[gelöst] "node-gyp rebuild" wird ausgeführt - Warum?
@gaspode
Alles gemacht wie du geschrieben hast. Fehler kommt noch.
Mit js-controller 5.0.19 kommt er nicht.
Seltsam. -
@sigi234 said in [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?:
Hast du auch Diskusage manuell installiert?
Im ioBroker Root Verzeichnis:npm i diskusageGing das fehlerfrei?
@gaspode sagte in [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?:
********************************************************** *** Welcome to ioBroker. *** *** *** *** Type 'iob help' for list of instructions. *** *** For more help see *** *** https://github.com/ioBroker/ioBroker.docs *** ********************************************************** Your environment has been set up for using Node.js 20.16.0 (x64) and npm. C:\SmartHome>npm i diskusage npm error code 1 npm error path C:\SmartHome\node_modules\diskusage npm error command failed npm error command C:\WINDOWS\system32\cmd.exe /d /s /c node-gyp rebuild npm error gyp info it worked if it ends with ok npm error gyp info using node-gyp@10.1.0 npm error gyp info using node@20.16.0 | win32 | x64 npm error gyp info find Python using Python version 3.12.4 found at "C:\Users\Sigi\AppData\Local\Programs\Python\Python312\python.exe" npm error gyp ERR! find VS npm error gyp ERR! find VS msvs_version not set from command line or npm config npm error gyp ERR! find VS VCINSTALLDIR not set, not running in VS Command Prompt npm error gyp ERR! find VS could not use PowerShell to find Visual Studio 2017 or newer, try re-running with '--loglevel silly' for more details. npm error gyp ERR! find VS npm error gyp ERR! find VS Failure details: undefined npm error gyp ERR! find VS checking VS2022 (17.11.35208.52) found at: npm error gyp ERR! find VS "C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools" npm error gyp ERR! find VS - found "Visual Studio C++ core features" npm error gyp ERR! find VS - missing any VC++ toolset npm error gyp ERR! find VS could not find a version of Visual Studio 2017 or newer to use npm error gyp ERR! find VS could not use PowerShell to find Visual Studio 2017 or newer, try re-running with '--loglevel silly' for more details. npm error gyp ERR! find VS npm error gyp ERR! find VS Failure details: undefined npm error gyp ERR! find VS unsupported version "17.11.35208.52" found at "C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools" npm error gyp ERR! find VS could not find a version of Visual Studio 2017 or newer to use npm error gyp ERR! find VS not looking for VS2015 as it is only supported up to Node.js 18 npm error gyp ERR! find VS not looking for VS2013 as it is only supported up to Node.js 8 npm error gyp ERR! find VS npm error gyp ERR! find VS ************************************************************** npm error gyp ERR! find VS You need to install the latest version of Visual Studio npm error gyp ERR! find VS including the "Desktop development with C++" workload. npm error gyp ERR! find VS For more information consult the documentation at: npm error gyp ERR! find VS https://github.com/nodejs/node-gyp#on-windows npm error gyp ERR! find VS ************************************************************** npm error gyp ERR! find VS npm error gyp ERR! configure error npm error gyp ERR! stack Error: Could not find any Visual Studio installation to use npm error gyp ERR! stack at VisualStudioFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:116:11) npm error gyp ERR! stack at VisualStudioFinder.findVisualStudio (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:72:17) npm error gyp ERR! stack at process.processTicksAndRejections (node:internal/process/task_queues:95:5) npm error gyp ERR! stack at async createBuildDir (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:95:26) npm error gyp ERR! stack at async run (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js:81:18) npm error gyp ERR! System Windows_NT 10.0.19045 npm error gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild" npm error gyp ERR! cwd C:\SmartHome\node_modules\diskusage npm error gyp ERR! node -v v20.16.0 npm error gyp ERR! node-gyp -v v10.1.0 npm error gyp ERR! not ok npm error A complete log of this run can be found in: C:\Users\Sigi\AppData\Local\npm-cache\_logs\2024-08-20T06_57_48_846Z-debug-0.log C:\SmartHome>
Ich schätze mal, das liegt daran:
npm error gyp ERR! find VS unsupported version "17.11.35208.52" found at "C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools"Sorry, da hab ich dich weiter oben wohl auf die falsche Fährte geschickt. Bei mir laufen die Build Tools 2019 auf dem Testrechner und 2017 auf dem Produktivrechner, also evtl. mal damit versuchen (ich hab es im Beitrag oben mal auf 2019 angepasst).
********************************************************** *** Welcome to ioBroker. *** *** *** *** Type 'iob help' for list of instructions. *** *** For more help see *** *** https://github.com/ioBroker/ioBroker.docs *** ********************************************************** Your environment has been set up for using Node.js 20.16.0 (x64) and npm. C:\SmartHome>npm i diskusage npm error code 1 npm error path C:\SmartHome\node_modules\diskusage npm error command failed npm error command C:\WINDOWS\system32\cmd.exe /d /s /c node-gyp rebuild npm error gyp info it worked if it ends with ok npm error gyp info using node-gyp@10.1.0 npm error gyp info using node@20.16.0 | win32 | x64 npm error gyp ERR! find Python npm error gyp ERR! find Python Python is not set from command line or npm configuration npm error gyp ERR! find Python Python is not set from environment variable PYTHON npm error gyp ERR! find Python checking if the py launcher can be used to find Python 3 npm error gyp ERR! find Python - executable path is "" npm error gyp ERR! find Python - "" could not be run npm error gyp ERR! find Python checking if "python3" can be used npm error gyp ERR! find Python - executable path is "" npm error gyp ERR! find Python - "" could not be run npm error gyp ERR! find Python checking if "python" can be used npm error gyp ERR! find Python - executable path is "" npm error gyp ERR! find Python - "" could not be run npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python311\python.exe npm error gyp ERR! find Python - version is "" npm error gyp ERR! find Python - version is - should be >=3.6.0 npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python311\python.exe" could not be run npm error gyp ERR! find Python checking if Python is C:\Program Files\Python311\python.exe npm error gyp ERR! find Python - version is "" npm error gyp ERR! find Python - version is - should be >=3.6.0 npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED npm error gyp ERR! find Python - "C:\Program Files\Python311\python.exe" could not be run npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python311-32\python.exe npm error gyp ERR! find Python - version is "" npm error gyp ERR! find Python - version is - should be >=3.6.0 npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python311-32\python.exe" could not be run npm error gyp ERR! find Python checking if Python is C:\Program Files\Python311-32\python.exe npm error gyp ERR! find Python - version is "" npm error gyp ERR! find Python - version is - should be >=3.6.0 npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED npm error gyp ERR! find Python - "C:\Program Files\Python311-32\python.exe" could not be run npm error gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python311-32\python.exe npm error gyp ERR! find Python - version is "" npm error gyp ERR! find Python - version is - should be >=3.6.0 npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED npm error gyp ERR! find Python - "C:\Program Files (x86)\Python311-32\python.exe" could not be run npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python310\python.exe npm error gyp ERR! find Python - version is "" npm error gyp ERR! find Python - version is - should be >=3.6.0 npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python310\python.exe" could not be run npm error gyp ERR! find Python checking if Python is C:\Program Files\Python310\python.exe npm error gyp ERR! find Python - version is "" npm error gyp ERR! find Python - version is - should be >=3.6.0 npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED npm error gyp ERR! find Python - "C:\Program Files\Python310\python.exe" could not be run npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python310-32\python.exe npm error gyp ERR! find Python - version is "" npm error gyp ERR! find Python - version is - should be >=3.6.0 npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python310-32\python.exe" could not be run npm error gyp ERR! find Python checking if Python is C:\Program Files\Python310-32\python.exe npm error gyp ERR! find Python - version is "" npm error gyp ERR! find Python - version is - should be >=3.6.0 npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED npm error gyp ERR! find Python - "C:\Program Files\Python310-32\python.exe" could not be run npm error gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python310-32\python.exe npm error gyp ERR! find Python - version is "" npm error gyp ERR! find Python - version is - should be >=3.6.0 npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED npm error gyp ERR! find Python - "C:\Program Files (x86)\Python310-32\python.exe" could not be run npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python39\python.exe npm error gyp ERR! find Python - version is "" npm error gyp ERR! find Python - version is - should be >=3.6.0 npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python39\python.exe" could not be run npm error gyp ERR! find Python checking if Python is C:\Program Files\Python39\python.exe npm error gyp ERR! find Python - version is "" npm error gyp ERR! find Python - version is - should be >=3.6.0 npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED npm error gyp ERR! find Python - "C:\Program Files\Python39\python.exe" could not be run npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python39-32\python.exe npm error gyp ERR! find Python - version is "" npm error gyp ERR! find Python - version is - should be >=3.6.0 npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python39-32\python.exe" could not be run npm error gyp ERR! find Python checking if Python is C:\Program Files\Python39-32\python.exe npm error gyp ERR! find Python - version is "" npm error gyp ERR! find Python - version is - should be >=3.6.0 npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED npm error gyp ERR! find Python - "C:\Program Files\Python39-32\python.exe" could not be run npm error gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python39-32\python.exe npm error gyp ERR! find Python - version is "" npm error gyp ERR! find Python - version is - should be >=3.6.0 npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED npm error gyp ERR! find Python - "C:\Program Files (x86)\Python39-32\python.exe" could not be run npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python38\python.exe npm error gyp ERR! find Python - version is "" npm error gyp ERR! find Python - version is - should be >=3.6.0 npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python38\python.exe" could not be run npm error gyp ERR! find Python checking if Python is C:\Program Files\Python38\python.exe npm error gyp ERR! find Python - version is "" npm error gyp ERR! find Python - version is - should be >=3.6.0 npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED npm error gyp ERR! find Python - "C:\Program Files\Python38\python.exe" could not be run npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python38-32\python.exe npm error gyp ERR! find Python - version is "" npm error gyp ERR! find Python - version is - should be >=3.6.0 npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python38-32\python.exe" could not be run npm error gyp ERR! find Python checking if Python is C:\Program Files\Python38-32\python.exe npm error gyp ERR! find Python - version is "" npm error gyp ERR! find Python - version is - should be >=3.6.0 npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED npm error gyp ERR! find Python - "C:\Program Files\Python38-32\python.exe" could not be run npm error gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python38-32\python.exe npm error gyp ERR! find Python - version is "" npm error gyp ERR! find Python - version is - should be >=3.6.0 npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED npm error gyp ERR! find Python - "C:\Program Files (x86)\Python38-32\python.exe" could not be run npm error gyp ERR! find Python npm error gyp ERR! find Python ********************************************************** npm error gyp ERR! find Python You need to install the latest version of Python. npm error gyp ERR! find Python Node-gyp should be able to find and use Python. If not, npm error gyp ERR! find Python you can try one of the following options: npm error gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe" npm error gyp ERR! find Python (accepted by both node-gyp and npm) npm error gyp ERR! find Python - Set the environment variable PYTHON npm error gyp ERR! find Python - Set the npm configuration variable python: npm error gyp ERR! find Python npm config set python "C:\Path\To\python.exe" npm error gyp ERR! find Python For more information consult the documentation at: npm error gyp ERR! find Python https://github.com/nodejs/node-gyp#installation npm error gyp ERR! find Python ********************************************************** npm error gyp ERR! find Python npm error gyp ERR! configure error npm error gyp ERR! stack Error: Could not find any Python installation to use npm error gyp ERR! stack at PythonFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:306:11) npm error gyp ERR! stack at PythonFinder.findPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:164:17) npm error gyp ERR! stack at process.processTicksAndRejections (node:internal/process/task_queues:95:5) npm error gyp ERR! stack at async configure (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:27:18) npm error gyp ERR! stack at async run (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js:81:18) npm error gyp ERR! System Windows_NT 10.0.19045 npm error gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild" npm error gyp ERR! cwd C:\SmartHome\node_modules\diskusage npm error gyp ERR! node -v v20.16.0 npm error gyp ERR! node-gyp -v v10.1.0 npm error gyp ERR! not ok npm error A complete log of this run can be found in: C:\Users\Sigi\AppData\Local\npm-cache\_logs\2024-08-20T07_42_55_666Z-debug-0.log C:\SmartHome>python3 ???
@gaspode
Da frage ich mich welcher Adapter braucht das Ganze eigentlich? -
Gute Frage, ich finde nur eine optionale Dependency in node_modules@iobroker\js-controller-common-db\package.json
@foxriver76 , eine Idee?
python3 ???
Steht Python 2.7. auch im Pfad? Was passiert denn, wenn du in der iob Shell
pythoneingibst?
@gaspode ja das ist genau die Stelle, ist auch nur optional https://github.com/jduncanator/node-diskusage/issues/48
Damit schauen wir wie viel Speicher noch frei ist auf den Systemen um das im Admin etc anzuzeigen
@foxriver76 said in [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?:
Ja, dass die Dependency optional ist, hatte ich ja geschrieben. Anscheinend verursacht sie dennoch das komische verhalten mit node-gyp.
Wenn ich diskusage aus meinem npm tree deinstalliere und lösche, wird zumindest unter Windows immer noch der korrekte Festplattenplatz angezeigt. Ist die Dependency also wirklich notwendig? Wie gesagt, es kommt halt auf einigen Systemen zu diesen Meldungen, das könnte evtl. bei einigen Usern zu Verwirrungen führen. Linux konnte ich jetzt noch nicht testen.
@gaspode puh war noch vor meiner Zeit als die Funktion implementiert wurde kann man mal checken ob alles ohne gehen würde mach gerne mal Controller issue bin die Woche im Urlaub
@gaspode said in [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?:
Edit:
Mit sauber konfiguriertem node-gyp ist das kein Problem, diese Voraussetzung dürfte auf den meisten Windos Systemen aber nicht erfüllt sein. -
Kann ich demnächst mal unter Linux testen und ggfs. ein Issue schreiben.
Ich wünsche dir einen schönen Urlaub, Danke, dass du trotzdem geantwortet hast.
@gaspode aber im Endeffekt muss man sagen ist es vollkommen ok, die optional dep kann nicht installiert werden Controller handelt das richtig, wenn sie da ist wird sie genutzt. Es ist halt blöd dass der User das sieht. Aber führt Admin denn das immer mit debug Flag aus? Ich denke das sollte nicht der Standard sein
python3 ???
pythoneingibst?
Da komme ich da hin:
@sigi234
OK, dann steht es wohl nicht im Pfad. Am schnellsten geht es wahrscheinlich, wenn du das manuell machst.Im Startmenü "Systemumgebungsvariablen" eingeben, Dialog öffnen, Karte "Erweitert" wählen, Umgebungsvariablen wählen, im oberen Bereich "Path" wählen, dann "Bearbeiten". "Neu" drücken und den Pfad zu deiner Python Exe eintragen, meist "C:\Python27" oder so.
Dann die iob Shell schließen und neu starten. Nochmal versuchen. -
Stimmt schon, auf der anderen Seite muss man ja nix mitschleppen, was nicht gebraucht wird, oder?
Im Admin wird ein Adapter Update ja anscheinend nicht immer mit debug Flag ausgeführt, ich muss mal ein wenig forschen. Wird aber dauern. Genieße deinen Urlaub.
@sigi234
Dann die iob Shell schließen und neu starten. Nochmal versuchen.Soll ich jetzt die 3 er installieren oder bei der 2.7 bleiben? Installieren wenn 3 in der cmd oder mit dem Downloadlink.
Sollte egal sein, die 2.7 hat den Vorteil, dass das wohl die offiziell von node-gyp empfohlene Version ist. Daher würde ich erst mal die ausprobieren, zumal die ja bereits installiert ist und wohl nur im Pfad fehlt.
npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python310\python.exe" could not be run npm error gyp ERR! find Python checking if Python is C:\Program Files\Python310\python.exeSelbe Meldung , es such noch immer im Falschen Verzeichnis?
Edit:
