    3. Entwicklung
    4. Adapter Worx Landroid v3.x.x
      Lucky_ESA Developer Most Active @falkomfs last edited by
      @falkomfs sagte in Adapter Worx Landroid v3.x.x:
      @lucky_esa Moin,
      also über den Button Edgecut fährt er noch nicht los, aber über SendCommand funktioniert es jetzt
      Was musst du in der APP einstellen wenn du dort Kantenschnitt auswählst? Kannst du den Adapter auf debug stellen und dann per APP den Kantenschnitt statrten? Poste dann mal das Log.
      F 4 Replies Last reply Reply Quote 0
        falkomfs @Lucky_ESA last edited by
        @lucky_esa also in der APP habe ich den Button wie auf dem Bild
          @lucky_esa
          das ist jetzt der Log über den Button .mower.edgecut
          2024-08-25 13:57:37.523 - debug: worx.0 (129277) this.modules! {"202330294702002506EF":{"edgeCut":false,"slots":2,"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"tq":0,"channel":true,"HL":{"enabled":0},"DF":{"cut":1,"fh":0},"al":{"lvl":0,"t":60},"al_last":60}}
          2024-08-25 13:57:37.523 - debug: worx.0 (129277) state change: id_____ worx.0.202330294702002506EF.mower.edgecut Mower 202330294702002506EF_____edgecut______{"id":923901,"uuid":"98c93462-d518-4002-afad-c91894f61969","product_id":73,"user_id":503887,"serial_number":"202330294702002506EF","mac_address":"","locked":false,"firmware_version":"3.34.0+10","firmware_auto_upgrade":true,"sim":"","test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2023-05-27 00:00:00","online":true,"protocol":1,"pending_radio_link_validation":"","capabilities":["auto_lock","bluetooth_pairing","border_cut","display_pairing_shortcut","lock","mqtt","multi_zone_tag","one_time_scheduler","ota_upgrade","pause_over_border","rain_delay","unrestricted_mowing_time","vision"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandIn","command_out":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut"},"name":"falkomfs","blade_height_shift":0,"push_notifications":true,"push_notifications_level":"warning","pin_code":"","app_settings":"","warranty_registered":true,"purchased_at":"2023-05-27 00:00:00","warranty_expires_at":"2025-05-27 00:00:00","setup_location":{"latitude":52.72299989287376,"longitude":7.930778502216534},"city":{"id":2928809,"country_id":276,"name":"Essen","latitude":52.700001,"longitude":7.91667,"created_at":"2018-02-15 22:41:14","updated_at":"2018-02-15 22:41:14"},"time_zone":"Europe/Berlin","lawn_size":119.93579864502,"lawn_perimeter":28,"auto_schedule_settings":"","auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":284806,"mower_work_time":17976,"blade_work_time":17373,"blade_work_time_reset":0,"blade_work_time_reset_at":"","battery_charge_cycles":3491,"battery_charge_cycles_reset":0,"battery_charge_cycles_reset_at":"","created_at":"2023-03-28 06:50:27","updated_at":"2024-08-23 09:43:47","last_status":{"payload":{"cfg":{"id":39809,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":0,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":0,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":1,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":2,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":3,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":4,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":5,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":6,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T11:54:57.794Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":22.4,"v":19.7,"p":96,"nr":3513,"c":1,"m":1},"dmp":[-5.4,-0.8,15.9],"st":{"b":17440,"d":285704,"wt":18053,"bl":28},"rsi":-61,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}},"timestamp":"2024-08-25 13:54:57.435"},"last_gps_status":""}
          2024-08-25 13:57:37.523 - debug: worx.0 (129277) Worxcloud MQTT sendMessage to 202330294702002506EF Message: {"cut":{"b":1,"z":[],"bd": 100,"ob": 1}}
          2024-08-25 13:57:37.523 - info: worx.0 (129277) Request Counter: 2
          2024-08-25 13:57:37.523 - debug: worx.0 (129277) length: 0
          2024-08-25 13:57:37.523 - debug: worx.0 (129277) Start MQTT ping: {"id":36893,"cmd":0,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-25T13:57:37.523Z","cut":{"b":1,"z":[],"bd":100,"ob":1}}
          2024-08-25 13:57:37.523 - debug: worx.0 (129277) lastCommand_start: {"36893":{"id":36893,"cmd":0,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-25T13:57:37.523Z","cut":{"b":1,"z":[],"bd":100,"ob":1}}}
          2024-08-25 13:57:37.526 - debug: worx.0 (129277) this.mqtt_response_check: {"36893":{"id":36893,"cmd":0,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-25T13:57:37.523Z","cut":{"b":1,"z":[],"bd":100,"ob":1},"request":1724587057524,"response":0,"action":"worx.0.202330294702002506EF.mower.edgecut","user":"iobroker"}}
          2024-08-25 13:57:37.526 - debug: worx.0 (129277) sendData: {"id":36893,"cmd":0,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-25T13:57:37.523Z","cut":{"b":1,"z":[],"bd":100,"ob":1}}
          2024-08-25 13:57:38.695 - debug: worx.0 (129277) Mower MQTT: {"cfg":{"id":36893,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":0,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0}},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T11:57:38.951Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":22.5,"v":19.8,"p":97,"nr":3513,"c":1,"m":1},"dmp":[-5.4,-0.8,15.9],"st":{"b":17440,"d":285704,"wt":18053,"bl":28},"rsi":-62,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
          2024-08-25 13:57:38.695 - debug: worx.0 (129277) topic: WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut
          2024-08-25 13:57:38.695 - debug: worx.0 (129277) getQueueStatistics: {"incompleteOperationCount":0,"incompleteOperationSize":0,"unackedOperationCount":0,"unackedOperationSize":0}
          2024-08-25 13:57:38.696 - debug: worx.0 (129277) Worxcloud MQTT get Message for mower falkomfs (202330294702002506EF)
          2024-08-25 13:57:38.696 - debug: worx.0 (129277) Request ID 36893 has been passed to the mower
          2024-08-25 13:57:38.696 - debug: worx.0 (129277) lastCommand_start: {"36893":{"id":36893,"cmd":0,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-25T13:57:37.523Z","cut":{"b":1,"z":[],"bd":100,"ob":1},"request":1724587057524,"response":0,"action":"worx.0.202330294702002506EF.mower.edgecut","user":"iobroker"}}
          2024-08-25 13:57:38.696 - debug: worx.0 (129277) Set new timestamp
          2024-08-25 13:57:38.742 - debug: worx.0 (129277) GET MQTT DATA from API: {"cfg":{"id":36893,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":0,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T11:57:38.951Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":22.5,"v":19.8,"p":97,"nr":3513,"c":1,"m":1},"dmp":[-5.4,-0.8,15.9],"st":{"b":17440,"d":285704,"wt":18053,"bl":28},"rsi":-62,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
          2024-08-25 13:57:38.795 - debug: worx.0 (129277) Test Status: 1
          2024-08-25 13:57:38.801 - debug: worx.0 (129277) COUNTER: 7
          2024-08-25 13:57:38.801 - debug: worx.0 (129277) COUNTER SLOTS: 2
          2024-08-25 13:57:38.801 - debug: worx.0 (129277) {"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
          2024-08-25 13:57:38.852 - debug: worx.0 (129277) {"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
          2024-08-25 13:57:38.859 - debug: worx.0 (129277) {"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
          2024-08-25 13:57:38.865 - debug: worx.0 (129277) {"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
          2024-08-25 13:57:38.871 - debug: worx.0 (129277) {"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
          2024-08-25 13:57:38.878 - debug: worx.0 (129277) {"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
          2024-08-25 13:57:38.884 - debug: worx.0 (129277) {"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
          2024-08-25 13:57:38.897 - debug: worx.0 (129277) MOWER with full schedule: {"id":923901,"uuid":"98c93462-d518-4002-afad-c91894f61969","product_id":73,"user_id":503887,"serial_number":"202330294702002506EF","mac_address":"","locked":false,"firmware_version":"3.34.0+10","firmware_auto_upgrade":true,"sim":"","test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2023-05-27 00:00:00","online":true,"protocol":1,"pending_radio_link_validation":"","capabilities":["auto_lock","bluetooth_pairing","border_cut","display_pairing_shortcut","lock","mqtt","multi_zone_tag","one_time_scheduler","ota_upgrade","pause_over_border","rain_delay","unrestricted_mowing_time","vision"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandIn","command_out":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut"},"name":"falkomfs","blade_height_shift":0,"push_notifications":true,"push_notifications_level":"warning","pin_code":"","app_settings":"","warranty_registered":true,"purchased_at":"2023-05-27 00:00:00","warranty_expires_at":"2025-05-27 00:00:00","setup_location":{"latitude":52.72299989287376,"longitude":7.930778502216534},"city":{"id":2928809,"country_id":276,"name":"Essen","latitude":52.700001,"longitude":7.91667,"created_at":"2018-02-15 22:41:14","updated_at":"2018-02-15 22:41:14"},"time_zone":"Europe/Berlin","lawn_size":119.93579864502,"lawn_perimeter":28,"auto_schedule_settings":"","auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":284806,"mower_work_time":17976,"blade_work_time":17373,"blade_work_time_reset":0,"blade_work_time_reset_at":"","battery_charge_cycles":3491,"battery_charge_cycles_reset":0,"battery_charge_cycles_reset_at":"","created_at":"2023-03-28 06:50:27","updated_at":"2024-08-23 09:43:47","last_status":{"payload":{"cfg":{"id":36893,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":0,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":0,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":1,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":2,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":3,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":4,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":5,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":6,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T11:57:38.951Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":22.5,"v":19.8,"p":97,"nr":3513,"c":1,"m":1},"dmp":[-5.4,-0.8,15.9],"st":{"b":17440,"d":285704,"wt":18053,"bl":28},"rsi":-62,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}},"timestamp":"2024-08-25 13:57:38.696"},"last_gps_status":""}
          2024-08-25 13:57:38.958 - debug: worx.0 (129277) Count Zone: 1 - Count Passage: 0
          2024-08-25 13:57:38.958 - debug: worx.0 (129277) Count Receive Zone: 1 - Count Receive Passage: 0
          2024-08-25 13:57:38.958 - debug: worx.0 (129277) Write multi zone: {"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]}
          2024-08-25 13:57:38.967 - debug: worx.0 (129277) Edgecut Start section :1
            @lucky_esa das ist der Log über .mower.sendCommand.BorderCut(101. Hier funtioniert es auch und kann somit genutzt werden
            2024-08-25 13:59:10.866 - debug: worx.0 (129277) this.modules! {"202330294702002506EF":{"edgeCut":true,"slots":2,"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"tq":0,"channel":true,"HL":{"enabled":0},"DF":{"cut":1,"fh":0},"al":{"lvl":0,"t":60},"al_last":60}}
            2024-08-25 13:59:10.866 - debug: worx.0 (129277) state change: id_____ worx.0.202330294702002506EF.mower.sendCommand Mower 202330294702002506EF_____sendCommand______{"id":923901,"uuid":"98c93462-d518-4002-afad-c91894f61969","product_id":73,"user_id":503887,"serial_number":"202330294702002506EF","mac_address":"","locked":false,"firmware_version":"3.34.0+10","firmware_auto_upgrade":true,"sim":"","test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2023-05-27 00:00:00","online":true,"protocol":1,"pending_radio_link_validation":"","capabilities":["auto_lock","bluetooth_pairing","border_cut","display_pairing_shortcut","lock","mqtt","multi_zone_tag","one_time_scheduler","ota_upgrade","pause_over_border","rain_delay","unrestricted_mowing_time","vision"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandIn","command_out":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut"},"name":"falkomfs","blade_height_shift":0,"push_notifications":true,"push_notifications_level":"warning","pin_code":"","app_settings":"","warranty_registered":true,"purchased_at":"2023-05-27 00:00:00","warranty_expires_at":"2025-05-27 00:00:00","setup_location":{"latitude":52.72299989287376,"longitude":7.930778502216534},"city":{"id":2928809,"country_id":276,"name":"Essen","latitude":52.700001,"longitude":7.91667,"created_at":"2018-02-15 22:41:14","updated_at":"2018-02-15 22:41:14"},"time_zone":"Europe/Berlin","lawn_size":119.93579864502,"lawn_perimeter":28,"auto_schedule_settings":"","auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":284806,"mower_work_time":17976,"blade_work_time":17373,"blade_work_time_reset":0,"blade_work_time_reset_at":"","battery_charge_cycles":3491,"battery_charge_cycles_reset":0,"battery_charge_cycles_reset_at":"","created_at":"2023-03-28 06:50:27","updated_at":"2024-08-23 09:43:47","last_status":{"payload":{"cfg":{"id":36893,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":0,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":0,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":1,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":2,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":3,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":4,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":5,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":6,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T11:57:38.951Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":22.5,"v":19.8,"p":97,"nr":3513,"c":1,"m":1},"dmp":[-5.4,-0.8,15.9],"st":{"b":17440,"d":285704,"wt":18053,"bl":28},"rsi":-62,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}},"timestamp":"2024-08-25 13:57:38.696"},"last_gps_status":""}
            2024-08-25 13:59:10.866 - debug: worx.0 (129277) Send cmd:101
            2024-08-25 13:59:10.866 - debug: worx.0 (129277) Worxcloud MQTT sendMessage to 202330294702002506EF Message: {"cmd":101}
            2024-08-25 13:59:10.866 - info: worx.0 (129277) Request Counter: 3
            2024-08-25 13:59:10.866 - debug: worx.0 (129277) length: 0
            2024-08-25 13:59:10.866 - debug: worx.0 (129277) Start MQTT ping: {"id":27589,"cmd":101,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-25T13:59:10.866Z"}
            2024-08-25 13:59:10.866 - debug: worx.0 (129277) lastCommand_start: {"27589":{"id":27589,"cmd":101,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-25T13:59:10.866Z"}}
            2024-08-25 13:59:10.910 - debug: worx.0 (129277) this.mqtt_response_check: {"27589":{"id":27589,"cmd":101,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-25T13:59:10.866Z","request":1724587150867,"response":0,"action":"worx.0.202330294702002506EF.mower.sendCommand","user":"iobroker"}}
            2024-08-25 13:59:10.910 - debug: worx.0 (129277) sendData: {"id":27589,"cmd":101,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-25T13:59:10.866Z"}
            2024-08-25 13:59:12.057 - debug: worx.0 (129277) Mower MQTT: {"cfg":{"id":27589,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0}},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T11:59:11.947Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":22.6,"v":19.9,"p":97,"nr":3513,"c":1,"m":1},"dmp":[-5.5,-0.8,15.9],"st":{"b":17440,"d":285704,"wt":18053,"bl":28},"rsi":-62,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
            2024-08-25 13:59:12.057 - debug: worx.0 (129277) topic: WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut
            2024-08-25 13:59:12.057 - debug: worx.0 (129277) getQueueStatistics: {"incompleteOperationCount":0,"incompleteOperationSize":0,"unackedOperationCount":0,"unackedOperationSize":0}
            2024-08-25 13:59:12.057 - debug: worx.0 (129277) Worxcloud MQTT get Message for mower falkomfs (202330294702002506EF)
            2024-08-25 13:59:12.057 - debug: worx.0 (129277) Request ID 27589 has been passed to the mower
            2024-08-25 13:59:12.058 - debug: worx.0 (129277) lastCommand_start: {"27589":{"id":27589,"cmd":101,"lg":"de","uuid":"98c93462-d518-4002-afad-c91894f61969","tm":"2024-08-25T13:59:10.866Z","request":1724587150867,"response":0,"action":"worx.0.202330294702002506EF.mower.sendCommand","user":"iobroker"}}
            2024-08-25 13:59:12.058 - debug: worx.0 (129277) Set new timestamp
            2024-08-25 13:59:12.102 - debug: worx.0 (129277) GET MQTT DATA from API: {"cfg":{"id":27589,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T11:59:11.947Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":22.6,"v":19.9,"p":97,"nr":3513,"c":1,"m":1},"dmp":[-5.5,-0.8,15.9],"st":{"b":17440,"d":285704,"wt":18053,"bl":28},"rsi":-62,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
            2024-08-25 13:59:12.158 - debug: worx.0 (129277) Test Status: 1
            2024-08-25 13:59:12.161 - debug: worx.0 (129277) COUNTER: 7
            2024-08-25 13:59:12.161 - debug: worx.0 (129277) COUNTER SLOTS: 2
            2024-08-25 13:59:12.162 - debug: worx.0 (129277) {"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
            2024-08-25 13:59:12.212 - debug: worx.0 (129277) {"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
            2024-08-25 13:59:12.217 - debug: worx.0 (129277) {"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
            2024-08-25 13:59:12.223 - debug: worx.0 (129277) {"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
            2024-08-25 13:59:12.230 - debug: worx.0 (129277) {"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
            2024-08-25 13:59:12.236 - debug: worx.0 (129277) {"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
            2024-08-25 13:59:12.242 - debug: worx.0 (129277) {"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
            2024-08-25 13:59:12.251 - debug: worx.0 (129277) MOWER with full schedule: {"id":923901,"uuid":"98c93462-d518-4002-afad-c91894f61969","product_id":73,"user_id":503887,"serial_number":"202330294702002506EF","mac_address":"","locked":false,"firmware_version":"3.34.0+10","firmware_auto_upgrade":true,"sim":"","test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2023-05-27 00:00:00","online":true,"protocol":1,"pending_radio_link_validation":"","capabilities":["auto_lock","bluetooth_pairing","border_cut","display_pairing_shortcut","lock","mqtt","multi_zone_tag","one_time_scheduler","ota_upgrade","pause_over_border","rain_delay","unrestricted_mowing_time","vision"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandIn","command_out":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut"},"name":"falkomfs","blade_height_shift":0,"push_notifications":true,"push_notifications_level":"warning","pin_code":"","app_settings":"","warranty_registered":true,"purchased_at":"2023-05-27 00:00:00","warranty_expires_at":"2025-05-27 00:00:00","setup_location":{"latitude":52.72299989287376,"longitude":7.930778502216534},"city":{"id":2928809,"country_id":276,"name":"Essen","latitude":52.700001,"longitude":7.91667,"created_at":"2018-02-15 22:41:14","updated_at":"2018-02-15 22:41:14"},"time_zone":"Europe/Berlin","lawn_size":119.93579864502,"lawn_perimeter":28,"auto_schedule_settings":"","auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":284806,"mower_work_time":17976,"blade_work_time":17373,"blade_work_time_reset":0,"blade_work_time_reset_at":"","battery_charge_cycles":3491,"battery_charge_cycles_reset":0,"battery_charge_cycles_reset_at":"","created_at":"2023-03-28 06:50:27","updated_at":"2024-08-23 09:43:47","last_status":{"payload":{"cfg":{"id":27589,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":0,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":1,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":2,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":3,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":4,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":5,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":6,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T11:59:11.947Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":22.6,"v":19.9,"p":97,"nr":3513,"c":1,"m":1},"dmp":[-5.5,-0.8,15.9],"st":{"b":17440,"d":285704,"wt":18053,"bl":28},"rsi":-62,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}},"timestamp":"2024-08-25 13:59:12.058"},"last_gps_status":""}
            2024-08-25 13:59:12.304 - debug: worx.0 (129277) Count Zone: 1 - Count Passage: 0
            2024-08-25 13:59:12.304 - debug: worx.0 (129277) Count Receive Zone: 1 - Count Receive Passage: 0
            2024-08-25 13:59:12.304 - debug: worx.0 (129277) Write multi zone: {"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]}
            2024-08-25 13:59:12.307 - debug: worx.0 (129277) Edgecut Start section :1
            2024-08-25 13:59:13.017 - debug: worx.0 (129277) Mower MQTT: {"cfg":{"id":0,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0}},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T11:59:12.701Z","ls":3,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":22.6,"v":19.7,"p":97,"nr":3513,"c":0,"m":0},"dmp":[-5.3,-0.9,15.9],"st":{"b":17440,"d":285704,"wt":18053,"bl":28},"rsi":-62,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
            2024-08-25 13:59:13.018 - debug: worx.0 (129277) topic: WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut
            2024-08-25 13:59:13.018 - debug: worx.0 (129277) getQueueStatistics: {"incompleteOperationCount":0,"incompleteOperationSize":0,"unackedOperationCount":0,"unackedOperationSize":0}
            2024-08-25 13:59:13.018 - debug: worx.0 (129277) Worxcloud MQTT get Message for mower falkomfs (202330294702002506EF)
            2024-08-25 13:59:13.018 - debug: worx.0 (129277) Set new timestamp
            2024-08-25 13:59:13.105 - debug: worx.0 (129277) GET MQTT DATA from API: {"cfg":{"id":0,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T11:59:12.701Z","ls":3,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":22.6,"v":19.7,"p":97,"nr":3513,"c":0,"m":0},"dmp":[-5.3,-0.9,15.9],"st":{"b":17440,"d":285704,"wt":18053,"bl":28},"rsi":-62,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
            2024-08-25 13:59:13.113 - debug: worx.0 (129277) Test Status: 3
            2024-08-25 13:59:13.114 - debug: worx.0 (129277) SET loadActivity on true
            2024-08-25 13:59:13.116 - debug: worx.0 (129277) COUNTER: 7
            2024-08-25 13:59:13.116 - debug: worx.0 (129277) COUNTER SLOTS: 2
            2024-08-25 13:59:13.116 - debug: worx.0 (129277) {"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
            2024-08-25 13:59:13.164 - debug: worx.0 (129277) {"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
            2024-08-25 13:59:13.169 - debug: worx.0 (129277) {"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
            2024-08-25 13:59:13.174 - debug: worx.0 (129277) {"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
            2024-08-25 13:59:13.179 - debug: worx.0 (129277) {"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
            2024-08-25 13:59:13.185 - debug: worx.0 (129277) {"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
            2024-08-25 13:59:13.191 - debug: worx.0 (129277) {"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
            2024-08-25 13:59:13.200 - debug: worx.0 (129277) MOWER with full schedule: {"id":923901,"uuid":"98c93462-d518-4002-afad-c91894f61969","product_id":73,"user_id":503887,"serial_number":"202330294702002506EF","mac_address":"","locked":false,"firmware_version":"3.34.0+10","firmware_auto_upgrade":true,"sim":"","test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2023-05-27 00:00:00","online":true,"protocol":1,"pending_radio_link_validation":"","capabilities":["auto_lock","bluetooth_pairing","border_cut","display_pairing_shortcut","lock","mqtt","multi_zone_tag","one_time_scheduler","ota_upgrade","pause_over_border","rain_delay","unrestricted_mowing_time","vision"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandIn","command_out":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut"},"name":"falkomfs","blade_height_shift":0,"push_notifications":true,"push_notifications_level":"warning","pin_code":"","app_settings":"","warranty_registered":true,"purchased_at":"2023-05-27 00:00:00","warranty_expires_at":"2025-05-27 00:00:00","setup_location":{"latitude":52.72299989287376,"longitude":7.930778502216534},"city":{"id":2928809,"country_id":276,"name":"Essen","latitude":52.700001,"longitude":7.91667,"created_at":"2018-02-15 22:41:14","updated_at":"2018-02-15 22:41:14"},"time_zone":"Europe/Berlin","lawn_size":119.93579864502,"lawn_perimeter":28,"auto_schedule_settings":"","auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":284806,"mower_work_time":17976,"blade_work_time":17373,"blade_work_time_reset":0,"blade_work_time_reset_at":"","battery_charge_cycles":3491,"battery_charge_cycles_reset":0,"battery_charge_cycles_reset_at":"","created_at":"2023-03-28 06:50:27","updated_at":"2024-08-23 09:43:47","last_status":{"payload":{"cfg":{"id":0,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":0,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":1,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":2,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":3,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":4,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":5,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":6,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T11:59:12.701Z","ls":3,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":22.6,"v":19.7,"p":97,"nr":3513,"c":0,"m":0},"dmp":[-5.3,-0.9,15.9],"st":{"b":17440,"d":285704,"wt":18053,"bl":28},"rsi":-62,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}},"timestamp":"2024-08-25 13:59:13.018"},"last_gps_status":""}
            2024-08-25 13:59:13.253 - debug: worx.0 (129277) Count Zone: 1 - Count Passage: 0
            2024-08-25 13:59:13.253 - debug: worx.0 (129277) Count Receive Zone: 1 - Count Receive Passage: 0
            2024-08-25 13:59:13.253 - debug: worx.0 (129277) Write multi zone: {"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]}
            2024-08-25 13:59:13.257 - debug: worx.0 (129277) Edgecut Start section :3
              @lucky_esa und das ist der Log beim Kantenschnitt über die APP
              2024-08-25 14:03:48.389 - debug: worx.0 (129330) Mower MQTT: {"cfg":{"id":51366,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0}},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T12:03:48.231Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":23,"v":19.4,"p":97,"nr":3513,"c":1,"m":0},"dmp":[-5.2,-0.9,17.1],"st":{"b":17442,"d":285736,"wt":18056,"bl":28},"rsi":-61,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
              2024-08-25 14:03:48.389 - debug: worx.0 (129330) topic: WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut
              2024-08-25 14:03:48.389 - debug: worx.0 (129330) getQueueStatistics: {"incompleteOperationCount":0,"incompleteOperationSize":0,"unackedOperationCount":0,"unackedOperationSize":0}
              2024-08-25 14:03:48.389 - debug: worx.0 (129330) Worxcloud MQTT get Message for mower falkomfs (202330294702002506EF)
              2024-08-25 14:03:48.389 - debug: worx.0 (129330) Response ID 51366 from mower
              2024-08-25 14:03:48.389 - debug: worx.0 (129330) lastCommand_start: {"cfg":{"id":51366,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T12:03:48.231Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":23,"v":19.4,"p":97,"nr":3513,"c":1,"m":0},"dmp":[-5.2,-0.9,17.1],"st":{"b":17442,"d":285736,"wt":18056,"bl":28},"rsi":-61,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
              2024-08-25 14:03:48.389 - debug: worx.0 (129330) Set new timestamp
              2024-08-25 14:03:48.434 - debug: worx.0 (129330) GET MQTT DATA from API: {"cfg":{"id":51366,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF","request":0,"response":1724587428391,"action":"APP","user":"APP"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T12:03:48.231Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":23,"v":19.4,"p":97,"nr":3513,"c":1,"m":0},"dmp":[-5.2,-0.9,17.1],"st":{"b":17442,"d":285736,"wt":18056,"bl":28},"rsi":-61,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
              2024-08-25 14:03:48.486 - debug: worx.0 (129330) Test Status: 1
              2024-08-25 14:03:48.489 - debug: worx.0 (129330) COUNTER: 7
              2024-08-25 14:03:48.489 - debug: worx.0 (129330) COUNTER SLOTS: 2
              2024-08-25 14:03:48.489 - debug: worx.0 (129330) {"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
              2024-08-25 14:03:48.569 - debug: worx.0 (129330) {"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
              2024-08-25 14:03:48.576 - debug: worx.0 (129330) {"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
              2024-08-25 14:03:48.585 - debug: worx.0 (129330) {"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
              2024-08-25 14:03:48.622 - debug: worx.0 (129330) {"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
              2024-08-25 14:03:48.628 - debug: worx.0 (129330) {"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
              2024-08-25 14:03:48.636 - debug: worx.0 (129330) {"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
              2024-08-25 14:03:48.649 - debug: worx.0 (129330) MOWER with full schedule: {"id":923901,"uuid":"98c93462-d518-4002-afad-c91894f61969","product_id":73,"user_id":503887,"serial_number":"202330294702002506EF","mac_address":"","locked":false,"firmware_version":"3.34.0+10","firmware_auto_upgrade":true,"sim":"","test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2023-05-27 00:00:00","online":true,"protocol":1,"pending_radio_link_validation":"","capabilities":["auto_lock","bluetooth_pairing","border_cut","display_pairing_shortcut","lock","mqtt","multi_zone_tag","one_time_scheduler","ota_upgrade","pause_over_border","rain_delay","unrestricted_mowing_time","vision"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandIn","command_out":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut"},"name":"falkomfs","blade_height_shift":0,"push_notifications":true,"push_notifications_level":"warning","pin_code":"","app_settings":"","warranty_registered":true,"purchased_at":"2023-05-27 00:00:00","warranty_expires_at":"2025-05-27 00:00:00","setup_location":{"latitude":52.72299989287376,"longitude":7.930778502216534},"city":{"id":2928809,"country_id":276,"name":"Essen","latitude":52.700001,"longitude":7.91667,"created_at":"2018-02-15 22:41:14","updated_at":"2018-02-15 22:41:14"},"time_zone":"Europe/Berlin","lawn_size":119.93579864502,"lawn_perimeter":28,"auto_schedule_settings":"","auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":284806,"mower_work_time":17976,"blade_work_time":17373,"blade_work_time_reset":0,"blade_work_time_reset_at":"","battery_charge_cycles":3491,"battery_charge_cycles_reset":0,"battery_charge_cycles_reset_at":"","created_at":"2023-03-28 06:50:27","updated_at":"2024-08-23 09:43:47","last_status":{"payload":{"cfg":{"id":51366,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":0,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":1,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":2,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":3,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":4,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":5,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":6,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF","request":0,"response":1724587428391,"action":"APP","user":"APP"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T12:03:48.231Z","ls":1,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":23,"v":19.4,"p":97,"nr":3513,"c":1,"m":0},"dmp":[-5.2,-0.9,17.1],"st":{"b":17442,"d":285736,"wt":18056,"bl":28},"rsi":-61,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}},"timestamp":"2024-08-25 14:03:48.389"},"last_gps_status":""}
              2024-08-25 14:03:48.700 - debug: worx.0 (129330) Count Zone: 1 - Count Passage: 0
              2024-08-25 14:03:48.701 - debug: worx.0 (129330) Count Receive Zone: 1 - Count Receive Passage: 0
              2024-08-25 14:03:48.701 - debug: worx.0 (129330) Write multi zone: {"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]}
              2024-08-25 14:03:49.554 - debug: worx.0 (129330) Mower MQTT: {"cfg":{"id":0,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0}},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T12:03:49.151Z","ls":3,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":23,"v":19.5,"p":97,"nr":3513,"c":0,"m":0},"dmp":[-5,-1,17.1],"st":{"b":17442,"d":285736,"wt":18056,"bl":28},"rsi":-61,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
              2024-08-25 14:03:49.554 - debug: worx.0 (129330) topic: WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut
              2024-08-25 14:03:49.554 - debug: worx.0 (129330) getQueueStatistics: {"incompleteOperationCount":0,"incompleteOperationSize":0,"unackedOperationCount":0,"unackedOperationSize":0}
              2024-08-25 14:03:49.554 - debug: worx.0 (129330) Worxcloud MQTT get Message for mower falkomfs (202330294702002506EF)
              2024-08-25 14:03:49.554 - debug: worx.0 (129330) Set new timestamp
              2024-08-25 14:03:49.645 - debug: worx.0 (129330) GET MQTT DATA from API: {"cfg":{"id":0,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T12:03:49.151Z","ls":3,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":23,"v":19.5,"p":97,"nr":3513,"c":0,"m":0},"dmp":[-5,-1,17.1],"st":{"b":17442,"d":285736,"wt":18056,"bl":28},"rsi":-61,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}}
              2024-08-25 14:03:49.653 - debug: worx.0 (129330) Test Status: 3
              2024-08-25 14:03:49.654 - debug: worx.0 (129330) SET loadActivity on true
              2024-08-25 14:03:49.656 - debug: worx.0 (129330) COUNTER: 7
              2024-08-25 14:03:49.656 - debug: worx.0 (129330) COUNTER SLOTS: 2
              2024-08-25 14:03:49.656 - debug: worx.0 (129330) {"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
              2024-08-25 14:03:49.704 - debug: worx.0 (129330) {"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
              2024-08-25 14:03:49.709 - debug: worx.0 (129330) {"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
              2024-08-25 14:03:49.714 - debug: worx.0 (129330) {"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
              2024-08-25 14:03:49.719 - debug: worx.0 (129330) {"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
              2024-08-25 14:03:49.725 - debug: worx.0 (129330) {"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
              2024-08-25 14:03:49.730 - debug: worx.0 (129330) {"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}}
              2024-08-25 14:03:49.745 - debug: worx.0 (129330) MOWER with full schedule: {"id":923901,"uuid":"98c93462-d518-4002-afad-c91894f61969","product_id":73,"user_id":503887,"serial_number":"202330294702002506EF","mac_address":"","locked":false,"firmware_version":"3.34.0+10","firmware_auto_upgrade":true,"sim":"","test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2023-05-27 00:00:00","online":true,"protocol":1,"pending_radio_link_validation":"","capabilities":["auto_lock","bluetooth_pairing","border_cut","display_pairing_shortcut","lock","mqtt","multi_zone_tag","one_time_scheduler","ota_upgrade","pause_over_border","rain_delay","unrestricted_mowing_time","vision"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandIn","command_out":"WX/MW/WR206E/98c93462-d518-4002-afad-c91894f61969/v1/commandOut"},"name":"falkomfs","blade_height_shift":0,"push_notifications":true,"push_notifications_level":"warning","pin_code":"","app_settings":"","warranty_registered":true,"purchased_at":"2023-05-27 00:00:00","warranty_expires_at":"2025-05-27 00:00:00","setup_location":{"latitude":52.72299989287376,"longitude":7.930778502216534},"city":{"id":2928809,"country_id":276,"name":"Essen","latitude":52.700001,"longitude":7.91667,"created_at":"2018-02-15 22:41:14","updated_at":"2018-02-15 22:41:14"},"time_zone":"Europe/Berlin","lawn_size":119.93579864502,"lawn_perimeter":28,"auto_schedule_settings":"","auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":284806,"mower_work_time":17976,"blade_work_time":17373,"blade_work_time_reset":0,"blade_work_time_reset_at":"","battery_charge_cycles":3491,"battery_charge_cycles_reset":0,"battery_charge_cycles_reset_at":"","created_at":"2023-03-28 06:50:27","updated_at":"2024-08-23 09:43:47","last_status":{"payload":{"cfg":{"id":0,"lg":"de","tz":"Europe/Berlin","log":{"imp":1,"diag":1},"rd":30,"cmd":101,"tq":0,"al":{"lvl":0,"t":60},"sc":{"enabled":1,"paused":0,"slots":[{"d":0,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":0,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":1,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":1,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":2,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":2,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":3,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":3,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":4,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":4,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":5,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":5,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}},{"d":6,"e":1,"s":600,"t":60,"cfg":{"cut":{"b":1,"z":[1]}}},{"e":0,"d":6,"s":0,"t":0,"cfg":{"cut":{"b":0,"z":[]}}}],"once":{"time":0,"cfg":{"cut":{"b":0,"z":[]}}}},"modules":{"DF":{"cut":1,"fh":0},"HL":{"enabled":0}},"cut":{"b":0,"z":[],"bd":0,"ob":0},"mz":{"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]},"vis":{"slab":0},"sn":"202330294702002506EF"},"dat":{"uuid":"98c93462-d518-4002-afad-c91894f61969","fw":"3.34.0+10","tm":"2024-08-25T12:03:49.151Z","ls":3,"le":0,"conn":"wifi","sc":{"slot":0,"once":0},"sh":0,"bt":{"t":23,"v":19.5,"p":97,"nr":3513,"c":0,"m":0},"dmp":[-5,-1,17.1],"st":{"b":17442,"d":285736,"wt":18056,"bl":28},"rsi":-61,"lk":0,"tr":0,"act":1,"rain":{"s":0,"cnt":0},"features":{"ble":0},"head":{"uuid":"98c93468-033a-4003-a039-739edc11f82b","act":1,"fw":"1.2.31+9"},"modules":{"DF":{"stat":"ok"}},"mac":"505A65D9387F","cam":{"status":0,"error":0},"rfid":{"status":0},"mz":[{"id":1,"p":28274,"a":64623937}],"cut":{"z":1}}},"timestamp":"2024-08-25 14:03:49.554"},"last_gps_status":""}
              2024-08-25 14:03:49.794 - debug: worx.0 (129330) Count Zone: 1 - Count Passage: 0
              2024-08-25 14:03:49.794 - debug: worx.0 (129330) Count Receive Zone: 1 - Count Receive Passage: 0
              2024-08-25 14:03:49.794 - debug: worx.0 (129330) Write multi zone: {"p":[],"s":[{"id":1,"c":1,"cfg":{"cut":{"bd":200,"ob":0}}}]}
                @falkomfs OK, die APP scheint dann auch nur die 101 zu versenden. Mich würde natürlich jetzt noch interessieren was User mit mehr als 1 Zone edgecut starten. Können diese dann noch die Zone auswählen oder werden alle Zonen angefahren....hmmmm
                  @lucky_esa sagte in Adapter Worx Landroid v3.x.x:
                  ja da kann ich leider nicht helfen. Bei mir reicht das auch so, der fährt jetzt schön 8 mal den Rand ab mit den unterschiedlichen Entfernungseinstellungen die er hat und das sieht recht sauber aus. Vorher hat er immer irgendwie einen Rand gelassen, der ist jetzt weg.
                  Also von mir vielen Dank für die Mühe.
                  • hsteinme
                    hsteinme last edited by
                    Die Positec'schen Drahtmäher kennen eigentlich keinen Kantenschnitt-Befehl. Der Worx-Adapter nutzt - wie manch andere Anwendung auch - einen "Indianertrick": Das Makro "edgecut" wird aus drei geschickt angeordneten Einzelbefehlen zusammengebastelt:
                    • Zonentraining, um den Mäher auf kürzestem Wege Richtung Draht zu schicken
                    • Pause
                    • Heimfahrt
                    Die letztgenannte Aktion schaltet die Messer ein und schickt den Mäher über den Draht zur Ladestation.
                    Dies ist wie gesagt eine "Sonderlocke" für Drahtmäher, die bei anderen Mähertypen einfach nicht funktionieren kann.
                    @Lucky_ESA
                    • Bitte diesen Datenpunkt bei Nicht-Drahtmähern nicht anbieten.
                    • Bitte die Dokumentation entsprechend anpassen (bei den Instanzeinstellungen und bei mower.edgecut)
                    Die App bietet keine Zonenauswahl an. Ich gehe davon aus (da mir mangels Zonen die Testmöglichkeit fehlt), dass die Ränder aller Zonen geschnitten werden. Aber das ist ja nicht das einzige Mal, wo die Worx App die von der API angebotene Funktionalität nicht voll weiterreicht (Beispiel: zeitlich begrenzter Partymodus). Aber ioBroker User können ja die Zonenauswahl über oneTimeZones (oder über oneTimeJson) bewerkstelligen.
                    Heißt dies, dass Dein Skript eine Vierfach-Schleife über multiZones.zones.zone_0.borderDistance enthält und dass bei jeder Schleifenrunde der Kantenschnitt aufgerufen wird? Ein kluger Ansatz!
                      falkomfs @hsteinme last edited by
                      @hsteinme sagte in Adapter Worx Landroid v3.x.x:
                      Im Prinzip sogar 8 mal, 4 mal mit "multiZones.zones.zone_0.cutOverBorder " Yes und 4 mal no die jeweiligen mm Abstand
                      • Dr. Bakterius
                        Dr. Bakterius Most Active last edited by
                        Mal eine andere Frage auf die ich zumindest keine Antwort gefunden habe.
                        Wenn ich in der App die Klingenstandzeit resette, wird das im Adapter nicht registriert und er zählt einfach weiter. Gibt es dafür eine Lösung? Oder muss ich in einem Skript den aktuellen Wert vom letzten Wechselwert abziehen um die korrekte Standzeit zu erhalten?
                        Eventuell ist das beim Akku auch der Fall. Den habe ich allerdings noch nicht getauscht.
                          Lucky_ESA Developer Most Active @Dr. Bakterius last edited by Lucky_ESA
                          @dr-bakterius sagte in Adapter Worx Landroid v3.x.x:
                          Du musst die Zeit selber berechnen. Dafür gibt es im Forum viele Scripte und Anleitungen. Habe aber gerade kein Link zur Hand, sorry.
                          EDIT: Suche Worx Klingen Script
                          https://forum.iobroker.net/topic/4834/adapter-worx-landroid-v2-x-x/344
                          EDIT2: Oder setze die Klingenarbeitszeit mit dem Adapter zurück und speicher dir die Gesamtzeit in einen State.
                          Gruß//Lucky
                          hsteinme Dr. Bakterius 2 Replies Last reply Reply Quote 1
                          • hsteinme
                            hsteinme @Lucky_ESA last edited by
                            Zum Hintergrund siehe auch https://forum.iobroker.net/topic/4834/adapter-worx-landroid-v2-x-x/342?_=1724697826242
                            • Dr. Bakterius
                              Dr. Bakterius Most Active @Lucky_ESA last edited by
                              Danke. Ich mache das jetzt direkt in der VIS.
                              {wert1:worx.0.***************.rawMqtt.last_status.payload.dat.st.b; wert2:worx.0.***************.rawMqtt.blade_work_time_reset; "Klingenstandzeit: "+(((+wert1)-(+wert2))/60).toFixed(1)+" Stunden"}
                              • hsteinme
                                hsteinme @hsteinme last edited by hsteinme
                                Wird in oneTimeJson
                                { "time": 30, "cfg": { "cut": { "b": 1, "z": [] } } }
                                eingetragen, so fährt der Mäher zum Mähen. Ob er zum Abschluss die Kante mäht? Dazu fehlte mir leider die Zeit, dies zu überprüfen.
                                @falkomfs sagte in Adapter Worx Landroid v3.x.x:
                                das habe ich dann mal geprüft. Nein, im Anschluss macht er auch keinen Kantenschnitt.
                                Ich habe den Test nun selbst durchgeführt. Bei zwei Testläufen hat der Mäher nach jeweils 25 Minuten den Mähvorgang beendet und den Kantenschnitt begonnen.
                                Der Test erfolgte mit der Version 1.2.31+9 - 3.34.9+10.
                                  Lucky_ESA Developer Most Active @hsteinme last edited by
                                  @hsteinme Habe den Faden verloren...Wenn ein Vision User den edgecut Button drückt versendet der Adapter jetzt cmd: 101
                                  Das sollte doch nun funktionieren, hoffe ich...
                                  hsteinme 1 Reply Last reply Reply Quote 0
                                  • hsteinme
                                    Laut https://forum.iobroker.net/post/1194756 funktioniert dies bestens.
                                    Im vorhergehenden Post hatte ich den One Time Scheduler mit Kantenschnitt getestet, weil @falkomfs meinte, dass bei ihm der Kantenschnitt beim One Time Scheduler nicht durchgeführt wurde.
                                      BlueTang last edited by
                                      Ich bin neu hier und habe eine Frage zum Adapter Worx Landroid v3.1.1. Was genau bewirkt der state switch mowerActive, Zeitgesteuertes Mähen, Time-controlled mowing? Ich habe ihn mal im Adapter auf "OFF" gesetzt, aber der Mähvorgang entsprechend Automatischem als auch Manuellem Zeitplan wird wie vorgegeben ausgeführt. Ich hatte zunächst gedacht, dass man ähnlich zum Party Modus das zeitgesteuerte Mähen aussetzen kann? So hätte ich auch die Erklärung in der README: mowerActive: Pause mowing plan (wire/changeable) verstanden. Ebenfalls konnte ich keine Änderung in der Landroid Smartphone App feststellen.
                                      Für Erklärungen wäre ich dankbar.
                                        Lucky_ESA Developer Most Active @BlueTang last edited by
                                        @bluetang Upps, so wie es aussieht muss 1 oder 2 gesetzt werden. Der Adapter setzt aber 1 und 0. Kann das wahrscheinlich erst zur nächsten Saison prüfen. (mein Mäher ist eingelagert daher kann ich nicht testen).
                                        @hsteinme
                                        Weißt du welcher Wert gesetzt werden muss?
                                        Gruß//Lucky
                                        • hsteinme
                                          @lucky_esa Das hatte mich immer schon mal interessiert 😊 Schau mal hier hin.
                                          Ich kann nur mit einem Statement Deines Amtsvorgängers @MeisterTr aus dem Jahr 2017 dienen:
                                          "Dieser Datenpunkt stellt die Mähzeiten aus und an."
                                          Sag mir doch mal bitte, welches API-Element zu diesem Datenpunkt gehört. Vielleicht kann ich dann eher eine Erklärung finden ...
                                            @hsteinme
                                            Aber dann hat das noch nie funktioniert oder die API wurde geändert. Bei mir sehe ich eine 2.
                                            Es wird cfg.sc.m gesetzt und cfg.sc.distm und cfg.sc.ots gelöscht.
                                            Wenn das eine Funktion hat, dann dürfte der Mäher bei true nicht losfahren. Derzeit kann man eine 2 nicht setzen.
                                               	"sc": {
                                               		"m": 2, // Dieser wird mit 1 oder 0 gesetzt
                                               		"d": [
                                               				"00:00",
                                               				0,
                                               				0
                                               				"11:00",
                                               				60,
                                               				"11:00",
                                               				150,
                                               				0
                                               				"11:00",
                                               				60,
                                               				0
                                               				"11:00",
                                               				60,
                                               				"11:00",
                                               				60,
                                               				0
                                               				"11:00",
                                               				150,
                                               				0
                                               		"dd": [
                                               				"00:00",
                                               				0,
                                               				0
                                               				"18:00",
                                               				60,
                                               				0
                                               				"17:30",
                                               				150,
                                               				0
                                               				"18:00",
                                               				60,
                                               				0
                                               				"18:00",
                                               				60,
                                               				0
                                               				"18:00",
                                               				60,
                                               				0
                                               				"17:30",
                                               				150,
                                               				0
                                               		"distm": 0, // Dieser wird gelöscht
                                               		"p": 0,
                                               		"ots": { // Dieser wird gelöscht
                                               			"wtm": 90,
                                               			"bc": 0
                                            788
                                            122685
