    4. NPM verschwunden ,Keine Änderungen in der Konsole möglich
      Thomas Braun Most Active @Burgsteff last edited by
      @burgsteff
      iob nodejs-update
        Burgsteff @Thomas Braun last edited by
        Your nodejs- Installation seems to be faulty. Shall we try to fix it?
        Mit y beantworten oder?
          Homoran Global Moderator Administrators @Burgsteff last edited by
          @burgsteff sagte in NPM verschwunden ,Keine Änderungen in der Konsole möglich:
          bitte alles zeigen!
            Ja, das soll ja berichtigt werden.
              ioBroker nodejs fixer 2024-05-23
              Recommended nodejs-version is: 20.17.0
              Checking your installation now. Please be patient!
              Your current setup is:
              /usr/bin/nodejs         v18.19.0
              /usr/bin/node           v18.19.0
              /home/iobroker/.nodejs-update.sh: line 146: npm: command not found
              /home/iobroker/.nodejs-update.sh: line 147: npx: command not found
              /home/iobroker/.nodejs-update.sh: line 168: npm: command not found
              /home/iobroker/.nodejs-update.sh: line 169: npx: command not found
              *** nodejs is NOT correctly installed ***
              We found these nodejs versions available for installation:
              nodejs:
                Installed: 18.19.0+dfsg-6~deb12u2
                Candidate: 18.19.0+dfsg-6~deb12u2
                Version table:
               *** 18.19.0+dfsg-6~deb12u2 500
                      500 http://deb.debian.org/debian bookworm/main amd64 Packages
                      100 /var/lib/dpkg/status
                   18.19.0+dfsg-6~deb12u1 500
                      500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                   18.17.1-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
              Your nodejs-Installation seems to be faulty. Shall we try to fix it?
              Press <y> to continue or any other key to quit
              Fixing your nodejs setup
              *** Deleting  ***
              rm: cannot remove '': No such file or directory
              *** Deleting  ***
              Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
              You are running nodejs v18.19.0. Do you want to install recommended version 20.17.0?
              Trying to fix your installation now. Please be patient.
              Virtualization: kvm
              Waiting for ioBroker to shut down - Give me a minute...
              *** These repos are active on your system:
              Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
              Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
              Reading package lists... Done
              *** Installing ca-certificates, curl and gnupg, just in case they are missing.
              *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
              deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
              Package: nodejs
              Pin: origin deb.nodesource.com
              Pin-Priority: 1001
              *** These repos are active after the adjustments:
              Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
              Hit:2 http://deb.debian.org/debian bookworm InRelease
              Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
              Get:4 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
              Get:5 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages [8942 B]
              Fetched 21.1 kB in 1s (29.9 kB/s)
              Installing nodejs now!
              E: Broken packages
              E: Broken packages
              *** You need to manually restart your container/virtual machine now! ***
              We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
                @burgsteff
                Ah, die Version ist nicht aktuell genug.
                Versuch es mal mit der Beta:
                curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_node_update.sh > iob_node_update
                chmod 744 iob_node_update
                ./iob_node_update
                  ioBroker nodejs maintenance 2024-08-08
                  ./iob_node_update: line 157: npm: command not found
                  ./iob_node_update: line 158: npx: command not found
                  ./iob_node_update: line 179: npm: command not found
                  ./iob_node_update: line 180: npx: command not found
                  nodejs:
                    Candidate: 20.17.0-1nodesource1
                    Version table:
                       20.17.0-1nodesource1 1001
                          500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                       20.16.0-1nodesource1 1001
                       20.15.1-1nodesource1 1001
                       20.15.0-1nodesource1 1001
                       20.14.0-1nodesource1 1001
                       20.13.1-1nodesource1 1001
                       20.13.0-1nodesource1 1001
                       20.12.2-1nodesource1 1001
                       20.12.1-1nodesource1 1001
                       20.12.0-1nodesource1 1001
                       20.11.1-1nodesource1 1001
                       20.11.0-1nodesource1 1001
                       20.10.0-1nodesource1 1001
                       20.9.0-1nodesource1 1001
                       20.8.1-1nodesource1 1001
                       20.8.0-1nodesource1 1001
                       20.7.0-1nodesource1 1001
                       20.6.1-1nodesource1 1001
                       20.6.0-1nodesource1 1001
                       20.5.1-1nodesource1 1001
                       20.5.0-1nodesource1 1001
                       20.4.0-1nodesource1 1001
                       20.3.1-1nodesource1 1001
                       20.3.0-1nodesource1 1001
                       20.2.0-1nodesource1 1001
                       20.1.0-1nodesource1 1001
                       20.0.0-1nodesource1 1001
                  *** Deleting  ***
                  *** Deleting  ***
                  Virtualization: kvm
                  Removing dfsg-nodejs
                  (Reading database ... 45351 files and directories currently installed.)
                  Removing nodejs-doc (18.19.0+dfsg-6~deb12u2) ...
                  Removing nodejs (18.19.0+dfsg-6~deb12u2) ...
                  Removing libnode108:amd64 (18.19.0+dfsg-6~deb12u2) ...
                  Removing node-acorn (8.8.1+ds+~cs25.17.7-2) ...
                  Removing node-undici (5.15.0+dfsg1+~cs20.10.9.3-1+deb12u4) ...
                  Removing node-busboy (1.6.0+~cs2.6.0-2) ...
                  Removing node-cjs-module-lexer (1.2.2+dfsg-5) ...
                  Removing node-xtend (4.0.2-3) ...
                  Processing triggers for libc-bin (2.36-9+deb12u7) ...
                  Package: nodejs
                  Pin-Priority: 1001
                  Fetched 21.1 kB in 1s (30.2 kB/s)
                  (Reading database ... 44612 files and directories currently installed.)
                  Preparing to unpack .../libaom3_3.6.0-1+deb12u1_amd64.deb ...
                  Unpacking libaom3:amd64 (3.6.0-1+deb12u1) over (3.6.0-1) ...
                  Selecting previously unselected package nodejs.
                  Preparing to unpack .../nodejs_20.17.0-1nodesource1_amd64.deb ...
                  Unpacking nodejs (20.17.0-1nodesource1) ...
                  Setting up libaom3:amd64 (3.6.0-1+deb12u1) ...
                  Setting up nodejs (20.17.0-1nodesource1) ...
                  burgsteff@ioBroker:~$
                    Mach das mal.
                      aber vorher
                        Skript v.2024-05-22
                        *** BASE SYSTEM ***
                         Static hostname: ioBroker
                               Icon name: computer-vm
                                 Chassis: vm 🖴
                          Virtualization: kvm
                                  Kernel: Linux 6.1.0-23-amd64
                            Architecture: x86-64
                         Hardware Vendor: QEMU
                          Hardware Model: Standard PC _i440FX + PIIX, 1996_
                        Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
                        model name      : QEMU Virtual CPU version 2.5+
                        Docker          : false
                        Virtualization  : kvm
                        Kernel          : x86_64
                        Userland        : 64 bit
                        Systemuptime and Load:
                         19:45:28 up 1 min,  2 users,  load average: 0.48, 0.16, 0.06
                        CPU threads: 4
                        *** Time and Time Zones ***
                                       Local time: Sun 2024-08-25 19:45:28 CEST
                                   Universal time: Sun 2024-08-25 17:45:28 UTC
                                         RTC time: Sun 2024-08-25 17:45:28
                        System clock synchronized: no
                                      NTP service: n/a
                                  RTC in local TZ: no
                        *** Users and Groups ***
                        User that called 'iob diag':
                        burgsteff
                        HOME=/home/burgsteff
                        GROUPS=burgsteff adm dialout cdrom floppy sudo audio dip video plugdev users input netdev iobroker
                        iobroker
                        HOME=/home/iobroker
                        GROUPS=iobroker tty dialout audio video plugdev
                        *** Display-Server-Setup ***
                        Display-Server: false
                        Desktop:
                        Terminal:       tty
                        Boot Target:    multi-user.target
                        *** MEMORY ***
                        Mem:            4.1G        1.2G        2.7G        516K        384M        2.9G
                        Swap:           1.0G          0B        1.0G
                        Total:          5.1G        1.2G        3.7G
                        Active iob-Instances:   12
                                 3914 M total memory
                                 1181 M used memory
                                  124 M active memory
                                 1027 M inactive memory
                                 2583 M free memory
                                   36 M buffer memory
                                  331 M swap cache
                                  974 M total swap
                                    0 M used swap
                                  974 M free swap
                        top - 19:45:28 up 1 min,  2 users,  load average: 0.48, 0.16, 0.06
                        Tasks: 123 total,   1 running, 122 sleeping,   0 stopped,   0 zombie
                        %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   3914.7 total,   2583.4 free,   1181.6 used,    367.3 buff/cache
                        MiB Swap:    975.0 total,    975.0 free,      0.0 used.   2733.2 avail Mem
                        *** FAILED SERVICES ***
                        0 loaded units listed.
                        *** FILESYSTEM ***
                        udev           devtmpfs  1.9G     0  1.9G   0% /dev
                        tmpfs          tmpfs     392M  512K  391M   1% /run
                        /dev/sda1      ext4       31G  6.5G   23G  23% /
                        tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                        tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
                        [Sun Aug 25 19:44:27 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                        [Sun Aug 25 19:44:27 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
                        Show mounted filesystems:
                        TARGET                                                  SOURCE      FSTYPE      OPTIONS
                        /                                                       /dev/sda1   ext4        rw,relatime,errors=remount-ro
                        |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
                        | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
                        | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                        | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
                        | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                        | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                        | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                        | |-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
                        | `-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                        |-/proc                                                 proc        proc        rw,nosuid,nodev,noexec,relatime
                        | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=14461
                        |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                        |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=1981136k,nr_inodes=495284,mode=755,inode64
                        | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                        | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev,inode64
                        | |-/dev/hugepages                                      hugetlbfs   hugetlbfs   rw,relatime,pagesize=2M
                        | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                        `-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=400872k,mode=755,inode64
                          |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
                          |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                          |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                          |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                          |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
                          |-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=400868k,nr_inodes=100217,mode=700,uid=1000,gid=1000,inode64
                          `-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                        /var:
                        745M    /var/
                        348M    /var/cache
                        343M    /var/cache/apt
                        267M    /var/cache/apt/archives
                        240M    /var/log
                        Archived and active journals take up 224.3M in the file system.
                        /opt/iobroker/backups:
                        35M     /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        837M    /opt/iobroker/iobroker-data/
                        748M    /opt/iobroker/iobroker-data/files
                        441M    /opt/iobroker/iobroker-data/files/javascript.admin
                        409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                        408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                        27M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
                        25M     /opt/iobroker/iobroker-data/objects.jsonl
                        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                        22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js.map
                        9.0M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js
                        USB-Devices by-id:
                        No Devices found 'by-id'
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v20.17.0
                        /usr/bin/node           v20.17.0
                        /usr/bin/npm            10.8.2
                        /usr/bin/npx            10.8.2
                        /usr/bin/corepack       0.29.3
                        nodejs:
                          Installed: 20.17.0-1nodesource1
                          Version table:
                         *** 20.17.0-1nodesource1 1001
                        No problems detected
                        Errors in npm tree:
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Core adapters versions
                        js-controller:  6.0.9
                        admin:          7.0.22
                        javascript:     8.7.6
                        nodejs modules from github:     2
                        +-- iobroker.tibber@0.3.1-beta (git+ssh://git@github.com/Magnus8513/ioBroker.tibber.git#283b14b7fbea6bb07eb37364dfba42eb2ca71786)
                        +-- iobroker.tibberconnect@0.0.10 (git+ssh://git@github.com/Codibris/ioBroker.tibberconnect.git#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83)
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          system.adapter.backitup.0               : backitup              : ioBroker                                 - disabled
                          system.adapter.flot.0                   : flot                  : ioBroker                                 -  enabled
                          system.adapter.history.0                : history               : ioBroker                                 - disabled
                        + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
                        + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                        + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                        + system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
                          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
                        + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                        + system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
                          system.adapter.modbus.1                 : modbus                : ioBroker                                 - disabled
                        + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                          system.adapter.semp.0                   : semp                  : ioBroker                                 -  enabled
                        + system.adapter.tibber.0                 : tibber                : ioBroker                                 -  enabled
                          system.adapter.tibberconnect.0          : tibberconnect         : ioBroker                                 -  enabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                          system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
                        + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                          system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
                          system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
                          system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
                          system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                          system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
                        + system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                          system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        + instance is alive
                        ioBroker-Repositories
                        │ (index) │ name               │ url                                                     │ auto upgrade │
                        │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                        │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                        Active repo(s): Stable (default)
                        Upgrade policy: none
                        Installed ioBroker-Instances
                        Used repository: Stable (default)
                        Adapter    "admin"        : 7.0.23   , installed 7.0.22 [Updatable]
                        Adapter    "backitup"     : 3.0.19   , installed 3.0.16 [Updatable]
                        Adapter    "hm-rega"      : 5.0.0    , installed 4.0.0  [Updatable]
                        Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                        Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                        Controller "js-controller": 6.0.9    , installed 6.0.9
                        Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                        Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                        Adapter    "semp"         : 1.4.5    , installed 1.4.5
                        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                        Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                        Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                        Adapter    "ws"           : 2.6.2    , installed 2.6.2
                        Objects and States
                        Objects:        6488
                        States:         5380
                        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 192.168.1.217:2010      0.0.0.0:*               LISTEN      1001       15000      655/io.hm-rpc.1
                        tcp        0      0 192.168.1.217:2001      0.0.0.0:*               LISTEN      1001       1768       640/io.hm-rpc.0
                        tcp        0      0 192.168.1.217:9292      0.0.0.0:*               LISTEN      1001       1783       670/io.hm-rpc.2
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14816      501/iobroker.js-con
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14811      501/iobroker.js-con
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13729      1/init
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14797      515/sshd: /usr/sbin
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17224      544/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16008      841/io.web.0
                        tcp6       0      0 :::9765                 :::*                    LISTEN      1001       17623      872/io.semp.0
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          934        1/init
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          14799      515/sshd: /usr/sbin
                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       17625      872/io.semp.0
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14757      417/dhclient
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1311       1/init
                        udp6       0      0 :::111                  :::*                                0          1312       1/init
                        2024-08-25 19:44:58.750  - info: mqtt.0 (685) Try to connect to mqtt://192.168.1.216:1883 with clientId=ioBroker.mqtt.0
                        2024-08-25 19:44:58.811  - info: mqtt.0 (685) Connected to 192.168.1.216
                        2024-08-25 19:44:58.812  - info: mqtt.0 (685) Subscribe on "#"
                        2024-08-25 19:45:01.141  - info: host.ioBroker instance system.adapter.modbus.0 in version "6.2.3" started with pid 703
                        2024-08-25 19:45:02.310  - info: modbus.0 (703) starting. Version 6.2.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v20.17.0, js-controller: 6.0.9
                        2024-08-25 19:45:02.813  - info: modbus.0 (703) Connected to slave 192.168.1.236
                        2024-08-25 19:45:04.449  - info: hm-rpc.2 (670) Connected
                        2024-08-25 19:45:05.149  - info: host.ioBroker instance system.adapter.tibber.0 in version "0.3.1-beta" (non-npm: Magnus8513/ioBroker.tibber#283b14b7fbea6bb07eb37364dfba42eb2ca71786) started with pid 718
                        2024-08-25 19:45:06.519  - info: tibber.0 (718) starting. Version 0.3.1-beta (non-npm: Magnus8513/ioBroker.tibber#283b14b7fbea6bb07eb37364dfba42eb2ca71786) in /opt/iobroker/node_modules/iobroker.tibber, node: v20.17.0, js-controller: 6.0.9
                        2024-08-25 19:45:06.894  - info: tibber.0 (718) Tibber refresh success
                        2024-08-25 19:45:09.217  - info: host.ioBroker instance system.adapter.vis-inventwo.0 in version "3.3.4" started with pid 772
                        2024-08-25 19:45:10.533  - info: vis-inventwo.0 (772) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v20.17.0, js-controller: 6.0.9
                        2024-08-25 19:45:14.459  - info: vis.0 (801) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.17.0, js-controller: 6.0.9
                        2024-08-25 19:45:15.948  - info: vis.0 (801) Terminated (NO_ERROR): Without reason
                        2024-08-25 19:45:16.563  - info: host.ioBroker instance system.adapter.vis.0 terminated while should be started once
                        2024-08-25 19:45:17.198  - info: host.ioBroker instance system.adapter.web.0 in version "6.2.5" started with pid 841
                        2024-08-25 19:45:18.951  - info: web.0 (841) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.9
                        2024-08-25 19:45:19.078  - info: web.0 (841) socket.io server listening on port 8082
                        2024-08-25 19:45:19.084  - info: web.0 (841) http server listening on port 8082
                        2024-08-25 19:45:21.172  - info: host.ioBroker instance system.adapter.tibberconnect.0 in version "0.0.10" (non-npm: Codibris/ioBroker.tibberconnect#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83) started with pid 857
                        2024-08-25 19:45:25.193  - info: host.ioBroker instance system.adapter.semp.0 in version "1.4.5" started with pid 872
                        2024-08-25 19:45:26.860  - info: semp.0 (872) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.semp, node: v20.17.0, js-controller: 6.0.9
                        2024-08-25 19:45:26.898  - error: semp.0 (872) Lambda wrong device SerialNr
                        2024-08-25 19:45:26.900  - info: semp.0 (872) device created F-12287760-000000000001-00 Lambda
                        2024-08-25 19:45:29.921  - info: semp.0 (872) adapter discovered by SHM
                        @Homoran Habe ich davor neu gestartet, danke für den Hinweis.
                          Homoran Global Moderator Administrators @Burgsteff last edited by Homoran
                          usr/bin/npm 10.8.2
                          da isses ja!
                          dann müsstest du jetzt die fehlenden Updates machen können.
                            Meeeeeeega, jetzt passt das wieder.
                            Vielen herzlichen Dank 👏 👏 👏
                            Was kann man euch Gutes tun?
                              @burgsteff
                              Gut, der ioBroker rennt wohl wieder.
                              cat /etc/profile
                              sagt?
                                burgsteff@ioBroker:~$ cat /etc/profile
                                # /etc/profile: system-wide .profile file for the Bourne shell (sh(1))
                                # and Bourne compatible shells (bash(1), ksh(1), ash(1), ...).
                                if [ "$(id -u)" -eq 0 ]; then
                                  PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
                                else
                                  PATH="/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games"
                                fi
                                export PATH
                                if [ "${PS1-}" ]; then
                                  if [ "${BASH-}" ] && [ "$BASH" != "/bin/sh" ]; then
                                    # The file bash.bashrc already sets the default PS1.
                                    # PS1='\h:\w\$ '
                                    if [ -f /etc/bash.bashrc ]; then
                                      . /etc/bash.bashrc
                                    fi
                                  else
                                      PS1='# '
                                    else
                                      PS1='$ '
                                    fi
                                  fi
                                fi
                                if [ -d /etc/profile.d ]; then
                                  for i in /etc/profile.d/*.sh; do
                                    if [ -r $i ]; then
                                      . $i
                                    fi
                                  done
                                  unset i
                                fi
                                  @burgsteff
                                  Das passt eigentlich. Lass es so.
                                    Dann ist ja gut, perfekt.
                                    Wirklich echt vielen Dank für die schnelle, kompetente und freundliche Hilfe.
                                      @burgsteff
                                      Trag mal in der Zeile 8 das ein:
                                      PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games"
                                        wie bzw. wo in Zeile 8?
                                          @burgsteff
                                          sudo nano /etc/profile
                                          Und dann statt
                                          da
                                          eintragen.
                                          Mit STRG-O und STRG-X speichern und den Editor verlassen.
                                            ok, hab ich gemacht. und nun?
                                            4576
