    4. Beim Update von Adaptern stürzt der ioBroker ab
      Thomas Braun Most Active last edited by
      @flommaster sagte in Beim Update von Adaptern stürzt der ioBroker ab:
      npm ls zlib
        flommaster @Thomas Braun last edited by
        @thomas-braun sagte in Beim Update von Adaptern stürzt der ioBroker ab:
        npm uninstall iobroker.mihome-vacuum
        Das hat leider nicht geklappt.
        Bevor die Deinstallation startet habe ich wieder ein Haufen an Hinweisen erhalten...
        flo@ioBrokerdebian:/opt/iobroker$ npm uninstall iobroker.mihome-vacuum
        [sudo] Passwort für flo:
        npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.web-speedy.git
        npm warn skipping integrity check for git dependency ssh://git@github.com/peterbaumert/ioBroker.vofo-speedtest.git
        npm warn skipping integrity check for git dependency ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git
        npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2-widgets-material.git
        npm warn skipping integrity check for git dependency ssh://git@github.com/ioBroker/ioBroker.vis-2.git
        npm warn skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git
        npm warn skipping integrity check for git dependency ssh://git@github.com/aendue/ioBroker.reolink.git
        npm warn skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.ical.git
        npm warn skipping integrity check for git dependency ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git
        npm warn skipping integrity check for git dependency ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git
        npm warn skipping integrity check for git dependency ssh://git@github.com/WLAN-Kabel/ioBroker.calendar.git
        npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
        npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
        npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
        npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
        npm warn deprecated uid-number@0.0.6: This package is no longer supported.
        npm warn deprecated npmlog@5.0.1: This package is no longer supported.
        npm warn deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
        npm warn deprecated npmlog@6.0.2: This package is no longer supported.
        npm warn deprecated har-validator@5.1.5: this library is no longer supported
        npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
        npm warn deprecated abab@2.0.6: Use your platform's native atob() and btoa() methods instead
        npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
        npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
        npm warn deprecated q@1.1.2: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
        npm warn deprecated
        npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
        npm warn deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
        npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
        npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
        npm warn deprecated domexception@4.0.0: Use your platform's native DOMException instead
        npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
        npm warn deprecated google-p12-pem@4.0.1: Package is no longer maintained
        npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
        npm warn deprecated google-p12-pem@3.1.4: Package is no longer maintained
        npm warn deprecated gauge@3.0.2: This package is no longer supported.
        npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm warn deprecated gauge@4.0.4: This package is no longer supported.
        npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        npm warn deprecated later@1.2.0: Please upgrade to the maintained and new drop-in replacement @breejs/later at https://github.com/breejs/later 🚀 Thanks and happy hacking! 🚀  @niftylettuce
        npm error code 1
        npm error path /opt/iobroker/node_modules/node-libcurl
        npm error command failed
        npm error command sh -c node-pre-gyp install --fallback-to-build
        npm error Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node --module_name=node_libcurl --module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding --napi_version=9 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v115' (1)
        npm error node-pre-gyp info it worked if it ends with ok
        npm error node-pre-gyp info using node-pre-gyp@1.0.10
        npm error node-pre-gyp info using node@20.16.0 | linux | x64
        npm error node-pre-gyp info check checked for "/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node" (not found)
        npm error node-pre-gyp http GET https://github.com/JCMais/node-libcurl/releases/download/v3.0.0/node_libcurl-v3.0.0-node-v115-linux-x64-glibc.tar.gz
        npm error node-pre-gyp ERR! install response status 404 Not Found on https://github.com/JCMais/node-libcurl/releases/download/v3.0.0/node_libcurl-v3.0.0-node-v115-linux-x64-glibc.tar.gz
        npm error node-pre-gyp WARN Pre-built binaries not installable for node-libcurl@3.0.0 and node@20.16.0 (node-v115 ABI, glibc) (falling back to source compile with node-gyp)
        npm error node-pre-gyp WARN Hit error response status 404 Not Found on https://github.com/JCMais/node-libcurl/releases/download/v3.0.0/node_libcurl-v3.0.0-node-v115-linux-x64-glibc.tar.gz
        npm error gyp info it worked if it ends with ok
        npm error gyp info using node-gyp@10.1.0
        npm error gyp info using node@20.16.0 | linux | x64
        npm error gyp info ok
        npm error gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
        npm error gyp http GET https://nodejs.org/download/release/v20.16.0/node-v20.16.0-headers.tar.gz
        npm error gyp http 200 https://nodejs.org/download/release/v20.16.0/node-v20.16.0-headers.tar.gz
        npm error gyp http GET https://nodejs.org/download/release/v20.16.0/SHASUMS256.txt
        npm error gyp http 200 https://nodejs.org/download/release/v20.16.0/SHASUMS256.txt
        npm error gyp info spawn /usr/bin/python3
        npm error gyp info spawn args [
        npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
        npm error gyp info spawn args 'binding.gyp',
        npm error gyp info spawn args '-f',
        npm error gyp info spawn args 'make',
        npm error gyp info spawn args '-I',
        npm error gyp info spawn args '/opt/iobroker/node_modules/node-libcurl/build/config.gypi',
        npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
        npm error gyp info spawn args '/home/iobroker/.cache/node-gyp/20.16.0/include/node/common.gypi',
        npm error gyp info spawn args '-Dlibrary=shared_library',
        npm error gyp info spawn args '-Dvisibility=default',
        npm error gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/20.16.0',
        npm error gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
        npm error gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/20.16.0/<(target_arch)/node.lib',
        npm error gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/node-libcurl',
        npm error gyp info spawn args '-Dnode_engine=v8',
        npm error gyp info spawn args '--depth=.',
        npm error gyp info spawn args '--no-parallel',
        npm error gyp info spawn args '--generator-output',
        npm error gyp info spawn args 'build',
        npm error gyp info spawn args '-Goutput_dir=.'
        npm error gyp info spawn args ]
        npm error Could not run curl-config, please make sure libcurl dev package is installed.
        npm error Output: /bin/sh: 1: curl-config: not found
        npm error
        npm error gyp: Call to 'node /opt/iobroker/node_modules/node-libcurl/scripts/curl-config.js --prefix' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
        npm error gyp ERR! configure error
        npm error gyp ERR! stack Error: `gyp` failed with exit code: 1
        npm error gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:297:18)
        npm error gyp ERR! stack at ChildProcess.emit (node:events:519:28)
        npm error gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:294:12)
        npm error gyp ERR! System Linux 6.1.0-23-amd64
        npm error gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node" "--module_name=node_libcurl" "--module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding" "--napi_version=9" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v115"
        npm error gyp ERR! cwd /opt/iobroker/node_modules/node-libcurl
        npm error gyp ERR! node -v v20.16.0
        npm error gyp ERR! node-gyp -v v10.1.0
        npm error gyp ERR! not ok
        npm error node-pre-gyp ERR! build error
        npm error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node --module_name=node_libcurl --module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding --napi_version=9 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v115' (1)
        npm error node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-libcurl/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
        npm error node-pre-gyp ERR! stack     at ChildProcess.emit (node:events:519:28)
        npm error node-pre-gyp ERR! stack     at maybeClose (node:internal/child_process:1105:16)
        npm error node-pre-gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:305:5)
        npm error node-pre-gyp ERR! System Linux 6.1.0-23-amd64
        npm error node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-libcurl/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
        npm error node-pre-gyp ERR! cwd /opt/iobroker/node_modules/node-libcurl
        npm error node-pre-gyp ERR! node -v v20.16.0
        npm error node-pre-gyp ERR! node-pre-gyp -v v1.0.10
        npm error node-pre-gyp ERR! not ok
        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-20T13_59_25_128Z-debug-0.log
        mikeal created this issue in request/request
        open Request’s Past, Present and Future #3142
        Qix- created this issue in visionmedia/debug
        closed ReDos Vulnerability Regression Visibility Notice #797
          npm ls zlib
          Hier ist noch das Ergebnis von npm ls zlib
          flo@ioBrokerdebian:/opt/iobroker$ npm ls zlib
          iobroker.inst@2.0.3 /opt/iobroker
          └─┬ iobroker.mihome-vacuum@3.11.0
            └── zlib@1.0.5
            Thomas Braun Most Active @flommaster last edited by
            @flommaster
            Du hast da nicht nur eine oder zwei Baustellen, das ist eine ausgewachsene Großbaustelle da bei dir...
            apt policy libcurl*
            apt policy libcurl*dev
            Es muss das entsprechende -dev-Paket zu der bei dir installierten Version von libcurl installiert werden.
            Zu mihome-vacuum versuch mal ein
            iob update
            iob upgrade iobroker.mihome-vacuum@4.2.0
              apt policy libcurl*
              flo@ioBrokerdebian:/opt/iobroker$ apt policy libcurl*
              libcurl4-openssl-dev:
                Installiert:           (keine)
                Installationskandidat: 7.88.1-10+deb12u6
                Versionstabelle:
                   7.88.1-10+deb12u6 500
                      500 http://deb.debian.org/debian bookworm/main amd64 Packages
                   7.88.1-10+deb12u5 500
                      500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
              libcurl3:
                Installationskandidat: (keine)
                Versionstabelle:
              libcurl4:
                Installiert:           7.88.1-10+deb12u6
                Versionstabelle:
               *** 7.88.1-10+deb12u6 500
                      100 /var/lib/dpkg/status
              libcurl3-gnutls:
                Versionstabelle:
              libcurl-ocaml:
                Installationskandidat: 0.9.2-3
                Versionstabelle:
                   0.9.2-3 500
              libcurl3-openssl-dev:
                Versionstabelle:
              libcurl3-gnutls-dev:
                Versionstabelle:
              libcurl4-gnutls-dev:
                Versionstabelle:
              libcurl-dev:
                Versionstabelle:
              libcurlpp0:
                Installationskandidat: 0.8.1-5.1
                Versionstabelle:
                   0.8.1-5.1 500
              libcurl-ocaml-dev:
                Versionstabelle:
                   0.9.2-3 500
              libcurl-ocaml-80io7:
                Versionstabelle:
              libcurlpp-dev:
                Versionstabelle:
                   0.8.1-5.1 500
              libcurl-ssl-dev:
                Versionstabelle:
              libcurl3-nss-dev:
                Versionstabelle:
              libcurl3-dev:
                Versionstabelle:
              libcurl-ocaml-dev-80io7:
                Versionstabelle:
              libcurl4-dev:
                Versionstabelle:
              libcurl4-doc:
                Versionstabelle:
              libcurl3-nss:
                Versionstabelle:
              libcurl4-nss-dev:
                Versionstabelle:
                Versionstabelle:
                Versionstabelle:
                Versionstabelle:
                Versionstabelle:
              libcurl-dev:
                Versionstabelle:
              libcurl-ocaml-dev:
                Versionstabelle:
                   0.9.2-3 500
              libcurlpp-dev:
                Versionstabelle:
                   0.8.1-5.1 500
              libcurl-ssl-dev:
                Versionstabelle:
              libcurl3-nss-dev:
                Versionstabelle:
              libcurl3-dev:
                Versionstabelle:
              libcurl4-dev:
                Versionstabelle:
              libcurl4-nss-dev:
                Versionstabelle:
                iob update iob upgrade iobroker.mihome-vacuum@4.2.0
                flo@ioBrokerdebian:/opt/iobroker$ iob update
                node:internal/modules/esm/resolve:215
                  const resolvedOption = FSLegacyMainResolve(packageJsonUrlString, packageConfig.main, baseStringified);
                Error: Cannot find package '/opt/iobroker/node_modules/@iobroker/js-controller-cli/package.json' imported from /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                    at legacyMainResolve (node:internal/modules/esm/resolve:215:26)
                    at packageResolve (node:internal/modules/esm/resolve:841:14)
                    at moduleResolve (node:internal/modules/esm/resolve:927:18)
                    at defaultResolve (node:internal/modules/esm/resolve:1169:11)
                    at ModuleLoader.defaultResolve (node:internal/modules/esm/loader:383:12)
                    at ModuleLoader.resolve (node:internal/modules/esm/loader:352:25)
                    at ModuleLoader.getModuleJob (node:internal/modules/esm/loader:227:38)
                    at ModuleLoader.import (node:internal/modules/esm/loader:315:34)
                    at defaultImportModuleDynamically (node:internal/modules/esm/utils:194:31)
                    at importModuleDynamicallyCallback (node:internal/modules/esm/utils:216:12) {
                  code: 'ERR_MODULE_NOT_FOUND'
                Node.js v20.16.0
                Node.js v20.16.0
                  @flommaster
                  iob update
                  zeilenweise einzeln eingeben.
                    apt policy libcurl*
                    Also libcurl4...
                    apt policy libcurl4*
                      @flommaster
                      iob update
                      iob update
                      Node.js v20.16.0
                      flo@ioBrokerdebian:/opt/iobroker$ iob upgrade iobroker.mihome-vacuum@4.2.0
                      Node.js v20.16.0
                        flo@ioBrokerdebian:/opt/iobroker$ apt policy libcurl4*
                          Versionstabelle:
                        libcurl4:
                          Versionstabelle:
                          Versionstabelle:
                        libcurl4-dev:
                          Versionstabelle:
                        libcurl4-doc:
                          Versionstabelle:
                        libcurl4-nss-dev:
                          Versionstabelle:
                          Installier das mal:
                          sudo apt install libcurl4-openssl-dev
                            erledigt.
                            flo@ioBrokerdebian:/opt/iobroker$ sudo apt install libcurl4-openssl-dev
                            Paketlisten werden gelesen… Fertig
                            Abhängigkeitsbaum wird aufgebaut… Fertig
                            Statusinformationen werden eingelesen… Fertig
                            Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                              g++-10 libbpf0 libcbor0 libdns-export1110 libgdk-pixbuf-xlib-2.0-0 libgdk-pixbuf-xlib-2.0-dev libgdk-pixbuf2.0-dev libicu67 libisc-export1105 libjsoncpp24 libldap-2.4-2 liblua5.1-0 libmpdec3 libnspr4 libnss3 libpcre16-3
                              libpcre2-posix2 libpcre3-dev libpcre32-3 libpcrecpp0v5 libperl5.32 libprocps8 libpython3.9 libpython3.9-minimal libpython3.9-stdlib libstdc++-10-dev libtiff5 liburing1 libusb-0.1-4 libwebp6 lua-bitop lua-cjson perl-modules-5.32 pigz
                              python3.9 python3.9-minimal telnet x11proto-xext-dev
                            Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                            Vorgeschlagene Pakete:
                              libcurl4-doc libidn-dev libkrb5-dev libldap2-dev librtmp-dev libssh2-1-dev libssl-dev
                            Die folgenden NEUEN Pakete werden installiert:
                            0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                            Es müssen 491 kB an Archiven heruntergeladen werden.
                            Nach dieser Operation werden 1.819 kB Plattenplatz zusätzlich benutzt.
                            Holen:1 http://deb.debian.org/debian bookworm/main amd64 libcurl4-openssl-dev amd64 7.88.1-10+deb12u6 [491 kB]
                            Es wurden 491 kB in 0 s geholt (2.021 kB/s).
                            Vormals nicht ausgewähltes Paket libcurl4-openssl-dev:amd64 wird gewählt.
                            (Lese Datenbank ... 63533 Dateien und Verzeichnisse sind derzeit installiert.)
                            Vorbereitung zum Entpacken von .../libcurl4-openssl-dev_7.88.1-10+deb12u6_amd64.deb ...
                            Entpacken von libcurl4-openssl-dev:amd64 (7.88.1-10+deb12u6) ...
                            libcurl4-openssl-dev:amd64 (7.88.1-10+deb12u6) wird eingerichtet ...
                            Trigger für man-db (2.11.2-2) werden verarbeitet ...
                              @flommaster
                              sudo apt autoremove
                              Jetzt die Holzhammermethode:
                              cd /opt/iobroker
                              npm install iobroker.js-controller@6.0.9 --force
                                @flommaster
                                sudo apt autoremove
                                cd /opt/iobroker
                                Das klappt leider auch nicht.
                                Soll ich mal ein downgrade auf die Version 5.x versuchen?
                                flo@ioBrokerdebian:/opt/iobroker$ cd /opt/iobroker
                                npm warn using --force Recommended protections disabled.
                                npm warn deprecated
                                npm error code 127
                                npm error path /opt/iobroker/node_modules/zlib
                                npm error command sh -c node-waf clean || true; node-waf configure build
                                npm error sh: 1: node-waf: not found
                                npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-20T18_16_12_082Z-debug-0.log
                                  @flommaster
                                  Du kannst die Kiste mal neuinstallieren.
                                    @flommaster
                                    Alles klar.
                                    Dann bestelle ich mir gleich nen neuen NUC mit 8GB RAM und setze den komplett neu auf.
                                    Gibt es aktuelle Empfehlungen?
                                    Ein Backup mit meinen Daten kann ich danach aber einspielen?
                                    Thomas Braun S 2 Replies Last reply Reply Quote 0
                                      Möglich. Vermutlich knallst du dir den Murks aber nur wieder rein.
                                        Shadowhunter23 @flommaster last edited by Shadowhunter23
                                        @flommaster
                                        https://itreturn.at/HP-EliteDesk-800-G4-Tiny-/-Intel-i5-8500-360GHz-/-256-GB-SSD-/-16GB-RAM-/-Windows-11-Home-/-12-Monate-Garantie
                                        Aber kein HDMI für Monitor.
                                        BananaJoe F 2 Replies Last reply Reply Quote 0
                                        • BananaJoe
                                          BananaJoe Most Active @Shadowhunter23 last edited by
                                          @shadowhunter23 wer braucht schon einen Monitor da dran ... ja ist beim ersten Installieren ganz nett ...
                                          Und ansonsten noch mal 5 Euro für einen Adapter: https://www.amazon.de/dp/B08XKB7PRP
                                            flommaster @Shadowhunter23 last edited by
                                            @shadowhunter23 sagte in Beim Update von Adaptern stürzt der ioBroker ab:
                                            @flommaster
                                            Danke für den Tipp!
                                            5480
