    3. Einsteigerfragen
    4. Installation
    5. Update js-controller from @6.0.7 to @6.0.11 nicht möglich
    • enzo
      enzo @Guest last edited by
      @mrs-antje danke für die hilfe mein deutsch ist nicht so gut.
        Thomas Braun Most Active @enzo last edited by
        @enzo
        Hi!
        We would need the long version of
        iob diag
        so we can better support you.
          Homoran Global Moderator Administrators @enzo last edited by
          @enzo sagte in Update js-controller from @6.0.7 to @6.0.11 nicht möglich:
          no problem, try in english or what else.
          but if it's italiano I can't help
          • enzo
            enzo @MartinP last edited by
            @martinp ok
            bin nicht so fit mit Linux
            enzo 1 Reply Last reply Reply Quote 0
            • enzo
              enzo @enzo last edited by
              Homoran enzo 2 Replies Last reply Reply Quote 0
                Homoran Global Moderator Administrators @enzo last edited by Homoran
                @enzo please enter iob diag in the console
                start the script and don't hit any key afterwards
                copy the output and post it here
                by pressing any key the long version disappears and the summary appears.
                but this summary does not contain the infos we need.
                no problem, we will guide you.
                • enzo
                  @enzo ======== Start marking the full check here =========
                  Skript v.2024-05-22
                  *** BASE SYSTEM ***
                     Static hostname: iobroker
                           Icon name: computer
                    Operating System: Debian GNU/Linux 11 (bullseye)
                              Kernel: Linux 6.1.21-v8+
                        Architecture: arm64
                  Model           : Raspberry Pi 4 Model B Rev 1.1
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : 64 bit
                  Systemuptime and Load:
                   20:30:00 up  5:46,  1 user,  load average: 1.93, 2.01, 1.59
                  CPU threads: 4
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** Time and Time Zones ***
                                 Local time: Tue 2024-08-27 20:30:00 CEST
                             Universal time: Tue 2024-08-27 18:30:00 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  iobroker
                  HOME=/home/iobroker
                  GROUPS=iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gp        io i2c spi
                  iobroker
                  HOME=/home/iobroker
                  *** Display-Server-Setup ***
                  Display-Server: false
                  Desktop:
                  Terminal:       tty
                  Boot Target:    multi-user.target
                  *** MEMORY ***
                  Mem:            3.8G        2.5G        626M        1.0M        705M        1.3G
                  Swap:            99M          0B         99M
                  Total:          3.9G        2.5G        726M
                  Active iob-Instances:   40
                           3793 M total memory
                           2461 M used memory
                           2616 M active memory
                            396 M inactive memory
                            626 M free memory
                            188 M buffer memory
                            517 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  top - 20:30:00 up  5:46,  1 user,  load average: 1.93, 2.01, 1.59
                  Tasks: 192 total,   3 running, 189 sleeping,   0 stopped,   0 zombie
                  %Cpu(s): 31.9 us, 11.1 sy,  0.0 ni, 55.6 id,  0.0 wa,  0.0 hi,  1.4 si,  0.0 st
                  MiB Mem :   3793.3 total,    630.0 free,   2457.2 used,    706.1 buff/cache
                  MiB Swap:    100.0 total,    100.0 free,      0.0 used.   1259.6 avail Mem
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** FILESYSTEM ***
                  /dev/root      ext4      234G   20G  203G   9% /
                  devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                  tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                  tmpfs          tmpfs     759M  1.2M  758M   1% /run
                  /dev/sda1      vfat       94M   31M   64M  33% /boot
                  tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                  [sudo] password for iobroker:
                  [Tue Aug 27 14:43:52 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:03:CD:DA vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2e420cd8-02 rootfstype=ext4 fsck.repair=yes rootwait
                  [Tue Aug 27 14:43:54 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                  [Tue Aug 27 14:43:54 2024] EXT4-fs (sda2): write access will be enabled during recovery
                  [Tue Aug 27 14:43:58 2024] EXT4-fs (sda2): recovery complete
                  [Tue Aug 27 14:43:58 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                  [Tue Aug 27 14:43:58 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                  [Tue Aug 27 14:44:00 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                  Show mounted filesystems:
                  TARGET                       SOURCE     FSTYPE     OPTIONS
                  /                            /dev/sda2  ext4       rw,noatime,stripe=8191
                  |-/dev                       devtmpfs   devtmpfs   rw,relatime,size=1677960k,nr_inodes=419490,mode=755
                  | |-/dev/shm                 tmpfs      tmpfs      rw,nosuid,nodev
                  | |-/dev/pts                 devpts     devpts     rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                  | `-/dev/mqueue              mqueue     mqueue     rw,nosuid,nodev,noexec,relatime
                  |-/proc                      proc       proc       rw,relatime
                  | `-/proc/sys/fs/binfmt_misc systemd-1  autofs     rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                  |-/sys                       sysfs      sysfs      rw,nosuid,nodev,noexec,relatime
                  | |-/sys/kernel/security     securityfs securityfs rw,nosuid,nodev,noexec,relatime
                  | |-/sys/fs/cgroup           cgroup2    cgroup2    rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                  | |-/sys/fs/pstore           pstore     pstore     rw,nosuid,nodev,noexec,relatime
                  | |-/sys/fs/bpf              bpf        bpf        rw,nosuid,nodev,noexec,relatime,mode=700
                  | |-/sys/kernel/debug        debugfs    debugfs    rw,nosuid,nodev,noexec,relatime
                  | |-/sys/kernel/tracing      tracefs    tracefs    rw,nosuid,nodev,noexec,relatime
                  | |-/sys/kernel/config       configfs   configfs   rw,nosuid,nodev,noexec,relatime
                  | `-/sys/fs/fuse/connections fusectl    fusectl    rw,nosuid,nodev,noexec,relatime
                  |-/run                       tmpfs      tmpfs      rw,nosuid,nodev,size=776876k,nr_inodes=819200,mode=755
                  | |-/run/lock                tmpfs      tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k
                  | |-/run/rpc_pipefs          sunrpc     rpc_pipefs rw,relatime
                  | `-/run/user/1000           tmpfs      tmpfs      rw,nosuid,nodev,relatime,size=388436k,nr_inodes=97109,mode=700,uid=1000,gid=1000
                  `-/boot                      /dev/sda1  vfat       rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  4.9G    /var/
                  4.1G    /var/log/journal/b90929d3efd64b92af5b6ca0e1d4d7ff
                  4.1G    /var/log
                  641M    /var/cache
                  Archived and active journals take up 4.0G in the file system.
                  /opt/iobroker/backups:
                  1.2G    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  2.6G    /opt/iobroker/iobroker-data/
                  1.6G    /opt/iobroker/iobroker-data/history
                  875M    /opt/iobroker/iobroker-data/files
                  493M    /opt/iobroker/iobroker-data/files/javascript.admin
                  461M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                  35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                  29M     /opt/iobroker/iobroker-data/objects.jsonl
                  26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.bad2715c.js.map
                  26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.bad2715c.js.map
                  24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.6c4f5a4e.js.map
                  USB-Devices by-id:
                  No Devices found 'by-id'
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v20.17.0
                  /usr/bin/node           v20.17.0
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  /usr/bin/corepack       0.29.3
                  nodejs:
                    Installed: 20.17.0-1nodesource1
                    Candidate: 20.17.0-1nodesource1
                    Version table:
                   *** 20.17.0-1nodesource1 600
                          500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                          100 /var/lib/dpkg/status
                       20.16.0-1nodesource1 600
                       20.15.1-1nodesource1 600
                       20.15.0-1nodesource1 600
                       20.14.0-1nodesource1 600
                       20.13.1-1nodesource1 600
                       20.13.0-1nodesource1 600
                       20.12.2-1nodesource1 600
                       20.12.1-1nodesource1 600
                       20.12.0-1nodesource1 600
                       20.11.1-1nodesource1 600
                       20.11.0-1nodesource1 600
                       20.10.0-1nodesource1 600
                       20.9.0-1nodesource1 600
                       20.8.1-1nodesource1 600
                       20.8.0-1nodesource1 600
                       20.7.0-1nodesource1 600
                       20.6.1-1nodesource1 600
                       20.6.0-1nodesource1 600
                       20.5.1-1nodesource1 600
                       20.5.0-1nodesource1 600
                       20.4.0-1nodesource1 600
                       20.3.1-1nodesource1 600
                       20.3.0-1nodesource1 600
                       20.2.0-1nodesource1 600
                       20.1.0-1nodesource1 600
                       20.0.0-1nodesource1 600
                       12.22.12~dfsg-1~deb11u4 500
                          500 http://deb.debian.org/debian bullseye/main arm64 Packages
                          500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                  No problems detected
                  Errors in npm tree:
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Core adapters versions
                  js-controller:  6.0.7
                  admin:          7.0.25
                  javascript:     8.8.2
                  nodejs modules from github:     3
                  +-- @iobroker/plugin-sentry@2.0.4 (git+ssh://git@github.com/ioBroker/plugin-sentry.git#f15de95b95fdd466e7a0ea558f3f54efd5e2c8bb)
                  +-- iobroker.opendtu@2.0.0 (git+ssh://git@github.com/o0shojo0o/ioBroker.opendtu.git#dd46be2f6e5a0096a0c7b376cdd2560efe4dc739)
                  +-- iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#de8c1ad97edafedb16cbbb2c6dc14b032848df8e)
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                  + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                  + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                    system.adapter.devices.0                : devices               : iobroker                                 - disabled
                  + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                  + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                  + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                  + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                    system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
                  + system.adapter.history.0                : history               : iobroker                                 -  enabled
                  + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                  + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                  + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
                  + system.adapter.hs100.0                  : hs100                 : iobroker                                 -  enabled
                  + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
                  + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
                  + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                  + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
                  + system.adapter.mihome-cloud.0           : mihome-cloud          : iobroker                                 -  enabled
                  + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
                  + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
                  + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                  + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                  + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled
                  + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.178.94
                  + system.adapter.shelly.2                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.94
                  + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
                  + system.adapter.switchbot-hub.0          : switchbot-hub         : iobroker                                 -  enabled
                  + system.adapter.tapo.0                   : tapo                  : iobroker                                 -  enabled
                  + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                  + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                  + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                  + system.adapter.tr-064.2                 : tr-064                : iobroker                                 -  enabled
                  + system.adapter.tr-064.3                 : tr-064                : iobroker                                 -  enabled
                  + system.adapter.tr-064.4                 : tr-064                : iobroker                                 -  enabled
                  + system.adapter.tr-064.5                 : tr-064                : iobroker                                 -  enabled
                  + system.adapter.tr-064.7                 : tr-064                : iobroker                                 -  enabled
                  + system.adapter.tradfri.0                : tradfri               : iobroker                                 -  enabled
                    system.adapter.tuya.0                   : tuya                  : iobroker                                 - disabled
                    system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                  + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.zendure-solarflow.1      : zendure-solarflow     : iobroker                                 -  enabled
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): beta
                  Upgrade policy: none
                  Installed ioBroker-Instances
                  Used repository: beta
                  Adapter    "admin"        : 7.0.25   , installed 7.0.25
                  Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                  Adapter    "backitup"     : 3.0.20   , installed 3.0.20
                  Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
                  Adapter    "echarts"      : 1.9.0    , installed 1.9.0
                  Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
                  Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                  Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                  Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
                  Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                  Adapter    "hmip"         : 1.24.1   , installed 1.24.1
                  Adapter    "hs100"        : 2.2.0    , installed 2.2.0
                  Adapter    "hue"          : 3.12.0   , installed 3.12.0
                  Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                  Adapter    "javascript"   : 8.8.2    , installed 8.8.2
                  Controller "js-controller": 6.0.11   , installed 6.0.7  [Updatable]
                  Adapter    "lovelace"     : 4.1.10   , installed 4.1.10
                  Adapter    "mihome-cloud" : 0.1.1    , installed 0.1.1
                  Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                  Adapter    "opendtu"      : 2.0.0    , installed 2.0.0
                  Adapter    "ping"         : 1.7.3    , installed 1.7.3
                  Adapter    "rpi2"         : 2.0.0    , installed 2.0.0
                  Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                  Adapter    "shelly"       : 8.1.1    , installed 8.0.0  [Updatable]
                  Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                  Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                  Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                  Adapter    "tapo"         : 0.3.3    , installed 0.3.3
                  Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                  Adapter    "text2command" : 3.0.3    , installed 3.0.3
                  Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                  Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
                  Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                  Adapter    "web"          : 6.3.0    , installed 6.3.0
                  Adapter    "ws"           : 2.6.2    , installed 2.6.2
                  Adapter    "zendure-solarflow": 1.8.5, installed 1.8.5
                  Objects and States
                  Objects:        9864
                  States:         7454
                  Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                  Hit:2 http://deb.debian.org/debian bullseye InRelease
                  Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                  Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       14895      1387/node-red
                  tcp        0      0 192.168.178.95:2001     0.0.0.0:*               LISTEN      1000       15761      1432/io.hm-rpc.0
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       12208      491/iobroker.js-con
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       14573      491/iobroker.js-con
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14524      533/sshd: /usr/sbin
                  tcp        0      0 192.168.178.94:1883     0.0.0.0:*               LISTEN      1000       15190      1614/io.shelly.2
                  tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       18107      1890/io.jarvis.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1000       15590      1139/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1000       16383      2352/io.web.0
                  tcp6       0      0 :::8088                 :::*                    LISTEN      1000       16260      2053/io.terminal.0
                  tcp6       0      0 :::8091                 :::*                    LISTEN      1000       17276      1919/io.lovelace.0
                  tcp6       0      0 :::3500                 :::*                    LISTEN      1000       15223      1796/io.sonos.0
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          14526      533/sshd: /usr/sbin
                  udp        0      0 192.168.178.95:5353     0.0.0.0:*                           1000       17045      1805/io.tr-064.0
                  udp        0      0 192.168.178.94:5353     0.0.0.0:*                           1000       17044      1805/io.tr-064.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       16536      1353/io.chromecast.
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13797      396/avahi-daemon: r
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       15145      1600/io.shelly.0
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12195      868/dhcpcd
                  udp        0      0 0.0.0.0:49377           0.0.0.0:*                           1000       19935      2110/io.tradfri.0
                  udp        0      0 0.0.0.0:49687           0.0.0.0:*                           108        13799      396/avahi-daemon: r
                  udp6       0      0 :::35531                :::*                                108        13800      396/avahi-daemon: r
                  udp6       0      0 :::5353                 :::*                                108        13798      396/avahi-daemon: r
                  udp6       0      0 :::546                  :::*                                0          12206      868/dhcpcd
                  2024-08-27 20:32:02.825  - info: chromecast.0 (1353) Cosmos - getStatus
                  2024-08-27 20:32:02.833  - info: chromecast.0 (1353) Cosmos - getStatus
                  2024-08-27 20:32:02.851  - info: chromecast.0 (1353) Cosmos - getStatus
                  2024-08-27 20:32:02.867  - info: chromecast.0 (1353) Cosmos - getStatus
                  2024-08-27 20:32:02.871  - info: chromecast.0 (1353) Cosmos - getStatus
                  2024-08-27 20:32:02.872  - info: chromecast.0 (1353) Cosmos - getStatus
                  2024-08-27 20:32:02.874  - info: chromecast.0 (1353) Cosmos - getStatus
                  2024-08-27 20:32:02.891  - info: chromecast.0 (1353) Cosmos - getStatus
                  2024-08-27 20:32:02.919  - info: chromecast.0 (1353) Cosmos - getStatus
                  2024-08-27 20:32:02.929  - info: chromecast.0 (1353) Cosmos - getStatus
                  2024-08-27 20:32:02.932  - info: chromecast.0 (1353) Cosmos - getStatus
                  2024-08-27 20:32:02.941  - info: chromecast.0 (1353) Cosmos - getStatus
                  2024-08-27 20:32:02.962  - info: chromecast.0 (1353) Cosmos - getStatus
                  2024-08-27 20:32:02.976  - info: chromecast.0 (1353) Cosmos - getStatus
                  2024-08-27 20:32:02.977  - info: chromecast.0 (1353) Cosmos - getStatus
                  2024-08-27 20:32:02.978  - info: chromecast.0 (1353) Cosmos - getStatus
                  2024-08-27 20:32:02.979  - info: chromecast.0 (1353) Cosmos - getStatus
                  2024-08-27 20:32:02.980  - info: chromecast.0 (1353) Cosmos - getStatus
                  2024-08-27 20:32:02.985  - info: chromecast.0 (1353) Cosmos - getStatus
                  2024-08-27 20:32:02.986  - info: chromecast.0 (1353) Cosmos - getStatus
                  2024-08-27 20:32:02.987  - info: chromecast.0 (1353) Cosmos - getStatus
                  2024-08-27 20:32:02.988  - info: chromecast.0 (1353) Cosmos - getStatus
                  iob diag has finished.
                  Press any key for a summary
                  Homoran Thomas Braun 2 Replies Last reply Reply Quote 1
                    your filesystem has been corrupted.
                    this is your problem?
                    I cannot see any obstacles for grading up.
                    maybe @Thomas-Braun will see better than me
                      I think that github-Version of @iobroker/plugin-sentry is the blocking item. Wherever this version comes from.
                      On my system:
                      echad@chet:/opt/iobroker $ npm ls @iobroker/plugin-sentry
                      iobroker.inst@3.0.0 /opt/iobroker
                      └─┬ iobroker.js-controller@6.0.11
                        ├─┬ @iobroker/js-controller-adapter@6.0.11
                        │ └── @iobroker/plugin-sentry@1.2.1 deduped
                      Try reinstalling js-controller with clean dependencies:
                      iob stop
                      cd /opt/iobroker && npm install iobroker.js-controller@6.0.11
                      iob start
                      • enzo
                        enzo @Thomas Braun last edited by
                        ok mache ich.
                        • enzo
                          enzo @Thomas Braun last edited by Homoran
                          iobroker@iobroker:~ $ iob stop
                          iobroker@iobroker:~ $ cd /opt/iobroker && npm install iobroker.js-controller@6.0.11
                          npm error code 6
                          npm error path /opt/iobroker/node_modules/iobroker.js-controller
                          npm error command failed
                          npm error command sh -c node iobroker.js setup first
                          npm error Uncaught Rejection: TypeError: callback is not a function
                          npm error     at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/@iobroker/plugin-base/lib/PluginBase.js:310:17
                          npm error This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                          npm error TypeError: callback is not a function
                          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-27T18_54_51_254Z-debug-0.log
                          iobroker@iobroker:/opt/iobroker $
                            A Former User @enzo last edited by
                            Hallo @Homoran
                            Hallo @Thomas-Braun
                            Ich denke wir können wieder auf Deutsch weitermachen ✌️
                            Das verstehe ich als Niederländerin besser 😉
                            Macht es Sinn den Controller upzudaten, wenn das Filesystem kaputt ist?
                            Samson71 enzo 2 Replies Last reply Reply Quote 0
                            • Samson71
                              Samson71 Global Moderator @Guest last edited by
                              @mrs-antje sagte in Update js-controller from @6.0.7 to @6.0.11 nicht möglich:
                              Dass es hier in keiner Weise um Dich, sondern um @enzo geht, der nach eigenem Bekunden in Deutsch nicht so fit ist, hast Du aber noch auf dem Schirm oder?
                              ? 1 Reply Last reply Reply Quote 1
                              • enzo
                                enzo @Guest last edited by enzo
                                @mrs-antje der iobroker läuft Ganz gut nur der js-controller@6.0.7 kann ich nicht ab und Downgraden .
                                mit google translater geht es ja.
                                und nochmal danke an alle die mir so gut helfen ich weis das zu Schätzen.
                                  @enzo
                                  Is it possible that you manage to manually install the js-controller in recursive directories?
                                  That path/file does not exist on my system:
                                  but
                                  /opt/iobroker/node_modules/@iobroker/plugin-base/lib/PluginBase.js
                                  It seems as if you did install a non-standard version of js-controller into the js-controller directory again.
                                    A Former User @Samson71 last edited by
                                    Hallo @samson71
                                    und da hilft ein Thread halb deutsch/ halb englisch den Leuten, die helfen wollen oder hier eine Lösung vielleicht finden, weiter?
                                    Wenn hier nur die Experten helfen sollen, okay.
                                    Hatte mich angemeldet , weil ich auch endlich helfen wollte , nachdem ich hier lange mitgelesen und einiges mitgenommen habe.
                                    Vielleicht liegt es auch daran, dass ich eine Frau bin.
                                    Who knows.
                                    Aber weil ein User schreibt , dass er nicht gut deutsch spricht , gleich mal die Sprache zu wechseln, obwohl der User anscheinend 40 Adapter gut auf deutsch einrichten konnte und hier bisher auch nur deutsch schreibt …..
                                    Aber Du bist der Moderator hier…..hast mich ja auch nett Willkommen geheißen ✌️
                                      Nein, warum sollte es?
                                      Who knows.
                                      I do.
                                        @enzo
                                        cd /opt/iobroker/node_modules/iobroker.js-controller && npm ls
                                          Homoran Global Moderator Administrators @Guest last edited by Homoran
                                          wer sagt das denn?
                                          iobroker kann auf viele Sprachen eingestellt werden
                                          • enzo
                                            iobroker@iobroker:~ $ cd /opt/iobroker/node_modules/iobroker.js-controller && np                            m ls
                                            iobroker.js-controller@6.0.7 /opt/iobroker/node_modules/iobroker.js-controller
                                            ├── UNMET DEPENDENCY @alcalzone/esbuild-register@^2.5.1-1
                                            ├── UNMET DEPENDENCY @iobroker/db-objects-file@6.0.7
                                            ├── UNMET DEPENDENCY @iobroker/db-objects-jsonl@6.0.7
                                            ├── UNMET DEPENDENCY @iobroker/db-objects-redis@6.0.7
                                            ├── UNMET DEPENDENCY @iobroker/db-states-file@6.0.7
                                            ├── UNMET DEPENDENCY @iobroker/db-states-jsonl@6.0.7
                                            ├── UNMET DEPENDENCY @iobroker/db-states-redis@6.0.7
                                            ├── UNMET DEPENDENCY @iobroker/js-controller-adapter@6.0.7
                                            ├── UNMET DEPENDENCY @iobroker/js-controller-cli@6.0.7
                                            ├── UNMET DEPENDENCY @iobroker/js-controller-common-db@6.0.7
                                            ├── UNMET DEPENDENCY @iobroker/js-controller-common@6.0.7
                                            ├── UNMET DEPENDENCY @iobroker/plugin-base@~2.0.1
                                            ├── UNMET DEPENDENCY @iobroker/plugin-sentry@~2.0.4
                                            ├── UNMET DEPENDENCY axios@^1.6.3
                                            ├── UNMET DEPENDENCY cron-parser@^4.9.0
                                            ├── UNMET DEPENDENCY debug@^4.3.4
                                            ├── UNMET DEPENDENCY decache@^4.6.1
                                            ├── UNMET DEPENDENCY deep-clone@^3.0.3
                                            ├── UNMET DEPENDENCY fs-extra@^11.1.0
                                            ├── UNMET DEPENDENCY jsonwebtoken@^9.0.0
                                            ├── UNMET DEPENDENCY jszip@^3.10.1
                                            ├── UNMET DEPENDENCY loadavg-windows@^1.1.1
                                            ├── UNMET DEPENDENCY node-schedule@^2.1.1
                                            ├── UNMET DEPENDENCY pidusage@^3.0.2
                                            ├── UNMET DEPENDENCY promisify-child-process@^4.1.1
                                            ├── UNMET DEPENDENCY prompt@^1.2.2
                                            ├── UNMET DEPENDENCY readline-sync@^1.4.10
                                            ├── UNMET DEPENDENCY semver@^7.5.2
                                            └── UNMET DEPENDENCY tar@^6.2.1
                                            npm error code ELSPROBLEMS
                                            npm error missing: @alcalzone/esbuild-register@^2.5.1-1, required by iobroker.js                            -controller@6.0.7
                                            npm error missing: @iobroker/db-objects-file@6.0.7, required by iobroker.js-cont                            roller@6.0.7
                                            npm error missing: @iobroker/db-objects-jsonl@6.0.7, required by iobroker.js-con                            troller@6.0.7
                                            npm error missing: @iobroker/db-objects-redis@6.0.7, required by iobroker.js-con                            troller@6.0.7
                                            npm error missing: @iobroker/db-states-file@6.0.7, required by iobroker.js-contr                            oller@6.0.7
                                            npm error missing: @iobroker/db-states-jsonl@6.0.7, required by iobroker.js-cont                            roller@6.0.7
                                            npm error missing: @iobroker/db-states-redis@6.0.7, required by iobroker.js-cont                            roller@6.0.7
                                            npm error missing: @iobroker/js-controller-adapter@6.0.7, required by iobroker.j                            s-controller@6.0.7
                                            npm error missing: @iobroker/js-controller-cli@6.0.7, required by iobroker.js-co                            ntroller@6.0.7
                                            npm error missing: @iobroker/js-controller-common-db@6.0.7, required by iobroker                            .js-controller@6.0.7
                                            npm error missing: @iobroker/js-controller-common@6.0.7, required by iobroker.js                            -controller@6.0.7
                                            npm error missing: @iobroker/plugin-base@~2.0.1, required by iobroker.js-control                            ler@6.0.7
                                            npm error missing: @iobroker/plugin-sentry@~2.0.4, required by iobroker.js-contr                            oller@6.0.7
                                            npm error missing: axios@^1.6.3, required by iobroker.js-controller@6.0.7
                                            npm error missing: cron-parser@^4.9.0, required by iobroker.js-controller@6.0.7
                                            npm error missing: debug@^4.3.4, required by iobroker.js-controller@6.0.7
                                            npm error missing: decache@^4.6.1, required by iobroker.js-controller@6.0.7
                                            npm error missing: deep-clone@^3.0.3, required by iobroker.js-controller@6.0.7
                                            npm error missing: fs-extra@^11.1.0, required by iobroker.js-controller@6.0.7
                                            npm error missing: jsonwebtoken@^9.0.0, required by iobroker.js-controller@6.0.7
                                            npm error missing: jszip@^3.10.1, required by iobroker.js-controller@6.0.7
                                            npm error missing: loadavg-windows@^1.1.1, required by iobroker.js-controller@6.                            0.7
                                            npm error missing: node-schedule@^2.1.1, required by iobroker.js-controller@6.0.                            7
                                            npm error missing: pidusage@^3.0.2, required by iobroker.js-controller@6.0.7
                                            npm error missing: promisify-child-process@^4.1.1, required by iobroker.js-contr                            oller@6.0.7
                                            npm error missing: prompt@^1.2.2, required by iobroker.js-controller@6.0.7
                                            npm error missing: readline-sync@^1.4.10, required by iobroker.js-controller@6.0                            .7
                                            npm error missing: semver@^7.5.2, required by iobroker.js-controller@6.0.7
                                            npm error missing: tar@^6.2.1, required by iobroker.js-controller@6.0.7
                                            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/                            2024-08-27T19_58_25_882Z-debug-0.log
                                            iobroker@iobroker:/opt/iobroker/node_modules/iobroker.js-controller $ iobroker@iobroker:~ $ cd /opt/iobroker/node_modules/iobroker.js-controller && np                            m ls
                                            4168
