    4. Beim Update von Adaptern stürzt der ioBroker ab
      flommaster @Homoran last edited by flommaster
      Hier ist das komplette Ergebnis.
      Ich habe nach dem letzten Versuch das Problem, dass ich den Controller gar nicht mehr zum laufen bekomme...
      Skript v.2024-05-22
      *** BASE SYSTEM ***
         Static hostname: ioBrokerdebian
               Icon name: computer-desktop
                 Chassis: desktop
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 5.10.0-32-amd64
            Architecture: x86-64
      model name      : Intel(R) Celeron(R) CPU J3355 @ 2.00GHz
      Docker          : false
      Virtualization  : none
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       14:18:18 up 54 min,  1 user,  load average: 2.75, 4.55, 3.06
      CPU threads: 2
      *** Time and Time Zones ***
                     Local time: Sun 2024-08-18 14:18:19 CEST
                 Universal time: Sun 2024-08-18 12:18:19 UTC
                       RTC time: Sun 2024-08-18 12:18:19
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      flo
      HOME=/home/flo
      GROUPS=flo cdrom floppy sudo audio dip video plugdev netdev iobroker
      js-controller is not running
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            3.7G        158M        3.0G        2.0M        606M        3.3G
      Swap:           3.9G         27M        3.9G
      Total:          7.7G        185M        6.9G
      Active iob-Instances:   0
               3749 M total memory
                158 M used memory
                401 M active memory
                198 M inactive memory
               2983 M free memory
                299 M buffer memory
                307 M swap cache
               3923 M total swap
                 27 M used swap
               3896 M free swap
      top - 14:18:19 up 54 min,  1 user,  load average: 2.75, 4.55, 3.06
      Tasks: 106 total,   2 running, 104 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  3.1 us,  0.0 sy,  0.0 ni, 96.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3749.5 total,   2983.8 free,    158.6 used,    607.1 buff/cache
      MiB Swap:   3924.0 total,   3897.0 free,     27.0 used.   3348.1 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.9G     0  1.9G   0% /dev
      tmpfs          tmpfs     375M  2.2M  373M   1% /run
      /dev/mmcblk0p2 ext4       53G   21G   30G  42% /
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      /dev/mmcblk0p1 vfat      511M  5.8M  506M   2% /boot/efi
      tmpfs          tmpfs     375M     0  375M   0% /run/user/1000
      [Sun Aug 18 13:23:25 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Sun Aug 18 13:23:26 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro
      Show mounted filesystems:
      TARGET                        SOURCE         FSTYPE     OPTIONS
      /                             /dev/mmcblk0p2 ext4       rw,relatime,errors=remount-ro
      |-/sys                        sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security      securityfs     securityfs rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup            cgroup2        cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore            pstore         pstore     rw,nosuid,nodev,noexec,relatime
      | |-/sys/firmware/efi/efivars efivarfs       efivarfs   rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf               none           bpf        rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/tracing       tracefs        tracefs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/debug         debugfs        debugfs    rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/config        configfs       configfs   rw,nosuid,nodev,noexec,relatime
      | `-/sys/fs/fuse/connections  fusectl        fusectl    rw,nosuid,nodev,noexec,relatime
      |-/proc                       proc           proc       rw,nosuid,nodev,noexec,relatime
      | `-/proc/sys/fs/binfmt_misc  systemd-1      autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=11397
      |-/dev                        udev           devtmpfs   rw,nosuid,relatime,size=1901928k,nr_inodes=475482,mode=755
      | |-/dev/pts                  devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                  tmpfs          tmpfs      rw,nosuid,nodev
      | |-/dev/mqueue               mqueue         mqueue     rw,nosuid,nodev,noexec,relatime
      | `-/dev/hugepages            hugetlbfs      hugetlbfs  rw,relatime,pagesize=2M
      |-/run                        tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=383948k,mode=755
      | |-/run/lock                 tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/rpc_pipefs           sunrpc         rpc_pipefs rw,relatime
      | `-/run/user/1000            tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=383944k,nr_inodes=95986,mode=700,uid=1000,gid=1000
      `-/boot/efi                   /dev/mmcblk0p1 vfat       rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
      /var:
      4.7G    /var/
      4.0G    /var/log/journal/37ccd33008fc48b08294fcfc7d596e40
      4.0G    /var/log
      521M    /var/cache
      Archived and active journals take up 72.0M in the file system.
      /opt/iobroker/backups:
      2.1G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      2.5G    /opt/iobroker/iobroker-data/
      1.7G    /opt/iobroker/iobroker-data/history
      512M    /opt/iobroker/iobroker-data/files
      139M    /opt/iobroker/iobroker-data/backup-objects
      88M     /opt/iobroker/iobroker-data/files/echarts.admin
      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      23M     /opt/iobroker/iobroker-data/objects.json.migrated
      23M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.7952f0f7.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D307ZMZV-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.4
      /usr/bin/node           v18.20.4
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      /usr/bin/corepack       0.28.0
      nodejs:
        Installed: 18.20.4-1nodesource1
        Candidate: 18.20.4-1nodesource1
        Version table:
       *** 18.20.4-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.20.3-1nodesource1 500
           18.20.2-1nodesource1 500
           18.20.1-1nodesource1 500
           18.20.0-1nodesource1 500
           18.19.1-1nodesource1 500
           18.19.0-1nodesource1 500
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      node:internal/modules/cjs/loader:1143
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
          at Module._load (node:internal/modules/cjs/loader:981:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          at node:internal/main/run_main_module:28:49 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      Node.js v18.20.4
      Core adapters versions
        throw err;
        requireStack: []
      Node.js v18.20.4
      js-controller:
        throw err;
        requireStack: []
      Node.js v18.20.4
      admin:
        throw err;
        requireStack: []
      Node.js v18.20.4
      javascript:
      nodejs modules from github:     1
      |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
      Adapter State
      ioBroker-Repositories
        throw err;
        requireStack: []
      Node.js v18.20.4
      Installed ioBroker-Instances
        throw err;
        requireStack: []
      Node.js v18.20.4
      Objects and States
      Objects:        0
      States:         0
      Hit:1 http://ftp.debian.org/debian bullseye-backports InRelease
      Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:3 http://deb.debian.org/debian bullseye InRelease
      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          16130      703/exim4
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          16363      786/smbd
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          16364      786/smbd
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        16070      425/redis-server 12
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          10125      1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14876      461/sshd: /usr/sbin
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          16131      703/exim4
      tcp6       0      0 :::445                  :::*                    LISTEN      0          16361      786/smbd
      tcp6       0      0 ::1:6379                :::*                    LISTEN      109        16071      425/redis-server 12
      tcp6       0      0 :::139                  :::*                    LISTEN      0          16362      786/smbd
      tcp6       0      0 :::111                  :::*                    LISTEN      0          10129      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14887      461/sshd: /usr/sbin
      udp        0      0 0.0.0.0:39663           0.0.0.0:*                           108        16019      418/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16017      418/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16032      407/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          10126      1/init
      udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          16280      424/nmbd
      udp        0      0 192.168.178.66:137      0.0.0.0:*                           0          16279      424/nmbd
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          16117      424/nmbd
      udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          16282      424/nmbd
      udp        0      0 192.168.178.66:138      0.0.0.0:*                           0          16281      424/nmbd
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          16118      424/nmbd
      udp6       0      0 :::5353                 :::*                                108        16018      418/avahi-daemon: r
      udp6       0      0 :::36880                :::*                                108        16020      418/avahi-daemon: r
      udp6       0      0 :::111                  :::*                                0          10132      1/init
      2024-08-18 13:35:45.339  - info: sql.0 (879) Terminated (NO_ERROR): Without reason
      2024-08-18 13:35:45.802  - error: sql.0 (879) Objects database error: read ECONNRESET
      2024-08-18 13:35:46.445  - info: modbus.1 (1048) terminating with timeout
      2024-08-18 13:35:45.384  - info: admin.0 (755) terminating http server on port 8081
      2024-08-18 13:35:46.272  - info: admin.0 (755) terminating
      2024-08-18 13:35:46.366  - info: admin.0 (755) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-08-18 13:35:43.410  - info: eusec.0 (1746) Disconnect from station T8410P202112109E
      2024-08-18 13:35:43.423  - info: eusec.0 (1746) Disconnect from station T84A1P102312214F
      2024-08-18 13:35:43.424  - info: eusec.0 (1746) Disconnect from station T84A1P1023122467
      2024-08-18 13:35:43.464  - info: eusec.0 (1746) terminating
      2024-08-18 13:35:43.466  - info: eusec.0 (1746) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-08-18 13:35:43.492  - info: eusec.0 (1746) Disconnected from station T8410P202112109E
      2024-08-18 13:35:44.969  - info: eusec.0 (1746) Disconnected from station T84A1P102312214F
      2024-08-18 13:35:46.206  - info: eusec.0 (1746) Disconnected from station T84A1P1023122467
      2024-08-18 13:35:46.776  - info: eusec.0 (1746) terminating
      2024-08-18 13:35:46.997  - info: admin.0 (755) terminating
      2024-08-18 13:35:47.926  - info: meross.0 (978) terminating
      2024-08-18 13:35:47.980  - info: meross.0 (978) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-08-18 13:35:48.000  - info: admin.0 (755) terminating with timeout
      2024-08-18 13:35:50.865  - info: meross.0 (978) terminating
      2024-08-18 13:35:50.896  - error: eusec.0 (1746) go2rtc error: exit with signal: terminated
      2024-08-18 13:35:50.905  - info: eusec.0 (1746) go2rtc terminated with exitcode 0
      2024-08-18 13:35:50.907  - info: eusec.0 (1746) terminating with timeout
      2024-08-18 13:35:51.525  - error: history.0 (795) Cannot find view "system" for search "instance" : Connection is closed.
        Homoran Global Moderator Administrators @flommaster last edited by
        @flommaster sagte in Beim Update von Adaptern stürzt der ioBroker ab:
        oh ja, der rödelt gewaltig!
        ok, läuft ja im Moment nicht.
        sollte beizeiten mal auf v20 hochgezogen werden.
        mal sehn was @Thomas-Braun meint.
        ich würde versuchen den Controller drüberzuinstallieren
          Thomas Braun Most Active @flommaster last edited by
          @flommaster
          Läuft das System von einer SD-Karte? Hat der NUC keine SSD/Festplatte?
          sudo usermod -aG adm flo
          exit
          iob nodejs-update
          cd /opt/iobroker
          npm install iobroker.js-controller@6.0.9
          Dann mal einen kompletten Neustart von der Kiste.
          Und wenn das läuft installierst du da Debian 12 'Bookworm', dein Debian 11 hat das Lebensende erreicht.
            flommaster @Thomas Braun last edited by
            @thomas-braun @Homoran
            Hallo Thomas, hallo Homoran,
            vielen Dank für die schnelle Unterstützung!
            Doch der NUC hat ne SSD. Eine SD-Karte nutze ich bei dem Gerät nicht.
            Ok, ich habe die Kiste neu gestartet und die Befehle ausgeführt.
            Am Schluss erhalte ich folgende Fehlermeldung:
            npm warn cleanup Failed to remove some directories [
            npm warn cleanup   [
            npm warn cleanup     '/opt/iobroker/node_modules/iobroker.javascript/node_modules',
            npm warn cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin'] {
            npm warn cleanup       errno: -39,
            npm warn cleanup       code: 'ENOTEMPTY',
            npm warn cleanup       syscall: 'rmdir',
            npm warn cleanup       path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.bin'
            npm warn cleanup     }
            npm warn cleanup   ],
            npm warn cleanup   [
            npm warn cleanup     '/opt/iobroker/node_modules/iobroker.javascript',
            npm warn cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readable-stream'] {
            npm warn cleanup       path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/readable-stream'
            npm warn cleanup     }
            npm warn cleanup   ],
            npm warn cleanup   [
            npm warn cleanup     }
            npm warn cleanup   ]
            npm warn cleanup ]
            npm error code 127
            npm error path /opt/iobroker/node_modules/zlib
            npm error command failed
            npm error command sh -c node-waf clean || true; node-waf configure build
            npm error sh: 1: node-waf: not found
            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T12_33_37_590Z-debug-0.log
            Habt Ihr eine Idee, wie ich das System noch retten kann?
            Vielen Dank und viele Grüße
            Florian
              iob stop
              iob fix
              iob start
                @flommaster
                Ich wunder mich nur, weil typischerweise das Gerät
                /dev/mmcblk0p2
                eine SD-Karte beschreibt.
                node-waf liefert:
                https://forum.iobroker.net/topic/74670/adapter-lassen-sich-nicht-mehr-aktualisieren
                Ro75 1 Reply Last reply Reply Quote 0
                • Ro75
                  Ro75 @Thomas Braun last edited by
                  @thomas-braun laut den Daten ist keine SSD gemountet. Das Teil läuft von einer SD-Karte. Meine Vermutung. Das Teil hat einen SD-Karten-Slot. Karte rein und dann vielleicht Klonen wollen auf SSD und vergessen rauszunehmen. Oder Geklont und ohne SD-KArte läuft das Teil nicht. Oder Oder Oder...
                  Ro75.
                    Thomas Braun Most Active @Ro75 last edited by
                    @ro75 sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                    Ja, würde ich auch so sehen.
                      Ich weiß beim besten Willen nicht, wie das Teil auf einer SD-Karten laufen soll.
                      Ich habe gerade noch mal alle Anschlüsse geprüft. In meinem NUC steckt keine SD-Karte...
                      Es könnte ggf. dran liegen, dass ich den NUC vor ein paar Jahren von einem Raspberry PI mit SD-Karte umgezogen habe...
                      Mit den Updates bin ich jetzt durch.
                      Das System läuft jetzt auf Debian Bookworm
                      /usr/bin/nodejs
                      v20.16.0
                      /usr/bin/node
                      v20.16.0
                      /usr/bin/npm
                      10.8.1
                      /usr/bin/npx
                      10.8.1
                      nodejs:
                        Installiert:           20.16.0-1nodesource1
                        Installationskandidat: 20.16.0-1nodesource1
                        Versionstabelle:
                       *** 20.16.0-1nodesource1 1001
                              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                           20.15.1-1nodesource1 1001
                           20.15.0-1nodesource1 1001
                           20.14.0-1nodesource1 1001
                           20.13.1-1nodesource1 1001
                           20.13.0-1nodesource1 1001
                           20.12.2-1nodesource1 1001
                           20.12.1-1nodesource1 1001
                           20.12.0-1nodesource1 1001
                           20.11.1-1nodesource1 1001
                           20.11.0-1nodesource1 1001
                           20.10.0-1nodesource1 1001
                           20.9.0-1nodesource1 1001
                           20.8.1-1nodesource1 1001
                           20.8.0-1nodesource1 1001
                           20.7.0-1nodesource1 1001
                           20.6.1-1nodesource1 1001
                           20.6.0-1nodesource1 1001
                           20.5.1-1nodesource1 1001
                           20.5.0-1nodesource1 1001
                           20.4.0-1nodesource1 1001
                           20.3.1-1nodesource1 1001
                           20.3.0-1nodesource1 1001
                           20.2.0-1nodesource1 1001
                           20.1.0-1nodesource1 1001
                           20.0.0-1nodesource1 1001
                           18.19.0+dfsg-6~deb12u2 500
                              500 http://deb.debian.org/debian bookworm/main amd64 Packages
                           18.19.0+dfsg-6~deb12u1 500
                              500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
                      Den ioBroker bekomme ich aber leider nicht zum laufen.
                      Ich habe mehrfach den Fixer (iob fix) als auch die Installation ausgeführt.
                      Mir ist gerade aufgefallen, dass im Verzeichnis die Datei "/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js" fehlt.
                      /opt/iobroker/node_modules/iobroker.js-controller$ dir
                      build  LICENSE  node_modules
                        Vermutlich geclont. Da clonst du aber auch die falschen Devices mit.
                          @flommaster
                          iob stop
                          cd /opt/iobroker
                          iob start
                            Hallo Thomas,
                            nach zahlreichen Warnmeldungen, kommt dann eine Error Meldung (npm error code 127) die den Vorgang abbricht.
                            npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.web-speedy.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/peterbaumert/ioBroker.vofo-speedtest.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2-widgets-material.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/aendue/ioBroker.reolink.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.ical.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/WLAN-Kabel/ioBroker.calendar.git
                            npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                            npm warn deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                            npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                            npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
                            npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
                            npm warn deprecated uid-number@0.0.6: This package is no longer supported.
                            npm warn deprecated npmlog@5.0.1: This package is no longer supported.
                            npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                            npm warn deprecated npmlog@6.0.2: This package is no longer supported.
                            npm warn deprecated har-validator@5.1.5: this library is no longer supported
                            npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                            npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
                            npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
                            npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
                            npm warn deprecated q@1.1.2: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
                            npm warn deprecated
                            npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
                            npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                            npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                            npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
                            npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
                            npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                            npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
                            npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                            npm warn deprecated google-p12-pem@3.1.4: Package is no longer maintained
                            npm warn deprecated gauge@3.0.2: This package is no longer supported.
                            npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                            npm warn deprecated gauge@4.0.4: This package is no longer supported.
                            npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                            npm warn deprecated later@1.2.0: Please upgrade to the maintained and new drop-in replacement @breejs/later at https://github.com/breejs/later 🚀 Thanks and happy hacking! 🚀  @niftylettuce
                            npm error code 127
                            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T19_24_28_844Z-debug-0.log
                            Kann ich da noch was retten?
                              Das ist genau das Ding aus dem anderen Thread. Welcher Adapter war das da? mihome-vaccuum?
                              Versuch den mal zu aktualisieren.
                              iob update
                              iob upgrade BÖSER_ADAPTER
                                Das geht gar nicht mehr.
                                iob upgrade mihome-vaccuum
                                node:internal/modules/cjs/loader:1148
                                  throw err;
                                    at Module._resolveFilename (node:internal/modules/cjs/loader:1145:15)
                                    at Module._load (node:internal/modules/cjs/loader:986:27)
                                    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
                                  requireStack: []
                                Node.js v20.16.0
                                Kann ich den Adapter auch komplett löschen. Den Staubsauger nutze ich nur noch manuell...
                                  @flommaster
                                  cd /opt/iobroker && npm ls
                                  spuckt aus?
                                  mcm1957 F 2 Replies Last reply Reply Quote 0
                                  • mcm1957
                                    mcm1957 @Thomas Braun last edited by
                                    Wo stammen eigentlich die ganzen GITHUB dependencies her, z.B.
                                    Den Adapter gibts (dort) gar nicht ...
                                      @thomas-braun sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                                      zu viele Fehler...
                                      Teil 1
                                      iobroker.inst@2.0.3 /opt/iobroker
                                      ├── @alcalzone/esbuild-register@2.5.1-1 extraneous
                                      ├── @alcalzone/jsonl-db@3.1.1 extraneous
                                      ├── @alcalzone/pak@0.8.1 extraneous
                                      ├── @alcalzone/proper-lockfile@4.1.3-0 extraneous
                                      ├── @aws-sdk/util-utf8-browser@3.259.0 extraneous
                                      ├── @azure/abort-controller@1.1.0 extraneous
                                      ├── @azure/core-auth@1.7.2 extraneous
                                      ├── @azure/core-client@ extraneous
                                      ├── @azure/core-http-compat@ extraneous
                                      ├── @azure/core-lro@ extraneous
                                      ├── @azure/core-paging@1.6.2 extraneous
                                      ├── @azure/core-rest-pipeline@ extraneous
                                      ├── @azure/core-tracing@1.1.2 extraneous
                                      ├── @azure/core-util@ extraneous
                                      ├── @azure/identity@ extraneous
                                      ├── @azure/keyvault-keys@ extraneous
                                      ├── @azure/logger@1.1.4 extraneous
                                      ├── @azure/msal-browser@ extraneous
                                      ├── @azure/msal-common@ extraneous
                                      ├── @azure/msal-node@1.18.4 extraneous
                                      ├── @babel/code-frame@7.24.7 extraneous
                                      ├── @babel/helper-validator-identifier@7.24.7 extraneous
                                      ├── @babel/highlight@7.24.7 extraneous
                                      ├── @babel/runtime@ extraneous
                                      ├── @colors/colors@1.5.0 extraneous
                                      ├── @dabh/diagnostics@2.0.3 extraneous
                                      ├── @datalust/winston-seq@1.0.2 extraneous
                                      ├── @gar/promisify@1.1.3 extraneous
                                      ├── @googleapis/calendar@9.7.7 extraneous
                                      ├── @googleapis/drive@5.1.0 extraneous
                                      ├── @googleapis/oauth2@1.0.7 extraneous
                                      ├── @httptoolkit/websocket-stream@6.0.1 extraneous
                                      ├── @iobroker/db-base@ extraneous
                                      ├── @iobroker/db-objects-file@ extraneous
                                      ├── @iobroker/db-objects-jsonl@ extraneous
                                      ├── @iobroker/db-objects-redis@ extraneous
                                      ├── @iobroker/db-states-file@ extraneous
                                      ├── @iobroker/db-states-jsonl@ extraneous
                                      ├── @iobroker/db-states-redis@ extraneous
                                      ├── @iobroker/js-controller-adapter@ extraneous
                                      ├── @iobroker/js-controller-cli@ extraneous
                                      ├── @iobroker/js-controller-common-db@ extraneous
                                      ├── @iobroker/js-controller-common@ extraneous
                                      ├── @iobroker/plugin-base@1.2.1 extraneous
                                      ├── @iobroker/plugin-sentry@1.2.1 extraneous
                                      ├── @iobroker/socket-classes@1.5.6 extraneous
                                      ├── @iobroker/webserver@1.0.3 extraneous
                                      ├── @isaacs/cliui@8.0.2 extraneous
                                      ├── @js-joda/core@ extraneous
                                      ├── @mapbox/node-pre-gyp@1.0.11 extraneous
                                      ├── @microsoft/microsoft-graph-types@2.40.0 extraneous
                                      ├── @nodelib/fs.scandir@2.1.5 extraneous
                                      ├── @nodelib/fs.stat@2.0.5 extraneous
                                      ├── @nodelib/fs.walk@1.2.8 extraneous
                                      ├── @npmcli/fs@2.1.2 extraneous
                                      ├── @npmcli/move-file@2.0.1 extraneous
                                      ├── @pkgjs/parseargs@0.11.0 extraneous
                                      ├── @protobufjs/aspromise@1.1.2 extraneous
                                      ├── @protobufjs/base64@1.1.2 extraneous
                                      ├── @protobufjs/codegen@2.0.4 extraneous
                                      ├── @protobufjs/eventemitter@1.1.0 extraneous
                                      ├── @protobufjs/fetch@1.1.0 extraneous
                                      ├── @protobufjs/float@1.0.2 extraneous
                                      ├── @protobufjs/inquire@1.1.0 extraneous
                                      ├── @protobufjs/path@1.1.2 extraneous
                                      ├── @protobufjs/pool@1.1.0 extraneous
                                      ├── @protobufjs/utf8@1.1.0 extraneous
                                      ├── @quasar/extras@ extraneous
                                      ├── @samverschueren/stream-to-observable@0.3.1 extraneous
                                      ├── @sentry-internal/tracing@ extraneous
                                      ├── @sentry/core@5.30.0 extraneous
                                      ├── @sentry/hub@5.30.0 extraneous
                                      ├── @sentry/minimal@5.30.0 extraneous
                                      ├── @sentry/node@ extraneous
                                      ├── @sentry/tracing@ extraneous
                                      ├── @sentry/types@ extraneous
                                      ├── @sentry/utils@ extraneous
                                      ├── @sindresorhus/is@4.6.0 extraneous
                                      ├── @socket.io/component-emitter@3.1.2 extraneous
                                      ├── @szmarczak/http-timer@4.0.6 extraneous
                                      ├── @tediousjs/connection-string@0.5.0 extraneous
                                      ├── @tootallnate/once@2.0.0 extraneous
                                      ├── @types/bl@5.1.0 extraneous
                                      ├── @types/cacheable-request@6.0.3 extraneous
                                      ├── @types/caseless@0.12.5 extraneous
                                      ├── @types/cookie@0.4.1 extraneous
                                      ├── @types/cors@2.8.17 extraneous
                                      ├── @types/geojson@7946.0.14 extraneous
                                      ├── @types/http-cache-semantics@4.0.4 extraneous
                                      ├── @types/keyv@3.1.4 extraneous
                                      ├── @types/leaflet@1.9.12 extraneous
                                      ├── @types/minimist@1.2.5 extraneous
                                      ├── @types/node-cron@2.0.8 extraneous
                                      ├── @types/node@ extraneous
                                      ├── @types/normalize-package-data@2.4.4 extraneous
                                      ├── @types/parse-json@4.0.2 extraneous
                                      ├── @types/readable-stream@4.0.15 extraneous
                                      ├── @types/request@2.48.12 extraneous
                                      ├── @types/responselike@1.0.3 extraneous
                                      ├── @types/tough-cookie@4.0.5 extraneous
                                      ├── @types/triple-beam@1.3.5 extraneous
                                      ├── @types/tz-offset@0.0.3 extraneous
                                      ├── @types/ws@8.5.12 extraneous
                                      ├── abab@2.0.6 extraneous
                                      ├── abbrev@1.1.1 extraneous
                                      ├── abort-controller@3.0.0 extraneous
                                      ├── agentkeepalive@4.5.0 extraneous
                                      ├── aggregate-error@3.1.0 extraneous
                                      ├── ajv@ extraneous
                                      ├── ansi-align@3.0.1 extraneous
                                      ├── ansi-colors@4.1.3 extraneous
                                      ├── ansi-escapes@4.3.2 extraneous
                                      ├── ansi-regex@5.0.1 extraneous
                                      ├── ansi-styles@4.3.0 extraneous
                                      ├── any-observable@0.5.1 extraneous
                                      ├── anymatch@3.1.3 extraneous
                                      ├── aproba@2.0.0 extraneous
                                      ├── archiver-utils@5.0.2 extraneous
                                      ├── archiver@7.0.1 extraneous
                                      ├── are-we-there-yet@2.0.0 extraneous
                                      ├── arg@4.1.0 extraneous
                                      ├── argparse@1.0.10 extraneous
                                      ├── array-buffer-byte-length@1.0.1 extraneous
                                      ├── array-flatten@1.1.1 extraneous
                                      ├── array-union@2.1.0 extraneous
                                      ├── arraybuffer.prototype.slice@1.0.3 extraneous
                                      ├── arrify@2.0.1 extraneous
                                      ├── asn1@0.2.6 extraneous
                                      ├── async-exit-hook@2.0.1 extraneous
                                      ├── authenticate-pam@1.0.5 extraneous
                                      ├── available-typed-arrays@1.0.7 extraneous
                                      ├── aws-crt@ extraneous
                                      ├── b4a@1.6.6 extraneous
                                      ├── balanced-match@1.0.2 extraneous
                                      ├── bare-events@2.4.2 extraneous
                                      ├── base-64@1.0.0 extraneous
                                      ├── base64-js@1.5.1 extraneous
                                      ├── bcrypt-pbkdf@1.0.2 extraneous
                                      ├── binary-extensions@2.3.0 extraneous
                                      ├── bindings@1.5.0 extraneous
                                      ├── bl@6.0.14 extraneous
                                      ├── bluebird@3.7.2 extraneous
                                      ├── body-parser@1.20.2 extraneous
                                      ├── bottleneck@2.19.5 extraneous
                                      ├── boxen@5.1.2 extraneous
                                      ├── brace-expansion@2.0.1 extraneous
                                      ├── braces@3.0.3 extraneous
                                      ├── buffer-crc32@1.0.0 extraneous
                                      ├── buffer-equal-constant-time@1.0.1 extraneous
                                      ├── buffer-shims@1.0.0 extraneous
                                      ├── buffer@6.0.3 extraneous
                                      ├── buildcheck@0.0.6 extraneous
                                      ├── builtins@1.0.3 extraneous
                                      ├── busboy@1.6.0 extraneous
                                      ├── byte-length@1.0.2 extraneous
                                      ├── bytes@3.1.2 extraneous
                                      ├── cacache@16.1.3 extraneous
                                      ├── cacheable-lookup@5.0.4 extraneous
                                      ├── cacheable-request@7.0.4 extraneous
                                      ├── callsites@3.1.0 extraneous
                                      ├── camelcase-keys@6.2.2 extraneous
                                      ├── camelcase@5.3.1 extraneous
                                      ├── capitalize@2.0.4 extraneous
                                      ├── chalk@4.1.2 extraneous
                                      ├── chardet@0.7.0 extraneous
                                      ├── charenc@0.0.2 extraneous
                                      ├── chokidar@3.6.0 extraneous
                                      ├── chownr@2.0.0 extraneous
                                      ├── ci-info@3.9.0 extraneous
                                      ├── clean-stack@2.2.0 extraneous
                                      ├── cli-boxes@2.2.1 extraneous
                                      ├── cli-cursor@3.1.0 extraneous
                                      ├── cli-truncate@0.2.1 extraneous
                                      ├── cli-width@3.0.0 extraneous
                                      ├── clone-response@1.0.3 extraneous
                                      ├── cloneextend@0.0.3 extraneous
                                      ├── cluster-key-slot@1.1.2 extraneous
                                      ├── coap-packet@1.1.1 extraneous
                                      ├── coffeescript@1.12.7 extraneous
                                      ├── color-convert@2.0.1 extraneous
                                      ├── color-name@1.1.4 extraneous
                                      ├── color-string@1.9.1 extraneous
                                      ├── color-support@1.1.3 extraneous
                                      ├── color@3.2.1 extraneous
                                      ├── colors@1.4.0
                                      ├── colorspace@1.1.4 extraneous
                                      ├── commander@9.5.0 extraneous
                                      ├── commist@3.2.0 extraneous
                                      ├── compress-commons@6.0.2 extraneous
                                      ├── compress-json@2.1.2 extraneous
                                      ├── compressible@2.0.18 extraneous
                                      ├── compression@1.7.4 extraneous
                                      ├── concat-map@0.0.1 extraneous
                                      ├── configstore@5.0.1 extraneous
                                      ├── connect-flash@0.1.1 extraneous
                                      ├── connect@3.7.0 extraneous
                                      ├── console-control-strings@1.1.0 extraneous
                                      ├── content-disposition@0.5.4 extraneous
                                      ├── content-type@1.0.5 extraneous
                                      ├── core-js@ extraneous
                                      ├── cors@2.8.5 extraneous
                                      ├── cosmiconfig@7.1.0 extraneous
                                      ├── cpu-features@ extraneous
                                      ├── crc-32@1.2.2 extraneous
                                      ├── crc@ extraneous
                                      ├── crc32-stream@6.0.0 extraneous
                                      ├── cross-fetch@4.0.0 extraneous
                                      ├── crypt@0.0.2 extraneous
                                      ├── crypto-js@ extraneous
                                      ├── crypto-random-string@2.0.0 extraneous
                                      ├── cssstyle@ extraneous
                                      ├── cycle@1.0.3 extraneous
                                      ├── dashdash@1.14.1 extraneous
                                      ├── data-urls@4.0.0 extraneous
                                      ├── data-view-buffer@1.0.1 extraneous
                                      ├── data-view-byte-length@1.0.1 extraneous
                                      ├── data-view-byte-offset@1.0.0 extraneous
                                      ├── date-and-time@ extraneous
                                      ├── date-fns@1.30.1 extraneous
                                      ├── dateformat@4.6.3 extraneous
                                      ├── dayjs@ extraneous
                                      ├── decache@4.6.2 extraneous
                                      ├── decamelize-keys@1.1.1 extraneous
                                      ├── decimal.js@10.4.3 extraneous
                                      ├── decompress-response@6.0.0 extraneous
                                      ├── deep-clone@3.0.3 extraneous
                                      ├── deep-extend@0.6.0 extraneous
                                      ├── deep-is@0.1.4 extraneous
                                      ├── defer-to-connect@2.0.1 extraneous
                                      ├── define-lazy-prop@2.0.0 extraneous
                                      ├── del@6.1.1 extraneous
                                      ├── delegates@1.0.0 extraneous
                                      ├── denque@1.5.1 extraneous
                                      ├── destroy@1.2.0 extraneous
                                      ├── detect-libc@2.0.3 extraneous
                                      ├── diacritics@1.3.0 extraneous
                                      ├── digest-header@1.1.0 extraneous
                                      ├── dir-glob@3.0.1 extraneous
                                      ├── diskusage@1.2.0 extraneous
                                      ├── domexception@4.0.0 extraneous
                                      ├── dot-prop@6.0.1 extraneous
                                      ├── draftlog@1.0.13 extraneous
                                      ├── dropbox-v2-api@ extraneous
                                      ├── duplexer@0.1.2 extraneous
                                      ├── duplexer3@0.1.5 extraneous
                                      ├── duplexify@3.7.1 extraneous
                                      ├── eastasianwidth@0.2.0 extraneous
                                      ├── ecc-jsbn@0.1.2 extraneous
                                      ├── ecdsa-sig-formatter@1.0.11 extraneous
                                      ├── echarts@ extraneous
                                      ├── ee-first@1.1.1 extraneous
                                      ├── elegant-spinner@1.0.1 extraneous
                                      ├── emoji-regex@9.2.2 extraneous
                                      ├── enabled@2.0.0 extraneous
                                      ├── encodeurl@1.0.2 extraneous
                                      ├── encoding@0.1.13 extraneous
                                      ├── end-of-stream@1.4.4 extraneous
                                      ├── entities@4.5.0 extraneous
                                      ├── err-code@2.0.3 extraneous
                                      ├── es-abstract@ extraneous
                                      ├── es-aggregate-error@1.0.13 extraneous
                                      ├── es-object-atoms@1.0.0 extraneous
                                      ├── es-set-tostringtag@2.0.3 extraneous
                                      ├── es-to-primitive@1.2.1 extraneous
                                      ├── es6-promise@4.2.8 extraneous
                                      ├── es6-promisify@5.0.0 extraneous
                                      ├── esbuild@0.11.23 extraneous
                                      ├── escalade@3.1.2 extraneous
                                      ├── escape-goat@3.0.0 extraneous
                                      ├── escape-html@1.0.3 extraneous
                                      ├── escape-string-regexp@4.0.0 extraneous
                                      ├── escodegen@1.14.3 extraneous
                                      ├── esprima@1.2.2 extraneous
                                      ├── estraverse@4.3.0 extraneous
                                      ├── esutils@2.0.3 extraneous
                                      ├── etag@1.8.1 extraneous
                                      ├── event-stream@4.0.1 extraneous
                                      ├── event-target-shim@5.0.1 extraneous
                                      ├── eventemitter2@6.4.9 extraneous
                                      ├── events@3.3.0 extraneous
                                      ├── execa@5.1.1 extraneous
                                      ├── expand-template@2.0.3 extraneous
                                      ├── express-fileupload@1.5.1 extraneous
                                      ├── express@4.19.2 extraneous
                                      ├── external-editor@3.1.0 extraneous
                                      ├── fast-deep-equal@3.1.3 extraneous
                                      ├── fast-fifo@1.3.2 extraneous
                                      ├── fast-glob@ extraneous
                                      ├── fast-json-stable-stringify@2.1.0 extraneous
                                      ├── fast-levenshtein@2.0.6 extraneous
                                      ├── fast-text-encoding@1.0.6 extraneous
                                      ├── fast-unique-numbers@ extraneous
                                      ├── fast-uri@3.0.1 extraneous
                                      ├── fast-xml-parser@ extraneous
                                      ├── fastq@1.17.1 extraneous
                                      ├── fastseries@2.0.0 extraneous
                                      ├── fecha@4.2.3 extraneous
                                      ├── figures@3.2.0 extraneous
                                      ├── file-stream-rotator@0.6.1 extraneous
                                      ├── file-type@10.11.0 extraneous
                                      ├── file-uri-to-path@1.0.0 extraneous
                                      ├── fill-range@7.1.1 extraneous
                                      ├── finalhandler@1.2.0 extraneous
                                      ├── find-up@5.0.0 extraneous
                                      ├── fn.name@1.1.0 extraneous
                                      ├── for-each@0.3.3 extraneous
                                      ├── foreground-child@3.3.0 extraneous
                                      ├── form-data-encoder@2.1.4 extraneous
                                      ├── form-data@4.0.0 extraneous
                                      ├── forwarded@0.2.0 extraneous
                                      ├── fresh@0.5.2 extraneous
                                      ├── from@0.1.7 extraneous
                                      ├── fs-constants@1.0.0 extraneous
                                      ├── fs-extra@7.0.1
                                      ├── fs-minipass@2.1.0 extraneous
                                      ├── fs.realpath@1.0.0 extraneous
                                      ├── fsevents@ extraneous
                                      ├── ftp@0.3.10 extraneous
                                      ├── function.prototype.name@1.1.6 extraneous
                                      ├── functions-have-names@1.2.3 extraneous
                                      ├── futoin-hkdf@1.4.3 extraneous
                                      ├── gauge@3.0.2 extraneous
                                      ├── gaxios@5.1.3 extraneous
                                      ├── gcp-metadata@5.3.0 extraneous
                                      ├── generate-function@2.3.1 extraneous
                                      ├── get-ssl-certificate@2.3.3 extraneous
                                      ├── get-stream@5.2.0 extraneous
                                      ├── get-symbol-description@1.0.2 extraneous
                                      ├── getpass@0.1.7 extraneous
                                      ├── github-from-package@0.0.0 extraneous
                                      ├── github-url-from-git@1.5.0 extraneous
                                      ├── glob-parent@5.1.2 extraneous
                                      ├── glob@10.4.5 extraneous
                                      ├── global-dirs@2.1.0 extraneous
                                      ├── globalthis@1.0.4 extraneous
                                      ├── globby@11.1.0 extraneous
                                      ├── glossy@0.1.7 extraneous
                                      ├── google-auth-library@ extraneous
                                      ├── google-p12-pem@4.0.1 extraneous
                                      ├── googleapis-common@6.0.4 extraneous
                                      ├── googleapis@ extraneous
                                      ├── gtoken@6.1.2 extraneous
                                      ├── hard-rejection@2.1.0 extraneous
                                      ├── has-ansi@2.0.0 extraneous
                                      ├── has-bigints@1.0.2 extraneous
                                      ├── has-flag@4.0.0 extraneous
                                      ├── has-tostringtag@1.0.2 extraneous
                                      ├── has-unicode@2.0.1 extraneous
                                      ├── has-yarn@2.1.0 extraneous
                                      ├── he@1.2.0 extraneous
                                      ├── help-me@5.0.0 extraneous
                                      ├── homebridge-plugin-wrapper@ extraneous
                                      ├── hosted-git-info@3.0.8 extraneous
                                      ├── hot-patcher@1.0.0 extraneous
                                      ├── html-encoding-sniffer@3.0.0 extraneous
                                      ├── http-cache-semantics@4.1.1 extraneous
                                      ├── http-errors@2.0.0 extraneous
                                      ├── http-proxy-agent@5.0.0 extraneous
                                      ├── http2-wrapper@1.0.3 extraneous
                                      ├── https@1.0.0 extraneous
                                      ├── humanize-ms@1.2.1 extraneous
                                      ├── ical.js@ extraneous
                                      ├── iconv-lite@0.4.24 extraneous
                                      ├── ieee754@1.2.1 extraneous
                                      ├── ignore-walk@3.0.4 extraneous
                                      ├── ignore@5.3.2 extraneous
                                      ├── image-type@4.1.0 extraneous
                                      ├── immediate@3.0.6 extraneous
                                      ├── import-fresh@3.3.0 extraneous
                                      ├── import-lazy@2.1.0 extraneous
                                      ├── import-local@3.2.0 extraneous
                                      ├── imurmurhash@0.1.4 extraneous
                                      ├── indent-string@3.2.0 extraneous
                                      ├── infer-owner@1.0.4 extraneous
                                      ├── inflight@1.0.6 extraneous
                                      ├── ini@1.3.7 extraneous
                                      ├── inquirer-autosubmit-prompt@0.2.0 extraneous
                                      ├── inquirer@7.3.3 extraneous
                                      ├── int64-buffer@1.0.1 extraneous
                                      ├── internal-slot@1.0.7 extraneous
                                      ├── iobroker-adapter-helpers@0.0.8 extraneous
                                      ├── iobroker.admin@ invalid: "^6.10.1" from the root project
                                      ├── iobroker.backitup@ invalid: "2.6.23" from the root project
                                      ├── iobroker.bmw@2.5.7
                                      ├── iobroker.calendar@ invalid: "github:WLAN-Kabel/ioBroker.calendar#c36410258c21a4a92eba80fb0ec084fc254c9259" from the root project
                                      ├── iobroker.cloud@4.4.1
                                      ├── iobroker.coronavirus-statistics@0.8.7
                                      ├── iobroker.daswetter@3.1.10
                                      ├── iobroker.discovery@ invalid: "3.1.0" from the root project
                                      ├── iobroker.dwd@2.8.5
                                      ├── iobroker.echarts@ invalid: "1.5.1" from the root project
                                      ├── iobroker.energiefluss@ invalid: "github:SKB-CGN/ioBroker.energiefluss#fc7a5b48f0f485b130619796daf0a9533f5b8426" from the root project
                                      ├── iobroker.eusec@1.1.2
                                      ├── iobroker.flot@ invalid: "1.12.0" from the root project
                                      ├── iobroker.fritzbox@0.2.1
                                      ├── iobroker.fullcalendar@ invalid: "1.2.0" from the root project
                                      ├── iobroker.fullybrowser@2.1.2
                                      ├── iobroker.gartenbewaesserung@ invalid: "github:TA2k/ioBroker.gartenbewaesserung#1931dcd562edf9dfa818dbf5cec61e28d3f72d72" from the root project
                                      ├── iobroker.ham@ invalid: "github:ioBroker/ioBroker.ham" from the root project
                                      ├── iobroker.harmony@1.2.2
                                      ├── iobroker.heatingcontrol@ invalid: "2.11.1" from the root project
                                      ├── iobroker.history@2.2.6
                                      ├── iobroker.hm-rega@3.0.47
                                      ├── iobroker.hm-rpc@1.15.19
                                      ├── iobroker.hue@3.9.5
                                      ├── iobroker.ical@ invalid: "github:iobroker-community-adapters/ioBroker.ical#ad28140ed1fa7ab23683d7e12b6204da06b7ce6f" from the root project
                                      ├── iobroker.icons-icons8@0.0.1
                                      ├── iobroker.icons-material-png@0.1.0
                                      ├── iobroker.icons-mfd-png@1.1.0
                                      ├── iobroker.icons-ultimate-png@1.0.1
                                      ├── iobroker.info@ invalid: "1.9.26" from the root project
                                      ├── iobroker.javascript@ invalid: "7.1.4" from the root project
                                      ├── iobroker.js-controller@ invalid: "^6.0.9" from the root project
                                      ├── iobroker.logparser@2.2.0
                                      ├── iobroker.material@ invalid: "1.3.1" from the root project
                                      ├── iobroker.meross@1.15.1
                                      ├── iobroker.mihome-vacuum@3.11.0
                                      ├── iobroker.milight-smart-light@ invalid: "1.2.2" from the root project
                                      ├── iobroker.milight@0.3.6
                                      ├── iobroker.mobile@ invalid: "1.0.1" from the root project
                                      ├── iobroker.modbus@ invalid: "5.0.11" from the root project
                                      ├── iobroker.mqtt@ invalid: "4.1.1" from the root project
                                      ├── iobroker.nina@ invalid: "0.0.25" from the root project
                                      ├── iobroker.pollenflug@1.0.6
                                      ├── iobroker.pushover@3.0.3
                                      ├── iobroker.pushsafer@1.0.3
                                      ├── iobroker.pvforecast@2.7.1
                                      ├── iobroker.renault@ invalid: "github:TA2k/ioBroker.renault" from the root project
                                      ├── iobroker.reolink@ invalid: "github:aendue/ioBroker.reolink#b78aab6744cdb81b360fd947a9c6e2fd6808bab1" from the root project
                                      ├── iobroker.schoolfree@ invalid: "1.1.2" from the root project
                                      ├── iobroker.simple-api@2.7.2
                                      ├── iobroker.smartmeter@3.3.4
                                      ├── iobroker.socketio@6.5.2
                                      ├── iobroker.sourceanalytix@ invalid: "github:DrozmotiX/ioBroker.sourceanalytix#362346b297c0a21c717ec20bd8d16331bca3b22d" from the root project
                                      ├── iobroker.sql@2.2.0
                                      ├── iobroker.statistics@2.3.0
                                      ├── iobroker.sunnyportal@0.1.5
                                      ├── iobroker.synology@ invalid: "2.1.13" from the root project
                                      ├── iobroker.tankerkoenig@ invalid: "3.3.7" from the root project
                                      ├── iobroker.terminal@ invalid: "1.0.0" from the root project
                                      ├── iobroker.tr-064@4.2.18
                                      ├── iobroker.trashschedule@2.2.0
                                      ├── iobroker.unifi@ invalid: "0.6.6" from the root project
                                      ├── iobroker.upnp@1.0.21
                                      ├── iobroker.valloxmv@1.2.0
                                      ├── iobroker.viessmannapi@ invalid: "github:TA2k/ioBroker.viessmannapi" from the root project
                                      ├── iobroker.virtualpowermeter@ invalid: "1.4.6" from the root project
                                      ├── iobroker.vis-2-widgets-material@ invalid: "github:ioBroker/ioBroker.vis-2-widgets-material#355a97e7d532721eaa97326fd873d13f12894ebd" from the root project
                                      ├── iobroker.vis-2@ invalid: "github:ioBroker/ioBroker.vis-2#17c7dcf5f26768f1f3a4badb087eddf9344591ea" from the root project
                                      ├── iobroker.vis-colorpicker@ invalid: "2.0.3" from the root project
                                      ├── iobroker.vis-fancyswitch@1.1.0
                                      ├── iobroker.vis-google-fonts@1.0.4
                                      ├── iobroker.vis-history@1.0.0
                                      ├── iobroker.vis-hqwidgets@ invalid: "1.4.0" from the root project
                                      ├── iobroker.vis-inventwo@ invalid: "3.3.3" from the root project
                                      ├── iobroker.vis-jqui-mfd@1.0.12
                                      ├── iobroker.vis-justgage@1.0.2
                                      ├── iobroker.vis-map@1.0.4
                                      ├── iobroker.vis-materialdesign@ invalid: "github:Scrounger/ioBroker.vis-materialdesign#8b7529d493f223dfc4f1d1f632553fcb35bbcc92" from the root project
                                      ├── iobroker.vis-metro@ invalid: "1.2.0" from the root project
                                      ├── iobroker.vis-rgraph@0.0.2
                                      ├── iobroker.vis-timeandweather@ invalid: "1.2.2" from the root project
                                      ├── iobroker.vis-weather@ invalid: "2.5.6" from the root project
                                      ├── iobroker.vis@ invalid: "1.4.16" from the root project
                                      ├── iobroker.vofo-speedtest@ invalid: "github:peterbaumert/ioBroker.vofo-speedtest#921201b4bbd53a88a64fc843c7242f9e7e8c0325" from the root project
                                      ├── iobroker.weatherunderground@3.4.2
                                      ├── iobroker.web-speedy@ invalid: "github:iobroker-community-adapters/ioBroker.web-speedy#8a5ad6a42a15688b6bb539f22e30ba2a1978c118" from the root project
                                      ├── iobroker.web@ invalid: "6.1.0" from the root project
                                      ├── iobroker.webcal@ invalid: "github:dirkhe/ioBroker.webcal#feature/DigestAuth" from the root project
                                      ├── iobroker.wiffi-wz@2.2.1
                                      ├── iobroker.windows-control@0.1.5
                                      ├── iobroker.worx@2.3.2
                                      ├── iobroker.ws@2.5.3
                                      ├── iobroker@2.0.3
                                      ├── ioredis@ extraneous
                                      ├── ip-address@9.0.5 extraneous
                                      ├── ip-regex@4.3.0 extraneous
                                      ├── ipaddr.js@2.2.0 extraneous
                                      ├── is-array-buffer@3.0.4 extraneous
                                      ├── is-bigint@1.0.4 extraneous
                                      ├── is-binary-path@2.1.0 extraneous
                                      ├── is-boolean-object@1.1.2 extraneous
                                      ├── is-buffer@1.1.6 extraneous
                                      ├── is-callable@1.2.7 extraneous
                                      ├── is-ci@2.0.0 extraneous
                                      ├── is-core-module@2.15.0 extraneous
                                      ├── is-data-view@1.0.1 extraneous
                                      ├── is-date-object@1.0.5 extraneous
                                      ├── is-docker@2.2.1 extraneous
                                      ├── is-empty-object@1.1.1 extraneous
                                      ├── is-extglob@2.1.1 extraneous
                                      ├── is-fullwidth-code-point@3.0.0 extraneous
                                      ├── is-glob@4.0.3 extraneous
                                      ├── is-installed-globally@0.3.2 extraneous
                                      ├── is-interactive@1.0.0 extraneous
                                      ├── is-lambda@1.0.1 extraneous
                                      ├── is-negative-zero@2.0.3 extraneous
                                      ├── is-npm@5.0.0 extraneous
                                      ├── is-number-object@1.0.7 extraneous
                                      ├── is-number@7.0.0 extraneous
                                      ├── is-obj@2.0.0 extraneous
                                      ├── is-observable@1.1.0 extraneous
                                      ├── is-path-cwd@2.2.0 extraneous
                                      ├── is-path-inside@3.0.3 extraneous
                                      ├── is-plain-obj@1.1.0 extraneous
                                      ├── is-potential-custom-element-name@1.0.1 extraneous
                                      ├── is-promise@2.2.2 extraneous
                                      ├── is-property@1.0.2 extraneous
                                      ├── is-regex@1.1.4 extraneous
                                      ├── is-scoped@2.1.0 extraneous
                                      ├── is-shared-array-buffer@1.0.3 extraneous
                                      ├── is-string@1.0.7 extraneous
                                      ├── is-symbol@1.0.4 extraneous
                                      ├── is-typed-array@1.1.13 extraneous
                                      ├── is-unicode-supported@0.1.0 extraneous
                                      ├── is-url-superb@4.0.0 extraneous
                                      ├── is-url@1.2.4 extraneous
                                      ├── is-weakref@1.0.2 extraneous
                                      ├── is-wsl@2.2.0 extraneous
                                      ├── is-yarn-global@0.3.0 extraneous
                                      ├── is@3.3.0 extraneous
                                      ├── is2@2.0.9 extraneous
                                      ├── isomorphic-ws@4.0.1 extraneous
                                      ├── issue-regex@3.1.0 extraneous
                                      ├── jackspeak@3.4.3 extraneous
                                      ├── js-md4@0.3.2 extraneous
                                      ├── js-sdsl@4.3.0 extraneous
                                      ├── js-tokens@4.0.0 extraneous
                                      ├── js-yaml@ extraneous
                                      ├── jsbi@4.3.0 extraneous
                                      ├── jsbn@1.1.0 extraneous
                                      ├── jsdom@ extraneous
                                      ├── jshashes@1.0.8 extraneous
                                      ├── json-buffer@3.0.1 extraneous
                                      ├── json-logic-js@2.0.5 extraneous
                                      ├── json-parse-even-better-errors@2.3.1 extraneous
                                      ├── json-schema-traverse@1.0.0 extraneous
                                      ├── json5@2.2.3 extraneous
                                      ├── jsonata@ extraneous
                                      ├── jsonc-parser@3.3.1 extraneous
                                      ├── jsonwebtoken@9.0.2 extraneous
                                      ├── jszip@ extraneous
                                      ├── jwa@2.0.0 extraneous
                                      ├── jws@4.0.0 extraneous
                                      ├── keyv@4.5.4 extraneous
                                      ├── kind-of@6.0.3 extraneous
                                      ├── kuler@2.0.0 extraneous
                                      ├── later@1.2.0 extraneous
                                      ├── latest-version@5.1.0 extraneous
                                      ├── layerr@0.1.2 extraneous
                                      ├── lazystream@1.0.1 extraneous
                                      ├── leven@2.1.0 extraneous
                                      ├── levn@0.3.0 extraneous
                                      ├── lie@3.3.0 extraneous
                                      ├── lines-and-columns@1.2.4 extraneous
                                      ├── listr-input@0.2.1 extraneous
                                      ├── listr-silent-renderer@1.1.1 extraneous
                                      ├── listr-update-renderer@0.5.0 extraneous
                                      ├── listr-verbose-renderer@0.5.0 extraneous
                                      ├── listr@0.14.3 extraneous
                                      ├── loadavg-windows@1.1.1 extraneous
                                      ├── locate-path@6.0.0 extraneous
                                      ├── lodash.defaults@4.2.0 extraneous
                                      ├── lodash.flatten@4.4.0 extraneous
                                      ├── lodash.includes@4.3.0 extraneous
                                      ├── lodash.isarguments@3.1.0 extraneous
                                      ├── lodash.isboolean@3.0.3 extraneous
                                      ├── lodash.isequal@4.5.0 extraneous
                                      ├── lodash.isinteger@4.0.4 extraneous
                                      ├── lodash.isnumber@3.0.3 extraneous
                                      ├── lodash.isplainobject@4.0.6 extraneous
                                      ├── lodash.isstring@4.0.1 extraneous
                                      ├── lodash.once@4.1.1 extraneous
                                      ├── lodash.zip@4.2.0 extraneous
                                      ├── log-symbols@4.1.0 extraneous
                                      ├── log-update@2.3.0 extraneous
                                      ├── logform@ extraneous
                                      ├── long@5.2.3 extraneous
                                      ├── lowercase-keys@2.0.0 extraneous
                                      ├── lru_map@0.3.3 extraneous
                                      ├── lru-cache@6.0.0 extraneous
                                      ├── make-dir@3.1.0 extraneous
                                      ├── make-fetch-happen@10.2.1 extraneous
                                      ├── map-age-cleaner@0.1.3 extraneous
                                      ├── map-obj@4.3.0 extraneous
                                      ├── map-stream@0.0.7 extraneous
                                      ├── md5@2.3.0 extraneous
                                      ├── media-typer@0.3.0 extraneous
                                      ├── meow@8.1.2 extraneous
                                      ├── merge-descriptors@1.0.1 extraneous
                                      ├── merge2@1.4.1 extraneous
                                      ├── methods@1.1.2 extraneous
                                      ├── micro@9.4.1 extraneous
                                      ├── micromatch@4.0.7 extraneous
                                      ├── mime-db@1.53.0 extraneous
                                      ├── mimic-response@1.0.1 extraneous
                                      ├── min-indent@1.0.1 extraneous
                                      ├── minimatch@9.0.5 extraneous
                                      ├── minimist-options@4.1.0 extraneous
                                      ├── minipass-collect@1.0.2 extraneous
                                      ├── minipass-fetch@2.1.2 extraneous
                                      ├── minipass-flush@1.0.5 extraneous
                                      ├── minipass-pipeline@1.2.4 extraneous
                                      ├── minipass-sized@1.0.3 extraneous
                                      ├── minipass@7.1.2 extraneous
                                      ├── minizlib@2.1.2 extraneous
                                      ├── mkdirp-classic@0.5.3 extraneous
                                      ├── mkdirp@1.0.4 extraneous
                                      ├── mock-require@3.0.3 extraneous
                                      ├── moment-duration-format@2.3.2 extraneous
                                      ├── mqtt-connection@4.1.0 extraneous
                                      ├── mqtt-packet@9.0.0 extraneous
                                      ├── mqtt@ extraneous
                                      ├── mute-stream@0.0.8 extraneous
                                      ├── named-placeholders@1.1.3 extraneous
                                      ├── nan@ extraneous
                                      ├── nanoid@3.3.7 extraneous
                                      ├── napi-build-utils@1.0.2 extraneous
                                      ├── native-duplexpair@1.0.0 extraneous
                                      ├── nconf@0.10.0 extraneous
                                      ├── nested-property@4.0.0 extraneous
                                      ├── netmask@2.0.2 extraneous
                                      ├── new-github-release-url@1.0.0 extraneous
                                      ├── node-abi@3.65.0 extraneous
                                      ├── node-abort-controller@3.1.1 extraneous
                                      ├── node-cron@2.0.3 extraneous
                                      ├── node-fetch@2.7.0 extraneous
                                      ├── node-forge@ extraneous
                                      ├── node-gyp@ extraneous
                                      ├── node-ical@0.16.1 extraneous
                                      ├── node-inspect@2.0.0 extraneous
                                      ├── node-libcurl@3.0.0 extraneous
                                      ├── node-mndp@0.0.3 extraneous
                                      ├── node-persist@0.0.11 extraneous
                                      ├── node-rsa@1.1.1 extraneous
                                      ├── node-unifi@2.5.1 extraneous
                                      ├── node-wol@0.1.1 extraneous
                                      ├── node.extend@2.0.3 extraneous
                                      ├── nopt@5.0.0 extraneous
                                      ├── normalize-package-data@3.0.3 extraneous
                                      ├── normalize-path@3.0.0 extraneous
                                      ├── normalize-url@6.1.0 extraneous
                                      ├── np@7.7.0 extraneous
                                      ├── npm-name@6.0.1 extraneous
                                      ├── npmlog@5.0.1 extraneous
                                      ├── number-allocator@1.0.14 extraneous
                                      ├── nwsapi@2.2.12 extraneous
                                      ├── object-assign@4.1.1 extraneous
                                      ├── object-hash@3.0.0 extraneous
                                      ├── on-finished@2.4.1 extraneous
                                      ├── once@1.4.0 extraneous
                                      ├── one-time@1.0.0 extraneous
                                      ├── onedrive-api@1.1.1 extraneous
                                      ├── open@7.4.2 extraneous
                                      ├── opencollective-postinstall@2.0.3 extraneous
                                      ├── optionator@0.8.3 extraneous
                                      ├── org-regex@1.0.0 extraneous
                                      ├── os-tmpdir@1.0.2 extraneous
                                      ├── ospath@1.2.2 extraneous
                                      ├── osx-temperature-sensor@ extraneous
                                      ├── otplib@11.0.1 extraneous
                                      ├── ow@0.21.0 extraneous
                                      ├── p-cancelable@2.1.1 extraneous
                                      ├── p-defer@1.0.0 extraneous
                                      ├── p-event@4.2.0 extraneous
                                      ├── p-finally@1.0.0 extraneous
                                      ├── p-limit@2.3.0 extraneous
                                      ├── p-locate@5.0.0 extraneous
                                      ├── p-map@2.1.0 extraneous
                                      ├── p-memoize@4.0.4 extraneous
                                      ├── p-reflect@2.1.0 extraneous
                                      ├── p-settle@4.1.1 extraneous
                                      ├── p-throttle@4.1.1 extraneous
                                      ├── p-timeout@4.1.0 extraneous
                                      ├── p-try@2.2.0 extraneous
                                      ├── package-json-from-dist@1.0.0 extraneous
                                      ├── package-json@6.5.0 extraneous
                                      ├── pako@ extraneous
                                      ├── parent-module@1.0.1 extraneous
                                      ├── parse-json@5.2.0 extraneous
                                      ├── parse5@ extraneous
                                      ├── passport-local@1.0.0 extraneous
                                      ├── passport@0.7.0 extraneous
                                      ├── path-exists@4.0.0 extraneous
                                      ├── path-is-absolute@1.0.1 extraneous
                                      ├── path-parse@1.0.7 extraneous
                                      ├── path-posix@1.0.0 extraneous
                                      ├── path-scurry@1.11.1 extraneous
                                      ├── path-to-regexp@0.1.7 extraneous
                                      ├── path-type@4.0.0 extraneous
                                      ├── pause-stream@0.0.11 extraneous
                                      ├── picomatch@2.3.1 extraneous
                                      ├── pidtree@0.6.0 extraneous
                                      ├── pidusage@3.0.2 extraneous
                                      ├── ping@0.4.4 extraneous
                                      ├── pkg-dir@5.0.0 extraneous
                                      ├── pluralize@8.0.0 extraneous
                                      ├── possible-typed-array-names@1.0.0 extraneous
                                      ├── prebuild-install@7.1.2 extraneous
                                      ├── prelude-ls@1.1.2 extraneous
                                      ├── prepend-http@2.0.0 extraneous
                                      ├── process-nextick-args@2.0.1 extraneous
                                      ├── process@0.11.10 extraneous
                                      ├── promise-inflight@1.0.1 extraneous
                                      ├── promise-object@0.1.7 extraneous
                                      ├── promise-retry@2.0.1 extraneous
                                      ├── promise-retryer@0.0.1 extraneous
                                      ├── promisify-child-process@4.1.2 extraneous
                                      ├── prompt@1.3.0 extraneous
                                      ├── protobufjs@ extraneous
                                      ├── proxy-addr@2.0.7 extraneous
                                      ├── proxy-from-env@1.1.0 extraneous
                                      ├── pump@3.0.0 extraneous
                                      ├── pupa@2.1.1 extraneous
                                      ├── q@1.1.2 extraneous
                                      ├── quasar@ extraneous
                                      ├── queue-microtask@1.2.3 extraneous
                                      ├── queue-tick@1.0.1 extraneous
                                      ├── quick-lru@5.1.1 extraneous
                                      ├── range-parser@1.2.1 extraneous
                                      ├── raw-body@2.5.2 extraneous
                                      ├── rc@1.2.8 extraneous
                                      ├── read-pkg-up@7.0.1 extraneous
                                      ├── read-pkg@5.2.0 extraneous
                                      ├── read@1.0.7 extraneous
                                      ├── readable-stream@ extraneous
                                      ├── readdir-glob@1.1.3 extraneous
                                      ├── readdirp@3.6.0 extraneous
                                      ├── readline-sync@1.4.10 extraneous
                                      ├── readline@1.3.0 extraneous
                                      ├── redent@3.0.0 extraneous
                                      ├── redis-commands@1.7.0 extraneous
                                      ├── redis-errors@1.2.0 extraneous
                                      ├── redis-parser@3.0.0 extraneous
                                      ├── regenerator-runtime@0.14.1 extraneous
                                      ├── regex-escape@3.4.10 extraneous
                                      ├── regexp.prototype.flags@1.5.2 extraneous
                                      ├── registry-auth-token@4.2.2 extraneous
                                      ├── registry-url@5.1.0 extraneous
                                      ├── reinterval@1.1.0 extraneous
                                      ├── remove-trailing-separator@1.1.0 extraneous
                                      ├── require-from-string@2.0.2 extraneous
                                      ├── resolve-alpn@1.2.1 extraneous
                                      ├── resolve-cwd@3.0.0 extraneous
                                      ├── resolve-from@4.0.0 extraneous
                                      ├── respjs@4.2.0 extraneous
                                      ├── responselike@2.0.1 extraneous
                                      ├── restore-cursor@3.1.0 extraneous
                                      ├── retry-axios@2.6.0 extraneous
                                      ├── retry@0.12.0 extraneous
                                      ├── reusify@1.0.4 extraneous
                                      ├── revalidator@0.1.8 extraneous
                                      ├── rfdc@1.4.1 extraneous
                                      ├── rimraf@3.0.2 extraneous
                                      ├── rrule@2.8.1 extraneous
                                      ├── rrweb-cssom@0.6.0 extraneous
                                      ├── run-async@2.4.1 extraneous
                                      ├── run-parallel@1.2.0 extraneous
                                      ├── rxjs@ extraneous
                                      ├── safe-array-concat@1.1.2 extraneous
                                      ├── safe-regex-test@1.0.3 extraneous
                                      ├── safe-stable-stringify@2.4.3 extraneous
                                      ├── safer-buffer@2.1.2 extraneous
                                      ├── saxes@6.0.0 extraneous
                                      ├── scoped-regex@2.1.0 extraneous
                                      ├── secure-keys@1.0.0 extraneous
                                      ├── semver-diff@3.1.1 extraneous
                                      ├── semver@5.7.2
                                      ├── send@0.18.0 extraneous
                                      ├── seq-logging@1.1.2 extraneous
                                      ├── seq-queue@0.0.5 extraneous
                                      ├── serve-static@1.15.0 extraneous
                                      ├── set-function-name@2.0.2 extraneous
                                      ├── setimmediate@1.0.5 extraneous
                                      ├── setprototypeof@1.2.0 extraneous
                                      ├── signal-exit@4.1.0 extraneous
                                      ├── simple-concat@1.0.1 extraneous
                                      ├── simple-get@3.1.1 extraneous
                                      ├── simple-ssh@1.1.1 extraneous
                                      ├── simple-swizzle@0.2.2 extraneous
                                      ├── slash@3.0.0 extraneous
                                      ├── slice-ansi@0.0.4 extraneous
                                      ├── smart-buffer@4.2.0 extraneous
                                      ├── socks-proxy-agent@7.0.0 extraneous
                                      ├── socks@2.8.3 extraneous
                                      ├── speedtest-net@1.6.2 extraneous
                                      ├── split@1.0.1 extraneous
                                      ├── sprintf-js@1.1.3 extraneous
                                      ├── sqlstring@2.3.3 extraneous
                                      ├── ssh2@ extraneous
                                      ├── ssri@9.0.1 extraneous
                                      ├── stack-trace@0.0.10 extraneous
                                      ├── stampit-event-bus@0.1.1 extraneous
                                      ├── stampit-state-machine@0.2.1 extraneous
                                      ├── stampit@2.1.2 extraneous
                                      ├── standard-as-callback@2.1.0 extraneous
                                      ├── static-eval@2.0.2 extraneous
                                      ├── statuses@2.0.1 extraneous
                                      ├── stoppable@1.1.0 extraneous
                                      ├── stream-combiner@0.2.2 extraneous
                                      ├── stream-shift@1.0.3 extraneous
                                      ├── streamsearch@1.1.0 extraneous
                                      ├── streamx@2.18.0 extraneous
                                      ├── string-argv@0.3.2 extraneous
                                      ├── string-width-cjs@npm:string-width@4.2.3 extraneous
                                      ├── string-width@5.1.2 extraneous
                                      ├── string.prototype.trim@1.2.9 extraneous
                                      ├── string.prototype.trimend@1.0.8 extraneous
                                      ├── string.prototype.trimstart@1.0.8 extraneous
                                      ├── strip-ansi-cjs@npm:strip-ansi@6.0.1 extraneous
                                      ├── strip-ansi@6.0.1 extraneous
                                      ├── strip-indent@3.0.0 extraneous
                                      ├── strip-json-comments@2.0.1 extraneous
                                      ├── strnum@1.0.5 extraneous
                                      ├── suncalc@1.9.0 extraneous
                                      ├── suncalc2@1.8.1 extraneous
                                      ├── supermixer@1.0.5 extraneous
                                      ├── supports-color@7.2.0 extraneous
                                      ├── supports-hyperlinks@2.3.0 extraneous
                                      ├── supports-preserve-symlinks-flag@1.0.0 extraneous
                                      ├── sweet-collections@1.1.0 extraneous
                                      ├── symbol-observable@3.0.0 extraneous
                                      ├── symbol-tree@3.2.4 extraneous
                                      ├── syno@ extraneous
                                      ├── systeminformation@ extraneous
                                      ├── tar-fs@2.1.1 extraneous
                                      ├── tar-stream@3.1.7 extraneous
                                      ├── tar@6.2.1 extraneous
                                      ├── tarn@3.0.2 extraneous
                                      ├── tcp-port-used@1.0.2 extraneous
                                      ├── tedious@ extraneous
                                      ├── terminal-link@2.1.1 extraneous
                                      ├── text-decoder@1.1.1 extraneous
                                      ├── text-hex@1.0.0 extraneous
                                      ├── thirty-two@1.0.2 extraneous
                                      ├── through@2.3.8 extraneous
                                      ├── through2@2.0.5 extraneous
                                      ├── tiny-typed-emitter@2.1.0 extraneous
                                      ├── tinycolor2@1.6.0 extraneous
                                      ├── tmp@0.0.33 extraneous
                                      ├── to-readable-stream@2.1.0 extraneous
                                      ├── to-regex-range@5.0.1 extraneous
                                      ├── toidentifier@1.0.1 extraneous
                                      ├── tr46@4.1.1 extraneous
                                      ├── trim-newlines@3.0.1 extraneous
                                      ├── triple-beam@1.4.1 extraneous
                                      ├── tsdav@ extraneous
                                      ├── tslib@2.3.0 extraneous
                                      ├── tweetnacl@0.14.5 extraneous
                                      ├── type-check@0.3.2 extraneous
                                      ├── type-fest@0.21.3 extraneous
                                      ├── type-is@1.6.18 extraneous
                                      ├── typed-array-buffer@1.0.2 extraneous
                                      ├── typed-array-byte-length@1.0.1 extraneous
                                      ├── typed-array-byte-offset@1.0.2 extraneous
                                      ├── typed-array-length@1.0.6 extraneous
                                      ├── typedarray-to-buffer@3.1.5 extraneous
                                      ├── typedarray.prototype.slice@1.0.3 extraneous
                                      ├── typescript@ extraneous
                                      ├── tz-offset@0.0.1 extraneous
                                      ├── uid-number@0.0.6 extraneous
                                      ├── unbox-primitive@1.0.2 extraneous
                                      ├── undici-types@6.19.6 extraneous
                                      ├── unique-filename@2.0.1 extraneous
                                      ├── unique-slug@3.0.0 extraneous
                                      ├── unique-string@2.0.0 extraneous
                                      ├── unix-dgram@2.0.6 extraneous
                                      ├── unpipe@1.0.0 extraneous
                                      ├── update-notifier@5.1.0 extraneous
                                      ├── uri-js@4.4.1 extraneous
                                      ├── url-join@4.0.1 extraneous
                                      ├── url-parse-lax@3.0.0 extraneous
                                      ├── url-template@2.0.8 extraneous
                                      ├── url@0.11.4 extraneous
                                      ├── vali-date@1.0.0 extraneous
                                      ├── validate-npm-package-name@3.0.0 extraneous
                                      ├── vary@1.1.2 extraneous
                                      ├── virtual-tsc@0.6.2 extraneous
                                      ├── vue-i18n@ extraneous
                                      ├── vuelidate-messages@0.1.2 extraneous
                                      ├── vuelidate@ extraneous
                                      ├── vuex-map-fields@1.4.1 extraneous
                                      ├── w3c-xmlserializer@4.0.0 extraneous
                                      ├── wake_on_lan@1.0.0 extraneous
                                      ├── weak-daemon@1.0.3 extraneous
                                      ├── webdav@ extraneous
                                      ├── webidl-conversions@7.0.0 extraneous
                                      ├── websocket-stream@5.5.2 extraneous
                                      ├── whatwg-encoding@2.0.0 extraneous
                                      ├── whatwg-mimetype@3.0.0 extraneous
                                      ├── whatwg-url@12.0.1 extraneous
                                      ├── which-boxed-primitive@1.0.2 extraneous
                                      ├── which-typed-array@1.1.15 extraneous
                                      ├── wide-align@1.1.5 extraneous
                                      ├── widest-line@3.1.0 extraneous
                                      ├── window-size@0.1.4 extraneous
                                      ├── winston-daily-rotate-file@5.0.0 extraneous
                                      ├── winston-seq-updated@1.0.4 extraneous
                                      ├── winston-syslog@2.7.1 extraneous
                                      ├── winston-transport@4.7.1 extraneous
                                      ├── winston@ extraneous
                                      ├── word-wrap@1.2.5 extraneous
                                      ├── worker-timers-broker@6.1.8 extraneous
                                      ├── worker-timers-worker@7.0.71 extraneous
                                      ├── worker-timers@7.1.8 extraneous
                                      ├── wrap-ansi-cjs@npm:wrap-ansi@7.0.0 extraneous
                                      ├── wrap-ansi@8.1.0 extraneous
                                      ├── wrappy@1.0.2 extraneous
                                      ├── write-file-atomic@3.0.3 extraneous
                                      ├── xdg-basedir@4.0.0 extraneous
                                      ├── xml-js@1.6.11 extraneous
                                      ├── xml-name-validator@4.0.0 extraneous
                                      ├── xmlchars@2.2.0 extraneous
                                      ├── xregexp@2.0.0 extraneous
                                      ├── yallist@4.0.0 extraneous
                                      ├── yaml@ extraneous
                                      ├── yargs-parser@20.2.9 extraneous
                                      ├── yargs@7.1.2
                                      ├── yocto-queue@0.1.0 extraneous
                                      ├── zip-stream@6.0.1 extraneous
                                      └── zrender@ extraneous
                                        flommaster @flommaster last edited by
                                        Teil 2
                                        npm error code ELSPROBLEMS
                                        npm error extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
                                        npm error extraneous: @alcalzone/jsonl-db@3.1.1 /opt/iobroker/node_modules/@alcalzone/jsonl-db
                                        npm error extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/@alcalzone/pak
                                        npm error extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
                                        npm error extraneous: @aws-sdk/util-utf8-browser@3.259.0 /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser
                                        npm error extraneous: @azure/abort-controller@1.1.0 /opt/iobroker/node_modules/@azure/abort-controller
                                        npm error extraneous: @azure/core-auth@1.7.2 /opt/iobroker/node_modules/@azure/core-auth
                                        npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
                                        npm error extraneous: @azure/core-http-compat@ /opt/iobroker/node_modules/@azure/core-http-compat
                                        npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
                                        npm error extraneous: @azure/core-paging@1.6.2 /opt/iobroker/node_modules/@azure/core-paging
                                        npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
                                        npm error extraneous: @azure/core-tracing@1.1.2 /opt/iobroker/node_modules/@azure/core-tracing
                                        npm error extraneous: @azure/core-util@ /opt/iobroker/node_modules/@azure/core-util
                                        npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
                                        npm error extraneous: @azure/keyvault-keys@ /opt/iobroker/node_modules/@azure/keyvault-keys
                                        npm error extraneous: @azure/logger@1.1.4 /opt/iobroker/node_modules/@azure/logger
                                        npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
                                        npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
                                        npm error extraneous: @azure/msal-node@1.18.4 /opt/iobroker/node_modules/@azure/msal-node
                                        npm error extraneous: @babel/code-frame@7.24.7 /opt/iobroker/node_modules/@babel/code-frame
                                        npm error extraneous: @babel/helper-validator-identifier@7.24.7 /opt/iobroker/node_modules/@babel/helper-validator-identifier
                                        npm error extraneous: @babel/highlight@7.24.7 /opt/iobroker/node_modules/@babel/highlight
                                        npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
                                        npm error extraneous: @colors/colors@1.5.0 /opt/iobroker/node_modules/@colors/colors
                                        npm error extraneous: @dabh/diagnostics@2.0.3 /opt/iobroker/node_modules/@dabh/diagnostics
                                        npm error extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
                                        npm error extraneous: @gar/promisify@1.1.3 /opt/iobroker/node_modules/@gar/promisify
                                        npm error extraneous: @googleapis/calendar@9.7.7 /opt/iobroker/node_modules/@googleapis/calendar
                                        npm error extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
                                        npm error extraneous: @googleapis/oauth2@1.0.7 /opt/iobroker/node_modules/@googleapis/oauth2
                                        npm error extraneous: @httptoolkit/websocket-stream@6.0.1 /opt/iobroker/node_modules/@httptoolkit/websocket-stream
                                        npm error extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
                                        npm error extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
                                        npm error extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
                                        npm error extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
                                        npm error extraneous: @iobroker/db-states-file@ /opt/iobroker/node_modules/@iobroker/db-states-file
                                        npm error extraneous: @iobroker/db-states-jsonl@ /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                                        npm error extraneous: @iobroker/db-states-redis@ /opt/iobroker/node_modules/@iobroker/db-states-redis
                                        npm error extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
                                        npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
                                        npm error extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modules/@iobroker/js-controller-common-db
                                        npm error extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
                                        npm error extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
                                        npm error extraneous: @iobroker/plugin-sentry@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-sentry
                                        npm error extraneous: @iobroker/socket-classes@1.5.6 /opt/iobroker/node_modules/@iobroker/socket-classes
                                        npm error extraneous: @iobroker/webserver@1.0.3 /opt/iobroker/node_modules/@iobroker/webserver
                                        npm error extraneous: @isaacs/cliui@8.0.2 /opt/iobroker/node_modules/@isaacs/cliui
                                        npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
                                        npm error extraneous: @mapbox/node-pre-gyp@1.0.11 /opt/iobroker/node_modules/@mapbox/node-pre-gyp
                                        npm error extraneous: @microsoft/microsoft-graph-types@2.40.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
                                        npm error extraneous: @nodelib/fs.scandir@2.1.5 /opt/iobroker/node_modules/@nodelib/fs.scandir
                                        npm error extraneous: @nodelib/fs.stat@2.0.5 /opt/iobroker/node_modules/@nodelib/fs.stat
                                        npm error extraneous: @nodelib/fs.walk@1.2.8 /opt/iobroker/node_modules/@nodelib/fs.walk
                                        npm error extraneous: @npmcli/fs@2.1.2 /opt/iobroker/node_modules/@npmcli/fs
                                        npm error extraneous: @npmcli/move-file@2.0.1 /opt/iobroker/node_modules/@npmcli/move-file
                                        npm error extraneous: @pkgjs/parseargs@0.11.0 /opt/iobroker/node_modules/@pkgjs/parseargs
                                        npm error extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
                                        npm error extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
                                        npm error extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
                                        npm error extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
                                        npm error extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
                                        npm error extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
                                        npm error extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
                                        npm error extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
                                        npm error extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
                                        npm error extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
                                        npm error extraneous: @quasar/extras@ /opt/iobroker/node_modules/@quasar/extras
                                        npm error extraneous: @samverschueren/stream-to-observable@0.3.1 /opt/iobroker/node_modules/@samverschueren/stream-to-observable
                                        npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
                                        npm error extraneous: @sentry/core@5.30.0 /opt/iobroker/node_modules/@sentry/core
                                        npm error extraneous: @sentry/hub@5.30.0 /opt/iobroker/node_modules/@sentry/hub
                                        npm error extraneous: @sentry/minimal@5.30.0 /opt/iobroker/node_modules/@sentry/minimal
                                        npm error extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
                                        npm error extraneous: @sentry/tracing@ /opt/iobroker/node_modules/@sentry/tracing
                                        npm error extraneous: @sentry/types@ /opt/iobroker/node_modules/@sentry/types
                                        npm error extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
                                        npm error extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/@sindresorhus/is
                                        npm error extraneous: @socket.io/component-emitter@3.1.2 /opt/iobroker/node_modules/@socket.io/component-emitter
                                        npm error extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/@szmarczak/http-timer
                                        npm error extraneous: @tediousjs/connection-string@0.5.0 /opt/iobroker/node_modules/@tediousjs/connection-string
                                        npm error extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
                                        npm error extraneous: @types/bl@5.1.0 /opt/iobroker/node_modules/@types/bl
                                        npm error extraneous: @types/cacheable-request@6.0.3 /opt/iobroker/node_modules/@types/cacheable-request
                                        npm error extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                                        npm error extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/@types/cookie
                                        npm error extraneous: @types/cors@2.8.17 /opt/iobroker/node_modules/@types/cors
                                        npm error extraneous: @types/geojson@7946.0.14 /opt/iobroker/node_modules/@types/geojson
                                        npm error extraneous: @types/http-cache-semantics@4.0.4 /opt/iobroker/node_modules/@types/http-cache-semantics
                                        npm error extraneous: @types/keyv@3.1.4 /opt/iobroker/node_modules/@types/keyv
                                        npm error extraneous: @types/leaflet@1.9.12 /opt/iobroker/node_modules/@types/leaflet
                                        npm error extraneous: @types/minimist@1.2.5 /opt/iobroker/node_modules/@types/minimist
                                        npm error extraneous: @types/node-cron@2.0.8 /opt/iobroker/node_modules/@types/node-cron
                                        npm error extraneous: @types/node@ /opt/iobroker/node_modules/@types/node
                                        npm error extraneous: @types/normalize-package-data@2.4.4 /opt/iobroker/node_modules/@types/normalize-package-data
                                        npm error extraneous: @types/parse-json@4.0.2 /opt/iobroker/node_modules/@types/parse-json
                                        npm error extraneous: @types/readable-stream@4.0.15 /opt/iobroker/node_modules/@types/readable-stream
                                        npm error extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                                        npm error extraneous: @types/responselike@1.0.3 /opt/iobroker/node_modules/@types/responselike
                                        npm error extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                                        npm error extraneous: @types/triple-beam@1.3.5 /opt/iobroker/node_modules/@types/triple-beam
                                        npm error extraneous: @types/tz-offset@0.0.3 /opt/iobroker/node_modules/@types/tz-offset
                                        npm error extraneous: @types/ws@8.5.12 /opt/iobroker/node_modules/@types/ws
                                        npm error extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
                                        npm error extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
                                        npm error extraneous: abort-controller@3.0.0 /opt/iobroker/node_modules/abort-controller
                                        npm error extraneous: agentkeepalive@4.5.0 /opt/iobroker/node_modules/agentkeepalive
                                        npm error extraneous: aggregate-error@3.1.0 /opt/iobroker/node_modules/aggregate-error
                                        npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
                                        npm error extraneous: ansi-align@3.0.1 /opt/iobroker/node_modules/ansi-align
                                        npm error extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/ansi-colors
                                        npm error extraneous: ansi-escapes@4.3.2 /opt/iobroker/node_modules/ansi-escapes
                                        npm error extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/ansi-regex
                                        npm error extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/ansi-styles
                                        npm error extraneous: any-observable@0.5.1 /opt/iobroker/node_modules/any-observable
                                        npm error extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
                                        npm error extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
                                        npm error extraneous: archiver-utils@5.0.2 /opt/iobroker/node_modules/archiver-utils
                                        npm error extraneous: archiver@7.0.1 /opt/iobroker/node_modules/archiver
                                        npm error extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
                                        npm error extraneous: arg@4.1.0 /opt/iobroker/node_modules/arg
                                        npm error extraneous: argparse@1.0.10 /opt/iobroker/node_modules/argparse
                                        npm error extraneous: array-buffer-byte-length@1.0.1 /opt/iobroker/node_modules/array-buffer-byte-length
                                        npm error extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/array-flatten
                                        npm error extraneous: array-union@2.1.0 /opt/iobroker/node_modules/array-union
                                        npm error extraneous: arraybuffer.prototype.slice@1.0.3 /opt/iobroker/node_modules/arraybuffer.prototype.slice
                                        npm error extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
                                        npm error extraneous: asn1@0.2.6 /opt/iobroker/node_modules/asn1
                                        npm error extraneous: async-exit-hook@2.0.1 /opt/iobroker/node_modules/async-exit-hook
                                        npm error extraneous: authenticate-pam@1.0.5 /opt/iobroker/node_modules/authenticate-pam
                                        npm error extraneous: available-typed-arrays@1.0.7 /opt/iobroker/node_modules/available-typed-arrays
                                        npm error extraneous: aws-crt@ /opt/iobroker/node_modules/aws-crt
                                        npm error extraneous: b4a@1.6.6 /opt/iobroker/node_modules/b4a
                                        npm error extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/balanced-match
                                        npm error extraneous: bare-events@2.4.2 /opt/iobroker/node_modules/bare-events
                                        npm error extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
                                        npm error extraneous: base64-js@1.5.1 /opt/iobroker/node_modules/base64-js
                                        npm error extraneous: bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/bcrypt-pbkdf
                                        npm error extraneous: binary-extensions@2.3.0 /opt/iobroker/node_modules/binary-extensions
                                        npm error extraneous: bindings@1.5.0 /opt/iobroker/node_modules/bindings
                                        npm error extraneous: bl@6.0.14 /opt/iobroker/node_modules/bl
                                        npm error extraneous: bluebird@3.7.2 /opt/iobroker/node_modules/bluebird
                                        npm error extraneous: body-parser@1.20.2 /opt/iobroker/node_modules/body-parser
                                        npm error extraneous: bottleneck@2.19.5 /opt/iobroker/node_modules/bottleneck
                                        npm error extraneous: boxen@5.1.2 /opt/iobroker/node_modules/boxen
                                        npm error extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/brace-expansion
                                        npm error extraneous: braces@3.0.3 /opt/iobroker/node_modules/braces
                                        npm error extraneous: buffer-crc32@1.0.0 /opt/iobroker/node_modules/buffer-crc32
                                        npm error extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
                                        npm error extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
                                        npm error extraneous: buffer@6.0.3 /opt/iobroker/node_modules/buffer
                                        npm error extraneous: buildcheck@0.0.6 /opt/iobroker/node_modules/buildcheck
                                        npm error extraneous: builtins@1.0.3 /opt/iobroker/node_modules/builtins
                                        npm error extraneous: busboy@1.6.0 /opt/iobroker/node_modules/busboy
                                        npm error extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
                                        npm error extraneous: bytes@3.1.2 /opt/iobroker/node_modules/bytes
                                        npm error extraneous: cacache@16.1.3 /opt/iobroker/node_modules/cacache
                                        npm error extraneous: cacheable-lookup@5.0.4 /opt/iobroker/node_modules/cacheable-lookup
                                        npm error extraneous: cacheable-request@7.0.4 /opt/iobroker/node_modules/cacheable-request
                                        npm error extraneous: callsites@3.1.0 /opt/iobroker/node_modules/callsites
                                        npm error extraneous: camelcase-keys@6.2.2 /opt/iobroker/node_modules/camelcase-keys
                                        npm error extraneous: camelcase@5.3.1 /opt/iobroker/node_modules/camelcase
                                        npm error extraneous: capitalize@2.0.4 /opt/iobroker/node_modules/capitalize
                                        npm error extraneous: chalk@4.1.2 /opt/iobroker/node_modules/chalk
                                        npm error extraneous: chardet@0.7.0 /opt/iobroker/node_modules/chardet
                                        npm error extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
                                        npm error extraneous: chokidar@3.6.0 /opt/iobroker/node_modules/chokidar
                                        npm error extraneous: chownr@2.0.0 /opt/iobroker/node_modules/chownr
                                        npm error extraneous: ci-info@3.9.0 /opt/iobroker/node_modules/ci-info
                                        npm error extraneous: clean-stack@2.2.0 /opt/iobroker/node_modules/clean-stack
                                        npm error extraneous: cli-boxes@2.2.1 /opt/iobroker/node_modules/cli-boxes
                                        npm error extraneous: cli-cursor@3.1.0 /opt/iobroker/node_modules/cli-cursor
                                        npm error extraneous: cli-truncate@0.2.1 /opt/iobroker/node_modules/cli-truncate
                                        npm error extraneous: cli-width@3.0.0 /opt/iobroker/node_modules/cli-width
                                        npm error extraneous: clone-response@1.0.3 /opt/iobroker/node_modules/clone-response
                                        npm error extraneous: cloneextend@0.0.3 /opt/iobroker/node_modules/cloneextend
                                        npm error extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
                                        npm error extraneous: coap-packet@1.1.1 /opt/iobroker/node_modules/coap-packet
                                        npm error extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                                        npm error extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/color-convert
                                        npm error extraneous: color-name@1.1.4 /opt/iobroker/node_modules/color-name
                                        npm error extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
                                        npm error extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
                                        npm error extraneous: color@3.2.1 /opt/iobroker/node_modules/color
                                        npm error extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
                                        npm error extraneous: commander@9.5.0 /opt/iobroker/node_modules/commander
                                        npm error extraneous: commist@3.2.0 /opt/iobroker/node_modules/commist
                                        npm error extraneous: compress-commons@6.0.2 /opt/iobroker/node_modules/compress-commons
                                        npm error extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
                                        npm error extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
                                        npm error extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
                                        npm error extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
                                        npm error extraneous: configstore@5.0.1 /opt/iobroker/node_modules/configstore
                                        npm error extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
                                        npm error extraneous: connect@3.7.0 /opt/iobroker/node_modules/connect
                                        npm error extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
                                        npm error extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/content-disposition
                                        npm error extraneous: content-type@1.0.5 /opt/iobroker/node_modules/content-type
                                        npm error extraneous: core-js@ /opt/iobroker/node_modules/core-js
                                        npm error extraneous: cors@2.8.5 /opt/iobroker/node_modules/cors
                                        npm error extraneous: cosmiconfig@7.1.0 /opt/iobroker/node_modules/cosmiconfig
                                        npm error extraneous: cpu-features@ /opt/iobroker/node_modules/cpu-features
                                        npm error extraneous: crc-32@1.2.2 /opt/iobroker/node_modules/crc-32
                                        npm error extraneous: crc@ /opt/iobroker/node_modules/crc
                                        npm error extraneous: crc32-stream@6.0.0 /opt/iobroker/node_modules/crc32-stream
                                        npm error extraneous: cross-fetch@4.0.0 /opt/iobroker/node_modules/cross-fetch
                                        npm error extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
                                        npm error extraneous: crypto-js@ /opt/iobroker/node_modules/crypto-js
                                        npm error extraneous: crypto-random-string@2.0.0 /opt/iobroker/node_modules/crypto-random-string
                                        npm error extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
                                        npm error extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
                                        npm error extraneous: dashdash@1.14.1 /opt/iobroker/node_modules/dashdash
                                        npm error extraneous: data-urls@4.0.0 /opt/iobroker/node_modules/data-urls
                                        npm error extraneous: data-view-buffer@1.0.1 /opt/iobroker/node_modules/data-view-buffer
                                        npm error extraneous: data-view-byte-length@1.0.1 /opt/iobroker/node_modules/data-view-byte-length
                                        npm error extraneous: data-view-byte-offset@1.0.0 /opt/iobroker/node_modules/data-view-byte-offset
                                        npm error extraneous: date-and-time@ /opt/iobroker/node_modules/date-and-time
                                        npm error extraneous: date-fns@1.30.1 /opt/iobroker/node_modules/date-fns
                                        npm error extraneous: dateformat@4.6.3 /opt/iobroker/node_modules/dateformat
                                        npm error extraneous: dayjs@ /opt/iobroker/node_modules/dayjs
                                        npm error extraneous: decache@4.6.2 /opt/iobroker/node_modules/decache
                                        npm error extraneous: decamelize-keys@1.1.1 /opt/iobroker/node_modules/decamelize-keys
                                        npm error extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
                                        npm error extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
                                        npm error extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
                                        npm error extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
                                        npm error extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is
                                        npm error extraneous: defer-to-connect@2.0.1 /opt/iobroker/node_modules/defer-to-connect
                                        npm error extraneous: define-lazy-prop@2.0.0 /opt/iobroker/node_modules/define-lazy-prop
                                        npm error extraneous: del@6.1.1 /opt/iobroker/node_modules/del
                                        npm error extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
                                        npm error extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
                                        npm error extraneous: destroy@1.2.0 /opt/iobroker/node_modules/destroy
                                        npm error extraneous: detect-libc@2.0.3 /opt/iobroker/node_modules/detect-libc
                                        npm error extraneous: diacritics@1.3.0 /opt/iobroker/node_modules/diacritics
                                        npm error extraneous: digest-header@1.1.0 /opt/iobroker/node_modules/digest-header
                                        npm error extraneous: dir-glob@3.0.1 /opt/iobroker/node_modules/dir-glob
                                        npm error extraneous: diskusage@1.2.0 /opt/iobroker/node_modules/diskusage
                                        npm error extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception
                                        npm error extraneous: dot-prop@6.0.1 /opt/iobroker/node_modules/dot-prop
                                        npm error extraneous: draftlog@1.0.13 /opt/iobroker/node_modules/draftlog
                                        npm error extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
                                        npm error extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
                                        npm error extraneous: duplexer3@0.1.5 /opt/iobroker/node_modules/duplexer3
                                        npm error extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/duplexify
                                        npm error extraneous: eastasianwidth@0.2.0 /opt/iobroker/node_modules/eastasianwidth
                                        npm error extraneous: ecc-jsbn@0.1.2 /opt/iobroker/node_modules/ecc-jsbn
                                        npm error extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
                                        npm error extraneous: echarts@ /opt/iobroker/node_modules/echarts
                                        npm error extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/ee-first
                                        npm error extraneous: elegant-spinner@1.0.1 /opt/iobroker/node_modules/elegant-spinner
                                        npm error extraneous: emoji-regex@9.2.2 /opt/iobroker/node_modules/emoji-regex
                                        npm error extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
                                        npm error extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/encodeurl
                                        npm error extraneous: encoding@0.1.13 /opt/iobroker/node_modules/encoding
                                        npm error extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/end-of-stream
                                        npm error extraneous: entities@4.5.0 /opt/iobroker/node_modules/entities
                                        npm error extraneous: err-code@2.0.3 /opt/iobroker/node_modules/err-code
                                        npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
                                        npm error extraneous: es-aggregate-error@1.0.13 /opt/iobroker/node_modules/es-aggregate-error
                                        npm error extraneous: es-object-atoms@1.0.0 /opt/iobroker/node_modules/es-object-atoms
                                        npm error extraneous: es-set-tostringtag@2.0.3 /opt/iobroker/node_modules/es-set-tostringtag
                                        npm error extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
                                        npm error extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
                                        npm error extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
                                        npm error extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
                                        npm error extraneous: escalade@3.1.2 /opt/iobroker/node_modules/escalade
                                        npm error extraneous: escape-goat@3.0.0 /opt/iobroker/node_modules/escape-goat
                                        npm error extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/escape-html
                                        npm error extraneous: escape-string-regexp@4.0.0 /opt/iobroker/node_modules/escape-string-regexp
                                        npm error extraneous: escodegen@1.14.3 /opt/iobroker/node_modules/escodegen
                                        npm error extraneous: esprima@1.2.2 /opt/iobroker/node_modules/esprima
                                        npm error extraneous: estraverse@4.3.0 /opt/iobroker/node_modules/estraverse
                                        npm error extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils
                                        npm error extraneous: etag@1.8.1 /opt/iobroker/node_modules/etag
                                        npm error extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
                                        npm error extraneous: event-target-shim@5.0.1 /opt/iobroker/node_modules/event-target-shim
                                        npm error extraneous: eventemitter2@6.4.9 /opt/iobroker/node_modules/eventemitter2
                                        npm error extraneous: events@3.3.0 /opt/iobroker/node_modules/events
                                        npm error extraneous: execa@5.1.1 /opt/iobroker/node_modules/execa
                                        npm error extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
                                        npm error extraneous: express-fileupload@1.5.1 /opt/iobroker/node_modules/express-fileupload
                                        npm error extraneous: express@4.19.2 /opt/iobroker/node_modules/express
                                        npm error extraneous: external-editor@3.1.0 /opt/iobroker/node_modules/external-editor
                                        npm error extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
                                        npm error extraneous: fast-fifo@1.3.2 /opt/iobroker/node_modules/fast-fifo
                                        npm error extraneous: fast-glob@ /opt/iobroker/node_modules/fast-glob
                                        npm error extraneous: fast-json-stable-stringify@2.1.0 /opt/iobroker/node_modules/fast-json-stable-stringify
                                        npm error extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein
                                        npm error extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
                                        npm error extraneous: fast-unique-numbers@ /opt/iobroker/node_modules/fast-unique-numbers
                                        npm error extraneous: fast-uri@3.0.1 /opt/iobroker/node_modules/fast-uri
                                        npm error extraneous: fast-xml-parser@ /opt/iobroker/node_modules/fast-xml-parser
                                        npm error extraneous: fastq@1.17.1 /opt/iobroker/node_modules/fastq
                                        npm error extraneous: fastseries@2.0.0 /opt/iobroker/node_modules/fastseries
                                        npm error extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
                                        npm error extraneous: figures@3.2.0 /opt/iobroker/node_modules/figures
                                        npm error extraneous: file-stream-rotator@0.6.1 /opt/iobroker/node_modules/file-stream-rotator
                                        npm error extraneous: file-type@10.11.0 /opt/iobroker/node_modules/file-type
                                        npm error extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
                                        npm error extraneous: fill-range@7.1.1 /opt/iobroker/node_modules/fill-range
                                        npm error extraneous: finalhandler@1.2.0 /opt/iobroker/node_modules/finalhandler
                                        npm error extraneous: find-up@5.0.0 /opt/iobroker/node_modules/find-up
                                        npm error extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
                                        npm error extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
                                        npm error extraneous: foreground-child@3.3.0 /opt/iobroker/node_modules/foreground-child
                                        npm error extraneous: form-data-encoder@2.1.4 /opt/iobroker/node_modules/form-data-encoder
                                        npm error extraneous: form-data@4.0.0 /opt/iobroker/node_modules/form-data
                                        npm error extraneous: forwarded@0.2.0 /opt/iobroker/node_modules/forwarded
                                        npm error extraneous: fresh@0.5.2 /opt/iobroker/node_modules/fresh
                                        npm error extraneous: from@0.1.7 /opt/iobroker/node_modules/from
                                        npm error extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
                                        npm error extraneous: fs-minipass@2.1.0 /opt/iobroker/node_modules/fs-minipass
                                        npm error extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
                                        npm error extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
                                        npm error extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
                                        npm error extraneous: function.prototype.name@1.1.6 /opt/iobroker/node_modules/function.prototype.name
                                        npm error extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
                                        npm error extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
                                        npm error extraneous: gauge@3.0.2 /opt/iobroker/node_modules/gauge
                                        npm error extraneous: gaxios@5.1.3 /opt/iobroker/node_modules/gaxios
                                        npm error extraneous: gcp-metadata@5.3.0 /opt/iobroker/node_modules/gcp-metadata
                                        npm error extraneous: generate-function@2.3.1 /opt/iobroker/node_modules/generate-function
                                        npm error extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ssl-certificate
                                        npm error extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/get-stream
                                        npm error extraneous: get-symbol-description@1.0.2 /opt/iobroker/node_modules/get-symbol-description
                                        npm error extraneous: getpass@0.1.7 /opt/iobroker/node_modules/getpass
                                        npm error extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
                                        npm error extraneous: github-url-from-git@1.5.0 /opt/iobroker/node_modules/github-url-from-git
                                        npm error extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/glob-parent
                                        npm error extraneous: glob@10.4.5 /opt/iobroker/node_modules/glob
                                        npm error extraneous: global-dirs@2.1.0 /opt/iobroker/node_modules/global-dirs
                                        npm error extraneous: globalthis@1.0.4 /opt/iobroker/node_modules/globalthis
                                        npm error extraneous: globby@11.1.0 /opt/iobroker/node_modules/globby
                                        npm error extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
                                        npm error extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
                                        npm error extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
                                        npm error extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
                                        npm error extraneous: googleapis@ /opt/iobroker/node_modules/googleapis
                                        npm error extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
                                        npm error extraneous: hard-rejection@2.1.0 /opt/iobroker/node_modules/hard-rejection
                                        npm error extraneous: has-ansi@2.0.0 /opt/iobroker/node_modules/has-ansi
                                        npm error extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
                                        npm error extraneous: has-flag@4.0.0 /opt/iobroker/node_modules/has-flag
                                        npm error extraneous: has-tostringtag@1.0.2 /opt/iobroker/node_modules/has-tostringtag
                                        npm error extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
                                        npm error extraneous: has-yarn@2.1.0 /opt/iobroker/node_modules/has-yarn
                                        npm error extraneous: he@1.2.0 /opt/iobroker/node_modules/he
                                        npm error extraneous: help-me@5.0.0 /opt/iobroker/node_modules/help-me
                                        npm error extraneous: homebridge-plugin-wrapper@ /opt/iobroker/node_modules/homebridge-plugin-wrapper
                                        npm error extraneous: hosted-git-info@3.0.8 /opt/iobroker/node_modules/hosted-git-info
                                        npm error extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
                                        npm error extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
                                        npm error extraneous: http-cache-semantics@4.1.1 /opt/iobroker/node_modules/http-cache-semantics
                                        npm error extraneous: http-errors@2.0.0 /opt/iobroker/node_modules/http-errors
                                        npm error extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
                                        npm error extraneous: http2-wrapper@1.0.3 /opt/iobroker/node_modules/http2-wrapper
                                        npm error extraneous: https@1.0.0 /opt/iobroker/node_modules/https
                                        npm error extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
                                        npm error extraneous: ical.js@ /opt/iobroker/node_modules/ical.js
                                        npm error extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/iconv-lite
                                        npm error extraneous: ieee754@1.2.1 /opt/iobroker/node_modules/ieee754
                                        npm error extraneous: ignore-walk@3.0.4 /opt/iobroker/node_modules/ignore-walk
                                        npm error extraneous: ignore@5.3.2 /opt/iobroker/node_modules/ignore
                                        npm error extraneous: image-type@4.1.0 /opt/iobroker/node_modules/image-type
                                        npm error extraneous: immediate@3.0.6 /opt/iobroker/node_modules/immediate
                                        npm error extraneous: import-fresh@3.3.0 /opt/iobroker/node_modules/import-fresh
                                        npm error extraneous: import-lazy@2.1.0 /opt/iobroker/node_modules/import-lazy
                                        npm error extraneous: import-local@3.2.0 /opt/iobroker/node_modules/import-local
                                        npm error extraneous: imurmurhash@0.1.4 /opt/iobroker/node_modules/imurmurhash
                                        npm error extraneous: indent-string@3.2.0 /opt/iobroker/node_modules/indent-string
                                        npm error extraneous: infer-owner@1.0.4 /opt/iobroker/node_modules/infer-owner
                                        npm error extraneous: inflight@1.0.6 /opt/iobroker/node_modules/inflight
                                        npm error extraneous: ini@1.3.7 /opt/iobroker/node_modules/ini
                                        npm error extraneous: inquirer-autosubmit-prompt@0.2.0 /opt/iobroker/node_modules/inquirer-autosubmit-prompt
                                        npm error extraneous: inquirer@7.3.3 /opt/iobroker/node_modules/inquirer
                                        npm error extraneous: int64-buffer@1.0.1 /opt/iobroker/node_modules/int64-buffer
                                        npm error extraneous: internal-slot@1.0.7 /opt/iobroker/node_modules/internal-slot
                                        npm error extraneous: iobroker-adapter-helpers@0.0.8 /opt/iobroker/node_modules/iobroker-adapter-helpers
                                        npm error invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
                                        npm error invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
                                        npm error invalid: iobroker.calendar@ /opt/iobroker/node_modules/iobroker.calendar
                                        npm error invalid: iobroker.discovery@ /opt/iobroker/node_modules/iobroker.discovery
                                        npm error invalid: iobroker.echarts@ /opt/iobroker/node_modules/iobroker.echarts
                                        npm error invalid: iobroker.energiefluss@ /opt/iobroker/node_modules/iobroker.energiefluss
                                        npm error invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
                                        npm error invalid: iobroker.fullcalendar@ /opt/iobroker/node_modules/iobroker.fullcalendar
                                        npm error invalid: iobroker.gartenbewaesserung@ /opt/iobroker/node_modules/iobroker.gartenbewaesserung
                                        npm error invalid: iobroker.ham@ /opt/iobroker/node_modules/iobroker.ham
                                        npm error invalid: iobroker.heatingcontrol@ /opt/iobroker/node_modules/iobroker.heatingcontrol
                                        npm error invalid: iobroker.ical@ /opt/iobroker/node_modules/iobroker.ical
                                        npm error invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
                                        npm error invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
                                        npm error invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
                                        npm error invalid: iobroker.material@ /opt/iobroker/node_modules/iobroker.material
                                        npm error invalid: iobroker.milight-smart-light@ /opt/iobroker/node_modules/iobroker.milight-smart-light
                                        npm error invalid: iobroker.mobile@ /opt/iobroker/node_modules/iobroker.mobile
                                        npm error invalid: iobroker.modbus@ /opt/iobroker/node_modules/iobroker.modbus
                                        npm error invalid: iobroker.mqtt@ /opt/iobroker/node_modules/iobroker.mqtt
                                        npm error invalid: iobroker.nina@ /opt/iobroker/node_modules/iobroker.nina
                                        npm error invalid: iobroker.renault@ /opt/iobroker/node_modules/iobroker.renault
                                        npm error invalid: iobroker.reolink@ /opt/iobroker/node_modules/iobroker.reolink
                                        npm error invalid: iobroker.schoolfree@ /opt/iobroker/node_modules/iobroker.schoolfree
                                        npm error invalid: iobroker.sourceanalytix@ /opt/iobroker/node_modules/iobroker.sourceanalytix
                                        npm error invalid: iobroker.synology@ /opt/iobroker/node_modules/iobroker.synology
                                        npm error invalid: iobroker.tankerkoenig@ /opt/iobroker/node_modules/iobroker.tankerkoenig
                                        npm error invalid: iobroker.terminal@ /opt/iobroker/node_modules/iobroker.terminal
                                        npm error invalid: iobroker.unifi@ /opt/iobroker/node_modules/iobroker.unifi
                                        npm error invalid: iobroker.viessmannapi@ /opt/iobroker/node_modules/iobroker.viessmannapi
                                        npm error invalid: iobroker.virtualpowermeter@ /opt/iobroker/node_modules/iobroker.virtualpowermeter
                                        npm error invalid: iobroker.vis-2-widgets-material@ /opt/iobroker/node_modules/iobroker.vis-2-widgets-material
                                        npm error invalid: iobroker.vis-2@ /opt/iobroker/node_modules/iobroker.vis-2
                                        npm error invalid: iobroker.vis-colorpicker@ /opt/iobroker/node_modules/iobroker.vis-colorpicker
                                        npm error invalid: iobroker.vis-hqwidgets@ /opt/iobroker/node_modules/iobroker.vis-hqwidgets
                                        npm error invalid: iobroker.vis-inventwo@ /opt/iobroker/node_modules/iobroker.vis-inventwo
                                        npm error invalid: iobroker.vis-materialdesign@ /opt/iobroker/node_modules/iobroker.vis-materialdesign
                                        npm error invalid: iobroker.vis-metro@ /opt/iobroker/node_modules/iobroker.vis-metro
                                        npm error invalid: iobroker.vis-timeandweather@ /opt/iobroker/node_modules/iobroker.vis-timeandweather
                                        npm error invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
                                        npm error invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
                                        npm error invalid: iobroker.vofo-speedtest@ /opt/iobroker/node_modules/iobroker.vofo-speedtest
                                        npm error invalid: iobroker.web-speedy@ /opt/iobroker/node_modules/iobroker.web-speedy
                                        npm error invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
                                        npm error invalid: iobroker.webcal@ /opt/iobroker/node_modules/iobroker.webcal
                                        npm error extraneous: ioredis@ /opt/iobroker/node_modules/ioredis
                                        npm error extraneous: ip-address@9.0.5 /opt/iobroker/node_modules/ip-address
                                        npm error extraneous: ip-regex@4.3.0 /opt/iobroker/node_modules/ip-regex
                                        npm error extraneous: ipaddr.js@2.2.0 /opt/iobroker/node_modules/ipaddr.js
                                        npm error extraneous: is-array-buffer@3.0.4 /opt/iobroker/node_modules/is-array-buffer
                                        npm error extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
                                        npm error extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
                                        npm error extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
                                        npm error extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
                                        npm error extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
                                        npm error extraneous: is-ci@2.0.0 /opt/iobroker/node_modules/is-ci
                                        npm error extraneous: is-core-module@2.15.0 /opt/iobroker/node_modules/is-core-module
                                        npm error extraneous: is-data-view@1.0.1 /opt/iobroker/node_modules/is-data-view
                                        npm error extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
                                        npm error extraneous: is-docker@2.2.1 /opt/iobroker/node_modules/is-docker
                                        npm error extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
                                        npm error extraneous: is-extglob@2.1.1 /opt/iobroker/node_modules/is-extglob
                                        npm error extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/is-fullwidth-code-point
                                        npm error extraneous: is-glob@4.0.3 /opt/iobroker/node_modules/is-glob
                                        npm error extraneous: is-installed-globally@0.3.2 /opt/iobroker/node_modules/is-installed-globally
                                        npm error extraneous: is-interactive@1.0.0 /opt/iobroker/node_modules/is-interactive
                                        npm error extraneous: is-lambda@1.0.1 /opt/iobroker/node_modules/is-lambda
                                        npm error extraneous: is-negative-zero@2.0.3 /opt/iobroker/node_modules/is-negative-zero
                                        npm error extraneous: is-npm@5.0.0 /opt/iobroker/node_modules/is-npm
                                        npm error extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
                                        npm error extraneous: is-number@7.0.0 /opt/iobroker/node_modules/is-number
                                        npm error extraneous: is-obj@2.0.0 /opt/iobroker/node_modules/is-obj
                                        npm error extraneous: is-observable@1.1.0 /opt/iobroker/node_modules/is-observable
                                        npm error extraneous: is-path-cwd@2.2.0 /opt/iobroker/node_modules/is-path-cwd
                                        npm error extraneous: is-path-inside@3.0.3 /opt/iobroker/node_modules/is-path-inside
                                        npm error extraneous: is-plain-obj@1.1.0 /opt/iobroker/node_modules/is-plain-obj
                                        npm error extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
                                        npm error extraneous: is-promise@2.2.2 /opt/iobroker/node_modules/is-promise
                                        npm error extraneous: is-property@1.0.2 /opt/iobroker/node_modules/is-property
                                        npm error extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
                                        npm error extraneous: is-scoped@2.1.0 /opt/iobroker/node_modules/is-scoped
                                        npm error extraneous: is-shared-array-buffer@1.0.3 /opt/iobroker/node_modules/is-shared-array-buffer
                                        npm error extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
                                        npm error extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
                                        npm error extraneous: is-typed-array@1.1.13 /opt/iobroker/node_modules/is-typed-array
                                        npm error extraneous: is-unicode-supported@0.1.0 /opt/iobroker/node_modules/is-unicode-supported
                                        npm error extraneous: is-url-superb@4.0.0 /opt/iobroker/node_modules/is-url-superb
                                        npm error extraneous: is-url@1.2.4 /opt/iobroker/node_modules/is-url
                                        npm error extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
                                        npm error extraneous: is-wsl@2.2.0 /opt/iobroker/node_modules/is-wsl
                                        npm error extraneous: is-yarn-global@0.3.0 /opt/iobroker/node_modules/is-yarn-global
                                        npm error extraneous: is@3.3.0 /opt/iobroker/node_modules/is
                                        npm error extraneous: is2@2.0.9 /opt/iobroker/node_modules/is2
                                        npm error extraneous: isomorphic-ws@4.0.1 /opt/iobroker/node_modules/isomorphic-ws
                                        npm error extraneous: issue-regex@3.1.0 /opt/iobroker/node_modules/issue-regex
                                        npm error extraneous: jackspeak@3.4.3 /opt/iobroker/node_modules/jackspeak
                                        npm error extraneous: js-md4@0.3.2 /opt/iobroker/node_modules/js-md4
                                        npm error extraneous: js-sdsl@4.3.0 /opt/iobroker/node_modules/js-sdsl
                                        npm error extraneous: js-tokens@4.0.0 /opt/iobroker/node_modules/js-tokens
                                        npm error extraneous: js-yaml@ /opt/iobroker/node_modules/js-yaml
                                        npm error extraneous: jsbi@4.3.0 /opt/iobroker/node_modules/jsbi
                                        npm error extraneous: jsbn@1.1.0 /opt/iobroker/node_modules/jsbn
                                        npm error extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
                                        npm error extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
                                        npm error extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/json-buffer
                                        npm error extraneous: json-logic-js@2.0.5 /opt/iobroker/node_modules/json-logic-js
                                        npm error extraneous: json-parse-even-better-errors@2.3.1 /opt/iobroker/node_modules/json-parse-even-better-errors
                                        npm error extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse
                                        npm error extraneous: json5@2.2.3 /opt/iobroker/node_modules/json5
                                        npm error extraneous: jsonata@ /opt/iobroker/node_modules/jsonata
                                        npm error extraneous: jsonc-parser@3.3.1 /opt/iobroker/node_modules/jsonc-parser
                                        npm error extraneous: jsonwebtoken@9.0.2 /opt/iobroker/node_modules/jsonwebtoken
                                        npm error extraneous: jszip@ /opt/iobroker/node_modules/jszip
                                        npm error extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
                                        npm error extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
                                        npm error extraneous: keyv@4.5.4 /opt/iobroker/node_modules/keyv
                                        npm error extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/kind-of
                                        npm error extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
                                        npm error extraneous: later@1.2.0 /opt/iobroker/node_modules/later
                                        npm error extraneous: latest-version@5.1.0 /opt/iobroker/node_modules/latest-version
                                        npm error extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
                                        npm error extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/lazystream
                                        npm error extraneous: leven@2.1.0 /opt/iobroker/node_modules/leven
                                        npm error extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn
                                        npm error extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
                                        npm error extraneous: lines-and-columns@1.2.4 /opt/iobroker/node_modules/lines-and-columns
                                        npm error extraneous: listr-input@0.2.1 /opt/iobroker/node_modules/listr-input
                                        npm error extraneous: listr-silent-renderer@1.1.1 /opt/iobroker/node_modules/listr-silent-renderer
                                        npm error extraneous: listr-update-renderer@0.5.0 /opt/iobroker/node_modules/listr-update-renderer
                                        npm error extraneous: listr-verbose-renderer@0.5.0 /opt/iobroker/node_modules/listr-verbose-renderer
                                        npm error extraneous: listr@0.14.3 /opt/iobroker/node_modules/listr
                                        npm error extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
                                        npm error extraneous: locate-path@6.0.0 /opt/iobroker/node_modules/locate-path
                                        npm error extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
                                        npm error extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
                                        npm error extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
                                        npm error extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
                                        npm error extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
                                        npm error extraneous: lodash.isequal@4.5.0 /opt/iobroker/node_modules/lodash.isequal
                                        npm error extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
                                        npm error extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
                                        npm error extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
                                        npm error extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
                                        npm error extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
                                        npm error extraneous: lodash.zip@4.2.0 /opt/iobroker/node_modules/lodash.zip
                                        npm error extraneous: log-symbols@4.1.0 /opt/iobroker/node_modules/log-symbols
                                        npm error extraneous: log-update@2.3.0 /opt/iobroker/node_modules/log-update
                                        npm error extraneous: logform@ /opt/iobroker/node_modules/logform
                                        npm error extraneous: long@5.2.3 /opt/iobroker/node_modules/long
                                        npm error extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/lowercase-keys
                                        npm error extraneous: lru_map@0.3.3 /opt/iobroker/node_modules/lru_map
                                        npm error extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/lru-cache
                                        npm error extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
                                        npm error extraneous: make-fetch-happen@10.2.1 /opt/iobroker/node_modules/make-fetch-happen
                                        npm error extraneous: map-age-cleaner@0.1.3 /opt/iobroker/node_modules/map-age-cleaner
                                        npm error extraneous: map-obj@4.3.0 /opt/iobroker/node_modules/map-obj
                                        npm error extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
                                        npm error extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
                                        npm error extraneous: media-typer@0.3.0 /opt/iobroker/node_modules/media-typer
                                        npm error extraneous: meow@8.1.2 /opt/iobroker/node_modules/meow
                                        npm error extraneous: merge-descriptors@1.0.1 /opt/iobroker/node_modules/merge-descriptors
                                        npm error extraneous: merge2@1.4.1 /opt/iobroker/node_modules/merge2
                                        npm error extraneous: methods@1.1.2 /opt/iobroker/node_modules/methods
                                        npm error extraneous: micro@9.4.1 /opt/iobroker/node_modules/micro
                                        npm error extraneous: micromatch@4.0.7 /opt/iobroker/node_modules/micromatch
                                        npm error extraneous: mime-db@1.53.0 /opt/iobroker/node_modules/mime-db
                                        npm error extraneous: mimic-response@1.0.1 /opt/iobroker/node_modules/mimic-response
                                        npm error extraneous: min-indent@1.0.1 /opt/iobroker/node_modules/min-indent
                                        npm error extraneous: minimatch@9.0.5 /opt/iobroker/node_modules/minimatch
                                        npm error extraneous: minimist-options@4.1.0 /opt/iobroker/node_modules/minimist-options
                                        npm error extraneous: minipass-collect@1.0.2 /opt/iobroker/node_modules/minipass-collect
                                        npm error extraneous: minipass-fetch@2.1.2 /opt/iobroker/node_modules/minipass-fetch
                                        npm error extraneous: minipass-flush@1.0.5 /opt/iobroker/node_modules/minipass-flush
                                        npm error extraneous: minipass-pipeline@1.2.4 /opt/iobroker/node_modules/minipass-pipeline
                                        npm error extraneous: minipass-sized@1.0.3 /opt/iobroker/node_modules/minipass-sized
                                        npm error extraneous: minipass@7.1.2 /opt/iobroker/node_modules/minipass
                                        npm error extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/minizlib
                                        npm error extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
                                        npm error extraneous: mkdirp@1.0.4 /opt/iobroker/node_modules/mkdirp
                                        npm error extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
                                        npm error extraneous: moment-duration-format@2.3.2 /opt/iobroker/node_modules/moment-duration-format
                                        npm error extraneous: mqtt-connection@4.1.0 /opt/iobroker/node_modules/mqtt-connection
                                        npm error extraneous: mqtt-packet@9.0.0 /opt/iobroker/node_modules/mqtt-packet
                                        npm error extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
                                        npm error extraneous: mute-stream@0.0.8 /opt/iobroker/node_modules/mute-stream
                                        npm error extraneous: named-placeholders@1.1.3 /opt/iobroker/node_modules/named-placeholders
                                        npm error extraneous: nan@ /opt/iobroker/node_modules/nan
                                        npm error extraneous: nanoid@3.3.7 /opt/iobroker/node_modules/nanoid
                                        npm error extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
                                        npm error extraneous: native-duplexpair@1.0.0 /opt/iobroker/node_modules/native-duplexpair
                                        npm error extraneous: nconf@0.10.0 /opt/iobroker/node_modules/nconf
                                        npm error extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
                                        npm error extraneous: netmask@2.0.2 /opt/iobroker/node_modules/netmask
                                        npm error extraneous: new-github-release-url@1.0.0 /opt/iobroker/node_modules/new-github-release-url
                                        npm error extraneous: node-abi@3.65.0 /opt/iobroker/node_modules/node-abi
                                        npm error extraneous: node-abort-controller@3.1.1 /opt/iobroker/node_modules/node-abort-controller
                                        npm error extraneous: node-cron@2.0.3 /opt/iobroker/node_modules/node-cron
                                        npm error extraneous: node-fetch@2.7.0 /opt/iobroker/node_modules/node-fetch
                                        npm error extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
                                        npm error extraneous: node-gyp@ /opt/iobroker/node_modules/node-gyp
                                        npm error extraneous: node-ical@0.16.1 /opt/iobroker/node_modules/node-ical
                                        npm error extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                                        npm error extraneous: node-libcurl@3.0.0 /opt/iobroker/node_modules/node-libcurl
                                        npm error extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
                                        npm error extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
                                        npm error extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
                                        npm error extraneous: node-unifi@2.5.1 /opt/iobroker/node_modules/node-unifi
                                        npm error extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
                                        npm error extraneous: node.extend@2.0.3 /opt/iobroker/node_modules/node.extend
                                        npm error extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
                                        npm error extraneous: normalize-package-data@3.0.3 /opt/iobroker/node_modules/normalize-package-data
                                        npm error extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
                                        npm error extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/normalize-url
                                        npm error extraneous: np@7.7.0 /opt/iobroker/node_modules/np
                                        npm error extraneous: npm-name@6.0.1 /opt/iobroker/node_modules/npm-name
                                        npm error extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
                                        npm error extraneous: number-allocator@1.0.14 /opt/iobroker/node_modules/number-allocator
                                        npm error extraneous: nwsapi@2.2.12 /opt/iobroker/node_modules/nwsapi
                                        npm error extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assign
                                        npm error extraneous: object-hash@3.0.0 /opt/iobroker/node_modules/object-hash
                                        npm error extraneous: on-finished@2.4.1 /opt/iobroker/node_modules/on-finished
                                        npm error extraneous: once@1.4.0 /opt/iobroker/node_modules/once
                                        npm error extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
                                        npm error extraneous: onedrive-api@1.1.1 /opt/iobroker/node_modules/onedrive-api
                                        npm error extraneous: open@7.4.2 /opt/iobroker/node_modules/open
                                        npm error extraneous: opencollective-postinstall@2.0.3 /opt/iobroker/node_modules/opencollective-postinstall
                                        npm error extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator
                                        npm error extraneous: org-regex@1.0.0 /opt/iobroker/node_modules/org-regex
                                        npm error extraneous: os-tmpdir@1.0.2 /opt/iobroker/node_modules/os-tmpdir
                                        npm error extraneous: ospath@1.2.2 /opt/iobroker/node_modules/ospath
                                        npm error extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
                                        npm error extraneous: otplib@11.0.1 /opt/iobroker/node_modules/otplib
                                        npm error extraneous: ow@0.21.0 /opt/iobroker/node_modules/ow
                                        npm error extraneous: p-cancelable@2.1.1 /opt/iobroker/node_modules/p-cancelable
                                        npm error extraneous: p-defer@1.0.0 /opt/iobroker/node_modules/p-defer
                                        npm error extraneous: p-event@4.2.0 /opt/iobroker/node_modules/p-event
                                        npm error extraneous: p-finally@1.0.0 /opt/iobroker/node_modules/p-finally
                                        npm error extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/p-limit
                                        npm error extraneous: p-locate@5.0.0 /opt/iobroker/node_modules/p-locate
                                        npm error extraneous: p-map@2.1.0 /opt/iobroker/node_modules/p-map
                                        npm error extraneous: p-memoize@4.0.4 /opt/iobroker/node_modules/p-memoize
                                        npm error extraneous: p-reflect@2.1.0 /opt/iobroker/node_modules/p-reflect
                                        npm error extraneous: p-settle@4.1.1 /opt/iobroker/node_modules/p-settle
                                        npm error extraneous: p-throttle@4.1.1 /opt/iobroker/node_modules/p-throttle
                                        npm error extraneous: p-timeout@4.1.0 /opt/iobroker/node_modules/p-timeout
                                        npm error extraneous: p-try@2.2.0 /opt/iobroker/node_modules/p-try
                                        npm error extraneous: package-json-from-dist@1.0.0 /opt/iobroker/node_modules/package-json-from-dist
                                        npm error extraneous: package-json@6.5.0 /opt/iobroker/node_modules/package-json
                                        npm error extraneous: pako@ /opt/iobroker/node_modules/pako
                                        npm error extraneous: parent-module@1.0.1 /opt/iobroker/node_modules/parent-module
                                        npm error extraneous: parse-json@5.2.0 /opt/iobroker/node_modules/parse-json
                                        npm error extraneous: parse5@ /opt/iobroker/node_modules/parse5
                                        npm error extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
                                        npm error extraneous: passport@0.7.0 /opt/iobroker/node_modules/passport
                                        npm error extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/path-exists
                                        npm error extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
                                        npm error extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
                                        npm error extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
                                        npm error extraneous: path-scurry@1.11.1 /opt/iobroker/node_modules/path-scurry
                                        npm error extraneous: path-to-regexp@0.1.7 /opt/iobroker/node_modules/path-to-regexp
                                        npm error extraneous: path-type@4.0.0 /opt/iobroker/node_modules/path-type
                                        npm error extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
                                        npm error extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/picomatch
                                        npm error extraneous: pidtree@0.6.0 /opt/iobroker/node_modules/pidtree
                                        npm error extraneous: pidusage@3.0.2 /opt/iobroker/node_modules/pidusage
                                        npm error extraneous: ping@0.4.4 /opt/iobroker/node_modules/ping
                                        npm error extraneous: pkg-dir@5.0.0 /opt/iobroker/node_modules/pkg-dir
                                        npm error extraneous: pluralize@8.0.0 /opt/iobroker/node_modules/pluralize
                                        npm error extraneous: possible-typed-array-names@1.0.0 /opt/iobroker/node_modules/possible-typed-array-names
                                        npm error extraneous: prebuild-install@7.1.2 /opt/iobroker/node_modules/prebuild-install
                                        npm error extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls
                                        npm error extraneous: prepend-http@2.0.0 /opt/iobroker/node_modules/prepend-http
                                        npm error extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/process-nextick-args
                                        npm error extraneous: process@0.11.10 /opt/iobroker/node_modules/process
                                        npm error extraneous: promise-inflight@1.0.1 /opt/iobroker/node_modules/promise-inflight
                                        npm error extraneous: promise-object@0.1.7 /opt/iobroker/node_modules/promise-object
                                        npm error extraneous: promise-retry@2.0.1 /opt/iobroker/node_modules/promise-retry
                                        npm error extraneous: promise-retryer@0.0.1 /opt/iobroker/node_modules/promise-retryer
                                        npm error extraneous: promisify-child-process@4.1.2 /opt/iobroker/node_modules/promisify-child-process
                                        npm error extraneous: prompt@1.3.0 /opt/iobroker/node_modules/prompt
                                        npm error extraneous: protobufjs@ /opt/iobroker/node_modules/protobufjs
                                        npm error extraneous: proxy-addr@2.0.7 /opt/iobroker/node_modules/proxy-addr
                                        npm error extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
                                        npm error extraneous: pump@3.0.0 /opt/iobroker/node_modules/pump
                                        npm error extraneous: pupa@2.1.1 /opt/iobroker/node_modules/pupa
                                        npm error extraneous: q@1.1.2 /opt/iobroker/node_modules/q
                                        npm error extraneous: quasar@ /opt/iobroker/node_modules/quasar
                                        npm error extraneous: queue-microtask@1.2.3 /opt/iobroker/node_modules/queue-microtask
                                        npm error extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
                                        npm error extraneous: quick-lru@5.1.1 /opt/iobroker/node_modules/quick-lru
                                        npm error extraneous: range-parser@1.2.1 /opt/iobroker/node_modules/range-parser
                                        npm error extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/raw-body
                                        npm error extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
                                        npm error extraneous: read-pkg-up@7.0.1 /opt/iobroker/node_modules/read-pkg-up
                                        npm error extraneous: read-pkg@5.2.0 /opt/iobroker/node_modules/read-pkg
                                        npm error extraneous: read@1.0.7 /opt/iobroker/node_modules/read
                                        npm error extraneous: readable-stream@ /opt/iobroker/node_modules/readable-stream
                                        npm error extraneous: readdir-glob@1.1.3 /opt/iobroker/node_modules/readdir-glob
                                        npm error extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
                                        npm error extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
                                        npm error extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
                                        npm error extraneous: redent@3.0.0 /opt/iobroker/node_modules/redent
                                        npm error extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
                                        npm error extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
                                        npm error extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
                                        npm error extraneous: regenerator-runtime@0.14.1 /opt/iobroker/node_modules/regenerator-runtime
                                        npm error extraneous: regex-escape@3.4.10 /opt/iobroker/node_modules/regex-escape
                                        npm error extraneous: regexp.prototype.flags@1.5.2 /opt/iobroker/node_modules/regexp.prototype.flags
                                        npm error extraneous: registry-auth-token@4.2.2 /opt/iobroker/node_modules/registry-auth-token
                                        npm error extraneous: registry-url@5.1.0 /opt/iobroker/node_modules/registry-url
                                        npm error extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
                                        npm error extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
                                        npm error extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string
                                        npm error extraneous: resolve-alpn@1.2.1 /opt/iobroker/node_modules/resolve-alpn
                                        npm error extraneous: resolve-cwd@3.0.0 /opt/iobroker/node_modules/resolve-cwd
                                        npm error extraneous: resolve-from@4.0.0 /opt/iobroker/node_modules/resolve-from
                                        npm error extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
                                        npm error extraneous: responselike@2.0.1 /opt/iobroker/node_modules/responselike
                                        npm error extraneous: restore-cursor@3.1.0 /opt/iobroker/node_modules/restore-cursor
                                        npm error extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
                                        npm error extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
                                        npm error extraneous: reusify@1.0.4 /opt/iobroker/node_modules/reusify
                                        npm error extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
                                        npm error extraneous: rfdc@1.4.1 /opt/iobroker/node_modules/rfdc
                                        npm error extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/rimraf
                                        npm error extraneous: rrule@2.8.1 /opt/iobroker/node_modules/rrule
                                        npm error extraneous: rrweb-cssom@0.6.0 /opt/iobroker/node_modules/rrweb-cssom
                                        npm error extraneous: run-async@2.4.1 /opt/iobroker/node_modules/run-async
                                        npm error extraneous: run-parallel@1.2.0 /opt/iobroker/node_modules/run-parallel
                                        npm error extraneous: rxjs@ /opt/iobroker/node_modules/rxjs
                                        npm error extraneous: safe-array-concat@1.1.2 /opt/iobroker/node_modules/safe-array-concat
                                        npm error extraneous: safe-regex-test@1.0.3 /opt/iobroker/node_modules/safe-regex-test
                                        npm error extraneous: safe-stable-stringify@2.4.3 /opt/iobroker/node_modules/safe-stable-stringify
                                        npm error extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/safer-buffer
                                        npm error extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
                                        npm error extraneous: scoped-regex@2.1.0 /opt/iobroker/node_modules/scoped-regex
                                        npm error extraneous: secure-keys@1.0.0 /opt/iobroker/node_modules/secure-keys
                                        npm error extraneous: semver-diff@3.1.1 /opt/iobroker/node_modules/semver-diff
                                        npm error extraneous: send@0.18.0 /opt/iobroker/node_modules/send
                                        npm error extraneous: seq-logging@1.1.2 /opt/iobroker/node_modules/seq-logging
                                        npm error extraneous: seq-queue@0.0.5 /opt/iobroker/node_modules/seq-queue
                                        npm error extraneous: serve-static@1.15.0 /opt/iobroker/node_modules/serve-static
                                        npm error extraneous: set-function-name@2.0.2 /opt/iobroker/node_modules/set-function-name
                                        npm error extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
                                        npm error extraneous: setprototypeof@1.2.0 /opt/iobroker/node_modules/setprototypeof
                                        npm error extraneous: signal-exit@4.1.0 /opt/iobroker/node_modules/signal-exit
                                        npm error extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
                                        npm error extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
                                        npm error extraneous: simple-ssh@1.1.1 /opt/iobroker/node_modules/simple-ssh
                                        npm error extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
                                        npm error extraneous: slash@3.0.0 /opt/iobroker/node_modules/slash
                                        npm error extraneous: slice-ansi@0.0.4 /opt/iobroker/node_modules/slice-ansi
                                        npm error extraneous: smart-buffer@4.2.0 /opt/iobroker/node_modules/smart-buffer
                                        npm error extraneous: socks-proxy-agent@7.0.0 /opt/iobroker/node_modules/socks-proxy-agent
                                        npm error extraneous: socks@2.8.3 /opt/iobroker/node_modules/socks
                                        npm error extraneous: speedtest-net@1.6.2 /opt/iobroker/node_modules/speedtest-net
                                        npm error extraneous: split@1.0.1 /opt/iobroker/node_modules/split
                                        npm error extraneous: sprintf-js@1.1.3 /opt/iobroker/node_modules/sprintf-js
                                        npm error extraneous: sqlstring@2.3.3 /opt/iobroker/node_modules/sqlstring
                                        npm error extraneous: ssh2@ /opt/iobroker/node_modules/ssh2
                                        npm error extraneous: ssri@9.0.1 /opt/iobroker/node_modules/ssri
                                        npm error extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
                                        npm error extraneous: stampit-event-bus@0.1.1 /opt/iobroker/node_modules/stampit-event-bus
                                        npm error extraneous: stampit-state-machine@0.2.1 /opt/iobroker/node_modules/stampit-state-machine
                                        npm error extraneous: stampit@2.1.2 /opt/iobroker/node_modules/stampit
                                        npm error extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
                                        npm error extraneous: static-eval@2.0.2 /opt/iobroker/node_modules/static-eval
                                        npm error extraneous: statuses@2.0.1 /opt/iobroker/node_modules/statuses
                                        npm error extraneous: stoppable@1.1.0 /opt/iobroker/node_modules/stoppable
                                        npm error extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
                                        npm error extraneous: stream-shift@1.0.3 /opt/iobroker/node_modules/stream-shift
                                        npm error extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
                                        npm error extraneous: streamx@2.18.0 /opt/iobroker/node_modules/streamx
                                        npm error extraneous: string-argv@0.3.2 /opt/iobroker/node_modules/string-argv
                                        npm error extraneous: string-width-cjs@npm:string-width@4.2.3 /opt/iobroker/node_modules/string-width-cjs
                                        npm error extraneous: string-width@5.1.2 /opt/iobroker/node_modules/string-width
                                        npm error extraneous: string.prototype.trim@1.2.9 /opt/iobroker/node_modules/string.prototype.trim
                                        npm error extraneous: string.prototype.trimend@1.0.8 /opt/iobroker/node_modules/string.prototype.trimend
                                        npm error extraneous: string.prototype.trimstart@1.0.8 /opt/iobroker/node_modules/string.prototype.trimstart
                                        npm error extraneous: strip-ansi-cjs@npm:strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi-cjs
                                        npm error extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi
                                        npm error extraneous: strip-indent@3.0.0 /opt/iobroker/node_modules/strip-indent
                                        npm error extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
                                        npm error extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
                                        npm error extraneous: suncalc@1.9.0 /opt/iobroker/node_modules/suncalc
                                        npm error extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                                        npm error extraneous: supermixer@1.0.5 /opt/iobroker/node_modules/supermixer
                                        npm error extraneous: supports-color@7.2.0 /opt/iobroker/node_modules/supports-color
                                        npm error extraneous: supports-hyperlinks@2.3.0 /opt/iobroker/node_modules/supports-hyperlinks
                                        npm error extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
                                        npm error extraneous: sweet-collections@1.1.0 /opt/iobroker/node_modules/sweet-collections
                                        npm error extraneous: symbol-observable@3.0.0 /opt/iobroker/node_modules/symbol-observable
                                        npm error extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
                                        npm error extraneous: syno@ /opt/iobroker/node_modules/syno
                                        npm error extraneous: systeminformation@ /opt/iobroker/node_modules/systeminformation
                                        npm error extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
                                        npm error extraneous: tar-stream@3.1.7 /opt/iobroker/node_modules/tar-stream
                                        npm error extraneous: tar@6.2.1 /opt/iobroker/node_modules/tar
                                        npm error extraneous: tarn@3.0.2 /opt/iobroker/node_modules/tarn
                                        npm error extraneous: tcp-port-used@1.0.2 /opt/iobroker/node_modules/tcp-port-used
                                        npm error extraneous: tedious@ /opt/iobroker/node_modules/tedious
                                        npm error extraneous: terminal-link@2.1.1 /opt/iobroker/node_modules/terminal-link
                                        npm error extraneous: text-decoder@1.1.1 /opt/iobroker/node_modules/text-decoder
                                        npm error extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
                                        npm error extraneous: thirty-two@1.0.2 /opt/iobroker/node_modules/thirty-two
                                        npm error extraneous: through@2.3.8 /opt/iobroker/node_modules/through
                                        npm error extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
                                        npm error extraneous: tiny-typed-emitter@2.1.0 /opt/iobroker/node_modules/tiny-typed-emitter
                                        npm error extraneous: tinycolor2@1.6.0 /opt/iobroker/node_modules/tinycolor2
                                        npm error extraneous: tmp@0.0.33 /opt/iobroker/node_modules/tmp
                                        npm error extraneous: to-readable-stream@2.1.0 /opt/iobroker/node_modules/to-readable-stream
                                        npm error extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/to-regex-range
                                        npm error extraneous: toidentifier@1.0.1 /opt/iobroker/node_modules/toidentifier
                                        npm error extraneous: tr46@4.1.1 /opt/iobroker/node_modules/tr46
                                        npm error extraneous: trim-newlines@3.0.1 /opt/iobroker/node_modules/trim-newlines
                                        npm error extraneous: triple-beam@1.4.1 /opt/iobroker/node_modules/triple-beam
                                        npm error extraneous: tsdav@ /opt/iobroker/node_modules/tsdav
                                        npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/tslib
                                        npm error extraneous: tweetnacl@0.14.5 /opt/iobroker/node_modules/tweetnacl
                                        npm error extraneous: type-check@0.3.2 /opt/iobroker/node_modules/type-check
                                        npm error extraneous: type-fest@0.21.3 /opt/iobroker/node_modules/type-fest
                                        npm error extraneous: type-is@1.6.18 /opt/iobroker/node_modules/type-is
                                        npm error extraneous: typed-array-buffer@1.0.2 /opt/iobroker/node_modules/typed-array-buffer
                                        npm error extraneous: typed-array-byte-length@1.0.1 /opt/iobroker/node_modules/typed-array-byte-length
                                        npm error extraneous: typed-array-byte-offset@1.0.2 /opt/iobroker/node_modules/typed-array-byte-offset
                                        npm error extraneous: typed-array-length@1.0.6 /opt/iobroker/node_modules/typed-array-length
                                        npm error extraneous: typedarray-to-buffer@3.1.5 /opt/iobroker/node_modules/typedarray-to-buffer
                                        npm error extraneous: typedarray.prototype.slice@1.0.3 /opt/iobroker/node_modules/typedarray.prototype.slice
                                        npm error extraneous: typescript@ /opt/iobroker/node_modules/typescript
                                        npm error extraneous: tz-offset@0.0.1 /opt/iobroker/node_modules/tz-offset
                                        npm error extraneous: uid-number@0.0.6 /opt/iobroker/node_modules/uid-number
                                        npm error extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
                                        npm error extraneous: undici-types@6.19.6 /opt/iobroker/node_modules/undici-types
                                        npm error extraneous: unique-filename@2.0.1 /opt/iobroker/node_modules/unique-filename
                                        npm error extraneous: unique-slug@3.0.0 /opt/iobroker/node_modules/unique-slug
                                        npm error extraneous: unique-string@2.0.0 /opt/iobroker/node_modules/unique-string
                                        npm error extraneous: unix-dgram@2.0.6 /opt/iobroker/node_modules/unix-dgram
                                        npm error extraneous: unpipe@1.0.0 /opt/iobroker/node_modules/unpipe
                                        npm error extraneous: update-notifier@5.1.0 /opt/iobroker/node_modules/update-notifier
                                        npm error extraneous: uri-js@4.4.1 /opt/iobroker/node_modules/uri-js
                                        npm error extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
                                        npm error extraneous: url-parse-lax@3.0.0 /opt/iobroker/node_modules/url-parse-lax
                                        npm error extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
                                        npm error extraneous: url@0.11.4 /opt/iobroker/node_modules/url
                                        npm error extraneous: vali-date@1.0.0 /opt/iobroker/node_modules/vali-date
                                        npm error extraneous: validate-npm-package-name@3.0.0 /opt/iobroker/node_modules/validate-npm-package-name
                                        npm error extraneous: vary@1.1.2 /opt/iobroker/node_modules/vary
                                        npm error extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                                        npm error extraneous: vue-i18n@ /opt/iobroker/node_modules/vue-i18n
                                        npm error extraneous: vuelidate-messages@0.1.2 /opt/iobroker/node_modules/vuelidate-messages
                                        npm error extraneous: vuelidate@ /opt/iobroker/node_modules/vuelidate
                                        npm error extraneous: vuex-map-fields@1.4.1 /opt/iobroker/node_modules/vuex-map-fields
                                        npm error extraneous: w3c-xmlserializer@4.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
                                        npm error extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                                        npm error extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
                                        npm error extraneous: webdav@ /opt/iobroker/node_modules/webdav
                                        npm error extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
                                        npm error extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
                                        npm error extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
                                        npm error extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
                                        npm error extraneous: whatwg-url@12.0.1 /opt/iobroker/node_modules/whatwg-url
                                        npm error extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
                                        npm error extraneous: which-typed-array@1.1.15 /opt/iobroker/node_modules/which-typed-array
                                        npm error extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
                                        npm error extraneous: widest-line@3.1.0 /opt/iobroker/node_modules/widest-line
                                        npm error extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
                                        npm error extraneous: winston-daily-rotate-file@5.0.0 /opt/iobroker/node_modules/winston-daily-rotate-file
                                        npm error extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
                                        npm error extraneous: winston-syslog@2.7.1 /opt/iobroker/node_modules/winston-syslog
                                        npm error extraneous: winston-transport@4.7.1 /opt/iobroker/node_modules/winston-transport
                                        npm error extraneous: winston@ /opt/iobroker/node_modules/winston
                                        npm error extraneous: word-wrap@1.2.5 /opt/iobroker/node_modules/word-wrap
                                        npm error extraneous: worker-timers-broker@6.1.8 /opt/iobroker/node_modules/worker-timers-broker
                                        npm error extraneous: worker-timers-worker@7.0.71 /opt/iobroker/node_modules/worker-timers-worker
                                        npm error extraneous: worker-timers@7.1.8 /opt/iobroker/node_modules/worker-timers
                                        npm error extraneous: wrap-ansi-cjs@npm:wrap-ansi@7.0.0 /opt/iobroker/node_modules/wrap-ansi-cjs
                                        npm error extraneous: wrap-ansi@8.1.0 /opt/iobroker/node_modules/wrap-ansi
                                        npm error extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/wrappy
                                        npm error extraneous: write-file-atomic@3.0.3 /opt/iobroker/node_modules/write-file-atomic
                                        npm error extraneous: xdg-basedir@4.0.0 /opt/iobroker/node_modules/xdg-basedir
                                        npm error extraneous: xml-js@1.6.11 /opt/iobroker/node_modules/xml-js
                                        npm error extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
                                        npm error extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
                                        npm error extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
                                        npm error extraneous: yallist@4.0.0 /opt/iobroker/node_modules/yallist
                                        npm error extraneous: yaml@ /opt/iobroker/node_modules/yaml
                                        npm error extraneous: yargs-parser@20.2.9 /opt/iobroker/node_modules/yargs-parser
                                        npm error extraneous: yocto-queue@0.1.0 /opt/iobroker/node_modules/yocto-queue
                                        npm error extraneous: zip-stream@6.0.1 /opt/iobroker/node_modules/zip-stream
                                        npm error extraneous: zrender@ /opt/iobroker/node_modules/zrender
                                        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T19_54_40_124Z-debug-0.log
                                          Thomas Braun Most Active @mcm1957 last edited by
                                          @mcm1957 sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                                          Wo stammen eigentlich die ganzen GITHUB dependencies her, z.B.
                                          War mich auch schon in's Auge gesprungen.
                                            flommaster @Thomas Braun last edited by
                                            @thomas-braun sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                                            Keine Ahnung.
                                            Soll ich das System komplett neu aufsetzen?
                                            5303
