9.0.2 /opt/iobroker/node_modules/jsonwebtoken
                                          npm error extraneous: jszip@ /opt/iobroker/node_modules/jszip
                                          npm error extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
                                          npm error extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
                                          npm error extraneous: keyv@4.5.4 /opt/iobroker/node_modules/keyv
                                          npm error extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/kind-of
                                          npm error extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
                                          npm error extraneous: later@1.2.0 /opt/iobroker/node_modules/later
                                          npm error extraneous: latest-version@5.1.0 /opt/iobroker/node_modules/latest-version
                                          npm error extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
                                          npm error extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/lazystream
                                          npm error extraneous: leven@2.1.0 /opt/iobroker/node_modules/leven
                                          npm error extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn
                                          npm error extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
                                          npm error extraneous: lines-and-columns@1.2.4 /opt/iobroker/node_modules/lines-and-columns
                                          npm error extraneous: listr-input@0.2.1 /opt/iobroker/node_modules/listr-input
                                          npm error extraneous: listr-silent-renderer@1.1.1 /opt/iobroker/node_modules/listr-silent-renderer
                                          npm error extraneous: listr-update-renderer@0.5.0 /opt/iobroker/node_modules/listr-update-renderer
                                          npm error extraneous: listr-verbose-renderer@0.5.0 /opt/iobroker/node_modules/listr-verbose-renderer
                                          npm error extraneous: listr@0.14.3 /opt/iobroker/node_modules/listr
                                          npm error extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
                                          npm error extraneous: locate-path@6.0.0 /opt/iobroker/node_modules/locate-path
                                          npm error extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
                                          npm error extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
                                          npm error extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
                                          npm error extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
                                          npm error extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
                                          npm error extraneous: lodash.isequal@4.5.0 /opt/iobroker/node_modules/lodash.isequal
                                          npm error extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
                                          npm error extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
                                          npm error extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
                                          npm error extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
                                          npm error extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
                                          npm error extraneous: lodash.zip@4.2.0 /opt/iobroker/node_modules/lodash.zip
                                          npm error extraneous: log-symbols@4.1.0 /opt/iobroker/node_modules/log-symbols
                                          npm error extraneous: log-update@2.3.0 /opt/iobroker/node_modules/log-update
                                          npm error extraneous: logform@ /opt/iobroker/node_modules/logform
                                          npm error extraneous: long@5.2.3 /opt/iobroker/node_modules/long
                                          npm error extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/lowercase-keys
                                          npm error extraneous: lru_map@0.3.3 /opt/iobroker/node_modules/lru_map
                                          npm error extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/lru-cache
                                          npm error extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
                                          npm error extraneous: make-fetch-happen@10.2.1 /opt/iobroker/node_modules/make-fetch-happen
                                          npm error extraneous: map-age-cleaner@0.1.3 /opt/iobroker/node_modules/map-age-cleaner
                                          npm error extraneous: map-obj@4.3.0 /opt/iobroker/node_modules/map-obj
                                          npm error extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
                                          npm error extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
                                          npm error extraneous: media-typer@0.3.0 /opt/iobroker/node_modules/media-typer
                                          npm error extraneous: meow@8.1.2 /opt/iobroker/node_modules/meow
                                          npm error extraneous: merge-descriptors@1.0.1 /opt/iobroker/node_modules/merge-descriptors
                                          npm error extraneous: merge2@1.4.1 /opt/iobroker/node_modules/merge2
                                          npm error extraneous: methods@1.1.2 /opt/iobroker/node_modules/methods
                                          npm error extraneous: micro@9.4.1 /opt/iobroker/node_modules/micro
                                          npm error extraneous: micromatch@4.0.7 /opt/iobroker/node_modules/micromatch
                                          npm error extraneous: mime-db@1.53.0 /opt/iobroker/node_modules/mime-db
                                          npm error extraneous: mimic-response@1.0.1 /opt/iobroker/node_modules/mimic-response
                                          npm error extraneous: min-indent@1.0.1 /opt/iobroker/node_modules/min-indent
                                          npm error extraneous: minimatch@9.0.5 /opt/iobroker/node_modules/minimatch
                                          npm error extraneous: minimist-options@4.1.0 /opt/iobroker/node_modules/minimist-options
                                          npm error extraneous: minipass-collect@1.0.2 /opt/iobroker/node_modules/minipass-collect
                                          npm error extraneous: minipass-fetch@2.1.2 /opt/iobroker/node_modules/minipass-fetch
                                          npm error extraneous: minipass-flush@1.0.5 /opt/iobroker/node_modules/minipass-flush
                                          npm error extraneous: minipass-pipeline@1.2.4 /opt/iobroker/node_modules/minipass-pipeline
                                          npm error extraneous: minipass-sized@1.0.3 /opt/iobroker/node_modules/minipass-sized
                                          npm error extraneous: minipass@7.1.2 /opt/iobroker/node_modules/minipass
                                          npm error extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/minizlib
                                          npm error extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
                                          npm error extraneous: mkdirp@1.0.4 /opt/iobroker/node_modules/mkdirp
                                          npm error extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
                                          npm error extraneous: moment-duration-format@2.3.2 /opt/iobroker/node_modules/moment-duration-format
                                          npm error extraneous: mqtt-connection@4.1.0 /opt/iobroker/node_modules/mqtt-connection
                                          npm error extraneous: mqtt-packet@9.0.0 /opt/iobroker/node_modules/mqtt-packet
                                          npm error extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
                                          npm error extraneous: mute-stream@0.0.8 /opt/iobroker/node_modules/mute-stream
                                          npm error extraneous: named-placeholders@1.1.3 /opt/iobroker/node_modules/named-placeholders
                                          npm error extraneous: nan@ /opt/iobroker/node_modules/nan
                                          npm error extraneous: nanoid@3.3.7 /opt/iobroker/node_modules/nanoid
                                          npm error extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
                                          npm error extraneous: native-duplexpair@1.0.0 /opt/iobroker/node_modules/native-duplexpair
                                          npm error extraneous: nconf@0.10.0 /opt/iobroker/node_modules/nconf
                                          npm error extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
                                          npm error extraneous: netmask@2.0.2 /opt/iobroker/node_modules/netmask
                                          npm error extraneous: new-github-release-url@1.0.0 /opt/iobroker/node_modules/new-github-release-url
                                          npm error extraneous: node-abi@3.65.0 /opt/iobroker/node_modules/node-abi
                                          npm error extraneous: node-abort-controller@3.1.1 /opt/iobroker/node_modules/node-abort-controller
                                          npm error extraneous: node-cron@2.0.3 /opt/iobroker/node_modules/node-cron
                                          npm error extraneous: node-fetch@2.7.0 /opt/iobroker/node_modules/node-fetch
                                          npm error extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
                                          npm error extraneous: node-gyp@ /opt/iobroker/node_modules/node-gyp
                                          npm error extraneous: node-ical@0.16.1 /opt/iobroker/node_modules/node-ical
                                          npm error extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                                          npm error extraneous: node-libcurl@3.0.0 /opt/iobroker/node_modules/node-libcurl
                                          npm error extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
                                          npm error extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
                                          npm error extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
                                          npm error extraneous: node-unifi@2.5.1 /opt/iobroker/node_modules/node-unifi
                                          npm error extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
                                          npm error extraneous: node.extend@2.0.3 /opt/iobroker/node_modules/node.extend
                                          npm error extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
                                          npm error extraneous: normalize-package-data@3.0.3 /opt/iobroker/node_modules/normalize-package-data
                                          npm error extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
                                          npm error extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/normalize-url
                                          npm error extraneous: np@7.7.0 /opt/iobroker/node_modules/np
                                          npm error extraneous: npm-name@6.0.1 /opt/iobroker/node_modules/npm-name
                                          npm error extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
                                          npm error extraneous: number-allocator@1.0.14 /opt/iobroker/node_modules/number-allocator
                                          npm error extraneous: nwsapi@2.2.12 /opt/iobroker/node_modules/nwsapi
                                          npm error extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assign
                                          npm error extraneous: object-hash@3.0.0 /opt/iobroker/node_modules/object-hash
                                          npm error extraneous: on-finished@2.4.1 /opt/iobroker/node_modules/on-finished
                                          npm error extraneous: once@1.4.0 /opt/iobroker/node_modules/once
                                          npm error extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
                                          npm error extraneous: onedrive-api@1.1.1 /opt/iobroker/node_modules/onedrive-api
                                          npm error extraneous: open@7.4.2 /opt/iobroker/node_modules/open
                                          npm error extraneous: opencollective-postinstall@2.0.3 /opt/iobroker/node_modules/opencollective-postinstall
                                          npm error extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator
                                          npm error extraneous: org-regex@1.0.0 /opt/iobroker/node_modules/org-regex
                                          npm error extraneous: os-tmpdir@1.0.2 /opt/iobroker/node_modules/os-tmpdir
                                          npm error extraneous: ospath@1.2.2 /opt/iobroker/node_modules/ospath
                                          npm error extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
                                          npm error extraneous: otplib@11.0.1 /opt/iobroker/node_modules/otplib
                                          npm error extraneous: ow@0.21.0 /opt/iobroker/node_modules/ow
                                          npm error extraneous: p-cancelable@2.1.1 /opt/iobroker/node_modules/p-cancelable
                                          npm error extraneous: p-defer@1.0.0 /opt/iobroker/node_modules/p-defer
                                          npm error extraneous: p-event@4.2.0 /opt/iobroker/node_modules/p-event
                                          npm error extraneous: p-finally@1.0.0 /opt/iobroker/node_modules/p-finally
                                          npm error extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/p-limit
                                          npm error extraneous: p-locate@5.0.0 /opt/iobroker/node_modules/p-locate
                                          npm error extraneous: p-map@2.1.0 /opt/iobroker/node_modules/p-map
                                          npm error extraneous: p-memoize@4.0.4 /opt/iobroker/node_modules/p-memoize
                                          npm error extraneous: p-reflect@2.1.0 /opt/iobroker/node_modules/p-reflect
                                          npm error extraneous: p-settle@4.1.1 /opt/iobroker/node_modules/p-settle
                                          npm error extraneous: p-throttle@4.1.1 /opt/iobroker/node_modules/p-throttle
                                          npm error extraneous: p-timeout@4.1.0 /opt/iobroker/node_modules/p-timeout
                                          npm error extraneous: p-try@2.2.0 /opt/iobroker/node_modules/p-try
                                          npm error extraneous: package-json-from-dist@1.0.0 /opt/iobroker/node_modules/package-json-from-dist
                                          npm error extraneous: package-json@6.5.0 /opt/iobroker/node_modules/package-json
                                          npm error extraneous: pako@ /opt/iobroker/node_modules/pako
                                          npm error extraneous: parent-module@1.0.1 /opt/iobroker/node_modules/parent-module
                                          npm error extraneous: parse-json@5.2.0 /opt/iobroker/node_modules/parse-json
                                          npm error extraneous: parse5@ /opt/iobroker/node_modules/parse5
                                          npm error extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
                                          npm error extraneous: passport@0.7.0 /opt/iobroker/node_modules/passport
                                          npm error extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/path-exists
                                          npm error extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
                                          npm error extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
                                          npm error extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
                                          npm error extraneous: path-scurry@1.11.1 /opt/iobroker/node_modules/path-scurry
                                          npm error extraneous: path-to-regexp@0.1.7 /opt/iobroker/node_modules/path-to-regexp
                                          npm error extraneous: path-type@4.0.0 /opt/iobroker/node_modules/path-type
                                          npm error extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
                                          npm error extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/picomatch
                                          npm error extraneous: pidtree@0.6.0 /opt/iobroker/node_modules/pidtree
                                          npm error extraneous: pidusage@3.0.2 /opt/iobroker/node_modules/pidusage
                                          npm error extraneous: ping@0.4.4 /opt/iobroker/node_modules/ping
                                          npm error extraneous: pkg-dir@5.0.0 /opt/iobroker/node_modules/pkg-dir
                                          npm error extraneous: pluralize@8.0.0 /opt/iobroker/node_modules/pluralize
                                          npm error extraneous: possible-typed-array-names@1.0.0 /opt/iobroker/node_modules/possible-typed-array-names
                                          npm error extraneous: prebuild-install@7.1.2 /opt/iobroker/node_modules/prebuild-install
                                          npm error extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls
                                          npm error extraneous: prepend-http@2.0.0 /opt/iobroker/node_modules/prepend-http
                                          npm error extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/process-nextick-args
                                          npm error extraneous: process@0.11.10 /opt/iobroker/node_modules/process
                                          npm error extraneous: promise-inflight@1.0.1 /opt/iobroker/node_modules/promise-inflight
                                          npm error extraneous: promise-object@0.1.7 /opt/iobroker/node_modules/promise-object
                                          npm error extraneous: promise-retry@2.0.1 /opt/iobroker/node_modules/promise-retry
                                          npm error extraneous: promise-retryer@0.0.1 /opt/iobroker/node_modules/promise-retryer
                                          npm error extraneous: promisify-child-process@4.1.2 /opt/iobroker/node_modules/promisify-child-process
                                          npm error extraneous: prompt@1.3.0 /opt/iobroker/node_modules/prompt
                                          npm error extraneous: protobufjs@ /opt/iobroker/node_modules/protobufjs
                                          npm error extraneous: proxy-addr@2.0.7 /opt/iobroker/node_modules/proxy-addr
                                          npm error extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
                                          npm error extraneous: pump@3.0.0 /opt/iobroker/node_modules/pump
                                          npm error extraneous: pupa@2.1.1 /opt/iobroker/node_modules/pupa
                                          npm error extraneous: q@1.1.2 /opt/iobroker/node_modules/q
                                          npm error extraneous: quasar@ /opt/iobroker/node_modules/quasar
                                          npm error extraneous: queue-microtask@1.2.3 /opt/iobroker/node_modules/queue-microtask
                                          npm error extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
                                          npm error extraneous: quick-lru@5.1.1 /opt/iobroker/node_modules/quick-lru
                                          npm error extraneous: range-parser@1.2.1 /opt/iobroker/node_modules/range-parser
                                          npm error extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/raw-body
                                          npm error extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
                                          npm error extraneous: read-pkg-up@7.0.1 /opt/iobroker/node_modules/read-pkg-up
                                          npm error extraneous: read-pkg@5.2.0 /opt/iobroker/node_modules/read-pkg
                                          npm error extraneous: read@1.0.7 /opt/iobroker/node_modules/read
                                          npm error extraneous: readable-stream@ /opt/iobroker/node_modules/readable-stream
                                          npm error extraneous: readdir-glob@1.1.3 /opt/iobroker/node_modules/readdir-glob
                                          npm error extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
                                          npm error extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
                                          npm error extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
                                          npm error extraneous: redent@3.0.0 /opt/iobroker/node_modules/redent
                                          npm error extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
                                          npm error extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
                                          npm error extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
                                          npm error extraneous: regenerator-runtime@0.14.1 /opt/iobroker/node_modules/regenerator-runtime
                                          npm error extraneous: regex-escape@3.4.10 /opt/iobroker/node_modules/regex-escape
                                          npm error extraneous: regexp.prototype.flags@1.5.2 /opt/iobroker/node_modules/regexp.prototype.flags
                                          npm error extraneous: registry-auth-token@4.2.2 /opt/iobroker/node_modules/registry-auth-token
                                          npm error extraneous: registry-url@5.1.0 /opt/iobroker/node_modules/registry-url
                                          npm error extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
                                          npm error extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
                                          npm error extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string
                                          npm error extraneous: resolve-alpn@1.2.1 /opt/iobroker/node_modules/resolve-alpn
                                          npm error extraneous: resolve-cwd@3.0.0 /opt/iobroker/node_modules/resolve-cwd
                                          npm error extraneous: resolve-from@4.0.0 /opt/iobroker/node_modules/resolve-from
                                          npm error extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
                                          npm error extraneous: responselike@2.0.1 /opt/iobroker/node_modules/responselike
                                          npm error extraneous: restore-cursor@3.1.0 /opt/iobroker/node_modules/restore-cursor
                                          npm error extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
                                          npm error extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
                                          npm error extraneous: reusify@1.0.4 /opt/iobroker/node_modules/reusify
                                          npm error extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
                                          npm error extraneous: rfdc@1.4.1 /opt/iobroker/node_modules/rfdc
                                          npm error extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/rimraf
                                          npm error extraneous: rrule@2.8.1 /opt/iobroker/node_modules/rrule
                                          npm error extraneous: rrweb-cssom@0.6.0 /opt/iobroker/node_modules/rrweb-cssom
                                          npm error extraneous: run-async@2.4.1 /opt/iobroker/node_modules/run-async
                                          npm error extraneous: run-parallel@1.2.0 /opt/iobroker/node_modules/run-parallel
                                          npm error extraneous: rxjs@ /opt/iobroker/node_modules/rxjs
                                          npm error extraneous: safe-array-concat@1.1.2 /opt/iobroker/node_modules/safe-array-concat
                                          npm error extraneous: safe-regex-test@1.0.3 /opt/iobroker/node_modules/safe-regex-test
                                          npm error extraneous: safe-stable-stringify@2.4.3 /opt/iobroker/node_modules/safe-stable-stringify
                                          npm error extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/safer-buffer
                                          npm error extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
                                          npm error extraneous: scoped-regex@2.1.0 /opt/iobroker/node_modules/scoped-regex
                                          npm error extraneous: secure-keys@1.0.0 /opt/iobroker/node_modules/secure-keys
                                          npm error extraneous: semver-diff@3.1.1 /opt/iobroker/node_modules/semver-diff
                                          npm error extraneous: send@0.18.0 /opt/iobroker/node_modules/send
                                          npm error extraneous: seq-logging@1.1.2 /opt/iobroker/node_modules/seq-logging
                                          npm error extraneous: seq-queue@0.0.5 /opt/iobroker/node_modules/seq-queue
                                          npm error extraneous: serve-static@1.15.0 /opt/iobroker/node_modules/serve-static
                                          npm error extraneous: set-function-name@2.0.2 /opt/iobroker/node_modules/set-function-name
                                          npm error extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
                                          npm error extraneous: setprototypeof@1.2.0 /opt/iobroker/node_modules/setprototypeof
                                          npm error extraneous: signal-exit@4.1.0 /opt/iobroker/node_modules/signal-exit
                                          npm error extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
                                          npm error extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
                                          npm error extraneous: simple-ssh@1.1.1 /opt/iobroker/node_modules/simple-ssh
                                          npm error extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
                                          npm error extraneous: slash@3.0.0 /opt/iobroker/node_modules/slash
                                          npm error extraneous: slice-ansi@0.0.4 /opt/iobroker/node_modules/slice-ansi
                                          npm error extraneous: smart-buffer@4.2.0 /opt/iobroker/node_modules/smart-buffer
                                          npm error extraneous: socks-proxy-agent@7.0.0 /opt/iobroker/node_modules/socks-proxy-agent
                                          npm error extraneous: socks@2.8.3 /opt/iobroker/node_modules/socks
                                          npm error extraneous: speedtest-net@1.6.2 /opt/iobroker/node_modules/speedtest-net
                                          npm error extraneous: split@1.0.1 /opt/iobroker/node_modules/split
                                          npm error extraneous: sprintf-js@1.1.3 /opt/iobroker/node_modules/sprintf-js
                                          npm error extraneous: sqlstring@2.3.3 /opt/iobroker/node_modules/sqlstring
                                          npm error extraneous: ssh2@ /opt/iobroker/node_modules/ssh2
                                          npm error extraneous: ssri@9.0.1 /opt/iobroker/node_modules/ssri
                                          npm error extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
                                          npm error extraneous: stampit-event-bus@0.1.1 /opt/iobroker/node_modules/stampit-event-bus
                                          npm error extraneous: stampit-state-machine@0.2.1 /opt/iobroker/node_modules/stampit-state-machine
                                          npm error extraneous: stampit@2.1.2 /opt/iobroker/node_modules/stampit
                                          npm error extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
                                          npm error extraneous: static-eval@2.0.2 /opt/iobroker/node_modules/static-eval
                                          npm error extraneous: statuses@2.0.1 /opt/iobroker/node_modules/statuses
                                          npm error extraneous: stoppable@1.1.0 /opt/iobroker/node_modules/stoppable
                                          npm error extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
                                          npm error extraneous: stream-shift@1.0.3 /opt/iobroker/node_modules/stream-shift
                                          npm error extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
                                          npm error extraneous: streamx@2.18.0 /opt/iobroker/node_modules/streamx
                                          npm error extraneous: string-argv@0.3.2 /opt/iobroker/node_modules/string-argv
                                          npm error extraneous: string-width-cjs@npm:string-width@4.2.3 /opt/iobroker/node_modules/string-width-cjs
                                          npm error extraneous: string-width@5.1.2 /opt/iobroker/node_modules/string-width
                                          npm error extraneous: string.prototype.trim@1.2.9 /opt/iobroker/node_modules/string.prototype.trim
                                          npm error extraneous: string.prototype.trimend@1.0.8 /opt/iobroker/node_modules/string.prototype.trimend
                                          npm error extraneous: string.prototype.trimstart@1.0.8 /opt/iobroker/node_modules/string.prototype.trimstart
                                          npm error extraneous: strip-ansi-cjs@npm:strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi-cjs
                                          npm error extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi
                                          npm error extraneous: strip-indent@3.0.0 /opt/iobroker/node_modules/strip-indent
                                          npm error extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
                                          npm error extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
                                          npm error extraneous: suncalc@1.9.0 /opt/iobroker/node_modules/suncalc
                                          npm error extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                                          npm error extraneous: supermixer@1.0.5 /opt/iobroker/node_modules/supermixer
                                          npm error extraneous: supports-color@7.2.0 /opt/iobroker/node_modules/supports-color
                                          npm error extraneous: supports-hyperlinks@2.3.0 /opt/iobroker/node_modules/supports-hyperlinks
                                          npm error extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
                                          npm error extraneous: sweet-collections@1.1.0 /opt/iobroker/node_modules/sweet-collections
                                          npm error extraneous: symbol-observable@3.0.0 /opt/iobroker/node_modules/symbol-observable
                                          npm error extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
                                          npm error extraneous: syno@ /opt/iobroker/node_modules/syno
                                          npm error extraneous: systeminformation@ /opt/iobroker/node_modules/systeminformation
                                          npm error extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
                                          npm error extraneous: tar-stream@3.1.7 /opt/iobroker/node_modules/tar-stream
                                          npm error extraneous: tar@6.2.1 /opt/iobroker/node_modules/tar
                                          npm error extraneous: tarn@3.0.2 /opt/iobroker/node_modules/tarn
                                          npm error extraneous: tcp-port-used@1.0.2 /opt/iobroker/node_modules/tcp-port-used
                                          npm error extraneous: tedious@ /opt/iobroker/node_modules/tedious
                                          npm error extraneous: terminal-link@2.1.1 /opt/iobroker/node_modules/terminal-link
                                          npm error extraneous: text-decoder@1.1.1 /opt/iobroker/node_modules/text-decoder
                                          npm error extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
                                          npm error extraneous: thirty-two@1.0.2 /opt/iobroker/node_modules/thirty-two
                                          npm error extraneous: through@2.3.8 /opt/iobroker/node_modules/through
                                          npm error extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
                                          npm error extraneous: tiny-typed-emitter@2.1.0 /opt/iobroker/node_modules/tiny-typed-emitter
                                          npm error extraneous: tinycolor2@1.6.0 /opt/iobroker/node_modules/tinycolor2
                                          npm error extraneous: tmp@0.0.33 /opt/iobroker/node_modules/tmp
                                          npm error extraneous: to-readable-stream@2.1.0 /opt/iobroker/node_modules/to-readable-stream
                                          npm error extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/to-regex-range
                                          npm error extraneous: toidentifier@1.0.1 /opt/iobroker/node_modules/toidentifier
                                          npm error extraneous: tr46@4.1.1 /opt/iobroker/node_modules/tr46
                                          npm error extraneous: trim-newlines@3.0.1 /opt/iobroker/node_modules/trim-newlines
                                          npm error extraneous: triple-beam@1.4.1 /opt/iobroker/node_modules/triple-beam
                                          npm error extraneous: tsdav@ /opt/iobroker/node_modules/tsdav
                                          npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/tslib
                                          npm error extraneous: tweetnacl@0.14.5 /opt/iobroker/node_modules/tweetnacl
                                          npm error extraneous: type-check@0.3.2 /opt/iobroker/node_modules/type-check
                                          npm error extraneous: type-fest@0.21.3 /opt/iobroker/node_modules/type-fest
                                          npm error extraneous: type-is@1.6.18 /opt/iobroker/node_modules/type-is
                                          npm error extraneous: typed-array-buffer@1.0.2 /opt/iobroker/node_modules/typed-array-buffer
                                          npm error extraneous: typed-array-byte-length@1.0.1 /opt/iobroker/node_modules/typed-array-byte-length
                                          npm error extraneous: typed-array-byte-offset@1.0.2 /opt/iobroker/node_modules/typed-array-byte-offset
                                          npm error extraneous: typed-array-length@1.0.6 /opt/iobroker/node_modules/typed-array-length
                                          npm error extraneous: typedarray-to-buffer@3.1.5 /opt/iobroker/node_modules/typedarray-to-buffer
                                          npm error extraneous: typedarray.prototype.slice@1.0.3 /opt/iobroker/node_modules/typedarray.prototype.slice
                                          npm error extraneous: typescript@ /opt/iobroker/node_modules/typescript
                                          npm error extraneous: tz-offset@0.0.1 /opt/iobroker/node_modules/tz-offset
                                          npm error extraneous: uid-number@0.0.6 /opt/iobroker/node_modules/uid-number
                                          npm error extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
                                          npm error extraneous: undici-types@6.19.6 /opt/iobroker/node_modules/undici-types
                                          npm error extraneous: unique-filename@2.0.1 /opt/iobroker/node_modules/unique-filename
                                          npm error extraneous: unique-slug@3.0.0 /opt/iobroker/node_modules/unique-slug
                                          npm error extraneous: unique-string@2.0.0 /opt/iobroker/node_modules/unique-string
                                          npm error extraneous: unix-dgram@2.0.6 /opt/iobroker/node_modules/unix-dgram
                                          npm error extraneous: unpipe@1.0.0 /opt/iobroker/node_modules/unpipe
                                          npm error extraneous: update-notifier@5.1.0 /opt/iobroker/node_modules/update-notifier
                                          npm error extraneous: uri-js@4.4.1 /opt/iobroker/node_modules/uri-js
                                          npm error extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
                                          npm error extraneous: url-parse-lax@3.0.0 /opt/iobroker/node_modules/url-parse-lax
                                          npm error extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
                                          npm error extraneous: url@0.11.4 /opt/iobroker/node_modules/url
                                          npm error extraneous: vali-date@1.0.0 /opt/iobroker/node_modules/vali-date
                                          npm error extraneous: validate-npm-package-name@3.0.0 /opt/iobroker/node_modules/validate-npm-package-name
                                          npm error extraneous: vary@1.1.2 /opt/iobroker/node_modules/vary
                                          npm error extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                                          npm error extraneous: vue-i18n@ /opt/iobroker/node_modules/vue-i18n
                                          npm error extraneous: vuelidate-messages@0.1.2 /opt/iobroker/node_modules/vuelidate-messages
                                          npm error extraneous: vuelidate@ /opt/iobroker/node_modules/vuelidate
                                          npm error extraneous: vuex-map-fields@1.4.1 /opt/iobroker/node_modules/vuex-map-fields
                                          npm error extraneous: w3c-xmlserializer@4.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
                                          npm error extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                                          npm error extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
                                          npm error extraneous: webdav@ /opt/iobroker/node_modules/webdav
                                          npm error extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
                                          npm error extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
                                          npm error extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
                                          npm error extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
                                          npm error extraneous: whatwg-url@12.0.1 /opt/iobroker/node_modules/whatwg-url
                                          npm error extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
                                          npm error extraneous: which-typed-array@1.1.15 /opt/iobroker/node_modules/which-typed-array
                                          npm error extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
                                          npm error extraneous: widest-line@3.1.0 /opt/iobroker/node_modules/widest-line
                                          npm error extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
                                          npm error extraneous: winston-daily-rotate-file@5.0.0 /opt/iobroker/node_modules/winston-daily-rotate-file
                                          npm error extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
                                          npm error extraneous: winston-syslog@2.7.1 /opt/iobroker/node_modules/winston-syslog
                                          npm error extraneous: winston-transport@4.7.1 /opt/iobroker/node_modules/winston-transport
                                          npm error extraneous: winston@ /opt/iobroker/node_modules/winston
                                          npm error extraneous: word-wrap@1.2.5 /opt/iobroker/node_modules/word-wrap
                                          npm error extraneous: worker-timers-broker@6.1.8 /opt/iobroker/node_modules/worker-timers-broker
                                          npm error extraneous: worker-timers-worker@7.0.71 /opt/iobroker/node_modules/worker-timers-worker
                                          npm error extraneous: worker-timers@7.1.8 /opt/iobroker/node_modules/worker-timers
                                          npm error extraneous: wrap-ansi-cjs@npm:wrap-ansi@7.0.0 /opt/iobroker/node_modules/wrap-ansi-cjs
                                          npm error extraneous: wrap-ansi@8.1.0 /opt/iobroker/node_modules/wrap-ansi
                                          npm error extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/wrappy
                                          npm error extraneous: write-file-atomic@3.0.3 /opt/iobroker/node_modules/write-file-atomic
                                          npm error extraneous: xdg-basedir@4.0.0 /opt/iobroker/node_modules/xdg-basedir
                                          npm error extraneous: xml-js@1.6.11 /opt/iobroker/node_modules/xml-js
                                          npm error extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
                                          npm error extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
                                          npm error extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
                                          npm error extraneous: yallist@4.0.0 /opt/iobroker/node_modules/yallist
                                          npm error extraneous: yaml@ /opt/iobroker/node_modules/yaml
                                          npm error extraneous: yargs-parser@20.2.9 /opt/iobroker/node_modules/yargs-parser
                                          npm error extraneous: yocto-queue@0.1.0 /opt/iobroker/node_modules/yocto-queue
                                          npm error extraneous: zip-stream@6.0.1 /opt/iobroker/node_modules/zip-stream
                                          npm error extraneous: zrender@ /opt/iobroker/node_modules/zrender
                                          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T19_54_40_124Z-debug-0.log
                                            Thomas Braun Most Active @mcm1957 last edited by
                                            @mcm1957 sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                                            Wo stammen eigentlich die ganzen GITHUB dependencies her, z.B.
                                            War mich auch schon in's Auge gesprungen.
                                            31.6k
                                            79.5k
                                            4455
