    4. Daten aus der Fritzbox visualisieren
    • Ro75
      Ro75 @Dr.Pie last edited by
      @dr-pie stell mal bitte den Code hier rein.
      Ro75.
      Dr.Pie 1 Reply Last reply Reply Quote 0
      • Dr.Pie
        Dr.Pie @Ro75 last edited by
        @ro75 von dem Script ?
        Ro75 1 Reply Last reply Reply Quote 0
        • Ro75
          @dr-pie ja
          Ro75.
          • Dr.Pie
            @ro75
            const Traffic_IN            = '0_userdata.0.FritzBox6591.Traffic.Traffic_IN';  // protokollieren mit SQL! Ggfs. zusätzlich mit Influx
            const Traffic_OUT           = '0_userdata.0.FritzBox6591.Traffic.Traffic_OUT';  // protokollieren mit SQL! Ggfs. zusätzlich mit Influx
            const Traffic_Tag_IN        = '0_userdata.0.FritzBox6591.Traffic.Tag_IN';  // protokollieren mit SQL! Ggfs. zusätzlich mit Influx
            const Traffic_Tag_OUT       = '0_userdata.0.FritzBox6591.Traffic.Tag_OUT';  // protokollieren mit SQL! Ggfs. zusätzlich mit Influx
            const Traffic_Monat_IN      = '0_userdata.0.FritzBox6591.Traffic.Monat_IN';  // protokollieren mit SQL! Ggfs. zusätzlich mit Influx
            const Traffic_Monat_OUT     = '0_userdata.0.FritzBox6591.Traffic.Monat_OUT';  // protokollieren mit SQL! Ggfs. zusätzlich mit Influx
            // die oberen 6 DP müssen protokolliert werden!
            const sTraffic_Monat_IN     = '0_userdata.0.FritzBox6591.Traffic.Traffic_Monat_IN';
            const sTraffic_Monat_OUT    = '0_userdata.0.FritzBox6591.Traffic.Traffic_Monat_OUT';
            createState(Traffic_IN, 0, {type: 'number', read: true, write: true});
            createState(Traffic_OUT, 0, {type: 'number', read: true, write: true});
            createState(Traffic_Tag_IN, 0, {type: 'number', read: true, write: true});
            createState(Traffic_Tag_OUT, 0, {type: 'number', read: true, write: true});
            createState(Traffic_Monat_IN, 0, {type: 'number', read: true, write: true});
            createState(Traffic_Monat_OUT, 0, {type: 'number', read: true, write: true});
            createState(sTraffic_Monat_IN, 0, {type: 'number', read: true, write: true});
            createState(sTraffic_Monat_OUT, 0, {type: 'number', read: true, write: true});
            var IPV4='';
            var IPV4I='';
            var tIN_NEW = 0;
            var tIN_OLD = 0;
            var tIN_DIFF = 0;
            var tIN_SUM = 0;
            var tOUT_NEW = 0;
            var tOUT_OLD = 0;
            var tOUT_DIFF = 0;
            var tOUT_SUM = 0;
            //Summierung der Tageswerte via SQL für Monatsergebnis
            function TrafficlfdMonat() {
                var Ergebnis=0;
                const moment = require("moment");
                let dateX=moment().format();
                var Stunden = ((parseFloat(formatDate(dateX, "TT"))-1)*24)*-1;
                sendTo('sql.0', 'query', 'SELECT id FROM iobroker.datapoints WHERE name="0_userdata.0.FritzBox6591.Traffic.Tag_IN"', function (result) {
                    if (result.error) {
                        console.error(result.error);
                    } else {
                        var now = new Date();
                        now.setHours(Stunden);
                        sendTo('sql.0', 'query', 'SELECT val FROM iobroker.ts_number WHERE ts >= ' + now.getTime() + ' AND id=' + result.result[0].id, function (result) {
                            let text = result.result;
                            for (let i = 0; i <= result.result.length-1; i++) {
                                var vRow=text[i].val;
                                Ergebnis=Ergebnis+parseFloat(vRow);
                            Ergebnis=Ergebnis+getState(Traffic_IN).val;
                            setState(sTraffic_Monat_IN, Ergebnis, true);
                var ErgebnisII=0;
                sendTo('sql.0', 'query', 'SELECT id FROM iobroker.datapoints WHERE name="0_userdata.0.FritzBox6591.Traffic.Tag_OUT"', function (result) {
                    if (result.error) {
                    } else {
                                ErgebnisII=ErgebnisII+parseFloat(vRow);
                            ErgebnisII=ErgebnisII+getState(Traffic_OUT).val;
                            setState(sTraffic_Monat_OUT, ErgebnisII, true);
            //um die Monatssumme "laufend" zu halten
            schedule('*/2 * * * *', function Auswertung7() {
                TrafficlfdMonat();
            // Berechnung Empfangsrichtung
            on({id: 'upnp.0.WANDevice_-_FRITZ!Box_6591_Cable_(kdg).WANDevice.WANCommonInterfaceConfig.TotalBytesReceived', change: 'any'}, function(dp) { //DP ggfs. anpassen
                if (IPV4 == '') {
                    IPV4 = getState('tr-064.0.states.externalIP').val;
                tIN_OLD=tIN_NEW;
                tIN_NEW = parseFloat(dp.state.val);
                if (tIN_OLD == 0) {
                    tIN_OLD=tIN_NEW;
                } else {
                    if (IPV4 == getState('tr-064.0.states.externalIP').val) {
                        tIN_DIFF=tIN_NEW-tIN_OLD;
                    } else {
                        tIN_DIFF=tIN_NEW;
                    if (tIN_DIFF < 0) {
                        tIN_DIFF=(4294967295-tIN_OLD)+tIN_NEW; //der Counter geht nur bis 4294967295, danach wieder ab 0 >> Berechnung
                    tIN_SUM=tIN_SUM+tIN_DIFF;
                    var oIn = parseFloat(getState(Traffic_IN).val);
                    setState(Traffic_IN, (oIn+tIN_DIFF)*1);
            // Berechnung Senderichtung
            on({id: 'upnp.0.WANDevice_-_FRITZ!Box_6591_Cable_(kdg).WANDevice.WANCommonInterfaceConfig.TotalBytesSent', change: 'any'}, function(dp) {
                if (IPV4I == '') {
                    IPV4I = getState('tr-064.0.states.externalIP').val;
                tOUT_OLD=tOUT_NEW;
                tOUT_NEW = parseFloat(dp.state.val);
                if (tOUT_OLD == 0) {
                    tOUT_OLD=tOUT_NEW;
                } else {
                    if (IPV4I == getState('tr-064.0.states.externalIP').val) {
                        tOUT_DIFF=tOUT_NEW-tOUT_OLD;
                    } else {
                        tOUT_DIFF=tOUT_NEW;
                    if (tOUT_DIFF < 0) {
                        tOUT_DIFF=(4294967295-tOUT_OLD)+tOUT_NEW; //der Counter geht nur bis 4294967295, danach wieder ab 0 >> Berechnung
                    tOUT_SUM=tOUT_SUM+tOUT_DIFF;
                    var oOUT = parseFloat(getState(Traffic_OUT).val);
                    setState(Traffic_OUT, (oOUT+tOUT_DIFF)*1);
            //Tages und Monatswert in DP schreiben
            schedule('30 59 23 * * *', function TrafficTagesWert() {
                setState(Traffic_Tag_IN, getState(Traffic_IN).val);
                setState(Traffic_Tag_OUT, getState(Traffic_OUT).val);
                //Reset für neuen Tag
                tOUT_SUM=0;
                tIN_SUM=0;
                setState(Traffic_IN, 0);
                setState(Traffic_OUT, 0);
                //herausfinden ob +- 10 Minuten immer noch den selben Monat oder letzter Tag im Monat ist
                let datePlus=moment().add(10, 'm').format();
                let dateMinus=moment().subtract(10, 'm').format();
                if (formatDate(datePlus, "MM") != formatDate(dateMinus, "MM")) {
                    //jetzt ist noch der letzte Tag des Monat
                    TrafficlfdMonat();
                    setState(Traffic_Monat_IN, getState('0_userdata.0.FritzBox6591.Traffic.Traffic_Monat_IN').val, true);
                    setState(Traffic_Monat_OUT, getState('0_userdata.0.FritzBox6591.Traffic.Traffic_Monat_OUT').val, true);
            Normalerweise sollte doch anstatt:
            upnp.0.WANDevice_-_FRITZ!Box_6591.WANDevice.WANCommonInterfaceConfig.TotalBytesSent
            müßte das nicht hier stehen:
            upnp.0.WANDevice_-_FRITZ!Box_6591.WANDevice.WANCommonInterfaceConfig.GetTotalBytesSent
            • Ro75
              Ro75 @Dr.Pie last edited by Ro75
              @dr-pie es muss schon "....WANDevice.WANCommonInterfaceConfig.TotalBytesReceived" bzw. "....WANDevice.WANCommonInterfaceConfig.TotalBytesSent" sein.
              Dein Code enthält:
              ABER weiter unten schreibst du:
              HIER und an der zeiten Stelle
              stimmt was nicht.
              Entweder: FRITZ!Box_6591.WANDevice.
              ODER: FRITZ!Box_6591_Cable_(kdg).WANDevice
              Wenn das nicht korrekt ist, kommen auch keine Daten rein, werden nicht verarbeitet und nicht mit dem SQL-Adapte protokolliert.
              Ro75.
              • Dr.Pie
                @ro75
                da hat mir wohl CopyPaste einen Strich durch die Rechnung gemacht.
                Der Code für das Script ist schon richtig.
                  Dominik009 @Dr.Pie last edited by
                  was sagen die Werte genau aus?
                  Charts/Receive und Charts/Send sollte ja das aktuelle Traffic sein.
                  Was genau ist der unterschied zwischen den anderen vier Werten?
                  VG
                  • Ro75
                    Ro75 @Dominik009 last edited by
                    @dominik009 das eine sind die Rohdaten und die anderen bereits "freundlich" gestaltet.
                    Ro75.
                      WernerS @Ro75 last edited by WernerS
                      Hallo
                      schaut hier als noch jemand vorbei?
                      Also soweit funktioniert das Script bei mir super. Nur 2 mal hat er jetzt bei den Montaen 0B berechnet. Weiß jemand was das sein kann?
                      Werner
                      const Traffic_IN            = '0_userdata.0.FritzBox.Traffic.Traffic_IN';  // protokollieren mit SQL! Ggfs. zusätzlich mit Influx
                      const Traffic_OUT           = '0_userdata.0.FritzBox.Traffic.Traffic_OUT';  // protokollieren mit SQL! Ggfs. zusätzlich mit Influx
                      const Traffic_Tag_IN        = '0_userdata.0.FritzBox.Traffic.Tag_IN';  // protokollieren mit SQL! Ggfs. zusätzlich mit Influx
                      const Traffic_Tag_OUT       = '0_userdata.0.FritzBox.Traffic.Tag_OUT';  // protokollieren mit SQL! Ggfs. zusätzlich mit Influx
                      const Traffic_Monat_IN      = '0_userdata.0.FritzBox.Traffic.Monat_IN';  // protokollieren mit SQL! Ggfs. zusätzlich mit Influx
                      const Traffic_Monat_OUT     = '0_userdata.0.FritzBox.Traffic.Monat_OUT';  // protokollieren mit SQL! Ggfs. zusätzlich mit Influx
                      const sTraffic_Monat_IN     = '0_userdata.0.FritzBox.Traffic.Traffic_Monat_IN';
                      const sTraffic_Monat_OUT    = '0_userdata.0.FritzBox.Traffic.Traffic_Monat_OUT';
                      var IPV4='';
                      var IPV4I='';
                      var tIN_NEW = 0;
                      var tIN_OLD = 0;
                      var tIN_DIFF = 0;
                      var tIN_SUM = 0;
                      var tOUT_NEW = 0;
                      var tOUT_OLD = 0;
                      var tOUT_DIFF = 0;
                      var tOUT_SUM = 0;
                          var Ergebnis=0;
                          sendTo('sql.0', 'query', 'SELECT id FROM iobroker.datapoints WHERE name="0_userdata.0.FritzBox.Traffic.Tag_IN"', function (result) {
                              if (result.error) {
                              } else {
                          var ErgebnisII=0;
                          sendTo('sql.0', 'query', 'SELECT id FROM iobroker.datapoints WHERE name="0_userdata.0.FritzBox.Traffic.Tag_OUT"', function (result) {
                              if (result.error) {
                              } else {
                          TrafficlfdMonat();
                      on({id: 'upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.TotalBytesReceived', change: 'any'}, function(dp) { //DP ggfs. anpassen
                          if (IPV4 == '') {
                          tIN_OLD=tIN_NEW;
                          if (tIN_OLD == 0) {
                              tIN_OLD=tIN_NEW;
                          } else {
                              } else {
                                  tIN_DIFF=tIN_NEW;
                              if (tIN_DIFF < 0) {
                      on({id: 'upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.TotalBytesSent', change: 'any'}, function(dp) {
                          if (IPV4I == '') {
                          tOUT_OLD=tOUT_NEW;
                              tOUT_OLD=tOUT_NEW;
                          } else {
                              } else {
                                  tOUT_DIFF=tOUT_NEW;
                          tOUT_SUM=0;
                          tIN_SUM=0;
                              TrafficlfdMonat();
                              setState(Traffic_Monat_IN, getState('0_userdata.0.FritzBox.Traffic.Traffic_Monat_IN').val, true);
                              setState(Traffic_Monat_OUT, getState('0_userdata.0.FritzBox.Traffic.Traffic_Monat_OUT').val, true);
                      • Ro75
                        Ro75 @WernerS last edited by Ro75
                        @werners Ja, da ist ein Fehler drin und zwar genau am ersten eines Monats. Hatte ich heute früh auch gesehen und bei mir korrigiert.
                        Die Funktion "TrafficlfdMonat" komplett mit dem hier ersetzen:
                            var Ergebnis = ErstelleZahl(getState(Traffic_IN).val);
                                if (!result.error) {
                                    sendTo('sql.0', 'query', 'SELECT SUM(val) AS val FROM iobroker.ts_number WHERE ts >= ' + now.getTime() + ' AND id=' + result.result[0].id, function (result) {
                                        Ergebnis = Ergebnis + ErstelleZahl(parseFloat(result.result[0].val));
                            setTimeout(function(){
                            },100);
                            var ErgebnisII = ErstelleZahl(getState(Traffic_OUT).val);
                                        ErgebnisII = ErgebnisII + ErstelleZahl(parseFloat(result.result[0].val));
                            },100);
                        und die nachfolgende Funktion in das Skript einfügen:
                        function ErstelleZahl(wert) {
                            if(isNaN(wert)) {
                                wert = 0;
                            return wert;
                        Wenn das geändert ist und das Skript nach dem Speichern neu gestartet wurde, dauert es ca. 2 Minuten bis die Aktualisierung erfolgt.
                        Ro75.
                          @ro75
                          Hallo
                          heisst das das die 2 Monate die Null sind neu berechnet werden?
                          Werde das heute abend mal checken.
                          Danke schon mal
                          Werner
                          • Ro75
                            @werners Nein, das heißt es nicht. In dem Skript gab es ein Fehler. Da wurde am ersten eines jeden Monat "null" geschrieben und ab dem zweiten Tag wieder korrekt.
                            Oder meinst du was anderes? Welche Datenpunkte? UND was sagt das Log denn dazu?
                            Ro75.
                              @ro75
                              also ich meinte ob die 2 Monate die 0B haben nochmal neu und richtig nachträglich berechnet werden. Oder bleiben die auf 0?
                              ich habe das mal schnell getestet. Mein Script sieht jetzt so aus
                              var IPV4='';
                              var IPV4I='';
                              var tIN_NEW = 0;
                              var tIN_OLD = 0;
                              var tIN_DIFF = 0;
                              var tIN_SUM = 0;
                              var tOUT_NEW = 0;
                              var tOUT_OLD = 0;
                              var tOUT_DIFF = 0;
                              var tOUT_SUM = 0;
                                  },100);
                                  },100);
                                  TrafficlfdMonat();
                                  if (IPV4 == '') {
                                  tIN_OLD=tIN_NEW;
                                  if (tIN_OLD == 0) {
                                      tIN_OLD=tIN_NEW;
                                  } else {
                                      } else {
                                          tIN_DIFF=tIN_NEW;
                                      if (tIN_DIFF < 0) {
                                  if (IPV4I == '') {
                                  tOUT_OLD=tOUT_NEW;
                                      tOUT_OLD=tOUT_NEW;
                                  } else {
                                      } else {
                                          tOUT_DIFF=tOUT_NEW;
                                  tOUT_SUM=0;
                                  tIN_SUM=0;
                                      TrafficlfdMonat();
                                  if(isNaN(wert)) {
                                      wert = 0;
                                  return wert;
                              Allerdings sind im Log einige Fehler. Ob die vorher schon waren weiss ich nicht, das Script hat ja funktioniert.
                              Der Fehler scheint alle 2 Minten zu kommen falls das was hilft
                              javascript.0
                              2024-09-01 17:36:09.014 error at processImmediate (node:internal/timers:476:21)
                              javascript.0
                              2024-09-01 17:36:09.013 error at Immediate._onImmediate (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:381:37)
                              javascript.0
                              2024-09-01 17:36:09.013 error at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:10886:45)
                              javascript.0
                              2024-09-01 17:36:09.013 error at Object.cb (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3097:38)
                              javascript.0
                              2024-09-01 17:36:09.013 error at Object.<anonymous> (script.js.common.FritzBox:63:148)
                              javascript.0
                              2024-09-01 17:36:09.013 error Error in callback: TypeError: Cannot read properties of undefined (reading 'id')
                              javascript.0
                              2024-09-01 17:36:09.011 error at processImmediate (node:internal/timers:476:21)
                              javascript.0
                              2024-09-01 17:36:09.011 error at Immediate._onImmediate (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:381:37)
                              javascript.0
                              2024-09-01 17:36:09.011 error at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:10886:45)
                              javascript.0
                              2024-09-01 17:36:09.011 error at Object.cb (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:3097:38)
                              javascript.0
                              2024-09-01 17:36:09.010 error at Object.<anonymous> (script.js.common.FritzBox:49:148)
                              javascript.0
                              2024-09-01 17:36:09.010 error Error in callback: TypeError: Cannot read properties of undefined (reading 'id')
                              Werner
                              • Ro75
                                @werners läuft MariaDB/MySQL auf dem Server? ist der SQL-Adapter installiert?
                                Werden diese DP mit dem SQL-Adapter protokolliert?
                                Ro75.
                                  @ro75
                                  ja läuft über einen sql Adapter
                                  bei mir sieht das so aus
                                  Werner
                                  • Ro75
                                    @werners sagte in Daten aus der Fritzbox visualisieren:
                                    Bitte mal zeigen.
                                    Ro75.
                                      @ro75
                                      was genau?
                                      Also der sqladapter läuft ohne probleme
                                      Werner
                                      • Ro75
                                        @werners Die Einstellungen zu den von mir aufgeführten Datenpunkte. Der SQL-Adapter alleine reicht nicht.
                                        Ro75.
                                          @ro75
                                          meinst du das?
                                          Werner
                                          • Ro75
                                            @werners für alle DP? Welche Aufbewahrungsdauer?
                                            Aufbewahrungsdauer:
                                            Tag_IN und Tag_OUT = 3 Monate
                                            Monat_IN und Monat_OUT = 2 Jahre
                                            Ro75.
                                            112
                                            11094
