    4. ioBroker update führt zu GLIBCXX_3.4.26-Problem - GELÖST!
    • I
      ioTechnik @Homoran last edited by
      Die Langfassung hatte ich, konnte sie aber nicht hochladen. Ich probiers gleich noch mal.
      • I
        ioTechnik last edited by
        Hier iob diag
        Skript v.2024-05-22
        *** BASE SYSTEM ***
           Static hostname: raspibroker
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 10 (buster)
                    Kernel: Linux 5.10.103-v7+
              Architecture: arm
        Model           : Raspberry Pi 3 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : 32 bit
        Systemuptime and Load:
         13:10:30 up  9:10,  1 user,  load average: 0.61, 0.42, 0.28
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        ~ Under-voltage detected
        ~ Arm frequency capped
        Previously detected issues:
        ~ Under-voltage has occurred
        ~ Arm frequency capping has occurred
        *** Time and Time Zones ***
                       Local time: Wed 2024-08-21 13:10:30 CEST
                   Universal time: Wed 2024-08-21 11:10:30 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        js-controller is not running
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:           972M         43M        305M        3.0M        624M        862M
        Swap:           99M        4.0M         95M
        Total:         1.1G         47M        400M
        Active iob-Instances:   0
                  972 M total memory
                   43 M used memory
                  292 M active memory
                  273 M inactive memory
                  305 M free memory
                  199 M buffer memory
                  424 M swap cache
                   99 M total swap
                    4 M used swap
                   95 M free swap
        top - 13:10:30 up  9:10,  1 user,  load average: 0.61, 0.42, 0.28
        Tasks: 116 total,   1 running, 115 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  3.9 us,  2.6 sy,  0.0 ni, 93.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :    972.8 total,    305.2 free,     43.5 used,    624.1 buff/cache
        MiB Swap:    100.0 total,     95.7 free,      4.3 used.    862.2 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed. Pass --all to see loaded but inactive units, too.
        To show all installed unit files use 'systemctl list-unit-files'.
        *** FILESYSTEM ***
        /dev/root      ext4      7.1G  5.7G  1.1G  85% /
        devtmpfs       devtmpfs  454M     0  454M   0% /dev
        tmpfs          tmpfs     487M     0  487M   0% /dev/shm
        tmpfs          tmpfs     487M  6.6M  480M   2% /run
        tmpfs          tmpfs     487M     0  487M   0% /sys/fs/cgroup
        /dev/sda1      vfat      247M   49M  198M  20% /boot
        tmpfs          tmpfs      98M     0   98M   0% /run/user/1000
        [Wed Aug 21 04:00:28 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=32e689ec-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Wed Aug 21 04:00:34 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
        [Wed Aug 21 04:00:34 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Wed Aug 21 04:00:36 2024] EXT4-fs (sda2): re-mounted. Opts: (null)
        Show mounted filesystems:
        TARGET                                SOURCE     FSTYPE     OPTIONS
        /                                     /dev/sda2  ext4       rw,noatime
        |-/dev                                devtmpfs   devtmpfs   rw,relatime,size=464768k,nr_inodes=116192,mode=755
        | |-/dev/shm                          tmpfs      tmpfs      rw,nosuid,nodev
        | |-/dev/pts                          devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | `-/dev/mqueue                       mqueue     mqueue     rw,relatime
        |-/sys                                sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security              securityfs securityfs rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup                    tmpfs      tmpfs      ro,nosuid,nodev,noexec,mode=755
        | | |-/sys/fs/cgroup/unified          cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate
        | | |-/sys/fs/cgroup/systemd          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
        | | |-/sys/fs/cgroup/cpuset           cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpuset
        | | |-/sys/fs/cgroup/perf_event       cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,perf_event
        | | |-/sys/fs/cgroup/blkio            cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,blkio
        | | |-/sys/fs/cgroup/net_cls,net_prio cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
        | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
        | | |-/sys/fs/cgroup/freezer          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,freezer
        | | |-/sys/fs/cgroup/devices          cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,devices
        | | `-/sys/fs/cgroup/pids             cgroup     cgroup     rw,nosuid,nodev,noexec,relatime,pids
        | |-/sys/fs/bpf                       none       bpf        rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/debug                 debugfs    debugfs    rw,relatime
        | |-/sys/kernel/config                configfs   configfs   rw,relatime
        | `-/sys/fs/fuse/connections          fusectl    fusectl    rw,relatime
        |-/proc                               proc       proc       rw,relatime
        | `-/proc/sys/fs/binfmt_misc          systemd-1  autofs     rw,relatime,fd=26,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
        |-/run                                tmpfs      tmpfs      rw,nosuid,nodev,mode=755
        | |-/run/lock                         tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/rpc_pipefs                   sunrpc     rpc_pipefs rw,relatime
        | `-/run/user/1000                    tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=99608k,mode=700,uid=1000,gid=1000
        `-/boot                               /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        300M    /var/
        94M     /var/lib
        85M     /var/cache
        78M     /var/cache/apt
        69M     /var/lib/apt/lists
        Archived and active journals take up 6.0M in the file system.
        /opt/iobroker/backups:
        1.3M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        908M    /opt/iobroker/iobroker-data/
        658M    /opt/iobroker/iobroker-data/files
        441M    /opt/iobroker/iobroker-data/files/javascript.admin
        409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
        13M     /opt/iobroker/iobroker-data/objects.jsonl
        9.9M    /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js
        9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v10.24.0
        /usr/bin/node           v10.24.0
        npm:                    N/A
        npx:                    N/A
        corepack:       N/A
        *** nodejs is NOT correctly installed ***
        nodejs:
          Installed: 10.24.0~dfsg-1~deb10u3
          Candidate: 10.24.0~dfsg-1~deb10u3
          Version table:
         *** 10.24.0~dfsg-1~deb10u3 500
                100 /var/lib/dpkg/status
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        (node:6853) UnhandledPromiseRejectionWarning: Error: Not supported
            at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:1)
            at Module._compile (internal/modules/cjs/loader.js:778:30)
            at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
            at Module.load (internal/modules/cjs/loader.js:653:32)
            at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
            at Function.Module._load (internal/modules/cjs/loader.js:585:3)
            at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
            at startup (internal/bootstrap/node.js:283:19)
            at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
        (node:6853) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
        (node:6853) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
        Core adapters versions
        (node:6863) UnhandledPromiseRejectionWarning: Error: Not supported
        (node:6863) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
        (node:6863) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
        js-controller:
        (node:6872) UnhandledPromiseRejectionWarning: Error: Not supported
        (node:6872) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
        (node:6872) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
        admin:
        (node:6881) UnhandledPromiseRejectionWarning: Error: Not supported
        (node:6881) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
        (node:6881) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
        javascript:
        nodejs modules from github:     0
        Adapter State
        ioBroker-Repositories
        (node:6898) UnhandledPromiseRejectionWarning: Error: Not supported
        (node:6898) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
        (node:6898) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
        Installed ioBroker-Instances
        (node:6907) UnhandledPromiseRejectionWarning: Error: Not supported
        (node:6907) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
        (node:6907) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
        Objects and States
        Objects:        0
        States:         0
        W: GPG error: https://deb.nodesource.com/node_18.x nodistro InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
        E: The repository 'https://deb.nodesource.com/node_18.x nodistro InRelease' is not signed.
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14266      678/sshd
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          17461      971/exim4
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14268      678/sshd
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          17462      971/exim4
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14851      625/dhcpcd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13707      385/avahi-daemon: r
        udp        0      0 0.0.0.0:60864           0.0.0.0:*                           108        13709      385/avahi-daemon: r
        udp6       0      0 :::45260                :::*                                108        13710      385/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        13708      385/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          16690      625/dhcpcd
        2024-08-20 09:12:38.956  - info: host.raspibroker stopInstance timeout system.adapter.admin.1 killing pid 800
        2024-08-20 09:12:38.959  - info: host.raspibroker stopInstance timeout system.adapter.javascript.0 killing pid 807
        2024-08-20 09:12:38.960  - info: host.raspibroker stopInstance timeout system.adapter.backitup.0 killing pid 853
        2024-08-20 09:12:38.961  - info: host.raspibroker stopInstance timeout system.adapter.tr-064.0 killing pid 859
        2024-08-20 09:12:38.961  - info: host.raspibroker stopInstance timeout system.adapter.ems-esp.0 killing pid 900
        2024-08-20 09:12:38.962  - info: host.raspibroker stopInstance timeout system.adapter.hm-rega.0 killing pid 932
        2024-08-20 09:12:38.964  - info: host.raspibroker stopInstance timeout system.adapter.web.0 killing pid 1138
        2024-08-20 09:12:39.162  - info: host.raspibroker instance system.adapter.sourceanalytix.0 terminated with code 0 (NO_ERROR)
        2024-08-20 09:12:39.164  - info: host.raspibroker instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
        2024-08-20 09:12:39.166  - info: host.raspibroker instance system.adapter.vis-inventwo.0 terminated with code 0 (NO_ERROR)
        2024-08-20 09:12:40.639  - info: host.raspibroker instance system.adapter.mqtt.0 terminated with code 0 (NO_ERROR)
        2024-08-20 09:12:40.641  - info: host.raspibroker instance system.adapter.tankerkoenig.0 terminated with code 0 (NO_ERROR)
        2024-08-20 09:12:40.642  - info: host.raspibroker instance system.adapter.pollenflug.0 terminated with code 0 (NO_ERROR)
        2024-08-20 09:12:40.686  - info: host.raspibroker instance system.adapter.admin.1 terminated with code 0 (NO_ERROR)
        2024-08-20 09:12:40.864  - info: host.raspibroker instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
        2024-08-20 09:12:40.866  - info: host.raspibroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
        2024-08-20 09:12:40.867  - info: host.raspibroker instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
        2024-08-20 09:12:40.868  - info: host.raspibroker instance system.adapter.ems-esp.0 terminated with code 0 (NO_ERROR)
        2024-08-20 09:12:40.869  - warn: host.raspibroker instance system.adapter.hm-rega.0 terminated due to SIGKILL
        2024-08-20 09:12:40.870  - info: host.raspibroker instance system.adapter.hm-rega.0 terminated with code null ()
        2024-08-20 09:12:40.871  - warn: host.raspibroker instance system.adapter.web.0 terminated due to SIGKILL
        2024-08-20 09:12:40.871  - info: host.raspibroker instance system.adapter.web.0 terminated with code null ()
        2024-08-20 09:12:41.153  - info: host.raspibroker instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
        2024-08-20 09:12:41.155  - info: host.raspibroker All instances are stopped.
        2024-08-20 09:12:41.396  - info: host.raspibroker terminated
        iob diag has finished.
          Homoran Global Moderator Administrators @ioTechnik last edited by Homoran
          @iotechnik sagte in ioBroker update führt zu GLIBCXX_3.4.26-Problem - GELÖST!:
          nach wie vor!!
          und mit
          wird das auch nichts.
          Hattest du nicht iob fix gefahren?
          und danach iob nodejs-update?
          kann natürlich am vergammelten
          liegen.
          Da das ganz aus xem Support raus ist, könnte es sein, dasss da gar kein update mehr möglich ist.
            Thomas Braun Most Active @ioTechnik last edited by
            @iotechnik
            Noch ein paar Hinweise:
            Setz das neue System als reines 64Bit-System auf.
            Spendier der Kiste ein gescheites, richtiges Netzteil. Die jetzige Spannungsversorgung ist zu schlapp.
            Mit
            kannst du auch gar nichts mehr reißen. Mit der dfsg-Version schon gerade nicht.
            Versuch das mal mit der Betaversion von hier zu beackern. :
            https://forum.iobroker.net/topic/68035/iob-node-fix-skript
            Aufruf des Skriptes dann per
            ./iob_node_update 18
            • I
              Hallo Thomas
              habe das System neu aufgesetzt (64bit). Das mit dem Netzteil ist auch OK - es lag am USB-Kabel - habe jetzt direkt verkabelt.
              Bin dabei die Adapter zu aktualisieren - leider lassen sich einige nicht über die Adapteroberfläche aktualisieren.
              Es scheitert momentan beim web-Adapter
              $ iobroker upgrade web@6.2.5
              Update web from @6.2.3 to @6.2.5
              NPM version: 10.8.2
              Installing iobroker.web@6.2.5... (System call)
              Could not handle ENOTEMPTY, because no deletable files were foundnpm error code ENOTEMPTYnpm error syscall renamenpm error path /opt/iobroker/node_modules/aggregate-errornpm error dest /opt/iobroker/node_modules/.aggregate-error-rAKexGiKnpm error errno -39npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/aggregate-error' -> '/opt/iobroker/node_modules/.aggregate-error-rAKexGiK'npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-23T14_35_28_536Z-debug-0.log
              host.raspberrypi Cannot install iobroker.web@6.2.5: 217
              ERROR: Process exited with code 25
              ebenso beim backitup-Adapter. Habe diesen schon neu installiert - ohne Erfolg
                @iotechnik
                iob stop
                iob fix
                iob start
                try again!
                • I
                  Hallo Thomas, Hallo Homoran
                  nach der Neuinstallation und dem Durchlauf der angebotenen Updates läuft der admin nicht mehr.
                  Ich komme nicht mehr auf meinen Pi3. Verschiedene Hinweise aus dem Forum brachten auch keinen Erfolg.
                  Hier iob diag
                  *** iob diag is starting up, please wait ***
                  The state system.host.raspberrypi.versions.nodeNewestNext was not found!
                  The state system.host.raspberrypi.versions.npmNewestNext was not found!
                  The state system.host.raspberrypi.versions.nodeCurrent was not found!
                  Skript v.2024-05-22
                  *** BASE SYSTEM ***
                   Static hostname: raspberrypi
                         Icon name: computer
                            Kernel: Linux 6.6.31+rpt-rpi-v8
                      Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : 64 bit
                   09:04:41 up  2:42,  3 users,  load average: 2.06, 1.49, 1.10
                  CPU threads: 4
                  Current issues:
                                 Local time: Mon 2024-08-26 09:04:41 CEST
                             Universal time: Mon 2024-08-26 07:04:41 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  HOME=/home/pi
                  GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                  iobroker
                  HOME=/home/iobroker
                  GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            951M        747M         93M         28K        167M        204M
                  Swap:           209M        206M        3.2M
                  Total:          1.2G        953M         96M
                  Active iob-Instances:   11
                            907 M total memory
                            712 M used memory
                            378 M active memory
                            351 M inactive memory
                             88 M free memory
                             18 M buffer memory
                            140 M swap cache
                            199 M total swap
                            196 M used swap
                              3 M free swap
                  top - 09:04:42 up  2:42,  3 users,  load average: 2.05, 1.49, 1.11
                  Tasks: 167 total,   1 running, 166 sleeping,   0 stopped,   0 zombie
                  %Cpu(s): 11.1 us, 22.2 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :    907.3 total,     88.9 free,    712.3 used,    159.8 buff/cache
                  MiB Swap:    200.0 total,      3.1 free,    196.9 used.    195.0 avail Mem
                  *** FILESYSTEM ***
                  udev           devtmpfs  318M     0  318M   0% /dev
                  tmpfs          tmpfs      91M  1.1M   90M   2% /run
                  /dev/sda2      ext4      6.8G  5.1G  1.4G  79% /
                  tmpfs          tmpfs     454M     0  454M   0% /dev/shm
                  tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
                  /dev/sda1      vfat      510M   64M  447M  13% /boot/firmware
                  tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                  [Mon Aug 26 06:22:24 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c80d8e3a-02 rootfstype=ext4 fsck.repair=yes rootwait
                  [Mon Aug 26 06:22:31 2024] EXT4-fs (sda2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
                  [Mon Aug 26 06:22:34 2024] EXT4-fs (sda2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
                  | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                  | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
                  | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                  | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                  | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                  | |-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                  | `-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
                  | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=2867
                  |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                  |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=325396k,nr_inodes=81349,mode=755
                  | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                  |-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=92912k,mode=755
                  | |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                  | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                  | |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                  | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                  | `-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=92908k,nr_inodes=23227,mode=700,uid=1000,gid=1000
                  `-/boot/firmware                                        /dev/sda1   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  1.1G    /var/
                  356M    /var/log
                  355M    /var/log/journal/6dc99cd23c35495a81d44ed7c87f33e1
                  349M    /var/cache
                  Archived and active journals take up 354.9M in the file system.
                  25M     /opt/iobroker/backups/
                  457M    /opt/iobroker/iobroker-data/
                  431M    /opt/iobroker/iobroker-data/files
                  142M    /opt/iobroker/iobroker-data/files/vis-2
                  81M     /opt/iobroker/iobroker-data/files/vis-2/static
                  80M     /opt/iobroker/iobroker-data/files/vis-2/static/js
                  24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                  19M     /opt/iobroker/iobroker-data/objects.jsonl
                  19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
                  USB-Devices by-id:
                  /usr/bin/nodejs         v20.17.0
                  /usr/bin/node           v20.17.0
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  /usr/bin/corepack       0.29.3
                  nodejs:
                    Installed: 20.17.0-1nodesource1
                    Candidate: 20.17.0-1nodesource1
                    Version table:
                   *** 20.17.0-1nodesource1 1001
                          500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                       20.16.0-1nodesource1 1001
                       20.15.1-1nodesource1 1001
                       20.15.0-1nodesource1 1001
                       20.14.0-1nodesource1 1001
                       20.13.1-1nodesource1 1001
                       20.13.0-1nodesource1 1001
                       20.12.2-1nodesource1 1001
                       20.12.1-1nodesource1 1001
                       20.12.0-1nodesource1 1001
                       20.11.1-1nodesource1 1001
                       20.11.0-1nodesource1 1001
                       20.10.0-1nodesource1 1001
                       20.9.0-1nodesource1 1001
                       20.8.1-1nodesource1 1001
                       20.8.0-1nodesource1 1001
                       20.7.0-1nodesource1 1001
                       20.6.1-1nodesource1 1001
                       20.6.0-1nodesource1 1001
                       20.5.1-1nodesource1 1001
                       20.5.0-1nodesource1 1001
                       20.4.0-1nodesource1 1001
                       20.3.1-1nodesource1 1001
                       20.3.0-1nodesource1 1001
                       20.2.0-1nodesource1 1001
                       20.1.0-1nodesource1 1001
                       20.0.0-1nodesource1 1001
                       18.19.0+dfsg-6~deb12u2 500
                       18.19.0+dfsg-6~deb12u1 500
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  js-controller:  6.0.9
                  admin:          7.0.23
                  javascript:     7.8.0
                  Adapter State
                    system.adapter.admin.1                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                    system.adapter.awattar.0                : awattar               : raspberrypi                              - disabled
                  + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                  + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                    system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                  + system.adapter.ems-esp.0                : ems-esp               : raspberrypi                              -  enabled
                    system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
                    system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              - disabled
                  + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                  + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                  + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                    system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                    system.adapter.material.0               : material              : raspberrypi                              - disabled
                  + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                    system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              - disabled
                    system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              - disabled
                  + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                  + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                    system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                    system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                    system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
                    system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
                    system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                    system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
                  + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + instance is alive
                  Active repo(s): stable
                  Upgrade policy: none
                  Used repository: stable
                  Adapter    "admin"        : 7.0.23   , installed 7.0.23
                  Adapter    "awattar"      : 1.0.6    , installed 1.0.6
                  Adapter    "backitup"     : 3.0.19   , installed 3.0.19
                  Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                  Adapter    "ems-esp"      : 3.5.0    , installed 3.5.0
                  Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
                  Adapter    "hm-rega"      : 5.0.0    , installed 4.0.0  [Updatable]
                  Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                  Adapter    "javascript"   : 8.7.6    , installed 7.8.0  [Updatable]
                  Controller "js-controller": 6.0.9    , installed 6.0.9
                  Adapter    "material"     : 1.3.1    , installed 1.3.1
                  Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                  Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
                  Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                  Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                  Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                  Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                  Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                  Adapter    "ws"           : 2.6.2    , installed 2.6.2
                  Objects and States
                  Objects:        6117
                  States:         5526
                  Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                  Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                  Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 0
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       5841       969/io.mqtt.0
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6367       619/iobroker.js-con
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6362       619/iobroker.js-con
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          826        647/sshd: /usr/sbin
                  tcp        0      0 192.168.2.16:2001       0.0.0.0:*               LISTEN      1001       6665       962/io.hm-rpc.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8706       1152/io.web.0
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          828        647/sshd: /usr/sbin
                  udp        0      0 0.0.0.0:52009           0.0.0.0:*                           104        712        498/avahi-daemon: r
                  udp        0      0 192.168.2.16:5353       0.0.0.0:*                           1001       6016       984/io.tr-064.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        710        498/avahi-daemon: r
                  udp6       0      0 :::57842                :::*                                104        713        498/avahi-daemon: r
                  udp6       0      0 fe80::aa28:f59d:ff7:546 :::*                                0          6357       565/NetworkManager
                  udp6       0      0 :::5353                 :::*                                104        711        498/avahi-daemon: r
                  2024-08-26 07:24:53.890  - info: weatherunderground.0 (2135) Terminated (NO_ERROR): Without reason
                  2024-08-26 07:24:54.485  - info: host.raspberrypi instance system.adapter.weatherunderground.0 having pid 2135 terminated with code 0 (NO_ERROR)
                  2024-08-26 07:30:48.064  - info: host.raspberrypi instance system.adapter.dwd.0 in version "2.8.5" started with pid 2156
                  2024-08-26 07:30:53.116  - info: dwd.0 (2156) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.17.0, js-controller: 6.0.9
                  2024-08-26 07:30:54.762  - info: dwd.0 (2156) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2024-08-26 07:30:55.325  - info: host.raspberrypi instance system.adapter.dwd.0 having pid 2156 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2024-08-26 07:59:50.814  - info: host.raspberrypi "system.adapter.weatherunderground.0" disabled
                  2024-08-26 07:59:50.823  - info: host.raspberrypi stopInstance system.adapter.weatherunderground.0 (force=false, process=false)
                  2024-08-26 07:59:50.825  - info: host.raspberrypi stopInstance canceled schedule system.adapter.weatherunderground.0
                  2024-08-26 08:00:48.124  - info: host.raspberrypi instance system.adapter.dwd.0 in version "2.8.5" started with pid 2347
                  2024-08-26 08:00:53.234  - info: dwd.0 (2347) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.17.0, js-controller: 6.0.9
                  2024-08-26 08:00:54.878  - info: dwd.0 (2347) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2024-08-26 08:00:55.449  - info: host.raspberrypi instance system.adapter.dwd.0 having pid 2347 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2024-08-26 08:24:54.735  - info: web.0 (1152) ==> Connected system.user.admin from ::ffff:192.168.2.21
                  2024-08-26 08:25:08.352  - info: web.0 (1152) <== Disconnect system.user.admin from ::ffff:192.168.2.21 vis.0
                  2024-08-26 08:25:08.595  - info: web.0 (1152) ==> Connected system.user.admin from ::ffff:192.168.2.21
                  2024-08-26 08:30:48.086  - info: host.raspberrypi instance system.adapter.dwd.0 in version "2.8.5" started with pid 2498
                  2024-08-26 08:30:54.414  - info: dwd.0 (2498) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.17.0, js-controller: 6.0.9
                  2024-08-26 08:30:56.287  - info: dwd.0 (2498) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2024-08-26 08:30:56.927  - info: host.raspberrypi instance system.adapter.dwd.0 having pid 2498 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2024-08-26 09:00:48.156  - info: host.raspberrypi instance system.adapter.dwd.0 in version "2.8.5" started with pid 3776
                  2024-08-26 09:00:56.331  - info: dwd.0 (3776) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.17.0, js-controller: 6.0.9
                  2024-08-26 09:00:58.375  - info: dwd.0 (3776) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2024-08-26 09:00:58.947  - info: host.raspberrypi instance system.adapter.dwd.0 having pid 3776 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    Thomas Braun Most Active @ioTechnik last edited by Thomas Braun
                    @iotechnik
                    Hat zwar mit dem ursprünglichen Thema nix mehr zu tun, aber starte den Admin mal.
                    iob start admin.1
                    Edit: Wenn ich mir die jetzige Auslastung anschaue und was da alles an Adaptern noch gar nicht gestartet ist würde ich sagen: Raspi3 mehr als ausgereizt.
                    • I
                      ioTechnik @Thomas Braun last edited by
                      Danke Thomas und Homoran. Habe mir sowas schon gedacht. Die Adapter werden wie bei Windows-updates o.ä. immer größer und der RAM reicht dann nicht mehr.
                      Ich habe hier einen alten Laptop 64-bit mit Linux vorbereitet und werde versuchen mein System dahin umzusiedeln.
                        1GB ist halt auch nicht so wirklich üppig.
                        Mittlerweile würde ich mindestens 4GB veranschlagen, wenn da eine durchschnittliche Installation laufen soll.
                          aber >20Adapter hat noch nie mit 1GB RAM funktioniert. auch nicht vor 5-10 Jahren
                          Seit Beginn wurde schon immer empfohlen mind. 2GB RAM zu verwenden (noch mehr war damals fast nicht zu bekommen)
                          10338
