    4. Beim Update von Adaptern stürzt der ioBroker ab
      flommaster @Thomas Braun last edited by
      Der Befehl "npm prune" liefert folgendes Ergebnis:
      Kann ich die github Installationen löschen?
      npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.web-speedy.git
      npm warn skipping integrity check for git dependency ssh://git@github.com/peterbaumert/ioBroker.vofo-speedtest.git
      npm warn skipping integrity check for git dependency ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git
      npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2.git
      npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2-widgets-material.git
      npm warn skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git
      npm warn skipping integrity check for git dependency ssh://git@github.com/aendue/ioBroker.reolink.git
      npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.ical.git
      npm warn skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git
      npm warn skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git
      npm warn skipping integrity check for git dependency ssh://git@github.com/WLAN-Kabel/ioBroker.calendar.git
      npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
      npm warn deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
      npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
      npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
      npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
      npm warn deprecated uid-number@0.0.6: This package is no longer supported.
      npm warn deprecated npmlog@5.0.1: This package is no longer supported.
      npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
      npm warn deprecated npmlog@6.0.2: This package is no longer supported.
      npm warn deprecated har-validator@5.1.5: this library is no longer supported
      npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
      npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
      npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
      npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
      npm warn deprecated q@1.1.2: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
      npm warn deprecated
      npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
      npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
      npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
      npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
      npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
      npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
      npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
      npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
      npm warn deprecated google-p12-pem@3.1.4: Package is no longer maintained
      npm warn deprecated gauge@3.0.2: This package is no longer supported.
      npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm warn deprecated gauge@4.0.4: This package is no longer supported.
      npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm warn deprecated later@1.2.0: Please upgrade to the maintained and new drop-in replacement @breejs/later at https://github.com/breejs/later 🚀 Thanks and happy hacking! 🚀  @niftylettuce
      npm error git dep preparation failed
      npm error signal SIGINT
      npm error command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
      npm error npm warn using --force Recommended protections disabled.
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
      Qix- created this issue in visionmedia/debug
      closed ReDos Vulnerability Regression Visibility Notice #797
        Thomas Braun Most Active @flommaster last edited by
        @flommaster sagte in Beim Update von Adaptern stürzt der ioBroker ab:
        Vollständig.
        Inkl. vollständiger Eingabezeile inkl. login prompt. Damit man sieht was du da genau in welchem Verzeichnis mit welchem User eingegeben hast.
          Gerne. Hier der komplette Auszug (Teil 1)
          flo@ioBrokerdebian:/opt/iobroker$ npm prune
          npm ls
          npm warn deprecated
          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T20_04_51_820Z-debug-0.log
          iobroker.inst@2.0.3 /opt/iobroker
          ├── @alcalzone/esbuild-register@2.5.1-1 extraneous
          ├── @alcalzone/jsonl-db@3.1.1 extraneous
          ├── @alcalzone/pak@0.8.1 extraneous
          ├── @alcalzone/proper-lockfile@4.1.3-0 extraneous
          ├── @aws-sdk/util-utf8-browser@3.259.0 extraneous
          ├── @azure/abort-controller@1.1.0 extraneous
          ├── @azure/core-auth@1.7.2 extraneous
          ├── @azure/core-client@ extraneous
          ├── @azure/core-http-compat@ extraneous
          ├── @azure/core-lro@ extraneous
          ├── @azure/core-paging@1.6.2 extraneous
          ├── @azure/core-rest-pipeline@ extraneous
          ├── @azure/core-tracing@1.1.2 extraneous
          ├── @azure/core-util@ extraneous
          ├── @azure/identity@ extraneous
          ├── @azure/keyvault-keys@ extraneous
          ├── @azure/logger@1.1.4 extraneous
          ├── @azure/msal-browser@ extraneous
          ├── @azure/msal-common@ extraneous
          ├── @azure/msal-node@1.18.4 extraneous
          ├── @babel/code-frame@7.24.7 extraneous
          ├── @babel/helper-validator-identifier@7.24.7 extraneous
          ├── @babel/highlight@7.24.7 extraneous
          ├── @babel/runtime@ extraneous
          ├── @colors/colors@1.5.0 extraneous
          ├── @dabh/diagnostics@2.0.3 extraneous
          ├── @datalust/winston-seq@1.0.2 extraneous
          ├── @gar/promisify@1.1.3 extraneous
          ├── @googleapis/calendar@9.7.7 extraneous
          ├── @googleapis/drive@5.1.0 extraneous
          ├── @googleapis/oauth2@1.0.7 extraneous
          ├── @httptoolkit/websocket-stream@6.0.1 extraneous
          ├── @iobroker/db-base@ extraneous
          ├── @iobroker/db-objects-file@ extraneous
          ├── @iobroker/db-objects-jsonl@ extraneous
          ├── @iobroker/db-objects-redis@ extraneous
          ├── @iobroker/db-states-file@ extraneous
          ├── @iobroker/db-states-jsonl@ extraneous
          ├── @iobroker/db-states-redis@ extraneous
          ├── @iobroker/js-controller-adapter@ extraneous
          ├── @iobroker/js-controller-cli@ extraneous
          ├── @iobroker/js-controller-common-db@ extraneous
          ├── @iobroker/js-controller-common@ extraneous
          ├── @iobroker/plugin-base@1.2.1 extraneous
          ├── @iobroker/plugin-sentry@1.2.1 extraneous
          ├── @iobroker/socket-classes@1.5.6 extraneous
          ├── @iobroker/webserver@1.0.3 extraneous
          ├── @isaacs/cliui@8.0.2 extraneous
          ├── @js-joda/core@ extraneous
          ├── @mapbox/node-pre-gyp@1.0.11 extraneous
          ├── @microsoft/microsoft-graph-types@2.40.0 extraneous
          ├── @nodelib/fs.scandir@2.1.5 extraneous
          ├── @nodelib/fs.stat@2.0.5 extraneous
          ├── @nodelib/fs.walk@1.2.8 extraneous
          ├── @npmcli/fs@2.1.2 extraneous
          ├── @npmcli/move-file@2.0.1 extraneous
          ├── @pkgjs/parseargs@0.11.0 extraneous
          ├── @protobufjs/aspromise@1.1.2 extraneous
          ├── @protobufjs/base64@1.1.2 extraneous
          ├── @protobufjs/codegen@2.0.4 extraneous
          ├── @protobufjs/eventemitter@1.1.0 extraneous
          ├── @protobufjs/fetch@1.1.0 extraneous
          ├── @protobufjs/float@1.0.2 extraneous
          ├── @protobufjs/inquire@1.1.0 extraneous
          ├── @protobufjs/path@1.1.2 extraneous
          ├── @protobufjs/pool@1.1.0 extraneous
          ├── @protobufjs/utf8@1.1.0 extraneous
          ├── @quasar/extras@ extraneous
          ├── @samverschueren/stream-to-observable@0.3.1 extraneous
          ├── @sentry-internal/tracing@ extraneous
          ├── @sentry/core@5.30.0 extraneous
          ├── @sentry/hub@5.30.0 extraneous
          ├── @sentry/minimal@5.30.0 extraneous
          ├── @sentry/node@ extraneous
          ├── @sentry/tracing@ extraneous
          ├── @sentry/types@ extraneous
          ├── @sentry/utils@ extraneous
          ├── @sindresorhus/is@4.6.0 extraneous
          ├── @socket.io/component-emitter@3.1.2 extraneous
          ├── @szmarczak/http-timer@4.0.6 extraneous
          ├── @tediousjs/connection-string@0.5.0 extraneous
          ├── @tootallnate/once@2.0.0 extraneous
          ├── @types/bl@5.1.0 extraneous
          ├── @types/cacheable-request@6.0.3 extraneous
          ├── @types/caseless@0.12.5 extraneous
          ├── @types/cookie@0.4.1 extraneous
          ├── @types/cors@2.8.17 extraneous
          ├── @types/geojson@7946.0.14 extraneous
          ├── @types/http-cache-semantics@4.0.4 extraneous
          ├── @types/keyv@3.1.4 extraneous
          ├── @types/leaflet@1.9.12 extraneous
          ├── @types/minimist@1.2.5 extraneous
          ├── @types/node-cron@2.0.8 extraneous
          ├── @types/node@ extraneous
          ├── @types/normalize-package-data@2.4.4 extraneous
          ├── @types/parse-json@4.0.2 extraneous
          ├── @types/readable-stream@4.0.15 extraneous
          ├── @types/request@2.48.12 extraneous
          ├── @types/responselike@1.0.3 extraneous
          ├── @types/tough-cookie@4.0.5 extraneous
          ├── @types/triple-beam@1.3.5 extraneous
          ├── @types/tz-offset@0.0.3 extraneous
          ├── @types/ws@8.5.12 extraneous
          ├── abab@2.0.6 extraneous
          ├── abbrev@1.1.1 extraneous
          ├── abort-controller@3.0.0 extraneous
          ├── agentkeepalive@4.5.0 extraneous
          ├── aggregate-error@3.1.0 extraneous
          ├── ajv@ extraneous
          ├── ansi-align@3.0.1 extraneous
          ├── ansi-colors@4.1.3 extraneous
          ├── ansi-escapes@4.3.2 extraneous
          ├── ansi-regex@5.0.1 extraneous
          ├── ansi-styles@4.3.0 extraneous
          ├── any-observable@0.5.1 extraneous
          ├── anymatch@3.1.3 extraneous
          ├── aproba@2.0.0 extraneous
          ├── archiver-utils@5.0.2 extraneous
          ├── archiver@7.0.1 extraneous
          ├── are-we-there-yet@2.0.0 extraneous
          ├── arg@4.1.0 extraneous
          ├── argparse@1.0.10 extraneous
          ├── array-buffer-byte-length@1.0.1 extraneous
          ├── array-flatten@1.1.1 extraneous
          ├── array-union@2.1.0 extraneous
          ├── arraybuffer.prototype.slice@1.0.3 extraneous
          ├── arrify@2.0.1 extraneous
          ├── asn1@0.2.6 extraneous
          ├── async-exit-hook@2.0.1 extraneous
          ├── authenticate-pam@1.0.5 extraneous
          ├── available-typed-arrays@1.0.7 extraneous
          ├── aws-crt@ extraneous
          ├── b4a@1.6.6 extraneous
          ├── balanced-match@1.0.2 extraneous
          ├── bare-events@2.4.2 extraneous
          ├── base-64@1.0.0 extraneous
          ├── base64-js@1.5.1 extraneous
          ├── bcrypt-pbkdf@1.0.2 extraneous
          ├── binary-extensions@2.3.0 extraneous
          ├── bindings@1.5.0 extraneous
          ├── bl@6.0.14 extraneous
          ├── bluebird@3.7.2 extraneous
          ├── body-parser@1.20.2 extraneous
          ├── bottleneck@2.19.5 extraneous
          ├── boxen@5.1.2 extraneous
          ├── brace-expansion@2.0.1 extraneous
          ├── braces@3.0.3 extraneous
          ├── buffer-crc32@1.0.0 extraneous
          ├── buffer-equal-constant-time@1.0.1 extraneous
          ├── buffer-shims@1.0.0 extraneous
          ├── buffer@6.0.3 extraneous
          ├── buildcheck@0.0.6 extraneous
          ├── builtins@1.0.3 extraneous
          ├── busboy@1.6.0 extraneous
          ├── byte-length@1.0.2 extraneous
          ├── bytes@3.1.2 extraneous
          ├── cacache@16.1.3 extraneous
          ├── cacheable-lookup@5.0.4 extraneous
          ├── cacheable-request@7.0.4 extraneous
          ├── callsites@3.1.0 extraneous
          ├── camelcase-keys@6.2.2 extraneous
          ├── camelcase@5.3.1 extraneous
          ├── capitalize@2.0.4 extraneous
          ├── chalk@4.1.2 extraneous
          ├── chardet@0.7.0 extraneous
          ├── charenc@0.0.2 extraneous
          ├── chokidar@3.6.0 extraneous
          ├── chownr@2.0.0 extraneous
          ├── ci-info@3.9.0 extraneous
          ├── clean-stack@2.2.0 extraneous
          ├── cli-boxes@2.2.1 extraneous
          ├── cli-cursor@3.1.0 extraneous
          ├── cli-truncate@0.2.1 extraneous
          ├── cli-width@3.0.0 extraneous
          ├── clone-response@1.0.3 extraneous
          ├── cloneextend@0.0.3 extraneous
          ├── cluster-key-slot@1.1.2 extraneous
          ├── coap-packet@1.1.1 extraneous
          ├── coffeescript@1.12.7 extraneous
          ├── color-convert@2.0.1 extraneous
          ├── color-name@1.1.4 extraneous
          ├── color-string@1.9.1 extraneous
          ├── color-support@1.1.3 extraneous
          ├── color@3.2.1 extraneous
          ├── colors@1.4.0
          ├── colorspace@1.1.4 extraneous
          ├── commander@9.5.0 extraneous
          ├── commist@3.2.0 extraneous
          ├── compress-commons@6.0.2 extraneous
          ├── compress-json@2.1.2 extraneous
          ├── compressible@2.0.18 extraneous
          ├── compression@1.7.4 extraneous
          ├── concat-map@0.0.1 extraneous
          ├── configstore@5.0.1 extraneous
          ├── connect-flash@0.1.1 extraneous
          ├── connect@3.7.0 extraneous
          ├── console-control-strings@1.1.0 extraneous
          ├── content-disposition@0.5.4 extraneous
          ├── content-type@1.0.5 extraneous
          ├── core-js@ extraneous
          ├── cors@2.8.5 extraneous
          ├── cosmiconfig@7.1.0 extraneous
          ├── cpu-features@ extraneous
          ├── crc-32@1.2.2 extraneous
          ├── crc@ extraneous
          ├── crc32-stream@6.0.0 extraneous
          ├── cross-fetch@4.0.0 extraneous
          ├── crypt@0.0.2 extraneous
          ├── crypto-js@ extraneous
          ├── crypto-random-string@2.0.0 extraneous
          ├── cssstyle@ extraneous
          ├── cycle@1.0.3 extraneous
          ├── dashdash@1.14.1 extraneous
          ├── data-urls@4.0.0 extraneous
          ├── data-view-buffer@1.0.1 extraneous
          ├── data-view-byte-length@1.0.1 extraneous
          ├── data-view-byte-offset@1.0.0 extraneous
          ├── date-and-time@ extraneous
          ├── date-fns@1.30.1 extraneous
          ├── dateformat@4.6.3 extraneous
          ├── dayjs@ extraneous
          ├── decache@4.6.2 extraneous
          ├── decamelize-keys@1.1.1 extraneous
          ├── decimal.js@10.4.3 extraneous
          ├── decompress-response@6.0.0 extraneous
          ├── deep-clone@3.0.3 extraneous
          ├── deep-extend@0.6.0 extraneous
          ├── deep-is@0.1.4 extraneous
          ├── defer-to-connect@2.0.1 extraneous
          ├── define-lazy-prop@2.0.0 extraneous
          ├── del@6.1.1 extraneous
          ├── delegates@1.0.0 extraneous
          ├── denque@1.5.1 extraneous
          ├── destroy@1.2.0 extraneous
          ├── detect-libc@2.0.3 extraneous
          ├── diacritics@1.3.0 extraneous
          ├── digest-header@1.1.0 extraneous
          ├── dir-glob@3.0.1 extraneous
          ├── diskusage@1.2.0 extraneous
          ├── domexception@4.0.0 extraneous
          ├── dot-prop@6.0.1 extraneous
          ├── draftlog@1.0.13 extraneous
          ├── dropbox-v2-api@ extraneous
          ├── duplexer@0.1.2 extraneous
          ├── duplexer3@0.1.5 extraneous
          ├── duplexify@3.7.1 extraneous
          ├── eastasianwidth@0.2.0 extraneous
          ├── ecc-jsbn@0.1.2 extraneous
          ├── ecdsa-sig-formatter@1.0.11 extraneous
          ├── echarts@ extraneous
          ├── ee-first@1.1.1 extraneous
          ├── elegant-spinner@1.0.1 extraneous
          ├── emoji-regex@9.2.2 extraneous
          ├── enabled@2.0.0 extraneous
          ├── encodeurl@1.0.2 extraneous
          ├── encoding@0.1.13 extraneous
          ├── end-of-stream@1.4.4 extraneous
          ├── entities@4.5.0 extraneous
          ├── err-code@2.0.3 extraneous
          ├── es-abstract@ extraneous
          ├── es-aggregate-error@1.0.13 extraneous
          ├── es-object-atoms@1.0.0 extraneous
          ├── es-set-tostringtag@2.0.3 extraneous
          ├── es-to-primitive@1.2.1 extraneous
          ├── es6-promise@4.2.8 extraneous
          ├── es6-promisify@5.0.0 extraneous
          ├── esbuild@0.11.23 extraneous
          ├── escalade@3.1.2 extraneous
          ├── escape-goat@3.0.0 extraneous
          ├── escape-html@1.0.3 extraneous
          ├── escape-string-regexp@4.0.0 extraneous
          ├── escodegen@1.14.3 extraneous
          ├── esprima@1.2.2 extraneous
          ├── estraverse@4.3.0 extraneous
          ├── esutils@2.0.3 extraneous
          ├── etag@1.8.1 extraneous
          ├── event-stream@4.0.1 extraneous
          ├── event-target-shim@5.0.1 extraneous
          ├── eventemitter2@6.4.9 extraneous
          ├── events@3.3.0 extraneous
          ├── execa@5.1.1 extraneous
          ├── expand-template@2.0.3 extraneous
          ├── express-fileupload@1.5.1 extraneous
          ├── express@4.19.2 extraneous
          ├── external-editor@3.1.0 extraneous
          ├── fast-deep-equal@3.1.3 extraneous
          ├── fast-fifo@1.3.2 extraneous
          ├── fast-glob@ extraneous
          ├── fast-json-stable-stringify@2.1.0 extraneous
          ├── fast-levenshtein@2.0.6 extraneous
          ├── fast-text-encoding@1.0.6 extraneous
          ├── fast-unique-numbers@ extraneous
          ├── fast-uri@3.0.1 extraneous
          ├── fast-xml-parser@ extraneous
          ├── fastq@1.17.1 extraneous
          ├── fastseries@2.0.0 extraneous
          ├── fecha@4.2.3 extraneous
          ├── figures@3.2.0 extraneous
          ├── file-stream-rotator@0.6.1 extraneous
          ├── file-type@10.11.0 extraneous
          ├── file-uri-to-path@1.0.0 extraneous
          ├── fill-range@7.1.1 extraneous
          ├── finalhandler@1.2.0 extraneous
          ├── find-up@5.0.0 extraneous
          ├── fn.name@1.1.0 extraneous
          ├── for-each@0.3.3 extraneous
          ├── foreground-child@3.3.0 extraneous
          ├── form-data-encoder@2.1.4 extraneous
          ├── form-data@4.0.0 extraneous
          ├── forwarded@0.2.0 extraneous
          ├── fresh@0.5.2 extraneous
          ├── from@0.1.7 extraneous
          ├── fs-constants@1.0.0 extraneous
          ├── fs-extra@7.0.1
          ├── fs-minipass@2.1.0 extraneous
          ├── fs.realpath@1.0.0 extraneous
          ├── fsevents@ extraneous
          ├── ftp@0.3.10 extraneous
          ├── function.prototype.name@1.1.6 extraneous
          ├── functions-have-names@1.2.3 extraneous
          ├── futoin-hkdf@1.4.3 extraneous
          ├── gauge@3.0.2 extraneous
          ├── gaxios@5.1.3 extraneous
          ├── gcp-metadata@5.3.0 extraneous
          ├── generate-function@2.3.1 extraneous
          ├── get-ssl-certificate@2.3.3 extraneous
          ├── get-stream@5.2.0 extraneous
          ├── get-symbol-description@1.0.2 extraneous
          ├── getpass@0.1.7 extraneous
          ├── github-from-package@0.0.0 extraneous
          ├── github-url-from-git@1.5.0 extraneous
          ├── glob-parent@5.1.2 extraneous
          ├── glob@10.4.5 extraneous
          ├── global-dirs@2.1.0 extraneous
          ├── globalthis@1.0.4 extraneous
          ├── globby@11.1.0 extraneous
          ├── glossy@0.1.7 extraneous
          ├── google-auth-library@ extraneous
          ├── google-p12-pem@4.0.1 extraneous
          ├── googleapis-common@6.0.4 extraneous
          ├── googleapis@ extraneous
          ├── gtoken@6.1.2 extraneous
          ├── hard-rejection@2.1.0 extraneous
          ├── has-ansi@2.0.0 extraneous
          ├── has-bigints@1.0.2 extraneous
          ├── has-flag@4.0.0 extraneous
          ├── has-tostringtag@1.0.2 extraneous
          ├── has-unicode@2.0.1 extraneous
          ├── has-yarn@2.1.0 extraneous
          ├── he@1.2.0 extraneous
          ├── help-me@5.0.0 extraneous
          ├── homebridge-plugin-wrapper@ extraneous
          ├── hosted-git-info@3.0.8 extraneous
          ├── hot-patcher@1.0.0 extraneous
          ├── html-encoding-sniffer@3.0.0 extraneous
          ├── http-cache-semantics@4.1.1 extraneous
          ├── http-errors@2.0.0 extraneous
          ├── http-proxy-agent@5.0.0 extraneous
          ├── http2-wrapper@1.0.3 extraneous
          ├── https@1.0.0 extraneous
          ├── humanize-ms@1.2.1 extraneous
          ├── ical.js@ extraneous
          ├── iconv-lite@0.4.24 extraneous
          ├── ieee754@1.2.1 extraneous
          ├── ignore-walk@3.0.4 extraneous
          ├── ignore@5.3.2 extraneous
          ├── image-type@4.1.0 extraneous
          ├── immediate@3.0.6 extraneous
          ├── import-fresh@3.3.0 extraneous
          ├── import-lazy@2.1.0 extraneous
          ├── import-local@3.2.0 extraneous
          ├── imurmurhash@0.1.4 extraneous
          ├── indent-string@3.2.0 extraneous
          ├── infer-owner@1.0.4 extraneous
          ├── inflight@1.0.6 extraneous
          ├── ini@1.3.7 extraneous
          ├── inquirer-autosubmit-prompt@0.2.0 extraneous
          ├── inquirer@7.3.3 extraneous
          ├── int64-buffer@1.0.1 extraneous
          ├── internal-slot@1.0.7 extraneous
          ├── iobroker-adapter-helpers@0.0.8 extraneous
          ├── iobroker.admin@ invalid: "^6.10.1" from the root project
          ├── iobroker.backitup@ invalid: "2.6.23" from the root project
          ├── iobroker.bmw@2.5.7
          ├── iobroker.calendar@ invalid: "github:WLAN-Kabel/ioBroker.calendar#c36410258c21a4a92eba80fb0ec084fc254c9259" from the root project
          ├── iobroker.cloud@4.4.1
          ├── iobroker.coronavirus-statistics@0.8.7
          ├── iobroker.daswetter@3.1.10
          ├── iobroker.discovery@ invalid: "3.1.0" from the root project
          ├── iobroker.dwd@2.8.5
          ├── iobroker.echarts@ invalid: "1.5.1" from the root project
          ├── iobroker.energiefluss@ invalid: "github:SKB-CGN/ioBroker.energiefluss#fc7a5b48f0f485b130619796daf0a9533f5b8426" from the root project
          ├── iobroker.eusec@1.1.2
          ├── iobroker.flot@ invalid: "1.12.0" from the root project
          ├── iobroker.fritzbox@0.2.1
          ├── iobroker.fullcalendar@ invalid: "1.2.0" from the root project
          ├── iobroker.fullybrowser@2.1.2
          ├── iobroker.gartenbewaesserung@ invalid: "github:TA2k/ioBroker.gartenbewaesserung#1931dcd562edf9dfa818dbf5cec61e28d3f72d72" from the root project
          ├── iobroker.ham@ invalid: "github:ioBroker/ioBroker.ham" from the root project
          ├── iobroker.harmony@1.2.2
          ├── iobroker.heatingcontrol@ invalid: "2.11.1" from the root project
          ├── iobroker.history@2.2.6
          ├── iobroker.hm-rega@3.0.47
          ├── iobroker.hm-rpc@1.15.19
          ├── iobroker.hue@3.9.5
          ├── iobroker.ical@ invalid: "github:iobroker-community-adapters/ioBroker.ical#ad28140ed1fa7ab23683d7e12b6204da06b7ce6f" from the root project
          ├── iobroker.icons-icons8@0.0.1
          ├── iobroker.icons-material-png@0.1.0
          ├── iobroker.icons-mfd-png@1.1.0
          ├── iobroker.icons-ultimate-png@1.0.1
          ├── iobroker.info@ invalid: "1.9.26" from the root project
          ├── iobroker.javascript@ invalid: "7.1.4" from the root project
          ├── iobroker.js-controller@ invalid: "^6.0.9" from the root project
          ├── iobroker.logparser@2.2.0
          ├── iobroker.material@ invalid: "1.3.1" from the root project
          ├── iobroker.meross@1.15.1
          ├── iobroker.mihome-vacuum@3.11.0
          ├── iobroker.milight-smart-light@ invalid: "1.2.2" from the root project
          ├── iobroker.milight@0.3.6
          ├── iobroker.mobile@ invalid: "1.0.1" from the root project
          ├── iobroker.modbus@ invalid: "5.0.11" from the root project
          ├── iobroker.mqtt@ invalid: "4.1.1" from the root project
          ├── iobroker.nina@ invalid: "0.0.25" from the root project
          ├── iobroker.pollenflug@1.0.6
          ├── iobroker.pushover@3.0.3
          ├── iobroker.pushsafer@1.0.3
          ├── iobroker.pvforecast@2.7.1
          ├── iobroker.renault@ invalid: "github:TA2k/ioBroker.renault" from the root project
          ├── iobroker.reolink@ invalid: "github:aendue/ioBroker.reolink#b78aab6744cdb81b360fd947a9c6e2fd6808bab1" from the root project
          ├── iobroker.schoolfree@ invalid: "1.1.2" from the root project
          ├── iobroker.simple-api@2.7.2
          ├── iobroker.smartmeter@3.3.4
          ├── iobroker.socketio@6.5.2
          ├── iobroker.sourceanalytix@ invalid: "github:DrozmotiX/ioBroker.sourceanalytix#362346b297c0a21c717ec20bd8d16331bca3b22d" from the root project
          ├── iobroker.sql@2.2.0
          ├── iobroker.statistics@2.3.0
          ├── iobroker.sunnyportal@0.1.5
          ├── iobroker.synology@ invalid: "2.1.13" from the root project
          ├── iobroker.tankerkoenig@ invalid: "3.3.7" from the root project
          ├── iobroker.terminal@ invalid: "1.0.0" from the root project
          ├── iobroker.tr-064@4.2.18
          ├── iobroker.trashschedule@2.2.0
          ├── iobroker.unifi@ invalid: "0.6.6" from the root project
          ├── iobroker.upnp@1.0.21
          ├── iobroker.valloxmv@1.2.0
          ├── iobroker.viessmannapi@ invalid: "github:TA2k/ioBroker.viessmannapi" from the root project
          ├── iobroker.virtualpowermeter@ invalid: "1.4.6" from the root project
          ├── iobroker.vis-2-widgets-material@ invalid: "github:ioBroker/ioBroker.vis-2-widgets-material#355a97e7d532721eaa97326fd873d13f12894ebd" from the root project
          ├── iobroker.vis-2@ invalid: "github:ioBroker/ioBroker.vis-2#17c7dcf5f26768f1f3a4badb087eddf9344591ea" from the root project
          ├── iobroker.vis-colorpicker@ invalid: "2.0.3" from the root project
          ├── iobroker.vis-fancyswitch@1.1.0
          ├── iobroker.vis-google-fonts@1.0.4
          ├── iobroker.vis-history@1.0.0
          ├── iobroker.vis-hqwidgets@ invalid: "1.4.0" from the root project
          ├── iobroker.vis-inventwo@ invalid: "3.3.3" from the root project
          ├── iobroker.vis-jqui-mfd@1.0.12
          ├── iobroker.vis-justgage@1.0.2
          ├── iobroker.vis-map@1.0.4
          ├── iobroker.vis-materialdesign@ invalid: "github:Scrounger/ioBroker.vis-materialdesign#8b7529d493f223dfc4f1d1f632553fcb35bbcc92" from the root project
          ├── iobroker.vis-metro@ invalid: "1.2.0" from the root project
          ├── iobroker.vis-rgraph@0.0.2
          ├── iobroker.vis-timeandweather@ invalid: "1.2.2" from the root project
          ├── iobroker.vis-weather@ invalid: "2.5.6" from the root project
          ├── iobroker.vis@ invalid: "1.4.16" from the root project
          ├── iobroker.vofo-speedtest@ invalid: "github:peterbaumert/ioBroker.vofo-speedtest#921201b4bbd53a88a64fc843c7242f9e7e8c0325" from the root project
          ├── iobroker.weatherunderground@3.4.2
          ├── iobroker.web-speedy@ invalid: "github:iobroker-community-adapters/ioBroker.web-speedy#8a5ad6a42a15688b6bb539f22e30ba2a1978c118" from the root project
          ├── iobroker.web@ invalid: "6.1.0" from the root project
          ├── iobroker.webcal@ invalid: "github:dirkhe/ioBroker.webcal#feature/DigestAuth" from the root project
          ├── iobroker.wiffi-wz@2.2.1
          ├── iobroker.windows-control@0.1.5
          ├── iobroker.worx@2.3.2
          ├── iobroker.ws@2.5.3
          ├── iobroker@2.0.3
          ├── ioredis@ extraneous
          ├── ip-address@9.0.5 extraneous
          ├── ip-regex@4.3.0 extraneous
          ├── ipaddr.js@2.2.0 extraneous
          ├── is-array-buffer@3.0.4 extraneous
          ├── is-bigint@1.0.4 extraneous
          ├── is-binary-path@2.1.0 extraneous
          ├── is-boolean-object@1.1.2 extraneous
          ├── is-buffer@1.1.6 extraneous
          ├── is-callable@1.2.7 extraneous
          ├── is-ci@2.0.0 extraneous
          ├── is-core-module@2.15.0 extraneous
          ├── is-data-view@1.0.1 extraneous
          ├── is-date-object@1.0.5 extraneous
          ├── is-docker@2.2.1 extraneous
          ├── is-empty-object@1.1.1 extraneous
          ├── is-extglob@2.1.1 extraneous
          ├── is-fullwidth-code-point@3.0.0 extraneous
          ├── is-glob@4.0.3 extraneous
          ├── is-installed-globally@0.3.2 extraneous
          ├── is-interactive@1.0.0 extraneous
          ├── is-lambda@1.0.1 extraneous
          ├── is-negative-zero@2.0.3 extraneous
          ├── is-npm@5.0.0 extraneous
          ├── is-number-object@1.0.7 extraneous
          ├── is-number@7.0.0 extraneous
          ├── is-obj@2.0.0 extraneous
          ├── is-observable@1.1.0 extraneous
          ├── is-path-cwd@2.2.0 extraneous
          ├── is-path-inside@3.0.3 extraneous
          ├── is-plain-obj@1.1.0 extraneous
          ├── is-potential-custom-element-name@1.0.1 extraneous
          ├── is-promise@2.2.2 extraneous
          ├── is-property@1.0.2 extraneous
          ├── is-regex@1.1.4 extraneous
          ├── is-scoped@2.1.0 extraneous
          ├── is-shared-array-buffer@1.0.3 extraneous
          ├── is-string@1.0.7 extraneous
          ├── is-symbol@1.0.4 extraneous
          ├── is-typed-array@1.1.13 extraneous
          ├── is-unicode-supported@0.1.0 extraneous
          ├── is-url-superb@4.0.0 extraneous
          ├── is-url@1.2.4 extraneous
          ├── is-weakref@1.0.2 extraneous
          ├── is-wsl@2.2.0 extraneous
          ├── is-yarn-global@0.3.0 extraneous
          ├── is@3.3.0 extraneous
          ├── is2@2.0.9 extraneous
          ├── isomorphic-ws@4.0.1 extraneous
          ├── issue-regex@3.1.0 extraneous
          ├── jackspeak@3.4.3 extraneous
          ├── js-md4@0.3.2 extraneous
          ├── js-sdsl@4.3.0 extraneous
          ├── js-tokens@4.0.0 extraneous
          ├── js-yaml@ extraneous
          ├── jsbi@4.3.0 extraneous
          ├── jsbn@1.1.0 extraneous
          ├── jsdom@ extraneous
          ├── jshashes@1.0.8 extraneous
          ├── json-buffer@3.0.1 extraneous
          ├── json-logic-js@2.0.5 extraneous
          ├── json-parse-even-better-errors@2.3.1 extraneous
          ├── json-schema-traverse@1.0.0 extraneous
          ├── json5@2.2.3 extraneous
          ├── jsonata@ extraneous
          ├── jsonc-parser@3.3.1 extraneous
          ├── jsonwebtoken@9.0.2 extraneous
          ├── jszip@ extraneous
          ├── jwa@2.0.0 extraneous
          ├── jws@4.0.0 extraneous
          ├── keyv@4.5.4 extraneous
          ├── kind-of@6.0.3 extraneous
          ├── kuler@2.0.0 extraneous
          ├── later@1.2.0 extraneous
          ├── latest-version@5.1.0 extraneous
          ├── layerr@0.1.2 extraneous
          ├── lazystream@1.0.1 extraneous
          ├── leven@2.1.0 extraneous
          ├── levn@0.3.0 extraneous
          ├── lie@3.3.0 extraneous
          ├── lines-and-columns@1.2.4 extraneous
          ├── listr-input@0.2.1 extraneous
          ├── listr-silent-renderer@1.1.1 extraneous
          ├── listr-update-renderer@0.5.0 extraneous
          ├── listr-verbose-renderer@0.5.0 extraneous
          ├── listr@0.14.3 extraneous
          ├── loadavg-windows@1.1.1 extraneous
          ├── locate-path@6.0.0 extraneous
          ├── lodash.defaults@4.2.0 extraneous
          ├── lodash.flatten@4.4.0 extraneous
          ├── lodash.includes@4.3.0 extraneous
          ├── lodash.isarguments@3.1.0 extraneous
          ├── lodash.isboolean@3.0.3 extraneous
          ├── lodash.isequal@4.5.0 extraneous
          ├── lodash.isinteger@4.0.4 extraneous
          ├── lodash.isnumber@3.0.3 extraneous
          ├── lodash.isplainobject@4.0.6 extraneous
          ├── lodash.isstring@4.0.1 extraneous
          ├── lodash.once@4.1.1 extraneous
          ├── lodash.zip@4.2.0 extraneous
          ├── log-symbols@4.1.0 extraneous
          ├── log-update@2.3.0 extraneous
          ├── logform@ extraneous
          ├── long@5.2.3 extraneous
          ├── lowercase-keys@2.0.0 extraneous
          ├── lru_map@0.3.3 extraneous
          ├── lru-cache@6.0.0 extraneous
          ├── make-dir@3.1.0 extraneous
          ├── make-fetch-happen@10.2.1 extraneous
          ├── map-age-cleaner@0.1.3 extraneous
          ├── map-obj@4.3.0 extraneous
          ├── map-stream@0.0.7 extraneous
          ├── md5@2.3.0 extraneous
          ├── media-typer@0.3.0 extraneous
          ├── meow@8.1.2 extraneous
          ├── merge-descriptors@1.0.1 extraneous
          ├── merge2@1.4.1 extraneous
          ├── methods@1.1.2 extraneous
          ├── micro@9.4.1 extraneous
          ├── micromatch@4.0.7 extraneous
          ├── mime-db@1.53.0 extraneous
          ├── mimic-response@1.0.1 extraneous
          ├── min-indent@1.0.1 extraneous
          ├── minimatch@9.0.5 extraneous
          ├── minimist-options@4.1.0 extraneous
          ├── minipass-collect@1.0.2 extraneous
          ├── minipass-fetch@2.1.2 extraneous
          ├── minipass-flush@1.0.5 extraneous
          ├── minipass-pipeline@1.2.4 extraneous
          ├── minipass-sized@1.0.3 extraneous
          ├── minipass@7.1.2 extraneous
          ├── minizlib@2.1.2 extraneous
          ├── mkdirp-classic@0.5.3 extraneous
          ├── mkdirp@1.0.4 extraneous
          ├── mock-require@3.0.3 extraneous
          ├── moment-duration-format@2.3.2 extraneous
          ├── mqtt-connection@4.1.0 extraneous
          ├── mqtt-packet@9.0.0 extraneous
          ├── mqtt@ extraneous
          ├── mute-stream@0.0.8 extraneous
          ├── named-placeholders@1.1.3 extraneous
          ├── nan@ extraneous
          ├── nanoid@3.3.7 extraneous
          ├── napi-build-utils@1.0.2 extraneous
          ├── native-duplexpair@1.0.0 extraneous
          ├── nconf@0.10.0 extraneous
          ├── nested-property@4.0.0 extraneous
          ├── netmask@2.0.2 extraneous
          ├── new-github-release-url@1.0.0 extraneous
          ├── node-abi@3.65.0 extraneous
          ├── node-abort-controller@3.1.1 extraneous
          ├── node-cron@2.0.3 extraneous
          ├── node-fetch@2.7.0 extraneous
          ├── node-forge@ extraneous
          ├── node-gyp@ extraneous
          ├── node-ical@0.16.1 extraneous
          ├── node-inspect@2.0.0 extraneous
          ├── node-libcurl@3.0.0 extraneous
          ├── node-mndp@0.0.3 extraneous
          ├── node-persist@0.0.11 extraneous
          ├── node-rsa@1.1.1 extraneous
          ├── node-unifi@2.5.1 extraneous
          ├── node-wol@0.1.1 extraneous
          ├── node.extend@2.0.3 extraneous
          ├── nopt@5.0.0 extraneous
          ├── normalize-package-data@3.0.3 extraneous
          ├── normalize-path@3.0.0 extraneous
          ├── normalize-url@6.1.0 extraneous
          ├── np@7.7.0 extraneous
          ├── npm-name@6.0.1 extraneous
          ├── npmlog@5.0.1 extraneous
          ├── number-allocator@1.0.14 extraneous
          ├── nwsapi@2.2.12 extraneous
          ├── object-assign@4.1.1 extraneous
          ├── object-hash@3.0.0 extraneous
          ├── on-finished@2.4.1 extraneous
          ├── once@1.4.0 extraneous
          ├── one-time@1.0.0 extraneous
          ├── onedrive-api@1.1.1 extraneous
          ├── open@7.4.2 extraneous
          ├── opencollective-postinstall@2.0.3 extraneous
          ├── optionator@0.8.3 extraneous
          ├── org-regex@1.0.0 extraneous
          ├── os-tmpdir@1.0.2 extraneous
          ├── ospath@1.2.2 extraneous
          ├── osx-temperature-sensor@ extraneous
          ├── otplib@11.0.1 extraneous
          ├── ow@0.21.0 extraneous
          ├── p-cancelable@2.1.1 extraneous
          ├── p-defer@1.0.0 extraneous
          ├── p-event@4.2.0 extraneous
          ├── p-finally@1.0.0 extraneous
          ├── p-limit@2.3.0 extraneous
          ├── p-locate@5.0.0 extraneous
          ├── p-map@2.1.0 extraneous
          ├── p-memoize@4.0.4 extraneous
          ├── p-reflect@2.1.0 extraneous
          ├── p-settle@4.1.1 extraneous
          ├── p-throttle@4.1.1 extraneous
          ├── p-timeout@4.1.0 extraneous
          ├── p-try@2.2.0 extraneous
          ├── package-json-from-dist@1.0.0 extraneous
          ├── package-json@6.5.0 extraneous
          ├── pako@ extraneous
          ├── parent-module@1.0.1 extraneous
          ├── parse-json@5.2.0 extraneous
          ├── parse5@ extraneous
          ├── passport-local@1.0.0 extraneous
          ├── passport@0.7.0 extraneous
          ├── path-exists@4.0.0 extraneous
          ├── path-is-absolute@1.0.1 extraneous
          ├── path-parse@1.0.7 extraneous
          ├── path-posix@1.0.0 extraneous
          ├── path-scurry@1.11.1 extraneous
          ├── path-to-regexp@0.1.7 extraneous
          ├── path-type@4.0.0 extraneous
          ├── pause-stream@0.0.11 extraneous
          ├── picomatch@2.3.1 extraneous
          ├── pidtree@0.6.0 extraneous
          ├── pidusage@3.0.2 extraneous
          ├── ping@0.4.4 extraneous
          ├── pkg-dir@5.0.0 extraneous
          ├── pluralize@8.0.0 extraneous
          ├── possible-typed-array-names@1.0.0 extraneous
          ├── prebuild-install@7.1.2 extraneous
          ├── prelude-ls@1.1.2 extraneous
          ├── prepend-http@2.0.0 extraneous
          ├── process-nextick-args@2.0.1 extraneous
          ├── process@0.11.10 extraneous
          ├── promise-inflight@1.0.1 extraneous
          ├── promise-object@0.1.7 extraneous
          ├── promise-retry@2.0.1 extraneous
          ├── promise-retryer@0.0.1 extraneous
          ├── promisify-child-process@4.1.2 extraneous
          ├── prompt@1.3.0 extraneous
          ├── protobufjs@ extraneous
          ├── proxy-addr@2.0.7 extraneous
          ├── proxy-from-env@1.1.0 extraneous
          ├── pump@3.0.0 extraneous
          ├── pupa@2.1.1 extraneous
          ├── q@1.1.2 extraneous
          ├── quasar@ extraneous
          ├── queue-microtask@1.2.3 extraneous
          ├── queue-tick@1.0.1 extraneous
          ├── quick-lru@5.1.1 extraneous
          ├── range-parser@1.2.1 extraneous
          ├── raw-body@2.5.2 extraneous
          ├── rc@1.2.8 extraneous
          ├── read-pkg-up@7.0.1 extraneous
          ├── read-pkg@5.2.0 extraneous
          ├── read@1.0.7 extraneous
          ├── readable-stream@ extraneous
          ├── readdir-glob@1.1.3 extraneous
          ├── readdirp@3.6.0 extraneous
          ├── readline-sync@1.4.10 extraneous
          ├── readline@1.3.0 extraneous
          ├── redent@3.0.0 extraneous
          ├── redis-commands@1.7.0 extraneous
          ├── redis-errors@1.2.0 extraneous
          ├── redis-parser@3.0.0 extraneous
          ├── regenerator-runtime@0.14.1 extraneous
          ├── regex-escape@3.4.10 extraneous
          ├── regexp.prototype.flags@1.5.2 extraneous
          ├── registry-auth-token@4.2.2 extraneous
          ├── registry-url@5.1.0 extraneous
          ├── reinterval@1.1.0 extraneous
          ├── remove-trailing-separator@1.1.0 extraneous
          ├── require-from-string@2.0.2 extraneous
          ├── resolve-alpn@1.2.1 extraneous
          ├── resolve-cwd@3.0.0 extraneous
          ├── resolve-from@4.0.0 extraneous
          ├── respjs@4.2.0 extraneous
          ├── responselike@2.0.1 extraneous
          ├── restore-cursor@3.1.0 extraneous
          ├── retry-axios@2.6.0 extraneous
          ├── retry@0.12.0 extraneous
          ├── reusify@1.0.4 extraneous
          ├── revalidator@0.1.8 extraneous
          ├── rfdc@1.4.1 extraneous
          ├── rimraf@3.0.2 extraneous
          ├── rrule@2.8.1 extraneous
          ├── rrweb-cssom@0.6.0 extraneous
          ├── run-async@2.4.1 extraneous
          ├── run-parallel@1.2.0 extraneous
          ├── rxjs@ extraneous
          ├── safe-array-concat@1.1.2 extraneous
          ├── safe-regex-test@1.0.3 extraneous
          ├── safe-stable-stringify@2.4.3 extraneous
          ├── safer-buffer@2.1.2 extraneous
          ├── saxes@6.0.0 extraneous
          ├── scoped-regex@2.1.0 extraneous
          ├── secure-keys@1.0.0 extraneous
          ├── semver-diff@3.1.1 extraneous
          ├── semver@5.7.2
          ├── send@0.18.0 extraneous
          ├── seq-logging@1.1.2 extraneous
          ├── seq-queue@0.0.5 extraneous
          ├── serve-static@1.15.0 extraneous
          ├── set-function-name@2.0.2 extraneous
          ├── setimmediate@1.0.5 extraneous
          ├── setprototypeof@1.2.0 extraneous
          ├── signal-exit@4.1.0 extraneous
          ├── simple-concat@1.0.1 extraneous
          ├── simple-get@3.1.1 extraneous
          ├── simple-ssh@1.1.1 extraneous
          ├── simple-swizzle@0.2.2 extraneous
          ├── slash@3.0.0 extraneous
          ├── slice-ansi@0.0.4 extraneous
          ├── smart-buffer@4.2.0 extraneous
          ├── socks-proxy-agent@7.0.0 extraneous
          ├── socks@2.8.3 extraneous
          ├── speedtest-net@1.6.2 extraneous
          ├── split@1.0.1 extraneous
          ├── sprintf-js@1.1.3 extraneous
          ├── sqlstring@2.3.3 extraneous
          ├── ssh2@ extraneous
          ├── ssri@9.0.1 extraneous
          ├── stack-trace@0.0.10 extraneous
          ├── stampit-event-bus@0.1.1 extraneous
          ├── stampit-state-machine@0.2.1 extraneous
          ├── stampit@2.1.2 extraneous
          ├── standard-as-callback@2.1.0 extraneous
          ├── static-eval@2.0.2 extraneous
          ├── statuses@2.0.1 extraneous
          ├── stoppable@1.1.0 extraneous
          ├── stream-combiner@0.2.2 extraneous
          ├── stream-shift@1.0.3 extraneous
          ├── streamsearch@1.1.0 extraneous
          ├── streamx@2.18.0 extraneous
          ├── string-argv@0.3.2 extraneous
          ├── string-width-cjs@npm:string-width@4.2.3 extraneous
          ├── string-width@5.1.2 extraneous
          ├── string.prototype.trim@1.2.9 extraneous
          ├── string.prototype.trimend@1.0.8 extraneous
          ├── string.prototype.trimstart@1.0.8 extraneous
          ├── strip-ansi-cjs@npm:strip-ansi@6.0.1 extraneous
          ├── strip-ansi@6.0.1 extraneous
          ├── strip-indent@3.0.0 extraneous
          ├── strip-json-comments@2.0.1 extraneous
          ├── strnum@1.0.5 extraneous
          ├── suncalc@1.9.0 extraneous
          ├── suncalc2@1.8.1 extraneous
          ├── supermixer@1.0.5 extraneous
          ├── supports-color@7.2.0 extraneous
          ├── supports-hyperlinks@2.3.0 extraneous
          ├── supports-preserve-symlinks-flag@1.0.0 extraneous
          ├── sweet-collections@1.1.0 extraneous
          ├── symbol-observable@3.0.0 extraneous
          ├── symbol-tree@3.2.4 extraneous
          ├── syno@ extraneous
          ├── systeminformation@ extraneous
          ├── tar-fs@2.1.1 extraneous
          ├── tar-stream@3.1.7 extraneous
          ├── tar@6.2.1 extraneous
          ├── tarn@3.0.2 extraneous
          ├── tcp-port-used@1.0.2 extraneous
          ├── tedious@ extraneous
          ├── terminal-link@2.1.1 extraneous
          ├── text-decoder@1.1.1 extraneous
          ├── text-hex@1.0.0 extraneous
          ├── thirty-two@1.0.2 extraneous
          ├── through@2.3.8 extraneous
          ├── through2@2.0.5 extraneous
          ├── tiny-typed-emitter@2.1.0 extraneous
          ├── tinycolor2@1.6.0 extraneous
          ├── tmp@0.0.33 extraneous
          ├── to-readable-stream@2.1.0 extraneous
          ├── to-regex-range@5.0.1 extraneous
          ├── toidentifier@1.0.1 extraneous
          ├── tr46@4.1.1 extraneous
          ├── trim-newlines@3.0.1 extraneous
          ├── triple-beam@1.4.1 extraneous
          ├── tsdav@ extraneous
          ├── tslib@2.3.0 extraneous
          ├── tweetnacl@0.14.5 extraneous
          ├── type-check@0.3.2 extraneous
          ├── type-fest@0.21.3 extraneous
          ├── type-is@1.6.18 extraneous
          ├── typed-array-buffer@1.0.2 extraneous
          ├── typed-array-byte-length@1.0.1 extraneous
          ├── typed-array-byte-offset@1.0.2 extraneous
          ├── typed-array-length@1.0.6 extraneous
          ├── typedarray-to-buffer@3.1.5 extraneous
          ├── typedarray.prototype.slice@1.0.3 extraneous
          ├── typescript@ extraneous
          ├── tz-offset@0.0.1 extraneous
          ├── uid-number@0.0.6 extraneous
          ├── unbox-primitive@1.0.2 extraneous
          ├── undici-types@6.19.6 extraneous
          ├── unique-filename@2.0.1 extraneous
          ├── unique-slug@3.0.0 extraneous
          ├── unique-string@2.0.0 extraneous
          ├── unix-dgram@2.0.6 extraneous
          ├── unpipe@1.0.0 extraneous
          ├── update-notifier@5.1.0 extraneous
          ├── uri-js@4.4.1 extraneous
          ├── url-join@4.0.1 extraneous
          ├── url-parse-lax@3.0.0 extraneous
          ├── url-template@2.0.8 extraneous
          ├── url@0.11.4 extraneous
          ├── vali-date@1.0.0 extraneous
          ├── validate-npm-package-name@3.0.0 extraneous
          ├── vary@1.1.2 extraneous
          ├── virtual-tsc@0.6.2 extraneous
          ├── vue-i18n@ extraneous
          ├── vuelidate-messages@0.1.2 extraneous
          ├── vuelidate@ extraneous
          ├── vuex-map-fields@1.4.1 extraneous
          ├── w3c-xmlserializer@4.0.0 extraneous
          ├── wake_on_lan@1.0.0 extraneous
          ├── weak-daemon@1.0.3 extraneous
          ├── webdav@ extraneous
          ├── webidl-conversions@7.0.0 extraneous
          ├── websocket-stream@5.5.2 extraneous
          ├── whatwg-encoding@2.0.0 extraneous
          ├── whatwg-mimetype@3.0.0 extraneous
          ├── whatwg-url@12.0.1 extraneous
          ├── which-boxed-primitive@1.0.2 extraneous
          ├── which-typed-array@1.1.15 extraneous
          ├── wide-align@1.1.5 extraneous
          ├── widest-line@3.1.0 extraneous
          ├── window-size@0.1.4 extraneous
          ├── winston-daily-rotate-file@5.0.0 extraneous
          ├── winston-seq-updated@1.0.4 extraneous
          ├── winston-syslog@2.7.1 extraneous
          ├── winston-transport@4.7.1 extraneous
          ├── winston@ extraneous
          ├── word-wrap@1.2.5 extraneous
          ├── worker-timers-broker@6.1.8 extraneous
          ├── worker-timers-worker@7.0.71 extraneous
          ├── worker-timers@7.1.8 extraneous
          ├── wrap-ansi-cjs@npm:wrap-ansi@7.0.0 extraneous
          ├── wrap-ansi@8.1.0 extraneous
          ├── wrappy@1.0.2 extraneous
          ├── write-file-atomic@3.0.3 extraneous
          ├── xdg-basedir@4.0.0 extraneous
          ├── xml-js@1.6.11 extraneous
          ├── xml-name-validator@4.0.0 extraneous
          ├── xmlchars@2.2.0 extraneous
          ├── xregexp@2.0.0 extraneous
          ├── yallist@4.0.0 extraneous
          ├── yaml@ extraneous
          ├── yargs-parser@20.2.9 extraneous
          ├── yargs@7.1.2
          ├── yocto-queue@0.1.0 extraneous
          ├── zip-stream@6.0.1 extraneous
          └── zrender@ extraneous
            Teil 2
            npm error code ELSPROBLEMS
            npm error extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
            npm error extraneous: @alcalzone/jsonl-db@3.1.1 /opt/iobroker/node_modules/@alcalzone/jsonl-db
            npm error extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/@alcalzone/pak
            npm error extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
            npm error extraneous: @aws-sdk/util-utf8-browser@3.259.0 /opt/iobroker/node_modules/@aws-sdk/util-utf8-browser
            npm error extraneous: @azure/abort-controller@1.1.0 /opt/iobroker/node_modules/@azure/abort-controller
            npm error extraneous: @azure/core-auth@1.7.2 /opt/iobroker/node_modules/@azure/core-auth
            npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
            npm error extraneous: @azure/core-http-compat@ /opt/iobroker/node_modules/@azure/core-http-compat
            npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
            npm error extraneous: @azure/core-paging@1.6.2 /opt/iobroker/node_modules/@azure/core-paging
            npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
            npm error extraneous: @azure/core-tracing@1.1.2 /opt/iobroker/node_modules/@azure/core-tracing
            npm error extraneous: @azure/core-util@ /opt/iobroker/node_modules/@azure/core-util
            npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
            npm error extraneous: @azure/keyvault-keys@ /opt/iobroker/node_modules/@azure/keyvault-keys
            npm error extraneous: @azure/logger@1.1.4 /opt/iobroker/node_modules/@azure/logger
            npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
            npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
            npm error extraneous: @azure/msal-node@1.18.4 /opt/iobroker/node_modules/@azure/msal-node
            npm error extraneous: @babel/code-frame@7.24.7 /opt/iobroker/node_modules/@babel/code-frame
            npm error extraneous: @babel/helper-validator-identifier@7.24.7 /opt/iobroker/node_modules/@babel/helper-validator-identifier
            npm error extraneous: @babel/highlight@7.24.7 /opt/iobroker/node_modules/@babel/highlight
            npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
            npm error extraneous: @colors/colors@1.5.0 /opt/iobroker/node_modules/@colors/colors
            npm error extraneous: @dabh/diagnostics@2.0.3 /opt/iobroker/node_modules/@dabh/diagnostics
            npm error extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
            npm error extraneous: @gar/promisify@1.1.3 /opt/iobroker/node_modules/@gar/promisify
            npm error extraneous: @googleapis/calendar@9.7.7 /opt/iobroker/node_modules/@googleapis/calendar
            npm error extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
            npm error extraneous: @googleapis/oauth2@1.0.7 /opt/iobroker/node_modules/@googleapis/oauth2
            npm error extraneous: @httptoolkit/websocket-stream@6.0.1 /opt/iobroker/node_modules/@httptoolkit/websocket-stream
            npm error extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
            npm error extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
            npm error extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
            npm error extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
            npm error extraneous: @iobroker/db-states-file@ /opt/iobroker/node_modules/@iobroker/db-states-file
            npm error extraneous: @iobroker/db-states-jsonl@ /opt/iobroker/node_modules/@iobroker/db-states-jsonl
            npm error extraneous: @iobroker/db-states-redis@ /opt/iobroker/node_modules/@iobroker/db-states-redis
            npm error extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
            npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
            npm error extraneous: @iobroker/js-controller-common-db@ /opt/iobroker/node_modules/@iobroker/js-controller-common-db
            npm error extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
            npm error extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
            npm error extraneous: @iobroker/plugin-sentry@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-sentry
            npm error extraneous: @iobroker/socket-classes@1.5.6 /opt/iobroker/node_modules/@iobroker/socket-classes
            npm error extraneous: @iobroker/webserver@1.0.3 /opt/iobroker/node_modules/@iobroker/webserver
            npm error extraneous: @isaacs/cliui@8.0.2 /opt/iobroker/node_modules/@isaacs/cliui
            npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
            npm error extraneous: @mapbox/node-pre-gyp@1.0.11 /opt/iobroker/node_modules/@mapbox/node-pre-gyp
            npm error extraneous: @microsoft/microsoft-graph-types@2.40.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
            npm error extraneous: @nodelib/fs.scandir@2.1.5 /opt/iobroker/node_modules/@nodelib/fs.scandir
            npm error extraneous: @nodelib/fs.stat@2.0.5 /opt/iobroker/node_modules/@nodelib/fs.stat
            npm error extraneous: @nodelib/fs.walk@1.2.8 /opt/iobroker/node_modules/@nodelib/fs.walk
            npm error extraneous: @npmcli/fs@2.1.2 /opt/iobroker/node_modules/@npmcli/fs
            npm error extraneous: @npmcli/move-file@2.0.1 /opt/iobroker/node_modules/@npmcli/move-file
            npm error extraneous: @pkgjs/parseargs@0.11.0 /opt/iobroker/node_modules/@pkgjs/parseargs
            npm error extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
            npm error extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
            npm error extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
            npm error extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
            npm error extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
            npm error extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
            npm error extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
            npm error extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
            npm error extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
            npm error extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
            npm error extraneous: @quasar/extras@ /opt/iobroker/node_modules/@quasar/extras
            npm error extraneous: @samverschueren/stream-to-observable@0.3.1 /opt/iobroker/node_modules/@samverschueren/stream-to-observable
            npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
            npm error extraneous: @sentry/core@5.30.0 /opt/iobroker/node_modules/@sentry/core
            npm error extraneous: @sentry/hub@5.30.0 /opt/iobroker/node_modules/@sentry/hub
            npm error extraneous: @sentry/minimal@5.30.0 /opt/iobroker/node_modules/@sentry/minimal
            npm error extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
            npm error extraneous: @sentry/tracing@ /opt/iobroker/node_modules/@sentry/tracing
            npm error extraneous: @sentry/types@ /opt/iobroker/node_modules/@sentry/types
            npm error extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
            npm error extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/@sindresorhus/is
            npm error extraneous: @socket.io/component-emitter@3.1.2 /opt/iobroker/node_modules/@socket.io/component-emitter
            npm error extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/@szmarczak/http-timer
            npm error extraneous: @tediousjs/connection-string@0.5.0 /opt/iobroker/node_modules/@tediousjs/connection-string
            npm error extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
            npm error extraneous: @types/bl@5.1.0 /opt/iobroker/node_modules/@types/bl
            npm error extraneous: @types/cacheable-request@6.0.3 /opt/iobroker/node_modules/@types/cacheable-request
            npm error extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
            npm error extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/@types/cookie
            npm error extraneous: @types/cors@2.8.17 /opt/iobroker/node_modules/@types/cors
            npm error extraneous: @types/geojson@7946.0.14 /opt/iobroker/node_modules/@types/geojson
            npm error extraneous: @types/http-cache-semantics@4.0.4 /opt/iobroker/node_modules/@types/http-cache-semantics
            npm error extraneous: @types/keyv@3.1.4 /opt/iobroker/node_modules/@types/keyv
            npm error extraneous: @types/leaflet@1.9.12 /opt/iobroker/node_modules/@types/leaflet
            npm error extraneous: @types/minimist@1.2.5 /opt/iobroker/node_modules/@types/minimist
            npm error extraneous: @types/node-cron@2.0.8 /opt/iobroker/node_modules/@types/node-cron
            npm error extraneous: @types/node@ /opt/iobroker/node_modules/@types/node
            npm error extraneous: @types/normalize-package-data@2.4.4 /opt/iobroker/node_modules/@types/normalize-package-data
            npm error extraneous: @types/parse-json@4.0.2 /opt/iobroker/node_modules/@types/parse-json
            npm error extraneous: @types/readable-stream@4.0.15 /opt/iobroker/node_modules/@types/readable-stream
            npm error extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
            npm error extraneous: @types/responselike@1.0.3 /opt/iobroker/node_modules/@types/responselike
            npm error extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
            npm error extraneous: @types/triple-beam@1.3.5 /opt/iobroker/node_modules/@types/triple-beam
            npm error extraneous: @types/tz-offset@0.0.3 /opt/iobroker/node_modules/@types/tz-offset
            npm error extraneous: @types/ws@8.5.12 /opt/iobroker/node_modules/@types/ws
            npm error extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
            npm error extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
            npm error extraneous: abort-controller@3.0.0 /opt/iobroker/node_modules/abort-controller
            npm error extraneous: agentkeepalive@4.5.0 /opt/iobroker/node_modules/agentkeepalive
            npm error extraneous: aggregate-error@3.1.0 /opt/iobroker/node_modules/aggregate-error
            npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
            npm error extraneous: ansi-align@3.0.1 /opt/iobroker/node_modules/ansi-align
            npm error extraneous: ansi-colors@4.1.3 /opt/iobroker/node_modules/ansi-colors
            npm error extraneous: ansi-escapes@4.3.2 /opt/iobroker/node_modules/ansi-escapes
            npm error extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/ansi-regex
            npm error extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/ansi-styles
            npm error extraneous: any-observable@0.5.1 /opt/iobroker/node_modules/any-observable
            npm error extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
            npm error extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
            npm error extraneous: archiver-utils@5.0.2 /opt/iobroker/node_modules/archiver-utils
            npm error extraneous: archiver@7.0.1 /opt/iobroker/node_modules/archiver
            npm error extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
            npm error extraneous: arg@4.1.0 /opt/iobroker/node_modules/arg
            npm error extraneous: argparse@1.0.10 /opt/iobroker/node_modules/argparse
            npm error extraneous: array-buffer-byte-length@1.0.1 /opt/iobroker/node_modules/array-buffer-byte-length
            npm error extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/array-flatten
            npm error extraneous: array-union@2.1.0 /opt/iobroker/node_modules/array-union
            npm error extraneous: arraybuffer.prototype.slice@1.0.3 /opt/iobroker/node_modules/arraybuffer.prototype.slice
            npm error extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
            npm error extraneous: asn1@0.2.6 /opt/iobroker/node_modules/asn1
            npm error extraneous: async-exit-hook@2.0.1 /opt/iobroker/node_modules/async-exit-hook
            npm error extraneous: authenticate-pam@1.0.5 /opt/iobroker/node_modules/authenticate-pam
            npm error extraneous: available-typed-arrays@1.0.7 /opt/iobroker/node_modules/available-typed-arrays
            npm error extraneous: aws-crt@ /opt/iobroker/node_modules/aws-crt
            npm error extraneous: b4a@1.6.6 /opt/iobroker/node_modules/b4a
            npm error extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/balanced-match
            npm error extraneous: bare-events@2.4.2 /opt/iobroker/node_modules/bare-events
            npm error extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
            npm error extraneous: base64-js@1.5.1 /opt/iobroker/node_modules/base64-js
            npm error extraneous: bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/bcrypt-pbkdf
            npm error extraneous: binary-extensions@2.3.0 /opt/iobroker/node_modules/binary-extensions
            npm error extraneous: bindings@1.5.0 /opt/iobroker/node_modules/bindings
            npm error extraneous: bl@6.0.14 /opt/iobroker/node_modules/bl
            npm error extraneous: bluebird@3.7.2 /opt/iobroker/node_modules/bluebird
            npm error extraneous: body-parser@1.20.2 /opt/iobroker/node_modules/body-parser
            npm error extraneous: bottleneck@2.19.5 /opt/iobroker/node_modules/bottleneck
            npm error extraneous: boxen@5.1.2 /opt/iobroker/node_modules/boxen
            npm error extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/brace-expansion
            npm error extraneous: braces@3.0.3 /opt/iobroker/node_modules/braces
            npm error extraneous: buffer-crc32@1.0.0 /opt/iobroker/node_modules/buffer-crc32
            npm error extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
            npm error extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
            npm error extraneous: buffer@6.0.3 /opt/iobroker/node_modules/buffer
            npm error extraneous: buildcheck@0.0.6 /opt/iobroker/node_modules/buildcheck
            npm error extraneous: builtins@1.0.3 /opt/iobroker/node_modules/builtins
            npm error extraneous: busboy@1.6.0 /opt/iobroker/node_modules/busboy
            npm error extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
            npm error extraneous: bytes@3.1.2 /opt/iobroker/node_modules/bytes
            npm error extraneous: cacache@16.1.3 /opt/iobroker/node_modules/cacache
            npm error extraneous: cacheable-lookup@5.0.4 /opt/iobroker/node_modules/cacheable-lookup
            npm error extraneous: cacheable-request@7.0.4 /opt/iobroker/node_modules/cacheable-request
            npm error extraneous: callsites@3.1.0 /opt/iobroker/node_modules/callsites
            npm error extraneous: camelcase-keys@6.2.2 /opt/iobroker/node_modules/camelcase-keys
            npm error extraneous: camelcase@5.3.1 /opt/iobroker/node_modules/camelcase
            npm error extraneous: capitalize@2.0.4 /opt/iobroker/node_modules/capitalize
            npm error extraneous: chalk@4.1.2 /opt/iobroker/node_modules/chalk
            npm error extraneous: chardet@0.7.0 /opt/iobroker/node_modules/chardet
            npm error extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
            npm error extraneous: chokidar@3.6.0 /opt/iobroker/node_modules/chokidar
            npm error extraneous: chownr@2.0.0 /opt/iobroker/node_modules/chownr
            npm error extraneous: ci-info@3.9.0 /opt/iobroker/node_modules/ci-info
            npm error extraneous: clean-stack@2.2.0 /opt/iobroker/node_modules/clean-stack
            npm error extraneous: cli-boxes@2.2.1 /opt/iobroker/node_modules/cli-boxes
            npm error extraneous: cli-cursor@3.1.0 /opt/iobroker/node_modules/cli-cursor
            npm error extraneous: cli-truncate@0.2.1 /opt/iobroker/node_modules/cli-truncate
            npm error extraneous: cli-width@3.0.0 /opt/iobroker/node_modules/cli-width
            npm error extraneous: clone-response@1.0.3 /opt/iobroker/node_modules/clone-response
            npm error extraneous: cloneextend@0.0.3 /opt/iobroker/node_modules/cloneextend
            npm error extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
            npm error extraneous: coap-packet@1.1.1 /opt/iobroker/node_modules/coap-packet
            npm error extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
            npm error extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/color-convert
            npm error extraneous: color-name@1.1.4 /opt/iobroker/node_modules/color-name
            npm error extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
            npm error extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
            npm error extraneous: color@3.2.1 /opt/iobroker/node_modules/color
            npm error extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
            npm error extraneous: commander@9.5.0 /opt/iobroker/node_modules/commander
            npm error extraneous: commist@3.2.0 /opt/iobroker/node_modules/commist
            npm error extraneous: compress-commons@6.0.2 /opt/iobroker/node_modules/compress-commons
            npm error extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
            npm error extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
            npm error extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
            npm error extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
            npm error extraneous: configstore@5.0.1 /opt/iobroker/node_modules/configstore
            npm error extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
            npm error extraneous: connect@3.7.0 /opt/iobroker/node_modules/connect
            npm error extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
            npm error extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/content-disposition
            npm error extraneous: content-type@1.0.5 /opt/iobroker/node_modules/content-type
            npm error extraneous: core-js@ /opt/iobroker/node_modules/core-js
            npm error extraneous: cors@2.8.5 /opt/iobroker/node_modules/cors
            npm error extraneous: cosmiconfig@7.1.0 /opt/iobroker/node_modules/cosmiconfig
            npm error extraneous: cpu-features@ /opt/iobroker/node_modules/cpu-features
            npm error extraneous: crc-32@1.2.2 /opt/iobroker/node_modules/crc-32
            npm error extraneous: crc@ /opt/iobroker/node_modules/crc
            npm error extraneous: crc32-stream@6.0.0 /opt/iobroker/node_modules/crc32-stream
            npm error extraneous: cross-fetch@4.0.0 /opt/iobroker/node_modules/cross-fetch
            npm error extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
            npm error extraneous: crypto-js@ /opt/iobroker/node_modules/crypto-js
            npm error extraneous: crypto-random-string@2.0.0 /opt/iobroker/node_modules/crypto-random-string
            npm error extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
            npm error extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
            npm error extraneous: dashdash@1.14.1 /opt/iobroker/node_modules/dashdash
            npm error extraneous: data-urls@4.0.0 /opt/iobroker/node_modules/data-urls
            npm error extraneous: data-view-buffer@1.0.1 /opt/iobroker/node_modules/data-view-buffer
            npm error extraneous: data-view-byte-length@1.0.1 /opt/iobroker/node_modules/data-view-byte-length
            npm error extraneous: data-view-byte-offset@1.0.0 /opt/iobroker/node_modules/data-view-byte-offset
            npm error extraneous: date-and-time@ /opt/iobroker/node_modules/date-and-time
            npm error extraneous: date-fns@1.30.1 /opt/iobroker/node_modules/date-fns
            npm error extraneous: dateformat@4.6.3 /opt/iobroker/node_modules/dateformat
            npm error extraneous: dayjs@ /opt/iobroker/node_modules/dayjs
            npm error extraneous: decache@4.6.2 /opt/iobroker/node_modules/decache
            npm error extraneous: decamelize-keys@1.1.1 /opt/iobroker/node_modules/decamelize-keys
            npm error extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
            npm error extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
            npm error extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
            npm error extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
            npm error extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is
            npm error extraneous: defer-to-connect@2.0.1 /opt/iobroker/node_modules/defer-to-connect
            npm error extraneous: define-lazy-prop@2.0.0 /opt/iobroker/node_modules/define-lazy-prop
            npm error extraneous: del@6.1.1 /opt/iobroker/node_modules/del
            npm error extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
            npm error extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
            npm error extraneous: destroy@1.2.0 /opt/iobroker/node_modules/destroy
            npm error extraneous: detect-libc@2.0.3 /opt/iobroker/node_modules/detect-libc
            npm error extraneous: diacritics@1.3.0 /opt/iobroker/node_modules/diacritics
            npm error extraneous: digest-header@1.1.0 /opt/iobroker/node_modules/digest-header
            npm error extraneous: dir-glob@3.0.1 /opt/iobroker/node_modules/dir-glob
            npm error extraneous: diskusage@1.2.0 /opt/iobroker/node_modules/diskusage
            npm error extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception
            npm error extraneous: dot-prop@6.0.1 /opt/iobroker/node_modules/dot-prop
            npm error extraneous: draftlog@1.0.13 /opt/iobroker/node_modules/draftlog
            npm error extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
            npm error extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
            npm error extraneous: duplexer3@0.1.5 /opt/iobroker/node_modules/duplexer3
            npm error extraneous: duplexify@3.7.1 /opt/iobroker/node_modules/duplexify
            npm error extraneous: eastasianwidth@0.2.0 /opt/iobroker/node_modules/eastasianwidth
            npm error extraneous: ecc-jsbn@0.1.2 /opt/iobroker/node_modules/ecc-jsbn
            npm error extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
            npm error extraneous: echarts@ /opt/iobroker/node_modules/echarts
            npm error extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/ee-first
            npm error extraneous: elegant-spinner@1.0.1 /opt/iobroker/node_modules/elegant-spinner
            npm error extraneous: emoji-regex@9.2.2 /opt/iobroker/node_modules/emoji-regex
            npm error extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
            npm error extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/encodeurl
            npm error extraneous: encoding@0.1.13 /opt/iobroker/node_modules/encoding
            npm error extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/end-of-stream
            npm error extraneous: entities@4.5.0 /opt/iobroker/node_modules/entities
            npm error extraneous: err-code@2.0.3 /opt/iobroker/node_modules/err-code
            npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
            npm error extraneous: es-aggregate-error@1.0.13 /opt/iobroker/node_modules/es-aggregate-error
            npm error extraneous: es-object-atoms@1.0.0 /opt/iobroker/node_modules/es-object-atoms
            npm error extraneous: es-set-tostringtag@2.0.3 /opt/iobroker/node_modules/es-set-tostringtag
            npm error extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
            npm error extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
            npm error extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
            npm error extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
            npm error extraneous: escalade@3.1.2 /opt/iobroker/node_modules/escalade
            npm error extraneous: escape-goat@3.0.0 /opt/iobroker/node_modules/escape-goat
            npm error extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/escape-html
            npm error extraneous: escape-string-regexp@4.0.0 /opt/iobroker/node_modules/escape-string-regexp
            npm error extraneous: escodegen@1.14.3 /opt/iobroker/node_modules/escodegen
            npm error extraneous: esprima@1.2.2 /opt/iobroker/node_modules/esprima
            npm error extraneous: estraverse@4.3.0 /opt/iobroker/node_modules/estraverse
            npm error extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils
            npm error extraneous: etag@1.8.1 /opt/iobroker/node_modules/etag
            npm error extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
            npm error extraneous: event-target-shim@5.0.1 /opt/iobroker/node_modules/event-target-shim
            npm error extraneous: eventemitter2@6.4.9 /opt/iobroker/node_modules/eventemitter2
            npm error extraneous: events@3.3.0 /opt/iobroker/node_modules/events
            npm error extraneous: execa@5.1.1 /opt/iobroker/node_modules/execa
            npm error extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
            npm error extraneous: express-fileupload@1.5.1 /opt/iobroker/node_modules/express-fileupload
            npm error extraneous: express@4.19.2 /opt/iobroker/node_modules/express
            npm error extraneous: external-editor@3.1.0 /opt/iobroker/node_modules/external-editor
            npm error extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
            npm error extraneous: fast-fifo@1.3.2 /opt/iobroker/node_modules/fast-fifo
            npm error extraneous: fast-glob@ /opt/iobroker/node_modules/fast-glob
            npm error extraneous: fast-json-stable-stringify@2.1.0 /opt/iobroker/node_modules/fast-json-stable-stringify
            npm error extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein
            npm error extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
            npm error extraneous: fast-unique-numbers@ /opt/iobroker/node_modules/fast-unique-numbers
            npm error extraneous: fast-uri@3.0.1 /opt/iobroker/node_modules/fast-uri
            npm error extraneous: fast-xml-parser@ /opt/iobroker/node_modules/fast-xml-parser
            npm error extraneous: fastq@1.17.1 /opt/iobroker/node_modules/fastq
            npm error extraneous: fastseries@2.0.0 /opt/iobroker/node_modules/fastseries
            npm error extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
            npm error extraneous: figures@3.2.0 /opt/iobroker/node_modules/figures
            npm error extraneous: file-stream-rotator@0.6.1 /opt/iobroker/node_modules/file-stream-rotator
            npm error extraneous: file-type@10.11.0 /opt/iobroker/node_modules/file-type
            npm error extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
            npm error extraneous: fill-range@7.1.1 /opt/iobroker/node_modules/fill-range
            npm error extraneous: finalhandler@1.2.0 /opt/iobroker/node_modules/finalhandler
            npm error extraneous: find-up@5.0.0 /opt/iobroker/node_modules/find-up
            npm error extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
            npm error extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
            npm error extraneous: foreground-child@3.3.0 /opt/iobroker/node_modules/foreground-child
            npm error extraneous: form-data-encoder@2.1.4 /opt/iobroker/node_modules/form-data-encoder
            npm error extraneous: form-data@4.0.0 /opt/iobroker/node_modules/form-data
            npm error extraneous: forwarded@0.2.0 /opt/iobroker/node_modules/forwarded
            npm error extraneous: fresh@0.5.2 /opt/iobroker/node_modules/fresh
            npm error extraneous: from@0.1.7 /opt/iobroker/node_modules/from
            npm error extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
            npm error extraneous: fs-minipass@2.1.0 /opt/iobroker/node_modules/fs-minipass
            npm error extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
            npm error extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
            npm error extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
            npm error extraneous: function.prototype.name@1.1.6 /opt/iobroker/node_modules/function.prototype.name
            npm error extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
            npm error extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
            npm error extraneous: gauge@3.0.2 /opt/iobroker/node_modules/gauge
            npm error extraneous: gaxios@5.1.3 /opt/iobroker/node_modules/gaxios
            npm error extraneous: gcp-metadata@5.3.0 /opt/iobroker/node_modules/gcp-metadata
            npm error extraneous: generate-function@2.3.1 /opt/iobroker/node_modules/generate-function
            npm error extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ssl-certificate
            npm error extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/get-stream
            npm error extraneous: get-symbol-description@1.0.2 /opt/iobroker/node_modules/get-symbol-description
            npm error extraneous: getpass@0.1.7 /opt/iobroker/node_modules/getpass
            npm error extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
            npm error extraneous: github-url-from-git@1.5.0 /opt/iobroker/node_modules/github-url-from-git
            npm error extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/glob-parent
            npm error extraneous: glob@10.4.5 /opt/iobroker/node_modules/glob
            npm error extraneous: global-dirs@2.1.0 /opt/iobroker/node_modules/global-dirs
            npm error extraneous: globalthis@1.0.4 /opt/iobroker/node_modules/globalthis
            npm error extraneous: globby@11.1.0 /opt/iobroker/node_modules/globby
            npm error extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
            npm error extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
            npm error extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
            npm error extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
            npm error extraneous: googleapis@ /opt/iobroker/node_modules/googleapis
            npm error extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
            npm error extraneous: hard-rejection@2.1.0 /opt/iobroker/node_modules/hard-rejection
            npm error extraneous: has-ansi@2.0.0 /opt/iobroker/node_modules/has-ansi
            npm error extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
            npm error extraneous: has-flag@4.0.0 /opt/iobroker/node_modules/has-flag
            npm error extraneous: has-tostringtag@1.0.2 /opt/iobroker/node_modules/has-tostringtag
            npm error extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
            npm error extraneous: has-yarn@2.1.0 /opt/iobroker/node_modules/has-yarn
            npm error extraneous: he@1.2.0 /opt/iobroker/node_modules/he
            npm error extraneous: help-me@5.0.0 /opt/iobroker/node_modules/help-me
            npm error extraneous: homebridge-plugin-wrapper@ /opt/iobroker/node_modules/homebridge-plugin-wrapper
            npm error extraneous: hosted-git-info@3.0.8 /opt/iobroker/node_modules/hosted-git-info
            npm error extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
            npm error extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
            npm error extraneous: http-cache-semantics@4.1.1 /opt/iobroker/node_modules/http-cache-semantics
            npm error extraneous: http-errors@2.0.0 /opt/iobroker/node_modules/http-errors
            npm error extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
            npm error extraneous: http2-wrapper@1.0.3 /opt/iobroker/node_modules/http2-wrapper
            npm error extraneous: https@1.0.0 /opt/iobroker/node_modules/https
            npm error extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
            npm error extraneous: ical.js@ /opt/iobroker/node_modules/ical.js
            npm error extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/iconv-lite
            npm error extraneous: ieee754@1.2.1 /opt/iobroker/node_modules/ieee754
            npm error extraneous: ignore-walk@3.0.4 /opt/iobroker/node_modules/ignore-walk
            npm error extraneous: ignore@5.3.2 /opt/iobroker/node_modules/ignore
            npm error extraneous: image-type@4.1.0 /opt/iobroker/node_modules/image-type
            npm error extraneous: immediate@3.0.6 /opt/iobroker/node_modules/immediate
            npm error extraneous: import-fresh@3.3.0 /opt/iobroker/node_modules/import-fresh
            npm error extraneous: import-lazy@2.1.0 /opt/iobroker/node_modules/import-lazy
            npm error extraneous: import-local@3.2.0 /opt/iobroker/node_modules/import-local
            npm error extraneous: imurmurhash@0.1.4 /opt/iobroker/node_modules/imurmurhash
            npm error extraneous: indent-string@3.2.0 /opt/iobroker/node_modules/indent-string
            npm error extraneous: infer-owner@1.0.4 /opt/iobroker/node_modules/infer-owner
            npm error extraneous: inflight@1.0.6 /opt/iobroker/node_modules/inflight
            npm error extraneous: ini@1.3.7 /opt/iobroker/node_modules/ini
            npm error extraneous: inquirer-autosubmit-prompt@0.2.0 /opt/iobroker/node_modules/inquirer-autosubmit-prompt
            npm error extraneous: inquirer@7.3.3 /opt/iobroker/node_modules/inquirer
            npm error extraneous: int64-buffer@1.0.1 /opt/iobroker/node_modules/int64-buffer
            npm error extraneous: internal-slot@1.0.7 /opt/iobroker/node_modules/internal-slot
            npm error extraneous: iobroker-adapter-helpers@0.0.8 /opt/iobroker/node_modules/iobroker-adapter-helpers
            npm error invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
            npm error invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
            npm error invalid: iobroker.calendar@ /opt/iobroker/node_modules/iobroker.calendar
            npm error invalid: iobroker.discovery@ /opt/iobroker/node_modules/iobroker.discovery
            npm error invalid: iobroker.echarts@ /opt/iobroker/node_modules/iobroker.echarts
            npm error invalid: iobroker.energiefluss@ /opt/iobroker/node_modules/iobroker.energiefluss
            npm error invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
            npm error invalid: iobroker.fullcalendar@ /opt/iobroker/node_modules/iobroker.fullcalendar
            npm error invalid: iobroker.gartenbewaesserung@ /opt/iobroker/node_modules/iobroker.gartenbewaesserung
            npm error invalid: iobroker.ham@ /opt/iobroker/node_modules/iobroker.ham
            npm error invalid: iobroker.heatingcontrol@ /opt/iobroker/node_modules/iobroker.heatingcontrol
            npm error invalid: iobroker.ical@ /opt/iobroker/node_modules/iobroker.ical
            npm error invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
            npm error invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
            npm error invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
            npm error invalid: iobroker.material@ /opt/iobroker/node_modules/iobroker.material
            npm error invalid: iobroker.milight-smart-light@ /opt/iobroker/node_modules/iobroker.milight-smart-light
            npm error invalid: iobroker.mobile@ /opt/iobroker/node_modules/iobroker.mobile
            npm error invalid: iobroker.modbus@ /opt/iobroker/node_modules/iobroker.modbus
            npm error invalid: iobroker.mqtt@ /opt/iobroker/node_modules/iobroker.mqtt
            npm error invalid: iobroker.nina@ /opt/iobroker/node_modules/iobroker.nina
            npm error invalid: iobroker.renault@ /opt/iobroker/node_modules/iobroker.renault
            npm error invalid: iobroker.reolink@ /opt/iobroker/node_modules/iobroker.reolink
            npm error invalid: iobroker.schoolfree@ /opt/iobroker/node_modules/iobroker.schoolfree
            npm error invalid: iobroker.sourceanalytix@ /opt/iobroker/node_modules/iobroker.sourceanalytix
            npm error invalid: iobroker.synology@ /opt/iobroker/node_modules/iobroker.synology
            npm error invalid: iobroker.tankerkoenig@ /opt/iobroker/node_modules/iobroker.tankerkoenig
            npm error invalid: iobroker.terminal@ /opt/iobroker/node_modules/iobroker.terminal
            npm error invalid: iobroker.unifi@ /opt/iobroker/node_modules/iobroker.unifi
            npm error invalid: iobroker.viessmannapi@ /opt/iobroker/node_modules/iobroker.viessmannapi
            npm error invalid: iobroker.virtualpowermeter@ /opt/iobroker/node_modules/iobroker.virtualpowermeter
            npm error invalid: iobroker.vis-2-widgets-material@ /opt/iobroker/node_modules/iobroker.vis-2-widgets-material
            npm error invalid: iobroker.vis-2@ /opt/iobroker/node_modules/iobroker.vis-2
            npm error invalid: iobroker.vis-colorpicker@ /opt/iobroker/node_modules/iobroker.vis-colorpicker
            npm error invalid: iobroker.vis-hqwidgets@ /opt/iobroker/node_modules/iobroker.vis-hqwidgets
            npm error invalid: iobroker.vis-inventwo@ /opt/iobroker/node_modules/iobroker.vis-inventwo
            npm error invalid: iobroker.vis-materialdesign@ /opt/iobroker/node_modules/iobroker.vis-materialdesign
            npm error invalid: iobroker.vis-metro@ /opt/iobroker/node_modules/iobroker.vis-metro
            npm error invalid: iobroker.vis-timeandweather@ /opt/iobroker/node_modules/iobroker.vis-timeandweather
            npm error invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
            npm error invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
            npm error invalid: iobroker.vofo-speedtest@ /opt/iobroker/node_modules/iobroker.vofo-speedtest
            npm error invalid: iobroker.web-speedy@ /opt/iobroker/node_modules/iobroker.web-speedy
            npm error invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
            npm error invalid: iobroker.webcal@ /opt/iobroker/node_modules/iobroker.webcal
            npm error extraneous: ioredis@ /opt/iobroker/node_modules/ioredis
            npm error extraneous: ip-address@9.0.5 /opt/iobroker/node_modules/ip-address
            npm error extraneous: ip-regex@4.3.0 /opt/iobroker/node_modules/ip-regex
            npm error extraneous: ipaddr.js@2.2.0 /opt/iobroker/node_modules/ipaddr.js
            npm error extraneous: is-array-buffer@3.0.4 /opt/iobroker/node_modules/is-array-buffer
            npm error extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
            npm error extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
            npm error extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
            npm error extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
            npm error extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
            npm error extraneous: is-ci@2.0.0 /opt/iobroker/node_modules/is-ci
            npm error extraneous: is-core-module@2.15.0 /opt/iobroker/node_modules/is-core-module
            npm error extraneous: is-data-view@1.0.1 /opt/iobroker/node_modules/is-data-view
            npm error extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
            npm error extraneous: is-docker@2.2.1 /opt/iobroker/node_modules/is-docker
            npm error extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
            npm error extraneous: is-extglob@2.1.1 /opt/iobroker/node_modules/is-extglob
            npm error extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/is-fullwidth-code-point
            npm error extraneous: is-glob@4.0.3 /opt/iobroker/node_modules/is-glob
            npm error extraneous: is-installed-globally@0.3.2 /opt/iobroker/node_modules/is-installed-globally
            npm error extraneous: is-interactive@1.0.0 /opt/iobroker/node_modules/is-interactive
            npm error extraneous: is-lambda@1.0.1 /opt/iobroker/node_modules/is-lambda
            npm error extraneous: is-negative-zero@2.0.3 /opt/iobroker/node_modules/is-negative-zero
            npm error extraneous: is-npm@5.0.0 /opt/iobroker/node_modules/is-npm
            npm error extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
            npm error extraneous: is-number@7.0.0 /opt/iobroker/node_modules/is-number
            npm error extraneous: is-obj@2.0.0 /opt/iobroker/node_modules/is-obj
            npm error extraneous: is-observable@1.1.0 /opt/iobroker/node_modules/is-observable
            npm error extraneous: is-path-cwd@2.2.0 /opt/iobroker/node_modules/is-path-cwd
            npm error extraneous: is-path-inside@3.0.3 /opt/iobroker/node_modules/is-path-inside
            npm error extraneous: is-plain-obj@1.1.0 /opt/iobroker/node_modules/is-plain-obj
            npm error extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
            npm error extraneous: is-promise@2.2.2 /opt/iobroker/node_modules/is-promise
            npm error extraneous: is-property@1.0.2 /opt/iobroker/node_modules/is-property
            npm error extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
            npm error extraneous: is-scoped@2.1.0 /opt/iobroker/node_modules/is-scoped
            npm error extraneous: is-shared-array-buffer@1.0.3 /opt/iobroker/node_modules/is-shared-array-buffer
            npm error extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
            npm error extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
            npm error extraneous: is-typed-array@1.1.13 /opt/iobroker/node_modules/is-typed-array
            npm error extraneous: is-unicode-supported@0.1.0 /opt/iobroker/node_modules/is-unicode-supported
            npm error extraneous: is-url-superb@4.0.0 /opt/iobroker/node_modules/is-url-superb
            npm error extraneous: is-url@1.2.4 /opt/iobroker/node_modules/is-url
            npm error extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
            npm error extraneous: is-wsl@2.2.0 /opt/iobroker/node_modules/is-wsl
            npm error extraneous: is-yarn-global@0.3.0 /opt/iobroker/node_modules/is-yarn-global
            npm error extraneous: is@3.3.0 /opt/iobroker/node_modules/is
            npm error extraneous: is2@2.0.9 /opt/iobroker/node_modules/is2
            npm error extraneous: isomorphic-ws@4.0.1 /opt/iobroker/node_modules/isomorphic-ws
            npm error extraneous: issue-regex@3.1.0 /opt/iobroker/node_modules/issue-regex
            npm error extraneous: jackspeak@3.4.3 /opt/iobroker/node_modules/jackspeak
            npm error extraneous: js-md4@0.3.2 /opt/iobroker/node_modules/js-md4
            npm error extraneous: js-sdsl@4.3.0 /opt/iobroker/node_modules/js-sdsl
            npm error extraneous: js-tokens@4.0.0 /opt/iobroker/node_modules/js-tokens
            npm error extraneous: js-yaml@ /opt/iobroker/node_modules/js-yaml
            npm error extraneous: jsbi@4.3.0 /opt/iobroker/node_modules/jsbi
            npm error extraneous: jsbn@1.1.0 /opt/iobroker/node_modules/jsbn
            npm error extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
            npm error extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
            npm error extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/json-buffer
            npm error extraneous: json-logic-js@2.0.5 /opt/iobroker/node_modules/json-logic-js
            npm error extraneous: json-parse-even-better-errors@2.3.1 /opt/iobroker/node_modules/json-parse-even-better-errors
            npm error extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse
            npm error extraneous: json5@2.2.3 /opt/iobroker/node_modules/json5
            npm error extraneous: jsonata@ /opt/iobroker/node_modules/jsonata
            npm error extraneous: jsonc-parser@3.3.1 /opt/iobroker/node_modules/jsonc-parser
            npm error extraneous: jsonwebtoken@9.0.2 /opt/iobroker/node_modules/jsonwebtoken
            npm error extraneous: jszip@ /opt/iobroker/node_modules/jszip
            npm error extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
            npm error extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
            npm error extraneous: keyv@4.5.4 /opt/iobroker/node_modules/keyv
            npm error extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/kind-of
            npm error extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
            npm error extraneous: later@1.2.0 /opt/iobroker/node_modules/later
            npm error extraneous: latest-version@5.1.0 /opt/iobroker/node_modules/latest-version
            npm error extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
            npm error extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/lazystream
            npm error extraneous: leven@2.1.0 /opt/iobroker/node_modules/leven
            npm error extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn
            npm error extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
            npm error extraneous: lines-and-columns@1.2.4 /opt/iobroker/node_modules/lines-and-columns
            npm error extraneous: listr-input@0.2.1 /opt/iobroker/node_modules/listr-input
            npm error extraneous: listr-silent-renderer@1.1.1 /opt/iobroker/node_modules/listr-silent-renderer
            npm error extraneous: listr-update-renderer@0.5.0 /opt/iobroker/node_modules/listr-update-renderer
            npm error extraneous: listr-verbose-renderer@0.5.0 /opt/iobroker/node_modules/listr-verbose-renderer
            npm error extraneous: listr@0.14.3 /opt/iobroker/node_modules/listr
            npm error extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
            npm error extraneous: locate-path@6.0.0 /opt/iobroker/node_modules/locate-path
            npm error extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
            npm error extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
            npm error extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
            npm error extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
            npm error extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
            npm error extraneous: lodash.isequal@4.5.0 /opt/iobroker/node_modules/lodash.isequal
            npm error extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
            npm error extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
            npm error extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
            npm error extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
            npm error extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
            npm error extraneous: lodash.zip@4.2.0 /opt/iobroker/node_modules/lodash.zip
            npm error extraneous: log-symbols@4.1.0 /opt/iobroker/node_modules/log-symbols
            npm error extraneous: log-update@2.3.0 /opt/iobroker/node_modules/log-update
            npm error extraneous: logform@ /opt/iobroker/node_modules/logform
            npm error extraneous: long@5.2.3 /opt/iobroker/node_modules/long
            npm error extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/lowercase-keys
            npm error extraneous: lru_map@0.3.3 /opt/iobroker/node_modules/lru_map
            npm error extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/lru-cache
            npm error extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
            npm error extraneous: make-fetch-happen@10.2.1 /opt/iobroker/node_modules/make-fetch-happen
            npm error extraneous: map-age-cleaner@0.1.3 /opt/iobroker/node_modules/map-age-cleaner
            npm error extraneous: map-obj@4.3.0 /opt/iobroker/node_modules/map-obj
            npm error extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
            npm error extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
            npm error extraneous: media-typer@0.3.0 /opt/iobroker/node_modules/media-typer
            npm error extraneous: meow@8.1.2 /opt/iobroker/node_modules/meow
            npm error extraneous: merge-descriptors@1.0.1 /opt/iobroker/node_modules/merge-descriptors
            npm error extraneous: merge2@1.4.1 /opt/iobroker/node_modules/merge2
            npm error extraneous: methods@1.1.2 /opt/iobroker/node_modules/methods
            npm error extraneous: micro@9.4.1 /opt/iobroker/node_modules/micro
            npm error extraneous: micromatch@4.0.7 /opt/iobroker/node_modules/micromatch
            npm error extraneous: mime-db@1.53.0 /opt/iobroker/node_modules/mime-db
            npm error extraneous: mimic-response@1.0.1 /opt/iobroker/node_modules/mimic-response
            npm error extraneous: min-indent@1.0.1 /opt/iobroker/node_modules/min-indent
            npm error extraneous: minimatch@9.0.5 /opt/iobroker/node_modules/minimatch
            npm error extraneous: minimist-options@4.1.0 /opt/iobroker/node_modules/minimist-options
            npm error extraneous: minipass-collect@1.0.2 /opt/iobroker/node_modules/minipass-collect
            npm error extraneous: minipass-fetch@2.1.2 /opt/iobroker/node_modules/minipass-fetch
            npm error extraneous: minipass-flush@1.0.5 /opt/iobroker/node_modules/minipass-flush
            npm error extraneous: minipass-pipeline@1.2.4 /opt/iobroker/node_modules/minipass-pipeline
            npm error extraneous: minipass-sized@1.0.3 /opt/iobroker/node_modules/minipass-sized
            npm error extraneous: minipass@7.1.2 /opt/iobroker/node_modules/minipass
            npm error extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/minizlib
            npm error extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
            npm error extraneous: mkdirp@1.0.4 /opt/iobroker/node_modules/mkdirp
            npm error extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
            npm error extraneous: moment-duration-format@2.3.2 /opt/iobroker/node_modules/moment-duration-format
            npm error extraneous: mqtt-connection@4.1.0 /opt/iobroker/node_modules/mqtt-connection
            npm error extraneous: mqtt-packet@9.0.0 /opt/iobroker/node_modules/mqtt-packet
            npm error extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
            npm error extraneous: mute-stream@0.0.8 /opt/iobroker/node_modules/mute-stream
            npm error extraneous: named-placeholders@1.1.3 /opt/iobroker/node_modules/named-placeholders
            npm error extraneous: nan@ /opt/iobroker/node_modules/nan
            npm error extraneous: nanoid@3.3.7 /opt/iobroker/node_modules/nanoid
            npm error extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
            npm error extraneous: native-duplexpair@1.0.0 /opt/iobroker/node_modules/native-duplexpair
            npm error extraneous: nconf@0.10.0 /opt/iobroker/node_modules/nconf
            npm error extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
            npm error extraneous: netmask@2.0.2 /opt/iobroker/node_modules/netmask
            npm error extraneous: new-github-release-url@1.0.0 /opt/iobroker/node_modules/new-github-release-url
            npm error extraneous: node-abi@3.65.0 /opt/iobroker/node_modules/node-abi
            npm error extraneous: node-abort-controller@3.1.1 /opt/iobroker/node_modules/node-abort-controller
            npm error extraneous: node-cron@2.0.3 /opt/iobroker/node_modules/node-cron
            npm error extraneous: node-fetch@2.7.0 /opt/iobroker/node_modules/node-fetch
            npm error extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
            npm error extraneous: node-gyp@ /opt/iobroker/node_modules/node-gyp
            npm error extraneous: node-ical@0.16.1 /opt/iobroker/node_modules/node-ical
            npm error extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
            npm error extraneous: node-libcurl@3.0.0 /opt/iobroker/node_modules/node-libcurl
            npm error extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
            npm error extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
            npm error extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
            npm error extraneous: node-unifi@2.5.1 /opt/iobroker/node_modules/node-unifi
            npm error extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
            npm error extraneous: node.extend@2.0.3 /opt/iobroker/node_modules/node.extend
            npm error extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
            npm error extraneous: normalize-package-data@3.0.3 /opt/iobroker/node_modules/normalize-package-data
            npm error extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
            npm error extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/normalize-url
            npm error extraneous: np@7.7.0 /opt/iobroker/node_modules/np
            npm error extraneous: npm-name@6.0.1 /opt/iobroker/node_modules/npm-name
            npm error extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
            npm error extraneous: number-allocator@1.0.14 /opt/iobroker/node_modules/number-allocator
            npm error extraneous: nwsapi@2.2.12 /opt/iobroker/node_modules/nwsapi
            npm error extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assign
            npm error extraneous: object-hash@3.0.0 /opt/iobroker/node_modules/object-hash
            npm error extraneous: on-finished@2.4.1 /opt/iobroker/node_modules/on-finished
            npm error extraneous: once@1.4.0 /opt/iobroker/node_modules/once
            npm error extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
            npm error extraneous: onedrive-api@1.1.1 /opt/iobroker/node_modules/onedrive-api
            npm error extraneous: open@7.4.2 /opt/iobroker/node_modules/open
            npm error extraneous: opencollective-postinstall@2.0.3 /opt/iobroker/node_modules/opencollective-postinstall
            npm error extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator
            npm error extraneous: org-regex@1.0.0 /opt/iobroker/node_modules/org-regex
            npm error extraneous: os-tmpdir@1.0.2 /opt/iobroker/node_modules/os-tmpdir
            npm error extraneous: ospath@1.2.2 /opt/iobroker/node_modules/ospath
            npm error extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
            npm error extraneous: otplib@11.0.1 /opt/iobroker/node_modules/otplib
            npm error extraneous: ow@0.21.0 /opt/iobroker/node_modules/ow
            npm error extraneous: p-cancelable@2.1.1 /opt/iobroker/node_modules/p-cancelable
            npm error extraneous: p-defer@1.0.0 /opt/iobroker/node_modules/p-defer
            npm error extraneous: p-event@4.2.0 /opt/iobroker/node_modules/p-event
            npm error extraneous: p-finally@1.0.0 /opt/iobroker/node_modules/p-finally
            npm error extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/p-limit
            npm error extraneous: p-locate@5.0.0 /opt/iobroker/node_modules/p-locate
            npm error extraneous: p-map@2.1.0 /opt/iobroker/node_modules/p-map
            npm error extraneous: p-memoize@4.0.4 /opt/iobroker/node_modules/p-memoize
            npm error extraneous: p-reflect@2.1.0 /opt/iobroker/node_modules/p-reflect
            npm error extraneous: p-settle@4.1.1 /opt/iobroker/node_modules/p-settle
            npm error extraneous: p-throttle@4.1.1 /opt/iobroker/node_modules/p-throttle
            npm error extraneous: p-timeout@4.1.0 /opt/iobroker/node_modules/p-timeout
            npm error extraneous: p-try@2.2.0 /opt/iobroker/node_modules/p-try
            npm error extraneous: package-json-from-dist@1.0.0 /opt/iobroker/node_modules/package-json-from-dist
            npm error extraneous: package-json@6.5.0 /opt/iobroker/node_modules/package-json
            npm error extraneous: pako@ /opt/iobroker/node_modules/pako
            npm error extraneous: parent-module@1.0.1 /opt/iobroker/node_modules/parent-module
            npm error extraneous: parse-json@5.2.0 /opt/iobroker/node_modules/parse-json
            npm error extraneous: parse5@ /opt/iobroker/node_modules/parse5
            npm error extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
            npm error extraneous: passport@0.7.0 /opt/iobroker/node_modules/passport
            npm error extraneous: path-exists@4.0.0 /opt/iobroker/node_modules/path-exists
            npm error extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
            npm error extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
            npm error extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
            npm error extraneous: path-scurry@1.11.1 /opt/iobroker/node_modules/path-scurry
            npm error extraneous: path-to-regexp@0.1.7 /opt/iobroker/node_modules/path-to-regexp
            npm error extraneous: path-type@4.0.0 /opt/iobroker/node_modules/path-type
            npm error extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
            npm error extraneous: picomatch@2.3.1 /opt/iobroker/node_modules/picomatch
            npm error extraneous: pidtree@0.6.0 /opt/iobroker/node_modules/pidtree
            npm error extraneous: pidusage@3.0.2 /opt/iobroker/node_modules/pidusage
            npm error extraneous: ping@0.4.4 /opt/iobroker/node_modules/ping
            npm error extraneous: pkg-dir@5.0.0 /opt/iobroker/node_modules/pkg-dir
            npm error extraneous: pluralize@8.0.0 /opt/iobroker/node_modules/pluralize
            npm error extraneous: possible-typed-array-names@1.0.0 /opt/iobroker/node_modules/possible-typed-array-names
            npm error extraneous: prebuild-install@7.1.2 /opt/iobroker/node_modules/prebuild-install
            npm error extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls
            npm error extraneous: prepend-http@2.0.0 /opt/iobroker/node_modules/prepend-http
            npm error extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/process-nextick-args
            npm error extraneous: process@0.11.10 /opt/iobroker/node_modules/process
            npm error extraneous: promise-inflight@1.0.1 /opt/iobroker/node_modules/promise-inflight
            npm error extraneous: promise-object@0.1.7 /opt/iobroker/node_modules/promise-object
            npm error extraneous: promise-retry@2.0.1 /opt/iobroker/node_modules/promise-retry
            npm error extraneous: promise-retryer@0.0.1 /opt/iobroker/node_modules/promise-retryer
            npm error extraneous: promisify-child-process@4.1.2 /opt/iobroker/node_modules/promisify-child-process
            npm error extraneous: prompt@1.3.0 /opt/iobroker/node_modules/prompt
            npm error extraneous: protobufjs@ /opt/iobroker/node_modules/protobufjs
            npm error extraneous: proxy-addr@2.0.7 /opt/iobroker/node_modules/proxy-addr
            npm error extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
            npm error extraneous: pump@3.0.0 /opt/iobroker/node_modules/pump
            npm error extraneous: pupa@2.1.1 /opt/iobroker/node_modules/pupa
            npm error extraneous: q@1.1.2 /opt/iobroker/node_modules/q
            npm error extraneous: quasar@ /opt/iobroker/node_modules/quasar
            npm error extraneous: queue-microtask@1.2.3 /opt/iobroker/node_modules/queue-microtask
            npm error extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
            npm error extraneous: quick-lru@5.1.1 /opt/iobroker/node_modules/quick-lru
            npm error extraneous: range-parser@1.2.1 /opt/iobroker/node_modules/range-parser
            npm error extraneous: raw-body@2.5.2 /opt/iobroker/node_modules/raw-body
            npm error extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
            npm error extraneous: read-pkg-up@7.0.1 /opt/iobroker/node_modules/read-pkg-up
            npm error extraneous: read-pkg@5.2.0 /opt/iobroker/node_modules/read-pkg
            npm error extraneous: read@1.0.7 /opt/iobroker/node_modules/read
            npm error extraneous: readable-stream@ /opt/iobroker/node_modules/readable-stream
            npm error extraneous: readdir-glob@1.1.3 /opt/iobroker/node_modules/readdir-glob
            npm error extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
            npm error extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
            npm error extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
            npm error extraneous: redent@3.0.0 /opt/iobroker/node_modules/redent
            npm error extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
            npm error extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
            npm error extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
            npm error extraneous: regenerator-runtime@0.14.1 /opt/iobroker/node_modules/regenerator-runtime
            npm error extraneous: regex-escape@3.4.10 /opt/iobroker/node_modules/regex-escape
            npm error extraneous: regexp.prototype.flags@1.5.2 /opt/iobroker/node_modules/regexp.prototype.flags
            npm error extraneous: registry-auth-token@4.2.2 /opt/iobroker/node_modules/registry-auth-token
            npm error extraneous: registry-url@5.1.0 /opt/iobroker/node_modules/registry-url
            npm error extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
            npm error extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
            npm error extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string
            npm error extraneous: resolve-alpn@1.2.1 /opt/iobroker/node_modules/resolve-alpn
            npm error extraneous: resolve-cwd@3.0.0 /opt/iobroker/node_modules/resolve-cwd
            npm error extraneous: resolve-from@4.0.0 /opt/iobroker/node_modules/resolve-from
            npm error extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
            npm error extraneous: responselike@2.0.1 /opt/iobroker/node_modules/responselike
            npm error extraneous: restore-cursor@3.1.0 /opt/iobroker/node_modules/restore-cursor
            npm error extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
            npm error extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
            npm error extraneous: reusify@1.0.4 /opt/iobroker/node_modules/reusify
            npm error extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
            npm error extraneous: rfdc@1.4.1 /opt/iobroker/node_modules/rfdc
            npm error extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/rimraf
            npm error extraneous: rrule@2.8.1 /opt/iobroker/node_modules/rrule
            npm error extraneous: rrweb-cssom@0.6.0 /opt/iobroker/node_modules/rrweb-cssom
            npm error extraneous: run-async@2.4.1 /opt/iobroker/node_modules/run-async
            npm error extraneous: run-parallel@1.2.0 /opt/iobroker/node_modules/run-parallel
            npm error extraneous: rxjs@ /opt/iobroker/node_modules/rxjs
            npm error extraneous: safe-array-concat@1.1.2 /opt/iobroker/node_modules/safe-array-concat
            npm error extraneous: safe-regex-test@1.0.3 /opt/iobroker/node_modules/safe-regex-test
            npm error extraneous: safe-stable-stringify@2.4.3 /opt/iobroker/node_modules/safe-stable-stringify
            npm error extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/safer-buffer
            npm error extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
            npm error extraneous: scoped-regex@2.1.0 /opt/iobroker/node_modules/scoped-regex
            npm error extraneous: secure-keys@1.0.0 /opt/iobroker/node_modules/secure-keys
            npm error extraneous: semver-diff@3.1.1 /opt/iobroker/node_modules/semver-diff
            npm error extraneous: send@0.18.0 /opt/iobroker/node_modules/send
            npm error extraneous: seq-logging@1.1.2 /opt/iobroker/node_modules/seq-logging
            npm error extraneous: seq-queue@0.0.5 /opt/iobroker/node_modules/seq-queue
            npm error extraneous: serve-static@1.15.0 /opt/iobroker/node_modules/serve-static
            npm error extraneous: set-function-name@2.0.2 /opt/iobroker/node_modules/set-function-name
            npm error extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
            npm error extraneous: setprototypeof@1.2.0 /opt/iobroker/node_modules/setprototypeof
            npm error extraneous: signal-exit@4.1.0 /opt/iobroker/node_modules/signal-exit
            npm error extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
            npm error extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
            npm error extraneous: simple-ssh@1.1.1 /opt/iobroker/node_modules/simple-ssh
            npm error extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
            npm error extraneous: slash@3.0.0 /opt/iobroker/node_modules/slash
            npm error extraneous: slice-ansi@0.0.4 /opt/iobroker/node_modules/slice-ansi
            npm error extraneous: smart-buffer@4.2.0 /opt/iobroker/node_modules/smart-buffer
            npm error extraneous: socks-proxy-agent@7.0.0 /opt/iobroker/node_modules/socks-proxy-agent
            npm error extraneous: socks@2.8.3 /opt/iobroker/node_modules/socks
            npm error extraneous: speedtest-net@1.6.2 /opt/iobroker/node_modules/speedtest-net
            npm error extraneous: split@1.0.1 /opt/iobroker/node_modules/split
            npm error extraneous: sprintf-js@1.1.3 /opt/iobroker/node_modules/sprintf-js
            npm error extraneous: sqlstring@2.3.3 /opt/iobroker/node_modules/sqlstring
            npm error extraneous: ssh2@ /opt/iobroker/node_modules/ssh2
            npm error extraneous: ssri@9.0.1 /opt/iobroker/node_modules/ssri
            npm error extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
            npm error extraneous: stampit-event-bus@0.1.1 /opt/iobroker/node_modules/stampit-event-bus
            npm error extraneous: stampit-state-machine@0.2.1 /opt/iobroker/node_modules/stampit-state-machine
            npm error extraneous: stampit@2.1.2 /opt/iobroker/node_modules/stampit
            npm error extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
            npm error extraneous: static-eval@2.0.2 /opt/iobroker/node_modules/static-eval
            npm error extraneous: statuses@2.0.1 /opt/iobroker/node_modules/statuses
            npm error extraneous: stoppable@1.1.0 /opt/iobroker/node_modules/stoppable
            npm error extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
            npm error extraneous: stream-shift@1.0.3 /opt/iobroker/node_modules/stream-shift
            npm error extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
            npm error extraneous: streamx@2.18.0 /opt/iobroker/node_modules/streamx
            npm error extraneous: string-argv@0.3.2 /opt/iobroker/node_modules/string-argv
            npm error extraneous: string-width-cjs@npm:string-width@4.2.3 /opt/iobroker/node_modules/string-width-cjs
            npm error extraneous: string-width@5.1.2 /opt/iobroker/node_modules/string-width
            npm error extraneous: string.prototype.trim@1.2.9 /opt/iobroker/node_modules/string.prototype.trim
            npm error extraneous: string.prototype.trimend@1.0.8 /opt/iobroker/node_modules/string.prototype.trimend
            npm error extraneous: string.prototype.trimstart@1.0.8 /opt/iobroker/node_modules/string.prototype.trimstart
            npm error extraneous: strip-ansi-cjs@npm:strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi-cjs
            npm error extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi
            npm error extraneous: strip-indent@3.0.0 /opt/iobroker/node_modules/strip-indent
            npm error extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
            npm error extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
            npm error extraneous: suncalc@1.9.0 /opt/iobroker/node_modules/suncalc
            npm error extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
            npm error extraneous: supermixer@1.0.5 /opt/iobroker/node_modules/supermixer
            npm error extraneous: supports-color@7.2.0 /opt/iobroker/node_modules/supports-color
            npm error extraneous: supports-hyperlinks@2.3.0 /opt/iobroker/node_modules/supports-hyperlinks
            npm error extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
            npm error extraneous: sweet-collections@1.1.0 /opt/iobroker/node_modules/sweet-collections
            npm error extraneous: symbol-observable@3.0.0 /opt/iobroker/node_modules/symbol-observable
            npm error extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
            npm error extraneous: syno@ /opt/iobroker/node_modules/syno
            npm error extraneous: systeminformation@ /opt/iobroker/node_modules/systeminformation
            npm error extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
            npm error extraneous: tar-stream@3.1.7 /opt/iobroker/node_modules/tar-stream
            npm error extraneous: tar@6.2.1 /opt/iobroker/node_modules/tar
            npm error extraneous: tarn@3.0.2 /opt/iobroker/node_modules/tarn
            npm error extraneous: tcp-port-used@1.0.2 /opt/iobroker/node_modules/tcp-port-used
            npm error extraneous: tedious@ /opt/iobroker/node_modules/tedious
            npm error extraneous: terminal-link@2.1.1 /opt/iobroker/node_modules/terminal-link
            npm error extraneous: text-decoder@1.1.1 /opt/iobroker/node_modules/text-decoder
            npm error extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
            npm error extraneous: thirty-two@1.0.2 /opt/iobroker/node_modules/thirty-two
            npm error extraneous: through@2.3.8 /opt/iobroker/node_modules/through
            npm error extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
            npm error extraneous: tiny-typed-emitter@2.1.0 /opt/iobroker/node_modules/tiny-typed-emitter
            npm error extraneous: tinycolor2@1.6.0 /opt/iobroker/node_modules/tinycolor2
            npm error extraneous: tmp@0.0.33 /opt/iobroker/node_modules/tmp
            npm error extraneous: to-readable-stream@2.1.0 /opt/iobroker/node_modules/to-readable-stream
            npm error extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/to-regex-range
            npm error extraneous: toidentifier@1.0.1 /opt/iobroker/node_modules/toidentifier
            npm error extraneous: tr46@4.1.1 /opt/iobroker/node_modules/tr46
            npm error extraneous: trim-newlines@3.0.1 /opt/iobroker/node_modules/trim-newlines
            npm error extraneous: triple-beam@1.4.1 /opt/iobroker/node_modules/triple-beam
            npm error extraneous: tsdav@ /opt/iobroker/node_modules/tsdav
            npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/tslib
            npm error extraneous: tweetnacl@0.14.5 /opt/iobroker/node_modules/tweetnacl
            npm error extraneous: type-check@0.3.2 /opt/iobroker/node_modules/type-check
            npm error extraneous: type-fest@0.21.3 /opt/iobroker/node_modules/type-fest
            npm error extraneous: type-is@1.6.18 /opt/iobroker/node_modules/type-is
            npm error extraneous: typed-array-buffer@1.0.2 /opt/iobroker/node_modules/typed-array-buffer
            npm error extraneous: typed-array-byte-length@1.0.1 /opt/iobroker/node_modules/typed-array-byte-length
            npm error extraneous: typed-array-byte-offset@1.0.2 /opt/iobroker/node_modules/typed-array-byte-offset
            npm error extraneous: typed-array-length@1.0.6 /opt/iobroker/node_modules/typed-array-length
            npm error extraneous: typedarray-to-buffer@3.1.5 /opt/iobroker/node_modules/typedarray-to-buffer
            npm error extraneous: typedarray.prototype.slice@1.0.3 /opt/iobroker/node_modules/typedarray.prototype.slice
            npm error extraneous: typescript@ /opt/iobroker/node_modules/typescript
            npm error extraneous: tz-offset@0.0.1 /opt/iobroker/node_modules/tz-offset
            npm error extraneous: uid-number@0.0.6 /opt/iobroker/node_modules/uid-number
            npm error extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
            npm error extraneous: undici-types@6.19.6 /opt/iobroker/node_modules/undici-types
            npm error extraneous: unique-filename@2.0.1 /opt/iobroker/node_modules/unique-filename
            npm error extraneous: unique-slug@3.0.0 /opt/iobroker/node_modules/unique-slug
            npm error extraneous: unique-string@2.0.0 /opt/iobroker/node_modules/unique-string
            npm error extraneous: unix-dgram@2.0.6 /opt/iobroker/node_modules/unix-dgram
            npm error extraneous: unpipe@1.0.0 /opt/iobroker/node_modules/unpipe
            npm error extraneous: update-notifier@5.1.0 /opt/iobroker/node_modules/update-notifier
            npm error extraneous: uri-js@4.4.1 /opt/iobroker/node_modules/uri-js
            npm error extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
            npm error extraneous: url-parse-lax@3.0.0 /opt/iobroker/node_modules/url-parse-lax
            npm error extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
            npm error extraneous: url@0.11.4 /opt/iobroker/node_modules/url
            npm error extraneous: vali-date@1.0.0 /opt/iobroker/node_modules/vali-date
            npm error extraneous: validate-npm-package-name@3.0.0 /opt/iobroker/node_modules/validate-npm-package-name
            npm error extraneous: vary@1.1.2 /opt/iobroker/node_modules/vary
            npm error extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
            npm error extraneous: vue-i18n@ /opt/iobroker/node_modules/vue-i18n
            npm error extraneous: vuelidate-messages@0.1.2 /opt/iobroker/node_modules/vuelidate-messages
            npm error extraneous: vuelidate@ /opt/iobroker/node_modules/vuelidate
            npm error extraneous: vuex-map-fields@1.4.1 /opt/iobroker/node_modules/vuex-map-fields
            npm error extraneous: w3c-xmlserializer@4.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
            npm error extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
            npm error extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
            npm error extraneous: webdav@ /opt/iobroker/node_modules/webdav
            npm error extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
            npm error extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
            npm error extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
            npm error extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
            npm error extraneous: whatwg-url@12.0.1 /opt/iobroker/node_modules/whatwg-url
            npm error extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
            npm error extraneous: which-typed-array@1.1.15 /opt/iobroker/node_modules/which-typed-array
            npm error extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
            npm error extraneous: widest-line@3.1.0 /opt/iobroker/node_modules/widest-line
            npm error extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
            npm error extraneous: winston-daily-rotate-file@5.0.0 /opt/iobroker/node_modules/winston-daily-rotate-file
            npm error extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
            npm error extraneous: winston-syslog@2.7.1 /opt/iobroker/node_modules/winston-syslog
            npm error extraneous: winston-transport@4.7.1 /opt/iobroker/node_modules/winston-transport
            npm error extraneous: winston@ /opt/iobroker/node_modules/winston
            npm error extraneous: word-wrap@1.2.5 /opt/iobroker/node_modules/word-wrap
            npm error extraneous: worker-timers-broker@6.1.8 /opt/iobroker/node_modules/worker-timers-broker
            npm error extraneous: worker-timers-worker@7.0.71 /opt/iobroker/node_modules/worker-timers-worker
            npm error extraneous: worker-timers@7.1.8 /opt/iobroker/node_modules/worker-timers
            npm error extraneous: wrap-ansi-cjs@npm:wrap-ansi@7.0.0 /opt/iobroker/node_modules/wrap-ansi-cjs
            npm error extraneous: wrap-ansi@8.1.0 /opt/iobroker/node_modules/wrap-ansi
            npm error extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/wrappy
            npm error extraneous: write-file-atomic@3.0.3 /opt/iobroker/node_modules/write-file-atomic
            npm error extraneous: xdg-basedir@4.0.0 /opt/iobroker/node_modules/xdg-basedir
            npm error extraneous: xml-js@1.6.11 /opt/iobroker/node_modules/xml-js
            npm error extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
            npm error extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
            npm error extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
            npm error extraneous: yallist@4.0.0 /opt/iobroker/node_modules/yallist
            npm error extraneous: yaml@ /opt/iobroker/node_modules/yaml
            npm error extraneous: yargs-parser@20.2.9 /opt/iobroker/node_modules/yargs-parser
            npm error extraneous: yocto-queue@0.1.0 /opt/iobroker/node_modules/yocto-queue
            npm error extraneous: zip-stream@6.0.1 /opt/iobroker/node_modules/zip-stream
            npm error extraneous: zrender@ /opt/iobroker/node_modules/zrender
            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-18T20_16_41_191Z-debug-0.log
              Thomas Braun Most Active @flommaster last edited by
              @flommaster
              iob repo list
                flommaster @Thomas Braun last edited by
                flo@ioBrokerdebian:/opt/iobroker$ iob repo list
                node:internal/modules/cjs/loader:1148
                  throw err;
                Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                    at Module._resolveFilename (node:internal/modules/cjs/loader:1145:15)
                    at Module._load (node:internal/modules/cjs/loader:986:27)
                    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
                    at node:internal/main/run_main_module:28:49 {
                  code: 'MODULE_NOT_FOUND',
                  requireStack: []
                Node.js v20.16.0
                  Homoran Global Moderator Administrators @flommaster last edited by
                  @flommaster sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                  flo@ioBrokerdebian:/opt/iobroker$ npm prune
                  hast du beide Befehle auf einmal gestartet?
                  bitte einzeln abarbeiten
                  F Thomas Braun 2 Replies Last reply Reply Quote 1
                    flommaster @Homoran last edited by
                    Ja,
                    Hier ist das Ergebnis von "npm prune"
                    npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.web-speedy.git
                    npm warn skipping integrity check for git dependency ssh://git@github.com/peterbaumert/ioBroker.vofo-speedtest.git
                    npm warn skipping integrity check for git dependency ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git
                    npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2-widgets-material.git
                    npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2.git
                    npm warn skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git
                    npm warn skipping integrity check for git dependency ssh://git@github.com/aendue/ioBroker.reolink.git
                    npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.ical.git
                    npm warn skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git
                    npm warn skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git
                    npm warn skipping integrity check for git dependency ssh://git@github.com/WLAN-Kabel/ioBroker.calendar.git
                    npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                    npm warn deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
                    npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                    npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
                    npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
                    npm warn deprecated uid-number@0.0.6: This package is no longer supported.
                    npm warn deprecated npmlog@5.0.1: This package is no longer supported.
                    npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
                    npm warn deprecated npmlog@6.0.2: This package is no longer supported.
                    npm warn deprecated har-validator@5.1.5: this library is no longer supported
                    npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                    npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
                    npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
                    npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
                    npm warn deprecated q@1.1.2: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
                    npm warn deprecated
                    npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
                    npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                    npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                    npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
                    npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
                    npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                    npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
                    npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                    npm warn deprecated google-p12-pem@3.1.4: Package is no longer maintained
                    npm warn deprecated gauge@3.0.2: This package is no longer supported.
                    npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                    npm warn deprecated gauge@4.0.4: This package is no longer supported.
                    npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                    mikeal created this issue in request/request
                    open Request’s Past, Present and Future #3142
                    Qix- created this issue in visionmedia/debug
                    closed ReDos Vulnerability Regression Visibility Notice #797
                      Thomas Braun Most Active @Homoran last edited by Thomas Braun
                      @flommaster
                      Gerade noch gehabt...
                      Vollständig.
                      Inkl. vollständiger Eingabezeile inkl. login prompt. Damit man sieht was du da genau in welchem Verzeichnis mit welchem User eingegeben hast.
                      Und auch inkl. der neuen leeren Eingabezeile, damit man sieht das es durchgelaufen ist und da nix fehlt.
                      iobroker url https://github.com/DrozmotiX/ioBroker.sourceanalytix --debug
                        flommaster @Thomas Braun last edited by flommaster
                        @thomas-braun @Homoran
                        hier ist noch das Ergebnis von npm prune
                        root@ioBrokerdebian:/home/flo# npm prune
                        up to date, audited 135 packages in 2s
                        11 packages are looking for funding
                          run `npm fund` for details
                        4 vulnerabilities (2 moderate, 2 high)
                        To address all issues, run:
                          npm audit fix
                        Run `npm audit` for details.
                        npm ls
                        root@ioBrokerdebian:/home/flo# npm ls
                        flo@ /home/flo
                        └── iobroker.admin@6.10.2
                        Vielen Dank und viele Grüße
                          root@
                          Nie nie niemals als root herumkaspern...
                            Ok. Mach ich nicht mehr.
                            Davor bin ich noch der Anweisung gefolgt und habe den Befehl "npm audit fix" ausgeführt.
                            Danach wurden mir bei npm prune keine Fehler mehr angezeigt.
                            up to date, audited 133 packages in 2s
                            found 0 vulnerabilities
                            flo@ /home/flo
                              Thomas Braun Most Active @flommaster last edited by Thomas Braun
                              @flommaster
                              Mooooooooooooooarrrrrrrrrrrr...
                              MELD DICH ALS ROOT AB!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                              Und NIE NIE NIEMEHR als root an!!!!!!!!!!!!!!!!
                              Und du hampelst dann auch im falschen Verzeichnis herum....
                              Und iobroker admin hat in /home/flo auch nix verloren...
                              Und auch nie npm audit fix ausführen. Insbesondere nicht mit --force.
                              Das macht dir auch mehr kaputt als das es hilft.
                                erledigt. Bin als Root abgemeldet.
                                Sorry, das wusste ich nicht.
                                Ich habe npm prune gerade unter dem Verzeichnis "/opt/iobroker" gestartet.
                                Hier ist das Ergebnis:
                                npm error code ENOTEMPTY
                                npm error syscall rename
                                npm error path /opt/iobroker/node_modules/ajv
                                npm error dest /opt/iobroker/node_modules/.ajv-Kze9IpmC
                                npm error errno -39
                                npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/ajv' -> '/opt/iobroker/node_modules/.ajv-Kze9IpmC'
                                npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-19T19_54_02_939Z-debug-0.log
                                npm ls
                                flo@ioBrokerdebian:~$ cd /opt/iobroker && npm ls
                                [sudo] Passwort für flo:
                                iobroker.inst@2.0.3 /opt/iobroker
                                ├── @alcalzone/esbuild-register@2.5.1-1 extraneous
                                ├── @alcalzone/jsonl-db@3.1.1 extraneous
                                ├── @alcalzone/pak@0.8.1 extraneous
                                ├── @alcalzone/proper-lockfile@4.1.3-0 extraneous
                                ├── @azure/abort-controller@1.1.0 extraneous
                                ├── @azure/core-auth@1.7.2 extraneous
                                ├── @azure/core-client@ extraneous
                                ├── @azure/core-http-compat@2.1.2 extraneous
                                ├── @azure/core-lro@ extraneous
                                ├── @azure/core-paging@1.6.2 extraneous
                                ├── @azure/core-rest-pipeline@ extraneous
                                ├── @azure/core-tracing@1.1.2 extraneous
                                ├── @azure/core-util@1.9.2 extraneous
                                ├── @azure/identity@ extraneous
                                ├── @azure/keyvault-keys@4.8.0 extraneous
                                ├── @azure/logger@1.1.4 extraneous
                                ├── @azure/msal-browser@ extraneous
                                ├── @azure/msal-common@ extraneous
                                ├── @azure/msal-node@ extraneous
                                ├── @babel/runtime@ extraneous
                                ├── @colors/colors@1.5.0 extraneous
                                ├── @dabh/diagnostics@2.0.3 extraneous
                                ├── @datalust/winston-seq@1.0.2 extraneous
                                ├── @gar/promisify@1.1.3 extraneous
                                ├── @googleapis/calendar@9.7.7 extraneous
                                ├── @googleapis/drive@5.1.0 extraneous
                                ├── @googleapis/oauth2@1.0.7 extraneous
                                ├── @iobroker/db-base@6.0.10 extraneous
                                ├── @iobroker/db-objects-file@6.0.10 extraneous
                                ├── @iobroker/db-objects-jsonl@6.0.10 extraneous
                                ├── @iobroker/db-objects-redis@6.0.10 extraneous
                                ├── @iobroker/db-states-file@6.0.10 extraneous
                                ├── @iobroker/db-states-jsonl@6.0.10 extraneous
                                ├── @iobroker/db-states-redis@6.0.10 extraneous
                                ├── @iobroker/js-controller-adapter@6.0.10 extraneous
                                ├── @iobroker/js-controller-cli@ extraneous
                                ├── @iobroker/js-controller-common-db@6.0.10 extraneous
                                ├── @iobroker/js-controller-common@6.0.10 extraneous
                                ├── @iobroker/plugin-base@1.2.1 extraneous
                                ├── @iobroker/plugin-sentry@1.2.1 extraneous
                                ├── @iobroker/socket-classes@1.5.6 extraneous
                                ├── @iobroker/webserver@1.0.3 extraneous
                                ├── @isaacs/cliui@8.0.2 extraneous
                                ├── @js-joda/core@ extraneous
                                ├── @microsoft/microsoft-graph-types@2.40.0 extraneous
                                ├── @npmcli/fs@2.1.2 extraneous
                                ├── @npmcli/move-file@2.0.1 extraneous
                                ├── @pkgjs/parseargs@0.11.0 extraneous
                                ├── @protobufjs/aspromise@1.1.2 extraneous
                                ├── @protobufjs/base64@1.1.2 extraneous
                                ├── @protobufjs/codegen@2.0.4 extraneous
                                ├── @protobufjs/eventemitter@1.1.0 extraneous
                                ├── @protobufjs/fetch@1.1.0 extraneous
                                ├── @protobufjs/float@1.0.2 extraneous
                                ├── @protobufjs/inquire@1.1.0 extraneous
                                ├── @protobufjs/path@1.1.2 extraneous
                                ├── @protobufjs/pool@1.1.0 extraneous
                                ├── @protobufjs/utf8@1.1.0 extraneous
                                ├── @quasar/extras@ extraneous
                                ├── @sentry-internal/tracing@ extraneous
                                ├── @sentry/core@5.30.0 extraneous
                                ├── @sentry/hub@5.30.0 extraneous
                                ├── @sentry/minimal@5.30.0 extraneous
                                ├── @sentry/node@5.30.0 extraneous
                                ├── @sentry/tracing@ extraneous
                                ├── @sentry/types@5.30.0 extraneous
                                ├── @sentry/utils@5.30.0 extraneous
                                ├── @tootallnate/once@2.0.0 extraneous
                                ├── @types/caseless@0.12.5 extraneous
                                ├── @types/geojson@7946.0.14 extraneous
                                ├── @types/leaflet@1.9.12 extraneous
                                ├── @types/node-cron@2.0.8 extraneous
                                ├── @types/request@2.48.12 extraneous
                                ├── @types/tough-cookie@4.0.5 extraneous
                                ├── @types/triple-beam@1.3.5 extraneous
                                ├── @types/tz-offset@0.0.3 extraneous
                                ├── abab@2.0.6 extraneous
                                ├── agentkeepalive@4.5.0 extraneous
                                ├── ajv@ extraneous
                                ├── anymatch@3.1.3 extraneous
                                ├── archiver-utils@5.0.2 extraneous
                                ├── archiver@7.0.1 extraneous
                                ├── argparse@1.0.10 extraneous
                                ├── array-buffer-byte-length@1.0.1 extraneous
                                ├── arraybuffer.prototype.slice@1.0.3 extraneous
                                ├── arrify@2.0.1 extraneous
                                ├── available-typed-arrays@1.0.7 extraneous
                                ├── b4a@1.6.6 extraneous
                                ├── bare-events@2.4.2 extraneous
                                ├── base-64@1.0.0 extraneous
                                ├── binary-extensions@2.3.0 extraneous
                                ├── bindings@1.5.0 extraneous
                                ├── bottleneck@2.19.5 extraneous
                                ├── brace-expansion@2.0.1 extraneous
                                ├── buffer-crc32@1.0.0 extraneous
                                ├── buffer-equal-constant-time@1.0.1 extraneous
                                ├── buffer-shims@1.0.0 extraneous
                                ├── buildcheck@0.0.6 extraneous
                                ├── busboy@1.6.0 extraneous
                                ├── byte-length@1.0.2 extraneous
                                ├── cacache@16.1.3 extraneous
                                ├── charenc@0.0.2 extraneous
                                ├── chokidar@3.6.0 extraneous
                                ├── ci-info@3.9.0 extraneous
                                ├── cloneextend@0.0.3 extraneous
                                ├── cluster-key-slot@1.1.2 extraneous
                                ├── coffeescript@1.12.7 extraneous
                                ├── color-string@1.9.1 extraneous
                                ├── color@3.2.1 extraneous
                                ├── colors@1.4.0
                                ├── colorspace@1.1.4 extraneous
                                ├── commist@3.2.0 extraneous
                                ├── compress-commons@6.0.2 extraneous
                                ├── compress-json@2.1.2 extraneous
                                ├── compressible@2.0.18 extraneous
                                ├── compression@1.7.4 extraneous
                                ├── core-js@ extraneous
                                ├── crc-32@1.2.2 extraneous
                                ├── crc@4.1.1 extraneous
                                ├── crc32-stream@6.0.0 extraneous
                                ├── cross-fetch@4.0.0 extraneous
                                ├── crypt@0.0.2 extraneous
                                ├── cssstyle@3.0.0 extraneous
                                ├── cycle@1.0.3 extraneous
                                ├── data-urls@4.0.0 extraneous
                                ├── data-view-buffer@1.0.1 extraneous
                                ├── data-view-byte-length@1.0.1 extraneous
                                ├── data-view-byte-offset@1.0.0 extraneous
                                ├── date-and-time@ extraneous
                                ├── dayjs@ extraneous
                                ├── decache@4.6.2 extraneous
                                ├── decimal.js@10.4.3 extraneous
                                ├── deep-clone@3.0.3 extraneous
                                ├── define-lazy-prop@2.0.0 extraneous
                                ├── denque@1.5.1 extraneous
                                ├── digest-header@1.1.0 extraneous
                                ├── diskusage@1.2.0 extraneous
                                ├── domexception@4.0.0 extraneous
                                ├── draftlog@1.0.13 extraneous
                                ├── dropbox-v2-api@ extraneous
                                ├── duplexer@0.1.2 extraneous
                                ├── eastasianwidth@0.2.0 extraneous
                                ├── ecdsa-sig-formatter@1.0.11 extraneous
                                ├── echarts@ extraneous
                                ├── emoji-regex@9.2.2 extraneous
                                ├── enabled@2.0.0 extraneous
                                ├── entities@4.5.0 extraneous
                                ├── err-code@2.0.3 extraneous
                                ├── es-abstract@ extraneous
                                ├── es-aggregate-error@1.0.13 extraneous
                                ├── es-object-atoms@1.0.0 extraneous
                                ├── es-set-tostringtag@2.0.3 extraneous
                                ├── es-to-primitive@1.2.1 extraneous
                                ├── es6-promise@4.2.8 extraneous
                                ├── es6-promisify@5.0.0 extraneous
                                ├── esbuild@0.11.23 extraneous
                                ├── event-stream@4.0.1 extraneous
                                ├── expand-template@2.0.3 extraneous
                                ├── express-fileupload@1.5.1 extraneous
                                ├── fast-deep-equal@3.1.3 extraneous
                                ├── fast-fifo@1.3.2 extraneous
                                ├── fast-json-stable-stringify@2.1.0 extraneous
                                ├── fast-text-encoding@1.0.6 extraneous
                                ├── fast-unique-numbers@8.0.13 extraneous
                                ├── fast-uri@3.0.1 extraneous
                                ├── fast-xml-parser@4.4.1 extraneous
                                ├── fecha@4.2.3 extraneous
                                ├── file-stream-rotator@0.6.1 extraneous
                                ├── file-type@10.11.0 extraneous
                                ├── file-uri-to-path@1.0.0 extraneous
                                ├── fn.name@1.1.0 extraneous
                                ├── for-each@0.3.3 extraneous
                                ├── foreground-child@3.3.0 extraneous
                                ├── from@0.1.7 extraneous
                                ├── fs-constants@1.0.0 extraneous
                                ├── fs-extra@7.0.1
                                ├── fsevents@ extraneous
                                ├── ftp@0.3.10 extraneous
                                ├── function.prototype.name@1.1.6 extraneous
                                ├── functions-have-names@1.2.3 extraneous
                                ├── futoin-hkdf@1.4.3 extraneous
                                ├── gaxios@5.1.3 extraneous
                                ├── gcp-metadata@5.3.0 extraneous
                                ├── get-ssl-certificate@2.3.3 extraneous
                                ├── get-symbol-description@1.0.2 extraneous
                                ├── github-from-package@0.0.0 extraneous
                                ├── glob@10.4.5 extraneous
                                ├── globalthis@1.0.4 extraneous
                                ├── glossy@0.1.7 extraneous
                                ├── google-auth-library@8.9.0 extraneous
                                ├── google-p12-pem@4.0.1 extraneous
                                ├── googleapis-common@6.0.4 extraneous
                                ├── googleapis@ extraneous
                                ├── gtoken@6.1.2 extraneous
                                ├── has-bigints@1.0.2 extraneous
                                ├── has-tostringtag@1.0.2 extraneous
                                ├── he@1.2.0 extraneous
                                ├── help-me@5.0.0 extraneous
                                ├── homebridge-plugin-wrapper@ extraneous
                                ├── hot-patcher@1.0.0 extraneous
                                ├── html-encoding-sniffer@3.0.0 extraneous
                                ├── http-proxy-agent@5.0.0 extraneous
                                ├── https@1.0.0 extraneous
                                ├── humanize-ms@1.2.1 extraneous
                                ├── ical.js@1.5.0 extraneous
                                ├── image-type@4.1.0 extraneous
                                ├── infer-owner@1.0.4 extraneous
                                ├── internal-slot@1.0.7 extraneous
                                ├── iobroker-adapter-helpers@0.0.8 extraneous
                                ├── iobroker.admin@ invalid: "^6.10.1" from the root project
                                ├── iobroker.backitup@ invalid: "2.6.23" from the root project
                                ├── iobroker.bmw@2.5.7
                                ├── iobroker.calendar@ invalid: "github:WLAN-Kabel/ioBroker.calendar#c36410258c21a4a92eba80fb0ec084fc254c9259" from the root project
                                ├── iobroker.cloud@4.4.1
                                ├── iobroker.coronavirus-statistics@0.8.7
                                ├── iobroker.daswetter@3.1.10
                                ├── iobroker.discovery@ invalid: "3.1.0" from the root project
                                ├── iobroker.dwd@2.8.5
                                ├── iobroker.echarts@ invalid: "1.5.1" from the root project
                                ├── iobroker.energiefluss@ invalid: "github:SKB-CGN/ioBroker.energiefluss#fc7a5b48f0f485b130619796daf0a9533f5b8426" from the root project
                                ├── iobroker.eusec@1.1.2
                                ├── iobroker.flot@ invalid: "1.12.0" from the root project
                                ├── iobroker.fritzbox@0.2.1
                                ├── iobroker.fullcalendar@1.2.0
                                ├── iobroker.fullybrowser@2.1.2
                                ├── iobroker.gartenbewaesserung@ invalid: "github:TA2k/ioBroker.gartenbewaesserung#1931dcd562edf9dfa818dbf5cec61e28d3f72d72" from the root project
                                ├── iobroker.ham@ invalid: "github:ioBroker/ioBroker.ham" from the root project
                                ├── iobroker.harmony@1.2.2
                                ├── iobroker.heatingcontrol@2.11.1
                                ├── iobroker.history@2.2.6
                                ├── iobroker.hm-rega@3.0.47
                                ├── iobroker.hm-rpc@1.15.19
                                ├── iobroker.hue@3.9.5
                                ├── iobroker.ical@ invalid: "github:iobroker-community-adapters/ioBroker.ical#ad28140ed1fa7ab23683d7e12b6204da06b7ce6f" from the root project
                                ├── iobroker.icons-icons8@0.0.1
                                ├── iobroker.icons-material-png@0.1.0
                                ├── iobroker.icons-mfd-png@1.1.0
                                ├── iobroker.icons-ultimate-png@1.0.1
                                ├── iobroker.info@ invalid: "1.9.26" from the root project
                                ├── iobroker.javascript@ invalid: "7.1.4" from the root project
                                ├── iobroker.js-controller@ invalid: "^6.0.9" from the root project
                                ├── iobroker.logparser@2.2.0
                                ├── iobroker.material@ invalid: "1.3.1" from the root project
                                ├── iobroker.meross@1.15.1
                                ├── iobroker.mihome-vacuum@3.11.0
                                ├── iobroker.milight-smart-light@ invalid: "1.2.2" from the root project
                                ├── iobroker.milight@0.3.6
                                ├── iobroker.mobile@ invalid: "1.0.1" from the root project
                                ├── iobroker.modbus@ invalid: "5.0.11" from the root project
                                ├── iobroker.mqtt@ invalid: "4.1.1" from the root project
                                ├── iobroker.nina@ invalid: "0.0.25" from the root project
                                ├── iobroker.pollenflug@1.0.6
                                ├── iobroker.pushover@3.0.3
                                ├── iobroker.pushsafer@1.0.3
                                ├── iobroker.pvforecast@2.7.1
                                ├── iobroker.renault@ invalid: "github:TA2k/ioBroker.renault" from the root project
                                ├── iobroker.reolink@ invalid: "github:aendue/ioBroker.reolink#b78aab6744cdb81b360fd947a9c6e2fd6808bab1" from the root project
                                ├── iobroker.schoolfree@ invalid: "1.1.2" from the root project
                                ├── iobroker.simple-api@2.7.2
                                ├── iobroker.smartmeter@3.3.4
                                ├── iobroker.socketio@6.5.2
                                ├── iobroker.sourceanalytix@ invalid: "github:DrozmotiX/ioBroker.sourceanalytix#362346b297c0a21c717ec20bd8d16331bca3b22d" from the root project
                                ├── iobroker.sql@2.2.0
                                ├── iobroker.statistics@2.3.0
                                ├── iobroker.sunnyportal@0.1.5
                                ├── iobroker.synology@2.1.13
                                ├── iobroker.tankerkoenig@ invalid: "3.3.7" from the root project
                                ├── iobroker.terminal@1.0.0
                                ├── iobroker.tr-064@4.2.18
                                ├── iobroker.trashschedule@2.2.0
                                ├── iobroker.unifi@0.6.6
                                ├── iobroker.upnp@1.0.21
                                ├── iobroker.valloxmv@1.2.0
                                ├── iobroker.viessmannapi@ invalid: "github:TA2k/ioBroker.viessmannapi" from the root project
                                ├── iobroker.virtualpowermeter@ invalid: "1.4.6" from the root project
                                ├── iobroker.vis-2-widgets-material@ invalid: "github:ioBroker/ioBroker.vis-2-widgets-material#355a97e7d532721eaa97326fd873d13f12894ebd" from the root project
                                ├── iobroker.vis-2@ invalid: "github:ioBroker/ioBroker.vis-2#17c7dcf5f26768f1f3a4badb087eddf9344591ea" from the root project
                                ├── iobroker.vis-colorpicker@2.0.3
                                ├── iobroker.vis-fancyswitch@1.1.0
                                ├── iobroker.vis-google-fonts@1.0.4
                                ├── iobroker.vis-history@1.0.0
                                ├── iobroker.vis-hqwidgets@1.4.0
                                ├── iobroker.vis-inventwo@3.3.3
                                ├── iobroker.vis-jqui-mfd@1.0.12
                                ├── iobroker.vis-justgage@1.0.2
                                ├── iobroker.vis-map@1.0.4
                                ├── iobroker.vis-materialdesign@ invalid: "github:Scrounger/ioBroker.vis-materialdesign#8b7529d493f223dfc4f1d1f632553fcb35bbcc92" from the root project
                                ├── iobroker.vis-metro@ invalid: "1.2.0" from the root project
                                ├── iobroker.vis-rgraph@0.0.2
                                ├── iobroker.vis-timeandweather@1.2.2
                                ├── iobroker.vis-weather@ invalid: "2.5.6" from the root project
                                ├── iobroker.vis@ invalid: "1.4.16" from the root project
                                ├── iobroker.vofo-speedtest@ invalid: "github:peterbaumert/ioBroker.vofo-speedtest#921201b4bbd53a88a64fc843c7242f9e7e8c0325" from the root project
                                ├── iobroker.weatherunderground@3.4.2
                                ├── iobroker.web-speedy@ invalid: "github:iobroker-community-adapters/ioBroker.web-speedy#8a5ad6a42a15688b6bb539f22e30ba2a1978c118" from the root project
                                ├── iobroker.web@ invalid: "6.1.0" from the root project
                                ├── iobroker.webcal@ invalid: "github:dirkhe/ioBroker.webcal#feature/DigestAuth" from the root project
                                ├── iobroker.wiffi-wz@2.2.1
                                ├── iobroker.windows-control@0.1.5
                                ├── iobroker.worx@2.3.2
                                ├── iobroker.ws@2.5.3
                                ├── iobroker@2.0.3
                                ├── ioredis@4.28.5 extraneous
                                ├── ip-address@9.0.5 extraneous
                                ├── ip-regex@4.3.0 extraneous
                                ├── ipaddr.js@2.2.0 extraneous
                                ├── is-array-buffer@3.0.4 extraneous
                                ├── is-bigint@1.0.4 extraneous
                                ├── is-binary-path@2.1.0 extraneous
                                ├── is-boolean-object@1.1.2 extraneous
                                ├── is-buffer@1.1.6 extraneous
                                ├── is-callable@1.2.7 extraneous
                                ├── is-data-view@1.0.1 extraneous
                                ├── is-date-object@1.0.5 extraneous
                                ├── is-empty-object@1.1.1 extraneous
                                ├── is-lambda@1.0.1 extraneous
                                ├── is-negative-zero@2.0.3 extraneous
                                ├── is-number-object@1.0.7 extraneous
                                ├── is-potential-custom-element-name@1.0.1 extraneous
                                ├── is-regex@1.1.4 extraneous
                                ├── is-shared-array-buffer@1.0.3 extraneous
                                ├── is-string@1.0.7 extraneous
                                ├── is-symbol@1.0.4 extraneous
                                ├── is-typed-array@1.1.13 extraneous
                                ├── is-url@1.2.4 extraneous
                                ├── is-weakref@1.0.2 extraneous
                                ├── is@3.3.0 extraneous
                                ├── is2@2.0.9 extraneous
                                ├── jackspeak@3.4.3 extraneous
                                ├── js-md4@0.3.2 extraneous
                                ├── js-yaml@3.14.1 extraneous
                                ├── jsbi@4.3.0 extraneous
                                ├── jsbn@1.1.0 extraneous
                                ├── jsdom@ extraneous
                                ├── jshashes@1.0.8 extraneous
                                ├── json-schema-traverse@1.0.0 extraneous
                                ├── json5@2.2.3 extraneous
                                ├── jsonata@2.0.5 extraneous
                                ├── jsonc-parser@3.3.1 extraneous
                                ├── jsonwebtoken@9.0.2 extraneous
                                ├── jszip@3.10.1 extraneous
                                ├── jwa@2.0.0 extraneous
                                ├── jws@4.0.0 extraneous
                                ├── kuler@2.0.0 extraneous
                                ├── layerr@0.1.2 extraneous
                                ├── lazystream@1.0.1 extraneous
                                ├── lie@3.3.0 extraneous
                                ├── loadavg-windows@1.1.1 extraneous
                                ├── lodash.defaults@4.2.0 extraneous
                                ├── lodash.flatten@4.4.0 extraneous
                                ├── lodash.includes@4.3.0 extraneous
                                ├── lodash.isarguments@3.1.0 extraneous
                                ├── lodash.isboolean@3.0.3 extraneous
                                ├── lodash.isinteger@4.0.4 extraneous
                                ├── lodash.isnumber@3.0.3 extraneous
                                ├── lodash.isplainobject@4.0.6 extraneous
                                ├── lodash.isstring@4.0.1 extraneous
                                ├── lodash.once@4.1.1 extraneous
                                ├── logform@2.6.1 extraneous
                                ├── long@5.2.3 extraneous
                                ├── make-fetch-happen@10.2.1 extraneous
                                ├── map-stream@0.0.7 extraneous
                                ├── md5@2.3.0 extraneous
                                ├── mime-db@1.53.0 extraneous
                                ├── minimatch@9.0.5 extraneous
                                ├── minipass-collect@1.0.2 extraneous
                                ├── minipass-fetch@2.1.2 extraneous
                                ├── minipass-flush@1.0.5 extraneous
                                ├── minipass-pipeline@1.2.4 extraneous
                                ├── minipass-sized@1.0.3 extraneous
                                ├── minipass@7.1.2 extraneous
                                ├── mkdirp-classic@0.5.3 extraneous
                                ├── mock-require@3.0.3 extraneous
                                ├── moment-duration-format@2.3.2 extraneous
                                ├── mqtt-connection@4.1.0 extraneous
                                ├── mqtt-packet@9.0.0 extraneous
                                ├── mqtt@ extraneous
                                ├── nanoid@3.3.7 extraneous
                                ├── napi-build-utils@1.0.2 extraneous
                                ├── native-duplexpair@1.0.0 extraneous
                                ├── nconf@0.10.0 extraneous
                                ├── nested-property@4.0.0 extraneous
                                ├── netmask@2.0.2 extraneous
                                ├── node-abi@3.65.0 extraneous
                                ├── node-abort-controller@3.1.1 extraneous
                                ├── node-cron@2.0.3 extraneous
                                ├── node-forge@ extraneous
                                ├── node-gyp@9.3.0 extraneous
                                ├── node-ical@0.16.1 extraneous
                                ├── node-inspect@2.0.0 extraneous
                                ├── node-libcurl@3.0.0 extraneous
                                ├── node-mndp@0.0.3 extraneous
                                ├── node-persist@0.0.11 extraneous
                                ├── node-rsa@1.1.1 extraneous
                                ├── node-wol@0.1.1 extraneous
                                ├── node.extend@2.0.3 extraneous
                                ├── normalize-path@3.0.0 extraneous
                                ├── nwsapi@2.2.12 extraneous
                                ├── object-hash@3.0.0 extraneous
                                ├── one-time@1.0.0 extraneous
                                ├── onedrive-api@1.1.1 extraneous
                                ├── opencollective-postinstall@2.0.3 extraneous
                                ├── ospath@1.2.2 extraneous
                                ├── osx-temperature-sensor@ extraneous
                                ├── otplib@11.0.1 extraneous
                                ├── p-throttle@4.1.1 extraneous
                                ├── package-json-from-dist@1.0.0 extraneous
                                ├── pako@1.0.11 extraneous
                                ├── parse5@7.1.2 extraneous
                                ├── passport@0.7.0 extraneous
                                ├── path-parse@1.0.7 extraneous
                                ├── path-posix@1.0.0 extraneous
                                ├── path-scurry@1.11.1 extraneous
                                ├── pause-stream@0.0.11 extraneous
                                ├── pidusage@3.0.2 extraneous
                                ├── ping@0.4.4 extraneous
                                ├── pluralize@8.0.0 extraneous
                                ├── possible-typed-array-names@1.0.0 extraneous
                                ├── prebuild-install@7.1.2 extraneous
                                ├── promise-inflight@1.0.1 extraneous
                                ├── promise-object@0.1.7 extraneous
                                ├── promise-retry@2.0.1 extraneous
                                ├── promise-retryer@0.0.1 extraneous
                                ├── promisify-child-process@4.1.2 extraneous
                                ├── prompt@1.3.0 extraneous
                                ├── protobufjs@ extraneous
                                ├── proxy-from-env@1.1.0 extraneous
                                ├── q@1.1.2 extraneous
                                ├── quasar@ extraneous
                                ├── queue-tick@1.0.1 extraneous
                                ├── read@1.0.7 extraneous
                                ├── readdir-glob@1.1.3 extraneous
                                ├── readdirp@3.6.0 extraneous
                                ├── readline-sync@1.4.10 extraneous
                                ├── readline@1.3.0 extraneous
                                ├── redis-commands@1.7.0 extraneous
                                ├── redis-errors@1.2.0 extraneous
                                ├── redis-parser@3.0.0 extraneous
                                ├── regenerator-runtime@0.14.1 extraneous
                                ├── regex-escape@3.4.10 extraneous
                                ├── regexp.prototype.flags@1.5.2 extraneous
                                ├── remove-trailing-separator@1.1.0 extraneous
                                ├── require-from-string@2.0.2 extraneous
                                ├── respjs@4.2.0 extraneous
                                ├── retry-axios@2.6.0 extraneous
                                ├── retry@0.12.0 extraneous
                                ├── revalidator@0.1.8 extraneous
                                ├── rrule@2.8.1 extraneous
                                ├── rrweb-cssom@0.6.0 extraneous
                                ├── safe-array-concat@1.1.2 extraneous
                                ├── safe-regex-test@1.0.3 extraneous
                                ├── safe-stable-stringify@2.4.3 extraneous
                                ├── saxes@6.0.0 extraneous
                                ├── secure-keys@1.0.0 extraneous
                                ├── semver@5.7.2
                                ├── seq-logging@1.1.2 extraneous
                                ├── set-function-name@2.0.2 extraneous
                                ├── setimmediate@1.0.5 extraneous
                                ├── signal-exit@4.1.0 extraneous
                                ├── simple-swizzle@0.2.2 extraneous
                                ├── smart-buffer@4.2.0 extraneous
                                ├── socks-proxy-agent@7.0.0 extraneous
                                ├── socks@2.8.3 extraneous
                                ├── speedtest-net@1.6.2 extraneous
                                ├── sprintf-js@1.1.3 extraneous
                                ├── ssri@9.0.1 extraneous
                                ├── stack-trace@0.0.10 extraneous
                                ├── stampit-event-bus@0.1.1 extraneous
                                ├── stampit-state-machine@0.2.1 extraneous
                                ├── stampit@2.1.2 extraneous
                                ├── standard-as-callback@2.1.0 extraneous
                                ├── stoppable@1.1.0 extraneous
                                ├── stream-combiner@0.2.2 extraneous
                                ├── streamsearch@1.1.0 extraneous
                                ├── streamx@2.18.0 extraneous
                                ├── string-argv@0.3.2 extraneous
                                ├── string-width-cjs@npm:string-width@4.2.3 extraneous
                                ├── string-width@5.1.2 extraneous
                                ├── string.prototype.trim@1.2.9 extraneous
                                ├── string.prototype.trimend@1.0.8 extraneous
                                ├── string.prototype.trimstart@1.0.8 extraneous
                                ├── strip-ansi-cjs@npm:strip-ansi@6.0.1 extraneous
                                ├── strnum@1.0.5 extraneous
                                ├── suncalc@1.9.0 extraneous
                                ├── suncalc2@1.8.1 extraneous
                                ├── supermixer@1.0.5 extraneous
                                ├── supports-preserve-symlinks-flag@1.0.0 extraneous
                                ├── sweet-collections@1.1.0 extraneous
                                ├── symbol-tree@3.2.4 extraneous
                                ├── systeminformation@5.23.4 extraneous
                                ├── tar-fs@2.1.1 extraneous
                                ├── tar-stream@3.1.7 extraneous
                                ├── tcp-port-used@1.0.2 extraneous
                                ├── text-decoder@1.1.1 extraneous
                                ├── text-hex@1.0.0 extraneous
                                ├── thirty-two@1.0.2 extraneous
                                ├── through2@2.0.5 extraneous
                                ├── tiny-typed-emitter@2.1.0 extraneous
                                ├── tinycolor2@1.6.0 extraneous
                                ├── tr46@4.1.1 extraneous
                                ├── triple-beam@1.4.1 extraneous
                                ├── tsdav@2.1.1 extraneous
                                ├── tslib@2.3.0 extraneous
                                ├── typed-array-buffer@1.0.2 extraneous
                                ├── typed-array-byte-length@1.0.1 extraneous
                                ├── typed-array-byte-offset@1.0.2 extraneous
                                ├── typed-array-length@1.0.6 extraneous
                                ├── typedarray.prototype.slice@1.0.3 extraneous
                                ├── typescript@ extraneous
                                ├── tz-offset@0.0.1 extraneous
                                ├── unbox-primitive@1.0.2 extraneous
                                ├── unique-filename@2.0.1 extraneous
                                ├── unique-slug@3.0.0 extraneous
                                ├── unix-dgram@2.0.6 extraneous
                                ├── uri-js@4.4.1 extraneous
                                ├── url-join@4.0.1 extraneous
                                ├── url-template@2.0.8 extraneous
                                ├── virtual-tsc@0.6.2 extraneous
                                ├── vue-i18n@8.28.2 extraneous
                                ├── vuelidate-messages@0.1.2 extraneous
                                ├── vuelidate@0.7.7 extraneous
                                ├── vuex-map-fields@1.4.1 extraneous
                                ├── w3c-xmlserializer@4.0.0 extraneous
                                ├── wake_on_lan@1.0.0 extraneous
                                ├── weak-daemon@1.0.3 extraneous
                                ├── webdav@4.11.3 extraneous
                                ├── webidl-conversions@7.0.0 extraneous
                                ├── websocket-stream@5.5.2 extraneous
                                ├── whatwg-encoding@2.0.0 extraneous
                                ├── whatwg-mimetype@3.0.0 extraneous
                                ├── whatwg-url@12.0.1 extraneous
                                ├── which-boxed-primitive@1.0.2 extraneous
                                ├── which-typed-array@1.1.15 extraneous
                                ├── window-size@0.1.4 extraneous
                                ├── winston-daily-rotate-file@5.0.0 extraneous
                                ├── winston-seq-updated@1.0.4 extraneous
                                ├── winston-syslog@2.7.1 extraneous
                                ├── winston-transport@4.7.1 extraneous
                                ├── winston@3.14.2 extraneous
                                ├── worker-timers-broker@6.1.8 extraneous
                                ├── worker-timers-worker@7.0.71 extraneous
                                ├── worker-timers@7.1.8 extraneous
                                ├── wrap-ansi-cjs@npm:wrap-ansi@7.0.0 extraneous
                                ├── wrap-ansi@8.1.0 extraneous
                                ├── xml-js@1.6.11 extraneous
                                ├── xml-name-validator@4.0.0 extraneous
                                ├── xmlchars@2.2.0 extraneous
                                ├── xregexp@2.0.0 extraneous
                                ├── yargs@7.1.2
                                ├── zip-stream@6.0.1 extraneous
                                └── zrender@ extraneous
                                npm error code ELSPROBLEMS
                                npm error extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
                                npm error extraneous: @alcalzone/jsonl-db@3.1.1 /opt/iobroker/node_modules/@alcalzone/jsonl-db
                                npm error extraneous: @alcalzone/pak@0.8.1 /opt/iobroker/node_modules/@alcalzone/pak
                                npm error extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
                                npm error extraneous: @azure/abort-controller@1.1.0 /opt/iobroker/node_modules/@azure/abort-controller
                                npm error extraneous: @azure/core-auth@1.7.2 /opt/iobroker/node_modules/@azure/core-auth
                                npm error extraneous: @azure/core-client@ /opt/iobroker/node_modules/@azure/core-client
                                npm error extraneous: @azure/core-http-compat@2.1.2 /opt/iobroker/node_modules/@azure/core-http-compat
                                npm error extraneous: @azure/core-lro@ /opt/iobroker/node_modules/@azure/core-lro
                                npm error extraneous: @azure/core-paging@1.6.2 /opt/iobroker/node_modules/@azure/core-paging
                                npm error extraneous: @azure/core-rest-pipeline@ /opt/iobroker/node_modules/@azure/core-rest-pipeline
                                npm error extraneous: @azure/core-tracing@1.1.2 /opt/iobroker/node_modules/@azure/core-tracing
                                npm error extraneous: @azure/core-util@1.9.2 /opt/iobroker/node_modules/@azure/core-util
                                npm error extraneous: @azure/identity@ /opt/iobroker/node_modules/@azure/identity
                                npm error extraneous: @azure/keyvault-keys@4.8.0 /opt/iobroker/node_modules/@azure/keyvault-keys
                                npm error extraneous: @azure/logger@1.1.4 /opt/iobroker/node_modules/@azure/logger
                                npm error extraneous: @azure/msal-browser@ /opt/iobroker/node_modules/@azure/msal-browser
                                npm error extraneous: @azure/msal-common@ /opt/iobroker/node_modules/@azure/msal-common
                                npm error extraneous: @azure/msal-node@ /opt/iobroker/node_modules/@azure/msal-node
                                npm error extraneous: @babel/runtime@ /opt/iobroker/node_modules/@babel/runtime
                                npm error extraneous: @colors/colors@1.5.0 /opt/iobroker/node_modules/@colors/colors
                                npm error extraneous: @dabh/diagnostics@2.0.3 /opt/iobroker/node_modules/@dabh/diagnostics
                                npm error extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
                                npm error extraneous: @gar/promisify@1.1.3 /opt/iobroker/node_modules/@gar/promisify
                                npm error extraneous: @googleapis/calendar@9.7.7 /opt/iobroker/node_modules/@googleapis/calendar
                                npm error extraneous: @googleapis/drive@5.1.0 /opt/iobroker/node_modules/@googleapis/drive
                                npm error extraneous: @googleapis/oauth2@1.0.7 /opt/iobroker/node_modules/@googleapis/oauth2
                                npm error extraneous: @iobroker/db-base@6.0.10 /opt/iobroker/node_modules/@iobroker/db-base
                                npm error extraneous: @iobroker/db-objects-file@6.0.10 /opt/iobroker/node_modules/@iobroker/db-objects-file
                                npm error extraneous: @iobroker/db-objects-jsonl@6.0.10 /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
                                npm error extraneous: @iobroker/db-objects-redis@6.0.10 /opt/iobroker/node_modules/@iobroker/db-objects-redis
                                npm error extraneous: @iobroker/db-states-file@6.0.10 /opt/iobroker/node_modules/@iobroker/db-states-file
                                npm error extraneous: @iobroker/db-states-jsonl@6.0.10 /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                                npm error extraneous: @iobroker/db-states-redis@6.0.10 /opt/iobroker/node_modules/@iobroker/db-states-redis
                                npm error extraneous: @iobroker/js-controller-adapter@6.0.10 /opt/iobroker/node_modules/@iobroker/js-controller-adapter
                                npm error extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
                                npm error extraneous: @iobroker/js-controller-common-db@6.0.10 /opt/iobroker/node_modules/@iobroker/js-controller-common-db
                                npm error extraneous: @iobroker/js-controller-common@6.0.10 /opt/iobroker/node_modules/@iobroker/js-controller-common
                                npm error extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
                                npm error extraneous: @iobroker/plugin-sentry@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-sentry
                                npm error extraneous: @iobroker/socket-classes@1.5.6 /opt/iobroker/node_modules/@iobroker/socket-classes
                                npm error extraneous: @iobroker/webserver@1.0.3 /opt/iobroker/node_modules/@iobroker/webserver
                                npm error extraneous: @isaacs/cliui@8.0.2 /opt/iobroker/node_modules/@isaacs/cliui
                                npm error extraneous: @js-joda/core@ /opt/iobroker/node_modules/@js-joda/core
                                npm error extraneous: @microsoft/microsoft-graph-types@2.40.0 /opt/iobroker/node_modules/@microsoft/microsoft-graph-types
                                npm error extraneous: @npmcli/fs@2.1.2 /opt/iobroker/node_modules/@npmcli/fs
                                npm error extraneous: @npmcli/move-file@2.0.1 /opt/iobroker/node_modules/@npmcli/move-file
                                npm error extraneous: @pkgjs/parseargs@0.11.0 /opt/iobroker/node_modules/@pkgjs/parseargs
                                npm error extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
                                npm error extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
                                npm error extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
                                npm error extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
                                npm error extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
                                npm error extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
                                npm error extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
                                npm error extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
                                npm error extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
                                npm error extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
                                npm error extraneous: @quasar/extras@ /opt/iobroker/node_modules/@quasar/extras
                                npm error extraneous: @sentry-internal/tracing@ /opt/iobroker/node_modules/@sentry-internal/tracing
                                npm error extraneous: @sentry/core@5.30.0 /opt/iobroker/node_modules/@sentry/core
                                npm error extraneous: @sentry/hub@5.30.0 /opt/iobroker/node_modules/@sentry/hub
                                npm error extraneous: @sentry/minimal@5.30.0 /opt/iobroker/node_modules/@sentry/minimal
                                npm error extraneous: @sentry/node@5.30.0 /opt/iobroker/node_modules/@sentry/node
                                npm error extraneous: @sentry/tracing@ /opt/iobroker/node_modules/@sentry/tracing
                                npm error extraneous: @sentry/types@5.30.0 /opt/iobroker/node_modules/@sentry/types
                                npm error extraneous: @sentry/utils@5.30.0 /opt/iobroker/node_modules/@sentry/utils
                                npm error extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
                                npm error extraneous: @types/caseless@0.12.5 /opt/iobroker/node_modules/@types/caseless
                                npm error extraneous: @types/geojson@7946.0.14 /opt/iobroker/node_modules/@types/geojson
                                npm error extraneous: @types/leaflet@1.9.12 /opt/iobroker/node_modules/@types/leaflet
                                npm error extraneous: @types/node-cron@2.0.8 /opt/iobroker/node_modules/@types/node-cron
                                npm error extraneous: @types/request@2.48.12 /opt/iobroker/node_modules/@types/request
                                npm error extraneous: @types/tough-cookie@4.0.5 /opt/iobroker/node_modules/@types/tough-cookie
                                npm error extraneous: @types/triple-beam@1.3.5 /opt/iobroker/node_modules/@types/triple-beam
                                npm error extraneous: @types/tz-offset@0.0.3 /opt/iobroker/node_modules/@types/tz-offset
                                npm error extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
                                npm error extraneous: agentkeepalive@4.5.0 /opt/iobroker/node_modules/agentkeepalive
                                npm error extraneous: ajv@ /opt/iobroker/node_modules/ajv
                                npm error extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
                                npm error extraneous: archiver-utils@5.0.2 /opt/iobroker/node_modules/archiver-utils
                                npm error extraneous: archiver@7.0.1 /opt/iobroker/node_modules/archiver
                                npm error extraneous: argparse@1.0.10 /opt/iobroker/node_modules/argparse
                                npm error extraneous: array-buffer-byte-length@1.0.1 /opt/iobroker/node_modules/array-buffer-byte-length
                                npm error extraneous: arraybuffer.prototype.slice@1.0.3 /opt/iobroker/node_modules/arraybuffer.prototype.slice
                                npm error extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
                                npm error extraneous: available-typed-arrays@1.0.7 /opt/iobroker/node_modules/available-typed-arrays
                                npm error extraneous: b4a@1.6.6 /opt/iobroker/node_modules/b4a
                                npm error extraneous: bare-events@2.4.2 /opt/iobroker/node_modules/bare-events
                                npm error extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
                                npm error extraneous: binary-extensions@2.3.0 /opt/iobroker/node_modules/binary-extensions
                                npm error extraneous: bindings@1.5.0 /opt/iobroker/node_modules/bindings
                                npm error extraneous: bottleneck@2.19.5 /opt/iobroker/node_modules/bottleneck
                                npm error extraneous: brace-expansion@2.0.1 /opt/iobroker/node_modules/brace-expansion
                                npm error extraneous: buffer-crc32@1.0.0 /opt/iobroker/node_modules/buffer-crc32
                                npm error extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
                                npm error extraneous: buffer-shims@1.0.0 /opt/iobroker/node_modules/buffer-shims
                                npm error extraneous: buildcheck@0.0.6 /opt/iobroker/node_modules/buildcheck
                                npm error extraneous: busboy@1.6.0 /opt/iobroker/node_modules/busboy
                                npm error extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
                                npm error extraneous: cacache@16.1.3 /opt/iobroker/node_modules/cacache
                                npm error extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
                                npm error extraneous: chokidar@3.6.0 /opt/iobroker/node_modules/chokidar
                                npm error extraneous: ci-info@3.9.0 /opt/iobroker/node_modules/ci-info
                                npm error extraneous: cloneextend@0.0.3 /opt/iobroker/node_modules/cloneextend
                                npm error extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
                                npm error extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                                npm error extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
                                npm error extraneous: color@3.2.1 /opt/iobroker/node_modules/color
                                npm error extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
                                npm error extraneous: commist@3.2.0 /opt/iobroker/node_modules/commist
                                npm error extraneous: compress-commons@6.0.2 /opt/iobroker/node_modules/compress-commons
                                npm error extraneous: compress-json@2.1.2 /opt/iobroker/node_modules/compress-json
                                npm error extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
                                npm error extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
                                npm error extraneous: core-js@ /opt/iobroker/node_modules/core-js
                                npm error extraneous: crc-32@1.2.2 /opt/iobroker/node_modules/crc-32
                                npm error extraneous: crc@4.1.1 /opt/iobroker/node_modules/crc
                                npm error extraneous: crc32-stream@6.0.0 /opt/iobroker/node_modules/crc32-stream
                                npm error extraneous: cross-fetch@4.0.0 /opt/iobroker/node_modules/cross-fetch
                                npm error extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
                                npm error extraneous: cssstyle@3.0.0 /opt/iobroker/node_modules/cssstyle
                                npm error extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
                                npm error extraneous: data-urls@4.0.0 /opt/iobroker/node_modules/data-urls
                                npm error extraneous: data-view-buffer@1.0.1 /opt/iobroker/node_modules/data-view-buffer
                                npm error extraneous: data-view-byte-length@1.0.1 /opt/iobroker/node_modules/data-view-byte-length
                                npm error extraneous: data-view-byte-offset@1.0.0 /opt/iobroker/node_modules/data-view-byte-offset
                                npm error extraneous: date-and-time@ /opt/iobroker/node_modules/date-and-time
                                npm error extraneous: dayjs@ /opt/iobroker/node_modules/dayjs
                                npm error extraneous: decache@4.6.2 /opt/iobroker/node_modules/decache
                                npm error extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
                                npm error extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
                                npm error extraneous: define-lazy-prop@2.0.0 /opt/iobroker/node_modules/define-lazy-prop
                                npm error extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
                                npm error extraneous: digest-header@1.1.0 /opt/iobroker/node_modules/digest-header
                                npm error extraneous: diskusage@1.2.0 /opt/iobroker/node_modules/diskusage
                                npm error extraneous: domexception@4.0.0 /opt/iobroker/node_modules/domexception
                                npm error extraneous: draftlog@1.0.13 /opt/iobroker/node_modules/draftlog
                                npm error extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
                                npm error extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
                                npm error extraneous: eastasianwidth@0.2.0 /opt/iobroker/node_modules/eastasianwidth
                                npm error extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
                                npm error extraneous: echarts@ /opt/iobroker/node_modules/echarts
                                npm error extraneous: emoji-regex@9.2.2 /opt/iobroker/node_modules/emoji-regex
                                npm error extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
                                npm error extraneous: entities@4.5.0 /opt/iobroker/node_modules/entities
                                npm error extraneous: err-code@2.0.3 /opt/iobroker/node_modules/err-code
                                npm error extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
                                npm error extraneous: es-aggregate-error@1.0.13 /opt/iobroker/node_modules/es-aggregate-error
                                npm error extraneous: es-object-atoms@1.0.0 /opt/iobroker/node_modules/es-object-atoms
                                npm error extraneous: es-set-tostringtag@2.0.3 /opt/iobroker/node_modules/es-set-tostringtag
                                npm error extraneous: es-to-primitive@1.2.1 /opt/iobroker/node_modules/es-to-primitive
                                npm error extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
                                npm error extraneous: es6-promisify@5.0.0 /opt/iobroker/node_modules/es6-promisify
                                npm error extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
                                npm error extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
                                npm error extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
                                npm error extraneous: express-fileupload@1.5.1 /opt/iobroker/node_modules/express-fileupload
                                npm error extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
                                npm error extraneous: fast-fifo@1.3.2 /opt/iobroker/node_modules/fast-fifo
                                npm error extraneous: fast-json-stable-stringify@2.1.0 /opt/iobroker/node_modules/fast-json-stable-stringify
                                npm error extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
                                npm error extraneous: fast-unique-numbers@8.0.13 /opt/iobroker/node_modules/fast-unique-numbers
                                npm error extraneous: fast-uri@3.0.1 /opt/iobroker/node_modules/fast-uri
                                npm error extraneous: fast-xml-parser@4.4.1 /opt/iobroker/node_modules/fast-xml-parser
                                npm error extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
                                npm error extraneous: file-stream-rotator@0.6.1 /opt/iobroker/node_modules/file-stream-rotator
                                npm error extraneous: file-type@10.11.0 /opt/iobroker/node_modules/file-type
                                npm error extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
                                npm error extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
                                npm error extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
                                npm error extraneous: foreground-child@3.3.0 /opt/iobroker/node_modules/foreground-child
                                npm error extraneous: from@0.1.7 /opt/iobroker/node_modules/from
                                npm error extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
                                npm error extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
                                npm error extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
                                npm error extraneous: function.prototype.name@1.1.6 /opt/iobroker/node_modules/function.prototype.name
                                npm error extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
                                npm error extraneous: futoin-hkdf@1.4.3 /opt/iobroker/node_modules/futoin-hkdf
                                npm error extraneous: gaxios@5.1.3 /opt/iobroker/node_modules/gaxios
                                npm error extraneous: gcp-metadata@5.3.0 /opt/iobroker/node_modules/gcp-metadata
                                npm error extraneous: get-ssl-certificate@2.3.3 /opt/iobroker/node_modules/get-ssl-certificate
                                npm error extraneous: get-symbol-description@1.0.2 /opt/iobroker/node_modules/get-symbol-description
                                npm error extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
                                npm error extraneous: glob@10.4.5 /opt/iobroker/node_modules/glob
                                npm error extraneous: globalthis@1.0.4 /opt/iobroker/node_modules/globalthis
                                npm error extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
                                npm error extraneous: google-auth-library@8.9.0 /opt/iobroker/node_modules/google-auth-library
                                npm error extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
                                npm error extraneous: googleapis-common@6.0.4 /opt/iobroker/node_modules/googleapis-common
                                npm error extraneous: googleapis@ /opt/iobroker/node_modules/googleapis
                                npm error extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
                                npm error extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
                                npm error extraneous: has-tostringtag@1.0.2 /opt/iobroker/node_modules/has-tostringtag
                                npm error extraneous: he@1.2.0 /opt/iobroker/node_modules/he
                                npm error extraneous: help-me@5.0.0 /opt/iobroker/node_modules/help-me
                                npm error extraneous: homebridge-plugin-wrapper@ /opt/iobroker/node_modules/homebridge-plugin-wrapper
                                npm error extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
                                npm error extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
                                npm error extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
                                npm error extraneous: https@1.0.0 /opt/iobroker/node_modules/https
                                npm error extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
                                npm error extraneous: ical.js@1.5.0 /opt/iobroker/node_modules/ical.js
                                npm error extraneous: image-type@4.1.0 /opt/iobroker/node_modules/image-type
                                npm error extraneous: infer-owner@1.0.4 /opt/iobroker/node_modules/infer-owner
                                npm error extraneous: internal-slot@1.0.7 /opt/iobroker/node_modules/internal-slot
                                npm error extraneous: iobroker-adapter-helpers@0.0.8 /opt/iobroker/node_modules/iobroker-adapter-helpers
                                npm error invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
                                npm error invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
                                npm error invalid: iobroker.calendar@ /opt/iobroker/node_modules/iobroker.calendar
                                npm error invalid: iobroker.discovery@ /opt/iobroker/node_modules/iobroker.discovery
                                npm error invalid: iobroker.echarts@ /opt/iobroker/node_modules/iobroker.echarts
                                npm error invalid: iobroker.energiefluss@ /opt/iobroker/node_modules/iobroker.energiefluss
                                npm error invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
                                npm error invalid: iobroker.gartenbewaesserung@ /opt/iobroker/node_modules/iobroker.gartenbewaesserung
                                npm error invalid: iobroker.ham@ /opt/iobroker/node_modules/iobroker.ham
                                npm error invalid: iobroker.ical@ /opt/iobroker/node_modules/iobroker.ical
                                npm error invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
                                npm error invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
                                npm error invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
                                npm error invalid: iobroker.material@ /opt/iobroker/node_modules/iobroker.material
                                npm error invalid: iobroker.milight-smart-light@ /opt/iobroker/node_modules/iobroker.milight-smart-light
                                npm error invalid: iobroker.mobile@ /opt/iobroker/node_modules/iobroker.mobile
                                npm error invalid: iobroker.modbus@ /opt/iobroker/node_modules/iobroker.modbus
                                npm error invalid: iobroker.mqtt@ /opt/iobroker/node_modules/iobroker.mqtt
                                npm error invalid: iobroker.nina@ /opt/iobroker/node_modules/iobroker.nina
                                npm error invalid: iobroker.renault@ /opt/iobroker/node_modules/iobroker.renault
                                npm error invalid: iobroker.reolink@ /opt/iobroker/node_modules/iobroker.reolink
                                npm error invalid: iobroker.schoolfree@ /opt/iobroker/node_modules/iobroker.schoolfree
                                npm error invalid: iobroker.sourceanalytix@ /opt/iobroker/node_modules/iobroker.sourceanalytix
                                npm error invalid: iobroker.tankerkoenig@ /opt/iobroker/node_modules/iobroker.tankerkoenig
                                npm error invalid: iobroker.viessmannapi@ /opt/iobroker/node_modules/iobroker.viessmannapi
                                npm error invalid: iobroker.virtualpowermeter@ /opt/iobroker/node_modules/iobroker.virtualpowermeter
                                npm error invalid: iobroker.vis-2-widgets-material@ /opt/iobroker/node_modules/iobroker.vis-2-widgets-material
                                npm error invalid: iobroker.vis-2@ /opt/iobroker/node_modules/iobroker.vis-2
                                npm error invalid: iobroker.vis-materialdesign@ /opt/iobroker/node_modules/iobroker.vis-materialdesign
                                npm error invalid: iobroker.vis-metro@ /opt/iobroker/node_modules/iobroker.vis-metro
                                npm error invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
                                npm error invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
                                npm error invalid: iobroker.vofo-speedtest@ /opt/iobroker/node_modules/iobroker.vofo-speedtest
                                npm error invalid: iobroker.web-speedy@ /opt/iobroker/node_modules/iobroker.web-speedy
                                npm error invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
                                npm error invalid: iobroker.webcal@ /opt/iobroker/node_modules/iobroker.webcal
                                npm error extraneous: ioredis@4.28.5 /opt/iobroker/node_modules/ioredis
                                npm error extraneous: ip-address@9.0.5 /opt/iobroker/node_modules/ip-address
                                npm error extraneous: ip-regex@4.3.0 /opt/iobroker/node_modules/ip-regex
                                npm error extraneous: ipaddr.js@2.2.0 /opt/iobroker/node_modules/ipaddr.js
                                npm error extraneous: is-array-buffer@3.0.4 /opt/iobroker/node_modules/is-array-buffer
                                npm error extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
                                npm error extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
                                npm error extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
                                npm error extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
                                npm error extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
                                npm error extraneous: is-data-view@1.0.1 /opt/iobroker/node_modules/is-data-view
                                npm error extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
                                npm error extraneous: is-empty-object@1.1.1 /opt/iobroker/node_modules/is-empty-object
                                npm error extraneous: is-lambda@1.0.1 /opt/iobroker/node_modules/is-lambda
                                npm error extraneous: is-negative-zero@2.0.3 /opt/iobroker/node_modules/is-negative-zero
                                npm error extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
                                npm error extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
                                npm error extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
                                npm error extraneous: is-shared-array-buffer@1.0.3 /opt/iobroker/node_modules/is-shared-array-buffer
                                npm error extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
                                npm error extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
                                npm error extraneous: is-typed-array@1.1.13 /opt/iobroker/node_modules/is-typed-array
                                npm error extraneous: is-url@1.2.4 /opt/iobroker/node_modules/is-url
                                npm error extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
                                npm error extraneous: is@3.3.0 /opt/iobroker/node_modules/is
                                npm error extraneous: is2@2.0.9 /opt/iobroker/node_modules/is2
                                npm error extraneous: jackspeak@3.4.3 /opt/iobroker/node_modules/jackspeak
                                npm error extraneous: js-md4@0.3.2 /opt/iobroker/node_modules/js-md4
                                npm error extraneous: js-yaml@3.14.1 /opt/iobroker/node_modules/js-yaml
                                npm error extraneous: jsbi@4.3.0 /opt/iobroker/node_modules/jsbi
                                npm error extraneous: jsbn@1.1.0 /opt/iobroker/node_modules/jsbn
                                npm error extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
                                npm error extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
                                npm error extraneous: json-schema-traverse@1.0.0 /opt/iobroker/node_modules/json-schema-traverse
                                npm error extraneous: json5@2.2.3 /opt/iobroker/node_modules/json5
                                npm error extraneous: jsonata@2.0.5 /opt/iobroker/node_modules/jsonata
                                npm error extraneous: jsonc-parser@3.3.1 /opt/iobroker/node_modules/jsonc-parser
                                npm error extraneous: jsonwebtoken@9.0.2 /opt/iobroker/node_modules/jsonwebtoken
                                npm error extraneous: jszip@3.10.1 /opt/iobroker/node_modules/jszip
                                npm error extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
                                npm error extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
                                npm error extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
                                npm error extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
                                npm error extraneous: lazystream@1.0.1 /opt/iobroker/node_modules/lazystream
                                npm error extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
                                npm error extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
                                npm error extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
                                npm error extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
                                npm error extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
                                npm error extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
                                npm error extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
                                npm error extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
                                npm error extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
                                npm error extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
                                npm error extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
                                npm error extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
                                npm error extraneous: logform@2.6.1 /opt/iobroker/node_modules/logform
                                npm error extraneous: long@5.2.3 /opt/iobroker/node_modules/long
                                npm error extraneous: make-fetch-happen@10.2.1 /opt/iobroker/node_modules/make-fetch-happen
                                npm error extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
                                npm error extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
                                npm error extraneous: mime-db@1.53.0 /opt/iobroker/node_modules/mime-db
                                npm error extraneous: minimatch@9.0.5 /opt/iobroker/node_modules/minimatch
                                npm error extraneous: minipass-collect@1.0.2 /opt/iobroker/node_modules/minipass-collect
                                npm error extraneous: minipass-fetch@2.1.2 /opt/iobroker/node_modules/minipass-fetch
                                npm error extraneous: minipass-flush@1.0.5 /opt/iobroker/node_modules/minipass-flush
                                npm error extraneous: minipass-pipeline@1.2.4 /opt/iobroker/node_modules/minipass-pipeline
                                npm error extraneous: minipass-sized@1.0.3 /opt/iobroker/node_modules/minipass-sized
                                npm error extraneous: minipass@7.1.2 /opt/iobroker/node_modules/minipass
                                npm error extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
                                npm error extraneous: mock-require@3.0.3 /opt/iobroker/node_modules/mock-require
                                npm error extraneous: moment-duration-format@2.3.2 /opt/iobroker/node_modules/moment-duration-format
                                npm error extraneous: mqtt-connection@4.1.0 /opt/iobroker/node_modules/mqtt-connection
                                npm error extraneous: mqtt-packet@9.0.0 /opt/iobroker/node_modules/mqtt-packet
                                npm error extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
                                npm error extraneous: nanoid@3.3.7 /opt/iobroker/node_modules/nanoid
                                npm error extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
                                npm error extraneous: native-duplexpair@1.0.0 /opt/iobroker/node_modules/native-duplexpair
                                npm error extraneous: nconf@0.10.0 /opt/iobroker/node_modules/nconf
                                npm error extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
                                npm error extraneous: netmask@2.0.2 /opt/iobroker/node_modules/netmask
                                npm error extraneous: node-abi@3.65.0 /opt/iobroker/node_modules/node-abi
                                npm error extraneous: node-abort-controller@3.1.1 /opt/iobroker/node_modules/node-abort-controller
                                npm error extraneous: node-cron@2.0.3 /opt/iobroker/node_modules/node-cron
                                npm error extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
                                npm error extraneous: node-gyp@9.3.0 /opt/iobroker/node_modules/node-gyp
                                npm error extraneous: node-ical@0.16.1 /opt/iobroker/node_modules/node-ical
                                npm error extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                                npm error extraneous: node-libcurl@3.0.0 /opt/iobroker/node_modules/node-libcurl
                                npm error extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
                                npm error extraneous: node-persist@0.0.11 /opt/iobroker/node_modules/node-persist
                                npm error extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
                                npm error extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
                                npm error extraneous: node.extend@2.0.3 /opt/iobroker/node_modules/node.extend
                                npm error extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
                                npm error extraneous: nwsapi@2.2.12 /opt/iobroker/node_modules/nwsapi
                                npm error extraneous: object-hash@3.0.0 /opt/iobroker/node_modules/object-hash
                                npm error extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
                                npm error extraneous: onedrive-api@1.1.1 /opt/iobroker/node_modules/onedrive-api
                                npm error extraneous: opencollective-postinstall@2.0.3 /opt/iobroker/node_modules/opencollective-postinstall
                                npm error extraneous: ospath@1.2.2 /opt/iobroker/node_modules/ospath
                                npm error extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
                                npm error extraneous: otplib@11.0.1 /opt/iobroker/node_modules/otplib
                                npm error extraneous: p-throttle@4.1.1 /opt/iobroker/node_modules/p-throttle
                                npm error extraneous: package-json-from-dist@1.0.0 /opt/iobroker/node_modules/package-json-from-dist
                                npm error extraneous: pako@1.0.11 /opt/iobroker/node_modules/pako
                                npm error extraneous: parse5@7.1.2 /opt/iobroker/node_modules/parse5
                                npm error extraneous: passport@0.7.0 /opt/iobroker/node_modules/passport
                                npm error extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
                                npm error extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
                                npm error extraneous: path-scurry@1.11.1 /opt/iobroker/node_modules/path-scurry
                                npm error extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
                                npm error extraneous: pidusage@3.0.2 /opt/iobroker/node_modules/pidusage
                                npm error extraneous: ping@0.4.4 /opt/iobroker/node_modules/ping
                                npm error extraneous: pluralize@8.0.0 /opt/iobroker/node_modules/pluralize
                                npm error extraneous: possible-typed-array-names@1.0.0 /opt/iobroker/node_modules/possible-typed-array-names
                                npm error extraneous: prebuild-install@7.1.2 /opt/iobroker/node_modules/prebuild-install
                                npm error extraneous: promise-inflight@1.0.1 /opt/iobroker/node_modules/promise-inflight
                                npm error extraneous: promise-object@0.1.7 /opt/iobroker/node_modules/promise-object
                                npm error extraneous: promise-retry@2.0.1 /opt/iobroker/node_modules/promise-retry
                                npm error extraneous: promise-retryer@0.0.1 /opt/iobroker/node_modules/promise-retryer
                                npm error extraneous: promisify-child-process@4.1.2 /opt/iobroker/node_modules/promisify-child-process
                                npm error extraneous: prompt@1.3.0 /opt/iobroker/node_modules/prompt
                                npm error extraneous: protobufjs@ /opt/iobroker/node_modules/protobufjs
                                npm error extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
                                npm error extraneous: q@1.1.2 /opt/iobroker/node_modules/q
                                npm error extraneous: quasar@ /opt/iobroker/node_modules/quasar
                                npm error extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
                                npm error extraneous: read@1.0.7 /opt/iobroker/node_modules/read
                                npm error extraneous: readdir-glob@1.1.3 /opt/iobroker/node_modules/readdir-glob
                                npm error extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
                                npm error extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
                                npm error extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
                                npm error extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
                                npm error extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
                                npm error extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
                                npm error extraneous: regenerator-runtime@0.14.1 /opt/iobroker/node_modules/regenerator-runtime
                                npm error extraneous: regex-escape@3.4.10 /opt/iobroker/node_modules/regex-escape
                                npm error extraneous: regexp.prototype.flags@1.5.2 /opt/iobroker/node_modules/regexp.prototype.flags
                                npm error extraneous: remove-trailing-separator@1.1.0 /opt/iobroker/node_modules/remove-trailing-separator
                                npm error extraneous: require-from-string@2.0.2 /opt/iobroker/node_modules/require-from-string
                                npm error extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
                                npm error extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
                                npm error extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
                                npm error extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
                                npm error extraneous: rrule@2.8.1 /opt/iobroker/node_modules/rrule
                                npm error extraneous: rrweb-cssom@0.6.0 /opt/iobroker/node_modules/rrweb-cssom
                                npm error extraneous: safe-array-concat@1.1.2 /opt/iobroker/node_modules/safe-array-concat
                                npm error extraneous: safe-regex-test@1.0.3 /opt/iobroker/node_modules/safe-regex-test
                                npm error extraneous: safe-stable-stringify@2.4.3 /opt/iobroker/node_modules/safe-stable-stringify
                                npm error extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
                                npm error extraneous: secure-keys@1.0.0 /opt/iobroker/node_modules/secure-keys
                                npm error extraneous: seq-logging@1.1.2 /opt/iobroker/node_modules/seq-logging
                                npm error extraneous: set-function-name@2.0.2 /opt/iobroker/node_modules/set-function-name
                                npm error extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
                                npm error extraneous: signal-exit@4.1.0 /opt/iobroker/node_modules/signal-exit
                                npm error extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
                                npm error extraneous: smart-buffer@4.2.0 /opt/iobroker/node_modules/smart-buffer
                                npm error extraneous: socks-proxy-agent@7.0.0 /opt/iobroker/node_modules/socks-proxy-agent
                                npm error extraneous: socks@2.8.3 /opt/iobroker/node_modules/socks
                                npm error extraneous: speedtest-net@1.6.2 /opt/iobroker/node_modules/speedtest-net
                                npm error extraneous: sprintf-js@1.1.3 /opt/iobroker/node_modules/sprintf-js
                                npm error extraneous: ssri@9.0.1 /opt/iobroker/node_modules/ssri
                                npm error extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
                                npm error extraneous: stampit-event-bus@0.1.1 /opt/iobroker/node_modules/stampit-event-bus
                                npm error extraneous: stampit-state-machine@0.2.1 /opt/iobroker/node_modules/stampit-state-machine
                                npm error extraneous: stampit@2.1.2 /opt/iobroker/node_modules/stampit
                                npm error extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
                                npm error extraneous: stoppable@1.1.0 /opt/iobroker/node_modules/stoppable
                                npm error extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
                                npm error extraneous: streamsearch@1.1.0 /opt/iobroker/node_modules/streamsearch
                                npm error extraneous: streamx@2.18.0 /opt/iobroker/node_modules/streamx
                                npm error extraneous: string-argv@0.3.2 /opt/iobroker/node_modules/string-argv
                                npm error extraneous: string-width-cjs@npm:string-width@4.2.3 /opt/iobroker/node_modules/string-width-cjs
                                npm error extraneous: string-width@5.1.2 /opt/iobroker/node_modules/string-width
                                npm error extraneous: string.prototype.trim@1.2.9 /opt/iobroker/node_modules/string.prototype.trim
                                npm error extraneous: string.prototype.trimend@1.0.8 /opt/iobroker/node_modules/string.prototype.trimend
                                npm error extraneous: string.prototype.trimstart@1.0.8 /opt/iobroker/node_modules/string.prototype.trimstart
                                npm error extraneous: strip-ansi-cjs@npm:strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi-cjs
                                npm error extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
                                npm error extraneous: suncalc@1.9.0 /opt/iobroker/node_modules/suncalc
                                npm error extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                                npm error extraneous: supermixer@1.0.5 /opt/iobroker/node_modules/supermixer
                                npm error extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
                                npm error extraneous: sweet-collections@1.1.0 /opt/iobroker/node_modules/sweet-collections
                                npm error extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
                                npm error extraneous: systeminformation@5.23.4 /opt/iobroker/node_modules/systeminformation
                                npm error extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
                                npm error extraneous: tar-stream@3.1.7 /opt/iobroker/node_modules/tar-stream
                                npm error extraneous: tcp-port-used@1.0.2 /opt/iobroker/node_modules/tcp-port-used
                                npm error extraneous: text-decoder@1.1.1 /opt/iobroker/node_modules/text-decoder
                                npm error extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
                                npm error extraneous: thirty-two@1.0.2 /opt/iobroker/node_modules/thirty-two
                                npm error extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
                                npm error extraneous: tiny-typed-emitter@2.1.0 /opt/iobroker/node_modules/tiny-typed-emitter
                                npm error extraneous: tinycolor2@1.6.0 /opt/iobroker/node_modules/tinycolor2
                                npm error extraneous: tr46@4.1.1 /opt/iobroker/node_modules/tr46
                                npm error extraneous: triple-beam@1.4.1 /opt/iobroker/node_modules/triple-beam
                                npm error extraneous: tsdav@2.1.1 /opt/iobroker/node_modules/tsdav
                                npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/tslib
                                npm error extraneous: typed-array-buffer@1.0.2 /opt/iobroker/node_modules/typed-array-buffer
                                npm error extraneous: typed-array-byte-length@1.0.1 /opt/iobroker/node_modules/typed-array-byte-length
                                npm error extraneous: typed-array-byte-offset@1.0.2 /opt/iobroker/node_modules/typed-array-byte-offset
                                npm error extraneous: typed-array-length@1.0.6 /opt/iobroker/node_modules/typed-array-length
                                npm error extraneous: typedarray.prototype.slice@1.0.3 /opt/iobroker/node_modules/typedarray.prototype.slice
                                npm error extraneous: typescript@ /opt/iobroker/node_modules/typescript
                                npm error extraneous: tz-offset@0.0.1 /opt/iobroker/node_modules/tz-offset
                                npm error extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
                                npm error extraneous: unique-filename@2.0.1 /opt/iobroker/node_modules/unique-filename
                                npm error extraneous: unique-slug@3.0.0 /opt/iobroker/node_modules/unique-slug
                                npm error extraneous: unix-dgram@2.0.6 /opt/iobroker/node_modules/unix-dgram
                                npm error extraneous: uri-js@4.4.1 /opt/iobroker/node_modules/uri-js
                                npm error extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
                                npm error extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
                                npm error extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                                npm error extraneous: vue-i18n@8.28.2 /opt/iobroker/node_modules/vue-i18n
                                npm error extraneous: vuelidate-messages@0.1.2 /opt/iobroker/node_modules/vuelidate-messages
                                npm error extraneous: vuelidate@0.7.7 /opt/iobroker/node_modules/vuelidate
                                npm error extraneous: vuex-map-fields@1.4.1 /opt/iobroker/node_modules/vuex-map-fields
                                npm error extraneous: w3c-xmlserializer@4.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
                                npm error extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                                npm error extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
                                npm error extraneous: webdav@4.11.3 /opt/iobroker/node_modules/webdav
                                npm error extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
                                npm error extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
                                npm error extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
                                npm error extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
                                npm error extraneous: whatwg-url@12.0.1 /opt/iobroker/node_modules/whatwg-url
                                npm error extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
                                npm error extraneous: which-typed-array@1.1.15 /opt/iobroker/node_modules/which-typed-array
                                npm error extraneous: window-size@0.1.4 /opt/iobroker/node_modules/window-size
                                npm error extraneous: winston-daily-rotate-file@5.0.0 /opt/iobroker/node_modules/winston-daily-rotate-file
                                npm error extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
                                npm error extraneous: winston-syslog@2.7.1 /opt/iobroker/node_modules/winston-syslog
                                npm error extraneous: winston-transport@4.7.1 /opt/iobroker/node_modules/winston-transport
                                npm error extraneous: winston@3.14.2 /opt/iobroker/node_modules/winston
                                npm error extraneous: worker-timers-broker@6.1.8 /opt/iobroker/node_modules/worker-timers-broker
                                npm error extraneous: worker-timers-worker@7.0.71 /opt/iobroker/node_modules/worker-timers-worker
                                npm error extraneous: worker-timers@7.1.8 /opt/iobroker/node_modules/worker-timers
                                npm error extraneous: wrap-ansi-cjs@npm:wrap-ansi@7.0.0 /opt/iobroker/node_modules/wrap-ansi-cjs
                                npm error extraneous: wrap-ansi@8.1.0 /opt/iobroker/node_modules/wrap-ansi
                                npm error extraneous: xml-js@1.6.11 /opt/iobroker/node_modules/xml-js
                                npm error extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
                                npm error extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
                                npm error extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
                                npm error extraneous: zip-stream@6.0.1 /opt/iobroker/node_modules/zip-stream
                                npm error extraneous: zrender@ /opt/iobroker/node_modules/zrender
                                npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-19T19_53_39_857Z-debug-0.log
                                flo@ioBrokerdebian:/opt/iobroker$
                                  Thomas Braun Most Active @flommaster last edited by
                                  @flommaster
                                  groups
                                    flommaster @Thomas Braun last edited by
                                    @thomas-braun sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                                    groups
                                    flo@ioBrokerdebian:/opt/iobroker$ groups
                                    flo adm cdrom floppy sudo audio dip video plugdev netdev iobroker
                                      @flommaster
                                      Das passt. Was mich wundert ist die Frage nach sudo und passwort oben. Das sollte eigentlich nicht kommen bei den Gruppen. Außer du hast dir per root da komplett das Rechtegefüge zerdeppert...
                                      iob fix
                                      sagt?
                                        iob fix
                                        Da will er wieder das Passwort für sudo...
                                        flo@ioBrokerdebian:/opt/iobroker$ iob fix
                                        library: loaded
                                        Library version=2024-05-24
                                            Welcome to the ioBroker installation fixer!
                                            Script version: 2024-01-04
                                            You might need to enter your password a couple of times.
                                            Installing prerequisites (1/5)
                                        [sudo] Passwort für flo:
                                        OK:1 http://deb.debian.org/debian bookworm InRelease
                                        Holen:2 http://deb.debian.org/debian bookworm-updates InRelease [55,4 kB]
                                        Holen:3 http://deb.debian.org/debian-security bookworm-security InRelease [48,0 kB]
                                        OK:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                                        Holen:5 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages [170 kB]
                                        Holen:6 http://deb.debian.org/debian-security bookworm-security/main Translation-en [103 kB]
                                        Es wurden 377 kB in 1 s geholt (342 kB/s).
                                        Paketlisten werden gelesen… Fertig
                                            Checking ioBroker user and directory permissions (2/5)
                                        Created /etc/sudoers.d/iobroker
                                        Fixing directory permissions...
                                            Check and cleanup npm temporary directories (3/5)
                                        Done.
                                            Database maintenance (4/5)
                                        Checking for uncompressed JSONL databases... This might take a while!
                                        Compressing /opt/iobroker/iobroker-data/objects.jsonl
                                        Compressed 1 JSONL files. Done
                                            Checking autostart (5/5)
                                        Enabling autostart...
                                        Autostart enabled!
                                            Your installation was fixed successfully
                                            Run iobroker start to start ioBroker again!
                                          @flommaster sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                                          Da ergibt das auch Sinn.
                                            Thomas Braun Most Active @flommaster last edited by Thomas Braun
                                            @flommaster
                                            Alles wird im Verzeichnis /opt/iobroker aufgerufen:
                                            npm prune
                                            npm ls
                                            6345
