    3. Einsteigerfragen
    4. Installation
    5. Update js-controller from @6.0.7 to @6.0.11 nicht möglich
    • MartinP
      MartinP @Homoran last edited by
      @enzo Um die Langfassung zu kopieren, sollte man NICHT den angeforderten Tastendruck (press any key for summary) für die Zusammenfassung im Ablauf auslösen, sondern zuerst die Output-Kopie anfertigen. Für die Summary wird der Screen gelöscht, und man muss von vorne beginnen!
      Thomas Braun enzo 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @MartinP last edited by
        @martinp
        Oder man klaubt das log aus dem home des iobrokers:
        echad@chet:~ $ ls -la /home/iobroker/iob_diag.log
        -rw-r--r-- 1 iobroker iobroker 34801 Aug 26 22:05 /home/iobroker/iob_diag.log
        • enzo
          enzo @Guest last edited by
          @mrs-antje danke für die hilfe mein deutsch ist nicht so gut.
            Thomas Braun Most Active @enzo last edited by
            @enzo
            Hi!
            We would need the long version of
            iob diag
            so we can better support you.
              Homoran Global Moderator Administrators @enzo last edited by
              @enzo sagte in Update js-controller from @6.0.7 to @6.0.11 nicht möglich:
              no problem, try in english or what else.
              but if it's italiano I can't help
              • enzo
                enzo @MartinP last edited by
                @martinp ok
                bin nicht so fit mit Linux
                enzo 1 Reply Last reply Reply Quote 0
                • enzo
                  enzo @enzo last edited by
                  Homoran enzo 2 Replies Last reply Reply Quote 0
                    Homoran Global Moderator Administrators @enzo last edited by Homoran
                    @enzo please enter iob diag in the console
                    start the script and don't hit any key afterwards
                    copy the output and post it here
                    by pressing any key the long version disappears and the summary appears.
                    but this summary does not contain the infos we need.
                    no problem, we will guide you.
                    • enzo
                      @enzo ======== Start marking the full check here =========
                      Skript v.2024-05-22
                      *** BASE SYSTEM ***
                         Static hostname: iobroker
                               Icon name: computer
                        Operating System: Debian GNU/Linux 11 (bullseye)
                                  Kernel: Linux 6.1.21-v8+
                            Architecture: arm64
                      Model           : Raspberry Pi 4 Model B Rev 1.1
                      Docker          : false
                      Virtualization  : none
                      Kernel          : aarch64
                      Userland        : 64 bit
                      Systemuptime and Load:
                       20:30:00 up  5:46,  1 user,  load average: 1.93, 2.01, 1.59
                      CPU threads: 4
                      *** RASPBERRY THROTTLING ***
                      Current issues:
                      Previously detected issues:
                      *** Time and Time Zones ***
                                     Local time: Tue 2024-08-27 20:30:00 CEST
                                 Universal time: Tue 2024-08-27 18:30:00 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      *** Users and Groups ***
                      User that called 'iob diag':
                      iobroker
                      HOME=/home/iobroker
                      GROUPS=iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gp        io i2c spi
                      iobroker
                      HOME=/home/iobroker
                      *** Display-Server-Setup ***
                      Display-Server: false
                      Desktop:
                      Terminal:       tty
                      Boot Target:    multi-user.target
                      *** MEMORY ***
                      Mem:            3.8G        2.5G        626M        1.0M        705M        1.3G
                      Swap:            99M          0B         99M
                      Total:          3.9G        2.5G        726M
                      Active iob-Instances:   40
                               3793 M total memory
                               2461 M used memory
                               2616 M active memory
                                396 M inactive memory
                                626 M free memory
                                188 M buffer memory
                                517 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      top - 20:30:00 up  5:46,  1 user,  load average: 1.93, 2.01, 1.59
                      Tasks: 192 total,   3 running, 189 sleeping,   0 stopped,   0 zombie
                      %Cpu(s): 31.9 us, 11.1 sy,  0.0 ni, 55.6 id,  0.0 wa,  0.0 hi,  1.4 si,  0.0 st
                      MiB Mem :   3793.3 total,    630.0 free,   2457.2 used,    706.1 buff/cache
                      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   1259.6 avail Mem
                      *** FAILED SERVICES ***
                      0 loaded units listed.
                      *** FILESYSTEM ***
                      /dev/root      ext4      234G   20G  203G   9% /
                      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                      tmpfs          tmpfs     759M  1.2M  758M   1% /run
                      /dev/sda1      vfat       94M   31M   64M  33% /boot
                      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                      [sudo] password for iobroker:
                      [Tue Aug 27 14:43:52 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:03:CD:DA vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2e420cd8-02 rootfstype=ext4 fsck.repair=yes rootwait
                      [Tue Aug 27 14:43:54 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                      [Tue Aug 27 14:43:54 2024] EXT4-fs (sda2): write access will be enabled during recovery
                      [Tue Aug 27 14:43:58 2024] EXT4-fs (sda2): recovery complete
                      [Tue Aug 27 14:43:58 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                      [Tue Aug 27 14:43:58 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                      [Tue Aug 27 14:44:00 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                      Show mounted filesystems:
                      TARGET                       SOURCE     FSTYPE     OPTIONS
                      /                            /dev/sda2  ext4       rw,noatime,stripe=8191
                      |-/dev                       devtmpfs   devtmpfs   rw,relatime,size=1677960k,nr_inodes=419490,mode=755
                      | |-/dev/shm                 tmpfs      tmpfs      rw,nosuid,nodev
                      | |-/dev/pts                 devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                      | `-/dev/mqueue              mqueue     mqueue     rw,nosuid,nodev,noexec,relatime
                      |-/proc                      proc       proc       rw,relatime
                      | `-/proc/sys/fs/binfmt_misc systemd-1  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                      |-/sys                       sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
                      | |-/sys/kernel/security     securityfs securityfs rw,nosuid,nodev,noexec,relatime
                      | |-/sys/fs/cgroup           cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                      | |-/sys/fs/pstore           pstore     pstore     rw,nosuid,nodev,noexec,relatime
                      | |-/sys/fs/bpf              bpf        bpf        rw,nosuid,nodev,noexec,relatime,mode=700
                      | |-/sys/kernel/debug        debugfs    debugfs    rw,nosuid,nodev,noexec,relatime
                      | |-/sys/kernel/tracing      tracefs    tracefs    rw,nosuid,nodev,noexec,relatime
                      | |-/sys/kernel/config       configfs   configfs   rw,nosuid,nodev,noexec,relatime
                      | `-/sys/fs/fuse/connections fusectl    fusectl    rw,nosuid,nodev,noexec,relatime
                      |-/run                       tmpfs      tmpfs      rw,nosuid,nodev,size=776876k,nr_inodes=819200,mode=755
                      | |-/run/lock                tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
                      | |-/run/rpc_pipefs          sunrpc     rpc_pipefs rw,relatime
                      | `-/run/user/1000           tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=388436k,nr_inodes=97109,mode=700,uid=1000,gid=1000
                      `-/boot                      /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      /var:
                      4.9G    /var/
                      4.1G    /var/log/journal/b90929d3efd64b92af5b6ca0e1d4d7ff
                      4.1G    /var/log
                      641M    /var/cache
                      Archived and active journals take up 4.0G in the file system.
                      /opt/iobroker/backups:
                      1.2G    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      2.6G    /opt/iobroker/iobroker-data/
                      1.6G    /opt/iobroker/iobroker-data/history
                      875M    /opt/iobroker/iobroker-data/files
                      493M    /opt/iobroker/iobroker-data/files/javascript.admin
                      461M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                      29M     /opt/iobroker/iobroker-data/objects.jsonl
                      26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.bad2715c.js.map
                      26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.bad2715c.js.map
                      24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.6c4f5a4e.js.map
                      USB-Devices by-id:
                      No Devices found 'by-id'
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v20.17.0
                      /usr/bin/node           v20.17.0
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      /usr/bin/corepack       0.29.3
                      nodejs:
                        Installed: 20.17.0-1nodesource1
                        Candidate: 20.17.0-1nodesource1
                        Version table:
                       *** 20.17.0-1nodesource1 600
                              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                              100 /var/lib/dpkg/status
                           20.16.0-1nodesource1 600
                           20.15.1-1nodesource1 600
                           20.15.0-1nodesource1 600
                           20.14.0-1nodesource1 600
                           20.13.1-1nodesource1 600
                           20.13.0-1nodesource1 600
                           20.12.2-1nodesource1 600
                           20.12.1-1nodesource1 600
                           20.12.0-1nodesource1 600
                           20.11.1-1nodesource1 600
                           20.11.0-1nodesource1 600
                           20.10.0-1nodesource1 600
                           20.9.0-1nodesource1 600
                           20.8.1-1nodesource1 600
                           20.8.0-1nodesource1 600
                           20.7.0-1nodesource1 600
                           20.6.1-1nodesource1 600
                           20.6.0-1nodesource1 600
                           20.5.1-1nodesource1 600
                           20.5.0-1nodesource1 600
                           20.4.0-1nodesource1 600
                           20.3.1-1nodesource1 600
                           20.3.0-1nodesource1 600
                           20.2.0-1nodesource1 600
                           20.1.0-1nodesource1 600
                           20.0.0-1nodesource1 600
                           12.22.12~dfsg-1~deb11u4 500
                              500 http://deb.debian.org/debian bullseye/main arm64 Packages
                              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                      No problems detected
                      Errors in npm tree:
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Core adapters versions
                      js-controller:  6.0.7
                      admin:          7.0.25
                      javascript:     8.8.2
                      nodejs modules from github:     3
                      +-- @iobroker/plugin-sentry@2.0.4 (git+ssh://git@github.com/ioBroker/plugin-sentry.git#f15de95b95fdd466e7a0ea558f3f54efd5e2c8bb)
                      +-- iobroker.opendtu@2.0.0 (git+ssh://git@github.com/o0shojo0o/ioBroker.opendtu.git#dd46be2f6e5a0096a0c7b376cdd2560efe4dc739)
                      +-- iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#de8c1ad97edafedb16cbbb2c6dc14b032848df8e)
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                      + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                        system.adapter.devices.0                : devices               : iobroker                                 - disabled
                      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                      + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                      + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                        system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
                      + system.adapter.history.0                : history               : iobroker                                 -  enabled
                      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                      + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
                      + system.adapter.hs100.0                  : hs100                 : iobroker                                 -  enabled
                      + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
                      + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                      + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
                      + system.adapter.mihome-cloud.0           : mihome-cloud          : iobroker                                 -  enabled
                      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
                      + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
                      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                      + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                      + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.178.94
                      + system.adapter.shelly.2                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.94
                      + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
                      + system.adapter.switchbot-hub.0          : switchbot-hub         : iobroker                                 -  enabled
                      + system.adapter.tapo.0                   : tapo                  : iobroker                                 -  enabled
                      + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                      + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                      + system.adapter.tr-064.2                 : tr-064                : iobroker                                 -  enabled
                      + system.adapter.tr-064.3                 : tr-064                : iobroker                                 -  enabled
                      + system.adapter.tr-064.4                 : tr-064                : iobroker                                 -  enabled
                      + system.adapter.tr-064.5                 : tr-064                : iobroker                                 -  enabled
                      + system.adapter.tr-064.7                 : tr-064                : iobroker                                 -  enabled
                      + system.adapter.tradfri.0                : tradfri               : iobroker                                 -  enabled
                        system.adapter.tuya.0                   : tuya                  : iobroker                                 - disabled
                        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + system.adapter.zendure-solarflow.1      : zendure-solarflow     : iobroker                                 -  enabled
                      + instance is alive
                      ioBroker-Repositories
                      Active repo(s): beta
                      Upgrade policy: none
                      Installed ioBroker-Instances
                      Used repository: beta
                      Adapter    "admin"        : 7.0.25   , installed 7.0.25
                      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                      Adapter    "backitup"     : 3.0.20   , installed 3.0.20
                      Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
                      Adapter    "echarts"      : 1.9.0    , installed 1.9.0
                      Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
                      Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                      Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
                      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                      Adapter    "hmip"         : 1.24.1   , installed 1.24.1
                      Adapter    "hs100"        : 2.2.0    , installed 2.2.0
                      Adapter    "hue"          : 3.12.0   , installed 3.12.0
                      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                      Adapter    "javascript"   : 8.8.2    , installed 8.8.2
                      Controller "js-controller": 6.0.11   , installed 6.0.7  [Updatable]
                      Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
                      Adapter    "mihome-cloud" : 0.1.1    , installed 0.1.1
                      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                      Adapter    "opendtu"      : 2.0.0    , installed 2.0.0
                      Adapter    "ping"         : 1.7.3    , installed 1.7.3
                      Adapter    "rpi2"         : 2.0.0    , installed 2.0.0
                      Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                      Adapter    "shelly"       : 8.1.1    , installed 8.0.0  [Updatable]
                      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                      Adapter    "tapo"         : 0.3.3    , installed 0.3.3
                      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                      Adapter    "text2command" : 3.0.3    , installed 3.0.3
                      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                      Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
                      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                      Adapter    "web"          : 6.3.0    , installed 6.3.0
                      Adapter    "ws"           : 2.6.2    , installed 2.6.2
                      Adapter    "zendure-solarflow": 1.8.5, installed 1.8.5
                      Objects and States
                      Objects:        9864
                      States:         7454
                      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                      Hit:2 http://deb.debian.org/debian bullseye InRelease
                      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Reading package lists...
                      Pending Updates: 0
                      *** Listening Ports ***
                      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       14895      1387/node-red
                      tcp        0      0 192.168.178.95:2001     0.0.0.0:*               LISTEN      1000       15761      1432/io.hm-rpc.0
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       12208      491/iobroker.js-con
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       14573      491/iobroker.js-con
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14524      533/sshd: /usr/sbin
                      tcp        0      0 192.168.178.94:1883     0.0.0.0:*               LISTEN      1000       15190      1614/io.shelly.2
                      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       18107      1890/io.jarvis.0
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       15590      1139/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       16383      2352/io.web.0
                      tcp6       0      0 :::8088                 :::*                    LISTEN      1000       16260      2053/io.terminal.0
                      tcp6       0      0 :::8091                 :::*                    LISTEN      1000       17276      1919/io.lovelace.0
                      tcp6       0      0 :::3500                 :::*                    LISTEN      1000       15223      1796/io.sonos.0
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          14526      533/sshd: /usr/sbin
                      udp        0      0 192.168.178.95:5353     0.0.0.0:*                           1000       17045      1805/io.tr-064.0
                      udp        0      0 192.168.178.94:5353     0.0.0.0:*                           1000       17044      1805/io.tr-064.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       16536      1353/io.chromecast.
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13797      396/avahi-daemon: r
                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       15145      1600/io.shelly.0
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12195      868/dhcpcd
                      udp        0      0 0.0.0.0:49377           0.0.0.0:*                           1000       19935      2110/io.tradfri.0
                      udp        0      0 0.0.0.0:49687           0.0.0.0:*                           108        13799      396/avahi-daemon: r
                      udp6       0      0 :::35531                :::*                                108        13800      396/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                108        13798      396/avahi-daemon: r
                      udp6       0      0 :::546                  :::*                                0          12206      868/dhcpcd
                      2024-08-27 20:32:02.825  - info: chromecast.0 (1353) Cosmos - getStatus
                      2024-08-27 20:32:02.833  - info: chromecast.0 (1353) Cosmos - getStatus
                      2024-08-27 20:32:02.851  - info: chromecast.0 (1353) Cosmos - getStatus
                      2024-08-27 20:32:02.867  - info: chromecast.0 (1353) Cosmos - getStatus
                      2024-08-27 20:32:02.871  - info: chromecast.0 (1353) Cosmos - getStatus
                      2024-08-27 20:32:02.872  - info: chromecast.0 (1353) Cosmos - getStatus
                      2024-08-27 20:32:02.874  - info: chromecast.0 (1353) Cosmos - getStatus
                      2024-08-27 20:32:02.891  - info: chromecast.0 (1353) Cosmos - getStatus
                      2024-08-27 20:32:02.919  - info: chromecast.0 (1353) Cosmos - getStatus
                      2024-08-27 20:32:02.929  - info: chromecast.0 (1353) Cosmos - getStatus
                      2024-08-27 20:32:02.932  - info: chromecast.0 (1353) Cosmos - getStatus
                      2024-08-27 20:32:02.941  - info: chromecast.0 (1353) Cosmos - getStatus
                      2024-08-27 20:32:02.962  - info: chromecast.0 (1353) Cosmos - getStatus
                      2024-08-27 20:32:02.976  - info: chromecast.0 (1353) Cosmos - getStatus
                      2024-08-27 20:32:02.977  - info: chromecast.0 (1353) Cosmos - getStatus
                      2024-08-27 20:32:02.978  - info: chromecast.0 (1353) Cosmos - getStatus
                      2024-08-27 20:32:02.979  - info: chromecast.0 (1353) Cosmos - getStatus
                      2024-08-27 20:32:02.980  - info: chromecast.0 (1353) Cosmos - getStatus
                      2024-08-27 20:32:02.985  - info: chromecast.0 (1353) Cosmos - getStatus
                      2024-08-27 20:32:02.986  - info: chromecast.0 (1353) Cosmos - getStatus
                      2024-08-27 20:32:02.987  - info: chromecast.0 (1353) Cosmos - getStatus
                      2024-08-27 20:32:02.988  - info: chromecast.0 (1353) Cosmos - getStatus
                      iob diag has finished.
                      Press any key for a summary
                      Homoran Thomas Braun 2 Replies Last reply Reply Quote 1
                        your filesystem has been corrupted.
                        this is your problem?
                        I cannot see any obstacles for grading up.
                        maybe @Thomas-Braun will see better than me
                          I think that github-Version of @iobroker/plugin-sentry is the blocking item. Wherever this version comes from.
                          On my system:
                          echad@chet:/opt/iobroker $ npm ls @iobroker/plugin-sentry
                          iobroker.inst@3.0.0 /opt/iobroker
                          └─┬ iobroker.js-controller@6.0.11
                            ├─┬ @iobroker/js-controller-adapter@6.0.11
                            │ └── @iobroker/plugin-sentry@1.2.1 deduped
                          Try reinstalling js-controller with clean dependencies:
                          iob stop
                          cd /opt/iobroker && npm install iobroker.js-controller@6.0.11
                          iob start
                          • enzo
                            enzo @Thomas Braun last edited by
                            ok mache ich.
                            • enzo
                              enzo @Thomas Braun last edited by Homoran
                              iobroker@iobroker:~ $ iob stop
                              iobroker@iobroker:~ $ cd /opt/iobroker && npm install iobroker.js-controller@6.0.11
                              npm error code 6
                              npm error path /opt/iobroker/node_modules/iobroker.js-controller
                              npm error command failed
                              npm error command sh -c node iobroker.js setup first
                              npm error Uncaught Rejection: TypeError: callback is not a function
                              npm error     at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
                              npm error This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                              npm error TypeError: callback is not a function
                              npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-27T18_54_51_254Z-debug-0.log
                              iobroker@iobroker:/opt/iobroker $
                                A Former User @enzo last edited by
                                Hallo @Homoran
                                Hallo @Thomas-Braun
                                Ich denke wir können wieder auf Deutsch weitermachen ✌️
                                Das verstehe ich als Niederländerin besser 😉
                                Macht es Sinn den Controller upzudaten, wenn das Filesystem kaputt ist?
                                Samson71 enzo 2 Replies Last reply Reply Quote 0
                                • Samson71
                                  Samson71 Global Moderator @Guest last edited by
                                  @mrs-antje sagte in Update js-controller from @6.0.7 to @6.0.11 nicht möglich:
                                  Dass es hier in keiner Weise um Dich, sondern um @enzo geht, der nach eigenem Bekunden in Deutsch nicht so fit ist, hast Du aber noch auf dem Schirm oder?
                                  ? 1 Reply Last reply Reply Quote 1
                                  • enzo
                                    enzo @Guest last edited by enzo
                                    @mrs-antje der iobroker läuft Ganz gut nur der js-controller@6.0.7 kann ich nicht ab und Downgraden .
                                    mit google translater geht es ja.
                                    und nochmal danke an alle die mir so gut helfen ich weis das zu Schätzen.
                                      @enzo
                                      Is it possible that you manage to manually install the js-controller in recursive directories?
                                      That path/file does not exist on my system:
                                      but
                                      /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js
                                      It seems as if you did install a non-standard version of js-controller into the js-controller directory again.
                                        A Former User @Samson71 last edited by
                                        Hallo @samson71
                                        und da hilft ein Thread halb deutsch/ halb englisch den Leuten, die helfen wollen oder hier eine Lösung vielleicht finden, weiter?
                                        Wenn hier nur die Experten helfen sollen, okay.
                                        Hatte mich angemeldet , weil ich auch endlich helfen wollte , nachdem ich hier lange mitgelesen und einiges mitgenommen habe.
                                        Vielleicht liegt es auch daran, dass ich eine Frau bin.
                                        Who knows.
                                        Aber weil ein User schreibt , dass er nicht gut deutsch spricht , gleich mal die Sprache zu wechseln, obwohl der User anscheinend 40 Adapter gut auf deutsch einrichten konnte und hier bisher auch nur deutsch schreibt …..
                                        Aber Du bist der Moderator hier…..hast mich ja auch nett Willkommen geheißen ✌️
                                          Nein, warum sollte es?
                                          Who knows.
                                          I do.
                                            @enzo
                                            cd /opt/iobroker/node_modules/iobroker.js-controller && npm ls
                                            4168
