    4. NPM verschwunden ,Keine Änderungen in der Konsole möglich
      Thomas Braun Most Active @Burgsteff last edited by
      @burgsteff
      Dann
      exit
      exit
      und nochmal als 'burgsteff' neu anmelden.
        Burgsteff @Thomas Braun last edited by
        Hab mich wieder als burgsteff angemeldet
        Danke schon mal.
          @burgsteff
          iob nodejs-update
            Your nodejs- Installation seems to be faulty. Shall we try to fix it?
            Mit y beantworten oder?
              Homoran Global Moderator Administrators @Burgsteff last edited by
              @burgsteff sagte in NPM verschwunden ,Keine Änderungen in der Konsole möglich:
              bitte alles zeigen!
                Ja, das soll ja berichtigt werden.
                  ioBroker nodejs fixer 2024-05-23
                  Recommended nodejs-version is: 20.17.0
                  Checking your installation now. Please be patient!
                  Your current setup is:
                  /usr/bin/nodejs         v18.19.0
                  /usr/bin/node           v18.19.0
                  /home/iobroker/.nodejs-update.sh: line 146: npm: command not found
                  /home/iobroker/.nodejs-update.sh: line 147: npx: command not found
                  /home/iobroker/.nodejs-update.sh: line 168: npm: command not found
                  /home/iobroker/.nodejs-update.sh: line 169: npx: command not found
                  *** nodejs is NOT correctly installed ***
                  We found these nodejs versions available for installation:
                  nodejs:
                    Installed: 18.19.0+dfsg-6~deb12u2
                    Candidate: 18.19.0+dfsg-6~deb12u2
                    Version table:
                   *** 18.19.0+dfsg-6~deb12u2 500
                          500 http://deb.debian.org/debian bookworm/main amd64 Packages
                          100 /var/lib/dpkg/status
                       18.19.0+dfsg-6~deb12u1 500
                          500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                       18.17.1-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
                  Your nodejs-Installation seems to be faulty. Shall we try to fix it?
                  Press <y> to continue or any other key to quit
                  Fixing your nodejs setup
                  *** Deleting  ***
                  rm: cannot remove '': No such file or directory
                  *** Deleting  ***
                  Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
                  You are running nodejs v18.19.0. Do you want to install recommended version 20.17.0?
                  Trying to fix your installation now. Please be patient.
                  Virtualization: kvm
                  Waiting for ioBroker to shut down - Give me a minute...
                  *** These repos are active on your system:
                  Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                  Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
                  Reading package lists... Done
                  *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                  *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                  deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                  Package: nodejs
                  Pin: origin deb.nodesource.com
                  Pin-Priority: 1001
                  *** These repos are active after the adjustments:
                  Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                  Hit:2 http://deb.debian.org/debian bookworm InRelease
                  Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                  Get:4 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
                  Get:5 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages [8942 B]
                  Fetched 21.1 kB in 1s (29.9 kB/s)
                  Installing nodejs now!
                  E: Broken packages
                  E: Broken packages
                  *** You need to manually restart your container/virtual machine now! ***
                  We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
                    @burgsteff
                    Ah, die Version ist nicht aktuell genug.
                    Versuch es mal mit der Beta:
                    curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_node_update.sh > iob_node_update
                    chmod 744 iob_node_update
                    ./iob_node_update
                      ioBroker nodejs maintenance 2024-08-08
                      ./iob_node_update: line 157: npm: command not found
                      ./iob_node_update: line 158: npx: command not found
                      ./iob_node_update: line 179: npm: command not found
                      ./iob_node_update: line 180: npx: command not found
                      nodejs:
                        Candidate: 20.17.0-1nodesource1
                        Version table:
                           20.17.0-1nodesource1 1001
                              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                           20.16.0-1nodesource1 1001
                           20.15.1-1nodesource1 1001
                           20.15.0-1nodesource1 1001
                           20.14.0-1nodesource1 1001
                           20.13.1-1nodesource1 1001
                           20.13.0-1nodesource1 1001
                           20.12.2-1nodesource1 1001
                           20.12.1-1nodesource1 1001
                           20.12.0-1nodesource1 1001
                           20.11.1-1nodesource1 1001
                           20.11.0-1nodesource1 1001
                           20.10.0-1nodesource1 1001
                           20.9.0-1nodesource1 1001
                           20.8.1-1nodesource1 1001
                           20.8.0-1nodesource1 1001
                           20.7.0-1nodesource1 1001
                           20.6.1-1nodesource1 1001
                           20.6.0-1nodesource1 1001
                           20.5.1-1nodesource1 1001
                           20.5.0-1nodesource1 1001
                           20.4.0-1nodesource1 1001
                           20.3.1-1nodesource1 1001
                           20.3.0-1nodesource1 1001
                           20.2.0-1nodesource1 1001
                           20.1.0-1nodesource1 1001
                           20.0.0-1nodesource1 1001
                      *** Deleting  ***
                      *** Deleting  ***
                      Virtualization: kvm
                      Removing dfsg-nodejs
                      (Reading database ... 45351 files and directories currently installed.)
                      Removing nodejs-doc (18.19.0+dfsg-6~deb12u2) ...
                      Removing nodejs (18.19.0+dfsg-6~deb12u2) ...
                      Removing libnode108:amd64 (18.19.0+dfsg-6~deb12u2) ...
                      Removing node-acorn (8.8.1+ds+~cs25.17.7-2) ...
                      Removing node-undici (5.15.0+dfsg1+~cs20.10.9.3-1+deb12u4) ...
                      Removing node-busboy (1.6.0+~cs2.6.0-2) ...
                      Removing node-cjs-module-lexer (1.2.2+dfsg-5) ...
                      Removing node-xtend (4.0.2-3) ...
                      Processing triggers for libc-bin (2.36-9+deb12u7) ...
                      Package: nodejs
                      Pin-Priority: 1001
                      Fetched 21.1 kB in 1s (30.2 kB/s)
                      (Reading database ... 44612 files and directories currently installed.)
                      Preparing to unpack .../libaom3_3.6.0-1+deb12u1_amd64.deb ...
                      Unpacking libaom3:amd64 (3.6.0-1+deb12u1) over (3.6.0-1) ...
                      Selecting previously unselected package nodejs.
                      Preparing to unpack .../nodejs_20.17.0-1nodesource1_amd64.deb ...
                      Unpacking nodejs (20.17.0-1nodesource1) ...
                      Setting up libaom3:amd64 (3.6.0-1+deb12u1) ...
                      Setting up nodejs (20.17.0-1nodesource1) ...
                      burgsteff@ioBroker:~$
                        Mach das mal.
                          aber vorher
                            Skript v.2024-05-22
                            *** BASE SYSTEM ***
                             Static hostname: ioBroker
                                   Icon name: computer-vm
                                     Chassis: vm 🖴
                              Virtualization: kvm
                                      Kernel: Linux 6.1.0-23-amd64
                                Architecture: x86-64
                             Hardware Vendor: QEMU
                              Hardware Model: Standard PC _i440FX + PIIX, 1996_
                            Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
                            model name      : QEMU Virtual CPU version 2.5+
                            Docker          : false
                            Virtualization  : kvm
                            Kernel          : x86_64
                            Userland        : 64 bit
                            Systemuptime and Load:
                             19:45:28 up 1 min,  2 users,  load average: 0.48, 0.16, 0.06
                            CPU threads: 4
                            *** Time and Time Zones ***
                                           Local time: Sun 2024-08-25 19:45:28 CEST
                                       Universal time: Sun 2024-08-25 17:45:28 UTC
                                             RTC time: Sun 2024-08-25 17:45:28
                            System clock synchronized: no
                                          NTP service: n/a
                                      RTC in local TZ: no
                            *** Users and Groups ***
                            User that called 'iob diag':
                            burgsteff
                            HOME=/home/burgsteff
                            GROUPS=burgsteff adm dialout cdrom floppy sudo audio dip video plugdev users input netdev iobroker
                            iobroker
                            HOME=/home/iobroker
                            GROUPS=iobroker tty dialout audio video plugdev
                            *** Display-Server-Setup ***
                            Display-Server: false
                            Desktop:
                            Terminal:       tty
                            Boot Target:    multi-user.target
                            *** MEMORY ***
                            Mem:            4.1G        1.2G        2.7G        516K        384M        2.9G
                            Swap:           1.0G          0B        1.0G
                            Total:          5.1G        1.2G        3.7G
                            Active iob-Instances:   12
                                     3914 M total memory
                                     1181 M used memory
                                      124 M active memory
                                     1027 M inactive memory
                                     2583 M free memory
                                       36 M buffer memory
                                      331 M swap cache
                                      974 M total swap
                                        0 M used swap
                                      974 M free swap
                            top - 19:45:28 up 1 min,  2 users,  load average: 0.48, 0.16, 0.06
                            Tasks: 123 total,   1 running, 122 sleeping,   0 stopped,   0 zombie
                            %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   3914.7 total,   2583.4 free,   1181.6 used,    367.3 buff/cache
                            MiB Swap:    975.0 total,    975.0 free,      0.0 used.   2733.2 avail Mem
                            *** FAILED SERVICES ***
                            0 loaded units listed.
                            *** FILESYSTEM ***
                            udev           devtmpfs  1.9G     0  1.9G   0% /dev
                            tmpfs          tmpfs     392M  512K  391M   1% /run
                            /dev/sda1      ext4       31G  6.5G   23G  23% /
                            tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                            tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                            tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
                            [Sun Aug 25 19:44:27 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                            [Sun Aug 25 19:44:27 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
                            Show mounted filesystems:
                            TARGET                                                  SOURCE      FSTYPE      OPTIONS
                            /                                                       /dev/sda1   ext4        rw,relatime,errors=remount-ro
                            |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
                            | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
                            | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                            | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
                            | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                            | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                            | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                            | |-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
                            | `-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                            |-/proc                                                 proc        proc        rw,nosuid,nodev,noexec,relatime
                            | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=14461
                            |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                            |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=1981136k,nr_inodes=495284,mode=755,inode64
                            | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                            | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev,inode64
                            | |-/dev/hugepages                                      hugetlbfs   hugetlbfs   rw,relatime,pagesize=2M
                            | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                            `-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=400872k,mode=755,inode64
                              |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
                              |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                              |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                              |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                              |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
                              |-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=400868k,nr_inodes=100217,mode=700,uid=1000,gid=1000,inode64
                              `-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                            /var:
                            745M    /var/
                            348M    /var/cache
                            343M    /var/cache/apt
                            267M    /var/cache/apt/archives
                            240M    /var/log
                            Archived and active journals take up 224.3M in the file system.
                            /opt/iobroker/backups:
                            35M     /opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            837M    /opt/iobroker/iobroker-data/
                            748M    /opt/iobroker/iobroker-data/files
                            441M    /opt/iobroker/iobroker-data/files/javascript.admin
                            409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                            408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                            27M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
                            25M     /opt/iobroker/iobroker-data/objects.jsonl
                            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                            22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js.map
                            9.0M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js
                            USB-Devices by-id:
                            No Devices found 'by-id'
                            *** NodeJS-Installation ***
                            /usr/bin/nodejs         v20.17.0
                            /usr/bin/node           v20.17.0
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            /usr/bin/corepack       0.29.3
                            nodejs:
                              Installed: 20.17.0-1nodesource1
                              Version table:
                             *** 20.17.0-1nodesource1 1001
                            No problems detected
                            Errors in npm tree:
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Core adapters versions
                            js-controller:  6.0.9
                            admin:          7.0.22
                            javascript:     8.7.6
                            nodejs modules from github:     2
                            +-- iobroker.tibber@0.3.1-beta (git+ssh://git@github.com/Magnus8513/ioBroker.tibber.git#283b14b7fbea6bb07eb37364dfba42eb2ca71786)
                            +-- iobroker.tibberconnect@0.0.10 (git+ssh://git@github.com/Codibris/ioBroker.tibberconnect.git#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83)
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              system.adapter.backitup.0               : backitup              : ioBroker                                 - disabled
                              system.adapter.flot.0                   : flot                  : ioBroker                                 -  enabled
                              system.adapter.history.0                : history               : ioBroker                                 - disabled
                            + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
                            + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                            + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                            + system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                              system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
                              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
                            + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                            + system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
                              system.adapter.modbus.1                 : modbus                : ioBroker                                 - disabled
                            + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                              system.adapter.semp.0                   : semp                  : ioBroker                                 -  enabled
                            + system.adapter.tibber.0                 : tibber                : ioBroker                                 -  enabled
                              system.adapter.tibberconnect.0          : tibberconnect         : ioBroker                                 -  enabled
                              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                              system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
                            + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                              system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
                              system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
                              system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
                              system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                              system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
                            + system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                              system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            + instance is alive
                            ioBroker-Repositories
                            │ (index) │ name               │ url                                                     │ auto upgrade │
                            │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                            │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                            Active repo(s): Stable (default)
                            Upgrade policy: none
                            Installed ioBroker-Instances
                            Used repository: Stable (default)
                            Adapter    "admin"        : 7.0.23   , installed 7.0.22 [Updatable]
                            Adapter    "backitup"     : 3.0.19   , installed 3.0.16 [Updatable]
                            Adapter    "hm-rega"      : 5.0.0    , installed 4.0.0  [Updatable]
                            Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                            Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                            Controller "js-controller": 6.0.9    , installed 6.0.9
                            Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                            Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                            Adapter    "semp"         : 1.4.5    , installed 1.4.5
                            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                            Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                            Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                            Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                            Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                            Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                            Adapter    "ws"           : 2.6.2    , installed 2.6.2
                            Objects and States
                            Objects:        6488
                            States:         5380
                            Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                            Pending Updates: 0
                            *** Listening Ports ***
                            tcp        0      0 192.168.1.217:2010      0.0.0.0:*               LISTEN      1001       15000      655/io.hm-rpc.1
                            tcp        0      0 192.168.1.217:2001      0.0.0.0:*               LISTEN      1001       1768       640/io.hm-rpc.0
                            tcp        0      0 192.168.1.217:9292      0.0.0.0:*               LISTEN      1001       1783       670/io.hm-rpc.2
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14816      501/iobroker.js-con
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14811      501/iobroker.js-con
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13729      1/init
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14797      515/sshd: /usr/sbin
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17224      544/io.admin.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16008      841/io.web.0
                            tcp6       0      0 :::9765                 :::*                    LISTEN      1001       17623      872/io.semp.0
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          934        1/init
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          14799      515/sshd: /usr/sbin
                            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       17625      872/io.semp.0
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14757      417/dhclient
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1311       1/init
                            udp6       0      0 :::111                  :::*                                0          1312       1/init
                            2024-08-25 19:44:58.750  - info: mqtt.0 (685) Try to connect to mqtt://192.168.1.216:1883 with clientId=ioBroker.mqtt.0
                            2024-08-25 19:44:58.811  - info: mqtt.0 (685) Connected to 192.168.1.216
                            2024-08-25 19:44:58.812  - info: mqtt.0 (685) Subscribe on "#"
                            2024-08-25 19:45:01.141  - info: host.ioBroker instance system.adapter.modbus.0 in version "6.2.3" started with pid 703
                            2024-08-25 19:45:02.310  - info: modbus.0 (703) starting. Version 6.2.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v20.17.0, js-controller: 6.0.9
                            2024-08-25 19:45:02.813  - info: modbus.0 (703) Connected to slave 192.168.1.236
                            2024-08-25 19:45:04.449  - info: hm-rpc.2 (670) Connected
                            2024-08-25 19:45:05.149  - info: host.ioBroker instance system.adapter.tibber.0 in version "0.3.1-beta" (non-npm: Magnus8513/ioBroker.tibber#283b14b7fbea6bb07eb37364dfba42eb2ca71786) started with pid 718
                            2024-08-25 19:45:06.519  - info: tibber.0 (718) starting. Version 0.3.1-beta (non-npm: Magnus8513/ioBroker.tibber#283b14b7fbea6bb07eb37364dfba42eb2ca71786) in /opt/iobroker/node_modules/iobroker.tibber, node: v20.17.0, js-controller: 6.0.9
                            2024-08-25 19:45:06.894  - info: tibber.0 (718) Tibber refresh success
                            2024-08-25 19:45:09.217  - info: host.ioBroker instance system.adapter.vis-inventwo.0 in version "3.3.4" started with pid 772
                            2024-08-25 19:45:10.533  - info: vis-inventwo.0 (772) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v20.17.0, js-controller: 6.0.9
                            2024-08-25 19:45:14.459  - info: vis.0 (801) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.17.0, js-controller: 6.0.9
                            2024-08-25 19:45:15.948  - info: vis.0 (801) Terminated (NO_ERROR): Without reason
                            2024-08-25 19:45:16.563  - info: host.ioBroker instance system.adapter.vis.0 terminated while should be started once
                            2024-08-25 19:45:17.198  - info: host.ioBroker instance system.adapter.web.0 in version "6.2.5" started with pid 841
                            2024-08-25 19:45:18.951  - info: web.0 (841) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.9
                            2024-08-25 19:45:19.078  - info: web.0 (841) socket.io server listening on port 8082
                            2024-08-25 19:45:19.084  - info: web.0 (841) http server listening on port 8082
                            2024-08-25 19:45:21.172  - info: host.ioBroker instance system.adapter.tibberconnect.0 in version "0.0.10" (non-npm: Codibris/ioBroker.tibberconnect#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83) started with pid 857
                            2024-08-25 19:45:25.193  - info: host.ioBroker instance system.adapter.semp.0 in version "1.4.5" started with pid 872
                            2024-08-25 19:45:26.860  - info: semp.0 (872) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.semp, node: v20.17.0, js-controller: 6.0.9
                            2024-08-25 19:45:26.898  - error: semp.0 (872) Lambda wrong device SerialNr
                            2024-08-25 19:45:26.900  - info: semp.0 (872) device created F-12287760-000000000001-00 Lambda
                            2024-08-25 19:45:29.921  - info: semp.0 (872) adapter discovered by SHM
                            @Homoran Habe ich davor neu gestartet, danke für den Hinweis.
                              Homoran Global Moderator Administrators @Burgsteff last edited by Homoran
                              usr/bin/npm 10.8.2
                              da isses ja!
                              dann müsstest du jetzt die fehlenden Updates machen können.
                                Meeeeeeega, jetzt passt das wieder.
                                Vielen herzlichen Dank 👏 👏 👏
                                Was kann man euch Gutes tun?
                                  @burgsteff
                                  Gut, der ioBroker rennt wohl wieder.
                                  cat /etc/profile
                                  sagt?
                                    burgsteff@ioBroker:~$ cat /etc/profile
                                    # /etc/profile: system-wide .profile file for the Bourne shell (sh(1))
                                    # and Bourne compatible shells (bash(1), ksh(1), ash(1), ...).
                                    if [ "$(id -u)" -eq 0 ]; then
                                      PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
                                    else
                                      PATH="/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games"
                                    fi
                                    export PATH
                                    if [ "${PS1-}" ]; then
                                      if [ "${BASH-}" ] && [ "$BASH" != "/bin/sh" ]; then
                                        # The file bash.bashrc already sets the default PS1.
                                        # PS1='\h:\w\$ '
                                        if [ -f /etc/bash.bashrc ]; then
                                          . /etc/bash.bashrc
                                        fi
                                      else
                                          PS1='# '
                                        else
                                          PS1='$ '
                                        fi
                                      fi
                                    fi
                                    if [ -d /etc/profile.d ]; then
                                      for i in /etc/profile.d/*.sh; do
                                        if [ -r $i ]; then
                                          . $i
                                        fi
                                      done
                                      unset i
                                    fi
                                      @burgsteff
                                      Das passt eigentlich. Lass es so.
                                        Dann ist ja gut, perfekt.
                                        Wirklich echt vielen Dank für die schnelle, kompetente und freundliche Hilfe.
                                          @burgsteff
                                          Trag mal in der Zeile 8 das ein:
                                          PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games"
                                            wie bzw. wo in Zeile 8?
                                            4576
