    4. NPM verschwunden ,Keine Änderungen in der Konsole möglich
      Burgsteff @Thomas Braun last edited by
      Skript v.2024-05-22
      *** BASE SYSTEM ***
       Static hostname: ioBroker
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-23-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
      model name      : QEMU Virtual CPU version 2.5+
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       11:22:19 up  3:01,  3 users,  load average: 0.04, 0.06, 0.04
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Sun 2024-08-25 11:22:20 EDT
                 Universal time: Sun 2024-08-25 15:22:20 UTC
                       RTC time: Sun 2024-08-25 15:22:20
                      Time zone: US/Eastern (EDT, -0400)
      System clock synchronized: no
                    NTP service: n/a
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      root
      HOME=/root
      GROUPS=root
      js-controller is not running
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.1G        366M        3.4G        528K        574M        3.7G
      Swap:           1.0G          0B        1.0G
      Total:          5.1G        366M        4.4G
      Active iob-Instances:   1
               3914 M total memory
                350 M used memory
                341 M active memory
                171 M inactive memory
               3247 M free memory
                 70 M buffer memory
                477 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      top - 11:22:20 up  3:01,  3 users,  load average: 0.04, 0.06, 0.04
      Tasks: 106 total,   1 running, 105 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3914.7 total,   3246.2 free,    351.1 used,    548.3 buff/cache
      MiB Swap:    975.0 total,    975.0 free,      0.0 used.   3563.6 avail Mem
      *** FAILED SERVICES ***
        UNIT             LOAD   ACTIVE SUB    DESCRIPTION
      * iobroker.service loaded failed failed ioBroker Server
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.9G     0  1.9G   0% /dev
      tmpfs          tmpfs     392M  516K  391M   1% /run
      /dev/sda1      ext4       31G  6.4G   23G  22% /
      tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
      [Sun Aug 25 08:21:11 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun Aug 25 08:21:11 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET                                                  SOURCE      FSTYPE      OPTIONS
      /                                                       /dev/sda1   ext4        rw,relatime,errors=remount-ro
      |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
      | `-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
      |-/proc                                                 proc        proc        rw,nosuid,nodev,noexec,relatime
      | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=13260
      |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
      |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=1981136k,nr_inodes=495284,mode=755,inode64
      | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev,inode64
      | |-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
      | `-/dev/hugepages                                      hugetlbfs   hugetlbfs   rw,relatime,pagesize=2M
      `-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=400872k,mode=755,inode64
        |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
        |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
        |-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=400868k,nr_inodes=100217,mode=700,uid=1000,gid=1000,inode64
        `-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      /var:
      712M    /var/
      316M    /var/cache
      310M    /var/cache/apt
      240M    /var/log
      235M    /var/cache/apt/archives
      Archived and active journals take up 224.3M in the file system.
      /opt/iobroker/backups:
      35M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      839M    /opt/iobroker/iobroker-data/
      748M    /opt/iobroker/iobroker-data/files
      441M    /opt/iobroker/iobroker-data/files/javascript.admin
      409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      27M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
      24M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js.map
      9.0M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      npm:                    N/A
      npx:                    N/A
      corepack:       N/A
      *** nodejs is NOT correctly installed ***
      nodejs:
        Installed: 18.19.0+dfsg-6~deb12u2
        Candidate: 18.19.0+dfsg-6~deb12u2
        Version table:
       *** 18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
              100 /var/lib/dpkg/status
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
           18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  6.0.9
      admin:          7.0.22
      javascript:     8.7.6
      nodejs modules from github:     0
      Adapter State
        system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.backitup.0               : backitup              : ioBroker                                 - disabled
        system.adapter.flot.0                   : flot                  : ioBroker                                 -  enabled
        system.adapter.history.0                : history               : ioBroker                                 - disabled
        system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
        system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
        system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
        system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
        system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
        system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
        system.adapter.modbus.1                 : modbus                : ioBroker                                 - disabled
        system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.semp.0                   : semp                  : ioBroker                                 -  enabled
        system.adapter.tibber.0                 : tibber                : ioBroker                                 -  enabled
        system.adapter.tibberconnect.0          : tibberconnect         : ioBroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
        system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
        system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
        system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      │ (index) │        name        │                           url                           │ auto upgrade │
      │    0    │ 'Stable (default)' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
      │    1    │  'Beta (latest)'   │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
      Active repo(s): Stable (default)
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: Stable (default)
      Adapter    "admin"        : 7.0.23   , installed 7.0.22 [Updatable]
      Adapter    "backitup"     : 3.0.19   , installed 3.0.16 [Updatable]
      Adapter    "hm-rega"      : 5.0.0    , installed 4.0.0  [Updatable]
      Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
      Controller "js-controller": 6.0.9    , installed 6.0.9
      Adapter    "modbus"       : 6.2.3    , installed 6.2.3
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "semp"         : 1.4.5    , installed 1.4.5
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Objects and States
      Objects:        6488
      States:         5263
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x bookworm InRelease
      Reading package lists...
      Pending Updates: 1
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14648      519/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14255      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14650      519/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          1566       1/init
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15818      437/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          347        1/init
      udp6       0      0 :::111                  :::*                                0          1567       1/init
      2024-08-25 10:33:26.944  - info: javascript.0 (2261) terminating
      2024-08-25 10:33:26.951  - info: mqtt.0 (2350) terminating
      2024-08-25 10:33:26.957  - info: modbus.0 (2366) terminating
      2024-08-25 10:33:26.959  - info: tibber.0 (2381) terminating
      2024-08-25 10:33:26.962  - info: vis-inventwo.0 (2396) terminating
      2024-08-25 10:33:26.965  - info: semp.0 (2456) terminating
      2024-08-25 10:33:26.976  - info: admin.0 (2962) terminating
      2024-08-25 10:33:27.288  - info: host.ioBroker instance system.adapter.tibber.0 terminated with code 0 (NO_ERROR)
      2024-08-25 10:33:27.289  - info: host.ioBroker instance system.adapter.semp.0 terminated with code 0 (NO_ERROR)
      2024-08-25 10:33:27.307  - info: host.ioBroker instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
      2024-08-25 10:33:27.384  - info: host.ioBroker instance system.adapter.vis-inventwo.0 terminated with code 0 (NO_ERROR)
      2024-08-25 10:33:27.384  - info: host.ioBroker instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
      2024-08-25 10:33:27.482  - info: host.ioBroker instance system.adapter.modbus.0 terminated with code 0 (NO_ERROR)
      2024-08-25 10:33:27.509  - info: host.ioBroker instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
      2024-08-25 10:33:27.509  - info: host.ioBroker instance system.adapter.tibberconnect.0 terminated with code 0 (NO_ERROR)
      2024-08-25 10:33:27.521  - info: host.ioBroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
      2024-08-25 10:33:27.575  - info: host.ioBroker stopInstance timeout system.adapter.web.0 killing pid 2426
      2024-08-25 10:33:27.600  - info: host.ioBroker instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
      2024-08-25 10:33:27.600  - info: host.ioBroker instance system.adapter.hm-rpc.2 terminated with code 0 (NO_ERROR)
      2024-08-25 10:33:27.633  - info: host.ioBroker instance system.adapter.hm-rega.0 terminated with code 0 (NO_ERROR)
      2024-08-25 10:33:27.633  - info: host.ioBroker All instances are stopped.
      2024-08-25 10:33:27.668  - warn: host.ioBroker instance system.adapter.web.0 terminated due to SIGKILL
      2024-08-25 10:33:27.668  - info: host.ioBroker instance system.adapter.web.0 terminated with code null ()
      2024-08-25 10:33:27.668  - info: host.ioBroker All instances are stopped.
      2024-08-25 10:33:27.812  - info: host.ioBroker terminated
      Wohne in Baden- Württemberg 🙂
        Homoran Global Moderator Administrators @Burgsteff last edited by
        @burgsteff sagte in NPM verschwunden ,Keine Änderungen in der Konsole möglich:
        dann wäre zumindest da
        Timezone: US/Eastern (EDT, -0400)
        erwas zu korrigieren
          Thomas Braun Most Active @Burgsteff last edited by Thomas Braun
          Und seit wann gilt da die Time zone: US/Eastern?
          Da ist aber noch mehr krumm und schief...
          timedatectl set-timezone Europe/Berlin
          systemctl set-default multi-user.target
          iob nodejs-update
          Dann noch
          apt update
          apt install passwd sudo
          B 2 Replies Last reply Reply Quote 1
            root@ioBroker:/home/burgsteff# timedatectl set-timezone Europe/Berlin
            systemctl set-default mutli-user.target
            Failed to set default target: Unit file mutli-user.target does not exist.
            Hmmm...
              root@ioBroker:/home/burgsteff# iob nodejs-update
              iobroker nodejs-update [<major-version>]
              Upgrade the Node.JS installation to the current LTS
              Options:
                --help  Show help  [boolean]
                @burgsteff
                iob fix
                  mutli-user
                  nix mutli!
                  multi
                    Hallo, bin wieder da, musste kurz nach den Kindern schauen... sorry.
                    Also der fixer hat sich jetzt ausführen lassen. Habe das als allerdings jetzt auch als root gemacht.
                    Wenn ich usermod nutze kommt allerdings immer noch :
                    root@ioBroker:/home/burgsteff# usermod -aG adm,dialout,sudo,input,iobroker
                    bash: usermod: command not found
                      @burgsteff
                      apt update
                      Danach müsste usermod verfügbar sein.
                        root@ioBroker:/home/burgsteff# apt update
                        Reading package lists... Done
                        Building dependency tree... Done
                        1 package can be upgraded. Run 'apt list --upgradable' to see it.
                        passwd is already the newest version (1:4.13+dfsg1-1+b1).
                        sudo is already the newest version (1.9.13p3-1+deb12u1).
                        0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
                          was vollkommen widersinnig ist, da der fixer due durch root-Nutzung verbogenen Rechte wieder geradebiegen soll.
                            @burgsteff
                            type -P usermod
                            Liefert?
                              @thomas-braun mit oder ohne root?
                                @burgsteff
                                (Fast) egal.
                                /usr/sbin/usermod -a -G adm,dialout,sudo,input,iobroker burgsteff
                                  root@ioBroker:/home/burgsteff# type -P usermod
                                    root@ioBroker:/home/burgsteff# /usr/sbin/usermod -a -G adm,dialout,sudo,input,iobroker burgsteff
                                      @burgsteff
                                      echo $PATH
                                      sudo -H -u burgsteff echo $PATH
                                        root@ioBroker:/home/burgsteff# echo $PATH
                                        /usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
                                        root@ioBroker:/home/burgsteff# sudo -H -u burgsteff echo $PATH
                                          @burgsteff
                                          Da sind nicht alle Verzeichnisse eingetragen. Kümmern wir uns später noch drum.
                                          sudo -H -u burgsteff id
                                            root@ioBroker:/home/burgsteff# sudo -H -u burgsteff id
                                            uid=1000(burgsteff) gid=1000(burgsteff) groups=1000(burgsteff),4(adm),20(dialout),24(cdrom),25(floppy),27(sudo),29(audio),30(dip),44(video),46(plugdev),100(users),102(input),106(netdev),1001(iobroker)
                                            3716
