    3. Entwicklung
    4. Adapter Worx Landroid v3.x.x
      Lucky_ESA Developer Most Active @falkomfs last edited by
      @hsteinme Funktioniert bei dir edgecut?
      @falkomfs Wenn du in edgecut ein true setzt, was kommt im Log? Kommt da nichts dann den Adapter auf debug stellen und erneut edgecut auf true setzen.
      F L 2 Replies Last reply Reply Quote 0
        falkomfs @Lucky_ESA last edited by
        @lucky_esa also ohne debug erscheint dort nichts. Mit debug kommt folgendes
        2024-08-23 12:41:27.554 - debug: worx.0 (125302) this.modules! {"202330294702002506EF":{"edgeCut":true,"slots":2,"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"tq":0,"channel":true,"HL":{"enabled":0},"DF":{"cut":1,"fh":0},"al":{"lvl":0,"t":60},"al_last":60}}
        2024-08-23 12:41:27.554 - debug: worx.0 (125302) state change: id_____ worx.0.202330294702002506EF.mower.edgecut Mower 202330294702002506EF_____edgecut______{"id":923901,"uuid":"98c93462-d518-4002-afad-c91894f61969","product_id":73,"user_id":503887,"serial_number":"202330294702002506EF","mac_address":"","locked":false,"firmware_version":"3.34.0+10","firmware_auto_upgrade":true,"sim":"","test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2023-05-27 00:00:00","online":true,"protocol":1,"pending_radio_link_validation":"","capabilities":["auto_lock","bluetooth_pairing","border_cut","display_pairing_shortcut","lock","mqtt","multi_zone_tag","one_time_scheduler","ota_upgrade","pause_over_border","rain_delay","unrestricted_mowing_time","vision"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandIn","command_out":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut"},"name":"falkomfs","blade_height_shift":0,"push_notifications":true,"push_notifications_level":"warning","pin_code":"","app_settings":"","warranty_registered":true,"purchased_at":"2023-05-27 00:00:00","warranty_expires_at":"2025-05-27 00:00:00","setup_location":{"latitude":52.72299989287376,"longitude":7.930778502216534},"city":{"id":2928809,"country_id":276,"name":"Essen","latitude":52.700001,"longitude":7.91667,"created_at":"2018-02-15 22:41:14","updated_at":"2018-02-15 22:41:14"},"time_zone":"Europe/Berlin","lawn_size":119.93579864502,"lawn_perimeter":28,"auto_schedule_settings":"","auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":282917,"mower_work_time":17859,"blade_work_time":17266,"blade_work_time_reset":0,"blade_work_time_reset_at":"","battery_charge_cycles":3379,"battery_charge_cycles_reset":0,"battery_charge_cycles_reset_at":"","created_at":"2023-03-28 06:50:27","updated_at":"2024-08-23 09:43:47","last_status":{"payload":{"cfg":{"id":15153,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":0,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}},{"e":0,"d":0,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":1,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}},{"e":0,"d":1,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":2,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}},{"e":0,"d":2,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":3,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}},{"e":0,"d":3,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":4,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}},{"e":0,"d":4,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":5,"e":1,"s":615,"t":5,"cfg":{"cut":{"b":1,"z":[]}}},{"d":5,"e":1,"s":720,"t":130,"cfg":{"cut":{"b":1,"z":[]}}},{"d":6,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}},{"e":0,"d":6,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}}],"once":{"time":30,"cfg":{"cut":{"b":1,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-23T10:40:19.71Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":27.5,"v":19.3,"p":100,"nr":3421,"c":0,"m":0},"dmp":[-5.2,-1.3,162.5],"st":{"b":17294,"d":283572,"wt":17892,"bl":28},"rsi":-68,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}},"timestamp":"2024-08-23 12:40:32.368"},"last_gps_status":""}
        2024-08-23 12:41:27.554 - debug: worx.0 (125302) Worxcloud MQTT sendMessage to 202330294702002506EF Message: {"cut":{"b":1,"z":[]}}
        2024-08-23 12:41:27.554 - info: worx.0 (125302) Request Counter: 3
        2024-08-23 12:41:27.554 - debug: worx.0 (125302) length: 0
        2024-08-23 12:41:27.554 - debug: worx.0 (125302) Start MQTT ping: {"id":21423,"cmd":0,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-23T12:41:27.554Z","cut":{"b":1,"z":[]}}
        2024-08-23 12:41:27.554 - debug: worx.0 (125302) lastCommand_start: {"21423":{"id":21423,"cmd":0,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-23T12:41:27.554Z","cut":{"b":1,"z":[]}}}
        2024-08-23 12:41:27.605 - debug: worx.0 (125302) this.mqtt_response_check: {"21423":{"id":21423,"cmd":0,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-23T12:41:27.554Z","cut":{"b":1,"z":[]},"request":1724409687602,"response":0,"action":"worx.0.202330294702002506EF.mower.edgecut","user":"iobroker"}}
        2024-08-23 12:41:27.605 - debug: worx.0 (125302) sendData: {"id":21423,"cmd":0,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-23T12:41:27.554Z","cut":{"b":1,"z":[]}}
        2024-08-23 12:41:28.758 - debug: worx.0 (125302) Mower MQTT: {"cfg":{"id":21423,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":0,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}},{"d":1,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}},{"d":2,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}},{"d":3,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}},{"d":4,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}},{"d":5,"e":1,"s":615,"t":5,"cfg":{"cut":{"b":1,"z":[]}}},{"d":5,"e":1,"s":720,"t":130,"cfg":{"cut":{"b":1,"z":[]}}},{"d":6,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}}],"once":{"time":30,"cfg":{"cut":{"b":1,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0}},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-23T10:41:16.492Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":27.5,"v":19.3,"p":100,"nr":3421,"c":0,"m":0},"dmp":[-5.2,-1.3,162.5],"st":{"b":17294,"d":283572,"wt":17892,"bl":28},"rsi":-68,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
        2024-08-23 12:41:28.758 - debug: worx.0 (125302) topic: WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut
        2024-08-23 12:41:28.759 - debug: worx.0 (125302) getQueueStatistics: {"incompleteOperationCount":0,"incompleteOperationSize":0,"unackedOperationCount":0,"unackedOperationSize":0}
        2024-08-23 12:41:28.759 - debug: worx.0 (125302) Worxcloud MQTT get Message for mower falkomfs (202330294702002506EF)
        2024-08-23 12:41:28.759 - debug: worx.0 (125302) Request ID 21423 has been passed to the mower
        2024-08-23 12:41:28.759 - debug: worx.0 (125302) lastCommand_start: {"21423":{"id":21423,"cmd":0,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-23T12:41:27.554Z","cut":{"b":1,"z":[]},"request":1724409687602,"response":0,"action":"worx.0.202330294702002506EF.mower.edgecut","user":"iobroker"}}
        2024-08-23 12:41:28.759 - debug: worx.0 (125302) Set new timestamp
        2024-08-23 12:41:28.807 - debug: worx.0 (125302) GET MQTT DATA from API: {"cfg":{"id":21423,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":0,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}},{"d":1,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}},{"d":2,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}},{"d":3,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}},{"d":4,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}},{"d":5,"e":1,"s":615,"t":5,"cfg":{"cut":{"b":1,"z":[]}}},{"d":5,"e":1,"s":720,"t":130,"cfg":{"cut":{"b":1,"z":[]}}},{"d":6,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}}],"once":{"time":30,"cfg":{"cut":{"b":1,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-23T10:41:16.492Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":27.5,"v":19.3,"p":100,"nr":3421,"c":0,"m":0},"dmp":[-5.2,-1.3,162.5],"st":{"b":17294,"d":283572,"wt":17892,"bl":28},"rsi":-68,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
        2024-08-23 12:41:28.862 - debug: worx.0 (125302) Test Status: 1
        2024-08-23 12:41:28.910 - debug: worx.0 (125302) COUNTER: 8
        2024-08-23 12:41:28.910 - debug: worx.0 (125302) COUNTER SLOTS: 2
        2024-08-23 12:41:28.910 - debug: worx.0 (125302) {"d":0,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}}
        2024-08-23 12:41:28.962 - debug: worx.0 (125302) {"d":1,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}}
        2024-08-23 12:41:29.016 - debug: worx.0 (125302) {"d":2,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}}
        2024-08-23 12:41:29.069 - debug: worx.0 (125302) {"d":3,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}}
        2024-08-23 12:41:29.121 - debug: worx.0 (125302) {"d":4,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}}
        2024-08-23 12:41:29.172 - debug: worx.0 (125302) {"d":5,"e":1,"s":615,"t":5,"cfg":{"cut":{"b":1,"z":[]}}}
        2024-08-23 12:41:29.218 - debug: worx.0 (125302) {"d":5,"e":1,"s":720,"t":130,"cfg":{"cut":{"b":1,"z":[]}}}
        2024-08-23 12:41:29.266 - debug: worx.0 (125302) {"d":6,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}}
        2024-08-23 12:41:29.333 - debug: worx.0 (125302) MOWER with full schedule: {"id":923901,"uuid":"98c93462-d518-4002-afad-c91894f61969","product_id":73,"user_id":503887,"serial_number":"202330294702002506EF","mac_address":"","locked":false,"firmware_version":"3.34.0+10","firmware_auto_upgrade":true,"sim":"","test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2023-05-27 00:00:00","online":true,"protocol":1,"pending_radio_link_validation":"","capabilities":["auto_lock","bluetooth_pairing","border_cut","display_pairing_shortcut","lock","mqtt","multi_zone_tag","one_time_scheduler","ota_upgrade","pause_over_border","rain_delay","unrestricted_mowing_time","vision"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandIn","command_out":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut"},"name":"falkomfs","blade_height_shift":0,"push_notifications":true,"push_notifications_level":"warning","pin_code":"","app_settings":"","warranty_registered":true,"purchased_at":"2023-05-27 00:00:00","warranty_expires_at":"2025-05-27 00:00:00","setup_location":{"latitude":52.72299989287376,"longitude":7.930778502216534},"city":{"id":2928809,"country_id":276,"name":"Essen","latitude":52.700001,"longitude":7.91667,"created_at":"2018-02-15 22:41:14","updated_at":"2018-02-15 22:41:14"},"time_zone":"Europe/Berlin","lawn_size":119.93579864502,"lawn_perimeter":28,"auto_schedule_settings":"","auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":282917,"mower_work_time":17859,"blade_work_time":17266,"blade_work_time_reset":0,"blade_work_time_reset_at":"","battery_charge_cycles":3379,"battery_charge_cycles_reset":0,"battery_charge_cycles_reset_at":"","created_at":"2023-03-28 06:50:27","updated_at":"2024-08-23 09:43:47","last_status":{"payload":{"cfg":{"id":21423,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":0,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}},{"e":0,"d":0,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":1,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}},{"e":0,"d":1,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":2,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}},{"e":0,"d":2,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":3,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}},{"e":0,"d":3,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":4,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}},{"e":0,"d":4,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":5,"e":1,"s":615,"t":5,"cfg":{"cut":{"b":1,"z":[]}}},{"d":5,"e":1,"s":720,"t":130,"cfg":{"cut":{"b":1,"z":[]}}},{"d":6,"e":1,"s":720,"t":120,"cfg":{"cut":{"b":1,"z":[]}}},{"e":0,"d":6,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}}],"once":{"time":30,"cfg":{"cut":{"b":1,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-23T10:41:16.492Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":27.5,"v":19.3,"p":100,"nr":3421,"c":0,"m":0},"dmp":[-5.2,-1.3,162.5],"st":{"b":17294,"d":283572,"wt":17892,"bl":28},"rsi":-68,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}},"timestamp":"2024-08-23 12:41:28.759"},"last_gps_status":""}
        2024-08-23 12:41:29.440 - debug: worx.0 (125302) Count Zone: 1 - Count Passage: 0
        2024-08-23 12:41:29.440 - debug: worx.0 (125302) Count Receive Zone: 1 - Count Receive Passage: 0
        2024-08-23 12:41:29.440 - debug: worx.0 (125302) Write multi zone: {"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]}
        2024-08-23 12:41:29.446 - debug: worx.0 (125302) Edgecut Start section :1
          @falkomfs Das sieht super aus. Spontan würde ich sagen da könnte was fehlen...
          @hsteinme Bist du so lieb und probierst mal das aus.
          {"cut": {"b": 1,"z": [],"bd": 100,"ob": 0}
          Da fehlt aktuell: "bd": 100,"ob": 0
          hsteinme 1 Reply Last reply Reply Quote 0
          • hsteinme
            hsteinme @Lucky_ESA last edited by
            @lucky_esa sagte in Adapter Worx Landroid v3.x.x:
            Ich habe im Moment keine lauffähige Vision-Installation, mit der ich testen könnte. Ich steige aber am Wochenende mal in die Theorie des Themas ein.
            L hsteinme 2 Replies Last reply Reply Quote 0
              Lucky_ESA Developer Most Active @hsteinme last edited by
              @hsteinme Kein Stress
              @falkomfs Wenn ich was anpasse, weißt du wie man von GIT lädt?
                ja, schon ab und an gemacht
                • hsteinme
                  hsteinme @hsteinme last edited by
                  @hsteinme sagte in Adapter Worx Landroid v3.x.x:
                  Ich habe mir notdürftig eine Vision-Installation für erste Tests zusammengenagelt.
                  (1) Wird cmd 101 von der DeskApp zum Mäher geschickt, macht er brav seinen Kantenschnitt.
                  (2) Wird cmd 101 per Adapter in sendCommand geschickt, so legt sich der Adapter quer: "Sending cmd:101 is not allowed." laut Logdatei.
                  (3) Wird in oneTimeJson
                    "time": 30,
                    "cfg": {
                      "cut": {
                        "b": 1,
                        "z": []
                  eingetragen, so fährt der Mäher zum Mähen. Ob er zum Abschluss die Kante mäht? Dazu fehlte mir leider die Zeit, dies zu überprüfen.
                  (4) Wird statt 30 in time 0 eingetragen, so wird dies vom Adapter abgelehnt.
                  (5) Wird in developer_json
                  	"sc": {
                  		"once": {
                  			"time": 15,
                  			"cfg": {
                  				"cut": {
                  					"b": 1,
                  					"z": []
                  eingetragen, so beginnt der Mäher mit einem Kantenschnitt.
                  (6) Dies erfolgt auch mit time = 1.
                  (7) time = 0 wird vom Mäher ignoriert. Daher denke ich, dass die Sequenz aus (4) ebenfalls vom Mäher ignoriert würde, wenn der Adapter sie durchlassen würde.
                  (8) Das Verhalten beim Setzen von oneTimeWithBorder und OneTimeWorkTiem und nachfolgendem Starten von oneTimeStart entspricht dem Verhalten in (3) und (4).
                  (9) Schreibfehler in Logdatei:
                  falsch: ONETIMESCHEDULE: NO vailed JSON format
                  richtig: ONETIMESCHEDULE: NO valid JSON format
                  So, das war's für heute. Weitere Tests können erst in der nächsten Woche erfolgen. Ich wünsche allen ein ganz dolles Wochenende.
                  F hsteinme 2 Replies Last reply Reply Quote 0
                    falkomfs @hsteinme last edited by
                    das habe ich dann mal geprüft. Nein, im Anschluss macht er auch keinen Kantenschnitt.
                      Lucky_ESA Developer Most Active @Lucky_ESA last edited by
                      @hsteinme Vielen Dank
                      @falkomfs Kannst du dann mal von GIT laden und den Datenpunkt edgecut und danach states testen?
                        falkomfs @Lucky_ESA last edited by falkomfs
                        @lucky_esa Moin,
                        also über den Button Edgecut fährt er noch nicht los, aber über SendCommand funktioniert es jetzt
                          @falkomfs sagte in Adapter Worx Landroid v3.x.x:
                          @lucky_esa Moin,
                          Was musst du in der APP einstellen wenn du dort Kantenschnitt auswählst? Kannst du den Adapter auf debug stellen und dann per APP den Kantenschnitt statrten? Poste dann mal das Log.
                          F 4 Replies Last reply Reply Quote 0
                            @lucky_esa also in der APP habe ich den Button wie auf dem Bild
                              @lucky_esa
                              das ist jetzt der Log über den Button .mower.edgecut
                              2024-08-25 13:57:37.523 - debug: worx.0 (129277) this.modules! {"202330294702002506EF":{"edgeCut":false,"slots":2,"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"tq":0,"channel":true,"HL":{"enabled":0},"DF":{"cut":1,"fh":0},"al":{"lvl":0,"t":60},"al_last":60}}
                              2024-08-25 13:57:37.523 - debug: worx.0 (129277) state change: id_____ worx.0.202330294702002506EF.mower.edgecut Mower 202330294702002506EF_____edgecut______{"id":923901,"uuid":"98c93462-d518-4002-afad-c91894f61969","product_id":73,"user_id":503887,"serial_number":"202330294702002506EF","mac_address":"","locked":false,"firmware_version":"3.34.0+10","firmware_auto_upgrade":true,"sim":"","test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2023-05-27 00:00:00","online":true,"protocol":1,"pending_radio_link_validation":"","capabilities":["auto_lock","bluetooth_pairing","border_cut","display_pairing_shortcut","lock","mqtt","multi_zone_tag","one_time_scheduler","ota_upgrade","pause_over_border","rain_delay","unrestricted_mowing_time","vision"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandIn","command_out":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut"},"name":"falkomfs","blade_height_shift":0,"push_notifications":true,"push_notifications_level":"warning","pin_code":"","app_settings":"","warranty_registered":true,"purchased_at":"2023-05-27 00:00:00","warranty_expires_at":"2025-05-27 00:00:00","setup_location":{"latitude":52.72299989287376,"longitude":7.930778502216534},"city":{"id":2928809,"country_id":276,"name":"Essen","latitude":52.700001,"longitude":7.91667,"created_at":"2018-02-15 22:41:14","updated_at":"2018-02-15 22:41:14"},"time_zone":"Europe/Berlin","lawn_size":119.93579864502,"lawn_perimeter":28,"auto_schedule_settings":"","auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":284806,"mower_work_time":17976,"blade_work_time":17373,"blade_work_time_reset":0,"blade_work_time_reset_at":"","battery_charge_cycles":3491,"battery_charge_cycles_reset":0,"battery_charge_cycles_reset_at":"","created_at":"2023-03-28 06:50:27","updated_at":"2024-08-23 09:43:47","last_status":{"payload":{"cfg":{"id":39809,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":0,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":0,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":1,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":2,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":3,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":4,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":5,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":6,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T11:54:57.794Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":22.4,"v":19.7,"p":96,"nr":3513,"c":1,"m":1},"dmp":[-5.4,-0.8,15.9],"st":{"b":17440,"d":285704,"wt":18053,"bl":28},"rsi":-61,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}},"timestamp":"2024-08-25 13:54:57.435"},"last_gps_status":""}
                              2024-08-25 13:57:37.523 - debug: worx.0 (129277) Worxcloud MQTT sendMessage to 202330294702002506EF Message: {"cut":{"b":1,"z":[],"bd": 100,"ob": 1}}
                              2024-08-25 13:57:37.523 - info: worx.0 (129277) Request Counter: 2
                              2024-08-25 13:57:37.523 - debug: worx.0 (129277) length: 0
                              2024-08-25 13:57:37.523 - debug: worx.0 (129277) Start MQTT ping: {"id":36893,"cmd":0,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-25T13:57:37.523Z","cut":{"b":1,"z":[],"bd":100,"ob":1}}
                              2024-08-25 13:57:37.523 - debug: worx.0 (129277) lastCommand_start: {"36893":{"id":36893,"cmd":0,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-25T13:57:37.523Z","cut":{"b":1,"z":[],"bd":100,"ob":1}}}
                              2024-08-25 13:57:37.526 - debug: worx.0 (129277) this.mqtt_response_check: {"36893":{"id":36893,"cmd":0,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-25T13:57:37.523Z","cut":{"b":1,"z":[],"bd":100,"ob":1},"request":1724587057524,"response":0,"action":"worx.0.202330294702002506EF.mower.edgecut","user":"iobroker"}}
                              2024-08-25 13:57:37.526 - debug: worx.0 (129277) sendData: {"id":36893,"cmd":0,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-25T13:57:37.523Z","cut":{"b":1,"z":[],"bd":100,"ob":1}}
                              2024-08-25 13:57:38.695 - debug: worx.0 (129277) Mower MQTT: {"cfg":{"id":36893,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":0,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0}},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T11:57:38.951Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":22.5,"v":19.8,"p":97,"nr":3513,"c":1,"m":1},"dmp":[-5.4,-0.8,15.9],"st":{"b":17440,"d":285704,"wt":18053,"bl":28},"rsi":-62,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
                              2024-08-25 13:57:38.695 - debug: worx.0 (129277) topic: WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut
                              2024-08-25 13:57:38.695 - debug: worx.0 (129277) getQueueStatistics: {"incompleteOperationCount":0,"incompleteOperationSize":0,"unackedOperationCount":0,"unackedOperationSize":0}
                              2024-08-25 13:57:38.696 - debug: worx.0 (129277) Worxcloud MQTT get Message for mower falkomfs (202330294702002506EF)
                              2024-08-25 13:57:38.696 - debug: worx.0 (129277) Request ID 36893 has been passed to the mower
                              2024-08-25 13:57:38.696 - debug: worx.0 (129277) lastCommand_start: {"36893":{"id":36893,"cmd":0,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-25T13:57:37.523Z","cut":{"b":1,"z":[],"bd":100,"ob":1},"request":1724587057524,"response":0,"action":"worx.0.202330294702002506EF.mower.edgecut","user":"iobroker"}}
                              2024-08-25 13:57:38.696 - debug: worx.0 (129277) Set new timestamp
                              2024-08-25 13:57:38.742 - debug: worx.0 (129277) GET MQTT DATA from API: {"cfg":{"id":36893,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":0,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T11:57:38.951Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":22.5,"v":19.8,"p":97,"nr":3513,"c":1,"m":1},"dmp":[-5.4,-0.8,15.9],"st":{"b":17440,"d":285704,"wt":18053,"bl":28},"rsi":-62,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
                              2024-08-25 13:57:38.795 - debug: worx.0 (129277) Test Status: 1
                              2024-08-25 13:57:38.801 - debug: worx.0 (129277) COUNTER: 7
                              2024-08-25 13:57:38.801 - debug: worx.0 (129277) COUNTER SLOTS: 2
                              2024-08-25 13:57:38.801 - debug: worx.0 (129277) {"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                              2024-08-25 13:57:38.852 - debug: worx.0 (129277) {"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                              2024-08-25 13:57:38.859 - debug: worx.0 (129277) {"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                              2024-08-25 13:57:38.865 - debug: worx.0 (129277) {"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                              2024-08-25 13:57:38.871 - debug: worx.0 (129277) {"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                              2024-08-25 13:57:38.878 - debug: worx.0 (129277) {"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                              2024-08-25 13:57:38.884 - debug: worx.0 (129277) {"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                              2024-08-25 13:57:38.897 - debug: worx.0 (129277) MOWER with full schedule: {"id":923901,"uuid":"98c93462-d518-4002-afad-c91894f61969","product_id":73,"user_id":503887,"serial_number":"202330294702002506EF","mac_address":"","locked":false,"firmware_version":"3.34.0+10","firmware_auto_upgrade":true,"sim":"","test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2023-05-27 00:00:00","online":true,"protocol":1,"pending_radio_link_validation":"","capabilities":["auto_lock","bluetooth_pairing","border_cut","display_pairing_shortcut","lock","mqtt","multi_zone_tag","one_time_scheduler","ota_upgrade","pause_over_border","rain_delay","unrestricted_mowing_time","vision"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandIn","command_out":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut"},"name":"falkomfs","blade_height_shift":0,"push_notifications":true,"push_notifications_level":"warning","pin_code":"","app_settings":"","warranty_registered":true,"purchased_at":"2023-05-27 00:00:00","warranty_expires_at":"2025-05-27 00:00:00","setup_location":{"latitude":52.72299989287376,"longitude":7.930778502216534},"city":{"id":2928809,"country_id":276,"name":"Essen","latitude":52.700001,"longitude":7.91667,"created_at":"2018-02-15 22:41:14","updated_at":"2018-02-15 22:41:14"},"time_zone":"Europe/Berlin","lawn_size":119.93579864502,"lawn_perimeter":28,"auto_schedule_settings":"","auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":284806,"mower_work_time":17976,"blade_work_time":17373,"blade_work_time_reset":0,"blade_work_time_reset_at":"","battery_charge_cycles":3491,"battery_charge_cycles_reset":0,"battery_charge_cycles_reset_at":"","created_at":"2023-03-28 06:50:27","updated_at":"2024-08-23 09:43:47","last_status":{"payload":{"cfg":{"id":36893,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":0,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":0,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":1,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":2,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":3,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":4,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":5,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":6,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T11:57:38.951Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":22.5,"v":19.8,"p":97,"nr":3513,"c":1,"m":1},"dmp":[-5.4,-0.8,15.9],"st":{"b":17440,"d":285704,"wt":18053,"bl":28},"rsi":-62,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}},"timestamp":"2024-08-25 13:57:38.696"},"last_gps_status":""}
                              2024-08-25 13:57:38.958 - debug: worx.0 (129277) Count Zone: 1 - Count Passage: 0
                              2024-08-25 13:57:38.958 - debug: worx.0 (129277) Count Receive Zone: 1 - Count Receive Passage: 0
                              2024-08-25 13:57:38.958 - debug: worx.0 (129277) Write multi zone: {"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]}
                              2024-08-25 13:57:38.967 - debug: worx.0 (129277) Edgecut Start section :1
                                @lucky_esa das ist der Log über .mower.sendCommand.BorderCut(101. Hier funtioniert es auch und kann somit genutzt werden
                                2024-08-25 13:59:10.866 - debug: worx.0 (129277) this.modules! {"202330294702002506EF":{"edgeCut":true,"slots":2,"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"tq":0,"channel":true,"HL":{"enabled":0},"DF":{"cut":1,"fh":0},"al":{"lvl":0,"t":60},"al_last":60}}
                                2024-08-25 13:59:10.866 - debug: worx.0 (129277) state change: id_____ worx.0.202330294702002506EF.mower.sendCommand Mower 202330294702002506EF_____sendCommand______{"id":923901,"uuid":"98c93462-d518-4002-afad-c91894f61969","product_id":73,"user_id":503887,"serial_number":"202330294702002506EF","mac_address":"","locked":false,"firmware_version":"3.34.0+10","firmware_auto_upgrade":true,"sim":"","test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2023-05-27 00:00:00","online":true,"protocol":1,"pending_radio_link_validation":"","capabilities":["auto_lock","bluetooth_pairing","border_cut","display_pairing_shortcut","lock","mqtt","multi_zone_tag","one_time_scheduler","ota_upgrade","pause_over_border","rain_delay","unrestricted_mowing_time","vision"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandIn","command_out":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut"},"name":"falkomfs","blade_height_shift":0,"push_notifications":true,"push_notifications_level":"warning","pin_code":"","app_settings":"","warranty_registered":true,"purchased_at":"2023-05-27 00:00:00","warranty_expires_at":"2025-05-27 00:00:00","setup_location":{"latitude":52.72299989287376,"longitude":7.930778502216534},"city":{"id":2928809,"country_id":276,"name":"Essen","latitude":52.700001,"longitude":7.91667,"created_at":"2018-02-15 22:41:14","updated_at":"2018-02-15 22:41:14"},"time_zone":"Europe/Berlin","lawn_size":119.93579864502,"lawn_perimeter":28,"auto_schedule_settings":"","auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":284806,"mower_work_time":17976,"blade_work_time":17373,"blade_work_time_reset":0,"blade_work_time_reset_at":"","battery_charge_cycles":3491,"battery_charge_cycles_reset":0,"battery_charge_cycles_reset_at":"","created_at":"2023-03-28 06:50:27","updated_at":"2024-08-23 09:43:47","last_status":{"payload":{"cfg":{"id":36893,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":0,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":0,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":1,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":2,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":3,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":4,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":5,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":6,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T11:57:38.951Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":22.5,"v":19.8,"p":97,"nr":3513,"c":1,"m":1},"dmp":[-5.4,-0.8,15.9],"st":{"b":17440,"d":285704,"wt":18053,"bl":28},"rsi":-62,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}},"timestamp":"2024-08-25 13:57:38.696"},"last_gps_status":""}
                                2024-08-25 13:59:10.866 - debug: worx.0 (129277) Send cmd:101
                                2024-08-25 13:59:10.866 - debug: worx.0 (129277) Worxcloud MQTT sendMessage to 202330294702002506EF Message: {"cmd":101}
                                2024-08-25 13:59:10.866 - info: worx.0 (129277) Request Counter: 3
                                2024-08-25 13:59:10.866 - debug: worx.0 (129277) length: 0
                                2024-08-25 13:59:10.866 - debug: worx.0 (129277) Start MQTT ping: {"id":27589,"cmd":101,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-25T13:59:10.866Z"}
                                2024-08-25 13:59:10.866 - debug: worx.0 (129277) lastCommand_start: {"27589":{"id":27589,"cmd":101,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-25T13:59:10.866Z"}}
                                2024-08-25 13:59:10.910 - debug: worx.0 (129277) this.mqtt_response_check: {"27589":{"id":27589,"cmd":101,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-25T13:59:10.866Z","request":1724587150867,"response":0,"action":"worx.0.202330294702002506EF.mower.sendCommand","user":"iobroker"}}
                                2024-08-25 13:59:10.910 - debug: worx.0 (129277) sendData: {"id":27589,"cmd":101,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-25T13:59:10.866Z"}
                                2024-08-25 13:59:12.057 - debug: worx.0 (129277) Mower MQTT: {"cfg":{"id":27589,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0}},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T11:59:11.947Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":22.6,"v":19.9,"p":97,"nr":3513,"c":1,"m":1},"dmp":[-5.5,-0.8,15.9],"st":{"b":17440,"d":285704,"wt":18053,"bl":28},"rsi":-62,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
                                2024-08-25 13:59:12.057 - debug: worx.0 (129277) topic: WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut
                                2024-08-25 13:59:12.057 - debug: worx.0 (129277) getQueueStatistics: {"incompleteOperationCount":0,"incompleteOperationSize":0,"unackedOperationCount":0,"unackedOperationSize":0}
                                2024-08-25 13:59:12.057 - debug: worx.0 (129277) Worxcloud MQTT get Message for mower falkomfs (202330294702002506EF)
                                2024-08-25 13:59:12.057 - debug: worx.0 (129277) Request ID 27589 has been passed to the mower
                                2024-08-25 13:59:12.058 - debug: worx.0 (129277) lastCommand_start: {"27589":{"id":27589,"cmd":101,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-25T13:59:10.866Z","request":1724587150867,"response":0,"action":"worx.0.202330294702002506EF.mower.sendCommand","user":"iobroker"}}
                                2024-08-25 13:59:12.058 - debug: worx.0 (129277) Set new timestamp
                                2024-08-25 13:59:12.102 - debug: worx.0 (129277) GET MQTT DATA from API: {"cfg":{"id":27589,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T11:59:11.947Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":22.6,"v":19.9,"p":97,"nr":3513,"c":1,"m":1},"dmp":[-5.5,-0.8,15.9],"st":{"b":17440,"d":285704,"wt":18053,"bl":28},"rsi":-62,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
                                2024-08-25 13:59:12.158 - debug: worx.0 (129277) Test Status: 1
                                2024-08-25 13:59:12.161 - debug: worx.0 (129277) COUNTER: 7
                                2024-08-25 13:59:12.161 - debug: worx.0 (129277) COUNTER SLOTS: 2
                                2024-08-25 13:59:12.162 - debug: worx.0 (129277) {"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                2024-08-25 13:59:12.212 - debug: worx.0 (129277) {"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                2024-08-25 13:59:12.217 - debug: worx.0 (129277) {"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                2024-08-25 13:59:12.223 - debug: worx.0 (129277) {"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                2024-08-25 13:59:12.230 - debug: worx.0 (129277) {"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                2024-08-25 13:59:12.236 - debug: worx.0 (129277) {"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                2024-08-25 13:59:12.242 - debug: worx.0 (129277) {"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                2024-08-25 13:59:12.251 - debug: worx.0 (129277) MOWER with full schedule: {"id":923901,"uuid":"98c93462-d518-4002-afad-c91894f61969","product_id":73,"user_id":503887,"serial_number":"202330294702002506EF","mac_address":"","locked":false,"firmware_version":"3.34.0+10","firmware_auto_upgrade":true,"sim":"","test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2023-05-27 00:00:00","online":true,"protocol":1,"pending_radio_link_validation":"","capabilities":["auto_lock","bluetooth_pairing","border_cut","display_pairing_shortcut","lock","mqtt","multi_zone_tag","one_time_scheduler","ota_upgrade","pause_over_border","rain_delay","unrestricted_mowing_time","vision"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandIn","command_out":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut"},"name":"falkomfs","blade_height_shift":0,"push_notifications":true,"push_notifications_level":"warning","pin_code":"","app_settings":"","warranty_registered":true,"purchased_at":"2023-05-27 00:00:00","warranty_expires_at":"2025-05-27 00:00:00","setup_location":{"latitude":52.72299989287376,"longitude":7.930778502216534},"city":{"id":2928809,"country_id":276,"name":"Essen","latitude":52.700001,"longitude":7.91667,"created_at":"2018-02-15 22:41:14","updated_at":"2018-02-15 22:41:14"},"time_zone":"Europe/Berlin","lawn_size":119.93579864502,"lawn_perimeter":28,"auto_schedule_settings":"","auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":284806,"mower_work_time":17976,"blade_work_time":17373,"blade_work_time_reset":0,"blade_work_time_reset_at":"","battery_charge_cycles":3491,"battery_charge_cycles_reset":0,"battery_charge_cycles_reset_at":"","created_at":"2023-03-28 06:50:27","updated_at":"2024-08-23 09:43:47","last_status":{"payload":{"cfg":{"id":27589,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":0,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":1,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":2,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":3,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":4,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":5,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":6,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T11:59:11.947Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":22.6,"v":19.9,"p":97,"nr":3513,"c":1,"m":1},"dmp":[-5.5,-0.8,15.9],"st":{"b":17440,"d":285704,"wt":18053,"bl":28},"rsi":-62,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}},"timestamp":"2024-08-25 13:59:12.058"},"last_gps_status":""}
                                2024-08-25 13:59:12.304 - debug: worx.0 (129277) Count Zone: 1 - Count Passage: 0
                                2024-08-25 13:59:12.304 - debug: worx.0 (129277) Count Receive Zone: 1 - Count Receive Passage: 0
                                2024-08-25 13:59:12.304 - debug: worx.0 (129277) Write multi zone: {"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]}
                                2024-08-25 13:59:12.307 - debug: worx.0 (129277) Edgecut Start section :1
                                2024-08-25 13:59:13.017 - debug: worx.0 (129277) Mower MQTT: {"cfg":{"id":0,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0}},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T11:59:12.701Z","ls":3,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":22.6,"v":19.7,"p":97,"nr":3513,"c":0,"m":0},"dmp":[-5.3,-0.9,15.9],"st":{"b":17440,"d":285704,"wt":18053,"bl":28},"rsi":-62,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
                                2024-08-25 13:59:13.018 - debug: worx.0 (129277) topic: WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut
                                2024-08-25 13:59:13.018 - debug: worx.0 (129277) getQueueStatistics: {"incompleteOperationCount":0,"incompleteOperationSize":0,"unackedOperationCount":0,"unackedOperationSize":0}
                                2024-08-25 13:59:13.018 - debug: worx.0 (129277) Worxcloud MQTT get Message for mower falkomfs (202330294702002506EF)
                                2024-08-25 13:59:13.018 - debug: worx.0 (129277) Set new timestamp
                                2024-08-25 13:59:13.105 - debug: worx.0 (129277) GET MQTT DATA from API: {"cfg":{"id":0,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T11:59:12.701Z","ls":3,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":22.6,"v":19.7,"p":97,"nr":3513,"c":0,"m":0},"dmp":[-5.3,-0.9,15.9],"st":{"b":17440,"d":285704,"wt":18053,"bl":28},"rsi":-62,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
                                2024-08-25 13:59:13.113 - debug: worx.0 (129277) Test Status: 3
                                2024-08-25 13:59:13.114 - debug: worx.0 (129277) SET loadActivity on true
                                2024-08-25 13:59:13.116 - debug: worx.0 (129277) COUNTER: 7
                                2024-08-25 13:59:13.116 - debug: worx.0 (129277) COUNTER SLOTS: 2
                                2024-08-25 13:59:13.116 - debug: worx.0 (129277) {"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                2024-08-25 13:59:13.164 - debug: worx.0 (129277) {"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                2024-08-25 13:59:13.169 - debug: worx.0 (129277) {"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                2024-08-25 13:59:13.174 - debug: worx.0 (129277) {"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                2024-08-25 13:59:13.179 - debug: worx.0 (129277) {"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                2024-08-25 13:59:13.185 - debug: worx.0 (129277) {"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                2024-08-25 13:59:13.191 - debug: worx.0 (129277) {"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                2024-08-25 13:59:13.200 - debug: worx.0 (129277) MOWER with full schedule: {"id":923901,"uuid":"98c93462-d518-4002-afad-c91894f61969","product_id":73,"user_id":503887,"serial_number":"202330294702002506EF","mac_address":"","locked":false,"firmware_version":"3.34.0+10","firmware_auto_upgrade":true,"sim":"","test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2023-05-27 00:00:00","online":true,"protocol":1,"pending_radio_link_validation":"","capabilities":["auto_lock","bluetooth_pairing","border_cut","display_pairing_shortcut","lock","mqtt","multi_zone_tag","one_time_scheduler","ota_upgrade","pause_over_border","rain_delay","unrestricted_mowing_time","vision"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandIn","command_out":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut"},"name":"falkomfs","blade_height_shift":0,"push_notifications":true,"push_notifications_level":"warning","pin_code":"","app_settings":"","warranty_registered":true,"purchased_at":"2023-05-27 00:00:00","warranty_expires_at":"2025-05-27 00:00:00","setup_location":{"latitude":52.72299989287376,"longitude":7.930778502216534},"city":{"id":2928809,"country_id":276,"name":"Essen","latitude":52.700001,"longitude":7.91667,"created_at":"2018-02-15 22:41:14","updated_at":"2018-02-15 22:41:14"},"time_zone":"Europe/Berlin","lawn_size":119.93579864502,"lawn_perimeter":28,"auto_schedule_settings":"","auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":284806,"mower_work_time":17976,"blade_work_time":17373,"blade_work_time_reset":0,"blade_work_time_reset_at":"","battery_charge_cycles":3491,"battery_charge_cycles_reset":0,"battery_charge_cycles_reset_at":"","created_at":"2023-03-28 06:50:27","updated_at":"2024-08-23 09:43:47","last_status":{"payload":{"cfg":{"id":0,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":0,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":1,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":2,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":3,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":4,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":5,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":6,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T11:59:12.701Z","ls":3,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":22.6,"v":19.7,"p":97,"nr":3513,"c":0,"m":0},"dmp":[-5.3,-0.9,15.9],"st":{"b":17440,"d":285704,"wt":18053,"bl":28},"rsi":-62,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}},"timestamp":"2024-08-25 13:59:13.018"},"last_gps_status":""}
                                2024-08-25 13:59:13.253 - debug: worx.0 (129277) Count Zone: 1 - Count Passage: 0
                                2024-08-25 13:59:13.253 - debug: worx.0 (129277) Count Receive Zone: 1 - Count Receive Passage: 0
                                2024-08-25 13:59:13.253 - debug: worx.0 (129277) Write multi zone: {"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]}
                                2024-08-25 13:59:13.257 - debug: worx.0 (129277) Edgecut Start section :3
                                  @lucky_esa und das ist der Log beim Kantenschnitt über die APP
                                  2024-08-25 14:03:48.389 - debug: worx.0 (129330) Mower MQTT: {"cfg":{"id":51366,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0}},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T12:03:48.231Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":23,"v":19.4,"p":97,"nr":3513,"c":1,"m":0},"dmp":[-5.2,-0.9,17.1],"st":{"b":17442,"d":285736,"wt":18056,"bl":28},"rsi":-61,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
                                  2024-08-25 14:03:48.389 - debug: worx.0 (129330) topic: WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut
                                  2024-08-25 14:03:48.389 - debug: worx.0 (129330) getQueueStatistics: {"incompleteOperationCount":0,"incompleteOperationSize":0,"unackedOperationCount":0,"unackedOperationSize":0}
                                  2024-08-25 14:03:48.389 - debug: worx.0 (129330) Worxcloud MQTT get Message for mower falkomfs (202330294702002506EF)
                                  2024-08-25 14:03:48.389 - debug: worx.0 (129330) Response ID 51366 from mower
                                  2024-08-25 14:03:48.389 - debug: worx.0 (129330) lastCommand_start: {"cfg":{"id":51366,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T12:03:48.231Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":23,"v":19.4,"p":97,"nr":3513,"c":1,"m":0},"dmp":[-5.2,-0.9,17.1],"st":{"b":17442,"d":285736,"wt":18056,"bl":28},"rsi":-61,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
                                  2024-08-25 14:03:48.389 - debug: worx.0 (129330) Set new timestamp
                                  2024-08-25 14:03:48.434 - debug: worx.0 (129330) GET MQTT DATA from API: {"cfg":{"id":51366,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF","request":0,"response":1724587428391,"action":"APP","user":"APP"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T12:03:48.231Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":23,"v":19.4,"p":97,"nr":3513,"c":1,"m":0},"dmp":[-5.2,-0.9,17.1],"st":{"b":17442,"d":285736,"wt":18056,"bl":28},"rsi":-61,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
                                  2024-08-25 14:03:48.486 - debug: worx.0 (129330) Test Status: 1
                                  2024-08-25 14:03:48.489 - debug: worx.0 (129330) COUNTER: 7
                                  2024-08-25 14:03:48.489 - debug: worx.0 (129330) COUNTER SLOTS: 2
                                  2024-08-25 14:03:48.489 - debug: worx.0 (129330) {"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                  2024-08-25 14:03:48.569 - debug: worx.0 (129330) {"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                  2024-08-25 14:03:48.576 - debug: worx.0 (129330) {"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                  2024-08-25 14:03:48.585 - debug: worx.0 (129330) {"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                  2024-08-25 14:03:48.622 - debug: worx.0 (129330) {"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                  2024-08-25 14:03:48.628 - debug: worx.0 (129330) {"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                  2024-08-25 14:03:48.636 - debug: worx.0 (129330) {"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                  2024-08-25 14:03:48.649 - debug: worx.0 (129330) MOWER with full schedule: {"id":923901,"uuid":"98c93462-d518-4002-afad-c91894f61969","product_id":73,"user_id":503887,"serial_number":"202330294702002506EF","mac_address":"","locked":false,"firmware_version":"3.34.0+10","firmware_auto_upgrade":true,"sim":"","test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2023-05-27 00:00:00","online":true,"protocol":1,"pending_radio_link_validation":"","capabilities":["auto_lock","bluetooth_pairing","border_cut","display_pairing_shortcut","lock","mqtt","multi_zone_tag","one_time_scheduler","ota_upgrade","pause_over_border","rain_delay","unrestricted_mowing_time","vision"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandIn","command_out":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut"},"name":"falkomfs","blade_height_shift":0,"push_notifications":true,"push_notifications_level":"warning","pin_code":"","app_settings":"","warranty_registered":true,"purchased_at":"2023-05-27 00:00:00","warranty_expires_at":"2025-05-27 00:00:00","setup_location":{"latitude":52.72299989287376,"longitude":7.930778502216534},"city":{"id":2928809,"country_id":276,"name":"Essen","latitude":52.700001,"longitude":7.91667,"created_at":"2018-02-15 22:41:14","updated_at":"2018-02-15 22:41:14"},"time_zone":"Europe/Berlin","lawn_size":119.93579864502,"lawn_perimeter":28,"auto_schedule_settings":"","auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":284806,"mower_work_time":17976,"blade_work_time":17373,"blade_work_time_reset":0,"blade_work_time_reset_at":"","battery_charge_cycles":3491,"battery_charge_cycles_reset":0,"battery_charge_cycles_reset_at":"","created_at":"2023-03-28 06:50:27","updated_at":"2024-08-23 09:43:47","last_status":{"payload":{"cfg":{"id":51366,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":0,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":1,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":2,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":3,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":4,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":5,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":6,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF","request":0,"response":1724587428391,"action":"APP","user":"APP"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T12:03:48.231Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":23,"v":19.4,"p":97,"nr":3513,"c":1,"m":0},"dmp":[-5.2,-0.9,17.1],"st":{"b":17442,"d":285736,"wt":18056,"bl":28},"rsi":-61,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}},"timestamp":"2024-08-25 14:03:48.389"},"last_gps_status":""}
                                  2024-08-25 14:03:48.700 - debug: worx.0 (129330) Count Zone: 1 - Count Passage: 0
                                  2024-08-25 14:03:48.701 - debug: worx.0 (129330) Count Receive Zone: 1 - Count Receive Passage: 0
                                  2024-08-25 14:03:48.701 - debug: worx.0 (129330) Write multi zone: {"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]}
                                  2024-08-25 14:03:49.554 - debug: worx.0 (129330) Mower MQTT: {"cfg":{"id":0,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0}},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T12:03:49.151Z","ls":3,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":23,"v":19.5,"p":97,"nr":3513,"c":0,"m":0},"dmp":[-5,-1,17.1],"st":{"b":17442,"d":285736,"wt":18056,"bl":28},"rsi":-61,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
                                  2024-08-25 14:03:49.554 - debug: worx.0 (129330) topic: WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut
                                  2024-08-25 14:03:49.554 - debug: worx.0 (129330) getQueueStatistics: {"incompleteOperationCount":0,"incompleteOperationSize":0,"unackedOperationCount":0,"unackedOperationSize":0}
                                  2024-08-25 14:03:49.554 - debug: worx.0 (129330) Worxcloud MQTT get Message for mower falkomfs (202330294702002506EF)
                                  2024-08-25 14:03:49.554 - debug: worx.0 (129330) Set new timestamp
                                  2024-08-25 14:03:49.645 - debug: worx.0 (129330) GET MQTT DATA from API: {"cfg":{"id":0,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T12:03:49.151Z","ls":3,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":23,"v":19.5,"p":97,"nr":3513,"c":0,"m":0},"dmp":[-5,-1,17.1],"st":{"b":17442,"d":285736,"wt":18056,"bl":28},"rsi":-61,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
                                  2024-08-25 14:03:49.653 - debug: worx.0 (129330) Test Status: 3
                                  2024-08-25 14:03:49.654 - debug: worx.0 (129330) SET loadActivity on true
                                  2024-08-25 14:03:49.656 - debug: worx.0 (129330) COUNTER: 7
                                  2024-08-25 14:03:49.656 - debug: worx.0 (129330) COUNTER SLOTS: 2
                                  2024-08-25 14:03:49.656 - debug: worx.0 (129330) {"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                  2024-08-25 14:03:49.704 - debug: worx.0 (129330) {"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                  2024-08-25 14:03:49.709 - debug: worx.0 (129330) {"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                  2024-08-25 14:03:49.714 - debug: worx.0 (129330) {"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                  2024-08-25 14:03:49.719 - debug: worx.0 (129330) {"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                  2024-08-25 14:03:49.725 - debug: worx.0 (129330) {"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                  2024-08-25 14:03:49.730 - debug: worx.0 (129330) {"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
                                  2024-08-25 14:03:49.745 - debug: worx.0 (129330) MOWER with full schedule: {"id":923901,"uuid":"98c93462-d518-4002-afad-c91894f61969","product_id":73,"user_id":503887,"serial_number":"202330294702002506EF","mac_address":"","locked":false,"firmware_version":"3.34.0+10","firmware_auto_upgrade":true,"sim":"","test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2023-05-27 00:00:00","online":true,"protocol":1,"pending_radio_link_validation":"","capabilities":["auto_lock","bluetooth_pairing","border_cut","display_pairing_shortcut","lock","mqtt","multi_zone_tag","one_time_scheduler","ota_upgrade","pause_over_border","rain_delay","unrestricted_mowing_time","vision"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandIn","command_out":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut"},"name":"falkomfs","blade_height_shift":0,"push_notifications":true,"push_notifications_level":"warning","pin_code":"","app_settings":"","warranty_registered":true,"purchased_at":"2023-05-27 00:00:00","warranty_expires_at":"2025-05-27 00:00:00","setup_location":{"latitude":52.72299989287376,"longitude":7.930778502216534},"city":{"id":2928809,"country_id":276,"name":"Essen","latitude":52.700001,"longitude":7.91667,"created_at":"2018-02-15 22:41:14","updated_at":"2018-02-15 22:41:14"},"time_zone":"Europe/Berlin","lawn_size":119.93579864502,"lawn_perimeter":28,"auto_schedule_settings":"","auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":284806,"mower_work_time":17976,"blade_work_time":17373,"blade_work_time_reset":0,"blade_work_time_reset_at":"","battery_charge_cycles":3491,"battery_charge_cycles_reset":0,"battery_charge_cycles_reset_at":"","created_at":"2023-03-28 06:50:27","updated_at":"2024-08-23 09:43:47","last_status":{"payload":{"cfg":{"id":0,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":0,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":1,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":2,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":3,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":4,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":5,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":6,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T12:03:49.151Z","ls":3,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":23,"v":19.5,"p":97,"nr":3513,"c":0,"m":0},"dmp":[-5,-1,17.1],"st":{"b":17442,"d":285736,"wt":18056,"bl":28},"rsi":-61,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}},"timestamp":"2024-08-25 14:03:49.554"},"last_gps_status":""}
                                  2024-08-25 14:03:49.794 - debug: worx.0 (129330) Count Zone: 1 - Count Passage: 0
                                  2024-08-25 14:03:49.794 - debug: worx.0 (129330) Count Receive Zone: 1 - Count Receive Passage: 0
                                  2024-08-25 14:03:49.794 - debug: worx.0 (129330) Write multi zone: {"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]}
                                    Lucky_ESA Developer Most Active @falkomfs last edited by
                                    @falkomfs OK, die APP scheint dann auch nur die 101 zu versenden. Mich würde natürlich jetzt noch interessieren was User mit mehr als 1 Zone edgecut starten. Können diese dann noch die Zone auswählen oder werden alle Zonen angefahren....hmmmm
                                      ja da kann ich leider nicht helfen. Bei mir reicht das auch so, der fährt jetzt schön 8 mal den Rand ab mit den unterschiedlichen Entfernungseinstellungen die er hat und das sieht recht sauber aus. Vorher hat er immer irgendwie einen Rand gelassen, der ist jetzt weg.
                                      Also von mir vielen Dank für die Mühe.
                                      • hsteinme
                                        Die Positec'schen Drahtmäher kennen eigentlich keinen Kantenschnitt-Befehl. Der Worx-Adapter nutzt - wie manch andere Anwendung auch - einen "Indianertrick": Das Makro "edgecut" wird aus drei geschickt angeordneten Einzelbefehlen zusammengebastelt:
                                        • Zonentraining, um den Mäher auf kürzestem Wege Richtung Draht zu schicken
                                        • Pause
                                        • Heimfahrt
                                        Die letztgenannte Aktion schaltet die Messer ein und schickt den Mäher über den Draht zur Ladestation.
                                        Dies ist wie gesagt eine "Sonderlocke" für Drahtmäher, die bei anderen Mähertypen einfach nicht funktionieren kann.
                                        @Lucky_ESA
                                        • Bitte diesen Datenpunkt bei Nicht-Drahtmähern nicht anbieten.
                                        • Bitte die Dokumentation entsprechend anpassen (bei den Instanzeinstellungen und bei mower.edgecut)
                                        @lucky_esa sagte in Adapter Worx Landroid v3.x.x:
                                        Die App bietet keine Zonenauswahl an. Ich gehe davon aus (da mir mangels Zonen die Testmöglichkeit fehlt), dass die Ränder aller Zonen geschnitten werden. Aber das ist ja nicht das einzige Mal, wo die Worx App die von der API angebotene Funktionalität nicht voll weiterreicht (Beispiel: zeitlich begrenzter Partymodus). Aber ioBroker User können ja die Zonenauswahl über oneTimeZones (oder über oneTimeJson) bewerkstelligen.
                                        Heißt dies, dass Dein Skript eine Vierfach-Schleife über multiZones.zones.zone_0.borderDistance enthält und dass bei jeder Schleifenrunde der Kantenschnitt aufgerufen wird? Ein kluger Ansatz!
                                          @hsteinme sagte in Adapter Worx Landroid v3.x.x:
                                          Im Prinzip sogar 8 mal, 4 mal mit "multiZones.zones.zone_0.cutOverBorder " Yes und 4 mal no die jeweiligen mm Abstand
                                          • Dr. Bakterius
                                            Dr. Bakterius Most Active last edited by
                                            Mal eine andere Frage auf die ich zumindest keine Antwort gefunden habe.
                                            Wenn ich in der App die Klingenstandzeit resette, wird das im Adapter nicht registriert und er zählt einfach weiter. Gibt es dafür eine Lösung? Oder muss ich in einem Skript den aktuellen Wert vom letzten Wechselwert abziehen um die korrekte Standzeit zu erhalten?
                                            Eventuell ist das beim Akku auch der Fall. Den habe ich allerdings noch nicht getauscht.
                                            788
                                            122814
