    4. NPM verschwunden ,Keine Änderungen in der Konsole möglich
      Burgsteff @Thomas Braun last edited by
      root@ioBroker:/home/burgsteff# sudo -H -u burgsteff id
      uid=1000(burgsteff) gid=1000(burgsteff) groups=1000(burgsteff),4(adm),20(dialout),24(cdrom),25(floppy),27(sudo),29(audio),30(dip),44(video),46(plugdev),100(users),102(input),106(netdev),1001(iobroker)
        Thomas Braun Most Active @Burgsteff last edited by
        @burgsteff
        Dann
        exit
        exit
        und nochmal als 'burgsteff' neu anmelden.
          Hab mich wieder als burgsteff angemeldet
          Danke schon mal.
            @burgsteff
            iob nodejs-update
              Your nodejs- Installation seems to be faulty. Shall we try to fix it?
              Mit y beantworten oder?
                Homoran Global Moderator Administrators @Burgsteff last edited by
                @burgsteff sagte in NPM verschwunden ,Keine Änderungen in der Konsole möglich:
                bitte alles zeigen!
                  Ja, das soll ja berichtigt werden.
                    ioBroker nodejs fixer 2024-05-23
                    Recommended nodejs-version is: 20.17.0
                    Checking your installation now. Please be patient!
                    Your current setup is:
                    /usr/bin/nodejs         v18.19.0
                    /usr/bin/node           v18.19.0
                    /home/iobroker/.nodejs-update.sh: line 146: npm: command not found
                    /home/iobroker/.nodejs-update.sh: line 147: npx: command not found
                    /home/iobroker/.nodejs-update.sh: line 168: npm: command not found
                    /home/iobroker/.nodejs-update.sh: line 169: npx: command not found
                    *** nodejs is NOT correctly installed ***
                    We found these nodejs versions available for installation:
                    nodejs:
                      Installed: 18.19.0+dfsg-6~deb12u2
                      Candidate: 18.19.0+dfsg-6~deb12u2
                      Version table:
                     *** 18.19.0+dfsg-6~deb12u2 500
                            500 http://deb.debian.org/debian bookworm/main amd64 Packages
                            100 /var/lib/dpkg/status
                         18.19.0+dfsg-6~deb12u1 500
                            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                         18.17.1-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
                    Your nodejs-Installation seems to be faulty. Shall we try to fix it?
                    Press <y> to continue or any other key to quit
                    Fixing your nodejs setup
                    *** Deleting  ***
                    rm: cannot remove '': No such file or directory
                    *** Deleting  ***
                    Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
                    You are running nodejs v18.19.0. Do you want to install recommended version 20.17.0?
                    Trying to fix your installation now. Please be patient.
                    Virtualization: kvm
                    Waiting for ioBroker to shut down - Give me a minute...
                    *** These repos are active on your system:
                    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                    Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
                    Reading package lists... Done
                    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                    Package: nodejs
                    Pin: origin deb.nodesource.com
                    Pin-Priority: 1001
                    *** These repos are active after the adjustments:
                    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                    Hit:2 http://deb.debian.org/debian bookworm InRelease
                    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                    Get:4 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
                    Get:5 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages [8942 B]
                    Fetched 21.1 kB in 1s (29.9 kB/s)
                    Installing nodejs now!
                    E: Broken packages
                    E: Broken packages
                    *** You need to manually restart your container/virtual machine now! ***
                    We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
                      @burgsteff
                      Ah, die Version ist nicht aktuell genug.
                      Versuch es mal mit der Beta:
                      curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_node_update.sh > iob_node_update
                      chmod 744 iob_node_update
                      ./iob_node_update
                        ioBroker nodejs maintenance 2024-08-08
                        ./iob_node_update: line 157: npm: command not found
                        ./iob_node_update: line 158: npx: command not found
                        ./iob_node_update: line 179: npm: command not found
                        ./iob_node_update: line 180: npx: command not found
                        nodejs:
                          Candidate: 20.17.0-1nodesource1
                          Version table:
                             20.17.0-1nodesource1 1001
                                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                             20.16.0-1nodesource1 1001
                             20.15.1-1nodesource1 1001
                             20.15.0-1nodesource1 1001
                             20.14.0-1nodesource1 1001
                             20.13.1-1nodesource1 1001
                             20.13.0-1nodesource1 1001
                             20.12.2-1nodesource1 1001
                             20.12.1-1nodesource1 1001
                             20.12.0-1nodesource1 1001
                             20.11.1-1nodesource1 1001
                             20.11.0-1nodesource1 1001
                             20.10.0-1nodesource1 1001
                             20.9.0-1nodesource1 1001
                             20.8.1-1nodesource1 1001
                             20.8.0-1nodesource1 1001
                             20.7.0-1nodesource1 1001
                             20.6.1-1nodesource1 1001
                             20.6.0-1nodesource1 1001
                             20.5.1-1nodesource1 1001
                             20.5.0-1nodesource1 1001
                             20.4.0-1nodesource1 1001
                             20.3.1-1nodesource1 1001
                             20.3.0-1nodesource1 1001
                             20.2.0-1nodesource1 1001
                             20.1.0-1nodesource1 1001
                             20.0.0-1nodesource1 1001
                        *** Deleting  ***
                        *** Deleting  ***
                        Virtualization: kvm
                        Removing dfsg-nodejs
                        (Reading database ... 45351 files and directories currently installed.)
                        Removing nodejs-doc (18.19.0+dfsg-6~deb12u2) ...
                        Removing nodejs (18.19.0+dfsg-6~deb12u2) ...
                        Removing libnode108:amd64 (18.19.0+dfsg-6~deb12u2) ...
                        Removing node-acorn (8.8.1+ds+~cs25.17.7-2) ...
                        Removing node-undici (5.15.0+dfsg1+~cs20.10.9.3-1+deb12u4) ...
                        Removing node-busboy (1.6.0+~cs2.6.0-2) ...
                        Removing node-cjs-module-lexer (1.2.2+dfsg-5) ...
                        Removing node-xtend (4.0.2-3) ...
                        Processing triggers for libc-bin (2.36-9+deb12u7) ...
                        Package: nodejs
                        Pin-Priority: 1001
                        Fetched 21.1 kB in 1s (30.2 kB/s)
                        (Reading database ... 44612 files and directories currently installed.)
                        Preparing to unpack .../libaom3_3.6.0-1+deb12u1_amd64.deb ...
                        Unpacking libaom3:amd64 (3.6.0-1+deb12u1) over (3.6.0-1) ...
                        Selecting previously unselected package nodejs.
                        Preparing to unpack .../nodejs_20.17.0-1nodesource1_amd64.deb ...
                        Unpacking nodejs (20.17.0-1nodesource1) ...
                        Setting up libaom3:amd64 (3.6.0-1+deb12u1) ...
                        Setting up nodejs (20.17.0-1nodesource1) ...
                        burgsteff@ioBroker:~$
                          Mach das mal.
                            aber vorher
                              Skript v.2024-05-22
                              *** BASE SYSTEM ***
                               Static hostname: ioBroker
                                     Icon name: computer-vm
                                       Chassis: vm 🖴
                                Virtualization: kvm
                                        Kernel: Linux 6.1.0-23-amd64
                                  Architecture: x86-64
                               Hardware Vendor: QEMU
                                Hardware Model: Standard PC _i440FX + PIIX, 1996_
                              Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
                              model name      : QEMU Virtual CPU version 2.5+
                              Docker          : false
                              Virtualization  : kvm
                              Kernel          : x86_64
                              Userland        : 64 bit
                              Systemuptime and Load:
                               19:45:28 up 1 min,  2 users,  load average: 0.48, 0.16, 0.06
                              CPU threads: 4
                              *** Time and Time Zones ***
                                             Local time: Sun 2024-08-25 19:45:28 CEST
                                         Universal time: Sun 2024-08-25 17:45:28 UTC
                                               RTC time: Sun 2024-08-25 17:45:28
                              System clock synchronized: no
                                            NTP service: n/a
                                        RTC in local TZ: no
                              *** Users and Groups ***
                              User that called 'iob diag':
                              burgsteff
                              HOME=/home/burgsteff
                              GROUPS=burgsteff adm dialout cdrom floppy sudo audio dip video plugdev users input netdev iobroker
                              iobroker
                              HOME=/home/iobroker
                              GROUPS=iobroker tty dialout audio video plugdev
                              *** Display-Server-Setup ***
                              Display-Server: false
                              Desktop:
                              Terminal:       tty
                              Boot Target:    multi-user.target
                              *** MEMORY ***
                              Mem:            4.1G        1.2G        2.7G        516K        384M        2.9G
                              Swap:           1.0G          0B        1.0G
                              Total:          5.1G        1.2G        3.7G
                              Active iob-Instances:   12
                                       3914 M total memory
                                       1181 M used memory
                                        124 M active memory
                                       1027 M inactive memory
                                       2583 M free memory
                                         36 M buffer memory
                                        331 M swap cache
                                        974 M total swap
                                          0 M used swap
                                        974 M free swap
                              top - 19:45:28 up 1 min,  2 users,  load average: 0.48, 0.16, 0.06
                              Tasks: 123 total,   1 running, 122 sleeping,   0 stopped,   0 zombie
                              %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :   3914.7 total,   2583.4 free,   1181.6 used,    367.3 buff/cache
                              MiB Swap:    975.0 total,    975.0 free,      0.0 used.   2733.2 avail Mem
                              *** FAILED SERVICES ***
                              0 loaded units listed.
                              *** FILESYSTEM ***
                              udev           devtmpfs  1.9G     0  1.9G   0% /dev
                              tmpfs          tmpfs     392M  512K  391M   1% /run
                              /dev/sda1      ext4       31G  6.5G   23G  23% /
                              tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                              tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                              tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
                              [Sun Aug 25 19:44:27 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                              [Sun Aug 25 19:44:27 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
                              Show mounted filesystems:
                              TARGET                                                  SOURCE      FSTYPE      OPTIONS
                              /                                                       /dev/sda1   ext4        rw,relatime,errors=remount-ro
                              |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
                              | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
                              | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                              | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
                              | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                              | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                              | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                              | |-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
                              | `-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                              |-/proc                                                 proc        proc        rw,nosuid,nodev,noexec,relatime
                              | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=14461
                              |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                              |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=1981136k,nr_inodes=495284,mode=755,inode64
                              | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                              | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev,inode64
                              | |-/dev/hugepages                                      hugetlbfs   hugetlbfs   rw,relatime,pagesize=2M
                              | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                              `-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=400872k,mode=755,inode64
                                |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
                                |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                                |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
                                |-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=400868k,nr_inodes=100217,mode=700,uid=1000,gid=1000,inode64
                                `-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                              /var:
                              745M    /var/
                              348M    /var/cache
                              343M    /var/cache/apt
                              267M    /var/cache/apt/archives
                              240M    /var/log
                              Archived and active journals take up 224.3M in the file system.
                              /opt/iobroker/backups:
                              35M     /opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              837M    /opt/iobroker/iobroker-data/
                              748M    /opt/iobroker/iobroker-data/files
                              441M    /opt/iobroker/iobroker-data/files/javascript.admin
                              409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                              408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                              27M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
                              25M     /opt/iobroker/iobroker-data/objects.jsonl
                              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                              22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js.map
                              9.0M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js
                              USB-Devices by-id:
                              No Devices found 'by-id'
                              *** NodeJS-Installation ***
                              /usr/bin/nodejs         v20.17.0
                              /usr/bin/node           v20.17.0
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              /usr/bin/corepack       0.29.3
                              nodejs:
                                Installed: 20.17.0-1nodesource1
                                Version table:
                               *** 20.17.0-1nodesource1 1001
                              No problems detected
                              Errors in npm tree:
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Core adapters versions
                              js-controller:  6.0.9
                              admin:          7.0.22
                              javascript:     8.7.6
                              nodejs modules from github:     2
                              +-- iobroker.tibber@0.3.1-beta (git+ssh://git@github.com/Magnus8513/ioBroker.tibber.git#283b14b7fbea6bb07eb37364dfba42eb2ca71786)
                              +-- iobroker.tibberconnect@0.0.10 (git+ssh://git@github.com/Codibris/ioBroker.tibberconnect.git#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83)
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                system.adapter.backitup.0               : backitup              : ioBroker                                 - disabled
                                system.adapter.flot.0                   : flot                  : ioBroker                                 -  enabled
                                system.adapter.history.0                : history               : ioBroker                                 - disabled
                              + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
                              + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                              + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                              + system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                                system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
                                system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
                              + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                              + system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
                                system.adapter.modbus.1                 : modbus                : ioBroker                                 - disabled
                              + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                system.adapter.semp.0                   : semp                  : ioBroker                                 -  enabled
                              + system.adapter.tibber.0                 : tibber                : ioBroker                                 -  enabled
                                system.adapter.tibberconnect.0          : tibberconnect         : ioBroker                                 -  enabled
                                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                                system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
                              + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                                system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
                                system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
                                system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
                                system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
                                system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                                system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
                              + system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                                system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + instance is alive
                              ioBroker-Repositories
                              │ (index) │ name               │ url                                                     │ auto upgrade │
                              │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                              │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                              Active repo(s): Stable (default)
                              Upgrade policy: none
                              Installed ioBroker-Instances
                              Used repository: Stable (default)
                              Adapter    "admin"        : 7.0.23   , installed 7.0.22 [Updatable]
                              Adapter    "backitup"     : 3.0.19   , installed 3.0.16 [Updatable]
                              Adapter    "hm-rega"      : 5.0.0    , installed 4.0.0  [Updatable]
                              Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                              Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                              Controller "js-controller": 6.0.9    , installed 6.0.9
                              Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                              Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                              Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                              Adapter    "semp"         : 1.4.5    , installed 1.4.5
                              Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                              Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                              Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                              Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                              Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                              Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                              Adapter    "ws"           : 2.6.2    , installed 2.6.2
                              Objects and States
                              Objects:        6488
                              States:         5380
                              Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                              Pending Updates: 0
                              *** Listening Ports ***
                              tcp        0      0 192.168.1.217:2010      0.0.0.0:*               LISTEN      1001       15000      655/io.hm-rpc.1
                              tcp        0      0 192.168.1.217:2001      0.0.0.0:*               LISTEN      1001       1768       640/io.hm-rpc.0
                              tcp        0      0 192.168.1.217:9292      0.0.0.0:*               LISTEN      1001       1783       670/io.hm-rpc.2
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14816      501/iobroker.js-con
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14811      501/iobroker.js-con
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13729      1/init
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14797      515/sshd: /usr/sbin
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17224      544/io.admin.0
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16008      841/io.web.0
                              tcp6       0      0 :::9765                 :::*                    LISTEN      1001       17623      872/io.semp.0
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          934        1/init
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          14799      515/sshd: /usr/sbin
                              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       17625      872/io.semp.0
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14757      417/dhclient
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1311       1/init
                              udp6       0      0 :::111                  :::*                                0          1312       1/init
                              2024-08-25 19:44:58.750  - info: mqtt.0 (685) Try to connect to mqtt://192.168.1.216:1883 with clientId=ioBroker.mqtt.0
                              2024-08-25 19:44:58.811  - info: mqtt.0 (685) Connected to 192.168.1.216
                              2024-08-25 19:44:58.812  - info: mqtt.0 (685) Subscribe on "#"
                              2024-08-25 19:45:01.141  - info: host.ioBroker instance system.adapter.modbus.0 in version "6.2.3" started with pid 703
                              2024-08-25 19:45:02.310  - info: modbus.0 (703) starting. Version 6.2.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v20.17.0, js-controller: 6.0.9
                              2024-08-25 19:45:02.813  - info: modbus.0 (703) Connected to slave 192.168.1.236
                              2024-08-25 19:45:04.449  - info: hm-rpc.2 (670) Connected
                              2024-08-25 19:45:05.149  - info: host.ioBroker instance system.adapter.tibber.0 in version "0.3.1-beta" (non-npm: Magnus8513/ioBroker.tibber#283b14b7fbea6bb07eb37364dfba42eb2ca71786) started with pid 718
                              2024-08-25 19:45:06.519  - info: tibber.0 (718) starting. Version 0.3.1-beta (non-npm: Magnus8513/ioBroker.tibber#283b14b7fbea6bb07eb37364dfba42eb2ca71786) in /opt/iobroker/node_modules/iobroker.tibber, node: v20.17.0, js-controller: 6.0.9
                              2024-08-25 19:45:06.894  - info: tibber.0 (718) Tibber refresh success
                              2024-08-25 19:45:09.217  - info: host.ioBroker instance system.adapter.vis-inventwo.0 in version "3.3.4" started with pid 772
                              2024-08-25 19:45:10.533  - info: vis-inventwo.0 (772) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v20.17.0, js-controller: 6.0.9
                              2024-08-25 19:45:14.459  - info: vis.0 (801) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.17.0, js-controller: 6.0.9
                              2024-08-25 19:45:15.948  - info: vis.0 (801) Terminated (NO_ERROR): Without reason
                              2024-08-25 19:45:16.563  - info: host.ioBroker instance system.adapter.vis.0 terminated while should be started once
                              2024-08-25 19:45:17.198  - info: host.ioBroker instance system.adapter.web.0 in version "6.2.5" started with pid 841
                              2024-08-25 19:45:18.951  - info: web.0 (841) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.9
                              2024-08-25 19:45:19.078  - info: web.0 (841) socket.io server listening on port 8082
                              2024-08-25 19:45:19.084  - info: web.0 (841) http server listening on port 8082
                              2024-08-25 19:45:21.172  - info: host.ioBroker instance system.adapter.tibberconnect.0 in version "0.0.10" (non-npm: Codibris/ioBroker.tibberconnect#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83) started with pid 857
                              2024-08-25 19:45:25.193  - info: host.ioBroker instance system.adapter.semp.0 in version "1.4.5" started with pid 872
                              2024-08-25 19:45:26.860  - info: semp.0 (872) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.semp, node: v20.17.0, js-controller: 6.0.9
                              2024-08-25 19:45:26.898  - error: semp.0 (872) Lambda wrong device SerialNr
                              2024-08-25 19:45:26.900  - info: semp.0 (872) device created F-12287760-000000000001-00 Lambda
                              2024-08-25 19:45:29.921  - info: semp.0 (872) adapter discovered by SHM
                              @Homoran Habe ich davor neu gestartet, danke für den Hinweis.
                                Homoran Global Moderator Administrators @Burgsteff last edited by Homoran
                                usr/bin/npm 10.8.2
                                da isses ja!
                                dann müsstest du jetzt die fehlenden Updates machen können.
                                  Meeeeeeega, jetzt passt das wieder.
                                  Vielen herzlichen Dank 👏 👏 👏
                                  Was kann man euch Gutes tun?
                                    @burgsteff
                                    Gut, der ioBroker rennt wohl wieder.
                                    cat /etc/profile
                                    sagt?
                                      burgsteff@ioBroker:~$ cat /etc/profile
                                      # /etc/profile: system-wide .profile file for the Bourne shell (sh(1))
                                      # and Bourne compatible shells (bash(1), ksh(1), ash(1), ...).
                                      if [ "$(id -u)" -eq 0 ]; then
                                        PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
                                      else
                                        PATH="/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games"
                                      fi
                                      export PATH
                                      if [ "${PS1-}" ]; then
                                        if [ "${BASH-}" ] && [ "$BASH" != "/bin/sh" ]; then
                                          # The file bash.bashrc already sets the default PS1.
                                          # PS1='\h:\w\$ '
                                          if [ -f /etc/bash.bashrc ]; then
                                            . /etc/bash.bashrc
                                          fi
                                        else
                                            PS1='# '
                                          else
                                            PS1='$ '
                                          fi
                                        fi
                                      fi
                                      if [ -d /etc/profile.d ]; then
                                        for i in /etc/profile.d/*.sh; do
                                          if [ -r $i ]; then
                                            . $i
                                          fi
                                        done
                                        unset i
                                      fi
                                        @burgsteff
                                        Das passt eigentlich. Lass es so.
                                          Dann ist ja gut, perfekt.
                                          Wirklich echt vielen Dank für die schnelle, kompetente und freundliche Hilfe.
                                            @burgsteff
                                            Trag mal in der Zeile 8 das ein:
                                            PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games"
                                            3686
