    4. Exception in ebusd_ReceiveData [Error: connect ETIMEDOUT]
      Krissie777 @Marc Berg last edited by
      @marc-berg
      ok habe ich vertauscht, wieder der Fehler:
      exception in ebusd_ReceiveData [Error: connect ECONNREFUSED 127.0.0.1:8889]
      Kris
      • Marc Berg
        Marc Berg Most Active last edited by
        @krissie777 sagte in Exception in ebusd_ReceiveData [Error: connect ETIMEDOUT]:
        und iob diag gibt jetzt immer noch
        > tcp        0      0 0.0.0.0:8889            0.0.0.0:*               LISTEN      0          967460     26805/ebusd
        aus?
          @marc-berg said in Exception in ebusd_ReceiveData [Error: connect ETIMEDOUT]:
          iob diag
          Skript v.2024-05-22
          *** BASE SYSTEM ***
             Static hostname: raspberrypi
                   Icon name: computer
            Operating System: Raspbian GNU/Linux 10 (buster)
                      Kernel: Linux 5.10.103-v7l+
                Architecture: arm
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : armv7l
          Userland        : 32 bit
          Systemuptime and Load:
           15:37:31 up  1:22,  2 users,  load average: 1.21, 0.69, 0.52
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          ~ Under-voltage detected
          ~ Arm frequency capped
          Previously detected issues:
          ~ Under-voltage has occurred
          ~ Arm frequency capping has occurred
          *** Time and Time Zones ***
                         Local time: Fri 2024-08-23 15:37:31 CEST
                     Universal time: Fri 2024-08-23 13:37:31 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          pi
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
          *** Display-Server-Setup ***
          Display-Server: false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:           3.8G        1.0G        1.4G        9.0M        1.5G        2.8G
          Swap:           99M          0B         99M
          Total:         3.9G        1.0G        1.5G
          Active iob-Instances:   15
                   3837 M total memory
                   1010 M used memory
                    331 M active memory
                   2050 M inactive memory
                   1351 M free memory
                     87 M buffer memory
                   1387 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          top - 15:37:32 up  1:22,  2 users,  load average: 1.21, 0.69, 0.52
          Tasks: 156 total,   2 running, 154 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 18.3 us, 20.4 sy,  0.0 ni, 58.1 id,  1.1 wa,  0.0 hi,  2.2 si,  0.0 st
          MiB Mem :   3837.7 total,   1351.6 free,   1010.7 used,   1475.5 buff/cache
          MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2827.9 avail Mem
          *** FAILED SERVICES ***
            UNIT               LOAD   ACTIVE SUB    DESCRIPTION
          * PiEMItMgmt.service loaded failed failed PiEM-It! Mgmt-Modul, respawn
          * Webserver.service  loaded failed failed PiEM-It! Webserver-Modul, respawn
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          2 loaded units listed. Pass --all to see loaded but inactive units, too.
          To show all installed unit files use 'systemctl list-unit-files'.
          *** FILESYSTEM ***
          /dev/root      ext4       29G   14G   15G  49% /
          devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
          tmpfs          tmpfs     1.9G  9.6M  1.9G   1% /run
          tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
          /dev/sda1      vfat      253M   49M  204M  20% /boot
          tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
          [Fri Aug 23 14:14:55 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hd        mi=1 video=HDMI-A-1:1920x1080M@60D smsc95xx.macaddr=E4:5F:01:57:C6:34 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tt        yS0,115200 console=tty1 root=PARTUUID=d2b297f7-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.igno        re-serial-consoles
          [Fri Aug 23 14:14:57 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
          [Fri Aug 23 14:14:57 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Fri Aug 23 14:14:58 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
          Show mounted filesystems:
          TARGET                                SOURCE     FSTYPE     OPTIONS
          /                                     /dev/sda2  ext4       rw,noatime
          |-/dev                                devtmpfs   devtmpfs   rw,relatime,size=1800056k,nr_inodes=84157,mode=755
          | |-/dev/shm                          tmpfs      tmpfs      rw,nosuid,nodev
          | |-/dev/pts                          devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
          | `-/dev/mqueue                       mqueue     mqueue     rw,relatime
          |-/sys                                sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/security              securityfs securityfs rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/cgroup                    tmpfs      tmpfs      ro,nosuid,nodev,noexec,mode=755
          | | |-/sys/fs/cgroup/unified          cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
          | | |-/sys/fs/cgroup/systemd          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
          | | |-/sys/fs/cgroup/cpuset           cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
          | | |-/sys/fs/cgroup/net_cls,net_prio cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
          | | |-/sys/fs/cgroup/blkio            cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,blkio
          | | |-/sys/fs/cgroup/pids             cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,pids
          | | |-/sys/fs/cgroup/devices          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,devices
          | | |-/sys/fs/cgroup/freezer          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,freezer
          | | |-/sys/fs/cgroup/perf_event       cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
          | | `-/sys/fs/cgroup/cpu,cpuacct      cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
          | |-/sys/fs/bpf                       none       bpf        rw,nosuid,nodev,noexec,relatime,mode=700
          | |-/sys/kernel/debug                 debugfs    debugfs    rw,relatime
          | `-/sys/kernel/config                configfs   configfs   rw,relatime
          |-/proc                               proc       proc       rw,relatime
          | `-/proc/sys/fs/binfmt_misc          systemd-1  autofs     rw,relatime,fd=36,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
          |-/run                                tmpfs      tmpfs      rw,nosuid,nodev,mode=755
          | |-/run/lock                         tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
          | |-/run/rpc_pipefs                   sunrpc     rpc_pipefs rw,relatime
          | `-/run/user/1000                    tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=392984k,mode=700,uid=1000,gid=1000
          `-/boot                               /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mi        xed,errors=remount-ro
          /var:
          2.6G    /var/
          1.5G    /var/cache/apt
          1.5G    /var/cache
          1.4G    /var/cache/apt/archives
          789M    /var/lib
          Archived and active journals take up 8.0M in the file system.
          /opt/iobroker/backups:
          4.3G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          824M    /opt/iobroker/iobroker-data/
          696M    /opt/iobroker/iobroker-data/files
          441M    /opt/iobroker/iobroker-data/files/javascript.admin
          409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
          24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
          23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
          17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-Device_GmbH_DvIR-USB_DvIR-USB_000524-if00-port0
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.20.4
          /usr/bin/node           v18.20.4
          /usr/bin/npm            10.7.0
          /usr/bin/npx            10.7.0
          /usr/bin/corepack       0.28.0
          nodejs:
            Installed: 18.20.4-1nodesource1
            Candidate: 18.20.4-1nodesource1
            Version table:
           *** 18.20.4-1nodesource1 600
                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                  100 /var/lib/dpkg/status
               18.20.3-1nodesource1 600
               18.20.2-1nodesource1 600
               18.20.1-1nodesource1 600
               18.20.0-1nodesource1 600
               18.19.1-1nodesource1 600
               18.19.0-1nodesource1 600
               18.18.2-1nodesource1 600
               18.18.1-1nodesource1 600
               18.18.0-1nodesource1 600
               18.17.1-1nodesource1 600
               18.17.0-1nodesource1 600
               18.16.1-1nodesource1 600
               18.16.0-1nodesource1 600
               18.15.0-1nodesource1 600
               18.14.2-1nodesource1 600
               18.14.1-1nodesource1 600
               18.14.0-1nodesource1 600
               18.13.0-1nodesource1 600
               18.12.0-1nodesource1 600
               18.11.0-1nodesource1 600
               18.10.0-1nodesource1 600
               18.9.1-1nodesource1 600
               18.9.0-1nodesource1 600
               18.8.0-1nodesource1 600
               18.7.0-1nodesource1 600
               18.6.0-1nodesource1 600
               18.5.0-1nodesource1 600
               18.4.0-1nodesource1 600
               18.3.0-1nodesource1 600
               18.2.0-1nodesource1 600
               18.1.0-1nodesource1 600
               18.0.0-1nodesource1 600
               10.24.0~dfsg-1~deb10u3 500
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  6.0.9
          admin:          7.0.23
          javascript:     8.7.6
          nodejs modules from github:     0
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
            system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
          + system.adapter.ebus.0                   : ebus                  : raspberrypi                              -  enabled
            system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
          + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
          + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
          + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
          + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
          + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
          + system.adapter.wolf-smartset.0          : wolf-smartset         : raspberrypi                              -  enabled
          + system.adapter.ws.0                     : ws                    : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          │ (index) │   name   │                           url                           │ auto upgrade │
          │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
          │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
          Adapter    "admin"        : 7.0.23   , installed 7.0.23
          Adapter    "backitup"     : 3.0.19   , installed 3.0.19
          Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
          Adapter    "discovery"    : 4.5.0    , installed 4.5.0
          Adapter    "ebus"         : 3.3.4    , installed 3.3.4
          Adapter    "echarts"      : 1.7.2    , installed 1.7.2
          Adapter    "email"        : 1.3.1    , installed 1.3.1
          Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
          Adapter    "hmip"         : 1.23.3   , installed 1.23.3
          Adapter    "javascript"   : 8.7.6    , installed 8.7.6
          Controller "js-controller": 6.0.9    , installed 6.0.9
          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "solarwetter"  : 1.2.0    , installed 1.2.0
          Adapter    "wolf-smartset": 1.2.3    , installed 1.2.3
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Objects and States
          Objects:        9367
          States:         8906
          Hit:1 http://archive.raspberrypi.org/debian buster InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:3 https://repos.influxdata.com/debian stable InRelease
          Hit:4 https://repos.influxdata.com/debian buster InRelease
          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
          Hit:6 https://repo.ebusd.eu/apt/default/buster buster InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20676      721/sshd
          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        20846      703/influxd
          tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          19480      707/ebusd
          tcp        0      0 0.0.0.0:8089            0.0.0.0:*               LISTEN      0          19481      707/ebusd
          tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          21030      783/smbd
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19427      970/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19420      970/iobroker.js-con
          tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          21031      783/smbd
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       21373      989/io.admin.0
          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       24742      1140/io.ws.0
          tcp6       0      0 :::8086                 :::*                    LISTEN      998        19334      703/influxd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          20686      721/sshd
          tcp6       0      0 ::1:3350                :::*                    LISTEN      0          18719      718/xrdp-sesman
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       23966      1155/io.simple-api.
          tcp6       0      0 :::3000                 :::*                    LISTEN      109        21203      695/grafana-server
          tcp6       0      0 :::3389                 :::*                    LISTEN      111        21042      746/xrdp
          tcp6       0      0 :::445                  :::*                    LISTEN      0          21028      783/smbd
          tcp6       0      0 :::139                  :::*                    LISTEN      0          21029      783/smbd
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15346      692/dhcpcd
          udp        0      0 0.0.0.0:50817           0.0.0.0:*                           108        15105      437/avahi-daemon: r
          udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          19917      694/nmbd
          udp        0      0 192.168.178.47:137      0.0.0.0:*                           0          19916      694/nmbd
          udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          19904      694/nmbd
          udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          19919      694/nmbd
          udp        0      0 192.168.178.47:138      0.0.0.0:*                           0          19918      694/nmbd
          udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          19905      694/nmbd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15103      437/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          15357      692/dhcpcd
          udp6       0      0 :::52931                :::*                                108        15106      437/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        15104      437/avahi-daemon: r
          2024-08-23 15:36:15.729  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:36:22.548  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:36:29.418  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:36:36.396  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:36:43.393  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:36:50.112  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:36:57.033  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:37:03.747  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:37:11.014  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:37:18.072  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:37:24.543  - error: ebus.0 (8494) exception in ebusd_ReceiveData [Error: connect ECONNREFUSED 127.0.0.1:8889]
          2024-08-23 15:37:25.231  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:37:32.418  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:37:39.536  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:37:46.531  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:37:53.634  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:38:00.732  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:38:07.896  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:38:15.017  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:38:22.246  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:38:30.347  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:38:36.389  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:38:43.653  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:38:51.001  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          2024-08-23 15:38:58.341  - info: smartmeter.0 (1093) Received 6 values, 3 updated
          Marc Berg Homoran 2 Replies Last reply Reply Quote 0
          • Marc Berg
            Marc Berg Most Active @Krissie777 last edited by Marc Berg
            Du machst mich fertig. In die ebusd muss 8889 rein als httpport, nicht 8089.
            EDIT: es sind doch nur zwei Zahlen, ZWEI! 😥
            K 2 Replies Last reply Reply Quote 1
              Homoran Global Moderator Administrators @Krissie777 last edited by
              tcp
              da steht aber wieder was anderes!
              zeig die Konfiguration!
                @marc-berg
                Hallo Marc, im Adapter ist es so eingestellt, wie ich gesagt hatte:
                Wo die 8080 herkommt weiß ich nicht...
                LG
                Kris
                  nicht 8080, sondern 8089.
                  die kommt vom ebusd nehme ich an
                    @marc-berg
                    das ist doch in der Zeile bei influx, oder?
                    LG
                    Kris
                      Krissie777 @Homoran last edited by
                      Hallo Hormoran, entschuldige ich meinte 8089, hatte mich verschieben.
                      In dem Screenshot seht Ihr dass ich die Adressen richtig eingestellt habe, oder?
                      LG
                      Kris
                      • Marc Berg
                        Nein, ganz andere Baustelle.
                        Hier hattest du es gaaanz oben schon richtig:
                        EBUSD_OPTS="--device=192.178.168.70:5002 --httpport=8889 --scanconfig --latency=30000 --configpath=http://ebusd.eu/config/"
                        Hinter "httpport=", 8889. acht-acht-acht-neun
                          im Adapter, und was steht im ebusd?
                            @marc-berg
                            Hallo MArc, bin in die Konfig rein, die stimmt doch?
                            EBUSD_OPTS="--device=127.0.0.1:8889 --httpport=8888 --scanconfig=full --latency=30000 --configpath=/etc/ebusd"
                            Ich habe hier nichts mehr verändert.
                            LG
                            Kris
                            Entschuldigt bitte, ich hatte eine stärkere Grippe...
                            Homoran Marc Berg 2 Replies Last reply Reply Quote 0
                              httpport=8888
                              • Marc Berg
                                --httpport=8888
                                sorry, ich geb' auf. Mach weiter, wenn Die Grippe vorbei ist.
                                  danke mist, kann leider nicht 100% klar denken...
                                  LG ändere es sofort
                                  • Marc Berg
                                    Dann ist es leider etwas unfair, die Denkarbeit auf andere zu verlagern.
                                    K 2 Replies Last reply Reply Quote 0
                                      @marc-berg
                                      Hallo Marc, das kann ich verstehen und melde mich, wenn es mir wieder besser geht. Ist das io für Dich?
                                      Das letzte was ich noch probiere ist:
                                      EBUSD_OPTS="--device=127.0.0.1:8889 --httpport=8889 --scanconfig=full --latency=30000 --configpath=/etc/ebusd"
                                      LG und bis bald
                                      Vielen Dank bisherr fü alles
                                        jetzt hast du beides auf 8889 gestellt.
                                        nennt dich Corona!
                                        gute Besserung.
                                        Das wird auch noch Wochen anhalten
                                          @marc-berg
                                          Hallo Marc, nochmal vielen Dank für Deine Hilfe und Unterstützung vergangenes Jahr.
                                          Ich habe jetzt da ich endlich die Zeit hatte, ein komplett neues Debian System aufgesetzt und es funktioniert alles wunderbar bis auf den Ebus.
                                          Da dieser Chat schon sehr alt ist habe ich einen neuen angelegt:
                                          https://forum.iobroker.net/post/1291620
                                          Darf ich Dich bitten, hier noch zusätzlich zu untersützen?
                                          Danke Dir und LG
                                          Kris
                                            Hallo homoran, nochmal vielen Dank für Deine Hilfe und Unterstützung vergangenes Jahr.
                                            Danke Dir und LG
                                            Kris
                                            81.1k
                                            2903
