    4. Beim Update von Adaptern stürzt der ioBroker ab
      flommaster @Thomas Braun last edited by
      Hallo Thomas,
      nach zahlreichen Warnmeldungen, kommt dann eine Error Meldung (npm error code 127) die den Vorgang abbricht.
      npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.web-speedy.git
      npm warn skipping integrity check for git dependency ssh://git@github.com/peterbaumert/ioBroker.vofo-speedtest.git
      npm warn skipping integrity check for git dependency ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git
      npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2-widgets-material.git
      npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2.git
      npm warn skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git
      npm warn skipping integrity check for git dependency ssh://git@github.com/aendue/ioBroker.reolink.git
      npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.ical.git
      npm warn skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git
      npm warn skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git
      npm warn skipping integrity check for git dependency ssh://git@github.com/WLAN-Kabel/ioBroker.calendar.git
      npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
      npm warn deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
      npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
      npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
      npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
      npm warn deprecated uid-number@0.0.6: This package is no longer supported.
      npm warn deprecated npmlog@5.0.1: This package is no longer supported.
      npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
      npm warn deprecated npmlog@6.0.2: This package is no longer supported.
      npm warn deprecated har-validator@5.1.5: this library is no longer supported
      npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
      npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
      npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
      npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
      npm warn deprecated q@1.1.2: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
      npm warn deprecated
      npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
      npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
      npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
      npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
      npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
      npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
      npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
      npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
      npm warn deprecated google-p12-pem@3.1.4: Package is no longer maintained
      npm warn deprecated gauge@3.0.2: This package is no longer supported.
      npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm warn deprecated gauge@4.0.4: This package is no longer supported.
      npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm warn deprecated later@1.2.0: Please upgrade to the maintained and new drop-in replacement @breejs/later at https://github.com/breejs/later 🚀 Thanks and happy hacking! 🚀  @niftylettuce
      npm error code 127
      npm error path /opt/iobroker/node_modules/zlib
      npm error command failed
      npm error command sh -c node-waf clean || true; node-waf configure build
      npm error sh: 1: node-waf: not found
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T19_24_28_844Z-debug-0.log
      Kann ich da noch was retten?
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
      Qix- created this issue in visionmedia/debug
      closed ReDos Vulnerability Regression Visibility Notice #797
        Thomas Braun Most Active @flommaster last edited by
        @flommaster sagte in Beim Update von Adaptern stürzt der ioBroker ab:
        Das ist genau das Ding aus dem anderen Thread. Welcher Adapter war das da? mihome-vaccuum?
        Versuch den mal zu aktualisieren.
        iob update
        iob upgrade BÖSER_ADAPTER
          Das geht gar nicht mehr.
          iob upgrade mihome-vaccuum
          node:internal/modules/cjs/loader:1148
            throw err;
          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
              at Module._resolveFilename (node:internal/modules/cjs/loader:1145:15)
              at Module._load (node:internal/modules/cjs/loader:986:27)
              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
              at node:internal/main/run_main_module:28:49 {
            code: 'MODULE_NOT_FOUND',
            requireStack: []
          Node.js v20.16.0
          Kann ich den Adapter auch komplett löschen. Den Staubsauger nutze ich nur noch manuell...
            @flommaster
            cd /opt/iobroker && npm ls
            spuckt aus?
            mcm1957 F 2 Replies Last reply Reply Quote 0
            • mcm1957
              mcm1957 @Thomas Braun last edited by
              Wo stammen eigentlich die ganzen GITHUB dependencies her, z.B.
              Den Adapter gibts (dort) gar nicht ...
                @thomas-braun sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                zu viele Fehler...
                Teil 1
                iobroker.inst@2.0.3 /opt/iobroker
                ├── @alcalzone/esbuild-register@2.5.1-1 extraneous
                ├── @alcalzone/jsonl-db@3.1.1 extraneous
                ├── @alcalzone/pak@0.8.1 extraneous
                ├── @alcalzone/proper-lockfile@4.1.3-0 extraneous
                ├── @aws-sdk/util-utf8-browser@3.259.0 extraneous
                ├── @azure/abort-controller@1.1.0 extraneous
                ├── @azure/core-auth@1.7.2 extraneous
                ├── @azure/core-client@ extraneous
                ├── @azure/core-http-compat@ extraneous
                ├── @azure/core-lro@ extraneous
                ├── @azure/core-paging@1.6.2 extraneous
                ├── @azure/core-rest-pipeline@ extraneous
                ├── @azure/core-tracing@1.1.2 extraneous
                ├── @azure/core-util@ extraneous
                ├── @azure/identity@ extraneous
                ├── @azure/keyvault-keys@ extraneous
                ├── @azure/logger@1.1.4 extraneous
                ├── @azure/msal-browser@ extraneous
                ├── @azure/msal-common@ extraneous
                ├── @azure/msal-node@1.18.4 extraneous
                ├── @babel/code-frame@7.24.7 extraneous
                ├── @babel/helper-validator-identifier@7.24.7 extraneous
                ├── @babel/highlight@7.24.7 extraneous
                ├── @babel/runtime@ extraneous
                ├── @colors/colors@1.5.0 extraneous
                ├── @dabh/diagnostics@2.0.3 extraneous
                ├── @datalust/winston-seq@1.0.2 extraneous
                ├── @gar/promisify@1.1.3 extraneous
                ├── @googleapis/calendar@9.7.7 extraneous
                ├── @googleapis/drive@5.1.0 extraneous
                ├── @googleapis/oauth2@1.0.7 extraneous
                ├── @httptoolkit/websocket-stream@6.0.1 extraneous
                ├── @iobroker/db-base@ extraneous
                ├── @iobroker/db-objects-file@ extraneous
                ├── @iobroker/db-objects-jsonl@ extraneous
                ├── @iobroker/db-objects-redis@ extraneous
                ├── @iobroker/db-states-file@ extraneous
                ├── @iobroker/db-states-jsonl@ extraneous
                ├── @iobroker/db-states-redis@ extraneous
                ├── @iobroker/js-controller-adapter@ extraneous
                ├── @iobroker/js-controller-cli@ extraneous
                ├── @iobroker/js-controller-common-db@ extraneous
                ├── @iobroker/js-controller-common@ extraneous
                ├── @iobroker/plugin-base@1.2.1 extraneous
                ├── @iobroker/plugin-sentry@1.2.1 extraneous
                ├── @iobroker/socket-classes@1.5.6 extraneous
                ├── @iobroker/webserver@1.0.3 extraneous
                ├── @isaacs/cliui@8.0.2 extraneous
                ├── @js-joda/core@ extraneous
                ├── @mapbox/node-pre-gyp@1.0.11 extraneous
                ├── @microsoft/microsoft-graph-types@2.40.0 extraneous
                ├── @nodelib/fs.scandir@2.1.5 extraneous
                ├── @nodelib/fs.stat@2.0.5 extraneous
                ├── @nodelib/fs.walk@1.2.8 extraneous
                ├── @npmcli/fs@2.1.2 extraneous
                ├── @npmcli/move-file@2.0.1 extraneous
                ├── @pkgjs/parseargs@0.11.0 extraneous
                ├── @protobufjs/aspromise@1.1.2 extraneous
                ├── @protobufjs/base64@1.1.2 extraneous
                ├── @protobufjs/codegen@2.0.4 extraneous
                ├── @protobufjs/eventemitter@1.1.0 extraneous
                ├── @protobufjs/fetch@1.1.0 extraneous
                ├── @protobufjs/float@1.0.2 extraneous
                ├── @protobufjs/inquire@1.1.0 extraneous
                ├── @protobufjs/path@1.1.2 extraneous
                ├── @protobufjs/pool@1.1.0 extraneous
                ├── @protobufjs/utf8@1.1.0 extraneous
                ├── @quasar/extras@ extraneous
                ├── @samverschueren/stream-to-observable@0.3.1 extraneous
                ├── @sentry-internal/tracing@ extraneous
                ├── @sentry/core@5.30.0 extraneous
                ├── @sentry/hub@5.30.0 extraneous
                ├── @sentry/minimal@5.30.0 extraneous
                ├── @sentry/node@ extraneous
                ├── @sentry/tracing@ extraneous
                ├── @sentry/types@ extraneous
                ├── @sentry/utils@ extraneous
                ├── @sindresorhus/is@4.6.0 extraneous
                ├── @socket.io/component-emitter@3.1.2 extraneous
                ├── @szmarczak/http-timer@4.0.6 extraneous
                ├── @tediousjs/connection-string@0.5.0 extraneous
                ├── @tootallnate/once@2.0.0 extraneous
                ├── @types/bl@5.1.0 extraneous
                ├── @types/cacheable-request@6.0.3 extraneous
                ├── @types/caseless@0.12.5 extraneous
                ├── @types/cookie@0.4.1 extraneous
                ├── @types/cors@2.8.17 extraneous
                ├── @types/geojson@7946.0.14 extraneous
                ├── @types/http-cache-semantics@4.0.4 extraneous
                ├── @types/keyv@3.1.4 extraneous
                ├── @types/leaflet@1.9.12 extraneous
                ├── @types/minimist@1.2.5 extraneous
                ├── @types/node-cron@2.0.8 extraneous
                ├── @types/node@ extraneous
                ├── @types/normalize-package-data@2.4.4 extraneous
                ├── @types/parse-json@4.0.2 extraneous
                ├── @types/readable-stream@4.0.15 extraneous
                ├── @types/request@2.48.12 extraneous
                ├── @types/responselike@1.0.3 extraneous
                ├── @types/tough-cookie@4.0.5 extraneous
                ├── @types/triple-beam@1.3.5 extraneous
                ├── @types/tz-offset@0.0.3 extraneous
                ├── @types/ws@8.5.12 extraneous
                ├── abab@2.0.6 extraneous
                ├── abbrev@1.1.1 extraneous
                ├── abort-controller@3.0.0 extraneous
                ├── agentkeepalive@4.5.0 extraneous
                ├── aggregate-error@3.1.0 extraneous
                ├── ajv@ extraneous
                ├── ansi-align@3.0.1 extraneous
                ├── ansi-colors@4.1.3 extraneous
                ├── ansi-escapes@4.3.2 extraneous
                ├── ansi-regex@5.0.1 extraneous
                ├── ansi-styles@4.3.0 extraneous
                ├── any-observable@0.5.1 extraneous
                ├── anymatch@3.1.3 extraneous
                ├── aproba@2.0.0 extraneous
                ├── archiver-utils@5.0.2 extraneous
                ├── archiver@7.0.1 extraneous
                ├── are-we-there-yet@2.0.0 extraneous
                ├── arg@4.1.0 extraneous
                ├── argparse@1.0.10 extraneous
                ├── array-buffer-byte-length@1.0.1 extraneous
                ├── array-flatten@1.1.1 extraneous
                ├── array-union@2.1.0 extraneous
                ├── arraybuffer.prototype.slice@1.0.3 extraneous
                ├── arrify@2.0.1 extraneous
                ├── asn1@0.2.6 extraneous
                ├── async-exit-hook@2.0.1 extraneous
                ├── authenticate-pam@1.0.5 extraneous
                ├── available-typed-arrays@1.0.7 extraneous
                ├── aws-crt@ extraneous
                ├── b4a@1.6.6 extraneous
                ├── balanced-match@1.0.2 extraneous
                ├── bare-events@2.4.2 extraneous
                ├── base-64@1.0.0 extraneous
                ├── base64-js@1.5.1 extraneous
                ├── bcrypt-pbkdf@1.0.2 extraneous
                ├── binary-extensions@2.3.0 extraneous
                ├── bindings@1.5.0 extraneous
                ├── bl@6.0.14 extraneous
                ├── bluebird@3.7.2 extraneous
                ├── body-parser@1.20.2 extraneous
                ├── bottleneck@2.19.5 extraneous
                ├── boxen@5.1.2 extraneous
                ├── brace-expansion@2.0.1 extraneous
                ├── braces@3.0.3 extraneous
                ├── buffer-crc32@1.0.0 extraneous
                ├── buffer-equal-constant-time@1.0.1 extraneous
                ├── buffer-shims@1.0.0 extraneous
                ├── buffer@6.0.3 extraneous
                ├── buildcheck@0.0.6 extraneous
                ├── builtins@1.0.3 extraneous
                ├── busboy@1.6.0 extraneous
                ├── byte-length@1.0.2 extraneous
                ├── bytes@3.1.2 extraneous
                ├── cacache@16.1.3 extraneous
                ├── cacheable-lookup@5.0.4 extraneous
                ├── cacheable-request@7.0.4 extraneous
                ├── callsites@3.1.0 extraneous
                ├── camelcase-keys@6.2.2 extraneous
                ├── camelcase@5.3.1 extraneous
                ├── capitalize@2.0.4 extraneous
                ├── chalk@4.1.2 extraneous
                ├── chardet@0.7.0 extraneous
                ├── charenc@0.0.2 extraneous
                ├── chokidar@3.6.0 extraneous
                ├── chownr@2.0.0 extraneous
                ├── ci-info@3.9.0 extraneous
                ├── clean-stack@2.2.0 extraneous
                ├── cli-boxes@2.2.1 extraneous
                ├── cli-cursor@3.1.0 extraneous
                ├── cli-truncate@0.2.1 extraneous
                ├── cli-width@3.0.0 extraneous
                ├── clone-response@1.0.3 extraneous
                ├── cloneextend@0.0.3 extraneous
                ├── cluster-key-slot@1.1.2 extraneous
                ├── coap-packet@1.1.1 extraneous
                ├── coffeescript@1.12.7 extraneous
                ├── color-convert@2.0.1 extraneous
                ├── color-name@1.1.4 extraneous
                ├── color-string@1.9.1 extraneous
                ├── color-support@1.1.3 extraneous
                ├── color@3.2.1 extraneous
                ├── colors@1.4.0
                ├── colorspace@1.1.4 extraneous
                ├── commander@9.5.0 extraneous
                ├── commist@3.2.0 extraneous
                ├── compress-commons@6.0.2 extraneous
                ├── compress-json@2.1.2 extraneous
                ├── compressible@2.0.18 extraneous
                ├── compression@1.7.4 extraneous
                ├── concat-map@0.0.1 extraneous
                ├── configstore@5.0.1 extraneous
                ├── connect-flash@0.1.1 extraneous
                ├── connect@3.7.0 extraneous
                ├── console-control-strings@1.1.0 extraneous
                ├── content-disposition@0.5.4 extraneous
                ├── content-type@1.0.5 extraneous
                ├── core-js@ extraneous
                ├── cors@2.8.5 extraneous
                ├── cosmiconfig@7.1.0 extraneous
                ├── cpu-features@ extraneous
                ├── crc-32@1.2.2 extraneous
                ├── crc@ extraneous
                ├── crc32-stream@6.0.0 extraneous
                ├── cross-fetch@4.0.0 extraneous
                ├── crypt@0.0.2 extraneous
                ├── crypto-js@ extraneous
                ├── crypto-random-string@2.0.0 extraneous
                ├── cssstyle@ extraneous
                ├── cycle@1.0.3 extraneous
                ├── dashdash@1.14.1 extraneous
                ├── data-urls@4.0.0 extraneous
                ├── data-view-buffer@1.0.1 extraneous
                ├── data-view-byte-length@1.0.1 extraneous
                ├── data-view-byte-offset@1.0.0 extraneous
                ├── date-and-time@ extraneous
                ├── date-fns@1.30.1 extraneous
                ├── dateformat@4.6.3 extraneous
                ├── dayjs@ extraneous
                ├── decache@4.6.2 extraneous
                ├── decamelize-keys@1.1.1 extraneous
                ├── decimal.js@10.4.3 extraneous
                ├── decompress-response@6.0.0 extraneous
                ├── deep-clone@3.0.3 extraneous
                ├── deep-extend@0.6.0 extraneous
                ├── deep-is@0.1.4 extraneous
                ├── defer-to-connect@2.0.1 extraneous
                ├── define-lazy-prop@2.0.0 extraneous
                ├── del@6.1.1 extraneous
                ├── delegates@1.0.0 extraneous
                ├── denque@1.5.1 extraneous
                ├── destroy@1.2.0 extraneous
                ├── detect-libc@2.0.3 extraneous
                ├── diacritics@1.3.0 extraneous
                ├── digest-header@1.1.0 extraneous
                ├── dir-glob@3.0.1 extraneous
                ├── diskusage@1.2.0 extraneous
                ├── domexception@4.0.0 extraneous
                ├── dot-prop@6.0.1 extraneous
                ├── draftlog@1.0.13 extraneous
                ├── dropbox-v2-api@ extraneous
                ├── duplexer@0.1.2 extraneous
                ├── duplexer3@0.1.5 extraneous
                ├── duplexify@3.7.1 extraneous
                ├── eastasianwidth@0.2.0 extraneous
                ├── ecc-jsbn@0.1.2 extraneous
                ├── ecdsa-sig-formatter@1.0.11 extraneous
                ├── echarts@ extraneous
                ├── ee-first@1.1.1 extraneous
                ├── elegant-spinner@1.0.1 extraneous
                ├── emoji-regex@9.2.2 extraneous
                ├── enabled@2.0.0 extraneous
                ├── encodeurl@1.0.2 extraneous
                ├── encoding@0.1.13 extraneous
                ├── end-of-stream@1.4.4 extraneous
                ├── entities@4.5.0 extraneous
                ├── err-code@2.0.3 extraneous
                ├── es-abstract@ extraneous
                ├── es-aggregate-error@1.0.13 extraneous
                ├── es-object-atoms@1.0.0 extraneous
                ├── es-set-tostringtag@2.0.3 extraneous
                ├── es-to-primitive@1.2.1 extraneous
                ├── es6-promise@4.2.8 extraneous
                ├── es6-promisify@5.0.0 extraneous
                ├── esbuild@0.11.23 extraneous
                ├── escalade@3.1.2 extraneous
                ├── escape-goat@3.0.0 extraneous
                ├── escape-html@1.0.3 extraneous
                ├── escape-string-regexp@4.0.0 extraneous
                ├── escodegen@1.14.3 extraneous
                ├── esprima@1.2.2 extraneous
                ├── estraverse@4.3.0 extraneous
                ├── esutils@2.0.3 extraneous
                ├── etag@1.8.1 extraneous
                ├── event-stream@4.0.1 extraneous
                ├── event-target-shim@5.0.1 extraneous
                ├── eventemitter2@6.4.9 extraneous
                ├── events@3.3.0 extraneous
                ├── execa@5.1.1 extraneous
                ├── expand-template@2.0.3 extraneous
                ├── express-fileupload@1.5.1 extraneous
                ├── express@4.19.2 extraneous
                ├── external-editor@3.1.0 extraneous
                ├── fast-deep-equal@3.1.3 extraneous
                ├── fast-fifo@1.3.2 extraneous
                ├── fast-glob@ extraneous
                ├── fast-json-stable-stringify@2.1.0 extraneous
                ├── fast-levenshtein@2.0.6 extraneous
                ├── fast-text-encoding@1.0.6 extraneous
                ├── fast-unique-numbers@ extraneous
                ├── fast-uri@3.0.1 extraneous
                ├── fast-xml-parser@ extraneous
                ├── fastq@1.17.1 extraneous
                ├── fastseries@2.0.0 extraneous
                ├── fecha@4.2.3 extraneous
                ├── figures@3.2.0 extraneous
                ├── file-stream-rotator@0.6.1 extraneous
                ├── file-type@10.11.0 extraneous
                ├── file-uri-to-path@1.0.0 extraneous
                ├── fill-range@7.1.1 extraneous
                ├── finalhandler@1.2.0 extraneous
                ├── find-up@5.0.0 extraneous
                ├── fn.name@1.1.0 extraneous
                ├── for-each@0.3.3 extraneous
                ├── foreground-child@3.3.0 extraneous
                ├── form-data-encoder@2.1.4 extraneous
                ├── form-data@4.0.0 extraneous
                ├── forwarded@0.2.0 extraneous
                ├── fresh@0.5.2 extraneous
                ├── from@0.1.7 extraneous
                ├── fs-constants@1.0.0 extraneous
                ├── fs-extra@7.0.1
                ├── fs-minipass@2.1.0 extraneous
                ├── fs.realpath@1.0.0 extraneous
                ├── fsevents@ extraneous
                ├── ftp@0.3.10 extraneous
                ├── function.prototype.name@1.1.6 extraneous
                ├── functions-have-names@1.2.3 extraneous
                ├── futoin-hkdf@1.4.3 extraneous
                ├── gauge@3.0.2 extraneous
                ├── gaxios@5.1.3 extraneous
                ├── gcp-metadata@5.3.0 extraneous
                ├── generate-function@2.3.1 extraneous
                ├── get-ssl-certificate@2.3.3 extraneous
                ├── get-stream@5.2.0 extraneous
                ├── get-symbol-description@1.0.2 extraneous
                ├── getpass@0.1.7 extraneous
                ├── github-from-package@0.0.0 extraneous
                ├── github-url-from-git@1.5.0 extraneous
                ├── glob-parent@5.1.2 extraneous
                ├── glob@10.4.5 extraneous
                ├── global-dirs@2.1.0 extraneous
                ├── globalthis@1.0.4 extraneous
                ├── globby@11.1.0 extraneous
                ├── glossy@0.1.7 extraneous
                ├── google-auth-library@ extraneous
                ├── google-p12-pem@4.0.1 extraneous
                ├── googleapis-common@6.0.4 extraneous
                ├── googleapis@ extraneous
                ├── gtoken@6.1.2 extraneous
                ├── hard-rejection@2.1.0 extraneous
                ├── has-ansi@2.0.0 extraneous
                ├── has-bigints@1.0.2 extraneous
                ├── has-flag@4.0.0 extraneous
                ├── has-tostringtag@1.0.2 extraneous
                ├── has-unicode@2.0.1 extraneous
                ├── has-yarn@2.1.0 extraneous
                ├── he@1.2.0 extraneous
                ├── help-me@5.0.0 extraneous
                ├── homebridge-plugin-wrapper@ extraneous
                ├── hosted-git-info@3.0.8 extraneous
                ├── hot-patcher@1.0.0 extraneous
                ├── html-encoding-sniffer@3.0.0 extraneous
                ├── http-cache-semantics@4.1.1 extraneous
                ├── http-errors@2.0.0 extraneous
                ├── http-proxy-agent@5.0.0 extraneous
                ├── http2-wrapper@1.0.3 extraneous
                ├── https@1.0.0 extraneous
                ├── humanize-ms@1.2.1 extraneous
                ├── ical.js@ extraneous
                ├── iconv-lite@0.4.24 extraneous
                ├── ieee754@1.2.1 extraneous
                ├── ignore-walk@3.0.4 extraneous
                ├── ignore@5.3.2 extraneous
                ├── image-type@4.1.0 extraneous
                ├── immediate@3.0.6 extraneous
                ├── import-fresh@3.3.0 extraneous
                ├── import-lazy@2.1.0 extraneous
                ├── import-local@3.2.0 extraneous
                ├── imurmurhash@0.1.4 extraneous
                ├── indent-string@3.2.0 extraneous
                ├── infer-owner@1.0.4 extraneous
                ├── inflight@1.0.6 extraneous
                ├── ini@1.3.7 extraneous
                ├── inquirer-autosubmit-prompt@0.2.0 extraneous
                ├── inquirer@7.3.3 extraneous
                ├── int64-buffer@1.0.1 extraneous
                ├── internal-slot@1.0.7 extraneous
                ├── iobroker-adapter-helpers@0.0.8 extraneous
                ├── iobroker.admin@ invalid: "^6.10.1" from the root project
                ├── iobroker.backitup@ invalid: "2.6.23" from the root project
                ├── iobroker.bmw@2.5.7
                ├── iobroker.calendar@ invalid: "github:WLAN-Kabel/ioBroker.calendar#c36410258c21a4a92eba80fb0ec084fc254c9259" from the root project
                ├── iobroker.cloud@4.4.1
                ├── iobroker.coronavirus-statistics@0.8.7
                ├── iobroker.daswetter@3.1.10
                ├── iobroker.discovery@ invalid: "3.1.0" from the root project
                ├── iobroker.dwd@2.8.5
                ├── iobroker.echarts@ invalid: "1.5.1" from the root project
                ├── iobroker.energiefluss@ invalid: "github:SKB-CGN/ioBroker.energiefluss#fc7a5b48f0f485b130619796daf0a9533f5b8426" from the root project
                ├── iobroker.eusec@1.1.2
                ├── iobroker.flot@ invalid: "1.12.0" from the root project
                ├── iobroker.fritzbox@0.2.1
                ├── iobroker.fullcalendar@ invalid: "1.2.0" from the root project
                ├── iobroker.fullybrowser@2.1.2
                ├── iobroker.gartenbewaesserung@ invalid: "github:TA2k/ioBroker.gartenbewaesserung#1931dcd562edf9dfa818dbf5cec61e28d3f72d72" from the root project
                ├── iobroker.ham@ invalid: "github:ioBroker/ioBroker.ham" from the root project
                ├── iobroker.harmony@1.2.2
                ├── iobroker.heatingcontrol@ invalid: "2.11.1" from the root project
                ├── iobroker.history@2.2.6
                ├── iobroker.hm-rega@3.0.47
                ├── iobroker.hm-rpc@1.15.19
                ├── iobroker.hue@3.9.5
                ├── iobroker.ical@ invalid: "github:iobroker-community-adapters/ioBroker.ical#ad28140ed1fa7ab23683d7e12b6204da06b7ce6f" from the root project
                ├── iobroker.icons-icons8@0.0.1
                ├── iobroker.icons-material-png@0.1.0
                ├── iobroker.icons-mfd-png@1.1.0
                ├── iobroker.icons-ultimate-png@1.0.1
                ├── iobroker.info@ invalid: "1.9.26" from the root project
                ├── iobroker.javascript@ invalid: "7.1.4" from the root project
                ├── iobroker.js-controller@ invalid: "^6.0.9" from the root project
                ├── iobroker.logparser@2.2.0
                ├── iobroker.material@ invalid: "1.3.1" from the root project
                ├── iobroker.meross@1.15.1
                ├── iobroker.mihome-vacuum@3.11.0
                ├── iobroker.milight-smart-light@ invalid: "1.2.2" from the root project
                ├── iobroker.milight@0.3.6
                ├── iobroker.mobile@ invalid: "1.0.1" from the root project
                ├── iobroker.modbus@ invalid: "5.0.11" from the root project
                ├── iobroker.mqtt@ invalid: "4.1.1" from the root project
                ├── iobroker.nina@ invalid: "0.0.25" from the root project
                ├── iobroker.pollenflug@1.0.6
                ├── iobroker.pushover@3.0.3
                ├── iobroker.pushsafer@1.0.3
                ├── iobroker.pvforecast@2.7.1
                ├── iobroker.renault@ invalid: "github:TA2k/ioBroker.renault" from the root project
                ├── iobroker.reolink@ invalid: "github:aendue/ioBroker.reolink#b78aab6744cdb81b360fd947a9c6e2fd6808bab1" from the root project
                ├── iobroker.schoolfree@ invalid: "1.1.2" from the root project
                ├── iobroker.simple-api@2.7.2
                ├── iobroker.smartmeter@3.3.4
                ├── iobroker.socketio@6.5.2
                ├── iobroker.sourceanalytix@ invalid: "github:DrozmotiX/ioBroker.sourceanalytix#362346b297c0a21c717ec20bd8d16331bca3b22d" from the root project
                ├── iobroker.sql@2.2.0
                ├── iobroker.statistics@2.3.0
                ├── iobroker.sunnyportal@0.1.5
                ├── iobroker.synology@ invalid: "2.1.13" from the root project
                ├── iobroker.tankerkoenig@ invalid: "3.3.7" from the root project
                ├── iobroker.terminal@ invalid: "1.0.0" from the root project
                ├── iobroker.tr-064@4.2.18
                ├── iobroker.trashschedule@2.2.0
                ├── iobroker.unifi@ invalid: "0.6.6" from the root project
                ├── iobroker.upnp@1.0.21
                ├── iobroker.valloxmv@1.2.0
                ├── iobroker.viessmannapi@ invalid: "github:TA2k/ioBroker.viessmannapi" from the root project
                ├── iobroker.virtualpowermeter@ invalid: "1.4.6" from the root project
                ├── iobroker.vis-2-widgets-material@ invalid: "github:ioBroker/ioBroker.vis-2-widgets-material#355a97e7d532721eaa97326fd873d13f12894ebd" from the root project
                ├── iobroker.vis-2@ invalid: "github:ioBroker/ioBroker.vis-2#17c7dcf5f26768f1f3a4badb087eddf9344591ea" from the root project
                ├── iobroker.vis-colorpicker@ invalid: "2.0.3" from the root project
                ├── iobroker.vis-fancyswitch@1.1.0
                ├── iobroker.vis-google-fonts@1.0.4
                ├── iobroker.vis-history@1.0.0
                ├── iobroker.vis-hqwidgets@ invalid: "1.4.0" from the root project
                ├── iobroker.vis-inventwo@ invalid: "3.3.3" from the root project
                ├── iobroker.vis-jqui-mfd@1.0.12
                ├── iobroker.vis-justgage@1.0.2
                ├── iobroker.vis-map@1.0.4
                ├── iobroker.vis-materialdesign@ invalid: "github:Scrounger/ioBroker.vis-materialdesign#8b7529d493f223dfc4f1d1f632553fcb35bbcc92" from the root project
                ├── iobroker.vis-metro@ invalid: "1.2.0" from the root project
                ├── iobroker.vis-rgraph@0.0.2
                ├── iobroker.vis-timeandweather@ invalid: "1.2.2" from the root project
                ├── iobroker.vis-weather@ invalid: "2.5.6" from the root project
                ├── iobroker.vis@ invalid: "1.4.16" from the root project
                ├── iobroker.vofo-speedtest@ invalid: "github:peterbaumert/ioBroker.vofo-speedtest#921201b4bbd53a88a64fc843c7242f9e7e8c0325" from the root project
                ├── iobroker.weatherunderground@3.4.2
                ├── iobroker.web-speedy@ invalid: "github:iobroker-community-adapters/ioBroker.web-speedy#8a5ad6a42a15688b6bb539f22e30ba2a1978c118" from the root project
                ├── iobroker.web@ invalid: "6.1.0" from the root project
                ├── iobroker.webcal@ invalid: "github:dirkhe/ioBroker.webcal#feature/DigestAuth" from the root project
                ├── iobroker.wiffi-wz@2.2.1
                ├── iobroker.windows-control@0.1.5
                ├── iobroker.worx@2.3.2
                ├── iobroker.ws@2.5.3
                ├── iobroker@2.0.3
                ├── ioredis@ extraneous
                ├── ip-address@9.0.5 extraneous
                ├── ip-regex@4.3.0 extraneous
                ├── ipaddr.js@2.2.0 extraneous
                ├── is-array-buffer@3.0.4 extraneous
                ├── is-bigint@1.0.4 extraneous
                ├── is-binary-path@2.1.0 extraneous
                ├── is-boolean-object@1.1.2 extraneous
                ├── is-buffer@1.1.6 extraneous
                ├── is-callable@1.2.7 extraneous
                ├── is-ci@2.0.0 extraneous
                ├── is-core-module@2.15.0 extraneous
                ├── is-data-view@1.0.1 extraneous
                ├── is-date-object@1.0.5 extraneous
                ├── is-docker@2.2.1 extraneous
                ├── is-empty-object@1.1.1 extraneous
                ├── is-extglob@2.1.1 extraneous
                ├── is-fullwidth-code-point@3.0.0 extraneous
                ├── is-glob@4.0.3 extraneous
                ├── is-installed-globally@0.3.2 extraneous
                ├── is-interactive@1.0.0 extraneous
                ├── is-lambda@1.0.1 extraneous
                ├── is-negative-zero@2.0.3 extraneous
                ├── is-npm@5.0.0 extraneous
                ├── is-number-object@1.0.7 extraneous
                ├── is-number@7.0.0 extraneous
                ├── is-obj@2.0.0 extraneous
                ├── is-observable@1.1.0 extraneous
                ├── is-path-cwd@2.2.0 extraneous
                ├── is-path-inside@3.0.3 extraneous
                ├── is-plain-obj@1.1.0 extraneous
                ├── is-potential-custom-element-name@1.0.1 extraneous
                ├── is-promise@2.2.2 extraneous
                ├── is-property@1.0.2 extraneous
                ├── is-regex@1.1.4 extraneous
                ├── is-scoped@2.1.0 extraneous
                ├── is-shared-array-buffer@1.0.3 extraneous
                ├── is-string@1.0.7 extraneous
                ├── is-symbol@1.0.4 extraneous
                ├── is-typed-array@1.1.13 extraneous
                ├── is-unicode-supported@0.1.0 extraneous
                ├── is-url-superb@4.0.0 extraneous
                ├── is-url@1.2.4 extraneous
                ├── is-weakref@1.0.2 extraneous
                ├── is-wsl@2.2.0 extraneous
                ├── is-yarn-global@0.3.0 extraneous
                ├── is@3.3.0 extraneous
                ├── is2@2.0.9 extraneous
                ├── isomorphic-ws@4.0.1 extraneous
                ├── issue-regex@3.1.0 extraneous
                ├── jackspeak@3.4.3 extraneous
                ├── js-md4@0.3.2 extraneous
                ├── js-sdsl@4.3.0 extraneous
                ├── js-tokens@4.0.0 extraneous
                ├── js-yaml@ extraneous
                ├── jsbi@4.3.0 extraneous
                ├── jsbn@1.1.0 extraneous
                ├── jsdom@ extraneous
                ├── jshashes@1.0.8 extraneous
                ├── json-buffer@3.0.1 extraneous
                ├── json-logic-js@2.0.5 extraneous
                ├── json-parse-even-better-errors@2.3.1 extraneous
                ├── json-schema-traverse@1.0.0 extraneous
                ├── json5@2.2.3 extraneous
                ├── jsonata@ extraneous
                ├── jsonc-parser@3.3.1 extraneous
                ├── jsonwebtoken@9.0.2 extraneous
                ├── jszip@ extraneous
                ├── jwa@2.0.0 extraneous
                ├── jws@4.0.0 extraneous
                ├── keyv@4.5.4 extraneous
                ├── kind-of@6.0.3 extraneous
                ├── kuler@2.0.0 extraneous
                ├── later@1.2.0 extraneous
                ├── latest-version@5.1.0 extraneous
                ├── layerr@0.1.2 extraneous
                ├── lazystream@1.0.1 extraneous
                ├── leven@2.1.0 extraneous
                ├── levn@0.3.0 extraneous
                ├── lie@3.3.0 extraneous
                ├── lines-and-columns@1.2.4 extraneous
                ├── listr-input@0.2.1 extraneous
                ├── listr-silent-renderer@1.1.1 extraneous
                ├── listr-update-renderer@0.5.0 extraneous
                ├── listr-verbose-renderer@0.5.0 extraneous
                ├── listr@0.14.3 extraneous
                ├── loadavg-windows@1.1.1 extraneous
                ├── locate-path@6.0.0 extraneous
                ├── lodash.defaults@4.2.0 extraneous
                ├── lodash.flatten@4.4.0 extraneous
                ├── lodash.includes@4.3.0 extraneous
                ├── lodash.isarguments@3.1.0 extraneous
                ├── lodash.isboolean@3.0.3 extraneous
                ├── lodash.isequal@4.5.0 extraneous
                ├── lodash.isinteger@4.0.4 extraneous
                ├── lodash.isnumber@3.0.3 extraneous
                ├── lodash.isplainobject@4.0.6 extraneous
                ├── lodash.isstring@4.0.1 extraneous
                ├── lodash.once@4.1.1 extraneous
                ├── lodash.zip@4.2.0 extraneous
                ├── log-symbols@4.1.0 extraneous
                ├── log-update@2.3.0 extraneous
                ├── logform@ extraneous
                ├── long@5.2.3 extraneous
                ├── lowercase-keys@2.0.0 extraneous
                ├── lru_map@0.3.3 extraneous
                ├── lru-cache@6.0.0 extraneous
                ├── make-dir@3.1.0 extraneous
                ├── make-fetch-happen@10.2.1 extraneous
                ├── map-age-cleaner@0.1.3 extraneous
                ├── map-obj@4.3.0 extraneous
                ├── map-stream@0.0.7 extraneous
                ├── md5@2.3.0 extraneous
                ├── media-typer@0.3.0 extraneous
                ├── meow@8.1.2 extraneous
                ├── merge-descriptors@1.0.1 extraneous
                ├── merge2@1.4.1 extraneous
                ├── methods@1.1.2 extraneous
                ├── micro@9.4.1 extraneous
                ├── micromatch@4.0.7 extraneous
                ├── mime-db@1.53.0 extraneous
                ├── mimic-response@1.0.1 extraneous
                ├── min-indent@1.0.1 extraneous
                ├── minimatch@9.0.5 extraneous
                ├── minimist-options@4.1.0 extraneous
                ├── minipass-collect@1.0.2 extraneous
                ├── minipass-fetch@2.1.2 extraneous
                ├── minipass-flush@1.0.5 extraneous
                ├── minipass-pipeline@1.2.4 extraneous
                ├── minipass-sized@1.0.3 extraneous
                ├── minipass@7.1.2 extraneous
                ├── minizlib@2.1.2 extraneous
                ├── mkdirp-classic@0.5.3 extraneous
                ├── mkdirp@1.0.4 extraneous
                ├── mock-require@3.0.3 extraneous
                ├── moment-duration-format@2.3.2 extraneous
                ├── mqtt-connection@4.1.0 extraneous
                ├── mqtt-packet@9.0.0 extraneous
                ├── mqtt@ extraneous
                ├── mute-stream@0.0.8 extraneous
                ├── named-placeholders@1.1.3 extraneous
                ├── nan@ extraneous
                ├── nanoid@3.3.7 extraneous
                ├── napi-build-utils@1.0.2 extraneous
                ├── native-duplexpair@1.0.0 extraneous
                ├── nconf@0.10.0 extraneous
                ├── nested-property@4.0.0 extraneous
                ├── netmask@2.0.2 extraneous
                ├── new-github-release-url@1.0.0 extraneous
                ├── node-abi@3.65.0 extraneous
                ├── node-abort-controller@3.1.1 extraneous
                ├── node-cron@2.0.3 extraneous
                ├── node-fetch@2.7.0 extraneous
                ├── node-forge@ extraneous
                ├── node-gyp@ extraneous
                ├── node-ical@0.16.1 extraneous
                ├── node-inspect@2.0.0 extraneous
                ├── node-libcurl@3.0.0 extraneous
                ├── node-mndp@0.0.3 extraneous
                ├── node-persist@0.0.11 extraneous
                ├── node-rsa@1.1.1 extraneous
                ├── node-unifi@2.5.1 extraneous
                ├── node-wol@0.1.1 extraneous
                ├── node.extend@2.0.3 extraneous
                ├── nopt@5.0.0 extraneous
                ├── normalize-package-data@3.0.3 extraneous
                ├── normalize-path@3.0.0 extraneous
                ├── normalize-url@6.1.0 extraneous
                ├── np@7.7.0 extraneous
                ├── npm-name@6.0.1 extraneous
                ├── npmlog@5.0.1 extraneous
                ├── number-allocator@1.0.14 extraneous
                ├── nwsapi@2.2.12 extraneous
                ├── object-assign@4.1.1 extraneous
                ├── object-hash@3.0.0 extraneous
                ├── on-finished@2.4.1 extraneous
                ├── once@1.4.0 extraneous
                ├── one-time@1.0.0 extraneous
                ├── onedrive-api@1.1.1 extraneous
                ├── open@7.4.2 extraneous
                ├── opencollective-postinstall@2.0.3 extraneous
                ├── optionator@0.8.3 extraneous
                ├── org-regex@1.0.0 extraneous
                ├── os-tmpdir@1.0.2 extraneous
                ├── ospath@1.2.2 extraneous
                ├── osx-temperature-sensor@ extraneous
                ├── otplib@11.0.1 extraneous
                ├── ow@0.21.0 extraneous
                ├── p-cancelable@2.1.1 extraneous
                ├── p-defer@1.0.0 extraneous
                ├── p-event@4.2.0 extraneous
                ├── p-finally@1.0.0 extraneous
                ├── p-limit@2.3.0 extraneous
                ├── p-locate@5.0.0 extraneous
                ├── p-map@2.1.0 extraneous
                ├── p-memoize@4.0.4 extraneous
                ├── p-reflect@2.1.0 extraneous
                ├── p-settle@4.1.1 extraneous
                ├── p-throttle@4.1.1 extraneous
                ├── p-timeout@4.1.0 extraneous
                ├── p-try@2.2.0 extraneous
                ├── package-json-from-dist@1.0.0 extraneous
                ├── package-json@6.5.0 extraneous
                ├── pako@ extraneous
                ├── parent-module@1.0.1 extraneous
                ├── parse-json@5.2.0 extraneous
                ├── parse5@ extraneous
                ├── passport-local@1.0.0 extraneous
                ├── passport@0.7.0 extraneous
                ├── path-exists@4.0.0 extraneous
                ├── path-is-absolute@1.0.1 extraneous
                ├── path-parse@1.0.7 extraneous
                ├── path-posix@1.0.0 extraneous
                ├── path-scurry@1.11.1 extraneous
                ├── path-to-regexp@0.1.7 extraneous
                ├── path-type@4.0.0 extraneous
                ├── pause-stream@0.0.11 extraneous
                ├── picomatch@2.3.1 extraneous
                ├── pidtree@0.6.0 extraneous
                ├── pidusage@3.0.2 extraneous
                ├── ping@0.4.4 extraneous
                ├── pkg-dir@5.0.0 extraneous
                ├── pluralize@8.0.0 extraneous
                ├── possible-typed-array-names@1.0.0 extraneous
                ├── prebuild-install@7.1.2 extraneous
                ├── prelude-ls@1.1.2 extraneous
                ├── prepend-http@2.0.0 extraneous
                ├── process-nextick-args@2.0.1 extraneous
                ├── process@0.11.10 extraneous
                ├── promise-inflight@1.0.1 extraneous
                ├── promise-object@0.1.7 extraneous
                ├── promise-retry@2.0.1 extraneous
                ├── promise-retryer@0.0.1 extraneous
                ├── promisify-child-process@4.1.2 extraneous
                ├── prompt@1.3.0 extraneous
                ├── protobufjs@ extraneous
                ├── proxy-addr@2.0.7 extraneous
                ├── proxy-from-env@1.1.0 extraneous
                ├── pump@3.0.0 extraneous
                ├── pupa@2.1.1 extraneous
                ├── q@1.1.2 extraneous
                ├── quasar@ extraneous
                ├── queue-microtask@1.2.3 extraneous
                ├── queue-tick@1.0.1 extraneous
                ├── quick-lru@5.1.1 extraneous
                ├── range-parser@1.2.1 extraneous
                ├── raw-body@2.5.2 extraneous
                ├── rc@1.2.8 extraneous
                ├── read-pkg-up@7.0.1 extraneous
                ├── read-pkg@5.2.0 extraneous
                ├── read@1.0.7 extraneous
                ├── readable-stream@ extraneous
                ├── readdir-glob@1.1.3 extraneous
                ├── readdirp@3.6.0 extraneous
                ├── readline-sync@1.4.10 extraneous
                ├── readline@1.3.0 extraneous
                ├── redent@3.0.0 extraneous
                ├── redis-commands@1.7.0 extraneous
                ├── redis-errors@1.2.0 extraneous
                ├── redis-parser@3.0.0 extraneous
                ├── regenerator-runtime@0.14.1 extraneous
                ├── regex-escape@3.4.10 extraneous
                ├── regexp.prototype.flags@1.5.2 extraneous
                ├── registry-auth-token@4.2.2 extraneous
                ├── registry-url@5.1.0 extraneous
                ├── reinterval@1.1.0 extraneous
                ├── remove-trailing-separator@1.1.0 extraneous
                ├── require-from-string@2.0.2 extraneous
                ├── resolve-alpn@1.2.1 extraneous
                ├── resolve-cwd@3.0.0 extraneous
                ├── resolve-from@4.0.0 extraneous
                ├── respjs@4.2.0 extraneous
                ├── responselike@2.0.1 extraneous
                ├── restore-cursor@3.1.0 extraneous
                ├── retry-axios@2.6.0 extraneous
                ├── retry@0.12.0 extraneous
                ├── reusify@1.0.4 extraneous
                ├── revalidator@0.1.8 extraneous
                ├── rfdc@1.4.1 extraneous
                ├── rimraf@3.0.2 extraneous
                ├── rrule@2.8.1 extraneous
                ├── rrweb-cssom@0.6.0 extraneous
                ├── run-async@2.4.1 extraneous
                ├── run-parallel@1.2.0 extraneous
                ├── rxjs@ extraneous
                ├── safe-array-concat@1.1.2 extraneous
                ├── safe-regex-test@1.0.3 extraneous
                ├── safe-stable-stringify@2.4.3 extraneous
                ├── safer-buffer@2.1.2 extraneous
                ├── saxes@6.0.0 extraneous
                ├── scoped-regex@2.1.0 extraneous
                ├── secure-keys@1.0.0 extraneous
                ├── semver-diff@3.1.1 extraneous
                ├── semver@5.7.2
                ├── send@0.18.0 extraneous
                ├── seq-logging@1.1.2 extraneous
                ├── seq-queue@0.0.5 extraneous
                ├── serve-static@1.15.0 extraneous
                ├── set-function-name@2.0.2 extraneous
                ├── setimmediate@1.0.5 extraneous
                ├── setprototypeof@1.2.0 extraneous
                ├── signal-exit@4.1.0 extraneous
                ├── simple-concat@1.0.1 extraneous
                ├── simple-get@3.1.1 extraneous
                ├── simple-ssh@1.1.1 extraneous
                ├── simple-swizzle@0.2.2 extraneous
                ├── slash@3.0.0 extraneous
                ├── slice-ansi@0.0.4 extraneous
                ├── smart-buffer@4.2.0 extraneous
                ├── socks-proxy-agent@7.0.0 extraneous
                ├── socks@2.8.3 extraneous
                ├── speedtest-net@1.6.2 extraneous
                ├── split@1.0.1 extraneous
                ├── sprintf-js@1.1.3 extraneous
                ├── sqlstring@2.3.3 extraneous
                ├── ssh2@ extraneous
                ├── ssri@9.0.1 extraneous
                ├── stack-trace@0.0.10 extraneous
                ├── stampit-event-bus@0.1.1 extraneous
                ├── stampit-state-machine@0.2.1 extraneous
                ├── stampit@2.1.2 extraneous
                ├── standard-as-callback@2.1.0 extraneous
                ├── static-eval@2.0.2 extraneous
                ├── statuses@2.0.1 extraneous
                ├── stoppable@1.1.0 extraneous
                ├── stream-combiner@0.2.2 extraneous
                ├── stream-shift@1.0.3 extraneous
                ├── streamsearch@1.1.0 extraneous
                ├── streamx@2.18.0 extraneous
                ├── string-argv@0.3.2 extraneous
                ├── string-width-cjs@npm:string-width@4.2.3 extraneous
                ├── string-width@5.1.2 extraneous
                ├── string.prototype.trim@1.2.9 extraneous
                ├── string.prototype.trimend@1.0.8 extraneous
                ├── string.prototype.trimstart@1.0.8 extraneous
                ├── strip-ansi-cjs@npm:strip-ansi@6.0.1 extraneous
                ├── strip-ansi@6.0.1 extraneous
                ├── strip-indent@3.0.0 extraneous
                ├── strip-json-comments@2.0.1 extraneous
                ├── strnum@1.0.5 extraneous
                ├── suncalc@1.9.0 extraneous
                ├── suncalc2@1.8.1 extraneous
                ├── supermixer@1.0.5 extraneous
                ├── supports-color@7.2.0 extraneous
                ├── supports-hyperlinks@2.3.0 extraneous
                ├── supports-preserve-symlinks-flag@1.0.0 extraneous
                ├── sweet-collections@1.1.0 extraneous
                ├── symbol-observable@3.0.0 extraneous
                ├── symbol-tree@3.2.4 extraneous
                ├── syno@ extraneous
                ├── systeminformation@ extraneous
                ├── tar-fs@2.1.1 extraneous
                ├── tar-stream@3.1.7 extraneous
                ├── tar@6.2.1 extraneous
                ├── tarn@3.0.2 extraneous
                ├── tcp-port-used@1.0.2 extraneous
                ├── tedious@ extraneous
                ├── terminal-link@2.1.1 extraneous
                ├── text-decoder@1.1.1 extraneous
                ├── text-hex@1.0.0 extraneous
                ├── thirty-two@1.0.2 extraneous
                ├── through@2.3.8 extraneous
                ├── through2@2.0.5 extraneous
                ├── tiny-typed-emitter@2.1.0 extraneous
                ├── tinycolor2@1.6.0 extraneous
                ├── tmp@0.0.33 extraneous
                ├── to-readable-stream@2.1.0 extraneous
                ├── to-regex-range@5.0.1 extraneous
                ├── toidentifier@1.0.1 extraneous
                ├── tr46@4.1.1 extraneous
                ├── trim-newlines@3.0.1 extraneous
                ├── triple-beam@1.4.1 extraneous
                ├── tsdav@ extraneous
                ├── tslib@2.3.0 extraneous
                ├── tweetnacl@0.14.5 extraneous
                ├── type-check@0.3.2 extraneous
                ├── type-fest@0.21.3 extraneous
                ├── type-is@1.6.18 extraneous
                ├── typed-array-buffer@1.0.2 extraneous
                ├── typed-array-byte-length@1.0.1 extraneous
                ├── typed-array-byte-offset@1.0.2 extraneous
                ├── typed-array-length@1.0.6 extraneous
                ├── typedarray-to-buffer@3.1.5 extraneous
                ├── typedarray.prototype.slice@1.0.3 extraneous
                ├── typescript@ extraneous
                ├── tz-offset@0.0.1 extraneous
                ├── uid-number@0.0.6 extraneous
                ├── unbox-primitive@1.0.2 extraneous
                ├── undici-types@6.19.6 extraneous
                ├── unique-filename@2.0.1 extraneous
                ├── unique-slug@3.0.0 extraneous
                ├── unique-string@2.0.0 extraneous
                ├── unix-dgram@2.0.6 extraneous
                ├── unpipe@1.0.0 extraneous
                ├── update-notifier@5.1.0 extraneous
                ├── uri-js@4.4.1 extraneous
                ├── url-join@4.0.1 extraneous
                ├── url-parse-lax@3.0.0 extraneous
                ├── url-template@2.0.8 extraneous
                ├── url@0.11.4 extraneous
                ├── vali-date@1.0.0 extraneous
                ├── validate-npm-package-name@3.0.0 extraneous
                ├── vary@1.1.2 extraneous
                ├── virtual-tsc@0.6.2 extraneous
                ├── vue-i18n@ extraneous
                ├── vuelidate-messages@0.1.2 extraneous
                ├── vuelidate@ extraneous
                ├── vuex-map-fields@1.4.1 extraneous
                ├── w3c-xmlserializer@4.0.0 extraneous
                ├── wake_on_lan@1.0.0 extraneous
                ├── weak-daemon@1.0.3 extraneous
                ├── webdav@ extraneous
                ├── webidl-conversions@7.0.0 extraneous
                ├── websocket-stream@5.5.2 extraneous
                ├── whatwg-encoding@2.0.0 extraneous
                ├── whatwg-mimetype@3.0.0 extraneous
                ├── whatwg-url@12.0.1 extraneous
                ├── which-boxed-primitive@1.0.2 extraneous
                ├── which-typed-array@1.1.15 extraneous
                ├── wide-align@1.1.5 extraneous
                ├── widest-line@3.1.0 extraneous
                ├── window-size@0.1.4 extraneous
                ├── winston-daily-rotate-file@5.0.0 extraneous
                ├── winston-seq-updated@1.0.4 extraneous
                ├── winston-syslog@2.7.1 extraneous
                ├── winston-transport@4.7.1 extraneous
                ├── winston@ extraneous
                ├── word-wrap@1.2.5 extraneous
                ├── worker-timers-broker@6.1.8 extraneous
                ├── worker-timers-worker@7.0.71 extraneous
                ├── worker-timers@7.1.8 extraneous
                ├── wrap-ansi-cjs@npm:wrap-ansi@7.0.0 extraneous
                ├── wrap-ansi@8.1.0 extraneous
                ├── wrappy@1.0.2 extraneous
                ├── write-file-atomic@3.0.3 extraneous
                ├── xdg-basedir@4.0.0 extraneous
                ├── xml-js@1.6.11 extraneous
                ├── xml-name-validator@4.0.0 extraneous
                ├── xmlchars@2.2.0 extraneous
                ├── xregexp@2.0.0 extraneous
                ├── yallist@4.0.0 extraneous
                ├── yaml@ extraneous
                ├── yargs-parser@20.2.9 extraneous
                ├── yargs@7.1.2
                ├── yocto-queue@0.1.0 extraneous
                ├── zip-stream@6.0.1 extraneous
                └── zrender@ extraneous
                  flommaster @flommaster last edited by
                  Teil 2
                  npm error code ELSPROBLEMS
                  npm error extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
                  npm error extraneous: @alcalzone/jsonl-db@3.1.1 /opt/iobroker/node_modules/@alcalzone/jsonl-db
                  npm error extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/@alcalzone/pak
                  npm error extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
                  npm error extraneous: @aws-sdk/util-utf8-browser@3.259.0 /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser
                  npm error extraneous: @azure/abort-controller@1.1.0 /opt/iobroker/node_modules/@azure/abort-controller
                  npm error extraneous: @azure/core-auth@1.7.2 /opt/iobroker/node_modules/@azure/core-auth
                  npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
                  npm error extraneous: @azure/core-http-compat@ /opt/iobroker/node_modules/@azure/core-http-compat
                  npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
                  npm error extraneous: @azure/core-paging@1.6.2 /opt/iobroker/node_modules/@azure/core-paging
                  npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
                  npm error extraneous: @azure/core-tracing@1.1.2 /opt/iobroker/node_modules/@azure/core-tracing
                  npm error extraneous: @azure/core-util@ /opt/iobroker/node_modules/@azure/core-util
                  npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
                  npm error extraneous: @azure/keyvault-keys@ /opt/iobroker/node_modules/@azure/keyvault-keys
                  npm error extraneous: @azure/logger@1.1.4 /opt/iobroker/node_modules/@azure/logger
                  npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
                  npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
                  npm error extraneous: @azure/msal-node@1.18.4 /opt/iobroker/node_modules/@azure/msal-node
                  npm error extraneous: @babel/code-frame@7.24.7 /opt/iobroker/node_modules/@babel/code-frame
                  npm error extraneous: @babel/helper-validator-identifier@7.24.7 /opt/iobroker/node_modules/@babel/helper-validator-identifier
                  npm error extraneous: @babel/highlight@7.24.7 /opt/iobroker/node_modules/@babel/highlight
                  npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
                  npm error extraneous: @colors/colors@1.5.0 /opt/iobroker/node_modules/@colors/colors
                  npm error extraneous: @dabh/diagnostics@2.0.3 /opt/iobroker/node_modules/@dabh/diagnostics
                  npm error extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
                  npm error extraneous: @gar/promisify@1.1.3 /opt/iobroker/node_modules/@gar/promisify
                  npm error extraneous: @googleapis/calendar@9.7.7 /opt/iobroker/node_modules/@googleapis/calendar
                  npm error extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
                  npm error extraneous: @googleapis/oauth2@1.0.7 /opt/iobroker/node_modules/@googleapis/oauth2
                  npm error extraneous: @httptoolkit/websocket-stream@6.0.1 /opt/iobroker/node_modules/@httptoolkit/websocket-stream
                  npm error extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
                  npm error extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
                  npm error extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
                  npm error extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
                  npm error extraneous: @iobroker/db-states-file@ /opt/iobroker/node_modules/@iobroker/db-states-file
                  npm error extraneous: @iobroker/db-states-jsonl@ /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                  npm error extraneous: @iobroker/db-states-redis@ /opt/iobroker/node_modules/@iobroker/db-states-redis
                  npm error extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
                  npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
                  npm error extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modules/@iobroker/js-controller-common-db
                  npm error extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
                  npm error extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
                  npm error extraneous: @iobroker/plugin-sentry@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-sentry
                  npm error extraneous: @iobroker/socket-classes@1.5.6 /opt/iobroker/node_modules/@iobroker/socket-classes
                  npm error extraneous: @iobroker/webserver@1.0.3 /opt/iobroker/node_modules/@iobroker/webserver
                  npm error extraneous: @isaacs/cliui@8.0.2 /opt/iobroker/node_modules/@isaacs/cliui
                  npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
                  npm error extraneous: @mapbox/node-pre-gyp@1.0.11 /opt/iobroker/node_modules/@mapbox/node-pre-gyp
                  npm error extraneous: @microsoft/microsoft-graph-types@2.40.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
                  npm error extraneous: @nodelib/fs.scandir@2.1.5 /opt/iobroker/node_modules/@nodelib/fs.scandir
                  npm error extraneous: @nodelib/fs.stat@2.0.5 /opt/iobroker/node_modules/@nodelib/fs.stat
                  npm error extraneous: @nodelib/fs.walk@1.2.8 /opt/iobroker/node_modules/@nodelib/fs.walk
                  npm error extraneous: @npmcli/fs@2.1.2 /opt/iobroker/node_modules/@npmcli/fs
                  npm error extraneous: @npmcli/move-file@2.0.1 /opt/iobroker/node_modules/@npmcli/move-file
                  npm error extraneous: @pkgjs/parseargs@0.11.0 /opt/iobroker/node_modules/@pkgjs/parseargs
                  npm error extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
                  npm error extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
                  npm error extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
                  npm error extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
                  npm error extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
                  npm error extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
                  npm error extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
                  npm error extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
                  npm error extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
                  npm error extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
                  npm error extraneous: @quasar/extras@ /opt/iobroker/node_modules/@quasar/extras
                  npm error extraneous: @samverschueren/stream-to-observable@0.3.1 /opt/iobroker/node_modules/@samverschueren/stream-to-observable
                  npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
                  npm error extraneous: @sentry/core@5.30.0 /opt/iobroker/node_modules/@sentry/core
                  npm error extraneous: @sentry/hub@5.30.0 /opt/iobroker/node_modules/@sentry/hub
                  npm error extraneous: @sentry/minimal@5.30.0 /opt/iobroker/node_modules/@sentry/minimal
                  npm error extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
                  npm error extraneous: @sentry/tracing@ /opt/iobroker/node_modules/@sentry/tracing
                  npm error extraneous: @sentry/types@ /opt/iobroker/node_modules/@sentry/types
                  npm error extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
                  npm error extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/@sindresorhus/is
                  npm error extraneous: @socket.io/component-emitter@3.1.2 /opt/iobroker/node_modules/@socket.io/component-emitter
                  npm error extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/@szmarczak/http-timer
                  npm error extraneous: @tediousjs/connection-string@0.5.0 /opt/iobroker/node_modules/@tediousjs/connection-string
                  npm error extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
                  npm error extraneous: @types/bl@5.1.0 /opt/iobroker/node_modules/@types/bl
                  npm error extraneous: @types/cacheable-request@6.0.3 /opt/iobroker/node_modules/@types/cacheable-request
                  npm error extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                  npm error extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/@types/cookie
                  npm error extraneous: @types/cors@2.8.17 /opt/iobroker/node_modules/@types/cors
                  npm error extraneous: @types/geojson@7946.0.14 /opt/iobroker/node_modules/@types/geojson
                  npm error extraneous: @types/http-cache-semantics@4.0.4 /opt/iobroker/node_modules/@types/http-cache-semantics
                  npm error extraneous: @types/keyv@3.1.4 /opt/iobroker/node_modules/@types/keyv
                  npm error extraneous: @types/leaflet@1.9.12 /opt/iobroker/node_modules/@types/leaflet
                  npm error extraneous: @types/minimist@1.2.5 /opt/iobroker/node_modules/@types/minimist
                  npm error extraneous: @types/node-cron@2.0.8 /opt/iobroker/node_modules/@types/node-cron
                  npm error extraneous: @types/node@ /opt/iobroker/node_modules/@types/node
                  npm error extraneous: @types/normalize-package-data@2.4.4 /opt/iobroker/node_modules/@types/normalize-package-data
                  npm error extraneous: @types/parse-json@4.0.2 /opt/iobroker/node_modules/@types/parse-json
                  npm error extraneous: @types/readable-stream@4.0.15 /opt/iobroker/node_modules/@types/readable-stream
                  npm error extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                  npm error extraneous: @types/responselike@1.0.3 /opt/iobroker/node_modules/@types/responselike
                  npm error extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                  npm error extraneous: @types/triple-beam@1.3.5 /opt/iobroker/node_modules/@types/triple-beam
                  npm error extraneous: @types/tz-offset@0.0.3 /opt/iobroker/node_modules/@types/tz-offset
                  npm error extraneous: @types/ws@8.5.12 /opt/iobroker/node_modules/@types/ws
                  npm error extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
                  npm error extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
                  npm error extraneous: abort-controller@3.0.0 /opt/iobroker/node_modules/abort-controller
                  npm error extraneous: agentkeepalive@4.5.0 /opt/iobroker/node_modules/agentkeepalive
                  npm error extraneous: aggregate-error@3.1.0 /opt/iobroker/node_modules/aggregate-error
                  npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
                  npm error extraneous: ansi-align@3.0.1 /opt/iobroker/node_modules/ansi-align
                  npm error extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/ansi-colors
                  npm error extraneous: ansi-escapes@4.3.2 /opt/iobroker/node_modules/ansi-escapes
                  npm error extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/ansi-regex
                  npm error extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/ansi-styles
                  npm error extraneous: any-observable@0.5.1 /opt/iobroker/node_modules/any-observable
                  npm error extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
                  npm error extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
                  npm error extraneous: archiver-utils@5.0.2 /opt/iobroker/node_modules/archiver-utils
                  npm error extraneous: archiver@7.0.1 /opt/iobroker/node_modules/archiver
                  npm error extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
                  npm error extraneous: arg@4.1.0 /opt/iobroker/node_modules/arg
                  npm error extraneous: argparse@1.0.10 /opt/iobroker/node_modules/argparse
                  npm error extraneous: array-buffer-byte-length@1.0.1 /opt/iobroker/node_modules/array-buffer-byte-length
                  npm error extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/array-flatten
                  npm error extraneous: array-union@2.1.0 /opt/iobroker/node_modules/array-union
                  npm error extraneous: arraybuffer.prototype.slice@1.0.3 /opt/iobroker/node_modules/arraybuffer.prototype.slice
                  npm error extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
                  npm error extraneous: asn1@0.2.6 /opt/iobroker/node_modules/asn1
                  npm error extraneous: async-exit-hook@2.0.1 /opt/iobroker/node_modules/async-exit-hook
                  npm error extraneous: authenticate-pam@1.0.5 /opt/iobroker/node_modules/authenticate-pam
                  npm error extraneous: available-typed-arrays@1.0.7 /opt/iobroker/node_modules/available-typed-arrays
                  npm error extraneous: aws-crt@ /opt/iobroker/node_modules/aws-crt
                  npm error extraneous: b4a@1.6.6 /opt/iobroker/node_modules/b4a
                  npm error extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/balanced-match
                  npm error extraneous: bare-events@2.4.2 /opt/iobroker/node_modules/bare-events
                  npm error extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
                  npm error extraneous: base64-js@1.5.1 /opt/iobroker/node_modules/base64-js
                  npm error extraneous: bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/bcrypt-pbkdf
                  npm error extraneous: binary-extensions@2.3.0 /opt/iobroker/node_modules/binary-extensions
                  npm error extraneous: bindings@1.5.0 /opt/iobroker/node_modules/bindings
                  npm error extraneous: bl@6.0.14 /opt/iobroker/node_modules/bl
                  npm error extraneous: bluebird@3.7.2 /opt/iobroker/node_modules/bluebird
                  npm error extraneous: body-parser@1.20.2 /opt/iobroker/node_modules/body-parser
                  npm error extraneous: bottleneck@2.19.5 /opt/iobroker/node_modules/bottleneck
                  npm error extraneous: boxen@5.1.2 /opt/iobroker/node_modules/boxen
                  npm error extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/brace-expansion
                  npm error extraneous: braces@3.0.3 /opt/iobroker/node_modules/braces
                  npm error extraneous: buffer-crc32@1.0.0 /opt/iobroker/node_modules/buffer-crc32
                  npm error extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
                  npm error extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
                  npm error extraneous: buffer@6.0.3 /opt/iobroker/node_modules/buffer
                  npm error extraneous: buildcheck@0.0.6 /opt/iobroker/node_modules/buildcheck
                  npm error extraneous: builtins@1.0.3 /opt/iobroker/node_modules/builtins
                  npm error extraneous: busboy@1.6.0 /opt/iobroker/node_modules/busboy
                  npm error extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
                  npm error extraneous: bytes@3.1.2 /opt/iobroker/node_modules/bytes
                  npm error extraneous: cacache@16.1.3 /opt/iobroker/node_modules/cacache
                  npm error extraneous: cacheable-lookup@5.0.4 /opt/iobroker/node_modules/cacheable-lookup
                  npm error extraneous: cacheable-request@7.0.4 /opt/iobroker/node_modules/cacheable-request
                  npm error extraneous: callsites@3.1.0 /opt/iobroker/node_modules/callsites
                  npm error extraneous: camelcase-keys@6.2.2 /opt/iobroker/node_modules/camelcase-keys
                  npm error extraneous: camelcase@5.3.1 /opt/iobroker/node_modules/camelcase
                  npm error extraneous: capitalize@2.0.4 /opt/iobroker/node_modules/capitalize
                  npm error extraneous: chalk@4.1.2 /opt/iobroker/node_modules/chalk
                  npm error extraneous: chardet@0.7.0 /opt/iobroker/node_modules/chardet
                  npm error extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
                  npm error extraneous: chokidar@3.6.0 /opt/iobroker/node_modules/chokidar
                  npm error extraneous: chownr@2.0.0 /opt/iobroker/node_modules/chownr
                  npm error extraneous: ci-info@3.9.0 /opt/iobroker/node_modules/ci-info
                  npm error extraneous: clean-stack@2.2.0 /opt/iobroker/node_modules/clean-stack
                  npm error extraneous: cli-boxes@2.2.1 /opt/iobroker/node_modules/cli-boxes
                  npm error extraneous: cli-cursor@3.1.0 /opt/iobroker/node_modules/cli-cursor
                  npm error extraneous: cli-truncate@0.2.1 /opt/iobroker/node_modules/cli-truncate
                  npm error extraneous: cli-width@3.0.0 /opt/iobroker/node_modules/cli-width
                  npm error extraneous: clone-response@1.0.3 /opt/iobroker/node_modules/clone-response
                  npm error extraneous: cloneextend@0.0.3 /opt/iobroker/node_modules/cloneextend
                  npm error extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
                  npm error extraneous: coap-packet@1.1.1 /opt/iobroker/node_modules/coap-packet
                  npm error extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                  npm error extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/color-convert
                  npm error extraneous: color-name@1.1.4 /opt/iobroker/node_modules/color-name
                  npm error extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
                  npm error extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
                  npm error extraneous: color@3.2.1 /opt/iobroker/node_modules/color
                  npm error extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
                  npm error extraneous: commander@9.5.0 /opt/iobroker/node_modules/commander
                  npm error extraneous: commist@3.2.0 /opt/iobroker/node_modules/commist
                  npm error extraneous: compress-commons@6.0.2 /opt/iobroker/node_modules/compress-commons
                  npm error extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
                  npm error extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
                  npm error extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
                  npm error extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
                  npm error extraneous: configstore@5.0.1 /opt/iobroker/node_modules/configstore
                  npm error extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
                  npm error extraneous: connect@3.7.0 /opt/iobroker/node_modules/connect
                  npm error extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
                  npm error extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/content-disposition
                  npm error extraneous: content-type@1.0.5 /opt/iobroker/node_modules/content-type
                  npm error extraneous: core-js@ /opt/iobroker/node_modules/core-js
                  npm error extraneous: cors@2.8.5 /opt/iobroker/node_modules/cors
                  npm error extraneous: cosmiconfig@7.1.0 /opt/iobroker/node_modules/cosmiconfig
                  npm error extraneous: cpu-features@ /opt/iobroker/node_modules/cpu-features
                  npm error extraneous: crc-32@1.2.2 /opt/iobroker/node_modules/crc-32
                  npm error extraneous: crc@ /opt/iobroker/node_modules/crc
                  npm error extraneous: crc32-stream@6.0.0 /opt/iobroker/node_modules/crc32-stream
                  npm error extraneous: cross-fetch@4.0.0 /opt/iobroker/node_modules/cross-fetch
                  npm error extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
                  npm error extraneous: crypto-js@ /opt/iobroker/node_modules/crypto-js
                  npm error extraneous: crypto-random-string@2.0.0 /opt/iobroker/node_modules/crypto-random-string
                  npm error extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
                  npm error extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
                  npm error extraneous: dashdash@1.14.1 /opt/iobroker/node_modules/dashdash
                  npm error extraneous: data-urls@4.0.0 /opt/iobroker/node_modules/data-urls
                  npm error extraneous: data-view-buffer@1.0.1 /opt/iobroker/node_modules/data-view-buffer
                  npm error extraneous: data-view-byte-length@1.0.1 /opt/iobroker/node_modules/data-view-byte-length
                  npm error extraneous: data-view-byte-offset@1.0.0 /opt/iobroker/node_modules/data-view-byte-offset
                  npm error extraneous: date-and-time@ /opt/iobroker/node_modules/date-and-time
                  npm error extraneous: date-fns@1.30.1 /opt/iobroker/node_modules/date-fns
                  npm error extraneous: dateformat@4.6.3 /opt/iobroker/node_modules/dateformat
                  npm error extraneous: dayjs@ /opt/iobroker/node_modules/dayjs
                  npm error extraneous: decache@4.6.2 /opt/iobroker/node_modules/decache
                  npm error extraneous: decamelize-keys@1.1.1 /opt/iobroker/node_modules/decamelize-keys
                  npm error extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
                  npm error extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
                  npm error extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
                  npm error extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
                  npm error extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is
                  npm error extraneous: defer-to-connect@2.0.1 /opt/iobroker/node_modules/defer-to-connect
                  npm error extraneous: define-lazy-prop@2.0.0 /opt/iobroker/node_modules/define-lazy-prop
                  npm error extraneous: del@6.1.1 /opt/iobroker/node_modules/del
                  npm error extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
                  npm error extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
                  npm error extraneous: destroy@1.2.0 /opt/iobroker/node_modules/destroy
                  npm error extraneous: detect-libc@2.0.3 /opt/iobroker/node_modules/detect-libc
                  npm error extraneous: diacritics@1.3.0 /opt/iobroker/node_modules/diacritics
                  npm error extraneous: digest-header@1.1.0 /opt/iobroker/node_modules/digest-header
                  npm error extraneous: dir-glob@3.0.1 /opt/iobroker/node_modules/dir-glob
                  npm error extraneous: diskusage@1.2.0 /opt/iobroker/node_modules/diskusage
                  npm error extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception
                  npm error extraneous: dot-prop@6.0.1 /opt/iobroker/node_modules/dot-prop
                  npm error extraneous: draftlog@1.0.13 /opt/iobroker/node_modules/draftlog
                  npm error extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
                  npm error extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
                  npm error extraneous: duplexer3@0.1.5 /opt/iobroker/node_modules/duplexer3
                  npm error extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/duplexify
                  npm error extraneous: eastasianwidth@0.2.0 /opt/iobroker/node_modules/eastasianwidth
                  npm error extraneous: ecc-jsbn@0.1.2 /opt/iobroker/node_modules/ecc-jsbn
                  npm error extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
                  npm error extraneous: echarts@ /opt/iobroker/node_modules/echarts
                  npm error extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/ee-first
                  npm error extraneous: elegant-spinner@1.0.1 /opt/iobroker/node_modules/elegant-spinner
                  npm error extraneous: emoji-regex@9.2.2 /opt/iobroker/node_modules/emoji-regex
                  npm error extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
                  npm error extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/encodeurl
                  npm error extraneous: encoding@0.1.13 /opt/iobroker/node_modules/encoding
                  npm error extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/end-of-stream
                  npm error extraneous: entities@4.5.0 /opt/iobroker/node_modules/entities
                  npm error extraneous: err-code@2.0.3 /opt/iobroker/node_modules/err-code
                  npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
                  npm error extraneous: es-aggregate-error@1.0.13 /opt/iobroker/node_modules/es-aggregate-error
                  npm error extraneous: es-object-atoms@1.0.0 /opt/iobroker/node_modules/es-object-atoms
                  npm error extraneous: es-set-tostringtag@2.0.3 /opt/iobroker/node_modules/es-set-tostringtag
                  npm error extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
                  npm error extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
                  npm error extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
                  npm error extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
                  npm error extraneous: escalade@3.1.2 /opt/iobroker/node_modules/escalade
                  npm error extraneous: escape-goat@3.0.0 /opt/iobroker/node_modules/escape-goat
                  npm error extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/escape-html
                  npm error extraneous: escape-string-regexp@4.0.0 /opt/iobroker/node_modules/escape-string-regexp
                  npm error extraneous: escodegen@1.14.3 /opt/iobroker/node_modules/escodegen
                  npm error extraneous: esprima@1.2.2 /opt/iobroker/node_modules/esprima
                  npm error extraneous: estraverse@4.3.0 /opt/iobroker/node_modules/estraverse
                  npm error extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils
                  npm error extraneous: etag@1.8.1 /opt/iobroker/node_modules/etag
                  npm error extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
                  npm error extraneous: event-target-shim@5.0.1 /opt/iobroker/node_modules/event-target-shim
                  npm error extraneous: eventemitter2@6.4.9 /opt/iobroker/node_modules/eventemitter2
                  npm error extraneous: events@3.3.0 /opt/iobroker/node_modules/events
                  npm error extraneous: execa@5.1.1 /opt/iobroker/node_modules/execa
                  npm error extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
                  npm error extraneous: express-fileupload@1.5.1 /opt/iobroker/node_modules/express-fileupload
                  npm error extraneous: express@4.19.2 /opt/iobroker/node_modules/express
                  npm error extraneous: external-editor@3.1.0 /opt/iobroker/node_modules/external-editor
                  npm error extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
                  npm error extraneous: fast-fifo@1.3.2 /opt/iobroker/node_modules/fast-fifo
                  npm error extraneous: fast-glob@ /opt/iobroker/node_modules/fast-glob
                  npm error extraneous: fast-json-stable-stringify@2.1.0 /opt/iobroker/node_modules/fast-json-stable-stringify
                  npm error extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein
                  npm error extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
                  npm error extraneous: fast-unique-numbers@ /opt/iobroker/node_modules/fast-unique-numbers
                  npm error extraneous: fast-uri@3.0.1 /opt/iobroker/node_modules/fast-uri
                  npm error extraneous: fast-xml-parser@ /opt/iobroker/node_modules/fast-xml-parser
                  npm error extraneous: fastq@1.17.1 /opt/iobroker/node_modules/fastq
                  npm error extraneous: fastseries@2.0.0 /opt/iobroker/node_modules/fastseries
                  npm error extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
                  npm error extraneous: figures@3.2.0 /opt/iobroker/node_modules/figures
                  npm error extraneous: file-stream-rotator@0.6.1 /opt/iobroker/node_modules/file-stream-rotator
                  npm error extraneous: file-type@10.11.0 /opt/iobroker/node_modules/file-type
                  npm error extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
                  npm error extraneous: fill-range@7.1.1 /opt/iobroker/node_modules/fill-range
                  npm error extraneous: finalhandler@1.2.0 /opt/iobroker/node_modules/finalhandler
                  npm error extraneous: find-up@5.0.0 /opt/iobroker/node_modules/find-up
                  npm error extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
                  npm error extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
                  npm error extraneous: foreground-child@3.3.0 /opt/iobroker/node_modules/foreground-child
                  npm error extraneous: form-data-encoder@2.1.4 /opt/iobroker/node_modules/form-data-encoder
                  npm error extraneous: form-data@4.0.0 /opt/iobroker/node_modules/form-data
                  npm error extraneous: forwarded@0.2.0 /opt/iobroker/node_modules/forwarded
                  npm error extraneous: fresh@0.5.2 /opt/iobroker/node_modules/fresh
                  npm error extraneous: from@0.1.7 /opt/iobroker/node_modules/from
                  npm error extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
                  npm error extraneous: fs-minipass@2.1.0 /opt/iobroker/node_modules/fs-minipass
                  npm error extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
                  npm error extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
                  npm error extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
                  npm error extraneous: function.prototype.name@1.1.6 /opt/iobroker/node_modules/function.prototype.name
                  npm error extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
                  npm error extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
                  npm error extraneous: gauge@3.0.2 /opt/iobroker/node_modules/gauge
                  npm error extraneous: gaxios@5.1.3 /opt/iobroker/node_modules/gaxios
                  npm error extraneous: gcp-metadata@5.3.0 /opt/iobroker/node_modules/gcp-metadata
                  npm error extraneous: generate-function@2.3.1 /opt/iobroker/node_modules/generate-function
                  npm error extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ssl-certificate
                  npm error extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/get-stream
                  npm error extraneous: get-symbol-description@1.0.2 /opt/iobroker/node_modules/get-symbol-description
                  npm error extraneous: getpass@0.1.7 /opt/iobroker/node_modules/getpass
                  npm error extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
                  npm error extraneous: github-url-from-git@1.5.0 /opt/iobroker/node_modules/github-url-from-git
                  npm error extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/glob-parent
                  npm error extraneous: glob@10.4.5 /opt/iobroker/node_modules/glob
                  npm error extraneous: global-dirs@2.1.0 /opt/iobroker/node_modules/global-dirs
                  npm error extraneous: globalthis@1.0.4 /opt/iobroker/node_modules/globalthis
                  npm error extraneous: globby@11.1.0 /opt/iobroker/node_modules/globby
                  npm error extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
                  npm error extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
                  npm error extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
                  npm error extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
                  npm error extraneous: googleapis@ /opt/iobroker/node_modules/googleapis
                  npm error extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
                  npm error extraneous: hard-rejection@2.1.0 /opt/iobroker/node_modules/hard-rejection
                  npm error extraneous: has-ansi@2.0.0 /opt/iobroker/node_modules/has-ansi
                  npm error extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
                  npm error extraneous: has-flag@4.0.0 /opt/iobroker/node_modules/has-flag
                  npm error extraneous: has-tostringtag@1.0.2 /opt/iobroker/node_modules/has-tostringtag
                  npm error extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
                  npm error extraneous: has-yarn@2.1.0 /opt/iobroker/node_modules/has-yarn
                  npm error extraneous: he@1.2.0 /opt/iobroker/node_modules/he
                  npm error extraneous: help-me@5.0.0 /opt/iobroker/node_modules/help-me
                  npm error extraneous: homebridge-plugin-wrapper@ /opt/iobroker/node_modules/homebridge-plugin-wrapper
                  npm error extraneous: hosted-git-info@3.0.8 /opt/iobroker/node_modules/hosted-git-info
                  npm error extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
                  npm error extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
                  npm error extraneous: http-cache-semantics@4.1.1 /opt/iobroker/node_modules/http-cache-semantics
                  npm error extraneous: http-errors@2.0.0 /opt/iobroker/node_modules/http-errors
                  npm error extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
                  npm error extraneous: http2-wrapper@1.0.3 /opt/iobroker/node_modules/http2-wrapper
                  npm error extraneous: https@1.0.0 /opt/iobroker/node_modules/https
                  npm error extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
                  npm error extraneous: ical.js@ /opt/iobroker/node_modules/ical.js
                  npm error extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/iconv-lite
                  npm error extraneous: ieee754@1.2.1 /opt/iobroker/node_modules/ieee754
                  npm error extraneous: ignore-walk@3.0.4 /opt/iobroker/node_modules/ignore-walk
                  npm error extraneous: ignore@5.3.2 /opt/iobroker/node_modules/ignore
                  npm error extraneous: image-type@4.1.0 /opt/iobroker/node_modules/image-type
                  npm error extraneous: immediate@3.0.6 /opt/iobroker/node_modules/immediate
                  npm error extraneous: import-fresh@3.3.0 /opt/iobroker/node_modules/import-fresh
                  npm error extraneous: import-lazy@2.1.0 /opt/iobroker/node_modules/import-lazy
                  npm error extraneous: import-local@3.2.0 /opt/iobroker/node_modules/import-local
                  npm error extraneous: imurmurhash@0.1.4 /opt/iobroker/node_modules/imurmurhash
                  npm error extraneous: indent-string@3.2.0 /opt/iobroker/node_modules/indent-string
                  npm error extraneous: infer-owner@1.0.4 /opt/iobroker/node_modules/infer-owner
                  npm error extraneous: inflight@1.0.6 /opt/iobroker/node_modules/inflight
                  npm error extraneous: ini@1.3.7 /opt/iobroker/node_modules/ini
                  npm error extraneous: inquirer-autosubmit-prompt@0.2.0 /opt/iobroker/node_modules/inquirer-autosubmit-prompt
                  npm error extraneous: inquirer@7.3.3 /opt/iobroker/node_modules/inquirer
                  npm error extraneous: int64-buffer@1.0.1 /opt/iobroker/node_modules/int64-buffer
                  npm error extraneous: internal-slot@1.0.7 /opt/iobroker/node_modules/internal-slot
                  npm error extraneous: iobroker-adapter-helpers@0.0.8 /opt/iobroker/node_modules/iobroker-adapter-helpers
                  npm error invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
                  npm error invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
                  npm error invalid: iobroker.calendar@ /opt/iobroker/node_modules/iobroker.calendar
                  npm error invalid: iobroker.discovery@ /opt/iobroker/node_modules/iobroker.discovery
                  npm error invalid: iobroker.echarts@ /opt/iobroker/node_modules/iobroker.echarts
                  npm error invalid: iobroker.energiefluss@ /opt/iobroker/node_modules/iobroker.energiefluss
                  npm error invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
                  npm error invalid: iobroker.fullcalendar@ /opt/iobroker/node_modules/iobroker.fullcalendar
                  npm error invalid: iobroker.gartenbewaesserung@ /opt/iobroker/node_modules/iobroker.gartenbewaesserung
                  npm error invalid: iobroker.ham@ /opt/iobroker/node_modules/iobroker.ham
                  npm error invalid: iobroker.heatingcontrol@ /opt/iobroker/node_modules/iobroker.heatingcontrol
                  npm error invalid: iobroker.ical@ /opt/iobroker/node_modules/iobroker.ical
                  npm error invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
                  npm error invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
                  npm error invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
                  npm error invalid: iobroker.material@ /opt/iobroker/node_modules/iobroker.material
                  npm error invalid: iobroker.milight-smart-light@ /opt/iobroker/node_modules/iobroker.milight-smart-light
                  npm error invalid: iobroker.mobile@ /opt/iobroker/node_modules/iobroker.mobile
                  npm error invalid: iobroker.modbus@ /opt/iobroker/node_modules/iobroker.modbus
                  npm error invalid: iobroker.mqtt@ /opt/iobroker/node_modules/iobroker.mqtt
                  npm error invalid: iobroker.nina@ /opt/iobroker/node_modules/iobroker.nina
                  npm error invalid: iobroker.renault@ /opt/iobroker/node_modules/iobroker.renault
                  npm error invalid: iobroker.reolink@ /opt/iobroker/node_modules/iobroker.reolink
                  npm error invalid: iobroker.schoolfree@ /opt/iobroker/node_modules/iobroker.schoolfree
                  npm error invalid: iobroker.sourceanalytix@ /opt/iobroker/node_modules/iobroker.sourceanalytix
                  npm error invalid: iobroker.synology@ /opt/iobroker/node_modules/iobroker.synology
                  npm error invalid: iobroker.tankerkoenig@ /opt/iobroker/node_modules/iobroker.tankerkoenig
                  npm error invalid: iobroker.terminal@ /opt/iobroker/node_modules/iobroker.terminal
                  npm error invalid: iobroker.unifi@ /opt/iobroker/node_modules/iobroker.unifi
                  npm error invalid: iobroker.viessmannapi@ /opt/iobroker/node_modules/iobroker.viessmannapi
                  npm error invalid: iobroker.virtualpowermeter@ /opt/iobroker/node_modules/iobroker.virtualpowermeter
                  npm error invalid: iobroker.vis-2-widgets-material@ /opt/iobroker/node_modules/iobroker.vis-2-widgets-material
                  npm error invalid: iobroker.vis-2@ /opt/iobroker/node_modules/iobroker.vis-2
                  npm error invalid: iobroker.vis-colorpicker@ /opt/iobroker/node_modules/iobroker.vis-colorpicker
                  npm error invalid: iobroker.vis-hqwidgets@ /opt/iobroker/node_modules/iobroker.vis-hqwidgets
                  npm error invalid: iobroker.vis-inventwo@ /opt/iobroker/node_modules/iobroker.vis-inventwo
                  npm error invalid: iobroker.vis-materialdesign@ /opt/iobroker/node_modules/iobroker.vis-materialdesign
                  npm error invalid: iobroker.vis-metro@ /opt/iobroker/node_modules/iobroker.vis-metro
                  npm error invalid: iobroker.vis-timeandweather@ /opt/iobroker/node_modules/iobroker.vis-timeandweather
                  npm error invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
                  npm error invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
                  npm error invalid: iobroker.vofo-speedtest@ /opt/iobroker/node_modules/iobroker.vofo-speedtest
                  npm error invalid: iobroker.web-speedy@ /opt/iobroker/node_modules/iobroker.web-speedy
                  npm error invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
                  npm error invalid: iobroker.webcal@ /opt/iobroker/node_modules/iobroker.webcal
                  npm error extraneous: ioredis@ /opt/iobroker/node_modules/ioredis
                  npm error extraneous: ip-address@9.0.5 /opt/iobroker/node_modules/ip-address
                  npm error extraneous: ip-regex@4.3.0 /opt/iobroker/node_modules/ip-regex
                  npm error extraneous: ipaddr.js@2.2.0 /opt/iobroker/node_modules/ipaddr.js
                  npm error extraneous: is-array-buffer@3.0.4 /opt/iobroker/node_modules/is-array-buffer
                  npm error extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
                  npm error extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
                  npm error extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
                  npm error extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
                  npm error extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
                  npm error extraneous: is-ci@2.0.0 /opt/iobroker/node_modules/is-ci
                  npm error extraneous: is-core-module@2.15.0 /opt/iobroker/node_modules/is-core-module
                  npm error extraneous: is-data-view@1.0.1 /opt/iobroker/node_modules/is-data-view
                  npm error extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
                  npm error extraneous: is-docker@2.2.1 /opt/iobroker/node_modules/is-docker
                  npm error extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
                  npm error extraneous: is-extglob@2.1.1 /opt/iobroker/node_modules/is-extglob
                  npm error extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/is-fullwidth-code-point
                  npm error extraneous: is-glob@4.0.3 /opt/iobroker/node_modules/is-glob
                  npm error extraneous: is-installed-globally@0.3.2 /opt/iobroker/node_modules/is-installed-globally
                  npm error extraneous: is-interactive@1.0.0 /opt/iobroker/node_modules/is-interactive
                  npm error extraneous: is-lambda@1.0.1 /opt/iobroker/node_modules/is-lambda
                  npm error extraneous: is-negative-zero@2.0.3 /opt/iobroker/node_modules/is-negative-zero
                  npm error extraneous: is-npm@5.0.0 /opt/iobroker/node_modules/is-npm
                  npm error extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
                  npm error extraneous: is-number@7.0.0 /opt/iobroker/node_modules/is-number
                  npm error extraneous: is-obj@2.0.0 /opt/iobroker/node_modules/is-obj
                  npm error extraneous: is-observable@1.1.0 /opt/iobroker/node_modules/is-observable
                  npm error extraneous: is-path-cwd@2.2.0 /opt/iobroker/node_modules/is-path-cwd
                  npm error extraneous: is-path-inside@3.0.3 /opt/iobroker/node_modules/is-path-inside
                  npm error extraneous: is-plain-obj@1.1.0 /opt/iobroker/node_modules/is-plain-obj
                  npm error extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
                  npm error extraneous: is-promise@2.2.2 /opt/iobroker/node_modules/is-promise
                  npm error extraneous: is-property@1.0.2 /opt/iobroker/node_modules/is-property
                  npm error extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
                  npm error extraneous: is-scoped@2.1.0 /opt/iobroker/node_modules/is-scoped
                  npm error extraneous: is-shared-array-buffer@1.0.3 /opt/iobroker/node_modules/is-shared-array-buffer
                  npm error extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
                  npm error extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
                  npm error extraneous: is-typed-array@1.1.13 /opt/iobroker/node_modules/is-typed-array
                  npm error extraneous: is-unicode-supported@0.1.0 /opt/iobroker/node_modules/is-unicode-supported
                  npm error extraneous: is-url-superb@4.0.0 /opt/iobroker/node_modules/is-url-superb
                  npm error extraneous: is-url@1.2.4 /opt/iobroker/node_modules/is-url
                  npm error extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
                  npm error extraneous: is-wsl@2.2.0 /opt/iobroker/node_modules/is-wsl
                  npm error extraneous: is-yarn-global@0.3.0 /opt/iobroker/node_modules/is-yarn-global
                  npm error extraneous: is@3.3.0 /opt/iobroker/node_modules/is
                  npm error extraneous: is2@2.0.9 /opt/iobroker/node_modules/is2
                  npm error extraneous: isomorphic-ws@4.0.1 /opt/iobroker/node_modules/isomorphic-ws
                  npm error extraneous: issue-regex@3.1.0 /opt/iobroker/node_modules/issue-regex
                  npm error extraneous: jackspeak@3.4.3 /opt/iobroker/node_modules/jackspeak
                  npm error extraneous: js-md4@0.3.2 /opt/iobroker/node_modules/js-md4
                  npm error extraneous: js-sdsl@4.3.0 /opt/iobroker/node_modules/js-sdsl
                  npm error extraneous: js-tokens@4.0.0 /opt/iobroker/node_modules/js-tokens
                  npm error extraneous: js-yaml@ /opt/iobroker/node_modules/js-yaml
                  npm error extraneous: jsbi@4.3.0 /opt/iobroker/node_modules/jsbi
                  npm error extraneous: jsbn@1.1.0 /opt/iobroker/node_modules/jsbn
                  npm error extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
                  npm error extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
                  npm error extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/json-buffer
                  npm error extraneous: json-logic-js@2.0.5 /opt/iobroker/node_modules/json-logic-js
                  npm error extraneous: json-parse-even-better-errors@2.3.1 /opt/iobroker/node_modules/json-parse-even-better-errors
                  npm error extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse
                  npm error extraneous: json5@2.2.3 /opt/iobroker/node_modules/json5
                  npm error extraneous: jsonata@ /opt/iobroker/node_modules/jsonata
                  npm error extraneous: jsonc-parser@3.3.1 /opt/iobroker/node_modules/jsonc-parser
                  npm error extraneous: jsonwebtoken@9.0.2 /opt/iobroker/node_modules/jsonwebtoken
                  npm error extraneous: jszip@ /opt/iobroker/node_modules/jszip
                  npm error extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
                  npm error extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
                  npm error extraneous: keyv@4.5.4 /opt/iobroker/node_modules/keyv
                  npm error extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/kind-of
                  npm error extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
                  npm error extraneous: later@1.2.0 /opt/iobroker/node_modules/later
                  npm error extraneous: latest-version@5.1.0 /opt/iobroker/node_modules/latest-version
                  npm error extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
                  npm error extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/lazystream
                  npm error extraneous: leven@2.1.0 /opt/iobroker/node_modules/leven
                  npm error extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn
                  npm error extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
                  npm error extraneous: lines-and-columns@1.2.4 /opt/iobroker/node_modules/lines-and-columns
                  npm error extraneous: listr-input@0.2.1 /opt/iobroker/node_modules/listr-input
                  npm error extraneous: listr-silent-renderer@1.1.1 /opt/iobroker/node_modules/listr-silent-renderer
                  npm error extraneous: listr-update-renderer@0.5.0 /opt/iobroker/node_modules/listr-update-renderer
                  npm error extraneous: listr-verbose-renderer@0.5.0 /opt/iobroker/node_modules/listr-verbose-renderer
                  npm error extraneous: listr@0.14.3 /opt/iobroker/node_modules/listr
                  npm error extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
                  npm error extraneous: locate-path@6.0.0 /opt/iobroker/node_modules/locate-path
                  npm error extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
                  npm error extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
                  npm error extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
                  npm error extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
                  npm error extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
                  npm error extraneous: lodash.isequal@4.5.0 /opt/iobroker/node_modules/lodash.isequal
                  npm error extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
                  npm error extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
                  npm error extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
                  npm error extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
                  npm error extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
                  npm error extraneous: lodash.zip@4.2.0 /opt/iobroker/node_modules/lodash.zip
                  npm error extraneous: log-symbols@4.1.0 /opt/iobroker/node_modules/log-symbols
                  npm error extraneous: log-update@2.3.0 /opt/iobroker/node_modules/log-update
                  npm error extraneous: logform@ /opt/iobroker/node_modules/logform
                  npm error extraneous: long@5.2.3 /opt/iobroker/node_modules/long
                  npm error extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/lowercase-keys
                  npm error extraneous: lru_map@0.3.3 /opt/iobroker/node_modules/lru_map
                  npm error extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/lru-cache
                  npm error extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
                  npm error extraneous: make-fetch-happen@10.2.1 /opt/iobroker/node_modules/make-fetch-happen
                  npm error extraneous: map-age-cleaner@0.1.3 /opt/iobroker/node_modules/map-age-cleaner
                  npm error extraneous: map-obj@4.3.0 /opt/iobroker/node_modules/map-obj
                  npm error extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
                  npm error extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
                  npm error extraneous: media-typer@0.3.0 /opt/iobroker/node_modules/media-typer
                  npm error extraneous: meow@8.1.2 /opt/iobroker/node_modules/meow
                  npm error extraneous: merge-descriptors@1.0.1 /opt/iobroker/node_modules/merge-descriptors
                  npm error extraneous: merge2@1.4.1 /opt/iobroker/node_modules/merge2
                  npm error extraneous: methods@1.1.2 /opt/iobroker/node_modules/methods
                  npm error extraneous: micro@9.4.1 /opt/iobroker/node_modules/micro
                  npm error extraneous: micromatch@4.0.7 /opt/iobroker/node_modules/micromatch
                  npm error extraneous: mime-db@1.53.0 /opt/iobroker/node_modules/mime-db
                  npm error extraneous: mimic-response@1.0.1 /opt/iobroker/node_modules/mimic-response
                  npm error extraneous: min-indent@1.0.1 /opt/iobroker/node_modules/min-indent
                  npm error extraneous: minimatch@9.0.5 /opt/iobroker/node_modules/minimatch
                  npm error extraneous: minimist-options@4.1.0 /opt/iobroker/node_modules/minimist-options
                  npm error extraneous: minipass-collect@1.0.2 /opt/iobroker/node_modules/minipass-collect
                  npm error extraneous: minipass-fetch@2.1.2 /opt/iobroker/node_modules/minipass-fetch
                  npm error extraneous: minipass-flush@1.0.5 /opt/iobroker/node_modules/minipass-flush
                  npm error extraneous: minipass-pipeline@1.2.4 /opt/iobroker/node_modules/minipass-pipeline
                  npm error extraneous: minipass-sized@1.0.3 /opt/iobroker/node_modules/minipass-sized
                  npm error extraneous: minipass@7.1.2 /opt/iobroker/node_modules/minipass
                  npm error extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/minizlib
                  npm error extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
                  npm error extraneous: mkdirp@1.0.4 /opt/iobroker/node_modules/mkdirp
                  npm error extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
                  npm error extraneous: moment-duration-format@2.3.2 /opt/iobroker/node_modules/moment-duration-format
                  npm error extraneous: mqtt-connection@4.1.0 /opt/iobroker/node_modules/mqtt-connection
                  npm error extraneous: mqtt-packet@9.0.0 /opt/iobroker/node_modules/mqtt-packet
                  npm error extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
                  npm error extraneous: mute-stream@0.0.8 /opt/iobroker/node_modules/mute-stream
                  npm error extraneous: named-placeholders@1.1.3 /opt/iobroker/node_modules/named-placeholders
                  npm error extraneous: nan@ /opt/iobroker/node_modules/nan
                  npm error extraneous: nanoid@3.3.7 /opt/iobroker/node_modules/nanoid
                  npm error extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
                  npm error extraneous: native-duplexpair@1.0.0 /opt/iobroker/node_modules/native-duplexpair
                  npm error extraneous: nconf@0.10.0 /opt/iobroker/node_modules/nconf
                  npm error extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
                  npm error extraneous: netmask@2.0.2 /opt/iobroker/node_modules/netmask
                  npm error extraneous: new-github-release-url@1.0.0 /opt/iobroker/node_modules/new-github-release-url
                  npm error extraneous: node-abi@3.65.0 /opt/iobroker/node_modules/node-abi
                  npm error extraneous: node-abort-controller@3.1.1 /opt/iobroker/node_modules/node-abort-controller
                  npm error extraneous: node-cron@2.0.3 /opt/iobroker/node_modules/node-cron
                  npm error extraneous: node-fetch@2.7.0 /opt/iobroker/node_modules/node-fetch
                  npm error extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
                  npm error extraneous: node-gyp@ /opt/iobroker/node_modules/node-gyp
                  npm error extraneous: node-ical@0.16.1 /opt/iobroker/node_modules/node-ical
                  npm error extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                  npm error extraneous: node-libcurl@3.0.0 /opt/iobroker/node_modules/node-libcurl
                  npm error extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
                  npm error extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
                  npm error extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
                  npm error extraneous: node-unifi@2.5.1 /opt/iobroker/node_modules/node-unifi
                  npm error extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
                  npm error extraneous: node.extend@2.0.3 /opt/iobroker/node_modules/node.extend
                  npm error extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
                  npm error extraneous: normalize-package-data@3.0.3 /opt/iobroker/node_modules/normalize-package-data
                  npm error extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
                  npm error extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/normalize-url
                  npm error extraneous: np@7.7.0 /opt/iobroker/node_modules/np
                  npm error extraneous: npm-name@6.0.1 /opt/iobroker/node_modules/npm-name
                  npm error extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
                  npm error extraneous: number-allocator@1.0.14 /opt/iobroker/node_modules/number-allocator
                  npm error extraneous: nwsapi@2.2.12 /opt/iobroker/node_modules/nwsapi
                  npm error extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assign
                  npm error extraneous: object-hash@3.0.0 /opt/iobroker/node_modules/object-hash
                  npm error extraneous: on-finished@2.4.1 /opt/iobroker/node_modules/on-finished
                  npm error extraneous: once@1.4.0 /opt/iobroker/node_modules/once
                  npm error extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
                  npm error extraneous: onedrive-api@1.1.1 /opt/iobroker/node_modules/onedrive-api
                  npm error extraneous: open@7.4.2 /opt/iobroker/node_modules/open
                  npm error extraneous: opencollective-postinstall@2.0.3 /opt/iobroker/node_modules/opencollective-postinstall
                  npm error extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator
                  npm error extraneous: org-regex@1.0.0 /opt/iobroker/node_modules/org-regex
                  npm error extraneous: os-tmpdir@1.0.2 /opt/iobroker/node_modules/os-tmpdir
                  npm error extraneous: ospath@1.2.2 /opt/iobroker/node_modules/ospath
                  npm error extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
                  npm error extraneous: otplib@11.0.1 /opt/iobroker/node_modules/otplib
                  npm error extraneous: ow@0.21.0 /opt/iobroker/node_modules/ow
                  npm error extraneous: p-cancelable@2.1.1 /opt/iobroker/node_modules/p-cancelable
                  npm error extraneous: p-defer@1.0.0 /opt/iobroker/node_modules/p-defer
                  npm error extraneous: p-event@4.2.0 /opt/iobroker/node_modules/p-event
                  npm error extraneous: p-finally@1.0.0 /opt/iobroker/node_modules/p-finally
                  npm error extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/p-limit
                  npm error extraneous: p-locate@5.0.0 /opt/iobroker/node_modules/p-locate
                  npm error extraneous: p-map@2.1.0 /opt/iobroker/node_modules/p-map
                  npm error extraneous: p-memoize@4.0.4 /opt/iobroker/node_modules/p-memoize
                  npm error extraneous: p-reflect@2.1.0 /opt/iobroker/node_modules/p-reflect
                  npm error extraneous: p-settle@4.1.1 /opt/iobroker/node_modules/p-settle
                  npm error extraneous: p-throttle@4.1.1 /opt/iobroker/node_modules/p-throttle
                  npm error extraneous: p-timeout@4.1.0 /opt/iobroker/node_modules/p-timeout
                  npm error extraneous: p-try@2.2.0 /opt/iobroker/node_modules/p-try
                  npm error extraneous: package-json-from-dist@1.0.0 /opt/iobroker/node_modules/package-json-from-dist
                  npm error extraneous: package-json@6.5.0 /opt/iobroker/node_modules/package-json
                  npm error extraneous: pako@ /opt/iobroker/node_modules/pako
                  npm error extraneous: parent-module@1.0.1 /opt/iobroker/node_modules/parent-module
                  npm error extraneous: parse-json@5.2.0 /opt/iobroker/node_modules/parse-json
                  npm error extraneous: parse5@ /opt/iobroker/node_modules/parse5
                  npm error extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
                  npm error extraneous: passport@0.7.0 /opt/iobroker/node_modules/passport
                  npm error extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/path-exists
                  npm error extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
                  npm error extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
                  npm error extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
                  npm error extraneous: path-scurry@1.11.1 /opt/iobroker/node_modules/path-scurry
                  npm error extraneous: path-to-regexp@0.1.7 /opt/iobroker/node_modules/path-to-regexp
                  npm error extraneous: path-type@4.0.0 /opt/iobroker/node_modules/path-type
                  npm error extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
                  npm error extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/picomatch
                  npm error extraneous: pidtree@0.6.0 /opt/iobroker/node_modules/pidtree
                  npm error extraneous: pidusage@3.0.2 /opt/iobroker/node_modules/pidusage
                  npm error extraneous: ping@0.4.4 /opt/iobroker/node_modules/ping
                  npm error extraneous: pkg-dir@5.0.0 /opt/iobroker/node_modules/pkg-dir
                  npm error extraneous: pluralize@8.0.0 /opt/iobroker/node_modules/pluralize
                  npm error extraneous: possible-typed-array-names@1.0.0 /opt/iobroker/node_modules/possible-typed-array-names
                  npm error extraneous: prebuild-install@7.1.2 /opt/iobroker/node_modules/prebuild-install
                  npm error extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls
                  npm error extraneous: prepend-http@2.0.0 /opt/iobroker/node_modules/prepend-http
                  npm error extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/process-nextick-args
                  npm error extraneous: process@0.11.10 /opt/iobroker/node_modules/process
                  npm error extraneous: promise-inflight@1.0.1 /opt/iobroker/node_modules/promise-inflight
                  npm error extraneous: promise-object@0.1.7 /opt/iobroker/node_modules/promise-object
                  npm error extraneous: promise-retry@2.0.1 /opt/iobroker/node_modules/promise-retry
                  npm error extraneous: promise-retryer@0.0.1 /opt/iobroker/node_modules/promise-retryer
                  npm error extraneous: promisify-child-process@4.1.2 /opt/iobroker/node_modules/promisify-child-process
                  npm error extraneous: prompt@1.3.0 /opt/iobroker/node_modules/prompt
                  npm error extraneous: protobufjs@ /opt/iobroker/node_modules/protobufjs
                  npm error extraneous: proxy-addr@2.0.7 /opt/iobroker/node_modules/proxy-addr
                  npm error extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
                  npm error extraneous: pump@3.0.0 /opt/iobroker/node_modules/pump
                  npm error extraneous: pupa@2.1.1 /opt/iobroker/node_modules/pupa
                  npm error extraneous: q@1.1.2 /opt/iobroker/node_modules/q
                  npm error extraneous: quasar@ /opt/iobroker/node_modules/quasar
                  npm error extraneous: queue-microtask@1.2.3 /opt/iobroker/node_modules/queue-microtask
                  npm error extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
                  npm error extraneous: quick-lru@5.1.1 /opt/iobroker/node_modules/quick-lru
                  npm error extraneous: range-parser@1.2.1 /opt/iobroker/node_modules/range-parser
                  npm error extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/raw-body
                  npm error extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
                  npm error extraneous: read-pkg-up@7.0.1 /opt/iobroker/node_modules/read-pkg-up
                  npm error extraneous: read-pkg@5.2.0 /opt/iobroker/node_modules/read-pkg
                  npm error extraneous: read@1.0.7 /opt/iobroker/node_modules/read
                  npm error extraneous: readable-stream@ /opt/iobroker/node_modules/readable-stream
                  npm error extraneous: readdir-glob@1.1.3 /opt/iobroker/node_modules/readdir-glob
                  npm error extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
                  npm error extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
                  npm error extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
                  npm error extraneous: redent@3.0.0 /opt/iobroker/node_modules/redent
                  npm error extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
                  npm error extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
                  npm error extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
                  npm error extraneous: regenerator-runtime@0.14.1 /opt/iobroker/node_modules/regenerator-runtime
                  npm error extraneous: regex-escape@3.4.10 /opt/iobroker/node_modules/regex-escape
                  npm error extraneous: regexp.prototype.flags@1.5.2 /opt/iobroker/node_modules/regexp.prototype.flags
                  npm error extraneous: registry-auth-token@4.2.2 /opt/iobroker/node_modules/registry-auth-token
                  npm error extraneous: registry-url@5.1.0 /opt/iobroker/node_modules/registry-url
                  npm error extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
                  npm error extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
                  npm error extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string
                  npm error extraneous: resolve-alpn@1.2.1 /opt/iobroker/node_modules/resolve-alpn
                  npm error extraneous: resolve-cwd@3.0.0 /opt/iobroker/node_modules/resolve-cwd
                  npm error extraneous: resolve-from@4.0.0 /opt/iobroker/node_modules/resolve-from
                  npm error extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
                  npm error extraneous: responselike@2.0.1 /opt/iobroker/node_modules/responselike
                  npm error extraneous: restore-cursor@3.1.0 /opt/iobroker/node_modules/restore-cursor
                  npm error extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
                  npm error extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
                  npm error extraneous: reusify@1.0.4 /opt/iobroker/node_modules/reusify
                  npm error extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
                  npm error extraneous: rfdc@1.4.1 /opt/iobroker/node_modules/rfdc
                  npm error extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/rimraf
                  npm error extraneous: rrule@2.8.1 /opt/iobroker/node_modules/rrule
                  npm error extraneous: rrweb-cssom@0.6.0 /opt/iobroker/node_modules/rrweb-cssom
                  npm error extraneous: run-async@2.4.1 /opt/iobroker/node_modules/run-async
                  npm error extraneous: run-parallel@1.2.0 /opt/iobroker/node_modules/run-parallel
                  npm error extraneous: rxjs@ /opt/iobroker/node_modules/rxjs
                  npm error extraneous: safe-array-concat@1.1.2 /opt/iobroker/node_modules/safe-array-concat
                  npm error extraneous: safe-regex-test@1.0.3 /opt/iobroker/node_modules/safe-regex-test
                  npm error extraneous: safe-stable-stringify@2.4.3 /opt/iobroker/node_modules/safe-stable-stringify
                  npm error extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/safer-buffer
                  npm error extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
                  npm error extraneous: scoped-regex@2.1.0 /opt/iobroker/node_modules/scoped-regex
                  npm error extraneous: secure-keys@1.0.0 /opt/iobroker/node_modules/secure-keys
                  npm error extraneous: semver-diff@3.1.1 /opt/iobroker/node_modules/semver-diff
                  npm error extraneous: send@0.18.0 /opt/iobroker/node_modules/send
                  npm error extraneous: seq-logging@1.1.2 /opt/iobroker/node_modules/seq-logging
                  npm error extraneous: seq-queue@0.0.5 /opt/iobroker/node_modules/seq-queue
                  npm error extraneous: serve-static@1.15.0 /opt/iobroker/node_modules/serve-static
                  npm error extraneous: set-function-name@2.0.2 /opt/iobroker/node_modules/set-function-name
                  npm error extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
                  npm error extraneous: setprototypeof@1.2.0 /opt/iobroker/node_modules/setprototypeof
                  npm error extraneous: signal-exit@4.1.0 /opt/iobroker/node_modules/signal-exit
                  npm error extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
                  npm error extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
                  npm error extraneous: simple-ssh@1.1.1 /opt/iobroker/node_modules/simple-ssh
                  npm error extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
                  npm error extraneous: slash@3.0.0 /opt/iobroker/node_modules/slash
                  npm error extraneous: slice-ansi@0.0.4 /opt/iobroker/node_modules/slice-ansi
                  npm error extraneous: smart-buffer@4.2.0 /opt/iobroker/node_modules/smart-buffer
                  npm error extraneous: socks-proxy-agent@7.0.0 /opt/iobroker/node_modules/socks-proxy-agent
                  npm error extraneous: socks@2.8.3 /opt/iobroker/node_modules/socks
                  npm error extraneous: speedtest-net@1.6.2 /opt/iobroker/node_modules/speedtest-net
                  npm error extraneous: split@1.0.1 /opt/iobroker/node_modules/split
                  npm error extraneous: sprintf-js@1.1.3 /opt/iobroker/node_modules/sprintf-js
                  npm error extraneous: sqlstring@2.3.3 /opt/iobroker/node_modules/sqlstring
                  npm error extraneous: ssh2@ /opt/iobroker/node_modules/ssh2
                  npm error extraneous: ssri@9.0.1 /opt/iobroker/node_modules/ssri
                  npm error extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
                  npm error extraneous: stampit-event-bus@0.1.1 /opt/iobroker/node_modules/stampit-event-bus
                  npm error extraneous: stampit-state-machine@0.2.1 /opt/iobroker/node_modules/stampit-state-machine
                  npm error extraneous: stampit@2.1.2 /opt/iobroker/node_modules/stampit
                  npm error extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
                  npm error extraneous: static-eval@2.0.2 /opt/iobroker/node_modules/static-eval
                  npm error extraneous: statuses@2.0.1 /opt/iobroker/node_modules/statuses
                  npm error extraneous: stoppable@1.1.0 /opt/iobroker/node_modules/stoppable
                  npm error extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
                  npm error extraneous: stream-shift@1.0.3 /opt/iobroker/node_modules/stream-shift
                  npm error extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
                  npm error extraneous: streamx@2.18.0 /opt/iobroker/node_modules/streamx
                  npm error extraneous: string-argv@0.3.2 /opt/iobroker/node_modules/string-argv
                  npm error extraneous: string-width-cjs@npm:string-width@4.2.3 /opt/iobroker/node_modules/string-width-cjs
                  npm error extraneous: string-width@5.1.2 /opt/iobroker/node_modules/string-width
                  npm error extraneous: string.prototype.trim@1.2.9 /opt/iobroker/node_modules/string.prototype.trim
                  npm error extraneous: string.prototype.trimend@1.0.8 /opt/iobroker/node_modules/string.prototype.trimend
                  npm error extraneous: string.prototype.trimstart@1.0.8 /opt/iobroker/node_modules/string.prototype.trimstart
                  npm error extraneous: strip-ansi-cjs@npm:strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi-cjs
                  npm error extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi
                  npm error extraneous: strip-indent@3.0.0 /opt/iobroker/node_modules/strip-indent
                  npm error extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
                  npm error extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
                  npm error extraneous: suncalc@1.9.0 /opt/iobroker/node_modules/suncalc
                  npm error extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                  npm error extraneous: supermixer@1.0.5 /opt/iobroker/node_modules/supermixer
                  npm error extraneous: supports-color@7.2.0 /opt/iobroker/node_modules/supports-color
                  npm error extraneous: supports-hyperlinks@2.3.0 /opt/iobroker/node_modules/supports-hyperlinks
                  npm error extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
                  npm error extraneous: sweet-collections@1.1.0 /opt/iobroker/node_modules/sweet-collections
                  npm error extraneous: symbol-observable@3.0.0 /opt/iobroker/node_modules/symbol-observable
                  npm error extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
                  npm error extraneous: syno@ /opt/iobroker/node_modules/syno
                  npm error extraneous: systeminformation@ /opt/iobroker/node_modules/systeminformation
                  npm error extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
                  npm error extraneous: tar-stream@3.1.7 /opt/iobroker/node_modules/tar-stream
                  npm error extraneous: tar@6.2.1 /opt/iobroker/node_modules/tar
                  npm error extraneous: tarn@3.0.2 /opt/iobroker/node_modules/tarn
                  npm error extraneous: tcp-port-used@1.0.2 /opt/iobroker/node_modules/tcp-port-used
                  npm error extraneous: tedious@ /opt/iobroker/node_modules/tedious
                  npm error extraneous: terminal-link@2.1.1 /opt/iobroker/node_modules/terminal-link
                  npm error extraneous: text-decoder@1.1.1 /opt/iobroker/node_modules/text-decoder
                  npm error extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
                  npm error extraneous: thirty-two@1.0.2 /opt/iobroker/node_modules/thirty-two
                  npm error extraneous: through@2.3.8 /opt/iobroker/node_modules/through
                  npm error extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
                  npm error extraneous: tiny-typed-emitter@2.1.0 /opt/iobroker/node_modules/tiny-typed-emitter
                  npm error extraneous: tinycolor2@1.6.0 /opt/iobroker/node_modules/tinycolor2
                  npm error extraneous: tmp@0.0.33 /opt/iobroker/node_modules/tmp
                  npm error extraneous: to-readable-stream@2.1.0 /opt/iobroker/node_modules/to-readable-stream
                  npm error extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/to-regex-range
                  npm error extraneous: toidentifier@1.0.1 /opt/iobroker/node_modules/toidentifier
                  npm error extraneous: tr46@4.1.1 /opt/iobroker/node_modules/tr46
                  npm error extraneous: trim-newlines@3.0.1 /opt/iobroker/node_modules/trim-newlines
                  npm error extraneous: triple-beam@1.4.1 /opt/iobroker/node_modules/triple-beam
                  npm error extraneous: tsdav@ /opt/iobroker/node_modules/tsdav
                  npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/tslib
                  npm error extraneous: tweetnacl@0.14.5 /opt/iobroker/node_modules/tweetnacl
                  npm error extraneous: type-check@0.3.2 /opt/iobroker/node_modules/type-check
                  npm error extraneous: type-fest@0.21.3 /opt/iobroker/node_modules/type-fest
                  npm error extraneous: type-is@1.6.18 /opt/iobroker/node_modules/type-is
                  npm error extraneous: typed-array-buffer@1.0.2 /opt/iobroker/node_modules/typed-array-buffer
                  npm error extraneous: typed-array-byte-length@1.0.1 /opt/iobroker/node_modules/typed-array-byte-length
                  npm error extraneous: typed-array-byte-offset@1.0.2 /opt/iobroker/node_modules/typed-array-byte-offset
                  npm error extraneous: typed-array-length@1.0.6 /opt/iobroker/node_modules/typed-array-length
                  npm error extraneous: typedarray-to-buffer@3.1.5 /opt/iobroker/node_modules/typedarray-to-buffer
                  npm error extraneous: typedarray.prototype.slice@1.0.3 /opt/iobroker/node_modules/typedarray.prototype.slice
                  npm error extraneous: typescript@ /opt/iobroker/node_modules/typescript
                  npm error extraneous: tz-offset@0.0.1 /opt/iobroker/node_modules/tz-offset
                  npm error extraneous: uid-number@0.0.6 /opt/iobroker/node_modules/uid-number
                  npm error extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
                  npm error extraneous: undici-types@6.19.6 /opt/iobroker/node_modules/undici-types
                  npm error extraneous: unique-filename@2.0.1 /opt/iobroker/node_modules/unique-filename
                  npm error extraneous: unique-slug@3.0.0 /opt/iobroker/node_modules/unique-slug
                  npm error extraneous: unique-string@2.0.0 /opt/iobroker/node_modules/unique-string
                  npm error extraneous: unix-dgram@2.0.6 /opt/iobroker/node_modules/unix-dgram
                  npm error extraneous: unpipe@1.0.0 /opt/iobroker/node_modules/unpipe
                  npm error extraneous: update-notifier@5.1.0 /opt/iobroker/node_modules/update-notifier
                  npm error extraneous: uri-js@4.4.1 /opt/iobroker/node_modules/uri-js
                  npm error extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
                  npm error extraneous: url-parse-lax@3.0.0 /opt/iobroker/node_modules/url-parse-lax
                  npm error extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
                  npm error extraneous: url@0.11.4 /opt/iobroker/node_modules/url
                  npm error extraneous: vali-date@1.0.0 /opt/iobroker/node_modules/vali-date
                  npm error extraneous: validate-npm-package-name@3.0.0 /opt/iobroker/node_modules/validate-npm-package-name
                  npm error extraneous: vary@1.1.2 /opt/iobroker/node_modules/vary
                  npm error extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                  npm error extraneous: vue-i18n@ /opt/iobroker/node_modules/vue-i18n
                  npm error extraneous: vuelidate-messages@0.1.2 /opt/iobroker/node_modules/vuelidate-messages
                  npm error extraneous: vuelidate@ /opt/iobroker/node_modules/vuelidate
                  npm error extraneous: vuex-map-fields@1.4.1 /opt/iobroker/node_modules/vuex-map-fields
                  npm error extraneous: w3c-xmlserializer@4.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
                  npm error extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                  npm error extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
                  npm error extraneous: webdav@ /opt/iobroker/node_modules/webdav
                  npm error extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
                  npm error extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
                  npm error extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
                  npm error extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
                  npm error extraneous: whatwg-url@12.0.1 /opt/iobroker/node_modules/whatwg-url
                  npm error extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
                  npm error extraneous: which-typed-array@1.1.15 /opt/iobroker/node_modules/which-typed-array
                  npm error extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
                  npm error extraneous: widest-line@3.1.0 /opt/iobroker/node_modules/widest-line
                  npm error extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
                  npm error extraneous: winston-daily-rotate-file@5.0.0 /opt/iobroker/node_modules/winston-daily-rotate-file
                  npm error extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
                  npm error extraneous: winston-syslog@2.7.1 /opt/iobroker/node_modules/winston-syslog
                  npm error extraneous: winston-transport@4.7.1 /opt/iobroker/node_modules/winston-transport
                  npm error extraneous: winston@ /opt/iobroker/node_modules/winston
                  npm error extraneous: word-wrap@1.2.5 /opt/iobroker/node_modules/word-wrap
                  npm error extraneous: worker-timers-broker@6.1.8 /opt/iobroker/node_modules/worker-timers-broker
                  npm error extraneous: worker-timers-worker@7.0.71 /opt/iobroker/node_modules/worker-timers-worker
                  npm error extraneous: worker-timers@7.1.8 /opt/iobroker/node_modules/worker-timers
                  npm error extraneous: wrap-ansi-cjs@npm:wrap-ansi@7.0.0 /opt/iobroker/node_modules/wrap-ansi-cjs
                  npm error extraneous: wrap-ansi@8.1.0 /opt/iobroker/node_modules/wrap-ansi
                  npm error extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/wrappy
                  npm error extraneous: write-file-atomic@3.0.3 /opt/iobroker/node_modules/write-file-atomic
                  npm error extraneous: xdg-basedir@4.0.0 /opt/iobroker/node_modules/xdg-basedir
                  npm error extraneous: xml-js@1.6.11 /opt/iobroker/node_modules/xml-js
                  npm error extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
                  npm error extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
                  npm error extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
                  npm error extraneous: yallist@4.0.0 /opt/iobroker/node_modules/yallist
                  npm error extraneous: yaml@ /opt/iobroker/node_modules/yaml
                  npm error extraneous: yargs-parser@20.2.9 /opt/iobroker/node_modules/yargs-parser
                  npm error extraneous: yocto-queue@0.1.0 /opt/iobroker/node_modules/yocto-queue
                  npm error extraneous: zip-stream@6.0.1 /opt/iobroker/node_modules/zip-stream
                  npm error extraneous: zrender@ /opt/iobroker/node_modules/zrender
                  npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T19_54_40_124Z-debug-0.log
                    Thomas Braun Most Active @mcm1957 last edited by
                    @mcm1957 sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                    Wo stammen eigentlich die ganzen GITHUB dependencies her, z.B.
                    War mich auch schon in's Auge gesprungen.
                      flommaster @Thomas Braun last edited by
                      @thomas-braun sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                      Keine Ahnung.
                      Soll ich das System komplett neu aufsetzen?
                        Thomas Braun Most Active @flommaster last edited by
                        @flommaster
                        npm prune
                        npm ls
                          Thomas Braun Most Active @flommaster last edited by Thomas Braun
                          @flommaster
                          Das kommt davon, wenn man da alles und jedes (Ich hab da jetzt 13 Kandidaten gezählt) über github installiert und nicht ordentlich aus einem Repo.
                          Da wird wohl einer der Adapter gelöscht oder verschoben worden sein sein. Das führt dann für alle anderen Adapter zu der Meldung
                          invalid "blablubb" from the root project
                            Der Befehl "npm prune" liefert folgendes Ergebnis:
                            Kann ich die github Installationen löschen?
                            npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.web-speedy.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/peterbaumert/ioBroker.vofo-speedtest.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2-widgets-material.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/aendue/ioBroker.reolink.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.ical.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git
                            npm warn skipping integrity check for git dependency ssh://git@github.com/WLAN-Kabel/ioBroker.calendar.git
                            npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                            npm warn deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                            npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                            npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
                            npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
                            npm warn deprecated uid-number@0.0.6: This package is no longer supported.
                            npm warn deprecated npmlog@5.0.1: This package is no longer supported.
                            npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                            npm warn deprecated npmlog@6.0.2: This package is no longer supported.
                            npm warn deprecated har-validator@5.1.5: this library is no longer supported
                            npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                            npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
                            npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
                            npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
                            npm warn deprecated q@1.1.2: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
                            npm warn deprecated
                            npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
                            npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                            npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                            npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
                            npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
                            npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                            npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
                            npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                            npm warn deprecated google-p12-pem@3.1.4: Package is no longer maintained
                            npm warn deprecated gauge@3.0.2: This package is no longer supported.
                            npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                            npm warn deprecated gauge@4.0.4: This package is no longer supported.
                            npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                            npm warn deprecated later@1.2.0: Please upgrade to the maintained and new drop-in replacement @breejs/later at https://github.com/breejs/later 🚀 Thanks and happy hacking! 🚀  @niftylettuce
                            npm error git dep preparation failed
                            npm error signal SIGINT
                            npm error command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
                            npm error npm warn using --force Recommended protections disabled.
                            mikeal created this issue in request/request
                            open Request’s Past, Present and Future #3142
                            Qix- created this issue in visionmedia/debug
                            closed ReDos Vulnerability Regression Visibility Notice #797
                              @flommaster sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                              Vollständig.
                              Inkl. vollständiger Eingabezeile inkl. login prompt. Damit man sieht was du da genau in welchem Verzeichnis mit welchem User eingegeben hast.
                                Gerne. Hier der komplette Auszug (Teil 1)
                                flo@ioBrokerdebian:/opt/iobroker$ npm prune
                                npm ls
                                npm warn deprecated
                                npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T20_04_51_820Z-debug-0.log
                                iobroker.inst@2.0.3 /opt/iobroker
                                ├── @alcalzone/esbuild-register@2.5.1-1 extraneous
                                ├── @alcalzone/jsonl-db@3.1.1 extraneous
                                ├── @alcalzone/pak@0.8.1 extraneous
                                ├── @alcalzone/proper-lockfile@4.1.3-0 extraneous
                                ├── @aws-sdk/util-utf8-browser@3.259.0 extraneous
                                ├── @azure/abort-controller@1.1.0 extraneous
                                ├── @azure/core-auth@1.7.2 extraneous
                                ├── @azure/core-client@ extraneous
                                ├── @azure/core-http-compat@ extraneous
                                ├── @azure/core-lro@ extraneous
                                ├── @azure/core-paging@1.6.2 extraneous
                                ├── @azure/core-rest-pipeline@ extraneous
                                ├── @azure/core-tracing@1.1.2 extraneous
                                ├── @azure/core-util@ extraneous
                                ├── @azure/identity@ extraneous
                                ├── @azure/keyvault-keys@ extraneous
                                ├── @azure/logger@1.1.4 extraneous
                                ├── @azure/msal-browser@ extraneous
                                ├── @azure/msal-common@ extraneous
                                ├── @azure/msal-node@1.18.4 extraneous
                                ├── @babel/code-frame@7.24.7 extraneous
                                ├── @babel/helper-validator-identifier@7.24.7 extraneous
                                ├── @babel/highlight@7.24.7 extraneous
                                ├── @babel/runtime@ extraneous
                                ├── @colors/colors@1.5.0 extraneous
                                ├── @dabh/diagnostics@2.0.3 extraneous
                                ├── @datalust/winston-seq@1.0.2 extraneous
                                ├── @gar/promisify@1.1.3 extraneous
                                ├── @googleapis/calendar@9.7.7 extraneous
                                ├── @googleapis/drive@5.1.0 extraneous
                                ├── @googleapis/oauth2@1.0.7 extraneous
                                ├── @httptoolkit/websocket-stream@6.0.1 extraneous
                                ├── @iobroker/db-base@ extraneous
                                ├── @iobroker/db-objects-file@ extraneous
                                ├── @iobroker/db-objects-jsonl@ extraneous
                                ├── @iobroker/db-objects-redis@ extraneous
                                ├── @iobroker/db-states-file@ extraneous
                                ├── @iobroker/db-states-jsonl@ extraneous
                                ├── @iobroker/db-states-redis@ extraneous
                                ├── @iobroker/js-controller-adapter@ extraneous
                                ├── @iobroker/js-controller-cli@ extraneous
                                ├── @iobroker/js-controller-common-db@ extraneous
                                ├── @iobroker/js-controller-common@ extraneous
                                ├── @iobroker/plugin-base@1.2.1 extraneous
                                ├── @iobroker/plugin-sentry@1.2.1 extraneous
                                ├── @iobroker/socket-classes@1.5.6 extraneous
                                ├── @iobroker/webserver@1.0.3 extraneous
                                ├── @isaacs/cliui@8.0.2 extraneous
                                ├── @js-joda/core@ extraneous
                                ├── @mapbox/node-pre-gyp@1.0.11 extraneous
                                ├── @microsoft/microsoft-graph-types@2.40.0 extraneous
                                ├── @nodelib/fs.scandir@2.1.5 extraneous
                                ├── @nodelib/fs.stat@2.0.5 extraneous
                                ├── @nodelib/fs.walk@1.2.8 extraneous
                                ├── @npmcli/fs@2.1.2 extraneous
                                ├── @npmcli/move-file@2.0.1 extraneous
                                ├── @pkgjs/parseargs@0.11.0 extraneous
                                ├── @protobufjs/aspromise@1.1.2 extraneous
                                ├── @protobufjs/base64@1.1.2 extraneous
                                ├── @protobufjs/codegen@2.0.4 extraneous
                                ├── @protobufjs/eventemitter@1.1.0 extraneous
                                ├── @protobufjs/fetch@1.1.0 extraneous
                                ├── @protobufjs/float@1.0.2 extraneous
                                ├── @protobufjs/inquire@1.1.0 extraneous
                                ├── @protobufjs/path@1.1.2 extraneous
                                ├── @protobufjs/pool@1.1.0 extraneous
                                ├── @protobufjs/utf8@1.1.0 extraneous
                                ├── @quasar/extras@ extraneous
                                ├── @samverschueren/stream-to-observable@0.3.1 extraneous
                                ├── @sentry-internal/tracing@ extraneous
                                ├── @sentry/core@5.30.0 extraneous
                                ├── @sentry/hub@5.30.0 extraneous
                                ├── @sentry/minimal@5.30.0 extraneous
                                ├── @sentry/node@ extraneous
                                ├── @sentry/tracing@ extraneous
                                ├── @sentry/types@ extraneous
                                ├── @sentry/utils@ extraneous
                                ├── @sindresorhus/is@4.6.0 extraneous
                                ├── @socket.io/component-emitter@3.1.2 extraneous
                                ├── @szmarczak/http-timer@4.0.6 extraneous
                                ├── @tediousjs/connection-string@0.5.0 extraneous
                                ├── @tootallnate/once@2.0.0 extraneous
                                ├── @types/bl@5.1.0 extraneous
                                ├── @types/cacheable-request@6.0.3 extraneous
                                ├── @types/caseless@0.12.5 extraneous
                                ├── @types/cookie@0.4.1 extraneous
                                ├── @types/cors@2.8.17 extraneous
                                ├── @types/geojson@7946.0.14 extraneous
                                ├── @types/http-cache-semantics@4.0.4 extraneous
                                ├── @types/keyv@3.1.4 extraneous
                                ├── @types/leaflet@1.9.12 extraneous
                                ├── @types/minimist@1.2.5 extraneous
                                ├── @types/node-cron@2.0.8 extraneous
                                ├── @types/node@ extraneous
                                ├── @types/normalize-package-data@2.4.4 extraneous
                                ├── @types/parse-json@4.0.2 extraneous
                                ├── @types/readable-stream@4.0.15 extraneous
                                ├── @types/request@2.48.12 extraneous
                                ├── @types/responselike@1.0.3 extraneous
                                ├── @types/tough-cookie@4.0.5 extraneous
                                ├── @types/triple-beam@1.3.5 extraneous
                                ├── @types/tz-offset@0.0.3 extraneous
                                ├── @types/ws@8.5.12 extraneous
                                ├── abab@2.0.6 extraneous
                                ├── abbrev@1.1.1 extraneous
                                ├── abort-controller@3.0.0 extraneous
                                ├── agentkeepalive@4.5.0 extraneous
                                ├── aggregate-error@3.1.0 extraneous
                                ├── ajv@ extraneous
                                ├── ansi-align@3.0.1 extraneous
                                ├── ansi-colors@4.1.3 extraneous
                                ├── ansi-escapes@4.3.2 extraneous
                                ├── ansi-regex@5.0.1 extraneous
                                ├── ansi-styles@4.3.0 extraneous
                                ├── any-observable@0.5.1 extraneous
                                ├── anymatch@3.1.3 extraneous
                                ├── aproba@2.0.0 extraneous
                                ├── archiver-utils@5.0.2 extraneous
                                ├── archiver@7.0.1 extraneous
                                ├── are-we-there-yet@2.0.0 extraneous
                                ├── arg@4.1.0 extraneous
                                ├── argparse@1.0.10 extraneous
                                ├── array-buffer-byte-length@1.0.1 extraneous
                                ├── array-flatten@1.1.1 extraneous
                                ├── array-union@2.1.0 extraneous
                                ├── arraybuffer.prototype.slice@1.0.3 extraneous
                                ├── arrify@2.0.1 extraneous
                                ├── asn1@0.2.6 extraneous
                                ├── async-exit-hook@2.0.1 extraneous
                                ├── authenticate-pam@1.0.5 extraneous
                                ├── available-typed-arrays@1.0.7 extraneous
                                ├── aws-crt@ extraneous
                                ├── b4a@1.6.6 extraneous
                                ├── balanced-match@1.0.2 extraneous
                                ├── bare-events@2.4.2 extraneous
                                ├── base-64@1.0.0 extraneous
                                ├── base64-js@1.5.1 extraneous
                                ├── bcrypt-pbkdf@1.0.2 extraneous
                                ├── binary-extensions@2.3.0 extraneous
                                ├── bindings@1.5.0 extraneous
                                ├── bl@6.0.14 extraneous
                                ├── bluebird@3.7.2 extraneous
                                ├── body-parser@1.20.2 extraneous
                                ├── bottleneck@2.19.5 extraneous
                                ├── boxen@5.1.2 extraneous
                                ├── brace-expansion@2.0.1 extraneous
                                ├── braces@3.0.3 extraneous
                                ├── buffer-crc32@1.0.0 extraneous
                                ├── buffer-equal-constant-time@1.0.1 extraneous
                                ├── buffer-shims@1.0.0 extraneous
                                ├── buffer@6.0.3 extraneous
                                ├── buildcheck@0.0.6 extraneous
                                ├── builtins@1.0.3 extraneous
                                ├── busboy@1.6.0 extraneous
                                ├── byte-length@1.0.2 extraneous
                                ├── bytes@3.1.2 extraneous
                                ├── cacache@16.1.3 extraneous
                                ├── cacheable-lookup@5.0.4 extraneous
                                ├── cacheable-request@7.0.4 extraneous
                                ├── callsites@3.1.0 extraneous
                                ├── camelcase-keys@6.2.2 extraneous
                                ├── camelcase@5.3.1 extraneous
                                ├── capitalize@2.0.4 extraneous
                                ├── chalk@4.1.2 extraneous
                                ├── chardet@0.7.0 extraneous
                                ├── charenc@0.0.2 extraneous
                                ├── chokidar@3.6.0 extraneous
                                ├── chownr@2.0.0 extraneous
                                ├── ci-info@3.9.0 extraneous
                                ├── clean-stack@2.2.0 extraneous
                                ├── cli-boxes@2.2.1 extraneous
                                ├── cli-cursor@3.1.0 extraneous
                                ├── cli-truncate@0.2.1 extraneous
                                ├── cli-width@3.0.0 extraneous
                                ├── clone-response@1.0.3 extraneous
                                ├── cloneextend@0.0.3 extraneous
                                ├── cluster-key-slot@1.1.2 extraneous
                                ├── coap-packet@1.1.1 extraneous
                                ├── coffeescript@1.12.7 extraneous
                                ├── color-convert@2.0.1 extraneous
                                ├── color-name@1.1.4 extraneous
                                ├── color-string@1.9.1 extraneous
                                ├── color-support@1.1.3 extraneous
                                ├── color@3.2.1 extraneous
                                ├── colors@1.4.0
                                ├── colorspace@1.1.4 extraneous
                                ├── commander@9.5.0 extraneous
                                ├── commist@3.2.0 extraneous
                                ├── compress-commons@6.0.2 extraneous
                                ├── compress-json@2.1.2 extraneous
                                ├── compressible@2.0.18 extraneous
                                ├── compression@1.7.4 extraneous
                                ├── concat-map@0.0.1 extraneous
                                ├── configstore@5.0.1 extraneous
                                ├── connect-flash@0.1.1 extraneous
                                ├── connect@3.7.0 extraneous
                                ├── console-control-strings@1.1.0 extraneous
                                ├── content-disposition@0.5.4 extraneous
                                ├── content-type@1.0.5 extraneous
                                ├── core-js@ extraneous
                                ├── cors@2.8.5 extraneous
                                ├── cosmiconfig@7.1.0 extraneous
                                ├── cpu-features@ extraneous
                                ├── crc-32@1.2.2 extraneous
                                ├── crc@ extraneous
                                ├── crc32-stream@6.0.0 extraneous
                                ├── cross-fetch@4.0.0 extraneous
                                ├── crypt@0.0.2 extraneous
                                ├── crypto-js@ extraneous
                                ├── crypto-random-string@2.0.0 extraneous
                                ├── cssstyle@ extraneous
                                ├── cycle@1.0.3 extraneous
                                ├── dashdash@1.14.1 extraneous
                                ├── data-urls@4.0.0 extraneous
                                ├── data-view-buffer@1.0.1 extraneous
                                ├── data-view-byte-length@1.0.1 extraneous
                                ├── data-view-byte-offset@1.0.0 extraneous
                                ├── date-and-time@ extraneous
                                ├── date-fns@1.30.1 extraneous
                                ├── dateformat@4.6.3 extraneous
                                ├── dayjs@ extraneous
                                ├── decache@4.6.2 extraneous
                                ├── decamelize-keys@1.1.1 extraneous
                                ├── decimal.js@10.4.3 extraneous
                                ├── decompress-response@6.0.0 extraneous
                                ├── deep-clone@3.0.3 extraneous
                                ├── deep-extend@0.6.0 extraneous
                                ├── deep-is@0.1.4 extraneous
                                ├── defer-to-connect@2.0.1 extraneous
                                ├── define-lazy-prop@2.0.0 extraneous
                                ├── del@6.1.1 extraneous
                                ├── delegates@1.0.0 extraneous
                                ├── denque@1.5.1 extraneous
                                ├── destroy@1.2.0 extraneous
                                ├── detect-libc@2.0.3 extraneous
                                ├── diacritics@1.3.0 extraneous
                                ├── digest-header@1.1.0 extraneous
                                ├── dir-glob@3.0.1 extraneous
                                ├── diskusage@1.2.0 extraneous
                                ├── domexception@4.0.0 extraneous
                                ├── dot-prop@6.0.1 extraneous
                                ├── draftlog@1.0.13 extraneous
                                ├── dropbox-v2-api@ extraneous
                                ├── duplexer@0.1.2 extraneous
                                ├── duplexer3@0.1.5 extraneous
                                ├── duplexify@3.7.1 extraneous
                                ├── eastasianwidth@0.2.0 extraneous
                                ├── ecc-jsbn@0.1.2 extraneous
                                ├── ecdsa-sig-formatter@1.0.11 extraneous
                                ├── echarts@ extraneous
                                ├── ee-first@1.1.1 extraneous
                                ├── elegant-spinner@1.0.1 extraneous
                                ├── emoji-regex@9.2.2 extraneous
                                ├── enabled@2.0.0 extraneous
                                ├── encodeurl@1.0.2 extraneous
                                ├── encoding@0.1.13 extraneous
                                ├── end-of-stream@1.4.4 extraneous
                                ├── entities@4.5.0 extraneous
                                ├── err-code@2.0.3 extraneous
                                ├── es-abstract@ extraneous
                                ├── es-aggregate-error@1.0.13 extraneous
                                ├── es-object-atoms@1.0.0 extraneous
                                ├── es-set-tostringtag@2.0.3 extraneous
                                ├── es-to-primitive@1.2.1 extraneous
                                ├── es6-promise@4.2.8 extraneous
                                ├── es6-promisify@5.0.0 extraneous
                                ├── esbuild@0.11.23 extraneous
                                ├── escalade@3.1.2 extraneous
                                ├── escape-goat@3.0.0 extraneous
                                ├── escape-html@1.0.3 extraneous
                                ├── escape-string-regexp@4.0.0 extraneous
                                ├── escodegen@1.14.3 extraneous
                                ├── esprima@1.2.2 extraneous
                                ├── estraverse@4.3.0 extraneous
                                ├── esutils@2.0.3 extraneous
                                ├── etag@1.8.1 extraneous
                                ├── event-stream@4.0.1 extraneous
                                ├── event-target-shim@5.0.1 extraneous
                                ├── eventemitter2@6.4.9 extraneous
                                ├── events@3.3.0 extraneous
                                ├── execa@5.1.1 extraneous
                                ├── expand-template@2.0.3 extraneous
                                ├── express-fileupload@1.5.1 extraneous
                                ├── express@4.19.2 extraneous
                                ├── external-editor@3.1.0 extraneous
                                ├── fast-deep-equal@3.1.3 extraneous
                                ├── fast-fifo@1.3.2 extraneous
                                ├── fast-glob@ extraneous
                                ├── fast-json-stable-stringify@2.1.0 extraneous
                                ├── fast-levenshtein@2.0.6 extraneous
                                ├── fast-text-encoding@1.0.6 extraneous
                                ├── fast-unique-numbers@ extraneous
                                ├── fast-uri@3.0.1 extraneous
                                ├── fast-xml-parser@ extraneous
                                ├── fastq@1.17.1 extraneous
                                ├── fastseries@2.0.0 extraneous
                                ├── fecha@4.2.3 extraneous
                                ├── figures@3.2.0 extraneous
                                ├── file-stream-rotator@0.6.1 extraneous
                                ├── file-type@10.11.0 extraneous
                                ├── file-uri-to-path@1.0.0 extraneous
                                ├── fill-range@7.1.1 extraneous
                                ├── finalhandler@1.2.0 extraneous
                                ├── find-up@5.0.0 extraneous
                                ├── fn.name@1.1.0 extraneous
                                ├── for-each@0.3.3 extraneous
                                ├── foreground-child@3.3.0 extraneous
                                ├── form-data-encoder@2.1.4 extraneous
                                ├── form-data@4.0.0 extraneous
                                ├── forwarded@0.2.0 extraneous
                                ├── fresh@0.5.2 extraneous
                                ├── from@0.1.7 extraneous
                                ├── fs-constants@1.0.0 extraneous
                                ├── fs-extra@7.0.1
                                ├── fs-minipass@2.1.0 extraneous
                                ├── fs.realpath@1.0.0 extraneous
                                ├── fsevents@ extraneous
                                ├── ftp@0.3.10 extraneous
                                ├── function.prototype.name@1.1.6 extraneous
                                ├── functions-have-names@1.2.3 extraneous
                                ├── futoin-hkdf@1.4.3 extraneous
                                ├── gauge@3.0.2 extraneous
                                ├── gaxios@5.1.3 extraneous
                                ├── gcp-metadata@5.3.0 extraneous
                                ├── generate-function@2.3.1 extraneous
                                ├── get-ssl-certificate@2.3.3 extraneous
                                ├── get-stream@5.2.0 extraneous
                                ├── get-symbol-description@1.0.2 extraneous
                                ├── getpass@0.1.7 extraneous
                                ├── github-from-package@0.0.0 extraneous
                                ├── github-url-from-git@1.5.0 extraneous
                                ├── glob-parent@5.1.2 extraneous
                                ├── glob@10.4.5 extraneous
                                ├── global-dirs@2.1.0 extraneous
                                ├── globalthis@1.0.4 extraneous
                                ├── globby@11.1.0 extraneous
                                ├── glossy@0.1.7 extraneous
                                ├── google-auth-library@ extraneous
                                ├── google-p12-pem@4.0.1 extraneous
                                ├── googleapis-common@6.0.4 extraneous
                                ├── googleapis@ extraneous
                                ├── gtoken@6.1.2 extraneous
                                ├── hard-rejection@2.1.0 extraneous
                                ├── has-ansi@2.0.0 extraneous
                                ├── has-bigints@1.0.2 extraneous
                                ├── has-flag@4.0.0 extraneous
                                ├── has-tostringtag@1.0.2 extraneous
                                ├── has-unicode@2.0.1 extraneous
                                ├── has-yarn@2.1.0 extraneous
                                ├── he@1.2.0 extraneous
                                ├── help-me@5.0.0 extraneous
                                ├── homebridge-plugin-wrapper@ extraneous
                                ├── hosted-git-info@3.0.8 extraneous
                                ├── hot-patcher@1.0.0 extraneous
                                ├── html-encoding-sniffer@3.0.0 extraneous
                                ├── http-cache-semantics@4.1.1 extraneous
                                ├── http-errors@2.0.0 extraneous
                                ├── http-proxy-agent@5.0.0 extraneous
                                ├── http2-wrapper@1.0.3 extraneous
                                ├── https@1.0.0 extraneous
                                ├── humanize-ms@1.2.1 extraneous
                                ├── ical.js@ extraneous
                                ├── iconv-lite@0.4.24 extraneous
                                ├── ieee754@1.2.1 extraneous
                                ├── ignore-walk@3.0.4 extraneous
                                ├── ignore@5.3.2 extraneous
                                ├── image-type@4.1.0 extraneous
                                ├── immediate@3.0.6 extraneous
                                ├── import-fresh@3.3.0 extraneous
                                ├── import-lazy@2.1.0 extraneous
                                ├── import-local@3.2.0 extraneous
                                ├── imurmurhash@0.1.4 extraneous
                                ├── indent-string@3.2.0 extraneous
                                ├── infer-owner@1.0.4 extraneous
                                ├── inflight@1.0.6 extraneous
                                ├── ini@1.3.7 extraneous
                                ├── inquirer-autosubmit-prompt@0.2.0 extraneous
                                ├── inquirer@7.3.3 extraneous
                                ├── int64-buffer@1.0.1 extraneous
                                ├── internal-slot@1.0.7 extraneous
                                ├── iobroker-adapter-helpers@0.0.8 extraneous
                                ├── iobroker.admin@ invalid: "^6.10.1" from the root project
                                ├── iobroker.backitup@ invalid: "2.6.23" from the root project
                                ├── iobroker.bmw@2.5.7
                                ├── iobroker.calendar@ invalid: "github:WLAN-Kabel/ioBroker.calendar#c36410258c21a4a92eba80fb0ec084fc254c9259" from the root project
                                ├── iobroker.cloud@4.4.1
                                ├── iobroker.coronavirus-statistics@0.8.7
                                ├── iobroker.daswetter@3.1.10
                                ├── iobroker.discovery@ invalid: "3.1.0" from the root project
                                ├── iobroker.dwd@2.8.5
                                ├── iobroker.echarts@ invalid: "1.5.1" from the root project
                                ├── iobroker.energiefluss@ invalid: "github:SKB-CGN/ioBroker.energiefluss#fc7a5b48f0f485b130619796daf0a9533f5b8426" from the root project
                                ├── iobroker.eusec@1.1.2
                                ├── iobroker.flot@ invalid: "1.12.0" from the root project
                                ├── iobroker.fritzbox@0.2.1
                                ├── iobroker.fullcalendar@ invalid: "1.2.0" from the root project
                                ├── iobroker.fullybrowser@2.1.2
                                ├── iobroker.gartenbewaesserung@ invalid: "github:TA2k/ioBroker.gartenbewaesserung#1931dcd562edf9dfa818dbf5cec61e28d3f72d72" from the root project
                                ├── iobroker.ham@ invalid: "github:ioBroker/ioBroker.ham" from the root project
                                ├── iobroker.harmony@1.2.2
                                ├── iobroker.heatingcontrol@ invalid: "2.11.1" from the root project
                                ├── iobroker.history@2.2.6
                                ├── iobroker.hm-rega@3.0.47
                                ├── iobroker.hm-rpc@1.15.19
                                ├── iobroker.hue@3.9.5
                                ├── iobroker.ical@ invalid: "github:iobroker-community-adapters/ioBroker.ical#ad28140ed1fa7ab23683d7e12b6204da06b7ce6f" from the root project
                                ├── iobroker.icons-icons8@0.0.1
                                ├── iobroker.icons-material-png@0.1.0
                                ├── iobroker.icons-mfd-png@1.1.0
                                ├── iobroker.icons-ultimate-png@1.0.1
                                ├── iobroker.info@ invalid: "1.9.26" from the root project
                                ├── iobroker.javascript@ invalid: "7.1.4" from the root project
                                ├── iobroker.js-controller@ invalid: "^6.0.9" from the root project
                                ├── iobroker.logparser@2.2.0
                                ├── iobroker.material@ invalid: "1.3.1" from the root project
                                ├── iobroker.meross@1.15.1
                                ├── iobroker.mihome-vacuum@3.11.0
                                ├── iobroker.milight-smart-light@ invalid: "1.2.2" from the root project
                                ├── iobroker.milight@0.3.6
                                ├── iobroker.mobile@ invalid: "1.0.1" from the root project
                                ├── iobroker.modbus@ invalid: "5.0.11" from the root project
                                ├── iobroker.mqtt@ invalid: "4.1.1" from the root project
                                ├── iobroker.nina@ invalid: "0.0.25" from the root project
                                ├── iobroker.pollenflug@1.0.6
                                ├── iobroker.pushover@3.0.3
                                ├── iobroker.pushsafer@1.0.3
                                ├── iobroker.pvforecast@2.7.1
                                ├── iobroker.renault@ invalid: "github:TA2k/ioBroker.renault" from the root project
                                ├── iobroker.reolink@ invalid: "github:aendue/ioBroker.reolink#b78aab6744cdb81b360fd947a9c6e2fd6808bab1" from the root project
                                ├── iobroker.schoolfree@ invalid: "1.1.2" from the root project
                                ├── iobroker.simple-api@2.7.2
                                ├── iobroker.smartmeter@3.3.4
                                ├── iobroker.socketio@6.5.2
                                ├── iobroker.sourceanalytix@ invalid: "github:DrozmotiX/ioBroker.sourceanalytix#362346b297c0a21c717ec20bd8d16331bca3b22d" from the root project
                                ├── iobroker.sql@2.2.0
                                ├── iobroker.statistics@2.3.0
                                ├── iobroker.sunnyportal@0.1.5
                                ├── iobroker.synology@ invalid: "2.1.13" from the root project
                                ├── iobroker.tankerkoenig@ invalid: "3.3.7" from the root project
                                ├── iobroker.terminal@ invalid: "1.0.0" from the root project
                                ├── iobroker.tr-064@4.2.18
                                ├── iobroker.trashschedule@2.2.0
                                ├── iobroker.unifi@ invalid: "0.6.6" from the root project
                                ├── iobroker.upnp@1.0.21
                                ├── iobroker.valloxmv@1.2.0
                                ├── iobroker.viessmannapi@ invalid: "github:TA2k/ioBroker.viessmannapi" from the root project
                                ├── iobroker.virtualpowermeter@ invalid: "1.4.6" from the root project
                                ├── iobroker.vis-2-widgets-material@ invalid: "github:ioBroker/ioBroker.vis-2-widgets-material#355a97e7d532721eaa97326fd873d13f12894ebd" from the root project
                                ├── iobroker.vis-2@ invalid: "github:ioBroker/ioBroker.vis-2#17c7dcf5f26768f1f3a4badb087eddf9344591ea" from the root project
                                ├── iobroker.vis-colorpicker@ invalid: "2.0.3" from the root project
                                ├── iobroker.vis-fancyswitch@1.1.0
                                ├── iobroker.vis-google-fonts@1.0.4
                                ├── iobroker.vis-history@1.0.0
                                ├── iobroker.vis-hqwidgets@ invalid: "1.4.0" from the root project
                                ├── iobroker.vis-inventwo@ invalid: "3.3.3" from the root project
                                ├── iobroker.vis-jqui-mfd@1.0.12
                                ├── iobroker.vis-justgage@1.0.2
                                ├── iobroker.vis-map@1.0.4
                                ├── iobroker.vis-materialdesign@ invalid: "github:Scrounger/ioBroker.vis-materialdesign#8b7529d493f223dfc4f1d1f632553fcb35bbcc92" from the root project
                                ├── iobroker.vis-metro@ invalid: "1.2.0" from the root project
                                ├── iobroker.vis-rgraph@0.0.2
                                ├── iobroker.vis-timeandweather@ invalid: "1.2.2" from the root project
                                ├── iobroker.vis-weather@ invalid: "2.5.6" from the root project
                                ├── iobroker.vis@ invalid: "1.4.16" from the root project
                                ├── iobroker.vofo-speedtest@ invalid: "github:peterbaumert/ioBroker.vofo-speedtest#921201b4bbd53a88a64fc843c7242f9e7e8c0325" from the root project
                                ├── iobroker.weatherunderground@3.4.2
                                ├── iobroker.web-speedy@ invalid: "github:iobroker-community-adapters/ioBroker.web-speedy#8a5ad6a42a15688b6bb539f22e30ba2a1978c118" from the root project
                                ├── iobroker.web@ invalid: "6.1.0" from the root project
                                ├── iobroker.webcal@ invalid: "github:dirkhe/ioBroker.webcal#feature/DigestAuth" from the root project
                                ├── iobroker.wiffi-wz@2.2.1
                                ├── iobroker.windows-control@0.1.5
                                ├── iobroker.worx@2.3.2
                                ├── iobroker.ws@2.5.3
                                ├── iobroker@2.0.3
                                ├── ioredis@ extraneous
                                ├── ip-address@9.0.5 extraneous
                                ├── ip-regex@4.3.0 extraneous
                                ├── ipaddr.js@2.2.0 extraneous
                                ├── is-array-buffer@3.0.4 extraneous
                                ├── is-bigint@1.0.4 extraneous
                                ├── is-binary-path@2.1.0 extraneous
                                ├── is-boolean-object@1.1.2 extraneous
                                ├── is-buffer@1.1.6 extraneous
                                ├── is-callable@1.2.7 extraneous
                                ├── is-ci@2.0.0 extraneous
                                ├── is-core-module@2.15.0 extraneous
                                ├── is-data-view@1.0.1 extraneous
                                ├── is-date-object@1.0.5 extraneous
                                ├── is-docker@2.2.1 extraneous
                                ├── is-empty-object@1.1.1 extraneous
                                ├── is-extglob@2.1.1 extraneous
                                ├── is-fullwidth-code-point@3.0.0 extraneous
                                ├── is-glob@4.0.3 extraneous
                                ├── is-installed-globally@0.3.2 extraneous
                                ├── is-interactive@1.0.0 extraneous
                                ├── is-lambda@1.0.1 extraneous
                                ├── is-negative-zero@2.0.3 extraneous
                                ├── is-npm@5.0.0 extraneous
                                ├── is-number-object@1.0.7 extraneous
                                ├── is-number@7.0.0 extraneous
                                ├── is-obj@2.0.0 extraneous
                                ├── is-observable@1.1.0 extraneous
                                ├── is-path-cwd@2.2.0 extraneous
                                ├── is-path-inside@3.0.3 extraneous
                                ├── is-plain-obj@1.1.0 extraneous
                                ├── is-potential-custom-element-name@1.0.1 extraneous
                                ├── is-promise@2.2.2 extraneous
                                ├── is-property@1.0.2 extraneous
                                ├── is-regex@1.1.4 extraneous
                                ├── is-scoped@2.1.0 extraneous
                                ├── is-shared-array-buffer@1.0.3 extraneous
                                ├── is-string@1.0.7 extraneous
                                ├── is-symbol@1.0.4 extraneous
                                ├── is-typed-array@1.1.13 extraneous
                                ├── is-unicode-supported@0.1.0 extraneous
                                ├── is-url-superb@4.0.0 extraneous
                                ├── is-url@1.2.4 extraneous
                                ├── is-weakref@1.0.2 extraneous
                                ├── is-wsl@2.2.0 extraneous
                                ├── is-yarn-global@0.3.0 extraneous
                                ├── is@3.3.0 extraneous
                                ├── is2@2.0.9 extraneous
                                ├── isomorphic-ws@4.0.1 extraneous
                                ├── issue-regex@3.1.0 extraneous
                                ├── jackspeak@3.4.3 extraneous
                                ├── js-md4@0.3.2 extraneous
                                ├── js-sdsl@4.3.0 extraneous
                                ├── js-tokens@4.0.0 extraneous
                                ├── js-yaml@ extraneous
                                ├── jsbi@4.3.0 extraneous
                                ├── jsbn@1.1.0 extraneous
                                ├── jsdom@ extraneous
                                ├── jshashes@1.0.8 extraneous
                                ├── json-buffer@3.0.1 extraneous
                                ├── json-logic-js@2.0.5 extraneous
                                ├── json-parse-even-better-errors@2.3.1 extraneous
                                ├── json-schema-traverse@1.0.0 extraneous
                                ├── json5@2.2.3 extraneous
                                ├── jsonata@ extraneous
                                ├── jsonc-parser@3.3.1 extraneous
                                ├── jsonwebtoken@9.0.2 extraneous
                                ├── jszip@ extraneous
                                ├── jwa@2.0.0 extraneous
                                ├── jws@4.0.0 extraneous
                                ├── keyv@4.5.4 extraneous
                                ├── kind-of@6.0.3 extraneous
                                ├── kuler@2.0.0 extraneous
                                ├── later@1.2.0 extraneous
                                ├── latest-version@5.1.0 extraneous
                                ├── layerr@0.1.2 extraneous
                                ├── lazystream@1.0.1 extraneous
                                ├── leven@2.1.0 extraneous
                                ├── levn@0.3.0 extraneous
                                ├── lie@3.3.0 extraneous
                                ├── lines-and-columns@1.2.4 extraneous
                                ├── listr-input@0.2.1 extraneous
                                ├── listr-silent-renderer@1.1.1 extraneous
                                ├── listr-update-renderer@0.5.0 extraneous
                                ├── listr-verbose-renderer@0.5.0 extraneous
                                ├── listr@0.14.3 extraneous
                                ├── loadavg-windows@1.1.1 extraneous
                                ├── locate-path@6.0.0 extraneous
                                ├── lodash.defaults@4.2.0 extraneous
                                ├── lodash.flatten@4.4.0 extraneous
                                ├── lodash.includes@4.3.0 extraneous
                                ├── lodash.isarguments@3.1.0 extraneous
                                ├── lodash.isboolean@3.0.3 extraneous
                                ├── lodash.isequal@4.5.0 extraneous
                                ├── lodash.isinteger@4.0.4 extraneous
                                ├── lodash.isnumber@3.0.3 extraneous
                                ├── lodash.isplainobject@4.0.6 extraneous
                                ├── lodash.isstring@4.0.1 extraneous
                                ├── lodash.once@4.1.1 extraneous
                                ├── lodash.zip@4.2.0 extraneous
                                ├── log-symbols@4.1.0 extraneous
                                ├── log-update@2.3.0 extraneous
                                ├── logform@ extraneous
                                ├── long@5.2.3 extraneous
                                ├── lowercase-keys@2.0.0 extraneous
                                ├── lru_map@0.3.3 extraneous
                                ├── lru-cache@6.0.0 extraneous
                                ├── make-dir@3.1.0 extraneous
                                ├── make-fetch-happen@10.2.1 extraneous
                                ├── map-age-cleaner@0.1.3 extraneous
                                ├── map-obj@4.3.0 extraneous
                                ├── map-stream@0.0.7 extraneous
                                ├── md5@2.3.0 extraneous
                                ├── media-typer@0.3.0 extraneous
                                ├── meow@8.1.2 extraneous
                                ├── merge-descriptors@1.0.1 extraneous
                                ├── merge2@1.4.1 extraneous
                                ├── methods@1.1.2 extraneous
                                ├── micro@9.4.1 extraneous
                                ├── micromatch@4.0.7 extraneous
                                ├── mime-db@1.53.0 extraneous
                                ├── mimic-response@1.0.1 extraneous
                                ├── min-indent@1.0.1 extraneous
                                ├── minimatch@9.0.5 extraneous
                                ├── minimist-options@4.1.0 extraneous
                                ├── minipass-collect@1.0.2 extraneous
                                ├── minipass-fetch@2.1.2 extraneous
                                ├── minipass-flush@1.0.5 extraneous
                                ├── minipass-pipeline@1.2.4 extraneous
                                ├── minipass-sized@1.0.3 extraneous
                                ├── minipass@7.1.2 extraneous
                                ├── minizlib@2.1.2 extraneous
                                ├── mkdirp-classic@0.5.3 extraneous
                                ├── mkdirp@1.0.4 extraneous
                                ├── mock-require@3.0.3 extraneous
                                ├── moment-duration-format@2.3.2 extraneous
                                ├── mqtt-connection@4.1.0 extraneous
                                ├── mqtt-packet@9.0.0 extraneous
                                ├── mqtt@ extraneous
                                ├── mute-stream@0.0.8 extraneous
                                ├── named-placeholders@1.1.3 extraneous
                                ├── nan@ extraneous
                                ├── nanoid@3.3.7 extraneous
                                ├── napi-build-utils@1.0.2 extraneous
                                ├── native-duplexpair@1.0.0 extraneous
                                ├── nconf@0.10.0 extraneous
                                ├── nested-property@4.0.0 extraneous
                                ├── netmask@2.0.2 extraneous
                                ├── new-github-release-url@1.0.0 extraneous
                                ├── node-abi@3.65.0 extraneous
                                ├── node-abort-controller@3.1.1 extraneous
                                ├── node-cron@2.0.3 extraneous
                                ├── node-fetch@2.7.0 extraneous
                                ├── node-forge@ extraneous
                                ├── node-gyp@ extraneous
                                ├── node-ical@0.16.1 extraneous
                                ├── node-inspect@2.0.0 extraneous
                                ├── node-libcurl@3.0.0 extraneous
                                ├── node-mndp@0.0.3 extraneous
                                ├── node-persist@0.0.11 extraneous
                                ├── node-rsa@1.1.1 extraneous
                                ├── node-unifi@2.5.1 extraneous
                                ├── node-wol@0.1.1 extraneous
                                ├── node.extend@2.0.3 extraneous
                                ├── nopt@5.0.0 extraneous
                                ├── normalize-package-data@3.0.3 extraneous
                                ├── normalize-path@3.0.0 extraneous
                                ├── normalize-url@6.1.0 extraneous
                                ├── np@7.7.0 extraneous
                                ├── npm-name@6.0.1 extraneous
                                ├── npmlog@5.0.1 extraneous
                                ├── number-allocator@1.0.14 extraneous
                                ├── nwsapi@2.2.12 extraneous
                                ├── object-assign@4.1.1 extraneous
                                ├── object-hash@3.0.0 extraneous
                                ├── on-finished@2.4.1 extraneous
                                ├── once@1.4.0 extraneous
                                ├── one-time@1.0.0 extraneous
                                ├── onedrive-api@1.1.1 extraneous
                                ├── open@7.4.2 extraneous
                                ├── opencollective-postinstall@2.0.3 extraneous
                                ├── optionator@0.8.3 extraneous
                                ├── org-regex@1.0.0 extraneous
                                ├── os-tmpdir@1.0.2 extraneous
                                ├── ospath@1.2.2 extraneous
                                ├── osx-temperature-sensor@ extraneous
                                ├── otplib@11.0.1 extraneous
                                ├── ow@0.21.0 extraneous
                                ├── p-cancelable@2.1.1 extraneous
                                ├── p-defer@1.0.0 extraneous
                                ├── p-event@4.2.0 extraneous
                                ├── p-finally@1.0.0 extraneous
                                ├── p-limit@2.3.0 extraneous
                                ├── p-locate@5.0.0 extraneous
                                ├── p-map@2.1.0 extraneous
                                ├── p-memoize@4.0.4 extraneous
                                ├── p-reflect@2.1.0 extraneous
                                ├── p-settle@4.1.1 extraneous
                                ├── p-throttle@4.1.1 extraneous
                                ├── p-timeout@4.1.0 extraneous
                                ├── p-try@2.2.0 extraneous
                                ├── package-json-from-dist@1.0.0 extraneous
                                ├── package-json@6.5.0 extraneous
                                ├── pako@ extraneous
                                ├── parent-module@1.0.1 extraneous
                                ├── parse-json@5.2.0 extraneous
                                ├── parse5@ extraneous
                                ├── passport-local@1.0.0 extraneous
                                ├── passport@0.7.0 extraneous
                                ├── path-exists@4.0.0 extraneous
                                ├── path-is-absolute@1.0.1 extraneous
                                ├── path-parse@1.0.7 extraneous
                                ├── path-posix@1.0.0 extraneous
                                ├── path-scurry@1.11.1 extraneous
                                ├── path-to-regexp@0.1.7 extraneous
                                ├── path-type@4.0.0 extraneous
                                ├── pause-stream@0.0.11 extraneous
                                ├── picomatch@2.3.1 extraneous
                                ├── pidtree@0.6.0 extraneous
                                ├── pidusage@3.0.2 extraneous
                                ├── ping@0.4.4 extraneous
                                ├── pkg-dir@5.0.0 extraneous
                                ├── pluralize@8.0.0 extraneous
                                ├── possible-typed-array-names@1.0.0 extraneous
                                ├── prebuild-install@7.1.2 extraneous
                                ├── prelude-ls@1.1.2 extraneous
                                ├── prepend-http@2.0.0 extraneous
                                ├── process-nextick-args@2.0.1 extraneous
                                ├── process@0.11.10 extraneous
                                ├── promise-inflight@1.0.1 extraneous
                                ├── promise-object@0.1.7 extraneous
                                ├── promise-retry@2.0.1 extraneous
                                ├── promise-retryer@0.0.1 extraneous
                                ├── promisify-child-process@4.1.2 extraneous
                                ├── prompt@1.3.0 extraneous
                                ├── protobufjs@ extraneous
                                ├── proxy-addr@2.0.7 extraneous
                                ├── proxy-from-env@1.1.0 extraneous
                                ├── pump@3.0.0 extraneous
                                ├── pupa@2.1.1 extraneous
                                ├── q@1.1.2 extraneous
                                ├── quasar@ extraneous
                                ├── queue-microtask@1.2.3 extraneous
                                ├── queue-tick@1.0.1 extraneous
                                ├── quick-lru@5.1.1 extraneous
                                ├── range-parser@1.2.1 extraneous
                                ├── raw-body@2.5.2 extraneous
                                ├── rc@1.2.8 extraneous
                                ├── read-pkg-up@7.0.1 extraneous
                                ├── read-pkg@5.2.0 extraneous
                                ├── read@1.0.7 extraneous
                                ├── readable-stream@ extraneous
                                ├── readdir-glob@1.1.3 extraneous
                                ├── readdirp@3.6.0 extraneous
                                ├── readline-sync@1.4.10 extraneous
                                ├── readline@1.3.0 extraneous
                                ├── redent@3.0.0 extraneous
                                ├── redis-commands@1.7.0 extraneous
                                ├── redis-errors@1.2.0 extraneous
                                ├── redis-parser@3.0.0 extraneous
                                ├── regenerator-runtime@0.14.1 extraneous
                                ├── regex-escape@3.4.10 extraneous
                                ├── regexp.prototype.flags@1.5.2 extraneous
                                ├── registry-auth-token@4.2.2 extraneous
                                ├── registry-url@5.1.0 extraneous
                                ├── reinterval@1.1.0 extraneous
                                ├── remove-trailing-separator@1.1.0 extraneous
                                ├── require-from-string@2.0.2 extraneous
                                ├── resolve-alpn@1.2.1 extraneous
                                ├── resolve-cwd@3.0.0 extraneous
                                ├── resolve-from@4.0.0 extraneous
                                ├── respjs@4.2.0 extraneous
                                ├── responselike@2.0.1 extraneous
                                ├── restore-cursor@3.1.0 extraneous
                                ├── retry-axios@2.6.0 extraneous
                                ├── retry@0.12.0 extraneous
                                ├── reusify@1.0.4 extraneous
                                ├── revalidator@0.1.8 extraneous
                                ├── rfdc@1.4.1 extraneous
                                ├── rimraf@3.0.2 extraneous
                                ├── rrule@2.8.1 extraneous
                                ├── rrweb-cssom@0.6.0 extraneous
                                ├── run-async@2.4.1 extraneous
                                ├── run-parallel@1.2.0 extraneous
                                ├── rxjs@ extraneous
                                ├── safe-array-concat@1.1.2 extraneous
                                ├── safe-regex-test@1.0.3 extraneous
                                ├── safe-stable-stringify@2.4.3 extraneous
                                ├── safer-buffer@2.1.2 extraneous
                                ├── saxes@6.0.0 extraneous
                                ├── scoped-regex@2.1.0 extraneous
                                ├── secure-keys@1.0.0 extraneous
                                ├── semver-diff@3.1.1 extraneous
                                ├── semver@5.7.2
                                ├── send@0.18.0 extraneous
                                ├── seq-logging@1.1.2 extraneous
                                ├── seq-queue@0.0.5 extraneous
                                ├── serve-static@1.15.0 extraneous
                                ├── set-function-name@2.0.2 extraneous
                                ├── setimmediate@1.0.5 extraneous
                                ├── setprototypeof@1.2.0 extraneous
                                ├── signal-exit@4.1.0 extraneous
                                ├── simple-concat@1.0.1 extraneous
                                ├── simple-get@3.1.1 extraneous
                                ├── simple-ssh@1.1.1 extraneous
                                ├── simple-swizzle@0.2.2 extraneous
                                ├── slash@3.0.0 extraneous
                                ├── slice-ansi@0.0.4 extraneous
                                ├── smart-buffer@4.2.0 extraneous
                                ├── socks-proxy-agent@7.0.0 extraneous
                                ├── socks@2.8.3 extraneous
                                ├── speedtest-net@1.6.2 extraneous
                                ├── split@1.0.1 extraneous
                                ├── sprintf-js@1.1.3 extraneous
                                ├── sqlstring@2.3.3 extraneous
                                ├── ssh2@ extraneous
                                ├── ssri@9.0.1 extraneous
                                ├── stack-trace@0.0.10 extraneous
                                ├── stampit-event-bus@0.1.1 extraneous
                                ├── stampit-state-machine@0.2.1 extraneous
                                ├── stampit@2.1.2 extraneous
                                ├── standard-as-callback@2.1.0 extraneous
                                ├── static-eval@2.0.2 extraneous
                                ├── statuses@2.0.1 extraneous
                                ├── stoppable@1.1.0 extraneous
                                ├── stream-combiner@0.2.2 extraneous
                                ├── stream-shift@1.0.3 extraneous
                                ├── streamsearch@1.1.0 extraneous
                                ├── streamx@2.18.0 extraneous
                                ├── string-argv@0.3.2 extraneous
                                ├── string-width-cjs@npm:string-width@4.2.3 extraneous
                                ├── string-width@5.1.2 extraneous
                                ├── string.prototype.trim@1.2.9 extraneous
                                ├── string.prototype.trimend@1.0.8 extraneous
                                ├── string.prototype.trimstart@1.0.8 extraneous
                                ├── strip-ansi-cjs@npm:strip-ansi@6.0.1 extraneous
                                ├── strip-ansi@6.0.1 extraneous
                                ├── strip-indent@3.0.0 extraneous
                                ├── strip-json-comments@2.0.1 extraneous
                                ├── strnum@1.0.5 extraneous
                                ├── suncalc@1.9.0 extraneous
                                ├── suncalc2@1.8.1 extraneous
                                ├── supermixer@1.0.5 extraneous
                                ├── supports-color@7.2.0 extraneous
                                ├── supports-hyperlinks@2.3.0 extraneous
                                ├── supports-preserve-symlinks-flag@1.0.0 extraneous
                                ├── sweet-collections@1.1.0 extraneous
                                ├── symbol-observable@3.0.0 extraneous
                                ├── symbol-tree@3.2.4 extraneous
                                ├── syno@ extraneous
                                ├── systeminformation@ extraneous
                                ├── tar-fs@2.1.1 extraneous
                                ├── tar-stream@3.1.7 extraneous
                                ├── tar@6.2.1 extraneous
                                ├── tarn@3.0.2 extraneous
                                ├── tcp-port-used@1.0.2 extraneous
                                ├── tedious@ extraneous
                                ├── terminal-link@2.1.1 extraneous
                                ├── text-decoder@1.1.1 extraneous
                                ├── text-hex@1.0.0 extraneous
                                ├── thirty-two@1.0.2 extraneous
                                ├── through@2.3.8 extraneous
                                ├── through2@2.0.5 extraneous
                                ├── tiny-typed-emitter@2.1.0 extraneous
                                ├── tinycolor2@1.6.0 extraneous
                                ├── tmp@0.0.33 extraneous
                                ├── to-readable-stream@2.1.0 extraneous
                                ├── to-regex-range@5.0.1 extraneous
                                ├── toidentifier@1.0.1 extraneous
                                ├── tr46@4.1.1 extraneous
                                ├── trim-newlines@3.0.1 extraneous
                                ├── triple-beam@1.4.1 extraneous
                                ├── tsdav@ extraneous
                                ├── tslib@2.3.0 extraneous
                                ├── tweetnacl@0.14.5 extraneous
                                ├── type-check@0.3.2 extraneous
                                ├── type-fest@0.21.3 extraneous
                                ├── type-is@1.6.18 extraneous
                                ├── typed-array-buffer@1.0.2 extraneous
                                ├── typed-array-byte-length@1.0.1 extraneous
                                ├── typed-array-byte-offset@1.0.2 extraneous
                                ├── typed-array-length@1.0.6 extraneous
                                ├── typedarray-to-buffer@3.1.5 extraneous
                                ├── typedarray.prototype.slice@1.0.3 extraneous
                                ├── typescript@ extraneous
                                ├── tz-offset@0.0.1 extraneous
                                ├── uid-number@0.0.6 extraneous
                                ├── unbox-primitive@1.0.2 extraneous
                                ├── undici-types@6.19.6 extraneous
                                ├── unique-filename@2.0.1 extraneous
                                ├── unique-slug@3.0.0 extraneous
                                ├── unique-string@2.0.0 extraneous
                                ├── unix-dgram@2.0.6 extraneous
                                ├── unpipe@1.0.0 extraneous
                                ├── update-notifier@5.1.0 extraneous
                                ├── uri-js@4.4.1 extraneous
                                ├── url-join@4.0.1 extraneous
                                ├── url-parse-lax@3.0.0 extraneous
                                ├── url-template@2.0.8 extraneous
                                ├── url@0.11.4 extraneous
                                ├── vali-date@1.0.0 extraneous
                                ├── validate-npm-package-name@3.0.0 extraneous
                                ├── vary@1.1.2 extraneous
                                ├── virtual-tsc@0.6.2 extraneous
                                ├── vue-i18n@ extraneous
                                ├── vuelidate-messages@0.1.2 extraneous
                                ├── vuelidate@ extraneous
                                ├── vuex-map-fields@1.4.1 extraneous
                                ├── w3c-xmlserializer@4.0.0 extraneous
                                ├── wake_on_lan@1.0.0 extraneous
                                ├── weak-daemon@1.0.3 extraneous
                                ├── webdav@ extraneous
                                ├── webidl-conversions@7.0.0 extraneous
                                ├── websocket-stream@5.5.2 extraneous
                                ├── whatwg-encoding@2.0.0 extraneous
                                ├── whatwg-mimetype@3.0.0 extraneous
                                ├── whatwg-url@12.0.1 extraneous
                                ├── which-boxed-primitive@1.0.2 extraneous
                                ├── which-typed-array@1.1.15 extraneous
                                ├── wide-align@1.1.5 extraneous
                                ├── widest-line@3.1.0 extraneous
                                ├── window-size@0.1.4 extraneous
                                ├── winston-daily-rotate-file@5.0.0 extraneous
                                ├── winston-seq-updated@1.0.4 extraneous
                                ├── winston-syslog@2.7.1 extraneous
                                ├── winston-transport@4.7.1 extraneous
                                ├── winston@ extraneous
                                ├── word-wrap@1.2.5 extraneous
                                ├── worker-timers-broker@6.1.8 extraneous
                                ├── worker-timers-worker@7.0.71 extraneous
                                ├── worker-timers@7.1.8 extraneous
                                ├── wrap-ansi-cjs@npm:wrap-ansi@7.0.0 extraneous
                                ├── wrap-ansi@8.1.0 extraneous
                                ├── wrappy@1.0.2 extraneous
                                ├── write-file-atomic@3.0.3 extraneous
                                ├── xdg-basedir@4.0.0 extraneous
                                ├── xml-js@1.6.11 extraneous
                                ├── xml-name-validator@4.0.0 extraneous
                                ├── xmlchars@2.2.0 extraneous
                                ├── xregexp@2.0.0 extraneous
                                ├── yallist@4.0.0 extraneous
                                ├── yaml@ extraneous
                                ├── yargs-parser@20.2.9 extraneous
                                ├── yargs@7.1.2
                                ├── yocto-queue@0.1.0 extraneous
                                ├── zip-stream@6.0.1 extraneous
                                └── zrender@ extraneous
                                  Teil 2
                                  npm error code ELSPROBLEMS
                                  npm error extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
                                  npm error extraneous: @alcalzone/jsonl-db@3.1.1 /opt/iobroker/node_modules/@alcalzone/jsonl-db
                                  npm error extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/@alcalzone/pak
                                  npm error extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
                                  npm error extraneous: @aws-sdk/util-utf8-browser@3.259.0 /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser
                                  npm error extraneous: @azure/abort-controller@1.1.0 /opt/iobroker/node_modules/@azure/abort-controller
                                  npm error extraneous: @azure/core-auth@1.7.2 /opt/iobroker/node_modules/@azure/core-auth
                                  npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
                                  npm error extraneous: @azure/core-http-compat@ /opt/iobroker/node_modules/@azure/core-http-compat
                                  npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
                                  npm error extraneous: @azure/core-paging@1.6.2 /opt/iobroker/node_modules/@azure/core-paging
                                  npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
                                  npm error extraneous: @azure/core-tracing@1.1.2 /opt/iobroker/node_modules/@azure/core-tracing
                                  npm error extraneous: @azure/core-util@ /opt/iobroker/node_modules/@azure/core-util
                                  npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
                                  npm error extraneous: @azure/keyvault-keys@ /opt/iobroker/node_modules/@azure/keyvault-keys
                                  npm error extraneous: @azure/logger@1.1.4 /opt/iobroker/node_modules/@azure/logger
                                  npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
                                  npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
                                  npm error extraneous: @azure/msal-node@1.18.4 /opt/iobroker/node_modules/@azure/msal-node
                                  npm error extraneous: @babel/code-frame@7.24.7 /opt/iobroker/node_modules/@babel/code-frame
                                  npm error extraneous: @babel/helper-validator-identifier@7.24.7 /opt/iobroker/node_modules/@babel/helper-validator-identifier
                                  npm error extraneous: @babel/highlight@7.24.7 /opt/iobroker/node_modules/@babel/highlight
                                  npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
                                  npm error extraneous: @colors/colors@1.5.0 /opt/iobroker/node_modules/@colors/colors
                                  npm error extraneous: @dabh/diagnostics@2.0.3 /opt/iobroker/node_modules/@dabh/diagnostics
                                  npm error extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
                                  npm error extraneous: @gar/promisify@1.1.3 /opt/iobroker/node_modules/@gar/promisify
                                  npm error extraneous: @googleapis/calendar@9.7.7 /opt/iobroker/node_modules/@googleapis/calendar
                                  npm error extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
                                  npm error extraneous: @googleapis/oauth2@1.0.7 /opt/iobroker/node_modules/@googleapis/oauth2
                                  npm error extraneous: @httptoolkit/websocket-stream@6.0.1 /opt/iobroker/node_modules/@httptoolkit/websocket-stream
                                  npm error extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
                                  npm error extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
                                  npm error extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
                                  npm error extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
                                  npm error extraneous: @iobroker/db-states-file@ /opt/iobroker/node_modules/@iobroker/db-states-file
                                  npm error extraneous: @iobroker/db-states-jsonl@ /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                                  npm error extraneous: @iobroker/db-states-redis@ /opt/iobroker/node_modules/@iobroker/db-states-redis
                                  npm error extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
                                  npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
                                  npm error extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modules/@iobroker/js-controller-common-db
                                  npm error extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
                                  npm error extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
                                  npm error extraneous: @iobroker/plugin-sentry@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-sentry
                                  npm error extraneous: @iobroker/socket-classes@1.5.6 /opt/iobroker/node_modules/@iobroker/socket-classes
                                  npm error extraneous: @iobroker/webserver@1.0.3 /opt/iobroker/node_modules/@iobroker/webserver
                                  npm error extraneous: @isaacs/cliui@8.0.2 /opt/iobroker/node_modules/@isaacs/cliui
                                  npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
                                  npm error extraneous: @mapbox/node-pre-gyp@1.0.11 /opt/iobroker/node_modules/@mapbox/node-pre-gyp
                                  npm error extraneous: @microsoft/microsoft-graph-types@2.40.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
                                  npm error extraneous: @nodelib/fs.scandir@2.1.5 /opt/iobroker/node_modules/@nodelib/fs.scandir
                                  npm error extraneous: @nodelib/fs.stat@2.0.5 /opt/iobroker/node_modules/@nodelib/fs.stat
                                  npm error extraneous: @nodelib/fs.walk@1.2.8 /opt/iobroker/node_modules/@nodelib/fs.walk
                                  npm error extraneous: @npmcli/fs@2.1.2 /opt/iobroker/node_modules/@npmcli/fs
                                  npm error extraneous: @npmcli/move-file@2.0.1 /opt/iobroker/node_modules/@npmcli/move-file
                                  npm error extraneous: @pkgjs/parseargs@0.11.0 /opt/iobroker/node_modules/@pkgjs/parseargs
                                  npm error extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
                                  npm error extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
                                  npm error extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
                                  npm error extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
                                  npm error extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
                                  npm error extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
                                  npm error extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
                                  npm error extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
                                  npm error extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
                                  npm error extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
                                  npm error extraneous: @quasar/extras@ /opt/iobroker/node_modules/@quasar/extras
                                  npm error extraneous: @samverschueren/stream-to-observable@0.3.1 /opt/iobroker/node_modules/@samverschueren/stream-to-observable
                                  npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
                                  npm error extraneous: @sentry/core@5.30.0 /opt/iobroker/node_modules/@sentry/core
                                  npm error extraneous: @sentry/hub@5.30.0 /opt/iobroker/node_modules/@sentry/hub
                                  npm error extraneous: @sentry/minimal@5.30.0 /opt/iobroker/node_modules/@sentry/minimal
                                  npm error extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
                                  npm error extraneous: @sentry/tracing@ /opt/iobroker/node_modules/@sentry/tracing
                                  npm error extraneous: @sentry/types@ /opt/iobroker/node_modules/@sentry/types
                                  npm error extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
                                  npm error extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/@sindresorhus/is
                                  npm error extraneous: @socket.io/component-emitter@3.1.2 /opt/iobroker/node_modules/@socket.io/component-emitter
                                  npm error extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/@szmarczak/http-timer
                                  npm error extraneous: @tediousjs/connection-string@0.5.0 /opt/iobroker/node_modules/@tediousjs/connection-string
                                  npm error extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
                                  npm error extraneous: @types/bl@5.1.0 /opt/iobroker/node_modules/@types/bl
                                  npm error extraneous: @types/cacheable-request@6.0.3 /opt/iobroker/node_modules/@types/cacheable-request
                                  npm error extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                                  npm error extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/@types/cookie
                                  npm error extraneous: @types/cors@2.8.17 /opt/iobroker/node_modules/@types/cors
                                  npm error extraneous: @types/geojson@7946.0.14 /opt/iobroker/node_modules/@types/geojson
                                  npm error extraneous: @types/http-cache-semantics@4.0.4 /opt/iobroker/node_modules/@types/http-cache-semantics
                                  npm error extraneous: @types/keyv@3.1.4 /opt/iobroker/node_modules/@types/keyv
                                  npm error extraneous: @types/leaflet@1.9.12 /opt/iobroker/node_modules/@types/leaflet
                                  npm error extraneous: @types/minimist@1.2.5 /opt/iobroker/node_modules/@types/minimist
                                  npm error extraneous: @types/node-cron@2.0.8 /opt/iobroker/node_modules/@types/node-cron
                                  npm error extraneous: @types/node@ /opt/iobroker/node_modules/@types/node
                                  npm error extraneous: @types/normalize-package-data@2.4.4 /opt/iobroker/node_modules/@types/normalize-package-data
                                  npm error extraneous: @types/parse-json@4.0.2 /opt/iobroker/node_modules/@types/parse-json
                                  npm error extraneous: @types/readable-stream@4.0.15 /opt/iobroker/node_modules/@types/readable-stream
                                  npm error extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                                  npm error extraneous: @types/responselike@1.0.3 /opt/iobroker/node_modules/@types/responselike
                                  npm error extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                                  npm error extraneous: @types/triple-beam@1.3.5 /opt/iobroker/node_modules/@types/triple-beam
                                  npm error extraneous: @types/tz-offset@0.0.3 /opt/iobroker/node_modules/@types/tz-offset
                                  npm error extraneous: @types/ws@8.5.12 /opt/iobroker/node_modules/@types/ws
                                  npm error extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
                                  npm error extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
                                  npm error extraneous: abort-controller@3.0.0 /opt/iobroker/node_modules/abort-controller
                                  npm error extraneous: agentkeepalive@4.5.0 /opt/iobroker/node_modules/agentkeepalive
                                  npm error extraneous: aggregate-error@3.1.0 /opt/iobroker/node_modules/aggregate-error
                                  npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
                                  npm error extraneous: ansi-align@3.0.1 /opt/iobroker/node_modules/ansi-align
                                  npm error extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/ansi-colors
                                  npm error extraneous: ansi-escapes@4.3.2 /opt/iobroker/node_modules/ansi-escapes
                                  npm error extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/ansi-regex
                                  npm error extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/ansi-styles
                                  npm error extraneous: any-observable@0.5.1 /opt/iobroker/node_modules/any-observable
                                  npm error extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
                                  npm error extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
                                  npm error extraneous: archiver-utils@5.0.2 /opt/iobroker/node_modules/archiver-utils
                                  npm error extraneous: archiver@7.0.1 /opt/iobroker/node_modules/archiver
                                  npm error extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
                                  npm error extraneous: arg@4.1.0 /opt/iobroker/node_modules/arg
                                  npm error extraneous: argparse@1.0.10 /opt/iobroker/node_modules/argparse
                                  npm error extraneous: array-buffer-byte-length@1.0.1 /opt/iobroker/node_modules/array-buffer-byte-length
                                  npm error extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/array-flatten
                                  npm error extraneous: array-union@2.1.0 /opt/iobroker/node_modules/array-union
                                  npm error extraneous: arraybuffer.prototype.slice@1.0.3 /opt/iobroker/node_modules/arraybuffer.prototype.slice
                                  npm error extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
                                  npm error extraneous: asn1@0.2.6 /opt/iobroker/node_modules/asn1
                                  npm error extraneous: async-exit-hook@2.0.1 /opt/iobroker/node_modules/async-exit-hook
                                  npm error extraneous: authenticate-pam@1.0.5 /opt/iobroker/node_modules/authenticate-pam
                                  npm error extraneous: available-typed-arrays@1.0.7 /opt/iobroker/node_modules/available-typed-arrays
                                  npm error extraneous: aws-crt@ /opt/iobroker/node_modules/aws-crt
                                  npm error extraneous: b4a@1.6.6 /opt/iobroker/node_modules/b4a
                                  npm error extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/balanced-match
                                  npm error extraneous: bare-events@2.4.2 /opt/iobroker/node_modules/bare-events
                                  npm error extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
                                  npm error extraneous: base64-js@1.5.1 /opt/iobroker/node_modules/base64-js
                                  npm error extraneous: bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/bcrypt-pbkdf
                                  npm error extraneous: binary-extensions@2.3.0 /opt/iobroker/node_modules/binary-extensions
                                  npm error extraneous: bindings@1.5.0 /opt/iobroker/node_modules/bindings
                                  npm error extraneous: bl@6.0.14 /opt/iobroker/node_modules/bl
                                  npm error extraneous: bluebird@3.7.2 /opt/iobroker/node_modules/bluebird
                                  npm error extraneous: body-parser@1.20.2 /opt/iobroker/node_modules/body-parser
                                  npm error extraneous: bottleneck@2.19.5 /opt/iobroker/node_modules/bottleneck
                                  npm error extraneous: boxen@5.1.2 /opt/iobroker/node_modules/boxen
                                  npm error extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/brace-expansion
                                  npm error extraneous: braces@3.0.3 /opt/iobroker/node_modules/braces
                                  npm error extraneous: buffer-crc32@1.0.0 /opt/iobroker/node_modules/buffer-crc32
                                  npm error extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
                                  npm error extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
                                  npm error extraneous: buffer@6.0.3 /opt/iobroker/node_modules/buffer
                                  npm error extraneous: buildcheck@0.0.6 /opt/iobroker/node_modules/buildcheck
                                  npm error extraneous: builtins@1.0.3 /opt/iobroker/node_modules/builtins
                                  npm error extraneous: busboy@1.6.0 /opt/iobroker/node_modules/busboy
                                  npm error extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
                                  npm error extraneous: bytes@3.1.2 /opt/iobroker/node_modules/bytes
                                  npm error extraneous: cacache@16.1.3 /opt/iobroker/node_modules/cacache
                                  npm error extraneous: cacheable-lookup@5.0.4 /opt/iobroker/node_modules/cacheable-lookup
                                  npm error extraneous: cacheable-request@7.0.4 /opt/iobroker/node_modules/cacheable-request
                                  npm error extraneous: callsites@3.1.0 /opt/iobroker/node_modules/callsites
                                  npm error extraneous: camelcase-keys@6.2.2 /opt/iobroker/node_modules/camelcase-keys
                                  npm error extraneous: camelcase@5.3.1 /opt/iobroker/node_modules/camelcase
                                  npm error extraneous: capitalize@2.0.4 /opt/iobroker/node_modules/capitalize
                                  npm error extraneous: chalk@4.1.2 /opt/iobroker/node_modules/chalk
                                  npm error extraneous: chardet@0.7.0 /opt/iobroker/node_modules/chardet
                                  npm error extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
                                  npm error extraneous: chokidar@3.6.0 /opt/iobroker/node_modules/chokidar
                                  npm error extraneous: chownr@2.0.0 /opt/iobroker/node_modules/chownr
                                  npm error extraneous: ci-info@3.9.0 /opt/iobroker/node_modules/ci-info
                                  npm error extraneous: clean-stack@2.2.0 /opt/iobroker/node_modules/clean-stack
                                  npm error extraneous: cli-boxes@2.2.1 /opt/iobroker/node_modules/cli-boxes
                                  npm error extraneous: cli-cursor@3.1.0 /opt/iobroker/node_modules/cli-cursor
                                  npm error extraneous: cli-truncate@0.2.1 /opt/iobroker/node_modules/cli-truncate
                                  npm error extraneous: cli-width@3.0.0 /opt/iobroker/node_modules/cli-width
                                  npm error extraneous: clone-response@1.0.3 /opt/iobroker/node_modules/clone-response
                                  npm error extraneous: cloneextend@0.0.3 /opt/iobroker/node_modules/cloneextend
                                  npm error extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
                                  npm error extraneous: coap-packet@1.1.1 /opt/iobroker/node_modules/coap-packet
                                  npm error extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                                  npm error extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/color-convert
                                  npm error extraneous: color-name@1.1.4 /opt/iobroker/node_modules/color-name
                                  npm error extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
                                  npm error extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
                                  npm error extraneous: color@3.2.1 /opt/iobroker/node_modules/color
                                  npm error extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
                                  npm error extraneous: commander@9.5.0 /opt/iobroker/node_modules/commander
                                  npm error extraneous: commist@3.2.0 /opt/iobroker/node_modules/commist
                                  npm error extraneous: compress-commons@6.0.2 /opt/iobroker/node_modules/compress-commons
                                  npm error extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
                                  npm error extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
                                  npm error extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
                                  npm error extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
                                  npm error extraneous: configstore@5.0.1 /opt/iobroker/node_modules/configstore
                                  npm error extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
                                  npm error extraneous: connect@3.7.0 /opt/iobroker/node_modules/connect
                                  npm error extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
                                  npm error extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/content-disposition
                                  npm error extraneous: content-type@1.0.5 /opt/iobroker/node_modules/content-type
                                  npm error extraneous: core-js@ /opt/iobroker/node_modules/core-js
                                  npm error extraneous: cors@2.8.5 /opt/iobroker/node_modules/cors
                                  npm error extraneous: cosmiconfig@7.1.0 /opt/iobroker/node_modules/cosmiconfig
                                  npm error extraneous: cpu-features@ /opt/iobroker/node_modules/cpu-features
                                  npm error extraneous: crc-32@1.2.2 /opt/iobroker/node_modules/crc-32
                                  npm error extraneous: crc@ /opt/iobroker/node_modules/crc
                                  npm error extraneous: crc32-stream@6.0.0 /opt/iobroker/node_modules/crc32-stream
                                  npm error extraneous: cross-fetch@4.0.0 /opt/iobroker/node_modules/cross-fetch
                                  npm error extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
                                  npm error extraneous: crypto-js@ /opt/iobroker/node_modules/crypto-js
                                  npm error extraneous: crypto-random-string@2.0.0 /opt/iobroker/node_modules/crypto-random-string
                                  npm error extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
                                  npm error extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
                                  npm error extraneous: dashdash@1.14.1 /opt/iobroker/node_modules/dashdash
                                  npm error extraneous: data-urls@4.0.0 /opt/iobroker/node_modules/data-urls
                                  npm error extraneous: data-view-buffer@1.0.1 /opt/iobroker/node_modules/data-view-buffer
                                  npm error extraneous: data-view-byte-length@1.0.1 /opt/iobroker/node_modules/data-view-byte-length
                                  npm error extraneous: data-view-byte-offset@1.0.0 /opt/iobroker/node_modules/data-view-byte-offset
                                  npm error extraneous: date-and-time@ /opt/iobroker/node_modules/date-and-time
                                  npm error extraneous: date-fns@1.30.1 /opt/iobroker/node_modules/date-fns
                                  npm error extraneous: dateformat@4.6.3 /opt/iobroker/node_modules/dateformat
                                  npm error extraneous: dayjs@ /opt/iobroker/node_modules/dayjs
                                  npm error extraneous: decache@4.6.2 /opt/iobroker/node_modules/decache
                                  npm error extraneous: decamelize-keys@1.1.1 /opt/iobroker/node_modules/decamelize-keys
                                  npm error extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
                                  npm error extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
                                  npm error extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
                                  npm error extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
                                  npm error extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is
                                  npm error extraneous: defer-to-connect@2.0.1 /opt/iobroker/node_modules/defer-to-connect
                                  npm error extraneous: define-lazy-prop@2.0.0 /opt/iobroker/node_modules/define-lazy-prop
                                  npm error extraneous: del@6.1.1 /opt/iobroker/node_modules/del
                                  npm error extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
                                  npm error extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
                                  npm error extraneous: destroy@1.2.0 /opt/iobroker/node_modules/destroy
                                  npm error extraneous: detect-libc@2.0.3 /opt/iobroker/node_modules/detect-libc
                                  npm error extraneous: diacritics@1.3.0 /opt/iobroker/node_modules/diacritics
                                  npm error extraneous: digest-header@1.1.0 /opt/iobroker/node_modules/digest-header
                                  npm error extraneous: dir-glob@3.0.1 /opt/iobroker/node_modules/dir-glob
                                  npm error extraneous: diskusage@1.2.0 /opt/iobroker/node_modules/diskusage
                                  npm error extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception
                                  npm error extraneous: dot-prop@6.0.1 /opt/iobroker/node_modules/dot-prop
                                  npm error extraneous: draftlog@1.0.13 /opt/iobroker/node_modules/draftlog
                                  npm error extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
                                  npm error extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
                                  npm error extraneous: duplexer3@0.1.5 /opt/iobroker/node_modules/duplexer3
                                  npm error extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/duplexify
                                  npm error extraneous: eastasianwidth@0.2.0 /opt/iobroker/node_modules/eastasianwidth
                                  npm error extraneous: ecc-jsbn@0.1.2 /opt/iobroker/node_modules/ecc-jsbn
                                  npm error extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
                                  npm error extraneous: echarts@ /opt/iobroker/node_modules/echarts
                                  npm error extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/ee-first
                                  npm error extraneous: elegant-spinner@1.0.1 /opt/iobroker/node_modules/elegant-spinner
                                  npm error extraneous: emoji-regex@9.2.2 /opt/iobroker/node_modules/emoji-regex
                                  npm error extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
                                  npm error extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/encodeurl
                                  npm error extraneous: encoding@0.1.13 /opt/iobroker/node_modules/encoding
                                  npm error extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/end-of-stream
                                  npm error extraneous: entities@4.5.0 /opt/iobroker/node_modules/entities
                                  npm error extraneous: err-code@2.0.3 /opt/iobroker/node_modules/err-code
                                  npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
                                  npm error extraneous: es-aggregate-error@1.0.13 /opt/iobroker/node_modules/es-aggregate-error
                                  npm error extraneous: es-object-atoms@1.0.0 /opt/iobroker/node_modules/es-object-atoms
                                  npm error extraneous: es-set-tostringtag@2.0.3 /opt/iobroker/node_modules/es-set-tostringtag
                                  npm error extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
                                  npm error extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
                                  npm error extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
                                  npm error extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
                                  npm error extraneous: escalade@3.1.2 /opt/iobroker/node_modules/escalade
                                  npm error extraneous: escape-goat@3.0.0 /opt/iobroker/node_modules/escape-goat
                                  npm error extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/escape-html
                                  npm error extraneous: escape-string-regexp@4.0.0 /opt/iobroker/node_modules/escape-string-regexp
                                  npm error extraneous: escodegen@1.14.3 /opt/iobroker/node_modules/escodegen
                                  npm error extraneous: esprima@1.2.2 /opt/iobroker/node_modules/esprima
                                  npm error extraneous: estraverse@4.3.0 /opt/iobroker/node_modules/estraverse
                                  npm error extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils
                                  npm error extraneous: etag@1.8.1 /opt/iobroker/node_modules/etag
                                  npm error extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
                                  npm error extraneous: event-target-shim@5.0.1 /opt/iobroker/node_modules/event-target-shim
                                  npm error extraneous: eventemitter2@6.4.9 /opt/iobroker/node_modules/eventemitter2
                                  npm error extraneous: events@3.3.0 /opt/iobroker/node_modules/events
                                  npm error extraneous: execa@5.1.1 /opt/iobroker/node_modules/execa
                                  npm error extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
                                  npm error extraneous: express-fileupload@1.5.1 /opt/iobroker/node_modules/express-fileupload
                                  npm error extraneous: express@4.19.2 /opt/iobroker/node_modules/express
                                  npm error extraneous: external-editor@3.1.0 /opt/iobroker/node_modules/external-editor
                                  npm error extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
                                  npm error extraneous: fast-fifo@1.3.2 /opt/iobroker/node_modules/fast-fifo
                                  npm error extraneous: fast-glob@ /opt/iobroker/node_modules/fast-glob
                                  npm error extraneous: fast-json-stable-stringify@2.1.0 /opt/iobroker/node_modules/fast-json-stable-stringify
                                  npm error extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein
                                  npm error extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
                                  npm error extraneous: fast-unique-numbers@ /opt/iobroker/node_modules/fast-unique-numbers
                                  npm error extraneous: fast-uri@3.0.1 /opt/iobroker/node_modules/fast-uri
                                  npm error extraneous: fast-xml-parser@ /opt/iobroker/node_modules/fast-xml-parser
                                  npm error extraneous: fastq@1.17.1 /opt/iobroker/node_modules/fastq
                                  npm error extraneous: fastseries@2.0.0 /opt/iobroker/node_modules/fastseries
                                  npm error extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
                                  npm error extraneous: figures@3.2.0 /opt/iobroker/node_modules/figures
                                  npm error extraneous: file-stream-rotator@0.6.1 /opt/iobroker/node_modules/file-stream-rotator
                                  npm error extraneous: file-type@10.11.0 /opt/iobroker/node_modules/file-type
                                  npm error extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
                                  npm error extraneous: fill-range@7.1.1 /opt/iobroker/node_modules/fill-range
                                  npm error extraneous: finalhandler@1.2.0 /opt/iobroker/node_modules/finalhandler
                                  npm error extraneous: find-up@5.0.0 /opt/iobroker/node_modules/find-up
                                  npm error extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
                                  npm error extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
                                  npm error extraneous: foreground-child@3.3.0 /opt/iobroker/node_modules/foreground-child
                                  npm error extraneous: form-data-encoder@2.1.4 /opt/iobroker/node_modules/form-data-encoder
                                  npm error extraneous: form-data@4.0.0 /opt/iobroker/node_modules/form-data
                                  npm error extraneous: forwarded@0.2.0 /opt/iobroker/node_modules/forwarded
                                  npm error extraneous: fresh@0.5.2 /opt/iobroker/node_modules/fresh
                                  npm error extraneous: from@0.1.7 /opt/iobroker/node_modules/from
                                  npm error extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
                                  npm error extraneous: fs-minipass@2.1.0 /opt/iobroker/node_modules/fs-minipass
                                  npm error extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
                                  npm error extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
                                  npm error extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
                                  npm error extraneous: function.prototype.name@1.1.6 /opt/iobroker/node_modules/function.prototype.name
                                  npm error extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
                                  npm error extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
                                  npm error extraneous: gauge@3.0.2 /opt/iobroker/node_modules/gauge
                                  npm error extraneous: gaxios@5.1.3 /opt/iobroker/node_modules/gaxios
                                  npm error extraneous: gcp-metadata@5.3.0 /opt/iobroker/node_modules/gcp-metadata
                                  npm error extraneous: generate-function@2.3.1 /opt/iobroker/node_modules/generate-function
                                  npm error extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ssl-certificate
                                  npm error extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/get-stream
                                  npm error extraneous: get-symbol-description@1.0.2 /opt/iobroker/node_modules/get-symbol-description
                                  npm error extraneous: getpass@0.1.7 /opt/iobroker/node_modules/getpass
                                  npm error extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
                                  npm error extraneous: github-url-from-git@1.5.0 /opt/iobroker/node_modules/github-url-from-git
                                  npm error extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/glob-parent
                                  npm error extraneous: glob@10.4.5 /opt/iobroker/node_modules/glob
                                  npm error extraneous: global-dirs@2.1.0 /opt/iobroker/node_modules/global-dirs
                                  npm error extraneous: globalthis@1.0.4 /opt/iobroker/node_modules/globalthis
                                  npm error extraneous: globby@11.1.0 /opt/iobroker/node_modules/globby
                                  npm error extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
                                  npm error extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
                                  npm error extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
                                  npm error extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
                                  npm error extraneous: googleapis@ /opt/iobroker/node_modules/googleapis
                                  npm error extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
                                  npm error extraneous: hard-rejection@2.1.0 /opt/iobroker/node_modules/hard-rejection
                                  npm error extraneous: has-ansi@2.0.0 /opt/iobroker/node_modules/has-ansi
                                  npm error extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
                                  npm error extraneous: has-flag@4.0.0 /opt/iobroker/node_modules/has-flag
                                  npm error extraneous: has-tostringtag@1.0.2 /opt/iobroker/node_modules/has-tostringtag
                                  npm error extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
                                  npm error extraneous: has-yarn@2.1.0 /opt/iobroker/node_modules/has-yarn
                                  npm error extraneous: he@1.2.0 /opt/iobroker/node_modules/he
                                  npm error extraneous: help-me@5.0.0 /opt/iobroker/node_modules/help-me
                                  npm error extraneous: homebridge-plugin-wrapper@ /opt/iobroker/node_modules/homebridge-plugin-wrapper
                                  npm error extraneous: hosted-git-info@3.0.8 /opt/iobroker/node_modules/hosted-git-info
                                  npm error extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
                                  npm error extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
                                  npm error extraneous: http-cache-semantics@4.1.1 /opt/iobroker/node_modules/http-cache-semantics
                                  npm error extraneous: http-errors@2.0.0 /opt/iobroker/node_modules/http-errors
                                  npm error extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
                                  npm error extraneous: http2-wrapper@1.0.3 /opt/iobroker/node_modules/http2-wrapper
                                  npm error extraneous: https@1.0.0 /opt/iobroker/node_modules/https
                                  npm error extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
                                  npm error extraneous: ical.js@ /opt/iobroker/node_modules/ical.js
                                  npm error extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/iconv-lite
                                  npm error extraneous: ieee754@1.2.1 /opt/iobroker/node_modules/ieee754
                                  npm error extraneous: ignore-walk@3.0.4 /opt/iobroker/node_modules/ignore-walk
                                  npm error extraneous: ignore@5.3.2 /opt/iobroker/node_modules/ignore
                                  npm error extraneous: image-type@4.1.0 /opt/iobroker/node_modules/image-type
                                  npm error extraneous: immediate@3.0.6 /opt/iobroker/node_modules/immediate
                                  npm error extraneous: import-fresh@3.3.0 /opt/iobroker/node_modules/import-fresh
                                  npm error extraneous: import-lazy@2.1.0 /opt/iobroker/node_modules/import-lazy
                                  npm error extraneous: import-local@3.2.0 /opt/iobroker/node_modules/import-local
                                  npm error extraneous: imurmurhash@0.1.4 /opt/iobroker/node_modules/imurmurhash
                                  npm error extraneous: indent-string@3.2.0 /opt/iobroker/node_modules/indent-string
                                  npm error extraneous: infer-owner@1.0.4 /opt/iobroker/node_modules/infer-owner
                                  npm error extraneous: inflight@1.0.6 /opt/iobroker/node_modules/inflight
                                  npm error extraneous: ini@1.3.7 /opt/iobroker/node_modules/ini
                                  npm error extraneous: inquirer-autosubmit-prompt@0.2.0 /opt/iobroker/node_modules/inquirer-autosubmit-prompt
                                  npm error extraneous: inquirer@7.3.3 /opt/iobroker/node_modules/inquirer
                                  npm error extraneous: int64-buffer@1.0.1 /opt/iobroker/node_modules/int64-buffer
                                  npm error extraneous: internal-slot@1.0.7 /opt/iobroker/node_modules/internal-slot
                                  npm error extraneous: iobroker-adapter-helpers@0.0.8 /opt/iobroker/node_modules/iobroker-adapter-helpers
                                  npm error invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
                                  npm error invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
                                  npm error invalid: iobroker.calendar@ /opt/iobroker/node_modules/iobroker.calendar
                                  npm error invalid: iobroker.discovery@ /opt/iobroker/node_modules/iobroker.discovery
                                  npm error invalid: iobroker.echarts@ /opt/iobroker/node_modules/iobroker.echarts
                                  npm error invalid: iobroker.energiefluss@ /opt/iobroker/node_modules/iobroker.energiefluss
                                  npm error invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
                                  npm error invalid: iobroker.fullcalendar@ /opt/iobroker/node_modules/iobroker.fullcalendar
                                  npm error invalid: iobroker.gartenbewaesserung@ /opt/iobroker/node_modules/iobroker.gartenbewaesserung
                                  npm error invalid: iobroker.ham@ /opt/iobroker/node_modules/iobroker.ham
                                  npm error invalid: iobroker.heatingcontrol@ /opt/iobroker/node_modules/iobroker.heatingcontrol
                                  npm error invalid: iobroker.ical@ /opt/iobroker/node_modules/iobroker.ical
                                  npm error invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
                                  npm error invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
                                  npm error invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
                                  npm error invalid: iobroker.material@ /opt/iobroker/node_modules/iobroker.material
                                  npm error invalid: iobroker.milight-smart-light@ /opt/iobroker/node_modules/iobroker.milight-smart-light
                                  npm error invalid: iobroker.mobile@ /opt/iobroker/node_modules/iobroker.mobile
                                  npm error invalid: iobroker.modbus@ /opt/iobroker/node_modules/iobroker.modbus
                                  npm error invalid: iobroker.mqtt@ /opt/iobroker/node_modules/iobroker.mqtt
                                  npm error invalid: iobroker.nina@ /opt/iobroker/node_modules/iobroker.nina
                                  npm error invalid: iobroker.renault@ /opt/iobroker/node_modules/iobroker.renault
                                  npm error invalid: iobroker.reolink@ /opt/iobroker/node_modules/iobroker.reolink
                                  npm error invalid: iobroker.schoolfree@ /opt/iobroker/node_modules/iobroker.schoolfree
                                  npm error invalid: iobroker.sourceanalytix@ /opt/iobroker/node_modules/iobroker.sourceanalytix
                                  npm error invalid: iobroker.synology@ /opt/iobroker/node_modules/iobroker.synology
                                  npm error invalid: iobroker.tankerkoenig@ /opt/iobroker/node_modules/iobroker.tankerkoenig
                                  npm error invalid: iobroker.terminal@ /opt/iobroker/node_modules/iobroker.terminal
                                  npm error invalid: iobroker.unifi@ /opt/iobroker/node_modules/iobroker.unifi
                                  npm error invalid: iobroker.viessmannapi@ /opt/iobroker/node_modules/iobroker.viessmannapi
                                  npm error invalid: iobroker.virtualpowermeter@ /opt/iobroker/node_modules/iobroker.virtualpowermeter
                                  npm error invalid: iobroker.vis-2-widgets-material@ /opt/iobroker/node_modules/iobroker.vis-2-widgets-material
                                  npm error invalid: iobroker.vis-2@ /opt/iobroker/node_modules/iobroker.vis-2
                                  npm error invalid: iobroker.vis-colorpicker@ /opt/iobroker/node_modules/iobroker.vis-colorpicker
                                  npm error invalid: iobroker.vis-hqwidgets@ /opt/iobroker/node_modules/iobroker.vis-hqwidgets
                                  npm error invalid: iobroker.vis-inventwo@ /opt/iobroker/node_modules/iobroker.vis-inventwo
                                  npm error invalid: iobroker.vis-materialdesign@ /opt/iobroker/node_modules/iobroker.vis-materialdesign
                                  npm error invalid: iobroker.vis-metro@ /opt/iobroker/node_modules/iobroker.vis-metro
                                  npm error invalid: iobroker.vis-timeandweather@ /opt/iobroker/node_modules/iobroker.vis-timeandweather
                                  npm error invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
                                  npm error invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
                                  npm error invalid: iobroker.vofo-speedtest@ /opt/iobroker/node_modules/iobroker.vofo-speedtest
                                  npm error invalid: iobroker.web-speedy@ /opt/iobroker/node_modules/iobroker.web-speedy
                                  npm error invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
                                  npm error invalid: iobroker.webcal@ /opt/iobroker/node_modules/iobroker.webcal
                                  npm error extraneous: ioredis@ /opt/iobroker/node_modules/ioredis
                                  npm error extraneous: ip-address@9.0.5 /opt/iobroker/node_modules/ip-address
                                  npm error extraneous: ip-regex@4.3.0 /opt/iobroker/node_modules/ip-regex
                                  npm error extraneous: ipaddr.js@2.2.0 /opt/iobroker/node_modules/ipaddr.js
                                  npm error extraneous: is-array-buffer@3.0.4 /opt/iobroker/node_modules/is-array-buffer
                                  npm error extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
                                  npm error extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
                                  npm error extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
                                  npm error extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
                                  npm error extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
                                  npm error extraneous: is-ci@2.0.0 /opt/iobroker/node_modules/is-ci
                                  npm error extraneous: is-core-module@2.15.0 /opt/iobroker/node_modules/is-core-module
                                  npm error extraneous: is-data-view@1.0.1 /opt/iobroker/node_modules/is-data-view
                                  npm error extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
                                  npm error extraneous: is-docker@2.2.1 /opt/iobroker/node_modules/is-docker
                                  npm error extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
                                  npm error extraneous: is-extglob@2.1.1 /opt/iobroker/node_modules/is-extglob
                                  npm error extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/is-fullwidth-code-point
                                  npm error extraneous: is-glob@4.0.3 /opt/iobroker/node_modules/is-glob
                                  npm error extraneous: is-installed-globally@0.3.2 /opt/iobroker/node_modules/is-installed-globally
                                  npm error extraneous: is-interactive@1.0.0 /opt/iobroker/node_modules/is-interactive
                                  npm error extraneous: is-lambda@1.0.1 /opt/iobroker/node_modules/is-lambda
                                  npm error extraneous: is-negative-zero@2.0.3 /opt/iobroker/node_modules/is-negative-zero
                                  npm error extraneous: is-npm@5.0.0 /opt/iobroker/node_modules/is-npm
                                  npm error extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
                                  npm error extraneous: is-number@7.0.0 /opt/iobroker/node_modules/is-number
                                  npm error extraneous: is-obj@2.0.0 /opt/iobroker/node_modules/is-obj
                                  npm error extraneous: is-observable@1.1.0 /opt/iobroker/node_modules/is-observable
                                  npm error extraneous: is-path-cwd@2.2.0 /opt/iobroker/node_modules/is-path-cwd
                                  npm error extraneous: is-path-inside@3.0.3 /opt/iobroker/node_modules/is-path-inside
                                  npm error extraneous: is-plain-obj@1.1.0 /opt/iobroker/node_modules/is-plain-obj
                                  npm error extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
                                  npm error extraneous: is-promise@2.2.2 /opt/iobroker/node_modules/is-promise
                                  npm error extraneous: is-property@1.0.2 /opt/iobroker/node_modules/is-property
                                  npm error extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
                                  npm error extraneous: is-scoped@2.1.0 /opt/iobroker/node_modules/is-scoped
                                  npm error extraneous: is-shared-array-buffer@1.0.3 /opt/iobroker/node_modules/is-shared-array-buffer
                                  npm error extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
                                  npm error extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
                                  npm error extraneous: is-typed-array@1.1.13 /opt/iobroker/node_modules/is-typed-array
                                  npm error extraneous: is-unicode-supported@0.1.0 /opt/iobroker/node_modules/is-unicode-supported
                                  npm error extraneous: is-url-superb@4.0.0 /opt/iobroker/node_modules/is-url-superb
                                  npm error extraneous: is-url@1.2.4 /opt/iobroker/node_modules/is-url
                                  npm error extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
                                  npm error extraneous: is-wsl@2.2.0 /opt/iobroker/node_modules/is-wsl
                                  npm error extraneous: is-yarn-global@0.3.0 /opt/iobroker/node_modules/is-yarn-global
                                  npm error extraneous: is@3.3.0 /opt/iobroker/node_modules/is
                                  npm error extraneous: is2@2.0.9 /opt/iobroker/node_modules/is2
                                  npm error extraneous: isomorphic-ws@4.0.1 /opt/iobroker/node_modules/isomorphic-ws
                                  npm error extraneous: issue-regex@3.1.0 /opt/iobroker/node_modules/issue-regex
                                  npm error extraneous: jackspeak@3.4.3 /opt/iobroker/node_modules/jackspeak
                                  npm error extraneous: js-md4@0.3.2 /opt/iobroker/node_modules/js-md4
                                  npm error extraneous: js-sdsl@4.3.0 /opt/iobroker/node_modules/js-sdsl
                                  npm error extraneous: js-tokens@4.0.0 /opt/iobroker/node_modules/js-tokens
                                  npm error extraneous: js-yaml@ /opt/iobroker/node_modules/js-yaml
                                  npm error extraneous: jsbi@4.3.0 /opt/iobroker/node_modules/jsbi
                                  npm error extraneous: jsbn@1.1.0 /opt/iobroker/node_modules/jsbn
                                  npm error extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
                                  npm error extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
                                  npm error extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/json-buffer
                                  npm error extraneous: json-logic-js@2.0.5 /opt/iobroker/node_modules/json-logic-js
                                  npm error extraneous: json-parse-even-better-errors@2.3.1 /opt/iobroker/node_modules/json-parse-even-better-errors
                                  npm error extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse
                                  npm error extraneous: json5@2.2.3 /opt/iobroker/node_modules/json5
                                  npm error extraneous: jsonata@ /opt/iobroker/node_modules/jsonata
                                  npm error extraneous: jsonc-parser@3.3.1 /opt/iobroker/node_modules/jsonc-parser
                                  npm error extraneous: jsonwebtoken@9.0.2 /opt/iobroker/node_modules/jsonwebtoken
                                  npm error extraneous: jszip@ /opt/iobroker/node_modules/jszip
                                  npm error extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
                                  npm error extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
                                  npm error extraneous: keyv@4.5.4 /opt/iobroker/node_modules/keyv
                                  npm error extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/kind-of
                                  npm error extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
                                  npm error extraneous: later@1.2.0 /opt/iobroker/node_modules/later
                                  npm error extraneous: latest-version@5.1.0 /opt/iobroker/node_modules/latest-version
                                  npm error extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
                                  npm error extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/lazystream
                                  npm error extraneous: leven@2.1.0 /opt/iobroker/node_modules/leven
                                  npm error extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn
                                  npm error extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
                                  npm error extraneous: lines-and-columns@1.2.4 /opt/iobroker/node_modules/lines-and-columns
                                  npm error extraneous: listr-input@0.2.1 /opt/iobroker/node_modules/listr-input
                                  npm error extraneous: listr-silent-renderer@1.1.1 /opt/iobroker/node_modules/listr-silent-renderer
                                  npm error extraneous: listr-update-renderer@0.5.0 /opt/iobroker/node_modules/listr-update-renderer
                                  npm error extraneous: listr-verbose-renderer@0.5.0 /opt/iobroker/node_modules/listr-verbose-renderer
                                  npm error extraneous: listr@0.14.3 /opt/iobroker/node_modules/listr
                                  npm error extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
                                  npm error extraneous: locate-path@6.0.0 /opt/iobroker/node_modules/locate-path
                                  npm error extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
                                  npm error extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
                                  npm error extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
                                  npm error extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
                                  npm error extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
                                  npm error extraneous: lodash.isequal@4.5.0 /opt/iobroker/node_modules/lodash.isequal
                                  npm error extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
                                  npm error extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
                                  npm error extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
                                  npm error extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
                                  npm error extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
                                  npm error extraneous: lodash.zip@4.2.0 /opt/iobroker/node_modules/lodash.zip
                                  npm error extraneous: log-symbols@4.1.0 /opt/iobroker/node_modules/log-symbols
                                  npm error extraneous: log-update@2.3.0 /opt/iobroker/node_modules/log-update
                                  npm error extraneous: logform@ /opt/iobroker/node_modules/logform
                                  npm error extraneous: long@5.2.3 /opt/iobroker/node_modules/long
                                  npm error extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/lowercase-keys
                                  npm error extraneous: lru_map@0.3.3 /opt/iobroker/node_modules/lru_map
                                  npm error extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/lru-cache
                                  npm error extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
                                  npm error extraneous: make-fetch-happen@10.2.1 /opt/iobroker/node_modules/make-fetch-happen
                                  npm error extraneous: map-age-cleaner@0.1.3 /opt/iobroker/node_modules/map-age-cleaner
                                  npm error extraneous: map-obj@4.3.0 /opt/iobroker/node_modules/map-obj
                                  npm error extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
                                  npm error extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
                                  npm error extraneous: media-typer@0.3.0 /opt/iobroker/node_modules/media-typer
                                  npm error extraneous: meow@8.1.2 /opt/iobroker/node_modules/meow
                                  npm error extraneous: merge-descriptors@1.0.1 /opt/iobroker/node_modules/merge-descriptors
                                  npm error extraneous: merge2@1.4.1 /opt/iobroker/node_modules/merge2
                                  npm error extraneous: methods@1.1.2 /opt/iobroker/node_modules/methods
                                  npm error extraneous: micro@9.4.1 /opt/iobroker/node_modules/micro
                                  npm error extraneous: micromatch@4.0.7 /opt/iobroker/node_modules/micromatch
                                  npm error extraneous: mime-db@1.53.0 /opt/iobroker/node_modules/mime-db
                                  npm error extraneous: mimic-response@1.0.1 /opt/iobroker/node_modules/mimic-response
                                  npm error extraneous: min-indent@1.0.1 /opt/iobroker/node_modules/min-indent
                                  npm error extraneous: minimatch@9.0.5 /opt/iobroker/node_modules/minimatch
                                  npm error extraneous: minimist-options@4.1.0 /opt/iobroker/node_modules/minimist-options
                                  npm error extraneous: minipass-collect@1.0.2 /opt/iobroker/node_modules/minipass-collect
                                  npm error extraneous: minipass-fetch@2.1.2 /opt/iobroker/node_modules/minipass-fetch
                                  npm error extraneous: minipass-flush@1.0.5 /opt/iobroker/node_modules/minipass-flush
                                  npm error extraneous: minipass-pipeline@1.2.4 /opt/iobroker/node_modules/minipass-pipeline
                                  npm error extraneous: minipass-sized@1.0.3 /opt/iobroker/node_modules/minipass-sized
                                  npm error extraneous: minipass@7.1.2 /opt/iobroker/node_modules/minipass
                                  npm error extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/minizlib
                                  npm error extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
                                  npm error extraneous: mkdirp@1.0.4 /opt/iobroker/node_modules/mkdirp
                                  npm error extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
                                  npm error extraneous: moment-duration-format@2.3.2 /opt/iobroker/node_modules/moment-duration-format
                                  npm error extraneous: mqtt-connection@4.1.0 /opt/iobroker/node_modules/mqtt-connection
                                  npm error extraneous: mqtt-packet@9.0.0 /opt/iobroker/node_modules/mqtt-packet
                                  npm error extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
                                  npm error extraneous: mute-stream@0.0.8 /opt/iobroker/node_modules/mute-stream
                                  npm error extraneous: named-placeholders@1.1.3 /opt/iobroker/node_modules/named-placeholders
                                  npm error extraneous: nan@ /opt/iobroker/node_modules/nan
                                  npm error extraneous: nanoid@3.3.7 /opt/iobroker/node_modules/nanoid
                                  npm error extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
                                  npm error extraneous: native-duplexpair@1.0.0 /opt/iobroker/node_modules/native-duplexpair
                                  npm error extraneous: nconf@0.10.0 /opt/iobroker/node_modules/nconf
                                  npm error extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
                                  npm error extraneous: netmask@2.0.2 /opt/iobroker/node_modules/netmask
                                  npm error extraneous: new-github-release-url@1.0.0 /opt/iobroker/node_modules/new-github-release-url
                                  npm error extraneous: node-abi@3.65.0 /opt/iobroker/node_modules/node-abi
                                  npm error extraneous: node-abort-controller@3.1.1 /opt/iobroker/node_modules/node-abort-controller
                                  npm error extraneous: node-cron@2.0.3 /opt/iobroker/node_modules/node-cron
                                  npm error extraneous: node-fetch@2.7.0 /opt/iobroker/node_modules/node-fetch
                                  npm error extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
                                  npm error extraneous: node-gyp@ /opt/iobroker/node_modules/node-gyp
                                  npm error extraneous: node-ical@0.16.1 /opt/iobroker/node_modules/node-ical
                                  npm error extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                                  npm error extraneous: node-libcurl@3.0.0 /opt/iobroker/node_modules/node-libcurl
                                  npm error extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
                                  npm error extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
                                  npm error extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
                                  npm error extraneous: node-unifi@2.5.1 /opt/iobroker/node_modules/node-unifi
                                  npm error extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
                                  npm error extraneous: node.extend@2.0.3 /opt/iobroker/node_modules/node.extend
                                  npm error extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
                                  npm error extraneous: normalize-package-data@3.0.3 /opt/iobroker/node_modules/normalize-package-data
                                  npm error extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
                                  npm error extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/normalize-url
                                  npm error extraneous: np@7.7.0 /opt/iobroker/node_modules/np
                                  npm error extraneous: npm-name@6.0.1 /opt/iobroker/node_modules/npm-name
                                  npm error extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
                                  npm error extraneous: number-allocator@1.0.14 /opt/iobroker/node_modules/number-allocator
                                  npm error extraneous: nwsapi@2.2.12 /opt/iobroker/node_modules/nwsapi
                                  npm error extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assign
                                  npm error extraneous: object-hash@3.0.0 /opt/iobroker/node_modules/object-hash
                                  npm error extraneous: on-finished@2.4.1 /opt/iobroker/node_modules/on-finished
                                  npm error extraneous: once@1.4.0 /opt/iobroker/node_modules/once
                                  npm error extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
                                  npm error extraneous: onedrive-api@1.1.1 /opt/iobroker/node_modules/onedrive-api
                                  npm error extraneous: open@7.4.2 /opt/iobroker/node_modules/open
                                  npm error extraneous: opencollective-postinstall@2.0.3 /opt/iobroker/node_modules/opencollective-postinstall
                                  npm error extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator
                                  npm error extraneous: org-regex@1.0.0 /opt/iobroker/node_modules/org-regex
                                  npm error extraneous: os-tmpdir@1.0.2 /opt/iobroker/node_modules/os-tmpdir
                                  npm error extraneous: ospath@1.2.2 /opt/iobroker/node_modules/ospath
                                  npm error extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
                                  npm error extraneous: otplib@11.0.1 /opt/iobroker/node_modules/otplib
                                  npm error extraneous: ow@0.21.0 /opt/iobroker/node_modules/ow
                                  npm error extraneous: p-cancelable@2.1.1 /opt/iobroker/node_modules/p-cancelable
                                  npm error extraneous: p-defer@1.0.0 /opt/iobroker/node_modules/p-defer
                                  npm error extraneous: p-event@4.2.0 /opt/iobroker/node_modules/p-event
                                  npm error extraneous: p-finally@1.0.0 /opt/iobroker/node_modules/p-finally
                                  npm error extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/p-limit
                                  npm error extraneous: p-locate@5.0.0 /opt/iobroker/node_modules/p-locate
                                  npm error extraneous: p-map@2.1.0 /opt/iobroker/node_modules/p-map
                                  npm error extraneous: p-memoize@4.0.4 /opt/iobroker/node_modules/p-memoize
                                  npm error extraneous: p-reflect@2.1.0 /opt/iobroker/node_modules/p-reflect
                                  npm error extraneous: p-settle@4.1.1 /opt/iobroker/node_modules/p-settle
                                  npm error extraneous: p-throttle@4.1.1 /opt/iobroker/node_modules/p-throttle
                                  npm error extraneous: p-timeout@4.1.0 /opt/iobroker/node_modules/p-timeout
                                  npm error extraneous: p-try@2.2.0 /opt/iobroker/node_modules/p-try
                                  npm error extraneous: package-json-from-dist@1.0.0 /opt/iobroker/node_modules/package-json-from-dist
                                  npm error extraneous: package-json@6.5.0 /opt/iobroker/node_modules/package-json
                                  npm error extraneous: pako@ /opt/iobroker/node_modules/pako
                                  npm error extraneous: parent-module@1.0.1 /opt/iobroker/node_modules/parent-module
                                  npm error extraneous: parse-json@5.2.0 /opt/iobroker/node_modules/parse-json
                                  npm error extraneous: parse5@ /opt/iobroker/node_modules/parse5
                                  npm error extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
                                  npm error extraneous: passport@0.7.0 /opt/iobroker/node_modules/passport
                                  npm error extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/path-exists
                                  npm error extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
                                  npm error extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
                                  npm error extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
                                  npm error extraneous: path-scurry@1.11.1 /opt/iobroker/node_modules/path-scurry
                                  npm error extraneous: path-to-regexp@0.1.7 /opt/iobroker/node_modules/path-to-regexp
                                  npm error extraneous: path-type@4.0.0 /opt/iobroker/node_modules/path-type
                                  npm error extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
                                  npm error extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/picomatch
                                  npm error extraneous: pidtree@0.6.0 /opt/iobroker/node_modules/pidtree
                                  npm error extraneous: pidusage@3.0.2 /opt/iobroker/node_modules/pidusage
                                  npm error extraneous: ping@0.4.4 /opt/iobroker/node_modules/ping
                                  npm error extraneous: pkg-dir@5.0.0 /opt/iobroker/node_modules/pkg-dir
                                  npm error extraneous: pluralize@8.0.0 /opt/iobroker/node_modules/pluralize
                                  npm error extraneous: possible-typed-array-names@1.0.0 /opt/iobroker/node_modules/possible-typed-array-names
                                  npm error extraneous: prebuild-install@7.1.2 /opt/iobroker/node_modules/prebuild-install
                                  npm error extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls
                                  npm error extraneous: prepend-http@2.0.0 /opt/iobroker/node_modules/prepend-http
                                  npm error extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/process-nextick-args
                                  npm error extraneous: process@0.11.10 /opt/iobroker/node_modules/process
                                  npm error extraneous: promise-inflight@1.0.1 /opt/iobroker/node_modules/promise-inflight
                                  npm error extraneous: promise-object@0.1.7 /opt/iobroker/node_modules/promise-object
                                  npm error extraneous: promise-retry@2.0.1 /opt/iobroker/node_modules/promise-retry
                                  npm error extraneous: promise-retryer@0.0.1 /opt/iobroker/node_modules/promise-retryer
                                  npm error extraneous: promisify-child-process@4.1.2 /opt/iobroker/node_modules/promisify-child-process
                                  npm error extraneous: prompt@1.3.0 /opt/iobroker/node_modules/prompt
                                  npm error extraneous: protobufjs@ /opt/iobroker/node_modules/protobufjs
                                  npm error extraneous: proxy-addr@2.0.7 /opt/iobroker/node_modules/proxy-addr
                                  npm error extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
                                  npm error extraneous: pump@3.0.0 /opt/iobroker/node_modules/pump
                                  npm error extraneous: pupa@2.1.1 /opt/iobroker/node_modules/pupa
                                  npm error extraneous: q@1.1.2 /opt/iobroker/node_modules/q
                                  npm error extraneous: quasar@ /opt/iobroker/node_modules/quasar
                                  npm error extraneous: queue-microtask@1.2.3 /opt/iobroker/node_modules/queue-microtask
                                  npm error extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
                                  npm error extraneous: quick-lru@5.1.1 /opt/iobroker/node_modules/quick-lru
                                  npm error extraneous: range-parser@1.2.1 /opt/iobroker/node_modules/range-parser
                                  npm error extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/raw-body
                                  npm error extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
                                  npm error extraneous: read-pkg-up@7.0.1 /opt/iobroker/node_modules/read-pkg-up
                                  npm error extraneous: read-pkg@5.2.0 /opt/iobroker/node_modules/read-pkg
                                  npm error extraneous: read@1.0.7 /opt/iobroker/node_modules/read
                                  npm error extraneous: readable-stream@ /opt/iobroker/node_modules/readable-stream
                                  npm error extraneous: readdir-glob@1.1.3 /opt/iobroker/node_modules/readdir-glob
                                  npm error extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
                                  npm error extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
                                  npm error extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
                                  npm error extraneous: redent@3.0.0 /opt/iobroker/node_modules/redent
                                  npm error extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
                                  npm error extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
                                  npm error extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
                                  npm error extraneous: regenerator-runtime@0.14.1 /opt/iobroker/node_modules/regenerator-runtime
                                  npm error extraneous: regex-escape@3.4.10 /opt/iobroker/node_modules/regex-escape
                                  npm error extraneous: regexp.prototype.flags@1.5.2 /opt/iobroker/node_modules/regexp.prototype.flags
                                  npm error extraneous: registry-auth-token@4.2.2 /opt/iobroker/node_modules/registry-auth-token
                                  npm error extraneous: registry-url@5.1.0 /opt/iobroker/node_modules/registry-url
                                  npm error extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
                                  npm error extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
                                  npm error extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string
                                  npm error extraneous: resolve-alpn@1.2.1 /opt/iobroker/node_modules/resolve-alpn
                                  npm error extraneous: resolve-cwd@3.0.0 /opt/iobroker/node_modules/resolve-cwd
                                  npm error extraneous: resolve-from@4.0.0 /opt/iobroker/node_modules/resolve-from
                                  npm error extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
                                  npm error extraneous: responselike@2.0.1 /opt/iobroker/node_modules/responselike
                                  npm error extraneous: restore-cursor@3.1.0 /opt/iobroker/node_modules/restore-cursor
                                  npm error extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
                                  npm error extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
                                  npm error extraneous: reusify@1.0.4 /opt/iobroker/node_modules/reusify
                                  npm error extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
                                  npm error extraneous: rfdc@1.4.1 /opt/iobroker/node_modules/rfdc
                                  npm error extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/rimraf
                                  npm error extraneous: rrule@2.8.1 /opt/iobroker/node_modules/rrule
                                  npm error extraneous: rrweb-cssom@0.6.0 /opt/iobroker/node_modules/rrweb-cssom
                                  npm error extraneous: run-async@2.4.1 /opt/iobroker/node_modules/run-async
                                  npm error extraneous: run-parallel@1.2.0 /opt/iobroker/node_modules/run-parallel
                                  npm error extraneous: rxjs@ /opt/iobroker/node_modules/rxjs
                                  npm error extraneous: safe-array-concat@1.1.2 /opt/iobroker/node_modules/safe-array-concat
                                  npm error extraneous: safe-regex-test@1.0.3 /opt/iobroker/node_modules/safe-regex-test
                                  npm error extraneous: safe-stable-stringify@2.4.3 /opt/iobroker/node_modules/safe-stable-stringify
                                  npm error extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/safer-buffer
                                  npm error extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
                                  npm error extraneous: scoped-regex@2.1.0 /opt/iobroker/node_modules/scoped-regex
                                  npm error extraneous: secure-keys@1.0.0 /opt/iobroker/node_modules/secure-keys
                                  npm error extraneous: semver-diff@3.1.1 /opt/iobroker/node_modules/semver-diff
                                  npm error extraneous: send@0.18.0 /opt/iobroker/node_modules/send
                                  npm error extraneous: seq-logging@1.1.2 /opt/iobroker/node_modules/seq-logging
                                  npm error extraneous: seq-queue@0.0.5 /opt/iobroker/node_modules/seq-queue
                                  npm error extraneous: serve-static@1.15.0 /opt/iobroker/node_modules/serve-static
                                  npm error extraneous: set-function-name@2.0.2 /opt/iobroker/node_modules/set-function-name
                                  npm error extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
                                  npm error extraneous: setprototypeof@1.2.0 /opt/iobroker/node_modules/setprototypeof
                                  npm error extraneous: signal-exit@4.1.0 /opt/iobroker/node_modules/signal-exit
                                  npm error extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
                                  npm error extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
                                  npm error extraneous: simple-ssh@1.1.1 /opt/iobroker/node_modules/simple-ssh
                                  npm error extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
                                  npm error extraneous: slash@3.0.0 /opt/iobroker/node_modules/slash
                                  npm error extraneous: slice-ansi@0.0.4 /opt/iobroker/node_modules/slice-ansi
                                  npm error extraneous: smart-buffer@4.2.0 /opt/iobroker/node_modules/smart-buffer
                                  npm error extraneous: socks-proxy-agent@7.0.0 /opt/iobroker/node_modules/socks-proxy-agent
                                  npm error extraneous: socks@2.8.3 /opt/iobroker/node_modules/socks
                                  npm error extraneous: speedtest-net@1.6.2 /opt/iobroker/node_modules/speedtest-net
                                  npm error extraneous: split@1.0.1 /opt/iobroker/node_modules/split
                                  npm error extraneous: sprintf-js@1.1.3 /opt/iobroker/node_modules/sprintf-js
                                  npm error extraneous: sqlstring@2.3.3 /opt/iobroker/node_modules/sqlstring
                                  npm error extraneous: ssh2@ /opt/iobroker/node_modules/ssh2
                                  npm error extraneous: ssri@9.0.1 /opt/iobroker/node_modules/ssri
                                  npm error extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
                                  npm error extraneous: stampit-event-bus@0.1.1 /opt/iobroker/node_modules/stampit-event-bus
                                  npm error extraneous: stampit-state-machine@0.2.1 /opt/iobroker/node_modules/stampit-state-machine
                                  npm error extraneous: stampit@2.1.2 /opt/iobroker/node_modules/stampit
                                  npm error extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
                                  npm error extraneous: static-eval@2.0.2 /opt/iobroker/node_modules/static-eval
                                  npm error extraneous: statuses@2.0.1 /opt/iobroker/node_modules/statuses
                                  npm error extraneous: stoppable@1.1.0 /opt/iobroker/node_modules/stoppable
                                  npm error extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
                                  npm error extraneous: stream-shift@1.0.3 /opt/iobroker/node_modules/stream-shift
                                  npm error extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
                                  npm error extraneous: streamx@2.18.0 /opt/iobroker/node_modules/streamx
                                  npm error extraneous: string-argv@0.3.2 /opt/iobroker/node_modules/string-argv
                                  npm error extraneous: string-width-cjs@npm:string-width@4.2.3 /opt/iobroker/node_modules/string-width-cjs
                                  npm error extraneous: string-width@5.1.2 /opt/iobroker/node_modules/string-width
                                  npm error extraneous: string.prototype.trim@1.2.9 /opt/iobroker/node_modules/string.prototype.trim
                                  npm error extraneous: string.prototype.trimend@1.0.8 /opt/iobroker/node_modules/string.prototype.trimend
                                  npm error extraneous: string.prototype.trimstart@1.0.8 /opt/iobroker/node_modules/string.prototype.trimstart
                                  npm error extraneous: strip-ansi-cjs@npm:strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi-cjs
                                  npm error extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi
                                  npm error extraneous: strip-indent@3.0.0 /opt/iobroker/node_modules/strip-indent
                                  npm error extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
                                  npm error extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
                                  npm error extraneous: suncalc@1.9.0 /opt/iobroker/node_modules/suncalc
                                  npm error extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                                  npm error extraneous: supermixer@1.0.5 /opt/iobroker/node_modules/supermixer
                                  npm error extraneous: supports-color@7.2.0 /opt/iobroker/node_modules/supports-color
                                  npm error extraneous: supports-hyperlinks@2.3.0 /opt/iobroker/node_modules/supports-hyperlinks
                                  npm error extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
                                  npm error extraneous: sweet-collections@1.1.0 /opt/iobroker/node_modules/sweet-collections
                                  npm error extraneous: symbol-observable@3.0.0 /opt/iobroker/node_modules/symbol-observable
                                  npm error extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
                                  npm error extraneous: syno@ /opt/iobroker/node_modules/syno
                                  npm error extraneous: systeminformation@ /opt/iobroker/node_modules/systeminformation
                                  npm error extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
                                  npm error extraneous: tar-stream@3.1.7 /opt/iobroker/node_modules/tar-stream
                                  npm error extraneous: tar@6.2.1 /opt/iobroker/node_modules/tar
                                  npm error extraneous: tarn@3.0.2 /opt/iobroker/node_modules/tarn
                                  npm error extraneous: tcp-port-used@1.0.2 /opt/iobroker/node_modules/tcp-port-used
                                  npm error extraneous: tedious@ /opt/iobroker/node_modules/tedious
                                  npm error extraneous: terminal-link@2.1.1 /opt/iobroker/node_modules/terminal-link
                                  npm error extraneous: text-decoder@1.1.1 /opt/iobroker/node_modules/text-decoder
                                  npm error extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
                                  npm error extraneous: thirty-two@1.0.2 /opt/iobroker/node_modules/thirty-two
                                  npm error extraneous: through@2.3.8 /opt/iobroker/node_modules/through
                                  npm error extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
                                  npm error extraneous: tiny-typed-emitter@2.1.0 /opt/iobroker/node_modules/tiny-typed-emitter
                                  npm error extraneous: tinycolor2@1.6.0 /opt/iobroker/node_modules/tinycolor2
                                  npm error extraneous: tmp@0.0.33 /opt/iobroker/node_modules/tmp
                                  npm error extraneous: to-readable-stream@2.1.0 /opt/iobroker/node_modules/to-readable-stream
                                  npm error extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/to-regex-range
                                  npm error extraneous: toidentifier@1.0.1 /opt/iobroker/node_modules/toidentifier
                                  npm error extraneous: tr46@4.1.1 /opt/iobroker/node_modules/tr46
                                  npm error extraneous: trim-newlines@3.0.1 /opt/iobroker/node_modules/trim-newlines
                                  npm error extraneous: triple-beam@1.4.1 /opt/iobroker/node_modules/triple-beam
                                  npm error extraneous: tsdav@ /opt/iobroker/node_modules/tsdav
                                  npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/tslib
                                  npm error extraneous: tweetnacl@0.14.5 /opt/iobroker/node_modules/tweetnacl
                                  npm error extraneous: type-check@0.3.2 /opt/iobroker/node_modules/type-check
                                  npm error extraneous: type-fest@0.21.3 /opt/iobroker/node_modules/type-fest
                                  npm error extraneous: type-is@1.6.18 /opt/iobroker/node_modules/type-is
                                  npm error extraneous: typed-array-buffer@1.0.2 /opt/iobroker/node_modules/typed-array-buffer
                                  npm error extraneous: typed-array-byte-length@1.0.1 /opt/iobroker/node_modules/typed-array-byte-length
                                  npm error extraneous: typed-array-byte-offset@1.0.2 /opt/iobroker/node_modules/typed-array-byte-offset
                                  npm error extraneous: typed-array-length@1.0.6 /opt/iobroker/node_modules/typed-array-length
                                  npm error extraneous: typedarray-to-buffer@3.1.5 /opt/iobroker/node_modules/typedarray-to-buffer
                                  npm error extraneous: typedarray.prototype.slice@1.0.3 /opt/iobroker/node_modules/typedarray.prototype.slice
                                  npm error extraneous: typescript@ /opt/iobroker/node_modules/typescript
                                  npm error extraneous: tz-offset@0.0.1 /opt/iobroker/node_modules/tz-offset
                                  npm error extraneous: uid-number@0.0.6 /opt/iobroker/node_modules/uid-number
                                  npm error extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
                                  npm error extraneous: undici-types@6.19.6 /opt/iobroker/node_modules/undici-types
                                  npm error extraneous: unique-filename@2.0.1 /opt/iobroker/node_modules/unique-filename
                                  npm error extraneous: unique-slug@3.0.0 /opt/iobroker/node_modules/unique-slug
                                  npm error extraneous: unique-string@2.0.0 /opt/iobroker/node_modules/unique-string
                                  npm error extraneous: unix-dgram@2.0.6 /opt/iobroker/node_modules/unix-dgram
                                  npm error extraneous: unpipe@1.0.0 /opt/iobroker/node_modules/unpipe
                                  npm error extraneous: update-notifier@5.1.0 /opt/iobroker/node_modules/update-notifier
                                  npm error extraneous: uri-js@4.4.1 /opt/iobroker/node_modules/uri-js
                                  npm error extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
                                  npm error extraneous: url-parse-lax@3.0.0 /opt/iobroker/node_modules/url-parse-lax
                                  npm error extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
                                  npm error extraneous: url@0.11.4 /opt/iobroker/node_modules/url
                                  npm error extraneous: vali-date@1.0.0 /opt/iobroker/node_modules/vali-date
                                  npm error extraneous: validate-npm-package-name@3.0.0 /opt/iobroker/node_modules/validate-npm-package-name
                                  npm error extraneous: vary@1.1.2 /opt/iobroker/node_modules/vary
                                  npm error extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                                  npm error extraneous: vue-i18n@ /opt/iobroker/node_modules/vue-i18n
                                  npm error extraneous: vuelidate-messages@0.1.2 /opt/iobroker/node_modules/vuelidate-messages
                                  npm error extraneous: vuelidate@ /opt/iobroker/node_modules/vuelidate
                                  npm error extraneous: vuex-map-fields@1.4.1 /opt/iobroker/node_modules/vuex-map-fields
                                  npm error extraneous: w3c-xmlserializer@4.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
                                  npm error extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                                  npm error extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
                                  npm error extraneous: webdav@ /opt/iobroker/node_modules/webdav
                                  npm error extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
                                  npm error extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
                                  npm error extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
                                  npm error extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
                                  npm error extraneous: whatwg-url@12.0.1 /opt/iobroker/node_modules/whatwg-url
                                  npm error extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
                                  npm error extraneous: which-typed-array@1.1.15 /opt/iobroker/node_modules/which-typed-array
                                  npm error extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
                                  npm error extraneous: widest-line@3.1.0 /opt/iobroker/node_modules/widest-line
                                  npm error extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
                                  npm error extraneous: winston-daily-rotate-file@5.0.0 /opt/iobroker/node_modules/winston-daily-rotate-file
                                  npm error extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
                                  npm error extraneous: winston-syslog@2.7.1 /opt/iobroker/node_modules/winston-syslog
                                  npm error extraneous: winston-transport@4.7.1 /opt/iobroker/node_modules/winston-transport
                                  npm error extraneous: winston@ /opt/iobroker/node_modules/winston
                                  npm error extraneous: word-wrap@1.2.5 /opt/iobroker/node_modules/word-wrap
                                  npm error extraneous: worker-timers-broker@6.1.8 /opt/iobroker/node_modules/worker-timers-broker
                                  npm error extraneous: worker-timers-worker@7.0.71 /opt/iobroker/node_modules/worker-timers-worker
                                  npm error extraneous: worker-timers@7.1.8 /opt/iobroker/node_modules/worker-timers
                                  npm error extraneous: wrap-ansi-cjs@npm:wrap-ansi@7.0.0 /opt/iobroker/node_modules/wrap-ansi-cjs
                                  npm error extraneous: wrap-ansi@8.1.0 /opt/iobroker/node_modules/wrap-ansi
                                  npm error extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/wrappy
                                  npm error extraneous: write-file-atomic@3.0.3 /opt/iobroker/node_modules/write-file-atomic
                                  npm error extraneous: xdg-basedir@4.0.0 /opt/iobroker/node_modules/xdg-basedir
                                  npm error extraneous: xml-js@1.6.11 /opt/iobroker/node_modules/xml-js
                                  npm error extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
                                  npm error extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
                                  npm error extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
                                  npm error extraneous: yallist@4.0.0 /opt/iobroker/node_modules/yallist
                                  npm error extraneous: yaml@ /opt/iobroker/node_modules/yaml
                                  npm error extraneous: yargs-parser@20.2.9 /opt/iobroker/node_modules/yargs-parser
                                  npm error extraneous: yocto-queue@0.1.0 /opt/iobroker/node_modules/yocto-queue
                                  npm error extraneous: zip-stream@6.0.1 /opt/iobroker/node_modules/zip-stream
                                  npm error extraneous: zrender@ /opt/iobroker/node_modules/zrender
                                  npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T20_16_41_191Z-debug-0.log
                                    Thomas Braun Most Active @flommaster last edited by
                                    @flommaster
                                    iob repo list
                                      flommaster @Thomas Braun last edited by
                                      flo@ioBrokerdebian:/opt/iobroker$ iob repo list
                                      node:internal/modules/cjs/loader:1148
                                        throw err;
                                      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                          at Module._resolveFilename (node:internal/modules/cjs/loader:1145:15)
                                          at Module._load (node:internal/modules/cjs/loader:986:27)
                                          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
                                          at node:internal/main/run_main_module:28:49 {
                                        code: 'MODULE_NOT_FOUND',
                                        requireStack: []
                                      Node.js v20.16.0
                                        Homoran Global Moderator Administrators @flommaster last edited by
                                        @flommaster sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                                        flo@ioBrokerdebian:/opt/iobroker$ npm prune
                                        hast du beide Befehle auf einmal gestartet?
                                        bitte einzeln abarbeiten
                                        F Thomas Braun 2 Replies Last reply Reply Quote 1
                                          flommaster @Homoran last edited by
                                          Ja,
                                          Hier ist das Ergebnis von "npm prune"
                                          npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.web-speedy.git
                                          npm warn skipping integrity check for git dependency ssh://git@github.com/peterbaumert/ioBroker.vofo-speedtest.git
                                          npm warn skipping integrity check for git dependency ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git
                                          npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2-widgets-material.git
                                          npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2.git
                                          npm warn skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git
                                          npm warn skipping integrity check for git dependency ssh://git@github.com/aendue/ioBroker.reolink.git
                                          npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.ical.git
                                          npm warn skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git
                                          npm warn skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git
                                          npm warn skipping integrity check for git dependency ssh://git@github.com/WLAN-Kabel/ioBroker.calendar.git
                                          npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                                          npm warn deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                                          npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                                          npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
                                          npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
                                          npm warn deprecated uid-number@0.0.6: This package is no longer supported.
                                          npm warn deprecated npmlog@5.0.1: This package is no longer supported.
                                          npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                          npm warn deprecated npmlog@6.0.2: This package is no longer supported.
                                          npm warn deprecated har-validator@5.1.5: this library is no longer supported
                                          npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                                          npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
                                          npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
                                          npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
                                          npm warn deprecated q@1.1.2: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
                                          npm warn deprecated
                                          npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
                                          npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                                          npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                                          npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
                                          npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
                                          npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                                          npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
                                          npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                                          npm warn deprecated google-p12-pem@3.1.4: Package is no longer maintained
                                          npm warn deprecated gauge@3.0.2: This package is no longer supported.
                                          npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                          npm warn deprecated gauge@4.0.4: This package is no longer supported.
                                          npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                          mikeal created this issue in request/request
                                          open Request’s Past, Present and Future #3142
                                          Qix- created this issue in visionmedia/debug
                                          closed ReDos Vulnerability Regression Visibility Notice #797
                                            Thomas Braun Most Active @Homoran last edited by Thomas Braun
                                            @flommaster
                                            Gerade noch gehabt...
                                            Vollständig.
                                            Inkl. vollständiger Eingabezeile inkl. login prompt. Damit man sieht was du da genau in welchem Verzeichnis mit welchem User eingegeben hast.
                                            Und auch inkl. der neuen leeren Eingabezeile, damit man sieht das es durchgelaufen ist und da nix fehlt.
                                            iobroker url https://github.com/DrozmotiX/ioBroker.sourceanalytix --debug
                                            5327
