    4. ioBroker update führt zu GLIBCXX_3.4.26-Problem - GELÖST!
      Homoran Global Moderator Administrators @ioTechnik last edited by
      @iotechnik konntest du denn inzwischen die Langfassung von iob diag bekommen?
        Thomas Braun Most Active @ioTechnik last edited by
        @iotechnik sagte in ioBroker update führt zu GLIBCXX_3.4.26-Problem - GELÖST!:
        Bleibt wohl nur die Neuinstallation.
        Die musst du eh machen.
        • I
          ioTechnik @Homoran last edited by
          Die Langfassung hatte ich, konnte sie aber nicht hochladen. Ich probiers gleich noch mal.
          • I
            Hier iob diag
            Skript v.2024-05-22
            *** BASE SYSTEM ***
               Static hostname: raspibroker
                     Icon name: computer
              Operating System: Raspbian GNU/Linux 10 (buster)
                        Kernel: Linux 5.10.103-v7+
                  Architecture: arm
            Model           : Raspberry Pi 3 Model B Rev 1.2
            Docker          : false
            Virtualization  : none
            Kernel          : armv7l
            Userland        : 32 bit
            Systemuptime and Load:
             13:10:30 up  9:10,  1 user,  load average: 0.61, 0.42, 0.28
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            ~ Under-voltage detected
            ~ Arm frequency capped
            Previously detected issues:
            ~ Under-voltage has occurred
            ~ Arm frequency capping has occurred
            *** Time and Time Zones ***
                           Local time: Wed 2024-08-21 13:10:30 CEST
                       Universal time: Wed 2024-08-21 11:10:30 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            pi
            HOME=/home/pi
            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
            js-controller is not running
            *** Display-Server-Setup ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            Boot Target:    multi-user.target
            *** MEMORY ***
            Mem:           972M         43M        305M        3.0M        624M        862M
            Swap:           99M        4.0M         95M
            Total:         1.1G         47M        400M
            Active iob-Instances:   0
                      972 M total memory
                       43 M used memory
                      292 M active memory
                      273 M inactive memory
                      305 M free memory
                      199 M buffer memory
                      424 M swap cache
                       99 M total swap
                        4 M used swap
                       95 M free swap
            top - 13:10:30 up  9:10,  1 user,  load average: 0.61, 0.42, 0.28
            Tasks: 116 total,   1 running, 115 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  3.9 us,  2.6 sy,  0.0 ni, 93.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :    972.8 total,    305.2 free,     43.5 used,    624.1 buff/cache
            MiB Swap:    100.0 total,     95.7 free,      4.3 used.    862.2 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed. Pass --all to see loaded but inactive units, too.
            To show all installed unit files use 'systemctl list-unit-files'.
            *** FILESYSTEM ***
            /dev/root      ext4      7.1G  5.7G  1.1G  85% /
            devtmpfs       devtmpfs  454M     0  454M   0% /dev
            tmpfs          tmpfs     487M     0  487M   0% /dev/shm
            tmpfs          tmpfs     487M  6.6M  480M   2% /run
            tmpfs          tmpfs     487M     0  487M   0% /sys/fs/cgroup
            /dev/sda1      vfat      247M   49M  198M  20% /boot
            tmpfs          tmpfs      98M     0   98M   0% /run/user/1000
            [Wed Aug 21 04:00:28 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=32e689ec-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Wed Aug 21 04:00:34 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
            [Wed Aug 21 04:00:34 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
            [Wed Aug 21 04:00:36 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
            Show mounted filesystems:
            TARGET                                SOURCE     FSTYPE     OPTIONS
            /                                     /dev/sda2  ext4       rw,noatime
            |-/dev                                devtmpfs   devtmpfs   rw,relatime,size=464768k,nr_inodes=116192,mode=755
            | |-/dev/shm                          tmpfs      tmpfs      rw,nosuid,nodev
            | |-/dev/pts                          devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
            | `-/dev/mqueue                       mqueue     mqueue     rw,relatime
            |-/sys                                sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
            | |-/sys/kernel/security              securityfs securityfs rw,nosuid,nodev,noexec,relatime
            | |-/sys/fs/cgroup                    tmpfs      tmpfs      ro,nosuid,nodev,noexec,mode=755
            | | |-/sys/fs/cgroup/unified          cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
            | | |-/sys/fs/cgroup/systemd          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
            | | |-/sys/fs/cgroup/cpuset           cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
            | | |-/sys/fs/cgroup/perf_event       cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
            | | |-/sys/fs/cgroup/blkio            cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,blkio
            | | |-/sys/fs/cgroup/net_cls,net_prio cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
            | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
            | | |-/sys/fs/cgroup/freezer          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,freezer
            | | |-/sys/fs/cgroup/devices          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,devices
            | | `-/sys/fs/cgroup/pids             cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,pids
            | |-/sys/fs/bpf                       none       bpf        rw,nosuid,nodev,noexec,relatime,mode=700
            | |-/sys/kernel/debug                 debugfs    debugfs    rw,relatime
            | |-/sys/kernel/config                configfs   configfs   rw,relatime
            | `-/sys/fs/fuse/connections          fusectl    fusectl    rw,relatime
            |-/proc                               proc       proc       rw,relatime
            | `-/proc/sys/fs/binfmt_misc          systemd-1  autofs     rw,relatime,fd=26,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
            |-/run                                tmpfs      tmpfs      rw,nosuid,nodev,mode=755
            | |-/run/lock                         tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
            | |-/run/rpc_pipefs                   sunrpc     rpc_pipefs rw,relatime
            | `-/run/user/1000                    tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=99608k,mode=700,uid=1000,gid=1000
            `-/boot                               /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            300M    /var/
            94M     /var/lib
            85M     /var/cache
            78M     /var/cache/apt
            69M     /var/lib/apt/lists
            Archived and active journals take up 6.0M in the file system.
            /opt/iobroker/backups:
            1.3M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            908M    /opt/iobroker/iobroker-data/
            658M    /opt/iobroker/iobroker-data/files
            441M    /opt/iobroker/iobroker-data/files/javascript.admin
            409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
            27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
            13M     /opt/iobroker/iobroker-data/objects.jsonl
            9.9M    /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js
            9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
            USB-Devices by-id:
            No Devices found 'by-id'
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v10.24.0
            /usr/bin/node           v10.24.0
            npm:                    N/A
            npx:                    N/A
            corepack:       N/A
            *** nodejs is NOT correctly installed ***
            nodejs:
              Installed: 10.24.0~dfsg-1~deb10u3
              Candidate: 10.24.0~dfsg-1~deb10u3
              Version table:
             *** 10.24.0~dfsg-1~deb10u3 500
                    100 /var/lib/dpkg/status
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            (node:6853) UnhandledPromiseRejectionWarning: Error: Not supported
                at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:1)
                at Module._compile (internal/modules/cjs/loader.js:778:30)
                at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                at Module.load (internal/modules/cjs/loader.js:653:32)
                at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                at startup (internal/bootstrap/node.js:283:19)
                at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
            (node:6853) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
            (node:6853) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
            Core adapters versions
            (node:6863) UnhandledPromiseRejectionWarning: Error: Not supported
            (node:6863) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
            (node:6863) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
            js-controller:
            (node:6872) UnhandledPromiseRejectionWarning: Error: Not supported
            (node:6872) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
            (node:6872) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
            admin:
            (node:6881) UnhandledPromiseRejectionWarning: Error: Not supported
            (node:6881) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
            (node:6881) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
            javascript:
            nodejs modules from github:     0
            Adapter State
            ioBroker-Repositories
            (node:6898) UnhandledPromiseRejectionWarning: Error: Not supported
            (node:6898) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
            (node:6898) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
            Installed ioBroker-Instances
            (node:6907) UnhandledPromiseRejectionWarning: Error: Not supported
            (node:6907) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
            (node:6907) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
            Objects and States
            Objects:        0
            States:         0
            W: GPG error: https://deb.nodesource.com/node_18.x nodistro InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
            E: The repository 'https://deb.nodesource.com/node_18.x nodistro InRelease' is not signed.
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14266      678/sshd
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          17461      971/exim4
            tcp6       0      0 :::22                   :::*                    LISTEN      0          14268      678/sshd
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          17462      971/exim4
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14851      625/dhcpcd
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13707      385/avahi-daemon: r
            udp        0      0 0.0.0.0:60864           0.0.0.0:*                           108        13709      385/avahi-daemon: r
            udp6       0      0 :::45260                :::*                                108        13710      385/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        13708      385/avahi-daemon: r
            udp6       0      0 :::546                  :::*                                0          16690      625/dhcpcd
            2024-08-20 09:12:38.956  - info: host.raspibroker stopInstance timeout system.adapter.admin.1 killing pid 800
            2024-08-20 09:12:38.959  - info: host.raspibroker stopInstance timeout system.adapter.javascript.0 killing pid 807
            2024-08-20 09:12:38.960  - info: host.raspibroker stopInstance timeout system.adapter.backitup.0 killing pid 853
            2024-08-20 09:12:38.961  - info: host.raspibroker stopInstance timeout system.adapter.tr-064.0 killing pid 859
            2024-08-20 09:12:38.961  - info: host.raspibroker stopInstance timeout system.adapter.ems-esp.0 killing pid 900
            2024-08-20 09:12:38.962  - info: host.raspibroker stopInstance timeout system.adapter.hm-rega.0 killing pid 932
            2024-08-20 09:12:38.964  - info: host.raspibroker stopInstance timeout system.adapter.web.0 killing pid 1138
            2024-08-20 09:12:39.162  - info: host.raspibroker instance system.adapter.sourceanalytix.0 terminated with code 0 (NO_ERROR)
            2024-08-20 09:12:39.164  - info: host.raspibroker instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
            2024-08-20 09:12:39.166  - info: host.raspibroker instance system.adapter.vis-inventwo.0 terminated with code 0 (NO_ERROR)
            2024-08-20 09:12:40.639  - info: host.raspibroker instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
            2024-08-20 09:12:40.641  - info: host.raspibroker instance system.adapter.tankerkoenig.0 terminated with code 0 (NO_ERROR)
            2024-08-20 09:12:40.642  - info: host.raspibroker instance system.adapter.pollenflug.0 terminated with code 0 (NO_ERROR)
            2024-08-20 09:12:40.686  - info: host.raspibroker instance system.adapter.admin.1 terminated with code 0 (NO_ERROR)
            2024-08-20 09:12:40.864  - info: host.raspibroker instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
            2024-08-20 09:12:40.866  - info: host.raspibroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
            2024-08-20 09:12:40.867  - info: host.raspibroker instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
            2024-08-20 09:12:40.868  - info: host.raspibroker instance system.adapter.ems-esp.0 terminated with code 0 (NO_ERROR)
            2024-08-20 09:12:40.869  - warn: host.raspibroker instance system.adapter.hm-rega.0 terminated due to SIGKILL
            2024-08-20 09:12:40.870  - info: host.raspibroker instance system.adapter.hm-rega.0 terminated with code null ()
            2024-08-20 09:12:40.871  - warn: host.raspibroker instance system.adapter.web.0 terminated due to SIGKILL
            2024-08-20 09:12:40.871  - info: host.raspibroker instance system.adapter.web.0 terminated with code null ()
            2024-08-20 09:12:41.153  - info: host.raspibroker instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
            2024-08-20 09:12:41.155  - info: host.raspibroker All instances are stopped.
            2024-08-20 09:12:41.396  - info: host.raspibroker terminated
            iob diag has finished.
              Homoran Global Moderator Administrators @ioTechnik last edited by Homoran
              nach wie vor!!
              und mit
              wird das auch nichts.
              Hattest du nicht iob fix gefahren?
              und danach iob nodejs-update?
              kann natürlich am vergammelten
              liegen.
              Da das ganz aus xem Support raus ist, könnte es sein, dasss da gar kein update mehr möglich ist.
                @iotechnik
                Noch ein paar Hinweise:
                Setz das neue System als reines 64Bit-System auf.
                Spendier der Kiste ein gescheites, richtiges Netzteil. Die jetzige Spannungsversorgung ist zu schlapp.
                Mit
                kannst du auch gar nichts mehr reißen. Mit der dfsg-Version schon gerade nicht.
                Versuch das mal mit der Betaversion von hier zu beackern. :
                https://forum.iobroker.net/topic/68035/iob-node-fix-skript
                Aufruf des Skriptes dann per
                ./iob_node_update 18
                • I
                  Hallo Thomas
                  habe das System neu aufgesetzt (64bit). Das mit dem Netzteil ist auch OK - es lag am USB-Kabel - habe jetzt direkt verkabelt.
                  Bin dabei die Adapter zu aktualisieren - leider lassen sich einige nicht über die Adapteroberfläche aktualisieren.
                  Es scheitert momentan beim web-Adapter
                  $ iobroker upgrade web@6.2.5
                  Update web from @6.2.3 to @6.2.5
                  NPM version: 10.8.2
                  Installing iobroker.web@6.2.5... (System call)
                  Could not handle ENOTEMPTY, because no deletable files were foundnpm error code ENOTEMPTYnpm error syscall renamenpm error path /opt/iobroker/node_modules/aggregate-errornpm error dest /opt/iobroker/node_modules/.aggregate-error-rAKexGiKnpm error errno -39npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/aggregate-error' -> '/opt/iobroker/node_modules/.aggregate-error-rAKexGiK'npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-23T14_35_28_536Z-debug-0.log
                  host.raspberrypi Cannot install iobroker.web@6.2.5: 217
                  ERROR: Process exited with code 25
                  ebenso beim backitup-Adapter. Habe diesen schon neu installiert - ohne Erfolg
                    @iotechnik
                    iob stop
                    iob fix
                    iob start
                    try again!
                    • I
                      Hallo Thomas, Hallo Homoran
                      nach der Neuinstallation und dem Durchlauf der angebotenen Updates läuft der admin nicht mehr.
                      Ich komme nicht mehr auf meinen Pi3. Verschiedene Hinweise aus dem Forum brachten auch keinen Erfolg.
                      Hier iob diag
                      *** iob diag is starting up, please wait ***
                      The state system.host.raspberrypi.versions.nodeNewestNext was not found!
                      The state system.host.raspberrypi.versions.npmNewestNext was not found!
                      The state system.host.raspberrypi.versions.nodeCurrent was not found!
                      Skript v.2024-05-22
                      *** BASE SYSTEM ***
                       Static hostname: raspberrypi
                             Icon name: computer
                                Kernel: Linux 6.6.31+rpt-rpi-v8
                          Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                       09:04:41 up  2:42,  3 users,  load average: 2.06, 1.49, 1.10
                      CPU threads: 4
                      Current issues:
                                     Local time: Mon 2024-08-26 09:04:41 CEST
                                 Universal time: Mon 2024-08-26 07:04:41 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      HOME=/home/pi
                      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                      iobroker
                      HOME=/home/iobroker
                      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            951M        747M         93M         28K        167M        204M
                      Swap:           209M        206M        3.2M
                      Total:          1.2G        953M         96M
                      Active iob-Instances:   11
                                907 M total memory
                                712 M used memory
                                378 M active memory
                                351 M inactive memory
                                 88 M free memory
                                 18 M buffer memory
                                140 M swap cache
                                199 M total swap
                                196 M used swap
                                  3 M free swap
                      top - 09:04:42 up  2:42,  3 users,  load average: 2.05, 1.49, 1.11
                      Tasks: 167 total,   1 running, 166 sleeping,   0 stopped,   0 zombie
                      %Cpu(s): 11.1 us, 22.2 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :    907.3 total,     88.9 free,    712.3 used,    159.8 buff/cache
                      MiB Swap:    200.0 total,      3.1 free,    196.9 used.    195.0 avail Mem
                      *** FILESYSTEM ***
                      udev           devtmpfs  318M     0  318M   0% /dev
                      tmpfs          tmpfs      91M  1.1M   90M   2% /run
                      /dev/sda2      ext4      6.8G  5.1G  1.4G  79% /
                      tmpfs          tmpfs     454M     0  454M   0% /dev/shm
                      tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
                      /dev/sda1      vfat      510M   64M  447M  13% /boot/firmware
                      tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                      [Mon Aug 26 06:22:24 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c80d8e3a-02 rootfstype=ext4 fsck.repair=yes rootwait
                      [Mon Aug 26 06:22:31 2024] EXT4-fs (sda2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                      [Mon Aug 26 06:22:34 2024] EXT4-fs (sda2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
                      | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                      | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
                      | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                      | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                      | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                      | |-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                      | `-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
                      | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=2867
                      |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                      |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=325396k,nr_inodes=81349,mode=755
                      | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                      |-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=92912k,mode=755
                      | |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                      | |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                      | `-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=92908k,nr_inodes=23227,mode=700,uid=1000,gid=1000
                      `-/boot/firmware                                        /dev/sda1   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      /var:
                      1.1G    /var/
                      356M    /var/log
                      355M    /var/log/journal/6dc99cd23c35495a81d44ed7c87f33e1
                      349M    /var/cache
                      Archived and active journals take up 354.9M in the file system.
                      25M     /opt/iobroker/backups/
                      457M    /opt/iobroker/iobroker-data/
                      431M    /opt/iobroker/iobroker-data/files
                      142M    /opt/iobroker/iobroker-data/files/vis-2
                      81M     /opt/iobroker/iobroker-data/files/vis-2/static
                      80M     /opt/iobroker/iobroker-data/files/vis-2/static/js
                      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                      19M     /opt/iobroker/iobroker-data/objects.jsonl
                      19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
                      USB-Devices by-id:
                      /usr/bin/nodejs         v20.17.0
                      /usr/bin/node           v20.17.0
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      /usr/bin/corepack       0.29.3
                      nodejs:
                        Installed: 20.17.0-1nodesource1
                        Candidate: 20.17.0-1nodesource1
                        Version table:
                       *** 20.17.0-1nodesource1 1001
                              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                           20.16.0-1nodesource1 1001
                           20.15.1-1nodesource1 1001
                           20.15.0-1nodesource1 1001
                           20.14.0-1nodesource1 1001
                           20.13.1-1nodesource1 1001
                           20.13.0-1nodesource1 1001
                           20.12.2-1nodesource1 1001
                           20.12.1-1nodesource1 1001
                           20.12.0-1nodesource1 1001
                           20.11.1-1nodesource1 1001
                           20.11.0-1nodesource1 1001
                           20.10.0-1nodesource1 1001
                           20.9.0-1nodesource1 1001
                           20.8.1-1nodesource1 1001
                           20.8.0-1nodesource1 1001
                           20.7.0-1nodesource1 1001
                           20.6.1-1nodesource1 1001
                           20.6.0-1nodesource1 1001
                           20.5.1-1nodesource1 1001
                           20.5.0-1nodesource1 1001
                           20.4.0-1nodesource1 1001
                           20.3.1-1nodesource1 1001
                           20.3.0-1nodesource1 1001
                           20.2.0-1nodesource1 1001
                           20.1.0-1nodesource1 1001
                           20.0.0-1nodesource1 1001
                           18.19.0+dfsg-6~deb12u2 500
                           18.19.0+dfsg-6~deb12u1 500
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      js-controller:  6.0.9
                      admin:          7.0.23
                      javascript:     7.8.0
                      Adapter State
                        system.adapter.admin.1                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                        system.adapter.awattar.0                : awattar               : raspberrypi                              - disabled
                      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                      + system.adapter.ems-esp.0                : ems-esp               : raspberrypi                              -  enabled
                        system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
                        system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              - disabled
                      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                        system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                        system.adapter.material.0               : material              : raspberrypi                              - disabled
                      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                        system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              - disabled
                        system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              - disabled
                      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                        system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
                        system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
                        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
                      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + instance is alive
                      Active repo(s): stable
                      Upgrade policy: none
                      Used repository: stable
                      Adapter    "admin"        : 7.0.23   , installed 7.0.23
                      Adapter    "awattar"      : 1.0.6    , installed 1.0.6
                      Adapter    "backitup"     : 3.0.19   , installed 3.0.19
                      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                      Adapter    "ems-esp"      : 3.5.0    , installed 3.5.0
                      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
                      Adapter    "hm-rega"      : 5.0.0    , installed 4.0.0  [Updatable]
                      Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                      Adapter    "javascript"   : 8.7.6    , installed 7.8.0  [Updatable]
                      Controller "js-controller": 6.0.9    , installed 6.0.9
                      Adapter    "material"     : 1.3.1    , installed 1.3.1
                      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
                      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                      Adapter    "ws"           : 2.6.2    , installed 2.6.2
                      Objects and States
                      Objects:        6117
                      States:         5526
                      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Reading package lists...
                      Pending Updates: 0
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       5841       969/io.mqtt.0
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6367       619/iobroker.js-con
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6362       619/iobroker.js-con
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          826        647/sshd: /usr/sbin
                      tcp        0      0 192.168.2.16:2001       0.0.0.0:*               LISTEN      1001       6665       962/io.hm-rpc.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8706       1152/io.web.0
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          828        647/sshd: /usr/sbin
                      udp        0      0 0.0.0.0:52009           0.0.0.0:*                           104        712        498/avahi-daemon: r
                      udp        0      0 192.168.2.16:5353       0.0.0.0:*                           1001       6016       984/io.tr-064.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        710        498/avahi-daemon: r
                      udp6       0      0 :::57842                :::*                                104        713        498/avahi-daemon: r
                      udp6       0      0 fe80::aa28:f59d:ff7:546 :::*                                0          6357       565/NetworkManager
                      udp6       0      0 :::5353                 :::*                                104        711        498/avahi-daemon: r
                      2024-08-26 07:24:53.890  - info: weatherunderground.0 (2135) Terminated (NO_ERROR): Without reason
                      2024-08-26 07:24:54.485  - info: host.raspberrypi instance system.adapter.weatherunderground.0 having pid 2135 terminated with code 0 (NO_ERROR)
                      2024-08-26 07:30:48.064  - info: host.raspberrypi instance system.adapter.dwd.0 in version "2.8.5" started with pid 2156
                      2024-08-26 07:30:53.116  - info: dwd.0 (2156) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.17.0, js-controller: 6.0.9
                      2024-08-26 07:30:54.762  - info: dwd.0 (2156) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2024-08-26 07:30:55.325  - info: host.raspberrypi instance system.adapter.dwd.0 having pid 2156 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2024-08-26 07:59:50.814  - info: host.raspberrypi "system.adapter.weatherunderground.0" disabled
                      2024-08-26 07:59:50.823  - info: host.raspberrypi stopInstance system.adapter.weatherunderground.0 (force=false, process=false)
                      2024-08-26 07:59:50.825  - info: host.raspberrypi stopInstance canceled schedule system.adapter.weatherunderground.0
                      2024-08-26 08:00:48.124  - info: host.raspberrypi instance system.adapter.dwd.0 in version "2.8.5" started with pid 2347
                      2024-08-26 08:00:53.234  - info: dwd.0 (2347) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.17.0, js-controller: 6.0.9
                      2024-08-26 08:00:54.878  - info: dwd.0 (2347) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2024-08-26 08:00:55.449  - info: host.raspberrypi instance system.adapter.dwd.0 having pid 2347 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2024-08-26 08:24:54.735  - info: web.0 (1152) ==> Connected system.user.admin from ::ffff:192.168.2.21
                      2024-08-26 08:25:08.352  - info: web.0 (1152) <== Disconnect system.user.admin from ::ffff:192.168.2.21 vis.0
                      2024-08-26 08:25:08.595  - info: web.0 (1152) ==> Connected system.user.admin from ::ffff:192.168.2.21
                      2024-08-26 08:30:48.086  - info: host.raspberrypi instance system.adapter.dwd.0 in version "2.8.5" started with pid 2498
                      2024-08-26 08:30:54.414  - info: dwd.0 (2498) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.17.0, js-controller: 6.0.9
                      2024-08-26 08:30:56.287  - info: dwd.0 (2498) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2024-08-26 08:30:56.927  - info: host.raspberrypi instance system.adapter.dwd.0 having pid 2498 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2024-08-26 09:00:48.156  - info: host.raspberrypi instance system.adapter.dwd.0 in version "2.8.5" started with pid 3776
                      2024-08-26 09:00:56.331  - info: dwd.0 (3776) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.17.0, js-controller: 6.0.9
                      2024-08-26 09:00:58.375  - info: dwd.0 (3776) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2024-08-26 09:00:58.947  - info: host.raspberrypi instance system.adapter.dwd.0 having pid 3776 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        Thomas Braun Most Active @ioTechnik last edited by Thomas Braun
                        @iotechnik
                        Hat zwar mit dem ursprünglichen Thema nix mehr zu tun, aber starte den Admin mal.
                        iob start admin.1
                        Edit: Wenn ich mir die jetzige Auslastung anschaue und was da alles an Adaptern noch gar nicht gestartet ist würde ich sagen: Raspi3 mehr als ausgereizt.
                        • I
                          ioTechnik @Thomas Braun last edited by
                          Danke Thomas und Homoran. Habe mir sowas schon gedacht. Die Adapter werden wie bei Windows-updates o.ä. immer größer und der RAM reicht dann nicht mehr.
                          Ich habe hier einen alten Laptop 64-bit mit Linux vorbereitet und werde versuchen mein System dahin umzusiedeln.
                            1GB ist halt auch nicht so wirklich üppig.
                            Mittlerweile würde ich mindestens 4GB veranschlagen, wenn da eine durchschnittliche Installation laufen soll.
                              aber >20Adapter hat noch nie mit 1GB RAM funktioniert. auch nicht vor 5-10 Jahren
                              Seit Beginn wurde schon immer empfohlen mind. 2GB RAM zu verwenden (noch mehr war damals fast nicht zu bekommen)
                              10301
