    3. Off Topic
    4. Grafana
    5. (gelöst) Grafana: X-Achse ändern von Zeit auf Werte
    • Cephalopod
      Cephalopod last edited by Cephalopod
      Ich kämpfe schon seit Stunden mit einer Visualisierung des Strompreises.
      Der Strompreisverlauf über den Tag ist in 24 einzelnen (Stunden-) Variablen gespeichert.
      Diese möchte ich als Balken darstellen, also 24 einzelne Balken nebeneinander.
      Meine Datenquelle sieht so aus:
      from(bucket: "iobroker")
        |> range(start: v.timeRangeStart, stop: v.timeRangeStop)
        |> filter(fn: (r) => r["_measurement"] == "awattar.0.prices.0.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.1.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.2.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.3.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.4.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.5.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.10.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.11.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.12.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.13.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.14.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.15.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.16.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.17.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.18.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.19.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.20.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.21.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.22.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.23.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.24.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.6.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.7.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.8.totalPriceKwh" or r["_measurement"] == "awattar.0.prices.9.totalPriceKwh")
        |> filter(fn: (r) => r["_field"] == "value")
        |> aggregateWindow(every: v.windowPeriod, fn: last, createEmpty: false)
        |> yield(name: "last")
      Das habe ich bisher hinbekommen:
      Ich möchte die X-Achse nicht mehr als Zeitachse haben, sondern als Werteachse von 0 bis 24.
      Wie geht das?
      Cephalopod 1 Reply Last reply Reply Quote 0
      • Cephalopod
        Cephalopod @Cephalopod last edited by
        Habe es hinbekommen:
        Angezeigt wird der aktuelle Tag bis morgen früh 8 Uhr.
        Unten noch ein Balken mit dem aktuellen Verbrauch:
        P T 2 Replies Last reply Reply Quote 1
          peterfido @Cephalopod last edited by
          @cephalopod
          Magst Du Deine Lösung noch zeigen? Evtl. kann es jemand gebrauchen.
          • Cephalopod
            Cephalopod @peterfido last edited by
            @peterfido
            Stimmt.
            Der "Trick" war, bei der Auswahl der Visualisierung "BAR GAUGE" anstatt "Bar chart" zu verwenden.
            Bei letzterem wird anscheinend immer eine Zeitleiste als X-Achse verwendet.
              tritor @Cephalopod last edited by
              @Cephalopod
              Wie hast du die Uhrzeiten auf die x-Achse gebracht?
              Bei mir wird der DP Name angezeigt.
              • Cephalopod
                Cephalopod @tritor last edited by
                @tritor
                Das ist einfach.
                Per Override die Beschriftung für jede einzelne Datenreihe ändern.
                Fleißarbeit 😊
                  tritor @Cephalopod last edited by tritor
                  @cephalopod
                  hätte ich schon gemacht bleibt aber durcheinander
                  oder darf ich nur numerisch verwenden?
                  • Cephalopod
                    @tritor sagte in (gelöst) Grafana: X-Achse ändern von Zeit auf Werte:
                    @cephalopod
                    Du musst die Datenreihen umbenennen, dass die Einstelligen Uhrzeiten mit einer 0 beginnen.
                    Mit influxdb kannst du z.B. die Datenpunkte unter einem anderen Namen speichern.
