    5. Zeitliches Blockly
    Zeitliches Blockly
    • Yoda
      Yoda @Meister Mopper last edited by
      @meister-mopper - gern
      Der Wert von TotalAvtivPower steht hier auf 100, nun soll aber nicht sofort darauf reagiert werden sondern erst wenn der Wert 10 sec lang ansteht. Ich habe hier sonst immer kurze Schwankungen.
      <block xmlns="https://developers.google.com/blockly/xml" type="on_ext" id="wNNWp~Y_FZe|v#%-dVwx" x="-1187" y="-1713">
        <mutation xmlns="http://www.w3.org/1999/xhtml" items="3"></mutation>
        <value name="OID0">
          <shadow type="field_oid" id="~?t}50$cE*vhNwt/9d{k">
            <field name="oid">zendure-solarflow.0.A8yh63.0cWQxK41.outputPackPower</field>
        <value name="OID1">
          <shadow type="field_oid" id="9]|juE*X@]U*!j[pRC2u">
            <field name="oid">hmip.0.devices.3014F711A00034DF29AEA71A.channels.1.currentPowerConsumption</field>
        <value name="OID2">
          <shadow type="field_oid" id=":2FsUl-eM!wCb6/lY=Fn">
            <field name="oid">zendure-solarflow.0.A8yh63.0cWQxK41.packInputPower</field>
          <block type="controls_if" id="RtbEZklb).NV+Z98Gef:">
              <block type="logic_multi_and" id="Ly}_d63K/Bp2rG^?L=ST">
                <mutation xmlns="http://www.w3.org/1999/xhtml" items="6"></mutation>
                <value name="AND0">
                  <block type="time_compare" id="hH9U#G+TH0pk@~BgyC^A">
                    <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true"></mutation>
                    <field name="START_TIME">09:00</field>
                    <field name="END_TIME">17:00</field>
                <value name="AND1">
                  <block type="logic_compare" id="fuxUgs_I)3/**$t=3t9J">
                    <field name="OP">EQ</field>
                      <block type="get_value" id="+,5X|3^),oqO0!}d*{E`">
                        <field name="OID">0_userdata.0.Solar-Sperre-Teichfilter</field>
                      <block type="logic_boolean" id="~o5f`KDX.u!-Ri+#S|vh">
                <value name="AND2">
                  <block type="logic_compare" id="WJ.diWk5c7i.pRep//ka">
                    <field name="OP">GT</field>
                      <block type="get_value" id="HFl9Hn,c8dfJYn`F.B[d">
                        <field name="OID">hmip.0.devices.3014F711A00034DF29AEA71A.channels.1.currentPowerConsumption</field>
                      <block type="math_number" id="uveFFq.T_9Lx=eY);g`k">
                        <field name="NUM">400</field>
                <value name="AND3">
                  <block type="logic_compare" id=",lD!woaeUk*n},,Q8dyh">
                    <field name="OP">LT</field>
                      <block type="get_value" id="iOOL`$49Lpb~a~Cfy?6/">
                        <field name="OID">shelly.0.shellypro3em#08f9e0e88fc4#1.EM0.TotalActivePower</field>
                      <block type="math_number" id="P0+nxpjOhm+$|]p,lE%/">
                        <field name="NUM">100</field>
                <value name="AND4">
                  <block type="logic_compare" id="$d*V9TR/0Z.}(?6CPTXx">
                      <block type="get_value" id="D,UDO_{3ofWLR9M_mBEZ">
                        <field name="OID">zendure-solarflow.0.A8yh63.0cWQxK41.electricLevel</field>
                      <block type="math_number" id="[XaEKzdrQr3Yp~Hy.(`|">
                        <field name="NUM">15</field>
                <value name="AND5">
                  <block type="logic_compare" id="i]E:BC:U4ty/zr9002Z.">
                      <block type="get_value" id="isgSQ4|7*^b,?o+m}yLR">
                        <field name="OID">tuya.0.bf06b08cba98cae305vmq9.1</field>
                      <block type="logic_boolean" id="/Jv5FiYqe,yD@MJtIDXy">
              <block type="control" id="ZD8UYvnpDNM,=+-c[DQ_">
                  <block type="logic_boolean" id="P79SB~asx4ATCd,}-Fqg">
              <block type="controls_if" id="hJr0.@Y1~RI;3IW3[5K!">
                  <block type="logic_multi_and" id="(*AaLF]Maq`z,rY^I}[!">
                    <mutation xmlns="http://www.w3.org/1999/xhtml" items="4"></mutation>
                    <value name="AND0">
                      <block type="time_compare" id="r9ji==s|VO[4#i?UCWSj">
                    <value name="AND1">
                      <block type="logic_compare" id="6O9?IZ`kK`%?PaL8l[{a">
                          <block type="get_value" id="XlIhPxmStMAYK,(5NrvO">
                          <block type="logic_boolean" id="7haYzh#7.wI$P2!@I}MM">
                    <value name="AND2">
                      <block type="logic_compare" id=",{T9oWA:!5!Q=4qOzR[e">
                          <block type="get_value" id="t8m=n?JVi/qfZNyv(R)|">
                            <field name="OID">zendure-solarflow.0.A8yh63.0cWQxK41.packInputPower</field>
                          <block type="math_number" id="A75:vl.ToHfAAd:W~hUY">
                            <field name="NUM">150</field>
                    <value name="AND3">
                      <block type="logic_compare" id=";|r%QwiMsCT(Egi?XW]A">
                          <block type="get_value" id="DmFnwh1RYi`J5_Li9eA3">
                          <block type="logic_boolean" id=".C6TPs,LBmcgJw40[2B!">
                  <block type="control" id="es@w!jjASKB}}Qsg;=91">
                      <block type="logic_boolean" id="0MA%-wf1{E#D28tpA4h@">
                  <block type="controls_if" id="wouwQAS@zy*e+jH;/91E">
                      <block type="logic_multi_and" id=")hAj/[xUx]qTiH)C@BX;">
                        <value name="AND0">
                          <block type="time_compare" id=")zf(T$c;NJthMuHzy!?3">
                        <value name="AND1">
                          <block type="logic_compare" id="2;DX[MAs3j6fBr3L=(4z">
                            <field name="OP">LTE</field>
                              <block type="get_value" id="FPX~-renJeJM-}8X5kN4">
                              <block type="math_number" id=":~+rl|)7m1x28I[D#$n1">
                                <field name="NUM">12</field>
                        <value name="AND2">
                          <block type="logic_compare" id="j5,OB77+xhM]c+c6-+jU">
                              <block type="get_value" id="6FV(b=zKM)Q}APpYq2Jb">
                              <block type="logic_boolean" id="L=BC;:~%-y{.^PD*CmBE">
                      <block type="control" id="tgxaEJojQPY^Hr+|B6Gl">
                          <block type="logic_boolean" id="+eda6Jsb)Gu6_D_@i;2p">
        paul53 @Yoda last edited by paul53
        @yoda sagte: 2 Blocklys
        @yoda sagte in Zeitliches Blockly:
        TotalAvtivPower
        Dieser Datenpunkt sollte triggern!
        Yoda 2 Replies Last reply Reply Quote 0
        • Yoda
          Yoda @paul53 last edited by
          @paul53 das hilft mir schon etwas weiter Danke dir,
          werde nacher mal schauen wie ich das in dem Script am besten einfüge da ich dort ja einige und : und : und habe.
          Denke da an einen Hilfs Datenpunkt anzulegen und diesen dann bei länger 10 sec auf True zu stellen.
          • Yoda
            @paul53 ich verstehe es noch nicht ganz.
            Ich habs soweit nun mal nachgebaut mit einer Variable die auf "Wahr" gehen soll wenn länger 10 sec die Größer 100 schalten soll.
            Nun müsste ich ja auch wieder auf fals schalten.... ? Damit ich die Variable in meine Fals / dann einbauen könnte...
            <block xmlns="https://developers.google.com/blockly/xml" type="on_ext" id="$MTczKq5M[)q~5ums$P1" x="-362" y="-1812">
              <value name="OID0">
                <shadow type="field_oid" id="dcv3.1sshW|CuMJl$$sW">
                  <field name="oid">shelly.0.shellypro3em#08f9e0e88fc4#1.EM0.TotalActivePower</field>
                <block type="controls_if" id="1i$gNV20J$nzQGH=pZAl">
                    <block type="logic_compare" id="bg35k3A:0k0Zmuc8WAfG">
                        <block type="on_source" id="Z|ueY`Pf~m.C9]-S$oy;">
                        <block type="math_number" id="fOB#07r~#k5onO#bK}E,">
                    <block type="timeouts_cleartimeout" id="WUC*cW,hX39=H^+yf~Ay">
                  <value name="IF1">
                    <block type="logic_compare" id="TNN;|i{obr-ufa@Ci=]i">
                        <block type="on_source" id="zg{c|U7(A1ciP.Xrweos">
                          <field name="ATTR">oldState.val</field>
                        <block type="math_number" id="7+q7Z#XtTlDdB0goRGY]">
                  <statement name="DO1">
                    <block type="timeouts_settimeout" id="9,{:SCW9{Aq$@@.%bC_d">
                      <field name="DELAY">10</field>
                        <block type="variables_set" id="ZQ(Du_x+u(B81G,DJV$s">
                          <field name="VAR" id="FwZuvv3JjYTCoyr:KIFb">Power-Zeit</field>
                            <block type="logic_boolean" id="E$fo^14~^jad`uM0wniQ">
              <value name="OID0">
              <value name="OID1">
              <value name="OID2">
                      <mutation xmlns="http://www.w3.org/1999/xhtml" items="7"></mutation>
                      <value name="AND0">
                      <value name="AND1">
                      <value name="AND2">
                              <field name="OID">zendure-solarflow.0.A8yh63.0cWQxK41.solarInputPower</field>
                      <value name="AND3">
                      <value name="AND4">
                        <block type="logic_compare" id="4JW?f$x,{x@t+]cZebTp">
                            <block type="get_value_var" id="K-eDhGmoj_AmbLDgAK`Y">
                              <value name="OID">
                                <shadow type="field_oid" id="2xB1-%(Opuf#]OLjd34R">
                                  <field name="oid">ID auswählen</field>
                                <block type="variables_get" id="mtc~Jo8/GxHr9xC($x=M">
                            <block type="logic_boolean" id="VOt09-Bl!t,2KW7eD%nG">
                      <value name="AND5">
                      <value name="AND6">
                          <value name="AND0">
                          <value name="AND1">
                          <value name="AND2">
                          <value name="AND3">
                              <value name="AND0">
                              <value name="AND1">
                              <value name="AND2">
            • Codierknecht
              Codierknecht Developer Most Active @Yoda last edited by Codierknecht
              @Yoda
              Im rechten Teil:
              Edit
              Tipp: Auch wenn das intern in einen Unterstrich geändert wird (Power_Zeit) würde ich in Variablennamen keinen Bindestrich verwenden!
              Yoda 1 Reply Last reply Reply Quote 1
              • Yoda
                Yoda @Codierknecht last edited by
                @codierknecht Danke dir, werde ich versuchen
                • Codierknecht
                  @yoda
                  Im linken Teil muss die Prüfung auf "TotalActivePower < 100" nach meinem Verständnis raus.
                  Yoda 1 Reply Last reply Reply Quote 0
                  • Yoda
                    @codierknecht ja habs draußen, ich teste mal ein wenig rum...
                    • Codierknecht
                      @yoda
                      Nein - so:
                      • Yoda
                        @codierknecht stimmt das habe ich gesehen als ich es Postete, habs nun Aktiv kommen aber nur Fehlermeldungen
                        • Codierknecht
                          @yoda
                          Schau in den JS-Quellcode. In den Fehlermeldungen sind Zeilennummern (35) angegeben.
                          Da ist wohl ein State gar nicht bool.
                          • Yoda
                            Yoda @Codierknecht last edited by Yoda
                            @codierknecht
                            ich habe mal einen neuen Datenpunkt angelegt der entsprechend geschaltet werden soll.
                            Das macht er soweit ich sehe auch.
                            Nur kommt immer eine Warnung:
                            <block xmlns="https://developers.google.com/blockly/xml" type="on_ext" id="$MTczKq5M[)q~5ums$P1" x="-438" y="-1587">
                              <value name="OID0">
                                        <block type="control" id="0}u[]$oUiUyIi742-%J[">
                                          <field name="OID">0_userdata.0.DatenpunktAktivPowerZeit</field>
                                            <block type="logic_boolean" id=",q5NBv#]~80biB1$Dp3=">
                                  <value name="IF1">
                                        <block type="control" id="(8vdZEBPf=R^4mrhGF(`">
                                            <block type="logic_boolean" id="%{R2^o9Bl1VqB:9wBkK_">
                            Das steht in Zeile 51:
                            ![d962188c-caaf-486a-9548-79df818694ef-image.png](/assets/uploads/files/1724242654751-d962188c-caaf-486a-9548-79df818694ef-image.png) code_text
                            on({ id: [].concat(['shelly.0.shellypro3em#08f9e0e88fc4#1.EM0.TotalActivePower']), change: 'ne' }, async (obj) => {
                            let value = obj.state.val;
                            if ((obj.state ? obj.state.val : '') <= 100) {
                            (() => { if (timeout2) { clearTimeout(timeout2); timeout2 = null; }})();
                            setState('0_userdata.0.DatenpunktAktivPowerZeit' /* DatenpunktAktivPowerZeit /, false);
                            } else if ((obj.oldState ? obj.oldState.val : '') <= 100) {
                            timeout2 = setTimeout(async () => {
                            timeout2 = null;
                            DatenpunktAktivPowerZeit */, true);
                            }, 10000);
                            web.0
                            2024-08-21 14:21:06.606	info	<== Disconnect system.user.admin from ::ffff:192.168.178.166 flot
                            web.0
                            2024-08-21 14:21:06.601	info	<== Disconnect system.user.admin from ::ffff:192.168.178.166 flot
                            web.0
                            2024-08-21 14:21:06.543	info	<== Disconnect system.user.admin from ::ffff:192.168.178.166 flot
                            javascript.0
                            2024-08-21 14:21:04.339	info	State value to set for "0_userdata.0.DatenpunktAktivPowerZeit" has to be type "string" but received type "boolean"
                            javascript.0
                            2024-08-21 14:21:04.323	warn	at processImmediate (node:internal/timers:483:21)
                            javascript.0
                            2024-08-21 14:21:04.323	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11053:62)
                            javascript.0
                            2024-08-21 14:21:04.323	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
                            javascript.0
                            2024-08-21 14:21:04.322	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
                            javascript.0
                            2024-08-21 14:21:04.322	warn	at Object.<anonymous> (script.js.Manni_Schalter.Aussen.Teichfilter-Sommer1:51:5)
                            javascript.0
                            2024-08-21 14:21:04.322	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
                            javascript.0
                            2024-08-21 14:21:04.319	warn	You are assigning a boolean to the state "0_userdata.0.DatenpunktAktivPowerZeit" which expects a string. Please fix your code to use a string or change the state type to boolean. This warning might become an error in future versions.
                            javascript.0
                            2024-08-21 14:21:00.285	info	State value to set for "0_userdata.0.DatenpunktAktivPowerZeit" has to be type "string" but received type "boolean"
                            javascript.0
                            2024-08-21 14:21:00.272	warn	at processImmediate (node:internal/timers:483:21)
                            • Codierknecht
                              Das XML ist nur der rechte Teil.
                              Hast Du den Datenpunkt als "Zeichenfolge" angelegt?
                              • Yoda
                                @codierknecht
                                  "common": {
                                    "name": "DatenpunktAktivPowerZeit",
                                    "desc": "Manuell erzeugt",
                                    "role": "state",
                                    "type": "string",
                                    "read": true,
                                    "write": true,
                                    "def": ""
                                  "type": "state",
                                  "native": {},
                                  "_id": "0_userdata.0.DatenpunktAktivPowerZeit",
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                    "owner": "system.user.admin",
                                  "user": "system.user.admin",
                                  "ts": 1724243075612
                                • Codierknecht
                                  "type": "string",
                                  Das muss bool sein (Logikwert)
                                  • Yoda
                                    @codierknecht perfekt vielen Dank, sieht soweit nun sauber aus, in der Praxis muss ich noch etwas schauen wie es sich verhält.
                                    blockly
                                    621
