    4. timedatectl failed
    timedatectl failed
    • N
      Nordischerjung last edited by
      Moin,
      ich habe im iOBroker als Hinweis, dass die Zeiten zwischen Browser und iOBroker Server einen Unterschiede von 66 Minuten haben.
      Da dachte ich mir, gut guckste mal mit timedatectl, was da eingestellt ist und dann kam das dabei heraus:
      sb@iOBroker:~$ timedatectl
      Failed to query server: Failed to activate service 'org.freedesktop.timedate1': timed out (service_start_timeout=25000ms)
      sb@iOBroker:~$ sudo systemctl restart systemd-timedated
      Job for systemd-timedated.service failed because the control process exited with error code.
      See "systemctl status systemd-timedated.service" and "journalctl -xeu systemd-timedated.service" for details.
      Das steht inm Status:
      sb@iOBroker:~$ systemctl status systemd-timedated.service
      x systemd-timedated.service - Time & Date Service
           Loaded: loaded (/lib/systemd/system/systemd-timedated.service; static)
           Active: failed (Result: exit-code) since Mon 2024-08-19 10:28:08 CEST; 1min 4s ago
             Docs: man:systemd-timedated.service(8)
                   man:localtime(5)
                   man:org.freedesktop.timedate1(5)
          Process: 4908 ExecStart=/lib/systemd/systemd-timedated (code=exited, status=226/NAMESPACE)
         Main PID: 4908 (code=exited, status=226/NAMESPACE)
              CPU: 14ms
      Aug 19 10:28:08 iOBroker systemd[1]: Starting systemd-timedated.service - Time & Date Service...
      Aug 19 10:28:08 iOBroker (imedated)[4908]: systemd-timedated.service: Failed to set up mount namespacing: /run/systemd/unit-root/proc: Permission denied
      Aug 19 10:28:08 iOBroker (imedated)[4908]: systemd-timedated.service: Failed at step NAMESPACE spawning /lib/systemd/systemd-timedated: Permission denied
      Aug 19 10:28:08 iOBroker systemd[1]: systemd-timedated.service: Main process exited, code=exited, status=226/NAMESPACE
      Aug 19 10:28:08 iOBroker systemd[1]: systemd-timedated.service: Failed with result 'exit-code'.
      Aug 19 10:28:08 iOBroker systemd[1]: Failed to start systemd-timedated.service - Time & Date Service.
      ich habe auch schon den iob fix laufen lassen.
      Ich weiß auch gar nicht, seit wann das Problem besteht.
      Hat jemand einen Tip?
      und hier noch iob diag
      Skript v.2024-05-22
      *** BASE SYSTEM ***
      Failed to query system properties: Connection timed out
      model name      : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       11:56:08 up  3:32,  2 users,  load average: 0.79, 0.77, 0.79
      CPU threads: 4
      *** Time and Time Zones ***
      *** Users and Groups ***
      User that called 'iob diag':
      sb
      HOME=/home/sb
      GROUPS=sb adm sudo iobroker lxc_shares
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            6.4G        3.6G        1.7G         98K        1.2G        2.8G
      Swap:           6.4G          0B        6.4G
      Total:           12G        3.6G        8.1G
      Active iob-Instances:   38
               6144 M total memory
               3452 M used memory
               3012 M active memory
                976 M inactive memory
               1585 M free memory
                  0 M buffer memory
               1106 M swap cache
               6144 M total swap
                  0 M used swap
               6144 M free swap
      top - 11:56:33 up  3:33,  2 users,  load average: 0.98, 0.82, 0.81
      Tasks:  64 total,   1 running,  62 sleeping,   1 stopped,   0 zombie
      %Cpu(s): 25.0 us, 25.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   6144.0 total,   1584.0 free,   3454.1 used,   1106.0 buff/cache
      MiB Swap:   6144.0 total,   6144.0 free,      0.0 used.   2689.9 avail Mem
      *** FAILED SERVICES ***
        UNIT                      LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount      loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount   loaded failed failed Kernel Configuration File System
      * influxdb.service          loaded failed failed InfluxDB is an open-source, distributed, time series database
      * networking.service        loaded failed failed Raise network interfaces
      * systemd-hostnamed.service loaded failed failed Hostname Service
      * systemd-logind.service    loaded failed failed User Login Management
      * systemd-timedated.service loaded failed failed Time & Date Service
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      7 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--101--disk--0 ext4       25G   15G  8.7G  63% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
      tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs                            tmpfs     1.6G   92K  1.6G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs                            tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-sysctl.service
      tmpfs                            tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-sysusers.service
      tmpfs                            tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-tmpfiles-setup-dev.service
      tmpfs                            tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-tmpfiles-setup.service
      dmesg: read kernel buffer failed: Operation not permitted
      Show mounted filesystems:
      TARGET                                                  SOURCE                           FSTYPE     OPTIONS
      /                                                       /dev/mapper/pve-vm--101--disk--0 ext4       rw,relatime,stripe=16
      |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=1596100k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
      | |-/run/lock                                           tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
      | |-/run/credentials/systemd-sysctl.service             tmpfs                            tmpfs      ro,nosuid,nodev,noexec,relatime,size=1024k,nr_inodes=1024,mode=700,uid=100000,gid=100000,inode64
      | |-/run/credentials/systemd-sysusers.service           tmpfs                            tmpfs      ro,nosuid,nodev,noexec,relatime,size=1024k,nr_inodes=1024,mode=700,uid=100000,gid=100000,inode64
      | |-/run/credentials/systemd-tmpfiles-setup-dev.service tmpfs                            tmpfs      ro,nosuid,nodev,noexec,relatime,size=1024k,nr_inodes=1024,mode=700,uid=100000,gid=100000,inode64
      | `-/run/credentials/systemd-tmpfiles-setup.service     tmpfs                            tmpfs      ro,nosuid,nodev,noexec,relatime,size=1024k,nr_inodes=1024,mode=700,uid=100000,gid=100000,inode64
      |-/dev                                                  none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
      | |-/dev/shm                                            tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
      | |-/dev/mqueue                                         mqueue                           mqueue     rw,nosuid,nodev,noexec,relatime
      | |-/dev/full                                           udev[/full]                      devtmpfs   rw,nosuid,relatime,size=3956416k,nr_inodes=989104,mode=755,inode64
      | |-/dev/null                                           udev[/null]                      devtmpfs   rw,nosuid,relatime,size=3956416k,nr_inodes=989104,mode=755,inode64
      | |-/dev/random                                         udev[/random]                    devtmpfs   rw,nosuid,relatime,size=3956416k,nr_inodes=989104,mode=755,inode64
      | |-/dev/tty                                            udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=3956416k,nr_inodes=989104,mode=755,inode64
      | |-/dev/urandom                                        udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=3956416k,nr_inodes=989104,mode=755,inode64
      | |-/dev/zero                                           udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=3956416k,nr_inodes=989104,mode=755,inode64
      | |-/dev/pts                                            devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/ptmx                                           devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/console                                        devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | |-/dev/tty1                                           devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      | `-/dev/tty2                                           devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
      |-/proc                                                 proc                             proc       rw,nosuid,nodev,noexec,relatime
      | |-/proc/sys                                           proc[/sys]                       proc       ro,relatime
      | | |-/proc/sys/net                                     proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
      | | `-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
      | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]             proc       ro,relatime
      | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/diskstats                                     lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/loadavg                                       lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/meminfo                                       lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/stat                                          lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | |-/proc/swaps                                         lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      | `-/proc/uptime                                        lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      `-/sys                                                  sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
        |-/sys/fs/fuse/connections                            fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
        |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
        |-/sys/fs/cgroup                                      none                             cgroup2    rw,nosuid,nodev,noexec,relatime
        `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
      /var:
      1.1G    /var/
      597M    /var/lib
      432M    /var/cache
      427M    /var/cache/apt
      400M    /var/lib/influxdb
      Archived and active journals take up 24.0M in the file system.
      /opt/iobroker/backups:
      494M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      4.3G    /opt/iobroker/iobroker-data/
      1.9G    /opt/iobroker/iobroker-data/files
      1.6G    /opt/iobroker/iobroker-data/history
      656M    /opt/iobroker/iobroker-data/files/vis-2-beta
      573M    /opt/iobroker/iobroker-data/files/vis-2-beta/static
      90M     /opt/iobroker/iobroker-data/states.jsonl
      55M     /opt/iobroker/iobroker-data/objects.jsonl
      41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.16.0
      /usr/bin/node           v20.16.0
      /usr/bin/npm            10.8.1
      /usr/bin/npx            10.8.1
      /usr/bin/corepack       0.28.2
      nodejs:
        Installed: 20.16.0-1nodesource1
        Candidate: 20.16.0-1nodesource1
        Version table:
       *** 20.16.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.9
      admin:          7.0.22
      javascript:     8.7.6
      nodejs modules from github:     9
      +-- iobroker.esphome@0.2.4 (git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#479f1eec57b0fa67cb6b72e14d3db853ca778801)
      +-- iobroker.hm-rega@4.0.0 (git+ssh://git@github.com/ioBroker/ioBroker.hm-rega.git#ce42f9cfcb88d4884c204ffc8545e2c0c65a2b73)
      +-- iobroker.icons-icons8@0.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.icons-icons8.git#119cfa311105f1dbe4e674909c975cce7046977f)
      +-- iobroker.mytime@0.7.12 (git+ssh://git@github.com/oweitman/ioBroker.mytime.git#e14111fe835aab072d9a53d1d16fdbb004906c44)
      +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#9c4635239c7b9321601dcf0fcdd8677a55a8b13f)
      | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      +-- iobroker.tapo@0.2.9 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#bded02134bbcc37543a2af51224c4d50c718088f)
      +-- iobroker.vaillant@0.7.2 (git+ssh://git@github.com/TA2k/ioBroker.vaillant.git#3567516e477b37552195d02f4cc8d94d0bf9de65)
      +-- iobroker.vofo-speedtest@0.0.13 (git+ssh://git@github.com/peterbaumert/ioBroker.vofo-speedtest.git#31b8cdda3ad63524bfa926060845b920cf4f151d)
      Adapter State
      + system.adapter.admin.0                  : admin                 : iOBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : iOBroker                                 -  enabled
        system.adapter.alias-manager.0          : alias-manager         : iOBroker                                 - disabled
      + system.adapter.backitup.0               : backitup              : iOBroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : iOBroker                                 -  enabled
        system.adapter.device-watcher.0         : device-watcher        : iOBroker                                 - disabled
      + system.adapter.discovery.0              : discovery             : iOBroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : iOBroker                                 -  enabled
        system.adapter.easee.0                  : easee                 : iOBroker                                 - disabled
        system.adapter.echarts.0                : echarts               : iOBroker                                 - disabled
      + system.adapter.enigma2.0                : enigma2               : iOBroker                                 -  enabled
      + system.adapter.esphome.0                : esphome               : iOBroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : iOBroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iOBroker                                 - disabled
        system.adapter.ford.0                   : ford                  : iOBroker                                 - disabled
        system.adapter.fritzdect.0              : fritzdect             : iOBroker                                 - disabled
      + system.adapter.fullybrowser.0           : fullybrowser          : iOBroker                                 -  enabled
      + system.adapter.harmony.0                : harmony               : iOBroker                                 -  enabled
      + system.adapter.heatingcontrol.0         : heatingcontrol        : iOBroker                                 -  enabled
        system.adapter.hiob.0                   : hiob                  : iOBroker                                 - disabled, port: 8090
        system.adapter.history.0                : history               : iOBroker                                 - disabled
      + system.adapter.hm-rega.0                : hm-rega               : iOBroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iOBroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : iOBroker                                 -  enabled, port: 0
        system.adapter.hue-extended.0           : hue-extended          : iOBroker                                 - disabled
      + system.adapter.hue.0                    : hue                   : iOBroker                                 -  enabled, port: 80
        system.adapter.ical.0                   : ical                  : iOBroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : iOBroker                                 -  enabled
        system.adapter.ical.2                   : ical                  : iOBroker                                 -  enabled
        system.adapter.ical.3                   : ical                  : iOBroker                                 -  enabled
        system.adapter.ical.4                   : ical                  : iOBroker                                 -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : iOBroker                                 - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : iOBroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iOBroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iOBroker                                 - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iOBroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : iOBroker                                 -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : iOBroker                                 -  enabled
      + system.adapter.iqontrol.0               : iqontrol              : iOBroker                                 -  enabled
        system.adapter.jarvis.0                 : jarvis                : iOBroker                                 - disabled
      + system.adapter.javascript.0             : javascript            : iOBroker                                 -  enabled
      + system.adapter.javascript.1             : javascript            : iOBroker                                 -  enabled
        system.adapter.logparser.0              : logparser             : iOBroker                                 - disabled
        system.adapter.material.0               : material              : iOBroker                                 - disabled
      + system.adapter.meross.0                 : meross                : iOBroker                                 -  enabled
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : iOBroker                                 - disabled, port: 54321
      + system.adapter.mqtt.0                   : mqtt                  : iOBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.mqtt.1                   : mqtt                  : iOBroker                                 -  enabled, port: 1899, bind: 0.0.0.0
        system.adapter.mytime.0                 : mytime                : iOBroker                                 - disabled
        system.adapter.onkyo.0                  : onkyo                 : iOBroker                                 - disabled
        system.adapter.openweathermap.0         : openweathermap        : iOBroker                                 - disabled
        system.adapter.ping.0                   : ping                  : iOBroker                                 - disabled
        system.adapter.proxmox.0                : proxmox               : iOBroker                                 - disabled, port: 8006
      + system.adapter.pushover.0               : pushover              : iOBroker                                 -  enabled
      + system.adapter.radar2.0                 : radar2                : iOBroker                                 -  enabled
        system.adapter.reolink.0                : reolink               : iOBroker                                 - disabled
        system.adapter.roborock.0               : roborock              : iOBroker                                 - disabled
      + system.adapter.s7.0                     : s7                    : iOBroker                                 -  enabled
        system.adapter.sayit.0                  : sayit                 : iOBroker                                 - disabled
      + system.adapter.scenes.0                 : scenes                : iOBroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iOBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : iOBroker                                 -  enabled, port: 4882, bind: 0.0.0.0
        system.adapter.simple-api.0             : simple-api            : iOBroker                                 - disabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.socketio.0               : socketio              : iOBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iOBroker                                 -  enabled
        system.adapter.synology.0               : synology              : iOBroker                                 - disabled, port: 5000
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iOBroker                                 -  enabled
        system.adapter.tapo.0                   : tapo                  : iOBroker                                 - disabled
      + system.adapter.telegram.0               : telegram              : iOBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.1               : telegram              : iOBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.2               : telegram              : iOBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.text2command.0           : text2command          : iOBroker                                 - disabled
        system.adapter.tr-064.0                 : tr-064                : iOBroker                                 - disabled
      + system.adapter.trashschedule.0          : trashschedule         : iOBroker                                 -  enabled
      + system.adapter.vaillant.0               : vaillant              : iOBroker                                 -  enabled
        system.adapter.vis-2-beta.0             : vis-2-beta            : iOBroker                                 - disabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iOBroker                                 -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iOBroker                                 -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iOBroker                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iOBroker                                 - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iOBroker                                 - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iOBroker                                 - disabled
        system.adapter.vis-history.0            : vis-history           : iOBroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iOBroker                                 - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : iOBroker                                 - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iOBroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iOBroker                                 - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iOBroker                                 - disabled
        system.adapter.vis-metro.0              : vis-metro             : iOBroker                                 - disabled
        system.adapter.vis-players.0            : vis-players           : iOBroker                                 - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iOBroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iOBroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : iOBroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iOBroker                                 -  enabled
        system.adapter.vofo-speedtest.0         : vofo-speedtest        : iOBroker                                 - disabled
      + system.adapter.web.0                    : web                   : iOBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iOBroker                                 - disabled
      + system.adapter.ws.0                     : ws                    : iOBroker                                 -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.0.22   , installed 7.0.22
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.16   , installed 3.0.16
      Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
      Adapter    "easee"        : 1.0.10   , installed 1.0.10
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "enigma2"      : 2.1.1    , installed 2.1.1
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "ford"         : 1.0.4    , installed 1.0.4
      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
      Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
      Adapter    "harmony"      : 1.4.0    , installed 1.4.0
      Adapter    "heatingcontrol": 2.12.8  , installed 2.12.8
      Adapter    "hiob"         : 0.1.5    , installed 0.1.5
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
      Adapter    "hue"          : 3.11.0   , installed 3.11.0
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.9    , installed 6.0.9
      Adapter    "logparser"    : 2.2.2    , installed 2.2.2
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
      Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "radar2"       : 2.2.0    , installed 2.2.0
      Adapter    "reolink"      : 1.1.0    , installed 1.1.0
      Adapter    "roborock"     : 0.6.4    , installed 0.6.4
      Adapter    "s7"           : 1.4.3    , installed 1.4.3
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "scenes"       : 3.2.1    , installed 3.2.1
      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "vis-2-widgets-energy": 1.0.0, installed 1.0.0
      Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
      Adapter    "vis-2-widgets-material": 1.3.32, installed 1.3.32
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Objects and States
      Objects:        42575
      States:         41949
      Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       28824      872/io.mqtt.0
      tcp        0      0 0.0.0.0:1899            0.0.0.0:*               LISTEN      109        20309      207/mosquitto
      tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1001       27545      726/io.hm-rpc.2
      tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      1001       27279      711/io.hm-rpc.0
      tcp        0      0 0.0.0.0:4882            0.0.0.0:*               LISTEN      1001       28502      955/io.shelly.1
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       21813      206/iobroker.js-con
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       20756      206/iobroker.js-con
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20602      212/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          9808       1/systemd
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          20416      359/master
      tcp6       0      0 :::1899                 :::*                    LISTEN      109        20310      207/mosquitto
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       26880      681/io.harmony.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          20604      212/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          9810       1/systemd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22892      371/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       34157      1181/io.web.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       33837      1119/io.socketio.0
      tcp6       0      0 :::8085                 :::*                    LISTEN      1001       31640      1196/io.ws.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          20417      359/master
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       31226      1025/io.esphome.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       31117      928/io.shelly.0
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       28877      898/io.radar2.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          9809       1/systemd
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       26881      681/io.harmony.0
      udp6       0      0 :::111                  :::*                                0          9811       1/systemd
      2024-08-19 08:37:38.757  - info: scenes.0 (490) Got terminate signal TERMINATE_YOURSELF
      2024-08-19 08:37:38.759  - info: scenes.0 (490) terminating
      2024-08-19 08:37:38.761  - info: scenes.0 (490) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-08-19 08:37:39.263  - info: scenes.0 (490) terminating
      2024-08-19 08:37:47.394  - info: scenes.0 (1571) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.scenes, node: v20.16.0, js-controller: 6.0.9
      2024-08-19 08:37:51.539  - warn: host.iOBroker instance system.adapter.telegram.0 terminated due to SIGKILL
      2024-08-19 08:37:52.136  - warn: host.iOBroker instance system.adapter.telegram.1 terminated due to SIGKILL
      2024-08-19 08:37:52.270  - warn: host.iOBroker instance system.adapter.telegram.2 terminated due to SIGKILL
      2024-08-19 09:03:20.086  - error: influxdb.0 (409) Error during ping: Error: connect ECONNREFUSED 192.168.170.119:8086. Attempting reconnect.
      2024-08-19 09:03:30.094  - error: influxdb.0 (409) Error: connect ECONNREFUSED 192.168.170.119:8086
      2024-08-19 09:03:40.097  - error: influxdb.0 (409) Error: connect ECONNREFUSED 192.168.170.119:8086
      2024-08-19 09:03:50.100  - error: influxdb.0 (409) Error: connect ECONNREFUSED 192.168.170.119:8086
      2024-08-19 09:04:00.103  - error: influxdb.0 (409) Error: connect ECONNREFUSED 192.168.170.119:8086
      2024-08-19 09:04:10.105  - error: influxdb.0 (409) Error: connect ECONNREFUSED 192.168.170.119:8086
      2024-08-19 09:04:20.108  - error: influxdb.0 (409) Error: connect ECONNREFUSED 192.168.170.119:8086
      2024-08-19 09:04:30.111  - error: influxdb.0 (409) Error: connect ECONNREFUSED 192.168.170.119:8086
      2024-08-19 09:04:40.116  - error: influxdb.0 (409) Error: connect ECONNREFUSED 192.168.170.119:8086
      2024-08-19 09:04:50.122  - error: influxdb.0 (409) Error: connect ECONNREFUSED 192.168.170.119:8086
      2024-08-19 09:05:00.125  - error: influxdb.0 (409) Error: connect ECONNREFUSED 192.168.170.119:8086
      2024-08-19 09:05:10.129  - error: influxdb.0 (409) Error: connect ECONNREFUSED 192.168.170.119:8086
      2024-08-19 09:06:14.040  - info: admin.0 (371) ==> Connected system.user.admin from ::ffff:192.168.160.132
      2024-08-19 09:06:48.218  - info: admin.0 (371) <== Disconnect system.user.admin from ::ffff:192.168.160.132
      2024-08-19 09:08:24.130  - error: fullybrowser.0 (2623) No Fully devices defined in adapter instance settings!
      2024-08-19 09:08:24.132  - error: fullybrowser.0 (2623) Adapter settings initialization failed.  ---> Please check your adapter instance settings!
      2024-08-19 09:30:14.274  - warn: ical.2 (4004) get state error: Connection is closed.
        Thomas Braun Most Active @Nordischerjung last edited by
        @nordischerjung sagte in timedatectl failed:
        Es gibt ja eine ganze Latte an Services, die nicht auf die Beine kommen.
        Da die sich tw. gegenseitig bedingen würde ich da ansetzen.
        Bei LXCs kann ich aber nicht weiterhelfen.
        • Ro75
          Ro75 last edited by
          Die abweichende Zeit ist aber ein generelles Problem und wird auf GIT diskutiert.
          https://github.com/ioBroker/ioBroker.admin/issues/2606
          *** FAILED SERVICES *** ist wie @Thomas-Braun schon schrieb eine andere Nummer und ist davon unabhängig zu betrachten und bearbeiten.
          Ro75
          • mcm1957
            mcm1957 @Ro75 last edited by
            @ro75 said in timedatectl failed:
            Ro75
            Bitte schau dir doch das Issue an bevor du Querveerweie behauptest.
            Das Issue hat nichts mit dem hier diskutierten Problem, dass auf dem hier beteiligten System die automatische Aktualisiserung der Systemzeit nicht funktioniert. Das Issue betrifft eine Fehlanzeige nachdem ein Browsertab im Hintergrund ist/war - dieses Topic betrifft ein Service das nicht läuft. Und ioBroker kann kein fehlerhaftes / nicht laufendes Systemservice "richten".
