    4. "Hosts" zeigt verfügbares Update, aber keines verfügbar
    • teletapi
      teletapi @invidianer last edited by teletapi
      Ich hatte die Meldung auch gerade und hab "sudo apt update && sudo apt full-upgrade" ausgeführt damit sollte das Update erledigt sein. Mein repo steht aber auf Beta
      Skript v.2024-05-22
      *** BASE SYSTEM ***
       Static hostname: Raspberrypi5
             Icon name: computer
                Kernel: Linux 6.6.31+rpt-rpi-2712
          Architecture: arm64
      Model           : Raspberry Pi 5 Model B Rev 1.0
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       11:11:01 up 2 min,  2 users,  load average: 1.44, 0.79, 0.32
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Fri 2024-08-23 11:11:01 CEST
                 Universal time: Fri 2024-08-23 09:11:01 UTC
                       RTC time: Fri 2024-08-23 09:11:01
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            8.4G        2.4G        5.3G        5.6M        924M        6.1G
      Swap:           209M          0B        209M
      Total:          8.7G        2.4G        5.5G
      Active iob-Instances:   32
               8052 M total memory
               2260 M used memory
               2370 M active memory
                377 M inactive memory
               5009 M free memory
                 87 M buffer memory
                794 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      top - 11:11:02 up 2 min,  2 users,  load average: 1.44, 0.79, 0.32
      Tasks: 205 total,   2 running, 203 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8052.4 total,   5009.1 free,   2261.3 used,    881.8 buff/cache
      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5791.0 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  3.8G     0  3.8G   0% /dev
      tmpfs          tmpfs     806M  5.3M  800M   1% /run
      /dev/sda2      ext4       59G   16G   40G  28% /
      tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
      tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
      /dev/sda1      vfat      510M   64M  447M  13% /boot/firmware
      tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
      [Fri Aug 23 11:08:02 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=D8:3A:DD:A3:25:8A vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=beeda195-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
      [Fri Aug 23 11:08:05 2024] EXT4-fs (sda2): mounted filesystem 6835594d-a5f3-459f-a244-318060e7e0ab ro with ordered data mode. Quota mode: none.
      [Fri Aug 23 11:08:06 2024] EXT4-fs (sda2): re-mounted 6835594d-a5f3-459f-a244-318060e7e0ab r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET                                                  SOURCE      FSTYPE      OPTIONS
      /                                                       /dev/sda2   ext4        rw,noatime
      |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
      |-/proc                                                 proc        proc        rw,relatime
      | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=653
      |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
      |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=3950816k,nr_inodes=246926,mode=755
      | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev
      | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
      |-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=824576k,mode=755
      | |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | `-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=824560k,nr_inodes=206140,mode=700,uid=1000,gid=1000
      `-/boot/firmware                                        /dev/sda1   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      2.7G    /var/
      1.2G    /var/lib
      968M    /var/lib/influxdb
      967M    /var/lib/influxdb/engine
      959M    /var/lib/influxdb/engine/data/235761e38e03d026/autogen
      Archived and active journals take up 941.8M in the file system.
      /opt/iobroker/backups:
      2.8G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      969M    /opt/iobroker/iobroker-data/
      690M    /opt/iobroker/iobroker-data/files
      493M    /opt/iobroker/iobroker-data/files/javascript.admin
      461M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      460M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      34M     /opt/iobroker/iobroker-data/objects.jsonl
      22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js.map
      19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.1d90720e.js.map
      11M     /opt/iobroker/iobroker-data/states.jsonl
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.17.0
      /usr/bin/node           v20.17.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.3
      nodejs:
        Installed: 20.17.0-1nodesource1
        Candidate: 20.17.0-1nodesource1
        Version table:
       *** 20.17.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.11
      admin:          7.0.24
      javascript:     8.8.2
      nodejs modules from github:     2
      +-- iobroker.energiefluss-erweitert@0.5.1-alpha.4 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#3bca8a9aec27db7730fd9b97d3c61600ef989fd8)
      +-- iobroker.jarvis@3.2.0-beta.54 (git+ssh://git@github.com/Zefau/ioBroker.jarvis.git#7492e53b87211c2b5dc032a9f6db3fd6d3e54d9e)
      Adapter State
      + system.adapter.admin.0                  : admin                 : Raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : Raspberrypi5                             -  enabled
        system.adapter.alias-manager.0          : alias-manager         : Raspberrypi5                             -  enabled
      + system.adapter.alpha-ess.0              : alpha-ess             : Raspberrypi5                             -  enabled
      + system.adapter.backitup.0               : backitup              : Raspberrypi5                             -  enabled
      + system.adapter.cloud.0                  : cloud                 : Raspberrypi5                             -  enabled
      + system.adapter.discovery.0              : discovery             : Raspberrypi5                             -  enabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: Raspberrypi5                             -  enabled
      + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: Raspberrypi5                             -  enabled
        system.adapter.energiefluss-erweitert.2 : energiefluss-erweitert: Raspberrypi5                             - disabled
        system.adapter.energiefluss-erweitert.4 : energiefluss-erweitert: Raspberrypi5                             - disabled
      + system.adapter.fritzdect.0              : fritzdect             : Raspberrypi5                             -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : Raspberrypi5                             -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 18701
      + system.adapter.hm-rpc.1                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 18701
      + system.adapter.hm-rpc.2                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 12001
      + system.adapter.hm-rpc.3                 : hm-rpc                : Raspberrypi5                             -  enabled, port: 0
      + system.adapter.hue.0                    : hue                   : Raspberrypi5                             -  enabled, port: 80
        system.adapter.ical.0                   : ical                  : Raspberrypi5                             -  enabled
      + system.adapter.influxdb.0               : influxdb              : Raspberrypi5                             -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : Raspberrypi5                             -  enabled
      + system.adapter.jarvis.0                 : jarvis                : Raspberrypi5                             -  enabled
      + system.adapter.javascript.0             : javascript            : Raspberrypi5                             -  enabled
      + system.adapter.modbus.0                 : modbus                : Raspberrypi5                             -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : Raspberrypi5                             -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.net-tools.0              : net-tools             : Raspberrypi5                             -  enabled
      + system.adapter.node-red.0               : node-red              : Raspberrypi5                             -  enabled, port: 1880, bind: 0.0.0.0
        system.adapter.openweathermap.0         : openweathermap        : Raspberrypi5                             -  enabled
      + system.adapter.ping.0                   : ping                  : Raspberrypi5                             -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : Raspberrypi5                             -  enabled
      + system.adapter.simple-api.0             : simple-api            : Raspberrypi5                             -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
      + system.adapter.socketio.0               : socketio              : Raspberrypi5                             -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : Raspberrypi5                             -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.telegram.0               : telegram              : Raspberrypi5                             -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : Raspberrypi5                             -  enabled
      + system.adapter.web.0                    : web                   : Raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 7.0.24   , installed 7.0.24
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "alpha-ess"    : 2.1.4    , installed 2.1.4
      Adapter    "backitup"     : 3.0.20   , installed 3.0.20
      Adapter    "energiefluss-erweitert": 0.4.1, installed 0.5.1-alpha.4
      Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
      Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
      Adapter    "hm-rpc"       : 2.0.0    , installed 2.0.0
      Adapter    "hue"          : 3.12.0   , installed 3.12.0
      Adapter    "ical"         : 1.15.0   , installed 1.15.0
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "jarvis"       : 3.1.8    , installed 3.2.0-beta.54
      Adapter    "javascript"   : 8.8.2    , installed 8.8.2
      Controller "js-controller": 6.0.11   , installed 6.0.11
      Adapter    "modbus"       : 6.2.3    , installed 6.2.3
      Adapter    "mqtt"         : 6.0.2    , installed 6.0.2
      Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
      Adapter    "ping"         : 1.7.0    , installed 1.7.0
      Adapter    "rpi2"         : 2.0.0    , installed 2.0.0
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "telegram"     : 3.9.0    , installed 3.9.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "web"          : 6.3.0    , installed 6.3.0
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Objects and States
      Objects:        10268
      States:         10337
      Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:2 https://apt.grafana.com stable InRelease
      Hit:3 http://deb.debian.org/debian bookworm InRelease
      Hit:4 https://repos.influxdata.com/debian stable InRelease
      Hit:5 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:6 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5706       797/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7797       955/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6799       955/iobroker.js-con
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       11624      1564/io.jarvis.0
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       10368      1346/io.sonoff.0
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       5959       1084/node-red
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      106        4818       789/mosquitto
      tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       8288       1203/io.hm-rpc.3
      tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       6042       1188/io.hm-rpc.0
      tcp        0      0 192.168.178.82:18702    0.0.0.0:*               LISTEN      1001       11406      1416/io.hm-rpc.1
      tcp        0      0 192.168.178.82:12001    0.0.0.0:*               LISTEN      1001       8544       1434/io.hm-rpc.2
      tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       10835      1584/io.simple-api.
      tcp6       0      0 :::22                   :::*                    LISTEN      0          5708       797/sshd: /usr/sbin
      tcp6       0      0 :::1883                 :::*                    LISTEN      106        4819       789/mosquitto
      tcp6       0      0 :::3000                 :::*                    LISTEN      107        4917       954/grafana
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       10888      1619/io.socketio.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        5796       875/influxd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5854       997/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9723       1660/io.web.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5539       659/avahi-daemon: r
      udp        0      0 0.0.0.0:51043           0.0.0.0:*                           104        5541       659/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        5540       659/avahi-daemon: r
      udp6       0      0 :::57582                :::*                                104        5542       659/avahi-daemon: r
      udp6       0      0 fe80::f05b:9255:16f:546 :::*                                0          6770       745/NetworkManager
      udp6       0      0 fe80::38be:beb2:fe6:546 :::*                                0          6438       745/NetworkManager
      2024-08-23 11:10:20.695  - info: sonoff.0 (1346) Client [Balkon_Weihnachtsbeleuchtung] connected with secret 1724404220693_2826
      2024-08-23 11:10:20.709  - info: sonoff.0 (1346) Client [Steckdose_Waschmaschine] connected with secret 1724404220705_6298
      2024-08-23 11:10:20.930  - info: sonoff.0 (1346) Client [Gosund_01_Magenta] connected with secret 1724404220930_9471
      2024-08-23 11:10:20.932  - info: sonoff.0 (1346) Client [Display_Büro] connected with secret 1724404220930_5007
      2024-08-23 11:10:21.024  - info: simple-api.0 (1584) starting. Version 2.8.0 in /opt/iobroker/node_modules/iobroker.simple-api, node: v20.17.0, js-controller: 6.0.11
      2024-08-23 11:10:21.044  - info: simple-api.0 (1584) simpleAPI server listening on port 8087
      2024-08-23 11:10:21.045  - info: simple-api.0 (1584) Allow states only when user is owner: false
      2024-08-23 11:10:21.054  - info: simple-api.0 (1584) http server listening on port 8087
      2024-08-23 11:10:21.092  - info: sonoff.0 (1346) Client [Gosund_04] connected with secret 1724404221092_3351
      2024-08-23 11:10:24.125  - info: host.Raspberrypi5 instance system.adapter.socketio.0 in version "6.7.1" started with pid 1619
      2024-08-23 11:10:25.135  - info: socketio.0 (1619) starting. Version 6.7.1 in /opt/iobroker/node_modules/iobroker.socketio, node: v20.17.0, js-controller: 6.0.11
      2024-08-23 11:10:25.170  - info: socketio.0 (1619) socket.io server listening on port 8084
      2024-08-23 11:10:28.063  - info: host.Raspberrypi5 instance system.adapter.web.0 in version "6.3.0" started with pid 1660
      2024-08-23 11:10:28.438  - info: openweathermap.0 (1473) Terminated (NO_ERROR): Without reason
      2024-08-23 11:10:28.982  - info: host.Raspberrypi5 instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
      2024-08-23 11:10:29.173  - info: web.0 (1660) starting. Version 6.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.11
      2024-08-23 11:10:29.301  - info: web.0 (1660) socket.io server listening on port 8082
      2024-08-23 11:10:29.421  - info: web.0 (1660) Connecting extension "energiefluss-erweitert/lib/web.js"
      2024-08-23 11:10:29.424  - info: web.0 (1660) Connecting extension "energiefluss-erweitert/lib/web.js"
      2024-08-23 11:10:29.432  - info: web.0 (1660) http server listening on port 8082
      2024-08-23 11:10:32.103  - info: host.Raspberrypi5 instance system.adapter.energiefluss-erweitert.1 in version "0.5.1-alpha.4" (non-npm: SKB-CGN/ioBroker.energiefluss-erweitert) started with pid 1701
      2024-08-23 11:10:32.903  - info: energiefluss-erweitert.1 (1701) starting. Version 0.5.1-alpha.4 (non-npm: SKB-CGN/ioBroker.energiefluss-erweitert) in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v20.17.0, js-controller: 6.0.11
      2024-08-23 11:10:32.930  - info: energiefluss-erweitert.1 (1701) Adapter started. Loading config!
      2024-08-23 11:10:33.656  - info: energiefluss-erweitert.1 (1701) Configuration loaded!
      2024-08-23 11:10:33.657  - info: energiefluss-erweitert.1 (1701) Requesting the following states: energiefluss-erweitert.1.configuration,alpha-ess.0.Realtime.Battery_SOC,alpha-ess.0.Summary.Income_total,alpha-ess.0.Realtime.PV_power_string_1,alpha-ess.0.Realtime.PV_power_string_2,alpha-ess.0.Realtime.PV_power_total,alpha-ess.0.Realtime.Grid_power_total,alpha-ess.0.Realtime.Load_total,alpha-ess.0.Summary.Grid_consumption_today,alpha-ess.0.Summary.Grid_feed_in_today,alpha-ess.0.Summary.Consumption_today,alpha-ess.0.Summary.Generation_today,alpha-ess.0.Realtime.Battery_power,alpha-ess.0.Summary.Self_sufficiency_total,alpha-ess.0.Summary.Self_consumption_total,javascript.0.variables.dayTime,openweathermap.0.forecast.current.temperature,openweathermap.0.forecast.day1.temperatureMax,openweathermap.0.forecast.current.sunrise,openweathermap.0.forecast.current.windSpeed,javascript.0.Astro.Zeiten.06-solarNoon,javascript.0.variables.astro.sunrise,javascript.0.variables.astro.sunset,alpha-ess.0.Realtime.Charging_pile_power_total,modbus.0.holdingRegisters.1055_PV1_power,modbus.0.holdingRegisters.1059_PV2_power,hm-rpc.1.00089D89A244F2.2.STATE,mqtt.0.Wechselrichter.total.P_AC,modbus.0.holdingRegisters.2258_The_system_total_PV_energy,modbus.0.holdingRegisters.258_BatterySOC,energiefluss-erweitert.1.calculation.battery.remaining,modbus.0.holdingRegisters.281_Battery_capacity,modbus.0.holdingRegisters.2128_UPS_Reserve_Soc,modbus.0.holdingRegisters.294_Battery_Power,sonoff.0.Tasmota Energie LG E320.E320_Power_in,mqtt.0.solar24.total.P_AC,modbus.0.holdingRegisters.161_Total_Active_power_(PVMeter),openweathermap.0.forecast.current.icon,openweathermap.0.forecast.day1.icon
      • icebear
        icebear @invidianer last edited by
        @invidianer said in "Hosts" zeigt verfügbares Update, aber keines verfügbar:
        „Bestätigen und schließen“ anklicken, dann sollte es erledigt sein.
        Ja, das mach ich ja, aber die Meldung poppt bei jedem Browser refresh oder bei bei neuanmeldung am Admin immer wieder neu auf.
        I JoJo58 2 Replies Last reply Reply Quote 0
        • I
          invidianer @icebear last edited by
          @icebear
          Achso? Gut, das ist dann ja bissi blöd.
          (Ich hatte die Updates dann immer direkt gemacht, daher kann ich es nicht feststellen.)
          • JoJo58
            JoJo58 @icebear last edited by
            @icebear Hast du den ganz neuen Admin, Version 7.0.23? Damit sollte das vorbei sein. So habe ich es verstanden...
            icebear 1 Reply Last reply Reply Quote 0
            • icebear
              icebear @JoJo58 last edited by
              @jojo58 said in "Hosts" zeigt verfügbares Update, aber keines verfügbar:
              Ich hab grad auf 7.0.24 das update gemacht, die Meldung poppt aber weiterhin auf.
              • haus-automatisierung
                haus-automatisierung Developer Most Active @icebear last edited by
                @icebear sagte in "Hosts" zeigt verfügbares Update, aber keines verfügbar:
                Bei mir läuft ioBroker im Docker Container von Buanet
                In Docker-Containern sollte die Meldung gar nicht kommen (ab js-controller 6.0.11)
                https://github.com/ioBroker/ioBroker.js-controller/commit/5f45bcb2855730898c2abe049b073f40236989a4
                0 foxriver76 committed to ioBroker/ioBroker.js-controller
                [feat]: only generate packageUpdates notification if a new package update has been detected (#2865)
                * only generate packageUpdates notification if a new package update has been detected
                - closes #2864
                * reuse const
                * remove unnecessary check
                * Update CHANGELOG.md
                Will be backported to Kiera
                * Update main.ts
                * Replace find by some
                icebear 1 Reply Last reply Reply Quote 1
                • icebear
                  @haus-automatisierung
                  Ah, ok, ich bin aktuell noch auf 6.0.9, dann werd ich mal das Update auf 6.0.11 machen
                  Danke für den Hinweis.
                    warp735 @invidianer last edited by
                    @invidianer sagte in "Hosts" zeigt verfügbares Update, aber keines verfügbar:
                    und dachte, nach dem Update würde die „1“ verschwinden, tat sie aber nicht.
                    Das ist bei den Adapter Updates leider auch so "blöd"
                    Man aktualisiert, aber die blöde Meldung muss man nochmal zusätzlich bestätigen. Warum verschwindet die nicht von alleine?
                    Thomas Braun haus-automatisierung 2 Replies Last reply Reply Quote 0
                      Thomas Braun Most Active @warp735 last edited by
                      @warp735 sagte in "Hosts" zeigt verfügbares Update, aber keines verfügbar:
                      Weil die Informationen in Intervallen abgerufen werden.
                        haus-automatisierung Developer Most Active @warp735 last edited by
                        @warp735 Würde sie - nach der nächsten Prüfung
                        • icebear
                          icebear @haus-automatisierung last edited by
                          @haus-automatisierung said in "Hosts" zeigt verfügbares Update, aber keines verfügbar:
                          Ich hab jetzt das Update auf 6.0.11 gemacht, dann kam die Meldung nach dem Neustart vom ioBroker. Einmal bestätigt und jetzt ist gut, die Meldung kommt erstmal nicht mehr.
                          1512
