    4. NPM verschwunden ,Keine Änderungen in der Konsole möglich
      Burgsteff @Thomas Braun last edited by
      ioBroker nodejs fixer 2024-05-23
      Recommended nodejs-version is: 20.17.0
      Checking your installation now. Please be patient!
      Your current setup is:
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /home/iobroker/.nodejs-update.sh: line 146: npm: command not found
      /home/iobroker/.nodejs-update.sh: line 147: npx: command not found
      /home/iobroker/.nodejs-update.sh: line 168: npm: command not found
      /home/iobroker/.nodejs-update.sh: line 169: npx: command not found
      *** nodejs is NOT correctly installed ***
      We found these nodejs versions available for installation:
      nodejs:
        Installed: 18.19.0+dfsg-6~deb12u2
        Candidate: 18.19.0+dfsg-6~deb12u2
        Version table:
       *** 18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
              100 /var/lib/dpkg/status
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
           18.17.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x bookworm/main amd64 Packages
      Your nodejs-Installation seems to be faulty. Shall we try to fix it?
      Press <y> to continue or any other key to quit
      Fixing your nodejs setup
      *** Deleting  ***
      rm: cannot remove '': No such file or directory
      *** Deleting  ***
      Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
      You are running nodejs v18.19.0. Do you want to install recommended version 20.17.0?
      Trying to fix your installation now. Please be patient.
      Virtualization: kvm
      Waiting for ioBroker to shut down - Give me a minute...
      *** These repos are active on your system:
      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
      Reading package lists... Done
      *** Installing ca-certificates, curl and gnupg, just in case they are missing.
      *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
      Package: nodejs
      Pin: origin deb.nodesource.com
      Pin-Priority: 1001
      *** These repos are active after the adjustments:
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Get:4 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
      Get:5 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages [8942 B]
      Fetched 21.1 kB in 1s (29.9 kB/s)
      Installing nodejs now!
      E: Broken packages
      E: Broken packages
      *** You need to manually restart your container/virtual machine now! ***
      We tried our best to fix your nodejs. Please run 'iob diag' again to verify.
        Thomas Braun Most Active @Burgsteff last edited by
        @burgsteff
        Ah, die Version ist nicht aktuell genug.
        Versuch es mal mit der Beta:
        curl https://raw.githubusercontent.com/Grothesk242/iob_diag/main/iob_node_update.sh > iob_node_update
        chmod 744 iob_node_update
        ./iob_node_update
          ioBroker nodejs maintenance 2024-08-08
          ./iob_node_update: line 157: npm: command not found
          ./iob_node_update: line 158: npx: command not found
          ./iob_node_update: line 179: npm: command not found
          ./iob_node_update: line 180: npx: command not found
          nodejs:
            Candidate: 20.17.0-1nodesource1
            Version table:
               20.17.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
          *** Deleting  ***
          *** Deleting  ***
          Virtualization: kvm
          Removing dfsg-nodejs
          (Reading database ... 45351 files and directories currently installed.)
          Removing nodejs-doc (18.19.0+dfsg-6~deb12u2) ...
          Removing nodejs (18.19.0+dfsg-6~deb12u2) ...
          Removing libnode108:amd64 (18.19.0+dfsg-6~deb12u2) ...
          Removing node-acorn (8.8.1+ds+~cs25.17.7-2) ...
          Removing node-undici (5.15.0+dfsg1+~cs20.10.9.3-1+deb12u4) ...
          Removing node-busboy (1.6.0+~cs2.6.0-2) ...
          Removing node-cjs-module-lexer (1.2.2+dfsg-5) ...
          Removing node-xtend (4.0.2-3) ...
          Processing triggers for libc-bin (2.36-9+deb12u7) ...
          Package: nodejs
          Pin-Priority: 1001
          Fetched 21.1 kB in 1s (30.2 kB/s)
          (Reading database ... 44612 files and directories currently installed.)
          Preparing to unpack .../libaom3_3.6.0-1+deb12u1_amd64.deb ...
          Unpacking libaom3:amd64 (3.6.0-1+deb12u1) over (3.6.0-1) ...
          Selecting previously unselected package nodejs.
          Preparing to unpack .../nodejs_20.17.0-1nodesource1_amd64.deb ...
          Unpacking nodejs (20.17.0-1nodesource1) ...
          Setting up libaom3:amd64 (3.6.0-1+deb12u1) ...
          Setting up nodejs (20.17.0-1nodesource1) ...
          burgsteff@ioBroker:~$
            @burgsteff sagte in NPM verschwunden ,Keine Änderungen in der Konsole möglich:
            Mach das mal.
              Homoran Global Moderator Administrators @Burgsteff last edited by
              aber vorher
                Skript v.2024-05-22
                *** BASE SYSTEM ***
                 Static hostname: ioBroker
                       Icon name: computer-vm
                         Chassis: vm 🖴
                  Virtualization: kvm
                          Kernel: Linux 6.1.0-23-amd64
                    Architecture: x86-64
                 Hardware Vendor: QEMU
                  Hardware Model: Standard PC _i440FX + PIIX, 1996_
                Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
                model name      : QEMU Virtual CPU version 2.5+
                Docker          : false
                Virtualization  : kvm
                Kernel          : x86_64
                Userland        : 64 bit
                Systemuptime and Load:
                 19:45:28 up 1 min,  2 users,  load average: 0.48, 0.16, 0.06
                CPU threads: 4
                *** Time and Time Zones ***
                               Local time: Sun 2024-08-25 19:45:28 CEST
                           Universal time: Sun 2024-08-25 17:45:28 UTC
                                 RTC time: Sun 2024-08-25 17:45:28
                System clock synchronized: no
                              NTP service: n/a
                          RTC in local TZ: no
                *** Users and Groups ***
                User that called 'iob diag':
                burgsteff
                HOME=/home/burgsteff
                GROUPS=burgsteff adm dialout cdrom floppy sudo audio dip video plugdev users input netdev iobroker
                iobroker
                HOME=/home/iobroker
                GROUPS=iobroker tty dialout audio video plugdev
                *** Display-Server-Setup ***
                Display-Server: false
                Desktop:
                Terminal:       tty
                Boot Target:    multi-user.target
                *** MEMORY ***
                Mem:            4.1G        1.2G        2.7G        516K        384M        2.9G
                Swap:           1.0G          0B        1.0G
                Total:          5.1G        1.2G        3.7G
                Active iob-Instances:   12
                         3914 M total memory
                         1181 M used memory
                          124 M active memory
                         1027 M inactive memory
                         2583 M free memory
                           36 M buffer memory
                          331 M swap cache
                          974 M total swap
                            0 M used swap
                          974 M free swap
                top - 19:45:28 up 1 min,  2 users,  load average: 0.48, 0.16, 0.06
                Tasks: 123 total,   1 running, 122 sleeping,   0 stopped,   0 zombie
                %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :   3914.7 total,   2583.4 free,   1181.6 used,    367.3 buff/cache
                MiB Swap:    975.0 total,    975.0 free,      0.0 used.   2733.2 avail Mem
                *** FAILED SERVICES ***
                0 loaded units listed.
                *** FILESYSTEM ***
                udev           devtmpfs  1.9G     0  1.9G   0% /dev
                tmpfs          tmpfs     392M  512K  391M   1% /run
                /dev/sda1      ext4       31G  6.5G   23G  23% /
                tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
                [Sun Aug 25 19:44:27 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
                [Sun Aug 25 19:44:27 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
                Show mounted filesystems:
                TARGET                                                  SOURCE      FSTYPE      OPTIONS
                /                                                       /dev/sda1   ext4        rw,relatime,errors=remount-ro
                |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
                | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
                | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
                | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                | |-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
                | `-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                |-/proc                                                 proc        proc        rw,nosuid,nodev,noexec,relatime
                | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=14461
                |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=1981136k,nr_inodes=495284,mode=755,inode64
                | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev,inode64
                | |-/dev/hugepages                                      hugetlbfs   hugetlbfs   rw,relatime,pagesize=2M
                | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                `-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=400872k,mode=755,inode64
                  |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
                  |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                  |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                  |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                  |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
                  |-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=400868k,nr_inodes=100217,mode=700,uid=1000,gid=1000,inode64
                  `-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                /var:
                745M    /var/
                348M    /var/cache
                343M    /var/cache/apt
                267M    /var/cache/apt/archives
                240M    /var/log
                Archived and active journals take up 224.3M in the file system.
                /opt/iobroker/backups:
                35M     /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                837M    /opt/iobroker/iobroker-data/
                748M    /opt/iobroker/iobroker-data/files
                441M    /opt/iobroker/iobroker-data/files/javascript.admin
                409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                27M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.ce422ec2.js.map
                25M     /opt/iobroker/iobroker-data/objects.jsonl
                24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js.map
                9.0M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.18496c94.js
                USB-Devices by-id:
                No Devices found 'by-id'
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v20.17.0
                /usr/bin/node           v20.17.0
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                /usr/bin/corepack       0.29.3
                nodejs:
                  Installed: 20.17.0-1nodesource1
                  Version table:
                 *** 20.17.0-1nodesource1 1001
                No problems detected
                Errors in npm tree:
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller:  6.0.9
                admin:          7.0.22
                javascript:     8.7.6
                nodejs modules from github:     2
                +-- iobroker.tibber@0.3.1-beta (git+ssh://git@github.com/Magnus8513/ioBroker.tibber.git#283b14b7fbea6bb07eb37364dfba42eb2ca71786)
                +-- iobroker.tibberconnect@0.0.10 (git+ssh://git@github.com/Codibris/ioBroker.tibberconnect.git#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83)
                Adapter State
                + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  system.adapter.backitup.0               : backitup              : ioBroker                                 - disabled
                  system.adapter.flot.0                   : flot                  : ioBroker                                 -  enabled
                  system.adapter.history.0                : history               : ioBroker                                 - disabled
                + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
                + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                + system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
                  system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
                + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                + system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
                  system.adapter.modbus.1                 : modbus                : ioBroker                                 - disabled
                + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                  system.adapter.semp.0                   : semp                  : ioBroker                                 -  enabled
                + system.adapter.tibber.0                 : tibber                : ioBroker                                 -  enabled
                  system.adapter.tibberconnect.0          : tibberconnect         : ioBroker                                 -  enabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
                + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                  system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
                  system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
                  system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
                  system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                  system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
                + system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                  system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + instance is alive
                ioBroker-Repositories
                │ (index) │ name               │ url                                                     │ auto upgrade │
                │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                Active repo(s): Stable (default)
                Upgrade policy: none
                Installed ioBroker-Instances
                Used repository: Stable (default)
                Adapter    "admin"        : 7.0.23   , installed 7.0.22 [Updatable]
                Adapter    "backitup"     : 3.0.19   , installed 3.0.16 [Updatable]
                Adapter    "hm-rega"      : 5.0.0    , installed 4.0.0  [Updatable]
                Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                Controller "js-controller": 6.0.9    , installed 6.0.9
                Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                Adapter    "semp"         : 1.4.5    , installed 1.4.5
                Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                Adapter    "ws"           : 2.6.2    , installed 2.6.2
                Objects and States
                Objects:        6488
                States:         5380
                Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 192.168.1.217:2010      0.0.0.0:*               LISTEN      1001       15000      655/io.hm-rpc.1
                tcp        0      0 192.168.1.217:2001      0.0.0.0:*               LISTEN      1001       1768       640/io.hm-rpc.0
                tcp        0      0 192.168.1.217:9292      0.0.0.0:*               LISTEN      1001       1783       670/io.hm-rpc.2
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14816      501/iobroker.js-con
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14811      501/iobroker.js-con
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13729      1/init
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14797      515/sshd: /usr/sbin
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17224      544/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16008      841/io.web.0
                tcp6       0      0 :::9765                 :::*                    LISTEN      1001       17623      872/io.semp.0
                tcp6       0      0 :::111                  :::*                    LISTEN      0          934        1/init
                tcp6       0      0 :::22                   :::*                    LISTEN      0          14799      515/sshd: /usr/sbin
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       17625      872/io.semp.0
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14757      417/dhclient
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1311       1/init
                udp6       0      0 :::111                  :::*                                0          1312       1/init
                2024-08-25 19:44:58.750  - info: mqtt.0 (685) Try to connect to mqtt://192.168.1.216:1883 with clientId=ioBroker.mqtt.0
                2024-08-25 19:44:58.811  - info: mqtt.0 (685) Connected to 192.168.1.216
                2024-08-25 19:44:58.812  - info: mqtt.0 (685) Subscribe on "#"
                2024-08-25 19:45:01.141  - info: host.ioBroker instance system.adapter.modbus.0 in version "6.2.3" started with pid 703
                2024-08-25 19:45:02.310  - info: modbus.0 (703) starting. Version 6.2.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v20.17.0, js-controller: 6.0.9
                2024-08-25 19:45:02.813  - info: modbus.0 (703) Connected to slave 192.168.1.236
                2024-08-25 19:45:04.449  - info: hm-rpc.2 (670) Connected
                2024-08-25 19:45:05.149  - info: host.ioBroker instance system.adapter.tibber.0 in version "0.3.1-beta" (non-npm: Magnus8513/ioBroker.tibber#283b14b7fbea6bb07eb37364dfba42eb2ca71786) started with pid 718
                2024-08-25 19:45:06.519  - info: tibber.0 (718) starting. Version 0.3.1-beta (non-npm: Magnus8513/ioBroker.tibber#283b14b7fbea6bb07eb37364dfba42eb2ca71786) in /opt/iobroker/node_modules/iobroker.tibber, node: v20.17.0, js-controller: 6.0.9
                2024-08-25 19:45:06.894  - info: tibber.0 (718) Tibber refresh success
                2024-08-25 19:45:09.217  - info: host.ioBroker instance system.adapter.vis-inventwo.0 in version "3.3.4" started with pid 772
                2024-08-25 19:45:10.533  - info: vis-inventwo.0 (772) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v20.17.0, js-controller: 6.0.9
                2024-08-25 19:45:14.459  - info: vis.0 (801) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.17.0, js-controller: 6.0.9
                2024-08-25 19:45:15.948  - info: vis.0 (801) Terminated (NO_ERROR): Without reason
                2024-08-25 19:45:16.563  - info: host.ioBroker instance system.adapter.vis.0 terminated while should be started once
                2024-08-25 19:45:17.198  - info: host.ioBroker instance system.adapter.web.0 in version "6.2.5" started with pid 841
                2024-08-25 19:45:18.951  - info: web.0 (841) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.9
                2024-08-25 19:45:19.078  - info: web.0 (841) socket.io server listening on port 8082
                2024-08-25 19:45:19.084  - info: web.0 (841) http server listening on port 8082
                2024-08-25 19:45:21.172  - info: host.ioBroker instance system.adapter.tibberconnect.0 in version "0.0.10" (non-npm: Codibris/ioBroker.tibberconnect#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83) started with pid 857
                2024-08-25 19:45:25.193  - info: host.ioBroker instance system.adapter.semp.0 in version "1.4.5" started with pid 872
                2024-08-25 19:45:26.860  - info: semp.0 (872) starting. Version 1.4.5 in /opt/iobroker/node_modules/iobroker.semp, node: v20.17.0, js-controller: 6.0.9
                2024-08-25 19:45:26.898  - error: semp.0 (872) Lambda wrong device SerialNr
                2024-08-25 19:45:26.900  - info: semp.0 (872) device created F-12287760-000000000001-00 Lambda
                2024-08-25 19:45:29.921  - info: semp.0 (872) adapter discovered by SHM
                @Homoran Habe ich davor neu gestartet, danke für den Hinweis.
                  Homoran Global Moderator Administrators @Burgsteff last edited by Homoran
                  usr/bin/npm 10.8.2
                  da isses ja!
                  dann müsstest du jetzt die fehlenden Updates machen können.
                    Meeeeeeega, jetzt passt das wieder.
                    Vielen herzlichen Dank 👏 👏 👏
                    Was kann man euch Gutes tun?
                      @burgsteff
                      Gut, der ioBroker rennt wohl wieder.
                      cat /etc/profile
                      sagt?
                        burgsteff@ioBroker:~$ cat /etc/profile
                        # /etc/profile: system-wide .profile file for the Bourne shell (sh(1))
                        # and Bourne compatible shells (bash(1), ksh(1), ash(1), ...).
                        if [ "$(id -u)" -eq 0 ]; then
                          PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
                        else
                          PATH="/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games"
                        fi
                        export PATH
                        if [ "${PS1-}" ]; then
                          if [ "${BASH-}" ] && [ "$BASH" != "/bin/sh" ]; then
                            # The file bash.bashrc already sets the default PS1.
                            # PS1='\h:\w\$ '
                            if [ -f /etc/bash.bashrc ]; then
                              . /etc/bash.bashrc
                            fi
                          else
                              PS1='# '
                            else
                              PS1='$ '
                            fi
                          fi
                        fi
                        if [ -d /etc/profile.d ]; then
                          for i in /etc/profile.d/*.sh; do
                            if [ -r $i ]; then
                              . $i
                            fi
                          done
                          unset i
                        fi
                          @burgsteff
                          Das passt eigentlich. Lass es so.
                            Dann ist ja gut, perfekt.
                            Wirklich echt vielen Dank für die schnelle, kompetente und freundliche Hilfe.
                              @burgsteff
                              Trag mal in der Zeile 8 das ein:
                              PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games"
                                wie bzw. wo in Zeile 8?
                                  @burgsteff
                                  sudo nano /etc/profile
                                  Und dann statt
                                  da
                                  eintragen.
                                  Mit STRG-O und STRG-X speichern und den Editor verlassen.
                                    ok, hab ich gemacht. und nun?
                                      @burgsteff
                                      Starte den Container mal neu.
                                      Danach sollte dann auch bei
                                      type -P usermod
                                      der Pfad zurückgemeldet werden. Also so:
                                      echad@chet:~ $ type -P usermod
                                      /usr/sbin/usermod
                                      echad@chet:~ $
                                        else
                                        fi
                                        export PATH
                                            # PS1='\h:\w\$ '
                                              . /etc/bash.bashrc
                                            fi
                                          else
                                              PS1='# '
                                            else
                                              PS1='$ '
                                            fi
                                          fi
                                        fi
                                            if [ -r $i ]; then
                                              . $i
                                            fi
                                          done
                                          unset i
                                        fi
                                        so oder?
                                          @burgsteff
                                          Ja.
                                            burgsteff@ioBroker:~$ type -P usermod
                                            /usr/sbin/usermod
                                            passt oder?
                                            4576
