    4. [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?
      sigi234 Forum Testing Most Active @Gaspode last edited by sigi234
      @gaspode
      ***               Welcome to ioBroker.                 ***
      ***     Type 'iob help' for list of instructions.      ***
      ***                For more help see                   ***
      ***     https://github.com/ioBroker/ioBroker.docs      ***
      Your environment has been set up for using Node.js 20.16.0 (x64) and npm.
      C:\SmartHome>npm i diskusage
      npm error code 1
      npm error path C:\SmartHome\node_modules\diskusage
      npm error command failed
      npm error command C:\WINDOWS\system32\cmd.exe /d /s /c node-gyp rebuild
      npm error gyp info it worked if it ends with ok
      npm error gyp info using node-gyp@10.1.0
      npm error gyp info using node@20.16.0 | win32 | x64
      npm error gyp ERR! find Python
      npm error gyp ERR! find Python Python is not set from command line or npm configuration
      npm error gyp ERR! find Python Python is not set from environment variable PYTHON
      npm error gyp ERR! find Python checking if the py launcher can be used to find Python 3
      npm error gyp ERR! find Python - executable path is ""
      npm error gyp ERR! find Python - "" could not be run
      npm error gyp ERR! find Python checking if "python3" can be used
      npm error gyp ERR! find Python checking if "python" can be used
      npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python311\python.exe
      npm error gyp ERR! find Python - version is ""
      npm error gyp ERR! find Python - version is  - should be >=3.6.0
      npm error gyp ERR! find Python - THIS VERSION OF PYTHON IS NOT SUPPORTED
      npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python311\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files\Python311\python.exe
      npm error gyp ERR! find Python - "C:\Program Files\Python311\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python311-32\python.exe
      npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python311-32\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files\Python311-32\python.exe
      npm error gyp ERR! find Python - "C:\Program Files\Python311-32\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python311-32\python.exe
      npm error gyp ERR! find Python - "C:\Program Files (x86)\Python311-32\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python310\python.exe
      npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python310\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files\Python310\python.exe
      npm error gyp ERR! find Python - "C:\Program Files\Python310\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python310-32\python.exe
      npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python310-32\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files\Python310-32\python.exe
      npm error gyp ERR! find Python - "C:\Program Files\Python310-32\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python310-32\python.exe
      npm error gyp ERR! find Python - "C:\Program Files (x86)\Python310-32\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python39\python.exe
      npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python39\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files\Python39\python.exe
      npm error gyp ERR! find Python - "C:\Program Files\Python39\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python39-32\python.exe
      npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python39-32\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files\Python39-32\python.exe
      npm error gyp ERR! find Python - "C:\Program Files\Python39-32\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python39-32\python.exe
      npm error gyp ERR! find Python - "C:\Program Files (x86)\Python39-32\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python38\python.exe
      npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python38\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files\Python38\python.exe
      npm error gyp ERR! find Python - "C:\Program Files\Python38\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Users\Sigi\AppData\Local\Programs\Python\Python38-32\python.exe
      npm error gyp ERR! find Python - "C:\Users\Sigi\AppData\Local\Programs\Python\Python38-32\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files\Python38-32\python.exe
      npm error gyp ERR! find Python - "C:\Program Files\Python38-32\python.exe" could not be run
      npm error gyp ERR! find Python checking if Python is C:\Program Files (x86)\Python38-32\python.exe
      npm error gyp ERR! find Python - "C:\Program Files (x86)\Python38-32\python.exe" could not be run
      npm error gyp ERR! find Python **********************************************************
      npm error gyp ERR! find Python You need to install the latest version of Python.
      npm error gyp ERR! find Python Node-gyp should be able to find and use Python. If not,
      npm error gyp ERR! find Python you can try one of the following options:
      npm error gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe"
      npm error gyp ERR! find Python (accepted by both node-gyp and npm)
      npm error gyp ERR! find Python - Set the environment variable PYTHON
      npm error gyp ERR! find Python - Set the npm configuration variable python:
      npm error gyp ERR! find Python npm config set python "C:\Path\To\python.exe"
      npm error gyp ERR! find Python For more information consult the documentation at:
      npm error gyp ERR! find Python https://github.com/nodejs/node-gyp#installation
      npm error gyp ERR! configure error
      npm error gyp ERR! stack Error: Could not find any Python installation to use
      npm error gyp ERR! stack at PythonFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:306:11)
      npm error gyp ERR! stack at PythonFinder.findPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:164:17)
      npm error gyp ERR! stack at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      npm error gyp ERR! stack at async configure (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:27:18)
      npm error gyp ERR! stack at async run (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js:81:18)
      npm error gyp ERR! System Windows_NT 10.0.19045
      npm error gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
      npm error gyp ERR! cwd C:\SmartHome\node_modules\diskusage
      npm error gyp ERR! node -v v20.16.0
      npm error gyp ERR! node-gyp -v v10.1.0
      npm error gyp ERR! not ok
      npm error A complete log of this run can be found in: C:\Users\Sigi\AppData\Local\npm-cache\_logs\2024-08-20T07_42_55_666Z-debug-0.log
      C:\SmartHome>
      python3 ???
      Gaspode 1 Reply Last reply Reply Quote 0
        @gaspode
        Da frage ich mich welcher Adapter braucht das Ganze eigentlich?
        • Gaspode
          Gaspode @sigi234 last edited by
          @sigi234 said in [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?:
          Gute Frage, ich finde nur eine optionale Dependency in node_modules@iobroker\js-controller-common-db\package.json
          @foxriver76 , eine Idee?
          • Gaspode
            python3 ???
            Steht Python 2.7. auch im Pfad? Was passiert denn, wenn du in der iob Shell
            python
            eingibst?
            • foxriver76
              foxriver76 Developer @Gaspode last edited by
              @gaspode ja das ist genau die Stelle, ist auch nur optional https://github.com/jduncanator/node-diskusage/issues/48
              Damit schauen wir wie viel Speicher noch frei ist auf den Systemen um das im Admin etc anzuzeigen
              RF-Bernhard created this issue in jduncanator/node-diskusage
              closed diskusage@1.1.2 install: `node-gyp rebuild` #48
              Gaspode 1 Reply Last reply Reply Quote 1
              • Gaspode
                Gaspode @foxriver76 last edited by
                @foxriver76 said in [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?:
                Ja, dass die Dependency optional ist, hatte ich ja geschrieben. Anscheinend verursacht sie dennoch das komische verhalten mit node-gyp.
                Wenn ich diskusage aus meinem npm tree deinstalliere und lösche, wird zumindest unter Windows immer noch der korrekte Festplattenplatz angezeigt. Ist die Dependency also wirklich notwendig? Wie gesagt, es kommt halt auf einigen Systemen zu diesen Meldungen, das könnte evtl. bei einigen Usern zu Verwirrungen führen. Linux konnte ich jetzt noch nicht testen.
                foxriver76 Gaspode 2 Replies Last reply Reply Quote 0
                • foxriver76
                  @gaspode puh war noch vor meiner Zeit als die Funktion implementiert wurde kann man mal checken ob alles ohne gehen würde mach gerne mal Controller issue bin die Woche im Urlaub
                  • Gaspode
                    Gaspode @Gaspode last edited by
                    @gaspode said in [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?:
                    Edit:
                    Mit sauber konfiguriertem node-gyp ist das kein Problem, diese Voraussetzung dürfte auf den meisten Windos Systemen aber nicht erfüllt sein.
                    • Gaspode
                      Kann ich demnächst mal unter Linux testen und ggfs. ein Issue schreiben.
                      Ich wünsche dir einen schönen Urlaub, Danke, dass du trotzdem geantwortet hast. 🙂
                      • foxriver76
                        @gaspode aber im Endeffekt muss man sagen ist es vollkommen ok, die optional dep kann nicht installiert werden Controller handelt das richtig, wenn sie da ist wird sie genutzt. Es ist halt blöd dass der User das sieht. Aber führt Admin denn das immer mit debug Flag aus? Ich denke das sollte nicht der Standard sein
                          @gaspode sagte in [gelöst] "node-gyp rebuild" wird ausgeführt - Warum?:
                          python3 ???
                          python
                          eingibst?
                          Da komme ich da hin:
                          • Gaspode
                            Gaspode @sigi234 last edited by Gaspode
                            @sigi234
                            OK, dann steht es wohl nicht im Pfad. Am schnellsten geht es wahrscheinlich, wenn du das manuell machst.
                            Im Startmenü "Systemumgebungsvariablen" eingeben, Dialog öffnen, Karte "Erweitert" wählen, Umgebungsvariablen wählen, im oberen Bereich "Path" wählen, dann "Bearbeiten". "Neu" drücken und den Pfad zu deiner Python Exe eintragen, meist "C:\Python27" oder so.
                            Dann die iob Shell schließen und neu starten. Nochmal versuchen.
                            • Gaspode
                              Stimmt schon, auf der anderen Seite muss man ja nix mitschleppen, was nicht gebraucht wird, oder?
                              Im Admin wird ein Adapter Update ja anscheinend nicht immer mit debug Flag ausgeführt, ich muss mal ein wenig forschen. Wird aber dauern. Genieße deinen Urlaub. 🙂
                                @sigi234
                                Soll ich jetzt die 3 er installieren oder bei der 2.7 bleiben? Installieren wenn 3 in der cmd oder mit dem Downloadlink.
                                • Gaspode
                                  Sollte egal sein, die 2.7 hat den Vorteil, dass das wohl die offiziell von node-gyp empfohlene Version ist. Daher würde ich erst mal die ausprobieren, zumal die ja bereits installiert ist und wohl nur im Pfad fehlt.
                                    Selbe Meldung , es such noch immer im Falschen Verzeichnis?
                                    Edit:
                                    • Gaspode
                                      @sigi234
                                      Was passiert denn jetzt bei
                                      python
                                      in der iob Shell?
                                        @sigi234
                                        python
                                        in der iob Shell?
                                        npm error code 1
                                        npm error A complete log of this run can be found in: C:\Users\Sigi\AppData\Local\npm-cache\_logs\2024-08-20T11_21_58_639Z-debug-0.log
                                        C:\SmartHome>
                                        • Gaspode
                                          @sigi234
                                          https://github.com/nodejs/node-gyp#configuring-python-dependency
                                          Also gucken, was alles verfügbar ist mit
                                          py --list-paths
                                          Und testweise setzen mit
                                          set npm_config_python=C:\python27
                                          npm i diskusage
                                          Sollte das klappen (sonst bin ich mit meinem Latein erst mal am Ende), die Variable npm_config_python im System setzen, analog zur Erweiterung von Path, nur halt als neue Variable anlegen.
                                          Edit: Bei mir war das nicht notwendig, ich hatte Glück und er hat sich die korrekte Version automatisch rausgesucht.
                                            @gaspode
                                            Ich gebe auf...
                                            6141
