    4. Nach Update js-controller macht host.raspberrypi Fehler
    • [erledigt] 15. 05. Wartungsarbeiten am ioBroker Forum
    • spicer
      spicer last edited by
      Nach Update des js-controller von @6.0.9 nach @6.0.11 macht host.raspberrypi folgende Fehler:
      host.raspberrypi
      	2024-08-28 22:44:01.596	error	instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi
      	2024-08-28 22:44:01.595	error	Caught by controller[0]: Node.js v18.20.4
      host.raspberrypi
      	2024-08-28 22:44:01.595	error	Caught by controller[0]: }
      host.raspberrypi
      	2024-08-28 22:44:01.595	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.echarts/main.js' ]
      host.raspberrypi
      	2024-08-28 22:44:01.595	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.raspberrypi
      	2024-08-28 22:44:01.594	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12) {
      host.raspberrypi
      	2024-08-28 22:44:01.594	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
      host.raspberrypi
      	2024-08-28 22:44:01.594	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
      host.raspberrypi
      	2024-08-28 22:44:01.594	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
      host.raspberrypi
      	2024-08-28 22:44:01.593	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
      host.raspberrypi
      	2024-08-28 22:44:01.592	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/main.js:12:21)
      host.raspberrypi
      	2024-08-28 22:44:01.592	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
      host.raspberrypi
      	2024-08-28 22:44:01.591	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
      host.raspberrypi
      	2024-08-28 22:44:01.591	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:981:27)
      host.raspberrypi
      	2024-08-28 22:44:01.591	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
      host.raspberrypi
      	2024-08-28 22:44:01.591	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/main.js
      host.raspberrypi
      	2024-08-28 22:44:01.590	error	Caught by controller[0]: Require stack:
      host.raspberrypi
      	2024-08-28 22:44:01.590	error	Caught by controller[0]: Error: Cannot find module '@iobroker/adapter-core'
      host.raspberrypi
      	2024-08-28 22:44:01.590	error	Caught by controller[0]: ^
      host.raspberrypi
      	2024-08-28 22:44:01.589	error	Caught by controller[0]: throw err;
      host.raspberrypi
      	2024-08-28 22:44:01.588	error	Caught by controller[0]: node:internal/modules/cjs/loader:1143
      Echarts läuft so auch nicht mehr.
      Hat jemand Rat?
        Thomas Braun Most Active @spicer last edited by
        @spicer sagte in Nach Update js-controller macht host.raspberrypi Fehler:
        Node.js v18.20.4
        iob nodejs-update
        Danach die Langfassung von
        iob diag
        spicer 1 Reply Last reply Reply Quote 0
        • spicer
          spicer @Thomas Braun last edited by spicer
          Skript v.2024-05-22
          *** BASE SYSTEM ***
          Static hostname: raspberrypi
          Icon name: computer
          Operating System: Raspbian GNU/Linux 11 (bullseye)
          Kernel: Linux 6.1.21-v7+
          Architecture: arm
          Model : Raspberry Pi 3 Model B Rev 1.2
          Docker : false
          Virtualization : none
          Kernel : armv7l
          Userland : 32 bit
          Systemuptime and Load:
          23:15:39 up 1:10, 3 users, load average: 3.87, 3.05, 1.60
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
          Local time: Wed 2024-08-28 23:15:39 CEST
          Universal time: Wed 2024-08-28 21:15:39 UTC
          RTC time: Wed 2024-08-28 21:15:40
          Time zone: Europe/Zurich (CEST, +0200)
          NTP service: active
          RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          pi
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
          *** Display-Server-Setup ***
          Display-Server: true
          Desktop:
          Terminal: tty
          Boot Target: graphical.target
          *** MEMORY ***
          total used free shared buff/cache available
          Mem: 921M 547M 147M 0.0K 227M 315M
          Swap: 2.0G 374M 1.7G
          Total: 3.0G 922M 1.8G
          Active iob-Instances: 10
                921 M total memory
                547 M used memory
                404 M active memory
                278 M inactive memory
                147 M free memory
                 39 M buffer memory
                187 M swap cache
               2047 M total swap
                374 M used swap
               1673 M free swap
          *** top - Table Of Processes ***
          top - 23:15:40 up 1:10, 3 users, load average: 3.87, 3.05, 1.60
          Tasks: 196 total, 2 running, 194 sleeping, 0 stopped, 0 zombie
          %Cpu(s): 39.2 us, 5.1 sy, 0.0 ni, 55.7 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
          MiB Mem : 922.0 total, 146.0 free, 548.2 used, 227.7 buff/cache
          MiB Swap: 2048.0 total, 1673.2 free, 374.8 used. 314.1 avail Mem
          *** FAILED SERVICES ***
          • plymouth-start.service loaded failed failed Show Plymouth Boot Screen
          LOAD = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB = The low-level unit activation state, values depend on unit type.
          1 loaded units listed.
          *** FILESYSTEM ***
          Filesystem Type Size Used Avail Use% Mounted on
          /dev/root ext4 118G 12G 101G 11% /
          devtmpfs devtmpfs 333M 0 333M 0% /dev
          tmpfs tmpfs 461M 0 461M 0% /dev/shm
          tmpfs tmpfs 185M 1.1M 184M 1% /run
          tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
          /dev/sda1 vfat 255M 51M 205M 20% /boot
          tmpfs tmpfs 93M 24K 93M 1% /run/user/1000
          [Wed Aug 28 22:04:46 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=tty1 root=PARTUUID=7a0c97b2-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Wed Aug 28 22:04:53 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Wed Aug 28 22:04:53 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Wed Aug 28 22:04:56 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
          Show mounted filesystems:
          TARGET SOURCE FSTYPE OPTIONS
          / /dev/sda2 ext4 rw,noatime
          |-/dev devtmpfs devtmpfs rw,relatime,size=340460k,nr_inodes=85115,mode=755
          | |-/dev/shm tmpfs tmpfs rw,nosuid,nodev
          | |-/dev/pts devpts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
          | -/dev/mqueue mqueue mqueue rw,nosuid,nodev,noexec,relatime |-/proc proc proc rw,relatime | -/proc/sys/fs/binfmt_misc systemd-1 autofs rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
          |-/sys sysfs sysfs rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/security securityfs securityfs rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/cgroup cgroup2 cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
          | |-/sys/fs/pstore pstore pstore rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/bpf bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700
          | |-/sys/kernel/debug debugfs debugfs rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/tracing tracefs tracefs rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/config configfs configfs rw,nosuid,nodev,noexec,relatime
          | -/sys/fs/fuse/connections fusectl fusectl rw,nosuid,nodev,noexec,relatime |-/run tmpfs tmpfs rw,nosuid,nodev,size=188820k,nr_inodes=819200,mode=755 | |-/run/lock tmpfs tmpfs rw,nosuid,nodev,noexec,relatime,size=5120k | |-/run/rpc_pipefs sunrpc rpc_pipefs rw,relatime | -/run/user/1000 tmpfs tmpfs rw,nosuid,nodev,relatime,size=94408k,nr_inodes=23602,mode=700,uid=1000,gid=1000
          | -/run/user/1000/gvfs gvfsd-fuse fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000 -/boot /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          3.5G /var/
          975M /var/log
          969M /var/log/journal/b5953832ba8144d6b0bc329e94b66653
          335M /var/cache
          Archived and active journals take up 968.0M in the file system.
          /opt/iobroker/backups:
          92M /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          816M /opt/iobroker/iobroker-data/
          710M /opt/iobroker/iobroker-data/files
          441M /opt/iobroker/iobroker-data/files/javascript.admin
          409M /opt/iobroker/iobroker-data/files/javascript.admin/static
          408M /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          24M /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          24M /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
          24M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
          23M /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
          17M /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map
          USB-Devices by-id:
          USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id':
          No Devices found 'by-id'
          *** NodeJS-Installation ***
          /usr/bin/nodejs v20.17.0
          /usr/bin/node v20.17.0
          /usr/bin/npm 10.8.2
          /usr/bin/npx 10.8.2
          /usr/bin/corepack 0.29.3
          nodejs:
          Installed: 20.17.0-1nodesource1
          Candidate: 20.17.0-1nodesource1
          Version table:
          *** 20.17.0-1nodesource1 1001
          500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
          100 /var/lib/dpkg/status
          20.16.0-1nodesource1 1001
          20.15.1-1nodesource1 1001
          20.15.0-1nodesource1 1001
          20.14.0-1nodesource1 1001
          20.13.1-1nodesource1 1001
          20.13.0-1nodesource1 1001
          20.12.2-1nodesource1 1001
          20.12.1-1nodesource1 1001
          20.12.0-1nodesource1 1001
          20.11.1-1nodesource1 1001
          20.11.0-1nodesource1 1001
          20.10.0-1nodesource1 1001
          20.9.0-1nodesource1 1001
          20.8.1-1nodesource1 1001
          20.8.0-1nodesource1 1001
          20.7.0-1nodesource1 1001
          20.6.1-1nodesource1 1001
          20.6.0-1nodesource1 1001
          20.5.1-1nodesource1 1001
          20.5.0-1nodesource1 1001
          20.4.0-1nodesource1 1001
          20.3.1-1nodesource1 1001
          20.3.0-1nodesource1 1001
          20.2.0-1nodesource1 1001
          20.1.0-1nodesource1 1001
          20.0.0-1nodesource1 1001
          12.22.12~dfsg-1~deb11u4 500
          500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States type: jsonl
          Core adapters versions
          js-controller: 6.0.11
          admin: 7.0.23
          javascript: 8.7.6
          nodejs modules from github: 0
          Adapter State
          • system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin
          • system.adapter.backitup.0 : backitup : raspberrypi - enabled
          • system.adapter.deconz.0 : deconz : raspberrypi - enabled, port: 80
            system.adapter.discovery.0 : discovery : raspberrypi - disabled
            system.adapter.echarts.0 : echarts : raspberrypi - enabled
            system.adapter.email.0 : email : raspberrypi - disabled
            system.adapter.flot.0 : flot : raspberrypi - disabled
            system.adapter.heizoel24-mex.0 : heizoel24-mex : raspberrypi - enabled
          • system.adapter.history.0 : history : raspberrypi - enabled
          • system.adapter.javascript.0 : javascript : raspberrypi - enabled
          • system.adapter.mqtt.1 : mqtt : raspberrypi - enabled, port: 1883, bind: 0.0.0.0
            system.adapter.openweathermap.0 : openweathermap : raspberrypi - enabled
            system.adapter.ping.0 : ping : raspberrypi - disabled
            system.adapter.shelly.0 : shelly : raspberrypi - disabled, port: 1882, bind: 0.0.0.0
            system.adapter.solarmanpv.0 : solarmanpv : raspberrypi - enabled
          • system.adapter.telegram.0 : telegram : raspberrypi - enabled, port: 8443, bind: 0.0.0.0
          • system.adapter.tr-064.0 : tr-064 : raspberrypi - enabled
            system.adapter.vis-timeandweather.0 : vis-timeandweather : raspberrypi - enabled
            system.adapter.vis.0 : vis : raspberrypi - enabled
          • system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin
          • instance is alive
          ioBroker-Repositories
          │ (index) │ name │ url │ auto upgrade │
          │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │
          │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: stable
          Adapter "admin" : 7.0.23 , installed 7.0.23
          Adapter "backitup" : 3.0.19 , installed 3.0.19
          Adapter "deconz" : 1.4.1 , installed 1.4.1
          Adapter "discovery" : 4.5.0 , installed 4.5.0
          Adapter "echarts" : 1.7.2 , installed 1.7.2
          Adapter "email" : 1.3.1 , installed 1.3.1
          Adapter "flot" : 1.12.0 , installed 1.12.0
          Adapter "heizoel24-mex": 1.3.5 , installed 1.3.5
          Adapter "history" : 3.0.1 , installed 3.0.1
          Adapter "javascript" : 8.7.6 , installed 8.7.6
          Controller "js-controller": 6.0.11 , installed 6.0.11
          Adapter "mqtt" : 5.2.0 , installed 5.2.0
          Adapter "openweathermap": 1.1.2 , installed 1.1.2
          Adapter "ping" : 1.6.2 , installed 1.6.2
          Adapter "shelly" : 7.0.0 , installed 7.0.0
          Adapter "simple-api" : 2.8.0 , installed 2.8.0
          Adapter "socketio" : 6.7.1 , installed 6.7.1
          Adapter "solarmanpv" : 0.5.1 , installed 0.5.1
          Adapter "telegram" : 3.9.0 , installed 3.9.0
          Adapter "tr-064" : 4.3.0 , installed 4.3.0
          Adapter "vis" : 1.5.6 , installed 1.5.6
          Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
          Adapter "web" : 6.2.5 , installed 6.2.5
          Adapter "ws" : 2.6.2 , installed 2.6.2
          Adapter "zigbee" : 1.10.3 , installed 1.10.3
          Objects and States
          Objects: 2500
          States: 2012
          Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
          tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 136564 26546/iobroker.js-c
          tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 136569 26546/iobroker.js-c
          tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 1000 19616 1562/deCONZ
          tcp 0 0 0.0.0.0:444 0.0.0.0:* LISTEN 0 13280 608/nginx: master p
          tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 139292 26882/io.mqtt.1
          tcp 0 0 0.0.0.0:5900 0.0.0.0:* LISTEN 0 15371 578/vncserver-x11-c
          tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 1018 558/cupsd
          tcp 0 0 0.0.0.0:81 0.0.0.0:* LISTEN 0 13279 608/nginx: master p
          tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 1000 17836 1562/deCONZ
          tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 13755 594/sshd: /usr/sbin
          tcp6 0 0 :::8081 :::* LISTEN 1001 137292 26574/io.admin.0
          tcp6 0 0 :::8082 :::* LISTEN 1001 137130 26709/io.web.0
          tcp6 0 0 :::5900 :::* LISTEN 0 15370 578/vncserver-x11-c
          tcp6 0 0 :::22 :::* LISTEN 0 13757 594/sshd: /usr/sbin
          tcp6 0 0 ::1:631 :::* LISTEN 0 1017 558/cupsd
          udp 0 0 0.0.0.0:631 0.0.0.0:* 0 13305 677/cups-browsed
          udp 0 0 0.0.0.0:53889 0.0.0.0:* 108 837 394/avahi-daemon: r
          udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 835 394/avahi-daemon: r
          udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 138664 26844/io.deconz.0
          udp 0 0 0.0.0.0:1900 0.0.0.0:* 1000 20612 1562/deCONZ
          udp 0 0 0.0.0.0:68 0.0.0.0:* 0 13764 516/dhcpcd
          udp6 0 0 :::55524 :::* 108 838 394/avahi-daemon: r
          udp6 0 0 :::5353 :::* 108 836 394/avahi-daemon: r
          udp6 0 0 :::1900 :::* 1001 138666 26844/io.deconz.0
          udp6 0 0 :::1900 :::* 1001 138665 26844/io.deconz.0
          udp6 0 0 :::546 :::* 0 13819 516/dhcpcd
          2024-08-28 23:17:10.734 - info: mqtt.1 (26882) Client [mosqsub|20101-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
          2024-08-28 23:17:10.935 - info: mqtt.1 (26882) Client [mosqsub|20101-Dachrollo] publishOnSubscribe
          2024-08-28 23:17:10.940 - info: mqtt.1 (26882) Client [mosqsub|20101-Dachrollo] connection closed: disconnected
          2024-08-28 23:17:11.026 - info: mqtt.1 (26882) Client [mosqsub|20103-Dachrollo] connected with secret 1724879831024_5801
          2024-08-28 23:17:11.031 - info: mqtt.1 (26882) Client [mosqsub|20103-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
          2024-08-28 23:17:11.233 - info: mqtt.1 (26882) Client [mosqsub|20103-Dachrollo] publishOnSubscribe
          2024-08-28 23:17:11.241 - info: mqtt.1 (26882) Client [mosqsub|20103-Dachrollo] connection closed: disconnected
          2024-08-28 23:17:11.330 - info: mqtt.1 (26882) Client [mosqsub|20105-Dachrollo] connected with secret 1724879831327_2609
          2024-08-28 23:17:11.337 - info: mqtt.1 (26882) Client [mosqsub|20105-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
          2024-08-28 23:17:11.539 - info: mqtt.1 (26882) Client [mosqsub|20105-Dachrollo] publishOnSubscribe
          2024-08-28 23:17:11.548 - info: mqtt.1 (26882) Client [mosqsub|20105-Dachrollo] connection closed: disconnected
          2024-08-28 23:17:11.648 - info: mqtt.1 (26882) Client [mosqpub|20107-Dachrollo] connected with secret 1724879831646_7297
          2024-08-28 23:17:11.668 - info: mqtt.1 (26882) Client [mosqpub|20107-Dachrollo] connection closed: disconnected
          2024-08-28 23:17:11.767 - info: mqtt.1 (26882) Client [mosqpub|20109-Dachrollo] connected with secret 1724879831760_5992
          2024-08-28 23:17:11.777 - info: mqtt.1 (26882) Client [mosqpub|20109-Dachrollo] connection closed: disconnected
          2024-08-28 23:17:11.876 - info: mqtt.1 (26882) Client [mosqpub|20111-Dachrollo] connected with secret 1724879831869_594
          2024-08-28 23:17:11.888 - info: mqtt.1 (26882) Client [mosqpub|20111-Dachrollo] connection closed: disconnected
          2024-08-28 23:17:11.983 - info: mqtt.1 (26882) Client [mosqpub|20113-Dachrollo] connected with secret 1724879831982_6023
          2024-08-28 23:17:11.989 - info: mqtt.1 (26882) Client [mosqpub|20113-Dachrollo] connection closed: disconnected
          2024-08-28 23:17:12.087 - info: mqtt.1 (26882) Client [mosqpub|20115-Dachrollo] connected with secret 1724879832085_8693
          2024-08-28 23:17:12.094 - info: mqtt.1 (26882) Client [mosqpub|20115-Dachrollo] connection closed: disconnected
          2024-08-28 23:17:12.379 - info: mqtt.1 (26882) Client [mosqpub|20130-Dachrollo] connected with secret 1724879832377_2746
          2024-08-28 23:17:12.386 - info: mqtt.1 (26882) Client [mosqpub|20130-Dachrollo] connection closed: disconnected
          2024-08-28 23:17:12.552 - info: mqtt.1 (26882) Client [mosqpub|20136-Dachrollo] connected with secret 1724879832551_8318
          2024-08-28 23:17:12.562 - info: mqtt.1 (26882) Client [mosqpub|20136-Dachrollo] connection closed: disconnected
          iob diag has finished.
          Press any key for a summary
          diag.txt
          spicer Thomas Braun 2 Replies Last reply Reply Quote 0
          • spicer
            spicer @spicer last edited by
            Sorry. Hier der richtige Log:
            			v.2024-05-22
                     Icon name: computer
                  Architecture: arm
            Installation: 		native
            Kernel: 		armv7l
            Userland: 		32 bit
            Timezone: 		Europe/Zurich (CEST, +0200)
            User-ID: 		1000
            Pending OS-Updates: 	0
            Pending iob updates: 	0
            Nodejs-Installation:
            /usr/bin/npm 		10.8.2
            /usr/bin/npx 		10.8.2
            Recommended versions are nodejs 20.17.0 and npm 10.8.2
            MEMORY:
            Mem:            921M        557M        149M        0.0K        214M        302M
            Swap:           2.0G        441M        1.6G
            Total:          3.0G        999M        1.8G
            ioBroker Core: 		js-controller 		6.0.11
            			admin 			7.0.23
            ioBroker Status: 	iobroker is running on this host.
            Objects type: jsonl
            States  type: jsonl
            + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            Objects: 		2500
            States: 		2012
            Size of iob-Database:
            14M	/opt/iobroker/iobroker-data/objects.jsonl
            4.6M	/opt/iobroker/iobroker-data/states.jsonl
              Installier das bei nächster Gelegenheit komplett neu.
              Dann ohne Desktop und in der 64Bit-Version.
              Und mit einem username ungleich 'pi' und ungleich 'iobroker'.
              iob start echarts.0
              sagt?
              spicer 2 Replies Last reply Reply Quote 0
              • spicer
                iob start echarts.0 sagt nichts!
                Den Desktop brauche ich, da deCONZ auch da drauf läuft und ich VNC brauche.
                Der RPI 3 kann 64bit?
                  @spicer
                  Zeigen. Komplette Ein- wie Ausgabezeilen.
                    Nein, braucht man nicht. deCONZ läuft auch headless. Und VNC braucht es auf einem Server nie. Weil da nie eine GUI rennt.
                    Ja.
                    • spicer
                      pi@raspberrypi:~ $ iob start echarts.0
                      pi@raspberrypi:~ $
                        @spicer
                        iob list instances
                        • spicer
                          pi@raspberrypi:~ $ iob list instances
                          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                          + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
                          + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                          + system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                          + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                          + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                          + instance is alive
                            @spicer
                            Dann schau nochmal in das Log:
                            iob logs
                            • spicer
                               MB von 922MB (33%)
                              2024-08-28 23:27:00.129  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: Freier Swap: 1638
                               MB von 2048MB (80%)
                              2024-08-28 23:27:10.247  - info: mqtt.1 (26882) Client [mosqsub|20744-Dachrollo] connected with secret 1724880430246_4288
                              2024-08-28 23:27:10.252  - info: mqtt.1 (26882) Client [mosqsub|20744-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
                              2024-08-28 23:27:10.453  - info: mqtt.1 (26882) Client [mosqsub|20744-Dachrollo] publishOnSubscribe
                              2024-08-28 23:27:10.456  - info: mqtt.1 (26882) Client [mosqsub|20744-Dachrollo] connection closed: disconnected
                              2024-08-28 23:27:10.546  - info: mqtt.1 (26882) Client [mosqsub|20746-Dachrollo] connected with secret 1724880430545_7858
                              2024-08-28 23:27:10.552  - info: mqtt.1 (26882) Client [mosqsub|20746-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
                              2024-08-28 23:27:10.752  - info: mqtt.1 (26882) Client [mosqsub|20746-Dachrollo] publishOnSubscribe
                              2024-08-28 23:27:10.757  - info: mqtt.1 (26882) Client [mosqsub|20746-Dachrollo] connection closed: disconnected
                              2024-08-28 23:27:10.845  - info: mqtt.1 (26882) Client [mosqsub|20748-Dachrollo] connected with secret 1724880430844_7856
                              2024-08-28 23:27:10.850  - info: mqtt.1 (26882) Client [mosqsub|20748-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
                              2024-08-28 23:27:11.051  - info: mqtt.1 (26882) Client [mosqsub|20748-Dachrollo] publishOnSubscribe
                              2024-08-28 23:27:11.054  - info: mqtt.1 (26882) Client [mosqsub|20748-Dachrollo] connection closed: disconnected
                              2024-08-28 23:27:11.139  - info: mqtt.1 (26882) Client [mosqsub|20750-Dachrollo] connected with secret 1724880431138_4610
                              2024-08-28 23:27:11.143  - info: mqtt.1 (26882) Client [mosqsub|20750-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
                              2024-08-28 23:27:11.344  - info: mqtt.1 (26882) Client [mosqsub|20750-Dachrollo] publishOnSubscribe
                              2024-08-28 23:27:11.348  - info: mqtt.1 (26882) Client [mosqsub|20750-Dachrollo] connection closed: disconnected
                              2024-08-28 23:27:11.436  - info: mqtt.1 (26882) Client [mosqsub|20752-Dachrollo] connected with secret 1724880431435_6621
                              2024-08-28 23:27:11.439  - info: mqtt.1 (26882) Client [mosqsub|20752-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
                              2024-08-28 23:27:11.640  - info: mqtt.1 (26882) Client [mosqsub|20752-Dachrollo] publishOnSubscribe
                              2024-08-28 23:27:11.644  - info: mqtt.1 (26882) Client [mosqsub|20752-Dachrollo] connection closed: disconnected
                              2024-08-28 23:27:11.742  - info: mqtt.1 (26882) Client [mosqpub|20754-Dachrollo] connected with secret 1724880431741_3090
                              2024-08-28 23:27:11.747  - info: mqtt.1 (26882) Client [mosqpub|20754-Dachrollo] connection closed: disconnected
                              2024-08-28 23:27:11.842  - info: mqtt.1 (26882) Client [mosqpub|20756-Dachrollo] connected with secret 1724880431840_414
                              2024-08-28 23:27:11.849  - info: mqtt.1 (26882) Client [mosqpub|20756-Dachrollo] connection closed: disconnected
                              2024-08-28 23:27:11.920  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] connected with secret 1724880431917_6742
                              2024-08-28 23:27:11.942  - info: mqtt.1 (26882) Client [mosqpub|20758-Dachrollo] connected with secret 1724880431941_8754
                              2024-08-28 23:27:11.947  - info: mqtt.1 (26882) Client [mosqpub|20758-Dachrollo] connection closed: disconnected
                              2024-08-28 23:27:12.042  - info: mqtt.1 (26882) Client [mosqpub|20760-Dachrollo] connected with secret 1724880432041_2336
                              2024-08-28 23:27:12.047  - info: mqtt.1 (26882) Client [mosqpub|20760-Dachrollo] connection closed: disconnected
                              2024-08-28 23:27:12.051  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.12V_on_off"
                              2024-08-28 23:27:12.065  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert2"
                              2024-08-28 23:27:12.066  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert3"
                              2024-08-28 23:27:12.067  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert4"
                              2024-08-28 23:27:12.067  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] connection closed: disconnected
                              2024-08-28 23:27:12.142  - info: mqtt.1 (26882) Client [mosqpub|20762-Dachrollo] connected with secret 1724880432141_7072
                              2024-08-28 23:27:12.147  - info: mqtt.1 (26882) Client [mosqpub|20762-Dachrollo] connection closed: disconnected
                              2024-08-28 23:27:12.251  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                              2024-08-28 23:27:12.265  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                              2024-08-28 23:27:12.266  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                              2024-08-28 23:27:12.268  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                              2024-08-28 23:27:12.432  - info: mqtt.1 (26882) Client [mosqpub|20777-Dachrollo] connected with secret 1724880432431_7101
                              2024-08-28 23:27:12.437  - info: mqtt.1 (26882) Client [mosqpub|20777-Dachrollo] connection closed: disconnected
                              2024-08-28 23:27:12.465  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] connected with secret 1724880432460_7409
                              2024-08-28 23:27:12.584  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.12V_on_off"
                              2024-08-28 23:27:12.593  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert2"
                              2024-08-28 23:27:12.595  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert3"
                              2024-08-28 23:27:12.595  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert4"
                              2024-08-28 23:27:12.605  - info: mqtt.1 (26882) Client [mosqpub|20783-Dachrollo] connected with secret 1724880432604_1289
                              2024-08-28 23:27:12.609  - info: mqtt.1 (26882) Client [mosqpub|20783-Dachrollo] connection closed: disconnected
                              2024-08-28 23:27:12.785  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                              2024-08-28 23:27:12.794  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                              2024-08-28 23:27:12.795  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                              2024-08-28 23:27:12.796  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                              2024-08-28 23:27:16.040  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] connected with secret 1724880433108_3203
                              2024-08-28 23:27:16.058  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] subscribes on "/Aussenfuehler/#" with regex /^Aussenfuehler\..*/
                              2024-08-28 23:27:16.059  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] subscribes on "/Aussenfuehler/#"  with regex /^mqtt\.1\.Aussenfuehler\..*/
                              2024-08-28 23:27:16.260  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] publishOnSubscribe send all known states
                              2024-08-28 23:27:17.184  - info: web.0 (26709) <== Disconnect system.user.admin from ::ffff:192.168.1.63 vis.0
                              2024-08-28 23:27:19.478  - info: web.0 (26709) ==> Connected system.user.admin from ::ffff:192.168.1.63
                              2024-08-28 23:28:08.339  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] connection closed: disconnected
                              2024-08-28 23:28:10.235  - info: mqtt.1 (26882) Client [mosqsub|20808-Dachrollo] connected with secret 1724880490233_3193
                              2024-08-28 23:28:10.238  - info: mqtt.1 (26882) Client [mosqsub|20808-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
                              2024-08-28 23:28:10.439  - info: mqtt.1 (26882) Client [mosqsub|20808-Dachrollo] publishOnSubscribe
                              2024-08-28 23:28:10.443  - info: mqtt.1 (26882) Client [mosqsub|20808-Dachrollo] connection closed: disconnected
                              2024-08-28 23:28:10.530  - info: mqtt.1 (26882) Client [mosqsub|20810-Dachrollo] connected with secret 1724880490529_1990
                              2024-08-28 23:28:10.534  - info: mqtt.1 (26882) Client [mosqsub|20810-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
                              2024-08-28 23:28:10.734  - info: mqtt.1 (26882) Client [mosqsub|20810-Dachrollo] publishOnSubscribe
                              2024-08-28 23:28:10.737  - info: mqtt.1 (26882) Client [mosqsub|20810-Dachrollo] connection closed: disconnected
                              2024-08-28 23:28:10.824  - info: mqtt.1 (26882) Client [mosqsub|20812-Dachrollo] connected with secret 1724880490822_5106
                              2024-08-28 23:28:10.828  - info: mqtt.1 (26882) Client [mosqsub|20812-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
                              2024-08-28 23:28:11.030  - info: mqtt.1 (26882) Client [mosqsub|20812-Dachrollo] publishOnSubscribe
                              2024-08-28 23:28:11.034  - info: mqtt.1 (26882) Client [mosqsub|20812-Dachrollo] connection closed: disconnected
                              2024-08-28 23:28:11.122  - info: mqtt.1 (26882) Client [mosqsub|20814-Dachrollo] connected with secret 1724880491121_2661
                              2024-08-28 23:28:11.128  - info: mqtt.1 (26882) Client [mosqsub|20814-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
                              2024-08-28 23:28:11.329  - info: mqtt.1 (26882) Client [mosqsub|20814-Dachrollo] publishOnSubscribe
                              2024-08-28 23:28:11.333  - info: mqtt.1 (26882) Client [mosqsub|20814-Dachrollo] connection closed: disconnected
                              2024-08-28 23:28:11.418  - info: mqtt.1 (26882) Client [mosqsub|20816-Dachrollo] connected with secret 1724880491417_8233
                              2024-08-28 23:28:11.424  - info: mqtt.1 (26882) Client [mosqsub|20816-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
                              2024-08-28 23:28:11.626  - info: mqtt.1 (26882) Client [mosqsub|20816-Dachrollo] publishOnSubscribe
                              2024-08-28 23:28:11.630  - info: mqtt.1 (26882) Client [mosqsub|20816-Dachrollo] connection closed: disconnected
                              2024-08-28 23:28:11.730  - info: mqtt.1 (26882) Client [mosqpub|20818-Dachrollo] connected with secret 1724880491729_2398
                              2024-08-28 23:28:11.741  - info: mqtt.1 (26882) Client [mosqpub|20818-Dachrollo] connection closed: disconnected
                              2024-08-28 23:28:11.836  - info: mqtt.1 (26882) Client [mosqpub|20820-Dachrollo] connected with secret 1724880491834_449
                              2024-08-28 23:28:11.841  - info: mqtt.1 (26882) Client [mosqpub|20820-Dachrollo] connection closed: disconnected
                              2024-08-28 23:28:11.935  - info: mqtt.1 (26882) Client [mosqpub|20822-Dachrollo] connected with secret 1724880491933_9250
                              2024-08-28 23:28:11.940  - info: mqtt.1 (26882) Client [mosqpub|20822-Dachrollo] connection closed: disconnected
                              2024-08-28 23:28:12.034  - info: mqtt.1 (26882) Client [mosqpub|20824-Dachrollo] connected with secret 1724880492032_7881
                              2024-08-28 23:28:12.040  - info: mqtt.1 (26882) Client [mosqpub|20824-Dachrollo] connection closed: disconnected
                              2024-08-28 23:28:12.132  - info: mqtt.1 (26882) Client [mosqpub|20826-Dachrollo] connected with secret 1724880492131_3921
                              2024-08-28 23:28:12.137  - info: mqtt.1 (26882) Client [mosqpub|20826-Dachrollo] connection closed: disconnected
                              2024-08-28 23:28:12.424  - info: mqtt.1 (26882) Client [mosqpub|20841-Dachrollo] connected with secret 1724880492422_535
                              2024-08-28 23:28:12.429  - info: mqtt.1 (26882) Client [mosqpub|20841-Dachrollo] connection closed: disconnected
                              2024-08-28 23:28:12.595  - info: mqtt.1 (26882) Client [mosqpub|20847-Dachrollo] connected with secret 1724880492594_2652
                              2024-08-28 23:28:12.600  - info: mqtt.1 (26882) Client [mosqpub|20847-Dachrollo] connection closed: disconnected
                              2024-08-28 23:28:17.701  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] connection closed: timeout
                              2024-08-28 23:29:10.238  - info: mqtt.1 (26882) Client [mosqsub|20872-Dachrollo] connected with secret 1724880550237_799
                              2024-08-28 23:29:10.242  - info: mqtt.1 (26882) Client [mosqsub|20872-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
                              2024-08-28 23:29:10.443  - info: mqtt.1 (26882) Client [mosqsub|20872-Dachrollo] publishOnSubscribe
                              2024-08-28 23:29:10.446  - info: mqtt.1 (26882) Client [mosqsub|20872-Dachrollo] connection closed: disconnected
                              2024-08-28 23:29:10.534  - info: mqtt.1 (26882) Client [mosqsub|20874-Dachrollo] connected with secret 1724880550533_1548
                              2024-08-28 23:29:10.537  - info: mqtt.1 (26882) Client [mosqsub|20874-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
                              2024-08-28 23:29:10.740  - info: mqtt.1 (26882) Client [mosqsub|20874-Dachrollo] publishOnSubscribe
                              2024-08-28 23:29:10.744  - info: mqtt.1 (26882) Client [mosqsub|20874-Dachrollo] connection closed: disconnected
                              2024-08-28 23:29:10.832  - info: mqtt.1 (26882) Client [mosqsub|20876-Dachrollo] connected with secret 1724880550831_672
                              2024-08-28 23:29:10.837  - info: mqtt.1 (26882) Client [mosqsub|20876-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
                              2024-08-28 23:29:11.038  - info: mqtt.1 (26882) Client [mosqsub|20876-Dachrollo] publishOnSubscribe
                              2024-08-28 23:29:11.042  - info: mqtt.1 (26882) Client [mosqsub|20876-Dachrollo] connection closed: disconnected
                              2024-08-28 23:29:11.129  - info: mqtt.1 (26882) Client [mosqsub|20878-Dachrollo] connected with secret 1724880551128_5523
                              2024-08-28 23:29:11.134  - info: mqtt.1 (26882) Client [mosqsub|20878-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
                              2024-08-28 23:29:11.334  - info: mqtt.1 (26882) Client [mosqsub|20878-Dachrollo] publishOnSubscribe
                              2024-08-28 23:29:11.338  - info: mqtt.1 (26882) Client [mosqsub|20878-Dachrollo] connection closed: disconnected
                              2024-08-28 23:29:11.424  - info: mqtt.1 (26882) Client [mosqsub|20880-Dachrollo] connected with secret 1724880551423_9587
                              2024-08-28 23:29:11.427  - info: mqtt.1 (26882) Client [mosqsub|20880-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
                              2024-08-28 23:29:11.628  - info: mqtt.1 (26882) Client [mosqsub|20880-Dachrollo] publishOnSubscribe
                              2024-08-28 23:29:11.631  - info: mqtt.1 (26882) Client [mosqsub|20880-Dachrollo] connection closed: disconnected
                              2024-08-28 23:29:11.728  - info: mqtt.1 (26882) Client [mosqpub|20882-Dachrollo] connected with secret 1724880551727_6491
                              2024-08-28 23:29:11.732  - info: mqtt.1 (26882) Client [mosqpub|20882-Dachrollo] connection closed: disconnected
                              2024-08-28 23:29:11.825  - info: mqtt.1 (26882) Client [mosqpub|20884-Dachrollo] connected with secret 1724880551824_4315
                              2024-08-28 23:29:11.830  - info: mqtt.1 (26882) Client [mosqpub|20884-Dachrollo] connection closed: disconnected
                              2024-08-28 23:29:11.924  - info: mqtt.1 (26882) Client [mosqpub|20886-Dachrollo] connected with secret 1724880551923_1207
                              2024-08-28 23:29:11.931  - info: mqtt.1 (26882) Client [mosqpub|20886-Dachrollo] connection closed: disconnected
                              2024-08-28 23:29:12.025  - info: mqtt.1 (26882) Client [mosqpub|20888-Dachrollo] connected with secret 1724880552024_7072
                              2024-08-28 23:29:12.030  - info: mqtt.1 (26882) Client [mosqpub|20888-Dachrollo] connection closed: disconnected
                              2024-08-28 23:29:12.124  - info: mqtt.1 (26882) Client [mosqpub|20890-Dachrollo] connected with secret 1724880552123_5335
                              2024-08-28 23:29:12.130  - info: mqtt.1 (26882) Client [mosqpub|20890-Dachrollo] connection closed: disconnected
                              2024-08-28 23:29:12.416  - info: mqtt.1 (26882) Client [mosqpub|20905-Dachrollo] connected with secret 1724880552414_5267
                              2024-08-28 23:29:12.426  - info: mqtt.1 (26882) Client [mosqpub|20905-Dachrollo] connection closed: disconnected
                              2024-08-28 23:29:12.593  - info: mqtt.1 (26882) Client [mosqpub|20911-Dachrollo] connected with secret 1724880552592_1927
                              2024-08-28 23:29:12.598  - info: mqtt.1 (26882) Client [mosqpub|20911-Dachrollo] connection closed: disconnected
                              2024-08-28 23:29:17.143  - info: web.0 (26709) <== Disconnect system.user.admin from ::ffff:192.168.1.63 vis.0
                              2024-08-28 23:29:19.190  - info: web.0 (26709) ==> Connected system.user.admin from ::ffff:192.168.1.63
                              2024-08-28 23:30:00.147  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: GPU Temp: 51.5 °C
                              2024-08-28 23:30:00.149  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: CPU Temp: 51.54 °C
                              2024-08-28 23:30:00.167  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: Freier RAM: 291
                               MB von 922MB (32%)
                              2024-08-28 23:30:00.168  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: Freier Swap: 1641
                               MB von 2048MB (80%)
                              2024-08-28 23:30:06.383  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] connected with secret 1724880606359_1638
                              2024-08-28 23:30:06.508  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.12V_on_off"
                              2024-08-28 23:30:06.527  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert2"
                              2024-08-28 23:30:06.529  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert3"
                              2024-08-28 23:30:06.530  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert4"
                              2024-08-28 23:30:06.530  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] connection closed: disconnected
                              2024-08-28 23:30:06.709  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                              2024-08-28 23:30:06.728  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                              2024-08-28 23:30:06.729  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                              2024-08-28 23:30:06.730  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                              2024-08-28 23:30:06.926  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] connected with secret 1724880606923_6224
                              2024-08-28 23:30:07.048  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.12V_on_off"
                              2024-08-28 23:30:07.058  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert2"
                              2024-08-28 23:30:07.059  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert3"
                              2024-08-28 23:30:07.060  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert4"
                              2024-08-28 23:30:07.249  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                              2024-08-28 23:30:07.259  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                              2024-08-28 23:30:07.260  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                              2024-08-28 23:30:07.261  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                              2024-08-28 23:30:08.311  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] connected with secret 1724880608310_4118
                              2024-08-28 23:30:08.334  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] subscribes on "/Aussenfuehler/#" with regex /^Aussenfuehler\..*/
                              2024-08-28 23:30:08.335  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] subscribes on "/Aussenfuehler/#"  with regex /^mqtt\.1\.Aussenfuehler\..*/
                              2024-08-28 23:30:08.536  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] publishOnSubscribe send all known states
                              2024-08-28 23:30:09.840  - info: mqtt.1 (26882) Client [mosqsub|20937-Dachrollo] connected with secret 1724880609839_84
                              2024-08-28 23:30:09.845  - info: mqtt.1 (26882) Client [mosqsub|20937-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
                              2024-08-28 23:30:10.047  - info: mqtt.1 (26882) Client [mosqsub|20937-Dachrollo] publishOnSubscribe
                              2024-08-28 23:30:10.052  - info: mqtt.1 (26882) Client [mosqsub|20937-Dachrollo] connection closed: disconnected
                              2024-08-28 23:30:10.139  - info: mqtt.1 (26882) Client [mosqsub|20939-Dachrollo] connected with secret 1724880610138_6843
                              2024-08-28 23:30:10.143  - info: mqtt.1 (26882) Client [mosqsub|20939-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
                              2024-08-28 23:30:10.344  - info: mqtt.1 (26882) Client [mosqsub|20939-Dachrollo] publishOnSubscribe
                              2024-08-28 23:30:10.348  - info: mqtt.1 (26882) Client [mosqsub|20939-Dachrollo] connection closed: disconnected
                              2024-08-28 23:30:10.435  - info: mqtt.1 (26882) Client [mosqsub|20941-Dachrollo] connected with secret 1724880610434_1514
                              2024-08-28 23:30:10.439  - info: mqtt.1 (26882) Client [mosqsub|20941-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
                              2024-08-28 23:30:10.639  - info: mqtt.1 (26882) Client [mosqsub|20941-Dachrollo] publishOnSubscribe
                              2024-08-28 23:30:10.642  - info: mqtt.1 (26882) Client [mosqsub|20941-Dachrollo] connection closed: disconnected
                              2024-08-28 23:30:10.729  - info: mqtt.1 (26882) Client [mosqsub|20943-Dachrollo] connected with secret 1724880610729_4274
                              2024-08-28 23:30:10.734  - info: mqtt.1 (26882) Client [mosqsub|20943-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
                              2024-08-28 23:30:10.933  - info: mqtt.1 (26882) Client [mosqsub|20943-Dachrollo] publishOnSubscribe
                              2024-08-28 23:30:10.937  - info: mqtt.1 (26882) Client [mosqsub|20943-Dachrollo] connection closed: disconnected
                              2024-08-28 23:30:11.024  - info: mqtt.1 (26882) Client [mosqsub|20945-Dachrollo] connected with secret 1724880611022_7241
                              2024-08-28 23:30:11.031  - info: mqtt.1 (26882) Client [mosqsub|20945-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
                              2024-08-28 23:30:11.231  - info: mqtt.1 (26882) Client [mosqsub|20945-Dachrollo] publishOnSubscribe
                              2024-08-28 23:30:11.235  - info: mqtt.1 (26882) Client [mosqsub|20945-Dachrollo] connection closed: disconnected
                              2024-08-28 23:30:11.334  - info: mqtt.1 (26882) Client [mosqpub|20947-Dachrollo] connected with secret 1724880611332_7886
                              2024-08-28 23:30:11.340  - info: mqtt.1 (26882) Client [mosqpub|20947-Dachrollo] connection closed: disconnected
                              2024-08-28 23:30:11.434  - info: mqtt.1 (26882) Client [mosqpub|20949-Dachrollo] connected with secret 1724880611432_1732
                              2024-08-28 23:30:11.438  - info: mqtt.1 (26882) Client [mosqpub|20949-Dachrollo] connection closed: disconnected
                              2024-08-28 23:30:11.532  - info: mqtt.1 (26882) Client [mosqpub|20951-Dachrollo] connected with secret 1724880611531_1670
                              2024-08-28 23:30:11.536  - info: mqtt.1 (26882) Client [mosqpub|20951-Dachrollo] connection closed: disconnected
                              2024-08-28 23:30:11.633  - info: mqtt.1 (26882) Client [mosqpub|20953-Dachrollo] connected with secret 1724880611632_7524
                              2024-08-28 23:30:11.637  - info: mqtt.1 (26882) Client [mosqpub|20953-Dachrollo] connection closed: disconnected
                              2024-08-28 23:30:11.731  - info: mqtt.1 (26882) Client [mosqpub|20955-Dachrollo] connected with secret 1724880611730_1286
                              2024-08-28 23:30:11.737  - info: mqtt.1 (26882) Client [mosqpub|20955-Dachrollo] connection closed: disconnected
                              2024-08-28 23:30:12.022  - info: mqtt.1 (26882) Client [mosqpub|20970-Dachrollo] connected with secret 1724880612020_5469
                              2024-08-28 23:30:12.028  - info: mqtt.1 (26882) Client [mosqpub|20970-Dachrollo] connection closed: disconnected
                              2024-08-28 23:30:12.191  - info: mqtt.1 (26882) Client [mosqpub|20976-Dachrollo] connected with secret 1724880612190_4018
                              2024-08-28 23:30:12.196  - info: mqtt.1 (26882) Client [mosqpub|20976-Dachrollo] connection closed: disconnected
                              2024-08-28 23:30:16.090  - info: host.raspberrypi instance system.adapter.solarmanpv.0 in version "0.5.1" started with pid 3463
                              2024-08-28 23:30:20.386  - info: solarmanpv.0 (3463) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v20.17.0, js-controller: 6.0.11
                              2024-08-28 23:30:26.448  - info: solarmanpv.0 (3463) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                              2024-08-28 23:30:27.010  - info: host.raspberrypi instance system.adapter.solarmanpv.0 having pid 3463 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2024-08-28 23:31:01.576  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] connection closed: disconnected
                              2024-08-28 23:31:09.600  - info: mqtt.1 (26882) Client [mosqsub|21001-Dachrollo] connected with secret 1724880669599_266
                              2024-08-28 23:31:09.605  - info: mqtt.1 (26882) Client [mosqsub|21001-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
                              2024-08-28 23:31:09.806  - info: mqtt.1 (26882) Client [mosqsub|21001-Dachrollo] publishOnSubscribe
                              2024-08-28 23:31:09.810  - info: mqtt.1 (26882) Client [mosqsub|21001-Dachrollo] connection closed: disconnected
                              2024-08-28 23:31:09.897  - info: mqtt.1 (26882) Client [mosqsub|21003-Dachrollo] connected with secret 1724880669896_5577
                              2024-08-28 23:31:09.901  - info: mqtt.1 (26882) Client [mosqsub|21003-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
                              2024-08-28 23:31:10.102  - info: mqtt.1 (26882) Client [mosqsub|21003-Dachrollo] publishOnSubscribe
                              2024-08-28 23:31:10.105  - info: mqtt.1 (26882) Client [mosqsub|21003-Dachrollo] connection closed: disconnected
                              2024-08-28 23:31:10.195  - info: mqtt.1 (26882) Client [mosqsub|21005-Dachrollo] connected with secret 1724880670193_6155
                              2024-08-28 23:31:10.199  - info: mqtt.1 (26882) Client [mosqsub|21005-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
                              2024-08-28 23:31:10.400  - info: mqtt.1 (26882) Client [mosqsub|21005-Dachrollo] publishOnSubscribe
                              2024-08-28 23:31:10.404  - info: mqtt.1 (26882) Client [mosqsub|21005-Dachrollo] connection closed: disconnected
                              2024-08-28 23:31:10.494  - info: mqtt.1 (26882) Client [mosqsub|21007-Dachrollo] connected with secret 1724880670492_5423
                              2024-08-28 23:31:10.498  - info: mqtt.1 (26882) Client [mosqsub|21007-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
                              2024-08-28 23:31:10.700  - info: mqtt.1 (26882) Client [mosqsub|21007-Dachrollo] publishOnSubscribe
                              2024-08-28 23:31:10.704  - info: mqtt.1 (26882) Client [mosqsub|21007-Dachrollo] connection closed: disconnected
                              2024-08-28 23:31:10.793  - info: mqtt.1 (26882) Client [mosqsub|21009-Dachrollo] connected with secret 1724880670792_2510
                              2024-08-28 23:31:10.798  - info: mqtt.1 (26882) Client [mosqsub|21009-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
                              2024-08-28 23:31:10.999  - info: mqtt.1 (26882) Client [mosqsub|21009-Dachrollo] publishOnSubscribe
                              2024-08-28 23:31:11.004  - info: mqtt.1 (26882) Client [mosqsub|21009-Dachrollo] connection closed: disconnected
                              2024-08-28 23:31:11.100  - info: mqtt.1 (26882) Client [mosqpub|21011-Dachrollo] connected with secret 1724880671099_3141
                              2024-08-28 23:31:11.105  - info: mqtt.1 (26882) Client [mosqpub|21011-Dachrollo] connection closed: disconnected
                              2024-08-28 23:31:11.201  - info: mqtt.1 (26882) Client [mosqpub|21013-Dachrollo] connected with secret 1724880671200_5157
                              2024-08-28 23:31:11.205  - info: mqtt.1 (26882) Client [mosqpub|21013-Dachrollo] connection closed: disconnected
                              2024-08-28 23:31:11.301  - info: mqtt.1 (26882) Client [mosqpub|21015-Dachrollo] connected with secret 1724880671300_2586
                              2024-08-28 23:31:11.306  - info: mqtt.1 (26882) Client [mosqpub|21015-Dachrollo] connection closed: disconnected
                              2024-08-28 23:31:11.400  - info: mqtt.1 (26882) Client [mosqpub|21017-Dachrollo] connected with secret 1724880671398_6147
                              2024-08-28 23:31:11.406  - info: mqtt.1 (26882) Client [mosqpub|21017-Dachrollo] connection closed: disconnected
                              2024-08-28 23:31:11.498  - info: mqtt.1 (26882) Client [mosqpub|21019-Dachrollo] connected with secret 1724880671497_5787
                              2024-08-28 23:31:11.502  - info: mqtt.1 (26882) Client [mosqpub|21019-Dachrollo] connection closed: disconnected
                              2024-08-28 23:31:11.788  - info: mqtt.1 (26882) Client [mosqpub|21034-Dachrollo] connected with secret 1724880671787_1514
                              2024-08-28 23:31:11.793  - info: mqtt.1 (26882) Client [mosqpub|21034-Dachrollo] connection closed: disconnected
                              2024-08-28 23:31:11.959  - info: mqtt.1 (26882) Client [mosqpub|21040-Dachrollo] connected with secret 1724880671958_6103
                              2024-08-28 23:31:11.964  - info: mqtt.1 (26882) Client [mosqpub|21040-Dachrollo] connection closed: disconnected
                              2024-08-28 23:31:12.255  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] connection closed: timeout
                              2024-08-28 23:31:53.672  - info: web.0 (26709) <== Disconnect system.user.admin from ::ffff:192.168.1.63 vis.0
                              2024-08-28 23:32:09.627  - info: mqtt.1 (26882) Client [mosqsub|21065-Dachrollo] connected with secret 1724880729626_9840
                              2024-08-28 23:32:09.630  - info: mqtt.1 (26882) Client [mosqsub|21065-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
                              2024-08-28 23:32:09.831  - info: mqtt.1 (26882) Client [mosqsub|21065-Dachrollo] publishOnSubscribe
                              2024-08-28 23:32:09.836  - info: mqtt.1 (26882) Client [mosqsub|21065-Dachrollo] connection closed: disconnected
                              2024-08-28 23:32:09.920  - info: mqtt.1 (26882) Client [mosqsub|21067-Dachrollo] connected with secret 1724880729919_130
                              2024-08-28 23:32:09.924  - info: mqtt.1 (26882) Client [mosqsub|21067-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
                              2024-08-28 23:32:10.126  - info: mqtt.1 (26882) Client [mosqsub|21067-Dachrollo] publishOnSubscribe
                              2024-08-28 23:32:10.131  - info: mqtt.1 (26882) Client [mosqsub|21067-Dachrollo] connection closed: disconnected
                              2024-08-28 23:32:10.215  - info: mqtt.1 (26882) Client [mosqsub|21069-Dachrollo] connected with secret 1724880730214_885
                              2024-08-28 23:32:10.219  - info: mqtt.1 (26882) Client [mosqsub|21069-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
                              2024-08-28 23:32:10.420  - info: mqtt.1 (26882) Client [mosqsub|21069-Dachrollo] publishOnSubscribe
                              2024-08-28 23:32:10.424  - info: mqtt.1 (26882) Client [mosqsub|21069-Dachrollo] connection closed: disconnected
                              2024-08-28 23:32:10.512  - info: mqtt.1 (26882) Client [mosqsub|21071-Dachrollo] connected with secret 1724880730511_5111
                              2024-08-28 23:32:10.515  - info: mqtt.1 (26882) Client [mosqsub|21071-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
                              2024-08-28 23:32:10.716  - info: mqtt.1 (26882) Client [mosqsub|21071-Dachrollo] publishOnSubscribe
                              2024-08-28 23:32:10.720  - info: mqtt.1 (26882) Client [mosqsub|21071-Dachrollo] connection closed: disconnected
                              2024-08-28 23:32:10.808  - info: mqtt.1 (26882) Client [mosqsub|21073-Dachrollo] connected with secret 1724880730807_9951
                              2024-08-28 23:32:10.813  - info: mqtt.1 (26882) Client [mosqsub|21073-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
                              2024-08-28 23:32:11.014  - info: mqtt.1 (26882) Client [mosqsub|21073-Dachrollo] publishOnSubscribe
                              2024-08-28 23:32:11.018  - info: mqtt.1 (26882) Client [mosqsub|21073-Dachrollo] connection closed: disconnected
                              2024-08-28 23:32:11.116  - info: mqtt.1 (26882) Client [mosqpub|21075-Dachrollo] connected with secret 1724880731115_4953
                              2024-08-28 23:32:11.122  - info: mqtt.1 (26882) Client [mosqpub|21075-Dachrollo] connection closed: disconnected
                              2024-08-28 23:32:11.217  - info: mqtt.1 (26882) Client [mosqpub|21077-Dachrollo] connected with secret 1724880731216_3779
                              2024-08-28 23:32:11.224  - info: mqtt.1 (26882) Client [mosqpub|21077-Dachrollo] connection closed: disconnected
                              2024-08-28 23:32:11.318  - info: mqtt.1 (26882) Client [mosqpub|21079-Dachrollo] connected with secret 1724880731317_7677
                              2024-08-28 23:32:11.323  - info: mqtt.1 (26882) Client [mosqpub|21079-Dachrollo] connection closed: disconnected
                              2024-08-28 23:32:11.414  - info: mqtt.1 (26882) Client [mosqpub|21081-Dachrollo] connected with secret 1724880731414_1714
                              2024-08-28 23:32:11.421  - info: mqtt.1 (26882) Client [mosqpub|21081-Dachrollo] connection closed: disconnected
                              2024-08-28 23:32:11.511  - info: mqtt.1 (26882) Client [mosqpub|21083-Dachrollo] connected with secret 1724880731510_2679
                              2024-08-28 23:32:11.517  - info: mqtt.1 (26882) Client [mosqpub|21083-Dachrollo] connection closed: disconnected
                              2024-08-28 23:32:11.801  - info: mqtt.1 (26882) Client [mosqpub|21098-Dachrollo] connected with secret 1724880731800_6944
                              2024-08-28 23:32:11.805  - info: mqtt.1 (26882) Client [mosqpub|21098-Dachrollo] connection closed: disconnected
                              2024-08-28 23:32:11.974  - info: mqtt.1 (26882) Client [mosqpub|21104-Dachrollo] connected with secret 1724880731973_9365
                              2024-08-28 23:32:11.979  - info: mqtt.1 (26882) Client [mosqpub|21104-Dachrollo] connection closed: disconnected
                              2024-08-28 23:33:00.167  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: Freier Swap: 1647
                               MB von 2048MB (80%)
                              2024-08-28 23:33:00.169  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: GPU Temp: 50.5 °C
                              2024-08-28 23:33:00.170  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: CPU Temp: 50.464 °C
                              2024-08-28 23:33:00.174  - info: javascript.0 (26627) script.js.Telegram_Bot.System_Temperaturen: Freier RAM: 275
                               MB von 922MB (30%)
                              2024-08-28 23:33:09.618  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] connected with secret 1724880789617_2706
                              2024-08-28 23:33:09.748  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.12V_on_off"
                              2024-08-28 23:33:09.763  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert2"
                              2024-08-28 23:33:09.764  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert3"
                              2024-08-28 23:33:09.765  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] subscribes on "mqtt.1.Wert4"
                              2024-08-28 23:33:09.766  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] connection closed: disconnected
                              2024-08-28 23:33:09.949  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                              2024-08-28 23:33:09.964  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                              2024-08-28 23:33:09.970  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                              2024-08-28 23:33:09.971  - info: mqtt.1 (26882) Client [Aussenfuehler-Import] publishOnSubscribe
                              2024-08-28 23:33:10.158  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] connected with secret 1724880790154_1169
                              2024-08-28 23:33:10.198  - info: mqtt.1 (26882) Client [mosqsub|21130-Dachrollo] connected with secret 1724880790197_1908
                              2024-08-28 23:33:10.202  - info: mqtt.1 (26882) Client [mosqsub|21130-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
                              2024-08-28 23:33:10.278  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.12V_on_off"
                              2024-08-28 23:33:10.288  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert2"
                              2024-08-28 23:33:10.289  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert3"
                              2024-08-28 23:33:10.290  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] subscribes on "mqtt.1.Wert4"
                              2024-08-28 23:33:10.403  - info: mqtt.1 (26882) Client [mosqsub|21130-Dachrollo] publishOnSubscribe
                              2024-08-28 23:33:10.407  - info: mqtt.1 (26882) Client [mosqsub|21130-Dachrollo] connection closed: disconnected
                              2024-08-28 23:33:10.480  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                              2024-08-28 23:33:10.489  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                              2024-08-28 23:33:10.491  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                              2024-08-28 23:33:10.492  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] publishOnSubscribe
                              2024-08-28 23:33:10.496  - info: mqtt.1 (26882) Client [mosqsub|21132-Dachrollo] connected with secret 1724880790495_8889
                              2024-08-28 23:33:10.501  - info: mqtt.1 (26882) Client [mosqsub|21132-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
                              2024-08-28 23:33:10.702  - info: mqtt.1 (26882) Client [mosqsub|21132-Dachrollo] publishOnSubscribe
                              2024-08-28 23:33:10.707  - info: mqtt.1 (26882) Client [mosqsub|21132-Dachrollo] connection closed: disconnected
                              2024-08-28 23:33:10.782  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] connected with secret 1724880790781_6189
                              2024-08-28 23:33:10.797  - info: mqtt.1 (26882) Client [mosqsub|21134-Dachrollo] connected with secret 1724880790791_138
                              2024-08-28 23:33:10.802  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] subscribes on "/Aussenfuehler/#" with regex /^Aussenfuehler\..*/
                              2024-08-28 23:33:10.803  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] subscribes on "/Aussenfuehler/#"  with regex /^mqtt\.1\.Aussenfuehler\..*/
                              2024-08-28 23:33:10.806  - info: mqtt.1 (26882) Client [mosqsub|21134-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
                              2024-08-28 23:33:10.837  - info: mqtt.1 (26882) Client [mosqsub|21134-Dachrollo] connection closed: disconnected
                              2024-08-28 23:33:10.921  - info: mqtt.1 (26882) Client [mosqsub|21136-Dachrollo] connected with secret 1724880790921_4967
                              2024-08-28 23:33:10.926  - info: mqtt.1 (26882) Client [mosqsub|21136-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
                              2024-08-28 23:33:11.003  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] publishOnSubscribe send all known states
                              2024-08-28 23:33:11.007  - info: mqtt.1 (26882) Client [mosqsub|21134-Dachrollo] publishOnSubscribe
                              2024-08-28 23:33:11.126  - info: mqtt.1 (26882) Client [mosqsub|21136-Dachrollo] publishOnSubscribe
                              2024-08-28 23:33:11.144  - info: mqtt.1 (26882) Client [mosqsub|21136-Dachrollo] connection closed: disconnected
                              2024-08-28 23:33:11.231  - info: mqtt.1 (26882) Client [mosqsub|21138-Dachrollo] connected with secret 1724880791230_2289
                              2024-08-28 23:33:11.235  - info: mqtt.1 (26882) Client [mosqsub|21138-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
                              2024-08-28 23:33:11.436  - info: mqtt.1 (26882) Client [mosqsub|21138-Dachrollo] publishOnSubscribe
                              2024-08-28 23:33:11.440  - info: mqtt.1 (26882) Client [mosqsub|21138-Dachrollo] connection closed: disconnected
                              2024-08-28 23:33:11.537  - info: mqtt.1 (26882) Client [mosqpub|21140-Dachrollo] connected with secret 1724880791536_1720
                              2024-08-28 23:33:11.542  - info: mqtt.1 (26882) Client [mosqpub|21140-Dachrollo] connection closed: disconnected
                              2024-08-28 23:33:11.635  - info: mqtt.1 (26882) Client [mosqpub|21142-Dachrollo] connected with secret 1724880791634_1007
                              2024-08-28 23:33:11.640  - info: mqtt.1 (26882) Client [mosqpub|21142-Dachrollo] connection closed: disconnected
                              2024-08-28 23:33:11.733  - info: mqtt.1 (26882) Client [mosqpub|21144-Dachrollo] connected with secret 1724880791732_6488
                              2024-08-28 23:33:11.739  - info: mqtt.1 (26882) Client [mosqpub|21144-Dachrollo] connection closed: disconnected
                              2024-08-28 23:33:11.831  - info: mqtt.1 (26882) Client [mosqpub|21146-Dachrollo] connected with secret 1724880791830_5171
                              2024-08-28 23:33:11.837  - info: mqtt.1 (26882) Client [mosqpub|21146-Dachrollo] connection closed: disconnected
                              2024-08-28 23:33:11.932  - info: mqtt.1 (26882) Client [mosqpub|21148-Dachrollo] connected with secret 1724880791931_7
                              2024-08-28 23:33:11.936  - info: mqtt.1 (26882) Client [mosqpub|21148-Dachrollo] connection closed: disconnected
                              2024-08-28 23:33:12.102  - info: host.raspberrypi instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 4431
                              2024-08-28 23:33:12.221  - info: mqtt.1 (26882) Client [mosqpub|21163-Dachrollo] connected with secret 1724880792220_4268
                              2024-08-28 23:33:12.226  - info: mqtt.1 (26882) Client [mosqpub|21163-Dachrollo] connection closed: disconnected
                              2024-08-28 23:33:12.390  - info: mqtt.1 (26882) Client [mosqpub|21169-Dachrollo] connected with secret 1724880792389_8236
                              2024-08-28 23:33:12.397  - info: mqtt.1 (26882) Client [mosqpub|21169-Dachrollo] connection closed: disconnected
                              2024-08-28 23:33:17.921  - info: openweathermap.0 (4431) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.17.0, js-controller: 6.0.11
                              2024-08-28 23:33:33.176  - info: openweathermap.0 (4431) Terminated (NO_ERROR): Without reason
                              2024-08-28 23:33:33.731  - info: host.raspberrypi instance system.adapter.openweathermap.0 having pid 4431 terminated with code 0 (NO_ERROR)
                              2024-08-28 23:33:55.602  - info: mqtt.1 (26882) Client [ESPClient_4C:11:AE:04:5D:28] connection closed: disconnected
                              2024-08-28 23:34:05.529  - info: mqtt.1 (26882) Client [Aussenfuehler-Import1] connection closed: timeout
                              2024-08-28 23:34:10.081  - info: mqtt.1 (26882) Client [mosqsub|21194-Dachrollo] connected with secret 1724880850080_3567
                              2024-08-28 23:34:10.087  - info: mqtt.1 (26882) Client [mosqsub|21194-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
                              2024-08-28 23:34:10.288  - info: mqtt.1 (26882) Client [mosqsub|21194-Dachrollo] publishOnSubscribe
                              2024-08-28 23:34:10.292  - info: mqtt.1 (26882) Client [mosqsub|21194-Dachrollo] connection closed: disconnected
                              2024-08-28 23:34:10.382  - info: mqtt.1 (26882) Client [mosqsub|21196-Dachrollo] connected with secret 1724880850380_616
                              2024-08-28 23:34:10.386  - info: mqtt.1 (26882) Client [mosqsub|21196-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
                              2024-08-28 23:34:10.588  - info: mqtt.1 (26882) Client [mosqsub|21196-Dachrollo] publishOnSubscribe
                              2024-08-28 23:34:10.592  - info: mqtt.1 (26882) Client [mosqsub|21196-Dachrollo] connection closed: disconnected
                              2024-08-28 23:34:10.680  - info: mqtt.1 (26882) Client [mosqsub|21198-Dachrollo] connected with secret 1724880850679_9243
                              2024-08-28 23:34:10.684  - info: mqtt.1 (26882) Client [mosqsub|21198-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
                              2024-08-28 23:34:10.886  - info: mqtt.1 (26882) Client [mosqsub|21198-Dachrollo] publishOnSubscribe
                              2024-08-28 23:34:10.890  - info: mqtt.1 (26882) Client [mosqsub|21198-Dachrollo] connection closed: disconnected
                              2024-08-28 23:34:10.979  - info: mqtt.1 (26882) Client [mosqsub|21200-Dachrollo] connected with secret 1724880850978_7977
                              2024-08-28 23:34:10.983  - info: mqtt.1 (26882) Client [mosqsub|21200-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
                              2024-08-28 23:34:11.184  - info: mqtt.1 (26882) Client [mosqsub|21200-Dachrollo] publishOnSubscribe
                              2024-08-28 23:34:11.188  - info: mqtt.1 (26882) Client [mosqsub|21200-Dachrollo] connection closed: disconnected
                              2024-08-28 23:34:11.273  - info: mqtt.1 (26882) Client [mosqsub|21202-Dachrollo] connected with secret 1724880851272_675
                              2024-08-28 23:34:11.276  - info: mqtt.1 (26882) Client [mosqsub|21202-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
                              2024-08-28 23:34:11.477  - info: mqtt.1 (26882) Client [mosqsub|21202-Dachrollo] publishOnSubscribe
                              2024-08-28 23:34:11.480  - info: mqtt.1 (26882) Client [mosqsub|21202-Dachrollo] connection closed: disconnected
                              2024-08-28 23:34:11.578  - info: mqtt.1 (26882) Client [mosqpub|21204-Dachrollo] connected with secret 1724880851578_9634
                              2024-08-28 23:34:11.582  - info: mqtt.1 (26882) Client [mosqpub|21204-Dachrollo] connection closed: disconnected
                              2024-08-28 23:34:11.677  - info: mqtt.1 (26882) Client [mosqpub|21206-Dachrollo] connected with secret 1724880851676_7585
                              2024-08-28 23:34:11.681  - info: mqtt.1 (26882) Client [mosqpub|21206-Dachrollo] connection closed: disconnected
                              2024-08-28 23:34:11.783  - info: mqtt.1 (26882) Client [mosqpub|21208-Dachrollo] connected with secret 1724880851781_2571
                              2024-08-28 23:34:11.787  - info: mqtt.1 (26882) Client [mosqpub|21208-Dachrollo] connection closed: disconnected
                              2024-08-28 23:34:11.883  - info: mqtt.1 (26882) Client [mosqpub|21210-Dachrollo] connected with secret 1724880851882_5629
                              2024-08-28 23:34:11.887  - info: mqtt.1 (26882) Client [mosqpub|21210-Dachrollo] connection closed: disconnected
                              2024-08-28 23:34:11.984  - info: mqtt.1 (26882) Client [mosqpub|21212-Dachrollo] connected with secret 1724880851983_6311
                              2024-08-28 23:34:11.989  - info: mqtt.1 (26882) Client [mosqpub|21212-Dachrollo] connection closed: disconnected
                              2024-08-28 23:34:12.275  - info: mqtt.1 (26882) Client [mosqpub|21227-Dachrollo] connected with secret 1724880852274_1264
                              2024-08-28 23:34:12.280  - info: mqtt.1 (26882) Client [mosqpub|21227-Dachrollo] connection closed: disconnected
                              2024-08-28 23:34:12.443  - info: mqtt.1 (26882) Client [mosqpub|21233-Dachrollo] connected with secret 1724880852442_7748
                              2024-08-28 23:34:12.449  - info: mqtt.1 (26882) Client [mosqpub|21233-Dachrollo] connection closed: disconnected
                              2024-08-28 23:35:10.184  - info: mqtt.1 (26882) Client [mosqsub|21259-Dachrollo] connected with secret 1724880910179_266
                              2024-08-28 23:35:10.188  - info: mqtt.1 (26882) Client [mosqsub|21259-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Temperatur"
                              2024-08-28 23:35:10.389  - info: mqtt.1 (26882) Client [mosqsub|21259-Dachrollo] publishOnSubscribe
                              2024-08-28 23:35:10.392  - info: mqtt.1 (26882) Client [mosqsub|21259-Dachrollo] connection closed: disconnected
                              2024-08-28 23:35:10.481  - info: mqtt.1 (26882) Client [mosqsub|21261-Dachrollo] connected with secret 1724880910480_4468
                              2024-08-28 23:35:10.485  - info: mqtt.1 (26882) Client [mosqsub|21261-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Temperatur_Feucht_Si7021.Luftfeuchtigkeit"
                              2024-08-28 23:35:10.686  - info: mqtt.1 (26882) Client [mosqsub|21261-Dachrollo] publishOnSubscribe
                              2024-08-28 23:35:10.691  - info: mqtt.1 (26882) Client [mosqsub|21261-Dachrollo] connection closed: disconnected
                              2024-08-28 23:35:10.776  - info: mqtt.1 (26882) Client [mosqsub|21263-Dachrollo] connected with secret 1724880910775_6079
                              2024-08-28 23:35:10.780  - info: mqtt.1 (26882) Client [mosqsub|21263-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.status.LWT"
                              2024-08-28 23:35:10.980  - info: mqtt.1 (26882) Client [mosqsub|21263-Dachrollo] publishOnSubscribe
                              2024-08-28 23:35:10.984  - info: mqtt.1 (26882) Client [mosqsub|21263-Dachrollo] connection closed: disconnected
                              2024-08-28 23:35:11.074  - info: mqtt.1 (26882) Client [mosqsub|21265-Dachrollo] connected with secret 1724880911073_2895
                              2024-08-28 23:35:11.079  - info: mqtt.1 (26882) Client [mosqsub|21265-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Licht.Licht"
                              2024-08-28 23:35:11.280  - info: mqtt.1 (26882) Client [mosqsub|21265-Dachrollo] publishOnSubscribe
                              2024-08-28 23:35:11.284  - info: mqtt.1 (26882) Client [mosqsub|21265-Dachrollo] connection closed: disconnected
                              2024-08-28 23:35:11.372  - info: mqtt.1 (26882) Client [mosqsub|21267-Dachrollo] connected with secret 1724880911370_5712
                              2024-08-28 23:35:11.376  - info: mqtt.1 (26882) Client [mosqsub|21267-Dachrollo] subscribes on "mqtt.1.Aussenfuehler.Akku_Spannung.AkkuSpannung"
                              2024-08-28 23:35:11.578  - info: mqtt.1 (26882) Client [mosqsub|21267-Dachrollo] publishOnSubscribe
                              2024-08-28 23:35:11.581  - info: mqtt.1 (26882) Client [mosqsub|21267-Dachrollo] connection closed: disconnected
                              2024-08-28 23:35:11.678  - info: mqtt.1 (26882) Client [mosqpub|21269-Dachrollo] connected with secret 1724880911677_3316
                              2024-08-28 23:35:11.682  - info: mqtt.1 (26882) Client [mosqpub|21269-Dachrollo] connection closed: disconnected
                              2024-08-28 23:35:11.777  - info: mqtt.1 (26882) Client [mosqpub|21271-Dachrollo] connected with secret 1724880911776_1770
                              2024-08-28 23:35:11.781  - info: mqtt.1 (26882) Client [mosqpub|21271-Dachrollo] connection closed: disconnected
                              2024-08-28 23:35:11.875  - info: mqtt.1 (26882) Client [mosqpub|21273-Dachrollo] connected with secret 1724880911874_1281
                              2024-08-28 23:35:11.879  - info: mqtt.1 (26882) Client [mosqpub|21273-Dachrollo] connection closed: disconnected
                              2024-08-28 23:35:11.972  - info: mqtt.1 (26882) Client [mosqpub|21275-Dachrollo] connected with secret 1724880911971_1361
                              2024-08-28 23:35:11.976  - info: mqtt.1 (26882) Client [mosqpub|21275-Dachrollo] connection closed: disconnected
                              2024-08-28 23:35:12.070  - info: mqtt.1 (26882) Client [mosqpub|21277-Dachrollo] connected with secret 1724880912069_4224
                              2024-08-28 23:35:12.075  - info: mqtt.1 (26882) Client [mosqpub|21277-Dachrollo] connection closed: disconnected
                              2024-08-28 23:35:12.365  - info: mqtt.1 (26882) Client [mosqpub|21292-Dachrollo] connected with secret 1724880912364_9741
                              2024-08-28 23:35:12.374  - info: mqtt.1 (26882) Client [mosqpub|21292-Dachrollo] connection closed: disconnected
                              2024-08-28 23:35:12.541  - info: mqtt.1 (26882) Client [mosqpub|21298-Dachrollo] connected with secret 1724880912539_6908
                              2024-08-28 23:35:12.546  - info: mqtt.1 (26882) Client [mosqpub|21298-Dachrollo] connection closed: disconnected
                              2024-08-28 23:35:16.047  - info: host.raspberrypi instance system.adapter.solarmanpv.0 in version "0.5.1" started with pid 5119
                              2024-08-28 23:35:20.529  - info: solarmanpv.0 (5119) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v20.17.0, js-controller: 6.0.11
                              2024-08-28 23:35:24.146  - info: solarmanpv.0 (5119) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                              2024-08-28 23:35:24.701  - info: host.raspberrypi instance system.adapter.solarmanpv.0 having pid 5119 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              pi@raspberrypi:~ $
                              spicer 1 Reply Last reply Reply Quote 0
                              • spicer
                                Das ist wohl interessanter:
                                2024-08-28 23:24:40.199  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1228
                                2024-08-28 23:24:40.201  - error: host.raspberrypi Caught by controller[0]:   throw err;
                                2024-08-28 23:24:40.202  - error: host.raspberrypi Caught by controller[0]:   ^
                                2024-08-28 23:24:40.204  - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '@iobroker/adapter-core'
                                2024-08-28 23:24:40.205  - error: host.raspberrypi Caught by controller[0]: Require stack:
                                2024-08-28 23:24:40.206  - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/main.js
                                2024-08-28 23:24:40.207  - error: host.raspberrypi Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1225:15)
                                2024-08-28 23:24:40.208  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1051:27)
                                2024-08-28 23:24:40.210  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
                                2024-08-28 23:24:40.210  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                                2024-08-28 23:24:40.211  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/main.js:12:21)
                                2024-08-28 23:24:40.211  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1469:14)
                                2024-08-28 23:24:40.212  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                                2024-08-28 23:24:40.213  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1288:32)
                                2024-08-28 23:24:40.214  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1104:12)
                                2024-08-28 23:24:40.215  - error: host.raspberrypi Caught by controller[0]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12) {
                                2024-08-28 23:24:40.215  - error: host.raspberrypi Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                2024-08-28 23:24:40.218  - error: host.raspberrypi Caught by controller[0]:   requireStack: [ '/opt/iobroker/node_modules/iobroker.echarts/main.js' ]
                                2024-08-28 23:24:40.222  - error: host.raspberrypi Caught by controller[0]: }
                                2024-08-28 23:24:40.223  - error: host.raspberrypi Caught by controller[0]: Node.js v20.17.0
                                2024-08-28 23:24:40.224  - error: host.raspberrypi instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                2024-08-28 23:24:40.225  - info: host.raspberrypi Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                  Thomas Braun Most Active @spicer last edited by
                                  @spicer
                                  iobroker rebuild echarts
                                  parallel in einer zweiten Session das Log beobachten.
                                  iob logs --watch
                                  • spicer
                                    spicer @Thomas Braun last edited by
                                    pi@raspberrypi:~ $ iobroker rebuild echarts
                                    Rebuilding native module "echarts" ...
                                    rebuilt dependencies successfully
                                    Rebuilding native modules done
                                    In der anderen Konsole ist nichts relevantes erschienen.
                                    • spicer
                                      Sorry, ich muss jetzt erstmal ins Bett. Kann morgen am späteren Nachmittag weiter machen 😉
                                      Vielen Dank schonmal für Deine Hilfe.
                                      • spicer
                                        spicer @Thomas Braun last edited by spicer
                                        @thomas-braun sagte in Nach Update js-controller macht host.raspberrypi Fehler:
                                        Hab ich vor ca 2 Jahren auf Empfehlung von hier bereits gemacht und immer brav die empfohlenen Updates gemacht.
                                        Damals war das System auch in instabilem Zustand wegen Updates.
                                        Dann mache ich doch besser keine Updates mehr... ist eigentlich Irrsinn.
                                        Habe mich ev etwas falsch ausgedrückt.
                                        Am RPI hängt ein RaspBee 2 (ZigBee Adapter). Um diese GUI zu erhalten
                                        habe ich keine Lösung gefunden, bei welcher die GUI per http im Browser angeschaut/editiert werden kann.
                                        Natürlich hat man sonst auf den Servern keine GUI. Das hab ich auf meinen externen Servern auch nirgends drauf 😉
                                        • spicer
                                          Zum Problem zurück.
                                          Jetzt wird's interessant. eCharts funktioniert und es kommen auch keine Fehler mehr im Log.
                                          Aber bei den Instanzen steht:
                                            @spicer sagte in Nach Update js-controller macht host.raspberrypi Fehler:
                                            Du sollst es ja auch nicht updaten sondern NEUinstallieren.
                                            spicer M 2 Replies Last reply Reply Quote 0
                                            31.6k
                                            79.5k
                                            1493
