    3. Einsteigerfragen
    4. Installation
    5. Wie kann ich eine alte Version von Backitup installieren?
      d003232 @Homoran last edited by
      @homoran Pefekt. Habe mir die Dateien aus dem Verzeuchnis gleich mal gesichert.
        d003232 @Thomas Braun last edited by Homoran
        @thomas-braun Ich glaube das war einer meiner Update Versuche. Ich habe wohl den Kernel aktualisiert und erst danach gelesen, dass man das eigentlich nicht soll.
        Heir nochmal eine "iobroker diag" Auswertung. Soweit bin ich erst mal zufrieden und warte auf die Post mit dem neuen Raspi 5. Dann geht es weiter.
        *** iob diag is starting up, please wait ***
        *** ioBroker Diagnosis ***
        Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
        The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
        https://forum.iobroker.net
        Just copy and paste the Summary Page, including the ``` characters at start and end.
        It helps us to help you!
        Press any key to continue
        Skript v.2024-05-22
        *** BASE SYSTEM ***
           Static hostname: raspi-scheuermatthof
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 9 (stretch)
                    Kernel: Linux 6.6.45-v7+
              Architecture: arm
        Model		: Raspberry Pi 3 Model B Plus Rev 1.3
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : 32 bit
        Systemuptime and Load:
         15:16:53 up 1 day,  2:26,  1 user,  load average: 1.88, 1.20, 2.43
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        ~ Under-voltage has occurred
        ~ Arm frequency capping has occurred
        ~ Throttling has occurred
        ~ Soft temperature limit has occurred
        *** Time and Time Zones ***
              Local time: Mon 2024-08-19 15:16:54 CEST
          Universal time: Mon 2024-08-19 13:16:54 UTC
                RTC time: n/a
         Network time on: yes
        NTP synchronized: yes
         RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        JAVA_HOME=/usr/lib/jvm/java-8-oracle
        DERBY_HOME=/usr/lib/jvm/java-8-oracle/db
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
        *** Display-Server-Setup ***
        Display-Server: true
        Desktop:
        Terminal:
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:           943M        489M         38M        1.1M        415M        398M
        Swap:          1.0G        466M        557M
        Total:         2.0G        955M        596M
        Active iob-Instances: 	12
                  921 M total memory
                  477 M used memory
                  309 M active memory
                  288 M inactive memory
                   37 M free memory
                   56 M buffer memory
                  348 M swap cache
                  999 M total swap
                  455 M used swap
                  544 M free swap
        top - 15:16:54 up 1 day,  2:26,  1 user,  load average: 1.88, 1.20, 2.43
        Tasks: 135 total,   2 running,  78 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  4.1 us,  1.0 sy,  0.0 ni, 83.5 id, 11.2 wa,  0.0 hi,  0.1 si,  0.0 st
        KiB Mem :   943416 total,    38392 free,   489372 used,   415652 buff/cache
        KiB Swap:  1023996 total,   557720 free,   466276 used.   398736 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed. Pass --all to see loaded but inactive units, too.
        To show all installed unit files use 'systemctl list-unit-files'.
        *** FILESYSTEM ***
        /dev/root      ext4       30G   25G  3.7G  88% /
        devtmpfs       devtmpfs  429M     0  429M   0% /dev
        tmpfs          tmpfs     461M     0  461M   0% /dev/shm
        tmpfs          tmpfs     461M   12M  449M   3% /run
        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs          tmpfs     461M     0  461M   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat       44M   28M   16M  65% /boot
        tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
        [Sun Aug 18 12:50:12 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=040bf7a6-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Sun Aug 18 12:50:15 2024] EXT4-fs (mmcblk0p2): mounted filesystem e9646bf0-ef1f-4e8b-983b-c9f97f60e931 ro with ordered data mode. Quota mode: none.
        [Sun Aug 18 12:50:15 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Sun Aug 18 12:50:17 2024] EXT4-fs (mmcblk0p2): re-mounted e9646bf0-ef1f-4e8b-983b-c9f97f60e931 r/w. Quota mode: none.
        Show mounted filesystems:
        TARGET                                SOURCE         FSTYPE     OPTIONS
        /                                     /dev/mmcblk0p2 ext4       rw,noatime
        |-/dev                                devtmpfs       devtmpfs   rw,relatime,size=438428k,nr_inodes=109607,mode=755
        | |-/dev/shm                          tmpfs          tmpfs      rw,nosuid,nodev
        | |-/dev/pts                          devpts         devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | `-/dev/mqueue                       mqueue         mqueue     rw,relatime
        |-/sys                                sysfs          sysfs      rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security              securityfs     securityfs rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup                    tmpfs          tmpfs      ro,nosuid,nodev,noexec,mode=755
        | | |-/sys/fs/cgroup/systemd          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd
        | | |-/sys/fs/cgroup/perf_event       cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
        | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
        | | |-/sys/fs/cgroup/pids             cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,pids
        | | |-/sys/fs/cgroup/blkio            cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,blkio
        | | |-/sys/fs/cgroup/devices          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,devices
        | | |-/sys/fs/cgroup/net_cls,net_prio cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
        | | |-/sys/fs/cgroup/freezer          cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,freezer
        | | `-/sys/fs/cgroup/cpuset           cgroup         cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
        | |-/sys/fs/pstore                    pstore         pstore     rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/debug                 debugfs        debugfs    rw,relatime
        | `-/sys/kernel/config                configfs       configfs   rw,relatime
        |-/proc                               proc           proc       rw,relatime
        | `-/proc/sys/fs/binfmt_misc          systemd-1      autofs     rw,relatime,fd=31,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
        |-/run                                tmpfs          tmpfs      rw,nosuid,nodev,mode=755
        | |-/run/lock                         tmpfs          tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/rpc_pipefs                   sunrpc         rpc_pipefs rw,relatime
        | `-/run/user/1000                    tmpfs          tmpfs      rw,nosuid,nodev,relatime,size=94340k,mode=700,uid=1000,gid=1000
        `-/boot                               /dev/mmcblk0p1 vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
          Homoran Global Moderator Administrators @d003232 last edited by Homoran
          @d003232 bitte nicht (und schon gar nicht mit einem Windows Editor) bearbeiten
            d003232 @Thomas Braun last edited by d003232
            @thomas-braun said in Wie kann ich eine alte Version von Backitup installieren?:
            (Und lass das neue System nicht wieder Jahre versumpfen. Das ganze wird immer komplizierter zu handhaben, je länger da gepennt wird.) Es gibt nicht ohne Grund Release Plans wie den obigen.
            Das System soll halt laufen. Alle paar Monate mache ich dann einen Update. Ich möchte eigentlich nicht alle paar Jahre die Hardware austauschen, ohne dass ein zwingender Grund besteht. Dazu verstehe ich zu wenige von Linux und der Systemseite. Ich dann immer ein riesen Aufwand, mich da reinzuarbeiten. Ich wusste ja nicht einmal, was mit "Strech" gemeint war. 🙂
            Nun ist dieser zwingende Grund leider gekommen. 😥
            btw: auf dem Raspi 3 kann ich kein Buster oder höheres laufen lassen? Wo sehe ich, was maximal auf dem Raspi 3 läuft?
              Thomas Braun Most Active @d003232 last edited by
              @d003232 sagte in Wie kann ich eine alte Version von Backitup installieren?:
              Mit rpi-update oder wie das Ding heißt? Nein, das tut man nicht.
              Spendier dem Rpi5 aber unbedingt ein anderes (besseres) Netzteil. Das jetzige ist am Rpi3 schon zu wackelig.
                d003232 @Codierknecht last edited by
                @codierknecht said in Wie kann ich eine alte Version von Backitup installieren?:
                @d003232
                Und wenn Du das neu aufsetzt: Auf einen Server gehört kein Desktop!
                OK, das heisst beim nächsten mal ein Image "Raspberry Pi OS Lite" runterladen statt "Raspberry Pi OS with desktop"?
                • Codierknecht
                  Codierknecht Developer Most Active @d003232 last edited by
                  Ja. Und das dann in der 64Bit-Variante.
                    Thomas Braun Most Active @d003232 last edited by Thomas Braun
                    Das ist deutlich zu selten.
                    Von Hardware spreche ich auch nicht. Aber das Betriebssystem muss regelmäßig auf Stand gehalten werden.
                    (Wobei der Raspi3 mit seinem 1GB RAM für den ioBroker mittlerweile auch zu schwach auf der Brust ist. Jedenfalls wenn da mehr als eine einstellige Zahl an Adaptern laufen soll).
                    Da läuft auch das aktuelle Release Raspberry OS 12 'Bookworm' in der 64Bit-Version drauf. Musste nur komplett neuinstallieren, weil der Sprung nicht möglich ist.
                      OK. Das heisst statt nur regelmäßig
                      sudo apt-get update
                      sudo apt-get upgrade
                      sudo apt-get dist-upgrade
                      hätte ich auch das Raspberry Release wechseln müssen? Aber das geht wohl nicht mit einem einfachen Update Befehl, sondern braucht eine größere Anleitung?
                        Ja, spätestens wenn das EndOfLife erreicht ist. Besser aber in den 12 Monaten zuvor. Da geht das nämlich am geschmeidigsten. Und dafür ist diese Übergangsphase auch gedacht. (Außer beim Sprung auf Raspberry 12 'Bookworm', da kann man nicht gescheit rüberwechseln, muss immer flugs neuinstalliert werden. Vielleicht ist ein 'in-line'-Upgrade auf Version 13 'Trixie' dann aber auch wieder möglich. Muss man abwarten bis das im Sommer/Herbst 2025 dann erscheint.)
                        Ja, da gibt es dann Typen, die schreiben die sogar hier ins Forum, obwohl das bei strenger Betrachtung hier gar nix verloren hat.
                          @thomas-braun @crunchip @haus-automatisierung @simatec @Homoran
                          Besten Dank für eure kompetente und schnelle Unterstützung. Damit ist mein Problem mit dem Backup erst einmal gelöst.
                          Heute habe ich einiges gelernt 🤗
                            Das ist das wichtigste!
                            backitup raspi3
                            3180
