    4. [Javascript] Midas (Aquatemp) Poolheizung
    • Michael Roling
      Michael Roling Developer @sunnylaila last edited by
      @sunnylaila weil aktuell nichts an Daten rein kommt. Bzw. welche Daten meinst du ?
        sunnylaila @Michael Roling last edited by
        @michael-roling
        zb die Daten von temp in und temp out
        laut log würde ich denken das es t2 und t3 sind die aber nicht in Objekte übernommen wird
        2024-07-21 19:15:34.799	info	DeviceDetails: {"sessionid":null,"error_code":"0","error_msg":"Success","error_msg_code":"","totalSize":null,"totalPage":null,"nextPage":null,"objectResult":[{"value":"1","code":"Power"},{"value":"1","code":"Mode"},{"value":"0","code":"Manual-mute"},{"value":"0","code":"T01"},{"value":"0","code":"T02"},{"value":"0","code":"2074"},{"value":"0","code":"2075"},{"value":"0","code":"2076"},{"value":"0","code":"2077"},{"value":"0","code":"H03"},{"value":"0","code":"Set_Temp"},{"value":"12.0","code":"R08"},{"value":"40.0","code":"R09"},{"value":"12.0","code":"R10"},{"value":"40.0","code":"R11"},{"value":"26.0","code":"R01"},{"value":"25.0","code":"R02"},{"value":"26.0","code":"R03"},{"value":"0","code":"T03"},{"value":"0","code":"1158"},{"value":"0","code":"1159"},{"value":"8","code":"F17"},{"value":"2","code":"H02"},{"value":"0","code":"T04"},{"value":"0","code":"T05"},{"value":"0","code":"T06"},{"value":"0","code":"T07"},{"value":"0","code":"T14"},{"value":"0","code":"T17"},{"value":"17.0","code":"T1"},{"value":"29.0","code":"T2"},{"value":"29.0","code":"T3"},{"value":"28.5","code":"T4"},{"value":"30.0","code":"T5"},{"value":"0","code":"T6"},{"value":"0","code":"T7"}],"isReusltSuc":true}
        • Michael Roling
          @sunnylaila Versuch jetzt noch mal, ich habe in meiner Heizung geschaut gehabt und habe deswegen den falschen Wert eingetragen. 🙈
            @michael-roling
            ja genau das war es, jetzt geht es und trägt die Werte auch in Objekte ein
            vielen vielen Dank für deine Mühen.
            Brauchst du den Test Account noch?
            • Michael Roling
              @sunnylaila grundsätzlich brauche ich den nicht mehr. Aber ich würde vorschlagen du testest morgen noch mal in Ruhe , auch mit werte setzen usw. Wenn alles geht kannst du den löschen. Du kannst den natürlich auch sofort löschen und gegebenenfalls neu erstellen wenn benötigt
                @michael-roling
                ok machen wir so, werde es noch ein paar tage lassen falls du etwas testen möchtest.
                • Michael Roling
                  Michael Roling Developer @oxident last edited by
                  @oxident Moin. Hast du eine eine Liste mit Geräten die mit dem Adapter funktionieren? Oder Links zum Hersteller , oder so?
                  mcm1957 O 2 Replies Last reply Reply Quote 0
                  • mcm1957
                    mcm1957 @Michael Roling last edited by mcm1957
                    Der ADAPTER für midas-aquatemp wurde vom Dev aus den Repositoriies zurückgezogen u wird - wenn ich die Information nicht falsch verstanden habe - NICHT weiterentwickelt.
                    Ref https://github.com/ioBroker/ioBroker.repositories/pull/3890
                    MiRo1310 created this issue in ioBroker/ioBroker.repositories
                    closed Add midas-aquatemp to latest #3890
                    • Michael Roling
                      Michael Roling Developer @mcm1957 last edited by Michael Roling
                      @mcm1957 Nicht ganz, erstmal läuft alles ja. Und es ist nicht zwingend notwendig das dieser aktuell ins Latest kommt. Issues würde ich natürlich bearbeiten.
                      Ich werde dieses natürlich noch nachholen, aber im Moment schaffe ich das nicht. Aber der Winter kommt ja bald.
                      • mcm1957
                        Von der direkten Installation von Github wird jedenfalls abgeraten
                        Der Vollständigkeit und als Info - NICHT als Kritik
                        Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten. GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
                        Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
                        Adapter die nur via GitHub oder npm (also NICHT aus einem der beiden Repositories) installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler drum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
                        Und falls es irgendwie unklar ist:
                        ioBroker unterstützt folgende Arten von Installation:
                        • aus dem STABLE Repository
                          Das sind Adapter Releases die keine groben Fehler aufweisen (sollten). Natürlich kann es auch dort Fehler geben, die Behebung davon obliegt dem jeweiligen Dev und kann ggF auch dauern.
                        • aus dem LATEST Repository
                          Das sind Adapter Releases die neu erstellt wurden und nur rudimentär getestet sind - oft auch als BETA Releases bezeichnet. Releases aus dem LATEST sind primär für unsere zahlreichen freiwilligen Tester gedacht. BETA / LATEST Releases können durchaus Fehler aufweisen - auch wenn ich davon ausgehe dass jeder aintainer dies zu vermeiden versucht. Vom Einsatz auf produktiven Systemen wird abgeraten außer man braucht irgenein neues Feature (z.B. neues Gerät) unbedingt. Hier muss dann jeder Entscheiden was ihm wichtig ist.
                        • direkt von GITHUB
                          Von Installationen direkt aus Giuthub wird definitiv abgeraten außer auf Anweisung des Maintainers und für den Fall dass man gemeinsam mit diesem etwas testen will. Details siehe oben.
                        • direkt von npm
                          Diese Installation kann erforderlich sein, wenn man eine bestimmte Version installieren möchte / muss. Im Normalfall sollte man direkte npm Installationen ebenso meiden wie direkte GitHub Installationen - ausgenommen um z.B. zu einer bekannten Version downzugraden - obwohl hier wenigstens ein definierter Stand garantiert ist.
                        Adapter die NUR via npm und/oder nur via GitHub installierbar sind sollte man meiden - diese wurden nicht mal einem rudimentären Review unterzogen und sollten mit dem Attribut "vollständig auf eigenes Risiko verwenden" installiert werden. Hier empfiehlt es sich den Developer zu ersuchen eine Aufnahme in die Repos zu veranlassen. Wenn dieser darauf nicht reagiert sollte man von einer eher kurzen und unklaren Lebensdauer des Adapters ausgehen. Support meiner-/unsererseits für solche Adapter ist mit sicherheit minimalistisch.
                        Michael Roling 1 Reply Last reply Reply Quote 1
                        • Michael Roling
                          @mcm1957 Ja das mag ja sein, aber solange die Nachfrage so gering ist, setzte ich erstmal meine Prioritäten anders
                          • O
                            oxident @Michael Roling last edited by
                            @michael-roling Leider weder noch. Hierzulande dürften es durchgängig nur Midas-Geräte sein. Der eigentliche Hersteller scheint aber PHNX zu heißen.
                            Die nächste "Eskalationsstufe" wäre das komplette Ersetzen des Cloud-Zugangs durch einen Modbus-Adapter. Hab ich schon was zu gefunden ... ist aber sehr nerdig.
                            Danke, dass Du Dich um den Adapter kümmerst. Ich denke auch, die Stable-Sache sollte noch warten!
                            • Michael Roling
                              @oxident kannst du mir das mal schicken was du gefunden hattest? Ohne cloud wäre noch viel besser. Du kannst es natürlich auch selbst einbauen 😉
                              • O
                                oxident @Michael Roling last edited by oxident
                                @michael-roling
                                Aquatemp _ https___heatpumps4pools(1).pdf
                                Vielleicht mal in der nächsten Saison. Bisher läuft die Cloud ja recht stabil...
                                  Roesch-fe @oxident last edited by
                                  @oxident Hallo zusammen, ist schon jemand zu dem Thema fündig geworden? ich habe eine InverPro17 Wärmepumpe. Ich besitze kein WiFi Modul. Ich möchte mir auch keins zulegen. Ich würde gern direkt auf die RS485 Schnittstelle gehen (Umsetzer von LAN oder WLAN auf RS485) und das ganze über die ioBroker einbinden. Meine Wärmepumpe besitzt zwei RS485. Eine direkt neben der Klemme Remote ON/OFF und eine RS485 wo das Touchdisplay angeschlossen ist. Wenn ich mit einem USB-RS485 Dongle an den RS485 neben der Remote ON/OFF Klemme gehe, kommt da nichts. Ich sehe mit dem Ozzi nur auf einer Leitung einen statischen 5Volt High-Pegel. Versuche mit dem CASModbusScanner blieben ohne Response. Auf der Leitung zum TouchDisplay ist reger Datenverkehr (9600 Baud).
                                  Aus meiner Sicht ist das aber keine normale MODBUS Kommunikation. Wenn ich das richtig verstanden habe, kommt bei einer MODBUS Kommunikation eine Anfrage von Master der den Slave anspricht. Das erste Byte ist dann die Adresse vom Slave. Wenn der Slave antwortet sendet er wieder seine Adresse gefolgt von den Daten. Beim Mitschreiben der Daten sehe ich im Wechsel Telegramme die mit 0x00, 0x01, 0x02 und 0x42 starten.
                                  Ich habe schon im Netzt gesucht aber nichts gefunden. Kennt jemand hier evtl. das Kommunikationsprotokoll der RS485?
                                  • O
                                    oxident @Roesch-fe last edited by
                                    @roesch-fe Hast Du das oben verlinkte Dokument mal angeschaut?
                                    Also die Verbindung zum Display ist definitiv die falsche ... aber eine der anderen beiden müsste eigentlich klappen. Habe es aber selber noch nicht probiert.
                                      @oxident Danke für den Tipp, die Seite kannte ich noch, schaue ich mir mal an!
                                        memme last edited by
                                        Kurze Frage, funktioniert das Modul auch mit einer Pool Full-Inverter-Wärmepumpe POOLSANA InverPOWER NEXT 15 ?
                                        • O
                                          oxident @memme last edited by
                                          @memme Gute Frage. Kommt wohl auf das Wifi-Modul bzw. die zugehörige App an. Hast Du da Infos?
                                            App ist “Smart Life”
                                            359
                                            70447
