    4. Exception in ebusd_ReceiveData [Error: connect ETIMEDOUT]
      Homoran Global Moderator Administrators @Marc Berg last edited by
      @marc-berg sagte in Exception in ebusd_ReceiveData [Error: connect ETIMEDOUT]:
      Das ist genau falsch rum:
      @Krissie777
      und genau deswegen immer alles zeigen.
        Krissie777 @Marc Berg last edited by
        @marc-berg
        ok habe ich vertauscht, wieder der Fehler:
        exception in ebusd_ReceiveData [Error: connect ECONNREFUSED 127.0.0.1:8889]
        Kris
        • Marc Berg
          Marc Berg Most Active last edited by
          @krissie777 sagte in Exception in ebusd_ReceiveData [Error: connect ETIMEDOUT]:
          und iob diag gibt jetzt immer noch
          > tcp        0      0 0.0.0.0:8889            0.0.0.0:*               LISTEN      0          967460     26805/ebusd
          aus?
            @marc-berg said in Exception in ebusd_ReceiveData [Error: connect ETIMEDOUT]:
            iob diag
            Skript v.2024-05-22
            *** BASE SYSTEM ***
               Static hostname: raspberrypi
                     Icon name: computer
              Operating System: Raspbian GNU/Linux 10 (buster)
                        Kernel: Linux 5.10.103-v7l+
                  Architecture: arm
            Model           : Raspberry Pi 4 Model B Rev 1.4
            Docker          : false
            Virtualization  : none
            Kernel          : armv7l
            Userland        : 32 bit
            Systemuptime and Load:
             15:37:31 up  1:22,  2 users,  load average: 1.21, 0.69, 0.52
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            ~ Under-voltage detected
            ~ Arm frequency capped
            Previously detected issues:
            ~ Under-voltage has occurred
            ~ Arm frequency capping has occurred
            *** Time and Time Zones ***
                           Local time: Fri 2024-08-23 15:37:31 CEST
                       Universal time: Fri 2024-08-23 13:37:31 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            pi
            HOME=/home/pi
            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
            *** Display-Server-Setup ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:           3.8G        1.0G        1.4G        9.0M        1.5G        2.8G
            Swap:           99M          0B         99M
            Total:         3.9G        1.0G        1.5G
            Active iob-Instances:   15
                     3837 M total memory
                     1010 M used memory
                      331 M active memory
                     2050 M inactive memory
                     1351 M free memory
                       87 M buffer memory
                     1387 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            top - 15:37:32 up  1:22,  2 users,  load average: 1.21, 0.69, 0.52
            Tasks: 156 total,   2 running, 154 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 18.3 us, 20.4 sy,  0.0 ni, 58.1 id,  1.1 wa,  0.0 hi,  2.2 si,  0.0 st
            MiB Mem :   3837.7 total,   1351.6 free,   1010.7 used,   1475.5 buff/cache
            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2827.9 avail Mem
            *** FAILED SERVICES ***
              UNIT               LOAD   ACTIVE SUB    DESCRIPTION
            * PiEMItMgmt.service loaded failed failed PiEM-It! Mgmt-Modul, respawn
            * Webserver.service  loaded failed failed PiEM-It! Webserver-Modul, respawn
            LOAD   = Reflects whether the unit definition was properly loaded.
            ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
            SUB    = The low-level unit activation state, values depend on unit type.
            2 loaded units listed. Pass --all to see loaded but inactive units, too.
            To show all installed unit files use 'systemctl list-unit-files'.
            *** FILESYSTEM ***
            /dev/root      ext4       29G   14G   15G  49% /
            devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
            tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
            tmpfs          tmpfs     1.9G  9.6M  1.9G   1% /run
            tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
            /dev/sda1      vfat      253M   49M  204M  20% /boot
            tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
            [Fri Aug 23 14:14:55 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hd        mi=1 video=HDMI-A-1:1920x1080M@60D smsc95xx.macaddr=E4:5F:01:57:C6:34 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tt        yS0,115200 console=tty1 root=PARTUUID=d2b297f7-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.igno        re-serial-consoles
            [Fri Aug 23 14:14:57 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
            [Fri Aug 23 14:14:57 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
            [Fri Aug 23 14:14:58 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
            Show mounted filesystems:
            TARGET                                SOURCE     FSTYPE     OPTIONS
            /                                     /dev/sda2  ext4       rw,noatime
            |-/dev                                devtmpfs   devtmpfs   rw,relatime,size=1800056k,nr_inodes=84157,mode=755
            | |-/dev/shm                          tmpfs      tmpfs      rw,nosuid,nodev
            | |-/dev/pts                          devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
            | `-/dev/mqueue                       mqueue     mqueue     rw,relatime
            |-/sys                                sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
            | |-/sys/kernel/security              securityfs securityfs rw,nosuid,nodev,noexec,relatime
            | |-/sys/fs/cgroup                    tmpfs      tmpfs      ro,nosuid,nodev,noexec,mode=755
            | | |-/sys/fs/cgroup/unified          cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
            | | |-/sys/fs/cgroup/systemd          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
            | | |-/sys/fs/cgroup/cpuset           cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
            | | |-/sys/fs/cgroup/net_cls,net_prio cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
            | | |-/sys/fs/cgroup/blkio            cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,blkio
            | | |-/sys/fs/cgroup/pids             cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,pids
            | | |-/sys/fs/cgroup/devices          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,devices
            | | |-/sys/fs/cgroup/freezer          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,freezer
            | | |-/sys/fs/cgroup/perf_event       cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
            | | `-/sys/fs/cgroup/cpu,cpuacct      cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
            | |-/sys/fs/bpf                       none       bpf        rw,nosuid,nodev,noexec,relatime,mode=700
            | |-/sys/kernel/debug                 debugfs    debugfs    rw,relatime
            | `-/sys/kernel/config                configfs   configfs   rw,relatime
            |-/proc                               proc       proc       rw,relatime
            | `-/proc/sys/fs/binfmt_misc          systemd-1  autofs     rw,relatime,fd=36,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
            |-/run                                tmpfs      tmpfs      rw,nosuid,nodev,mode=755
            | |-/run/lock                         tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
            | |-/run/rpc_pipefs                   sunrpc     rpc_pipefs rw,relatime
            | `-/run/user/1000                    tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=392984k,mode=700,uid=1000,gid=1000
            `-/boot                               /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mi        xed,errors=remount-ro
            /var:
            2.6G    /var/
            1.5G    /var/cache/apt
            1.5G    /var/cache
            1.4G    /var/cache/apt/archives
            789M    /var/lib
            Archived and active journals take up 8.0M in the file system.
            /opt/iobroker/backups:
            4.3G    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            824M    /opt/iobroker/iobroker-data/
            696M    /opt/iobroker/iobroker-data/files
            441M    /opt/iobroker/iobroker-data/files/javascript.admin
            409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
            24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
            24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
            23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
            17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map
            USB-Devices by-id:
            /dev/serial/by-id/usb-Device_GmbH_DvIR-USB_DvIR-USB_000524-if00-port0
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.20.4
            /usr/bin/node           v18.20.4
            /usr/bin/npm            10.7.0
            /usr/bin/npx            10.7.0
            /usr/bin/corepack       0.28.0
            nodejs:
              Installed: 18.20.4-1nodesource1
              Candidate: 18.20.4-1nodesource1
              Version table:
             *** 18.20.4-1nodesource1 600
                    500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                    100 /var/lib/dpkg/status
                 18.20.3-1nodesource1 600
                 18.20.2-1nodesource1 600
                 18.20.1-1nodesource1 600
                 18.20.0-1nodesource1 600
                 18.19.1-1nodesource1 600
                 18.19.0-1nodesource1 600
                 18.18.2-1nodesource1 600
                 18.18.1-1nodesource1 600
                 18.18.0-1nodesource1 600
                 18.17.1-1nodesource1 600
                 18.17.0-1nodesource1 600
                 18.16.1-1nodesource1 600
                 18.16.0-1nodesource1 600
                 18.15.0-1nodesource1 600
                 18.14.2-1nodesource1 600
                 18.14.1-1nodesource1 600
                 18.14.0-1nodesource1 600
                 18.13.0-1nodesource1 600
                 18.12.0-1nodesource1 600
                 18.11.0-1nodesource1 600
                 18.10.0-1nodesource1 600
                 18.9.1-1nodesource1 600
                 18.9.0-1nodesource1 600
                 18.8.0-1nodesource1 600
                 18.7.0-1nodesource1 600
                 18.6.0-1nodesource1 600
                 18.5.0-1nodesource1 600
                 18.4.0-1nodesource1 600
                 18.3.0-1nodesource1 600
                 18.2.0-1nodesource1 600
                 18.1.0-1nodesource1 600
                 18.0.0-1nodesource1 600
                 10.24.0~dfsg-1~deb10u3 500
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  6.0.9
            admin:          7.0.23
            javascript:     8.7.6
            nodejs modules from github:     0
            Adapter State
            + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
              system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
            + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
            + system.adapter.ebus.0                   : ebus                  : raspberrypi                              -  enabled
              system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
            + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
            + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
            + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
            + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
            + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
            + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
            + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
            + system.adapter.wolf-smartset.0          : wolf-smartset         : raspberrypi                              -  enabled
            + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            + instance is alive
            ioBroker-Repositories
            │ (index) │   name   │                           url                           │ auto upgrade │
            │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
            │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
            Active repo(s): stable
            Upgrade policy: none
            Installed ioBroker-Instances
            Used repository: stable
            Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
            Adapter    "admin"        : 7.0.23   , installed 7.0.23
            Adapter    "backitup"     : 3.0.19   , installed 3.0.19
            Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
            Adapter    "discovery"    : 4.5.0    , installed 4.5.0
            Adapter    "ebus"         : 3.3.4    , installed 3.3.4
            Adapter    "echarts"      : 1.7.2    , installed 1.7.2
            Adapter    "email"        : 1.3.1    , installed 1.3.1
            Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
            Adapter    "hmip"         : 1.23.3   , installed 1.23.3
            Adapter    "javascript"   : 8.7.6    , installed 8.7.6
            Controller "js-controller": 6.0.9    , installed 6.0.9
            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
            Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "solarwetter"  : 1.2.0    , installed 1.2.0
            Adapter    "wolf-smartset": 1.2.3    , installed 1.2.3
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            Objects and States
            Objects:        9367
            States:         8906
            Hit:1 http://archive.raspberrypi.org/debian buster InRelease
            Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
            Hit:3 https://repos.influxdata.com/debian stable InRelease
            Hit:4 https://repos.influxdata.com/debian buster InRelease
            Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
            Hit:6 https://repo.ebusd.eu/apt/default/buster buster InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20676      721/sshd
            tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        20846      703/influxd
            tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          19480      707/ebusd
            tcp        0      0 0.0.0.0:8089            0.0.0.0:*               LISTEN      0          19481      707/ebusd
            tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          21030      783/smbd
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19427      970/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19420      970/iobroker.js-con
            tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          21031      783/smbd
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       21373      989/io.admin.0
            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       24742      1140/io.ws.0
            tcp6       0      0 :::8086                 :::*                    LISTEN      998        19334      703/influxd
            tcp6       0      0 :::22                   :::*                    LISTEN      0          20686      721/sshd
            tcp6       0      0 ::1:3350                :::*                    LISTEN      0          18719      718/xrdp-sesman
            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       23966      1155/io.simple-api.
            tcp6       0      0 :::3000                 :::*                    LISTEN      109        21203      695/grafana-server
            tcp6       0      0 :::3389                 :::*                    LISTEN      111        21042      746/xrdp
            tcp6       0      0 :::445                  :::*                    LISTEN      0          21028      783/smbd
            tcp6       0      0 :::139                  :::*                    LISTEN      0          21029      783/smbd
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15346      692/dhcpcd
            udp        0      0 0.0.0.0:50817           0.0.0.0:*                           108        15105      437/avahi-daemon: r
            udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          19917      694/nmbd
            udp        0      0 192.168.178.47:137      0.0.0.0:*                           0          19916      694/nmbd
            udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          19904      694/nmbd
            udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          19919      694/nmbd
            udp        0      0 192.168.178.47:138      0.0.0.0:*                           0          19918      694/nmbd
            udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          19905      694/nmbd
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15103      437/avahi-daemon: r
            udp6       0      0 :::546                  :::*                                0          15357      692/dhcpcd
            udp6       0      0 :::52931                :::*                                108        15106      437/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        15104      437/avahi-daemon: r
            2024-08-23 15:36:15.729  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:36:22.548  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:36:29.418  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:36:36.396  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:36:43.393  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:36:50.112  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:36:57.033  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:37:03.747  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:37:11.014  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:37:18.072  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:37:24.543  - error: ebus.0 (8494) exception in ebusd_ReceiveData [Error: connect ECONNREFUSED 127.0.0.1:8889]
            2024-08-23 15:37:25.231  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:37:32.418  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:37:39.536  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:37:46.531  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:37:53.634  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:38:00.732  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:38:07.896  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:38:15.017  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:38:22.246  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:38:30.347  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:38:36.389  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:38:43.653  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:38:51.001  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            2024-08-23 15:38:58.341  - info: smartmeter.0 (1093) Received 6 values, 3 updated
            Marc Berg Homoran 2 Replies Last reply Reply Quote 0
            • Marc Berg
              Marc Berg Most Active @Krissie777 last edited by Marc Berg
              Du machst mich fertig. In die ebusd muss 8889 rein als httpport, nicht 8089.
              EDIT: es sind doch nur zwei Zahlen, ZWEI! 😥
              K 2 Replies Last reply Reply Quote 1
                Homoran Global Moderator Administrators @Krissie777 last edited by
                tcp
                da steht aber wieder was anderes!
                zeig die Konfiguration!
                  @marc-berg
                  Hallo Marc, im Adapter ist es so eingestellt, wie ich gesagt hatte:
                  Wo die 8080 herkommt weiß ich nicht...
                  LG
                  Kris
                    nicht 8080, sondern 8089.
                    die kommt vom ebusd nehme ich an
                      @marc-berg
                      das ist doch in der Zeile bei influx, oder?
                      LG
                      Kris
                        Krissie777 @Homoran last edited by
                        Hallo Hormoran, entschuldige ich meinte 8089, hatte mich verschieben.
                        In dem Screenshot seht Ihr dass ich die Adressen richtig eingestellt habe, oder?
                        LG
                        Kris
                        • Marc Berg
                          Nein, ganz andere Baustelle.
                          Hier hattest du es gaaanz oben schon richtig:
                          EBUSD_OPTS="--device=192.178.168.70:5002 --httpport=8889 --scanconfig --latency=30000 --configpath=http://ebusd.eu/config/"
                          Hinter "httpport=", 8889. acht-acht-acht-neun
                            im Adapter, und was steht im ebusd?
                              @marc-berg
                              Hallo MArc, bin in die Konfig rein, die stimmt doch?
                              EBUSD_OPTS="--device=127.0.0.1:8889 --httpport=8888 --scanconfig=full --latency=30000 --configpath=/etc/ebusd"
                              Ich habe hier nichts mehr verändert.
                              LG
                              Kris
                              Entschuldigt bitte, ich hatte eine stärkere Grippe...
                              Homoran Marc Berg 2 Replies Last reply Reply Quote 0
                                httpport=8888
                                • Marc Berg
                                  --httpport=8888
                                  sorry, ich geb' auf. Mach weiter, wenn Die Grippe vorbei ist.
                                    danke mist, kann leider nicht 100% klar denken...
                                    LG ändere es sofort
                                    • Marc Berg
                                      Dann ist es leider etwas unfair, die Denkarbeit auf andere zu verlagern.
                                      K 2 Replies Last reply Reply Quote 0
                                        @marc-berg
                                        Hallo Marc, das kann ich verstehen und melde mich, wenn es mir wieder besser geht. Ist das io für Dich?
                                        Das letzte was ich noch probiere ist:
                                        EBUSD_OPTS="--device=127.0.0.1:8889 --httpport=8889 --scanconfig=full --latency=30000 --configpath=/etc/ebusd"
                                        LG und bis bald
                                        Vielen Dank bisherr fü alles
                                          jetzt hast du beides auf 8889 gestellt.
                                          nennt dich Corona!
                                          gute Besserung.
                                          Das wird auch noch Wochen anhalten
                                            @marc-berg
                                            Hallo Marc, nochmal vielen Dank für Deine Hilfe und Unterstützung vergangenes Jahr.
                                            Ich habe jetzt da ich endlich die Zeit hatte, ein komplett neues Debian System aufgesetzt und es funktioniert alles wunderbar bis auf den Ebus.
                                            Da dieser Chat schon sehr alt ist habe ich einen neuen angelegt:
                                            https://forum.iobroker.net/post/1291620
                                            Darf ich Dich bitten, hier noch zusätzlich zu untersützen?
                                            Danke Dir und LG
                                            Kris
                                            81.1k
                                            2903
