    4. Beim Update von Adaptern stürzt der ioBroker ab
      flommaster @Thomas Braun last edited by
      Das geht gar nicht mehr.
      iob upgrade mihome-vaccuum
      node:internal/modules/cjs/loader:1148
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Module._resolveFilename (node:internal/modules/cjs/loader:1145:15)
          at Module._load (node:internal/modules/cjs/loader:986:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
          at node:internal/main/run_main_module:28:49 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      Node.js v20.16.0
      Kann ich den Adapter auch komplett löschen. Den Staubsauger nutze ich nur noch manuell...
        Thomas Braun Most Active @flommaster last edited by
        @flommaster
        cd /opt/iobroker && npm ls
        spuckt aus?
        mcm1957 F 2 Replies Last reply Reply Quote 0
        • mcm1957
          mcm1957 @Thomas Braun last edited by
          Wo stammen eigentlich die ganzen GITHUB dependencies her, z.B.
          npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.web-speedy.git
          Den Adapter gibts (dort) gar nicht ...
            @thomas-braun sagte in Beim Update von Adaptern stürzt der ioBroker ab:
            zu viele Fehler...
            Teil 1
            iobroker.inst@2.0.3 /opt/iobroker
            ├── @alcalzone/esbuild-register@2.5.1-1 extraneous
            ├── @alcalzone/jsonl-db@3.1.1 extraneous
            ├── @alcalzone/pak@0.8.1 extraneous
            ├── @alcalzone/proper-lockfile@4.1.3-0 extraneous
            ├── @aws-sdk/util-utf8-browser@3.259.0 extraneous
            ├── @azure/abort-controller@1.1.0 extraneous
            ├── @azure/core-auth@1.7.2 extraneous
            ├── @azure/core-client@ extraneous
            ├── @azure/core-http-compat@ extraneous
            ├── @azure/core-lro@ extraneous
            ├── @azure/core-paging@1.6.2 extraneous
            ├── @azure/core-rest-pipeline@ extraneous
            ├── @azure/core-tracing@1.1.2 extraneous
            ├── @azure/core-util@ extraneous
            ├── @azure/identity@ extraneous
            ├── @azure/keyvault-keys@ extraneous
            ├── @azure/logger@1.1.4 extraneous
            ├── @azure/msal-browser@ extraneous
            ├── @azure/msal-common@ extraneous
            ├── @azure/msal-node@1.18.4 extraneous
            ├── @babel/code-frame@7.24.7 extraneous
            ├── @babel/helper-validator-identifier@7.24.7 extraneous
            ├── @babel/highlight@7.24.7 extraneous
            ├── @babel/runtime@ extraneous
            ├── @colors/colors@1.5.0 extraneous
            ├── @dabh/diagnostics@2.0.3 extraneous
            ├── @datalust/winston-seq@1.0.2 extraneous
            ├── @gar/promisify@1.1.3 extraneous
            ├── @googleapis/calendar@9.7.7 extraneous
            ├── @googleapis/drive@5.1.0 extraneous
            ├── @googleapis/oauth2@1.0.7 extraneous
            ├── @httptoolkit/websocket-stream@6.0.1 extraneous
            ├── @iobroker/db-base@ extraneous
            ├── @iobroker/db-objects-file@ extraneous
            ├── @iobroker/db-objects-jsonl@ extraneous
            ├── @iobroker/db-objects-redis@ extraneous
            ├── @iobroker/db-states-file@ extraneous
            ├── @iobroker/db-states-jsonl@ extraneous
            ├── @iobroker/db-states-redis@ extraneous
            ├── @iobroker/js-controller-adapter@ extraneous
            ├── @iobroker/js-controller-cli@ extraneous
            ├── @iobroker/js-controller-common-db@ extraneous
            ├── @iobroker/js-controller-common@ extraneous
            ├── @iobroker/plugin-base@1.2.1 extraneous
            ├── @iobroker/plugin-sentry@1.2.1 extraneous
            ├── @iobroker/socket-classes@1.5.6 extraneous
            ├── @iobroker/webserver@1.0.3 extraneous
            ├── @isaacs/cliui@8.0.2 extraneous
            ├── @js-joda/core@ extraneous
            ├── @mapbox/node-pre-gyp@1.0.11 extraneous
            ├── @microsoft/microsoft-graph-types@2.40.0 extraneous
            ├── @nodelib/fs.scandir@2.1.5 extraneous
            ├── @nodelib/fs.stat@2.0.5 extraneous
            ├── @nodelib/fs.walk@1.2.8 extraneous
            ├── @npmcli/fs@2.1.2 extraneous
            ├── @npmcli/move-file@2.0.1 extraneous
            ├── @pkgjs/parseargs@0.11.0 extraneous
            ├── @protobufjs/aspromise@1.1.2 extraneous
            ├── @protobufjs/base64@1.1.2 extraneous
            ├── @protobufjs/codegen@2.0.4 extraneous
            ├── @protobufjs/eventemitter@1.1.0 extraneous
            ├── @protobufjs/fetch@1.1.0 extraneous
            ├── @protobufjs/float@1.0.2 extraneous
            ├── @protobufjs/inquire@1.1.0 extraneous
            ├── @protobufjs/path@1.1.2 extraneous
            ├── @protobufjs/pool@1.1.0 extraneous
            ├── @protobufjs/utf8@1.1.0 extraneous
            ├── @quasar/extras@ extraneous
            ├── @samverschueren/stream-to-observable@0.3.1 extraneous
            ├── @sentry-internal/tracing@ extraneous
            ├── @sentry/core@5.30.0 extraneous
            ├── @sentry/hub@5.30.0 extraneous
            ├── @sentry/minimal@5.30.0 extraneous
            ├── @sentry/node@ extraneous
            ├── @sentry/tracing@ extraneous
            ├── @sentry/types@ extraneous
            ├── @sentry/utils@ extraneous
            ├── @sindresorhus/is@4.6.0 extraneous
            ├── @socket.io/component-emitter@3.1.2 extraneous
            ├── @szmarczak/http-timer@4.0.6 extraneous
            ├── @tediousjs/connection-string@0.5.0 extraneous
            ├── @tootallnate/once@2.0.0 extraneous
            ├── @types/bl@5.1.0 extraneous
            ├── @types/cacheable-request@6.0.3 extraneous
            ├── @types/caseless@0.12.5 extraneous
            ├── @types/cookie@0.4.1 extraneous
            ├── @types/cors@2.8.17 extraneous
            ├── @types/geojson@7946.0.14 extraneous
            ├── @types/http-cache-semantics@4.0.4 extraneous
            ├── @types/keyv@3.1.4 extraneous
            ├── @types/leaflet@1.9.12 extraneous
            ├── @types/minimist@1.2.5 extraneous
            ├── @types/node-cron@2.0.8 extraneous
            ├── @types/node@ extraneous
            ├── @types/normalize-package-data@2.4.4 extraneous
            ├── @types/parse-json@4.0.2 extraneous
            ├── @types/readable-stream@4.0.15 extraneous
            ├── @types/request@2.48.12 extraneous
            ├── @types/responselike@1.0.3 extraneous
            ├── @types/tough-cookie@4.0.5 extraneous
            ├── @types/triple-beam@1.3.5 extraneous
            ├── @types/tz-offset@0.0.3 extraneous
            ├── @types/ws@8.5.12 extraneous
            ├── abab@2.0.6 extraneous
            ├── abbrev@1.1.1 extraneous
            ├── abort-controller@3.0.0 extraneous
            ├── agentkeepalive@4.5.0 extraneous
            ├── aggregate-error@3.1.0 extraneous
            ├── ajv@ extraneous
            ├── ansi-align@3.0.1 extraneous
            ├── ansi-colors@4.1.3 extraneous
            ├── ansi-escapes@4.3.2 extraneous
            ├── ansi-regex@5.0.1 extraneous
            ├── ansi-styles@4.3.0 extraneous
            ├── any-observable@0.5.1 extraneous
            ├── anymatch@3.1.3 extraneous
            ├── aproba@2.0.0 extraneous
            ├── archiver-utils@5.0.2 extraneous
            ├── archiver@7.0.1 extraneous
            ├── are-we-there-yet@2.0.0 extraneous
            ├── arg@4.1.0 extraneous
            ├── argparse@1.0.10 extraneous
            ├── array-buffer-byte-length@1.0.1 extraneous
            ├── array-flatten@1.1.1 extraneous
            ├── array-union@2.1.0 extraneous
            ├── arraybuffer.prototype.slice@1.0.3 extraneous
            ├── arrify@2.0.1 extraneous
            ├── asn1@0.2.6 extraneous
            ├── async-exit-hook@2.0.1 extraneous
            ├── authenticate-pam@1.0.5 extraneous
            ├── available-typed-arrays@1.0.7 extraneous
            ├── aws-crt@ extraneous
            ├── b4a@1.6.6 extraneous
            ├── balanced-match@1.0.2 extraneous
            ├── bare-events@2.4.2 extraneous
            ├── base-64@1.0.0 extraneous
            ├── base64-js@1.5.1 extraneous
            ├── bcrypt-pbkdf@1.0.2 extraneous
            ├── binary-extensions@2.3.0 extraneous
            ├── bindings@1.5.0 extraneous
            ├── bl@6.0.14 extraneous
            ├── bluebird@3.7.2 extraneous
            ├── body-parser@1.20.2 extraneous
            ├── bottleneck@2.19.5 extraneous
            ├── boxen@5.1.2 extraneous
            ├── brace-expansion@2.0.1 extraneous
            ├── braces@3.0.3 extraneous
            ├── buffer-crc32@1.0.0 extraneous
            ├── buffer-equal-constant-time@1.0.1 extraneous
            ├── buffer-shims@1.0.0 extraneous
            ├── buffer@6.0.3 extraneous
            ├── buildcheck@0.0.6 extraneous
            ├── builtins@1.0.3 extraneous
            ├── busboy@1.6.0 extraneous
            ├── byte-length@1.0.2 extraneous
            ├── bytes@3.1.2 extraneous
            ├── cacache@16.1.3 extraneous
            ├── cacheable-lookup@5.0.4 extraneous
            ├── cacheable-request@7.0.4 extraneous
            ├── callsites@3.1.0 extraneous
            ├── camelcase-keys@6.2.2 extraneous
            ├── camelcase@5.3.1 extraneous
            ├── capitalize@2.0.4 extraneous
            ├── chalk@4.1.2 extraneous
            ├── chardet@0.7.0 extraneous
            ├── charenc@0.0.2 extraneous
            ├── chokidar@3.6.0 extraneous
            ├── chownr@2.0.0 extraneous
            ├── ci-info@3.9.0 extraneous
            ├── clean-stack@2.2.0 extraneous
            ├── cli-boxes@2.2.1 extraneous
            ├── cli-cursor@3.1.0 extraneous
            ├── cli-truncate@0.2.1 extraneous
            ├── cli-width@3.0.0 extraneous
            ├── clone-response@1.0.3 extraneous
            ├── cloneextend@0.0.3 extraneous
            ├── cluster-key-slot@1.1.2 extraneous
            ├── coap-packet@1.1.1 extraneous
            ├── coffeescript@1.12.7 extraneous
            ├── color-convert@2.0.1 extraneous
            ├── color-name@1.1.4 extraneous
            ├── color-string@1.9.1 extraneous
            ├── color-support@1.1.3 extraneous
            ├── color@3.2.1 extraneous
            ├── colors@1.4.0
            ├── colorspace@1.1.4 extraneous
            ├── commander@9.5.0 extraneous
            ├── commist@3.2.0 extraneous
            ├── compress-commons@6.0.2 extraneous
            ├── compress-json@2.1.2 extraneous
            ├── compressible@2.0.18 extraneous
            ├── compression@1.7.4 extraneous
            ├── concat-map@0.0.1 extraneous
            ├── configstore@5.0.1 extraneous
            ├── connect-flash@0.1.1 extraneous
            ├── connect@3.7.0 extraneous
            ├── console-control-strings@1.1.0 extraneous
            ├── content-disposition@0.5.4 extraneous
            ├── content-type@1.0.5 extraneous
            ├── core-js@ extraneous
            ├── cors@2.8.5 extraneous
            ├── cosmiconfig@7.1.0 extraneous
            ├── cpu-features@ extraneous
            ├── crc-32@1.2.2 extraneous
            ├── crc@ extraneous
            ├── crc32-stream@6.0.0 extraneous
            ├── cross-fetch@4.0.0 extraneous
            ├── crypt@0.0.2 extraneous
            ├── crypto-js@ extraneous
            ├── crypto-random-string@2.0.0 extraneous
            ├── cssstyle@ extraneous
            ├── cycle@1.0.3 extraneous
            ├── dashdash@1.14.1 extraneous
            ├── data-urls@4.0.0 extraneous
            ├── data-view-buffer@1.0.1 extraneous
            ├── data-view-byte-length@1.0.1 extraneous
            ├── data-view-byte-offset@1.0.0 extraneous
            ├── date-and-time@ extraneous
            ├── date-fns@1.30.1 extraneous
            ├── dateformat@4.6.3 extraneous
            ├── dayjs@ extraneous
            ├── decache@4.6.2 extraneous
            ├── decamelize-keys@1.1.1 extraneous
            ├── decimal.js@10.4.3 extraneous
            ├── decompress-response@6.0.0 extraneous
            ├── deep-clone@3.0.3 extraneous
            ├── deep-extend@0.6.0 extraneous
            ├── deep-is@0.1.4 extraneous
            ├── defer-to-connect@2.0.1 extraneous
            ├── define-lazy-prop@2.0.0 extraneous
            ├── del@6.1.1 extraneous
            ├── delegates@1.0.0 extraneous
            ├── denque@1.5.1 extraneous
            ├── destroy@1.2.0 extraneous
            ├── detect-libc@2.0.3 extraneous
            ├── diacritics@1.3.0 extraneous
            ├── digest-header@1.1.0 extraneous
            ├── dir-glob@3.0.1 extraneous
            ├── diskusage@1.2.0 extraneous
            ├── domexception@4.0.0 extraneous
            ├── dot-prop@6.0.1 extraneous
            ├── draftlog@1.0.13 extraneous
            ├── dropbox-v2-api@ extraneous
            ├── duplexer@0.1.2 extraneous
            ├── duplexer3@0.1.5 extraneous
            ├── duplexify@3.7.1 extraneous
            ├── eastasianwidth@0.2.0 extraneous
            ├── ecc-jsbn@0.1.2 extraneous
            ├── ecdsa-sig-formatter@1.0.11 extraneous
            ├── echarts@ extraneous
            ├── ee-first@1.1.1 extraneous
            ├── elegant-spinner@1.0.1 extraneous
            ├── emoji-regex@9.2.2 extraneous
            ├── enabled@2.0.0 extraneous
            ├── encodeurl@1.0.2 extraneous
            ├── encoding@0.1.13 extraneous
            ├── end-of-stream@1.4.4 extraneous
            ├── entities@4.5.0 extraneous
            ├── err-code@2.0.3 extraneous
            ├── es-abstract@ extraneous
            ├── es-aggregate-error@1.0.13 extraneous
            ├── es-object-atoms@1.0.0 extraneous
            ├── es-set-tostringtag@2.0.3 extraneous
            ├── es-to-primitive@1.2.1 extraneous
            ├── es6-promise@4.2.8 extraneous
            ├── es6-promisify@5.0.0 extraneous
            ├── esbuild@0.11.23 extraneous
            ├── escalade@3.1.2 extraneous
            ├── escape-goat@3.0.0 extraneous
            ├── escape-html@1.0.3 extraneous
            ├── escape-string-regexp@4.0.0 extraneous
            ├── escodegen@1.14.3 extraneous
            ├── esprima@1.2.2 extraneous
            ├── estraverse@4.3.0 extraneous
            ├── esutils@2.0.3 extraneous
            ├── etag@1.8.1 extraneous
            ├── event-stream@4.0.1 extraneous
            ├── event-target-shim@5.0.1 extraneous
            ├── eventemitter2@6.4.9 extraneous
            ├── events@3.3.0 extraneous
            ├── execa@5.1.1 extraneous
            ├── expand-template@2.0.3 extraneous
            ├── express-fileupload@1.5.1 extraneous
            ├── express@4.19.2 extraneous
            ├── external-editor@3.1.0 extraneous
            ├── fast-deep-equal@3.1.3 extraneous
            ├── fast-fifo@1.3.2 extraneous
            ├── fast-glob@ extraneous
            ├── fast-json-stable-stringify@2.1.0 extraneous
            ├── fast-levenshtein@2.0.6 extraneous
            ├── fast-text-encoding@1.0.6 extraneous
            ├── fast-unique-numbers@ extraneous
            ├── fast-uri@3.0.1 extraneous
            ├── fast-xml-parser@ extraneous
            ├── fastq@1.17.1 extraneous
            ├── fastseries@2.0.0 extraneous
            ├── fecha@4.2.3 extraneous
            ├── figures@3.2.0 extraneous
            ├── file-stream-rotator@0.6.1 extraneous
            ├── file-type@10.11.0 extraneous
            ├── file-uri-to-path@1.0.0 extraneous
            ├── fill-range@7.1.1 extraneous
            ├── finalhandler@1.2.0 extraneous
            ├── find-up@5.0.0 extraneous
            ├── fn.name@1.1.0 extraneous
            ├── for-each@0.3.3 extraneous
            ├── foreground-child@3.3.0 extraneous
            ├── form-data-encoder@2.1.4 extraneous
            ├── form-data@4.0.0 extraneous
            ├── forwarded@0.2.0 extraneous
            ├── fresh@0.5.2 extraneous
            ├── from@0.1.7 extraneous
            ├── fs-constants@1.0.0 extraneous
            ├── fs-extra@7.0.1
            ├── fs-minipass@2.1.0 extraneous
            ├── fs.realpath@1.0.0 extraneous
            ├── fsevents@ extraneous
            ├── ftp@0.3.10 extraneous
            ├── function.prototype.name@1.1.6 extraneous
            ├── functions-have-names@1.2.3 extraneous
            ├── futoin-hkdf@1.4.3 extraneous
            ├── gauge@3.0.2 extraneous
            ├── gaxios@5.1.3 extraneous
            ├── gcp-metadata@5.3.0 extraneous
            ├── generate-function@2.3.1 extraneous
            ├── get-ssl-certificate@2.3.3 extraneous
            ├── get-stream@5.2.0 extraneous
            ├── get-symbol-description@1.0.2 extraneous
            ├── getpass@0.1.7 extraneous
            ├── github-from-package@0.0.0 extraneous
            ├── github-url-from-git@1.5.0 extraneous
            ├── glob-parent@5.1.2 extraneous
            ├── glob@10.4.5 extraneous
            ├── global-dirs@2.1.0 extraneous
            ├── globalthis@1.0.4 extraneous
            ├── globby@11.1.0 extraneous
            ├── glossy@0.1.7 extraneous
            ├── google-auth-library@ extraneous
            ├── google-p12-pem@4.0.1 extraneous
            ├── googleapis-common@6.0.4 extraneous
            ├── googleapis@ extraneous
            ├── gtoken@6.1.2 extraneous
            ├── hard-rejection@2.1.0 extraneous
            ├── has-ansi@2.0.0 extraneous
            ├── has-bigints@1.0.2 extraneous
            ├── has-flag@4.0.0 extraneous
            ├── has-tostringtag@1.0.2 extraneous
            ├── has-unicode@2.0.1 extraneous
            ├── has-yarn@2.1.0 extraneous
            ├── he@1.2.0 extraneous
            ├── help-me@5.0.0 extraneous
            ├── homebridge-plugin-wrapper@ extraneous
            ├── hosted-git-info@3.0.8 extraneous
            ├── hot-patcher@1.0.0 extraneous
            ├── html-encoding-sniffer@3.0.0 extraneous
            ├── http-cache-semantics@4.1.1 extraneous
            ├── http-errors@2.0.0 extraneous
            ├── http-proxy-agent@5.0.0 extraneous
            ├── http2-wrapper@1.0.3 extraneous
            ├── https@1.0.0 extraneous
            ├── humanize-ms@1.2.1 extraneous
            ├── ical.js@ extraneous
            ├── iconv-lite@0.4.24 extraneous
            ├── ieee754@1.2.1 extraneous
            ├── ignore-walk@3.0.4 extraneous
            ├── ignore@5.3.2 extraneous
            ├── image-type@4.1.0 extraneous
            ├── immediate@3.0.6 extraneous
            ├── import-fresh@3.3.0 extraneous
            ├── import-lazy@2.1.0 extraneous
            ├── import-local@3.2.0 extraneous
            ├── imurmurhash@0.1.4 extraneous
            ├── indent-string@3.2.0 extraneous
            ├── infer-owner@1.0.4 extraneous
            ├── inflight@1.0.6 extraneous
            ├── ini@1.3.7 extraneous
            ├── inquirer-autosubmit-prompt@0.2.0 extraneous
            ├── inquirer@7.3.3 extraneous
            ├── int64-buffer@1.0.1 extraneous
            ├── internal-slot@1.0.7 extraneous
            ├── iobroker-adapter-helpers@0.0.8 extraneous
            ├── iobroker.admin@ invalid: "^6.10.1" from the root project
            ├── iobroker.backitup@ invalid: "2.6.23" from the root project
            ├── iobroker.bmw@2.5.7
            ├── iobroker.calendar@ invalid: "github:WLAN-Kabel/ioBroker.calendar#c36410258c21a4a92eba80fb0ec084fc254c9259" from the root project
            ├── iobroker.cloud@4.4.1
            ├── iobroker.coronavirus-statistics@0.8.7
            ├── iobroker.daswetter@3.1.10
            ├── iobroker.discovery@ invalid: "3.1.0" from the root project
            ├── iobroker.dwd@2.8.5
            ├── iobroker.echarts@ invalid: "1.5.1" from the root project
            ├── iobroker.energiefluss@ invalid: "github:SKB-CGN/ioBroker.energiefluss#fc7a5b48f0f485b130619796daf0a9533f5b8426" from the root project
            ├── iobroker.eusec@1.1.2
            ├── iobroker.flot@ invalid: "1.12.0" from the root project
            ├── iobroker.fritzbox@0.2.1
            ├── iobroker.fullcalendar@ invalid: "1.2.0" from the root project
            ├── iobroker.fullybrowser@2.1.2
            ├── iobroker.gartenbewaesserung@ invalid: "github:TA2k/ioBroker.gartenbewaesserung#1931dcd562edf9dfa818dbf5cec61e28d3f72d72" from the root project
            ├── iobroker.ham@ invalid: "github:ioBroker/ioBroker.ham" from the root project
            ├── iobroker.harmony@1.2.2
            ├── iobroker.heatingcontrol@ invalid: "2.11.1" from the root project
            ├── iobroker.history@2.2.6
            ├── iobroker.hm-rega@3.0.47
            ├── iobroker.hm-rpc@1.15.19
            ├── iobroker.hue@3.9.5
            ├── iobroker.ical@ invalid: "github:iobroker-community-adapters/ioBroker.ical#ad28140ed1fa7ab23683d7e12b6204da06b7ce6f" from the root project
            ├── iobroker.icons-icons8@0.0.1
            ├── iobroker.icons-material-png@0.1.0
            ├── iobroker.icons-mfd-png@1.1.0
            ├── iobroker.icons-ultimate-png@1.0.1
            ├── iobroker.info@ invalid: "1.9.26" from the root project
            ├── iobroker.javascript@ invalid: "7.1.4" from the root project
            ├── iobroker.js-controller@ invalid: "^6.0.9" from the root project
            ├── iobroker.logparser@2.2.0
            ├── iobroker.material@ invalid: "1.3.1" from the root project
            ├── iobroker.meross@1.15.1
            ├── iobroker.mihome-vacuum@3.11.0
            ├── iobroker.milight-smart-light@ invalid: "1.2.2" from the root project
            ├── iobroker.milight@0.3.6
            ├── iobroker.mobile@ invalid: "1.0.1" from the root project
            ├── iobroker.modbus@ invalid: "5.0.11" from the root project
            ├── iobroker.mqtt@ invalid: "4.1.1" from the root project
            ├── iobroker.nina@ invalid: "0.0.25" from the root project
            ├── iobroker.pollenflug@1.0.6
            ├── iobroker.pushover@3.0.3
            ├── iobroker.pushsafer@1.0.3
            ├── iobroker.pvforecast@2.7.1
            ├── iobroker.renault@ invalid: "github:TA2k/ioBroker.renault" from the root project
            ├── iobroker.reolink@ invalid: "github:aendue/ioBroker.reolink#b78aab6744cdb81b360fd947a9c6e2fd6808bab1" from the root project
            ├── iobroker.schoolfree@ invalid: "1.1.2" from the root project
            ├── iobroker.simple-api@2.7.2
            ├── iobroker.smartmeter@3.3.4
            ├── iobroker.socketio@6.5.2
            ├── iobroker.sourceanalytix@ invalid: "github:DrozmotiX/ioBroker.sourceanalytix#362346b297c0a21c717ec20bd8d16331bca3b22d" from the root project
            ├── iobroker.sql@2.2.0
            ├── iobroker.statistics@2.3.0
            ├── iobroker.sunnyportal@0.1.5
            ├── iobroker.synology@ invalid: "2.1.13" from the root project
            ├── iobroker.tankerkoenig@ invalid: "3.3.7" from the root project
            ├── iobroker.terminal@ invalid: "1.0.0" from the root project
            ├── iobroker.tr-064@4.2.18
            ├── iobroker.trashschedule@2.2.0
            ├── iobroker.unifi@ invalid: "0.6.6" from the root project
            ├── iobroker.upnp@1.0.21
            ├── iobroker.valloxmv@1.2.0
            ├── iobroker.viessmannapi@ invalid: "github:TA2k/ioBroker.viessmannapi" from the root project
            ├── iobroker.virtualpowermeter@ invalid: "1.4.6" from the root project
            ├── iobroker.vis-2-widgets-material@ invalid: "github:ioBroker/ioBroker.vis-2-widgets-material#355a97e7d532721eaa97326fd873d13f12894ebd" from the root project
            ├── iobroker.vis-2@ invalid: "github:ioBroker/ioBroker.vis-2#17c7dcf5f26768f1f3a4badb087eddf9344591ea" from the root project
            ├── iobroker.vis-colorpicker@ invalid: "2.0.3" from the root project
            ├── iobroker.vis-fancyswitch@1.1.0
            ├── iobroker.vis-google-fonts@1.0.4
            ├── iobroker.vis-history@1.0.0
            ├── iobroker.vis-hqwidgets@ invalid: "1.4.0" from the root project
            ├── iobroker.vis-inventwo@ invalid: "3.3.3" from the root project
            ├── iobroker.vis-jqui-mfd@1.0.12
            ├── iobroker.vis-justgage@1.0.2
            ├── iobroker.vis-map@1.0.4
            ├── iobroker.vis-materialdesign@ invalid: "github:Scrounger/ioBroker.vis-materialdesign#8b7529d493f223dfc4f1d1f632553fcb35bbcc92" from the root project
            ├── iobroker.vis-metro@ invalid: "1.2.0" from the root project
            ├── iobroker.vis-rgraph@0.0.2
            ├── iobroker.vis-timeandweather@ invalid: "1.2.2" from the root project
            ├── iobroker.vis-weather@ invalid: "2.5.6" from the root project
            ├── iobroker.vis@ invalid: "1.4.16" from the root project
            ├── iobroker.vofo-speedtest@ invalid: "github:peterbaumert/ioBroker.vofo-speedtest#921201b4bbd53a88a64fc843c7242f9e7e8c0325" from the root project
            ├── iobroker.weatherunderground@3.4.2
            ├── iobroker.web-speedy@ invalid: "github:iobroker-community-adapters/ioBroker.web-speedy#8a5ad6a42a15688b6bb539f22e30ba2a1978c118" from the root project
            ├── iobroker.web@ invalid: "6.1.0" from the root project
            ├── iobroker.webcal@ invalid: "github:dirkhe/ioBroker.webcal#feature/DigestAuth" from the root project
            ├── iobroker.wiffi-wz@2.2.1
            ├── iobroker.windows-control@0.1.5
            ├── iobroker.worx@2.3.2
            ├── iobroker.ws@2.5.3
            ├── iobroker@2.0.3
            ├── ioredis@ extraneous
            ├── ip-address@9.0.5 extraneous
            ├── ip-regex@4.3.0 extraneous
            ├── ipaddr.js@2.2.0 extraneous
            ├── is-array-buffer@3.0.4 extraneous
            ├── is-bigint@1.0.4 extraneous
            ├── is-binary-path@2.1.0 extraneous
            ├── is-boolean-object@1.1.2 extraneous
            ├── is-buffer@1.1.6 extraneous
            ├── is-callable@1.2.7 extraneous
            ├── is-ci@2.0.0 extraneous
            ├── is-core-module@2.15.0 extraneous
            ├── is-data-view@1.0.1 extraneous
            ├── is-date-object@1.0.5 extraneous
            ├── is-docker@2.2.1 extraneous
            ├── is-empty-object@1.1.1 extraneous
            ├── is-extglob@2.1.1 extraneous
            ├── is-fullwidth-code-point@3.0.0 extraneous
            ├── is-glob@4.0.3 extraneous
            ├── is-installed-globally@0.3.2 extraneous
            ├── is-interactive@1.0.0 extraneous
            ├── is-lambda@1.0.1 extraneous
            ├── is-negative-zero@2.0.3 extraneous
            ├── is-npm@5.0.0 extraneous
            ├── is-number-object@1.0.7 extraneous
            ├── is-number@7.0.0 extraneous
            ├── is-obj@2.0.0 extraneous
            ├── is-observable@1.1.0 extraneous
            ├── is-path-cwd@2.2.0 extraneous
            ├── is-path-inside@3.0.3 extraneous
            ├── is-plain-obj@1.1.0 extraneous
            ├── is-potential-custom-element-name@1.0.1 extraneous
            ├── is-promise@2.2.2 extraneous
            ├── is-property@1.0.2 extraneous
            ├── is-regex@1.1.4 extraneous
            ├── is-scoped@2.1.0 extraneous
            ├── is-shared-array-buffer@1.0.3 extraneous
            ├── is-string@1.0.7 extraneous
            ├── is-symbol@1.0.4 extraneous
            ├── is-typed-array@1.1.13 extraneous
            ├── is-unicode-supported@0.1.0 extraneous
            ├── is-url-superb@4.0.0 extraneous
            ├── is-url@1.2.4 extraneous
            ├── is-weakref@1.0.2 extraneous
            ├── is-wsl@2.2.0 extraneous
            ├── is-yarn-global@0.3.0 extraneous
            ├── is@3.3.0 extraneous
            ├── is2@2.0.9 extraneous
            ├── isomorphic-ws@4.0.1 extraneous
            ├── issue-regex@3.1.0 extraneous
            ├── jackspeak@3.4.3 extraneous
            ├── js-md4@0.3.2 extraneous
            ├── js-sdsl@4.3.0 extraneous
            ├── js-tokens@4.0.0 extraneous
            ├── js-yaml@ extraneous
            ├── jsbi@4.3.0 extraneous
            ├── jsbn@1.1.0 extraneous
            ├── jsdom@ extraneous
            ├── jshashes@1.0.8 extraneous
            ├── json-buffer@3.0.1 extraneous
            ├── json-logic-js@2.0.5 extraneous
            ├── json-parse-even-better-errors@2.3.1 extraneous
            ├── json-schema-traverse@1.0.0 extraneous
            ├── json5@2.2.3 extraneous
            ├── jsonata@ extraneous
            ├── jsonc-parser@3.3.1 extraneous
            ├── jsonwebtoken@9.0.2 extraneous
            ├── jszip@ extraneous
            ├── jwa@2.0.0 extraneous
            ├── jws@4.0.0 extraneous
            ├── keyv@4.5.4 extraneous
            ├── kind-of@6.0.3 extraneous
            ├── kuler@2.0.0 extraneous
            ├── later@1.2.0 extraneous
            ├── latest-version@5.1.0 extraneous
            ├── layerr@0.1.2 extraneous
            ├── lazystream@1.0.1 extraneous
            ├── leven@2.1.0 extraneous
            ├── levn@0.3.0 extraneous
            ├── lie@3.3.0 extraneous
            ├── lines-and-columns@1.2.4 extraneous
            ├── listr-input@0.2.1 extraneous
            ├── listr-silent-renderer@1.1.1 extraneous
            ├── listr-update-renderer@0.5.0 extraneous
            ├── listr-verbose-renderer@0.5.0 extraneous
            ├── listr@0.14.3 extraneous
            ├── loadavg-windows@1.1.1 extraneous
            ├── locate-path@6.0.0 extraneous
            ├── lodash.defaults@4.2.0 extraneous
            ├── lodash.flatten@4.4.0 extraneous
            ├── lodash.includes@4.3.0 extraneous
            ├── lodash.isarguments@3.1.0 extraneous
            ├── lodash.isboolean@3.0.3 extraneous
            ├── lodash.isequal@4.5.0 extraneous
            ├── lodash.isinteger@4.0.4 extraneous
            ├── lodash.isnumber@3.0.3 extraneous
            ├── lodash.isplainobject@4.0.6 extraneous
            ├── lodash.isstring@4.0.1 extraneous
            ├── lodash.once@4.1.1 extraneous
            ├── lodash.zip@4.2.0 extraneous
            ├── log-symbols@4.1.0 extraneous
            ├── log-update@2.3.0 extraneous
            ├── logform@ extraneous
            ├── long@5.2.3 extraneous
            ├── lowercase-keys@2.0.0 extraneous
            ├── lru_map@0.3.3 extraneous
            ├── lru-cache@6.0.0 extraneous
            ├── make-dir@3.1.0 extraneous
            ├── make-fetch-happen@10.2.1 extraneous
            ├── map-age-cleaner@0.1.3 extraneous
            ├── map-obj@4.3.0 extraneous
            ├── map-stream@0.0.7 extraneous
            ├── md5@2.3.0 extraneous
            ├── media-typer@0.3.0 extraneous
            ├── meow@8.1.2 extraneous
            ├── merge-descriptors@1.0.1 extraneous
            ├── merge2@1.4.1 extraneous
            ├── methods@1.1.2 extraneous
            ├── micro@9.4.1 extraneous
            ├── micromatch@4.0.7 extraneous
            ├── mime-db@1.53.0 extraneous
            ├── mimic-response@1.0.1 extraneous
            ├── min-indent@1.0.1 extraneous
            ├── minimatch@9.0.5 extraneous
            ├── minimist-options@4.1.0 extraneous
            ├── minipass-collect@1.0.2 extraneous
            ├── minipass-fetch@2.1.2 extraneous
            ├── minipass-flush@1.0.5 extraneous
            ├── minipass-pipeline@1.2.4 extraneous
            ├── minipass-sized@1.0.3 extraneous
            ├── minipass@7.1.2 extraneous
            ├── minizlib@2.1.2 extraneous
            ├── mkdirp-classic@0.5.3 extraneous
            ├── mkdirp@1.0.4 extraneous
            ├── mock-require@3.0.3 extraneous
            ├── moment-duration-format@2.3.2 extraneous
            ├── mqtt-connection@4.1.0 extraneous
            ├── mqtt-packet@9.0.0 extraneous
            ├── mqtt@ extraneous
            ├── mute-stream@0.0.8 extraneous
            ├── named-placeholders@1.1.3 extraneous
            ├── nan@ extraneous
            ├── nanoid@3.3.7 extraneous
            ├── napi-build-utils@1.0.2 extraneous
            ├── native-duplexpair@1.0.0 extraneous
            ├── nconf@0.10.0 extraneous
            ├── nested-property@4.0.0 extraneous
            ├── netmask@2.0.2 extraneous
            ├── new-github-release-url@1.0.0 extraneous
            ├── node-abi@3.65.0 extraneous
            ├── node-abort-controller@3.1.1 extraneous
            ├── node-cron@2.0.3 extraneous
            ├── node-fetch@2.7.0 extraneous
            ├── node-forge@ extraneous
            ├── node-gyp@ extraneous
            ├── node-ical@0.16.1 extraneous
            ├── node-inspect@2.0.0 extraneous
            ├── node-libcurl@3.0.0 extraneous
            ├── node-mndp@0.0.3 extraneous
            ├── node-persist@0.0.11 extraneous
            ├── node-rsa@1.1.1 extraneous
            ├── node-unifi@2.5.1 extraneous
            ├── node-wol@0.1.1 extraneous
            ├── node.extend@2.0.3 extraneous
            ├── nopt@5.0.0 extraneous
            ├── normalize-package-data@3.0.3 extraneous
            ├── normalize-path@3.0.0 extraneous
            ├── normalize-url@6.1.0 extraneous
            ├── np@7.7.0 extraneous
            ├── npm-name@6.0.1 extraneous
            ├── npmlog@5.0.1 extraneous
            ├── number-allocator@1.0.14 extraneous
            ├── nwsapi@2.2.12 extraneous
            ├── object-assign@4.1.1 extraneous
            ├── object-hash@3.0.0 extraneous
            ├── on-finished@2.4.1 extraneous
            ├── once@1.4.0 extraneous
            ├── one-time@1.0.0 extraneous
            ├── onedrive-api@1.1.1 extraneous
            ├── open@7.4.2 extraneous
            ├── opencollective-postinstall@2.0.3 extraneous
            ├── optionator@0.8.3 extraneous
            ├── org-regex@1.0.0 extraneous
            ├── os-tmpdir@1.0.2 extraneous
            ├── ospath@1.2.2 extraneous
            ├── osx-temperature-sensor@ extraneous
            ├── otplib@11.0.1 extraneous
            ├── ow@0.21.0 extraneous
            ├── p-cancelable@2.1.1 extraneous
            ├── p-defer@1.0.0 extraneous
            ├── p-event@4.2.0 extraneous
            ├── p-finally@1.0.0 extraneous
            ├── p-limit@2.3.0 extraneous
            ├── p-locate@5.0.0 extraneous
            ├── p-map@2.1.0 extraneous
            ├── p-memoize@4.0.4 extraneous
            ├── p-reflect@2.1.0 extraneous
            ├── p-settle@4.1.1 extraneous
            ├── p-throttle@4.1.1 extraneous
            ├── p-timeout@4.1.0 extraneous
            ├── p-try@2.2.0 extraneous
            ├── package-json-from-dist@1.0.0 extraneous
            ├── package-json@6.5.0 extraneous
            ├── pako@ extraneous
            ├── parent-module@1.0.1 extraneous
            ├── parse-json@5.2.0 extraneous
            ├── parse5@ extraneous
            ├── passport-local@1.0.0 extraneous
            ├── passport@0.7.0 extraneous
            ├── path-exists@4.0.0 extraneous
            ├── path-is-absolute@1.0.1 extraneous
            ├── path-parse@1.0.7 extraneous
            ├── path-posix@1.0.0 extraneous
            ├── path-scurry@1.11.1 extraneous
            ├── path-to-regexp@0.1.7 extraneous
            ├── path-type@4.0.0 extraneous
            ├── pause-stream@0.0.11 extraneous
            ├── picomatch@2.3.1 extraneous
            ├── pidtree@0.6.0 extraneous
            ├── pidusage@3.0.2 extraneous
            ├── ping@0.4.4 extraneous
            ├── pkg-dir@5.0.0 extraneous
            ├── pluralize@8.0.0 extraneous
            ├── possible-typed-array-names@1.0.0 extraneous
            ├── prebuild-install@7.1.2 extraneous
            ├── prelude-ls@1.1.2 extraneous
            ├── prepend-http@2.0.0 extraneous
            ├── process-nextick-args@2.0.1 extraneous
            ├── process@0.11.10 extraneous
            ├── promise-inflight@1.0.1 extraneous
            ├── promise-object@0.1.7 extraneous
            ├── promise-retry@2.0.1 extraneous
            ├── promise-retryer@0.0.1 extraneous
            ├── promisify-child-process@4.1.2 extraneous
            ├── prompt@1.3.0 extraneous
            ├── protobufjs@ extraneous
            ├── proxy-addr@2.0.7 extraneous
            ├── proxy-from-env@1.1.0 extraneous
            ├── pump@3.0.0 extraneous
            ├── pupa@2.1.1 extraneous
            ├── q@1.1.2 extraneous
            ├── quasar@ extraneous
            ├── queue-microtask@1.2.3 extraneous
            ├── queue-tick@1.0.1 extraneous
            ├── quick-lru@5.1.1 extraneous
            ├── range-parser@1.2.1 extraneous
            ├── raw-body@2.5.2 extraneous
            ├── rc@1.2.8 extraneous
            ├── read-pkg-up@7.0.1 extraneous
            ├── read-pkg@5.2.0 extraneous
            ├── read@1.0.7 extraneous
            ├── readable-stream@ extraneous
            ├── readdir-glob@1.1.3 extraneous
            ├── readdirp@3.6.0 extraneous
            ├── readline-sync@1.4.10 extraneous
            ├── readline@1.3.0 extraneous
            ├── redent@3.0.0 extraneous
            ├── redis-commands@1.7.0 extraneous
            ├── redis-errors@1.2.0 extraneous
            ├── redis-parser@3.0.0 extraneous
            ├── regenerator-runtime@0.14.1 extraneous
            ├── regex-escape@3.4.10 extraneous
            ├── regexp.prototype.flags@1.5.2 extraneous
            ├── registry-auth-token@4.2.2 extraneous
            ├── registry-url@5.1.0 extraneous
            ├── reinterval@1.1.0 extraneous
            ├── remove-trailing-separator@1.1.0 extraneous
            ├── require-from-string@2.0.2 extraneous
            ├── resolve-alpn@1.2.1 extraneous
            ├── resolve-cwd@3.0.0 extraneous
            ├── resolve-from@4.0.0 extraneous
            ├── respjs@4.2.0 extraneous
            ├── responselike@2.0.1 extraneous
            ├── restore-cursor@3.1.0 extraneous
            ├── retry-axios@2.6.0 extraneous
            ├── retry@0.12.0 extraneous
            ├── reusify@1.0.4 extraneous
            ├── revalidator@0.1.8 extraneous
            ├── rfdc@1.4.1 extraneous
            ├── rimraf@3.0.2 extraneous
            ├── rrule@2.8.1 extraneous
            ├── rrweb-cssom@0.6.0 extraneous
            ├── run-async@2.4.1 extraneous
            ├── run-parallel@1.2.0 extraneous
            ├── rxjs@ extraneous
            ├── safe-array-concat@1.1.2 extraneous
            ├── safe-regex-test@1.0.3 extraneous
            ├── safe-stable-stringify@2.4.3 extraneous
            ├── safer-buffer@2.1.2 extraneous
            ├── saxes@6.0.0 extraneous
            ├── scoped-regex@2.1.0 extraneous
            ├── secure-keys@1.0.0 extraneous
            ├── semver-diff@3.1.1 extraneous
            ├── semver@5.7.2
            ├── send@0.18.0 extraneous
            ├── seq-logging@1.1.2 extraneous
            ├── seq-queue@0.0.5 extraneous
            ├── serve-static@1.15.0 extraneous
            ├── set-function-name@2.0.2 extraneous
            ├── setimmediate@1.0.5 extraneous
            ├── setprototypeof@1.2.0 extraneous
            ├── signal-exit@4.1.0 extraneous
            ├── simple-concat@1.0.1 extraneous
            ├── simple-get@3.1.1 extraneous
            ├── simple-ssh@1.1.1 extraneous
            ├── simple-swizzle@0.2.2 extraneous
            ├── slash@3.0.0 extraneous
            ├── slice-ansi@0.0.4 extraneous
            ├── smart-buffer@4.2.0 extraneous
            ├── socks-proxy-agent@7.0.0 extraneous
            ├── socks@2.8.3 extraneous
            ├── speedtest-net@1.6.2 extraneous
            ├── split@1.0.1 extraneous
            ├── sprintf-js@1.1.3 extraneous
            ├── sqlstring@2.3.3 extraneous
            ├── ssh2@ extraneous
            ├── ssri@9.0.1 extraneous
            ├── stack-trace@0.0.10 extraneous
            ├── stampit-event-bus@0.1.1 extraneous
            ├── stampit-state-machine@0.2.1 extraneous
            ├── stampit@2.1.2 extraneous
            ├── standard-as-callback@2.1.0 extraneous
            ├── static-eval@2.0.2 extraneous
            ├── statuses@2.0.1 extraneous
            ├── stoppable@1.1.0 extraneous
            ├── stream-combiner@0.2.2 extraneous
            ├── stream-shift@1.0.3 extraneous
            ├── streamsearch@1.1.0 extraneous
            ├── streamx@2.18.0 extraneous
            ├── string-argv@0.3.2 extraneous
            ├── string-width-cjs@npm:string-width@4.2.3 extraneous
            ├── string-width@5.1.2 extraneous
            ├── string.prototype.trim@1.2.9 extraneous
            ├── string.prototype.trimend@1.0.8 extraneous
            ├── string.prototype.trimstart@1.0.8 extraneous
            ├── strip-ansi-cjs@npm:strip-ansi@6.0.1 extraneous
            ├── strip-ansi@6.0.1 extraneous
            ├── strip-indent@3.0.0 extraneous
            ├── strip-json-comments@2.0.1 extraneous
            ├── strnum@1.0.5 extraneous
            ├── suncalc@1.9.0 extraneous
            ├── suncalc2@1.8.1 extraneous
            ├── supermixer@1.0.5 extraneous
            ├── supports-color@7.2.0 extraneous
            ├── supports-hyperlinks@2.3.0 extraneous
            ├── supports-preserve-symlinks-flag@1.0.0 extraneous
            ├── sweet-collections@1.1.0 extraneous
            ├── symbol-observable@3.0.0 extraneous
            ├── symbol-tree@3.2.4 extraneous
            ├── syno@ extraneous
            ├── systeminformation@ extraneous
            ├── tar-fs@2.1.1 extraneous
            ├── tar-stream@3.1.7 extraneous
            ├── tar@6.2.1 extraneous
            ├── tarn@3.0.2 extraneous
            ├── tcp-port-used@1.0.2 extraneous
            ├── tedious@ extraneous
            ├── terminal-link@2.1.1 extraneous
            ├── text-decoder@1.1.1 extraneous
            ├── text-hex@1.0.0 extraneous
            ├── thirty-two@1.0.2 extraneous
            ├── through@2.3.8 extraneous
            ├── through2@2.0.5 extraneous
            ├── tiny-typed-emitter@2.1.0 extraneous
            ├── tinycolor2@1.6.0 extraneous
            ├── tmp@0.0.33 extraneous
            ├── to-readable-stream@2.1.0 extraneous
            ├── to-regex-range@5.0.1 extraneous
            ├── toidentifier@1.0.1 extraneous
            ├── tr46@4.1.1 extraneous
            ├── trim-newlines@3.0.1 extraneous
            ├── triple-beam@1.4.1 extraneous
            ├── tsdav@ extraneous
            ├── tslib@2.3.0 extraneous
            ├── tweetnacl@0.14.5 extraneous
            ├── type-check@0.3.2 extraneous
            ├── type-fest@0.21.3 extraneous
            ├── type-is@1.6.18 extraneous
            ├── typed-array-buffer@1.0.2 extraneous
            ├── typed-array-byte-length@1.0.1 extraneous
            ├── typed-array-byte-offset@1.0.2 extraneous
            ├── typed-array-length@1.0.6 extraneous
            ├── typedarray-to-buffer@3.1.5 extraneous
            ├── typedarray.prototype.slice@1.0.3 extraneous
            ├── typescript@ extraneous
            ├── tz-offset@0.0.1 extraneous
            ├── uid-number@0.0.6 extraneous
            ├── unbox-primitive@1.0.2 extraneous
            ├── undici-types@6.19.6 extraneous
            ├── unique-filename@2.0.1 extraneous
            ├── unique-slug@3.0.0 extraneous
            ├── unique-string@2.0.0 extraneous
            ├── unix-dgram@2.0.6 extraneous
            ├── unpipe@1.0.0 extraneous
            ├── update-notifier@5.1.0 extraneous
            ├── uri-js@4.4.1 extraneous
            ├── url-join@4.0.1 extraneous
            ├── url-parse-lax@3.0.0 extraneous
            ├── url-template@2.0.8 extraneous
            ├── url@0.11.4 extraneous
            ├── vali-date@1.0.0 extraneous
            ├── validate-npm-package-name@3.0.0 extraneous
            ├── vary@1.1.2 extraneous
            ├── virtual-tsc@0.6.2 extraneous
            ├── vue-i18n@ extraneous
            ├── vuelidate-messages@0.1.2 extraneous
            ├── vuelidate@ extraneous
            ├── vuex-map-fields@1.4.1 extraneous
            ├── w3c-xmlserializer@4.0.0 extraneous
            ├── wake_on_lan@1.0.0 extraneous
            ├── weak-daemon@1.0.3 extraneous
            ├── webdav@ extraneous
            ├── webidl-conversions@7.0.0 extraneous
            ├── websocket-stream@5.5.2 extraneous
            ├── whatwg-encoding@2.0.0 extraneous
            ├── whatwg-mimetype@3.0.0 extraneous
            ├── whatwg-url@12.0.1 extraneous
            ├── which-boxed-primitive@1.0.2 extraneous
            ├── which-typed-array@1.1.15 extraneous
            ├── wide-align@1.1.5 extraneous
            ├── widest-line@3.1.0 extraneous
            ├── window-size@0.1.4 extraneous
            ├── winston-daily-rotate-file@5.0.0 extraneous
            ├── winston-seq-updated@1.0.4 extraneous
            ├── winston-syslog@2.7.1 extraneous
            ├── winston-transport@4.7.1 extraneous
            ├── winston@ extraneous
            ├── word-wrap@1.2.5 extraneous
            ├── worker-timers-broker@6.1.8 extraneous
            ├── worker-timers-worker@7.0.71 extraneous
            ├── worker-timers@7.1.8 extraneous
            ├── wrap-ansi-cjs@npm:wrap-ansi@7.0.0 extraneous
            ├── wrap-ansi@8.1.0 extraneous
            ├── wrappy@1.0.2 extraneous
            ├── write-file-atomic@3.0.3 extraneous
            ├── xdg-basedir@4.0.0 extraneous
            ├── xml-js@1.6.11 extraneous
            ├── xml-name-validator@4.0.0 extraneous
            ├── xmlchars@2.2.0 extraneous
            ├── xregexp@2.0.0 extraneous
            ├── yallist@4.0.0 extraneous
            ├── yaml@ extraneous
            ├── yargs-parser@20.2.9 extraneous
            ├── yargs@7.1.2
            ├── yocto-queue@0.1.0 extraneous
            ├── zip-stream@6.0.1 extraneous
            └── zrender@ extraneous
              flommaster @flommaster last edited by
              Teil 2
              npm error code ELSPROBLEMS
              npm error extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
              npm error extraneous: @alcalzone/jsonl-db@3.1.1 /opt/iobroker/node_modules/@alcalzone/jsonl-db
              npm error extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/@alcalzone/pak
              npm error extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
              npm error extraneous: @aws-sdk/util-utf8-browser@3.259.0 /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser
              npm error extraneous: @azure/abort-controller@1.1.0 /opt/iobroker/node_modules/@azure/abort-controller
              npm error extraneous: @azure/core-auth@1.7.2 /opt/iobroker/node_modules/@azure/core-auth
              npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
              npm error extraneous: @azure/core-http-compat@ /opt/iobroker/node_modules/@azure/core-http-compat
              npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
              npm error extraneous: @azure/core-paging@1.6.2 /opt/iobroker/node_modules/@azure/core-paging
              npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
              npm error extraneous: @azure/core-tracing@1.1.2 /opt/iobroker/node_modules/@azure/core-tracing
              npm error extraneous: @azure/core-util@ /opt/iobroker/node_modules/@azure/core-util
              npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
              npm error extraneous: @azure/keyvault-keys@ /opt/iobroker/node_modules/@azure/keyvault-keys
              npm error extraneous: @azure/logger@1.1.4 /opt/iobroker/node_modules/@azure/logger
              npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
              npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
              npm error extraneous: @azure/msal-node@1.18.4 /opt/iobroker/node_modules/@azure/msal-node
              npm error extraneous: @babel/code-frame@7.24.7 /opt/iobroker/node_modules/@babel/code-frame
              npm error extraneous: @babel/helper-validator-identifier@7.24.7 /opt/iobroker/node_modules/@babel/helper-validator-identifier
              npm error extraneous: @babel/highlight@7.24.7 /opt/iobroker/node_modules/@babel/highlight
              npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
              npm error extraneous: @colors/colors@1.5.0 /opt/iobroker/node_modules/@colors/colors
              npm error extraneous: @dabh/diagnostics@2.0.3 /opt/iobroker/node_modules/@dabh/diagnostics
              npm error extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
              npm error extraneous: @gar/promisify@1.1.3 /opt/iobroker/node_modules/@gar/promisify
              npm error extraneous: @googleapis/calendar@9.7.7 /opt/iobroker/node_modules/@googleapis/calendar
              npm error extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
              npm error extraneous: @googleapis/oauth2@1.0.7 /opt/iobroker/node_modules/@googleapis/oauth2
              npm error extraneous: @httptoolkit/websocket-stream@6.0.1 /opt/iobroker/node_modules/@httptoolkit/websocket-stream
              npm error extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
              npm error extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
              npm error extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
              npm error extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
              npm error extraneous: @iobroker/db-states-file@ /opt/iobroker/node_modules/@iobroker/db-states-file
              npm error extraneous: @iobroker/db-states-jsonl@ /opt/iobroker/node_modules/@iobroker/db-states-jsonl
              npm error extraneous: @iobroker/db-states-redis@ /opt/iobroker/node_modules/@iobroker/db-states-redis
              npm error extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
              npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
              npm error extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modules/@iobroker/js-controller-common-db
              npm error extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
              npm error extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
              npm error extraneous: @iobroker/plugin-sentry@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-sentry
              npm error extraneous: @iobroker/socket-classes@1.5.6 /opt/iobroker/node_modules/@iobroker/socket-classes
              npm error extraneous: @iobroker/webserver@1.0.3 /opt/iobroker/node_modules/@iobroker/webserver
              npm error extraneous: @isaacs/cliui@8.0.2 /opt/iobroker/node_modules/@isaacs/cliui
              npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
              npm error extraneous: @mapbox/node-pre-gyp@1.0.11 /opt/iobroker/node_modules/@mapbox/node-pre-gyp
              npm error extraneous: @microsoft/microsoft-graph-types@2.40.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
              npm error extraneous: @nodelib/fs.scandir@2.1.5 /opt/iobroker/node_modules/@nodelib/fs.scandir
              npm error extraneous: @nodelib/fs.stat@2.0.5 /opt/iobroker/node_modules/@nodelib/fs.stat
              npm error extraneous: @nodelib/fs.walk@1.2.8 /opt/iobroker/node_modules/@nodelib/fs.walk
              npm error extraneous: @npmcli/fs@2.1.2 /opt/iobroker/node_modules/@npmcli/fs
              npm error extraneous: @npmcli/move-file@2.0.1 /opt/iobroker/node_modules/@npmcli/move-file
              npm error extraneous: @pkgjs/parseargs@0.11.0 /opt/iobroker/node_modules/@pkgjs/parseargs
              npm error extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
              npm error extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
              npm error extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
              npm error extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
              npm error extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
              npm error extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
              npm error extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
              npm error extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
              npm error extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
              npm error extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
              npm error extraneous: @quasar/extras@ /opt/iobroker/node_modules/@quasar/extras
              npm error extraneous: @samverschueren/stream-to-observable@0.3.1 /opt/iobroker/node_modules/@samverschueren/stream-to-observable
              npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
              npm error extraneous: @sentry/core@5.30.0 /opt/iobroker/node_modules/@sentry/core
              npm error extraneous: @sentry/hub@5.30.0 /opt/iobroker/node_modules/@sentry/hub
              npm error extraneous: @sentry/minimal@5.30.0 /opt/iobroker/node_modules/@sentry/minimal
              npm error extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
              npm error extraneous: @sentry/tracing@ /opt/iobroker/node_modules/@sentry/tracing
              npm error extraneous: @sentry/types@ /opt/iobroker/node_modules/@sentry/types
              npm error extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
              npm error extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/@sindresorhus/is
              npm error extraneous: @socket.io/component-emitter@3.1.2 /opt/iobroker/node_modules/@socket.io/component-emitter
              npm error extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/@szmarczak/http-timer
              npm error extraneous: @tediousjs/connection-string@0.5.0 /opt/iobroker/node_modules/@tediousjs/connection-string
              npm error extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
              npm error extraneous: @types/bl@5.1.0 /opt/iobroker/node_modules/@types/bl
              npm error extraneous: @types/cacheable-request@6.0.3 /opt/iobroker/node_modules/@types/cacheable-request
              npm error extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
              npm error extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/@types/cookie
              npm error extraneous: @types/cors@2.8.17 /opt/iobroker/node_modules/@types/cors
              npm error extraneous: @types/geojson@7946.0.14 /opt/iobroker/node_modules/@types/geojson
              npm error extraneous: @types/http-cache-semantics@4.0.4 /opt/iobroker/node_modules/@types/http-cache-semantics
              npm error extraneous: @types/keyv@3.1.4 /opt/iobroker/node_modules/@types/keyv
              npm error extraneous: @types/leaflet@1.9.12 /opt/iobroker/node_modules/@types/leaflet
              npm error extraneous: @types/minimist@1.2.5 /opt/iobroker/node_modules/@types/minimist
              npm error extraneous: @types/node-cron@2.0.8 /opt/iobroker/node_modules/@types/node-cron
              npm error extraneous: @types/node@ /opt/iobroker/node_modules/@types/node
              npm error extraneous: @types/normalize-package-data@2.4.4 /opt/iobroker/node_modules/@types/normalize-package-data
              npm error extraneous: @types/parse-json@4.0.2 /opt/iobroker/node_modules/@types/parse-json
              npm error extraneous: @types/readable-stream@4.0.15 /opt/iobroker/node_modules/@types/readable-stream
              npm error extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
              npm error extraneous: @types/responselike@1.0.3 /opt/iobroker/node_modules/@types/responselike
              npm error extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
              npm error extraneous: @types/triple-beam@1.3.5 /opt/iobroker/node_modules/@types/triple-beam
              npm error extraneous: @types/tz-offset@0.0.3 /opt/iobroker/node_modules/@types/tz-offset
              npm error extraneous: @types/ws@8.5.12 /opt/iobroker/node_modules/@types/ws
              npm error extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
              npm error extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
              npm error extraneous: abort-controller@3.0.0 /opt/iobroker/node_modules/abort-controller
              npm error extraneous: agentkeepalive@4.5.0 /opt/iobroker/node_modules/agentkeepalive
              npm error extraneous: aggregate-error@3.1.0 /opt/iobroker/node_modules/aggregate-error
              npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
              npm error extraneous: ansi-align@3.0.1 /opt/iobroker/node_modules/ansi-align
              npm error extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/ansi-colors
              npm error extraneous: ansi-escapes@4.3.2 /opt/iobroker/node_modules/ansi-escapes
              npm error extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/ansi-regex
              npm error extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/ansi-styles
              npm error extraneous: any-observable@0.5.1 /opt/iobroker/node_modules/any-observable
              npm error extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
              npm error extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
              npm error extraneous: archiver-utils@5.0.2 /opt/iobroker/node_modules/archiver-utils
              npm error extraneous: archiver@7.0.1 /opt/iobroker/node_modules/archiver
              npm error extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
              npm error extraneous: arg@4.1.0 /opt/iobroker/node_modules/arg
              npm error extraneous: argparse@1.0.10 /opt/iobroker/node_modules/argparse
              npm error extraneous: array-buffer-byte-length@1.0.1 /opt/iobroker/node_modules/array-buffer-byte-length
              npm error extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/array-flatten
              npm error extraneous: array-union@2.1.0 /opt/iobroker/node_modules/array-union
              npm error extraneous: arraybuffer.prototype.slice@1.0.3 /opt/iobroker/node_modules/arraybuffer.prototype.slice
              npm error extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
              npm error extraneous: asn1@0.2.6 /opt/iobroker/node_modules/asn1
              npm error extraneous: async-exit-hook@2.0.1 /opt/iobroker/node_modules/async-exit-hook
              npm error extraneous: authenticate-pam@1.0.5 /opt/iobroker/node_modules/authenticate-pam
              npm error extraneous: available-typed-arrays@1.0.7 /opt/iobroker/node_modules/available-typed-arrays
              npm error extraneous: aws-crt@ /opt/iobroker/node_modules/aws-crt
              npm error extraneous: b4a@1.6.6 /opt/iobroker/node_modules/b4a
              npm error extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/balanced-match
              npm error extraneous: bare-events@2.4.2 /opt/iobroker/node_modules/bare-events
              npm error extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
              npm error extraneous: base64-js@1.5.1 /opt/iobroker/node_modules/base64-js
              npm error extraneous: bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/bcrypt-pbkdf
              npm error extraneous: binary-extensions@2.3.0 /opt/iobroker/node_modules/binary-extensions
              npm error extraneous: bindings@1.5.0 /opt/iobroker/node_modules/bindings
              npm error extraneous: bl@6.0.14 /opt/iobroker/node_modules/bl
              npm error extraneous: bluebird@3.7.2 /opt/iobroker/node_modules/bluebird
              npm error extraneous: body-parser@1.20.2 /opt/iobroker/node_modules/body-parser
              npm error extraneous: bottleneck@2.19.5 /opt/iobroker/node_modules/bottleneck
              npm error extraneous: boxen@5.1.2 /opt/iobroker/node_modules/boxen
              npm error extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/brace-expansion
              npm error extraneous: braces@3.0.3 /opt/iobroker/node_modules/braces
              npm error extraneous: buffer-crc32@1.0.0 /opt/iobroker/node_modules/buffer-crc32
              npm error extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
              npm error extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
              npm error extraneous: buffer@6.0.3 /opt/iobroker/node_modules/buffer
              npm error extraneous: buildcheck@0.0.6 /opt/iobroker/node_modules/buildcheck
              npm error extraneous: builtins@1.0.3 /opt/iobroker/node_modules/builtins
              npm error extraneous: busboy@1.6.0 /opt/iobroker/node_modules/busboy
              npm error extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
              npm error extraneous: bytes@3.1.2 /opt/iobroker/node_modules/bytes
              npm error extraneous: cacache@16.1.3 /opt/iobroker/node_modules/cacache
              npm error extraneous: cacheable-lookup@5.0.4 /opt/iobroker/node_modules/cacheable-lookup
              npm error extraneous: cacheable-request@7.0.4 /opt/iobroker/node_modules/cacheable-request
              npm error extraneous: callsites@3.1.0 /opt/iobroker/node_modules/callsites
              npm error extraneous: camelcase-keys@6.2.2 /opt/iobroker/node_modules/camelcase-keys
              npm error extraneous: camelcase@5.3.1 /opt/iobroker/node_modules/camelcase
              npm error extraneous: capitalize@2.0.4 /opt/iobroker/node_modules/capitalize
              npm error extraneous: chalk@4.1.2 /opt/iobroker/node_modules/chalk
              npm error extraneous: chardet@0.7.0 /opt/iobroker/node_modules/chardet
              npm error extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
              npm error extraneous: chokidar@3.6.0 /opt/iobroker/node_modules/chokidar
              npm error extraneous: chownr@2.0.0 /opt/iobroker/node_modules/chownr
              npm error extraneous: ci-info@3.9.0 /opt/iobroker/node_modules/ci-info
              npm error extraneous: clean-stack@2.2.0 /opt/iobroker/node_modules/clean-stack
              npm error extraneous: cli-boxes@2.2.1 /opt/iobroker/node_modules/cli-boxes
              npm error extraneous: cli-cursor@3.1.0 /opt/iobroker/node_modules/cli-cursor
              npm error extraneous: cli-truncate@0.2.1 /opt/iobroker/node_modules/cli-truncate
              npm error extraneous: cli-width@3.0.0 /opt/iobroker/node_modules/cli-width
              npm error extraneous: clone-response@1.0.3 /opt/iobroker/node_modules/clone-response
              npm error extraneous: cloneextend@0.0.3 /opt/iobroker/node_modules/cloneextend
              npm error extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
              npm error extraneous: coap-packet@1.1.1 /opt/iobroker/node_modules/coap-packet
              npm error extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
              npm error extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/color-convert
              npm error extraneous: color-name@1.1.4 /opt/iobroker/node_modules/color-name
              npm error extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
              npm error extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
              npm error extraneous: color@3.2.1 /opt/iobroker/node_modules/color
              npm error extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
              npm error extraneous: commander@9.5.0 /opt/iobroker/node_modules/commander
              npm error extraneous: commist@3.2.0 /opt/iobroker/node_modules/commist
              npm error extraneous: compress-commons@6.0.2 /opt/iobroker/node_modules/compress-commons
              npm error extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
              npm error extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
              npm error extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
              npm error extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
              npm error extraneous: configstore@5.0.1 /opt/iobroker/node_modules/configstore
              npm error extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
              npm error extraneous: connect@3.7.0 /opt/iobroker/node_modules/connect
              npm error extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
              npm error extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/content-disposition
              npm error extraneous: content-type@1.0.5 /opt/iobroker/node_modules/content-type
              npm error extraneous: core-js@ /opt/iobroker/node_modules/core-js
              npm error extraneous: cors@2.8.5 /opt/iobroker/node_modules/cors
              npm error extraneous: cosmiconfig@7.1.0 /opt/iobroker/node_modules/cosmiconfig
              npm error extraneous: cpu-features@ /opt/iobroker/node_modules/cpu-features
              npm error extraneous: crc-32@1.2.2 /opt/iobroker/node_modules/crc-32
              npm error extraneous: crc@ /opt/iobroker/node_modules/crc
              npm error extraneous: crc32-stream@6.0.0 /opt/iobroker/node_modules/crc32-stream
              npm error extraneous: cross-fetch@4.0.0 /opt/iobroker/node_modules/cross-fetch
              npm error extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
              npm error extraneous: crypto-js@ /opt/iobroker/node_modules/crypto-js
              npm error extraneous: crypto-random-string@2.0.0 /opt/iobroker/node_modules/crypto-random-string
              npm error extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
              npm error extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
              npm error extraneous: dashdash@1.14.1 /opt/iobroker/node_modules/dashdash
              npm error extraneous: data-urls@4.0.0 /opt/iobroker/node_modules/data-urls
              npm error extraneous: data-view-buffer@1.0.1 /opt/iobroker/node_modules/data-view-buffer
              npm error extraneous: data-view-byte-length@1.0.1 /opt/iobroker/node_modules/data-view-byte-length
              npm error extraneous: data-view-byte-offset@1.0.0 /opt/iobroker/node_modules/data-view-byte-offset
              npm error extraneous: date-and-time@ /opt/iobroker/node_modules/date-and-time
              npm error extraneous: date-fns@1.30.1 /opt/iobroker/node_modules/date-fns
              npm error extraneous: dateformat@4.6.3 /opt/iobroker/node_modules/dateformat
              npm error extraneous: dayjs@ /opt/iobroker/node_modules/dayjs
              npm error extraneous: decache@4.6.2 /opt/iobroker/node_modules/decache
              npm error extraneous: decamelize-keys@1.1.1 /opt/iobroker/node_modules/decamelize-keys
              npm error extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
              npm error extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
              npm error extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
              npm error extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
              npm error extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is
              npm error extraneous: defer-to-connect@2.0.1 /opt/iobroker/node_modules/defer-to-connect
              npm error extraneous: define-lazy-prop@2.0.0 /opt/iobroker/node_modules/define-lazy-prop
              npm error extraneous: del@6.1.1 /opt/iobroker/node_modules/del
              npm error extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
              npm error extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
              npm error extraneous: destroy@1.2.0 /opt/iobroker/node_modules/destroy
              npm error extraneous: detect-libc@2.0.3 /opt/iobroker/node_modules/detect-libc
              npm error extraneous: diacritics@1.3.0 /opt/iobroker/node_modules/diacritics
              npm error extraneous: digest-header@1.1.0 /opt/iobroker/node_modules/digest-header
              npm error extraneous: dir-glob@3.0.1 /opt/iobroker/node_modules/dir-glob
              npm error extraneous: diskusage@1.2.0 /opt/iobroker/node_modules/diskusage
              npm error extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception
              npm error extraneous: dot-prop@6.0.1 /opt/iobroker/node_modules/dot-prop
              npm error extraneous: draftlog@1.0.13 /opt/iobroker/node_modules/draftlog
              npm error extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
              npm error extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
              npm error extraneous: duplexer3@0.1.5 /opt/iobroker/node_modules/duplexer3
              npm error extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/duplexify
              npm error extraneous: eastasianwidth@0.2.0 /opt/iobroker/node_modules/eastasianwidth
              npm error extraneous: ecc-jsbn@0.1.2 /opt/iobroker/node_modules/ecc-jsbn
              npm error extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
              npm error extraneous: echarts@ /opt/iobroker/node_modules/echarts
              npm error extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/ee-first
              npm error extraneous: elegant-spinner@1.0.1 /opt/iobroker/node_modules/elegant-spinner
              npm error extraneous: emoji-regex@9.2.2 /opt/iobroker/node_modules/emoji-regex
              npm error extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
              npm error extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/encodeurl
              npm error extraneous: encoding@0.1.13 /opt/iobroker/node_modules/encoding
              npm error extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/end-of-stream
              npm error extraneous: entities@4.5.0 /opt/iobroker/node_modules/entities
              npm error extraneous: err-code@2.0.3 /opt/iobroker/node_modules/err-code
              npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
              npm error extraneous: es-aggregate-error@1.0.13 /opt/iobroker/node_modules/es-aggregate-error
              npm error extraneous: es-object-atoms@1.0.0 /opt/iobroker/node_modules/es-object-atoms
              npm error extraneous: es-set-tostringtag@2.0.3 /opt/iobroker/node_modules/es-set-tostringtag
              npm error extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
              npm error extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
              npm error extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
              npm error extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
              npm error extraneous: escalade@3.1.2 /opt/iobroker/node_modules/escalade
              npm error extraneous: escape-goat@3.0.0 /opt/iobroker/node_modules/escape-goat
              npm error extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/escape-html
              npm error extraneous: escape-string-regexp@4.0.0 /opt/iobroker/node_modules/escape-string-regexp
              npm error extraneous: escodegen@1.14.3 /opt/iobroker/node_modules/escodegen
              npm error extraneous: esprima@1.2.2 /opt/iobroker/node_modules/esprima
              npm error extraneous: estraverse@4.3.0 /opt/iobroker/node_modules/estraverse
              npm error extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils
              npm error extraneous: etag@1.8.1 /opt/iobroker/node_modules/etag
              npm error extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
              npm error extraneous: event-target-shim@5.0.1 /opt/iobroker/node_modules/event-target-shim
              npm error extraneous: eventemitter2@6.4.9 /opt/iobroker/node_modules/eventemitter2
              npm error extraneous: events@3.3.0 /opt/iobroker/node_modules/events
              npm error extraneous: execa@5.1.1 /opt/iobroker/node_modules/execa
              npm error extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
              npm error extraneous: express-fileupload@1.5.1 /opt/iobroker/node_modules/express-fileupload
              npm error extraneous: express@4.19.2 /opt/iobroker/node_modules/express
              npm error extraneous: external-editor@3.1.0 /opt/iobroker/node_modules/external-editor
              npm error extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
              npm error extraneous: fast-fifo@1.3.2 /opt/iobroker/node_modules/fast-fifo
              npm error extraneous: fast-glob@ /opt/iobroker/node_modules/fast-glob
              npm error extraneous: fast-json-stable-stringify@2.1.0 /opt/iobroker/node_modules/fast-json-stable-stringify
              npm error extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein
              npm error extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
              npm error extraneous: fast-unique-numbers@ /opt/iobroker/node_modules/fast-unique-numbers
              npm error extraneous: fast-uri@3.0.1 /opt/iobroker/node_modules/fast-uri
              npm error extraneous: fast-xml-parser@ /opt/iobroker/node_modules/fast-xml-parser
              npm error extraneous: fastq@1.17.1 /opt/iobroker/node_modules/fastq
              npm error extraneous: fastseries@2.0.0 /opt/iobroker/node_modules/fastseries
              npm error extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
              npm error extraneous: figures@3.2.0 /opt/iobroker/node_modules/figures
              npm error extraneous: file-stream-rotator@0.6.1 /opt/iobroker/node_modules/file-stream-rotator
              npm error extraneous: file-type@10.11.0 /opt/iobroker/node_modules/file-type
              npm error extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
              npm error extraneous: fill-range@7.1.1 /opt/iobroker/node_modules/fill-range
              npm error extraneous: finalhandler@1.2.0 /opt/iobroker/node_modules/finalhandler
              npm error extraneous: find-up@5.0.0 /opt/iobroker/node_modules/find-up
              npm error extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
              npm error extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
              npm error extraneous: foreground-child@3.3.0 /opt/iobroker/node_modules/foreground-child
              npm error extraneous: form-data-encoder@2.1.4 /opt/iobroker/node_modules/form-data-encoder
              npm error extraneous: form-data@4.0.0 /opt/iobroker/node_modules/form-data
              npm error extraneous: forwarded@0.2.0 /opt/iobroker/node_modules/forwarded
              npm error extraneous: fresh@0.5.2 /opt/iobroker/node_modules/fresh
              npm error extraneous: from@0.1.7 /opt/iobroker/node_modules/from
              npm error extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
              npm error extraneous: fs-minipass@2.1.0 /opt/iobroker/node_modules/fs-minipass
              npm error extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
              npm error extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
              npm error extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
              npm error extraneous: function.prototype.name@1.1.6 /opt/iobroker/node_modules/function.prototype.name
              npm error extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
              npm error extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
              npm error extraneous: gauge@3.0.2 /opt/iobroker/node_modules/gauge
              npm error extraneous: gaxios@5.1.3 /opt/iobroker/node_modules/gaxios
              npm error extraneous: gcp-metadata@5.3.0 /opt/iobroker/node_modules/gcp-metadata
              npm error extraneous: generate-function@2.3.1 /opt/iobroker/node_modules/generate-function
              npm error extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ssl-certificate
              npm error extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/get-stream
              npm error extraneous: get-symbol-description@1.0.2 /opt/iobroker/node_modules/get-symbol-description
              npm error extraneous: getpass@0.1.7 /opt/iobroker/node_modules/getpass
              npm error extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
              npm error extraneous: github-url-from-git@1.5.0 /opt/iobroker/node_modules/github-url-from-git
              npm error extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/glob-parent
              npm error extraneous: glob@10.4.5 /opt/iobroker/node_modules/glob
              npm error extraneous: global-dirs@2.1.0 /opt/iobroker/node_modules/global-dirs
              npm error extraneous: globalthis@1.0.4 /opt/iobroker/node_modules/globalthis
              npm error extraneous: globby@11.1.0 /opt/iobroker/node_modules/globby
              npm error extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
              npm error extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
              npm error extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
              npm error extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
              npm error extraneous: googleapis@ /opt/iobroker/node_modules/googleapis
              npm error extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
              npm error extraneous: hard-rejection@2.1.0 /opt/iobroker/node_modules/hard-rejection
              npm error extraneous: has-ansi@2.0.0 /opt/iobroker/node_modules/has-ansi
              npm error extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
              npm error extraneous: has-flag@4.0.0 /opt/iobroker/node_modules/has-flag
              npm error extraneous: has-tostringtag@1.0.2 /opt/iobroker/node_modules/has-tostringtag
              npm error extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
              npm error extraneous: has-yarn@2.1.0 /opt/iobroker/node_modules/has-yarn
              npm error extraneous: he@1.2.0 /opt/iobroker/node_modules/he
              npm error extraneous: help-me@5.0.0 /opt/iobroker/node_modules/help-me
              npm error extraneous: homebridge-plugin-wrapper@ /opt/iobroker/node_modules/homebridge-plugin-wrapper
              npm error extraneous: hosted-git-info@3.0.8 /opt/iobroker/node_modules/hosted-git-info
              npm error extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
              npm error extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
              npm error extraneous: http-cache-semantics@4.1.1 /opt/iobroker/node_modules/http-cache-semantics
              npm error extraneous: http-errors@2.0.0 /opt/iobroker/node_modules/http-errors
              npm error extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
              npm error extraneous: http2-wrapper@1.0.3 /opt/iobroker/node_modules/http2-wrapper
              npm error extraneous: https@1.0.0 /opt/iobroker/node_modules/https
              npm error extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
              npm error extraneous: ical.js@ /opt/iobroker/node_modules/ical.js
              npm error extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/iconv-lite
              npm error extraneous: ieee754@1.2.1 /opt/iobroker/node_modules/ieee754
              npm error extraneous: ignore-walk@3.0.4 /opt/iobroker/node_modules/ignore-walk
              npm error extraneous: ignore@5.3.2 /opt/iobroker/node_modules/ignore
              npm error extraneous: image-type@4.1.0 /opt/iobroker/node_modules/image-type
              npm error extraneous: immediate@3.0.6 /opt/iobroker/node_modules/immediate
              npm error extraneous: import-fresh@3.3.0 /opt/iobroker/node_modules/import-fresh
              npm error extraneous: import-lazy@2.1.0 /opt/iobroker/node_modules/import-lazy
              npm error extraneous: import-local@3.2.0 /opt/iobroker/node_modules/import-local
              npm error extraneous: imurmurhash@0.1.4 /opt/iobroker/node_modules/imurmurhash
              npm error extraneous: indent-string@3.2.0 /opt/iobroker/node_modules/indent-string
              npm error extraneous: infer-owner@1.0.4 /opt/iobroker/node_modules/infer-owner
              npm error extraneous: inflight@1.0.6 /opt/iobroker/node_modules/inflight
              npm error extraneous: ini@1.3.7 /opt/iobroker/node_modules/ini
              npm error extraneous: inquirer-autosubmit-prompt@0.2.0 /opt/iobroker/node_modules/inquirer-autosubmit-prompt
              npm error extraneous: inquirer@7.3.3 /opt/iobroker/node_modules/inquirer
              npm error extraneous: int64-buffer@1.0.1 /opt/iobroker/node_modules/int64-buffer
              npm error extraneous: internal-slot@1.0.7 /opt/iobroker/node_modules/internal-slot
              npm error extraneous: iobroker-adapter-helpers@0.0.8 /opt/iobroker/node_modules/iobroker-adapter-helpers
              npm error invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
              npm error invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
              npm error invalid: iobroker.calendar@ /opt/iobroker/node_modules/iobroker.calendar
              npm error invalid: iobroker.discovery@ /opt/iobroker/node_modules/iobroker.discovery
              npm error invalid: iobroker.echarts@ /opt/iobroker/node_modules/iobroker.echarts
              npm error invalid: iobroker.energiefluss@ /opt/iobroker/node_modules/iobroker.energiefluss
              npm error invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
              npm error invalid: iobroker.fullcalendar@ /opt/iobroker/node_modules/iobroker.fullcalendar
              npm error invalid: iobroker.gartenbewaesserung@ /opt/iobroker/node_modules/iobroker.gartenbewaesserung
              npm error invalid: iobroker.ham@ /opt/iobroker/node_modules/iobroker.ham
              npm error invalid: iobroker.heatingcontrol@ /opt/iobroker/node_modules/iobroker.heatingcontrol
              npm error invalid: iobroker.ical@ /opt/iobroker/node_modules/iobroker.ical
              npm error invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
              npm error invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
              npm error invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
              npm error invalid: iobroker.material@ /opt/iobroker/node_modules/iobroker.material
              npm error invalid: iobroker.milight-smart-light@ /opt/iobroker/node_modules/iobroker.milight-smart-light
              npm error invalid: iobroker.mobile@ /opt/iobroker/node_modules/iobroker.mobile
              npm error invalid: iobroker.modbus@ /opt/iobroker/node_modules/iobroker.modbus
              npm error invalid: iobroker.mqtt@ /opt/iobroker/node_modules/iobroker.mqtt
              npm error invalid: iobroker.nina@ /opt/iobroker/node_modules/iobroker.nina
              npm error invalid: iobroker.renault@ /opt/iobroker/node_modules/iobroker.renault
              npm error invalid: iobroker.reolink@ /opt/iobroker/node_modules/iobroker.reolink
              npm error invalid: iobroker.schoolfree@ /opt/iobroker/node_modules/iobroker.schoolfree
              npm error invalid: iobroker.sourceanalytix@ /opt/iobroker/node_modules/iobroker.sourceanalytix
              npm error invalid: iobroker.synology@ /opt/iobroker/node_modules/iobroker.synology
              npm error invalid: iobroker.tankerkoenig@ /opt/iobroker/node_modules/iobroker.tankerkoenig
              npm error invalid: iobroker.terminal@ /opt/iobroker/node_modules/iobroker.terminal
              npm error invalid: iobroker.unifi@ /opt/iobroker/node_modules/iobroker.unifi
              npm error invalid: iobroker.viessmannapi@ /opt/iobroker/node_modules/iobroker.viessmannapi
              npm error invalid: iobroker.virtualpowermeter@ /opt/iobroker/node_modules/iobroker.virtualpowermeter
              npm error invalid: iobroker.vis-2-widgets-material@ /opt/iobroker/node_modules/iobroker.vis-2-widgets-material
              npm error invalid: iobroker.vis-2@ /opt/iobroker/node_modules/iobroker.vis-2
              npm error invalid: iobroker.vis-colorpicker@ /opt/iobroker/node_modules/iobroker.vis-colorpicker
              npm error invalid: iobroker.vis-hqwidgets@ /opt/iobroker/node_modules/iobroker.vis-hqwidgets
              npm error invalid: iobroker.vis-inventwo@ /opt/iobroker/node_modules/iobroker.vis-inventwo
              npm error invalid: iobroker.vis-materialdesign@ /opt/iobroker/node_modules/iobroker.vis-materialdesign
              npm error invalid: iobroker.vis-metro@ /opt/iobroker/node_modules/iobroker.vis-metro
              npm error invalid: iobroker.vis-timeandweather@ /opt/iobroker/node_modules/iobroker.vis-timeandweather
              npm error invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
              npm error invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
              npm error invalid: iobroker.vofo-speedtest@ /opt/iobroker/node_modules/iobroker.vofo-speedtest
              npm error invalid: iobroker.web-speedy@ /opt/iobroker/node_modules/iobroker.web-speedy
              npm error invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
              npm error invalid: iobroker.webcal@ /opt/iobroker/node_modules/iobroker.webcal
              npm error extraneous: ioredis@ /opt/iobroker/node_modules/ioredis
              npm error extraneous: ip-address@9.0.5 /opt/iobroker/node_modules/ip-address
              npm error extraneous: ip-regex@4.3.0 /opt/iobroker/node_modules/ip-regex
              npm error extraneous: ipaddr.js@2.2.0 /opt/iobroker/node_modules/ipaddr.js
              npm error extraneous: is-array-buffer@3.0.4 /opt/iobroker/node_modules/is-array-buffer
              npm error extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
              npm error extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
              npm error extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
              npm error extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
              npm error extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
              npm error extraneous: is-ci@2.0.0 /opt/iobroker/node_modules/is-ci
              npm error extraneous: is-core-module@2.15.0 /opt/iobroker/node_modules/is-core-module
              npm error extraneous: is-data-view@1.0.1 /opt/iobroker/node_modules/is-data-view
              npm error extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
              npm error extraneous: is-docker@2.2.1 /opt/iobroker/node_modules/is-docker
              npm error extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
              npm error extraneous: is-extglob@2.1.1 /opt/iobroker/node_modules/is-extglob
              npm error extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/is-fullwidth-code-point
              npm error extraneous: is-glob@4.0.3 /opt/iobroker/node_modules/is-glob
              npm error extraneous: is-installed-globally@0.3.2 /opt/iobroker/node_modules/is-installed-globally
              npm error extraneous: is-interactive@1.0.0 /opt/iobroker/node_modules/is-interactive
              npm error extraneous: is-lambda@1.0.1 /opt/iobroker/node_modules/is-lambda
              npm error extraneous: is-negative-zero@2.0.3 /opt/iobroker/node_modules/is-negative-zero
              npm error extraneous: is-npm@5.0.0 /opt/iobroker/node_modules/is-npm
              npm error extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
              npm error extraneous: is-number@7.0.0 /opt/iobroker/node_modules/is-number
              npm error extraneous: is-obj@2.0.0 /opt/iobroker/node_modules/is-obj
              npm error extraneous: is-observable@1.1.0 /opt/iobroker/node_modules/is-observable
              npm error extraneous: is-path-cwd@2.2.0 /opt/iobroker/node_modules/is-path-cwd
              npm error extraneous: is-path-inside@3.0.3 /opt/iobroker/node_modules/is-path-inside
              npm error extraneous: is-plain-obj@1.1.0 /opt/iobroker/node_modules/is-plain-obj
              npm error extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
              npm error extraneous: is-promise@2.2.2 /opt/iobroker/node_modules/is-promise
              npm error extraneous: is-property@1.0.2 /opt/iobroker/node_modules/is-property
              npm error extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
              npm error extraneous: is-scoped@2.1.0 /opt/iobroker/node_modules/is-scoped
              npm error extraneous: is-shared-array-buffer@1.0.3 /opt/iobroker/node_modules/is-shared-array-buffer
              npm error extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
              npm error extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
              npm error extraneous: is-typed-array@1.1.13 /opt/iobroker/node_modules/is-typed-array
              npm error extraneous: is-unicode-supported@0.1.0 /opt/iobroker/node_modules/is-unicode-supported
              npm error extraneous: is-url-superb@4.0.0 /opt/iobroker/node_modules/is-url-superb
              npm error extraneous: is-url@1.2.4 /opt/iobroker/node_modules/is-url
              npm error extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
              npm error extraneous: is-wsl@2.2.0 /opt/iobroker/node_modules/is-wsl
              npm error extraneous: is-yarn-global@0.3.0 /opt/iobroker/node_modules/is-yarn-global
              npm error extraneous: is@3.3.0 /opt/iobroker/node_modules/is
              npm error extraneous: is2@2.0.9 /opt/iobroker/node_modules/is2
              npm error extraneous: isomorphic-ws@4.0.1 /opt/iobroker/node_modules/isomorphic-ws
              npm error extraneous: issue-regex@3.1.0 /opt/iobroker/node_modules/issue-regex
              npm error extraneous: jackspeak@3.4.3 /opt/iobroker/node_modules/jackspeak
              npm error extraneous: js-md4@0.3.2 /opt/iobroker/node_modules/js-md4
              npm error extraneous: js-sdsl@4.3.0 /opt/iobroker/node_modules/js-sdsl
              npm error extraneous: js-tokens@4.0.0 /opt/iobroker/node_modules/js-tokens
              npm error extraneous: js-yaml@ /opt/iobroker/node_modules/js-yaml
              npm error extraneous: jsbi@4.3.0 /opt/iobroker/node_modules/jsbi
              npm error extraneous: jsbn@1.1.0 /opt/iobroker/node_modules/jsbn
              npm error extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
              npm error extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
              npm error extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/json-buffer
              npm error extraneous: json-logic-js@2.0.5 /opt/iobroker/node_modules/json-logic-js
              npm error extraneous: json-parse-even-better-errors@2.3.1 /opt/iobroker/node_modules/json-parse-even-better-errors
              npm error extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse
              npm error extraneous: json5@2.2.3 /opt/iobroker/node_modules/json5
              npm error extraneous: jsonata@ /opt/iobroker/node_modules/jsonata
              npm error extraneous: jsonc-parser@3.3.1 /opt/iobroker/node_modules/jsonc-parser
              npm error extraneous: jsonwebtoken@9.0.2 /opt/iobroker/node_modules/jsonwebtoken
              npm error extraneous: jszip@ /opt/iobroker/node_modules/jszip
              npm error extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
              npm error extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
              npm error extraneous: keyv@4.5.4 /opt/iobroker/node_modules/keyv
              npm error extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/kind-of
              npm error extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
              npm error extraneous: later@1.2.0 /opt/iobroker/node_modules/later
              npm error extraneous: latest-version@5.1.0 /opt/iobroker/node_modules/latest-version
              npm error extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
              npm error extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/lazystream
              npm error extraneous: leven@2.1.0 /opt/iobroker/node_modules/leven
              npm error extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn
              npm error extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
              npm error extraneous: lines-and-columns@1.2.4 /opt/iobroker/node_modules/lines-and-columns
              npm error extraneous: listr-input@0.2.1 /opt/iobroker/node_modules/listr-input
              npm error extraneous: listr-silent-renderer@1.1.1 /opt/iobroker/node_modules/listr-silent-renderer
              npm error extraneous: listr-update-renderer@0.5.0 /opt/iobroker/node_modules/listr-update-renderer
              npm error extraneous: listr-verbose-renderer@0.5.0 /opt/iobroker/node_modules/listr-verbose-renderer
              npm error extraneous: listr@0.14.3 /opt/iobroker/node_modules/listr
              npm error extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
              npm error extraneous: locate-path@6.0.0 /opt/iobroker/node_modules/locate-path
              npm error extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
              npm error extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
              npm error extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
              npm error extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
              npm error extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
              npm error extraneous: lodash.isequal@4.5.0 /opt/iobroker/node_modules/lodash.isequal
              npm error extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
              npm error extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
              npm error extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
              npm error extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
              npm error extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
              npm error extraneous: lodash.zip@4.2.0 /opt/iobroker/node_modules/lodash.zip
              npm error extraneous: log-symbols@4.1.0 /opt/iobroker/node_modules/log-symbols
              npm error extraneous: log-update@2.3.0 /opt/iobroker/node_modules/log-update
              npm error extraneous: logform@ /opt/iobroker/node_modules/logform
              npm error extraneous: long@5.2.3 /opt/iobroker/node_modules/long
              npm error extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/lowercase-keys
              npm error extraneous: lru_map@0.3.3 /opt/iobroker/node_modules/lru_map
              npm error extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/lru-cache
              npm error extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
              npm error extraneous: make-fetch-happen@10.2.1 /opt/iobroker/node_modules/make-fetch-happen
              npm error extraneous: map-age-cleaner@0.1.3 /opt/iobroker/node_modules/map-age-cleaner
              npm error extraneous: map-obj@4.3.0 /opt/iobroker/node_modules/map-obj
              npm error extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
              npm error extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
              npm error extraneous: media-typer@0.3.0 /opt/iobroker/node_modules/media-typer
              npm error extraneous: meow@8.1.2 /opt/iobroker/node_modules/meow
              npm error extraneous: merge-descriptors@1.0.1 /opt/iobroker/node_modules/merge-descriptors
              npm error extraneous: merge2@1.4.1 /opt/iobroker/node_modules/merge2
              npm error extraneous: methods@1.1.2 /opt/iobroker/node_modules/methods
              npm error extraneous: micro@9.4.1 /opt/iobroker/node_modules/micro
              npm error extraneous: micromatch@4.0.7 /opt/iobroker/node_modules/micromatch
              npm error extraneous: mime-db@1.53.0 /opt/iobroker/node_modules/mime-db
              npm error extraneous: mimic-response@1.0.1 /opt/iobroker/node_modules/mimic-response
              npm error extraneous: min-indent@1.0.1 /opt/iobroker/node_modules/min-indent
              npm error extraneous: minimatch@9.0.5 /opt/iobroker/node_modules/minimatch
              npm error extraneous: minimist-options@4.1.0 /opt/iobroker/node_modules/minimist-options
              npm error extraneous: minipass-collect@1.0.2 /opt/iobroker/node_modules/minipass-collect
              npm error extraneous: minipass-fetch@2.1.2 /opt/iobroker/node_modules/minipass-fetch
              npm error extraneous: minipass-flush@1.0.5 /opt/iobroker/node_modules/minipass-flush
              npm error extraneous: minipass-pipeline@1.2.4 /opt/iobroker/node_modules/minipass-pipeline
              npm error extraneous: minipass-sized@1.0.3 /opt/iobroker/node_modules/minipass-sized
              npm error extraneous: minipass@7.1.2 /opt/iobroker/node_modules/minipass
              npm error extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/minizlib
              npm error extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
              npm error extraneous: mkdirp@1.0.4 /opt/iobroker/node_modules/mkdirp
              npm error extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
              npm error extraneous: moment-duration-format@2.3.2 /opt/iobroker/node_modules/moment-duration-format
              npm error extraneous: mqtt-connection@4.1.0 /opt/iobroker/node_modules/mqtt-connection
              npm error extraneous: mqtt-packet@9.0.0 /opt/iobroker/node_modules/mqtt-packet
              npm error extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
              npm error extraneous: mute-stream@0.0.8 /opt/iobroker/node_modules/mute-stream
              npm error extraneous: named-placeholders@1.1.3 /opt/iobroker/node_modules/named-placeholders
              npm error extraneous: nan@ /opt/iobroker/node_modules/nan
              npm error extraneous: nanoid@3.3.7 /opt/iobroker/node_modules/nanoid
              npm error extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
              npm error extraneous: native-duplexpair@1.0.0 /opt/iobroker/node_modules/native-duplexpair
              npm error extraneous: nconf@0.10.0 /opt/iobroker/node_modules/nconf
              npm error extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
              npm error extraneous: netmask@2.0.2 /opt/iobroker/node_modules/netmask
              npm error extraneous: new-github-release-url@1.0.0 /opt/iobroker/node_modules/new-github-release-url
              npm error extraneous: node-abi@3.65.0 /opt/iobroker/node_modules/node-abi
              npm error extraneous: node-abort-controller@3.1.1 /opt/iobroker/node_modules/node-abort-controller
              npm error extraneous: node-cron@2.0.3 /opt/iobroker/node_modules/node-cron
              npm error extraneous: node-fetch@2.7.0 /opt/iobroker/node_modules/node-fetch
              npm error extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
              npm error extraneous: node-gyp@ /opt/iobroker/node_modules/node-gyp
              npm error extraneous: node-ical@0.16.1 /opt/iobroker/node_modules/node-ical
              npm error extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
              npm error extraneous: node-libcurl@3.0.0 /opt/iobroker/node_modules/node-libcurl
              npm error extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
              npm error extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
              npm error extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
              npm error extraneous: node-unifi@2.5.1 /opt/iobroker/node_modules/node-unifi
              npm error extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
              npm error extraneous: node.extend@2.0.3 /opt/iobroker/node_modules/node.extend
              npm error extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
              npm error extraneous: normalize-package-data@3.0.3 /opt/iobroker/node_modules/normalize-package-data
              npm error extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
              npm error extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/normalize-url
              npm error extraneous: np@7.7.0 /opt/iobroker/node_modules/np
              npm error extraneous: npm-name@6.0.1 /opt/iobroker/node_modules/npm-name
              npm error extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
              npm error extraneous: number-allocator@1.0.14 /opt/iobroker/node_modules/number-allocator
              npm error extraneous: nwsapi@2.2.12 /opt/iobroker/node_modules/nwsapi
              npm error extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assign
              npm error extraneous: object-hash@3.0.0 /opt/iobroker/node_modules/object-hash
              npm error extraneous: on-finished@2.4.1 /opt/iobroker/node_modules/on-finished
              npm error extraneous: once@1.4.0 /opt/iobroker/node_modules/once
              npm error extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
              npm error extraneous: onedrive-api@1.1.1 /opt/iobroker/node_modules/onedrive-api
              npm error extraneous: open@7.4.2 /opt/iobroker/node_modules/open
              npm error extraneous: opencollective-postinstall@2.0.3 /opt/iobroker/node_modules/opencollective-postinstall
              npm error extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator
              npm error extraneous: org-regex@1.0.0 /opt/iobroker/node_modules/org-regex
              npm error extraneous: os-tmpdir@1.0.2 /opt/iobroker/node_modules/os-tmpdir
              npm error extraneous: ospath@1.2.2 /opt/iobroker/node_modules/ospath
              npm error extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
              npm error extraneous: otplib@11.0.1 /opt/iobroker/node_modules/otplib
              npm error extraneous: ow@0.21.0 /opt/iobroker/node_modules/ow
              npm error extraneous: p-cancelable@2.1.1 /opt/iobroker/node_modules/p-cancelable
              npm error extraneous: p-defer@1.0.0 /opt/iobroker/node_modules/p-defer
              npm error extraneous: p-event@4.2.0 /opt/iobroker/node_modules/p-event
              npm error extraneous: p-finally@1.0.0 /opt/iobroker/node_modules/p-finally
              npm error extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/p-limit
              npm error extraneous: p-locate@5.0.0 /opt/iobroker/node_modules/p-locate
              npm error extraneous: p-map@2.1.0 /opt/iobroker/node_modules/p-map
              npm error extraneous: p-memoize@4.0.4 /opt/iobroker/node_modules/p-memoize
              npm error extraneous: p-reflect@2.1.0 /opt/iobroker/node_modules/p-reflect
              npm error extraneous: p-settle@4.1.1 /opt/iobroker/node_modules/p-settle
              npm error extraneous: p-throttle@4.1.1 /opt/iobroker/node_modules/p-throttle
              npm error extraneous: p-timeout@4.1.0 /opt/iobroker/node_modules/p-timeout
              npm error extraneous: p-try@2.2.0 /opt/iobroker/node_modules/p-try
              npm error extraneous: package-json-from-dist@1.0.0 /opt/iobroker/node_modules/package-json-from-dist
              npm error extraneous: package-json@6.5.0 /opt/iobroker/node_modules/package-json
              npm error extraneous: pako@ /opt/iobroker/node_modules/pako
              npm error extraneous: parent-module@1.0.1 /opt/iobroker/node_modules/parent-module
              npm error extraneous: parse-json@5.2.0 /opt/iobroker/node_modules/parse-json
              npm error extraneous: parse5@ /opt/iobroker/node_modules/parse5
              npm error extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
              npm error extraneous: passport@0.7.0 /opt/iobroker/node_modules/passport
              npm error extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/path-exists
              npm error extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
              npm error extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
              npm error extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
              npm error extraneous: path-scurry@1.11.1 /opt/iobroker/node_modules/path-scurry
              npm error extraneous: path-to-regexp@0.1.7 /opt/iobroker/node_modules/path-to-regexp
              npm error extraneous: path-type@4.0.0 /opt/iobroker/node_modules/path-type
              npm error extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
              npm error extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/picomatch
              npm error extraneous: pidtree@0.6.0 /opt/iobroker/node_modules/pidtree
              npm error extraneous: pidusage@3.0.2 /opt/iobroker/node_modules/pidusage
              npm error extraneous: ping@0.4.4 /opt/iobroker/node_modules/ping
              npm error extraneous: pkg-dir@5.0.0 /opt/iobroker/node_modules/pkg-dir
              npm error extraneous: pluralize@8.0.0 /opt/iobroker/node_modules/pluralize
              npm error extraneous: possible-typed-array-names@1.0.0 /opt/iobroker/node_modules/possible-typed-array-names
              npm error extraneous: prebuild-install@7.1.2 /opt/iobroker/node_modules/prebuild-install
              npm error extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls
              npm error extraneous: prepend-http@2.0.0 /opt/iobroker/node_modules/prepend-http
              npm error extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/process-nextick-args
              npm error extraneous: process@0.11.10 /opt/iobroker/node_modules/process
              npm error extraneous: promise-inflight@1.0.1 /opt/iobroker/node_modules/promise-inflight
              npm error extraneous: promise-object@0.1.7 /opt/iobroker/node_modules/promise-object
              npm error extraneous: promise-retry@2.0.1 /opt/iobroker/node_modules/promise-retry
              npm error extraneous: promise-retryer@0.0.1 /opt/iobroker/node_modules/promise-retryer
              npm error extraneous: promisify-child-process@4.1.2 /opt/iobroker/node_modules/promisify-child-process
              npm error extraneous: prompt@1.3.0 /opt/iobroker/node_modules/prompt
              npm error extraneous: protobufjs@ /opt/iobroker/node_modules/protobufjs
              npm error extraneous: proxy-addr@2.0.7 /opt/iobroker/node_modules/proxy-addr
              npm error extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
              npm error extraneous: pump@3.0.0 /opt/iobroker/node_modules/pump
              npm error extraneous: pupa@2.1.1 /opt/iobroker/node_modules/pupa
              npm error extraneous: q@1.1.2 /opt/iobroker/node_modules/q
              npm error extraneous: quasar@ /opt/iobroker/node_modules/quasar
              npm error extraneous: queue-microtask@1.2.3 /opt/iobroker/node_modules/queue-microtask
              npm error extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
              npm error extraneous: quick-lru@5.1.1 /opt/iobroker/node_modules/quick-lru
              npm error extraneous: range-parser@1.2.1 /opt/iobroker/node_modules/range-parser
              npm error extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/raw-body
              npm error extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
              npm error extraneous: read-pkg-up@7.0.1 /opt/iobroker/node_modules/read-pkg-up
              npm error extraneous: read-pkg@5.2.0 /opt/iobroker/node_modules/read-pkg
              npm error extraneous: read@1.0.7 /opt/iobroker/node_modules/read
              npm error extraneous: readable-stream@ /opt/iobroker/node_modules/readable-stream
              npm error extraneous: readdir-glob@1.1.3 /opt/iobroker/node_modules/readdir-glob
              npm error extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
              npm error extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
              npm error extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
              npm error extraneous: redent@3.0.0 /opt/iobroker/node_modules/redent
              npm error extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
              npm error extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
              npm error extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
              npm error extraneous: regenerator-runtime@0.14.1 /opt/iobroker/node_modules/regenerator-runtime
              npm error extraneous: regex-escape@3.4.10 /opt/iobroker/node_modules/regex-escape
              npm error extraneous: regexp.prototype.flags@1.5.2 /opt/iobroker/node_modules/regexp.prototype.flags
              npm error extraneous: registry-auth-token@4.2.2 /opt/iobroker/node_modules/registry-auth-token
              npm error extraneous: registry-url@5.1.0 /opt/iobroker/node_modules/registry-url
              npm error extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
              npm error extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
              npm error extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string
              npm error extraneous: resolve-alpn@1.2.1 /opt/iobroker/node_modules/resolve-alpn
              npm error extraneous: resolve-cwd@3.0.0 /opt/iobroker/node_modules/resolve-cwd
              npm error extraneous: resolve-from@4.0.0 /opt/iobroker/node_modules/resolve-from
              npm error extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
              npm error extraneous: responselike@2.0.1 /opt/iobroker/node_modules/responselike
              npm error extraneous: restore-cursor@3.1.0 /opt/iobroker/node_modules/restore-cursor
              npm error extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
              npm error extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
              npm error extraneous: reusify@1.0.4 /opt/iobroker/node_modules/reusify
              npm error extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
              npm error extraneous: rfdc@1.4.1 /opt/iobroker/node_modules/rfdc
              npm error extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/rimraf
              npm error extraneous: rrule@2.8.1 /opt/iobroker/node_modules/rrule
              npm error extraneous: rrweb-cssom@0.6.0 /opt/iobroker/node_modules/rrweb-cssom
              npm error extraneous: run-async@2.4.1 /opt/iobroker/node_modules/run-async
              npm error extraneous: run-parallel@1.2.0 /opt/iobroker/node_modules/run-parallel
              npm error extraneous: rxjs@ /opt/iobroker/node_modules/rxjs
              npm error extraneous: safe-array-concat@1.1.2 /opt/iobroker/node_modules/safe-array-concat
              npm error extraneous: safe-regex-test@1.0.3 /opt/iobroker/node_modules/safe-regex-test
              npm error extraneous: safe-stable-stringify@2.4.3 /opt/iobroker/node_modules/safe-stable-stringify
              npm error extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/safer-buffer
              npm error extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
              npm error extraneous: scoped-regex@2.1.0 /opt/iobroker/node_modules/scoped-regex
              npm error extraneous: secure-keys@1.0.0 /opt/iobroker/node_modules/secure-keys
              npm error extraneous: semver-diff@3.1.1 /opt/iobroker/node_modules/semver-diff
              npm error extraneous: send@0.18.0 /opt/iobroker/node_modules/send
              npm error extraneous: seq-logging@1.1.2 /opt/iobroker/node_modules/seq-logging
              npm error extraneous: seq-queue@0.0.5 /opt/iobroker/node_modules/seq-queue
              npm error extraneous: serve-static@1.15.0 /opt/iobroker/node_modules/serve-static
              npm error extraneous: set-function-name@2.0.2 /opt/iobroker/node_modules/set-function-name
              npm error extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
              npm error extraneous: setprototypeof@1.2.0 /opt/iobroker/node_modules/setprototypeof
              npm error extraneous: signal-exit@4.1.0 /opt/iobroker/node_modules/signal-exit
              npm error extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
              npm error extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
              npm error extraneous: simple-ssh@1.1.1 /opt/iobroker/node_modules/simple-ssh
              npm error extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
              npm error extraneous: slash@3.0.0 /opt/iobroker/node_modules/slash
              npm error extraneous: slice-ansi@0.0.4 /opt/iobroker/node_modules/slice-ansi
              npm error extraneous: smart-buffer@4.2.0 /opt/iobroker/node_modules/smart-buffer
              npm error extraneous: socks-proxy-agent@7.0.0 /opt/iobroker/node_modules/socks-proxy-agent
              npm error extraneous: socks@2.8.3 /opt/iobroker/node_modules/socks
              npm error extraneous: speedtest-net@1.6.2 /opt/iobroker/node_modules/speedtest-net
              npm error extraneous: split@1.0.1 /opt/iobroker/node_modules/split
              npm error extraneous: sprintf-js@1.1.3 /opt/iobroker/node_modules/sprintf-js
              npm error extraneous: sqlstring@2.3.3 /opt/iobroker/node_modules/sqlstring
              npm error extraneous: ssh2@ /opt/iobroker/node_modules/ssh2
              npm error extraneous: ssri@9.0.1 /opt/iobroker/node_modules/ssri
              npm error extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
              npm error extraneous: stampit-event-bus@0.1.1 /opt/iobroker/node_modules/stampit-event-bus
              npm error extraneous: stampit-state-machine@0.2.1 /opt/iobroker/node_modules/stampit-state-machine
              npm error extraneous: stampit@2.1.2 /opt/iobroker/node_modules/stampit
              npm error extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
              npm error extraneous: static-eval@2.0.2 /opt/iobroker/node_modules/static-eval
              npm error extraneous: statuses@2.0.1 /opt/iobroker/node_modules/statuses
              npm error extraneous: stoppable@1.1.0 /opt/iobroker/node_modules/stoppable
              npm error extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
              npm error extraneous: stream-shift@1.0.3 /opt/iobroker/node_modules/stream-shift
              npm error extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
              npm error extraneous: streamx@2.18.0 /opt/iobroker/node_modules/streamx
              npm error extraneous: string-argv@0.3.2 /opt/iobroker/node_modules/string-argv
              npm error extraneous: string-width-cjs@npm:string-width@4.2.3 /opt/iobroker/node_modules/string-width-cjs
              npm error extraneous: string-width@5.1.2 /opt/iobroker/node_modules/string-width
              npm error extraneous: string.prototype.trim@1.2.9 /opt/iobroker/node_modules/string.prototype.trim
              npm error extraneous: string.prototype.trimend@1.0.8 /opt/iobroker/node_modules/string.prototype.trimend
              npm error extraneous: string.prototype.trimstart@1.0.8 /opt/iobroker/node_modules/string.prototype.trimstart
              npm error extraneous: strip-ansi-cjs@npm:strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi-cjs
              npm error extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi
              npm error extraneous: strip-indent@3.0.0 /opt/iobroker/node_modules/strip-indent
              npm error extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
              npm error extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
              npm error extraneous: suncalc@1.9.0 /opt/iobroker/node_modules/suncalc
              npm error extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
              npm error extraneous: supermixer@1.0.5 /opt/iobroker/node_modules/supermixer
              npm error extraneous: supports-color@7.2.0 /opt/iobroker/node_modules/supports-color
              npm error extraneous: supports-hyperlinks@2.3.0 /opt/iobroker/node_modules/supports-hyperlinks
              npm error extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
              npm error extraneous: sweet-collections@1.1.0 /opt/iobroker/node_modules/sweet-collections
              npm error extraneous: symbol-observable@3.0.0 /opt/iobroker/node_modules/symbol-observable
              npm error extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
              npm error extraneous: syno@ /opt/iobroker/node_modules/syno
              npm error extraneous: systeminformation@ /opt/iobroker/node_modules/systeminformation
              npm error extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
              npm error extraneous: tar-stream@3.1.7 /opt/iobroker/node_modules/tar-stream
              npm error extraneous: tar@6.2.1 /opt/iobroker/node_modules/tar
              npm error extraneous: tarn@3.0.2 /opt/iobroker/node_modules/tarn
              npm error extraneous: tcp-port-used@1.0.2 /opt/iobroker/node_modules/tcp-port-used
              npm error extraneous: tedious@ /opt/iobroker/node_modules/tedious
              npm error extraneous: terminal-link@2.1.1 /opt/iobroker/node_modules/terminal-link
              npm error extraneous: text-decoder@1.1.1 /opt/iobroker/node_modules/text-decoder
              npm error extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
              npm error extraneous: thirty-two@1.0.2 /opt/iobroker/node_modules/thirty-two
              npm error extraneous: through@2.3.8 /opt/iobroker/node_modules/through
              npm error extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
              npm error extraneous: tiny-typed-emitter@2.1.0 /opt/iobroker/node_modules/tiny-typed-emitter
              npm error extraneous: tinycolor2@1.6.0 /opt/iobroker/node_modules/tinycolor2
              npm error extraneous: tmp@0.0.33 /opt/iobroker/node_modules/tmp
              npm error extraneous: to-readable-stream@2.1.0 /opt/iobroker/node_modules/to-readable-stream
              npm error extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/to-regex-range
              npm error extraneous: toidentifier@1.0.1 /opt/iobroker/node_modules/toidentifier
              npm error extraneous: tr46@4.1.1 /opt/iobroker/node_modules/tr46
              npm error extraneous: trim-newlines@3.0.1 /opt/iobroker/node_modules/trim-newlines
              npm error extraneous: triple-beam@1.4.1 /opt/iobroker/node_modules/triple-beam
              npm error extraneous: tsdav@ /opt/iobroker/node_modules/tsdav
              npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/tslib
              npm error extraneous: tweetnacl@0.14.5 /opt/iobroker/node_modules/tweetnacl
              npm error extraneous: type-check@0.3.2 /opt/iobroker/node_modules/type-check
              npm error extraneous: type-fest@0.21.3 /opt/iobroker/node_modules/type-fest
              npm error extraneous: type-is@1.6.18 /opt/iobroker/node_modules/type-is
              npm error extraneous: typed-array-buffer@1.0.2 /opt/iobroker/node_modules/typed-array-buffer
              npm error extraneous: typed-array-byte-length@1.0.1 /opt/iobroker/node_modules/typed-array-byte-length
              npm error extraneous: typed-array-byte-offset@1.0.2 /opt/iobroker/node_modules/typed-array-byte-offset
              npm error extraneous: typed-array-length@1.0.6 /opt/iobroker/node_modules/typed-array-length
              npm error extraneous: typedarray-to-buffer@3.1.5 /opt/iobroker/node_modules/typedarray-to-buffer
              npm error extraneous: typedarray.prototype.slice@1.0.3 /opt/iobroker/node_modules/typedarray.prototype.slice
              npm error extraneous: typescript@ /opt/iobroker/node_modules/typescript
              npm error extraneous: tz-offset@0.0.1 /opt/iobroker/node_modules/tz-offset
              npm error extraneous: uid-number@0.0.6 /opt/iobroker/node_modules/uid-number
              npm error extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
              npm error extraneous: undici-types@6.19.6 /opt/iobroker/node_modules/undici-types
              npm error extraneous: unique-filename@2.0.1 /opt/iobroker/node_modules/unique-filename
              npm error extraneous: unique-slug@3.0.0 /opt/iobroker/node_modules/unique-slug
              npm error extraneous: unique-string@2.0.0 /opt/iobroker/node_modules/unique-string
              npm error extraneous: unix-dgram@2.0.6 /opt/iobroker/node_modules/unix-dgram
              npm error extraneous: unpipe@1.0.0 /opt/iobroker/node_modules/unpipe
              npm error extraneous: update-notifier@5.1.0 /opt/iobroker/node_modules/update-notifier
              npm error extraneous: uri-js@4.4.1 /opt/iobroker/node_modules/uri-js
              npm error extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
              npm error extraneous: url-parse-lax@3.0.0 /opt/iobroker/node_modules/url-parse-lax
              npm error extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
              npm error extraneous: url@0.11.4 /opt/iobroker/node_modules/url
              npm error extraneous: vali-date@1.0.0 /opt/iobroker/node_modules/vali-date
              npm error extraneous: validate-npm-package-name@3.0.0 /opt/iobroker/node_modules/validate-npm-package-name
              npm error extraneous: vary@1.1.2 /opt/iobroker/node_modules/vary
              npm error extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
              npm error extraneous: vue-i18n@ /opt/iobroker/node_modules/vue-i18n
              npm error extraneous: vuelidate-messages@0.1.2 /opt/iobroker/node_modules/vuelidate-messages
              npm error extraneous: vuelidate@ /opt/iobroker/node_modules/vuelidate
              npm error extraneous: vuex-map-fields@1.4.1 /opt/iobroker/node_modules/vuex-map-fields
              npm error extraneous: w3c-xmlserializer@4.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
              npm error extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
              npm error extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
              npm error extraneous: webdav@ /opt/iobroker/node_modules/webdav
              npm error extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
              npm error extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
              npm error extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
              npm error extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
              npm error extraneous: whatwg-url@12.0.1 /opt/iobroker/node_modules/whatwg-url
              npm error extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
              npm error extraneous: which-typed-array@1.1.15 /opt/iobroker/node_modules/which-typed-array
              npm error extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
              npm error extraneous: widest-line@3.1.0 /opt/iobroker/node_modules/widest-line
              npm error extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
              npm error extraneous: winston-daily-rotate-file@5.0.0 /opt/iobroker/node_modules/winston-daily-rotate-file
              npm error extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
              npm error extraneous: winston-syslog@2.7.1 /opt/iobroker/node_modules/winston-syslog
              npm error extraneous: winston-transport@4.7.1 /opt/iobroker/node_modules/winston-transport
              npm error extraneous: winston@ /opt/iobroker/node_modules/winston
              npm error extraneous: word-wrap@1.2.5 /opt/iobroker/node_modules/word-wrap
              npm error extraneous: worker-timers-broker@6.1.8 /opt/iobroker/node_modules/worker-timers-broker
              npm error extraneous: worker-timers-worker@7.0.71 /opt/iobroker/node_modules/worker-timers-worker
              npm error extraneous: worker-timers@7.1.8 /opt/iobroker/node_modules/worker-timers
              npm error extraneous: wrap-ansi-cjs@npm:wrap-ansi@7.0.0 /opt/iobroker/node_modules/wrap-ansi-cjs
              npm error extraneous: wrap-ansi@8.1.0 /opt/iobroker/node_modules/wrap-ansi
              npm error extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/wrappy
              npm error extraneous: write-file-atomic@3.0.3 /opt/iobroker/node_modules/write-file-atomic
              npm error extraneous: xdg-basedir@4.0.0 /opt/iobroker/node_modules/xdg-basedir
              npm error extraneous: xml-js@1.6.11 /opt/iobroker/node_modules/xml-js
              npm error extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
              npm error extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
              npm error extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
              npm error extraneous: yallist@4.0.0 /opt/iobroker/node_modules/yallist
              npm error extraneous: yaml@ /opt/iobroker/node_modules/yaml
              npm error extraneous: yargs-parser@20.2.9 /opt/iobroker/node_modules/yargs-parser
              npm error extraneous: yocto-queue@0.1.0 /opt/iobroker/node_modules/yocto-queue
              npm error extraneous: zip-stream@6.0.1 /opt/iobroker/node_modules/zip-stream
              npm error extraneous: zrender@ /opt/iobroker/node_modules/zrender
              npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T19_54_40_124Z-debug-0.log
                Thomas Braun Most Active @mcm1957 last edited by
                @mcm1957 sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                Wo stammen eigentlich die ganzen GITHUB dependencies her, z.B.
                War mich auch schon in's Auge gesprungen.
                  flommaster @Thomas Braun last edited by
                  @thomas-braun sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                  Keine Ahnung.
                  Soll ich das System komplett neu aufsetzen?
                    Thomas Braun Most Active @flommaster last edited by
                    @flommaster
                    npm prune
                    npm ls
                      Thomas Braun Most Active @flommaster last edited by Thomas Braun
                      @flommaster
                      Das kommt davon, wenn man da alles und jedes (Ich hab da jetzt 13 Kandidaten gezählt) über github installiert und nicht ordentlich aus einem Repo.
                      Da wird wohl einer der Adapter gelöscht oder verschoben worden sein sein. Das führt dann für alle anderen Adapter zu der Meldung
                      invalid "blablubb" from the root project
                        Der Befehl "npm prune" liefert folgendes Ergebnis:
                        Kann ich die github Installationen löschen?
                        npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.web-speedy.git
                        npm warn skipping integrity check for git dependency ssh://git@github.com/peterbaumert/ioBroker.vofo-speedtest.git
                        npm warn skipping integrity check for git dependency ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git
                        npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2.git
                        npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2-widgets-material.git
                        npm warn skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git
                        npm warn skipping integrity check for git dependency ssh://git@github.com/aendue/ioBroker.reolink.git
                        npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.ical.git
                        npm warn skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git
                        npm warn skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git
                        npm warn skipping integrity check for git dependency ssh://git@github.com/WLAN-Kabel/ioBroker.calendar.git
                        npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                        npm warn deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                        npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                        npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
                        npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
                        npm warn deprecated uid-number@0.0.6: This package is no longer supported.
                        npm warn deprecated npmlog@5.0.1: This package is no longer supported.
                        npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                        npm warn deprecated npmlog@6.0.2: This package is no longer supported.
                        npm warn deprecated har-validator@5.1.5: this library is no longer supported
                        npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                        npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
                        npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
                        npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
                        npm warn deprecated q@1.1.2: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
                        npm warn deprecated
                        npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
                        npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                        npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                        npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
                        npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
                        npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                        npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
                        npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                        npm warn deprecated google-p12-pem@3.1.4: Package is no longer maintained
                        npm warn deprecated gauge@3.0.2: This package is no longer supported.
                        npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                        npm warn deprecated gauge@4.0.4: This package is no longer supported.
                        npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                        npm warn deprecated later@1.2.0: Please upgrade to the maintained and new drop-in replacement @breejs/later at https://github.com/breejs/later 🚀 Thanks and happy hacking! 🚀  @niftylettuce
                        npm error git dep preparation failed
                        npm error signal SIGINT
                        npm error command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
                        npm error npm warn using --force Recommended protections disabled.
                          @flommaster sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                          Vollständig.
                          Inkl. vollständiger Eingabezeile inkl. login prompt. Damit man sieht was du da genau in welchem Verzeichnis mit welchem User eingegeben hast.
                            Gerne. Hier der komplette Auszug (Teil 1)
                            flo@ioBrokerdebian:/opt/iobroker$ npm prune
                            npm ls
                            npm warn deprecated
                            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T20_04_51_820Z-debug-0.log
                            iobroker.inst@2.0.3 /opt/iobroker
                            ├── @alcalzone/esbuild-register@2.5.1-1 extraneous
                            ├── @alcalzone/jsonl-db@3.1.1 extraneous
                            ├── @alcalzone/pak@0.8.1 extraneous
                            ├── @alcalzone/proper-lockfile@4.1.3-0 extraneous
                            ├── @aws-sdk/util-utf8-browser@3.259.0 extraneous
                            ├── @azure/abort-controller@1.1.0 extraneous
                            ├── @azure/core-auth@1.7.2 extraneous
                            ├── @azure/core-client@ extraneous
                            ├── @azure/core-http-compat@ extraneous
                            ├── @azure/core-lro@ extraneous
                            ├── @azure/core-paging@1.6.2 extraneous
                            ├── @azure/core-rest-pipeline@ extraneous
                            ├── @azure/core-tracing@1.1.2 extraneous
                            ├── @azure/core-util@ extraneous
                            ├── @azure/identity@ extraneous
                            ├── @azure/keyvault-keys@ extraneous
                            ├── @azure/logger@1.1.4 extraneous
                            ├── @azure/msal-browser@ extraneous
                            ├── @azure/msal-common@ extraneous
                            ├── @azure/msal-node@1.18.4 extraneous
                            ├── @babel/code-frame@7.24.7 extraneous
                            ├── @babel/helper-validator-identifier@7.24.7 extraneous
                            ├── @babel/highlight@7.24.7 extraneous
                            ├── @babel/runtime@ extraneous
                            ├── @colors/colors@1.5.0 extraneous
                            ├── @dabh/diagnostics@2.0.3 extraneous
                            ├── @datalust/winston-seq@1.0.2 extraneous
                            ├── @gar/promisify@1.1.3 extraneous
                            ├── @googleapis/calendar@9.7.7 extraneous
                            ├── @googleapis/drive@5.1.0 extraneous
                            ├── @googleapis/oauth2@1.0.7 extraneous
                            ├── @httptoolkit/websocket-stream@6.0.1 extraneous
                            ├── @iobroker/db-base@ extraneous
                            ├── @iobroker/db-objects-file@ extraneous
                            ├── @iobroker/db-objects-jsonl@ extraneous
                            ├── @iobroker/db-objects-redis@ extraneous
                            ├── @iobroker/db-states-file@ extraneous
                            ├── @iobroker/db-states-jsonl@ extraneous
                            ├── @iobroker/db-states-redis@ extraneous
                            ├── @iobroker/js-controller-adapter@ extraneous
                            ├── @iobroker/js-controller-cli@ extraneous
                            ├── @iobroker/js-controller-common-db@ extraneous
                            ├── @iobroker/js-controller-common@ extraneous
                            ├── @iobroker/plugin-base@1.2.1 extraneous
                            ├── @iobroker/plugin-sentry@1.2.1 extraneous
                            ├── @iobroker/socket-classes@1.5.6 extraneous
                            ├── @iobroker/webserver@1.0.3 extraneous
                            ├── @isaacs/cliui@8.0.2 extraneous
                            ├── @js-joda/core@ extraneous
                            ├── @mapbox/node-pre-gyp@1.0.11 extraneous
                            ├── @microsoft/microsoft-graph-types@2.40.0 extraneous
                            ├── @nodelib/fs.scandir@2.1.5 extraneous
                            ├── @nodelib/fs.stat@2.0.5 extraneous
                            ├── @nodelib/fs.walk@1.2.8 extraneous
                            ├── @npmcli/fs@2.1.2 extraneous
                            ├── @npmcli/move-file@2.0.1 extraneous
                            ├── @pkgjs/parseargs@0.11.0 extraneous
                            ├── @protobufjs/aspromise@1.1.2 extraneous
                            ├── @protobufjs/base64@1.1.2 extraneous
                            ├── @protobufjs/codegen@2.0.4 extraneous
                            ├── @protobufjs/eventemitter@1.1.0 extraneous
                            ├── @protobufjs/fetch@1.1.0 extraneous
                            ├── @protobufjs/float@1.0.2 extraneous
                            ├── @protobufjs/inquire@1.1.0 extraneous
                            ├── @protobufjs/path@1.1.2 extraneous
                            ├── @protobufjs/pool@1.1.0 extraneous
                            ├── @protobufjs/utf8@1.1.0 extraneous
                            ├── @quasar/extras@ extraneous
                            ├── @samverschueren/stream-to-observable@0.3.1 extraneous
                            ├── @sentry-internal/tracing@ extraneous
                            ├── @sentry/core@5.30.0 extraneous
                            ├── @sentry/hub@5.30.0 extraneous
                            ├── @sentry/minimal@5.30.0 extraneous
                            ├── @sentry/node@ extraneous
                            ├── @sentry/tracing@ extraneous
                            ├── @sentry/types@ extraneous
                            ├── @sentry/utils@ extraneous
                            ├── @sindresorhus/is@4.6.0 extraneous
                            ├── @socket.io/component-emitter@3.1.2 extraneous
                            ├── @szmarczak/http-timer@4.0.6 extraneous
                            ├── @tediousjs/connection-string@0.5.0 extraneous
                            ├── @tootallnate/once@2.0.0 extraneous
                            ├── @types/bl@5.1.0 extraneous
                            ├── @types/cacheable-request@6.0.3 extraneous
                            ├── @types/caseless@0.12.5 extraneous
                            ├── @types/cookie@0.4.1 extraneous
                            ├── @types/cors@2.8.17 extraneous
                            ├── @types/geojson@7946.0.14 extraneous
                            ├── @types/http-cache-semantics@4.0.4 extraneous
                            ├── @types/keyv@3.1.4 extraneous
                            ├── @types/leaflet@1.9.12 extraneous
                            ├── @types/minimist@1.2.5 extraneous
                            ├── @types/node-cron@2.0.8 extraneous
                            ├── @types/node@ extraneous
                            ├── @types/normalize-package-data@2.4.4 extraneous
                            ├── @types/parse-json@4.0.2 extraneous
                            ├── @types/readable-stream@4.0.15 extraneous
                            ├── @types/request@2.48.12 extraneous
                            ├── @types/responselike@1.0.3 extraneous
                            ├── @types/tough-cookie@4.0.5 extraneous
                            ├── @types/triple-beam@1.3.5 extraneous
                            ├── @types/tz-offset@0.0.3 extraneous
                            ├── @types/ws@8.5.12 extraneous
                            ├── abab@2.0.6 extraneous
                            ├── abbrev@1.1.1 extraneous
                            ├── abort-controller@3.0.0 extraneous
                            ├── agentkeepalive@4.5.0 extraneous
                            ├── aggregate-error@3.1.0 extraneous
                            ├── ajv@ extraneous
                            ├── ansi-align@3.0.1 extraneous
                            ├── ansi-colors@4.1.3 extraneous
                            ├── ansi-escapes@4.3.2 extraneous
                            ├── ansi-regex@5.0.1 extraneous
                            ├── ansi-styles@4.3.0 extraneous
                            ├── any-observable@0.5.1 extraneous
                            ├── anymatch@3.1.3 extraneous
                            ├── aproba@2.0.0 extraneous
                            ├── archiver-utils@5.0.2 extraneous
                            ├── archiver@7.0.1 extraneous
                            ├── are-we-there-yet@2.0.0 extraneous
                            ├── arg@4.1.0 extraneous
                            ├── argparse@1.0.10 extraneous
                            ├── array-buffer-byte-length@1.0.1 extraneous
                            ├── array-flatten@1.1.1 extraneous
                            ├── array-union@2.1.0 extraneous
                            ├── arraybuffer.prototype.slice@1.0.3 extraneous
                            ├── arrify@2.0.1 extraneous
                            ├── asn1@0.2.6 extraneous
                            ├── async-exit-hook@2.0.1 extraneous
                            ├── authenticate-pam@1.0.5 extraneous
                            ├── available-typed-arrays@1.0.7 extraneous
                            ├── aws-crt@ extraneous
                            ├── b4a@1.6.6 extraneous
                            ├── balanced-match@1.0.2 extraneous
                            ├── bare-events@2.4.2 extraneous
                            ├── base-64@1.0.0 extraneous
                            ├── base64-js@1.5.1 extraneous
                            ├── bcrypt-pbkdf@1.0.2 extraneous
                            ├── binary-extensions@2.3.0 extraneous
                            ├── bindings@1.5.0 extraneous
                            ├── bl@6.0.14 extraneous
                            ├── bluebird@3.7.2 extraneous
                            ├── body-parser@1.20.2 extraneous
                            ├── bottleneck@2.19.5 extraneous
                            ├── boxen@5.1.2 extraneous
                            ├── brace-expansion@2.0.1 extraneous
                            ├── braces@3.0.3 extraneous
                            ├── buffer-crc32@1.0.0 extraneous
                            ├── buffer-equal-constant-time@1.0.1 extraneous
                            ├── buffer-shims@1.0.0 extraneous
                            ├── buffer@6.0.3 extraneous
                            ├── buildcheck@0.0.6 extraneous
                            ├── builtins@1.0.3 extraneous
                            ├── busboy@1.6.0 extraneous
                            ├── byte-length@1.0.2 extraneous
                            ├── bytes@3.1.2 extraneous
                            ├── cacache@16.1.3 extraneous
                            ├── cacheable-lookup@5.0.4 extraneous
                            ├── cacheable-request@7.0.4 extraneous
                            ├── callsites@3.1.0 extraneous
                            ├── camelcase-keys@6.2.2 extraneous
                            ├── camelcase@5.3.1 extraneous
                            ├── capitalize@2.0.4 extraneous
                            ├── chalk@4.1.2 extraneous
                            ├── chardet@0.7.0 extraneous
                            ├── charenc@0.0.2 extraneous
                            ├── chokidar@3.6.0 extraneous
                            ├── chownr@2.0.0 extraneous
                            ├── ci-info@3.9.0 extraneous
                            ├── clean-stack@2.2.0 extraneous
                            ├── cli-boxes@2.2.1 extraneous
                            ├── cli-cursor@3.1.0 extraneous
                            ├── cli-truncate@0.2.1 extraneous
                            ├── cli-width@3.0.0 extraneous
                            ├── clone-response@1.0.3 extraneous
                            ├── cloneextend@0.0.3 extraneous
                            ├── cluster-key-slot@1.1.2 extraneous
                            ├── coap-packet@1.1.1 extraneous
                            ├── coffeescript@1.12.7 extraneous
                            ├── color-convert@2.0.1 extraneous
                            ├── color-name@1.1.4 extraneous
                            ├── color-string@1.9.1 extraneous
                            ├── color-support@1.1.3 extraneous
                            ├── color@3.2.1 extraneous
                            ├── colors@1.4.0
                            ├── colorspace@1.1.4 extraneous
                            ├── commander@9.5.0 extraneous
                            ├── commist@3.2.0 extraneous
                            ├── compress-commons@6.0.2 extraneous
                            ├── compress-json@2.1.2 extraneous
                            ├── compressible@2.0.18 extraneous
                            ├── compression@1.7.4 extraneous
                            ├── concat-map@0.0.1 extraneous
                            ├── configstore@5.0.1 extraneous
                            ├── connect-flash@0.1.1 extraneous
                            ├── connect@3.7.0 extraneous
                            ├── console-control-strings@1.1.0 extraneous
                            ├── content-disposition@0.5.4 extraneous
                            ├── content-type@1.0.5 extraneous
                            ├── core-js@ extraneous
                            ├── cors@2.8.5 extraneous
                            ├── cosmiconfig@7.1.0 extraneous
                            ├── cpu-features@ extraneous
                            ├── crc-32@1.2.2 extraneous
                            ├── crc@ extraneous
                            ├── crc32-stream@6.0.0 extraneous
                            ├── cross-fetch@4.0.0 extraneous
                            ├── crypt@0.0.2 extraneous
                            ├── crypto-js@ extraneous
                            ├── crypto-random-string@2.0.0 extraneous
                            ├── cssstyle@ extraneous
                            ├── cycle@1.0.3 extraneous
                            ├── dashdash@1.14.1 extraneous
                            ├── data-urls@4.0.0 extraneous
                            ├── data-view-buffer@1.0.1 extraneous
                            ├── data-view-byte-length@1.0.1 extraneous
                            ├── data-view-byte-offset@1.0.0 extraneous
                            ├── date-and-time@ extraneous
                            ├── date-fns@1.30.1 extraneous
                            ├── dateformat@4.6.3 extraneous
                            ├── dayjs@ extraneous
                            ├── decache@4.6.2 extraneous
                            ├── decamelize-keys@1.1.1 extraneous
                            ├── decimal.js@10.4.3 extraneous
                            ├── decompress-response@6.0.0 extraneous
                            ├── deep-clone@3.0.3 extraneous
                            ├── deep-extend@0.6.0 extraneous
                            ├── deep-is@0.1.4 extraneous
                            ├── defer-to-connect@2.0.1 extraneous
                            ├── define-lazy-prop@2.0.0 extraneous
                            ├── del@6.1.1 extraneous
                            ├── delegates@1.0.0 extraneous
                            ├── denque@1.5.1 extraneous
                            ├── destroy@1.2.0 extraneous
                            ├── detect-libc@2.0.3 extraneous
                            ├── diacritics@1.3.0 extraneous
                            ├── digest-header@1.1.0 extraneous
                            ├── dir-glob@3.0.1 extraneous
                            ├── diskusage@1.2.0 extraneous
                            ├── domexception@4.0.0 extraneous
                            ├── dot-prop@6.0.1 extraneous
                            ├── draftlog@1.0.13 extraneous
                            ├── dropbox-v2-api@ extraneous
                            ├── duplexer@0.1.2 extraneous
                            ├── duplexer3@0.1.5 extraneous
                            ├── duplexify@3.7.1 extraneous
                            ├── eastasianwidth@0.2.0 extraneous
                            ├── ecc-jsbn@0.1.2 extraneous
                            ├── ecdsa-sig-formatter@1.0.11 extraneous
                            ├── echarts@ extraneous
                            ├── ee-first@1.1.1 extraneous
                            ├── elegant-spinner@1.0.1 extraneous
                            ├── emoji-regex@9.2.2 extraneous
                            ├── enabled@2.0.0 extraneous
                            ├── encodeurl@1.0.2 extraneous
                            ├── encoding@0.1.13 extraneous
                            ├── end-of-stream@1.4.4 extraneous
                            ├── entities@4.5.0 extraneous
                            ├── err-code@2.0.3 extraneous
                            ├── es-abstract@ extraneous
                            ├── es-aggregate-error@1.0.13 extraneous
                            ├── es-object-atoms@1.0.0 extraneous
                            ├── es-set-tostringtag@2.0.3 extraneous
                            ├── es-to-primitive@1.2.1 extraneous
                            ├── es6-promise@4.2.8 extraneous
                            ├── es6-promisify@5.0.0 extraneous
                            ├── esbuild@0.11.23 extraneous
                            ├── escalade@3.1.2 extraneous
                            ├── escape-goat@3.0.0 extraneous
                            ├── escape-html@1.0.3 extraneous
                            ├── escape-string-regexp@4.0.0 extraneous
                            ├── escodegen@1.14.3 extraneous
                            ├── esprima@1.2.2 extraneous
                            ├── estraverse@4.3.0 extraneous
                            ├── esutils@2.0.3 extraneous
                            ├── etag@1.8.1 extraneous
                            ├── event-stream@4.0.1 extraneous
                            ├── event-target-shim@5.0.1 extraneous
                            ├── eventemitter2@6.4.9 extraneous
                            ├── events@3.3.0 extraneous
                            ├── execa@5.1.1 extraneous
                            ├── expand-template@2.0.3 extraneous
                            ├── express-fileupload@1.5.1 extraneous
                            ├── express@4.19.2 extraneous
                            ├── external-editor@3.1.0 extraneous
                            ├── fast-deep-equal@3.1.3 extraneous
                            ├── fast-fifo@1.3.2 extraneous
                            ├── fast-glob@ extraneous
                            ├── fast-json-stable-stringify@2.1.0 extraneous
                            ├── fast-levenshtein@2.0.6 extraneous
                            ├── fast-text-encoding@1.0.6 extraneous
                            ├── fast-unique-numbers@ extraneous
                            ├── fast-uri@3.0.1 extraneous
                            ├── fast-xml-parser@ extraneous
                            ├── fastq@1.17.1 extraneous
                            ├── fastseries@2.0.0 extraneous
                            ├── fecha@4.2.3 extraneous
                            ├── figures@3.2.0 extraneous
                            ├── file-stream-rotator@0.6.1 extraneous
                            ├── file-type@10.11.0 extraneous
                            ├── file-uri-to-path@1.0.0 extraneous
                            ├── fill-range@7.1.1 extraneous
                            ├── finalhandler@1.2.0 extraneous
                            ├── find-up@5.0.0 extraneous
                            ├── fn.name@1.1.0 extraneous
                            ├── for-each@0.3.3 extraneous
                            ├── foreground-child@3.3.0 extraneous
                            ├── form-data-encoder@2.1.4 extraneous
                            ├── form-data@4.0.0 extraneous
                            ├── forwarded@0.2.0 extraneous
                            ├── fresh@0.5.2 extraneous
                            ├── from@0.1.7 extraneous
                            ├── fs-constants@1.0.0 extraneous
                            ├── fs-extra@7.0.1
                            ├── fs-minipass@2.1.0 extraneous
                            ├── fs.realpath@1.0.0 extraneous
                            ├── fsevents@ extraneous
                            ├── ftp@0.3.10 extraneous
                            ├── function.prototype.name@1.1.6 extraneous
                            ├── functions-have-names@1.2.3 extraneous
                            ├── futoin-hkdf@1.4.3 extraneous
                            ├── gauge@3.0.2 extraneous
                            ├── gaxios@5.1.3 extraneous
                            ├── gcp-metadata@5.3.0 extraneous
                            ├── generate-function@2.3.1 extraneous
                            ├── get-ssl-certificate@2.3.3 extraneous
                            ├── get-stream@5.2.0 extraneous
                            ├── get-symbol-description@1.0.2 extraneous
                            ├── getpass@0.1.7 extraneous
                            ├── github-from-package@0.0.0 extraneous
                            ├── github-url-from-git@1.5.0 extraneous
                            ├── glob-parent@5.1.2 extraneous
                            ├── glob@10.4.5 extraneous
                            ├── global-dirs@2.1.0 extraneous
                            ├── globalthis@1.0.4 extraneous
                            ├── globby@11.1.0 extraneous
                            ├── glossy@0.1.7 extraneous
                            ├── google-auth-library@ extraneous
                            ├── google-p12-pem@4.0.1 extraneous
                            ├── googleapis-common@6.0.4 extraneous
                            ├── googleapis@ extraneous
                            ├── gtoken@6.1.2 extraneous
                            ├── hard-rejection@2.1.0 extraneous
                            ├── has-ansi@2.0.0 extraneous
                            ├── has-bigints@1.0.2 extraneous
                            ├── has-flag@4.0.0 extraneous
                            ├── has-tostringtag@1.0.2 extraneous
                            ├── has-unicode@2.0.1 extraneous
                            ├── has-yarn@2.1.0 extraneous
                            ├── he@1.2.0 extraneous
                            ├── help-me@5.0.0 extraneous
                            ├── homebridge-plugin-wrapper@ extraneous
                            ├── hosted-git-info@3.0.8 extraneous
                            ├── hot-patcher@1.0.0 extraneous
                            ├── html-encoding-sniffer@3.0.0 extraneous
                            ├── http-cache-semantics@4.1.1 extraneous
                            ├── http-errors@2.0.0 extraneous
                            ├── http-proxy-agent@5.0.0 extraneous
                            ├── http2-wrapper@1.0.3 extraneous
                            ├── https@1.0.0 extraneous
                            ├── humanize-ms@1.2.1 extraneous
                            ├── ical.js@ extraneous
                            ├── iconv-lite@0.4.24 extraneous
                            ├── ieee754@1.2.1 extraneous
                            ├── ignore-walk@3.0.4 extraneous
                            ├── ignore@5.3.2 extraneous
                            ├── image-type@4.1.0 extraneous
                            ├── immediate@3.0.6 extraneous
                            ├── import-fresh@3.3.0 extraneous
                            ├── import-lazy@2.1.0 extraneous
                            ├── import-local@3.2.0 extraneous
                            ├── imurmurhash@0.1.4 extraneous
                            ├── indent-string@3.2.0 extraneous
                            ├── infer-owner@1.0.4 extraneous
                            ├── inflight@1.0.6 extraneous
                            ├── ini@1.3.7 extraneous
                            ├── inquirer-autosubmit-prompt@0.2.0 extraneous
                            ├── inquirer@7.3.3 extraneous
                            ├── int64-buffer@1.0.1 extraneous
                            ├── internal-slot@1.0.7 extraneous
                            ├── iobroker-adapter-helpers@0.0.8 extraneous
                            ├── iobroker.admin@ invalid: "^6.10.1" from the root project
                            ├── iobroker.backitup@ invalid: "2.6.23" from the root project
                            ├── iobroker.bmw@2.5.7
                            ├── iobroker.calendar@ invalid: "github:WLAN-Kabel/ioBroker.calendar#c36410258c21a4a92eba80fb0ec084fc254c9259" from the root project
                            ├── iobroker.cloud@4.4.1
                            ├── iobroker.coronavirus-statistics@0.8.7
                            ├── iobroker.daswetter@3.1.10
                            ├── iobroker.discovery@ invalid: "3.1.0" from the root project
                            ├── iobroker.dwd@2.8.5
                            ├── iobroker.echarts@ invalid: "1.5.1" from the root project
                            ├── iobroker.energiefluss@ invalid: "github:SKB-CGN/ioBroker.energiefluss#fc7a5b48f0f485b130619796daf0a9533f5b8426" from the root project
                            ├── iobroker.eusec@1.1.2
                            ├── iobroker.flot@ invalid: "1.12.0" from the root project
                            ├── iobroker.fritzbox@0.2.1
                            ├── iobroker.fullcalendar@ invalid: "1.2.0" from the root project
                            ├── iobroker.fullybrowser@2.1.2
                            ├── iobroker.gartenbewaesserung@ invalid: "github:TA2k/ioBroker.gartenbewaesserung#1931dcd562edf9dfa818dbf5cec61e28d3f72d72" from the root project
                            ├── iobroker.ham@ invalid: "github:ioBroker/ioBroker.ham" from the root project
                            ├── iobroker.harmony@1.2.2
                            ├── iobroker.heatingcontrol@ invalid: "2.11.1" from the root project
                            ├── iobroker.history@2.2.6
                            ├── iobroker.hm-rega@3.0.47
                            ├── iobroker.hm-rpc@1.15.19
                            ├── iobroker.hue@3.9.5
                            ├── iobroker.ical@ invalid: "github:iobroker-community-adapters/ioBroker.ical#ad28140ed1fa7ab23683d7e12b6204da06b7ce6f" from the root project
                            ├── iobroker.icons-icons8@0.0.1
                            ├── iobroker.icons-material-png@0.1.0
                            ├── iobroker.icons-mfd-png@1.1.0
                            ├── iobroker.icons-ultimate-png@1.0.1
                            ├── iobroker.info@ invalid: "1.9.26" from the root project
                            ├── iobroker.javascript@ invalid: "7.1.4" from the root project
                            ├── iobroker.js-controller@ invalid: "^6.0.9" from the root project
                            ├── iobroker.logparser@2.2.0
                            ├── iobroker.material@ invalid: "1.3.1" from the root project
                            ├── iobroker.meross@1.15.1
                            ├── iobroker.mihome-vacuum@3.11.0
                            ├── iobroker.milight-smart-light@ invalid: "1.2.2" from the root project
                            ├── iobroker.milight@0.3.6
                            ├── iobroker.mobile@ invalid: "1.0.1" from the root project
                            ├── iobroker.modbus@ invalid: "5.0.11" from the root project
                            ├── iobroker.mqtt@ invalid: "4.1.1" from the root project
                            ├── iobroker.nina@ invalid: "0.0.25" from the root project
                            ├── iobroker.pollenflug@1.0.6
                            ├── iobroker.pushover@3.0.3
                            ├── iobroker.pushsafer@1.0.3
                            ├── iobroker.pvforecast@2.7.1
                            ├── iobroker.renault@ invalid: "github:TA2k/ioBroker.renault" from the root project
                            ├── iobroker.reolink@ invalid: "github:aendue/ioBroker.reolink#b78aab6744cdb81b360fd947a9c6e2fd6808bab1" from the root project
                            ├── iobroker.schoolfree@ invalid: "1.1.2" from the root project
                            ├── iobroker.simple-api@2.7.2
                            ├── iobroker.smartmeter@3.3.4
                            ├── iobroker.socketio@6.5.2
                            ├── iobroker.sourceanalytix@ invalid: "github:DrozmotiX/ioBroker.sourceanalytix#362346b297c0a21c717ec20bd8d16331bca3b22d" from the root project
                            ├── iobroker.sql@2.2.0
                            ├── iobroker.statistics@2.3.0
                            ├── iobroker.sunnyportal@0.1.5
                            ├── iobroker.synology@ invalid: "2.1.13" from the root project
                            ├── iobroker.tankerkoenig@ invalid: "3.3.7" from the root project
                            ├── iobroker.terminal@ invalid: "1.0.0" from the root project
                            ├── iobroker.tr-064@4.2.18
                            ├── iobroker.trashschedule@2.2.0
                            ├── iobroker.unifi@ invalid: "0.6.6" from the root project
                            ├── iobroker.upnp@1.0.21
                            ├── iobroker.valloxmv@1.2.0
                            ├── iobroker.viessmannapi@ invalid: "github:TA2k/ioBroker.viessmannapi" from the root project
                            ├── iobroker.virtualpowermeter@ invalid: "1.4.6" from the root project
                            ├── iobroker.vis-2-widgets-material@ invalid: "github:ioBroker/ioBroker.vis-2-widgets-material#355a97e7d532721eaa97326fd873d13f12894ebd" from the root project
                            ├── iobroker.vis-2@ invalid: "github:ioBroker/ioBroker.vis-2#17c7dcf5f26768f1f3a4badb087eddf9344591ea" from the root project
                            ├── iobroker.vis-colorpicker@ invalid: "2.0.3" from the root project
                            ├── iobroker.vis-fancyswitch@1.1.0
                            ├── iobroker.vis-google-fonts@1.0.4
                            ├── iobroker.vis-history@1.0.0
                            ├── iobroker.vis-hqwidgets@ invalid: "1.4.0" from the root project
                            ├── iobroker.vis-inventwo@ invalid: "3.3.3" from the root project
                            ├── iobroker.vis-jqui-mfd@1.0.12
                            ├── iobroker.vis-justgage@1.0.2
                            ├── iobroker.vis-map@1.0.4
                            ├── iobroker.vis-materialdesign@ invalid: "github:Scrounger/ioBroker.vis-materialdesign#8b7529d493f223dfc4f1d1f632553fcb35bbcc92" from the root project
                            ├── iobroker.vis-metro@ invalid: "1.2.0" from the root project
                            ├── iobroker.vis-rgraph@0.0.2
                            ├── iobroker.vis-timeandweather@ invalid: "1.2.2" from the root project
                            ├── iobroker.vis-weather@ invalid: "2.5.6" from the root project
                            ├── iobroker.vis@ invalid: "1.4.16" from the root project
                            ├── iobroker.vofo-speedtest@ invalid: "github:peterbaumert/ioBroker.vofo-speedtest#921201b4bbd53a88a64fc843c7242f9e7e8c0325" from the root project
                            ├── iobroker.weatherunderground@3.4.2
                            ├── iobroker.web-speedy@ invalid: "github:iobroker-community-adapters/ioBroker.web-speedy#8a5ad6a42a15688b6bb539f22e30ba2a1978c118" from the root project
                            ├── iobroker.web@ invalid: "6.1.0" from the root project
                            ├── iobroker.webcal@ invalid: "github:dirkhe/ioBroker.webcal#feature/DigestAuth" from the root project
                            ├── iobroker.wiffi-wz@2.2.1
                            ├── iobroker.windows-control@0.1.5
                            ├── iobroker.worx@2.3.2
                            ├── iobroker.ws@2.5.3
                            ├── iobroker@2.0.3
                            ├── ioredis@ extraneous
                            ├── ip-address@9.0.5 extraneous
                            ├── ip-regex@4.3.0 extraneous
                            ├── ipaddr.js@2.2.0 extraneous
                            ├── is-array-buffer@3.0.4 extraneous
                            ├── is-bigint@1.0.4 extraneous
                            ├── is-binary-path@2.1.0 extraneous
                            ├── is-boolean-object@1.1.2 extraneous
                            ├── is-buffer@1.1.6 extraneous
                            ├── is-callable@1.2.7 extraneous
                            ├── is-ci@2.0.0 extraneous
                            ├── is-core-module@2.15.0 extraneous
                            ├── is-data-view@1.0.1 extraneous
                            ├── is-date-object@1.0.5 extraneous
                            ├── is-docker@2.2.1 extraneous
                            ├── is-empty-object@1.1.1 extraneous
                            ├── is-extglob@2.1.1 extraneous
                            ├── is-fullwidth-code-point@3.0.0 extraneous
                            ├── is-glob@4.0.3 extraneous
                            ├── is-installed-globally@0.3.2 extraneous
                            ├── is-interactive@1.0.0 extraneous
                            ├── is-lambda@1.0.1 extraneous
                            ├── is-negative-zero@2.0.3 extraneous
                            ├── is-npm@5.0.0 extraneous
                            ├── is-number-object@1.0.7 extraneous
                            ├── is-number@7.0.0 extraneous
                            ├── is-obj@2.0.0 extraneous
                            ├── is-observable@1.1.0 extraneous
                            ├── is-path-cwd@2.2.0 extraneous
                            ├── is-path-inside@3.0.3 extraneous
                            ├── is-plain-obj@1.1.0 extraneous
                            ├── is-potential-custom-element-name@1.0.1 extraneous
                            ├── is-promise@2.2.2 extraneous
                            ├── is-property@1.0.2 extraneous
                            ├── is-regex@1.1.4 extraneous
                            ├── is-scoped@2.1.0 extraneous
                            ├── is-shared-array-buffer@1.0.3 extraneous
                            ├── is-string@1.0.7 extraneous
                            ├── is-symbol@1.0.4 extraneous
                            ├── is-typed-array@1.1.13 extraneous
                            ├── is-unicode-supported@0.1.0 extraneous
                            ├── is-url-superb@4.0.0 extraneous
                            ├── is-url@1.2.4 extraneous
                            ├── is-weakref@1.0.2 extraneous
                            ├── is-wsl@2.2.0 extraneous
                            ├── is-yarn-global@0.3.0 extraneous
                            ├── is@3.3.0 extraneous
                            ├── is2@2.0.9 extraneous
                            ├── isomorphic-ws@4.0.1 extraneous
                            ├── issue-regex@3.1.0 extraneous
                            ├── jackspeak@3.4.3 extraneous
                            ├── js-md4@0.3.2 extraneous
                            ├── js-sdsl@4.3.0 extraneous
                            ├── js-tokens@4.0.0 extraneous
                            ├── js-yaml@ extraneous
                            ├── jsbi@4.3.0 extraneous
                            ├── jsbn@1.1.0 extraneous
                            ├── jsdom@ extraneous
                            ├── jshashes@1.0.8 extraneous
                            ├── json-buffer@3.0.1 extraneous
                            ├── json-logic-js@2.0.5 extraneous
                            ├── json-parse-even-better-errors@2.3.1 extraneous
                            ├── json-schema-traverse@1.0.0 extraneous
                            ├── json5@2.2.3 extraneous
                            ├── jsonata@ extraneous
                            ├── jsonc-parser@3.3.1 extraneous
                            ├── jsonwebtoken@9.0.2 extraneous
                            ├── jszip@ extraneous
                            ├── jwa@2.0.0 extraneous
                            ├── jws@4.0.0 extraneous
                            ├── keyv@4.5.4 extraneous
                            ├── kind-of@6.0.3 extraneous
                            ├── kuler@2.0.0 extraneous
                            ├── later@1.2.0 extraneous
                            ├── latest-version@5.1.0 extraneous
                            ├── layerr@0.1.2 extraneous
                            ├── lazystream@1.0.1 extraneous
                            ├── leven@2.1.0 extraneous
                            ├── levn@0.3.0 extraneous
                            ├── lie@3.3.0 extraneous
                            ├── lines-and-columns@1.2.4 extraneous
                            ├── listr-input@0.2.1 extraneous
                            ├── listr-silent-renderer@1.1.1 extraneous
                            ├── listr-update-renderer@0.5.0 extraneous
                            ├── listr-verbose-renderer@0.5.0 extraneous
                            ├── listr@0.14.3 extraneous
                            ├── loadavg-windows@1.1.1 extraneous
                            ├── locate-path@6.0.0 extraneous
                            ├── lodash.defaults@4.2.0 extraneous
                            ├── lodash.flatten@4.4.0 extraneous
                            ├── lodash.includes@4.3.0 extraneous
                            ├── lodash.isarguments@3.1.0 extraneous
                            ├── lodash.isboolean@3.0.3 extraneous
                            ├── lodash.isequal@4.5.0 extraneous
                            ├── lodash.isinteger@4.0.4 extraneous
                            ├── lodash.isnumber@3.0.3 extraneous
                            ├── lodash.isplainobject@4.0.6 extraneous
                            ├── lodash.isstring@4.0.1 extraneous
                            ├── lodash.once@4.1.1 extraneous
                            ├── lodash.zip@4.2.0 extraneous
                            ├── log-symbols@4.1.0 extraneous
                            ├── log-update@2.3.0 extraneous
                            ├── logform@ extraneous
                            ├── long@5.2.3 extraneous
                            ├── lowercase-keys@2.0.0 extraneous
                            ├── lru_map@0.3.3 extraneous
                            ├── lru-cache@6.0.0 extraneous
                            ├── make-dir@3.1.0 extraneous
                            ├── make-fetch-happen@10.2.1 extraneous
                            ├── map-age-cleaner@0.1.3 extraneous
                            ├── map-obj@4.3.0 extraneous
                            ├── map-stream@0.0.7 extraneous
                            ├── md5@2.3.0 extraneous
                            ├── media-typer@0.3.0 extraneous
                            ├── meow@8.1.2 extraneous
                            ├── merge-descriptors@1.0.1 extraneous
                            ├── merge2@1.4.1 extraneous
                            ├── methods@1.1.2 extraneous
                            ├── micro@9.4.1 extraneous
                            ├── micromatch@4.0.7 extraneous
                            ├── mime-db@1.53.0 extraneous
                            ├── mimic-response@1.0.1 extraneous
                            ├── min-indent@1.0.1 extraneous
                            ├── minimatch@9.0.5 extraneous
                            ├── minimist-options@4.1.0 extraneous
                            ├── minipass-collect@1.0.2 extraneous
                            ├── minipass-fetch@2.1.2 extraneous
                            ├── minipass-flush@1.0.5 extraneous
                            ├── minipass-pipeline@1.2.4 extraneous
                            ├── minipass-sized@1.0.3 extraneous
                            ├── minipass@7.1.2 extraneous
                            ├── minizlib@2.1.2 extraneous
                            ├── mkdirp-classic@0.5.3 extraneous
                            ├── mkdirp@1.0.4 extraneous
                            ├── mock-require@3.0.3 extraneous
                            ├── moment-duration-format@2.3.2 extraneous
                            ├── mqtt-connection@4.1.0 extraneous
                            ├── mqtt-packet@9.0.0 extraneous
                            ├── mqtt@ extraneous
                            ├── mute-stream@0.0.8 extraneous
                            ├── named-placeholders@1.1.3 extraneous
                            ├── nan@ extraneous
                            ├── nanoid@3.3.7 extraneous
                            ├── napi-build-utils@1.0.2 extraneous
                            ├── native-duplexpair@1.0.0 extraneous
                            ├── nconf@0.10.0 extraneous
                            ├── nested-property@4.0.0 extraneous
                            ├── netmask@2.0.2 extraneous
                            ├── new-github-release-url@1.0.0 extraneous
                            ├── node-abi@3.65.0 extraneous
                            ├── node-abort-controller@3.1.1 extraneous
                            ├── node-cron@2.0.3 extraneous
                            ├── node-fetch@2.7.0 extraneous
                            ├── node-forge@ extraneous
                            ├── node-gyp@ extraneous
                            ├── node-ical@0.16.1 extraneous
                            ├── node-inspect@2.0.0 extraneous
                            ├── node-libcurl@3.0.0 extraneous
                            ├── node-mndp@0.0.3 extraneous
                            ├── node-persist@0.0.11 extraneous
                            ├── node-rsa@1.1.1 extraneous
                            ├── node-unifi@2.5.1 extraneous
                            ├── node-wol@0.1.1 extraneous
                            ├── node.extend@2.0.3 extraneous
                            ├── nopt@5.0.0 extraneous
                            ├── normalize-package-data@3.0.3 extraneous
                            ├── normalize-path@3.0.0 extraneous
                            ├── normalize-url@6.1.0 extraneous
                            ├── np@7.7.0 extraneous
                            ├── npm-name@6.0.1 extraneous
                            ├── npmlog@5.0.1 extraneous
                            ├── number-allocator@1.0.14 extraneous
                            ├── nwsapi@2.2.12 extraneous
                            ├── object-assign@4.1.1 extraneous
                            ├── object-hash@3.0.0 extraneous
                            ├── on-finished@2.4.1 extraneous
                            ├── once@1.4.0 extraneous
                            ├── one-time@1.0.0 extraneous
                            ├── onedrive-api@1.1.1 extraneous
                            ├── open@7.4.2 extraneous
                            ├── opencollective-postinstall@2.0.3 extraneous
                            ├── optionator@0.8.3 extraneous
                            ├── org-regex@1.0.0 extraneous
                            ├── os-tmpdir@1.0.2 extraneous
                            ├── ospath@1.2.2 extraneous
                            ├── osx-temperature-sensor@ extraneous
                            ├── otplib@11.0.1 extraneous
                            ├── ow@0.21.0 extraneous
                            ├── p-cancelable@2.1.1 extraneous
                            ├── p-defer@1.0.0 extraneous
                            ├── p-event@4.2.0 extraneous
                            ├── p-finally@1.0.0 extraneous
                            ├── p-limit@2.3.0 extraneous
                            ├── p-locate@5.0.0 extraneous
                            ├── p-map@2.1.0 extraneous
                            ├── p-memoize@4.0.4 extraneous
                            ├── p-reflect@2.1.0 extraneous
                            ├── p-settle@4.1.1 extraneous
                            ├── p-throttle@4.1.1 extraneous
                            ├── p-timeout@4.1.0 extraneous
                            ├── p-try@2.2.0 extraneous
                            ├── package-json-from-dist@1.0.0 extraneous
                            ├── package-json@6.5.0 extraneous
                            ├── pako@ extraneous
                            ├── parent-module@1.0.1 extraneous
                            ├── parse-json@5.2.0 extraneous
                            ├── parse5@ extraneous
                            ├── passport-local@1.0.0 extraneous
                            ├── passport@0.7.0 extraneous
                            ├── path-exists@4.0.0 extraneous
                            ├── path-is-absolute@1.0.1 extraneous
                            ├── path-parse@1.0.7 extraneous
                            ├── path-posix@1.0.0 extraneous
                            ├── path-scurry@1.11.1 extraneous
                            ├── path-to-regexp@0.1.7 extraneous
                            ├── path-type@4.0.0 extraneous
                            ├── pause-stream@0.0.11 extraneous
                            ├── picomatch@2.3.1 extraneous
                            ├── pidtree@0.6.0 extraneous
                            ├── pidusage@3.0.2 extraneous
                            ├── ping@0.4.4 extraneous
                            ├── pkg-dir@5.0.0 extraneous
                            ├── pluralize@8.0.0 extraneous
                            ├── possible-typed-array-names@1.0.0 extraneous
                            ├── prebuild-install@7.1.2 extraneous
                            ├── prelude-ls@1.1.2 extraneous
                            ├── prepend-http@2.0.0 extraneous
                            ├── process-nextick-args@2.0.1 extraneous
                            ├── process@0.11.10 extraneous
                            ├── promise-inflight@1.0.1 extraneous
                            ├── promise-object@0.1.7 extraneous
                            ├── promise-retry@2.0.1 extraneous
                            ├── promise-retryer@0.0.1 extraneous
                            ├── promisify-child-process@4.1.2 extraneous
                            ├── prompt@1.3.0 extraneous
                            ├── protobufjs@ extraneous
                            ├── proxy-addr@2.0.7 extraneous
                            ├── proxy-from-env@1.1.0 extraneous
                            ├── pump@3.0.0 extraneous
                            ├── pupa@2.1.1 extraneous
                            ├── q@1.1.2 extraneous
                            ├── quasar@ extraneous
                            ├── queue-microtask@1.2.3 extraneous
                            ├── queue-tick@1.0.1 extraneous
                            ├── quick-lru@5.1.1 extraneous
                            ├── range-parser@1.2.1 extraneous
                            ├── raw-body@2.5.2 extraneous
                            ├── rc@1.2.8 extraneous
                            ├── read-pkg-up@7.0.1 extraneous
                            ├── read-pkg@5.2.0 extraneous
                            ├── read@1.0.7 extraneous
                            ├── readable-stream@ extraneous
                            ├── readdir-glob@1.1.3 extraneous
                            ├── readdirp@3.6.0 extraneous
                            ├── readline-sync@1.4.10 extraneous
                            ├── readline@1.3.0 extraneous
                            ├── redent@3.0.0 extraneous
                            ├── redis-commands@1.7.0 extraneous
                            ├── redis-errors@1.2.0 extraneous
                            ├── redis-parser@3.0.0 extraneous
                            ├── regenerator-runtime@0.14.1 extraneous
                            ├── regex-escape@3.4.10 extraneous
                            ├── regexp.prototype.flags@1.5.2 extraneous
                            ├── registry-auth-token@4.2.2 extraneous
                            ├── registry-url@5.1.0 extraneous
                            ├── reinterval@1.1.0 extraneous
                            ├── remove-trailing-separator@1.1.0 extraneous
                            ├── require-from-string@2.0.2 extraneous
                            ├── resolve-alpn@1.2.1 extraneous
                            ├── resolve-cwd@3.0.0 extraneous
                            ├── resolve-from@4.0.0 extraneous
                            ├── respjs@4.2.0 extraneous
                            ├── responselike@2.0.1 extraneous
                            ├── restore-cursor@3.1.0 extraneous
                            ├── retry-axios@2.6.0 extraneous
                            ├── retry@0.12.0 extraneous
                            ├── reusify@1.0.4 extraneous
                            ├── revalidator@0.1.8 extraneous
                            ├── rfdc@1.4.1 extraneous
                            ├── rimraf@3.0.2 extraneous
                            ├── rrule@2.8.1 extraneous
                            ├── rrweb-cssom@0.6.0 extraneous
                            ├── run-async@2.4.1 extraneous
                            ├── run-parallel@1.2.0 extraneous
                            ├── rxjs@ extraneous
                            ├── safe-array-concat@1.1.2 extraneous
                            ├── safe-regex-test@1.0.3 extraneous
                            ├── safe-stable-stringify@2.4.3 extraneous
                            ├── safer-buffer@2.1.2 extraneous
                            ├── saxes@6.0.0 extraneous
                            ├── scoped-regex@2.1.0 extraneous
                            ├── secure-keys@1.0.0 extraneous
                            ├── semver-diff@3.1.1 extraneous
                            ├── semver@5.7.2
                            ├── send@0.18.0 extraneous
                            ├── seq-logging@1.1.2 extraneous
                            ├── seq-queue@0.0.5 extraneous
                            ├── serve-static@1.15.0 extraneous
                            ├── set-function-name@2.0.2 extraneous
                            ├── setimmediate@1.0.5 extraneous
                            ├── setprototypeof@1.2.0 extraneous
                            ├── signal-exit@4.1.0 extraneous
                            ├── simple-concat@1.0.1 extraneous
                            ├── simple-get@3.1.1 extraneous
                            ├── simple-ssh@1.1.1 extraneous
                            ├── simple-swizzle@0.2.2 extraneous
                            ├── slash@3.0.0 extraneous
                            ├── slice-ansi@0.0.4 extraneous
                            ├── smart-buffer@4.2.0 extraneous
                            ├── socks-proxy-agent@7.0.0 extraneous
                            ├── socks@2.8.3 extraneous
                            ├── speedtest-net@1.6.2 extraneous
                            ├── split@1.0.1 extraneous
                            ├── sprintf-js@1.1.3 extraneous
                            ├── sqlstring@2.3.3 extraneous
                            ├── ssh2@ extraneous
                            ├── ssri@9.0.1 extraneous
                            ├── stack-trace@0.0.10 extraneous
                            ├── stampit-event-bus@0.1.1 extraneous
                            ├── stampit-state-machine@0.2.1 extraneous
                            ├── stampit@2.1.2 extraneous
                            ├── standard-as-callback@2.1.0 extraneous
                            ├── static-eval@2.0.2 extraneous
                            ├── statuses@2.0.1 extraneous
                            ├── stoppable@1.1.0 extraneous
                            ├── stream-combiner@0.2.2 extraneous
                            ├── stream-shift@1.0.3 extraneous
                            ├── streamsearch@1.1.0 extraneous
                            ├── streamx@2.18.0 extraneous
                            ├── string-argv@0.3.2 extraneous
                            ├── string-width-cjs@npm:string-width@4.2.3 extraneous
                            ├── string-width@5.1.2 extraneous
                            ├── string.prototype.trim@1.2.9 extraneous
                            ├── string.prototype.trimend@1.0.8 extraneous
                            ├── string.prototype.trimstart@1.0.8 extraneous
                            ├── strip-ansi-cjs@npm:strip-ansi@6.0.1 extraneous
                            ├── strip-ansi@6.0.1 extraneous
                            ├── strip-indent@3.0.0 extraneous
                            ├── strip-json-comments@2.0.1 extraneous
                            ├── strnum@1.0.5 extraneous
                            ├── suncalc@1.9.0 extraneous
                            ├── suncalc2@1.8.1 extraneous
                            ├── supermixer@1.0.5 extraneous
                            ├── supports-color@7.2.0 extraneous
                            ├── supports-hyperlinks@2.3.0 extraneous
                            ├── supports-preserve-symlinks-flag@1.0.0 extraneous
                            ├── sweet-collections@1.1.0 extraneous
                            ├── symbol-observable@3.0.0 extraneous
                            ├── symbol-tree@3.2.4 extraneous
                            ├── syno@ extraneous
                            ├── systeminformation@ extraneous
                            ├── tar-fs@2.1.1 extraneous
                            ├── tar-stream@3.1.7 extraneous
                            ├── tar@6.2.1 extraneous
                            ├── tarn@3.0.2 extraneous
                            ├── tcp-port-used@1.0.2 extraneous
                            ├── tedious@ extraneous
                            ├── terminal-link@2.1.1 extraneous
                            ├── text-decoder@1.1.1 extraneous
                            ├── text-hex@1.0.0 extraneous
                            ├── thirty-two@1.0.2 extraneous
                            ├── through@2.3.8 extraneous
                            ├── through2@2.0.5 extraneous
                            ├── tiny-typed-emitter@2.1.0 extraneous
                            ├── tinycolor2@1.6.0 extraneous
                            ├── tmp@0.0.33 extraneous
                            ├── to-readable-stream@2.1.0 extraneous
                            ├── to-regex-range@5.0.1 extraneous
                            ├── toidentifier@1.0.1 extraneous
                            ├── tr46@4.1.1 extraneous
                            ├── trim-newlines@3.0.1 extraneous
                            ├── triple-beam@1.4.1 extraneous
                            ├── tsdav@ extraneous
                            ├── tslib@2.3.0 extraneous
                            ├── tweetnacl@0.14.5 extraneous
                            ├── type-check@0.3.2 extraneous
                            ├── type-fest@0.21.3 extraneous
                            ├── type-is@1.6.18 extraneous
                            ├── typed-array-buffer@1.0.2 extraneous
                            ├── typed-array-byte-length@1.0.1 extraneous
                            ├── typed-array-byte-offset@1.0.2 extraneous
                            ├── typed-array-length@1.0.6 extraneous
                            ├── typedarray-to-buffer@3.1.5 extraneous
                            ├── typedarray.prototype.slice@1.0.3 extraneous
                            ├── typescript@ extraneous
                            ├── tz-offset@0.0.1 extraneous
                            ├── uid-number@0.0.6 extraneous
                            ├── unbox-primitive@1.0.2 extraneous
                            ├── undici-types@6.19.6 extraneous
                            ├── unique-filename@2.0.1 extraneous
                            ├── unique-slug@3.0.0 extraneous
                            ├── unique-string@2.0.0 extraneous
                            ├── unix-dgram@2.0.6 extraneous
                            ├── unpipe@1.0.0 extraneous
                            ├── update-notifier@5.1.0 extraneous
                            ├── uri-js@4.4.1 extraneous
                            ├── url-join@4.0.1 extraneous
                            ├── url-parse-lax@3.0.0 extraneous
                            ├── url-template@2.0.8 extraneous
                            ├── url@0.11.4 extraneous
                            ├── vali-date@1.0.0 extraneous
                            ├── validate-npm-package-name@3.0.0 extraneous
                            ├── vary@1.1.2 extraneous
                            ├── virtual-tsc@0.6.2 extraneous
                            ├── vue-i18n@ extraneous
                            ├── vuelidate-messages@0.1.2 extraneous
                            ├── vuelidate@ extraneous
                            ├── vuex-map-fields@1.4.1 extraneous
                            ├── w3c-xmlserializer@4.0.0 extraneous
                            ├── wake_on_lan@1.0.0 extraneous
                            ├── weak-daemon@1.0.3 extraneous
                            ├── webdav@ extraneous
                            ├── webidl-conversions@7.0.0 extraneous
                            ├── websocket-stream@5.5.2 extraneous
                            ├── whatwg-encoding@2.0.0 extraneous
                            ├── whatwg-mimetype@3.0.0 extraneous
                            ├── whatwg-url@12.0.1 extraneous
                            ├── which-boxed-primitive@1.0.2 extraneous
                            ├── which-typed-array@1.1.15 extraneous
                            ├── wide-align@1.1.5 extraneous
                            ├── widest-line@3.1.0 extraneous
                            ├── window-size@0.1.4 extraneous
                            ├── winston-daily-rotate-file@5.0.0 extraneous
                            ├── winston-seq-updated@1.0.4 extraneous
                            ├── winston-syslog@2.7.1 extraneous
                            ├── winston-transport@4.7.1 extraneous
                            ├── winston@ extraneous
                            ├── word-wrap@1.2.5 extraneous
                            ├── worker-timers-broker@6.1.8 extraneous
                            ├── worker-timers-worker@7.0.71 extraneous
                            ├── worker-timers@7.1.8 extraneous
                            ├── wrap-ansi-cjs@npm:wrap-ansi@7.0.0 extraneous
                            ├── wrap-ansi@8.1.0 extraneous
                            ├── wrappy@1.0.2 extraneous
                            ├── write-file-atomic@3.0.3 extraneous
                            ├── xdg-basedir@4.0.0 extraneous
                            ├── xml-js@1.6.11 extraneous
                            ├── xml-name-validator@4.0.0 extraneous
                            ├── xmlchars@2.2.0 extraneous
                            ├── xregexp@2.0.0 extraneous
                            ├── yallist@4.0.0 extraneous
                            ├── yaml@ extraneous
                            ├── yargs-parser@20.2.9 extraneous
                            ├── yargs@7.1.2
                            ├── yocto-queue@0.1.0 extraneous
                            ├── zip-stream@6.0.1 extraneous
                            └── zrender@ extraneous
                              Teil 2
                              npm error code ELSPROBLEMS
                              npm error extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
                              npm error extraneous: @alcalzone/jsonl-db@3.1.1 /opt/iobroker/node_modules/@alcalzone/jsonl-db
                              npm error extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/@alcalzone/pak
                              npm error extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
                              npm error extraneous: @aws-sdk/util-utf8-browser@3.259.0 /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser
                              npm error extraneous: @azure/abort-controller@1.1.0 /opt/iobroker/node_modules/@azure/abort-controller
                              npm error extraneous: @azure/core-auth@1.7.2 /opt/iobroker/node_modules/@azure/core-auth
                              npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
                              npm error extraneous: @azure/core-http-compat@ /opt/iobroker/node_modules/@azure/core-http-compat
                              npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
                              npm error extraneous: @azure/core-paging@1.6.2 /opt/iobroker/node_modules/@azure/core-paging
                              npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
                              npm error extraneous: @azure/core-tracing@1.1.2 /opt/iobroker/node_modules/@azure/core-tracing
                              npm error extraneous: @azure/core-util@ /opt/iobroker/node_modules/@azure/core-util
                              npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
                              npm error extraneous: @azure/keyvault-keys@ /opt/iobroker/node_modules/@azure/keyvault-keys
                              npm error extraneous: @azure/logger@1.1.4 /opt/iobroker/node_modules/@azure/logger
                              npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
                              npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
                              npm error extraneous: @azure/msal-node@1.18.4 /opt/iobroker/node_modules/@azure/msal-node
                              npm error extraneous: @babel/code-frame@7.24.7 /opt/iobroker/node_modules/@babel/code-frame
                              npm error extraneous: @babel/helper-validator-identifier@7.24.7 /opt/iobroker/node_modules/@babel/helper-validator-identifier
                              npm error extraneous: @babel/highlight@7.24.7 /opt/iobroker/node_modules/@babel/highlight
                              npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
                              npm error extraneous: @colors/colors@1.5.0 /opt/iobroker/node_modules/@colors/colors
                              npm error extraneous: @dabh/diagnostics@2.0.3 /opt/iobroker/node_modules/@dabh/diagnostics
                              npm error extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
                              npm error extraneous: @gar/promisify@1.1.3 /opt/iobroker/node_modules/@gar/promisify
                              npm error extraneous: @googleapis/calendar@9.7.7 /opt/iobroker/node_modules/@googleapis/calendar
                              npm error extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
                              npm error extraneous: @googleapis/oauth2@1.0.7 /opt/iobroker/node_modules/@googleapis/oauth2
                              npm error extraneous: @httptoolkit/websocket-stream@6.0.1 /opt/iobroker/node_modules/@httptoolkit/websocket-stream
                              npm error extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
                              npm error extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
                              npm error extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
                              npm error extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
                              npm error extraneous: @iobroker/db-states-file@ /opt/iobroker/node_modules/@iobroker/db-states-file
                              npm error extraneous: @iobroker/db-states-jsonl@ /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                              npm error extraneous: @iobroker/db-states-redis@ /opt/iobroker/node_modules/@iobroker/db-states-redis
                              npm error extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
                              npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
                              npm error extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modules/@iobroker/js-controller-common-db
                              npm error extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
                              npm error extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
                              npm error extraneous: @iobroker/plugin-sentry@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-sentry
                              npm error extraneous: @iobroker/socket-classes@1.5.6 /opt/iobroker/node_modules/@iobroker/socket-classes
                              npm error extraneous: @iobroker/webserver@1.0.3 /opt/iobroker/node_modules/@iobroker/webserver
                              npm error extraneous: @isaacs/cliui@8.0.2 /opt/iobroker/node_modules/@isaacs/cliui
                              npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
                              npm error extraneous: @mapbox/node-pre-gyp@1.0.11 /opt/iobroker/node_modules/@mapbox/node-pre-gyp
                              npm error extraneous: @microsoft/microsoft-graph-types@2.40.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
                              npm error extraneous: @nodelib/fs.scandir@2.1.5 /opt/iobroker/node_modules/@nodelib/fs.scandir
                              npm error extraneous: @nodelib/fs.stat@2.0.5 /opt/iobroker/node_modules/@nodelib/fs.stat
                              npm error extraneous: @nodelib/fs.walk@1.2.8 /opt/iobroker/node_modules/@nodelib/fs.walk
                              npm error extraneous: @npmcli/fs@2.1.2 /opt/iobroker/node_modules/@npmcli/fs
                              npm error extraneous: @npmcli/move-file@2.0.1 /opt/iobroker/node_modules/@npmcli/move-file
                              npm error extraneous: @pkgjs/parseargs@0.11.0 /opt/iobroker/node_modules/@pkgjs/parseargs
                              npm error extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
                              npm error extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
                              npm error extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
                              npm error extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
                              npm error extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
                              npm error extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
                              npm error extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
                              npm error extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
                              npm error extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
                              npm error extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
                              npm error extraneous: @quasar/extras@ /opt/iobroker/node_modules/@quasar/extras
                              npm error extraneous: @samverschueren/stream-to-observable@0.3.1 /opt/iobroker/node_modules/@samverschueren/stream-to-observable
                              npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
                              npm error extraneous: @sentry/core@5.30.0 /opt/iobroker/node_modules/@sentry/core
                              npm error extraneous: @sentry/hub@5.30.0 /opt/iobroker/node_modules/@sentry/hub
                              npm error extraneous: @sentry/minimal@5.30.0 /opt/iobroker/node_modules/@sentry/minimal
                              npm error extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
                              npm error extraneous: @sentry/tracing@ /opt/iobroker/node_modules/@sentry/tracing
                              npm error extraneous: @sentry/types@ /opt/iobroker/node_modules/@sentry/types
                              npm error extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
                              npm error extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/@sindresorhus/is
                              npm error extraneous: @socket.io/component-emitter@3.1.2 /opt/iobroker/node_modules/@socket.io/component-emitter
                              npm error extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/@szmarczak/http-timer
                              npm error extraneous: @tediousjs/connection-string@0.5.0 /opt/iobroker/node_modules/@tediousjs/connection-string
                              npm error extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
                              npm error extraneous: @types/bl@5.1.0 /opt/iobroker/node_modules/@types/bl
                              npm error extraneous: @types/cacheable-request@6.0.3 /opt/iobroker/node_modules/@types/cacheable-request
                              npm error extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                              npm error extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/@types/cookie
                              npm error extraneous: @types/cors@2.8.17 /opt/iobroker/node_modules/@types/cors
                              npm error extraneous: @types/geojson@7946.0.14 /opt/iobroker/node_modules/@types/geojson
                              npm error extraneous: @types/http-cache-semantics@4.0.4 /opt/iobroker/node_modules/@types/http-cache-semantics
                              npm error extraneous: @types/keyv@3.1.4 /opt/iobroker/node_modules/@types/keyv
                              npm error extraneous: @types/leaflet@1.9.12 /opt/iobroker/node_modules/@types/leaflet
                              npm error extraneous: @types/minimist@1.2.5 /opt/iobroker/node_modules/@types/minimist
                              npm error extraneous: @types/node-cron@2.0.8 /opt/iobroker/node_modules/@types/node-cron
                              npm error extraneous: @types/node@ /opt/iobroker/node_modules/@types/node
                              npm error extraneous: @types/normalize-package-data@2.4.4 /opt/iobroker/node_modules/@types/normalize-package-data
                              npm error extraneous: @types/parse-json@4.0.2 /opt/iobroker/node_modules/@types/parse-json
                              npm error extraneous: @types/readable-stream@4.0.15 /opt/iobroker/node_modules/@types/readable-stream
                              npm error extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                              npm error extraneous: @types/responselike@1.0.3 /opt/iobroker/node_modules/@types/responselike
                              npm error extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                              npm error extraneous: @types/triple-beam@1.3.5 /opt/iobroker/node_modules/@types/triple-beam
                              npm error extraneous: @types/tz-offset@0.0.3 /opt/iobroker/node_modules/@types/tz-offset
                              npm error extraneous: @types/ws@8.5.12 /opt/iobroker/node_modules/@types/ws
                              npm error extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
                              npm error extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
                              npm error extraneous: abort-controller@3.0.0 /opt/iobroker/node_modules/abort-controller
                              npm error extraneous: agentkeepalive@4.5.0 /opt/iobroker/node_modules/agentkeepalive
                              npm error extraneous: aggregate-error@3.1.0 /opt/iobroker/node_modules/aggregate-error
                              npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
                              npm error extraneous: ansi-align@3.0.1 /opt/iobroker/node_modules/ansi-align
                              npm error extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/ansi-colors
                              npm error extraneous: ansi-escapes@4.3.2 /opt/iobroker/node_modules/ansi-escapes
                              npm error extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/ansi-regex
                              npm error extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/ansi-styles
                              npm error extraneous: any-observable@0.5.1 /opt/iobroker/node_modules/any-observable
                              npm error extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
                              npm error extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
                              npm error extraneous: archiver-utils@5.0.2 /opt/iobroker/node_modules/archiver-utils
                              npm error extraneous: archiver@7.0.1 /opt/iobroker/node_modules/archiver
                              npm error extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
                              npm error extraneous: arg@4.1.0 /opt/iobroker/node_modules/arg
                              npm error extraneous: argparse@1.0.10 /opt/iobroker/node_modules/argparse
                              npm error extraneous: array-buffer-byte-length@1.0.1 /opt/iobroker/node_modules/array-buffer-byte-length
                              npm error extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/array-flatten
                              npm error extraneous: array-union@2.1.0 /opt/iobroker/node_modules/array-union
                              npm error extraneous: arraybuffer.prototype.slice@1.0.3 /opt/iobroker/node_modules/arraybuffer.prototype.slice
                              npm error extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
                              npm error extraneous: asn1@0.2.6 /opt/iobroker/node_modules/asn1
                              npm error extraneous: async-exit-hook@2.0.1 /opt/iobroker/node_modules/async-exit-hook
                              npm error extraneous: authenticate-pam@1.0.5 /opt/iobroker/node_modules/authenticate-pam
                              npm error extraneous: available-typed-arrays@1.0.7 /opt/iobroker/node_modules/available-typed-arrays
                              npm error extraneous: aws-crt@ /opt/iobroker/node_modules/aws-crt
                              npm error extraneous: b4a@1.6.6 /opt/iobroker/node_modules/b4a
                              npm error extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/balanced-match
                              npm error extraneous: bare-events@2.4.2 /opt/iobroker/node_modules/bare-events
                              npm error extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
                              npm error extraneous: base64-js@1.5.1 /opt/iobroker/node_modules/base64-js
                              npm error extraneous: bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/bcrypt-pbkdf
                              npm error extraneous: binary-extensions@2.3.0 /opt/iobroker/node_modules/binary-extensions
                              npm error extraneous: bindings@1.5.0 /opt/iobroker/node_modules/bindings
                              npm error extraneous: bl@6.0.14 /opt/iobroker/node_modules/bl
                              npm error extraneous: bluebird@3.7.2 /opt/iobroker/node_modules/bluebird
                              npm error extraneous: body-parser@1.20.2 /opt/iobroker/node_modules/body-parser
                              npm error extraneous: bottleneck@2.19.5 /opt/iobroker/node_modules/bottleneck
                              npm error extraneous: boxen@5.1.2 /opt/iobroker/node_modules/boxen
                              npm error extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/brace-expansion
                              npm error extraneous: braces@3.0.3 /opt/iobroker/node_modules/braces
                              npm error extraneous: buffer-crc32@1.0.0 /opt/iobroker/node_modules/buffer-crc32
                              npm error extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
                              npm error extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
                              npm error extraneous: buffer@6.0.3 /opt/iobroker/node_modules/buffer
                              npm error extraneous: buildcheck@0.0.6 /opt/iobroker/node_modules/buildcheck
                              npm error extraneous: builtins@1.0.3 /opt/iobroker/node_modules/builtins
                              npm error extraneous: busboy@1.6.0 /opt/iobroker/node_modules/busboy
                              npm error extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
                              npm error extraneous: bytes@3.1.2 /opt/iobroker/node_modules/bytes
                              npm error extraneous: cacache@16.1.3 /opt/iobroker/node_modules/cacache
                              npm error extraneous: cacheable-lookup@5.0.4 /opt/iobroker/node_modules/cacheable-lookup
                              npm error extraneous: cacheable-request@7.0.4 /opt/iobroker/node_modules/cacheable-request
                              npm error extraneous: callsites@3.1.0 /opt/iobroker/node_modules/callsites
                              npm error extraneous: camelcase-keys@6.2.2 /opt/iobroker/node_modules/camelcase-keys
                              npm error extraneous: camelcase@5.3.1 /opt/iobroker/node_modules/camelcase
                              npm error extraneous: capitalize@2.0.4 /opt/iobroker/node_modules/capitalize
                              npm error extraneous: chalk@4.1.2 /opt/iobroker/node_modules/chalk
                              npm error extraneous: chardet@0.7.0 /opt/iobroker/node_modules/chardet
                              npm error extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
                              npm error extraneous: chokidar@3.6.0 /opt/iobroker/node_modules/chokidar
                              npm error extraneous: chownr@2.0.0 /opt/iobroker/node_modules/chownr
                              npm error extraneous: ci-info@3.9.0 /opt/iobroker/node_modules/ci-info
                              npm error extraneous: clean-stack@2.2.0 /opt/iobroker/node_modules/clean-stack
                              npm error extraneous: cli-boxes@2.2.1 /opt/iobroker/node_modules/cli-boxes
                              npm error extraneous: cli-cursor@3.1.0 /opt/iobroker/node_modules/cli-cursor
                              npm error extraneous: cli-truncate@0.2.1 /opt/iobroker/node_modules/cli-truncate
                              npm error extraneous: cli-width@3.0.0 /opt/iobroker/node_modules/cli-width
                              npm error extraneous: clone-response@1.0.3 /opt/iobroker/node_modules/clone-response
                              npm error extraneous: cloneextend@0.0.3 /opt/iobroker/node_modules/cloneextend
                              npm error extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
                              npm error extraneous: coap-packet@1.1.1 /opt/iobroker/node_modules/coap-packet
                              npm error extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                              npm error extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/color-convert
                              npm error extraneous: color-name@1.1.4 /opt/iobroker/node_modules/color-name
                              npm error extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
                              npm error extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
                              npm error extraneous: color@3.2.1 /opt/iobroker/node_modules/color
                              npm error extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
                              npm error extraneous: commander@9.5.0 /opt/iobroker/node_modules/commander
                              npm error extraneous: commist@3.2.0 /opt/iobroker/node_modules/commist
                              npm error extraneous: compress-commons@6.0.2 /opt/iobroker/node_modules/compress-commons
                              npm error extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
                              npm error extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
                              npm error extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
                              npm error extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
                              npm error extraneous: configstore@5.0.1 /opt/iobroker/node_modules/configstore
                              npm error extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
                              npm error extraneous: connect@3.7.0 /opt/iobroker/node_modules/connect
                              npm error extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
                              npm error extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/content-disposition
                              npm error extraneous: content-type@1.0.5 /opt/iobroker/node_modules/content-type
                              npm error extraneous: core-js@ /opt/iobroker/node_modules/core-js
                              npm error extraneous: cors@2.8.5 /opt/iobroker/node_modules/cors
                              npm error extraneous: cosmiconfig@7.1.0 /opt/iobroker/node_modules/cosmiconfig
                              npm error extraneous: cpu-features@ /opt/iobroker/node_modules/cpu-features
                              npm error extraneous: crc-32@1.2.2 /opt/iobroker/node_modules/crc-32
                              npm error extraneous: crc@ /opt/iobroker/node_modules/crc
                              npm error extraneous: crc32-stream@6.0.0 /opt/iobroker/node_modules/crc32-stream
                              npm error extraneous: cross-fetch@4.0.0 /opt/iobroker/node_modules/cross-fetch
                              npm error extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
                              npm error extraneous: crypto-js@ /opt/iobroker/node_modules/crypto-js
                              npm error extraneous: crypto-random-string@2.0.0 /opt/iobroker/node_modules/crypto-random-string
                              npm error extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
                              npm error extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
                              npm error extraneous: dashdash@1.14.1 /opt/iobroker/node_modules/dashdash
                              npm error extraneous: data-urls@4.0.0 /opt/iobroker/node_modules/data-urls
                              npm error extraneous: data-view-buffer@1.0.1 /opt/iobroker/node_modules/data-view-buffer
                              npm error extraneous: data-view-byte-length@1.0.1 /opt/iobroker/node_modules/data-view-byte-length
                              npm error extraneous: data-view-byte-offset@1.0.0 /opt/iobroker/node_modules/data-view-byte-offset
                              npm error extraneous: date-and-time@ /opt/iobroker/node_modules/date-and-time
                              npm error extraneous: date-fns@1.30.1 /opt/iobroker/node_modules/date-fns
                              npm error extraneous: dateformat@4.6.3 /opt/iobroker/node_modules/dateformat
                              npm error extraneous: dayjs@ /opt/iobroker/node_modules/dayjs
                              npm error extraneous: decache@4.6.2 /opt/iobroker/node_modules/decache
                              npm error extraneous: decamelize-keys@1.1.1 /opt/iobroker/node_modules/decamelize-keys
                              npm error extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
                              npm error extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
                              npm error extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
                              npm error extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
                              npm error extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is
                              npm error extraneous: defer-to-connect@2.0.1 /opt/iobroker/node_modules/defer-to-connect
                              npm error extraneous: define-lazy-prop@2.0.0 /opt/iobroker/node_modules/define-lazy-prop
                              npm error extraneous: del@6.1.1 /opt/iobroker/node_modules/del
                              npm error extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
                              npm error extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
                              npm error extraneous: destroy@1.2.0 /opt/iobroker/node_modules/destroy
                              npm error extraneous: detect-libc@2.0.3 /opt/iobroker/node_modules/detect-libc
                              npm error extraneous: diacritics@1.3.0 /opt/iobroker/node_modules/diacritics
                              npm error extraneous: digest-header@1.1.0 /opt/iobroker/node_modules/digest-header
                              npm error extraneous: dir-glob@3.0.1 /opt/iobroker/node_modules/dir-glob
                              npm error extraneous: diskusage@1.2.0 /opt/iobroker/node_modules/diskusage
                              npm error extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception
                              npm error extraneous: dot-prop@6.0.1 /opt/iobroker/node_modules/dot-prop
                              npm error extraneous: draftlog@1.0.13 /opt/iobroker/node_modules/draftlog
                              npm error extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
                              npm error extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
                              npm error extraneous: duplexer3@0.1.5 /opt/iobroker/node_modules/duplexer3
                              npm error extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/duplexify
                              npm error extraneous: eastasianwidth@0.2.0 /opt/iobroker/node_modules/eastasianwidth
                              npm error extraneous: ecc-jsbn@0.1.2 /opt/iobroker/node_modules/ecc-jsbn
                              npm error extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
                              npm error extraneous: echarts@ /opt/iobroker/node_modules/echarts
                              npm error extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/ee-first
                              npm error extraneous: elegant-spinner@1.0.1 /opt/iobroker/node_modules/elegant-spinner
                              npm error extraneous: emoji-regex@9.2.2 /opt/iobroker/node_modules/emoji-regex
                              npm error extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
                              npm error extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/encodeurl
                              npm error extraneous: encoding@0.1.13 /opt/iobroker/node_modules/encoding
                              npm error extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/end-of-stream
                              npm error extraneous: entities@4.5.0 /opt/iobroker/node_modules/entities
                              npm error extraneous: err-code@2.0.3 /opt/iobroker/node_modules/err-code
                              npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
                              npm error extraneous: es-aggregate-error@1.0.13 /opt/iobroker/node_modules/es-aggregate-error
                              npm error extraneous: es-object-atoms@1.0.0 /opt/iobroker/node_modules/es-object-atoms
                              npm error extraneous: es-set-tostringtag@2.0.3 /opt/iobroker/node_modules/es-set-tostringtag
                              npm error extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
                              npm error extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
                              npm error extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
                              npm error extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
                              npm error extraneous: escalade@3.1.2 /opt/iobroker/node_modules/escalade
                              npm error extraneous: escape-goat@3.0.0 /opt/iobroker/node_modules/escape-goat
                              npm error extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/escape-html
                              npm error extraneous: escape-string-regexp@4.0.0 /opt/iobroker/node_modules/escape-string-regexp
                              npm error extraneous: escodegen@1.14.3 /opt/iobroker/node_modules/escodegen
                              npm error extraneous: esprima@1.2.2 /opt/iobroker/node_modules/esprima
                              npm error extraneous: estraverse@4.3.0 /opt/iobroker/node_modules/estraverse
                              npm error extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils
                              npm error extraneous: etag@1.8.1 /opt/iobroker/node_modules/etag
                              npm error extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
                              npm error extraneous: event-target-shim@5.0.1 /opt/iobroker/node_modules/event-target-shim
                              npm error extraneous: eventemitter2@6.4.9 /opt/iobroker/node_modules/eventemitter2
                              npm error extraneous: events@3.3.0 /opt/iobroker/node_modules/events
                              npm error extraneous: execa@5.1.1 /opt/iobroker/node_modules/execa
                              npm error extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
                              npm error extraneous: express-fileupload@1.5.1 /opt/iobroker/node_modules/express-fileupload
                              npm error extraneous: express@4.19.2 /opt/iobroker/node_modules/express
                              npm error extraneous: external-editor@3.1.0 /opt/iobroker/node_modules/external-editor
                              npm error extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
                              npm error extraneous: fast-fifo@1.3.2 /opt/iobroker/node_modules/fast-fifo
                              npm error extraneous: fast-glob@ /opt/iobroker/node_modules/fast-glob
                              npm error extraneous: fast-json-stable-stringify@2.1.0 /opt/iobroker/node_modules/fast-json-stable-stringify
                              npm error extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein
                              npm error extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
                              npm error extraneous: fast-unique-numbers@ /opt/iobroker/node_modules/fast-unique-numbers
                              npm error extraneous: fast-uri@3.0.1 /opt/iobroker/node_modules/fast-uri
                              npm error extraneous: fast-xml-parser@ /opt/iobroker/node_modules/fast-xml-parser
                              npm error extraneous: fastq@1.17.1 /opt/iobroker/node_modules/fastq
                              npm error extraneous: fastseries@2.0.0 /opt/iobroker/node_modules/fastseries
                              npm error extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
                              npm error extraneous: figures@3.2.0 /opt/iobroker/node_modules/figures
                              npm error extraneous: file-stream-rotator@0.6.1 /opt/iobroker/node_modules/file-stream-rotator
                              npm error extraneous: file-type@10.11.0 /opt/iobroker/node_modules/file-type
                              npm error extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
                              npm error extraneous: fill-range@7.1.1 /opt/iobroker/node_modules/fill-range
                              npm error extraneous: finalhandler@1.2.0 /opt/iobroker/node_modules/finalhandler
                              npm error extraneous: find-up@5.0.0 /opt/iobroker/node_modules/find-up
                              npm error extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
                              npm error extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
                              npm error extraneous: foreground-child@3.3.0 /opt/iobroker/node_modules/foreground-child
                              npm error extraneous: form-data-encoder@2.1.4 /opt/iobroker/node_modules/form-data-encoder
                              npm error extraneous: form-data@4.0.0 /opt/iobroker/node_modules/form-data
                              npm error extraneous: forwarded@0.2.0 /opt/iobroker/node_modules/forwarded
                              npm error extraneous: fresh@0.5.2 /opt/iobroker/node_modules/fresh
                              npm error extraneous: from@0.1.7 /opt/iobroker/node_modules/from
                              npm error extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
                              npm error extraneous: fs-minipass@2.1.0 /opt/iobroker/node_modules/fs-minipass
                              npm error extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
                              npm error extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
                              npm error extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
                              npm error extraneous: function.prototype.name@1.1.6 /opt/iobroker/node_modules/function.prototype.name
                              npm error extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
                              npm error extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
                              npm error extraneous: gauge@3.0.2 /opt/iobroker/node_modules/gauge
                              npm error extraneous: gaxios@5.1.3 /opt/iobroker/node_modules/gaxios
                              npm error extraneous: gcp-metadata@5.3.0 /opt/iobroker/node_modules/gcp-metadata
                              npm error extraneous: generate-function@2.3.1 /opt/iobroker/node_modules/generate-function
                              npm error extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ssl-certificate
                              npm error extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/get-stream
                              npm error extraneous: get-symbol-description@1.0.2 /opt/iobroker/node_modules/get-symbol-description
                              npm error extraneous: getpass@0.1.7 /opt/iobroker/node_modules/getpass
                              npm error extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
                              npm error extraneous: github-url-from-git@1.5.0 /opt/iobroker/node_modules/github-url-from-git
                              npm error extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/glob-parent
                              npm error extraneous: glob@10.4.5 /opt/iobroker/node_modules/glob
                              npm error extraneous: global-dirs@2.1.0 /opt/iobroker/node_modules/global-dirs
                              npm error extraneous: globalthis@1.0.4 /opt/iobroker/node_modules/globalthis
                              npm error extraneous: globby@11.1.0 /opt/iobroker/node_modules/globby
                              npm error extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
                              npm error extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
                              npm error extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
                              npm error extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
                              npm error extraneous: googleapis@ /opt/iobroker/node_modules/googleapis
                              npm error extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
                              npm error extraneous: hard-rejection@2.1.0 /opt/iobroker/node_modules/hard-rejection
                              npm error extraneous: has-ansi@2.0.0 /opt/iobroker/node_modules/has-ansi
                              npm error extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
                              npm error extraneous: has-flag@4.0.0 /opt/iobroker/node_modules/has-flag
                              npm error extraneous: has-tostringtag@1.0.2 /opt/iobroker/node_modules/has-tostringtag
                              npm error extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
                              npm error extraneous: has-yarn@2.1.0 /opt/iobroker/node_modules/has-yarn
                              npm error extraneous: he@1.2.0 /opt/iobroker/node_modules/he
                              npm error extraneous: help-me@5.0.0 /opt/iobroker/node_modules/help-me
                              npm error extraneous: homebridge-plugin-wrapper@ /opt/iobroker/node_modules/homebridge-plugin-wrapper
                              npm error extraneous: hosted-git-info@3.0.8 /opt/iobroker/node_modules/hosted-git-info
                              npm error extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
                              npm error extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
                              npm error extraneous: http-cache-semantics@4.1.1 /opt/iobroker/node_modules/http-cache-semantics
                              npm error extraneous: http-errors@2.0.0 /opt/iobroker/node_modules/http-errors
                              npm error extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
                              npm error extraneous: http2-wrapper@1.0.3 /opt/iobroker/node_modules/http2-wrapper
                              npm error extraneous: https@1.0.0 /opt/iobroker/node_modules/https
                              npm error extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
                              npm error extraneous: ical.js@ /opt/iobroker/node_modules/ical.js
                              npm error extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/iconv-lite
                              npm error extraneous: ieee754@1.2.1 /opt/iobroker/node_modules/ieee754
                              npm error extraneous: ignore-walk@3.0.4 /opt/iobroker/node_modules/ignore-walk
                              npm error extraneous: ignore@5.3.2 /opt/iobroker/node_modules/ignore
                              npm error extraneous: image-type@4.1.0 /opt/iobroker/node_modules/image-type
                              npm error extraneous: immediate@3.0.6 /opt/iobroker/node_modules/immediate
                              npm error extraneous: import-fresh@3.3.0 /opt/iobroker/node_modules/import-fresh
                              npm error extraneous: import-lazy@2.1.0 /opt/iobroker/node_modules/import-lazy
                              npm error extraneous: import-local@3.2.0 /opt/iobroker/node_modules/import-local
                              npm error extraneous: imurmurhash@0.1.4 /opt/iobroker/node_modules/imurmurhash
                              npm error extraneous: indent-string@3.2.0 /opt/iobroker/node_modules/indent-string
                              npm error extraneous: infer-owner@1.0.4 /opt/iobroker/node_modules/infer-owner
                              npm error extraneous: inflight@1.0.6 /opt/iobroker/node_modules/inflight
                              npm error extraneous: ini@1.3.7 /opt/iobroker/node_modules/ini
                              npm error extraneous: inquirer-autosubmit-prompt@0.2.0 /opt/iobroker/node_modules/inquirer-autosubmit-prompt
                              npm error extraneous: inquirer@7.3.3 /opt/iobroker/node_modules/inquirer
                              npm error extraneous: int64-buffer@1.0.1 /opt/iobroker/node_modules/int64-buffer
                              npm error extraneous: internal-slot@1.0.7 /opt/iobroker/node_modules/internal-slot
                              npm error extraneous: iobroker-adapter-helpers@0.0.8 /opt/iobroker/node_modules/iobroker-adapter-helpers
                              npm error invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
                              npm error invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
                              npm error invalid: iobroker.calendar@ /opt/iobroker/node_modules/iobroker.calendar
                              npm error invalid: iobroker.discovery@ /opt/iobroker/node_modules/iobroker.discovery
                              npm error invalid: iobroker.echarts@ /opt/iobroker/node_modules/iobroker.echarts
                              npm error invalid: iobroker.energiefluss@ /opt/iobroker/node_modules/iobroker.energiefluss
                              npm error invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
                              npm error invalid: iobroker.fullcalendar@ /opt/iobroker/node_modules/iobroker.fullcalendar
                              npm error invalid: iobroker.gartenbewaesserung@ /opt/iobroker/node_modules/iobroker.gartenbewaesserung
                              npm error invalid: iobroker.ham@ /opt/iobroker/node_modules/iobroker.ham
                              npm error invalid: iobroker.heatingcontrol@ /opt/iobroker/node_modules/iobroker.heatingcontrol
                              npm error invalid: iobroker.ical@ /opt/iobroker/node_modules/iobroker.ical
                              npm error invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
                              npm error invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
                              npm error invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
                              npm error invalid: iobroker.material@ /opt/iobroker/node_modules/iobroker.material
                              npm error invalid: iobroker.milight-smart-light@ /opt/iobroker/node_modules/iobroker.milight-smart-light
                              npm error invalid: iobroker.mobile@ /opt/iobroker/node_modules/iobroker.mobile
                              npm error invalid: iobroker.modbus@ /opt/iobroker/node_modules/iobroker.modbus
                              npm error invalid: iobroker.mqtt@ /opt/iobroker/node_modules/iobroker.mqtt
                              npm error invalid: iobroker.nina@ /opt/iobroker/node_modules/iobroker.nina
                              npm error invalid: iobroker.renault@ /opt/iobroker/node_modules/iobroker.renault
                              npm error invalid: iobroker.reolink@ /opt/iobroker/node_modules/iobroker.reolink
                              npm error invalid: iobroker.schoolfree@ /opt/iobroker/node_modules/iobroker.schoolfree
                              npm error invalid: iobroker.sourceanalytix@ /opt/iobroker/node_modules/iobroker.sourceanalytix
                              npm error invalid: iobroker.synology@ /opt/iobroker/node_modules/iobroker.synology
                              npm error invalid: iobroker.tankerkoenig@ /opt/iobroker/node_modules/iobroker.tankerkoenig
                              npm error invalid: iobroker.terminal@ /opt/iobroker/node_modules/iobroker.terminal
                              npm error invalid: iobroker.unifi@ /opt/iobroker/node_modules/iobroker.unifi
                              npm error invalid: iobroker.viessmannapi@ /opt/iobroker/node_modules/iobroker.viessmannapi
                              npm error invalid: iobroker.virtualpowermeter@ /opt/iobroker/node_modules/iobroker.virtualpowermeter
                              npm error invalid: iobroker.vis-2-widgets-material@ /opt/iobroker/node_modules/iobroker.vis-2-widgets-material
                              npm error invalid: iobroker.vis-2@ /opt/iobroker/node_modules/iobroker.vis-2
                              npm error invalid: iobroker.vis-colorpicker@ /opt/iobroker/node_modules/iobroker.vis-colorpicker
                              npm error invalid: iobroker.vis-hqwidgets@ /opt/iobroker/node_modules/iobroker.vis-hqwidgets
                              npm error invalid: iobroker.vis-inventwo@ /opt/iobroker/node_modules/iobroker.vis-inventwo
                              npm error invalid: iobroker.vis-materialdesign@ /opt/iobroker/node_modules/iobroker.vis-materialdesign
                              npm error invalid: iobroker.vis-metro@ /opt/iobroker/node_modules/iobroker.vis-metro
                              npm error invalid: iobroker.vis-timeandweather@ /opt/iobroker/node_modules/iobroker.vis-timeandweather
                              npm error invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
                              npm error invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
                              npm error invalid: iobroker.vofo-speedtest@ /opt/iobroker/node_modules/iobroker.vofo-speedtest
                              npm error invalid: iobroker.web-speedy@ /opt/iobroker/node_modules/iobroker.web-speedy
                              npm error invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
                              npm error invalid: iobroker.webcal@ /opt/iobroker/node_modules/iobroker.webcal
                              npm error extraneous: ioredis@ /opt/iobroker/node_modules/ioredis
                              npm error extraneous: ip-address@9.0.5 /opt/iobroker/node_modules/ip-address
                              npm error extraneous: ip-regex@4.3.0 /opt/iobroker/node_modules/ip-regex
                              npm error extraneous: ipaddr.js@2.2.0 /opt/iobroker/node_modules/ipaddr.js
                              npm error extraneous: is-array-buffer@3.0.4 /opt/iobroker/node_modules/is-array-buffer
                              npm error extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
                              npm error extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
                              npm error extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
                              npm error extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
                              npm error extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
                              npm error extraneous: is-ci@2.0.0 /opt/iobroker/node_modules/is-ci
                              npm error extraneous: is-core-module@2.15.0 /opt/iobroker/node_modules/is-core-module
                              npm error extraneous: is-data-view@1.0.1 /opt/iobroker/node_modules/is-data-view
                              npm error extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
                              npm error extraneous: is-docker@2.2.1 /opt/iobroker/node_modules/is-docker
                              npm error extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
                              npm error extraneous: is-extglob@2.1.1 /opt/iobroker/node_modules/is-extglob
                              npm error extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/is-fullwidth-code-point
                              npm error extraneous: is-glob@4.0.3 /opt/iobroker/node_modules/is-glob
                              npm error extraneous: is-installed-globally@0.3.2 /opt/iobroker/node_modules/is-installed-globally
                              npm error extraneous: is-interactive@1.0.0 /opt/iobroker/node_modules/is-interactive
                              npm error extraneous: is-lambda@1.0.1 /opt/iobroker/node_modules/is-lambda
                              npm error extraneous: is-negative-zero@2.0.3 /opt/iobroker/node_modules/is-negative-zero
                              npm error extraneous: is-npm@5.0.0 /opt/iobroker/node_modules/is-npm
                              npm error extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
                              npm error extraneous: is-number@7.0.0 /opt/iobroker/node_modules/is-number
                              npm error extraneous: is-obj@2.0.0 /opt/iobroker/node_modules/is-obj
                              npm error extraneous: is-observable@1.1.0 /opt/iobroker/node_modules/is-observable
                              npm error extraneous: is-path-cwd@2.2.0 /opt/iobroker/node_modules/is-path-cwd
                              npm error extraneous: is-path-inside@3.0.3 /opt/iobroker/node_modules/is-path-inside
                              npm error extraneous: is-plain-obj@1.1.0 /opt/iobroker/node_modules/is-plain-obj
                              npm error extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
                              npm error extraneous: is-promise@2.2.2 /opt/iobroker/node_modules/is-promise
                              npm error extraneous: is-property@1.0.2 /opt/iobroker/node_modules/is-property
                              npm error extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
                              npm error extraneous: is-scoped@2.1.0 /opt/iobroker/node_modules/is-scoped
                              npm error extraneous: is-shared-array-buffer@1.0.3 /opt/iobroker/node_modules/is-shared-array-buffer
                              npm error extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
                              npm error extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
                              npm error extraneous: is-typed-array@1.1.13 /opt/iobroker/node_modules/is-typed-array
                              npm error extraneous: is-unicode-supported@0.1.0 /opt/iobroker/node_modules/is-unicode-supported
                              npm error extraneous: is-url-superb@4.0.0 /opt/iobroker/node_modules/is-url-superb
                              npm error extraneous: is-url@1.2.4 /opt/iobroker/node_modules/is-url
                              npm error extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
                              npm error extraneous: is-wsl@2.2.0 /opt/iobroker/node_modules/is-wsl
                              npm error extraneous: is-yarn-global@0.3.0 /opt/iobroker/node_modules/is-yarn-global
                              npm error extraneous: is@3.3.0 /opt/iobroker/node_modules/is
                              npm error extraneous: is2@2.0.9 /opt/iobroker/node_modules/is2
                              npm error extraneous: isomorphic-ws@4.0.1 /opt/iobroker/node_modules/isomorphic-ws
                              npm error extraneous: issue-regex@3.1.0 /opt/iobroker/node_modules/issue-regex
                              npm error extraneous: jackspeak@3.4.3 /opt/iobroker/node_modules/jackspeak
                              npm error extraneous: js-md4@0.3.2 /opt/iobroker/node_modules/js-md4
                              npm error extraneous: js-sdsl@4.3.0 /opt/iobroker/node_modules/js-sdsl
                              npm error extraneous: js-tokens@4.0.0 /opt/iobroker/node_modules/js-tokens
                              npm error extraneous: js-yaml@ /opt/iobroker/node_modules/js-yaml
                              npm error extraneous: jsbi@4.3.0 /opt/iobroker/node_modules/jsbi
                              npm error extraneous: jsbn@1.1.0 /opt/iobroker/node_modules/jsbn
                              npm error extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
                              npm error extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
                              npm error extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/json-buffer
                              npm error extraneous: json-logic-js@2.0.5 /opt/iobroker/node_modules/json-logic-js
                              npm error extraneous: json-parse-even-better-errors@2.3.1 /opt/iobroker/node_modules/json-parse-even-better-errors
                              npm error extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse
                              npm error extraneous: json5@2.2.3 /opt/iobroker/node_modules/json5
                              npm error extraneous: jsonata@ /opt/iobroker/node_modules/jsonata
                              npm error extraneous: jsonc-parser@3.3.1 /opt/iobroker/node_modules/jsonc-parser
                              npm error extraneous: jsonwebtoken@9.0.2 /opt/iobroker/node_modules/jsonwebtoken
                              npm error extraneous: jszip@ /opt/iobroker/node_modules/jszip
                              npm error extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
                              npm error extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
                              npm error extraneous: keyv@4.5.4 /opt/iobroker/node_modules/keyv
                              npm error extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/kind-of
                              npm error extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
                              npm error extraneous: later@1.2.0 /opt/iobroker/node_modules/later
                              npm error extraneous: latest-version@5.1.0 /opt/iobroker/node_modules/latest-version
                              npm error extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
                              npm error extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/lazystream
                              npm error extraneous: leven@2.1.0 /opt/iobroker/node_modules/leven
                              npm error extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn
                              npm error extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
                              npm error extraneous: lines-and-columns@1.2.4 /opt/iobroker/node_modules/lines-and-columns
                              npm error extraneous: listr-input@0.2.1 /opt/iobroker/node_modules/listr-input
                              npm error extraneous: listr-silent-renderer@1.1.1 /opt/iobroker/node_modules/listr-silent-renderer
                              npm error extraneous: listr-update-renderer@0.5.0 /opt/iobroker/node_modules/listr-update-renderer
                              npm error extraneous: listr-verbose-renderer@0.5.0 /opt/iobroker/node_modules/listr-verbose-renderer
                              npm error extraneous: listr@0.14.3 /opt/iobroker/node_modules/listr
                              npm error extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
                              npm error extraneous: locate-path@6.0.0 /opt/iobroker/node_modules/locate-path
                              npm error extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
                              npm error extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
                              npm error extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
                              npm error extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
                              npm error extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
                              npm error extraneous: lodash.isequal@4.5.0 /opt/iobroker/node_modules/lodash.isequal
                              npm error extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
                              npm error extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
                              npm error extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
                              npm error extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
                              npm error extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
                              npm error extraneous: lodash.zip@4.2.0 /opt/iobroker/node_modules/lodash.zip
                              npm error extraneous: log-symbols@4.1.0 /opt/iobroker/node_modules/log-symbols
                              npm error extraneous: log-update@2.3.0 /opt/iobroker/node_modules/log-update
                              npm error extraneous: logform@ /opt/iobroker/node_modules/logform
                              npm error extraneous: long@5.2.3 /opt/iobroker/node_modules/long
                              npm error extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/lowercase-keys
                              npm error extraneous: lru_map@0.3.3 /opt/iobroker/node_modules/lru_map
                              npm error extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/lru-cache
                              npm error extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
                              npm error extraneous: make-fetch-happen@10.2.1 /opt/iobroker/node_modules/make-fetch-happen
                              npm error extraneous: map-age-cleaner@0.1.3 /opt/iobroker/node_modules/map-age-cleaner
                              npm error extraneous: map-obj@4.3.0 /opt/iobroker/node_modules/map-obj
                              npm error extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
                              npm error extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
                              npm error extraneous: media-typer@0.3.0 /opt/iobroker/node_modules/media-typer
                              npm error extraneous: meow@8.1.2 /opt/iobroker/node_modules/meow
                              npm error extraneous: merge-descriptors@1.0.1 /opt/iobroker/node_modules/merge-descriptors
                              npm error extraneous: merge2@1.4.1 /opt/iobroker/node_modules/merge2
                              npm error extraneous: methods@1.1.2 /opt/iobroker/node_modules/methods
                              npm error extraneous: micro@9.4.1 /opt/iobroker/node_modules/micro
                              npm error extraneous: micromatch@4.0.7 /opt/iobroker/node_modules/micromatch
                              npm error extraneous: mime-db@1.53.0 /opt/iobroker/node_modules/mime-db
                              npm error extraneous: mimic-response@1.0.1 /opt/iobroker/node_modules/mimic-response
                              npm error extraneous: min-indent@1.0.1 /opt/iobroker/node_modules/min-indent
                              npm error extraneous: minimatch@9.0.5 /opt/iobroker/node_modules/minimatch
                              npm error extraneous: minimist-options@4.1.0 /opt/iobroker/node_modules/minimist-options
                              npm error extraneous: minipass-collect@1.0.2 /opt/iobroker/node_modules/minipass-collect
                              npm error extraneous: minipass-fetch@2.1.2 /opt/iobroker/node_modules/minipass-fetch
                              npm error extraneous: minipass-flush@1.0.5 /opt/iobroker/node_modules/minipass-flush
                              npm error extraneous: minipass-pipeline@1.2.4 /opt/iobroker/node_modules/minipass-pipeline
                              npm error extraneous: minipass-sized@1.0.3 /opt/iobroker/node_modules/minipass-sized
                              npm error extraneous: minipass@7.1.2 /opt/iobroker/node_modules/minipass
                              npm error extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/minizlib
                              npm error extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
                              npm error extraneous: mkdirp@1.0.4 /opt/iobroker/node_modules/mkdirp
                              npm error extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
                              npm error extraneous: moment-duration-format@2.3.2 /opt/iobroker/node_modules/moment-duration-format
                              npm error extraneous: mqtt-connection@4.1.0 /opt/iobroker/node_modules/mqtt-connection
                              npm error extraneous: mqtt-packet@9.0.0 /opt/iobroker/node_modules/mqtt-packet
                              npm error extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
                              npm error extraneous: mute-stream@0.0.8 /opt/iobroker/node_modules/mute-stream
                              npm error extraneous: named-placeholders@1.1.3 /opt/iobroker/node_modules/named-placeholders
                              npm error extraneous: nan@ /opt/iobroker/node_modules/nan
                              npm error extraneous: nanoid@3.3.7 /opt/iobroker/node_modules/nanoid
                              npm error extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
                              npm error extraneous: native-duplexpair@1.0.0 /opt/iobroker/node_modules/native-duplexpair
                              npm error extraneous: nconf@0.10.0 /opt/iobroker/node_modules/nconf
                              npm error extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
                              npm error extraneous: netmask@2.0.2 /opt/iobroker/node_modules/netmask
                              npm error extraneous: new-github-release-url@1.0.0 /opt/iobroker/node_modules/new-github-release-url
                              npm error extraneous: node-abi@3.65.0 /opt/iobroker/node_modules/node-abi
                              npm error extraneous: node-abort-controller@3.1.1 /opt/iobroker/node_modules/node-abort-controller
                              npm error extraneous: node-cron@2.0.3 /opt/iobroker/node_modules/node-cron
                              npm error extraneous: node-fetch@2.7.0 /opt/iobroker/node_modules/node-fetch
                              npm error extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
                              npm error extraneous: node-gyp@ /opt/iobroker/node_modules/node-gyp
                              npm error extraneous: node-ical@0.16.1 /opt/iobroker/node_modules/node-ical
                              npm error extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                              npm error extraneous: node-libcurl@3.0.0 /opt/iobroker/node_modules/node-libcurl
                              npm error extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
                              npm error extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
                              npm error extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
                              npm error extraneous: node-unifi@2.5.1 /opt/iobroker/node_modules/node-unifi
                              npm error extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
                              npm error extraneous: node.extend@2.0.3 /opt/iobroker/node_modules/node.extend
                              npm error extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
                              npm error extraneous: normalize-package-data@3.0.3 /opt/iobroker/node_modules/normalize-package-data
                              npm error extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
                              npm error extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/normalize-url
                              npm error extraneous: np@7.7.0 /opt/iobroker/node_modules/np
                              npm error extraneous: npm-name@6.0.1 /opt/iobroker/node_modules/npm-name
                              npm error extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
                              npm error extraneous: number-allocator@1.0.14 /opt/iobroker/node_modules/number-allocator
                              npm error extraneous: nwsapi@2.2.12 /opt/iobroker/node_modules/nwsapi
                              npm error extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assign
                              npm error extraneous: object-hash@3.0.0 /opt/iobroker/node_modules/object-hash
                              npm error extraneous: on-finished@2.4.1 /opt/iobroker/node_modules/on-finished
                              npm error extraneous: once@1.4.0 /opt/iobroker/node_modules/once
                              npm error extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
                              npm error extraneous: onedrive-api@1.1.1 /opt/iobroker/node_modules/onedrive-api
                              npm error extraneous: open@7.4.2 /opt/iobroker/node_modules/open
                              npm error extraneous: opencollective-postinstall@2.0.3 /opt/iobroker/node_modules/opencollective-postinstall
                              npm error extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator
                              npm error extraneous: org-regex@1.0.0 /opt/iobroker/node_modules/org-regex
                              npm error extraneous: os-tmpdir@1.0.2 /opt/iobroker/node_modules/os-tmpdir
                              npm error extraneous: ospath@1.2.2 /opt/iobroker/node_modules/ospath
                              npm error extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
                              npm error extraneous: otplib@11.0.1 /opt/iobroker/node_modules/otplib
                              npm error extraneous: ow@0.21.0 /opt/iobroker/node_modules/ow
                              npm error extraneous: p-cancelable@2.1.1 /opt/iobroker/node_modules/p-cancelable
                              npm error extraneous: p-defer@1.0.0 /opt/iobroker/node_modules/p-defer
                              npm error extraneous: p-event@4.2.0 /opt/iobroker/node_modules/p-event
                              npm error extraneous: p-finally@1.0.0 /opt/iobroker/node_modules/p-finally
                              npm error extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/p-limit
                              npm error extraneous: p-locate@5.0.0 /opt/iobroker/node_modules/p-locate
                              npm error extraneous: p-map@2.1.0 /opt/iobroker/node_modules/p-map
                              npm error extraneous: p-memoize@4.0.4 /opt/iobroker/node_modules/p-memoize
                              npm error extraneous: p-reflect@2.1.0 /opt/iobroker/node_modules/p-reflect
                              npm error extraneous: p-settle@4.1.1 /opt/iobroker/node_modules/p-settle
                              npm error extraneous: p-throttle@4.1.1 /opt/iobroker/node_modules/p-throttle
                              npm error extraneous: p-timeout@4.1.0 /opt/iobroker/node_modules/p-timeout
                              npm error extraneous: p-try@2.2.0 /opt/iobroker/node_modules/p-try
                              npm error extraneous: package-json-from-dist@1.0.0 /opt/iobroker/node_modules/package-json-from-dist
                              npm error extraneous: package-json@6.5.0 /opt/iobroker/node_modules/package-json
                              npm error extraneous: pako@ /opt/iobroker/node_modules/pako
                              npm error extraneous: parent-module@1.0.1 /opt/iobroker/node_modules/parent-module
                              npm error extraneous: parse-json@5.2.0 /opt/iobroker/node_modules/parse-json
                              npm error extraneous: parse5@ /opt/iobroker/node_modules/parse5
                              npm error extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
                              npm error extraneous: passport@0.7.0 /opt/iobroker/node_modules/passport
                              npm error extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/path-exists
                              npm error extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
                              npm error extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
                              npm error extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
                              npm error extraneous: path-scurry@1.11.1 /opt/iobroker/node_modules/path-scurry
                              npm error extraneous: path-to-regexp@0.1.7 /opt/iobroker/node_modules/path-to-regexp
                              npm error extraneous: path-type@4.0.0 /opt/iobroker/node_modules/path-type
                              npm error extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
                              npm error extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/picomatch
                              npm error extraneous: pidtree@0.6.0 /opt/iobroker/node_modules/pidtree
                              npm error extraneous: pidusage@3.0.2 /opt/iobroker/node_modules/pidusage
                              npm error extraneous: ping@0.4.4 /opt/iobroker/node_modules/ping
                              npm error extraneous: pkg-dir@5.0.0 /opt/iobroker/node_modules/pkg-dir
                              npm error extraneous: pluralize@8.0.0 /opt/iobroker/node_modules/pluralize
                              npm error extraneous: possible-typed-array-names@1.0.0 /opt/iobroker/node_modules/possible-typed-array-names
                              npm error extraneous: prebuild-install@7.1.2 /opt/iobroker/node_modules/prebuild-install
                              npm error extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls
                              npm error extraneous: prepend-http@2.0.0 /opt/iobroker/node_modules/prepend-http
                              npm error extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/process-nextick-args
                              npm error extraneous: process@0.11.10 /opt/iobroker/node_modules/process
                              npm error extraneous: promise-inflight@1.0.1 /opt/iobroker/node_modules/promise-inflight
                              npm error extraneous: promise-object@0.1.7 /opt/iobroker/node_modules/promise-object
                              npm error extraneous: promise-retry@2.0.1 /opt/iobroker/node_modules/promise-retry
                              npm error extraneous: promise-retryer@0.0.1 /opt/iobroker/node_modules/promise-retryer
                              npm error extraneous: promisify-child-process@4.1.2 /opt/iobroker/node_modules/promisify-child-process
                              npm error extraneous: prompt@1.3.0 /opt/iobroker/node_modules/prompt
                              npm error extraneous: protobufjs@ /opt/iobroker/node_modules/protobufjs
                              npm error extraneous: proxy-addr@2.0.7 /opt/iobroker/node_modules/proxy-addr
                              npm error extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
                              npm error extraneous: pump@3.0.0 /opt/iobroker/node_modules/pump
                              npm error extraneous: pupa@2.1.1 /opt/iobroker/node_modules/pupa
                              npm error extraneous: q@1.1.2 /opt/iobroker/node_modules/q
                              npm error extraneous: quasar@ /opt/iobroker/node_modules/quasar
                              npm error extraneous: queue-microtask@1.2.3 /opt/iobroker/node_modules/queue-microtask
                              npm error extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
                              npm error extraneous: quick-lru@5.1.1 /opt/iobroker/node_modules/quick-lru
                              npm error extraneous: range-parser@1.2.1 /opt/iobroker/node_modules/range-parser
                              npm error extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/raw-body
                              npm error extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
                              npm error extraneous: read-pkg-up@7.0.1 /opt/iobroker/node_modules/read-pkg-up
                              npm error extraneous: read-pkg@5.2.0 /opt/iobroker/node_modules/read-pkg
                              npm error extraneous: read@1.0.7 /opt/iobroker/node_modules/read
                              npm error extraneous: readable-stream@ /opt/iobroker/node_modules/readable-stream
                              npm error extraneous: readdir-glob@1.1.3 /opt/iobroker/node_modules/readdir-glob
                              npm error extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
                              npm error extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
                              npm error extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
                              npm error extraneous: redent@3.0.0 /opt/iobroker/node_modules/redent
                              npm error extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
                              npm error extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
                              npm error extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
                              npm error extraneous: regenerator-runtime@0.14.1 /opt/iobroker/node_modules/regenerator-runtime
                              npm error extraneous: regex-escape@3.4.10 /opt/iobroker/node_modules/regex-escape
                              npm error extraneous: regexp.prototype.flags@1.5.2 /opt/iobroker/node_modules/regexp.prototype.flags
                              npm error extraneous: registry-auth-token@4.2.2 /opt/iobroker/node_modules/registry-auth-token
                              npm error extraneous: registry-url@5.1.0 /opt/iobroker/node_modules/registry-url
                              npm error extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
                              npm error extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
                              npm error extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string
                              npm error extraneous: resolve-alpn@1.2.1 /opt/iobroker/node_modules/resolve-alpn
                              npm error extraneous: resolve-cwd@3.0.0 /opt/iobroker/node_modules/resolve-cwd
                              npm error extraneous: resolve-from@4.0.0 /opt/iobroker/node_modules/resolve-from
                              npm error extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
                              npm error extraneous: responselike@2.0.1 /opt/iobroker/node_modules/responselike
                              npm error extraneous: restore-cursor@3.1.0 /opt/iobroker/node_modules/restore-cursor
                              npm error extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
                              npm error extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
                              npm error extraneous: reusify@1.0.4 /opt/iobroker/node_modules/reusify
                              npm error extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
                              npm error extraneous: rfdc@1.4.1 /opt/iobroker/node_modules/rfdc
                              npm error extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/rimraf
                              npm error extraneous: rrule@2.8.1 /opt/iobroker/node_modules/rrule
                              npm error extraneous: rrweb-cssom@0.6.0 /opt/iobroker/node_modules/rrweb-cssom
                              npm error extraneous: run-async@2.4.1 /opt/iobroker/node_modules/run-async
                              npm error extraneous: run-parallel@1.2.0 /opt/iobroker/node_modules/run-parallel
                              npm error extraneous: rxjs@ /opt/iobroker/node_modules/rxjs
                              npm error extraneous: safe-array-concat@1.1.2 /opt/iobroker/node_modules/safe-array-concat
                              npm error extraneous: safe-regex-test@1.0.3 /opt/iobroker/node_modules/safe-regex-test
                              npm error extraneous: safe-stable-stringify@2.4.3 /opt/iobroker/node_modules/safe-stable-stringify
                              npm error extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/safer-buffer
                              npm error extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
                              npm error extraneous: scoped-regex@2.1.0 /opt/iobroker/node_modules/scoped-regex
                              npm error extraneous: secure-keys@1.0.0 /opt/iobroker/node_modules/secure-keys
                              npm error extraneous: semver-diff@3.1.1 /opt/iobroker/node_modules/semver-diff
                              npm error extraneous: send@0.18.0 /opt/iobroker/node_modules/send
                              npm error extraneous: seq-logging@1.1.2 /opt/iobroker/node_modules/seq-logging
                              npm error extraneous: seq-queue@0.0.5 /opt/iobroker/node_modules/seq-queue
                              npm error extraneous: serve-static@1.15.0 /opt/iobroker/node_modules/serve-static
                              npm error extraneous: set-function-name@2.0.2 /opt/iobroker/node_modules/set-function-name
                              npm error extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
                              npm error extraneous: setprototypeof@1.2.0 /opt/iobroker/node_modules/setprototypeof
                              npm error extraneous: signal-exit@4.1.0 /opt/iobroker/node_modules/signal-exit
                              npm error extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
                              npm error extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
                              npm error extraneous: simple-ssh@1.1.1 /opt/iobroker/node_modules/simple-ssh
                              npm error extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
                              npm error extraneous: slash@3.0.0 /opt/iobroker/node_modules/slash
                              npm error extraneous: slice-ansi@0.0.4 /opt/iobroker/node_modules/slice-ansi
                              npm error extraneous: smart-buffer@4.2.0 /opt/iobroker/node_modules/smart-buffer
                              npm error extraneous: socks-proxy-agent@7.0.0 /opt/iobroker/node_modules/socks-proxy-agent
                              npm error extraneous: socks@2.8.3 /opt/iobroker/node_modules/socks
                              npm error extraneous: speedtest-net@1.6.2 /opt/iobroker/node_modules/speedtest-net
                              npm error extraneous: split@1.0.1 /opt/iobroker/node_modules/split
                              npm error extraneous: sprintf-js@1.1.3 /opt/iobroker/node_modules/sprintf-js
                              npm error extraneous: sqlstring@2.3.3 /opt/iobroker/node_modules/sqlstring
                              npm error extraneous: ssh2@ /opt/iobroker/node_modules/ssh2
                              npm error extraneous: ssri@9.0.1 /opt/iobroker/node_modules/ssri
                              npm error extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
                              npm error extraneous: stampit-event-bus@0.1.1 /opt/iobroker/node_modules/stampit-event-bus
                              npm error extraneous: stampit-state-machine@0.2.1 /opt/iobroker/node_modules/stampit-state-machine
                              npm error extraneous: stampit@2.1.2 /opt/iobroker/node_modules/stampit
                              npm error extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
                              npm error extraneous: static-eval@2.0.2 /opt/iobroker/node_modules/static-eval
                              npm error extraneous: statuses@2.0.1 /opt/iobroker/node_modules/statuses
                              npm error extraneous: stoppable@1.1.0 /opt/iobroker/node_modules/stoppable
                              npm error extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
                              npm error extraneous: stream-shift@1.0.3 /opt/iobroker/node_modules/stream-shift
                              npm error extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
                              npm error extraneous: streamx@2.18.0 /opt/iobroker/node_modules/streamx
                              npm error extraneous: string-argv@0.3.2 /opt/iobroker/node_modules/string-argv
                              npm error extraneous: string-width-cjs@npm:string-width@4.2.3 /opt/iobroker/node_modules/string-width-cjs
                              npm error extraneous: string-width@5.1.2 /opt/iobroker/node_modules/string-width
                              npm error extraneous: string.prototype.trim@1.2.9 /opt/iobroker/node_modules/string.prototype.trim
                              npm error extraneous: string.prototype.trimend@1.0.8 /opt/iobroker/node_modules/string.prototype.trimend
                              npm error extraneous: string.prototype.trimstart@1.0.8 /opt/iobroker/node_modules/string.prototype.trimstart
                              npm error extraneous: strip-ansi-cjs@npm:strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi-cjs
                              npm error extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi
                              npm error extraneous: strip-indent@3.0.0 /opt/iobroker/node_modules/strip-indent
                              npm error extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
                              npm error extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
                              npm error extraneous: suncalc@1.9.0 /opt/iobroker/node_modules/suncalc
                              npm error extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                              npm error extraneous: supermixer@1.0.5 /opt/iobroker/node_modules/supermixer
                              npm error extraneous: supports-color@7.2.0 /opt/iobroker/node_modules/supports-color
                              npm error extraneous: supports-hyperlinks@2.3.0 /opt/iobroker/node_modules/supports-hyperlinks
                              npm error extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
                              npm error extraneous: sweet-collections@1.1.0 /opt/iobroker/node_modules/sweet-collections
                              npm error extraneous: symbol-observable@3.0.0 /opt/iobroker/node_modules/symbol-observable
                              npm error extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
                              npm error extraneous: syno@ /opt/iobroker/node_modules/syno
                              npm error extraneous: systeminformation@ /opt/iobroker/node_modules/systeminformation
                              npm error extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
                              npm error extraneous: tar-stream@3.1.7 /opt/iobroker/node_modules/tar-stream
                              npm error extraneous: tar@6.2.1 /opt/iobroker/node_modules/tar
                              npm error extraneous: tarn@3.0.2 /opt/iobroker/node_modules/tarn
                              npm error extraneous: tcp-port-used@1.0.2 /opt/iobroker/node_modules/tcp-port-used
                              npm error extraneous: tedious@ /opt/iobroker/node_modules/tedious
                              npm error extraneous: terminal-link@2.1.1 /opt/iobroker/node_modules/terminal-link
                              npm error extraneous: text-decoder@1.1.1 /opt/iobroker/node_modules/text-decoder
                              npm error extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
                              npm error extraneous: thirty-two@1.0.2 /opt/iobroker/node_modules/thirty-two
                              npm error extraneous: through@2.3.8 /opt/iobroker/node_modules/through
                              npm error extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
                              npm error extraneous: tiny-typed-emitter@2.1.0 /opt/iobroker/node_modules/tiny-typed-emitter
                              npm error extraneous: tinycolor2@1.6.0 /opt/iobroker/node_modules/tinycolor2
                              npm error extraneous: tmp@0.0.33 /opt/iobroker/node_modules/tmp
                              npm error extraneous: to-readable-stream@2.1.0 /opt/iobroker/node_modules/to-readable-stream
                              npm error extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/to-regex-range
                              npm error extraneous: toidentifier@1.0.1 /opt/iobroker/node_modules/toidentifier
                              npm error extraneous: tr46@4.1.1 /opt/iobroker/node_modules/tr46
                              npm error extraneous: trim-newlines@3.0.1 /opt/iobroker/node_modules/trim-newlines
                              npm error extraneous: triple-beam@1.4.1 /opt/iobroker/node_modules/triple-beam
                              npm error extraneous: tsdav@ /opt/iobroker/node_modules/tsdav
                              npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/tslib
                              npm error extraneous: tweetnacl@0.14.5 /opt/iobroker/node_modules/tweetnacl
                              npm error extraneous: type-check@0.3.2 /opt/iobroker/node_modules/type-check
                              npm error extraneous: type-fest@0.21.3 /opt/iobroker/node_modules/type-fest
                              npm error extraneous: type-is@1.6.18 /opt/iobroker/node_modules/type-is
                              npm error extraneous: typed-array-buffer@1.0.2 /opt/iobroker/node_modules/typed-array-buffer
                              npm error extraneous: typed-array-byte-length@1.0.1 /opt/iobroker/node_modules/typed-array-byte-length
                              npm error extraneous: typed-array-byte-offset@1.0.2 /opt/iobroker/node_modules/typed-array-byte-offset
                              npm error extraneous: typed-array-length@1.0.6 /opt/iobroker/node_modules/typed-array-length
                              npm error extraneous: typedarray-to-buffer@3.1.5 /opt/iobroker/node_modules/typedarray-to-buffer
                              npm error extraneous: typedarray.prototype.slice@1.0.3 /opt/iobroker/node_modules/typedarray.prototype.slice
                              npm error extraneous: typescript@ /opt/iobroker/node_modules/typescript
                              npm error extraneous: tz-offset@0.0.1 /opt/iobroker/node_modules/tz-offset
                              npm error extraneous: uid-number@0.0.6 /opt/iobroker/node_modules/uid-number
                              npm error extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
                              npm error extraneous: undici-types@6.19.6 /opt/iobroker/node_modules/undici-types
                              npm error extraneous: unique-filename@2.0.1 /opt/iobroker/node_modules/unique-filename
                              npm error extraneous: unique-slug@3.0.0 /opt/iobroker/node_modules/unique-slug
                              npm error extraneous: unique-string@2.0.0 /opt/iobroker/node_modules/unique-string
                              npm error extraneous: unix-dgram@2.0.6 /opt/iobroker/node_modules/unix-dgram
                              npm error extraneous: unpipe@1.0.0 /opt/iobroker/node_modules/unpipe
                              npm error extraneous: update-notifier@5.1.0 /opt/iobroker/node_modules/update-notifier
                              npm error extraneous: uri-js@4.4.1 /opt/iobroker/node_modules/uri-js
                              npm error extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
                              npm error extraneous: url-parse-lax@3.0.0 /opt/iobroker/node_modules/url-parse-lax
                              npm error extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
                              npm error extraneous: url@0.11.4 /opt/iobroker/node_modules/url
                              npm error extraneous: vali-date@1.0.0 /opt/iobroker/node_modules/vali-date
                              npm error extraneous: validate-npm-package-name@3.0.0 /opt/iobroker/node_modules/validate-npm-package-name
                              npm error extraneous: vary@1.1.2 /opt/iobroker/node_modules/vary
                              npm error extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                              npm error extraneous: vue-i18n@ /opt/iobroker/node_modules/vue-i18n
                              npm error extraneous: vuelidate-messages@0.1.2 /opt/iobroker/node_modules/vuelidate-messages
                              npm error extraneous: vuelidate@ /opt/iobroker/node_modules/vuelidate
                              npm error extraneous: vuex-map-fields@1.4.1 /opt/iobroker/node_modules/vuex-map-fields
                              npm error extraneous: w3c-xmlserializer@4.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
                              npm error extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                              npm error extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
                              npm error extraneous: webdav@ /opt/iobroker/node_modules/webdav
                              npm error extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
                              npm error extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
                              npm error extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
                              npm error extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
                              npm error extraneous: whatwg-url@12.0.1 /opt/iobroker/node_modules/whatwg-url
                              npm error extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
                              npm error extraneous: which-typed-array@1.1.15 /opt/iobroker/node_modules/which-typed-array
                              npm error extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
                              npm error extraneous: widest-line@3.1.0 /opt/iobroker/node_modules/widest-line
                              npm error extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
                              npm error extraneous: winston-daily-rotate-file@5.0.0 /opt/iobroker/node_modules/winston-daily-rotate-file
                              npm error extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
                              npm error extraneous: winston-syslog@2.7.1 /opt/iobroker/node_modules/winston-syslog
                              npm error extraneous: winston-transport@4.7.1 /opt/iobroker/node_modules/winston-transport
                              npm error extraneous: winston@ /opt/iobroker/node_modules/winston
                              npm error extraneous: word-wrap@1.2.5 /opt/iobroker/node_modules/word-wrap
                              npm error extraneous: worker-timers-broker@6.1.8 /opt/iobroker/node_modules/worker-timers-broker
                              npm error extraneous: worker-timers-worker@7.0.71 /opt/iobroker/node_modules/worker-timers-worker
                              npm error extraneous: worker-timers@7.1.8 /opt/iobroker/node_modules/worker-timers
                              npm error extraneous: wrap-ansi-cjs@npm:wrap-ansi@7.0.0 /opt/iobroker/node_modules/wrap-ansi-cjs
                              npm error extraneous: wrap-ansi@8.1.0 /opt/iobroker/node_modules/wrap-ansi
                              npm error extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/wrappy
                              npm error extraneous: write-file-atomic@3.0.3 /opt/iobroker/node_modules/write-file-atomic
                              npm error extraneous: xdg-basedir@4.0.0 /opt/iobroker/node_modules/xdg-basedir
                              npm error extraneous: xml-js@1.6.11 /opt/iobroker/node_modules/xml-js
                              npm error extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
                              npm error extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
                              npm error extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
                              npm error extraneous: yallist@4.0.0 /opt/iobroker/node_modules/yallist
                              npm error extraneous: yaml@ /opt/iobroker/node_modules/yaml
                              npm error extraneous: yargs-parser@20.2.9 /opt/iobroker/node_modules/yargs-parser
                              npm error extraneous: yocto-queue@0.1.0 /opt/iobroker/node_modules/yocto-queue
                              npm error extraneous: zip-stream@6.0.1 /opt/iobroker/node_modules/zip-stream
                              npm error extraneous: zrender@ /opt/iobroker/node_modules/zrender
                              npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T20_16_41_191Z-debug-0.log
                                Thomas Braun Most Active @flommaster last edited by
                                @flommaster
                                iob repo list
                                  flommaster @Thomas Braun last edited by
                                  flo@ioBrokerdebian:/opt/iobroker$ iob repo list
                                  node:internal/modules/cjs/loader:1148
                                    throw err;
                                  Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                      at Module._resolveFilename (node:internal/modules/cjs/loader:1145:15)
                                      at Module._load (node:internal/modules/cjs/loader:986:27)
                                      at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
                                      at node:internal/main/run_main_module:28:49 {
                                    code: 'MODULE_NOT_FOUND',
                                    requireStack: []
                                  Node.js v20.16.0
                                    Homoran Global Moderator Administrators @flommaster last edited by
                                    @flommaster sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                                    flo@ioBrokerdebian:/opt/iobroker$ npm prune
                                    hast du beide Befehle auf einmal gestartet?
                                    bitte einzeln abarbeiten
                                    F Thomas Braun 2 Replies Last reply Reply Quote 1
                                      flommaster @Homoran last edited by
                                      Ja,
                                      Hier ist das Ergebnis von "npm prune"
                                      npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.web-speedy.git
                                      npm warn skipping integrity check for git dependency ssh://git@github.com/peterbaumert/ioBroker.vofo-speedtest.git
                                      npm warn skipping integrity check for git dependency ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git
                                      npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2-widgets-material.git
                                      npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2.git
                                      npm warn skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git
                                      npm warn skipping integrity check for git dependency ssh://git@github.com/aendue/ioBroker.reolink.git
                                      npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.ical.git
                                      npm warn skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git
                                      npm warn skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git
                                      npm warn skipping integrity check for git dependency ssh://git@github.com/WLAN-Kabel/ioBroker.calendar.git
                                      npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                                      npm warn deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                                      npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                                      npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
                                      npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
                                      npm warn deprecated uid-number@0.0.6: This package is no longer supported.
                                      npm warn deprecated npmlog@5.0.1: This package is no longer supported.
                                      npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                                      npm warn deprecated npmlog@6.0.2: This package is no longer supported.
                                      npm warn deprecated har-validator@5.1.5: this library is no longer supported
                                      npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                                      npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
                                      npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
                                      npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
                                      npm warn deprecated q@1.1.2: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
                                      npm warn deprecated
                                      npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
                                      npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                                      npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                                      npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
                                      npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
                                      npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                                      npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
                                      npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                                      npm warn deprecated google-p12-pem@3.1.4: Package is no longer maintained
                                      npm warn deprecated gauge@3.0.2: This package is no longer supported.
                                      npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                      npm warn deprecated gauge@4.0.4: This package is no longer supported.
                                      npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                        Thomas Braun Most Active @Homoran last edited by Thomas Braun
                                        @flommaster
                                        Gerade noch gehabt...
                                        Vollständig.
                                        Inkl. vollständiger Eingabezeile inkl. login prompt. Damit man sieht was du da genau in welchem Verzeichnis mit welchem User eingegeben hast.
                                        Und auch inkl. der neuen leeren Eingabezeile, damit man sieht das es durchgelaufen ist und da nix fehlt.
                                        iobroker url https://github.com/DrozmotiX/ioBroker.sourceanalytix --debug
                                          flommaster @Thomas Braun last edited by flommaster
                                          @thomas-braun @Homoran
                                          hier ist noch das Ergebnis von npm prune
                                          root@ioBrokerdebian:/home/flo# npm prune
                                          up to date, audited 135 packages in 2s
                                          11 packages are looking for funding
                                            run `npm fund` for details
                                          4 vulnerabilities (2 moderate, 2 high)
                                          To address all issues, run:
                                            npm audit fix
                                          Run `npm audit` for details.
                                          npm ls
                                          root@ioBrokerdebian:/home/flo# npm ls
                                          flo@ /home/flo
                                          └── iobroker.admin@6.10.2
                                          Vielen Dank und viele Grüße
                                            root@
                                            Nie nie niemals als root herumkaspern...
                                            5358
