    5. missing or unrecognized endTime expresson
      Homoran Global Moderator Administrators @Fibricus last edited by
      @fibricus sagte in missing or unrecognized endTime expresson:
      schon wieder was gelernt!
      leider nicht
      @homoran sagte in missing or unrecognized endTime expresson:
      bitte als Text in code-tags
      so ist es am Handy weder zu entziffern, zitieren geht gar nicht
        Fibricus @Homoran last edited by
        @homoran said in missing or unrecognized endTime expresson:
        2024-08-11 09:30:47.212 - warn: javascript.0 (2311) script.js.PV.Konaladen: missing or unrecognized endTime expression: NaN
        2024-08-11 09:30:47.213 - warn: javascript.0 (2311) script.js.PV.Konaladen_aus: missing or unrecognized endTime expression: NaN
        2024-08-11 09:30:47.217 - warn: tuya.0 (2490) 5657716640f520e8def5.1: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
        2024-08-11 09:36:51.817 - warn: javascript.0 (2311) script.js.PV.Konaladen: missing or unrecognized endTime expression: NaN
        2024-08-11 09:36:51.818 - warn: javascript.0 (2311) script.js.PV.Konaladen_aus: missing or unrecognized endTime expression: NaN
        2024-08-11 09:36:51.823 - warn: tuya.0 (2490) 5657716640f520e8def5.1: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
        2024-08-11 09:40:47.732 - warn: javascript.0 (2311) script.js.PV.Konaladen: missing or unrecognized endTime expression: NaN
        2024-08-11 09:40:47.733 - warn: javascript.0 (2311) script.js.PV.Konaladen_aus: missing or unrecognized endTime expression: NaN
        2024-08-11 09:40:47.740 - warn: tuya.0 (2490) 5657716640f520e8def5.1: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
        So?
          So?
          ja!
          im Abstand einer Millisekunde kommt der Fehler angeblch von
          beiden Skripten.
          der Fehler behauptet eine Variable sei keine Zahl (not a number)
          Schade, meist wird in einer weiteren Zeile die Stelle im Skript angegeben.
          Jetzt bleibt dir nur testweise alle Blöcke mit "Zeit zwischen..." zu deaktivieren und zu sehen bei welchem die Meldung verschwindet.
          ich würde vorher einmal die js-Instanz neu starten, wenn das nicht hilft den ganzen iobroker oder den Raspi.
          wenn dann immer noch die Meldung kommt, die Blöcke deaktivieren.
          Die Frage nach globalen Skripten ist noch offen.
            Fibricus @Homoran last edited by Fibricus
            beiden Skripten.
            ...nur das das Script "Konaladen" ausgeschaltet ist... (s.u.)
            Ahhh, das heißt NaN!
            Dann werde ich das mal als nächstes probieren. Leider habe ich keine Ahnung wie ich den Lunux-Rechner neu starte.
            OK
            Neee, hatte ich oben schon beantwortet. Der Ordner mit den GLOBALEN Scripten ist leer:
              sudo reboot
              • Codierknecht
                Codierknecht Developer Most Active @Fibricus last edited by
                Wenn wir schon gerade beim Lernen sind: Es heißt "Script".
                Mein innerer Monk kriegt bei sowas Schnappatmung 😀
                  Fibricus @Codierknecht last edited by
                  @codierknecht said in missing or unrecognized endTime expresson:
                  Es tut mir leid, wenn Dein innerer Monk Atemschwierigkeiten bekommen hat.
                  Ich habe diesen Fehler sofort im kompleten Thema korrigiert.
                  Nich dass noch Schlimmeres passiert als Schnappatmung!
                  Ich hoffe es passiert nicht wieder... 😉
                    JS-Instanz ist neu gestartet - keine Änderung. Dann
                    Admin neu gestartet - keine Änderung. Dann
                    Host neu gestartet - keine Änderung
                    Nur meinen Linux-Mini-Rechner habe ich noch nicht neu gestartet.
                    Das mache ich heute Abend mal in Ruhe.
                    ...und wenn das alles nicht hilft, dann:
                    ... die Blöcke deaktivieren.
                      Fibricus @Fibricus last edited by
                      Was aber wirklich komisch ist:
                      Ich bekomme immer noch eine Fehlermeldung von einem Script, das nicht aktiv ist:
                      Und das Script ist wirklich ausgeschaltet:
                      Sonderbar...
                        Nachdem nix geholfen hat habe ich das Script "Konaladen" entfernt.
                        Aber dann war da noch das "NaN"-Problem bei der "endTime expression".
                        Fragt nicht warum, aber so tut's:
                        Dabei macht das jetzt eigentlich das Gleiche wie vorher die das hier:
                        Ich verstehe es nicht - aber das wichtigste: es TUT!!!
                        Danke für die vielen Tipps und vielleicht hat ja jemand eine Erklärung dafür.
                        1819
